H3C WX6103 Access Controller Switch Interface Board Command Reference-6W102
HomeSupportWirelessWX6000 Series Access ControllersReference GuidesCommand ReferencesH3C WX6103 Access Controller Switch Interface Board Command Reference-6W102
32-PKI Commands
32-PKI Commands 89.92 KB
The term switch in this document refers to a switch in a generic sense or an access controller configured with the switching function unless otherwise specified.
PKI Configuration Commands
attribute
attribute id { alt-subject-name { fqdn | ip } | { issuer-name | subject-name } { dn | fqdn | ip } } { ctn | equ | nctn | nequ} attribute-value
undo attribute { id | all }
View
Certificate attribute group view
Id: Sequence number of the certificate attribute rule, in the range 1 to 16.
alt-subject-name: Specifies the name of the alternative certificate subject.
fqdn: Specifies the FQDN of the entity.
ip: Specifies the IP address of the entity.
issuer-name: Specifies the name of the certificate issuer.
subject-name: Specifies the name of the certificate subject.
dn: Specifies the domain name of the entity.
ctn: Specifies the contain operation.
equ: Specifies the equal operation.
nctn: Specifies the not-contain operation.
nequ: Specifies the not-equal operation.
attribute-value: Value of the certificate attribute, a case-insensitive string of 1 to 128 characters.
all: Specifies all certificate attributes.
Use the attribute command to configure the attribute rules of the certificate issuer name, certificate subject name and alternative certificate subject name.
Use the undo attribute command to delete the attributes of one or all certificates.
By default, there is no restriction on the issuer name, subject name, and alternative subject name of a certificate.
Note that the attribute of the alternative certificate subject name does not appear as a domain name, and therefore the dn keyword is not available for the attribute.
# Create a certificate attribute rule, specifying that the DN in the subject name includes the string of abc.
[Sysname] pki certificate attribute-group mygroup
[Sysname-pki-cert-attribute-group-mygroup] attribute 1 subject-name dn ctn abc
# Create a certificate attribute rule, specifying that the FQDN in the issuer name cannot be the string of abc.
[Sysname-pki-cert-attribute-group-mygroup] attribute 2 issuer-name fqdn nequ abc
# Create a certificate attribute rule, specifying that the IP address in the alternative subject name cannot be 10.0.0.1.
[Sysname-pki-cert-attribute-group-mygroup] attribute 3 alt-subject-name ip nequ 10.0.0.1
ca identifier
ca identifier name
undo ca identifier
View
PKI domain view
name: Identifier of the trusted CA, a case-insensitive string of 1 to 63 characters
Use the ca identifier command to specify the trusted CA and bind the device with the CA.
Use the undo ca identifier command to remove the configuration.
By default, no trusted CA is specified for a PKI domain.
Certificate request, retrieval, revocation, and query all depend on the trusted CA.
# Specify the trusted CA as new-ca.
[Sysname] pki domain 1
[Sysname-pki-domain-1] ca identifier new-ca
certificate request entity
certificate request entity entity-name
undo certificate request entity
View
PKI domain view
entity-name: Name of the entity for certificate request, a case-insensitive string of 1 to 15 characters.
Use the certificate request entity command to specify the entity for certificate request.
Use the undo certificate request entity command to remove the configuration.
By default, no entity is specified for a PKI domain.
Related commands: pki entity.
# Specify the entity for certificate request as entity1.
[Sysname-pki-domain-1] certificate request entity entity1
certificate request from
certificate request from { ca | ra }
undo certificate request from
View
PKI domain view
ca: Indicates that the entity requests a certificate from a CA.
ra: Indicates that the entity requests a certificate from an RA.
Use the certificate request from command to specify the authority for certificate request.
Use the undo certificate request from command to remove the configuration.
By default, no authority is specified for a PKI domain view.
# Specify that the entity requests a certificate from the CA.
[Sysname-pki-domain-1] certificate request from ca
certificate request mode
certificate request mode { auto [ key-length key-length | password { cipher | simple } password ]* | manual}
undo certificate request mode
View
PKI domain view
auto: Specifies to request a certificate in auto mode.
key-length: Length of the RSA key, in the range 512 to 2,048 bits. It is 1,024 bits by default.
password: Password for certificate revocation, a case-sensitive string of 1 to 31 characters.
cipher: Specifies to display the password in cipher text.
simple: Specifies to display the password in clear text.
manual: Specifies to request a certificate in manual mode.
Use the certificate request mode command to set the certificate request mode.
Use the undo certificate request mode command to restore the default.
By default, manual mode is used.
In auto mode, an entity automatically requests a certificate from an RA or CA when it has no certificate or when the existing certificate is about to expire. In manual mode, all operations associated with certificate request are carried out manually.
Related commands: pki request-certificate.
# Specify to request a certificate in auto mode.
[Sysname-pki-domain-1] certificate request mode auto
certificate request polling
certificate request polling { count count | interval minutes }
undo certificate request polling { count | interval }
View
PKI domain view
count: Maximum number of attempts to poll the status of the certificate request, in the range 1 to 100.
minutes: Polling interval, in the range 5 to 168 minutes.
Use the certificate request polling command to specify the certificate request polling interval and maximum number of attempts.
Use the undo certificate request polling command to restore the defaults.
By default, the polling is executed every 20 minutes for up to 50 times.
After an applicant makes a certificate request, the CA may need a long period of time if it verifies the certificate request manually. During this period, the applicant needs to query the status of the request periodically to get the certificate as soon as possible after the certificate is signed.
Related commands: display pki certificate.
# Specify the polling interval as 15 minutes and the maximum number of attempts as 40.
[Sysname-pki-domain-1] certificate request polling interval 15
[Sysname-pki-domain-1] certificate request polling count 40
certificate request url
certificate request url url-string
undo certificate request url
View
PKI domain view
url-string: URL of the server for certificate request, a case-insensitive string of 1 to 127 characters. It comprises the location of the server and the location of CGI command interface script in the format of http: //server_location/ca_script_location, where server_location is generally expressed in IP address.
Use the certificate request url command to specify the URL of the server for certificate request through SCEP.
Use the undo certificate request url command to remove the configuration.
By default, no URL is specified for a PKI domain.
# Specify the URL of the server for certificate request.
[Sysname-pki-domain-1] certificate request url
http://169.254.0.100/certsrv/mscep/mscep.dll
common-name
common-name name
undo common-name
View
PKI entity view
name: Common name of an entity, a case-insensitive string of 1 to 31 characters. No comma can be included.
Use the common-name command to configure the common name of an entity, which can be, for example, the user name.
Use the undo common-name command to remove the configuration.
By default, no common name is specified.
# Configure the common name of an entity as test.
[Sysname] pki entity 1
[Sysname-pki-entity-1] common-name test
country
country country-code-str
undo country
View
PKI entity view
country-code-str: Country code for the entity, a 2-character case-insensitive string.
Use the country command to specify the code of the country to which an entity belongs. It is a standard 2-character code, for example, CN for China.
Use the undo country command to remove the configuration.
By default, no country code is specified.
# Set the country code of an entity to CN.
[Sysname-pki-entity-1] country CN
crl check
crl check { disable | enable }
View
PKI domain view
disable: Disables CRL checking.
enable: Enables CRL checking.
Use the crl check command to enable or disable CRL checking.
By default, CRL checking is enabled.
CRLs are files issued by the CA to distribute all certificates have been revoked. Revocation of a certificate may occur before the certificate expires. CRL checking is intended for checking whether a certificate has been revoked. A revoked certificate is no longer trusted.
# Disable CRL checking.
[Sysname-pki-domain-1] crl check disable
crl update-period
crl update-period hours
undo crl update-period
View
PKI domain view
hours: CRL update period, in the range 1 to 720 hours.
Use the crl update-period command to set the CRL update period, that is, the interval at which the PKI entity downloads the latest CRL.
Use the undo crl update-period command to restore the default.
By default, the CRL update period depends on the next update field in the CRL file.
The CRL update period is the interval at which a PKI entity with a certificate downloads a CRL from LDAP server.
# Set the CRL update period to 20 hours.
[Sysname-pki-domain-1] crl update-period 20
crl url
crl url url-string
undo crl url
View
PKI domain view
url-string: URL of the CRL distribution point, a case-insensitive string of 1 to 127 characters in the format of ldap: //server_location, where server_location is generally expressed by IP address.
Use the crl url command to specify the URL of the CRL distribution point.
Use the undo crl url command to remove the configuration.
By default, no CRL distribution point URL is specified.
Note that when the URL of the CRL distribution point is not set, you should acquire CA certificate and a local certificate, and then acquire a CRL through SCEP.
# Specify the URL of the CRL distribution point.
[Sysname-pki-domain-1] crl url ldap://169.254.0 30
display pki certificate { { ca | local } domain domain-name | request-status }
View
ca: Displays the CA certificate.
local: Displays the local certificate.
domain-name: Name of the PKI domain, a string of 1 to 15 characters.
request-status: Displays the status of a certificate request.
Use the display pki certificate command to display the contents or request status of a certificate.
Related commands: pki retrieval-certificate, pki domain and certificate request polling.
# Display the local certificate.
<Sysname> display pki certificate local domain 1
Data:
        Version: 3 (0x2)
        Serial Number:
            10B7D4E3 00010000 0086
        Signature Algorithm:  md5WithRSAEncryption
        Issuer:
            [email protected]
            C=CN
            ST=Country A
            L=City X
            O=abc
            OU=bjs
            CN=new-ca
        Validity
            Not Before:  Jan 13 08: 57: 21 2004 GMT
            Not After :  Jan 20 09: 07: 21 2005 GMT
        Subject:
            C=CN
            ST=Country B
            L=City Y
            CN=pki test
        Subject Public Key Info:
            Public Key Algorithm:  rsaEncryption
            RSA Public Key:  (512 bit)
                Modulus (512 bit):
                    00D41D1F …
                Exponent:  65537 (0x10001)
        X509v3 extensions:
            X509v3 Subject Alternative Name:
            DNS: hyf.xxyyzz.net
            X509v3 CRL Distribution Points:
            URI:http://1.1.1.1:447/myca.crl
        A3A5A447 4D08387D …
Table 1-1 Description on the fields of the display pki certificate command
Version
Version of the certificate
Serial Number
Serial number of the certificate
Signature Algorithm
Signature algorithm
Issuer
Issuer of the certificate
Validity
Validity period of the certificate
Subject
Entity holding the certificate
Public key information of the entity
X509v3 extensions
Extensions of the X509 (version 3) certificate
Distribution points of X509 (version 3) CRLs
display pki certificate access-control-policy
display pki certificate access-control-policy { policy-name | all }
View
policy-name: Name of the certificate attribute-based access control policy, a string of 1 to 16 characters.
all: Specifies all certificate attribute-based access control policies.
Use the display pki certificate access-control-policy command to display information about a specified or all certificate attribute-based access control policies.
# Display information about the certificate attribute-based access control policy named mypolicy.
<Sysname> display pki certificate access-control-policy mypolicy
 access-control-policy name: mypolicy
     rule  1 deny    mygroup1
     rule  2 permit  mygroup2
Table 1-2 Description on the fields of display pki certificate access-control-policy
rule number
Number of the access control rule
display pki certificate attribute-group
display pki certificate attribute-group { group-name | all }
View
group-name: Name of a certificate attribute group, a string of 1 to 16 characters.
all: Specifies all certificate attribute groups.
Use the display pki certificate attribute-group command to display information about a specified or all certificate attribute groups.
# Display information about certificate attribute group mygroup.
<Sysname> display pki certificate attribute-group mygroup
 attribute group name: mygroup
      attribute  2 issuer-name      fqdn  nctn  app
Table 1-3 Description on the fields of display pki certificate attribute-group
Name of the certificate attribute group
attribute number
Number of the attribute rule
subject-name
Name of the certificate subject
dn
Domain of the entity
ctn
Indicates the contain operations
abc
Value of attribute 1
issuer-name
Name of the certificate issuer
fqdn
FQDN of the entity
nctn
Indicates the not-contain operations
app
Value of attribute 2
display pki crl domain
display pki crl domain domain-name
View
Use the display pki crl domain command to display the locally saved CRLs.
Related commands: pki retrieval-crl and pki domain.
# Display the locally saved CRLs.
<Sysname> display pki crl domain 1
 Certificate Revocation List (CRL):
        Version 2 (0x1)
        Signature Algorithm:  sha1WithRSAEncryption
        Issuer:
            C=CN
            O=abc
            OU=soft
            CN=A Test Root
        Last Update:  Jan  5 08: 44: 19 2004 GMT
        Next Update:  Jan  5 21: 42: 13 2004 GMT
        CRL extensions:
            X509v3 Authority Key Identifier:
            keyid:0F71448E E075CAB8 ADDB3A12 0B747387 45D612EC
            Revoked Certificates:
            Serial Number: 05a234448E…
            Revocation Date: Sep  6 12:33:22 2004 GMT
            CRL entry extensions:…
Table 1-4 Description on the fields of the display pki crl domain command
Version
Version of the CRLs
Signature Algorithm
Signature algorithm used by the CRLs
Issuer
CA issuing the CRLs
Last Update
Last update time
Next Update
Next update time
CRL extensions
Extensions of CRL
CA issuing the CRLs. The certificate version is X509v3.
keyid
ID of the public key
Revoked certificates
Serial Number
Serial number of the revoked certificate
Revocation Date
Revocation date of the certificate
fqdn
fqdn name-str
undo fqdn
View
PKI entity view
name-str: Fully qualified domain name (FQDN) of an entity, a case-insensitive string of 1 to 127 characters
Use the fqdn command to configure the FQDN of an entity.
Use the undo fqdn command to remove the configuration.
By default, no FQDN is specified for an entity.
An FQDN is the unique identifier of an entity on a network. It consists of a host name and a domain name and can be resolved into an IP address.
# Configure the FQDN of an entity as pki.domain-name.com.
[Sysname-pki-entity-1] fqdn pki.domain-name.com
ip
ip ip-address
undo ip
View
PKI entity view
ip-address: IP address for an entity.
Use the ip command to configure the IP address of an entity.
Use the undo ip command to remove the configuration.
By default, no IP address is specified for an entity.
# Configure the IP address of an entity as 11.0.0.1.
[Sysname-pki-entity-1] ip 11.0.0.1
ldap-server
ldap-server ip ip-address [ port port-number ] [ version version-number ]
undo ldap-server
View
PKI domain view
ip-address: IP address of the LDAP server, in dotted decimal format.
port-number: Port number of the LDAP server, in the range 1 to 65535. The default is 389.
version-number: LDAP version number, either 2 or 3. By default, it is 2.
Use the ldap-server command to specify an LDAP server for a PKI domain.
Use the undo ldap-server command to remove the configuration.
By default, no LDP server is specified for a PKI domain.
# Specify an LDAP server for PKI domain 1.
[Sysname-pki-domain-1] ldap-server ip 169.254.0 30
locality
locality locality-name
undo locality
View
PKI entity view
locality-name: Name for the geographical locality, a case-insensitive string of 1 to 31 characters. No comma can be included.
Use the locality command to configure the geographical locality of an entity, which can be, for example, a city name.
Use the undo locality command to remove the configuration.
By default, no geographical locality is specified for an entity.
# Configure the locality of an entity as city.
[Sysname-pki-entity-1] locality city
organization
organization org-name
undo organization
View
PKI entity view
org-name: Organization name, a case-insensitive string of 1 to 31 characters. No comma can be included.
Use the organization command to configure the name of the organization to which the entity belongs.
Use the undo organization command to remove the configuration.
By default, no organization name is specified for an entity.
# Configure the name of the organization to which an entity belongs as org-name.
[Sysname-pki-entity-1] organization org-name
organizational-unit
organizational-unit org-unit-name
undo organizational-unit
View
PKI entity view
org-unit-name: Organization unit name, a case-insensitive string of 1 to 31 characters. No comma can be included. This argument is intended to distinguish different units in an organization.
Use the organizational-unit command to specify the name of the organization unit to which this entity belongs.
Use the undo organizational-unit command to remove the configuration.
By default, no organization unit name is specified for an entity.
# Configure the name of the organization unit to which an entity belongs as unit-name.
[Sysname-pki-entity-1] organizational-unit unit-name
pki certificate access-control-policy policy-name
undo pki certificate access-control-policy { policy-name | all }
View
policy-name: Name of the certificate attribute-based access control policy, a case-insensitive string of 1 to 16 characters. It cannot be “a”, “al” or “all”.
Use the pki certificate access-control-policy command to create a certificate attribute-based access control policy and enter its view.
Use the undo pki certificate access-control-policy command to remove a specified or all certificate attribute-based access control policies.
No access control policy exists by default.
# Configure an access control policy named mypolicy and enter its view.
[Sysname] pki certificate access-control-policy mypolicy
[Sysname-pki-cert-acp-mypolicy]
pki certificate attribute-group group-name
undo pki certificate attribute-group { group-name | all }
View
group-name: Name for the certificate attribute group, a case-insensitive string of 1 to 16 characters. It cannot be “a”, “al” or “all”.
Use the pki certificate attribute-group command to create a certificate attribute group and enter its view.
Use the undo pki certificate attribute-group command to delete one or all certificate attribute groups.
By default, no certificate attribute group exists.
# Create a certificate attribute group named mygroup and enter its view.
pki delete-certificate
pki delete-certificate { ca | local } domain domain-name
View
ca: Deletes the locally stored CA certificate.
local: Deletes the locally stored local certificate.
domain-name: Name of the PKI domain whose certificates are to be deleted, a string of 1 to 15 characters.
Use the pki delete-certificate command to delete locally stored certificates.
# Delete the local certificate for PKI domain cer.
[Sysname] pki delete-certificate local domain cer
pki domain
pki domain domain-name
undo pki domain domain-name
View
domain-name: PKI domain name, a case-insensitive string of 1 to 15 characters.
Use the pki domain command to create a PKI domain and enter PKI domain view or enter the view of an existing PKI domain.
Use the undo pki domain command to remove a PKI domain.
By default, no PKI domain exists.
# Create a PKI domain and enter its view.
pki entity
pki entity entity-name
undo pki entity entity-name
View
entity-name: Name for the entity, a case-insensitive string of 1 to 15 characters.
Use the pki entity command to create a PKI entity and enter PKI entity view.
Use the undo pki entity command to remove a PKI entity.
By default, no entity exists.
You can configure a variety of attributes for an entity in PKI entity view. An entity is intended only for convenience of reference by other commands.
# Create a PKI entity named en and enter its view.
[Sysname] pki entity en
[Sysname-pki-entity-en]
pki import-certificate
pki import-certificate { ca | local } domain domain-name { der | p12 | pem } [ filename filename ]
View
ca: Specifies a CA certificate.
local: Specifies a local certificate.
der: Specifies the certificate format of DER.
p12: Specifies the certificate format of P12.
pem: Specifies the certificate format of PEM.
filename: Name of the certificate file, a case-insensitive string of 1 to 127 characters. It defaults to domain-name_ca.cer or domain-name_local.cer, the name for the file to be created to save the imported certificate.
Use the pki import-certificate command to import a CA certificate or local certificate from a file and save it locally.
Related commands: pki domain.
# Import the CA certificate for PKI domain cer in the format of PEM.
<Sysnam> system-view
[Sysname] pki import-certificate ca domain cer pem
pki request-certificate domain
pki request-certificate domain domain-name [ password ] [ pkcs10 [ filename filename ] ]
View
domain-name: Name of the PKI domain name, a string of 1 to 15 characters.
pkcs10: Displays the BASE64-encoded PKCS#10 certificate request.
filename: Name of the file for saving the PKCS#10 certificate request, a case-insensitive string of 1 to 127 characters.
Use the pki request-certificate domain command to request a local certificate from a CA through SCEP. If SCEP fails, you can use the pkcs10 keyword to save the local certificate request in BASE64 format and send it to the CA by an out-of-band means like phone, disk or e-mail.
This operation will not be saved in the configuration file.
# Display the PKCS#10 certificate request information.
[Sysname] pki request-certificate domain 1 pkcs10
pki retrieval-certificate { ca | local } domain domain-name
View
ca: Downloads a CA certificate.
local: Downloads a local certificate.
domain-name: Name of the PKI domain used for certificate request.
Use the pki retrieval-certificate command to retrieve a certificate from the server for certificate distribution.
# Retrieve the CA certificate from the certificate issuing server.
[Sysname] pki retrieval-certificate ca domain 1
pki retrieval-crl domain
pki retrieval-crl domain domain-name
View
Use the pki retrieval-crl command to retrieve the latest CRLs from the server for CRL distribution.
CRLs are used to validate certificates.
# Retrieve CRLs.
[Sysname] pki retrieval-crl domain 1
pki validate-certificate
pki validate-certificate { ca | local } domain domain-name
View
ca: Validates the CA certificate.
local: Validates the local certificate.
domain-name: Name of the PKI domain the certificate to be validated is for, a string of 1 to 15 characters.
Use the pki validate-certificate command to verify the validity of a certificate.
The focus of certificate validity verification is to check that the certificate is signed by the CA and that the certificate has neither expired nor been revoked.
# Verify the validity of the local certificate.
[Sysname] pki validate-certificate domain 1
root-certificate fingerprint
root-certificate fingerprint { md5 | sha1 } string
undo root-certificate fingerprint
View
PKI domain view
md5: Uses an MD5 fingerprint.
sha1: Uses a SHA1 fingerprint.
string: Fingerprint to be used. An MD5 fingerprint must be a string of 32 characters in hexadecimal. A SHA1 fingerprint must be a string of 40 characters in hexadecimal.
Use the root-certificate fingerprint command to configure the fingerprint to be used for validating the CA root certificate.
Use the undo root-certificate fingerprint command to remove the configuration.
By default, no fingerprint is configured for validating the CA root certificate.
# Configure an MD5 fingerprint for validating the CA root certificate.
[Sysname-pki-domain-1] root-certificate fingerprint md5 12EF53FA355CD23E12EF53FA355CD23E
# Configure a SHA1 fingerprint for validating the CA root certificate.
[Sysname-pki-domain-1] root-certificate fingerprint sha1 D1526110AAD7527FB093ED7FC037B0B3CDDDAD93
rule
rule [ id ] { deny | permit } group-name
undo rule { id | all }
View
Access control policy view
id: Number of the certificate attribute access control rule, in the range 1 to 16. The default is the smallest unused number in this range.
deny: Indicates that a certificate matching an attribute rule in the specified attribute group is considered invalid and denied.
permit: Indicates that a certificate matching an attribute rule in the specified attribute group is considered valid and permitted.
group-name: Name of the certificate attribute group to be associated with the rule, a case-insensitive string of 1 to 16 characters. It cannot be “a”, “al” or “all”.
all: Specifies all access control rules.
Use the rule command to create a certificate attribute access control rule.
Use the undo rule command to delete a specified or all access control rules.
By default, no access control rule exists.
Note that a certificate attribute group must exist to be associated with a rule.
# Create an access control rule, specifying that a certificate is considered valid when it matches an attribute rule in certificate attribute group mygroup.
[Sysname -pki-cert-acp-mypolicy] rule 1 permit mygroup
state
state state-name
undo state
View
PKI entity view
state-name: State or province name, a case-insensitive string of 1 to 31 characters. No comma can be included.
Use the state command to specify the name of the state or province where an entity resides.
Use the undo state command to remove the configuration.
By default, no state or province is specified.
# Specify the state where an entity resides.
[Sysname-pki-entity-1] state Country
