H3C WX6103 Access Controller Switch Interface Board Command Reference-6W102
HomeSupportWirelessWX6000 Series Access ControllersReference GuidesCommand ReferencesH3C WX6103 Access Controller Switch Interface Board Command Reference-6W102
34-Index
34-Index 795.58 KB
Index
A B C D E F G H I J K L M N O P Q R S T U V W X Y
A
abr-summary
accounting
acl
acl (user interface view)
acl copy
acl ipv6
acl ipv6 copy
acl ipv6 name
acl name
activation-key
active region-configuration
area
arp check enable
arp max-learning-num
arp static
arp timer aging
asbr-summary
ascii
attribute
authentication-mode
authentication-mode
auto-execute command
B
backup startup-configuration
bandwidth-reference
binary
boot-loader
bootrom
bootrom-update security-check enable
bpdu-tunnel dot1q enable
bpdu-tunnel dot1q stp
bpdu-tunnel tunnel-dmac
broadcast-suppression
bye
bye
C
ca identifier
car
cd
cd
cd
cdup
cdup
certificate request entity
certificate request from
certificate request mode
certificate request polling
certificate request url
check region-configuration
checkzero
ciphersuite
classifier behavior
client-verify enable
clock datetime
clock summer-time one-off
clock summer-time repeating
clock timezone
close
close-mode wait
command-privilege
common-name
copy
country
crl check
crl update-period
crl url
D
databits
data-fill
data-size
debugging
debugging
default
default cost
default-cost
default-route originate
default-route-advertise
delete
delete
delete
delete static-routes all
description
description
description
description
description (for IPv4)
description (for IPv6)
destination ip
destination port
dhcp enable
dhcp relay address-check
dhcp relay information enable
dhcp relay information format
dhcp relay information strategy
dhcp relay release
dhcp relay security static
dhcp relay security tracker
dhcp relay server-detect
dhcp relay server-group
dhcp relay server-select
dhcp select relay
dhcp-snooping
dhcp-snooping information enable
dhcp-snooping information format
dhcp-snooping information strategy
dhcp-snooping trust
dir
dir
dir
disconnect
display acl
display acl ipv6
display acl resource
display arp
display arp ip-address
display arp timer aging
display boot-loader
display bootp client
display brief interface
display channel
display clipboard
display clock
display cpu-usage
display current-configuration
display debugging
display device
display device manuinfo
display dhcp client
display dhcp relay
display dhcp relay security
display dhcp relay security statistics
display dhcp relay security tracker
display dhcp relay server-group
display dhcp relay statistics
display dhcp-snooping
display dhcp-snooping trust
display diagnostic-information
display dldp
display dldp statistics
display dns domain
display dns dynamic-host
display dns proxy table
display dns server
display environment
display fib
display fib ip-address
display fib statistics
display ftp client configuration
display ftp-server
display ftp-user
display garp statistics
display garp timer
display gvrp local-vlan interface
display gvrp state
display gvrp statistics
display gvrp status
display gvrp vlan-operation interface
display history-command
display hotkey
display icmp statistics
display igmp-snooping group
display igmp-snooping statistics
display info-center
display interface
display interface Vlan-interface
display ip check source
display ip host
display ip https
display ip interface
display ip interface brief
display ip relay-route
display ip routing-table
display ip routing-table acl
display ip routing-table ip-address
display ip routing-table ip-prefix
display ip routing-table protocol
display ip routing-table statistics
display ip socket
display ip statistics
display ipv6 relay-route
display ipv6 routing-table
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table ipv6-address1 ipv6-address2
display ipv6 routing-table ipv6-prefix
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display ipv6 routing-table verbose
display lacp system-id
display link-aggregation interface
display link-aggregation summary
display link-aggregation verbose
display lldp local-information
display lldp neighbor-information
display lldp statistics
display lldp status
display lldp tlv-config
display local-proxy-arp
display logbuffer
display logbuffer summary
display loopback-detection
display mac-address
display mac-address aging-time
display mac-vlan
display mac-vlan interface
display memory
display mirroring-group
display multicast-vlan
display nqa
display nqa server status
display ntp-service sessions
display ntp-service status
display ntp-service trace
display ospf abr-asbr
display ospf asbr-summary
display ospf brief
display ospf cumulative
display ospf error
display ospf interface
display ospf lsdb
display ospf nexthop
display ospf peer
display ospf peer statistics
display ospf request-queue
display ospf retrans-queue
display ospf routing
display ospf vlink
display pki certificate
display pki certificate access-control-policy
display pki certificate attribute-group
display pki crl domain
display port combo
display port-group manual
display port-isolate group
display port-security
display port-security mac-address block
display port-security mac-address security
display proxy-arp
display public-key local
display public-key peer
display qos lr interface
display qos map-table
display qos policy
display qos policy interface
display qos sp interface
display qos trust interface
display qos vlan-policy
display qos wrr interface
display reboot-type
display rip
display rip database
display rip interface
display rip route
display rmon alarm
display rmon event
display rmon eventlog
display rmon history
display rmon prialarm
display rmon statistics
display saved-configuration
display schedule reboot
display sflow
display sftp client source
display snmp-agent community
display snmp-agent group
display snmp-agent local-engineid
display snmp-agent mib-view
display snmp-agent statistics
display snmp-agent sys-info
display snmp-agent trap-list
display snmp-agent usm-user
display ssh client source
display ssh server
display ssh server-info
display ssh user-information
display ssl client-policy
display ssl server-policy
display startup
display storm-constrain
display stp
display stp abnormal-port
display stp down-port
display stp history
display stp region-configuration
display stp root
display stp tc
display tcp statistics
display tcp status
display tftp client configuration
display this
display time-range
display track
display traffic behavior
display traffic classifier
display trapbuffer
display udp statistics
display udp-helper server
display user-bind
display user-interface
display users
display version
display vlan
display voice vlan oui
display voice vlan state
dldp authentication-mode
dldp delaydown-timer
dldp enable
dldp interval
dldp reset
dldp unidirectional-shutdown
dldp work-mode
dns domain
dns proxy enable
dns resolve
dns server
duplex
E
enable link-local-signaling
enable log
enable out-of-band-resynchronization
enable snmp trap updown
escape-key
execute
exit
F
fast-leave
file prompt
filename
filter
filter
filter-policy export
filter-policy import
fixdisk
flow-control
format
fqdn
free ftp user
free user-interface
frequency
ftp
ftp client source
ftp ipv6
ftp server enable
ftp timeout
ftp update
G
garp timer
garp timer leaveall
get
get
graceful-restart
graceful-restart help
graceful-restart interval
gratuitous-arp-learning enable
gratuitous-arp-sending enable
group-member
group-policy
gvrp
gvrp registration
H
handshake timeout
header
header
help
history-command max-size
history-records
host-advertise
host-aging-time
host-route
hotkey
http-version
I
idle-timeout
if-match
igmp-snooping
igmp-snooping drop-unknown
igmp-snooping enable
igmp-snooping fast-leave
igmp-snooping general-query source-ip
igmp-snooping group-limit
igmp-snooping group-policy
igmp-snooping host-aging-time
igmp-snooping host-join
igmp-snooping last-member-query-interval
igmp-snooping max-response-time
igmp-snooping overflow-replace
igmp-snooping querier
igmp-snooping query-interval
igmp-snooping router-aging-time
igmp-snooping source-deny
igmp-snooping special-query source-ip
igmp-snooping static-group
igmp-snooping static-router-port
igmp-snooping version
import
import-route
import-route
info-center channel name
info-center console channel
info-center enable
info-center logbuffer
info-center loghost
info-center loghost source
info-center monitor channel
info-center snmp channel
info-center source
info-center synchronous
info-center timestamp
info-center timestamp loghost
info-center trapbuffer
instance
interface
ip
ip address
ip address
ip address bootp-alloc
ip address dhcp-alloc
ip check source
ip forward-broadcast (interface view)
ip forward-broadcast (system view)
ip host
ip https acl
ip https certificate access-control-policy
ip https enable
ip https ssl-server-policy
ip redirects enable
ip route-static
ip route-static default-preference
ip ttl-expires enable
ip unreachables enable
J
jumboframe enable
K
L
lacp port-priority
lacp system-priority
lcd
ldap-server
link-aggregation group description
link-aggregation group mode
lldp admin-status
lldp check-change-interval
lldp enable
lldp fast-count
lldp hold-multiplier
lldp management-address-tlv
lldp notification remote-change enable
lldp timer notification-interval
lldp timer reinit-delay
lldp timer tx-delay
lldp timer tx-interval
lldp tlv-enable
locality
local-proxy-arp enable
lock
log-peer-change
loopback
loopback-detection control enable
loopback-detection enable
loopback-detection interval-time
loopback-detection per-vlan enable
ls
ls
lsa-arrival-interval
lsa-generation-interval
lsdb-overflow-limit
M
mac-address max-mac-count
mac-address timer
mac-vlan enable
mac-vlan mac-address
maximum load-balancing
maximum-routes
max-response-time
mdi
mirroring-group
mirroring-group mirroring-port
mirroring-group monitor-egress
mirroring-group monitor-port
mirroring-group remote-probe vlan
mirroring-port
mirror-to
mkdir
mkdir
mkdir
monitor-port
more
move
multicast-suppression
multicast-vlan enable
multicast-vlan subvlan
N
nest
network
network
next-hop
nqa
nqa agent enable
nqa agent max-concurrent
nqa schedule
nqa server enable
nqa server tcp-connect
nqa server udp-echo
nssa
ntp-service access
ntp-service authentication enable
ntp-service authentication-keyid
ntp-service broadcast-client
ntp-service broadcast-server
ntp-service in-interface disable
ntp-service max-dynamic-sessions
ntp-service multicast-client
ntp-service multicast-server
ntp-service reliable authentication-keyid
ntp-service source-interface
ntp-service unicast-peer
ntp-service unicast-server
O
oap connect slot
oap reboot slot
opaque-capability enable
open
open ipv6
operation (FTP test type view)
operation (HTTP test type view)
operation interface
organization
organizational-unit
ospf
ospf authentication-mode
ospf cost
ospf dr-priority
ospf mib-binding
ospf mtu-enable
ospf timer dead
ospf timer hello
ospf timer poll
ospf timer retransmit
ospf trans-delay
overflow-replace
P
parity
passive
password
peer
peer-public-key end
ping
ping ipv6
pki delete-certificate
pki domain
pki entity
pki import-certificate
pki request-certificate domain
pki retrieval-certificate
pki retrieval-crl domain
pki validate-certificate
pki-domain
port
port access vlan
port hybrid pvid vlan
port hybrid vlan
port link-aggregation group
port link-type
port trunk permit vlan
port trunk pvid vlan
port-group
port-group aggregation
port-isolate enable
port-security authorization ignore
port-security enable
port-security intrusion-mode
port-security max-mac-count
port-security ntk-mode
port-security oui
port-security port-mode
port-security timer disableport
port-security trap
prefer-cipher
preference
preference
probe count
probe packet-interval
probe packet-number
probe packet-timeout
probe timeout
protocol inbound
proxy-arp enable
public-key local create
public-key local destroy
public-key local export dsa
public-key local export rsa
public-key peer
public-key peer import sshkey
public-key-code begin
public-key-code end
put
put
pwd
pwd
pwd
Q
qinq enable
qinq ethernet-type
qinq vid
qos apply policy
qos lr outbound
qos map-table
qos policy
qos priority
qos sp
qos trust
qos vlan-policy
qos wrr
R
raw-vlan-id inbound
reaction
reaction trap
reboot
redirect
region-name
remark customer-vlan-id
remark dot1p
remark drop-precedence
remark dscp
remark ip-precedence
remark local-precedence
remark service-vlan-id
remotehelp
remove
rename
rename
report-aggregation
reset acl counter
reset acl ipv6 counter
reset arp
reset counters interface
reset dhcp relay statistics
reset dhcp-snooping
reset dldp statistics
reset dns dynamic-host
reset garp statistics
reset igmp-snooping group
reset igmp-snooping statistics
reset ip routing-table statistics protocol
reset ip statistics
reset ipv6 routing-table statistics
reset lacp statistics
reset logbuffer
reset ospf counters
reset ospf process
reset ospf redistribution
reset qos vlan-policy
reset recycle-bin
reset rip statistics
reset saved-configuration
reset stp
reset tcp statistics
reset trapbuffer
reset udp statistics
reset udp-helper packet
reset unused porttag
restore startup-configuration
return
revision-level
rfc1583 compatible
rip
rip authentication-mode
rip input
rip metricin
rip metricout
rip output
rip poison-reverse
rip split-horizon
rip summary-address
rip version
rmdir
rmdir
rmdir
rmon alarm
rmon event
rmon history
rmon prialarm
rmon statistics
root-certificate fingerprint
route-option bypass-route
router-aging-time
rule
rule (in advanced IPv4 ACL view)
rule (in advanced IPv6 ACL view)
rule (in basic IPv4 ACL view)
rule (in basic IPv6 ACL view)
rule (in Ethernet frame header ACL view)
rule comment (for IPv4)
rule comment (for IPv6)
S
save
schedule reboot at
schedule reboot delay
screen-length
send
service-type
service-type lan-access
session
set authentication password
sflow agent ip
sflow collector ip
sflow enable
sflow interval
sflow sampling-mode
sflow sampling-rate
sftp
sftp client ipv6 source
sftp client source
sftp ipv6
sftp server enable
sftp server idle-timeout
shell
shutdown
shutdown
silent-interface
silent-interface
snmp-agent
snmp-agent calculate-password
snmp-agent group
snmp-agent log
snmp-agent mib-view
snmp-agent packet max-size
snmp-agent sys-info
snmp-agent target-host
snmp-agent trap enable
snmp-agent trap enable ospf
snmp-agent trap if-mib link extended
snmp-agent trap life
snmp-agent trap queue-size
snmp-agent trap source
snmp-agent usm-user { v1 | v2c }
snmp-agent usm-user v3
source interface
source ip
source port
source-deny
speed
speed
spf-schedule-interval
ssh client authentication server
ssh client first-time enable
ssh client ipv6 source
ssh client source
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
ssh server enable
ssh server rekey-interval
ssh user
ssh2
ssh2 ipv6
ssl client-policy
ssl server-policy
startup saved-configuration
state
step (for IPv4)
step (for IPv6)
stopbits
storm-constrain
storm-constrain control
storm-constrain enable log
storm-constrain enable trap
storm-constrain interval
stp
stp bpdu-protection
stp bridge-diameter
stp compliance
stp config-digest-snooping
stp cost
stp edged-port
stp loop-protection
stp max-hops
stp mcheck
stp mode
stp no-agreement-check
stp pathcost-standard
stp point-to-point
stp port priority
stp port-log
stp priority
stp root primary
stp root secondary
stp root-protection
stp tc-protection
stp tc-protection threshold
stp timer forward-delay
stp timer hello
stp timer max-age
stp timer-factor
stp transmit-limit
stub
stub-router
summary
super
super password
sysname
sysname
T
tcp timer fin-timeout
tcp timer syn-timeout
tcp window
telnet
telnet
telnet client source
telnet server enable
terminal debugging
terminal logging
terminal monitor
terminal trapping
terminal type
tftp
tftp client source
tftp ipv6
tftp-server acl
time-range
timers
tos
tracert
tracert ipv6
track nqa
traffic behavior
traffic classifier
ttl
type
U
udp-helper enable
udp-helper port
udp-helper server
undelete
unicast-suppression
url
user
user privilege level
user-bind
user-interface
username
V
validate-source-address
verbose
version
version
virtual-cable-test
vlan
vlan-mapping modulo
vlink-peer
voice vlan
voice vlan aging
voice vlan enable
voice vlan mac-address
voice vlan mode auto
voice vlan security enable
W
X
Y
