05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71005-Layer 3 - IP Services Command Reference
09-IPv6 basics commands
09-IPv6 basics commands 269.6 KB
The device operates in IRF or standalone (the default) mode. For information about IRF mode, see IRF Configuration Guide.
display ipv6 fib
Use display ipv6 fib to display IPv6 FIB entries.
display ipv6 fib [ vpn-instance vpn-instance-name ] [ ipv6-address [ prefix-length ] ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters.
ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies a prefix length for the IPv6 address, in the range of 0 to 128.
If you do not specify any VPN, this command displays IPv6 FIB entries for the public network.
If you do not specify any prefix length, this command displays the IPv6 FIB entry longest matching the IPv6 address. If you specify a prefix, this command displays the IPv6 FIB entry exactly matching the IPv6 address and prefix length.
If you do not specify any parameter, this command displays all IPv6 FIB entries for the public network.
# Display all IPv6 FIB entries for the public network.
<Sysname> display ipv6 fib
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay     F:FRR
Destination: 1::1                                           Prefix length: 64
Nexthop    : 1::2                                           Flags: UHS
Time stamp : 0x1                                            Label: 100
Interface  : GE3/0/2                                         Token: Invalid
Destination count
Total number of destination addresses.
FIB entry count
Total number of IPv6 FIB entries.
Destination
Destination address.
Prefix length
Prefix length of the destination address.
Nexthop
Next hop.
Flags
Route flag:
·       UUsable route.
·       GGateway route.
·       HHost route.
·       BBlack hole route.
·       DDynamic route.
·       SStatic route.
·       RRecursive route.
·       FFast re-route.
Time stamp
Time when the IPv6 FIB entry was generated.
Label
Inner MPLS label.
Outgoing interface.
Token
Label switched path index number.
display ipv6 icmp statistics
Use display ipv6 icmp statistics to display ICMPv6 packet statistics.
In standalone mode:
In IRF mode:
display ipv6 icmp statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Displays ICMPv6 packet statistics for the specified card. The slot-number argument specifies the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ICMPv6 packet statistics for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
This command displays statistics about received and sent ICMPv6 packets.
# Display ICMPv6 packet statistics.
<Sysname> display ipv6 icmp statistics
  Input: bad code                0           too short                  0
         checksum error          0           bad length                 0
         path MTU changed        0          destination unreachable  0
         too big                  0           parameter problem         0
         echo request            0           echo reply                  0
         neighbor solicit        0           neighbor advertisement   0
         router solicit          0           router advertisement      0
         redirect                 0           router renumbering         0
 output: parameter problem     0           echo request                0
         echo reply               0           unreachable no route       0
         unreachable admin       0           unreachable beyond scope 0
         unreachable address    0           unreachable no port        0
         too big                   0           time exceed transit       0
         time exceed reassembly 0           redirect                    0
         ratelimited               0           other errors               0
display ipv6 interface
Use display ipv6 interface to display IPv6 interface information.
interface-type: Interface type.
interface-number: Interface number.
brief: Displays brief information.
If you specify the brief keyword, this command displays brief information including physical status, link-layer protocols, and IPv6 address.
If you do not specify the brief keyword, this command displays detailed information including IPv6 configuration and operating information, and IPv6 packet statistics.
If you do not specify any interface, this command displays IPv6 information for all interfaces.
If you specify only interface-type, this command displays IPv6 information for the interfaces of the specified type.
If you specify interface-type interface-number, this command displays IPv6 information for the specified interface.
# Display IPv6 information for VLAN-interface 2.
<Sysname> display ipv6 interface vlan-interface 2
Vlan-interface2 current state: UP
IPv6 is enabled, link-local address is FE80::1234:56FF:FE65:4322 [TENTATIVE]
  Global unicast address(es):
    10::1234:56FF:FE65:4322, subnet is 10::/64 [TENTATIVE] [AUTOCFG]
      [valid lifetime 4641s/preferred lifetime 4637s]
    20::1234:56ff:fe65:4322, subnet is 20::/64 [TENTATIVE] [EUI-64]
    30::1, subnet is 30::/64 [TENTATIVE] [ANYCAST]
    40::2, subnet is 40::/64 [TENTATIVE] [DHCP]
    50::3, subnet is 50::/64 [TENTATIVE]
  Joined group address(es):
    FF02::1
    FF02::2
    FF02::1:FF00:1
    FF02::1:FF65:4322
  MTU is 1500 bytes
IPv6 Packet statistics:
  InReceives:                     0
  InTooShorts:                  0
  InTruncatedPkts:             0
  InHopLimitExceeds:           0
  InBadHeaders:                 0
  InBadOptions:                 0
  ReasmReqds:                     0
  ReasmOKs:                           0
  InFragDrops:                  0
  InFragTimeouts:               0
  OutFragFails:                 0
  InUnknownProtos:                  0
  InDelivers:                     0
  OutRequests:                  0
  OutForwDatagrams:                 0
  InNoRoutes:                    0
  InTooBigErrors:               0
  OutFragOKs:                     0
  OutFragCreates:               0
  InMcastPkts:                  0
  InMcastNotMembers:                0
  OutMcastPkts:                 0
  InAddrErrors:                 0
Physical state of the interface:
·       Administratively DOWN—The VLAN interface has been administratively shut down with the shutdown command.
·       DOWN—The VLAN interface is administratively up but its physical state is down because all ports in the VLAN are down.
·       UP—The administrative and physical states of the VLAN interface are both up.
Link layer protocol state of the interface:
·       DOWN—The link layer protocol state of the VLAN interface is down.
·       UP—The link layer protocol state of the VLAN interface is up.
IPv6 is enabled
IPv6 is enabled on the interface. This function is automatically enabled after an IPv6 address is configured for an interface.
link-local address
Link-local address of the interface.
Global unicast addresses of the interface:
IPv6 address states:
·       TENTATIVEInitial state. DAD is being performed or is to be performed on the address.
·       DUPLICATE—The address is not unique on the link and cannot be used.
·       PREFERRED—The address is preferred and can be used as the source or destination address of a packet. If an address is in this state, the command does not display the address state.
·       DEPRECATED—The address is beyond the preferred lifetime but in the valid lifetime. It is valid, but it cannot be used as the source address for a new connection. Packets destined to the address are processed normally.
If a global unicast address is not manually configured, the following indicates how the address is obtained:
·       AUTOCFG—Stateless autoconfigured.
·       DHCPAssigned by a DHCPv6 server.
·       EUI-64Manually configured EUI-64 IPv6 address.
·       RANDOM—Random address automatically generated.
If the address is a manually configured anycast address, ANYCAST is marked.
valid lifetime
Specifies how long autoconfigured global unicast addresses using a prefix are valid.
preferred lifetime
Specifies how long autoconfigured global unicast addresses using a prefix are preferred.
Addresses of multicast groups that the interface has joined.
MTU
Maximum transmission unit (MTU) of the interface.
DAD is enabled.
·       If DAD is enabled, this field displays the number of attempts to send a NS message for DAD (set with the ipv6 nd dad attempts command).
·       If DAD is disabled, this field displays ND DAD is disabled. To disable DAD, set the number of attempts to 0.
ND reachable time
Time during which a neighboring device is reachable.
Interval for retransmitting an NS message.
Hosts obtained IPv6 addresses through stateless autoconfiguration.
InReceives
All IPv6 packets received by the interface, including error packets.
InTooShorts
Received IPv6 packets that are too short, with a length less than 40 bytes, for example.
InTruncatedPkts
Received IPv6 packets with a length less than that specified in the packets.
InHopLimitExceeds
Received IPv6 packets with a hop count exceeding the limit.
InBadHeaders
Received IPv6 packets with incorrect basic headers.
InBadOptions
Received IPv6 packets with incorrect extension headers.
ReasmReqds
Received IPv6 fragments.
ReasmOKs
Number of reassembled packets rather than the number of fragments.
InFragDrops
IPv6 fragments that are discarded because of certain errors.
InFragTimeouts
IPv6 fragments that are discarded because the amount of time they stayed in the system buffer exceeded the specified interval.
OutFragFails
Packets that failed to be fragmented on the output interface.
InUnknownProtos
Received IPv6 packets with unknown or unsupported protocol type.
InDelivers
Received IPv6 packets that are delivered to application layer protocols (such as ICMPv6, TCP, and UDP).
OutRequests
Local IPv6 packets sent by IPv6 application protocols.
OutForwDatagrams
Packets forwarded by the output interface.
InNoRoutes
Received IPv6 packets that are discarded because no matched route can be found.
InTooBigErrors
Received IPv6 packets that are discarded because they exceeded the Path MTU.
OutFragOKs
Fragmented packets on the output interface.
OutFragCreates
Number of fragmented packets on the output interface.
InMcastPkts
Received IPv6 multicast packets on the interface.
InMcastNotMembers
IPv6 multicast packets that are discarded because the interface did not join in the corresponding multicast group.
OutMcastPkts
IPv6 multicast packets sent by the interface.
InAddrErrors
IPv6 packets that are discarded due to invalid destination addresses.
InDiscards
IPv6 packets that are discarded due to resource problems rather than packet content errors.
OutDiscards
Sent packets that are discarded due to resource problems rather than packet content errors.
# Display brief IPv6 information for all interfaces.
<Sysname> display ipv6 interface brief
*down: administratively down
(s): spoofing
Interface                     Physical Protocol IPv6 Address
Vlan-interface1              down       down      Unassigned
Vlan-interface2              up          up        2001::1
Vlan-interface100           up           up        Unassigned
The interface has been administratively shut down with the shutdown command.
(s): spoofing
Spoofing attribute of the interface.
The link protocol state of the interface is up, but the link is temporarily set up on demand or does not exist.
Name of the interface.
Physical
·       *down—The VLAN interface has been administratively shut down with the shutdown command.
·       down—The VLAN interface is administratively up but its physical state is down because all ports in the VLAN are down.
·       up—The administrative and physical states of the VLAN interface are both up.
Protocol
·       down—The network layer protocol state of the VLAN interface is down.
·       up—The network layer protocol state of the VLAN interface is up.
IPv6 Address
IPv6 address of the interface.
·       If at least one global unicast address is configured, this field displays the lowest address.
·       If no global unicast address is configured, this field displays the link-local address.
·       If no address is configured, this field displays Unassigned.
display ipv6 interface prefix
Use display ipv6 interface prefix to display IPv6 prefix information on an interface.
# Display IPv6 prefix information about VLAN-interface 10.
<Sysname> display ipv6 interface Vlan-interface10 prefix
Prefix: 1001::/65                                          Origin: ADDRESS
Age:    -                                                     Flag:   AL
Lifetime(Valid/Preferred): 2592000/604800
Prefix: 2001::/64                                          Origin: STATIC
Age:    -                                                     Flag:   L
Lifetime(Valid/Preferred): 3000/2000
Prefix: 3001::/64                                          Origin: RA
Age:    600                                                   Flag:   A
Lifetime(Valid/Preferred): -
Filed
Prefix
IPv6 address prefix.
Origin
How the prefix is generated:
·       STATICManually configured with the ipv6 nd ra prefix command.
·       RA—Advertised in RA messages after stateless autoconfiguration is enabled.
·       ADDRESSGenerated by a manually configured address.
Age
Aging time in seconds. If the prefix does not age out, a hyphens (-) is displayed.
Flag
Flags advertised in RA messages. If no flags are available, this field displays a hyphen (-).
·       L—The address with the prefix is directly reachable on the link.
·       A—The prefix is used for stateless autoconfiguration.
Lifetime
Lifetime in seconds advertised in RA messages. If the prefix does not need to be advertised, this field displays a hyphen (-).
·       ValidValid lifetime of the prefix.
·       PreferredPreferred lifetime of the prefix.
ipv6 nd ra prefix
display ipv6 neighbors
Use display ipv6 neighbors to display IPv6 neighbor information.
In standalone mode:
In IRF mode:
display ipv6 neighbors { { ipv6-address | all | dynamic | static } [ chassis chassis-number slot slot-number ] | interface interface-type interface-number | vlan vlan-id } [ verbose ]
ipv6-address: Specifies the IPv6 address of a neighbor whose information is displayed.
all: Displays information about all neighbors, including neighbors acquired dynamically and configured statically on the public network and all private networks.
dynamic: Displays information about all neighbors acquired dynamically.
static: Displays information about all neighbors configured statically.
slot slot-number: Displays neighbor information for the specified card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays neighbor information for the specified card on the specified IRF member device. The chassis-number argument refers to the ID of the IRF member device. The slot-number argument refers to the number of the slot that holds the card. (In IRF mode.)
interface interface-type interface-number: Displays neighbor information for the interface. The interface-type interface-number argument specifies an interface by its type and number.
vlan vlan-id: Displays information about neighbors in the specified VLAN. The VLAN ID ranges from 1 to 4094.
verbose: Displays detailed neighbor information.
You can use the reset ipv6 neighbors command to clear specific IPv6 neighbor information.
# Display all neighbor information.
<Sysname> display ipv6 neighbors all
                       Type: S-Static    D-Dynamic    I-Invalid
IPv6 Address                   Link Layer     VID  Interface      State T  Age
FE80::200:5EFF:FE32:B800    0000-5e32-b800 N/A  GE3/0/1        REACH  D 10
# Display detailed information about all neighbors.
<Sysname> display ipv6 neighbors all verbose
IPv6 Address: FE80::200:5EFF:FE32:B800
Link layer  : 0000-5e32-b800      VID : N/A  Interface: GE3/0/1
State        : REACH                 Type: IS   Age      : -
Vpn-instance: vpn1
Table 5 Command output
IPv6 Address
IPv6 address of a neighbor.
Link Layer
Link layer address (MAC address) of a neighbor.
VID
VLAN to which the interface connected with a neighbor belongs.
Interface connected with a neighbor.
State of a neighbor:
·       INCMPThe address is being resolved. The link layer address of the neighbor is unknown.
·       REACHThe neighbor is reachable.
·       STALEWhether the neighbor is reachable is unknown. The device does not verify the reachability any longer unless data is sent to the neighbor.
·       DELAYWhether the neighbor is reachable is unknown. The device sends an NS message after a delay.
·       PROBEWhether the neighbor is reachable is unknown. The device sends an NS message to verify the reachability of the neighbor.
Neighbor information type:
·       SStatically configured.
·       DDynamically obtained.
·       IInvalid.
Age
A hyphen (-) indicates a static entry.
For a dynamic entry, this field displays the elapsed time in seconds. If the neighbor is never reachable, this field displays a pound sign (#).
Vpn-instance
Name of a VPN or [No Vrf] with no VPN configured.
·           ipv6 neighbor
·           reset ipv6 neighbors
display ipv6 neighbors count
Use display ipv6 neighbors count to display the number of neighbor entries.
In standalone mode:
In IRF mode:
display ipv6 neighbors { { all | dynamic | static } [ chassis chassis-number slot slot-number ] | interface interface-type interface-number | vlan vlan-id } count
all: Displays the total number of all neighbor entries, including neighbor entries created dynamically and configured statically.
dynamic: Displays the total number of neighbor entries created dynamically.
static: Displays the total number of neighbor entries configured statically.
slot slot-number: Displays the total number of neighbor entries for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the total number of neighbor entries for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
interface interface-type interface-number: Displays the total number of neighbor entries of a specific interface. The interface-type interface-number specifies an interface by its type and number.
vlan vlan-id: Displays the total number of neighbor entries in the specified VLAN. The VLAN ID ranges from 1 to 4094.
# Display the total number of neighbor entries created dynamically.
<Sysname> display ipv6 neighbors dynamic count
 Total number of dynamic entries: 2
display ipv6 neighbors vpn-instance
Use display ipv6 neighbors vpn-instance to display neighbor information for a specific VPN.
display ipv6 neighbors vpn-instance vpn-instance-name [ count ]
vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. The VPN must already exist.
count: Displays the total number of neighbor entries in the specified VPN.
# Display neighbor information for the VPN vpn1.
<Sysname> display ipv6 neighbors vpn-instance vpn1
FE80::200:5EFF:FE32:B800   0000-5e32-b800   N/A  GE3/0/1        REACH IS  -
Table 6 Command output
IPv6 Address
Link-layer
VID
Neighbor state:
T
·       I—Invalid.
Age
display ipv6 pathmtu
Use the display ipv6 pathmtu command to display IPv6 Path MTU information.
display ipv6 pathmtu [ vpn-instance vpn-instance-name ] { ipv6-address | { all | dynamic | static  } [ count ] }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv6 Path MTU information for the public network.
ipv6-address: Specifies the destination IPv6 address for which the Path MTU information is to be displayed.
all: Displays all Path MTU information on the public network.
dynamic: Displays all dynamic Path MTU information.
static: Displays all static Path MTU information.
count: Displays the total number of Path MTU entries.
Use display ipv6 pathmtu to display the IPv6 Path MTU information, including the dynamic Path MTUs and the static Path MTUs.
# Display all Path MTU information.
<Sysname> display ipv6 pathmtu all
IPv6 destination address                PathMTU   Age   Type
1:2::3:2                                   1800       -      Static
1:2::4:2                                   1400       10     Dynamic
1:2::5:2                                   1280       10     Dynamic
# Displays the total number of Path MTU entries.
<Sysname> display ipv6 pathmtu all count
Total number of entries: 3
Table 7  Command output
IPv6 Destination Address
Destination IPv6 address.
PathMTU
Path MTU value on the network path to an IPv6 address.
Age
Time for a Path MTU to live. For a static Path MTU, this field displays a hyphen (-).
Indicates that the Path MTU is dynamically negotiated or statically configured.
Total number of Path MTU entries.
·           ipv6 pathmtu
·           reset ipv6 pathmtu
display ipv6 rawip
Use display ipv6 rawip to display brief information about IPv6 RawIP connections.
In standalone mode:
display ipv6 rawip [ slot slot-number ]
In IRF mode:
display ipv6 rawip [ chassis chassis-number slot slot-number ]
slot slot-number: Displays brief information about IPv6 RawIP connections for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays brief information about IPv6 RawIP connections for the specified card for the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
Brief information about IPv6 RawIP connections includes the local and peer IPv6 addresses, protocol number, and PCB.
# (In standalone mode.) Display brief information about IPv6 RawIP connections.
<Sysname> display ipv6 rawip
Local Addr            Foreign Addr        Protocol Slot   PCB
2001:2002:2003:2     3001:3002:3003:3   58         1      0x0000000000000009
004:2005:2006:20     004:3005:3006:30
07:2008                07:3008
2002::100             2002::138            58         2      0x0000000000000008
::                     ::                     58         5      0x0000000000000002
# (In IRF mode.) Display brief information about IPv6 RawIP connections.
Local Addr            Foreign Addr        Protocol Chassis Slot   PCB
2001:2002:2003:2     3001:3002:3003:3   58        1         1      0x0000000000000009
07:2008                07:3008
2002::100             2002::138            58        1         2      0x0000000000000008
::                     ::                     58        1         5      0x0000000000000002
Table 8 Command output
Local Addr
Local IPv6 address.
Foreign Addr
Peer IPv6 address.
Protocol
Protocol number.
Chassis
Slot
Number of the slot that holds the card.
PCB
PCB index.
display ipv6 rawip verbose
Use display ipv6 rawip verbose to display detailed information about IPv6 RawIP connections.
In standalone mode:
In IRF mode:
display ipv6 rawip verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
pcb pcb-index: Displays detailed information about IPv6 RawIP connections of the specified PCB. The pcb-index argument specifies the index of the PCB, in the range of 1 to 16.
slot slot-number: Displays detailed information about IPv6 RawIP connections for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays detailed information about IPv6 RawIP connections for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
Detailed information about an IPv6 RawIP connection includes socket's creator, state, option, type, and protocol number, and source and destination IPv6 addresses of the connection.
# (In standalone mode.) Display detailed information about an IPv6 RawIP connection.
<Sysname> display ipv6 rawip verbose
Total RawIP Socket Number: 1
slot: 1
 creator: ping ipv6[320]
 state: N/A
 options: N/A
 error: 0
 rcvbuf(cc/hiwat/lowat/state): 0 / 9216 / 1 / N/A
 sndbuf(cc/hiwat/lowat/state): 0 / 9216 / 512 / N/A
 type: 3
 protocol: 58
 connection info: src = ::, dst = ::
 inpcb flags: N/A
 inpcb vflag: INP_IPV6
 hop limit: 255 (minimum hop limit: 0)
 send VRF: 0xffff
 receive VRF: 0xffff
# (In IRF mode.) Display detailed information about IPv6 RwaIP connections.
 chassis: 1 slot: 1
 state: N/A
 options: N/A
 error: 0
 type: 3
 protocol: 58
 inpcb flags: N/A
 send VRF: 0xffff
 receive VRF: 0xffff
Table 9 Command output
Total number of IPv6 RawIP sockets.
chassis
slot
creator
Task name of the socket. The process number is displayed in the square brackets.
state
Socket state.
options
Socket options.
Receiving buffer information: the used space, maximum space, minimum space, and the state in the parentheses.
The state can be:
·       SBS_CANTSENDMOREUnable to send data to the peer.
·       SBS_CANTRCVMOREUnable to receive data from the peer.
·       SBS_RCVATMARKReceiving tag.
·       N/ANone of the above.
Sending buffer information: the used space, maximum space, minimum space, and the state in the parentheses.
The state can be:
·       N/ANone of the above types.
type
Socket type:
·       SOCK_STREAM1.
·       SOCK_DGRAM2.
·       SOCK_RAW3.
·       SOCK_RDM4.
·       SOCK_SEQPACKET5.
protocol
Number of protocol using the socket. 58 represents ICMP.
connection info
Connection information, including the source and destination IPv6 addresses.
inpcb flags
Flags in the Internet PCB:
·       INP_RECVOPTSReceives IPv6 options.
·       INP_RECVRETOPTSReceives replied IPv6 options.
·       INP_RECMDCSTADDRReceives destination IPv6 address.
·       INP_HDRINCLProvides the entire IPv6 header.
·       N/ANone of the above flags.
inpcb vflag
IP version flag in the Internet PCB.
hop limit(minimum hop limit)
Hop limit in the Internet PCB. The minimum number of hops is displayed in the parentheses.
send VRF
Sent instances.
receive VRF
Received instances.
display ipv6 statistics
Use display ipv6 statistics to display IPv6 and ICMPv6 packet statistics.
In standalone mode:
In IRF mode:
display ipv6 statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Displays IPv6 and ICMPv6 packet statistics for the specified card. The slot-number specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays IPv6 and ICMPv6 packet statistics for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
This command displays statistics about received and sent IPv6 and ICMPv6 packets.
Use the reset ipv6 statistics command to clear the statistics of all IPv6 and ICMPv6 packets.
If you do not specify the slot slot-number option, this command displays IPv6 and ICMPv6 packet statistics of all cards. (In standalone mode.)
If you do not specify the chassis chassis-number slot slot-number option, this command displays IPv6 and ICMPv6 packet statistics of all cards on all IRF member devices. (In IRF mode.)
# Display IPv6 and ICMPv6 packet statistics.
<Sysname> display ipv6 statistics
  IPv6 statistics:
    Sent packets:
      Total:      0
        Sent locally:         0            Forwarded:              0
        Raw packets:          0            Discarded:              0
        Fragments:            0            Fragments failed:      0
        Routing failed:       0
    Received packets:
      Total:      0
        Received locally:     0            Hop limit exceeded:  0
        Fragments:             0            Reassembled:           0
        Reassembly failures:  0            Reassembly timeout:  0
        Format errors:         0            Option errors:        0
        Protocol errors:      0
  ICMPv6 statistics:
    Sent packets:
      Total:      0
        Unreachable:           0             Too big:                0
        Hop limit exceeded:   0             Reassembly timeouts: 0
        Parameter problems:   0
        Echo requests:         0             Echo replies:          0
        Neighbor solicits:    0             Neighbor adverts:     0
        Router solicits:      0             Router adverts:        0
        Redirects:             0
      Send failed:
        Rate limitation:      0             Other errors:          0
    Received packets:
      Total:      0
        Checksum errors:      0             Too short:              0
        Bad codes:             0
        Parameter problems:   0             Unknown error types:   0
        Redirects:              0             Router renumbering:   0
        Unknown info types:   0
      Deliver failed:
        Bad length:           0
display ipv6 tcp
Use display ipv6 tcp to display brief information about IPv6 TCP connections.
In standalone mode:
In IRF mode:
display ipv6 tcp [ chassis chassis-number slot slot-number ]
slot slot-number: Displays brief information about IPv6 TCP connections for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays brief information about IPv6 TCP connections for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
Brief information about IPv6 TCP connections includes the local IPv6 address and port number, peer IPv6 address and port number, and TCP connection state.
# (In standalone mode.) Display brief information about IPv6 TCP connections.
<Sysname> display ipv6 tcp
*: TCP MD5 Connection
LAddr->port         FAddr->port       State           Slot  PCB
*2001:2002:2003:2  3001:3002:3003:3 ESTABLISHED   1      0x000000000000c387
07:2008->1200       07:3008->1200
2001::1->23         2001::5->1284     ESTABLISHED   2      0x0000000000000008
2003::1->25         2001::2->1283     LISTEN         3      0x0000000000000009
# (In IRF mode.) Display brief information about IPv6 TCP connections.
LAddr->port         FAddr->port       State         Chassis Slot  PCB
*2001:2002:2003:2  3001:3002:3003:3 ESTABLISHED 1         1     0x000000000000c387
2001::1->23         2001::5->1284     ESTABLISHED 1         2     0x0000000000000008
2003::1->25         2001::2->1283     LISTEN       1         3     0x0000000000000009
Table 10 Command output
Indicates the TCP connection uses MD5 authentication.
LAddr->port
Local IPv6 address and port number.
FAddr->port
Peer IPv6 address and port number.
TCP connection state:
·       CLOSED—The server receives a disconnection request's reply from the client.
·       LISTEN—The server is waiting for connection requests.
·       SYN_SENT—The client is waiting for the server to reply to the connection request.
·       SYN_RCMDC—The server receives a connection request.
·       ESTABLISHED—The server and client have established connections and can transmit data bidirectionally.
·       CLOSE_WAITThe server receives a disconnection request from the client.
·       FIN_WAIT_1The client is waiting for the server to reply to a disconnection request.
·       CLOSING—The server and client are waiting for peer's disconnection reply when receiving disconnection requests from each other.
·       LAST_ACKThe server is waiting for the client to reply to a disconnection request.
·       FIN_WAIT_2The client receives a disconnection reply from the server.
·       TIME_WAIT—The client receives a disconnection request from the server.
Chassis
Slot
PCB
PCB index.
display ipv6 tcp verbose
Use display ipv6 tcp verbose to display detailed information about IPv6 TCP connections.
In standalone mode:
In IRF mode:
display ipv6 tcp verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
pcb pcb-index: Displays detailed information about IPv6 TCP connections of the specified PCB. The pcb-index argument specifies the index of the PCB, in the range of 1 to 16.
slot slot-number: Displays detailed information about IPv6 TCP connections for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays detailed information about IPv6 TCP connections for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
Detailed information about an IPv6 TCP connection includes socket's creator, state, option, type, protocol number, source IPv6 address and port number, destination IPv6 address and port number, and the connection state.
# (In standalone mode.) Display detailed information about an IPv6 TCP connection.
<Sysname> display ipv6 tcp verbose
slot: 1
 creator: telnetd_mips[199]
 state: ISCONNECTED
 options: N/A
 error: 0
 rcvbuf(cc/hiwat/lowat/state): 0 / 65536 / 1 / N/A
 sndbuf(cc/hiwat/lowat/state): 0 / 65536 / 512 / N/A
 type: 1
 protocol: 6
 connection info: src = 2001::1->23 ,  dst = 2001::2->4181
 inpcb flags: N/A
 connection state: ESTABLISHED
 send VRF: 0x0
 receive VRF: 0x0
# (In IRF mode.) Display detailed information about IPv6 TCP connections.
slot: 1
 state: ISCONNECTED
 options: N/A
 error: 0
 type: 1
 protocol: 6
 inpcb flags: N/A
 send VRF: 0x0
 receive VRF: 0x0
Table 11 Command output
TCP inpcb number
Number of IPv6 TCP Internet PCBs.
tcpcb number
Number of IPv6 TCP PCBs (excluding PCBs of TCP in the TIME_WAIT state).
chassis
slot
ID of the slot that holds the card.
creator
state
Socket state.
options
Socket options.
Receiving buffer information: the used space, maximum space, minimum space, and state in the parentheses.
The state can be:
·       N/ANone of the above states.
Sending buffer information: the used space, maximum space, minimum space, and state in the parentheses.
The state can be:
type
Socket types:
·       SOCK_STREAM1.
·       SOCK_DGRAM2.
·       SOCK_RAW3.
·       SOCK_RDM4.
·       SOCK_SEQPACKET5.
protocol
Number of the protocol using the socket. 6 represents TCP.
connection info
Connection information, including source IPv6 address and port number, and destination IPv6 address and port number.
inpcb flags
inpcb vflag
IP version flags in the Internet PCB.
connection state
send VRF
Sent instances.
receive VRF
Received instances.
display ipv6 udp
Use display ipv6 udp to display brief information about IPv6 UDP connections.
In standalone mode:
In IRF mode:
display ipv6 udp [ chassis chassis-number slot slot-number ]
slot slot-number: Displays brief information about IPv6 UDP connections for the specified card. The slot-number argument specifies the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays brief information about IPv6 UDP connections for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
Brief information about an IPv6 UDP connection includes local IPv6 address and port number, and peer IPv6 address and port number.
# (In standalone mode.) Displays brief information about IPv6 UDP connections.
<Sysname> display ipv6 udp
LAddr->port         FAddr->port         Slot  PCB
2001:2002:2003:2   3001:3002:3003:3   1      0x000000000000c387
2001::1->23         2001::5->1284       2      0x0000000000000008
2003::1->25         2001::2->1283       3      0x0000000000000009
# (In IRF mode.) Display brief information about IPv6 UDP connections.
LAddr->port         FAddr->port         Chassis Slot  PCB
2001:2002:2003:2   3001:3002:3003:3   1        1      0x000000000000c387
2001::1->23         2001::5->1284       1        2      0x0000000000000008
2003::1->25         2001::2->1283       1        3      0x0000000000000009
Table 12 Command output
LAddr->port
FAddr->port
Chassis
Slot
PCB
PCB index.
display ipv6 udp verbose
Use display ipv6 udp verbose to display detailed information about IPv6 UDP connections.
In standalone mode:
In IRF mode:
display ipv6 udp verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
pcb pcb-index: Displays detailed information about IPv6 UDP connections of the specified PCB. The pcb-index argument specifies the index of the PCB, in the range of 1 to 16.
slot slot-number: Displays detailed information about IPv6 UDP connections for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays detailed information about IPv6 UDP connections for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
Detailed information about an IPv6 UDP connection includes socket's creator, state, option, type, protocol number, source IPv6 address and port number, destination IPv6 address and port number, and the connection state.
# (In standalone mode.) Display detailed information about an IPv6 UDP connection.
<Sysname> display ipv6 udp verbose
Total UDP Socket Number: 1
 slot: 1
 creator: sock_test_mips[250]
 state: N/A
 options: N/A
 error: 0
 rcvbuf(cc/hiwat/lowat/state): 0 / 41600 / 1 / N/A
 type: 2
 protocol: 17
 connection info: src = ::->69, dst = ::->0
 inpcb flags: N/A
 send VRF: 0xffff
 receive VRF: 0xffff
# (In IRF mode.) Display detailed information about IPv6 UDP connections.
 chassis: 1 slot: 1
 state: N/A
 options: N/A
 error: 0
 type: 2
 protocol: 17
 inpcb flags: N/A
 send VRF: 0xffff
 receive VRF: 0xffff
Table 13 Command output
Total number of IPv6 UDP sockets.
chassis
slot
creator
Task name of the socket. The progress number is displayed in the square brackets.
state
Socket state.
options
Socket options.
The state can be:
Sending buffer information, the used space, maximum space, minimum space, and state in the parentheses.
The state can be:
type
Socket type:
·       SOCK_STREAM1.
·       SOCK_DGRAM2.
·       SOCK_RAW3.
·       SOCK_RDM4.
·       SOCK_SEQPACKET5.
protocol
Number of the protocol using the socket. 17 represents UDP.
connection info
inpcb flags
inpcb vflag
send VRF
Sent instances.
receive VRF
Received instances.
ipv6 address
Use ipv6 address to configure an IPv6 global unicast address for an interface.
Use undo ipv6 address to remove the IPv6 global unicast address of the interface.
undo ipv6 address [ ipv6-address prefix-length | ipv6-address/prefix-length ]
No IPv6 global unicast address is configured for an interface.
Interface view
prefix-length: Specifies a prefix length in the range of 1 to 128.
Like public IPv4 addresses, IPv6 global unicast addresses are assigned to ISPs. This type of address allows for prefix aggregation to reduce the number of global routing entries.
Except for link-local addresses automatically obtained and those generated through stateless autoconfiguration, all IPv6 addresses are removed from the interface if the undo ipv6 address command is executed without any parameter specified.
If you specify an IPv6 address for an interface that belongs to a VPN, the number of VPNs that can be specified on the device decreases.
# Set the IPv6 global unicast address of VLAN-interface 100 to 2001::1 with prefix length 64.
Method 1:
[Sysname-Vlan-interface100] ipv6 address 2001::1/64
Method 2:
[Sysname-Vlan-interface100] ipv6 address 2001::1 64
ipv6 address anycast
Use ipv6 address anycast to configure an IPv6 anycast address for an interface.
Use undo ipv6 address anycast to remove the IPv6 anycast address of the interface.
undo ipv6 address { ipv6-address prefix-length | ipv6-address/prefix-length } anycast
No IPv6 anycast address is configured for an interface.
Interface view
ipv6-address: IPv6 anycast address.
prefix-length: Prefix length in the range of 1 to 128.
# Set the IPv6 anycast address of VLAN-interface 100 to 2001::1 with prefix length 64.
Method 1:
[Sysname-Vlan-interface100] ipv6 address 2001::1/64 anycast
Method 2:
[Sysname-Vlan-interface100] ipv6 address 2001::1 64 anycast
ipv6 address auto link-local
Use ipv6 address auto link-local to automatically generate a link-local address for an interface.
Use undo ipv6 address auto link-local to remove the automatically generated link-local address for the interface.
No link-local address is configured on an interface, and a link-local address is automatically generated after an IPv6 global unicast address is configured for the interface.
Interface view
Link-local addresses are used for neighbor discovery and stateless autoconfiguration on the local link. Packets using link-local addresses as the source or destination addresses cannot be forwarded to other links.
After an IPv6 global unicast address is configured for an interface, an automatically generated link-local address is the same as the one generated by using the ipv6 address auto link-local command.
Only use the undo ipv6 address auto link-local command to remove the link-local addresses generated through the ipv6 address auto link-local command.
·           After the undo ipv6 address auto link-local command is used on an interface that has an IPv6 global unicast address configured, the interface still has a link-local address.
·           If the interface has no IPv6 global unicast address configured, it has no link-local address.
Manual assignment takes precedence over automatic generation.
·           If you first adopt automatic generation and then manual assignment, the manually assigned link-local address overwrites the automatically generated address.
·           If you first use manual assignment and then automatic generation, the automatically generated link-local address does not take effect and the link-local address of an interface is still the manually assigned address.
If you delete the manually assigned address, the automatically generated link-local address is validated.
For more information about manually assignment of an IPv6 link-local address, see the ipv6 address link-local command.
# Configure VLAN-interface 100 to automatically generate a link-local address.
[Sysname-Vlan-interface100] ipv6 address auto link-local
ipv6 address eui-64
Use ipv6 address eui-64 to configure an EUI-64 IPv6 address for an interface.
Use undo ipv6 address eui-64 to remove the EUI-64 IPv6 address of the interface.
undo ipv6 address [ ipv6-address prefix-length | ipv6-address/prefix-length ] eui-64
No EUI-64 IPv6 address is configured for an interface.
Interface view
ipv6-address/prefix-length: Specifies an IPv6 address and IPv6 prefix length. The ipv6-address and prefix-length arguments jointly specify the prefix of an EUI-64 IPv6 address. The prefix-length argument ranges from 1 to 64.
An EUI-64 IPv6 address is generated based on the specified prefix and the automatically generated interface identifier and is displayed by using the display ipv6 interface command.
The prefix length of an EUI-64 IPv6 address cannot be greater than 64.
# Configure an EUI-64 IPv6 address for VLAN-interface 100. The prefix of the address is the same as that of 2001::1/64, and the interface ID is generated based on the MAC address of the device.
Method 1:
[Sysname-Vlan-interface100] ipv6 address 2001::1/64 eui-64
Method 2:
[Sysname-Vlan-interface100] ipv6 address 2001::1 64 eui-64
Use ipv6 address link-local to configure a link-local address for the interface.
Use undo ipv6 address link-local to remove the link-local address of the interface.
undo ipv6 address ipv6-address link-local
No link-local address is configured for the interface.
Interface view
ipv6-address: IPv6 link-local address. The first 10 bits of an address must be 1111111010 (binary). The first group of hexadecimals in the address must be FE80 to FEBF.
If you adopt automatic generation, and then use manual assignment, the manually assigned link-local address overwrites the one that is automatically generated.
If you adopt manual assignment, and then use automatic generation, the automatically generated link-local address does not take effect and the manually assigned link-local address of an interface remains. After you delete the manually assigned address, the automatically generated link-local address takes effect. For automatic generation of an IPv6 link-local address, see the ipv6 address auto link-local command.
# Configure a link-local address for VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 address fe80::1 link-local
ipv6 hop-limit
Use ipv6 hop-limit to set the Hop Limit field in the IPv6 header.
Use undo ipv6 hop-limit to restore the default.
ipv6 hop-limit value
undo ipv6 hop-limit
The hop limit is 64.
Value: Specifies the number of hops, in the range of 1 to 255.
The hop limit determines the number of hops necessary for an IPv6 packet to get to its destination.
If the device advertises the hop limit in RA messages (set with the undo ipv6 nd hop-limit unspecified command), all RA message receivers uses the value set with the ipv6 hop-limit command to fill in the Hop Limit field.
# Set the maximum number of hops to 100.
[Sysname] ipv6 hop-limit 100
ipv6 hoplimit-expires enable
Use ipv6 hoplimit-expires enable to enable sending ICMPv6 Time Exceeded messages.
Use undo ipv6 hoplimit-expires to disable sending ICMPv6 Time Exceeded messages.
undo ipv6 hoplimit-expires enable
Sending ICMPv6 Time Exceeded messages is enabled.
ICMPv6 Time Exceeded messages are sent to the source of IPv6 packets after the device discards IPv6 packets because hop or reassembly times out.
To prevent too many ICMPv6 error packets from affecting device performance, disable this function. Even with the function disabled, the device still sends Fragment Reassembly Time Exceeded packets.
# Disable sending ICMPv6 Time Exceeded packets.
[Sysname] undo ipv6 hoplimit-expires enable
Use ipv6 icmpv6 multicast-echo-reply enable to enable replying to multicast echo requests.
Use undo ipv6 icmpv6 multicast-echo-reply to disable replying to multicast echo requests.
undo ipv6 icmpv6 multicast-echo-reply enable
The device is disabled from replying to multicast echo requests.
If a host is configured to reply to multicast echo requests, an attacker can use this mechanism to attack the host. For example, if Host A (an attacker) sends an echo request to a multicast address with Host B as the source, all hosts in the multicast group send echo replies to Host B.
To prevent attacks, do not enable the device to reply to multicast echo requests unless necessary.
# Enable replying to multicast echo requests.
[Sysname] ipv6 icmpv6 multicast-echo-reply enable
ipv6 mtu
Use ipv6 mtu to set the MTU of IPv6 packets sent over an interface.
Use undo ipv6 mtu to restore the default MTU.
ipv6 mtu mtu-size
undo ipv6 mtu
No MTU is configured for an interface.
Interface view
mtu-size: Specifies the size of the MTUs of an interface, the value ranging from 1280 to 10240 bytes.
IPv6 routers do not support packet fragmentation. After an IPv6 router receives an IPv6 packet, if the packet size is greater than the MTU of the forwarding interface, the router discards the packet. Meanwhile, the router sends the MTU to the source host through an ICMPv6 packet — Packet Too Big message. The source host fragments the packet according to the MTU and resends it. To reduce the extra flow overhead resulting from packet drops, configure a appropriate interface MTU for your network.
# Set the MTU of IPv6 packets sent over VLAN-interface 100 to 1280 bytes.
[Sysname-Vlan-interface100] ipv6 mtu 1280
Use ipv6 nd autoconfig managed-address-flag to set the managed address configuration (M) flag to 1 so that the host can obtain an IPv6 address through stateful autoconfiguration (for example, from a DHCPv6 server).
Use undo ipv6 nd autoconfig managed-address-flag to restore the default.
The M flag is set to 0 so that the host can obtain an IPv6 address through stateless autoconfiguration.
Interface view
The M flag determines whether a host uses stateful autoconfiguration to obtain an IPv6 address.
If the M flag is set to 1, the host uses stateful autoconfiguration (for example, from an DHCPv6 server to obtain an IPv6 address. Otherwise, the host uses stateless autoconfiguration to generate an IPv6 address according to its link-layer address and the prefix information in the RA message.
# Configure the host to obtain an IPv6 address through stateful autoconfiguration.
[Sysname-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
ipv6 nd autoconfig other-flag
Use ipv6 nd autoconfig other-flag to set the other stateful configuration flag (O) to 1 so that the host can obtain information other than IPv6 address through stateful autoconfiguration (for example, from a DHCPv6 server).
Use undo ipv6 nd autoconfig other-flag to restore the default.
The O flag is set to 0 so that the host can acquire other information through stateless autoconfiguration.
Interface view
The O flag determines whether a host uses stateful autoconfiguration to obtain configuration information other than IPv6 address.
If the O flag is set to 1, the host uses stateful autoconfiguration (for example, from a DHCPv6 server) to obtain configuration information other than IPv6 address. Otherwise, the host uses stateless autoconfiguration.
# Configure the host to obtain configuration information other than IPv6 address through stateless autoconfiguration.
[Sysname-Vlan-interface100] undo ipv6 nd autoconfig other-flag
Use ipv6 nd dad attempts to configure the number of attempts to send an NS message for DAD.
Use undo ipv6 nd dad attempts to restore the default.
ipv6 nd dad attempts value
The number of attempts to send an NS message for DAD is 1.
Interface view
value: Number of attempts to send an NS message for DAD, in the range of 0 to 600. If it is set to 0, DAD is disabled.
An interface sends an NS message for DAD after obtaining an IPv6 address.
If the interface does not receive a response within a specific time (set by the ipv6 nd ns retrans-timer command), it continues to send an NS message.
If the interface still does not receive a response after the number of attempts reaches the threshold (set by the ipv6 nd dad attempts command), the obtained address is considered usable.
# Set the number of attempts to send an NS message for DAD to 20.
[Sysname-Vlan-interface100] ipv6 nd dad attempts 20
·           display ipv6 interface
·           ipv6 nd ns retrans-timer
Use ipv6 nd ns retrans-timer to set the interval for retransmitting an NS message.
Use undo ipv6 nd ns retrans-timer to restore the default.
The local interface sends NS messages at an interval of 1000 milliseconds, and the Retrans Timer field in the RA messages sent is 0, so that the interval for retransmitting an NS message is determined by the receiving device.
Interface view
value: Specifies the interval for retransmitting an NS message, in the range of 1000 to 4294967295 milliseconds.
If a device does not receive a response from the peer within the specified interval, the device re-sends an NS message.
The value specified by this command serves as the interval for the local interface to retransmit an NS message. It also serves as the value in the Retrans Timer field in RA messages sent by the local interface.
# Specify VLAN-interface 100 to retransmit NS messages at an interval of 10000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd ns retrans-timer 10000
ipv6 nd nud reachable-time
Use ipv6 nd nud reachable-time to set the neighbor reachable time on an interface.
Use undo ipv6 nd nud reachable-time to restore the default.
ipv6 nd nud reachable-time value
The neighbor reachable time on the local interface is 30000 milliseconds and the value of the Reachable Time field in RA messages is 0, so that the reachable time is determined by the receiving device.
Interface view
value: Neighbor reachable time in the range of 1 to 3600000 milliseconds.
If the neighbor reachability detection shows that a neighbor is reachable, the device considers the neighbor reachable within the specified reachable time. If the device must send a packet to the neighbor after the specified reachable time expires, the device reconfirms whether the neighbor is reachable.
The value specified by this command serves as the neighbor reachable time on the local interface. It also serves as the value in the Reachable Time field in RA messages sent by the local interface.
# Set the neighbor reachable time on VLAN-interface 100 to 10000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd nud reachable-time 10000
ipv6 nd ra halt
Use ipv6 nd ra halt to suppress an interface from advertising RA message.
Use undo ipv6 nd ra halt to disable this function.
ipv6 nd ra halt
An interface is suppressed from sending RA messages.
Interface view
# Suppress VLAN-interface 100 from advertising RA messages.
[Sysname-Vlan-interface100] ipv6 nd ra halt
ipv6 nd ra hop-limit unspecified
Use ipv6 nd ra hop-limit unspecified to specify unlimited hops in RA messages.
Use undo ipv6 nd ra hop-limit unspecified to restore the default.
The maximum number of hops in the RA messages is limited to 64.
Interface view
To set the maximum number of hops to a value rather than the default setting, use the ipv6 hop-limit command.
# Specify unlimited hops in the RA messages on VLAN-interface 100.
[Sysname-Vlan-interface10] ipv6 nd ra hop-limit unspecified
ipv6 hop-limit
ipv6 nd ra interval
Use ipv6 nd ra interval to set the maximum and minimum intervals for advertising RA messages.
Use undo ipv6 nd ra interval to restore the default.
ipv6 nd ra interval max-interval-value min-interval-value
The maximum interval between RA messages is 600 seconds, and the minimum interval is 200 seconds.
Interface view
max-interval-value: Specifies the maximum interval for advertising RA messages in seconds, in the range of 4 to 1800.
min-interval-value: Specifies the minimum interval for advertising RA messages in seconds, in the range of 3 to three-fourths of the maximum interval.
The device advertises RA messages at intervals of a random value between the maximum interval and the minimum interval.
The maximum interval for sending RA messages should be less than or equal to the router lifetime in RA messages.
# Set the maximum interval for advertising RA messages to 1000 seconds and the minimum interval to 700 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra interval 1000 700
ipv6 nd ra router-lifetime
ipv6 nd ra no-advlinkmtu
Use ipv6 nd ra no-advlinkmtu to turn off the MTU option in RA messages.
Use undo ipv6 nd ra no-advlinkmtu to restore the default.
RA messages contain the MTU option.
Interface view
The MTU option in the RA messages specifies the link MTU to make sure all nodes on the link use the same MTU.
# Turn off the MTU option in RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
Use ipv6 nd ra prefix to configure the prefix information in RA messages.
Use undo ipv6 nd ra prefix to remove the prefix information from RA messages.
ipv6 nd ra prefix { ipv6-prefix prefix-length | ipv6-prefix/prefix-length } valid-lifetime preferred-lifetime [ no-autoconfig | off-link ] *
undo ipv6 nd ra prefix { ipv6-prefix | ipv6-prefix/prefix-length }
No prefix information is configured for RA messages. Instead, the IPv6 address of the interface sending RA messages is used as the prefix information.
If the IPv6 address is manually configured, the prefix uses the fixed valid lifetime 2592000 seconds (30 days) and preferred lifetime 604800 seconds (seven days).
If the IPv6 address is automatically obtained (through DHCP, for example), the prefix uses the valid and preferred lifetime of the IPv6 address.
Interface view
ipv6-prefix: Specifies the IPv6 prefix.
prefix-length: Specifies the prefix length of the IPv6 address.
valid-lifetime: Specifies the valid lifetime of a prefix, in the range of 0 to 4294967295 seconds.
preferred-lifetime: Specifies the preferred lifetime of a prefix used for stateless autoconfiguration, in the range of 0 to 4294967295 seconds. The preferred lifetime cannot be greater than the valid lifetime.
no-autoconfig: Specifies a prefix not to be used for stateless autoconfiguration. If this keyword is not specified, the prefix is used for stateless autoconfiguration.
off-link: Indicates that the address with the prefix is not directly reachable on the link. If this keyword is not specified, the address with the prefix is directly reachable on the link.
After hosts on the same link receive RA messages, they can use the prefix information in the RA messages for stateless autoconfiguration.
# Configure the prefix information for RA messages on VLAN-interface 100.
Method 1:
[Sysname-Vlan-interface100] ipv6 nd ra prefix 2001:10::100/64 100 10
Method 2:
[Sysname-Vlan-interface100] ipv6 nd ra prefix 2001:10::100 64 100 10
Use ipv6 nd ra router-lifetime to configure the router lifetime in RA messages.
Use undo ipv6 nd ra router-lifetime to restore the default.
ipv6 nd ra router-lifetime value
The router lifetime in RA messages is 1800 seconds.
Interface view
value: Specifies the router lifetime in the range of 0 to 9000 seconds. If the value is set to 0, the router does not serve as the default router.
The router lifetime in RA messages specifies how long the router sending the RA messages serves as the default router. Hosts receiving the RA messages check this value to determine whether using the sending router as the default router. If router lifetime is 0, the router cannot be used as the default router.
The router lifetime in RA messages must be greater than or equal to the advertising interval.
# Set the router lifetime in RA messages on VLAN-interface 100 to 1000 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra router-lifetime 1000
ipv6 nd ra interval
ipv6 nd router-preference
Use ipv6 nd router-preference to set a router preference in RA messages.
Use undo ipv6 nd router-preference to restore the default.
The router preference is medium.
Interface view
high: Sets the router preference to the highest.
low: Sets the router preference to the lowest.
medium: Sets the router preference to the medium.
A hosts selects a router with the highest preference as the default router.
When router preferences are the same in RA messages, a host selects the router corresponding to the first received RA message as the default gateway.
# Set the router preference in RA messages to the highest on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd router-preference high
ipv6 neighbor
Use ipv6 neighbor to configure a static neighbor entry.
Use undo ipv6 neighbor to remove a static neighbor entry.
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number } [ vpn-instance vpn-instance-name ]
undo ipv6 neighbor ipv6-address interface-type interface-number
No static neighbor entry is configured.
ipv6-address: Specifies the IPv6 address of the static neighbor entry.
mac-address: Specifies the MAC address (48 bits) of the static neighbor entry, in the format of H-H-H.
vlan-id: Specifies the VLAN ID of the static neighbor entry, in the range of 1 to 4094.
port-type port-number: Specifies a Layer 2 port of the static neighbor entry by its type and number.
interface interface-type interface-number: Specifies a Layer 3 interface of the static neighbor entry by its type and number.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN that the static neighbor entry belongs to. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the static neighbor entry is for the public network, do not specify this option.
The IPv6 address of a neighboring node can be resolved into a link-layer address either dynamically through NS and NA messages, or through a manually configured static neighbor entry.
The device uniquely identifies a static neighbor entry by the neighbor's IPv6 address and the local Layer 3 interface number. You can configure a static neighbor entry by using either of the following methods:
·           Method 1—Associate a neighbor IPv6 address and link-layer address with the Layer 3 interface of the local node.
·           Method 2—Associate a neighbor IPv6 address and link-layer address with a port in a VLAN containing the local node.
You can use either of the previous configuration methods to configure a static neighbor entry for a VLAN interface.
·           If Method 1 is used, the neighbor entry is in INCMP state. After the device obtains the corresponding Layer 2 port information, the neighbor entry goes into REACH state.
·           If Method 2 is used, the corresponding VLAN interface must already exist and the port specified by port-type port-number must belong to the VLAN specified by vlan-id. After the static neighbor entry is configured, the device associates the VLAN interface with the IPv6 address to uniquely identify the static neighbor entry and the entry will be in REACH state.
To remove a static neighbor entry for a VLAN interface, only specify the corresponding VLAN interface.
# Configure a static neighbor entry for Layer 3 interface GigabitEthernet 3/0/1.
[Sysname] ipv6 neighbor 2000::1 fe-e0-89 interface GigabitEthernet 3/0/1
·           display ipv6 neighbors
Use ipv6 neighbor link-local minimize to minimize link-local ND entries.
Use undo ipv6 neighbor link-local minimize to restore the default.
All ND entries are assigned to the driver.
Perform this command to minimize link-local ND entries assigned to the driver. Link-local ND entries refer to ND entries comprising link-local addresses.
By default, the device assigns all ND entries to the driver. With this feature enabled, the device does not add newly learned link-local ND entries whose link local addresses are not the next hop of any route to the driver, saving driver resources.
This feature affects only newly learned link-local ND entries rather than existing ND entries.
# Minimize link-local ND entries.
[Sysname] ipv6 neighbor link-local minimize
ipv6 neighbor stale-aging
Use ipv6 neighbor stale-aging to set the age timer for ND entries in stale state.
Use undo ipv6 neighbor stale-aging to restore the default.
The age timer for ND entries in the stale state is four hours.
aging-time: Specifies the age timer for ND entries in stale state, in the range of 1 to 24 hours.
ND entries in stale state have an age timer. If an ND entry in stale state is not refreshed before the timer expires, it moves to the delay state. If it is still not refreshed in five seconds, the ND entry moves to the probe state, and the device sends an NS message for detection for a maximum of three times. If no response is received, the device deletes the ND entry.
# Set the age timer for ND entries in the stale state to two hours.
[Sysname] ipv6 neighbor stale-aging 2
ipv6 neighbors max-learning-num
Use ipv6 neighbors max-learning-num to configure the maximum number of neighbors that an interface can dynamically learn.
Use undo ipv6 neighbors max-learning-num to restore the default.
ipv6 neighbors max-learning-num number
The maximum number of neighbors that an Ethernet interface can learn dynamically is the maximum capacity of the system.
Layer 2 interface view, Layer 3 interface view
number: Specifies the maximum number of neighbors that the interface can dynamically learn.
The device can dynamically acquire the link-layer address of a neighboring node through NS and NA messages and add it into the neighbor table. A large table can reduce the forwarding performance of the device.
You can restrict the size of the neighbor table by setting the maximum number of neighbors that an interface can dynamically learn. When the number of dynamically learned neighbors reaches the threshold, the interface stops learning neighbor information.
# Set the maximum number of neighbors that VLAN-interface 100 can dynamically learn to 10.
[Sysname-Vlan-interface100] ipv6 neighbors max-learning-num 10
ipv6 pathmtu
Use ipv6 pathmtu to configure a static Path MTU for a specific IPv6 address.
Use undo ipv6 pathmtu to remove the Path MTU configuration for the specified IPv6 address.
undo ipv6 pathmtu [ vpn-instance vpn-instance-name ] ipv6-address
No static Path MTU is configured.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN that the Path MTU belongs to. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the Path MTU is for the public network, do not specify this option.
ipv6-address: IPv6 address.
value: Specifies the Path MTU of a specific IPv6 address, in the range of 1280 to 10240 bytes.
You can configure a static Path MTU for a specific destination IPv6 address. When a source host sends a packet through an interface, it compares the interface MTU with the static Path MTU of the specified destination IPv6 address. If the packet size is larger than the smaller one of the two values, the host fragments the packet according to the smaller value.
# Configure a static Path MTU for a specific IPv6 address.
[Sysname] ipv6 pathmtu fe80::12 1300
·           display ipv6 pathmtu
ipv6 pathmtu age
Use ipv6 pathmtu age to configure the aging time for a dynamic Path MTU.
Use undo ipv6 pathmtu age to restore the default.
ipv6 pathmtu age age-time
The aging time for dynamic Path MTU is 10 minutes.
age-time: Specifies the aging time for Path MTU in minutes, in the range of 10 to 100.
After the path MTU from a source host to a destination host is dynamically determined, the source host sends subsequent packets to the destination host based on this MTU. After the aging time expires, the dynamic Path MTU is removed and the source host re-determines a dynamic path MTU through the Path MTU mechanism.
The aging time is invalid for a static Path MTU.
# Set the aging time for a dynamic Path MTU to 40 minutes.
[Sysname] ipv6 pathmtu age 40
ipv6 redirects enable
Use ipv6 redirects enable to enable sending ICMPv6 redirect messages.
Use undo ipv6 redirects enable to disable sending ICMPv6 redirect messages.
Sending ICMPv6 redirect messages is disabled.
The default gateway sends an ICMPv6 redirect message to the source of an IPv6 packet to inform of a better first hop.
Sending ICMPv6 redirect messages enables hosts that hold few routes to establish routing tables and find the best route. Because this function adds host route into the routing tables, host performance degrades when there are too many host routes. As a result, sending ICMPv6 redirect messages is disabled by default.
# Enable sending ICMPv6 redirect messages.
[Sysname] ipv6 redirects enable
ipv6 unreachables enable
Use ipv6 unreachables enable to enable sending ICMPv6 destination unreachable packets.
Use undo ipv6 unreachables to disable sending ICMPv6 destination unreachable packets.
undo ipv6 unreachables enable
Sending ICMPv6 destination unreachable packets is disabled.
If the device fails to forward a received IPv6 packet because of a destination unreachable error, it drops the packet and sends a corresponding ICMPv6 Destination Unreachable error message to the source.
If the device is generating ICMPv6 destination unreachable messages abnormally, disable the sending ICMPv6 destination unreachable packets to prevent attack risks.
# Enable sending ICMPv6 destination unreachable packets.
[Sysname] ipv6 unreachables enable
Use reset ipv6 neighbors to clear IPv6 neighbor information.
In standalone mode:
In IRF mode:
reset ipv6 neighbors { all | dynamic | interface interface-type interface-number | chassis chassis-number slot slot-number | static }
all: Clears static and dynamic neighbor information on all interfaces.
dynamic: Clears dynamic neighbor information on all interfaces.
interface interface-type interface-number: Clears dynamic neighbor information on the interface specified by its type and number.
slot slot-number: Clears the dynamic neighbor information for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Clears the dynamic neighbor information for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
static: Clears static neighbor information on all interfaces.
You can use the display ipv6 neighbors command to display IPv6 neighbor information.
# Clear neighbor information on all interfaces.
<Sysname> reset ipv6 neighbors all
This will delete all the entries. Continue? [Y/N]:Y
# Clear dynamic neighbor information on all interfaces.
<Sysname> reset ipv6 neighbors dynamic
This will delete all the dynamic entries. Continue? [Y/N]:Y
# Clear all neighbor information on GigabitEthernet 3/0/1.
<Sysname> reset ipv6 neighbors interface GigabitEthernet 3/0/1
This will delete all the dynamic entries by the interface you specified. Contin
ue? [Y/N]:Y
·           ipv6 neighbor
reset ipv6 pathmtu
Use reset ipv6 pathmtu to clear the Path MTU information.
all: Clears all Path MTUs.
dynamic: Clears all dynamic Path MTUs.
static: Clears all static Path MTUs.
# Clear all Path MTUs.
<Sysname> reset ipv6 pathmtu all
Use reset ipv6 statistics to clear IPv6 and ICMPv6 packet statistics.
In standalone mode:
In IRF mode:
reset ipv6 statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Clears IPv6 and ICMPv6 packet statistics for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Clears IPv6 and ICMPv6 packet statistics for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
You can use the display ipv6 statistics command to display the IPv6 and ICMPv6 packet statistics.
If you do not specify the slot slot-number option, this command clears IPv6 and ICMPv6 packet statistics of all cards. (In standalone mode.)
If you do not specify the chassis chassis-number slot slot-number option, this command clears IPv6 and ICMPv6 packet statistics of all cards on all IRF member devices. (In IRF mode.)
# Clear IPv6 and ICMPv6 packet statistics.
<Sysname> reset ipv6 statistics
