- 05-Layer 3 - IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-IP forwarding basics commands
- 06-Adjacency table commands
- 07-IP performance optimization commands
- 08-UDP helper commands
- 09-IPv6 basics commands
- 10-DHCPv6 commands
- 11-IPv6 fast forwarding commands
- 12-Fast forwarding commands
- 13-Tunnel commands
- 14-GRE commands
07-IP performance optimization commands | 164.54 KB |
The device operates in IRF or standalone (the default) mode. For information about IRF mode, see IRF Configuration Guide.
display icmp statistics
Use display icmp statistics to display ICMP statistics.
In standalone mode:
In IRF mode:
display icmp statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Displays ICMP statistics for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ICMP statistics for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
ICMP statistics include information about received and sent ICMP packets.
# Display ICMP statistics.
<Sysname> display icmp statistics
Input: bad formats 0 bad checksum 0
echo 175 destination unreachable 0
source quench 0 redirects 0
echo replies 201 parameter problem 0
timestamp 0 information requests 0
mask requests 0 mask replies 0
time exceeded 0 invalid type 0
router advert 0 router solicit 0
broadcast/multicast echo requests ignored 0
broadcast/multicast timestamp requests ignored 0
Output: echo 0 destination unreachable 0
echo replies 175 parameter problem 0
timestamp 0 information replies 0
time exceeded 0 bad address 0
packet error 1442
display ip statistics
Use display ip statistics to display IP packet statistics.
In standalone mode:
In IRF mode:
display ip statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Displays IP packet statistics for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays IP packet statistics for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
IP statistics include information about received and sent packets and reassembly.
# Display IP packet statistics.
<Sysname> display ip statistics
Input: sum 7120 local 112
bad protocol 0 bad format 0
bad checksum 0 bad options 0
Output: forwarding 0 local 27
dropped 0 no route 2
compress fails 0
Fragment:input 0 output 0
dropped 0
fragmented 0 couldn't fragment 0
Reassembling:sum 0 timeouts 0
Input |
sum |
Total number of packets received. |
local |
Total number of packets destined for the device. |
bad protocol |
Total number of unknown protocol packets. |
bad format |
Total number of packets with incorrect format. |
bad checksum |
Total number of packets with incorrect checksum. |
bad options |
Total number of packets with incorrect option. |
Output |
forwarding |
Total number of packets forwarded. |
local |
Total number of packets locally sent. |
dropped |
Total number of packets discarded. |
no route |
Total number of packets for which no route is available. |
compress fails |
Total number of packets failed to be compressed. |
Fragment |
input |
Total number of fragments received. |
output |
Total number of fragments sent. |
dropped |
Total number of fragments dropped. |
fragmented |
Total number of packets successfully fragmented. |
couldn't fragment |
Total number of packets failed to be fragmented. |
Reassembling |
sum |
Total number of packets reassembled. |
timeouts |
Total number of reassembly timeouts. |
· display ip interface
· reset ip statistics
display rawip
Use display rawip to display brief information about RawIP connections.
In standalone mode:
In IRF mode:
display rawip [ chassis chassis-number slot slot-number ]
slot slot-number: Displays brief RawIP connection information for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays brief RawIP connection information for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
Brief RawIP connection information includes local and peer addresses, protocol, and PCB.
# (In standalone mode.) Display brief information about RawIP connections.
<Sysname> display rawip
Local Addr Foreign Addr Protocol Slot PCB
0.0.0.0 0.0.0.0 1 1 0x0000000000000009
0.0.0.0 0.0.0.0 1 1 0x0000000000000008
0.0.0.0 0.0.0.0 1 5 0x0000000000000002
# (In IRF mode.) Display brief information about RawIP connections.
Local Addr Foreign Addr Protocol Chassis Slot PCB
0.0.0.0 0.0.0.0 1 1 1 0x0000000000000009
0.0.0.0 0.0.0.0 1 1 1 0x0000000000000008
0.0.0.0 0.0.0.0 1 1 5 0x0000000000000002
Local Addr |
Local IP address. |
Foreign Addr |
Peer IP address. |
Protocol |
Protocol number. |
Chassis |
ID of the IRF member device. |
Slot |
Number of the slot that holds the card. |
PCB |
Protocol control block. |
display rawip verbose
Use display rawip verbose to display detailed information about RawIP connections.
In standalone mode:
display rawip verbose [ slot slot-number [ pcb pcb-index ] ]
In IRF mode:
display rawip verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
pcb pcb-index: Displays detailed RawIP connection information for the specified PCB. The pcb-index argument specifies the index of the PCB, in the range of 1 to 16.
slot slot-number: Displays detailed RawIP connection information for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays detailed RawIP connection information for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
Use the display rawip verbose command to display detailed information about socket creator, state, option, type, protocol number, and the source and destination IP addresses of RawIP connections.
# (In standalone mode.) Display detailed information about RawIP connections.
<Sysname> display rawip verbose
Total RawIP Socket Number: 1
slot: 1
creator: ping[320]
state: N/A
options: N/A
error: 0
rcvbuf(cc/hiwat/lowat/state): 0 / 9216 / 1 / N/A
sndbuf(cc/hiwat/lowat/state): 0 / 9216 / 512 / N/A
type: 3
protocol: 1
connection info: src = 0.0.0.0, dst = 0.0.0.0
inpcb flags: N/A
inpcb vflag: INP_IPV4
TTL: 255(minimum TTL: 0)
send VRF: 0xffff
receive VRF: 0xffff
# (In IRF mode.) Display detailed information about RawIP connections.
chassis: 1
slot: 1
creator: ping[320]
state: N/A
options: N/A
error: 0
type: 3
protocol: 1
inpcb flags: N/A
send VRF: 0xffff
receive VRF: 0xffff
Total RawIP Socket Number |
Total number of RawIP sockets. |
chassis |
slot |
creator |
Name of the operation that created the socket. The number in brackets is the process number of the creator. |
state |
State of the socket. |
options |
Socket options. |
rcvbuf(cc/hiwat/lowat/state) |
Information about the receiving buffer: in brackets are the used space, the maximum space, the minimum space, and the state. |
sndbuf(cc/hiwat/lowat/state) |
Information about the sending buffer: in brackets are the used space, the maximum space, the minimum space, and the state. |
type |
Socket type. |
protocol |
Number of the protocol using the socket. |
connection info |
Source IP address and destination IP address. |
inpcb flags |
Flags in the Internet PCB. |
inpcb vflag |
IP version flags in the Internet PCB. |
display tcp
Use display tcp to display brief information about TCP connections.
In standalone mode:
In IRF mode:
display tcp [ chassis chassis-number slot slot-number ]
slot slot-number: Displays brief TCP connection information for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays brief TCP connection information for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
Brief TCP connection information includes local IP address, local port number, peer IP address, peer port number, and TCP connection state.
# (In standalone mode.) Display brief information about TCP connections.
<Sysname> display tcp
*: TCP MD5 Connection
Local Addr:port Foreign Addr:port State Slot PCB
*0.0.0.0:21 0.0.0.0:0 LISTEN 1 0x000000000000c387
192.168.20.200:23 192.168.20.14:1284 ESTABLISHED 1 0x0000000000000009
192.168.20.200:23 192.168.20.14:1283 ESTABLISHED 1 0x0000000000000002
# (In IRF mode.) Display brief information about TCP connections.
Local Addr:port Foreign Addr:port State Chassis Slot PCB
*0.0.0.0:21 0.0.0.0:0 LISTEN 1 1 0x000000000000c387
192.168.20.200:23 192.168.20.14:1284 ESTABLISHED 1 1 0x0000000000000009
192.168.20.200:23 192.168.20.14:1283 ESTABLISHED 1 1 0x0000000000000002
Indicates the TCP connection uses MD5 authentication. |
Local Addr:port |
Local IP address and port number. |
Foreign Addr:port |
Peer IP address and port number. |
State |
TCP connection state. |
Chassis |
Slot |
PCB |
PCB index. |
display tcp statistics
Use display tcp statistics to display TCP traffic statistics.
In standalone mode:
In IRF mode:
display tcp statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Displays TCP traffic statistics for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays TCP traffic statistics for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
TCP traffic statistics include information about received and sent TCP packets and Syncache/syncookie.
# Display TCP traffic statistics.
<Sysname> display tcp statistics
Received packets:
Total: 4150
packets in sequence: 1366 (134675 bytes)
window probe packets: 0, window update packets: 0
checksum error: 0, offset error: 0, short error: 0
packets dropped for lack of memory: 0
packets dropped due to PAWS: 0
duplicate packets: 12 (36 bytes), partially duplicate packets: 0 (0 bytes)
out-of-order packets: 0 (0 bytes)
packets with data after window: 0 (0 bytes)
packets after close: 0
ACK packets: 3531 (795048 bytes)
duplicate ACK packets: 33, ACK packets for unsent data: 0
Sent packets:
Total: 4058
urgent packets: 0
control packets: 50
window probe packets: 3, window update packets: 11
data packets: 3862 (795012 bytes), data packets retransmitted: 0 (0 bytes)
ACK-only packets: 150 (52 delayed)
unnecessary packet retransmissions: 0
Syncache/syncookie related statistics:
entries added to syncache: 12
syncache entries retransmitted: 0
duplicate SYN packets: 0
reply failures: 0
successfully build new socket: 12
bucket overflows: 0
zone failures: 0
syncache entries removed due to RST: 0
syncache entries removed due to timed out: 0
ACK checked by syncache or syncookie failures: 0
syncache entries aborted: 0
syncache entries removed due to bad ACK: 0
syncache entries removed due to ICMP unreachable: 0
SYN cookies sent: 0
SYN cookies received: 0
SACK related statistics:
SACK recoveries: 1
SACK retransmitted segments: 0 (0 bytes)
SACK blocks (options) received: 0
SACK blocks (options) sent: 0
SACK scoreboard overflows: 0
Other statistics:
retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
persist timeout: 0
keepalive timeout: 21, keepalive probe: 0
keepalive timeout, so connections disconnected: 0
fin_wait_2 timeout, so connections disconnected: 0
initiated connections: 29, accepted connections: 12, established connections:
23
closed connections: 50051 (dropped: 0, initiated dropped: 0)
bad connection attempt: 0
ignored RSTs in the window: 0
listen queue overflows: 0
RTT updates: 3518(attempt segment: 3537)
correct ACK header predictions: 0
correct data packet header predictions: 568
resends due to MTU discovery: 0
packets dropped with MD5 authentication: 0
packets permitted with MD5 authentication: 0
reset tcp statistics
display tcp verbose
Use display tcp verbose to display detailed information about TCP connections.
In standalone mode:
In IRF mode:
display tcp verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
pcb pcb-index: Displays detailed TCP connection information for the specified PCB. The pcb-index argument specifies the index of the PCB, in the range of 1 to 16.
slot slot-number: Displays detailed TCP connection information for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays detailed TCP connection information for the specified card on the specified member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
Detailed TCP connection information includes socket creator, state, option, type, protocol number, source IP address and port number, destination IP address and port number, and connection state.
# (In standalone mode.) Display detailed information about TCP connections.
<Sysname> display tcp verbose
slot: 1
creator: telnetd_mips[199]
state: ISCONNECTED
options: N/A
error: 0
rcvbuf(cc/hiwat/lowat/state): 0 / 65700 / 1 / N/A
sndbuf(cc/hiwat/lowat/state): 0 / 65700 / 512 / N/A
type: 1
protocol: 6
connection info: src = 192.168.20.200:23 , dst = 192.168.20.14:4181
inpcb flags: N/A
connection state: ESTABLISHED
send VRF: 0x0
receive VRF: 0x0
# (In IRF mode.) Display detailed information about TCP connections.
chassis: 1
slot: 1
state: ISCONNECTED
options: N/A
error: 0
type: 1
protocol: 6
inpcb flags: N/A
send VRF: 0x0
receive VRF: 0x0
display udp
Use display udp to display brief information about UDP connections.
In standalone mode:
In IRF mode:
display udp [ chassis chassis-number slot slot-number ]
slot slot-number: Displays brief UDP connection information for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays brief UDP connection information for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
Brief UDP connection information includes local IP address and port number, and peer IP address and port number.
# (In standalone mode.) Display brief information about UDP connections.
<Sysname> display udp
Local Addr:port Foreign Addr:port Slot PCB
0.0.0.0:69 0.0.0.0:0 1 0x0000000000000003
192.168.20.200:1024 192.168.20.14:69 5 0x0000000000000002
# (In IRF mode.) Display brief information about UDP connections.
Local Addr:port Foreign Addr:port Chassis Slot PCB
0.0.0.0:69 0.0.0.0:0 1 1 0x0000000000000003
192.168.20.200:1024 192.168.20.14:69 1 5 0x0000000000000002
Table 5 Command output
Local Addr:port |
Foreign Addr:port |
Chassis |
Slot |
Slot number of the card. |
PCB |
PCB index. |
display udp statistics
Use display udp statistics to display UDP traffic statistics.
In standalone mode:
In IRF mode:
display udp statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Displays UDP traffic statistics for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays UDP traffic statistics for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device and the slot-number argument specifies the slot number of the card. (In IRF mode.)
UDP traffic statistics include information about received and sent UDP packets.
# Display UDP traffic statistics.
<Sysname> display udp statistics
Received packets:
Total: 240
checksum error: 0, no checksum: 0
shorter than header: 0, data length larger than packet: 0
no socket on port(unicast): 0
no socket on port(broadcast/multicast): 240
not delivered, input socket full: 0
Sent packets:
Total: 0
reset udp statistics
display udp verbose
Use display udp verbose to display detailed information about UDP connections.
In standalone mode:
In IRF mode:
display udp verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
pcb pcb-index: Displays detailed UDP connection information for the specified PCB. The pcb-index argument specifies the index of the PCB, in the range of 1 to 16.
slot slot-number: Displays detailed UDP connection information for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays detailed UDP connection information for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
Detailed UDP connection information includes the socket creator, status, option, type, the protocol number, the source IP address and port number, and the destination IP address and port number for UDP connections.
# (In standalone mode.) Display detailed UDP connection information.
<Sysname> display udp verbose
Total UDP Socket Number: 1
slot: 1
creator: sock_test_mips[250]
state: N/A
options: N/A
error: 0
rcvbuf(cc/hiwat/lowat/state): 0 / 41600 / 1 / N/A
type: 2
protocol: 17
connection info: src = 0.0.0.0:69, dst = 0.0.0.0:0
inpcb flags: N/A
send VRF: 0xffff
receive VRF: 0xffff
# (In IRF mode.) Display detailed information about UDP connections.
chassis: 1
slot: 1
state: N/A
options: N/A
error: 0
type: 2
protocol: 17
inpcb flags: N/A
send VRF: 0xffff
receive VRF: 0xffff
Table 6 Command output
Total UDP Socket Number |
Total number of UDP sockets. |
chassis |
slot |
creator |
state |
Socket state. |
options |
Socket option. |
error |
Errors affecting socket connection. |
type |
Socket type. |
protocol |
inpcb flags |
inpcb vflag |
ip forward-broadcast
Use ip forward-broadcast to enable an interface to receive and forward directed broadcast packets destined for the directly connected network.
Use undo ip forward-broadcast to disable an interface from receiving and forwarding directed broadcast packets destined for the directly connected network.
An interface cannot forward directed broadcasts destined for the directly connected network. It can receive directed broadcasts destined for the directly connected network.
Interface view
A directed broadcast packet is destined for all hosts on a specific network. In the destination IP address of the directed broadcast, the network ID identifies the target network, and the host ID is made up of all ones.
If an interface is allowed to forward directed broadcasts destined for the directly connected network, hackers can exploit this vulnerability to attack the target network. In some scenarios, however, an interface must receive and send such directed broadcast packets to support UDP helper and Wake on LAN.
This command enables an interface to accept directed broadcast packets that are destined for and received from the directly connected network to support UDP helper, which converts the directed broadcasts to unicasts and forwards them to a specific server.
The command also enables the interface to forward directed broadcast packets that are destined for the directly connected network and are received from another subnet to support Wake on LAN, which sends the directed broadcasts to wake up the hosts on the target network.
# Enable VLAN-interface 2 to receive and forward directed broadcast packets destined for the directly connected network.
[Sysname-Vlan-interface2] ip forward-broadcast
ip icmp flow-control
Use ip icmp flow-control to enable ICMP flow control.
Use undo ip icmp flow-control to disable ICMP flow control.
ICMP flow control is disabled.
Delivering a large number of ICMP packets to the CPU impacts the processing of other services. To prevent this situation, you can enable ICMP flow control.
# Enable ICMP flow control.
[Sysname] ip icmp flow-control
ip icmp fragment discarding
Use ip icmp fragment discarding to disable forwarding of ICMP fragments.
Use undo ip icmp fragment discarding to enable forwarding of ICMP fragments.
Forwarding of ICMP fragments is enabled.
Disable forwarding of ICMP fragments can prevent ICMP fragment attacks.
# Disable forwarding of ICMP fragments.
[Sysname] ip icmp fragment discarding
ip mtu
Use ip mtu to configure an MTU for an interface.
Use undo ip mtu to restore the default.
ip mtu mtu-size
undo ip mtu
No MTU is configured for an interface.
Interface view
mtu-size: Specifies an MTU in the range of 128 to 2000 bytes.
When a packet exceeds the MTU of the output interface, the device processes it in one of the following ways:
· If the packet disallows fragmentation, the device discards it.
· If the packet allows fragmentation, the device fragments it and forwards the fragments.
Fragmentation and reassembling consume system resources, so set an appropriate MTU for an interface to avoid fragmentation.
If an interface supports both the mtu and ip mtu commands, the device fragments a packet based on the MTU set by the ip mtu command.
# Set the MTU of VLAN interface 100 to 1280 bytes.
[Sysname-Vlan-interface100] ip mtu 1280
ip redirects enable
Use ip redirects enable to enable sending ICMP redirect packets.
Use undo ip redirects enable to disable sending ICMP redirect packets.
ip redirects enable
Sending ICMP redirect packets is disabled.
ICMP redirect packets simplify host management and enable hosts to gradually optimize its routing table.
A host that has only one route destined to the default gateway sends all packets to the default gateway. The default gateway sends an ICMP redirect packet to inform the host of a correct next hop by following these rules:
· The receiving and sending interfaces are the same.
· The selected route is not created or modified by any ICMP redirect packet.
· The selected route is not destined for 0.0.0.0.
· There is no source route option in the received packet.
# Enable sending ICMP redirect packets.
[Sysname] ip redirects enable
ip ttl-expires enable
Use ip ttl-expires enable to enable sending ICMP time-exceeded packets.
Use undo ip ttl-expires enable to disable sending ICMP time-exceeded packets.
Sending ICMP time-exceeded packets is disabled.
A device sends ICMP time-exceeded packets by following these rules:
· If a received packet is not destined for the device and the TTL field of the packet is 1, the device sends an ICMP "TTL expired in transit" packet to the source.
· When the device receives the first fragment of an IP datagram destined for the device itself, it starts a timer. If the timer expires before all the fragments of the datagram are received, the device sends an ICMP "fragment reassembly timeout" packet to the source.
A device disabled from sending ICMP time-exceeded packets does not send ICMP "TTL expired" packets but can still send ICMP "fragment reassembly timeout" packets.
# Enable sending ICMP time-exceeded packets.
[Sysname] ip ttl-expires enable
ip unreachables enable
Use ip unreachables enable to enable sending ICMP destination unreachable packets.
Use undo ip unreachables enable to disable sending ICMP destination unreachable packets.
Sending ICMP destination unreachable packets is disabled.
A device sends ICMP destination unreachable packets by following these rules:
· If a packet does not match any specific route and there is no default route in the routing table, the device sends a Network Unreachable ICMP error packet to the source.
· If a packet is destined for the device but the transport layer protocol of the packet is not supported by the device, the device sends a Protocol Unreachable ICMP error packet to the source.
· If a UDP packet is destined for the device but the packet's port number does not match the running process, the device sends the source a Port Unreachable ICMP error packet.
· If the source uses Strict Source Routing to send packets, but the intermediate device finds that the next hop specified by the source is not directly connected, the device sends the source a Source Routing Failure ICMP error packet.
· If the MTU of the sending interface is smaller than the packet and the packet has a Don't Fragment set, the device sends the source a Fragmentation Needed and Don't Fragment-Set ICMP error packet.
# Enable sending ICMP destination unreachable packets.
[Sysname] ip unreachables enable
reset ip statistics
Use reset ip statistics to clear IP traffic statistics.
In standalone mode:
In IRF mode:
reset ip statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Clears IP traffic statistics for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Clears IP traffic statistics for the specified card of the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number specifies the slot number of the card. (In IRF mode.)
To collect new IP traffic statistics within a period of time, use this command to clear history IP traffic statistics first.
# Clear IP traffic statistics.
<Sysname> reset ip statistics
· display ip statistics
Use reset tcp statistics to clear TCP traffic statistics.
# Clear TCP traffic statistics.
<Sysname> reset tcp statistics
Use reset udp statistics to clear UDP traffic statistics.
# Clear UDP traffic statistics.
<Sysname> reset udp statistics
tcp mss
Use tcp mss to configure the TCP maximum segment size (MSS).
Use undo tcp mss to restore the default.
tcp mss value
undo tcp mss
The TCP MSS is 1460 bytes.
Interface view
Value: Specifies the TCP MSS in the range of 128 to 2048 bytes.
This configuration takes effect only on TCP connections that are established after the configuration and not on the TCP connections that already exist.
This configuration is effective only on IP packets. If MPLS is enabled on the interface, do not configure the TCP MSS on the interface.
The MSS option informs the receiver of the largest segment that the sender can accept. Each end announces its MSS during TCP connection establishment.
If the size of a TCP segment is smaller than the MSS of the receiver, TCP sends the TCP segment without fragmentation. If not, it fragments the segment according to the receiver's MSS.
If you configure a TCP MSS on an interface, the size of each TCP segment received or sent on the interface cannot exceed the MSS value.
# Set the TCP MSS to 300 bytes on VLAN-interface 100.
[Sysname-Vlan-interface100] tcp mss 300
tcp path-mtu-discovery
Use tcp path-mtu-discovery to enable TCP path MTU discovery.
Use undo tcp path-mtu-discovery to disable TCP path MTU discovery.
TCP path MTU discovery is disabled.
aging age-time: Sets the aging time for the path MTU, in the range of 10 to 30 minutes. The default aging time is 10 minutes.
no-aging: Does not age out the path MTU.
After you enable TCP path MTU discovery, all new TCP connections detect the path MTU. The device uses the path MTU to calculate the MSS to avoid IP fragmentation.
After you disable TCP path MTU discovery, the system stops all path MTU timers. The TCP connections established later do not detect the path MTU, but the TCP connections previously established still can detect the path MTU.
# Enable TCP path MTU discovery and set the path MTU aging time to 20 minutes.
[Sysname] tcp path-mtu-discovery aging 20
tcp syn-cookie enable
Use tcp syn-cookie enable to enable SYN Cookie to protect the device from SYN flood attacks.
Use undo tcp syn-cookie enable to disable SYN Cookie.
SYN Cookie is disabled.
A TCP connection is established through a three-way handshake:
1. The sender sends a SYN packet to the server.
2. The server receives the SYN packet, establishes a TCP semi-connection in SYN_RECEIVED state, and replies with a SYN ACK packet to the sender.
3. The sender receives the SYN ACK packet and replies with an ACK packet. Then, a TCP connection is established.
An attacker can exploit this mechanism to mount SYN flood attacks. The attacker sends a large number of SYN packets, but they do not respond to the SYN ACK packets from the server. As a result, the server establishes a large number of TCP semi-connections and cannot handle normal services.
SYN Cookie can protect the server from SYN flood attacks. When the server receives a SYN packet, it responds to the request with a SYN ACK packet without establishing a TCP semi-connection.
The server establishes a TCP connection and enters ESTABLISHED state only when it receives an ACK packet from the sender.
# Enable SYN Cookie.
[Sysname] tcp syn-cookie enable
tcp timer fin-timeout
Use tcp timer fin-timeout to configure the TCP FIN wait timer.
Use undo tcp timer fin-timeout to restore the default.
The TCP FIN wait timer is 675 seconds.
time-value: Specifies the TCP FIN wait timer in the range of 76 to 3600 seconds.
TCP starts the FIN wait timer when the state changes to FIN_WAIT_2. If no FIN packet is received within the timer interval, the TCP connection is terminated.
If a FIN packet is received, TCP changes connection state to TIME_WAIT. If a non-FIN packet is received, TCP restarts the timer and tears down the connection when the timer expires.
# Set the TCP FIN wait timer to 800 seconds.
[Sysname] tcp timer fin-timeout 800
tcp timer syn-timeout
Use tcp timer syn-timeout to configure the TCP SYN wait timer.
Use undo tcp timer syn-timeout to restore the default.
The TCP SYN wait timer is 75 seconds.
time-value: Specifies the TCP SYN wait timer in the range of 2 to 600 seconds.
TCP starts the SYN wait timer after sending a SYN packet. If no response packet is received within the SYN wait timer interval, TCP fails to establish the connection.
# Set the TCP SYN wait timer to 80 seconds.
[Sysname] tcp timer syn-timeout 80
tcp window
Use tcp window to configure the size of the TCP receive/send buffer.
Use undo tcp window to restore the default.
tcp window window-size
undo tcp window
The size of the TCP receive/send buffer is 64 KB.
window-size: Specifies the size of the TCP receive/send buffer in KB, in the range of 1 to 64.
# Configure the size of the TCP receive/send buffer as 3 KB.
[Sysname] tcp window 3
