H3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
15-HVRP Commands
15-HVRP Commands 43.17 KB
Chapter 1  HVRP Configuration Commands
1.1  HVRP Configuration Commands
1.1.1  debugging hvrp error
undo debugging hvrp error
View
None
Use the debugging hvrp error command to enable HVRP error debugging.
Use the undo debugging hvrp error command to disable HVRP error debugging.
By default, HVRP error debugging is disabled.
# Enable HVRP error debugging.
<H3C> debugging hvrp error
1.1.2  debugging hvrp info
debugging hvrp info
undo debugging hvrp info
View
None
Use the debugging hvrp info command to enable HVRP VLAN debugging function.
Use the undo debugging hvrp info command to disable HVRP VLAN debugging function.
By default, HVRP VLAN debugging function is disabled.
# Enable HVRP VLAN debugging function.
<H3C> debugging hvrp info
1.1.3  display hvrp brief
display hvrp brief
View
None
Use the display hvrp brief command to display HVRP status.
# Display HVRP status.
<H3C> display hvrp brief
HVRP is enabled globally.
1.1.4  display hvrp local-vlan
View
None
Use the display hvrp local-vlan command to display local VLAN information.
# Display local VLAN information.
<H3C> display hvrp local-vlan
Now, the following VLAN exist(s):
1(default), 97-100
1.1.5  display hvrp port-vlan
display hvrp port-vlan interface-type interface-num
View
interface-type: Port type, can be Ethernet or GigabitEthernet.
interface-num: Port number, in the form of ‘’service board slot number/card slot number/port number”
l           Service board slot number represents the slot number of the service board for a specified port, with S9505 ranging from 2 to 6, S9512 from 0 to 13, and S9508 from 0 to 3, 6 to 9.
l           Card slot number indicates the card slot number of a specific port, in the range of 1 to 3.
l           Port number specifies the card slot number of a given port. Depending on the actual port number of the card, it can be 1, or in the range of 1 to 2, 1 to 4, 1 to 10, 1 to 20, 1 to 24, 1 to 32, 1 to 48.
Use the display hvrp port-vlan command to display all interconnected VLANs for a given port.
# Display all interconnected VLANs for a given port.
<H3C> display hvrp port-vlan ethernet 6/1/18
2-5, 9-10, 99
1.1.6  display hvrp verbose
View
None
Use the display hvrp verbose command to display detailed HVRP information.
# Display detailed HVRP information.
<H3C> display hvrp verbose
 HVRP registervlan timer       : 5s
 HVRP registervlan age interval   : 15s
 HVRP age all VLAN             : Enabled
    HVRP statistics on port GigabitEthernet5/1/1 (PORT_LINK_UP)
    Mstp role            :
                 1 - designated
                 2 - designated
                 3 - designated
                 4 - designated
                 5 - designated
                 6 – designated
1.1.7  hvrp enable
hvrp enable
undo hvrp enable
View
System view or Ethernet port view
None.
Use the hvrp enable command to enable HVRP globally (in system view), or enable HVRP on an Ethernet port (in Ethernet port view).
Use the undo hvrp enable command to disable HVRP globally (in system view), or disable HVRP on an Ethernet port (in Ethernet port view).
By default, HVRP is disabled both globally and on Ethernet ports.
Be aware of the following aspects while configuring HVRP:
l           HVRP-enabled ports must be Trunk ports;
l           It is recommended to remove HVRP-enabled ports from VLAN 1
l           Only after HVRP has been enabled globally can HVRP be enabled on an Ethernet port.
l           Globally disabling HVRP will simultaneously disable HVRP on all ports.
l           Disabling HVRP on a port will automatically disable the other HVRP-related configurations on the port, such as timer configuration.
l           HVRP must be used together with STP/MSTP. Before HVRP is enabled, you must enable STP/MSTP. After you enable HVRP, it is not allowed to disable STP/MSTP.
l           After you enable HVRP, the system will dynamically set the mode in which a VLAN learns MAC addresses. Thus, you need not manually configure the number of MAC addresses that can be learned by the VLAN.
l           HVRP configuration cannot be copied between ports.
l           HVRP and GVRP are mutually exclusive.
l           XP4-type boards (except XP4L boards) do not support HVRP.
# Enable HVRP globally.
<H3C> system-view
[H3C] hvrp enable
# Enable HVRP for port Ethernet 2/1/1.
<H3C>system-view
[H3C] interface Ethernet 2/1/1
[H3C-Ethernet2/1/1] hvrp enable
1.1.8  hvrp permanent-vlan
hvrp permanent-vlan vlan-id [ to vlan-id ]
undo hvrp permanent-vlan [ vlan-id [ to vlan-id ] ]
View
vlan-id: VLAN ID, in the range of 1 to 4094.
Use the hvrp permanent-vlan command to configure a permanent VLAN or a group of permanent VLANs.
Use the undo hvrp permanent-vlan command to remove the permanent attribute of a VLAN or a group of VLANs.
No VLAN is configured as a permanent VLAN by default.
Except permanent VLANs, VLANs on HVRP ports may be aged out. Permanent VLANs will never be aged out.
You can configure the permanent property of a VLAN only after the specified VLAN is created.
# Configure VLAN 112 through VLAN 120 as permanent VLANs.
<H3C> system-view
[H3C] hvrp permanent-vlan 112 to 120
1.1.9  hvrp timer
hvrp timer { registervlan | registervlan-age } timer-num
undo hvrp timer { registervlan | registervlan-age }
View
registervlan: Specifies VLAN registration timer.
registervlan-age: Specifies registered-VLAN aging interval.
timer-num: VLAN registration interval or registered-VLAN aging time, in seconds.
Use the hvrp timer registervlan command to configure the VLAN registration timer for HVRP.
Use the undo hvrp timer registervlan command to restore the default VLAN registration time.
Use the hvrp timer registervlan-age command to configure the registered-VLAN aging interval for HVRP.
Use the undo hvrp timer registervlan-age command to restore the default registered-VLAN aging interval.
By default, the VLAN registration time is 5 seconds and the registered-VLAN aging interval is 15 seconds.
&  Note:
The hvrp timer registervlan-age command is used to configure the registered-VLAN aging interval. The VLAN registration timer is within the range below: not less than the registered-VLAN aging interval, but less than twice the registered-VLAN aging interval.
# Set the registered-VLAN aging interval to 5 seconds.
<H3C> system-view
[H3C]hvrp timer registervlan-age 5
1.1.10  hvrp vlan-age all
hvrp vlan-age all
undo hvrp vlan-age all
View
None
Use the hvrp vlan-age all command to allow the switch to age all VLANs.
Use the undo hvrp vlan-age all command to allow the switch to age only Local VLANs.
By default, only Local VLANs are allowed to be aged.
  Caution:
For single ring networks and multiple ring networks, you are recommended to use the default configuration that ages only the local VLANs. A switch located on the intersection point of the intersected rings must be configured to age all the VLANs.
# Allow the system to age all VLANs.
<H3C> system-view
[H3C] hvrp vlan-age all
