- 06-Layer 3 - IP Services Command Reference
- 01-ARP Commands
- 02-IP Addressing Commands
- 03-DHCP Commands
- 04-DNS Commands
- 05-NAT Commands
- 06-IP Forwarding Basics Commands
- 07-Adjacency Table Commands
- 08-IP Performance Optimization Commands
- 09-UDP Helper Commands
- 10-IPv6 Basics Commands
- 11-DHCPv6 Commands
- 12-IPv6 DNS Commands
- 13-Tunneling Commands
| 12-IPv6 DNS Commands | 61.66 KB |
display dns ipv6 server
display dns ipv6 server [ dynamic ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
dynamic: Displays IPv6 DNS server information acquired dynamically through DHCP or other protocols.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display dns ipv6 server command to display IPv6 DNS server information.
# Display IPv6 DNS server information.
<Sysname> display dns ipv6 server
Type:
D:Dynamic S:Static
DNS Server Type IPv6 Address (Interface Name)
1 S 1::1
2 S FE80::1 Vlan999
Table 1 Output description
DNS Server |
Sequence number of the DNS server, which is assigned automatically by the system, starting from 1. |
Type |
Type of the DNS server: “S” represents a statically configured DNS server, and “D” represents a DNS server obtained dynamically through DHCP or other protocols. |
IPv6 Address |
IPv6 address of the DNS server |
Interface Name |
Interface name, which is available only for a DNS server with an IPv6 link-local address configured. |
display ipv6 host
display ipv6 host [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ipv6 host command to display the mappings between host names and IPv6 addresses in the static domain name resolution table.
Related commands: ipv6 host.
# Display the mappings between host names and IPv6 addresses in the static domain name resolution table.
<Sysname> display ipv6 host
Host Age Flags IPv6Address
aaa 0 static 2002::1
bbb 0 static 2002::2
Table 2 Output description
Host |
Host name |
Age |
Time for the entry to live. “0” is displayed in the case of static configuration. |
Flags |
Type of the mapping. Static indicates a static mapping. |
IPv6Address |
IPv6 address of a host |
dns server ipv6
dns server ipv6 ipv6-address [ interface-type interface-number ]
undo dns server ipv6 ipv6-address [ interface-type interface-number ]
View
Default level
2: System level
ipv6-address: IPv6 address of a DNS server.
interface-type interface-number: Specifies an interface. When the IPv6 address of the DNS server is a link-local address, the two arguments must be specified.
Use the dns server ipv6 command to specify a DNS server.
Use the undo dns server ipv6 command to remove the specified DNS server.
By default, no DNS server is configured.
You can configure a maximum of six DNS servers, including those with IPv4 addresses.
# Specify a DNS server at 2002::1.
[Sysname] dns server ipv6 2002::1
ipv6 host
ipv6 host hostname ipv6-address
undo ipv6 host hostname [ ipv6-address ]
View
Default level
2: System level
hostname: Host name, a string of up to 255 characters. The character string can contain letters, numbers, underscores (_), hyphens (-), or dots (.) and must contain at least one letter.
ipv6-address: IPv6 address.
Use the ipv6 host command to configure a mapping between host name and IPv6 address.
Use the undo ipv6 host command to remove a mapping between host name and IPv6 address.
No mappings are created by default.
Each host name has only one IPv6 address. The IPv6 address you last assign to the host name overwrites the previous one.
Related commands: display ipv6 host.
# Configure the mapping between a host name and an IPv6 address.
[Sysname] ipv6 host aaa 2001::1
