H3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
13-MSTP Commands
13-MSTP Commands 186.42 KB
Table of Contents
Chapter 1 MSTP Configuration Commands. 1-1
1.1 MSTP Configuration Commands. 1-1
1.1.1 active region-configuration. 1-1
1.1.2 check region-configuration. 1-2
1.1.3 debugging stp. 1-3
1.1.4 display stp. 1-5
1.1.5 display stp region-configuration. 1-7
1.1.6 display stp tc. 1-8
1.1.7 instance. 1-9
1.1.8 region-name. 1-10
1.1.9 reset stp. 1-11
1.1.10 revision-level 1-12
1.1.11 stp. 1-12
1.1.12 stp bpdu-protection. 1-14
1.1.13 stp bridge-diameter 1-15
1.1.14 stp compliance. 1-16
1.1.15 stp config-digest-snooping. 1-17
1.1.16 stp cost 1-18
1.1.17 stp edged-port 1-19
1.1.18 stp instance root 1-21
1.1.19 stp interface. 1-22
1.1.20 stp interface edged-port 1-23
1.1.21 stp interface instance cost 1-25
1.1.22 stp interface instance port priority. 1-26
1.1.23 stp interface loop-protection. 1-27
1.1.24 stp interface mcheck. 1-28
1.1.25 stp interface no-agreement-check. 1-29
1.1.26 stp interface point-to-point 1-30
1.1.27 stp interface root-protection. 1-31
1.1.28 stp interface transmit-limit 1-32
1.1.29 stp loop-detection. 1-33
1.1.30 stp loop-protection. 1-34
1.1.31 stp max-hops. 1-35
1.1.32 stp mcheck. 1-36
1.1.33 stp mode. 1-37
1.1.34 stp no-agreement-check. 1-37
1.1.35 stp non-flooding. 1-38
1.1.36 stp pathcost-standard. 1-39
1.1.37 stp point-to-point 1-40
1.1.38 stp port priority. 1-41
1.1.39 stp priority. 1-42
1.1.40 stp region-configuration. 1-43
1.1.41 stp reset-arp. 1-43
1.1.42 stp root-protection. 1-44
1.1.43 stp tc-protection. 1-45
1.1.44 stp timer forward-delay. 1-46
1.1.45 stp timer hello. 1-47
1.1.46 stp timer max-age. 1-48
1.1.47 stp timer-factor 1-49
1.1.48 stp transmit-limit 1-50
1.1.49 vlan-mapping modulo. 1-51
View
MST region view
None
Use the active region-configuration command to activate the configurations of MST region.
This command is used for manually activate the configurations of MST region. Configuring the related parameters, especially the VLAN mapping table, of the MST region, will lead to the recalculation of spanning tree and network topology flapping. To bate such flapping, MSTP applies the configured parameters and launches recalculation of the spanning tree only when you activate the configured MST region parameters or enable MSTP.
After you entered this command, MSTP will apply the MST region parameters you have configured to the system and recalculate the spanning tree.
&  Note:
Before you activate the MST region configuration, make sure the PVID of an STP-enabled port is the VLAN ID of the port as a trunk port. Otherwise, error may occur in spanning tree calculation.
Related commands: instance, region-name, revision-level, vlan-mapping modulo, check region-configuration.
# Manually activate MST region configurations.
<H3C> system-view
[H3C] stp region-configuration
[H3C-mst-region] active region-configuration
View
MST region view
None
Use the check region-configuration command to view the configuration information, including switch region name, revision level, and VLAN mapping table, regardless whether the configurations are active or not.
MSTP defines that the user must ensure the correct region configurations, especially the VLAN mapping table configuration. The switches can be configured in the same region only if their region names, VLAN mapping tables, and MSTP revision levels are configured exactly the same. The switch may not be configured in the expected region due to any slight deviation. You can use this command to check if the MST region configurations are correct.
Related commands: instance, region-name, revision-level, vlan-mapping modulo, active region-configuration.
# View the latest configuration information about the region.
<H3C> system-view
[H3C-mst-region] check region-configuration
Admin. Configuration
   Format selector :0
   Region name     :00b010000001
   Revision level  :0
   Instance   Vlans Mapped
      0       1 to 9, 11 to 4094
     16       10
Table 1-1 Description on the fields of the check region-configuration command
Format selector
The selector defined by MSTP
Region name
Region name of MST region
Revision level
Revision level of MST region
VLAN mapping table of MST region
1.1.3  debugging stp
debugging stp { global-error | global-event | all | event [ flush | packetdrop | port ] | instance instance-id | lacp-key | packet | state-machine [ [ { pim | prs | prt | pst | tcm } [ instance instance-id ] ] | [ ppm | ptx | tcpm] ] | interface interface-type interface-number { lacp-key | packet | event } }
undo debugging stp { global-error | global-event | all | event [ flush | packetdrop | port ] | instance instance-id | lacp-key | packet | state-machine [ [ { pim | prs | prt | pst | tcm } [ instance instance-id ] ] | [ ppm | ptx | tcpm ] ] | interface interface-type interface-number { lacp-key | packet | event } }
View
None
Use the debugging stp { global-error | global-event } command to enable STP global error or event debugging.
Use the undo debugging stp { global-error | global-event } command to disable STP global error or event debugging.
Use the debugging stp all command to enable global debugging.
Use the undo debugging stp all command to disable global debugging.
Use the debugging stp event command to enable event debugging of MSTP.
Use the undo debugging stp event to disable event debugging of MSTP.
Use the debugging stp packet command to enable packet debugging of MSTP.
Use the undo debugging stp packet command to disable packet debugging of MSTP.
Use the debugging stp instance instance-id command to enable specified instance debugging of MSTP.
Use the undo debugging stp instance instance-id command to disable specified instance debugging of MSTP.
Use the debugging stp lacp-key command to enable MD5 summary information debugging of LACP protocol.
Use the undo debugging stp lacp-key command to disable MD5 summary information debugging of LACP protocol.
Use the debugging stp state-machine command to enable debugging of the state machine.
Use the undo debugging stp state-machine command to disable debugging of the state machine.
Use the debugging stp state-machine pim command to enable debugging of the port information state machine.
Use the undo debugging stp state-machine pim command to disable debugging of the port information state machine.
Use the debugging stp state-machine prs command to enable debugging of the state machine for port role selection. Use the undo debugging stp state-machine prs command to disable debugging of the state machine for port role selection.
Use the debugging stp state-machine prt command to enable debugging of the state machine for port role transition.
Use the undo debugging stp state-machine prt command to disable debugging of the state machine for port role transition.
Use the debugging stp state-machine pst command to enable debugging of the state machine for port state transition.
Use the undo debugging stp state-machine pst command to disable debugging of the state machine for port state transition.
Use the debugging stp state-machine tcm command to enable debugging of the topology change state machine.
Use the undo debugging stp state-machine tcm command to disable debugging of the topology change state machine.
Use the debugging stp state-machine ppm command to enable debugging of the state machine for port protocol transition. Use the undo debugging stp state-machine ppm command to disable debugging of the state machine for port protocol transition.
Use the debugging stp state-machine ptx command to enable debugging of the port transport state machine.
Use the undo debugging stp state-machine ptx command to disable debugging of the port transport state machine.
Use the debugging stp state-machine tcpm command to enable debugging of the state machine for topology change protection. Use the undo debugging stp state-machine tcpm command to disable debugging of the state machine for topology change protection.
Use the debugging stp interface interface-type interface-number { lacp-key | packet | event } command to enable specified port debugging of MSTP.
Use the undo debugging stp interface interface-type interface-number { lacp-key | packet | event } command to disable specified port debugging of MSTP.
# Enable STP global event debugging.
<H3C>debugging stp global-event
1.1.4  display stp
display stp [ instance instance-id ] [ interface interface-list | slot slot-num ] [ brief ]
View
instance instance-id: Specifies the spanning tree instance ID, ranging from 0 to 48. Instance 0 represents CIST.
interface interface-list: Ethernet port list, containing multiple Ethernet ports and expressed as interface-list = { { interface-type interface-number | interface-name } [ to { interface-type interface-number | interface-name } ] }&<1-10>. For details about the interface-type and interface-number arguments, refer to the interface command in Ethernet Port Configuration Commands. &<1-10> means that you can specify up to 10 ports or port ranges.
slot slot-num: Displays STP information about a specified slot.
brief: Displays only port state, port protection type and port role in the corresponding instance.
Use the display stp command to view the state information and statistics information of the spanning tree.
The MSTP state and statistics information can help analyze and maintain the network topology and maintain the normal operation of MSTP.
If no spanning tree instance ID or port list is specified, the command will display the spanning tree information of all the instances on all the ports in port number order. If the instance ID is specified, the command will display the spanning tree information of the specified instance on all the port in port number order. If only the port list is specified, the command will display the information about all the MSTIs on the port in port number order. If both instance ID and port list are specified, the command will display the spanning tree information of the specified instance and port according to the port list of the instance ID.
If there is an aggregation port, the command will only display the instance information on the master port.
MSTP state information includes:
1)         Global CIST parameter: Protocol operation mode, switch priority in the CIST instance, MAC address, Hello Time, Max Age, Forward Delay, Max Hops, CIST common root, external path cost of the switch to the CIST common root, region root, internal path cost of the switch to the region root, CIST root port of the switch, and whether to enable BPDU protection; Number of received TC/TCN packets, time interval for receiving packets. If you specify the relationship between a master root and one or multiple slave roots, the global CIST parameters can also be displayed in CIST Root Type.
2)         CIST port parameter: Port state, role, priority, path cost, path cost standard designated bridge, designated port, edge port/non-edge port, whether connected to the point-to-point link, port transit limit, whether to enable Root protection, whether being a region edge port, Hello Time, Max Age, Forward Delay, Message-age time, and Remaining-hops; Num of VLANs Mapped, number of sent BPDU packets, and number of received BPDU packets.
3)         Global MSTIs parameter: MSTI instance ID, bridge priority of the instance, region root, internal path cost, MSTI root port, MASTER bridge, path cost to region root and number of the received TC packets. If you specify the relationship between master roots and slave roots in an instance, the global MSTI parameters can also be displayed in MSTI Root Type.
4)         MSTIs port parameter: Port state, role, priority, path cost, path cost standard, designated bridge, designated port, and remaining hops. You can view Num of VLANs Mapped in port view.
Statistics information: Count of TCN, CONFIG BPDU, RST, and MST BPDU transmitted/received via the port.
Related commands: reset stp.
# Display the state and statistics information about the spanning tree.
<H3C> display stp instance 0 interface Ethernet 2/1/1 to Ethernet 2/1/4    GigabitEthernet 3/2/1 to GigabitEthernet 3/2/4 GigabitEthernet 3/3/1 brief
  MSTID      Port                  Role  STP State     Protection
   0        Ethernet2/1/1         ALTE  DISCARDING      LOOP
   0        Ethernet2/1/2         DESI  FORWARDING      NONE
   0        Ethernet2/1/3         DESI  FORWARDING      NONE
   0        Ethernet2/1/4         DESI  FORWARDING      NONE
   0        GigabitEthernet3/2/1  DESI  FORWARDING      NONE
   0        GigabitEthernet3/2/2  DESI  FORWARDING      NONE
   0        GigabitEthernet3/2/3  DESI  FORWARDING      NONE
   0        GigabitEthernet3/2/4  DESI  FORWARDING      NONE
   0        GigabitEthernet3/3/1  ROOT  FORWARDING      NONE
Table 1-2 Description on the fields of the display stp command
MSTID
MST instance ID in a MST region
Port
Port number, corresponding to the related MST instance
Role
Role of the port
STP State
Port STP state, including enabled status and disabled status, and also monitoring and learning status during transition
Protection
Protection type on the port
View
None
Use the display stp region-configuration command to view the effective MST region configurations.
MST region configuration information includes: region name, region revision level, and associations between VLANs and MSTIs. All these configurations together determine to which MST region a switch belongs.
Related commands: stp region-configuration.
# Display the MST region configuration information.
<H3C> display stp region-configuration
Oper Configuration
   Format selector :0
   Region name     :H3C
   Revision level  :0
      0       21 to 4094
      1       1 to 10
      2       11 to 20
Table 1-3 Description on the fields of the display stp region-configuration command
Format selector
Selector defined by MSTP
Region name
Revision level
display stp [ instance instanceid ] tc { all | detected | received | sent }
View
instance instanceid: Instance to be displayed. By default, TC (Topology Change) statistics of all the instances will be displayed.
detected: TC statistics detected by the bridge.
received: TC statistics received at the bridge.
sent: TC statistics sent from the bridge.
all: All TC statistics, including those detected, received and sent by the bridge.
Use the display stp tc command to view TC (transaction capabilities) statistics.
# Display all TC statistics.
<H3C> dis stp tc all
 ---------- Stp Instance 0 tc or tcn received count ----------
 Port Ethernet3/1/1              0
 Port Ethernet3/1/9              1
 ---------- Stp Instance 0 tc or tcn detected count ----------
 Port Ethernet3/1/1              1
 Port Ethernet3/1/9              0
 ---------- Stp Instance 0 tc or tcn sent count ----------
&  Note:
The topology changes and notification information of Instance 0 will be recorded in the log.
1.1.7  instance
instance instance-id vlan vlan-list
undo instance instance-id [ vlan vlan-list ]
View
MST region view
instance-id: Specifies the spanning tree instance ID, ranging from 0 to 48. The value 0 indicates a CIST.
vlan vlan-list: Specifies the VLAN list, ranging from 1 to 4094. vlan-list = { vlan-id [ to vlan-id ] }&<1-10>. Where, &<1-10> represents that you can specify up to 10 VLAN IDs or VLAN ID ranges.
Use the instance command to map the specified VLAN list to the specified MSTI.
Use the undo instance command to cancel the specified VLAN list from the specified MSTI, and the removed VLAN will then be mapped to the CIST (i.e., the Instance 0). If no VLAN is specified in the undo command, all the VLANs associated with the specified MSTI will be mapped to CIST.
By default, all the VLANs are mapped to CIST, i.e., the Instance 0.
MSTP describes the association between VLANs and MSTIs with the VLAN mapping table. You can use this command to configure this table. Every VLAN can be mapped to an MSTI as per your configuration.
You cannot map one VLAN to different instances, while you can map multiple VLANs to one instance. When you remap the mapped VLAN to a different instance, the original mapping relation is removed automatically. The mapping relationship of VLANs and instances in the same MSTP domain must be correct. The data will be transmitted according to the spanning tree topology structure of the instance the VLAN maps to.
Related commands: region-name, revision-level, check region-configuration, vlan-mapping modulo, active region-configuration.
# Map VLAN 2 to MSTI 1.
<H3C> system-view
[H3C]stp region-configuration
[H3C-mst-region] instance 1 vlan 2
# Map VLAN5-10 to MSTI 3.
[H3C-mst-region] instance 3 vlan 5 6 7 8 9 10
1.1.8  region-name
region-name name
undo region-name
View
MST region view
name: Specifies the MST region name of the switch with a character string not exceeding 32 bytes.
Use the region-name command to configure the MST region name of a switch.
Use the undo region-name command to restore the default MST region name.
By default, the MST region name of the switch is the switch MAC address in hexadecimal notation.
The switch region name, together with VLAN mapping table of the MST region and MSTP revision level, is used for determining the region to which the switch belongs.
Related commands: instance, revision-level, check region-configuration, vlan-mapping modulo, active region-configuration.
# Set the MST region name of the switch as abcde.
<H3C> system-view
[H3C-mst-region] region-name abcde
1.1.9  reset stp
reset stp [ interface interface-list ]
View
interface interface-list: Ethernet port list, containing multiple Ethernet ports and expressed as interface-list = { interface-type interface-number [ to { interface-type interface-number] }&<1-10>. For details about the interface-type and interface-number arguments, refer to the interface command in Ethernet Port Configuration Commands. &<1-10> means that you can specify up to 10 ports or port ranges.
Use the reset stp command to reset the spanning tree statistics information.
The spanning tree statistics information includes TCN, Config BPDU, RST, and MST BPDU, received and transmitted on the port. Among them, STP BPDU and TCN BPDU are counted on CIST.
If you specify a port list, the command clears the spanning tree statistics information of the specified port. If you do not specify any port, the command clears the spanning tree statistics information of all ports.
Related commands: display stp.
# Clear the statistics information on the ports from Ethernet 2/1/1 through Ethernet 2/1/3
<H3C> reset stp interface Ethernet 2/1/1 to Ethernet 2/1/3
revision-level level
undo revision-level
View
MST region view
level: Specifies the MSTP revision level, ranging from 0 to 65535. By default, MSTP revision level takes 0.
Use the revision-level command to configure MSTP revision level of the switch.
Use the undo revision-level command to restore the default revision level.
MSTP revision level, together with region name and VLAN mapping table, is used for determining the MST region to which the switch belongs.
Related commands: instance, region-name, check region-configuration, vlan-mapping modulo and active region-configuration.
# Set the MSTP revision level of the switch MST region to 5.
<H3C> system-view
[H3C-mst-region] revision-level 5
1.1.11  stp
stp { enable | disable }
undo stp
View
System view, Ethernet port view
enable: Enables global or port MSTP.
disable: Disables global or port MSTP.
Use the stp command to enable or disable MSTP on a device or a port.
Use the undo stp command to restore the default MSTP state on a device or a port.
By default, MSTP is disabled globally but enabled on individual ports. The MSTP feature takes effect on a port only after you enable MSTP both globally and on the port.
After MSTP is enabled, the switch determines to run MSTP in STP-compatible mode or MSTP mode according to your configurations. The switch serves as a transparent bridge after MSTP is disabled.
After MSTP is enabled, it will dynamically maintain the spanning tree state of the corresponding VLAN according to the received configuration BPDU until it is disabled. After MSTP is disabled, it will not maintain the state.
After you enable MSTP globally, the system automatically runs the stp non-flooding command and drops BPDU packets entering ports not enabled with MSTP. To avoid dropping BPDU packets, you can use the undo stp non-flooding command.
After you disable MSTP globally (regardless of whether MSTP is enabled or disabled on individual ports), the system automatically runs the undo stp non-flooding command, and BPDU packets are forwarded as common multicast packets.
&  Note:
l      When enabling the STP function for a port, make sure the PVID of the port is the VLAN ID of the port as a trunk port. Otherwise, error may occur in spanning tree calculation.
l      STP is mutually exclusive with the smart link function. If STP is not disabled on a member port of a smart link group, STP cannot be enabled globally.
l      Executing the undo stp command or the stp disable command on a port that does not support STP (such as an ATM port or a POS port) disables STP globally. So, use these two commands with caution on ports of this kind.
Related commands: stp mode, stp interface.
# Enable MSTP globally.
<H3C> system-view
[H3C] stp enable
# Disable MSTP on Ethernet 2/1/1
<H3C> system-view
[H3C] interface Ethernet 2/1/1
[H3C-Ethernet2/1/1] stp disable
stp bpdu-protection
undo stp bpdu-protection
View
None
Use the stp bpdu-protection command to enable the BPDU protection on the switch. Use the undo stp bpdu-protection command to restore the default state of BPDU protection.
By default, BPDU protection is disabled.
Generally, the access ports of the access layer devices are directly connected to user terminals (such as PC) or file servers. In this case, the access ports are set to edge ports to implement fast state transition. However, when such access ports receive configuration BPDU, the system will automatically set them to non-edge ports and recalculate the spanning tree, which makes the network topology flap. These ports will not receive any STP configuration BPDU in normal cases. Anyway, if someone maliciously attacks the switch with fake configuration BPDU, the network will flap.
MSTP provides BPDU protection function to avoid such attack: After configured with BPDU protection, the switch will disable the edge port through MSTP, which receives a BPDU, and notify the network manager at same time. These ports can be resumed by the network manager only.
# Enable BPDU protection on the switch.
<H3C> system-view
[H3C] stp bpdu-protection
stp bridge-diameter bridgenum
undo stp bridge-diameter
View
bridgenum: Specifies the switching network diameter. It ranges from 2 to 7 and defaults to 7.
Use the stp bridge-diameter command to configure the switching network diameter. Use the undo stp bridge-diameter command to restore the default network diameter.
The definition of network diameter: Maximum count of switches between the farthest communication ends.
The stp bridge-diameter command configures the switching network diameter and determines the three time parameters of MSTP accordingly. This configuration takes effect on CIST only but makes no sense for MSTI.
The spanning tree convergence can be speeded up, when Hello Time, Forward Delay, and Max Age are well configured. These parameters are related to the network scale.
You can configure the network scale to get the time parameters. When users configure the bridge-diameter parameter of the switch, MSTP will automatically set Hello Time, Forward Delay, and Max Age to moderate values. When bridge-diameter defaults to 7, the time parameters also take their respective default values.
Related commands: stp timer forward-delay, stp timer hello, stp timer max-age.
&  Note:
The stp bridge-diameter command configures the switching network diameter and determines the three MSTP time parameters (Hello Time, Forward Delay, and Max Age) accordingly.
# Set the diameter of the switching network to 5.
<H3C> system-view
[H3C] stp bridge-diameter 5
stp compliance { legacy | dot1s | auto }
View
Ethernet port view
legacy: Indicates that the port sends and receives private MSTP packets.
dot1s: Indicates that the port sends and receives standard MSTP packets.
auto: Indicates the port has the auto-sensing function. The port can automatically adjust the format of the packet to be sent based on the format of the received packet.
Use the stp compliance command to set the format of the packets that the current port sends and receives. You can configure the format to legacy, dot1s, or auto.
By default, the port works in the auto mode.
# Set Ethernet 2/1/1 to the auto mode.
<H3C> system-view
[H3C] interface Ethernet2/1/1
[H3C-Ethernet2/1/1] stp compliance auto
undo stp config-digest-snooping
View
None
Use the stp config-digest-snooping command to enable digest snooping.
Use the undo stp config-digest-snooping command to disable digest snooping.
Digest snooping is disabled by default.
According to IEEE 802.1s, two interconnected switches can communicate with each other through multiple spanning tree instances (MSTIs) in a multiple spanning tree protocol (MSTP) domain only when they are configured with the same domain settings. With MSTP employed, interconnected switches determine whether or not they are in the same domain by checking the configuration IDs of the bridge protocol data units (BPDUs) between them. (A configuration ID comprises information such as domain ID, configuration digest.)
As switches of some manufacturers come with some private protocols concerning spanning trees, a switch of this type cannot communicate with other switches in an MSTP domain even if it is configured with the same domain settings as other switches in the MSTP domain.
This kind of problems can be overcome by implementing digest snooping. Digest snooping enables a switch to track and maintain configuration digests of other switches that are in the same domain and come from other manufacturers by examining their BPDUs. It also enables the switch to insert corresponding configuration digests in its BPDUs destined for these switches. In this way, switches of different manufacturers are capable of communicating with each other in an MSTP domain.
&  Note:
l      You must enable digest snooping on a port first before enabling it globally.
l      Digest snooping is unnecessary if the interconnected switches are from the same manufacturer.
l      When implementing digest snooping, make sure that the domain configurations of the switches of different manufacturers are exactly the same to prevent possible broadcast storm caused by otherwise inconsistent mapping relationships between VLANs and VPN instances of each switch.
l      To change the configuration of a domain with one or multiple of its switches being digest snooping-enabled, be sure to disable digest snooping on these switches first to prevent possible broadcast storm caused by otherwise inconsistent mapping relationships between VLANs and VPN instances of each switch.
l      To ensure interoperability, digest snooping must be enabled on all ports in an MSTP domain connecting to third-party switches within the same MSTP region.
l      Do not enable digest snooping on edge ports of an MSTP domain.
l      A digest snooping-enabled switch always keeps the latest configuration digests it receives. A configuration digest remains valid even if the corresponding port goes down.
# Enable digest snooping on GigabitEthernet 3/1/1.
<H3C> system-view
[H3C] interface GigabitEthernet3/1/1
[H3C-GigabitEthernet3/1/1] stp config-digest-snooping
[H3C-GigabitEthernet3/1/1] quit
[H3C] stp config-digest-snooping
1.1.16  stp cost
stp [ instance instance-id ] cost cost
undo stp [ instance instance-id ] cost
View
Ethernet port view
instance instance-id: Specifies the spanning tree instance ID, ranging from 0 to 48. The Instance 0 represents CIST.
cost: Port path cost. Its range depends on the selected standard of path cost.
Use the stp instance cost command to configure the port path cost on the specified MSTI for the current port.
Use the undo stp instance cost command to restore the path cost on the specified MSTI.
By default, switch calculates the path costs of a port on different MSTIs.
You may specify the instance-id parameter as 0 to configure CIST path cost of the port. The path cost has effect on the port role selection. A port can be configured with different path costs on different MSTIs. Thus the traffic from different VLANs can run over different physical links, thereby implementing the VLAN-based load-balancing. MSTP will recalculate the port role and transit its state, upon the port path cost changes.
Related commands: stp interface instance cost.
# Set the path cost of Ethernet 2/1/3 on MSTIs 2 to 200.
<H3C> system-view
[H3C] interface Ethernet 2/1/3
[H3C-Ethernet2/1/3] stp instance 2 cost 200
stp edged-port { enable | disable }
undo stp edged-port
View
Ethernet port view
enable: Configures the current port as an edge port.
disable: Configures the current port as a non-edge port.
Use the stp edged-port enable command to configure the current Ethernet port as an edge port.
Use the stp edged-port disable command to configure the current Ethernet port as a non-edge port.
Use the undo stp edged-port command to restore the default state, i.e., non-edge port.
By default, all the switch ports are configured as non-edge ports.
If the current Ethernet port is connected to other switch, you can use the stp edged-port disable or no stp edged-port command to configure it as a non-edge port. The stp edged-port enable command is used for configuring the port as an edge port.
A port is considered as an edge port when it is directly connected to the user terminal, instead of any other switches or shared network segments. The edge port will not cause loop upon network topology changes. Accordingly, you can configure a port as an edge port, so that it can transit to forwarding state fast. For this purpose, configure the Ethernet port directly connected to the user terminal as an edge port.
Because the edge port is not connected to any other switches, it will not receive the configuration BPDUs from them.
  Caution:
If the STP function has been enabled on the downstream equipment of the switch, do not configure edge port on the equipment. Otherwise the system will fail to delete the MAC address table entries and ARP address table entries on the port.
Related commands: stp interface edged-port.
# Configure Ethernet 2/1/1 as a non-edge port.
<H3C> system-view
[H3C-Ethernet2/1/1] stp edged-port disable
stp [ instance instance-id ] root { primary | secondary } [ bridge-diameter bridgenum ] [ hello-time centi-seconds ]
undo stp [ instance instance-id ] root
View
instance instance-id: Specifies the spanning tree instance ID, ranging from 0 to 48. Specify it as 0 to configure the root bridge of CIST.
root primary: Configures the current switch as the primary root bridge of the specified MSTI.
root secondary: Configures the current switch as the secondary root bridge of the specified MSTI.
bridge-diameter bridgenum: Specifies the network diameter of the spanning tree, ranging from 2 to 7.
hello-time centi-seconds: Specifies the Hello Time of the spanning tree, which is in the range from 100 to 1000 and measured in centiseconds.
Use the stp root primary command to configure the current switch as the primary root bridge of a specified MSTI.
Use the stp root secondary command to configure the current switch as a secondary root bridge of a specified MSTI.
Use the undo stp root command to cancel the corresponding configuration.
If you execute these commands without using the instance instance-id option, your configuration takes effect only on the CIST instance.
By default, the switch serves as neither a primary root bridge nor a secondary root bridge.
You can specify one root bridge for each MSTI regardless of switch priority.
You can specify one or more secondary root bridges in each MSTI. When the primary root bridge fails or is powered off, the secondary root bridge takes over as the primary root bridge. If multiple secondary root bridges are configured, the one with the smallest MAC address takes over as the primary root bridge.
When setting a root bridge, you can use this command to specify the switching network diameter and the switch determines the three time parameters (Hello time, Forward Delay and Max Age). You are recommended to specify the switching network diameter and the Hello Time for the root bridge, and let the switch determine the other two parameter values for the root bridge.
When setting a secondary root bridge, you can use this command to specify the switching network diameter and the Hello Time parameter of the secondary root bridge, and let the switch determine the other two time parameters (Forward Delay and Max Age). If you execute the command with the instance-id of 0, the current switch is configured as the secondary root bridge of the CIST.
After you specify the current switch as the primary or secondary root bridge, you cannot change the priority of the switch any more.
  Caution:
In a switching network, you can configure only one root bridge for each MSTI and one or more secondary switches. Do not configure more than one root bridge for an MSTI at the same time. Otherwise, the calculation result will be unpredictable.
After a switch is configured as a primary root bridge or a secondary root bridge, users cannot modify the bridge priority of the switch.
# Designate the current switch as the root bridge of MSTI 0 and specify the diameter of the switching network as 4 and the Hello Time as 500 centiseconds.
<H3C> system-view
[H3C] stp instance 0 root primary bridge-diameter 4 hello-time 500
# Designate the current switch as a secondary root bridge of MSTI 0 and set the diameter of the switching network to 5 and the Hello Time to 300 centiseconds.
<H3C> system-view
[H3C] stp instance 0 root primary bridge-diameter 5 hello-time 300
stp interface interface-list { enable | disable }
View
interface-list: Ethernet port list, containing multiple Ethernet ports and expressed as interface-list = { interface-type interface-number [ to interface-type interface-number] }&<1-10>. For details about the interface-type and interface-number arguments, refer to the interface command in Ethernet Port Configuration Commands. &<1-10> means that you can specify up to 10 ports or port ranges.
enable: Enables MSTP on the port.
disable: Disables MSTP on the port.
Use the stp interface command to enable/disable MSTP on a switch port in system view.
By default, if MSTP is enabled globally, it is enabled on every port. If MSTP is disabled globally, it is also disabled on every port.
When MSTP is disabled, the corresponding port stays in forwarding state and does not take part in any MSTI calculation.
  Caution:
If you disable MSTP on a port, loops may occur.
Related commands: stp mode, stp.
# Enable MSTP on Ethernet 2/1/1 in system view.
<H3C> system-view
[H3C] stp interface Ethernet 2/1/1  enable
stp interface interface-list edged-port {enable | disable }
undo stp interface interface-list edged-port
View
interface-list: Ethernet port list, containing multiple Ethernet ports and expressed as interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>. For details about interface-type and interface-number parameters, refer to the interface command in Ethernet Port Configuration Commands. &<1-10> means that you can specify up to 10 ports or port ranges.
Use the stp interface edged-port enable command to configure a port as an edge port in system view.
Use the stp interface edged-port disable command to configure a port as a non-edge port in system view.
Use the undo stp interface edged-port command to restore the port to the default type (that is, non-edge port) in system view.
If the current Ethernet port is connected to other switches, you can use the stp interface edged-port disable or undo stp interface edged-port command to configure it as a non-edge port. The stp interface edged-port enable command is used for configuring the port as an edge port.
Related commands: stp edged-port.
# Configure Ethernet 2/1/3 as an edge port in system view.
<H3C> system-view
[H3C] stp interface Ethernet 2/1/3 edged-port enable
stp interface interface-list [ instance instance-id ] cost cost
undo stp interface interface-list [ instance instance-id ] cost
View
interface-list: Ethernet port list, containing multiple Ethernet ports and expressed as interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>. For details about the interface-type and interface-number arguments, refer to the interface command in Ethernet Port Configuration Commands. &<1-10> means that you can specify up to 10 ports or port ranges.
instance instance-id: Specifies the spanning tree instance ID, ranging from 0 to 48. The instance 0 represents CIST.
cost cost: Port path cost. Its range depends on the selected standard of path cost.
Use the stp interface cost command to configure the path cost of the specified port on the specified MSTI in system view.
Use the undo stp interface cost command to restore the path cost of the specified port on the specified MSTI to the default value in system view.
By default, the switch automatically calculates the path costs of a port on different MSTIs based on the corresponding standard.
You may specify the instance-id argument as 0 to configure CIST path cost of the port. The path cost has effect on the port role selection. You can configure different path costs for different MSTIs on a port. Thus the traffic from different VLANs can run over different physical links, thereby implementing the VLAN-based load-balancing. MSTP will recalculate the port role and transit its state, upon the port path cost changes.
The default path cost varies with the port rate. For details, refer to the related description in MSTP Operation.
Related commands: stp cost.
# Set the path cost of Ethernet 2/1/3 on MSTI 2 to 400 in system view.
<H3C> system-view
[H3C] stp interface Ethernet 2/1/3 instance 2 cost 400
stp interface interface-list instance instance-id port priority priority
undo stp interface interface-list instance instance-id port priority
View
priority priority: Specifies the port priority, ranging from 0 to 240 with a step length of 16, e.g., 0, 16 and 32. By default, the port has a priority of 128 on every MSTI.
Use the stp interface instance port priority command to configure the priority of the specified port on the specified MSTI in system view.
Use the undo stp interface instance port priority command to restore the default priority.
You may specify the instance-id parameter as 0 to configure CIST priority of the port. The port priority has effect on the port role selection for the specified MSTI. A port can be configured with different priorities on different MSTIs. Thus the traffic from different VLANs can run over different physical links, thereby implementing the VLAN-based load-balancing. MSTP will recalculate the port role and transit its state, upon the port priority changes.
Related commands: stp port priority.
# Set the priority of Ethernet 2/1/3 on MSTI 2 to 16 in system view.
<H3C> system-view
[H3C] stp interface Ethernet 2/1/3 instance 2 port priority 16
stp interface interface-list loop-protection
undo stp interface interface-list loop-protection
View
Use the stp interface loop-protection command to enable loop protection on the switch in system view.
Use the undo stp interface loop-protection command to restore the default loop protection state.
When port roles change, you can use the stp interface loop-protection command to change port state from forwarding state to discarding state, thus avoiding port loopback.
Use the undo stp interface loop-protection command to restore the default running state of loop protection in system view.
The root port and other blocked ports maintain their state according to the BPDUs sent by uplink switch. Due to link congestion or unidirectional link failure, these ports may be unable to receive BPDUs and the switch will select root port again. In this case, the former root port will turn into the specified port and the former blocked ports will change to the forwarding state, and link loop appears.
The loop protection function can inhibit the generation of loop. After it is enabled, the root port role will change according to the uplink port state. The blocked port will maintain in discarding state and do not forward packets, thus avoiding link loop.
By default, loop protection is disabled.
  Caution:
If the equipment connected to the port of the switch cannot send STP packets to the switch, do not configure the loop-protection command; otherwise the port will be congested for a long time.
Related commands: stp loop-protection.
&  Note:
For a loopback port, if the port participates in STP calculation, it must be specified port regardless of internal loop or external loop. However, the port is always set to be in discarding state on all instances.
# Enable loop protection on Ethernet 2/1/1.
<H3C> system-view
[H3C] stp interface Ethernet2/1/1 loop-protection
stp [ interface interface-list ] mcheck
View
interface interface-list: Ethernet port list, containing multiple Ethernet ports and expressed as interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>. For details about the interface-type and interface-number arguments, refer to the interface command in Ethernet Port Configuration Commands. &<1-10> means that you can specify up to 10 ports or port lists.
Use the stp interface mcheck command to perform mCheck operation on port(s).
In system view, execute this command with interface interface-list specified to perform mCheck on the specified port(s); execute the command without interface interface-list to perform mCheck on all ports. If a port of an MSTP switch on a switching network has ever been connected to an STP switch, the port will automatically transit to operate in STP-compatible mode. However, when the STP switch is removed, the port stays in STP-compatible mode and cannot automatically transit back to MSTP mode. In this case, you can perform mCheck operation to transit the port to MSTP mode by force.
&  Note:
By default, MSTP runs in MSTP mode, which is compatible with RSTP and STP (This mode can recognize MSTP BPDU, STP config BPDU and RSTP config BPDU). However, the STP switch can only recognize config BPDU (STP BPDU) sent by the STP and RSTP bridges. After the switch running STP-compatible mode switches back to MSTP mode, it will not send MSTP BPDU if you do not execute the stp mcheck command. Therefore, the connected device still sends config BPDU (STP BPDU) to it, causing the same configuration exist in different regions and other problems. Remember to perform stp mcheck after modifying stp mode.
Related commands: stp mcheck, stp mode.
# Set the mcheck parameter of Ethernet 2/1/3 in system view.
<H3C>system-view
[H3C] stp interface Ethernet2/1/3 mcheck
stp interface interface-type interface-number no-agreement-check
undo stp interface interface-type interface-number no-agreement-check
View
interface-type: Port type.
interface-number: Port number.
Use the stp interface no-agreement-check command to enable port fast transition.
Use the undo stp interface no-agreement-check command to disable port fast transition.
By default, port fast transition is disabled.
Related commands: stp no-agreement-check.
&  Note:
You can configure fast transition only on a root port or an alternate port.
# Enable fast transition on GigabitEthernet 1/1/1.
<H3C> system-view
[H3C]stp interface GigabitEthernet1/1/1 no-agreement-check
stp interface interface-list point-to-point { force-true | force-false | auto }
undo stp interface interface-list point-to-point
View
auto: Specifies automatic detection of the link type.
force-false: Specifies the non-point-to-point link type.
force-true: Specifies the point-to-point link type.
Use the stp interface point-to-point command to specify whether the current port(s) is/are connected to a point-to-point link or point-to-point links.
Use the undo stp interface point-to-point command to restore the system default.
The default setting is auto; namely the MSTP-enabled switch automatically detects whether an Ethernet port connects to a point-to-point link.
The port not connected with the point-to-point link cannot transit fast.
The master ports of the link aggregation and the ports operating in full-duplex mode are connected to the point-to-point link. You are recommended to keep the default settings and let MSTP detect the link state automatically.
This configuration takes effect on the CIST and all the MSTIs. Note that a temporary loop may be introduced if you configure a port as being on a point-to-point link while it is physically not.
Related commands: stp point-to-point.
# Configure Ethernet 2/1/3 to be connected to the point-to-point link.
<H3C> system-view
[H3C] stp interface Ethernet2/1/3 point-to-point force-true
stp interface interface-list root-protection
undo stp interface interface-list root-protection
View
interface-list: Ethernet port list, containing multiple Ethernet ports and expressed as interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>. &<1-10> means that you can specify up to 10 ports or port ranges.
Use the stp interface root-protection command to enable Root protection on the switch in system view.
Use the undo stp interface root-protection command to restore the default Root protection state.
By default, Root protection is disabled.
In case of configuration error or malicious attack, the legal primary root may receive the BPDU with a higher priority and then loose its place, which causes network topology change errors. Due to the illegal change, the traffic supposed to travel over the high-speed link may be pulled to the low-speed link and congestion will occur on the network.
Root protection function is used against such problem. The port configured with Root protection only plays a role of designated port on every instance. Whenever such port receives a higher-priority BPDU, that is, it is about to turn into non-designated port, it will be set to listening state and not forward packets any more (as if the link to the port is disconnected). So, Root protection takes effect only when it is enabled on a designated port. If the port has not received any higher-priority BPDU for a certain period of time thereafter, it will resume its original state.
Related commands: stp root-protection.
# Enable Root protection on Ethernet 2/1/1.
<H3C> system-view
[H3C] stp interface Ethernet2/1/1root-protection
stp interface interface-list transmit-limit packetnum
undo stp interface interface-list transmit-limit
View
packetnum: Maximum number of configuration BPDUs that can be transmitted via the port per Hello Time, ranging from 1 to 255 (expressed as a counter value without any units). By default, the transmission limit on every port is 10.
Use the stp interface transmit-limit command to configure an amount limit to the configuration BPDU transmitted via a specified port during the Hello Time in system view.
Use the undo stp interface transmit-limit command to restore the default limit on the specified port in system view.
The larger the value is, the more packets can be transmitted in a time unit, yet the more switch resources will be occupied. With a moderate value, the amount of the BPDUs transmitted during Hello Time via every port can be limited and MSTP will not occupy too many bandwidth resources when the network topology flaps.
Related commands: stp transmit-limit.
# Set a limit of 5 to the packets transmitted via Ethernet 2/1/3 in system view.
<H3C> system-view
[H3C] stp interface Ethernet2/1/3transmit-limit 5
stp loop-detection
undo stp loop-detection
View
Ethernet port view
None
Use the stp loop-detection command to enable the STP single-port loop detection function on an Ethernet port.
Use the undo stp loop-detection command to disable the STP single-port loop detection function.
By default, the STP single-port loop detection function is disabled.
# Enable the STP single-port loop detection function on GigabitEthernet 7/1/1.
<H3C> system-view
[H3C] interface GigabitEthernet7/1/1
[H3C-GigabitEthernet7/1/1] stp loop-detection
stp loop-protection
undo stp loop-protection
View
Ethernet port view
none
Use the stp loop-protection command to enable loop protection function.
Use the undo stp loop-protection command to restore the default setting.
By default, the loop protection function is not enabled.
Related commands: stp interface loop-protection.
&  Note:
The port configured with loop protection can only turn into discarding state on every instance. When such port receives no configuration message for a long time, only the port role changes, its discarding state remains unchanged, so no packets are forwarded. In this way, if the peer end cannot send BPDU packets due to error operation, and the port enters forwarding state directly for not receiving configuration message for a long time, no loop will be generated by enabling the loop protection.
  Caution:
# Enable loop protection function in Ethernet 2/1/1.
<H3C> system-view
[H3C-Ethernet2/1/1] stp loop-protection
1.1.31  stp max-hops
stp max-hops hop
undo stp max-hops
View
hop: Specifies the max hops, ranging from 1 to 40.
Use the stp max-hops command to configure the Max Hops of an MST region.
Use the undo stp max-hops command to restore the default hops.
By default, the Max Hops of an MST region is 20.
On CIST and MSTIs, the Max Hops configured on the region root determines the max switching network diameter supported by the local MST region. As the BPDU travels from the spanning tree root, each time when it is forwarded by a switch, the max hops will be reduced by 1. The switch discards the configuration BPDU with 0 hops left, thereby limiting the network scale inside the region. If the current switch is a CIST root bridge or MSTI root bridge in an MST region, the Max Hops configured on it will be the network diameter of the spanning tree to limit its scale in the local MST region. The Max Hops configured on the root bridge in an MST region will be adopted by other switches in the same region.
# Set the Max Hops of an MST region to 35.
<H3C> system-view
[H3C] stp max-hops 35
1.1.32  stp mcheck
stp mcheck
View
Ethernet port view
None
Use the stp mcheck command to perform mCheck operation on port(s).
&  Note:
Related commands: stp mode, stp interface mcheck.
# Set the mcheck parameter of Ethernet 2/1/1 in system view.
<H3C> system-view
[H3C-Ethernet2/1/1] stp mcheck
1.1.33  stp mode
stp mode { stp | mstp }
undo stp mode
View
stp: Configures the MSTP operation mode as STP-compatible.
mstp: Configures the MSTP operation mode as MSTP.
Use the stp mode command to configure MSTP operation mode of the switch.
Use the undo stp mode command to restore the default MSTP operation mode.
By default, a switch works in MSTP mode.
MSTP and RSTP are compatible and they can recognize the packets of each other. However, STP cannot recognize MSTP packets. To implement the compatibility, MSTP provides two operation modes, STP-compatible mode and MSTP mode. In STP-compatible mode, the switch sends STP BPDU packets via every port. In MSTP mode, the switch ports send MSTP BPDU packets. When detecting it is connected to an STP switch (it receives config BPDU packets from the STP switch), the switch port enters automatically STP-compatible mode and sends config BPDU packets from the STP switch. The port enters MSTP mode only when receiving MSTP BPDU packets again.
Related commands: stp mcheck, stp interface mcheck, stp, stp interface.
# Set MSTP operation mode as STP-compatible.
<H3C> system-view
[H3C] stp mode stp
undo stp no-agreement-check
View
Ethernet port view
None
Use the stp no-agreement-check command to enable port fast transition.
Related commands: stp interface no-agreement-check.
&  Note:
<H3C> system-view
[H3C] interface GigabitEthernet1/1/1
[H3C-GigabitEthernet1/1/1] stp no-agreement-check
stp non-flooding [ slot slotnum ]
undo stp non-flooding [ slot slotnum ]
View
slot slotnum: Specifies the slot of the LPU (line process unit). The slotnum argument is the slot number.
Use the stp non-flooding command to discard BPDU packets received by STP-disabled ports.
Use the undo stp non-flooding command to forward BPDU packets within the VLAN to which the STP-disabled ports belong.
By default, BPDU non-flooding is disabled.
Note that, after you use the stp enable command in system view, the system automatically runs the stp non-flooding command; after you use the stp disable command in system view, the system automatically runs the undo stp non-flooding command.
Related commands: stp.
# -Discard BPDU packets received on STP-disabled port.
<H3C> system-view
[H3C-GigabitEthernet3/1/1]stp disable
[H3C] stp non-flooding
# Discard BPDU packets received on STP-disabled port on slot 3.
<H3C> system-view
[H3C-GigabitEthernet3/1/1] stp disable
[H3C] stp non-flooding slot 3
# Discard BPDU packets received on all ports when STP is not globally enabled.
<H3C> system-view
[H3C] stp disable
stp pathcost-standard { dot1t | dot1d-1998 | legacy }
View
dot1d-1998: Configure the switch to use the IEEE 802.1D-1998 standard to calculate the default path costs of ports.
dot1t: Configure the switch to use the IEEE 802.1t standard to calculate the default path costs of ports.
legacy: Configure the switch to use the private standard to calculate the default path costs of ports.
Use the stp pathcost-standard command to set the STP port path cost calculation standard.
By default, the S9500 routing switches use the legacy standard.
# Set dot1d-1998 as the path cost calculation standard for STP ports.
<H3C> system-view
[H3C] stp pathcost-standard dot1d-1998
stp point-to-point { force-true | force-false | auto }
undo stp point-to-point
View
Ethernet port view
Use the stp point-to-point command to specify whether the current port is connected to a point-to-point link or point-to-point links.
Use the undo stp point-to-point command to restore the system default.
Related commands: stp interface point-to-point.
<H3C> system-view
[H3C] interface Ethernet2/1/3
[H3C-Ethernet2/1/3] stp point-to-point force-true
stp [ instance instance-id ] port priority priority
undo stp [ instance instance-id ] port priority
View
Ethernet port view
priority: Port priority, ranging from 0 to 240, with a step length of 16, e.g., 0, 16, and 32. By default, the priority of a port on the MSTIs is 128.
Use the stp port priority command to configure the priority of a port on a specified MSTI.
Use the undo stp port priority command to restore the default priority of the port on the specified MSTI.
You may specify the instance-id parameter as 0 to configure CIST priority of the port. The port priority has effect on the port role selection. A port can be configured with different priorities on different MSTIs. Thus the traffic from different VLANs can run over different physical links, thereby implementing the VLAN-based load-balancing. MSTP will recalculate the port role and transit its state, upon the port priority changes.
Related commands: stp interface instance port priority.
# Set the priority of Ethernet 2/1/1 on MSTI 2 to 16.
<H3C> system-view
[H3C-Ethernet2/1/1] stp instance 2 port priority 16
1.1.39  stp priority
stp [ instance instance-id ] priority priority
undo stp [ instance instance-id ] priority
View
instance instance-id: MSTI ID, in the range of 0 to 48. 0 represents CIST.
priority: Priority of the switch, in the range of 0 to 61,440 in the step of 4,096 (totally 16 priority values are available, such as 0, 4096, 8192).
Use the stp priority command to set the priority of the switch in a specified MST instance.
Use the undo stp priority command to restore the switch priority to the default setting.
By default, the priority of a switch is 32,768.
Execution of the stp priority command will affect the choosing of root bridge in the specified instance, and even affect the choosing of the common root bridge, causing the topology change of the entire network. Therefore, do not change the priority value at will after the priority is set.
The switch priority is involved in spanning tree computing. The switch priority is set on a per-instance basis. An MSTP-enabled switch can have different priorities in different MST instances. If you do not provide instance instance-id, your configuration will take effect in the CIST instance only.
# Set the switch priority in MST instance 1 to 4096.
<H3C> system-view
[H3C] stp instance 1 priority 4096
undo stp region-configuration
View
None
Use the stp region-configuration command to enter MST region view.
Use the undo stp region-configuration command to restore the default MSTP region configurations.
By default, the three MST region parameters take the default values. The MST region name of the switch is the first MAC address, all the VLANs are mapped to CIST, and MSTP revision level takes 0.
You can enter MST region view, using the stp region-configuration command. Then you can configure the parameters including region name, revision level, and VLAN mapping table of the region.
# Enter MST region view.
<H3C> system-view
[H3C-mst-region]
stp reset-arp { enable | disable }
undo stp reset-arp
View
None
Use the stp reset-arp enable command to enable the function of clearing dynamic ARP entries when the STP topology changes.
Use the stp reset-arp enable command to disable the function of clearing dynamic ARP entries when the STP topology changes.
Use the undo stp reset-arp command to restore the default ARP entries.
Note: If you enable the function of clearing dynamic ARP entries in system view, the ARP entries of all the ports will be deleted when the STP topology changes. If you enable the function of clearing dynamic ARP entries in port view, only the ARP entries of the specified port will be deleted when the STP topology changes.
# Enable the function of clearing dynamic ARP entries in system view.
<H3C> system-view
[H3C] stp reset-arp enable
stp root-protection
undo stp root-protection
View
Ethernet port view
None
Use the stp root-protection command to enable on Root protection the switch.
Use the undo stp root-protection command to restore the default state of Root protection.
MSTP provides Root protection function to protect the root bridge: The port configured with Root protection only plays a role of designated port on every instance. Whenever such a port receives a higher-priority BPDU, it will be set to listening state and not forward packets any more (as if the link to the port is disconnected). If the port has not received any higher-priority BPDU for a certain period of time thereafter, it will resume the normal state.
Related commands: stp interface root-protection.
<H3C> system-view
[H3C-Ethernet2/1/1] stp root-protection
stp tc-protection enable
stp tc-protection disable
View
None
Use the stp tc-protection enable command to enable the protection function so that the switch is protected against attack from TC-BPDU packets.
Use the stp tc-protection disable command to disable the protection function.
By default, the protection against TC-BPDU packet attack is enabled.
As a general rule, the switch deletes the corresponding entries in the MAC address table and ARP table upon receiving TC-BPDU packets. Under malicious attacks of TC-BPDU packets, the switch shall receive a great number of TC-BPDU packets in a very short period. Too frequent delete operations shall consume huge switch resources and bring great risk to network stability.
When the protection from TC-BPDU packet attack is enabled, the switch just perform one delete operation in a specified period (generally, 15 seconds) after receiving TC-BPDU packets, as well as monitoring whether it receives TC-BPDU packets during this period. Even if it detects a TC-BPDU packet is received in a period shorter than the specified interval, the switch shall not run the delete operation till the specified interval is reached. This can avoid frequent delete operations to the MAC address table and ARP table.
# Enable TC-BPDU protection on the switch.
<H3C> system-view
[H3C] stp tc-protection enable
1.1.44  stp timer forward-delay
stp timer forward-delay centi-seconds
undo stp timer forward-delay
View
centi-seconds: Specifies Forward Delay, which is in the range from 400 to 3000 and measured in centiseconds. By default, the Forward Delay of the switch is 1500 centiseconds.
Use the stp timer forward-delay command to configure Forward Delay for the switch.
Use the undo stp timer forward-delay command to restore the default Forward Delay.
To avoid temporary loop, MSTP defines a medium state, Learning, when the port switches from the Discarding state to Forwarding state. There is also a delay before state switchover to guarantee the synchronous switchover with the remote switch. The Forward Delay configured on the root bridge determines the state transition time.
The root bridge will determine the state transition time according to the configured values, while the other switches will apply the forward delay configured on it.
When configuring Hello time, Forward Delay and Max Age, guarantee the following equations:
2 x (Forward Delay - 1.0 second) >= Max Age
Max Age >= 2 x (Hello Time + 1.0 second)
Only if the above-mentioned formulas are equal can the MSTP normally operate on the entire network. Otherwise, the network may flap frequently. You are recommended to use the stp bridge-diameter command to specify the diameter of the switching network, so that MSTP can automatically calculate and give the moderate values for the time parameters.
&  Note:
Hello time, Forward Delay and Max Age affect each other. Modifying any of them will affect the value of other two parameters.
Related commands: stp timer hello, stp timer max-age, stp bridge-diameter.
# Set the Forward Delay of the device to 2000 centiseconds.
<H3C> system-view
[H3C] stp timer forward-delay 2000
1.1.45  stp timer hello
stp timer hello centi-seconds
undo stp timer hello
View
centi-seconds: Specifies Hello Time value with an integer in the range of 100 to 1000 in units of centiseconds. By default, the Hello Time of the switch is 200 centiseconds.
Use the stp timer hello command to configure Hello Time of the switch.
Use the undo stp timer hello command to restore the default Hello Time.
The STP defines to transmit configuration BPDU regularly at an interval specified with Hello Time to keep the spanning tree stable. If the switch receives no BPDU packets for a period of time, it will recalculate the spanning tree upon the BPDU timeouts. The root bridge transmits BPDU packets at an interval as you configured, while other switches apply the Hello Time configured on the root bridge.
When configuring Hello time, Forward Delay and Max Age, remember to guarantee the following equations:
2 x (Forward Delay -1.0 second) >= Max Age
Only if the earlier-mentioned formulas are equal can the MSTP normally operate on the entire network. Otherwise, the network may flap frequently. You are recommended to use the stp bridge-diameter command to specify the diameter of the switching network, so that MSTP can automatically calculate and give the moderate values for the time parameters.
Related commands: stp timer forward-delay, stp timer max-age, stp bridge-diameter.
# Set Hello Time of the switch to 400 centiseconds.
<H3C> system-view
[H3C] stp timer hello 400
1.1.46  stp timer max-age
stp timer max-age centi-seconds
undo stp timer max-age
View
centi-seconds: Specifies the Max Age, which is in the range from 600 to 4000 and measured with centiseconds. By default, the Max Age of the switch is 2000 centiseconds.
Use the stp timer max-age command to configure the Max Age of the switch.
Use the undo stp timer max-age command to restore the default Max Age.
MSTP can detect the link fault and automatically resume the forwarding state of the redundant link. On the CIST, the switch checks if the configuration BPDU received via the port expires according to the Max Age. If the BPDU expires, the MSTI has to be calculated again.
Max Age takes no effect on MSTIs. If the current switch is CIST root bridge, it will check if the configuration BPDU expires according to the configured Max Age. Otherwise, the switch adopts the Max Age configured on the CIST root bridge.
When you configure Hello time, Forward Delay and Max Age, remember to guarantee the following equations:
Related commands: stp timer forward-delay, stp timer hello, stp bridge-diameter.
# Set Max Age of the device to 1000 centiseconds.
<H3C> system-view
[H3C] stp timer max-age 1000
1.1.47  stp timer-factor
stp timer-factor number
undo stp timer-factor
View
number: Specifies the multiple of hello time, in the range of 1 to 10. The default value is 3.
Use the stp timer-factor command to configure the multiple of hello time for the switch.
Use the undo stp timer-factor command to restore the default multiple value.
The Ethernet switch transmits STP packets every hello time. Generally, if the switch does not receive the STP packets from the upstream switch for three times of hello time, the switch will decide the upstream switch is dead and will recalculate the topology of the network. Then in steady network, the recalculation may be caused when the upstream is busy. In this case, users can redefine the timeout interval to a longer time (four times the hello time or larger) by define the multiple of hello time. It is recommended to set 5, 6 or 7 as the value of multiple in the steady network.
# Set the multiple value of hello time to 7.
<H3C> system-view
[H3C] stp timer-factor 7
1.1.48  stp transmit-limit
stp transmit-limit packetnum
undo stp transmit-limit
View
Ethernet port view
packetnum: Specifies the amount limit to the transmitted packets, ranging from 1 to 255. By default, the value is 10.
Use the stp transmit-limit command to configure an amount limit to the configuration BPDU transmitted via a port during the Hello Time.
Use the undo stp transmit-limit command to restore the default limit.
Related commands: stp interface transmit-limit.
# Set a maximum of 5 packets can be transmitted via Ethernet 2/1/1 during the hello time.
<H3C> system-view
[H3C-Ethernet2/1/1] stp transmit-limit 5
1.1.49  vlan-mapping modulo
vlan-mapping modulo modulo
undo vlan-mapping modulo
View
MST region view
modulo: Specifies the modulus, ranging from 1 to 48.
Use the vlan-mapping modulo command to map all VLAN lists to STIs according to the specified modulo number.
Use the undo vlan-mapping modulo command to restore the default mappings.
By default, all the VLANs are mapped to CIST, namely Instance 0.
Related commands: region-name, revision-level, check region-configuration, active region-configuration.
# Map VLAN to MSTI based on modulo 16.
<H3C> system-view
[H3C] stp region-configuration
[H3C-mst-region] vlan-mapping modulo 16
