H3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
17-RPR Commands
17-RPR Commands 211.73 KB
Table of Contents
Chapter 1 RPR Port Configuration Commands. 1-1
1.1 RPR Port Configuration Commands. 1-1
1.1.1 clock-source. 1-1
1.1.2 debugging rpr 1-2
1.1.3 display interface. 1-2
1.1.4 display rpr counters. 1-7
1.1.5 display rpr defect 1-14
1.1.6 display rpr fairness. 1-16
1.1.7 display rpr mac. 1-17
1.1.8 display rpr protection. 1-18
1.1.9 display rpr rs-table. 1-20
1.1.10 display rpr statistics. 1-21
1.1.11 display rpr timers. 1-22
1.1.12 display rpr topology. 1-24
1.1.13 flag. 1-25
1.1.14 frame-format 1-26
1.1.15 interface { RprPos | Rpr10GE | RprGE } interface-number 1-26
1.1.16 interface { RprPos | Rpr10GE | RprGE } interface-number . { 1 | 2 } 1-27
1.1.17 loopback. 1-28
1.1.18 port-type. 1-28
1.1.19 reset counters interface. 1-29
1.1.20 rpr admin-request 1-30
1.1.21 rpr cos-precedence-map. 1-31
1.1.22 rpr default-rs. 1-32
1.1.23 rpr echo. 1-33
1.1.24 rpr protect-mode. 1-34
1.1.25 rpr rate-limiter 1-34
1.1.26 rpr reversion-mode. 1-35
1.1.27 rpr static-rs. 1-36
1.1.28 rpr station-mac. 1-37
1.1.29 rpr station-name. 1-37
1.1.30 rpr timer 1-38
1.1.31 rpr weight 1-39
1.1.32 sdh threshold. 1-40
1.1.33 shutdown. 1-41
Chapter 2 RPR Layer 2 Tunnel Extended Application Configuration Commands. 2-1
2.1 RPR Layer 2 Tunnel Extended Application Configuration Commands. 2-1
2.1.1 display rpr tunnel-table. 2-1
2.1.2 display rpr tunnel-track. 2-2
2.1.3 rpr tunnel track. 2-4
2.1.4 rpr tunnel vlan. 2-5
Chapter 3 VRRP over RPR Collaboration Group Configuration Commands. 3-1
3.1 VRRP over RPR Collaboration Group Configuration Commands. 3-1
3.1.1 display rpr vrrp. 3-1
3.1.2 rpr vrrp. 3-2
3.1.3 undo rpr vrrp group. 3-3
Chapter 4 Intersecting RPR Rings Configuration Commands. 4-1
4.1 Intersecting RPR Rings Configuration Commands. 4-1
4.1.1 debugging rpr cross-ring event 4-1
4.1.2 debugging rpr cross-ring packet 4-1
4.1.3 display rpr cross-ring backup-ring. 4-2
4.1.4 display rpr cross-ring defect 4-3
4.1.5 display rpr cross-ring instance. 4-4
4.1.6 rpr cross-ring. 4-5
4.1.7 rpr cross-ring instance. 4-6
4.1.8 rpr cross-ring neighbour 4-7
4.1.9 rpr cross-ring slave backup-ring. 4-8
Chapter 5 Distributed RPR Configuration Commands. 5-1
5.1 Distributed RPR Configuration Commands. 5-1
5.1.1 debugging rpr backup. 5-1
5.1.2 display rpr link-aggregation. 5-1
5.1.3 link-aggregation group mode manual 5-2
5.1.4 port link-aggregation group. 5-3
5.1.5 port-mode mate. 5-4
1.1.1  clock-source
clock-source { master | slave [ priority priority-value ] }
undo clock-source
View
RPR POS physical port view
master: Specifies the clock source mode as master, that is, as internal.
slave: Specifies the clock source mode as slave, that is, as line.
priority priority-value: Specifies the priority of the line clock source. It ranges from 1 to 2, and defaults to 1. The value 2 has a higher priority over the value 1.
Use the clock-source command to configure clock source.
Use the undo clock-source command to restore the default setting.
By default, the clock source mode is master.
Note that the slave clock source mode can be configured for the two ports of a link, but the two sources must have different priorities.
# Configure the clock source mode as master.
<H3C> system-view
[H3C] interface RprPos2/1/1.1
[H3C-RprPos2/1/1.1] clock-source master
# Configure the clock source mode as slave, and set the priority of the clock source to 2.
<H3C> system-view
[H3C-RprPos2/1/1.1] clock-source slave priority 2
1.1.2  debugging rpr
debugging rpr { all | topology | protection | controlframe | mac | ringselection | tp-frame | l2tunnel | vrrp }
undo debugging rpr { all | topology | protection | controlframe | mac | ringselection | tp-frame | l2tunnel | vrrp }
View
all: All RPR debugging.
topology: Debugging for RPR topology database modular.
protection: Debugging for RPR protection modular request.
controlframe: Debugging for RPR control frame processing.
mac: Debugging for RPR ring selection MAC module.
ringselection: Debugging for RPR ring selection module.
tp-frame: Debugging for RPR TP frame processing.
l2tunnel: Debugging for RPR Layer 2 tunneling.
vrrp: Debugging for VRRP over RPR.
Use the debugging rpr command to enable RPR debugging.
Use the undo debugging rpr command to disable RPR debugging.
By default, RPR debugging is disabled.
# Enable all debugging for an RPR port.
<H3C> debugging rpr all
display interface [ interface-type | interface-type interface-number [ packets ] ]
View
interface-type: Port type.
interface-number: Port number.
packets: Displays the statistics on the packets passing through the port.
Use the display interface command to display the RPR port configuration and status information.
l           If you specify neither port type nor port number, the command displays the information about all ports on the switch.
l           If you only specify a port type, the command displays the information about all ports of the specified type.
l           If you specify a port type and a port number, the command displays the information about the specified port.
When displaying information about RPR ports:
l           If you do not specify a port number, the command displays all port information, including the status information about RPRPOS logical interfaces and physical ports.
l           If you specify a port number, the command displays the information about the specified port.
By viewing the information about physical ports, you can monitor the SDH physical layer and performance. For example, you can monitor basic alarms such as out of frame (OOF), loss of frame (LOF).
# Display configuration information of the RPR logical interface RPRPOS 5/1/1.
<H3C> display interface RprPos 5/1/1
 RprPos5/1/1 current state : UP
 Rpr station name is: H3C
 Rpr station MAC address is 000f-e211-1116
 Rpr configured default ringlet is: 0
 RPR work mode:  NORMAL
The Priority Map is:
        ip  :  0-C 1-C 2-C 3-C 4-C 5-C 6-C 7-A
        mpls:  0-C 1-C 2-C 3-C 4-C 5-C 6-C 7-A
        tag :  0-C 1-C 2-C 3-C 4-C 5-C 6-C 7-A
 IP address of RPR Access VLAN's interface is: 100.0.0.4
 IP Mask of RPR Access VLAN's interface is: 255.255.0.0
 Link-status hold interval:3 Sec
  The Maximum Transmit Unit is 1536 ,Loopback not set
 2.5G speed mode and full duplex mode
 Flow-control is not enabled
 The Maximum Frame Length is 1552
 Broadcast MAX-ratio: 50%
 Allow jumbo frame to pass
 PVID: 100
 Port link-type: access
  Tagged   VLAN ID : none
  Untagged VLAN ID : 100
 Last 300 seconds input:  11 packets/sec 10960 bits/sec            0%
 Last 300 seconds output:  0 packets/sec 0 bits/sec           0%
 Input(total):  67061 packets,7414146 bytes
broadcasts, - multicasts
 Input(normal):  67061 packets, 7414146 bytes
          8666 broadcasts, 57941 multicasts
 Input:  0 input errors, 0 runts, 0 giants,  0 throttles, 0 CRC
          0 frame,  0 overruns, - aborts, 0 ignored, - parity errors
 Output(total): 35 packets, 2810 bytes
          - broadcasts, - multicasts, 0 pauses
Output(normal): 35 packets, 2810 bytes
          3 broadcasts, 0 multicasts, 0 pauses
 Output: 0 output errors,  - underruns, - buffer failures
          0 aborts, 0 deferred, - collisions, 0 late collisions
          - lost carrier, - no carrier
 Receive Packet Peak Value Info: 384394 bytes, happened at 15:43:04 2-17-2006
 Transmit Packet Peak Value Info: 1084 bytes, happened at 15:44:04 2-17-2006
# Display the status information of the RPR physical port RPRPOS 5/1/1.1.
<H3C> display interface RprPos 5/1/1.1
Rpr physical interface: RprPos5/1/1.1
Current state:  UP
Optical module  state: RPR_PHYPOS_CONNECTOR
     SDH alarm:
        section layer:
        line    layer:
        path    layer:
     SDH Overhead   C2                 J0               J1
          Rx        0x16               H3C              H3C
          Tx        0x16               H3C              H3C
     SDH Threshold:  sdber:  10e-6        sfber:  10e-4
     SDH error:
        section layer:  B1  465
        line    layer:  B2  18091
                        M1  37309
        path    layer:  B3  310
                        G1  949
Data Traffic Counters of the Interface: RprPos5/1/1.1
 Host receive              Packets                Bytes
   unicast                       149                13082
   multicast                     69547              7852724
 Line receive              Packets                Bytes
   unicast                       155                14288
   multicast                     69550              8131122
 Host send                 Packets                Bytes
   unicast                       19                 1710
   multicast                     3                  210
 Line send                 Packets                Bytes
   unicast                       13                 1100
   multicast                     0                    0
 Input Errors
   parity 0 short0 crc 0 ringiderr 0
 Output Errors
   parity 0 short0  giants0  fifo  0
 Control Frame                   In                  Out
           Oam                    0                    0
           Atd                    15398                 5162
            Tc                    51551               104258
            Tp                    27               104266
 Mode                  Packet                 Byte
 SaStrip                    0                    0
 TtlDrop                    51708            458323880
 TxFlood                    69671              8142460
 RxFlood                  69671              8142460
Last 300 second Host input:12 packet/sec  17248 bit/sec  0%
Last 300 second Line input: 12 packet/sec  17648 bit/sec  0%
Last 300 second Host output: 0 packet/sec   0 bit/sec  0%
Last 300 second Line output:  0 packet/sec   0 bit/sec  0%
Table 1-1 Description on the fields of the display interface command
Current RPRPOS port status
Rpr station name is
Name of the destination RPR station to be checked
MAC address of the RPR bridge
Configured default ring ID
RPR work mode
RPR operation mode
The priority Map is
Priority mapping
IP mask of RPR Access VLAN's interface is
IP address of the VLAN interface to which an RPR port is bound
IP subnet mask of the VLAN interface to which an RPR port is bound
Port hold time
The maximum transmit unit
2.5G mode and full duplex mode
Flow-control
Flow control
The maximum frame length
Broadcast MAX-ratio
Broadcast storm suppression ratio on the port
Allows jumbo frame to pass
PVID
Default port VLAN ID
Port link-type
Port link type
Tagged   VLAN ID
Identifies the tagged packets in the port’s VLANs
Untagged VLAN ID
Identifies the untagged packets in the port’s VLANs
Input and output rates and number of packets on ports in last 300 seconds
7414146 bytes          8666 broadcasts, 57941 multicasts
          0 frame,  0 overruns, - aborts, 0 ignored, - parity errors Output(total): 35 packets, 2810 bytes
Input/output packet and error statistics on ports. The hyphen (-) indicates this statistical item is not supported.
display rpr counters [ transit | host | total ] [ { RprPos | Rpr10GE | RprGE } interface-number ]
View
transit: Traffic transited by the station.
host: Host traffic through the station.
total: Total traffic through the station.
RprPos: Specifies the interface type RPRPOS.
Rpr10GE: Specifies the interface type RPR10GE.
RprGE: Specifies the interface type RPRGE.
interface-number: Interface number.
Use the display rpr counters command to display the statistics of different types of packets sent, received, and forwarded through the specified station.
The statistics includes packets sent and received on the hosts and interfaces of the current station, packets transited by the station, average rate in the latest specific time period, and the error packets received on the interface.
The statistics displays information about unicasts and multicasts of four priorities (A, B0, B1, and C) inserted, copied, and transited by the station.
Statistics of the transited packets are calculated as follows: the east transited packets are packets transited by ringlet 0; the west transited packets are packets transited by ringlet 1. The command output displays the east and west span statistics by physical port. For example, RPRPOS 1/1/1.1 specifies the west span and RPRPOS 1/1/1.2 specifies the east span.
l           If the traffic type is not specified, the command displays all the traffic statistics.
l           If no RPR port is specified, the command displays traffic statistics of all the RPR ports.
l           If an RPR logical interface is specified, traffic statistics of both west and east ports are displayed.
Example
# Display the traffic information of the RPR logical interface RPRPOS 1/1/1.
<H3C> display rpr counters RprPos1/1/1
Data traffic counters for RprPos1/1/1
West Span:
Transit                            Packets                Bytes
    total high priority            24527199               3580971054
    total med cir priority         2075963                303090598
    total med eir priority         22451236               3277880456
    total low priority             24527198               3580970908
    total unicast                  36790797               5371456362
    total multicast                36790799               5371456654
Host Receive                       Packets                Bytes
    unicast high priority          12267373               1741966966
    unicast med cir priority       1037627                147343034
    unicast med eir priority       11229746               1594623932
    unicast low priority           12267373               1741966966
    multicast high priority        12267373               1741966966
    multicast med cir priority     1038365                147447830
    multicast med eir priority     11229008               1594519136
    multicast low priority         12267373               1741966966
Line Receive                       Packets                Bytes
    unicast high priority          24534746               3582072916
    unicast med cir priority       2075740                303058040
    unicast med eir priority       22459005               3279014730
    unicast low priority           24534745               3582072770
    multicast high priority        12267373               1791036458
    multicast med cir priority     1038365                151601290
    multicast med eir priority     11229008               1639435168
    multicast low priority         12267373               1791036458
Host Transmit                      Packets                Bytes
    unicast high priority          12196151               1780638046
    unicast med cir priority       3116373                454990458
    unicast med eir priority       9080507                1325754022
    unicast low priority           12196501               1780689146
    multicast high priority        0                      0
    multicast med cir priority     0                      0
    multicast med eir priority     0                      0
    multicast low priority         0                      0
Line Transmit                      Packets                Bytes
    unicast high priority          24460679               3571259134
    unicast med cir priority       2632765                384383690
    unicast med eir priority       21827598               3186829308
    unicast low priority           24460238               3571194748
    multicast high priority        24463257               3571635522
    multicast med cir priority     2559571                373697366
    multicast med eir priority     21903442               3197902532
    multicast low priority         24462912               3571585152
Traffic Rate (20  Seconds)         Packets/Sec            Bits/Sec
    transit high priority          0                      0
    transit med cir priority       0                      0
    transit med eir priority       0                      0
    transit low priority           0                      0
    transit unicast                0                      0
    transit multicast              0                      0
    host receive                   0                      0
    host transmit                  0                      0
    line receive                   0                      0
    line transmit                  0                      0
Received Errors:
0 input errors,0 crc,0 parity,5177 ttldrop
0 frame runts,0 frame giants
East Span:
    total high priority            24534746               3582072916
    total med cir priority         2076478                303165788
    total med eir priority         22458267               3278906982
    total low priority             24534745               3582072770
    total unicast                  36802117               5373109082
    total multicast                36802119               5373109374
    unicast high priority          12263600               1741431200
    unicast med cir priority       1037178                147279276
    unicast med eir priority       11226422               1594151924
    unicast low priority           12263600               1741431200
    multicast high priority        12263600               1741431200
    multicast med cir priority     1038251                147431642
    multicast med eir priority     11225349               1593999558
    multicast low priority         12263599               1741431058
    unicast high priority          24527199               3580971054
    unicast med cir priority       2074890                302933940
    unicast med eir priority       22452309               3278037114
    unicast low priority           24527199               3580971054
    unicast high priority          12197080               1780773680
    unicast med cir priority       1595053                232877738
    unicast med eir priority       10601711               1547849806
    unicast low priority           12196639               1780709294
    multicast high priority        12199657               1781149922
    multicast med cir priority     1521320                222112720
    multicast med eir priority     10678093               1559001578
    multicast low priority         12199313               1781099698
    unicast high priority          24463524               3571674504
    unicast med cir priority       4154486                606554956
    unicast med eir priority       20309766               2965225836
    unicast low priority           24463873               3571725458
    transit unicast                0                      0
    host receive                   0                      0
    host transmit                  0                      0
    line receive                   0                      0
    line transmit                  0                      0
Received Errors:
0 input errors,0 crc,0 parity,5098 ttldrop
# Display the traffic statistics of the RPR physical port RPRPOS1/1/1.1.
<H3C> display rpr counters RprPos1/1/1.1
Data traffic counters for RprPos1/1/1.1
West Span:
    transit unicast                0                      0
    host receive                   0                      0
    host transmit                  0                      0
    line receive                   0                      0
    line transmit                  0                      0
Received Errors:
# Display transited traffic statistics of the RPR physical port RPRPOS 1/1/1.1.
<H3C> display rpr counters transit RprPos1/1/1.1
West Span:
Traffic Rate (300 Seconds)         Packets/Sec            Bits/Sec
    transit unicast                0                      0
Table 1-2 Description on the fields of the display rpr counters command
Data traffic counters for XXX
Traffic statistics of a specified port
West Span
West span
East Span
East span
Number of packets and bytes transited
total high priority
Total transited class A traffic
Total transited class B0 traffic
Total transited class B1 traffic
total low priority
Total transited class C traffic
total unicast
Total transited unicast
total multicast
Total transited multicast and broadcast
Number of packets and bytes the host receives
Number of packets and bytes the interface receives
Number of packets and bytes the host sends
Number of packets and bytes the interface sends
Class A unicast
Class B0 unicast
Class B1 unicast
Class C unicast
Class A multicast and broadcast
Class B0 multicast and broadcast
Class B1 multicast and broadcast
Class C multicast and broadcast
Traffic Rate (XXX Seconds)         Packets/Sec            Bits/Sec
Packet rate and bit rate in a time range, the value in the brackets can be tuned by the flow-interval command
Transited Class A traffic
Transited Class B0 traffic
Transited Class B1 traffic
Transited Class C traffic
transit unicast
Transited unicast
transit multicast
Transited multicast and broadcast
host receive
Traffic the host receives
host transmit
Traffic the host sends
line receive
Traffic the interface receives
line transmit
Traffic the interface sends
Received Errors
Error packets the interface receives
input errors
Input error statistics, including CRC packets, parity check packets, runt and giant packets.
crc
CRC packets
parity
Parity check packets
ttldrop
The packets dropped because the TTL becomes 0
frame runts
Runt frames
frame giants
Giant frames
display rpr defect [ { RprPos | Rpr10GE | RprGE } interface-number ]
View
Use the display rpr defect command to display all RPR defects. The value 1 indicates defects are found. The value 0 indicates there is no defect.
# Display all RPR defects.
<H3C> display rpr defect RprPos 5/1/1
Rpr defects of the interface: RprPos5/1/1
  Amount of reserved bandwidth exceeded defect: 0
  Jumbo configuration defect: 0
  Keepalive timeout:ringlet0 1,ringlet1 0
  Maximum number of stations exceeded defect: 0
  Miscabling defect: ringlet0: 0, ringlet1: 0
  Protection mode configuration defect: 0
  Inconsistent topology defect: 0
  Topology instability defect: 0
  IP address duplicate defect 0
Table 1-3 Description on the fields of the display rpr defect command
RPR defects of the port
Reserved bandwidth exceeded
Defect of maximum number of stations exceeded
Miscabling defect
Fiber misconnection defect
Instable topology defect
Duplicate IP address defect
display rpr fairness [ { RprPos | Rpr10GE | RprGE } interface-number ]
View
Use the display rpr fairness command to display configurable RPR fairness parameter values.
# Display RPR fairness parameters.
<H3C> display rpr fairness Rpr10GE5/1/1
Rpr fairness parameters of the interface:Rpr10GE5/1/1
  Station's fairness weight on ringlet0: 1
  Station's fairness weight on ringlet1: 1
  Local Reserved bandwidth for class A0 on ringlet0: 0Mbps
  Local Reserved bandwidth for class A0 on ringlet1: 0Mbps
  Local Rate-limiter bandwidth for high on ringlet0: 50Mbps
  Local Rate-limiter bandwidth for high on ringlet1: 50Mbps
  Local Rate-limiter bandwidth for medium on ringlet0: 0Mbps
  Local Rate-limiter bandwidth for medium on ringlet1: 0Mbps
  Local Rate-limiter bandwidth for low on ringlet0: 10000Mbps
  Local Rate-limiter bandwidth for low on ringlet1: 10000Mbps
  Total Reserved bandwidth for class A0 on ringlet0: 0Mbps
  Total Reserved bandwidth for class A0 on ringlet1: 0Mbps
Table 1-4 Description on the fields of the display rpr fairness command
RPR fairness parameters of the port
Station's fairness weight on ring 0
Station's fairness weight on ring 1
Locally reserved bandwidth for class A0 on ring 0
Locally reserved bandwidth for class A0 on ring 1
Local rate-limiter bandwidth for class A1 on ringlet0
Local rate-limiter bandwidth for class A1 on ringlet1
Local rate-limiter bandwidth for class B-CIR on ringlet0
Local rate-limiter bandwidth for class B-CIR on ringlet1
Local rate-limiter bandwidth for class C and class B-EIR on ringlet0
Local rate-limiter bandwidth for class C and class B-EIR on ringlet1
Totally reserved bandwidth for class A0 on ring 0
Totally reserved bandwidth for class A0 on ring 1
display rpr mac [ count | vlan-id vlan-id | eth-mac user-mac-addr | rpr-mac rpr-mac-addr | { RprPos | Rpr10GE | RprGE } interface-name ]
View
count: Number of MAC addresses learnt by an RPR port.
vlan-id vlan-id: VLAN ID.
eth-mac user-mac-addr: User MAC address.
rpr-mac rpr-mac-addr: RPR station MAC address.
interface-name: Interface name.
Use the display rpr mac command to display the information about the user MAC addresses and RPR station MAC addresses learnt. This command can also display the number of the user MAC addresses learnt if you specify the count keyword.
l           If the vlan-id argument is not specified, this command displays all the VLANs the users belong to.
l           If the user-mac-addr argument is not specified, this command displays all the user MAC addresses learnt.
l           If the rpr-mac-addr argument is not specified, this command displays the mapping relationship between all the stations and user MAC addresses.
l           If the interface-name argument is not specified, this command displays the information about the MAC addresses corresponding to all the RPR logical interfaces.
# Display the information about all the user MAC addresses learnt.
<H3C> display rpr mac
    Dest-MAC        RPR-MAC      VLANID     Ringlet   TTL
 000f-e211-1116  000f-e251-b1c6  100         1        1
 000f-e272-4a16  000f-e211-e018  6           1        1
 Total 2 mac(s) on device 1(RprGE3/1/2).
Table 1-5 Description on the fields of the display rpr mac command
Dest-MAC
User MAC addresses learnt by an RPR port
RPR-MAC
MAC address of an RPR station
VLANID
ID of the VLAN a user belongs to
Ringlet
ID of the ringlet selected for reaching a user from a station
TTL
Number of the hops between a station and a user
Number of the MAC addresses an RPR logical interface learnt
display rpr protection [ { RprPos | Rpr10GE | RprGE } interface-number ]
View
Use the display rpr protection command to view protection information. If you do not specify port number, the command displays the protection information about all RPR ports.
RPR protection information includes but is not limited to the following contents:
l           MAC addresses of the neighbor stations
l           Protection mode, recovery protection mode, automatic protection status, manual protection status and edge status for local station
l           Protection statistics such as protection times, last protection time, protection duration, and others
l           Protection mode can be either configured or effective. You can configure protection mode, however, the configured protection mode may not take effect. RPR automatically checks total protection mode, and makes effective protection mode as consistent as possible.
# Display protection information.
<H3C> display rpr protection
Protection information of the interface: RprGE6/1/1
  Protection mode configured: steer
  Protection mode effective: steer
  Protection reversion mode: revertive
  Containment active: 0
  MAC address of the east neighbour:000f-e26b-05b4
  MAC address of the west neighbour:000f-e26b-03e4
  Protection State of the east span:idle
  Protection State of the west span:idle
  Edge status of the east span: false
  Edge status of the west span: false
  The number of protections on the east span:1
  The number of protections on the west span:0
  Last protection time on the east span:2008.01.24 11:22:07
  Last protection time on the west span:NULL
Table 1-6 Description on the fields of the display rpr protection command
Protection information of the port
Configured protection mode
Currently effective protection mode
Recovery protection mode
Containment active
Strict order check (0 means disabled and 1 means enabled)
MAC address of the east neighbor
MAC address of the east neighbor station
MAC address of the west neighbor
MAC address of the west neighbor station
Protection status of the east span
Protection status of the west span
Protection start time on the east span
Protection start time on the west span
display rpr rs-table { overall | static | dynamic | vrrp } [ { RprPos | Rpr10GE | RprGE } interface-number ]
View
overall: Integrated ring selection tables, which guide field programmable gate array (FPGA) to select rings.
static: Static ring selection tables. You can create them manually. Their priority is higher than that of dynamic ring selection tables. But it takes effect only in closed rings.
dynamic: Dynamic ring selection tables. Topology databases can calculate them according to the shortest path.
vrrp: VRRP (virtual router redundancy protocol) ring selection tables, which consist of MAC ring selection entries from integrated ring selection tables when VRRP is supported.
Use the display rpr rs-table command to display integrated ring selection table information. Integrated ring selection tables, which are written in CAM (conditional access module) of the FPGA finally, are generated from static and dynamic ring selection tables, In the case of closed rings, for the same destination station, the system selects rings according to the existing static ring selection information. Otherwise, the system selects rings according to the dynamic ring selection information. In the case of open rings, static ring selection does not take effect.
# Display the dynamic ring selection table of RPRPOS 5/1/1.
<H3C> display rpr rs-table dynamic RprPos 5/1/1
Dynamic ringlet selection table of interface: RprPos5/1/1
MAC Address    Ringlet TTL  IP Address       Station Name
000f-e255-1006    1      1  100.0.0.3        S9500-C
000f-e211-1116    0      2  100.0.0.2        S9500-B
000f-e239-af18    0      1  100.1.1.1        S9500-A
display rpr statistics { dmac | smac } mac-address [ { RprPos | Rpr10GE | RprGE } interface-number ]
View
dmac: Destination MAC address.
smac: Source MAC address.
mac-address: You can input in the format of H-H-H to query the source station bridge MAC address. All 0 indicates displaying MAC addresses of all stations in the ring.
Use the display rpr statistics command to query the traffic statistics information of packets sent from other stations to local station or from the local station to other stations. .
# Query the traffic from station with bridge MAC address 000F-E211-1116 in the ring.
<H3C> display rpr statistics smac 000f-e211-1116 RprPos3/1/1
Source statistics of  interface: RprPos3/1/1
Mac address: 000f-e211-1116 Packets: 0 Bytes: 0
display rpr timers [ { RprPos | Rpr10GE | RprGE } interface-number ]
View
Use the display rpr timers command to display all configurable RPR timer values.
# Display all RPR timer values.
<H3C> display rpr timers RprPos 5/1/1
All the timers' value of  interface: RprPos5/1/1
  TP fast timer:  10ms
  TP slow timer: 100ms
  TC fast timer:  10ms
  TC slow timer: 100ms
  ATD timer:  1s
  WTR timer: 0s
  Holdoff timer: 0ms
  Topology stability timer: 40ms
  FDD timer:  100ms
  MAC-AGING timer: 30s
Table 1-7 Description on the fields of the display rpr timers command
All the timers' values of the port
TP fast timer
TP fast timer
TP slow timer
TP slow timer
TC fast timer
TC fast timer
TC slow timer
TC slow timer
ATD timer
ATD timer
WTR timer
WTR timer
Holdoff timer
Holdoff timer
Stable topology timer
FDD timer
FDD timer
MAC-AGING timer
Aging timer for RPR MAC learning
display rpr topology { all | ring | local | stations } [ verbose ] [ { RprPos | Rpr10GE | RprGE } interface-number ]
View
all: Displays complete RPR topology information.
ring: Displays ring-level topology information.
local: Displays local station topology information.
stations: Displays all station topology information on the ring.
verbose: Displays detailed information of the station topology.
Use the display topology command to view topology information.
With the all, ring, local and stations keywords, the command displays different ring topology information. When the optional parameter is an interface name, the command displays the topology information of the interface; when the optional parameter is verbose + interface name, the command displays the detailed information of the interface; when the optional parameter is verbose only, the command displays the detailed information of all interfaces.
Ring topology information includes the number of stations in the ring, ring topology type, maximum transmission unit (MTU) value and others.
Local station topology information includes local station MAC address, protection status, edge status, and others.
Other station topology information contains MAC addresses for other stations, protection status, edge status and others.
If you do not specify a port, the command displays all RPR port topology information.
# View the local topology information.
<H3C> display rpr topology local verbose
Local station topology information of interface:RprPos5/1/1
  Mac address:000f-e211-1116
  Station name:S9500-D
  Ip address:100.0.0.4
  Jumbo preference:jumbo
  Current protection mode:steer
  Protection state on ringlet0:idle
  Protection state on ringlet1:idle
  Edge status on ringlet0: false
  Edge status on ringlet1: false
  Sequence number:26
  Last known neighbour on ringlet0: 000f-e211-7a16
  Last known neighbour on ringlet1: 000f-e219-11a6
  Local topology state:topology is valid
1.1.13  flag
flag { c2 c2-value | j0 j0-value | j1 j1-value }
undo flag { c2 | j0 | j1 }
View
c2 c2-value: Path signal label byte, which is a high-order path overhead byte, and indicates the multiplexing structure and message payload of the VC (virtual container) frame.
j0 j0-value: Regeneration section trace message, which is a section overhead byte, and checks port connectivity at section level.
j1 j1-value: Higher-order VC-N path trace byte, which is a high-order overhead byte, and checks port connectivity at path level.
Use the flag command to configure SONET/SDH overhead bytes.
Use the undo flag command to restore the default configuration.
c2 is 0x16 by default.
By default, j0 and j1 both are “H3C”.
The c2, j0 and j1 values should be consistent respectively at the receiver and sender. Otherwise, the system may give alarms.
# Configure overhead byte for the RPR port.
<H3C> system-view
[H3C] interface RprPos 2/1/1.1
[H3C-RprPos2/1/1.1] flag c2 22
1.1.14  frame-format
frame-format { sdh | sonet }
undo frame-format
View
sdh: Specifies the framing format as SDH.
sonet: Specifies the framing format as SONET.
Use the frame-format command to configure the framing format on the RPR POS physical port.
Use the undo frame-format command to restore the default configuration.
By default, the framing format is SDH.
# Configure the RPR port RPRPOS 2/1/1.1 to use SDH framing format.
<H3C> system-view
[H3C-RprPos2/1/1.1] frame-format sdh
View
Use the interface { RprPos | Rpr10GE | RprGE } command to enter RPR logical interface view.
# Enter RPR logical interface view.
<H3C> system-view
[H3C] interface RprPos 3/1/1
[H3C-RprPos3/1/1]
View
interface-number { 1 | 2 }: Physical port number.
Use the interface { RprPos | Rpr10GE | RprGE } interface-number . { 1 | 2 } command to enter RPR physical port view.
# Enter RPR physical port view.
<H3C> system-view
[H3C] interface RprPos 3/1/1.1
[H3C-RprPos3/1/1.1]
1.1.17  loopback
undo loopback
external: Specifies the port loopback mode as external. Currently, the S9500 series do not support this mode.
internal: Specifies the port loopback mode as internal.
Use the loopback command to set the loopback mode of an RPR logical interface.
Use the undo loopback command to remove the configuration.
By default, no loopback mode is configured on the RPR logical interface.
# Set the loopback mode of the RPR logical interface as internal.
<H3C> system-view
[H3C] interface rprpos 3/1/1
[H3C-RprPos3/1/1] loopback internal
1.1.18  port-type
port-type { 10gpos | 10ge }
View
10gpos: Specifies the RPRPOS mode.
10ge: Specifies the RPR10GE mode.
Use the port-type command to set the 10G RPR board mode. After the mode changes successfully, the board restarts automatically for the port to switch to new RPR port type.
  Caution:
l      This command is only available to 10G RPR ports. A 2.5G RPR port supports only the POS mode, and a GE RPR port supports only the RprGE mode.
l      After you change the port type of an RPR port and the card  restarts, the existing configuration of the port will be automatically removed. Therefore, you need to configure the port again.
# Set RPR port type to 10GE.
<H3C> system-view
[H3C-RprPos3/1/1] port-type 10ge
reset counters interface [ interface-type interface-number ]
View
interface-type: Interface type.
interface-number: Port number, in the format of slot number/card number/port number. The port can be an RPRPOS logical interface or physical port.
Use the reset counters interface command to clear port statistics to implement statistics of related information on the port..
# Clear the statistics on RPRPOS 2/1/1.
<H3C> reset counters interface RprPos2/1/1
# Clear the statistics on RPRPOS 2/1/1.1.
<H3C> reset counters interface RprPos2/1/1.1
rpr admin-request { fs | ms | idle } { ringlet0 | ringlet1 }
View
fs: Forced switchover.
ms: Manual switchover.
idle: Clears forced switchover or manual switchover and enters Idle state.
ringlet0: Requests switchover in Ringlet0.
ringlet1: Requests switchover in Ringlet1.
Use the rpr admin-request fs command to generate a forced switchover request, making the station enter forced switchover status. The event related to switchover in protection mechanism includes FS, SF, SD, MS, WTR and IDLE. Other protection requests are not able to preempt FS with the highest priority. After you use the rpr admin-request fs command to generate an FS request, other events are not able to preempt FS. To cancel FS, you must use the rpr admin-request idle command.
Use the rpr admin-request ms command to generate an MS for manual switchover. The MS priority is lower. Both the rpr admin-request idle command and any failure (FS, SF or SD) in the RPR ring can preempt MS, making MS fail. If there are other commands with higher priority, the manual switchover you are performing also fails automatically.
Use the rpr admin-request idle command to clear forced switchover or manual switchover.
Note that:
l           The receiving and sending sub-rings of port 1 on the panel are Ringlet0 and Ringlet1 respectively. The receiving and sending sub-rings of port 2 on the panel are Ringlet1 and Ringlet0 respectively. Here Ringlet0 and Ringlet1 are both receiving sub-rings.
l           Do not request FS in the two ringlets on the same logical interface of the master board of the distributed RPR.
# Request FS in the Ringlet0 of the station.
<H3C> system-view
[H3C-RprPos2/1/1] rpr admin-request fs ringlet0
# Request for MS protection in the receiving direction on Ringlet1 of the station.
<H3C> system-view
[H3C-RprPos2/1/1] rpr admin-request ms ringlet1
rpr cos-precedence-map { tag | mpls | ip } value0 value1 value2 value3 value4 value5 value6 value7
undo rpr cos-precedence-map { tag | mpls | ip }
View
tag: Maps tag priority to RPR priority
mpls: Maps mpls priority to RPR priority
ip: Maps ip priority to RPR priority.
value0 to value7: Values of the RPR priority which tag, mpls and ip priorities correspond respectively to. 0—A, 1—B, 2—C.
Use the rpr cos-precedence-map command to map tag, mpls and ip priority types to RPR priority.
Use the undo rpr cos-precedence-map command to remove the configuration and restore the default configuration.
The eight parameters indicate the RPR priority which tag, mpls and ip priorities correspond respectively to. By default, for packets with a tag, the mapping will be implemented as per tag; for packets without a tag, if they are MPLS packets, the mapping will be implemented as per MPLS priority; if they are IP packets instead of MPLS packets, the mapping will be implemented as per IP priority; if they are either MPLS packets or IP packet, the priority will be mapped to Class C.
  Caution:
GE RPR ports do not support MPLS precedence mapping and IP precedence mapping.
# Configure tag priorities 6 and 7 as class A service, priorities 2, 3, 4 and 5 as class B service, and priorities 0 and 1 as class C service.
<H3C> system-view
[H3C] interface RprPos3/1/1
[H3C-RprPos3/1/1] rpr cos-precedence-map tag 2 2 1 1 1 1 0 0
rpr default-rs { ringlet0 | ringlet1 }
View
ringlet0: Transports broadcast, multicast and Flooding packets over Ringlet0.
Ringlet1: Transports broadcast, multicast and Flooding packets over Ringlet1.
Use the rpr default-rs command to configure the default RPR ring ID. Broadcast, multicast and Flooding packets are transmitted in the default ring. Note that the default ring selection is the sending sub-ring.
# Configure the default RPR ring ID as Ringlet0.
<H3C> system-view
[H3C-RprPos2/1/1] rpr default-rs ringlet0
1.1.23  rpr echo
rpr echo { mac mac-address | station-name station-name } [ -c value | -s value | -r value | -t value | -p value ] *
View
mac-address: MAC address of the destination station to be detected.
station-name: Name of the destination station to be detected. You can select either station name or MAC address.
-s: Specifies the sub-ring to send test frames. You cannot configure default sub-ring for transmitting packets.
-r: Specifies the sub-ring to receive test frames.
-c: Specifies the number of packets to be sent.
-t: Specifies the timeout time to wait for acknowledgement.
-p: Specifies whether OAM operations need to be protected in the steer mode.
Use the rpr echo command to test station connectivity. If two stations are connected correctly at the physical layer, but the connection fails at the service layer, you can use the Echo Req/Echo Rsp message to test the failure. The source station sends an Echo Req message. When receiving it, the destination station gives the sender an Echo Rsp message. If the source station receives the Echo Rsp message within the specified time, it shows the connection is correct. Otherwise, it shows the failure between the two stations.
# Detect whether the connection to station A whose Mac address is 000F-E211-1116 in the ring is correct.
<H3C> system-view
[H3C] interface RprPos5/1/1
[H3C-RprPos5/1/1] rpr echo mac 000f-e211-1116
  echo 000f-e211-1116 , press CTRL_C to break
    reply from  000f-e211-1116:  hops=1 seq=1 rcv-ri=0 time=2 ms
  --- echo 000f-e211-1116 statistics ---
    1 packet(s) transmitted
    1 packet(s) received
    0.00%  packet loss
    round-trip min/avg/max  = 2/2/2 ms
rpr protect-mode { steer | wrap }
undo rpr protect-mode
View
steer: The source station sends data in another direction for protection.
wrap: The failure station sends data in loopback mode for protection.
Use the rpr protect-mode command to configure station protection mode as Steer or Wrap. The default mode is Steer.
Use the undo rpr protect-mode command to restore the steer RPR protection mode.
# Set the RPR protection mode to Wrap.
<H3C> system-view
[H3C-RprPos3/1/1] rpr protect-mode wrap
rpr rate-limiter { high | low | medium | reserved } { ringlet0 | ringlet1 } value
undo rpr rate-limiter { high | low | medium | reserved } { ringlet0 | ringlet1 }
View
high: Class A service; the default value is five thousandth.
low: Class C and class B-EIR service.
medium: Class B-CIR service.
reserved: Configures the reserved bandwidth for class A0 service, which has the highest priority; the default value is 0 Mbps.
ringlet0: Configures the reserved bandwidth or rate limit for the station on Ringlet0.
ringlet1: Configures the reserved bandwidth or rate limit for the station on Ringlet1.
value: Thousandth of the reserved bandwidth or rate limiter, in the range 0 to 955. The step is 1, the default value of high class is 5.
Use the rpr rate-limiter command to configure rate limit for class A, class B-CIR, class C and class B-EIR services on the local station.
Use the undo rpr rate-limiter command to restore rate limit to the default value. When the rate exceeds this limit, back pressure will occur.
Note: The total reserved bandwidth for all stations on a ring must not exceed the ring bandwidth.
# Set the rate limit for local class A1 service on Ringlet0 and Ringlet1 to 5‰
<H3C> system-view
[H3C] interface Rpr10GE6/1/1
[H3C-Rpr10GE6/1/1] rpr rate-limiter high ringlet0 5
[H3C-Rpr10GE6/1/1] rpr rate-limiter high ringlet1 5
rpr reversion-mode { revertive | non-revertive }
undo rpr reversion-mode
View
non-revertive: Sets the protection reversion mode to non-revertive. After the WTR timer times out, the service cannot be restored till others request high priority protection in the ring.
revertive: Sets the protection reversion mode to revertive. After the WTR timer times out, the service can be restored at once.
Use the rpr reversion-mode command to set the protection reversion mode.
Use the undo rpr reversion-mode command to restore the default mode.
The default RPR protection reversion mode is revertive.
# Set RPR protection reversion mode to non-revertive.
<H3C> system-view
[H3C-RprPos2/1/1] rpr reversion-mode non-revertive
rpr static-rs { mac-address } { ringlet0 | ringlet1 }
undo rpr static-rs [ mac-address ]
View
mac-address: MAC address of destination station.
ringlet0: Transports packets to the specified station over Ringlet0.
ringlet1: Transports packets to the specified station over Ringlet1.
Use the rpr static-rs command to configure static ring selection information and force the RPR ring to transmit packets to the specified station. You can configure them according to the IP address or MAC address of the destination station.
Use the undo rpr static-rs command to remove the configuration. If no parameter is selected, the command removes all static configurations.
By default, the static ring selection information is not configured.
Note that two stations’ bridge MAC addresses cannot be the same on the ring. Here both Ringlet0 and Ringlet1 refer to sending sub-rings.
# Transport data packets to the destination station with MAC address 0016-E266-0101 over ringlet0, and transport data packets to the destination station with MAC address 0016-E266-0202 over ringlet1.
<H3C> system-view
[H3C-RprPos2/1/1] rpr static-rs 0016-e266-0101 ringlet0
[H3C-RprPos2/1/1] rpr static-rs 0016-e266-0202 ringlet1
rpr station-mac
undo rpr station-mac
View
None
Use the rpr station-mac command to configure the MAC address of the RPR station specified by the RPR logical interface. The configured MAC address will be: MAC address of the RPR station’s VLAN interface + 4.
Use the undo rpr station-mac command to restore the default.
By default, the MAC address of an RPR station is the MAC address of the RPR station’s VLAN interface.
Note that the rpr station-mac command cannot be executed on the GERPR interface.
Example
# Configure the MAC address of the RPR station specified by RPRPOS 2/1/1.
<H3C> system-view
[H3C-RprPos2/1/1] rpr station-mac
rpr station-name string
undo rpr station-name
View
string: Station name, a string consisting of up to 20 bytes.
Use the rpr station-name command to configure a station name.
Use the undo rpr station-name command to remove the configuration.
# Name the local station as hangzhou.
<H3C> system-view
[H3C-RprPos2/1/1] rpr station-name hangzhou
1.1.30  rpr timer
rpr timer { atd value | fdd value | holdoff value | stability value | tp-fast value | tp-slow value | tc-fast value | tc-slow value | wtr value | keepalive value | mac-aging value }
undo rpr timer { atd | fdd | holdoff | stability | tp-fast | tp-slow | tc-fast | tc-slow | wtr | keepalive | mac-aging }
View
atd value: Sets the ATD timer. The value argument ranges from 1 to 200 (in 50 ms). The system default is 20, meaning one second..
fdd value: Sets the FDD timer. The value argument ranges from 10 to 1,000 (in milliseconds).
holdoff value: Sets the hold-off timer. The value argument ranges from 0 to 50 (in 10 milliseconds). The system default is 0.
stability value: Sets the stability timer. The value argument ranges from 10 to 100 (in milliseconds).
tp-fast value: Sets the TP-fast timer. The value argument ranges from 1 to 20 (in milliseconds).
tp-slow value: Sets the TP-slow timer. The value argument ranges from 1 to 200 (in 50 ms). The system default is 20, meaning one second.
tc-fast value: Sets the TC-fast timer. The value argument ranges from 1 to 20 (in milliseconds).
tc-slow value: Sets the TC-slow timer. The value argument ranges from 50 to 1,000 (in milliseconds).
wtr value : Sets the WTR timer. The value argument ranges from 0 to 1440 (in seconds). The system default is 10 seconds.
keepalive value: Sets the keepalive timer (in million seconds). The value argument ranges from 2 to 50 and must be a multiple of 1. The system default is 10 ms.
mac-aging value: Sets the MAC aging timer (in seconds). The value argument ranges from 0 to 600 and must be a multiple of 1. The system default is 30 seconds.
Use the rpr timer to set a timer.
Use the undo rpr timer command to restore the setting of a timer to the default.
  Caution:
When configuring mac-aging keyword on a 10G or 2.5G RPR port, make sure the value is a multiple of 10.
# Set the ATD timer to 3 seconds.
<H3C> system-view
[H3C-RprPos2/1/1] rpr timer atd 3
1.1.31  rpr weight
rpr weight { ringlet0 | ringlet1 } value
undo rpr weight { ringlet0 | ringlet1 }
View
ringlet0: Configures station weight on Ringlet0.
Ringlet1: Configures station weight on Ringlet1.
value: Station weight. The default value is 1.
Use the rpr weight command to configure the station weight. Fairness algorithm uses station weight to calculate local fairness rate. The default weight is 1.
Use the undo rpr weight command to restore the default weight.
The fairness algorithm calculates the local fairness rate based on the station weight value. By default, the weight value is 0. In fact, the weight value configured here is the Nth power of 2, namely weight = 2 value, where value ranges 0 to 7. Therefore, the value range of weight is 1 to 128.
# Set weight of stations on ringlet0 to 2.
<H3C> system-view
[H3C-RprPos2/1/1] rpr weight ringlet0 2
sdh threshold sdber value sfber value
undo sdh threshold
View
sdber value: Threshold index for signal degrade (SD BER). It ranges from 5 to 7 and defaults to 6. The actual alarm threshold can be obtained by using the following expression: 10-value.
sfber value: Threshold index for signal failure (SF BER). It ranges from 3 to 5 and defaults to 4. The actual alarm threshold can be obtained by using the following expression: 10-value.
Use the sdh threshold command to set the SD threshold and SF threshold.
Use the undo sdh threshold command to restore the default configuration.
The alarm information configured by this command is the overhead in SDH frame header, which monitors SDH signals at each layer.
# Set the SD threshold index to 6 and the SF threshold index to 5.
<H3C> system-view
[H3C-RprPos2/1/1.1] sdh threshold sdber 6 sfber 5
1.1.33  shutdown
shutdown
View
RPR logical/physical port view
None
Use the shutdown command to disable the RPR logical/physical interface.
Use the undo shutdown command to enable the RPR logical/physical interface.
  Caution:
On a ring network, with the shutdown command executed on the RPR logical interface of a station, the traffic of the ring network is forwarded by the station instead of entering the logical interface.
After you disable an RPR physical port using the shutdown command, the corresponding laser is turned off, and the ring network enables the corresponding protection.
# Disable RPRPOS logical interface RPRPOS 2/1/1.
<H3C> system-view
[H3C-RprPos2/1/1.1] shutdown
display rpr tunnel-table [ vlan vlanid [ range number ] ] [ valid | invalid ] [ interface-type interface-number ]
View
vlanid: Start VLAN ID of the VLAN ID range.
range number: Number of the VLANs apart from the start VLAN.
valid: Displays the valid entries only.
invalid: Displays the invalid entries only.
Use the display rpr tunnel-table command to display the information about an RPR tunnel.
This command can also display the information about all the tunnels or display tunnel information according to VLAN, tunnel state (valid or invalid), or port number.
# Display the information about all the RPR Layer 2 tunnels.
<H3C> display rpr tunnel-table
Tunnel vlan table of  interface: RprPos4/1/1
Vid - Vlan ID, DA - Dest Mac Address, CA - Current Mac Address,
ARi - Actual Ringlet,CRi - Configed Ringlet, F - Force Ringlet,
Ttl - Ttl,Vld - Entry Valid, MonitorPort - Monitor Port
Vid      DA1                 DA2        CA  ARi  CRi  F  Ttl  Vld
1002     02dc-34e3-4ee0      N/A        1   0    0    T  2    1
1003     02dc-34e3-4ee0      N/A        1   0    0    T  2    1
MonitorPort
GigabitEthernet12/1/1
Ethernet11/1/3
 total 2, valid  2, invalid  0
Table 2-1 Description on the fields of the display rpr tunnel-table command
Vid
Tunnel entry corresponding to the VLAN
DA1
The first MAC address used to configure a tunnel
DA2
The second MAC address used to configure a tunnel
CA
Outbound MAC address of the current tunnel  (I means DA1 is used and 2 means DA2 is used)
ARi
ID of the current ringlet
CRi
ID of the user configured ringlet
F
Ringlet-tunnel binding by force: T means enabled, and F means disabled
Ttl
Time to live
Vld
The state of an entry
1 for valid, and 0 for invalid.
MonitorPort
Collaborating port
Number of total, valid, and invalid tunnel entries
display rpr tunnel-track { all | rpr-interface interface-type interface-number [ to bas-interface interface-type interface-number ] }
View
bas-Interface: Specifies a BAS port, which can be an Ethernet port or an RPR logical interface.
rpr-Interface: Specifies an RPR port, which can only be an RPR logical interface.
all: Displays all the port binding information.
Use the display rpr tunnel-track command to display all the port binding configuration or the binding configurations of a port.  When executing this command, you can specify only an RPR port or a complete collaboration port. However, you cannot only specify a BAS port.
# Display the port binding configuration that matches GigabitEthernet 2/1/1 to RPRPOS 6/1/1.
<H3C> display rpr tunnel-track rpr-interface r6/1/1 to bas-interface g2/1/1
BAS-Interface : GigabitEthernet2/1/1     [ USER_ADM_DOWN ]
RPR-Interface : RprPos6/1/1              [ LINK_UP ]
VLAN:
2 to 4,         6 to 8,         10 to 12,       14 to 16,
18 to 20,       22 to 24,       26 to 28,       30 to 32,
34 to 36,
Trigger-shutdown : enabled
Table 2-2 Description on the fields of the display rpr tunnel-track command
BAS-Interface
Configured port connected with the BAS
RPR-Interface
Configured RPR port
[ USER_ADM_DOWN ]
The status of the corresponding port.
USER_ADM_DOWN: The port is shut down manually.
BIND_DOWN: The port is shut down by the system because trigger-shutdown is configured.
LINK_UP: The link is up.
LINK_DOWN:: The link is down because of other problems.
VLAN
List of the VLANs bound
Trigger-shutdown
Decide whether to shut down the BAS port actively when the RPR port is not in up state.
rpr tunnel track interface-type interface-number to interface-type interface-number vlan vlan-list [ trigger-shutdown ]
undo rpr tunnel track [ interface-type interface-number to interface-type interface-number ]
View
vlan-list: VLANs to be bound. You can specify separate VLANs or a VLAN range in the format of vlan-list = { vlanid [ to vlanid ] }&<1-9>. &<1-9> means that you can provide up to nine separate VLANs or VLAN ranges.
trigger-shutdown: Specifies to shut down the ports bound to a BAS port when the latter goes down. If you specify this keyword, the ports specified are shut down automatically when the BAS port bound goes down. Otherwise, you need to shut down the ports manually.
Use the rpr tunnel track command to bind the port connected with a BAS and specified RPR ports and specify the related VLANs. Use the undo rpr tunnel track command to remove the corresponding configuration.
When a BAS port goes down/up, the RPR ports bound to it release a VLAN reachable/unreachable message to notify the entire network, by which the related RPR stations decide whether or not to switch Layer 2 tunnels. By specifying the trigger-shutdown keyword, you can have the BAS port automatically shut down when the status of specific RPR ports change to trigger port switching on the uplink BAS device.
# Bind GigabitEthernet 4/1/1 to RPRPOS 6/1/1. Specify the related VLANs as VLAN 2, VLAN 7, and VLAN 10. Enable automatic port shutdown.
<H3C> system-view
[H3C] rpr tunnel track GigabitEthernet4/1/1 to RprPos6/1/1 vlan 2 7 10 trigger-shutdown
# Remove a port binding.
[H3C] undo rpr tunnel track GigabitEthernet4/1/1 to RprPos6/1/1
# Remove all the port binding.
<H3C> system-view
rpr tunnel vlan vlanid [ range number ] dest-mac mac-address [ priority priority ] [ mac-address [ priority priority ] ] { ringlet0 | ringlet1 }
rpr tunnel vlan vlanid dest-mac mac-address { ringlet0 | ringlet1 } force-ringlet [ monitor-port interface-type interface-number ]
undo tunnel vlan vlanid [ range number ]
View
dest-mac mac-address: Destination MAC address of the Layer 2 tunnel. You can configure up to two destination MAC addresses. If the two destination MAC addresses are assigned with the same priorities, the first site is preferred.
priority priority: Assign a priority for a destination MAC address tunnel selecting. The default priority is 0. A bigger value represents a higher priority.
ringlet0: Specifies the ringlet 0 for data transfer.
ringlet1: Specifies the ringlet 1 for data transfer.
force-ringlet: Specifies a ringlet-tunnel binding by force. If the keyword is specified, the packets in the VLAN are tunneled through the ringlet in the binding if the original ringlet fails.
monitor-port interface-type interface-number: Specifies a collaborating port. The argument interface-type interface-number specifies an Ethernet port by port type and port number. A collaborating port can only be mapped to one tunnel. For an RPR logical interface, up to 32 tunnels with collaborating ports can be configured.
Use the rpr tunnel vlan command to configure packets of specific VLANs to be tunneled to the destination address.
Use the undo tunnel vlan command to restore the default.
By default, packets of VLANs are not configured to be tunneled to a destination station.
# Specify a tunnel for VLAN 8 to the destination address 000F-E211-1B16 through GigabitEthernet 2/1/1 by binding ringlet 0.
<H3C> system-view
[H3C] interface RprPos7/1/1
[H3C-RprPos7/1/1] rpr tunnel vlan 8 dest-mac 000f-e211-1b16 ringlet0 force-ringlet monitor-port GigabitEthernet12/1/1
display rpr vrrp [ interface-type interface-number ] [ group group-id ]
View
interface-type: RPR logical interface type.
interface-number: RPR port number.
group-id: VRRP group ID, in the range 1 to 2.
Use the display rpr vrrp group command to display the information about a VRRP group to which an RPR port is bound.
You can provide the logical RPR interface or the VRRP group, or both, for the command. When displaying collaboration group information, the system does not check whether or not the VLAN and VRID of the elaboration group exist in the system. If you do not specify a group ID, this command displays the information about all the groups on the port. If neither of the group number and RPR port number is provided, the command displays the information about all the collaboration groups configured in the system. If the VRRP group bound with the queried collaboration group is not configured, the system only displays the configuration information of the collaboration group.
# Display the information about the VRRP collaboration group 2 in RPR logical interface RPRPOS 4/1/1 with enabled VRID 1.
<H3C> display rpr vrrp RprPos4/1/1 group 2
Group ID        : 2
Interface       : RprPos4/1/1
 Vlan ID         : 1000
 VRID            : 1
 Mate MAC        : 000f-e211-1b16
 State           : Master
 Local Pri       : 100            Remote Pri   : 100
# Display the information about VRRP collaboration group 2 in RPR logical interface RPRPOS 4/1/1 with disabled VRID 1.
<H3C> display rpr vrrp RprPos 4/1/1 group 2
Group ID        : 1
Interface       : RprPos 4/1/1
 Vlan ID         : 1000
 VRID            : 1
Table 3-1 Description on the fields of the display rpr vrrp command
Port of a collaboration group
Vlan ID
VLAN of a collaboration group
VRID
VRID of a collaboration group
Mate MAC
MAC address of the adjacent station
State of a port in a collaboration group
Local Pri
Local priority
Remote Pri
Remote priority
3.1.2  rpr vrrp
rpr vrrp vlan vlan-id vrid vrid-id [ mate h-h-h ] group group-id
View
vlan-id: ID of the VLAN to be bound. It ranges from 1 to 4094 and can be in any group with the allowed VLAN specifications.
vrid-id: VRRP VRID group to be bound. It ranges from 1 to 255 and can be in any group with the allowed VLAN specifications.
mate h-h-h: MAC address of the adjacent station. It indicates whether fast switching is required for the current collaboration group. If you select this argument, the system will compare the received attribute discovery (ATD) frame with the configured MAC address. If they match each other, the system will resolve the frame, and switch the collaboration group according to the priorities.
group-id: Group ID in the range of 1 to 2.
Use the rpr vrrp command to bind a VRRP VRID in a VLAN to an RPR logical interface, and specify whether fast switching is required.
When you configure a collaboration group, the system does not check whether the specified VLAN and VRID exist or not. A collaboration group takes effect only when the VLAN and VRID exist. The MAC address of the adjacent station needs to be configured by users. Based on the protocol frame of the matched MAC address, the collaboration group decides whether to perform fast switching. The system does not check whether the configured MAC address of the adjacent station is an address in the RPR. Instead, users must make appropriate configurations themselves. Each RPR logical interface can only be configured with two VRRP over RPR collaboration groups.
# Add a VRRP collaboration group to the RPR logical interface RPRPOS 4/1/1, binding VRID 20 in VLAN 10 to RPRPOS 4/1/1 (the MAC address of the adjacent station is 000F-E211-1B16).
<H3C> system-view
[H3C] interface RprPos 4/1/1
[H3C-RprPos 4/1/1] Rpr vrrp vrid 20 vlan 10 mate 000f-e211-1b16 group 1
undo rpr vrrp group group-id
View
group-id: VRRP VRID configured in a port, in the range 1 to 2.
Use the undo rpr vrrp group command to unbind a VRRP VRID in a VLAN from a group configured in an RPR logical interface.
To execute the command in RPR logical interface view, you only need to specify the port number and collaboration group number.
# Remove VRRP collaboration group 2 configured on the RPR logical interface RPRPOS 4/1/1.
<H3C> system-view
[H3C-RprPos4/1/1] undo rpr vrrp group 2
undo debugging rpr cross-ring event
View
None
Use the debugging rpr cross-ring event command to enable the debugging for events of intersecting RPR rings.
Use the undo debugging rpr cross-ring event command to disable the debugging.
By default, the debugging is disabled.
After you execute the debugging rpr all/undo debugging rpr all command, the debugging for events of intersecting RPR rings is enabled/disabled.
# Enable the debugging for events of intersecting RPR rings.
<H3C> debugging rpr cross-ring event
debugging rpr cross-ring packet { all | nsn | nrc | psc | flushmac }
undo debugging rpr cross-ring packet { all | nsn | nrc | psc | flushmac }
View
all: Debugging for all protocol packets of intersecting RPR rings.
nsn: Debugging for notifications of intersecting RPR stations.
nrc: Debugging for role change notifications.
psc: Debugging for notifications of the intersecting port state changes.
flushmac: Debugging for flushmac packets of intersecting RPR rings.
Use the debugging rpr cross-ring packet command to enable debugging for all protocol packets of intersecting RPR rings.
Use the undo debugging rpr cross-ring packet command to disable the debugging.
After you execute the debugging rpr all/undo debugging rpr all command, the debugging for protocol packets of intersecting RPR rings is enabled/disabled.
# Enable debugging for all protocol packets of intersecting RPR rings.
<H3C> debugging rpr cross-ring packet all
View
None
Use the display rpr cross-ring backup-ring command to display the information about the backup rings of the intersecting RPR rings.
Example
# Display information about the backup ring of the intersecting RPR rings.
<H3C> display rpr cross-ring backup-ring
 Instance        backup-ring        status
    0            RprPos3/1/1        inactive
    1            RprPos3/1/1        inactive
    2            RprPos3/1/1        inactive
    3            Not configure      inactive
    4            Not configure      inactive
    5            RprPos3/1/1        active
Table 4-1 Description on the fields of the display rpr cross-ring backup-ring command
Instance
Intersecting ring instance
backup-ring
Backup ring of the instance
status
Status of the slave ring
4.1.4  display rpr cross-ring defect
View
None
Use the display rpr cross-ring defect command to display defects of intersecting RPR rings.
# Display defects of intersecting RPR rings.
<H3C> display rpr cross-ring defect
Inconsistent number of slave rings: false
 Instance: 0
  Inconsistent instance mapping configuration: false
  Inconsistent instance role configuration: true
Table 4-2 Description on the fields of the display rpr cross-ring defect command
Inconsistent mapping of intersecting ring instances to STP instances
Inconsistent intersecting ring role configuration
false
Configuration consistent
true
Configuration inconsistent
4.1.5  display rpr cross-ring instance
display rpr cross-ring instance { instance-id | all }
View
instance-id: Specifies an instance ID ranging from 0 to 5.
all: Specifies all instances.
Use the display rpr cross-ring instance command to display the basic configuration and instance information of the specified intersecting ring instance or all intersecting ring instances.
# Display information about all intersecting ring instances in the intersecting ring group.
<H3C> display rpr cross-ring instance all
 INS: Cross-ring Instance           STP-INS: STP Instance
 C-R: Configure Instance Role       A-R: Active Instance Role
 L-T(S): Local track port(status)   N-T-S: Neighbor track port status
 P: Primary Role                    S: Secondary Role
 I: Init Role                       N: Invalid Role
 Neighbor: 000f-e200-fff4
 Master-ring: RprPos9/1/1
 Slave-ring: RprPos7/1/1
 Neighbor reachable: Unreachable
 INS  C-R  A-R  STP-INS  L-T(S)                       N-T-S
 0    P    P    1        Not configure                DOWN
 1    S    P    2        Not configure                DOWN
 2    S    P    3        Not configure                DOWN
 3    S    P    4        Not configure                DOWN
 4    S    P    5        Not configure                DOWN
 5    S    P    6        GigabitEthernet3/2/1 (UP)    DOWN
Table 4-3 Description on the fields of the display rpr cross-ring instance command
neighbour
MAC address of the neighbor in the intersecting ring group
master-ring
Maser ring
slave-ring
Slave ring
INS
Intersecting ring instance number
C-R
Configured role
A-R
Actual role
STP-INS
Number of the corresponding MSTP instance
L-T(S)
Upstream port bound with the instance and the port state
N-T-S
State of the upstream port bound with the neighbor
4.1.6  rpr cross-ring
rpr cross-ring { master | slave }
undo rpr cross-ring
View
master: Specifies the interface as the master ring in the intersecting ring group.
slave: Specifies the interface as the slave ring in the intersecting ring group.
Use the rpr cross-ring command to specify the role of the RPR logical interface as master or slave in the intersecting ring group.
Use the undo rpr cross-ring command to restore the default.
By default, an RPR logical interface is not configured as the master ring or a slave ring.
Note that an RPR logical interface cannot be configured as both the master ring and a slave ring at the same time.
# Specify the RPR logical interface RPRPOS 0/1/1 as the master ring.
<H3C> system-view
[H3C] interface RprPos0/1/1
[H3C-RprPos0/1/1] rpr cross-ring master
4.1.7  rpr cross-ring instance
rpr cross-ring instance instance-id { primary | secondary } stp-instance stp-instance-id
rpr cross-ring instance instance-id track interface-type interface-number
undo rpr cross-ring instance instance-id [ track ]
View
primary: Specifies the device as the primary device.
secondary: Specifies the device as the secondary device.
instance-id: Intersecting ring instance ID, ranging from 0 to 5.
stp-instance-id: MSTP instance ID, ranging from 1 to 48. Specifying this argument associates the VLANs mapped to the MSTP instance with the intersecting ring instance.
track interface-type interface-number: Specifies the Ethernet interface as the collaboration port of the intersecting ring instance.
Use the rpr cross-ring instance command to associate an intersecting ring instance with an MSTP instance, specify the current device as the primary or secondary of the intersecting ring instance, and specify a collaboration port for the intersecting ring instance.
Use the undo rpr cross-ring instance command to remove the configuration.
# Associate intersecting ring instance 1 with MSTP instance 48, and specify the current device as the master device of intersecting ring instance 1.
<H3C> system-view
[H3C] rpr cross-ring instance 1 primary stp-instance 48
4.1.8  rpr cross-ring neighbour
rpr cross-ring neighbour mac-address
undo rpr cross-ring neighbour
View
mac-address: MAC address of the current device’s neighbor in the intersecting ring group. The mac-address argument is in the format of H-H-H and cannot be all 0s, multicast MAC address, or broadcast MAC address.
Use the rpr cross-ring neighbour command to specify a neighbor for the current device in the intersecting ring group. The neighbor is uniquely identified by the specified MAC address. Only one neighbor can be configured for the current device.
Use the undo rpr cross-ring neighbour command to remove the configuration.
# Specify the device with the MAC address 000F-E25A-D720 as the neighbor of the current device.
<H3C> system-view
[H3C] rpr cross-ring neighbour 000f-e25a-d720
4.1.9  rpr cross-ring slave backup-ring
rpr cross-ring slave backup-ring instance instance-id1 [ to instance-id2 ]
undo rpr cross-ring slave backup-ring instance instance-id1 [ to instance-id2 ]
View
instance instance-id1: Instance ID of the backup ring, ranging from 0 to 5.
to instance-id2: Specifies an instance ID range together with the parameter instance instance-id1. The value of instance instance-id2 must be greater than that of the instance instance-id1.
Use the rpr cross-ring slave backup-ring command to configure the backup ring for the specified intersecting ring instance(s).
Use the undo rpr cross-ring slave backup-ring command to remove the configuration.
Note that:
l           The rpr cross-ring slave backup-ring command also specifies the RPR logical interface as the slave ring of the intersecting rings.
l           The undo rpr cross-ring slave backup-ring command does not remove the slave ring configuration.
Example
# Configure the link where RPR interface RPRPOS 3/1/1 resides as the backup ring of intersecting ring instance 5.
<H3C> system-view
[H3C-RprPos3/1/1] rpr cross-ring slave backup-ring instance 5
Chapter 5  Distributed RPR Configuration Commands
5.1  Distributed RPR Configuration Commands
5.1.1  debugging rpr backup
debugging rpr backup { debug | error | event }
undo debugging rpr backup { debug | error | event }
View
debug: Debugging for distributed RPR.
error: Debugging for distributed RPR errors.
event: Debugging for distributed RPR events.
Use the debugging rpr backup command to enable debugging for distributed RPR.
Use the undo debugging rpr backup command to disable the debugging.
After you execute the debugging rpr all/undo debugging rpr all command, the debugging for distributed RPR is enabled/disabled.
# Enable debugging for distributed RPR errors.
<H3C> debugging rpr backup error
5.1.2  display rpr link-aggregation
display rpr link-aggregation [ group agg-id ]
View
group agg-id: Specifies an aggregation group by its ID, ranging from 1 to 31. The group ID ranges from 1 to 7 if a C-type board is used. If the keyword is not specified, the command displays information about all distributed RPR aggregation groups.
Use the display rpr link-aggregation command to display information about the specified or all distributed RPR aggregation group(s).
# Display information about all the distributed RPR aggregation groups.
<H3C> display rpr link-aggregation
 RPR Link-Aggregation Group 1
 Role    Port            Port-Mode       Link-Status
 Master  RprPos7/1/1     -               Up
         RprPos7/1/1.1   Normal          Up
         RprPos7/1/1.2   Normal          Up
 Slave   RprPos9/1/1     -               Up
         RprPos9/1/1.1   Normal          Up
         RprPos9/1/1.2   Normal          Up
Table 5-1 Description on the fields of the display rpr link-aggregation command
Role
Role of the RPR logical interface in the distributed RPR
Port
RPR port in the distributed RPR aggregation group
Port-Mode
Port state of the RPR physical port
Link-Status
Link state of the RPR port
5.1.3  link-aggregation group mode manual
link-aggregation group agg-id mode manual
undo link-aggregation group agg-id
View
agg-id: ID of the aggregation group, ranging from 1 to 31. The group ID ranges from 1 to 7 if a C-type board is used. Only manual aggregation group can be used for distributed RPR.
Use the link-aggregation group mode manual command to create a manual aggregation group for distributed RPR.
Use the undo link-aggregation group command to remove the specified aggregation group.
Related commands: display rpr link-aggregation.
&  Note:
The manual aggregation group configuration aggregates two RPR logical interfaces, implementing board-level protection for distributed RPR.
# Create manual aggregation group 1 for distributed RPR.
<H3C> system-view
[H3C] link-aggregation group 1 mode manual
5.1.4  port link-aggregation group
port link-aggregation group agg-id
undo port link-aggregation group
View
agg-id: ID of an aggregation group, ranging from 1 to 31. The group ID ranges from 1 to 7 if a C-type board is used. At present only RPR logical interfaces can be added to a manual aggregation group.
Use the port link-aggregation group command to add the RPR logical interface to the specified manual aggregation group.
Use the undo port link-aggregation group command to remove the RPR logical interface from the specified manual aggregation group.
Note that after you assign the RPR logical interface to the aggregation group, the ARP information of the interface will be erased.
# Add the RPR logical interface RPRPOS 2/1/1 to aggregation group 1.
<H3C> system-view
[H3C-RprPos2/1/1] port link-aggregation group 1
5.1.5  port-mode mate
port-mode mate
undo port-mode
View
None
Use the port-mode mate command to specify the RPR physical port as a mate port.
Use the undo port-mode command to remove the configuration.
By default, no mate port is configured.
# Specify the RPR physical port RPRPOS 2/1/1.2 as a mate port.
<H3C> system-view
[H3C] interface RprPos 2/1/1.2
[H3C-RprPos2/1/1.2] port-mode mate
