H3C WX6103 Access Controller Switch Interface Board Command Reference-6W102
HomeSupportWirelessWX6000 Series Access ControllersReference GuidesCommand ReferencesH3C WX6103 Access Controller Switch Interface Board Command Reference-6W102
25-DNS Commands
25-DNS Commands 49.95 KB
l          The term switch in this document refers to a switch in a generic sense or an access controller configured with the switching function unless otherwise specified.
l          This document only covers IPv4 DNS configuration commands. For introduction to IPv6 DNS configuration commands, refer to IPv6 in H3C WX6103 Access Controller Switch Interface Board Command Reference.
DNS Configuration Commands
display dns domain
display dns domain [ dynamic ]
View
dynamic: Displays the domain name suffixes dynamically obtained through DHCP or other protocols.
Use the display dns domain command to display the domain name suffixes.
Related commands: dns domain.
# Display domain name suffixes.
<Sysname> display dns domain
 Type:
  D:Dynamic    S:Static
No.    Type   Domain-name
1      S      com
Table 1-1 Description on fields of the display dns domain command
No
Sequence number
Type of domain name suffix: S represents a statically configured domain name suffix, and D represents a domain name suffix obtained dynamically through DHCP.
Domain-name
Domain name suffix
display dns dynamic-host
View
None
Use the display dns dynamic-host command to display the information of the dynamic domain name resolution cache.
# Display the information of the dynamic domain name resolution cache.
<Sysname> display dns dynamic-host
No  Host                  IP Address            TTL
1   www.baidu.com         202.108.249.134      63000
2   www.yahoo.akadns.net  66.94.230.39         24
3   www.hotmail.com       207.68.172.239       3585
4   www.eyou.com          61.136.62.70         3591
Table 1-2 Description on the field of the display dns dynamic-host command
No
Sequence number
Domain-name
Domain name
IP Address
IP address for the corresponding domain name
TTL
Time that a mapping can be stored in the cache (in seconds).
A domain name in the display dns dynamic-host command contains 21 characters at most. If a domain name consists of more than 21 characters, only the first 21 characters are displayed.
display dns proxy table
View
None
Use the display dns proxy table command to display the DNS proxy table.
# Display the DNS proxy table.
<Sysname> display dns proxy table
Source IP          Source Port  Trans ID     Server IP          Aging
192.168.0.98       1030         24580        192.168.111.244    35
Table 1-3 Description on the fields of the display dns proxy table command
Source IP
Source IP address of the DNS request, that is, the IP address of the DNS client.
Source Port
Source port number of the DNS request
Trans ID
Transaction ID of the DNS request
Server IP
IP address of the DNS server
Aging
Aging time of the DNS proxy table entry in seconds
display dns server
display dns server [ dynamic ]
View
dynamic: Displays the DNS server information dynamically obtained through DHCP or other protocols
Use the display dns server command to display the DNS server information.
Related commands: dns server.
# Display the DNS server information.
<Sysname> display dns server
Type:
  D:Dynamic    S:Static
DNS Server  Type  IP Address
    1       S     169.254.65.125
Table 1-4 Description on fields of the display dns server command
DNS Server
Sequence number of the DNS server, configured automatically by the device, starting from 1.
Type of domain name server: S represents a statically configured DNS server, and D represents a DNS server obtained dynamically through DHCP.
IP Address
display ip host
display ip host
View
None
Use the display ip host command to display the host names and corresponding IP addresses in the static domain name resolution table.
# Display the host names and corresponding IP addresses in the static domain name resolution table.
<Sysname> display ip host
Host          Age     Flags       Address
My            0       static      1.1.1.1
Aa            0       static      2.2.2.4
Table 1-5 Description on fields of the display ip host command
Host
Host name
Age
Time to live. 0 means that the static mapping will never age out.
You can only manually remove the mappings between host names and IP addresses.
Flags
Indicates the mapping type, static or dynamic.
Static represents static domain name resolution.
Address
Host IP address
dns domain
dns domain domain-name
undo dns domain [ domain-name ]
View
domain-name: Domain name suffix, consisting of character strings separated by a dot (for example, aabbcc.com). Each separated string contains no more than 63 characters. A domain name suffix may include case-insensitive letters, digits, hyphens (-), underscores (_), and dots (.), with a total length of 238 characters.
Use the dns domain command to configure a domain name suffix. The system can automatically add the suffix to part of the domain name you entered for resolution.
Use the undo dns domain command to delete a domain name suffix (with a domain name suffix specified) or all domain name suffixes (with no domain name suffix specified).
No domain name suffix is configured by default.
You can configure a maximum of 10 domain name suffixes.
Related commands: display dns domain.
# Configure com as a DNS suffix.
[Sysname] dns domain com
dns proxy enable
dns proxy enable
undo dns proxy enable
View
None
Use the dns proxy enable command to enable DNS proxy.
Use the undo dns proxy enable command to disable DNS proxy.
By default, DNS proxy is disabled.
# Enable DNS proxy.
[Sysname] dns proxy enable
dns resolve
dns resolve
undo dns resolve
View
None
Use the dns resolve command to enable dynamic domain name resolution.
Use the undo dns resolve command to disable dynamic domain name resolution.
Dynamic domain name resolution is disabled by default.
# Enable dynamic domain name resolution.
[Sysname] dns resolve
dns server
dns server ip-address
undo dns server [ ip-address ]
View
ip-address: IP address of the DNS server.
Use the dns server command to specify a DNS server.
Use the undo dns server to remove DNS server(s).
No DNS server is specified by default.
You can configure a maximum of six DNS servers.
Related commands: display dns server.
# Specify the DNS server 172.16.1.1.
[Sysname] dns server 172.16.1.1
ip host
ip host hostname ip-address
undo ip host hostname [ ip-address ]
View
Hostname: Host name, consisting of 1 to 20 characters, including case-insensitive letters, numbers, hyphens (-), or dots (.). The host name must include at least one letter.
ip-address: IP address of the specified host in dotted decimal notation.
Use the ip host command to create a host name to IP address mapping in the static resolution table.
Use the undo ip host command to remove a mapping.
No mappings are created by default.
You can configure only one mapping for a host name. A mapping newly configured for the host name will overwrite the previous one if there is any.
Related commands: display ip host.
# Map the IP address 10.110.0.1 to the host name aaa.
[Sysname] ip host aaa 10.110.0.1
reset dns dynamic-host
View
None
Use the reset dns dynamic-host command to clear the dynamic domain name resolution information.
Related commands: display dns dynamic-host.
# Clear the dynamic domain name resolution information.
<Sysname> reset dns dynamic-host
