- 06-Layer 3 - IP Services Command Reference
- 01-ARP Commands
- 02-IP Addressing Commands
- 03-DHCP Commands
- 04-DNS Commands
- 05-NAT Commands
- 06-IP Forwarding Basics Commands
- 07-Adjacency Table Commands
- 08-IP Performance Optimization Commands
- 09-UDP Helper Commands
- 10-IPv6 Basics Commands
- 11-DHCPv6 Commands
- 12-IPv6 DNS Commands
- 13-Tunneling Commands
| 01-ARP Commands | 118.61 KB |
Gratuitous ARP configuration commands
gratuitous-arp-learning enable
Proxy ARP configuration commands
NOTE: The switch supports two operation modes: standalone (default) and IRF. For more information about IRF mode, see IRF Configuration Guide. |
arp check enable
arp check enable
undo arp check enable
View
Default level
2: System level
None
Use the arp check enable command to enable dynamic ARP entry check.
Use the undo arp check enable command to disable dynamic ARP entry check.
By default, ARP entry check is enabled.
# Enable dynamic ARP entry check.
[Sysname] arp check enable
arp max-learning-num
arp max-learning-num number
undo arp max-learning-num
View
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view, Layer 3 Ethernet subinterface view, VLAN interface view, Layer 2 aggregate interface view, Layer 3 aggregate interface view, Layer 3 aggregate subinterface view
Default level
2: System level
number: Maximum number of dynamic ARP entries that an interface can learn.
Use the arp max-learning-num command to configure the maximum number of dynamic ARP entries that an interface can learn.
Use the undo arp max-learning-num command to restore the default number of dynamic ARP entries.
By default, the maximum number of dynamic ARP entries that an interface can learn is the maximum remaining resource of the switch.
When the number argument is set to 0, the interface is disabled from learning dynamic ARP entries.
# Specify VLAN-interface 40 to learn up to 500 dynamic ARP entries.
[Sysname] interface vlan-interface 40
[Sysname-Vlan-interface40] arp max-learning-num 500
# Specify GigabitEthernet 3/0/1 to learn up to 1000 dynamic ARP entries.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] arp max-learning-num 1000
# Specify Layer 2 aggregate interface Bridge-aggregation 1 to learn up to 1000 dynamic ARP entries.
[Sysname-Bridge-Aggregation1] arp max-learning-num 1000
# Specify Layer 3 aggregate interface Route-aggregation 1 to learn up to 1000 dynamic ARP entries.
[Sysname-Route-Aggregation1] arp max-learning-num 1000
arp static
arp static ip-address mac-address [ vlan-id interface-type interface-number ] [ vpn-instance vpn-instance-name ]
undo arp ip-address [ vpn-instance-name ]
View
Default level
2: System level
ip-address: IP address in an ARP entry.
mac-address: MAC address in an ARP entry, in the format H-H-H.
vlan-id: ID of a VLAN to which a static ARP entry belongs to, in the range 1 to 4094.
interface-type interface-number: Interface type and interface number.
vpn-instance vpn-instance-name: Specifies the VPN where a static ARP entry resides. The vpn-instance-name argument specifies the VPN instance name, a case-sensitive string of 1 to 31 characters. Without this argument, the static ARP entry resides on the public network.
Use the arp static command to configure a static ARP entry in the ARP mapping table.
Use the undo arp command to remove an ARP entry.
Note the following:
· A static ARP entry is effective when the switch works normally. However, when the VLAN or VLAN interface to which an ARP entry corresponds is deleted, the entry, if long, will be deleted, and if short and resolved, will become unresolved.
· The vlan-id argument is used to specify the VLAN of an ARP entry and must be the ID of an existing VLAN. In addition, the Ethernet interface following the argument must belong to that VLAN. The VLAN interface of the VLAN must have been created.
· If both the vlan-id and ip-address arguments are specified, the IP address of the VLAN interface corresponding to the vlan-id argument must be in the same network segment as the IP address specified by the ip-address argument.
Related commands: reset arp and display arp.
# Configure a static ARP entry, with the IP address 202.38.10.2, MAC address 00e0-fc01-0000, and outbound interface GigabitEthernet 3/0/1 of VLAN 10.
[Sysname] arp static 202.38.10.2 00e0-fc01-0000 10 GigabitEthernet 3/0/1
arp timer aging
arp timer aging aging-time
undo arp timer aging
View
Default level
2: System level
aging-time: Age timer for dynamic ARP entries in minutes, in the range of 1 to 1,440.
Use the arp timer aging command to set age timer for dynamic ARP entries.
Use the undo arp timer aging command to restore the default.
By default, the age timer for dynamic ARP entries is 20 minutes.
Related commands: display arp timer aging.
# Set the age timer for dynamic ARP entries to 10 minutes.
display arp
Standalone mode:
display arp [ [ all | dynamic | static ] [ slot slot-number ] | vlan vlan-id | interface interface-type interface-number ] [ [ verbose ] [ | { begin | exclude | include } regular-expression ] | count ]
IRF mode:
display arp [ [ all | dynamic | static ] [ chassis chassis-number slot slot-number ] | vlan vlan-id | interface interface-type interface-number ] [ [ verbose ] [ | { begin | exclude | include } regular-expression ] | count ]
View
Default level
1: Monitor level
all: Displays all ARP entries.
dynamic: Displays dynamic ARP entries.
static: Displays static ARP entries.
slot slot-number: Displays the ARP entries for the interface card specified by the slot number. (Standalone mode)
chassis chassis-number slot slot-number: Displays the ARP entries of a card on an IRF member switch. The chassis-number argument specifies the ID of the IRF member switch. The slot-number argument specifies the number of the slot where the card resides, which you can display with the display device command. (IRF mode)
vlan vlan-id: Displays the ARP entries of the specified VLAN. The value ranges from 1 to 4,094.
interface interface-type interface-number: Displays the ARP entries of the interface specified by the argument interface-type interface-number.
verbose: Displays detailed information about ARP entries.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression,a case-sensitive string of 1 to 256 characters.
count: Displays the number of ARP entries.
Use the display arp command to display ARP entries in the ARP mapping table.
If no parameter is specified, all ARP entries are displayed.
Related commands: arp static and reset arp.
# Display the detailed information of all ARP entries.
<Sysname> display arp all verbose
Type: S-Static D-Dynamic A-Authorized M-Multiport
IP Address MAC Address VLAN ID Interface Aging Type
Vpn-instance Name
192.168.1.250 0015-e943-9fc9 100 GE3/0/18 18 D
[No Vrf]
192.168.2.222 00e0-fc00-1601 1000 GE3/0/19 20 D
[No Vrf]
192.168.1.1 00e0-fc01-0000 N/A N/A N/A M
[No Vrf]
Table 1 Output description
IP Address |
IP address in an ARP entry |
MAC Address |
MAC address in an ARP entry |
VLAN ID |
VLAN ID contained a static ARP entry |
Outbound interface in an ARP entry |
Aging |
Age timer for a dynamic ARP entry in minutes (DIS or N/A indicates that the agie timer is unknown or there is no age timer) |
Type |
ARP entry type: · D for dynamic · S for static · A for authorized · M for multiple ports |
Vpn-instance Name |
Name of VPN instance. [No Vrf] indicates that no VPN instance is configured for the ARP entry. |
# Display the number of all ARP entries.
<Sysname> display arp all count
Total Entry(ies): 5
display arp ip-address
Standalone mode:
display arp ip-address [ slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display arp ip-address [ chassis chassis-number slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: Displays the ARP entry for the specified IP address.
verbose: Displays the detailed information about ARP entries.
Use the display arp ip-address command to display the ARP entry for a specified IP address.
# Display the ARP entry for the IP address 20.1.1.1.
<Sysname> display arp 20.1.1.1
20.1.1.1 00e0-fc00-0001 N/A N/A N/A S
display arp timer aging [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display arp timer aging command to display the age timer for dynamic ARP entries.
Related commands: arp timer aging.
# Display the age timer for dynamic ARP entries.
<Sysname> display arp timer aging
Current ARP aging time is 10 minute(s)
display arp vpn-instance
display arp vpn-instance vpn-instance-name [ count ] [ | { begin | exclude | include } regular-expression | count ]
View
Default level
1: Monitor level
vpn-instance-name: Specifies the name of a MPLS L3 VPN, a case-sensitive string of 1 to 31 characters.
Use the display arp vpn-instance command to display the ARP entries for a specified VPN instance.
# Display ARP entries for the VPN instance named test.
<Sysname> display arp vpn-instance test
naturemask-arp enable
undo naturemask-arp enable
View
Default level
2: System level
None
Use the naturemask-arp enable command to enable the support for ARP requests that are from a natural network.
Use the undo naturemask-arp enable command to restore the default.
By default, the support for ARP requests from a natural network is disabled.
# Enable the support for ARP requests from a natural network.
[Sysname] naturemask-arp enable
reset arp
Standalone mode:
reset arp { all | dynamic | static | slot slot-number | interface interface-type interface-number }
IRF mode:
reset arp { all | dynamic | static | chassis chassis-number slot slot-number | interface interface-type interface-number }
View
Default level
2: System level
all: Clears all ARP entries except authorized ARP entries.
dynamic: Clears all dynamic ARP entries.
static: Clears all static ARP entries.
slot slot-number: Clears the ARP entries for the interface card specified by the slot number. (Standalone mode)
chassis chassis-number slot slot-number: Clears the ARP entries of a card on an IRF member switch. The chassis-number argument specifies the ID of the IRF member switch. The slot-number argument specifies the number of the slot where the card resides, which you can display with the display device command. (IRF mode)
interface interface-type interface-number: Clears the ARP entries for the interface specified by the argument interface-type interface-number.
Use the reset arp command to clear ARP entries except authorized ARP entries from the ARP mapping table.
Note the following:
· With an interface specified, the command clears only dynamic ARP entries of the interface.
· With an interface card specified, the command clears only dynamic ARP entries of the card.
Related commands: arp static and display arp.
# Clear all static ARP entries.
<Sysname> reset arp static
undo gratuitous-arp-learning enable
View
Default level
2: System level
None
Use the gratuitous-arp-learning enable command to enable the gratuitous ARP packet learning function.
Use the undo gratuitous-arp-learning enable command to disable the function.
By default, gratuitous ARP packet learning is enabled.
With this function enabled, a device creates a dynamic ARP entry by using the sender IP and MAC addresses in a received gratuitous ARP packet if no matching ARP entry exists. If a matching ARP entry exists, the device updates the ARP entry regardless of whether this function is enabled.
# Enable the gratuitous ARP packet learning function.
[Sysname] gratuitous-arp-learning enable
gratuitous-arp-sending enable
undo gratuitous-arp-sending enable
View
Default level
2: System level
None
Use the gratuitous-arp-sending enable command to enable a switch to send gratuitous ARP packets when receiving ARP requests from another network segment.
Use the undo gratuitous-arp-sending enable command to restore the default.
By default, a switch cannot send gratuitous ARP packets when receiving ARP requests from another network segment.
# Disable a switch from sending gratuitous ARP packets.
[Sysname] undo gratuitous-arp-sending enable
display local-proxy-arp
display local-proxy-arp [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
interface interface-type interface-number: Displays the local proxy ARP status of the interface specified by the argument interface-type interface-number.
Use the display local-proxy-arp command to display the status of the local proxy ARP.
If an interface is specified, the local proxy ARP status of the specified interface is displayed. If no interface is specified, the local proxy ARP status of all interfaces is displayed.
Related commands: local-proxy-arp enable.
# Display the status of the local proxy ARP on VLAN-interface 2.
<Sysname> display local-proxy-arp interface vlan-interface 2
Interface Vlan-interface2
Local Proxy ARP status: enabled
display proxy-arp
display proxy-arp [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
interface interface-type interface-number: Displays the proxy ARP status of the interface specified by the argument interface-type interface-number.
Use the display proxy-arp command to display the proxy ARP status.
If an interface is specified, proxy ARP status of the specified interface is displayed. If no interface is specified, proxy ARP status of all interfaces is displayed.
Related commands: proxy-arp enable.
# Display the proxy ARP status on VLAN-interface 2.
[Sysname] display local-proxy-arp interface Vlan-interface 2
Local Proxy ARP status: disabled
local-proxy-arp enable [ ip-range startIP to endIP ]
undo local-proxy-arp enable
View
VLAN interface view, Layer 3 Ethernet interface view, Layer 3 Ethernet subinterface view, Layer 3 aggregate interface view, Layer 3 aggregate subinterface view
Default level
2: System level
ip-range startIP to endIP: Specifies the IP address range for which local proxy ARP is enabled. The start IP address must be lower than or equal to the end IP address.
Use the local-proxy-arp enable command to enable local proxy ARP.
Use the undo local-proxy-arp enable command to disable local proxy ARP.
By default, local proxy ARP is disabled.
Only one IP address range can be specified by using the ip-range keyword on an interface.
Related commands: display local-proxy-arp.
# Enable local proxy ARP on VLAN-interface 2.
[Sysname-Vlan-interface2] local-proxy-arp enable
# Enable local proxy ARP on VLAN-interface 2 for a specified IP address range.
[Sysname-Vlan-interface2] local-proxy-arp enable ip-range 1.1.1.1 to 1.1.1.20
proxy-arp enable
proxy-arp enable
undo proxy-arp enable
View
Default level
2: System level
None
Use the proxy-arp enable command to enable proxy ARP.
Use the undo proxy-arp enable command to disable proxy ARP.
By default, proxy ARP is disabled.
Related commands: display proxy-arp.
# Enable proxy ARP on VLAN-interface 2.
