- 06-Layer 3 - IP Services Command Reference
- 01-ARP Commands
- 02-IP Addressing Commands
- 03-DHCP Commands
- 04-DNS Commands
- 05-NAT Commands
- 06-IP Forwarding Basics Commands
- 07-Adjacency Table Commands
- 08-IP Performance Optimization Commands
- 09-UDP Helper Commands
- 10-IPv6 Basics Commands
- 11-DHCPv6 Commands
- 12-IPv6 DNS Commands
- 13-Tunneling Commands
| 13-Tunneling Commands | 140.95 KB |
NOTE: The switch supports two operation modes: standalone (default) and IRF. For more information about IRF mode, see IRF Configuration Guide. |
default
default
View
Tunnel interface view
Default level
2: System level
None
Use the default command to restore the default setting for the tunnel interface.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. You can use the display this command in interface view to check for these commands, and perform their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you perform it on a live network. |
# Restore the default setting of interface tunnel 1.
[Sysname] interface tunnel 1
[Sysname-Tunnel1] default
This command will restore the default settings. Continue? [Y/N]:y
description
View
Default level
2: System level
text: Description of an interface, a string of 1 to 80 characters.
Use the description command to configure a description for the current interface.
Use the undo description command to restore the default.
By default, the description of an interface is the interface name followed by the Interface string, for example, Tunnel1 Interface.
Related commands: display interface tunnel.
# Configure the description of interface Tunnel 1 as tunnel1.
[Sysname-Tunnel1] description tunnel1
destination
destination ip-address
undo destination
View
Default level
2: System level
ip-address: Tunnel destination IPv4 address.
Use the destination command to specify the destination address for the tunnel interface.
Use the undo destination command to remove the configured tunnel destination address.
By default, no tunnel destination address is configured.
Note the following:
· The tunnel destination address is the address of the peer interface receiving packets and should be configured as the source address of the peer tunnel interface.
· Automatic tunnel interfaces using the same encapsulation protocol must have different source addresses. Two or more tunnel interfaces using the same encapsulation protocol must have different source and destination addresses.
Related commands: source, interface tunnel, display interface tunnel, and display ipv6 interface tunnel.
# Set the interface VLAN-interface 100 (193.101.1.1) of Sysname 1 and the interface VLAN-interface 100 (192.100.1.1) of Sysname 2 as the source and destination interfaces of a tunnel between the two switches, respectively.
<Sysname1> system-view
[Sysname1] interface Tunnel 0
[Sysname1-Tunnel0] source 193.101.1.1
[Sysname1-Tunnel0] destination 192.100.1.1
<Sysname2> system-view
[Sysname2] interface Tunnel 0
[Sysname2-Tunnel0] source 192.100.1.1
[Sysname2-Tunnel0] destination 193.101.1.1
display interface [ tunnel ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface tunnel number [ brief ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
number: Sets the number of a tunnel interface. With this argument, the command specifies information about a specified tunnel interface.
down: Displays information about interfaces in the DOWN state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display interface tunnel command to display information about tunnel interfaces, such as the source address, destination address, and tunnel mode.
· If you do not specify the tunnel keyword, this command displays information about all interfaces on the device.
· If you specify the tunnel keyword without the number argument, this command displays information about all existing tunnel interfaces.
Related commands: interface tunnel, source, destination, and tunnel-protocol.
# Display the detailed information about interface Tunnel 0.
<Sysname> display interface tunnel 0
Tunnel0 current state: UP
The Maximum Transmit Unit is 1476
Internet Address is 10.1.2.1/24 Primary
Encapsulation is TUNNEL, service-loopback-group ID not set
Tunnel source 192.13.2.1, destination 192.13.2.2
Tunnel bandwidth 64 (kbps)
Tunnel keepalive enabled, Period(50 s), Retries(3)
Tunnel protocol/transport GRE/IP
GRE key disabled
Checksumming of GRE packets disabled
Last 300 seconds input: 0 bytes/sec, 0 packets/sec
Last 300 seconds output: 0 bytes/sec, 0 packets/sec
361 packets input, 9953388 bytes
0 input error
361 packets output, 30324 bytes
0 output error
Table 1 Output description
Tunnel0 current state |
Physical state of the tunnel interface, which can be · DOWN (Administratively)—Indicates that the interface is administratively down; that is, the interface is shut down with the shutdown command. · DOWN—Indicates that the interface is administratively up but its physical state is down. · UP—Indicates that both the administrative and physical states of the interface are up. |
Line protocol current state |
Link layer state of the tunnel interface, which can be · DOWN—Indicates that the protocol state of the interface is down. · UP—ndicates that the protocol state of the interface is up. |
Description of the tunnel interface |
Maximum Transmit Unit |
Maximum transmit unit allowed on the tunnel interface |
Internet Address |
IP address of the tunnel interface If no IP address is assigned to the interface, "Internet protocol processing : disabled" will be displayed, which means that packets cannot be processed. "Primary" indicates the primary IP address of the interface; "Sub" indicates a secondary IP address of the interface. |
Encapsulation is TUNNEL |
The encapsulation protocol is tunnel. |
service-loopback-group ID |
ID of the service loopback group referenced by the tunnel. If service loopback group is not supported or not specified, "service-loopback-group ID not set" will be displayed. |
Tunnel source |
Source address of the tunnel |
destination |
Destination address of the tunnel |
Tunnel bandwidth |
Bandwidth of the tunnel interface |
Tunnel keepalive enabled, Period(50 s), Retries(3) |
GRE keepalive is enabled to detect the state of the tunnel interface. In this example, keepalive packets are sent every 50 seconds and can be sent up to three times. |
Tunnel protocol/transport |
Tunnel mode and transport protocol, which can be · GRE/IP—GRE over IPv4 tunnel mode · IPv6/IP—IPv6 over IPv4 manual tunnel mode · IPv6/IP 6to4—IPv6 over IPv4 6to4 tunnel mode · IPv6/IP auto-tunnel—Automatic IPv6 over IPv4 tunnel mode · IPv6/IP ISATAP—IPv6 over IPv4 ISATAP tunnel mode · CR_LSP—MPLS TE tunnel mode |
GRE key disabled |
The tunnel interface key option of GRE is not configured. |
Checksumming of GRE packets disabled |
The GRE packet checksum function is disabled. |
Last clearing of counters |
Last time of clearing of counters |
Last 300 seconds input: 0 bytes/sec, 0 packets/sec |
Average input rate in the last 300 seconds in bytes/sec or packets/sec |
Last 300 seconds output: 0 bytes/sec, 0 packets/sec |
Average output rate in the last 300 seconds in bytes/sec or packets/sec |
packets input |
Total number of input packets |
input error |
Number of input error packets |
packets output |
Total number of output packets |
output error |
Number of output error packets |
# Display the brief information about interface Tunnel 0.
<Sysname> display interface tunnel 0 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface Link Protocol Main IP Description
Tun0 UP UP 1.1.1.1
# Display the brief information about interface Tunnel 1 in the DOWN state.
<Sysname> display interface tunnel brief down
Interface Link Cause
Tun1 DOWN Not connected
Table 2 Output description
The brief information of interface(s) under route mode |
Brief information about Layer 3 interfaces |
Link: ADM - administratively down; Stby - standby |
Link status: · ADM—The interface has been administratively shut down. To recover its physical state, perform the undo shutdown command. · Stby—The interface is operating as a backup interface. To see the primary interface, use the display standby state command (High Availability Command Reference). |
Protocol: (s) - spoofing |
If the network layer protocol state of an interface is shown as UP, but its link is an on-demand link or not present at all, its protocol attribute includes the spoofing flag (an s in parentheses). |
Abbreviated interface name |
Link |
Physical link state of the interface, which can be: · UP—The link is up. · DOWN—The link is down. · ADM—The link has been administratively shut down. To recover its physical state, perform the undo shutdown command. · Stby—The interface operates as a backup interface. |
Protocol |
Protocol connection state of the interface, which can be: · DOWN—Protocol connection is disabled on the interface. · UP—Protocol connection is enabled. |
Main IP |
The main IP address of the interface |
Description of the interface |
Cause |
The cause of a DOWN physical link. If the port has been shut down with the shutdown command, this field displays Administratively. To restore the physical state of the interface, use the undo shutdown command. |
display ipv6 interface tunnel [ number ] [ brief ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
number: Displays IPv6 information on a specific tunnel interface. If no interface number is specified, IPv6 information about all tunnel interfaces will be displayed.
brief: Displays brief information and IPv6 packet statistics for tunnel interfaces. If this keyword is not specified, detailed IPv6 information for tunnel interfaces is displayed.
Use the display ipv6 interface tunnel command to display IPv6 information for tunnel interfaces.
# Display detailed IPv6 information and IPv6 packet statistics for interface Tunnel 0.
<Sysname> display ipv6 interface tunnel 0
Tunnel0 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::202:201
Global unicast address(es):
3000::1, subnet is 3000::/64
Joined group address(es):
FF02::1:FF02:201
FF02::1:FF00:1
FF02::1:FF00:0
FF02::2
FF02::1
MTU is 1480 bytes
IPv6 Packet statistics:
InReceives: 45
InTooShorts: 0
InTruncatedPkts: 0
InHopLimitExceeds: 0
InBadHeaders: 0
InBadOptions: 0
ReasmReqds: 0
ReasmOKs: 0
InFragDrops: 0
InFragTimeouts: 0
OutFragFails: 0
InUnknownProtos: 0
InDelivers: 45
OutRequests: 45
OutForwDatagrams: 0
InNoRoutes: 0
InTooBigErrors: 0
OutFragOKs: 0
OutFragCreates: 0
InMcastPkts: 0
InMcastNotMembers: 0
OutMcastPkts: 0
InAddrErrors: 0
InDiscards: 0
OutDiscards: 0
Table 3 Output description
Physical state of the tunnel interface, which can be: · Administratively DOWN—Indicates that the interface is administratively down; that is, the interface is shut down with the shutdown command. · DOWN—Indicates that the interface is administratively up but its physical state is down. · UP—Indicates that both the administrative and physical states of the interface are up. |
Link layer state of the tunnel interface, which can be · DOWN—Indicates that the protocol state of the interface is down. · UP—Indicates that the protocol state of the interface is up. |
IPv6 is enabled |
IPv6 packet forwarding state of the tunnel interface. IPv6 packet forwarding is automatically enabled after an IPv6 address is assigned to the interface. IPv6 packet forwarding is enabled in the example. |
link-local address |
Link-local address configured for the tunnel interface |
Global unicast address(es) |
Global unicast address(es) configured for the tunnel interface |
Joined group address(es) |
Multicast address(es) of the tunnel interface |
MTU is 1480 bytes |
Maximum transmission unit of the tunnel interface. It is 1480 bytes in the example. |
ND reachable time |
Neighbor reachable time |
ND retransmit interval |
Interval for retransmitting a neighbor solicitation message |
Hosts use stateless autoconfig for addresses |
Hosts use stateless autoconfiguration mode to acquire IPv6 addresses. |
InReceives |
All IPv6 packets received by the tunnel interface, including types of error packets. |
InTooShorts |
Received IPv6 packets that are too short, with a length less than 40 bytes, for example. |
InTruncatedPkts |
Received IPv6 packets with a length less than that specified in the packets |
InHopLimitExceeds |
Received IPv6 packets with a hop count exceeding the limit |
InBadHeaders |
Received IPv6 packets with bad basic headers |
InBadOptions |
Received IPv6 packets with bad extension headers |
ReasmReqds |
Received IPv6 fragments |
ReasmOKs |
Number of packets after reassembly rather than the number of fragments |
InFragDrops |
IPv6 fragments discarded due to certain errors |
InFragTimeouts |
IPv6 fragments discarded because the interval for which they had stayed in the system buffer exceeded the specified period |
OutFragFails |
Packets failed in fragmentation on the outbound interface |
InUnknownProtos |
Received IPv6 packets with unknown or unsupported protocol type |
InDelivers |
Received IPv6 packets that were delivered to application layer protocols (such as ICMPv6, TCP, and UDP) |
OutRequests |
Local IPv6 packets sent by IPv6 application protocols |
OutForwDatagrams |
Packets forwarded by the outbound interface |
InNoRoutes |
IPv6 packets that were discarded because no matched route can be found |
InTooBigErrors |
IPv6 packets that were discarded because they exceeded the PMTU |
OutFragOKs |
Packets that were fragmented on the outbound interface |
OutFragCreates |
Number of packet fragments after fragmentation on the outbound interface |
InMcastPkts |
IPv6 multicast packets received on the interface |
InMcastNotMembers |
Incoming IPv6 multicast packets that were discarded because the interface did not belong to the corresponding multicast groups |
OutMcastPkts |
IPv6 multicast packets sent by the interface |
InAddrErrors |
IPv6 packets that were discarded due to invalid destination addresses |
InDiscards |
Received IPv6 packets that were discarded due to resource problems rather than packet content errors |
OutDiscards |
Sent packets that were discarded due to resource problems rather than packet content errors |
# Display brief IPv6 information for interface Tunnel 0.
<Sysname> display ipv6 interface tunnel 0 brief
*down: administratively down
(s): spoofing
Interface Physical Protocol IPv6 Address
Tunnel0 up up 3000::1
Table 4 Output description
*down |
The tunnel interface is administratively down, that is, the interface is closed by using the shutdown command. |
(s) |
Spoofing attribute of the tunnel interface, that is, the link protocol state of the tunnel interface is up, but the link does not exist, or the link is established on demand, instead of being permanent. |
Name of the tunnel interface |
Physical |
Physical state of the tunnel interface, which can be: · *down—Indicates that the interface is administratively down; that is, the interface is shut down with the shutdown command. · down—Indicates that the interface is administratively up but its physical state is down. · up—ndicates that both the administrative and physical states of the interface are up. |
Protocol |
Link layer protocol state of the tunnel interface, which can be · down—Indicates that the protocol state of the interface is down, which is usually because that no IPv6 address is assigned to the interface. · up—Indicates that the protocol state of the interface is up. |
IPv6 Address |
IPv6 address of the tunnel interface. Only the first of configured IPv6 addresses is displayed. (If no address is configured for the interface, “Unassigned” will be displayed.) |
interface tunnel
undo interface tunnel number
View
Default level
2: System level
number: Number of the tunnel interface, in the range of 0 to 1023.
Use the interface tunnel command to create a tunnel interface and enter its view.
Use the undo interface tunnel command to delete a specific tunnel interface.
By default, no tunnel interface is created on the switch.
Note the following:
· Use the interface tunnel command to enter the interface view of a specific tunnel. If the specified tunnel interface does not exist, the system will create the interface and enter its view.
· A tunnel interface number is only locally significant. Thus, the tunnel interfaces on the two ends of a tunnel can use the same or different interface numbers.
Related commands: display interface tunnel, display ipv6 interface tunnel, source, destination, and tunnel-protocol.
# Create interface Tunnel 3 and enter its view.
[Sysname] interface tunnel 3
[Sysname-Tunnel3]
mtu
mtu mtu-size
undo mtu
View
Default level
2: System level
mtu-size: MTU for IPv4 packets on the interface, in bytes, in the range of 64 to 9174.
Use the mtu command to set the MTU for IPv4 packets on an interface.
Use the undo mtu command to restore the default.
The default MTU for IPv4 packets is 1500.
# Set the MTU for IPv4 packets on interface Tunnel 3 to 2000 bytes.
[Sysname-Tunnel3] mtu 2000
ipv6 mtu
ipv6 mtu mtu-size
undo ipv6 mtu
View
Default level
2: System level
mtu-size: Size of the maximum transmission unit (MTU) of the tunnel interface, in bytes. The value ranges from 1280 to 9174.
Use the ipv6 mtu command to set the IPv6 MTU on the tunnel interface.
Use the undo ipv6 mtu command to restore the default MTU.
By default, the IPv6 MTU on the GRE tunnel interface is 1476, and the IPv6 MTU on other tunnels is 1480 bytes.
# Set the MTU of IPv6 packets on interface Tunnel 0 to 1280 bytes.
[Sysname] interface tunnel 0
[Sysname-Tunnel0] ipv6 mtu 1280
reset counters interface
reset counters interface [ tunnel [ number ] ]
View
Default level
2: System level
number: Tunnel interface number.
Use the reset counters interface command to clear the statistics of tunnel interfaces.
Before sampling network traffic within a specific period of time on an interface, you need to clear the existing statistics.
· If neither the tunnel keyword nor interface number is specified, this command clears the statistics of all interfaces.
· If only the tunnel keyword is specified, this command clears the statistics of all tunnel interfaces.
· If both the tunnel keyword and interface number are specified, this command clears the statistics of the specified tunnel interface.
# Clear the statistics of Tunnel 3.
<Sysname> reset counters interface tunnel 3
shutdown
shutdown
View
Default level
2: System level
None
Use the shutdown command to shut down a tunnel interface.
Use the undo shutdown command to bring up a tunnel interface.
By default, a tunnel interface is in the up state.
# Shut down interface Tunnel 1.
[Sysname-Tunnel1] shutdown
source
source { ip-address | interface-type interface-number }
undo source
View
Default level
2: System level
ip-address: Tunnel source IPv4 address.
interface-type interface-number: Specifies a Tunnel interface by its type and number. The interface types include tunnel and VLAN interface.
Use the source command to specify the source address or interface of the tunnel interface.
Use the undo source command to remove the configured source address or interface of the tunnel interface.
By default, no source address or interface is specified for the tunnel interface.
Note the following:
· The tunnel source address is the address of the interface sending packets and should be configured as the destination address of the peer tunnel interface.
· Automatic tunnel interfaces using the same encapsulation protocol must have different source addresses. Manual tunnel interfaces using the same encapsulation protocol must have different source and destination addresses.
Related commands: destination, interface tunnel, display interface tunnel, and display ipv6 interface tunnel.
# Set the tunnel source address to 192.100.1.1 (or the interface VLAN-interface 100) on Tunnel 0.
[Sysname-Tunnel0] source 192.100.1.1
Or
[Sysname-Tunnel0] source vlan-interface 100
tunnel bandwidth
tunnel bandwidth bandwidth-value
undo tunnel bandwidth
View
Default level
2: System level
bandwidth-value: Bandwidth value of the tunnel interface in kbps, in the range of 1 to 10000000.
Use the tunnel bandwidth command to set the bandiwith value of the tunnel interface.
Use the undo tunnel bandwidth command to restore the default.
By default, the bandwidth of the tunnel interface is 64 kbps.
The tunnel interface bandwidth set with the tunnel bandwidth command is for dynamical routing protocols to calculate the cost of a tunnel path, rather than changes the bandwidth of the tunnel interface. Refer to the bandwidth of the output interface of the packet when you set the bandwidth of the tunnel interface.
# Configure the bandwidth of Tunnel 0 as 100 kbps.
[Sysname-Tunnel0] tunnel bandwidth 100
tunnel-protocol
tunnel-protocol [ ipv6-ipv4 [ 6to4 | auto-tunnel | isatap ] | gre | mpls te ]
undo tunnel-protocol
View
Default level
2: System level
ipv6-ipv4: Specifies the IPv6 over IPv4 manual tunnel mode.
6to4: Specifies the 6to4 tunnel mode.
auto-tunnel: Specifies the automatic tunnel mode.
isatap: Specifies the ISATAP tunnel mode.
gre: Specifies the GRE over IPv4 tunnel mode.
mpls te: Specifies the MPLS TE tunnel mode.
Use the tunnel-protocol command to specify the tunnel mode for the tunnel interface.
Use the undo tunnel-protocol command to restore the default.
By default, the GRE over IPv4 tunnel mode is used.
Note the following:
· You can select a tunnel mode according to the actual network topology and application. The two ends of a tunnel must have the same tunnel mode specified, or traffic transmission may fail.
· Only one automatic tunnel can be created at the start point of a tunnel.
# Specify the Ipv6 over IPv4 tunnel mode for interface Tunnel 1.
[Sysname-Tunnel1] tunnel-protocol ipv6-ipv4
