H3C WX6103 Access Controller Switch Interface Board Command Reference-6W102
HomeSupportWirelessWX6000 Series Access ControllersReference GuidesCommand ReferencesH3C WX6103 Access Controller Switch Interface Board Command Reference-6W102
11-IPv4 Routing Commands
11-IPv4 Routing Commands 298.75 KB
Table of Contents
1 Static Routing Configuration Commands· 1-1
delete static-routes all 1-1
ip route-static· 1-1
ip route-static default-preference· 1-3
2 RIP Configuration Commands· 2-1
checkzero· 2-1
default cost 2-1
default-route originate· 2-2
display rip· 2-3
display rip database· 2-4
display rip interface· 2-5
display rip route· 2-6
filter-policy export 2-8
filter-policy import 2-8
host-route· 2-9
import-route· 2-10
network· 2-10
peer 2-11
preference· 2-12
reset rip statistics· 2-12
rip· 2-12
rip authentication-mode· 2-13
rip input 2-14
rip metricin· 2-14
rip metricout 2-15
rip output 2-15
rip poison-reverse· 2-16
rip split-horizon· 2-16
rip summary-address· 2-17
rip version· 2-17
silent-interface· 2-18
summary· 2-19
timers· 2-20
validate-source-address· 2-21
version· 2-21
3 OSPF Configuration Commands· 3-1
abr-summary· 3-1
area· 3-2
asbr-summary· 3-2
authentication-mode· 3-3
bandwidth-reference· 3-4
default 3-4
default-cost 3-5
default-route-advertise· 3-5
description· 3-6
display ospf abr-asbr 3-7
display ospf asbr-summary· 3-8
display ospf brief 3-9
display ospf cumulative· 3-11
display ospf error 3-13
display ospf interface· 3-14
display ospf lsdb· 3-15
display ospf nexthop· 3-17
display ospf peer 3-18
display ospf peer statistics· 3-20
display ospf request-queue· 3-21
display ospf retrans-queue· 3-22
display ospf routing· 3-23
display ospf vlink· 3-24
enable link-local-signaling· 3-25
enable log· 3-25
enable out-of-band-resynchronization· 3-26
filter 3-26
filter-policy export 3-27
filter-policy import 3-28
graceful-restart 3-28
graceful-restart help· 3-29
graceful-restart interval 3-30
host-advertise· 3-30
import-route· 3-31
log-peer-change· 3-32
lsa-arrival-interval 3-32
lsa-generation-interval 3-33
lsdb-overflow-limit 3-34
maximum load-balancing· 3-34
maximum-routes· 3-35
network· 3-35
nssa· 3-36
opaque-capability enable· 3-37
ospf 3-37
ospf authentication-mode· 3-38
ospf cost 3-39
ospf dr-priority· 3-40
ospf mib-binding· 3-40
ospf mtu-enable· 3-41
ospf timer dead· 3-41
ospf timer hello· 3-42
ospf timer poll 3-42
ospf timer retransmit 3-43
ospf trans-delay· 3-43
preference· 3-44
reset ospf counters· 3-45
reset ospf process· 3-45
reset ospf redistribution· 3-46
rfc1583 compatible· 3-46
silent-interface· 3-47
snmp-agent trap enable ospf 3-47
spf-schedule-interval 3-48
stub· 3-49
stub-router 3-49
vlink-peer 3-50
The term switch in this document refers to a switch in a generic sense or an access controller configured with the switching function unless otherwise specified.
View
None
Use the delete static-routes all command to delete all static routes.
When you use this command to delete static routes, the system will prompt you to confirm the operation before deleting all the static routes.
Related commands: display ip routing-table, ip route-static.
# Delete all static routes on the router.
[Sysname] delete static-routes all
This will erase all ipv4 static routes and their configurations, you must reconf
igure all static routes
Are you sure?[Y/N]:Y
ip route-static
ip route-static dest-address { mask | mask-length } { next-hop-address [ track track-entry-number ] | interface-type interface-number [ next-hop-address ] } [ preference preference-value ] [ tag tag-value ] [ description description-text ]
undo ip route-static dest-address { mask | mask-length } [ next-hop-address | interface-type interface-number [ next-hop-address ] ] [ preference preference-value ]
View
dest-address: Destination IP address of the static route, in dotted decimal notation.
mask: Mast of the IP address, in dotted decimal notation.
mask-length: Mask length, in the range 0 to 32.
next-hop-address: IP address of the next hop, in dotted decimal notation.
interface-type interface-number: Specifies the output interface by its type and number. If the output interface is a broadcast interface, such as an Ethernet interface, a virtual template or a VLAN interface, the next hop address must be specified.
preference preference-value : Specifies the preference of the static route, which is in the range of 1 to 255 and defaults to 60.
tag tag-value: Sets a tag value for the static route from 1 to 4294967295. The default is 0. Tags of routes are used in routing policies to control routing.
description description-text: Configures a description for the static route, which consists of 1 to 60 characters, including special characters like space, but excluding “?”.
track track-entry-number: Associates the static route with a track entry. Use the track-entry-number argument to specify a track entry number, in the range 1 to 1024.
Use the ip route-static command to configure a unicast static route.
Use the undo ip route-static command to delete a unicast static route.
When configuring a unicast static route, note that:
1)        If the destination IP address and the mask are both 0.0.0.0, the configured route is a default route. If routing table searching fails, the router will use the default route for packet forwarding.
2)        Different route management policies can be implemented for different route preference configurations. For example, specifying the same preference for different routes to the same destination address enables load sharing, while specifying different preferences for these routes enables route backup.
3)        When configuring a static route, you can specify the output interface or the next hop address based on the actual requirement. Note that the next hop address must not be the IP address of the local interface; otherwise, the route configuration will not take effect. For interfaces that support network address to link layer address resolution or point-to-point interfaces, you can specify the output interface or next hop address. When specifying the output interface, note that:
l          For a NULL 0 interface, if the output interface has already been configured, there is no need to configure the next hop address.
l          It is not recommended to specify a broadcast interface (such as VLAN interface) as the output interface for a static route, because a broadcast interface may have multiple next hops. If you have to do so, you must specify the corresponding next hop of the interface at the same time.
Related commands: display ip routing-table, ip route-static default-preference.
l          The static route does not take effect if you specify its next hop address first and then configure the address as the IP address of a local interface, such as VLAN interface.
l          To configure track monitoring for an existing static route, simply associate the static route with a track entry. For a non-existent static route, configure it and associate it with a Track entry.
l          If a static route needs route recursion, the associated track entry must monitor the nexthop of the recursive route instead of that of the static route; otherwise, a valid route may be mistakenly considered invalid.
# Configure a static route, whose destination address is 1.1.1.1/24, next hop address is 2.2.2.2, tag value is 45, and description information is for internet & intranet.
[Sysname] ip route-static 1.1.1.1 24 2.2.2.2 tag 45 description for internet & intranet
ip route-static default-preference default-preference-value
undo ip route-static default-preference
View
default-preference-value: Default preference for static routes, which is in the range of 1 to 255.
Use the ip route-static default-preference command to configure the default preference for static routes.
Use the undo ip route-static default-preference command to restore the default.
By default, the default preference of static routes is 60.
Note that:
l          If no preference is specified when configuring a static route, the default preference is used.
l          When the default preference is re-configured, it applies to newly added static routes only.
# Set the default preference of static routes to 120.
[Sysname] ip route-static default-preference 120
l          The term “router” in this document refers to a router in a generic sense or a Layer 3 switch.
l          The switch interface board only supports single RIP process.
checkzero
checkzero
undo checkzero
View
RIP view
None
Use the checkzero command to enable the zero field check on RIPv1 messages.
Use the undo checkzero command to disable the zero field check.
The zero field check is enabled by default.
After the zero field check is enabled, the router discards RIPv1 messages in which zero fields are non-zero. If all messages are trusty, you can disable this feature to spare the processing time of the CPU.
# Disable the zero field check on RIPv1 messages for RIP process 100.
[Sysname] rip 100
[Sysname-rip-100] undo checkzero
default cost
default cost value
undo default cost
View
RIP view
value: Default metric of redistributed routes, in the range of 0 to 16.
Use the default cost command to configure the default metric for redistributed routes.
Use the undo default cost command to restore the default.
By default, the default metric of redistributed routes is 0.
When you use the import-route command to redistribute routes from other protocols without specifying a metric, the metric specified by the default cost command applies.
Related command: import-route.
# Set the default metric for redistributed routes to 3.
[Sysname] rip 100
[Sysname-rip-100] default cost 3
default-route originate cost value
undo default-route originate
View
RIP view
value: Cost of the default route, in the range of 1 to 15.
Use the default-route originate cost command to advertise a default route with the specified metric to RIP neighbors.
Use the undo default-route originate command to disable the sending of a default route.
By default, no default route is sent to RIP neighbors.
The RIP router with this feature configured will not receive any default routes from RIP neighbors.
# Send a default route with a metric of 2 to RIP neighbors.
[Sysname] rip 100
[Sysname-rip-100] default-route originate cost 2
# Disable default route sending.
[Sysname-rip-100] undo default-route originate
display rip
display rip [ process-id ]
View
process-id: RIP process ID, in the range of 1 to 65535.
Use the display rip command to display the current status and configuration information of the specified RIP process.
If process-id is not specified, information about all configured RIP processes is displayed.
# Display the current status and configuration information of all configured RIP processes.
<Sysname> display rip
    RIP process : 1
       RIP version : 1
       Preference : 100
       Checkzero : Enabled
       Default-cost : 0
       Summary : Enabled
       Hostroutes : Enabled
       Maximum number of balanced paths : 1
       Update time   :   30 sec(s)  Timeout time         :  180 sec(s)
       Suppress time :  120 sec(s)  Garbage-collect time :  120 sec(s)
       TRIP retransmit time :    5 sec(s)
       TRIP response packets retransmit count :   36
       Silent interfaces : None
       Default routes : Disabled
       Verify-source : Enabled
       Networks :
           192.168.1.0
       Configured peers : None
       Triggered updates sent : 0
       Number of routes changes : 0
       Number of replies to queries : 0
Table 2-1 Description on the fields of the display rip command
RIP process
RIP process ID
RIP version
RIP version 1 or 2
Preference
RIP route priority
Checkzero
Indicates whether the zero field check is enabled for RIPv1 messages.
Default-cost
Default cost of the redistributed routes
Summary
Indicates whether the routing summarization is enabled
Hostroutes
Indicates whether to receive host routes
Maximum number of load balanced routes
Update time
RIP update interval
Timeout time
RIP timeout time
Suppress time
RIP suppress interval
RIP garbage collection interval
TRIP retransmit interval for sending update requests and responses.
Maximum retransmit times for update requests and responses
Silent interfaces
Number of silent interfaces, which do not periodically send updates
Default routes
Indicates whether a default route is sent to RIP neighbors
Verify-source
Indicates whether the source IP address is checked on the received RIP routing updates
Networks
Networks enabled with RIP
Configured peers
Configured neighbors
Number of sent triggered updates
Number of changed routes in the database
Number of RIP responses
display rip process-id database
View
Use the display rip database command to display the active routes in the RIP database, which are sent in normal RIP routing updates.
# Display the active routes in the database of RIP process 100.
<Sysname> display rip 100 database
  10.0.0.0/8, cost 1, ClassfulSumm
  10.0.0.0/24, cost 1, nexthop 10.0.0.1, Rip-interface
  11.0.0.0/8, cost 1, ClassfulSumm
  11.0.0.0/24, cost 1, nexthop 10.0.0.1, Imported
Table 2-2 Description on fields of the display rip database command
X.X.X.X/X
Destination address and subnet mask
cost
Cost of the route
classful-summ
Indicates the route is a RIP summary route.
Nexthop
Address of the next hop
Rip-interface
Routes learnt from a RIP–enabled interface
imported
Routes redistributed from other routing protocols
display rip process-id interface [ interface-type interface-number ]
View
interface-type interface-number: Specifies an interface.
Use the display rip interface command to display the RIP interface information of the RIP process.
If no interface is specified, information about all RIP interfaces of the RIP process is displayed.
# Display all the interface information of RIP process 1.
<Sysname> display rip 1 interface
 Interface-name: Vlan-interface1
    Address/Mask:192.168.0.154/24    Version:RIPv1
    MetricIn:0                       MetricIn route policy:Not designated
    MetricOut:1                      MetricOut route policy:Not designated
    Split-horizon/Poison-reverse:on/off  Input/Output:on/on
    Current packets number/Maximum packets number:10/2000
Table 2-3 Description on the fields of the display rip interface command
Interface-name
The name of an interface running RIP.
Address/Mask
The IP address and Mask of the interface.
Version
RIP version running on the interface
MetricIn
Additional routing metric added to the incoming routes
MetricOut
Additional routing metric added to the outgoing routes
Split-horizon
Indicates whether the split-horizon is enabled (ON: enabled, OFF: disabled).
Poison-reverse
Indicates whether the poison-reverse is enabled (ON: enabled, OFF: disabled)
Input/Output
Indicates if the interface is allowed to receive (Input) or send (Output) RIP messages (on is allowed, off is not allowed).
Packets to be sent/Maximum packets that can be sent on the interface
display rip route
display rip process-id route [ statistics | ip-address { mask | mask-length } | peer ip-address ]
View
statistics: Displays the route statistics, including total number of routes and number of routes of each neighbor.
ip-address { mask | mask-length }: Displays route information about a specified IP address.
peer ip-address: Displays all routing information learned from a specified neighbor.
Use the display rip route command to display the routing information of a specified RIP process.
# Display all routing information of RIP process 1.
<Sysname> display rip 1 route
 Route Flags: R-RIP, T-TRIP
              P-Permanent, A-Aging, S-Suppressed, G-Garbage-collect
Peer 21.0.0.23 on Vlan-interface1
Destination/Mask    NextHop      Cost     Tag    Flags     Sec
56.0.0.0/8         21.0.0.23      1         0       RA     102
34.0.0.0/8         21.0.0.23      1         0       RA      23
Peer 21.0.0.12 on Vlan-interface1
56.0.0.0/8         21.0.0.12      1         0       RA      34
12.0.0.0/8         21.0.0.12      1         0       RA      12
# Display routing information for network 56.0.0.0/8 of RIP process 1.
<Sysname> display rip 1 route 56.0.0.0 8
# Display RIP process1 routing information learned from the specified neighbor.
<Sysname> display rip 1 route peer 21.0.0.23
Table 2-4 Description on the fields of the display rip route command
Route Flags
R — RIP route
T — TRIP route
P — The route never expires
A — The route is aging
S — The route is suppressed
G — The route is in Garbage-collect state
Routing information learned on a RIP interface from the specified neighbor
Destination/Mask
Destination IP address and subnet mask
Nexthop
Next hop of the route
Cost
Cost of the route
Tag
Route tag
Flags
Indicates the route state
Sec
Remaining time of the timer corresponding to the route state
# Display the routing statistics of RIP process 1.
<Sysname> display rip 1 route statistics
Peer         Aging     Permanent    Garbage
21.0.0.23      2          0              3
21.0.0.12      2          0              4
Total          4          0              7
Table 2-5 Description on the fields of the display rip route statistics command
Peer
IP address of a neighbor
Aging
Total number of aging routes learned from the specified neighbor
Permanent
Total number of permanent routes learned from the specified neighbor
Garbage
Total number of routes in the garbage-collection state learned from the specified neighbor
Total
Total number of routes learned from all RIP neighbors
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] | interface-type interface-number ]
undo filter-policy export [ protocol [ process-id ] | interface-type interface-number ]
View
RIP view
acl-number: Number of an ACL used to filter outbound routes, in the range of 2000 to 3999.
ip-prefix ip-prefix-name: Name of an IP prefix list used to filter outbound routes, a string of 1 to 19 characters.
protocol: Filters outbound routes redistributed from a specified routing protocol, which can be direct, rip, and static.
process-id: Process ID of the specified routing protocol, in the range of 1 to 65535. You need to specify a process ID when the routing protocol is rip.
Use the filter-policy export command to configure the filtering of RIP outgoing routes. Only routes not filtered out can be advertised.
Use the undo filter-policy export command to remove the filtering.
By default, RIP does not filter outbound routes.
Note that:
l          If protocol is specified, RIP filters only the outgoing routes redistributed from the specified routing protocol. Otherwise, RIP filters all routes to be advertised.
l          If interface-type interface-number is specified, RIP filters only the routes advertised by the specified interface. Otherwise, RIP filters routes advertised by all RIP interfaces.
Related commands: acl, import-route, and ip ip-prefix.
# Reference ACL 2000 to filter outbound routes.
[Sysname] rip 1
[Sysname-rip-1] filter-policy 2000 export
# Reference IP prefix list abc to filter outbound routes on VLAN-interface 10.
[Sysname-rip-1] filter-policy ip-prefix abc export vlan-interface 10
filter-policy { acl-number | gateway ip-prefix-name | ip-prefix ip-prefix-name [ gateway ip-prefix-name ] } import [ interface-type interface-number ]
undo filter-policy import [ interface-type  interface-number ]
View
RIP view
acl-number: Number of the Access Control List (ACL) used for filtering incoming routes, in the range of 2000 to 3999.
ip-prefix ip-prefix-name: References an IP prefix list to filter incoming routes. The ip-prefix-name is a string of 1 to 19 characters.
gateway ip-prefix-name: References an IP prefix list to filter routes from the gateway.
Use the filter-policy import command to filter the incoming routes.
Use the undo filter-policy import command to restore the default.
By default, RIP does not filter incoming routes.
Related commands: acl and ip ip-prefix.
# Reference ACL 2000 to filter incoming routes.
[Sysname] rip 1
[Sysname-rip-1] filter-policy 2000 import
# Reference IP prefix list abc on VLAN-interface 10 to filter all received RIP routes.
[Sysname-rip-1] filter-policy ip-prefix abc import vlan-interface 10
host-route
host-route
undo host-route
View
RIP view
None
Use the host-route command to enable host route reception.
Use the undo host-route command to disable host route reception.
By default, receiving host routes is enabled.
In some cases, a router may receive many host routes from the same network segment. These routes are not helpful for routing and occupy a large amount of network resources. You can use the undo host-route command to disable receiving of host routes.
RIPv2 can be disabled from receiving host routes, but RIPv1 cannot.
# Disable RIP from receiving host routes.
[Sysname] rip 1
[Sysname-rip-1] undo host-route
import-route
import-route protocol [ cost cost | tag tag ]*
undo import-route protocol
View
RIP view
protocol: Specify a routing protocol from which to redistribute routes, currently including  direct and static.
cost: Cost for redistributed routes, in the range of 0 to 16. If cost is not specified, the default cost specified by the default cost command applies.
tag: Tag marking redistributed routes, in the range of 0 to 65,535. The default is 0.
Use the import-route command to enable route redistribution from another routing protocol.
Use the undo import-route command to disable route redistribution.
By default, RIP does not redistribute routes from other routing protocols.
l          You can configure a cost for redistributed routes using keyword cost.
l          You can configure a tag value for redistributed routes using keyword tag.
Related commands: default cost.
# Redistribute static routes, and set the cost to 4.
[Sysname] rip 1
[Sysname-rip-1] import-route static cost 4
# Set the default cost for redistributed routes to 3.
[Sysname-rip-1] default cost 3
network
network network-address
undo network network-address
View
RIP view
network-address: IP address of a network segment, which can be the IP network address of any interface.
Use the network command to enable RIP on the interface attached to the specified network.
Use the undo network command to disable RIP on the interface attached to the specified network.
RIP runs only on the interfaces attached to the specified network. For an interface not on the specified network, RIP neither receives/sends routes on it nor forwards interface route through it. Therefore, you need to specify the network after enabling RIP to validate RIP on a specific interface.
Use the network 0.0.0.0 command to enable RIP on all interfaces.
RIP is disabled on an interface by default.
# Enable RIP on the interface attached to the network 129.102.0.0.
[Sysname] rip 100
[Sysname-rip-100] network 129.102.0.0
peer
peer ip-address
undo peer ip-address
View
RIP view
ip-address: IP address of a RIP neighbor, in dotted decimal format.
Use the peer command to specify the IP address of a neighbor in the non-broadcast multi-access (NBMA) network, where routing updates destined to the peer are unicast, rather than multicast or broadcast.
Use the undo peer command to remove the IP address of a neighbor.
By default, no neighbor is specified.
Note: you need not use the peer ip-address command when the neighbor is directly connected; otherwise the neighbor may receive both the unicast and multicast (or broadcast) of the same routing information.
# Specify to send unicast updates to peer 202.38.165.1.
[Sysname] rip 1
[Sysname-rip-1] peer 202.38.165.1
preference
preference value
undo preference
View
RIP view
value: Priority for RIP route, in the range of 1 to 255. The smaller the value, the higher the priority.
Use the preference command to specify the RIP route priority.
Use the undo preference route-policy command to restore the default.
By default, the priority of RIP route is 100.
# Set the RIP route priority to 120.
[Sysname] rip 1
[Sysname-rip-1] preference 120
reset rip process-id statistics
View
Use the reset rip statistics command to clear the statistics of the specified RIP process.
# Clear statistics in RIP process 100.
<Sysname> reset rip 100 statistics
rip
rip [ process-id ]
undo rip [ process-id ]
View
process-id: RIP process ID, in the range of 1 to 65535. The default is 1.
Use the rip command to create a RIP process and enter RIP view.
Use the undo rip command to disable a RIP process.
By default, no RIP process runs.
Note that:
l          You must enable the RIP process before configuring the global parameters. This limitation is not for configuration of interface parameters.
l          The configured interface parameters become invalid after you disable the RIP process.
# Create a RIP process and enter RIP process view.
[Sysname] rip
[Sysname-rip-1]
rip authentication-mode { md5 { rfc2082 key-string key-id | rfc2453 key-string } | simple password }
undo rip authentication-mode
View
Interface view
md5: MD5 authentication mode.
rfc2453: Uses the message format defined in RFC 2453 (IETF standard).
rfc2082: Uses the message format defined in RFC 2082.
key-id: MD5 key number, in the range of 1 to 255.
key-string: MD5 key string with 1 to 16 characters in plain text format, or 24 characters in cipher text format. When the display current-configuration command is used to display system information, a 24-character cipher string is displayed as the MD5 key string.
simple: Plain text authentication mode.
password: Plain text authentication string with 1 to 16 characters.
Use the rip authentication-mode command to configure RIPv2 authentication mode and parameters.
Use the undo rip authentication-mode command to cancel authentication.
Note that the key string you configured can overwrite the old one if there is any.
Related commands: rip version.
# Configure MD5 authentication on VLAN-interface 10 with the key string being rose in the format defined in RFC 2453.
[Sysname-Vlan-interface10] rip version 2
[Sysname-Vlan-interface10] rip authentication-mode md5 rfc2453 rose
rip input
rip input
undo rip input
View
Interface view
None
Use the rip input command to enable the interface to receive RIP messages.
Use the undo rip input command to disable the interface from receiving RIP messages.
By default, an interface is enabled to receive RIP messages.
Related commands: rip output.
# Disable VLAN-interface 10 from receiving RIP messages.
[Sysname-Vlan-interface10] undo rip input
rip metricin
rip metricin value
undo rip metricin
View
Interface view
value: Additional metric added to received routes, in the range of 0 to 16.
Use the rip metricin command to add a metric to the received routes.
Use the undo rip metricin command to restore the default.
By default, the additional metric of a received route is 0.
When a valid RIP route is received, the system adds a metric to it and then installs it into the routing table. Therefore, the metric of routes received on the configured interface is increased.
Related commands: rip metricout.
# Configure VLAN-interface 10 to add a metric of 2 for incoming routes.
[Sysname-Vlan-interface10] rip metricin 2
rip metricout
rip metricout value
undo rip metricout
View
Interface view
value: Additional metric of sent routes, in the range of 1 to 16.
Use the rip metricout command to add a metric to a sent route.
Use the undo rip metricout command to restore the default.
By default, the additional metric for sent routes is 1.
Before a RIP route is sent, a metric will be added to it. Therefore, when the metric is configured on an interface, the metric of RIP routes sent on the interface will be increased.
Related commands: rip metricin.
#  Configure VLAN-interface 10 to add a metric of 2 for outgoing routes.
[Sysname-Vlan-interface10] rip metricout 2
rip output
rip output
undo rip output
View
Interface view
None
Use the rip output command to enable the interface to send RIP messages.
Use the undo rip output command to disable the interface from sending RIP messages.
Sending RIP messages is enabled on an interface by default.
Related commands: rip input.
[Sysname-Vlan-interface10] undo rip output
rip poison-reverse
rip poison-reverse
undo rip poison-reverse
View
Interface view
None
Use the rip poison-reverse command to enable the poison reverse function.
Use the undo rip poison-reverse command to disable the poison reverse function.
By default, the poison reverse function is disabled.
# Enable the poison reverse function for RIP routing updates on VLAN-interface 10.
[Sysname-Vlan-interface10] rip poison-reverse
rip split-horizon
rip split-horizon
undo rip split-horizon
View
Interface view
None
Use the rip split-horizon command to enable the split horizon function.
Use the undo rip split-horizon command to disable the split horizon function.
The split horizon function is enabled by default.
l          The split horizon function is necessary for preventing routing loops. Therefore, you are not recommended to disable it.
l          In special cases, make sure it is necessary to disable the split horizon function.
Only the poison reverse function takes effect if both the split horizon and poison reverse functions are enabled.
# Enable the split horizon function on VLAN-interface 10.
[Sysname-Vlan-interface10] rip split-horizon
rip summary-address
rip summary-address ip-address { mask | mask-length }
undo rip summary-address ip-address { mask | mask-length }
View
Interface view
ip-address: Summary IP address.
mask: Subnet mask in dotted decimal format.
mask-length: Subnet mask length.
Use the rip summary-address command to configure RIPv2 to advertise a summary route through the interface.
Use the undo rip summary-address command to remove the configuration.
Note that the summary address is valid only when the automatic summarization is disabled.
Related commands: summary.
# Advertise a local summary address on VLAN-interface 10.
[Sysname-Vlan-interface10] rip summary-address 10.0.0.0 255.255.255.0
rip version
rip version { 1 | 2 [ broadcast | multicast ] }
undo rip version
View
Interface view
1: RIP version 1.
2: RIP version 2.
broadcast: Sends RIPv2 messages in broadcast mode.
multicast: Sends RIPv2 messages in multicast mode.
Use the rip version command to specify a RIP version for the interface.
Use the undo rip version command to remove the specified RIP version.
By default, no RIP version is configured for an interface, which uses the global RIP version. If the global RIP version is not configured, the interface can only send RIPv1 broadcasts and can receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, multicasts and unicasts.
If RIPv2 is specified with no sending mode configured, RIPv2 messages will be sent in multicast mode.
When RIPv1 runs on an interface, the interface will:
l          Send RIPv1 broadcast messages
l          Receive RIPv1 broadcast messages
l          Receive RIPv1 unicast messages
When RIPv2 runs on the interface in broadcast mode, the interface will:
l          Send RIPv2 broadcast messages
l          Receive RIPv2 broadcast messages
l          Receive RIPv2 multicast messages
l          Receive RIPv2 unicast messages
When RIPv2 runs on the interface in multicast mode, the interface will:
l          Send RIPv2 multicast messages
# Configure VLAN-interface 10 to broadcast RIPv2 messages.
[Sysname] interface Vlan-interface 10
[Sysname-Vlan-interface10] rip version 2 broadcast
silent-interface
silent-interface { all | interface-type interface-number }
undo silent-interface { all | interface-type interface-number }
View
RIP view
all: Silents all interfaces.
Use the silent-interface command to disable an interface or all interfaces from sending routing updates. That is, the interface only receives but does not send RIP messages.
Use the undo silent-interface command to restore the default.
By default, all interfaces are allowed to send routing updates.
# Configure all VLAN interfaces to work in the silent state, and activate VLAN-interface 10.
[Sysname] rip 100
[Sysname-rip-100] silent-interface all
[Sysname-rip-100] undo silent-interface vlan-interface 10
[Sysname-rip-100] network 131.108.0.0
summary
summary
undo summary
View
RIP view
None
Use the summary command to enable automatic RIPv2 summarization. Natural masks are used to advertise summary routes so as to reduce the size of routing tables.
Use the undo summary command to disable automatic RIPv2 summarization so that all subnet routes can be broadcast.
By default, automatic RIPv2 summarization is enabled.
Enabling automatic RIPv2 summarization can reduce the size of the routing table to enhance the scalability and efficiency of large networks.
# Enable RIPv2 automatic summarization.
[Sysname] rip
[Sysname-rip-1] summary
timers
timers { garbage-collect garbage-collect-value | suppress suppress-value | timeout timeout-value | update update-value }*
undo timers { garbage-collect | suppress | timeout | update } *
View
RIP view
garbage-collect-value: Garbage-collect timer time in seconds, in the range of 1 to 3600.
suppress-value: Suppress timer time in seconds, in the range of 0 to 3600.
timeout-value: Timeout timer time in seconds, in the range of 1 to 3600.
update-value: Update timer time in seconds, in the range of 1 to 3600.
Use the timers command to configure RIP timers. By adjusting RIP timers, you can improve network performance.
Use the undo timers command to restore the default.
By default, the garbage-collect timer is 120 seconds, the suppress timer 120 seconds, the timeout timer 180 seconds, and the update timer 30 seconds.
RIP is controlled by the above four timers.
l          The update timer defines the interval between routing updates.
l          The timeout timer defines the route aging time. If no routing update related to a route is received after the aging time, the metric of the route is set to 16 in the routing table.
l          The suppress timer defines how long a RIP route stays in the suppressed state. When the metric of a route is 16, the route enters the suppressed state. In the suppressed state, only routes which come from the same neighbor and whose metric is less than 16 will be received by the router to replace unreachable routes.
l          The garbage-collect timer defines the interval from when the metric of a route becomes 16 to when it is deleted from the routing table. During the Garbage-Collect timer length, RIP advertises the route with the routing metric set to 16. If no routing update is announced for that route after the Garbage-Collect timer expires, the route will be deleted from the routing table.
Note that:
l          Generally, you are not recommended to change the default values of these timers.
l          The time lengths of these timers must be kept consistent on all routers and access servers in the network.
# Specifies the update, timeout, suppress, and garbage-collect timers as 5, 15, 15 and 30 respectively.
[Sysname] rip 100
[Sysname-rip-100] timers update 5
[Sysname-rip-100] timers timeout 15
[Sysname-rip-100] timers suppress 15
[Sysname-rip-100] timers garbage-collect 30
undo validate-source-address
View
RIP view
None
Use the validate-source-address command to enable the source IP address validation on incoming RIP routing updates.
Use the undo validate-source-address command to disable the source IP address validation.
The source IP address validation is enabled by default.
Generally, disabling the validation is not recommended.
# Enable the source IP address validation on incoming messages.
[Sysname-rip] rip 100
[Sysname-rip-100] validate-source-address
version
version { 1 | 2 }
undo version
View
RIP view
1: Specifies the RIP version as RIPv1.
2: Specifies the RIP version as RIPv2. RIPv2 messages are multicast.
Use the version command to specify a global RIP version.
Use the undo version command to remove the configured global RIP version.
By default, if an interface has a RIP version specified, the RIP version takes effect; if it has no RIP version specified, it can send RIPv1 broadcasts, and receive RIPv1 broadcasts, RIPv1 unicasts, RIPv2 broadcasts, RIPv2 multicasts, and RIPv2 unicasts.
Note that:
l          If an interface has an RIP version specified, the RIP version takes precedence over the global RIP version.
l          If no RIP version is specified for the interface and the global version is RIPv1, the interface inherits RIPv1, and it can send RIPv1 broadcasts, and receive RIPv1 broadcasts and unicasts.
l          If no RIP version is specified for the interface and the global version is RIPv2, the interface operates in the RIPv2 muticast mode, and it can send RIPv2 multicasts, and receive RIPv2 broadcasts, multicasts and unicasts.
# Specify RIPv2 as the global RIP version.
[Sysname] rip 100
[Sysname-rip-100] version 2
The term “router” in this document refers to a router in a generic sense or a Layer 3 switch running routing protocols.
abr-summary
abr-summary ip-address { mask | mask-length } [ advertise | not-advertise ] [ cost cost ]
undo abr-summary ip-address { mask | mask-length }
View
OSPF area view
ip-address: Destination IP address of the summary route, in dotted decimal format.
mask: Mask of the IP address in dotted decimal format.
mask-length: Mask length, in the range 0 to 32 bits.
advertise | not-advertise: Advertises the summary route or not. By default, the summary route is advertised.
cost cost: Specifies the cost of the summary route, in the range 1 to 16777215. The default cost is the largest cost value among routes that are summarized.
Use the abr-summary command to configure a summary route on the area border router.
Use the undo abr-summary command to remove a summary route.
By default, no route summarization is configured on an ABR.
You can enable advertising the summary route or not, and specify a route cost.
This command is usable only on an ABR. Multiple contiguous networks may be available in an area, where you can summarize them with one network on the ABR for advertisement. The ABR advertises only the summary route to other areas.
With the undo abr-summary command used, summarized routes will be advertised.
# Summarize networks 36.42.10.0/24 and 36.42.110.0/24 in Area 1 with 36.42.0.0/16.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] network 36.42.10.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] network 36.42.110.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] abr-summary 36.42.0.0 255.255.0.0
area
area area-id
undo area area-id
View
OSPF view
area-id: ID of an area, a decimal integer in the range 0 to 4294967295 that is translated into the IP address format by the system, or an IP address.
Use the area command to create an area and enter area view.
Use the undo area command to remove a specified area.
No OSPF area is created by default.
# Create Area 0 and enter Area 0 view
[Sysname] ospf 100
[Sysname-ospf-100] area 0
[Sysname-ospf-100-area-0.0.0.0]
asbr-summary
asbr-summary ip-address { mask | mask-length } [ tag tag | not-advertise | cost cost ]*
undo asbr-summary ip-address { mask | mask-length }
View
OSPF view
ip-address: IP address of the summary route in dotted decimal notation.
mask: IP address mask in dotted decimal notation.
not-advertise: Disables advertising the summary route. If the keyword is not specified, the route is advertised.
tag tag: Specifies a tag value for the summary route, used by a route policy to control route advertisement, in the range 0 to 4294967295. The default is 1.
cost cost: Specifies the cost of the summary route, in the range 1 to 16777214. For Type-1 external routes, the cost defaults to the largest cost among routes that are summarized. For Type-2 external routes, the cost defaults to the largest cost among routes that are summarized plus 1.
Use the asbr-summary command to configure a summary route.
Use the undo asbr-summary command to remove a summary route.
No ASBR route summarization is configured by default.
With the asbr-summary command configured on an ASBR, it summarizes redistributed routes that fall into the specified address range with a single route. If the ASBR resides in an NSSA area, it advertises the summary route in a Type-7 LSA into the area.
With the asbr-summary command configured on an NSSA ABR, it summarizes routes described by Type-5 LSAs translated from Type-7 LSAs with a single route and advertises the summary route to other areas. This command does not take effect on non NSSA ABRs.
With the undo asbr-summary command used, summarized routes will be advertised.
Related command: display ospf asbr-summary.
# Summarize redistributed routes with a single route.
[Sysname] ip route-static 10.2.1.0 24 null 0
[Sysname] ip route-static 10.2.2.0 24 null 0
[Sysname] ospf 100
[Sysname-ospf-100] import-route static
[Sysname-ospf-100] asbr-summary 10.2.0.0 255.255.0.0 tag 2 cost 100
authentication-mode
authentication-mode { simple | md5 }
undo authentication-mode
View
OSPF area view
simple: Specifies the simple authentication mode.
md5: Specifies the MD5 ciphertext authentication mode.
Use the authentication-mode command to specify an authentication mode for the OSPF area.
Use the undo authentication-mode command to remove the authentication mode.
By default, no authentication mode is configured for an OSPF area.
Routers that reside in the same area must have the same authentication mode: non-authentication, simple, or MD5.
Related commands: ospf authentication-mode.
# Specify the MD5 ciphertext authentication mode for OSPF area0.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] authentication-mode md5
bandwidth-reference
bandwidth-reference value
undo bandwidth-reference
View
OSPF view
value: Bandwidth reference value for link cost calculation, in the range 1 to 2147483648 Mbps.
Use the bandwidth-reference command to specify a reference bandwidth value for link cost calculation.
Use the undo bandwidth-reference command to restore the default value.
The default value is 100 Mbps.
When links have no cost values configured, OSPF calculates their cost values: Cost=Reference bandwidth value / Link bandwidth. If the calculated cost is greater than 65535, the value of 65535 is used.
# Specify the reference bandwidth value as 1000 Mbps.
[Sysname] ospf 100
[Sysname-ospf-100] bandwidth-reference 1000
default
default { cost cost | limit limit | tag tag | type type } *
undo default { cost | limit | tag | type } *
View
OSPF view
cost: Specifies the default cost for redistributed routes, in the range 0 to 16777214.
limit: Specifies the default upper limit of routes redistributed per time, in the range 1 to 2147483647.
tag: Specifies the default tag for redistributed routes, in the range 0 to 4294967295.
type: Specifies the default type for redistributed routes: 1 or 2.
Use the default command to configure default parameters for redistributed routes.
Use the undo default command to restore default values.
The cost, route type, tag, and the upper limit are 1, 2, 1 and 1000 by default.
Related commands: import-route.
# Configure the default cost, upper limit, tag and type as 10, 20000, 100 and 2 respectively for redistributed external routes.
[Sysname] ospf 100
[Sysname-ospf-100] default cost 10 limit 20000 tag 100 type 2
default-cost
default-cost cost
undo default-cost
View
OSPF area view
cost: Specifies a cost for the default route advertised to the Stub or NSSA area, in the range 0 to 16777214.
Use the default-cost command to specify a cost for the default route advertised to the stub or NSSA area.
Use the undo default-cost command to restore the default value.
The cost defaults to 1.
This command is only applicable to the ABR of a stub area or the ABR/ASBR of an NSSA area.
Related commands: stub, nssa.
# Configure Area 1 as a stub area, and specify the cost of the default route advertised to the stub area as 20.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
[Sysname-ospf-100-area-0.0.0.1] default-cost 20
default-route-advertise [ [ always | cost cost | type type | route-policy route-policy-name ] * | summary cost cost ]
undo default-route-advertise
View
OSPF view
always: Generates a default external route in an ASE LSA into the OSPF routing domain, if the router has no default route configured. Without this keyword used, you have to configure a default route to distribute it in a Type-5 LSA into the OSPF routing domain.
cost cost: Specifies a cost for the default route, in the range 0 to 16777214. The default is 1.
type type: Specifies a type for the ASE LSA: 1 or 2, which defaults to 2.
route-policy route-policy-name: Specifies a route policy name, a string of 1 to 19 characters. If the default route matches the specified route policy, the route policy modifies some values in the ASE LSA.
summary: Advertises the Type-3 summary LSA of the specified default route.
Use the default-route-advertise command to generate a default route into the OSPF routing domain.
Use the undo default-route-advertise command to disable OSPF from distributing a default external route.
By default, no default route is distributed.
Using the import-route command cannot redistribute a default route. To do so, use the default-route-advertise command. If no default route is configured, use the default-route-advertise always command to generate a default route in a Type-5 LSA.
The default-route-advertise summary cost command is applicable only to VPNs, and the default route is redistributed in a Type-3 LSA. The PE router advertises the redistributed default route to the CE router. Currently, this command is not supported on the access controller switch interface board because it does not support VPN.
# Generate a default route in an ASE LSA into the OSPF routing domain (no default route configured on the router).
[Sysname] ospf 100
[Sysname-ospf-100] default-route-advertise always
description
View
OSPF view/OSPF area view
description: Configures a description for the OSPF process in OSPF view, or for the OSPF area in OSPF area view. description is a string of up to 80 characters.
Use the description command to configure a description for an OSPF process or area.
Use the undo description command to remove the description.
No description is configured by default.
Use of this command is only for the identification of an OSPF process or area. The description has no special meaning.
# Describe the OSPF process 100 as abc.
[Sysname] ospf 100
[Sysname-ospf-100] description abc
# Describe the OSPF area0 as bone area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] description bone area
display ospf [ process-id ] abr-asbr
View
process-id: OSPF process ID, in the range 1 to 65535.
Use the display ospf abr-asbr command to display ABR/ASBR information.
If no process is specified, the ABR/ASBR information of all OSPF processes is displayed.
If you use this command on routers in a stub area, no ASBR information is displayed.
# Display ABR/ASBR information.
<Sysname> display ospf abr-asbr
          OSPF Process 1 with Router ID 192.168.1.2
                  Routing Table to ABR and ASBR
Type        Destination       Area       Cost  Nexthop         RtType
 Inter       3.3.3.3           0.0.0.0    3124  10.1.1.2        ASBR
 Intra       2.2.2.2           0.0.0.0    1562  10.1.1.2        ABR
Table 3-1 Description on the fields of the display ospf abr-asbr command
Intra-area router or Inter-area router
Destination
Router ID of an ABR/ASBR
Area
ID of the area of the next hop
Cost
Cost from the router to the ABR/ASBR
Nexthop
Next hop address
RtType
Router type: ABR, ASBR
display ospf [ process-id ] asbr-summary [ ip-address { mask | mask-length } ]
View
ip-address: IP address, in dotted decimal format.
mask: IP address mask, in dotted decimal format.
Use the display ospf asbr-summary command to display information about the redistributed routes that are summarized.
If no OSPF process is specified, related information of all OSPF processes is displayed.
If no IP address is specified, information about all summarized redistributed routes will be displayed.
Related commands: asbr-summary.
# Display information about all summarized redistributed routes.
<Sysname> display ospf asbr-summary
                  Summary Addresses
 Total Summary Address Count: 1
                  Summary Address
 Net         : 30.1.0.0
 Mask        : 255.255.0.0
 Tag         : 20
 Status      : Advertise
 Cost        : 10 (Configured)
 The Count of Route is : 2
 Destination     Net Mask        Proto      Process   Type     Metric
 30.1.2.0        255.255.255.0   OSPF       1         2        1
 30.1.1.0        255.255.255.0   OSPF       1         2        1
Table 3-2 Description on the fields of the display ospf asbr-summary command
Total summary route number
Net
The address of the summary route
Mask
The mask of the summary route address
Tag
The tag of the summary route
Status
The advertisement status of the summary route
Cost
The cost to the summary net
The Count of Route
The count of routes that are summarized
Destination
Destination address of a summarized route
Net Mask
Network mask of a summarized route
Proto
Routing protocol
Process
Process ID of routing protocol
Type of a summarized route
Metric
Metric of a summarized route
display ospf brief
display ospf [ process-id ] brief
View
Use the display ospf brief command to display OSPF brief information. If no OSPF process is specified, brief information about all OSPF processes is displayed.
# Display OSPF brief information.
<Sysname> display ospf brief
                  OSPF Protocol Information
 RouterID: 192.168.1.2      Border Router:  NSSA
 Route Tag: 0
 Applications Supported: MPLS Traffic-Engineering
 SPF-schedule-interval: 5 0 5000
 LSA generation interval: 5 0 5000
 LSA arrival interval: 1000
 Default ASE Parameter: Metric: 1 Tag: 1 Type: 2
 Route Preference: 10
 ASE Route Preference: 150
 SPF Computation Count: 22
 RFC 1583 Compatible
 Graceful restart interval: 120
 Area Count: 1   Nssa Area Count: 1
 ExChange/Loading Neighbors: 0
 Area: 0.0.0.1          (MPLS TE  not enabled)
 Authtype: None Area flag: NSSA
 SPF Scheduled Count: 5
 Interface: 192.168.1.2 (Vlan-interface1)
 Cost: 1       State: DR        Type: Broadcast    MTU: 1500
 Priority: 1
 Designated Router: 192.168.1.2
 Backup Designated Router: 192.168.1.1
 Timers: Hello 10 , Dead 40 , Poll  40 , Retransmit 5 , Transmit Delay 1
Table 3-3 Description on the fields of the display ospf brief command
RouterID
Router ID
Border Router
ABR, ASBR or NSSA ABR
Route Tag
The tag of redistributed routes
The OSPF process does not support multi-VPN-instance.
Applications supported
Interval for SPF calculations
Minimum LSA repeat arrival interval
Default ASE Parameters: metric, tag, route type.
Route Preference
Internal route priority
External route priority
SPF Computation count
SPF computation count of the OSPF process
RFC1583 Compatible
Compatible with routing rules defined in RFC1583
GR restart interval
Area Count
Area number of the current process
Nssa Area Count
NSSA area number of the current process
Neighbors in ExChange/Loading state
Area
Area ID in the IP address format
Authtype
Authentication type of the area: Non-authentication, simple authentication, or MD5 authentication
Area flag
The type of the area
SPF scheduled Count
SPF calculation count in the OSPF area
IP address of the interface
Cost
Interface cost
Interface state
Interface network type
MTU
Interface MTU
Priority
Router priority
Designated Router
The Designated Router
The Backup Designated Router
Timers
Intervals of timers: hello, dead, poll, retransmit, and transmit delay
display ospf [ process-id ] cumulative
View
Use the display ospf cumulative command to display OSPF statistics.
Use of this command is helpful for troubleshooting.
# Display OSPF statistics.
<Sysname> display ospf cumulative
                  Cumulations
  IO Statistics
             Type        Input     Output
            Hello           61        122
   DB Description            2          3
   Link-State Req            1          1
Link-State Update            3          3
   Link-State Ack            3          2
  LSAs originated by this router
  Router: 4
  Network: 0
  Sum-Net: 0
  Sum-Asbr: 0
  External: 0
  NSSA: 0
  Opq-Link: 0
  Opq-Area: 0
  Opq-As: 0
  LSAs Originated: 4  LSAs Received: 7
  Routing Table:
    Intra Area: 2  Inter Area: 3  ASE/NSSA: 0
Table 3-4 Description on the fields of the display ospf cumulative command
IO statistics
Statistics about input/output packets and LSAs
OSPF packet type
Input
Packets received
Output
Packets sent
Hello
Hell packet
DB Description
Database Description packet
Link-State Req
Link-State Request packet
Link-State Update
Link-State Update packet
Link-State Ack
Link-State Acknowledge packet
Router
Type-1 LSA
Network
Type-2 LSA
Sum-Net
Type-3 LSA
Sum-Asbr
Type-4 LSA
External
Type-5 LSA
NSSA
Type-7 LSA
Opq-Link
Type-9 LSA
Opq-Area
Type-10 LSA
Opq-As
Type-11 LSA
LSAs originated
LSAs originated
LSAs Received
LSAs received
Routing Table
Routing table
Intra Area
Intra-area route number
Inter Area
Inter-area route number
ASE
ASE route number
display ospf error
display ospf [ process-id ] error
View
Use the display ospf error command to display OSPF error information.
If no process is specified, the OSPF error information of all OSPF processes is displayed.
# Display OSPF error information.
<Sysname> display ospf error
          OSPF Process 1 with Router ID 192.168.80.100
                  OSPF Packet Error Statistics
0    : OSPF Router ID confusion     0    : OSPF bad packet
0    : OSPF bad version             0    : OSPF bad checksum
0    : OSPF bad area ID             0    : OSPF drop on unnumber interface
0    : OSPF bad virtual link        0    : OSPF bad authentication type
0    : OSPF bad authentication key  0    : OSPF packet too small
0    : OSPF Neighbor state low      0    : OSPF transmit error
0    : OSPF interface down          0    : OSPF unknown neighbor
0    : HELLO: Netmask mismatch      0    : HELLO: Hello timer mismatch
0    : HELLO: Dead timer mismatch   0    : HELLO: Extern option mismatch
0    : HELLO: NBMA neighbor unknown 0    : DD: MTU option mismatch
0    : DD: Unknown LSA type         0    : DD: Extern option mismatch
0    : LS ACK: Bad ack              0    : LS ACK: Unknown LSA type
0    : LS REQ: Empty request        0    : LS REQ: Bad request
0    : LS UPD: LSA checksum bad     0    : LS UPD: Received less recent LSA
0    : LS UPD: Unknown LSA type
Table 3-5 Description on the fields of the display ospf error command
Packets with duplicate route ID
OSPF bad packet
Packets illegal
OSPF bad version
Packets with wrong version
OSPF bad checksum
Packets with wrong checksum
OSPF bad area ID
Packets with invalid area ID
Packets dropped on the unnumbered interface
Packets on wrong virtual links
Packets with invalid authentication type
Packets with invalid authentication key
Packets too small in length
Packets received in low neighbor state
OSPF transmit error
Packets with error when being transmitted
OSPF interface down
Shutdown times of the interface
Packets received from unknown neighbors
Hello packets with mismatched mask
Hello packets with mismatched hello timer
Hello packets with mismatched dead timer
Hello packets with mismatched option field
Hello packets received from unknown NBMA neighbors
DD packets with mismatched MTU
DD packets with unknown LSA type
DD packets with mismatched option field
LS ACK: Bad ack
Bad LSAck packets for LSU packets
LSAck packets with unknown LSA type
LSR packets with no request information
LS REQ: Bad request
Bad LSR packets
LSU packets with wrong LSA checksum
LSU packets without latest LSA
LSU packets with unknown LSA type
display ospf [ process-id ] interface [ all | interface-type interface-number ]
View
all: Display the OSPF information of all interfaces.
interface-type interface-number: Interface type and interface number.
Use the display ospf interface command to display OSPF interface information.
If no OSPF process is specified, the OSPF interface information of all OSPF processes is displayed.
# Display OSPF interface information.
<Sysname> display ospf interface
          OSPF Process 1 with Router ID 192.168.1.1
                  Interfaces
 Area: 0.0.0.0
 IP Address      Type         State    Cost  Pri   DR              BDR
 192.168.1.1     PTP          P-2-P    1562  1     0.0.0.0         0.0.0.0
 Area: 0.0.0.1
 172.16.0.1      Broadcast    DR       1     1     172.16.0.1      0.0.0.0
Table 3-6 Description on the fields of the display ospf interface command
Area
Area ID of the interface
IP address
Interface IP address (regardless of whether TE is enabled or not)
Interface network type: PTP, PTMP, Broadcast, or NBMA
Interface state defined by interface state machine: DOWN, Waiting, p-2-p, DR, BDR, or DROther
Cost
Interface cost
Pri
Router priority
DR
The DR on the interface’s network segment
BDR
The BDR on the interface’s network segment
display ospf lsdb
display ospf [ process-id ] lsdb [ brief | [ { ase | router | network | summary | asbr | nssa | opaque-link | opaque-area | opaque-as } [ link-state-id ] ] [ originate-router advertising-router-id | self-originate ] ]
View
brief: Displays brief LSDB information.
ase: Displays Type-5 LSA (AS External LSA) information in the LSDB.
router: Displays Type-1 LSA (Router LSA) information in the LSDB.
network: Displays Type-2 LSA (Network LSA) information in the LSDB.
summary: Displays Type-3 LSA (Network Summary LSA) information in the LSDB.
asbr: Displays Type-4 LSA (ASBR Summary LSA) information in the LSDB.
nssa: Displays Type-7 LSA (NSSA External LSA) information in the LSDB.
opaque-link: Displays Type-9 LSA (Opaque-link LSA) information in the LSDB.
opaque-area: Displays Type-10 LSA (Opaque-area LSA) information in the LSDB.
opaque-as: Displays Type-11 LSA (Opaque-AS LSA) information in the LSDB.
link-state-id: Link state ID, in the IP address format.
originate-router advertising-router-id: Displays information about LSAs originated by the specified router.
self-originate: Displays information about self-originated LSAs.
Use the display ospf lsdb command to display LSDB information.
If no OSPF process is specified, LSDB information of all OSPF processes is displayed.
# Display OSPF LSDB information.
<Sysname> display ospf lsdb
         OSPF Process 1 with Router ID 192.168.0.1
                 Link State Database
                         Area: 0.0.0.0
 Type      LinkState ID    AdvRouter          Age  Len   Sequence   Metric
 Router    192.168.0.2     192.168.0.2        474  36    80000004       0
 Router    192.168.0.1     192.168.0.1         21  36    80000009       0
 Network   192.168.0.1     192.168.0.1        321  32    80000003       0
 Sum-Net   192.168.1.0     192.168.0.1        321  28    80000002       1
 Sum-Net   192.168.2.0     192.168.0.2        474  28    80000002       1
                         Area: 0.0.0.1
 Router    192.168.0.1     192.168.0.1         21  36    80000005       0
 Sum-Net   192.168.2.0     192.168.0.1        321  28    80000002       2
 Sum-Net   192.168.0.0     192.168.0.1        321  28    80000002       1
Table 3-7 Description on the fields of the display ospf lsdb command
Area
Area
LSA type
LinkState ID
Linkstate ID
AdvRouter
The router that advertised the LSA
Age
Age of the LSA
Len
Length of the LSA
Sequence
Sequence number of the LSA
Metric
Cost of the LSA
# Display Type2 LSA (Network LSA) information in the LSDB.
[Sysname] display ospf 1 lsdb network
                          Area: 0.0.0.0
                  Link State Database
    Type      : Network
    LS ID     : 192.168.0.2
    Adv Rtr   : 192.168.2.1
    LS Age    : 922
    Len       : 32
    Options   :  E
    Seq#      : 80000003
    Chksum    : 0x8d1b
    Net Mask  : 255.255.255.0
       Attached Router    192.168.1.1
       Attached Router    192.168.2.1
Table 3-8 Description on the fields of the display ospf 1 lsdb network command
LSA type
LS ID
DR IP address
Adv Rtr
Router that advertised the LSA
LS Age
LSA age time
Len
LSA length
Options
LSA options
Seq#
LSA sequence number
Chksum
LSA checksum
Net Mask
Network mask
Attached Router
ID of the router that established adjacency with the DR, and ID of the DR itself
View
Use the display ospf nexthop command to display OSPF next hop information.
If no OSPF process is specified, the next hop information of all OSPF processes is displayed.
# Display OSPF next hop information.
<Sysname> display ospf nexthop
                 Routing Nexthop Information
  Next Hops:
  Address         Refcount  IntfAddr        Intf Name
  192.168.0.1     1         192.168.0.1     Vlan-interface1
  192.168.0.2     1         192.168.0.1     Vlan-interface1
  192.168.1.1     1         192.168.1.1     Vlan-interface10
Table 3-9 Description on the fields of the display ospf nexthop command
Next hops
Information about Next hops
Address
Next hop address
Refcount
Reference count, namely, routes that reference the next hop
IntfAddr
Outbound interface address
Intf Name
Outbound interface name
display ospf peer
display ospf [ process-id ] peer [ verbose | [ interface-type interface-number ] [ neighbor-id ] ]
View
verbose: Displays detailed neighbor information.
neighbor-id: Neighbor router ID.
Use the display ospf peer command to display information about OSPF neighbors.
Note that:
If no OSPF process is specified, OSPF neighbor information of all OSPF processes is displayed.
If an interface is specified, the neighbor on the interface is displayed.
If a neighbor ID is specified, detailed information about the neighbor is displayed,
If neither interface nor neighbor ID is specified, brief information about neighbors of the specified OSPF process or all OSPF processes is displayed.
# Display detailed OSPF neighbor information.
<Sysname> display ospf peer verbose
          OSPF Process 1 with Router ID 192.168.0.138
                  Neighbors
 Area 0.0.0.1 interface 192.168.0.138(Vlan-interface1)'s neighbors
 Router ID: 192.168.0.136    Address: 192.168.0.136    GR State: Normal
   State: Full  Mode: Nbr is Slave  Priority: 1
   DR: 192.168.0.138  BDR: 192.168.0.136  MTU: 0
   Dead timer due in 40  sec
   Neighbor is up for 00:12:59
   Neighbor state change count: 5
Table 3-10 Description on the fields of the display ospf peer verbose command
Router ID
Neighbor router ID
Address
Neighbor router address
GR State
GR state
Neighbor state: Down, Init, Attempt, 2-Way, Exstart, Exchange, Loading or Full
Mode
Neighbor mode for DD exchange: master or slave
Priority
Router priority
DR
BDR
MTU
Interface MTU
Dead timer times out in 40 seconds
The neighbor has been up for 00:12:59
Authentication sequence number
Count of neighbor state changes
# Display brief OSPF neighbor information.
                        Neighbor Brief Information
 Area: 0.0.0.1
 Router ID       Address         Pri Dead-Time Interface       State
 192.168.0.136   192.168.0.136   1   37        Vlan1           Full/BDR
Table 3-11 Description on the fields of the display ospf peer command
Area
Neighbor area
Router ID
Neighbor router ID
Address
Neighbor interface address
Pri
Router priority
Dead time(s)
Dead interval remained
Interface connected to the neighbor
display ospf peer statistics
View
Use the display ospf peer statistics command to display OSPF neighbor statistics.
If no OSPF process is specified, OSPF neighbor statistics of all OSPF processes is displayed.
# Display OSPF neighbor statistics.
<Sysname> display ospf peer statistics
                            Neighbor Statistics
Area ID       Down  Attempt Init 2-Way ExStart Exchange Loading Full Total
0.0.0.1       0      0         0     0     0        0          0        1     1
Total         0      0         0     0     0        0          0        1     1
Table 3-12 Description on the fields of the display ospf peer statistics command
Area ID
Area ID
Down
Under this state, neighbor initial state, the router has not received any information from a neighboring router for a period of time.
Attempt
Available only in an NBMA network, such as Frame Relay, X.25 or ATM. Under this state, the OSPF router has not received any information from a neighbor for a period but can send Hello packets with a longer interval to keep neighbor relationship.
Init
Under this state, the router has received a hello packet from a neighbor but the packet contains no IP address of itself, so mutual communication is not established.
2-Way
Indicates mutual communication between the router and its neighbor is established. DR/BDR election is finished under this state (or higher).
ExStart
Under this state, the router decides on sequence numbers for DD packets.
Exchange
Under this state, the router exchanges link state information with the neighbor.
Loading
Under this state, the router requests the neighbor for needed LSAs.
Full
Indicates LSDB synchronization has been accomplished between neighbors.
Total
Total number of neighbors under the same state
display ospf request-queue
View
interface-type interface-number: Interface type and number.
neighbor-id: Neighbor’s router ID.
Use the display ospf request-queue command to display OSPF request queue information.
If no OSPF process is specified, the OSPF request queue information of all OSPF processes is displayed.
# Display OSPF request queue information.
<Sysname> display ospf request-queue
                  OSPF Request List
  The Router's Neighbor is Router ID 2.2.2.2         Address 10.1.1.2
  Interface 10.1.1.1         Area 0.0.0.0
  Request list:
       Type       LinkState ID      AdvRouter         Sequence   Age
       Router     2.2.2.2           1.1.1.1           80000004   1
       Network    192.168.0.1       1.1.1.1          80000003   1
       Sum-Net    192.168.1.0       1.1.1.1         80000002   2
Table 3-13 Description on the fields of the display ospf request queue command
Neighbor router ID
Address
Neighbor interface IP address
Local interface IP address
Area
Area ID
Request list
Request list information
LSA type
LinkState ID
Link state ID
AdvRouter
Advertising router
Sequence
LSA sequence number
Age
LSA age
display ospf retrans-queue
View
Use the display ospf retrans-queue command to display retransmission queue information.
If no OSPF process is specified, the retransmission queue information of all OSPF processes is displayed.
# Display OSPF retransmission queue information.
<Sysname> display ospf retrans-queue
                  OSPF Retransmit List
  Retransmit list:
       Router     2.2.2.2           2.2.2.2           80000004   1
       Network    12.18.0.1         2.2.2.2          80000003   1
       Sum-Net    12.18.1.0         2.2.2.2         80000002   2
Table 3-14 Description on the fields of the display ospf retrans-queue command
Neighbor router ID
Address
Interface address of the router
Area
Area ID
Retransmit list
Retransmission list
LSA type
LinkState ID
Link state ID
AdvRouter
Advertising router
Sequence
LSA sequence number
Age
LSA age
display ospf routing
display ospf [ process-id ] routing [ interface interface-type interface-number ] [ nexthop nexthop-address ]
View
interface interface-type interface-number: Displays OSPF routing information advertised via the interface.
nexthop nexthop-address: Displays OSPF routing information with the specified next hop.
Use the display ospf routing command to display OSPF routing information.
If no OSPF process is specified, the routing information of all OSPF processes is displayed.
# Display OSPF routing information.
<Sysname> display ospf routing
                   Routing Tables
 Routing for Network
 Destination        Cost  Type       NextHop         AdvRouter     Area
 192.168.1.0/24     1562  stub       192.168.1.2     192.168.1.2   0.0.0.0
 172.16.0.0/16      1563  Inter      192.168.1.1     192.168.1.1   0.0.0.0
 Total Nets: 2
 Intra Area: 1  Inter Area: 1  ASE: 0  NSSA: 0
Table 3-15 Description on the fields of the display ospf routing command
Destination
Destination network
Cost
Cost to destination
Route type: intra-area, transit, stub, inter-area, type1 external, type2 external.
NextHop
Next hop address
AdvRouter
Advertising router
Area
Area ID
Total Nets
Total networks
Intra Area
Total intra-area routes
Inter Area
Total inter-area routes
ASE
Total ASE routes
NSSA
Total NSSA routes
display ospf vlink
View
Use the display ospf vlink command to display OSPF virtual link information.
If no OSPF process is specified, the OSPF virtual link information of all OSPF processes is displayed.
# Display OSPF virtual link information.
<Sysname> display ospf vlink
                  Virtual Links
 Virtual-link Neighbor-ID  -> 2.2.2.2, Neighbor-State: Full
 Interface: 10.1.2.1 (Vlan-interface1)
 Cost: 1  State: P-2-P  Type: Virtual
 Transit Area: 0.0.0.1
 Timers: Hello 10 , Dead 40 , Retransmit 5 , Transmit Delay 1
Table 3-16 Description on the fields of the display ospf vlink command
Virtual-link Neighbor-id
ID of the neighbor connected to the router via the virtual link
Neighbor-State
Neighbor State: Down, Attempt, Init, 2-Way, ExStart, Exchange, Loading, Full.
Local interface’s IP address and name of the virtual link
Cost
Interface route cost
Interface state
Type: virtual link
Transit Area
Transit area ID
Timers
Values of timers: hello, dead, poll (NBMA), retransmit, and interface transmission delay
enable link-local-signaling
undo enable link-local-signaling
View
OSPF view
None
Use the enable link-local-signaling command to enable the OSPF link-local signaling (LLC) capability.
Use the undo enable link-local-signaling command to disable the OSPF link-local signaling capability.
By default, this capability is disabled.
# Enable link-local signaling for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] enable link-local-signaling
enable log
enable log [ config | error | state ]
undo enable log [ config | error | state ]
View
OSPF view
config: Enables configuration logging.
error: Enables error logging.
state: Enables state logging.
Use the enable command to enable specified OSPF logging.
Use the undo enable command to disable specified OSPF logging.
OSPF logging is disabled by default.
If no keyword is specified, all logging is enabled.
# Enable OSPF logging.
[Sysname] ospf 100
[Sysname-ospf-100] enable log
enable out-of-band-resynchronization
undo enable out-of-band-resynchronization
View
OSPF view
None
Use the enable out-of-band-resynchronization command to enable the OSPF out-of-band resynchronization (OOB-Resynch) capability.
Use the undo enable out-of-band-resynchronization command to disable the OSPF out-of-band resynchronization capability.
By default, the capability is disabled.
# Enable the out-of-band resynchronization capability for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] enable out-of-band-resynchronization
filter
filter { acl-number | ip-prefix ip-prefix-name } { import | export }
undo filter { import | export }
View
OSPF area view
acl-number: ACL number, in the range 2000 to 3999.
ip-prefix-name: IP prefix list name, a string of up to 19 characters.
import: Filters incoming LSAs.
export: Filters outgoing LSAs.
Use the filter command to configure incoming/outgoing summary LSAs filtering on an ABR.
Use the undo filter command to disable summary LSA filtering.
By default, summary LSAs filtering is disabled.
This command is only available on an ABR.
# Apply IP prefix list my-prefix-list to filter inbound Type-3 LSAs, and apply ACL 2000 to filter outbound Type-3 LSAs in OSPF Area 1.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] filter ip-prefix my-prefix-list import
[Sysname-ospf-100-area-0.0.0.1] filter 2000 export
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] ]
View
OSPF view
acl-number: Number of an ACL used to filter outgoing redistributed routes, in the range 2000 to 3999.
ip-prefix-name: Name of an IP prefix list used to filter outgoing redistributed routes, a string of up to 19 characters.
protocol: Specifies a protocol from which to filter redistributed routes. The protocol can be direct, static, rip, or ospf. If no protocol is specified, all redistributed routes are filtered.
process-id: Process ID, which is required when the protocol is ospf or rip, in the range 1 to 65535.
Use the filter-policy export command to configure the filtering of outgoing redistributed routes.
Use the undo filter-policy export command to disable the filtering.
By default, the filtering of outgoing redistributed routes is not configured.
You can use this command to filter outgoing redistributed routes as needed.
# Filter outgoing redistributed routes using ACL 2000.
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 export
filter-policy { acl-number | ip-prefix ip-prefix-name | gateway ip-prefix-name } import
View
OSPF view
acl-number: Number of an ACL used to filter incoming routes, in the range 2000 to 3999.
ip-prefix-name: Name of an IP address prefix list used to filter incoming routes, a string of up to 19 characters.
gateway ip-prefix-name: Name of an IP address prefix list used to filter routes from the specified neighbors, a string of up to 19 characters.
Use the filter-policy import command to configure the filtering of incoming routes.
Use the undo filter-policy import command to disable the filtering.
By default, no filtering of incoming routes is configured.
You can use the command to filter incoming routes as needed.
# Filter incoming routes using ACL 2000.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 192.168.10.0 0.0.0.255
[Sysname-acl-basic-2000] quit
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 import
graceful-restart
graceful-restart [ nonstandard | ietf ]
undo graceful-restart
View
OSPF view
nonstandard: Enables the non-IETF GR capability.
ietf: Enables the IETF GR capability.
Use the graceful-restart command to enable OSPF Graceful Restart capability.
Use the undo graceful-restart command to disable OSPF Graceful Restart capability.
By default, OSPF Graceful Restart capability is disabled.
Note the following:
l          Enable Opaque LSA advertisement and reception with the opaque-capability enable command before enabling the IETF GR capability for OSPF.
l          Before enabling non-IETF GR capability for OSPF, enable OSPF LLS (link local signaling) with the enable link-local-signaling command and OOB (out of band resynchronization) with the enable out-of-band-resynchronization command.
l          If the keywords nonstandard and ietf are not specified when OSPF GR is enabled, nonstandard is the default.
Related commands: enable link-local-signaling, enable out-of-band-resynchronization, opaque-capability enable.
# Enable IETF Graceful Restart for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] opaque-capability enable
[Sysname-ospf-1] graceful-restart ietf
# Enable non-IETF Graceful Restart for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart nonstandard
graceful-restart help
graceful-restart help { acl-number | prefix prefix-list }
undo graceful-restart help
View
OSPF view
acl-number: Basic or advanced ACL number, in the range 2000 to 3999.
prefix-list: Name of the specified IP prefix list, a string of 1 to 19 characters.
Use the graceful-restart help command to configure for which OSPF neighbors the current router can serve as a GR Helper. (The neighbors are specified by the ACL or the IP prefix list.)
Use the undo graceful-restart help command to restore the default.
By default, the router can serve as a GR Helper for any OSPF neighbor.
# Configure the switch as a GR Helper for OSPF neighbors defined in the ACL 2001.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart help 2001
graceful-restart interval
graceful-restart interval interval-value
undo graceful-restart interval
View
OSPF view
interval-value: Specifies the Graceful Restart interval, in the range 40 to 1,800 seconds.
Use the graceful-restart interval command to configure the Graceful Restart interval.
Use the undo graceful-restart interval command to restore the default Graceful Restart interval.
By default, the Graceful Restart interval is 120 seconds.
Note that the Graceful Restart interval of OSPF cannot be less than the maximum value of dead intervals on all OSPF interfaces; otherwise, the Graceful Restart of OSPF may fail.
Related commands: ospf timer dead.
# Configure the Graceful Restart interval for OSPF process 1 as 100 seconds.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart interval 100
host-advertise
host-advertise ip-address cost
undo host-advertise ip-address
View
OSPF area view
ip-address: IP address of a host
cost: Cost of the route, in the range 1 to 65535.
Use the host-advertise command to advertise a host route.
Use the undo host-advertise command to remove a host route.
No host route is advertised by default.
# Advertise the host route 1.1.1.1 with a cost of 100.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] host-advertise 1.1.1.1 100
import-route
import-route protocol [ process-id ] [ cost cost | type type | tag tag | route-policy route-policy-name ]*
undo import-route protocol [ process-id ]
View
OSPF view
protocol: Redistributes routes from the protocol, which can be direct, static, rip or ospf.
process-id: Process ID, in the range 1 to 65535. The default is 1. It is available only when the protocol is rip or ospf.
cost cost: Specifies a route cost, in the range 0 to 16777214. The default is 1.
type type: Specifies a cost type, 1 or 2. The default is 2.
tag tag : Specifies a tag for external LSAs. The default is 1.
route-policy route-policy-name: Specifies a route policy to redistribute qualified routes only. A Route policy name is a string of up to 19 characters.
Use the import-route command to redistribute routes from another protocol.
Use the undo import-route command to disable route redistribution from a protocol.
Route redistribution from another protocol is not configured by default.
OSPF prioritize routes as follows:
l          Intra-area route
l          Inter-area route
l          Type1 External route
l          Type2 External route
An intra-area route is a route in an OSPF area. An inter-area route is between any two OSPF areas. Both of them are internal routes.
An external route is a route to a destination outside the OSPF AS.
A Type-1 external route is an IGP route, such as RIP or STATIC, which has high reliability and whose cost is comparable with the cost of OSPF internal routes. Therefore, the cost from an OSPF router to a Type-1 external route’s destination equals the cost from the router to the corresponding ASBR plus the cost from the ASBR to the external route’s destination.
A Type-2 external route is an EGP route, which has low credibility, so OSPF considers the cost from the ASBR to a Type-2 external route is much bigger than the cost from the ASBR to an OSPF internal router. Therefore, the cost from an internal router to a Type-2 external route’s destination equals the cost from the ASBR to the Type-2 external route’s destination.
Related commands: default-route-advertise.
The import-route command cannot redistribute default routes.
# Redistribute routes from RIP process 40 and specify the type, tag, and cost as 2, 33 and 50 for redistributed routes.
[Sysname] ospf 100
[Sysname-ospf-100] import-route rip 40 type 2 tag 33 cost 50
log-peer-change
log-peer-change
undo log-peer-change
View
OSPF view
None
Use the log-peer-change command to enable the logging of OSPF neighbor state changes.
Use the undo log-peer-change command to disable the logging.
The logging is enabled by default.
With this feature enabled, information about neighbor state changes is displayed on the terminal until the feature is disabled.
# Disable the logging of neighbor state changes for OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] undo log-peer-change
lsa-arrival-interval
lsa-arrival-interval interval
undo lsa-arrival-interval
View
OSPF view
interval: Specifies the minimum LSA repeat arrival interval in milliseconds, in the range 0 to 60000.
Use the lsa-arrival-interval command to specify the minimum LSA repeat arrival interval.
Use the undo lsa-arrival-interval command to restore the default.
The interval defaults to 1000 milliseconds.
If an LSA that has the same LSA type, LS ID, originating router ID with the previous LSA is received within the interval, the LSA will be discarded. This feature helps protect routers and bandwidth from being over-consumed due to frequent network changes.
It is recommended the interval set with the lsa-arrival-interval command is smaller or equal to the initial interval set with the lsa-generation-interval command.
Related commands: lsa-generation-interval.
# Set the LSA minimum repeat arrival interval to 200 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsa-arrival-interval 200
lsa-generation-interval maximum-interval [ initial-interval [ incremental-interval ] ]
undo lsa-generation-interval
View
OSPF view
maximum-interval: Maximum LSA generation interval in seconds, in the range 1 to 60.
initial-interval: Minimum LSA generation interval in milliseconds, in the range 10 to 60000. The default is 0.
incremental-interval: LSA generation incremental interval in milliseconds, in the range 10 to 60000. The default is 5000 milliseconds.
Use the lsa-generation-interval command to configure the OSPF LSA generation interval.
Use the undo lsa-generation-interval command to restore the default.
The LSA generation interval defaults to 5 seconds.
With this command configured, when network changes are not frequent, LSAs are generated at the initial-interval. If network changes become frequent, LSA generation interval is incremented by a specified value each time a generation happens, up to the maximum-interval.
Related commands: lsa-arrival-interval.
# Configure the maximum LSA generation interval as 2 seconds, minimum interval as 100 milliseconds and incremental interval as 100 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsa-generation-interval 2 100 100
lsdb-overflow-limit
lsdb-overflow-limit number
undo lsdb-overflow-limit
View
OSPF view
number: Specifies the upper limit of external LSAs in the LSDB, in the range 1 to 1000000.
Use the lsdb-overflow-limit command to specify the upper limit of external LSAs in the LSDB.
Use the undo lsdb-overflow-limit command to cancel the limitation.
External LSAs in the LSDB are unlimited by default.
# Specify the upper limit of external LSAs as 400000.
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-limit 400000
maximum load-balancing
maximum load-balancing maximum
undo maximum load-balancing
View
OSPF view
maximum: Maximum number of equal cost routes for load balancing, in the range 1 to 4. No load balancing is available when the number is set to 1.
Use the maximum load-balancing command to specify the maximum number of equal cost routes for load balancing.
Use the undo maximum load-balancing command to restore the default.
By default, the maximum number of equal cost routes is 4.
# Specify the maximum number of equal cost routes as 2.
[Sysname] ospf 100
[Sysname-ospf-100] maximum load-balancing 2
maximum-routes
maximum-routes { external | inter | intra } number
undo maximum-routes { external | inter | intra }
View
OSPF view
external: Specifies the maximum number of external routes.
inter: Specifies the maximum number of inter-area routes.
intra: Specifies the maximum number of intra-area routes.
number: Maximum route number, in the range 0 to 12288.
Use the maximum-routes command to specify the maximum route number of a specified type, inter-area, intra-area or external.
Use the undo maximum-routes command to restore the default route maximum value of a specified type.
By default, the maximum route number is 12288.
# Specify the maximum number of intra-area routes as 500.
[Sysname] ospf 100
[Sysname-ospf-100] maximum-routes intra 500
network
undo network ip-address wildcard-mask
View
OSPF area view
ip-address: IP address of a network.
wildcard-mask: Wildcard mask of the IP address. For example, the wildcard mask of mask 255.0.0.0 is 0.255.255.255.
Use the network command to enable OSPF on the interface attached to the specified network in the area.
Use the undo network command to disable OSPF on an interface.
By default, an interface neither belongs to any area nor runs OSPF.
You can configure one or multiple interfaces in an area to run OSPF. Note that the interface’s primary IP address must fall into the specified network segment to make the interface run OSPF. If only the interface’s secondary IP address falls into the network segment, the interface cannot run OSPF.
Related commands: ospf.
# Specify the interface whose primary IP address falls into 131.108.20.0/24 to run OSPF in Area 2.
[Sysname] ospf 100
[Sysname-ospf-100] area 2
[Sysname-ospf-100-area-0.0.0.2] network 131.108.20.0 0.0.0.255
nssa
nssa [ default-route-advertise | no-import-route | no-summary ]*
undo nssa
View
OSPF area view
default-route-advertise: Usable on an NSSA ABR or an ASBR only. If it is configured on an NSSA ABR, the ABR generates a default route in a Type-7 LSA into the NSSA regardless of whether the default route is available. If it is configured on an ASBR, only a default route is available on the ASBR can it generates the default route in a Type-7 LSA into the attached area.
no-import-route: Usable only on an NSSA ABR that is also the ASBR of the OSPF routing domain to disable redistributing routes in Type7 LSAs into the NSSA area, making sure that routes can be redistributed correctly.
no-summary: Usable only on an NSSA ABR to advertise only a default route in a Type-3 summary LSA into the NSSA area. In this way, all the other summary LSAs are not advertised into the area. Such an area is known as an NSSA totally stub area.
Use the nssa command to configure the current area as an NSSA area.
Use the undo nssa command to restore the default.
By default, no NSSA area is configured.
All routers attached to an NSSA area must be configured with the nssa command in area view.
Related commands: default-cost.
# Configure Area 1 as an NSSA area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] nssa
undo opaque-capability
View
OSPF view
None
Use the opaque-capability enable command to enable opaque LSA advertisement and reception. With the command configured, the OSPF device can receive and advertise the Type-9, Type-10 and Type-11 opaque LSAs.
Use the undo opaque-capability command to restore the default.
The feature is disabled by default.
# Enable advertising and receiving opaque LSAs.
[Sysname] ospf 100
[Sysname-ospf-100]opaque-capability enable
ospf
ospf [ process-id | router-id router-id ]*
undo ospf [ process-id ]
View
router-id: OSPF Router ID, in dotted decimal format.
Use the ospf command to enable an OSPF process.
Use the undo ospf command to disable an OSPF process.
No OSPF process is enabled by default.
Use the router-id argument to specify different Router IDs for these processes.
# Enable OSPF process 100 and specify Router ID 10.10.10.1.
[Sysname] ospf 100 router-id 10.10.10.1
[Sysname-ospf-100]
For MD5/HMAC-MD5 authentication:
ospf authentication-mode { md5 | hmac-md5 } key-id [ plain | cipher ] password
undo ospf authentication-mode { md5 | hmac-md5 } key-id
For simple authentication:
ospf authentication-mode simple [ plain | cipher ] password
undo ospf authentication-mode simple
View
Interface view
md5: MD5 authentication.
hmac-md5: HMAC-MD5 authentication.
simple: Simple authentication.
key-id: Authentication key ID, in the range 1 to 255.
plain | cipher: Plain or cipher password. If plain is specified, only plain password is supported and displayed upon displaying the configuration file. If cipher is specified, both plain and cipher are supported, but only cipher password is displayed when displaying the configuration file. If no keyword is specified, the cipher type is the default for the MD5/HMAC-MD5 authentication mode, and the plain type is the default for the simple authentication mode.
password: Password. Simple authentication: For plain type password, a plain password is a string of up to 8 characters; for cipher type password, a plain password is a string of up to 8 characters, and a cipher password is a string of up to 24 characters. MD5/HMAC-MD5 authentication: For plain type password, a plain password is a string of up to 16 characters; for cipher type password, a plain password is a string of up to 16 characters, and a cipher password is a string of up to 24 characters.
Use the ospf authentication-mode command to set the authentication mode and key ID on an interface.
Use the undo ospf authentication-mode command to remove specified configuration.
By default, no authentication is available on an interface.
Interfaces attached to the same network segment must have the same authentication password and mode.
This configuration is not supported on the NULL interface.
Related commands: authentication-mode.
# Configure the network 131.119.0.0/16 in Area 1 to support MD5 cipher authentication, and set the interface key ID to 15, authentication password to abc, and password type to cipher.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] network 131.119.0.0 0.0.255.255
[Sysname-ospf-100-area-0.0.0.1] authentication-mode md5
[Sysname-ospf-100-area-0.0.0.1] quit
[Sysname-ospf-100] quit
[Sysname-Vlan-interface10] ospf authentication-mode md5 15 cipher abc
# Configure the network 131.119.0.0/16 in Area 1 to support simple authentication, and set for the interface the authentication password to abc, and password type to cipher.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] authentication-mode simple
[Sysname-Vlan-interface10] ospf authentication-mode simple cipher abc
ospf cost
ospf cost value
undo ospf cost
View
Interface view
value: OSPF cost, in the range 1 to 65535.
Use the ospf cost command to set an OSPF cost for the interface.
Use the undo ospf cost command to restore the default OSPF cost for the interface.
By default, an OSPF interface calculates its cost with the formula: interface default OSPF cost=100 Mbps/interface bandwidth(Mbps). Default OSPF costs of some interfaces are:
l          1785 for the 56 kbps serial interface
l          1562 for the 64 kbps serial interface
l          48 for the E1 (2.048 Mbps) interface
l          1 for the Ethernet interface
You can use the ospf cost command to set an OSPF cost for an interface manually.
# Set the OSPF cost for the interface to 65.
[Sysname-Vlan-interface10] ospf cost 65
ospf dr-priority
ospf dr-priority priority
undo ospf dr-priority
View
Interface view
priority: DR Priority of the interface, in the range 0 to 255.
Use the ospf dr-priority command to set the priority for DR/BDR election on an interface.
Use the undo ospf dr-priority command to restore the default value.
By default, the priority is 1.
The bigger the value, the higher the priority.
# Set the DR priority on the current interface to 8.
[Sysname-Vlan-interface10] ospf dr-priority 8
ospf mib-binding
ospf mib-binding process-id
undo ospf mib-binding
View
Use the ospf mib-binding command to bind an OSPF process to MIB operation.
Use the undo ospf mib-binding command to restore the default.
By default, MIB operation is bound to the first enabled OSPF process.
# Bind OSPF process 100 to MIB operation.
[Sysname] ospf mib-binding 100
ospf mtu-enable
ospf mtu-enable
undo ospf mtu-enable
View
Interface view
None
Use the ospf mtu-enable command to enable an interface to add the real MTU into DD packets.
Use the undo ospf mtu-enable command to restore the default.
By default, an interface adds a MTU of 0 into DD packets, that is, no real MTU is added.
# Enable the interface to add the real MTU value into DD packets.
[Sysname-Vlan-interface10] ospf mtu-enable
ospf timer dead
ospf timer dead seconds
undo ospf timer dead
View
Interface view
seconds: Dead interval in seconds, in the range 1 to 2147483647.
Use the ospf timer dead command to set the dead interval.
Use the undo ospf timer dead command to restore the default.
The dead interval defaults to 40s for Broadcast, P2P interfaces and defaults to 120s for P2MP and NBMA interfaces.
If an interface receives no hello packet from the neighbor within the dead interval, the interface considers the neighbor down. The dead interval on an interface is at least four times the hello interval. Any two routers attached to the same segment must have the same dead interval.
Related commands: ospf timer hello.
# Configure the dead interval on the current interface as 60 seconds.
[Sysname-Vlan-interface10] ospf timer dead 60
ospf timer hello
ospf timer hello seconds
undo ospf timer hello
View
Interface view
seconds: Hello interval in seconds, in the range 1 to 65535.
Use the ospf timer hello command to set the hello interval on an interface.
Use the undo ospf timer hello command to restore the default hello interval on an interface.
The hello interval defaults to 10s for P2P and Broadcast interfaces, and defaults to 30s for P2MP and NBMA interfaces.
The shorter the hello interval is, the faster the topology converges and the more resources are consumed. Make sure the hello interval on two neighboring interfaces is the same.
# Configure the hello interval on the current interface as 20 seconds.
[Sysname-Vlan-interface10] ospf timer hello 20
ospf timer poll
ospf timer poll seconds
undo ospf timer poll
View
Interface view
seconds: Poll interval in seconds, in the range 1 to 2147483647.
Use the ospf timer poll command to set the poll interval on an NBMA interface.
Use the undo ospf timer poll command to restore the default value.
By default, the poll interval is 120s.
When an NBMA interface finds its neighbor is down, it will send hello packets at the poll interval. The poll interval is at least four times the hello interval.
# Set the poll timer interval on the current interface to 130 seconds.
[Sysname-Vlan-interface10] ospf timer poll 130
ospf timer retransmit
ospf timer retransmit interval
undo ospf timer retransmit
View
Interface view
interval: LSA retransmission interval in seconds, in the range 1 to 3600.
Use the ospf timer retransmit command to set the LSA retransmission interval on an interface.
Use the undo ospf timer retransmit command to restore the default.
The interval defaults to 5s.
After sending an LSA, an interface waits for an acknowledgement packet. If the interface receives no acknowledgement within the retransmission interval, it will retransmit the LSA.
The retransmission interval should not be so small to avoid unnecessary retransmissions.
# Set the LSA retransmission interval to 8 seconds.
[Sysname-Vlan-interface10] ospf timer retransmit 8
ospf trans-delay
ospf trans-delay seconds
undo ospf trans-delay
View
Interface view
seconds: LSA transmission delay in seconds, in the range 1 to 3600.
Use the ospf trans-delay command to set the LSA transmission delay on an interface.
Use the undo ospf trans-delay command to restore the default.
The delay defaults to 1s.
Each LSA in the LSDB has an age that is incremented by 1 every second, but the age does not change during transmission. It is necessary to add a transmission delay into its age time, which is important for low speed networks.
# Set the LSA transmission delay to 3 seconds on the current interface.
[Sysname-Vlan-interface10] ospf trans-delay 3
preference
preference [ ase ] [ route-policy route-policy-name ] value
undo preference [ ase ]
View
OSPF view
ase: Sets a priority for ASE routes. If the keyword is not specified, using the command sets a priority for OSPF internal routes.
route-policy: Applies a routing policy to set priorities for specified routes.
route-policy-name: Routing policy name, a string of 1 to 19 characters.
value: Priority value, in the range 1 to 255. A smaller value represents a higher priority.
Use the preference command to set the priority of OSPF routes.
Use the undo preference command to restore the default.
The priority of OSPF internal routes defaults to 10, and the priority of OSPF external routes defaults to 150.
If a routing policy is specified, priorities defined by the routing policy will apply to matched routes, and the priorities set with the preference command apply to OSPF routes not matching the routing policy.
A router may run multiple routing protocols. When several routing protocols find routes to the same destination, the router uses the route found by the protocol with the highest priority.
# Set a priority of 150 for OSPF internal routes.
[Sysname] ospf 100
[Sysname-ospf-100] preference 150
reset ospf counters
reset ospf [ process-id ] counters [ neighbor [ interface-type interface-number ] [ router-id ] ]
View
neighbor: Clears neighbor statistics.
router-id: Neighbor Router ID.
Use the reset ospf counters command to reset OSPF counters. If no OSPF process is specified, counters of all OSPF processes are reset.
# Reset OSPF counters.
<Sysname> reset ospf counters
reset ospf process
View
graceful-restart: Starts GR for the OSPF process.
Use the reset ospf process command to reset all OSPF processes or a specified process.
Using the reset ospf process command will:
l          Clear all invalid LSAs without waiting for their timeouts;
l          Make a newly configured Router ID take effect;
l          Start a new round of DR/BDR election;
l          Not remove any previous OSPF configurations.
The system prompts whether to reset OSPF process upon execution of this command.
# Reset all OSPF processes.
<Sysname> reset ospf process
reset ospf redistribution
View
Use the reset ospf redistribution command to restart route redistribution. If no process ID is specified, using the command restarts route redistribution for all OSPF processes.
# Restart route redistribution.
<Sysname> reset ospf redistribution
rfc1583 compatible
rfc1583 compatible
undo rfc1583 compatible
View
OSPF view
None
Use the rfc1583 compatible command to make routing rules defined in RFC1583 compatible.
Use the undo rfc1583 compatible command to disable the function.
By default, RFC1583 routing rules are compatible.
RFC1583 and RFC2328 have different routing rules on selecting the best route when multiple AS external LSAs describe routes to the same destination. Using this command can make them compatible.
# Make RFC1583 routing rules compatible.
[Sysname] ospf 100
[Sysname-ospf-100] rfc1583 compatible
silent-interface
silent-interface { all | interface-type interface-number }
undo silent-interface { all | interface-type interface-number }
View
OSPF view
all: Disables all interfaces from sending OSPF packets.
Use the silent-interface command to disable an interface or all interfaces from sending OSPF packets.
Use the undo silent-interface command to restore the default.
By default, an interface sends OSPF packets.
A disabled interface is a passive interface, which cannot send any hello packet.
To make no routing information obtained by other routers on a network segment, you can use this command to disable the interface from sending OSPF packets.
# Disable an interface from sending OSPF packets.
[Sysname] ospf 100
[Sysname-ospf-100] silent-interface vlan-interface 10
snmp-agent trap enable ospf
snmp-agent trap enable ospf [ process-id ] [ ifauthfail | ifcfgerror | ifrxbadpkt | ifstatechange | iftxretransmit | lsdbapproachoverflow | lsdboverflow | maxagelsa | nbrstatechange | originatelsa | vifcfgerror | virifauthfail | virifrxbadpkt | virifstatechange | viriftxretransmit | virnbrstatechange ] *
undo snmp-agent trap enable ospf [ process-id ] [ ifauthfail | ifcfgerror | ifrxbadpkt | ifstatechange | iftxretransmit | lsdbapproachoverflow | lsdboverflow | maxagelsa | nbrstatechange | originatelsa | vifcfgerror | virifauthfail | virifrxbadpkt | virifstatechange | viriftxretransmit | virnbrstatechange ] *
View
ifauthfail: Interface authentication failure information.
ifcfgerror: Interface configuration error information.
ifrxbadpkt: Information about error packets received.
ifstatechange: Interface state change information.
iftxretransmit: Packet receiving and forwarding information.
lsdbapproachoverflow: Information about cases approaching LSDB overflow.
lsdboverflow: LSDB overflow information.
maxagelsa: LSA max age information.
nbrstatechange: Neighbor state change information.
originatelsa: Information about LSAs originated locally.
vifauthfail: Virtual interface authentication failure information.
vifcfgerror: Virtual interface configuration error information.
virifauthfail: Virtual interface authentication failure information.
virifrxbadpkt: Information about error packets received by virtual interfaces.
virifstatechange: Virtual interface state change information.
viriftxretransmit: Virtual interface packet retransmission information.
virnbrstatechange: Virtual interface neighbor state change information.
Use the snmp-agent trap enable ospf command to enable the sending of SNMP traps for a specified OSPF process. If no process is specified, the feature is enabled for all processes.
Use the undo snmp-agent trap enable ospf command to disable the feature.
By default, this feature is enabled.
Refer to SNMP-RMON in H3C WX6103 Access Controller Switch Interface Board Command Reference for related information.
# Enable the sending of SNMP traps for all OSPF processes.
[Sysname] snmp-agent trap enable ospf
spf-schedule-interval
spf-schedule-interval maximum-interval [ minimum-interval  [ incremental-interval ] ]
undo spf-schedule-interval
View
OSPF view
maximum-interval: Maximum SPF calculation interval in seconds, in the range 1 to 60.
minimum-interval: Minimum SPF calculation interval in milliseconds, in the range 10 to 60000, which defaults to 0.
incremental-interval: Incremental value in milliseconds, in the range 10 to 60000, which defaults to 5000.
Use the spf-schedule-interval command to set the OSPF SPF calculation interval.
Use the undo spf-schedule-interval command to restore the default.
The interval defaults to 5 seconds.
Based on its LSDB, an OSPF router calculates the shortest path tree with itself being the root, and uses it to determine the next hop to a destination. Through adjusting the SPF calculation interval, you can protect bandwidth and router resources from being over-consumed due to frequent network changes.
With this command configured, when network changes are not frequent, SPF calculation applies at the minimum-interval. If network changes become frequent, the SPF calculation interval is incremented by the incremental-interval each time a calculation happens, up to the maximum-interval.
# Configure the SPF calculation maximum interval as 10 seconds, minimum interval as 500 milliseconds and incremental interval as 200 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] spf-schedule-interval 10 500 200
stub
stub [ no-summary ]
undo stub
View
OSPF area view
no-summary: Usable only on a stub ABR. With it configured, the ABR advertises only a default route in a Summary LSA into the stub area (such a stub area is known as a totally stub area).
Use the stub command to configure an area as a stub area.
Use the undo stub command to remove the configuration.
No area is stub area by default. To configure an area as a stub area, all routers attached to it must be configured with this command.
Note that, to concel the no-summary configuration on the ABR, simply execute the stub command again to overwrite it.
# Configure Area1 as a stub area.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] stub
stub-router
stub-router
undo stub-router
View
OSPF view
None
Use the stub-router command to configure the router as a stub router.
Use the undo stub-router command to restore the default.
By default, no router is configured as a stub router.
The router LSAs from the stub router may contain different link type values. A value of 3 means a link to the stub network, so the cost of the link remains unchanged. A value of 1, 2 or 4 means a point-to-point link, a link to a transit network or a virtual link; in such cases, a maximum cost value of 65535 is used. Thus, other neighbors find the links to the stub router have such big costs, they will not send packets to the stub router for forwarding as long as there is a route with a smaller cost.
# Configure a stub router.
[Sysname] ospf 100
[Sysname-ospf-100] stub-router
vlink-peer
vlink-peer router-id [ hello seconds | retransmit seconds | trans-delay seconds | dead seconds | simple [ plain | cipher ] password | { md5 | hmac-md5 } key-id [ plain | cipher ] password ]*
undo vlink-peer router-id [ hello | retransmit | trans-delay | dead | [ simple | { md5 | hmac-md5 } key-id ] ]*
View
OSPF area view
router-id: Router ID of the neighbor on the virtual link.
hello seconds: Hello interval in seconds, in the range 1 to 8192. The default is 10. It must be identical to the hello interval on its virtual link neighbor.
retransmit seconds: Retransmission interval in seconds, in the range 1 to 3600, which defaults to 5.
trans-delay seconds: Transmission delay interval in seconds, in the range 1 to 3600, which defaults to 1.
dead seconds: Dead interval in seconds, in the range 1 to 32768, which defaults to 40 and is identical to the value on its virtual link neighbor. The dead interval is at least four times the hello interval.
key-id: Key ID for MD5 or HMAC-MD5 authentication, in the range 1 to 255.
plain | cipher: Plain or cipher type. If plain is specified, only plain password is supported and displayed upon displaying the configuration file. If cipher is specified, both plain and cipher are supported, but only cipher password is displayed when displaying the configuration file. By default, MD5 and HMAC-MD5 support cipher password, and simple authentication supports plain password.
password: Plain or cipher password. Simple authentication: For plain type, a plain password is a string of up to 8 characters. For cipher type, a plain password is a string of up to 8 characters, and a cipher password is a string of up to 24 characters. MD5/HMAC-MD5 authentication: For plain type, a plain password is a string of up to 16 characters. For cipher type, a plain password is a string of up to 16 characters, and a cipher password is a string of up to 24 characters.
Use the vlink-peer command to configure a virtual link.
Use the undo vlink-peer command to remove a virtual link.
As defined in RFC2328, all non-backbone areas must maintain connectivity to the backbone. You can use the vlink-peer command to configure a virtual link to connect an area to the backbone.
Considerations on parameters:
l          The smaller the hello interval is, the faster the network converges and the more network resources are consumed.
l          A so small retransmission interval will lead to unnecessary retransmissions. A big value is appropriate for a low speed link.
l          You need to specify an appropriate transmission delay with the trans-delay keyword.
The authentication mode at the non-backbone virtual link end follows the one at the backbone virtual link end. The two authentication modes (MD5 or Simple) are independent, and you can specify neither of them.
Related commands: authentication-mode, display ospf.
# Configure a virtual link to the neighbor with router ID 1.1.1.1.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.2] vlink-peer 1.1.1.1
