H3C WX6103 Access Controller Switch Interface Board Command Reference-6W102
HomeSupportWirelessWX6000 Series Access ControllersReference GuidesCommand ReferencesH3C WX6103 Access Controller Switch Interface Board Command Reference-6W102
12-IP Source Guard Commands
12-IP Source Guard Commands 28.83 KB
IP Source Guard Configuration Commands
The term switch in this document refers to a switching device in a generic sense or an access controller configured with the switching function unless otherwise specified.
display ip check source
display ip check source [ interface interface-type interface-number | ip-address ip-address | mac-address mac-address ]
View
interface interface-type interface-number: Displays the dynamic bindings of the port specified by its type and number.
ip-address ip-address: Displays the dynamic bindings of an IP address.
mac-address mac-address: Displays the dynamic bindings of an MAC address (in the format of H-H-H).
Use the display ip check source command to display dynamic bindings.
With no options specified, the command displays the dynamic bindings of all ports.
Related commands: ip check source.
# Display all dynamic bindings.
<Sysname> display ip check source
The following user address bindings have been configured:
 MAC               IP               Vlan   Port                         Status
 0001-0203-0406     192.168.0.1         2      GigabitEthernet0/0/1              DHCP-SNP
 0001-0203-0407     192.168.0.2         2      GigabitEthernet0/0/2              DHCP-SNP
 -----------------2 binding entries queried, 2 listed------------------
Table 1-1 Description on the fields of the display ip check source command
MAC
MAC address of the dynamic binding. N/A means that no MAC address is bound in the entry.
IP
IP address of the dynamic binding. N/A means that no IP address is bound in the entry.
Vlan
VLAN to which the obtained binding entry belongs. N/A means that no VLAN is bound in the entry.
Port
Port to which the dynamic binding entry is applied
Status
Type of dynamically obtaining the binding entry. DHCP-SNP means that the binding is dynamically obtained from DHCP snooping.
Counts of dynamic binding entries
display user-bind
display user-bind [ interface interface-type interface-number | ip-address ip-address | mac-address mac-address ]
View
interface interface-type interface-number: Displays the static bindings of the interface specified by it type and number.
ip-address ip-address: Displays the static bindings of an IP address.
mac-address mac-address: Displays the static bindings of an MAC address (in the format of H-H-H).
Use the display user-bind command to display static bindings.
With no options specified, the command displays static bindings of all interfaces.
Related commands: user-bind.
# Display all static bindings.
<Sysname> display user-bind
 0001-0203-0405      192.168.0.3           N/A    GigabitEthernet0/0/2                 Static
 0001-0203-0406      192.168.0.1           N/A    GigabitEthernet0/0/1                 Static
------------------2 binding entries queried, 2 listed------------------
Table 1-2 Description on the fields of the display user-bind command
MAC
MAC address of the binding. N/A means that no MAC address is bound in the entry.
IP
IP address of the binding. N/A means that no IP address is bound in the entry.
Vlan
Static binding entry does not support VLAN-port binding.
Port
Port of the binding
Status
Type of the binding. Static means that the binding is manually configured.
Counts of static binding entries
ip check source
ip check source { ip-address | ip-address mac-address | mac-address }
undo ip check source
View
Ethernet port view
ip-address: Specifies to bind source IP addresses to the port.
mac-address: Specifies to bind source MAC addresses to the port.
Use the ip check source command to configure the dynamic binding function on a port.
Use the undo ip check source command to restore the default.
By default, the dynamic binding function is disabled.
Note that you cannot configure the dynamic binding function on a port that is in an aggregation group.
Related commands: display ip check source.
# Configure dynamic binding function on port GigabitEthernet 0/0/1 to filter packets based on both source IP address and MAC address.
[Sysname] interface GigabitEthernet 0/0/1
[Sysname- GigabitEthernet0/0/1] ip check source ip-address mac-address
user-bind
user-bind { ip-address ip-address | ip-address ip-address mac-address mac-address | mac-address mac-address }
undo user-bind { ip-address ip-address | ip-address ip-address mac-address mac-address | mac-address mac-address }
View
Ethernet interface view
ip-address ip-address: Specifies the IP address for the static binding. The IP address can only be a Class A, Class B, or Class C address and can be neither 127.x.x.x nor 0.0.0.0.
mac-address mac-address: Specifies the MAC address for the static binding in the format of H-H-H. The MAC address cannot be all 0s, all Fs (a broadcast address), or a multicast address.
Use the user-bind command to configure a static binding. Use the undo user-bind command to delete a static binding.
By default, no static binding exists on a port.
Note that: The system does not support repeatedly configuring a binding entry to one port. A binding entry can be configured to multiple ports.
Related commands: display user-bind.
# Configure a static binding on port GigabitEthernet 0/0/1.
[Sysname- GigabitEthernet0/0/1] user-bind ip-address 192.168.0.1 mac-address 0001-0001-0001
