H3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
04-Port Isolation Configuration Commands
04-Port Isolation Configuration Commands 31.91 KB
Chapter 1  Port Isolation Configuration Commands
  Caution:
LSB1XP4CA0 and LSB1XP4B0 LPUs do not support port isolation.
1.1  Port Isolation Configuration Commands
1.1.1  display port-isolate group
display port-isolate group [ isolate-group-id ] [ verbose ]
View
isolate-group-id: ID of an isolation group, in the range 1 to 64. Up to 64 isolation groups can be created. If no isolation group is specified, information about all isolation groups is displayed.
verbose: Displays detailed information of the specified or all isolation groups.
Use the display port-isolate group command to display information about the specified or all isolation groups.
# Display information about all isolation groups.
<H3C> display port-isolate group
Now, the following port-isolate-group exist(s): 1,2-10,14
Port-isolate-group ID: 1
Uplink-port: Ethernet3/1/1
Isolate-Port(s): Ethernet3/1/2, Ethernet3/1/3
Port-isolate-group ID: 2
Uplink-port: Ethernet3/1/4
Isolate-Port(s): Ethernet3/1/5, Ethernet3/1/6
1.1.2  port-isolate group (system view)
port-isolate group isolate-group-id
undo port-isolate group isolate-group-id
View
Use the port-isolate group command to create an isolation group.
Use the undo port-isolate group command to remove an isolation group. Upon its removal, all the ports are removed from the group.
# Create isolation group 1.
<H3C> system-view
[H3C] port-isolate group 1
1.1.3  port-isolate group (port view)
View
Ethernet port view, RPR port view
Use the port-isolate group command to assign the current port to an isolation group as an isolated port.
Use the undo port-isolate group command to remove the current port from an isolation group.
Note that:
l           Before configuring the port-isolate group command, make sure the isolation group identified by the isolate-group-id argument already exists.
l           Only Ethernet ports or RPR logical ports can be configured as isolated ports.
l           A port cannot be an isolated port and the uplink port of an isolation group at the same time.
l           The number of isolated ports in an isolation group is not limited.
# Assign Ethernet 3/1/1 to isolation group 1 as an isolated port.
<H3C> system-view
[H3C] interface Ethernet3/1/1
[H3C-Ethernet3/1/1] port-isolate group 1
1.1.4  port-isolate uplink-port group
port-isolate uplink-port group isolate-group-id
undo port-isolate uplink-port group isolate-group-id
View
isolate-group-id: ID of an isolation group, in the range of 1 to 64. Up to 64 isolation groups can be created.
Use the port-isolate uplink-port group command to configure the current port as the uplink port in an isolation group.
Use the undo port-isolate uplink-port group command to cancel the configuration.
By default, no port operates as the uplink port of any isolation group.
Note that:
l           Before configuring the port-isolate uplink-port group command, make sure the isolation group identified by the isolate-group-id argument already exists.
l           The uplink port in an isolation group can be a member port of a link aggregation group that is neither static nor dynamic.
# Configure Ethernet 2/1/1 as the uplink port of isolation group 1.
<H3C> system-view
[H3C] interface Ethernet2/1/1
[H3C-Ethernet2/1/1] port-isolate uplink-port group 1
