H3C WX6103 Access Controller Switch Interface Board Command Reference-6W102
HomeSupportWirelessWX6000 Series Access ControllersReference GuidesCommand ReferencesH3C WX6103 Access Controller Switch Interface Board Command Reference-6W102
31-SSL-HTTPS Commands
31-SSL-HTTPS Commands 53.73 KB
The term switch in this document refers to a switch in a generic sense or an access controller configured with the switching function unless otherwise specified.
SSL Configuration Commands
ciphersuite
ciphersuite [ rsa_aes_128_cbc_sha | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha ] *
View
SSL server policy view
rsa_aes_128_cbc_sha: Specifies the key exchange algorithm of RSA, the data encryption algorithm of 128-bit AES_CBC, and the MAC algorithm of SHA.
rsa_des_cbc_sha: Specifies the key exchange algorithm of RSA, the data encryption algorithm of DES_CBC, and the MAC algorithm of SHA.
rsa_rc4_128_md5: Specifies the key exchange algorithm of RSA, the data encryption algorithm of 128-bit RC4, and the MAC algorithm of MD5.
rsa_rc4_128_sha: Specifies the key exchange algorithm of RSA, the data encryption algorithm of 128-bit RC4, and the MAC algorithm of SHA.
Use the ciphersuite command to specify the cipher suite(s) for an SSL server policy to support.
By default, an SSL server policy supports all cipher suites.
With no keyword specified, the command configures an SSL server policy to support all cipher suites.
# Specify the cipher suites for SSL server policy policy1 to support as rsa_rc4_128_md5 and rsa_rc4_128_sha.
[Sysname] ssl server-policy policy1
[Sysname-ssl-server-policy-policy1] ciphersuite rsa_rc4_128_md5 rsa_rc4_128_sha
client-verify enable
undo client-verify enable
View
None
Use the client-verify enable command to enable certificate-based SSL client authentication, that is, to enable the SSL server to perform certificate-based authentication of the client during the SSL handshake process.
Use the undo client-verify enable command to restore the default.
By default, certificate-based SSL client authentication is disabled.
# Enable certificate-based client authentication.
[Sysname-ssl-server-policy-policy1] client-verify enable
close-mode wait
close-mode wait
undo close-mode wait
View
None
Use the close-mode wait command to set the SSL connection close mode to wait. In this mode, after sending a close-notify message to a client, the server does not close the connection until it receives a close-notify message from the client.
Use the undo close-mode wait command to restore the default.
By default, an SSL server sends a close-notify alert message to the client and close the connection without waiting for the close-notify alert message from the client.
# Set the SSL connection close mode to wait mode.
[Sysname-ssl-server-policy-policy1] close-mode wait
display ssl client-policy
display ssl client-policy { policy-name | all }
View
policy-name: SSL client policy name, a string of 1 to 16 characters.
all: Displays information about all SSL client policies.
Use the display ssl client-policy command to view information about a specified or all SSL client policies.
# Display information about SSL client policy policy1.
<Sysname> display ssl client-policy policy1
 SSL Client Policy: policy1
     SSL Version: SSL 3.0
     PKI Domain: 1
     Prefer Ciphersuite:
         RSA_RC4_128_SHA
Table 1-1 Description on the fields of the display ssl client-policy command
SSL Client Policy
SSL Version
Version of the protocol used by the SSL client policy
PKI Domain
PKI domain of the SSL client policy
Prefer Ciphersuite
Preferred cipher suite of the SSL client policy
display ssl server-policy
display ssl server-policy { policy-name | all }
View
policy-name: SSL server policy name, a string of 1 to 16 characters.
all: Displays information about all SSL server policies.
Use the display ssl server-policy command to view information about a specified or all SSL server policies.
# Display information about SSL server policy policy1.
<Sysname> display ssl server-policy policy1
 SSL Server Policy: policy1
     PKI Domain: domain1
     Ciphersuite:
         RSA_RC4_128_MD5
         RSA_RC4_128_SHA
         RSA_DES_CBC_SHA
         RSA_AES_128_CBC_SHA
     Handshake Timeout: 3600
     Close-mode: wait disabled
     Session Timeout: 3600
     Session Cachesize: 500
     Client-verify: disabled
Table 1-2 Description on the fields of the display ssl server-policy command
SSL Server Policy
PKI Domain
PKI domain to which the SSL server policy belongs
Ciphersuite
Cipher suites supported by the SSL server policy
Handshake Timeout
Handshake timeout time of the SSL server policy
Close-mode
Close mode of the SSL server policy
Session Timeout
Session timeout time of the SSL server policy
Session Cachesize
Maximum number of buffered sessions of the SSL server policy
Client-verify
Whether client authentication is enabled
handshake timeout
handshake timeout time
undo handshake timeout
View
time: Handshake timeout time in seconds, in the range 180 to 7,200.
Use the handshake timeout command to set the handshake timeout time for an SSL server policy.
Use the undo handshake timeout command to restore the default.
By default, the handshake timeout time is 3,600 seconds.
# Set the handshake timeout time of SSL server policy policy1 to 3,000 seconds.
[Sysname-ssl-server-policy-policy1] handshake timeout 3000
pki-domain
pki-domain domain-name
undo pki-domain
View
SSL server policy view, SSL client policy view
domain-name: Name of a PKI domain, a string of 1 to 15 characters.
Use the pki-domain command to specify a PKI domain for an SSL server policy or SSL client policy.
Use the undo pki-domain command to restore the default.
By default, no PKI domain is configured for an SSL server policy or SSL client policy.
# Configure SSL server policy policy1 to use the PKI domain named server-domain.
[Sysname-ssl-server-policy-policy1] pki-domain server-domain
# Configure SSL client policy policy1 to use the PKI domain named client-domain.
[Sysname] ssl client-policy policy1
[Sysname-ssl-client-policy-policy1] pki-domain client-domain
prefer-cipher
prefer-cipher { rsa_aes_128_cbc_sha | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha }
undo prefer-cipher
View
Use the prefer-cipher command to specify the preferred cipher suite for an SSL client policy.
Use the undo prefer-cipher command to restore the default.
By default, the preferred cipher suite for an SSL client policy is rsa_rc4_128_md5.
# Set the preferred cipher suite for SSL client policy policy1 to rsa_aes_128_cbc_sha.
[Sysname-ssl-client-policy-policy1] prefer-cipher rsa_aes_128_cbc_sha
session
undo session { cachesize | timeout } *
View
size: Maximum number of cached sessions, in the range 100 to 1,000.
time: Caching timeout time in seconds, in the range 1,800 to 72,000.
Use the session command to set the maximum number of cached sessions and the caching timeout time.
Use the undo session command to restore the default.
By default, the maximum number of cached sessions is 500 and the caching timeout time is 3,600 seconds.
If the number of sessions in the cache reaches the maximum, SSL rejects to cache new sessions. If a session exists in the cache for a period equal to the caching timeout time, SSL removes it from the cache.
# Set the caching timeout time to 4,000 seconds and the maximum number of cached sessions to 600.
[Sysname-ssl-server-policy-policy1] session timeout 4000 cachesize 600
ssl client-policy
ssl client-policy policy-name
undo ssl client-policy { policy-name | all }
View
policy-name: SSL client policy name, a case-insensitive string of 1 to 16 characters, which cannot be “a”, “al” and “all”.
all: Specifies all SSL client policies.
Use the ssl client-policy command to create an SSL policy and enter its view.
Use the undo ssl client-policy command to remove a specified or all SSL client policies.
# Create an SSL client policy named policy1 and enter its view.
ssl server-policy
ssl server-policy policy-name
undo ssl server-policy { policy-name | all }
View
policy-name: SSL server policy name, a case-insensitive string of 1 to 16 characters, which cannot be “a”, “al” and “all”.
all: Specifies all SSL server policies.
Use the ssl server-policy command to create an SSL server policy and enter its view.
Use the undo ssl server-policy command to remove a specified or all SSL server policies.
Note that you cannot delete an SSL server policy that has been associated with one or more application layer protocols.
# Create an SSL server policy named policy1 and enter its view.
version
version { ssl3.0 | tls1.0 }
undo version
View
ssl3.0: Specifies SSL 3.0.
tls1.0: Specifies TLS 1.0.
Use the version command to specify the SSL protocol version for an SSL client policy.
Use the undo version command to restore the default.
By default, the SSL protocol version for an SSL client policy is TLS 1.0.
# Specify the SSL protocol version for SSL client policy policy1 as SSL 3.0.
[Sysname-ssl-client-policy-policy1] version ssl3.0
2  HTTPS Configuration Commands
display ip https
display ip https
View
None
Use the display ip https command to display information about HTTPS.
# Display information about HTTPS.
<Sysname> display ip https
SSL server policy: test
Certificate access-control-policy:
Basic ACL: 2222
Current connection: 0
Operation status: Running
Table 2-1 Description on the fields of the display ip https command
SSL server policy
The SSL server policy associated with the HTTPS service
The certificate attribute access control policy associated with the HTTPS service
Basic ACL
The basic ACL number associated with the HTTPS service
Current connection
The number of current connections
Operation status
Operation status
ip https acl
ip https acl acl-number
undo ip https acl
View
acl-number: Basic ACL number, in the range 2000 to 2999.
Use the ip https acl command to associate the HTTPS service with an ACL.
Use the undo ip https acl command to remove the association.
By default, the HTTPS service is not associated with any ACL.
# Associate the HTTPS service with an ACL. Only allow the clients within the 10.10.0.0/16 network segment to access the HTTPS server.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname-acl-basic-2001] quit
[Sysname] ip https acl 2001
ip https certificate access-control-policy
undo ip https certificate access-control-policy
View
policy-name: Name of the certificate attribute access control policy, a string of 1 to 16 characters.
Use the ip https certificate access-control-policy command to associate the HTTPS service with a certificate attribute access control policy.
Use the undo ip https certificate access-control-policy command to remove the association.
By default, the HTTPS service is not associated with any certificate attribute access control policy.
# Associate the HTTPS server to certificate attribute access control policy myacl.
[Sysname] ip https certificate access-control-policy myacl
ip https enable
ip https enable
undo ip https enable
View
None
Use the ip https enable command to enable the HTTPS service.
Use the undo ip https enable command to disable the HTTPS service.
By default, the HTTPS service is disabled.
Enabling of the HTTPS service triggers an SSL handshake negotiation process. During the process, if a local certificate of the device already exists, the SSL negotiation is successfully performed, and the HTTPS service can be started normally. If no local certificate exists, a certificate application process will be triggered by the SSL negotiation. Since the application process takes much time, the SSL negotiation often fails and the HTTPS service cannot be started normally. Therefore, the ip https enable command must be executed for multiple times to ensure normal startup of the HTTPS service.
# Enable the HTTPS service.
[Sysname] ip https enable
ip https ssl-server-policy
View
policy-name: Name of an SSL server policy, a string of 1 to 16 characters.
Use the ip https ssl-server-policy command to associate the HTTPS service with an SSL server-end policy.
By default, the HTTPS service is not associated with any SSL server-end policy.
Note that the HTTPS service can be enabled only after this command is configured successfully.
# Configure the HTTPS service to use SSL server-end policy myssl.
[Sysname] ip https ssl-server-policy myssl
