- 06-Layer 3 - IP Services Command Reference
- 01-ARP Commands
- 02-IP Addressing Commands
- 03-DHCP Commands
- 04-DNS Commands
- 05-NAT Commands
- 06-IP Forwarding Basics Commands
- 07-Adjacency Table Commands
- 08-IP Performance Optimization Commands
- 09-UDP Helper Commands
- 10-IPv6 Basics Commands
- 11-DHCPv6 Commands
- 12-IPv6 DNS Commands
- 13-Tunneling Commands
| 08-IP Performance Optimization Commands | 125.26 KB |
NOTE: The switch supports two operation modes: standalone (default) and IRF. For more information about IRF mode, see IRF Configuration Guide. |
display icmp statistics
Standalone mode:
display icmp statistics [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display icmp statistics [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
slot slot-number: Displays the ICMP statistics on a card specified by the slot number. (Standalone mode)
chassis chassis-number slot slot-number: Displays the ICMP statistics of a card on an IRF member switch. The chassis-number argument takes the ID of the IRF member switch. The slot-number argument specifies the number of the slot where the card resides. (IRF mode)
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display icmp statistics command to display ICMP statistics.
Related commands: display ip interface and reset ip statistics.
# Display ICMP statistics.
<Sysname> display icmp statistics
Input: bad formats 0 bad checksum 0
echo 5 destination unreachable 0
source quench 0 redirects 0
echo reply 10 parameter problem 0
timestamp 0 information request 0
mask requests 0 mask replies 0
time exceeded 0
Output:echo 10 destination unreachable 0
echo reply 5 parameter problem 0
timestamp 0 information reply 0
time exceeded 0
Table 1 Output description
bad formats |
Number of input wrong format packets |
bad checksum |
Number of input wrong checksum packets |
echo |
Number of input/output echo packets |
destination unreachable |
Number of input/output destination unreachable packets |
source quench |
Number of input/output source quench packets |
redirects |
Number of input/output redirection packets |
echo reply |
Number of input/output replies |
parameter problem |
Number of input/output parameter problem packets |
timestamp |
Number of input/output time stamp packets |
information request |
Number of input information request packets |
mask requests |
Number of input/output mask requests |
mask replies |
Number of input/output mask replies |
information reply |
Number of output information reply packets |
time exceeded |
Number of input/output expiration packets |
display ip socket
Standalone mode:
display ip socket [ socktype sock-type ] [ task-id socket-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display ip socket [ socktype sock-type ] [ task-id socket-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
socktype sock-type: Displays the socket information of this type. The sock type is in the range of 1 to 3, corresponding to TCP, UDP and raw IP respectively.
task-id: Displays the socket information of this task. Task ID is in the range of 1 to 180.
socket-id: Displays the information of the socket. Socket ID is in the range of 0 to 3072.
slot slot-number: Displays the socket information of the specified card. (Standalone mode)
chassis chassis-number slot slot-number: Displays the socket information of a card on an IRF member device. The chassis-number argument refers to the ID of the IRF member device. The slot-number argument refers to the number of the slot where the card resides. (IRF mode)
Use the display ip socket command to display socket information.
# Display the TCP socket information.
<Sysname> display ip socket
SOCK_STREAM:
Task = VTYD(38), socketid = 1, Proto = 6,
LA = 0.0.0.0:23, FA = 0.0.0.0:0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
sb_maxcc = 0, rb_maxcc = 0,
socket option = SO_ACCEPTCONN SO_KEEPALIVE SO_REUSEPORT SO_SENDVPNID(3073) SO_SETKEEPALIVE,
socket state = SS_PRIV SS_ASYNC
Task = HTTP(36), socketid = 1, Proto = 6,
LA = 0.0.0.0:80, FA = 0.0.0.0:0,
socket option = SO_ACCEPTCONN SO_REUSEPORT,
socket state = SS_PRIV SS_NBIO
Task = ROUT(69), socketid = 10, Proto = 6,
LA = 0.0.0.0:179, FA = 192.168.1.45:0,
socket option = SO_ACCEPTCONN SO_REUSEADDR SO_REUSEPORT SO_SENDVPNID(0),
Task = VTYD(38), socketid = 4, Proto = 6,
LA = 192.168.1.40:23, FA = 192.168.1.52:1917,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 237, rb_cc = 0,
socket option = SO_KEEPALIVE SO_OOBINLINE SO_REUSEPORT SO_SENDVPNID(0) SO_SETKEEPALIVE,
socket state = SS_ISCONNECTED SS_PRIV SS_ASYNC
Task = VTYD(38), socketid = 3, Proto = 6,
LA = 192.168.1.40:23, FA = 192.168.1.84:1503,
Task = ROUT(69), socketid = 11, Proto = 6,
LA = 192.168.1.40:1025, FA = 192.168.1.45:179,
socket option = SO_REUSEADDR SO_LINGER SO_SENDVPNID(0),
SOCK_DGRAM:
Task = NTPT(37), socketid = 1, Proto = 17,
LA = 0.0.0.0:123, FA = 0.0.0.0:0,
sndbuf = 9216, rcvbuf = 41600, sb_cc = 0, rb_cc = 0,
socket option = SO_UDPCHECKSUM SO_SENDVPNID(3073),
Task = AGNT(51), socketid = 1, Proto = 17,
LA = 0.0.0.0:161, FA = 0.0.0.0:0,
socket state = SS_PRIV SS_NBIO SS_ASYNC
Task = RDSO(56), socketid = 1, Proto = 17,
LA = 0.0.0.0:1024, FA = 0.0.0.0:0,
socket option = SO_UDPCHECKSUM,
Task = TRAP(52), socketid = 1, Proto = 17,
LA = 0.0.0.0:1025, FA = 0.0.0.0:0,
sndbuf = 9216, rcvbuf = 0, sb_cc = 0, rb_cc = 0,
Task = RDSO(56), socketid = 2, Proto = 17,
LA = 0.0.0.0:1812, FA = 0.0.0.0:0,
SOCK_RAW:
Task = ROUT(69), socketid = 8, Proto = 89,
LA = 0.0.0.0, FA = 0.0.0.0,
sndbuf = 262144, rcvbuf = 262144, sb_cc = 0, rb_cc = 0,
socket option = SO_SENDVPNID(0) SO_RCVVPNID(0),
Task = ROUT(69), socketid = 3, Proto = 2,
sndbuf = 32767, rcvbuf = 256000, sb_cc = 0, rb_cc = 0,
Task = ROUT(69), socketid = 2, Proto = 103,
sndbuf = 65536, rcvbuf = 256000, sb_cc = 0, rb_cc = 0,
Task = ROUT(69), socketid = 1, Proto = 65,
socket option = 0,
Task = RSVP(73), socketid = 1, Proto = 46,
sndbuf = 4194304, rcvbuf = 4194304, sb_cc = 0, rb_cc = 0,
socket option = 0,
Table 2 Output description
SOCK_STREAM |
TCP socket |
SOCK_DGRAM |
UDP socket |
SOCK_RAW |
Raw IP socket |
Task |
Task number |
socketid |
Socket ID |
Proto |
Protocol number of the socket, indicating the protocol type that IP carries |
LA |
Local address and local port number |
FA |
Remote address and remote port number |
sndbuf |
Sending buffer size of the socket, in bytes |
rcvbuf |
Receiving buffer size of the socket, in bytes |
sb_cc |
Current data size in the sending buffer (It is available only for TCP that can buffer data) |
rb_cc |
Data size currently in the receiving buffer |
socket option |
Socket option |
sb_maxcc |
Historical maximum of data size in the sending buffer |
rb_maxcc |
Historical maximum of data size in the receiving buffer |
socket state |
Socket state |
display ip statistics
Standalone mode:
display ip statistics [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display ip statistics [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
slot slot-number: Displays statistics of IP packets on the specified slot. (Standalone mode)
chassis chassis-number slot slot-number: Displays the IP packet statistics of a card on an IRF member device. The chassis-number argument refers to the ID of the IRF member device. The slot-number argument refers to the number of the slot where the card resides. (IRF mode)
Use the display ip statistics command to display statistics of IP packets.
# Display statistics of IP packets.
<Sysname> display ip statistics
Input: sum 7120 local 112
bad protocol 0 bad format 0
bad checksum 0 bad options 0
Output: forwarding 0 local 27
dropped 0 no route 2
compress fails 0
Fragment:input 0 output 0
dropped 0
fragmented 0 couldn't fragment 0
Reassembling:sum 0 timeouts 0
Table 3 Output description
Input |
sum |
Total number of packets received |
local |
Total number of packets with destination being local |
bad protocol |
Total number of unknown protocol packets |
bad format |
Total number of packets with incorrect format |
bad checksum |
Total number of packets with incorrect checksum |
bad options |
Total number of packets with incorrect option |
Output |
forwarding |
Total number of packets forwarded |
local |
Total number of packets sent from the local |
dropped |
Total number of packets discarded |
no route |
Total number of packets for which no route is available |
compress fails |
Total number of packets failed to be compressed |
Fragment |
input |
Total number of fragments received |
output |
Total number of fragments sent |
dropped |
Total number of fragments dropped |
fragmented |
Total number of packets successfully fragmented |
couldn't fragment |
Total number of packets that failed to be fragmented |
Reassembling |
sum |
Total number of packets reassembled |
timeouts |
Total number of reassembly timeout fragments |
display tcp statistics
display tcp statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display tcp statistics command to display statistics of TCP traffic.
Related commands: display tcp status and reset tcp statistics.
# Display statistics of TCP traffic.
<Sysname> display tcp statistics
Received packets:
Total: 8457
packets in sequence: 3660 (5272 bytes)
window probe packets: 0, window update packets: 0
checksum error: 0, offset error: 0, short error: 0
duplicate packets: 1 (8 bytes), partially duplicate packets: 0 (0 bytes)
out-of-order packets: 17 (0 bytes)
packets of data after window: 0 (0 bytes)
packets received after close: 0
ACK packets: 4625 (141989 bytes)
duplicate ACK packets: 1702, too much ACK packets: 0
Sent packets:
Total: 6726
urgent packets: 0
control packets: 21 (including 0 RST)
data packets: 6484 (141984 bytes) data packets retransmitted: 0 (0 bytes)
ACK-only packets: 221 (177 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 1682, keepalive probe: 1682, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 22, established connections: 22
Closed connections: 49 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
Table 4 Output description
Received packets |
Total |
packets in sequence |
Number of packets arriving in sequence |
window probe packets |
Number of window probe packets received |
window update packets |
Number of window update packets received |
checksum error |
Number of checksum error packets received |
offset error |
Number of offset error packets received |
short error |
Number of received packets with length being too small |
duplicate packets |
Number of completely duplicate packets received |
partially duplicate packets |
Number of partially duplicate packets received |
out-of-order packets |
Number of out-of-order packets received |
packets of data after window |
Number of packets outside the receiving window |
packets received after close |
Number of packets that arrived after connection is closed |
ACK packets |
Number of ACK packets received |
duplicate ACK packets |
Number of duplicate ACK packets received |
too much ACK packets |
Number of ACK packets for data unsent |
Sent packets |
Total |
Total number of packets sent |
urgent packets |
Number of urgent packets sent |
control packets |
Number of control packets sent |
Number of window probe packets sent; in the brackets are resent packets |
Number of window update packets sent |
data packets |
Number of data packets sent |
data packets retransmitted |
Number of data packets retransmitted |
ACK-only packets |
Number of ACK packets sent; in brackets are delayed ACK packets |
Retransmitted timeout |
Number of retransmission timer timeouts |
connections dropped in retransmitted timeout |
Number of connections broken due to retransmission timeouts |
Keepalive timeout |
Number of keepalive timer timeouts |
keepalive probe |
Number of keepalive probe packets sent |
Keepalive timeout, so connections disconnected |
Number of connections broken due to timeout of the keepalive timer |
Initiated connections |
Number of connections initiated |
accepted connections |
Number of connections accepted |
established connections |
Number of connections established |
Closed connections |
Number of connections closed; in brackets are connections closed accidentally (before receiving SYN from the peer) and connections closed initiatively (after receiving SYN from the peer) |
Packets dropped with MD5 authentication |
Number of packets dropped by MD5 authentication |
Packets permitted with MD5 authentication |
Number of packets permitted by MD5 authentication |
display udp statistics
display udp statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display udp statistics command to display statistics of UDP packets.
Related commands: reset udp statistics.
# Display statistics of UDP packets.
<Sysname> display udp statistics
Received packets:
Total: 0
checksum error: 0
shorter than header: 0, data length larger than packet: 0
unicast(no socket on port): 0
broadcast/multicast(no socket on port): 0
not delivered, input socket full: 0
input packets missing pcb cache: 0
Sent packets:
Total: 0
Table 5 Output description
Received packets |
Total |
Total number of UDP packets received |
checksum error |
shorter than header |
Number of packets with data shorter than head |
data length larger than packet |
Number of packets with data longer than packet |
unicast(no socket on port) |
Number of unicast packets with no socket on port |
broadcast/multicast(no socket on port) |
Number of broadcast/multicast packets without socket on port |
not delivered, input socket full |
Number of packets not delivered to an upper layer due to a full socket cache |
input packets missing pcb cache |
Number of packets without matching protocol control block (PCB) cache |
Sent packets |
Total |
Total number of UDP packets sent |
ip forward-broadcast
ip forward-broadcast [ acl acl-number ]
undo ip forward-broadcast
View
Interface view
Default level
2: System level
acl acl-number: Access control list number. Only directed broadcasts permitted by the ACL can be forwarded. This option is not supported by the switch.
Use the ip forward-broadcast command to enable the interface to forward directed broadcasts to a directly-connected network.
Use the undo ip forward-broadcast command to disable the interface from forwarding directed broadcasts to a directly-connected network.
By default, an interface is disabled from forwarding directed broadcasts to a directly-connected network.
CAUTION: · You can enable forwarding of directed broadcasts on the VLAN interface only. Although you can enable this feature on a Super-VLAN interface, the switch cannot forward directed broadcasts. · After this feature is enabled on an interface, the switch automatically generates a forwarding entry for the network segment where the interface is located. H3C does not recommend configuring a static ARP entry or a static route for the corresponding network segment. For example, if an interface on network segment 10.0.0.1/24 has this feature enabled, the switch generates a forwarding entry of 10.0.0.255/32. If a static ARP entry for 10.0.0.255 is configured, a configuration conflict occurs and logs may be generated. If such a conflict occurs, you must delete both the static ARP entry and the directed broadcast configuration, and reconfigure forwarding of directed broadcasts or a static ARP entry. After that, the service resumes. · The link status and protocol status of the interface must be up for it to forward directed broadcasts. |
# Allow VLAN-interface 2 to forward directed broadcasts.
[Sysname-Vlan-interface2] ip forward-broadcast
ip icmp flow-control
undo ip icmp flow-control
View
Default level
2: System level
None
Use the ip icmp flow-control command to enable ICMP flow control.
Use the undo ip icmp flow-control command to disable ICMP flow control.
By default, ICMP flow control is disabled.
# Enable ICMP flow control.
[Sysname] ip icmp flow-control
ip icmp-extensions
ip icmp-extensions { compliant | non-compliant }
undo ip icmp-extensions
View
Default level
2: System level
compliant: Specifies the compliant mode.
non-compliant: Specifies the non-compliant mode.
Use the ip icmp-extensions command to enable support for ICMP extensions.
Use the undo ip icmp-extensions command to disable support for ICMP extensions.
By default, ICMP extensions are not supported.
# Enable support for ICMP extensions in compliant mode.
[Sysname] ip icmp-extensions compliant
ip redirects enable
ip redirects enable
undo ip redirects
View
Default level
2: System level
None
Use the ip redirects enable command to enable sending of ICMP redirection packets.
Use the undo ip redirects command to disable sending of ICMP redirection packets.
This feature is disabled by default.
NOTE: You can configure this command only on the VLAN interfaces of an Ethernet interface card. |
# Enable sending of ICMP redirect packets.
[Sysname] ip redirects enable
ip ttl-expires enable
undo ip ttl-expires
View
Default level
2: System level
None
Use the ip ttl-expires enable command to enable sending of ICMP timeout packets, and allow sending packets whose TTL value is 1 to CPU.
Use the undo ip ttl-expires command to disable sending ICMP timeout packets, and enable dropping packets whose TTL value is 1.
By default, the switch is disabled from sending ICMP timeout packets and discards packets with a TTL of 1.
If the feature is disabled, the switch will not send TTL timeout ICMP packets, but still send “reassembly timeout” ICMP packets.
# Enable sending of ICMP timeout packets.
[Sysname] ip ttl-expires enable
reset ip statistics
In standalone mode:
In IRF mode:
reset ip statistics [ chassis chassis-number slot slot-number ]
View
Default level
2: System level
slot slot-number: Clears IP packet statistics on the specified slot. (In standalone mode)
chassis chassis-number slot slot-number: Clears the IP packet statistics on the specified card of the specified member device. The argument chassis-number refers to the ID of the IRF member device. The argument slot-number refers to the slot number of the specified card. (In IRF mode)
Use the reset ip statistics command to clear statistics of IP packets.
Related commands: display ip interface (see the chapter “IP addressing configuration commands”) and display ip statistics.
# Clear statistics of IP packets.
<Sysname> reset ip statistics
View
Default level
2: System level
None
Use the reset tcp statistics command to clear statistics of TCP traffic.
Related commands: display tcp statistics.
<Sysname> reset tcp statistics
View
Default level
2: System level
None
Use the reset udp statistics command to clear statistics of UDP traffic.
# Display statistics of UDP traffic.
<Sysname> reset udp statistics
tcp timer fin-timeout
undo tcp timer fin-timeout
View
Default level
2: System level
time-value: Length of the TCP finwait timer in seconds, in the range of 76 to 3,600.
Use the tcp timer fin-timeout command to configure the length of the TCP finwait timer.
Use the undo tcp timer fin-timeout command to restore the default.
By default, the length of the TCP finwait timer is 675 seconds.
The actual length of the finwait timer is determined by the following formula:
Actual length of the finwait timer = (Configured length of the finwait timer – 75) + configured length of the synwait timer
Related commands: tcp timer syn-timeout and tcp window.
# Set the length of the TCP finwait timer to 800 seconds.
[Sysname] tcp timer fin-timeout 800
undo tcp timer syn-timeout
View
Default level
2: System level
time-value: Length of the TCP finwait timer in seconds, in the range of 2 to 600.
Use the tcp timer syn-timeout command to configure the length of the TCP synwait timer.
Use the undo tcp timer syn-timeout command to restore the default.
By default, the value of the TCP synwait timer is 75 seconds.
Related commands: tcp timer fin-timeout and tcp window.
# Set the length of the TCP synwait timer to 80 seconds.
[Sysname] tcp timer syn-timeout 80
tcp window
tcp window window-size
undo tcp window
View
Default level
2: System level
window-size: Size of the send/receive buffer in KB, in the range of 1 to 32.
Use the tcp window command to configure the size of the TCP send/receive buffer.
Use the undo tcp window command to restore the default.
The size of the TCP send/receive buffer is 8 KB by default.
Related commands: tcp timer fin-timeout and tcp timer syn-timeout.
# Configure the receiving/sending buffer of TCP connection as 3 KB.
[Sysname] tcp window 3
