H3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
01-Ethernet Port Commands
01-Ethernet Port Commands 167.57 KB
Chapter 1  Ethernet Port Configuration Commands
1.1  Ethernet Port Configuration Commands
1.1.1  broadcast-suppression
broadcast-suppression { ratio | bandwidth bandwidth }
undo broadcast-suppression
View
Ethernet port view
ratio: Specifies a percentage of the total port bandwidth for broadcasts on the port. The value range is 1 to 100. The smaller the percentage is, the smaller the broadcast traffic is allowed.
bandwidth: Specifies the maximum bandwidth for broadcasts on the port. The value range is 1 to the maximum port bandwidth.
Use the broadcast-suppression command to enable broadcast suppression. When doing this, you can set the percentage of total port bandwidth for broadcasts or set the maximum port bandwidth for broadcasts. Broadcasts that cross the threshold will be suppressed.
Use the undo broadcast-suppression command to restore the default.
The default percentage of the total port bandwidth for broadcasts is 50%.
The broadcast suppression setting you configured with the broadcast-suppression command will overwrite the previous broadcast suppression setting, if any.
  Caution:
l      You cannot enable both broadcast suppression and multicast suppression on the same card. Namely, once you have enabled broadcast suppression on some ports of a card, you cannot enable multicast suppression on the other ports of the card, and vice versa.
l      While broadcast suppression does not work on multicasts, multicast suppression can suppress broadcasts.
l      No distinction is made between known multicast and unknown multicast for multicast suppression.
Related commands: multicast-suppression.
# Set the threshold that triggers broadcast suppression to 40.
<H3C> system-view
[H3C] interface Ethernet 2/1/1
[H3C-Ethernet2/1/1] broadcast-suppression 40
# Set the maximum broadcast traffic size that triggers broadcast suppression to 40 Mbps.
[H3C-Ethernet2/1/1] broadcast-suppression bandwidth 40
# Restore the default broadcast suppression setting.
[H3C-Ethernet2/1/1] undo broadcast-suppression
1.1.2  copy configuration
copy configuration source { interface-type interface-number | interface-name | aggregation-group agg-id } destination { interface-list [ aggregation-group agg-id ] | aggregation-group agg-id }
View
interface-type: Source port type.
interface-number: Source port number.
interface-list: Destination port list. You can specify individual ports and port ranges in the list, but the total number of them cannot exceed 10. Specify an individual port in the form of interface-type interface-number where interface-type is the port type and interface-number is the port number. Specify a port range in the form of interface-type interface-number to interface-type interface-number where the end port must be greater than the start port.
agg-id: Source or destination aggregation group ID. If it is a source aggregation group, the port with minimum port number is the source port; if it is a destination aggregation group, the configurations of all its member ports change to be consistent with those of the source port.
Use the copy configuration command to copy the configuration of a port to other ports to keep their configurations consistent.
# Copy the configuration of aggregation group 1 to aggregation group 2.
<H3C> system-view
[H3C] copy configuration source aggregation-group 1 destination aggregation-group 2
1.1.3  description
View
Ethernet port view
text: Port description character string, with 64 characters at most.
Use the description command to configure the description character string for Ethernet port.
Use the undo description command to cancel the port description character string.
By default, the port description character string is null.
# Configure the description character string of Ethernet port Ethernet 2/1/1 as lanswitch-interface.
<H3C> system-view
[H3C-Ethernet2/1/1] description lanswitch-interface
1.1.4  display counters
display counters [ rate ] { inbound | outbound } interface [ interface-type ]
View
rate: Displays the rate information of the ports in the Up state during the latest sampling period. If this keyword is not specified in the command, the system displays packet counts. The sampling period is 300 seconds by default. You can use the flow-interval to set the sampling period.
inbound: Displays the import statistic information.
outbound: Displays the export statistic information.
interface-type: Specifies the port type. Three types are available: Ethernet, Gigabit Ethernet, POS, and RPR.
Use the display counters command to view the statistics on the ports of the specified types. If the port type is not specified, the system displays statistics orderly on all the ports.
# Display the inbound statistics on the GigabitEthernet ports.
<H3C> display counters inbound interface GigabitEthernet
Interface          Total(pkts)    BroadCast(pkts)    MultiCast(pkts) Err(pkts)
GE3/2/1   12,345,678,912,345           OverFlow 12,345,678,912,345 1,234,567
GE3/2/2                      0                  0                  0                 0
GE3/2/3                      0                  0                  0                 0
GE3/2/4                      0                  0                  0                 0
 OverFlow :more than 14 decimal digits(7 digits for column "Err").
:not supported.
&  Note:
l      Statistic values are comma-separated decimal numbers.
l      For the Total, BroadCast and MultiCast items, decimal numbers of 14 digits can be displayed at most, and those of more than 14 digits are indicated with “OverFlow”.
l      For the Err item, decimal numbers of 7 digits can be displayed at most, and those of more than 7 digits are indicated with “OverFlow”.
1.1.5  display interface
display interface [ interface-type | interface-type interface-number [ packets] ]
View
interface-number: Specifies the port number.
Use the display interface command to view the configuration information on the port.
l           If the port type and number are not specified when displaying the port information, the information of all the ports will be displayed.
l           If only the port type is specified, all the information of the ports of this type will be displayed.
l           If both port type and port number are specified, the information of the designated port will be displayed.
# Display configuration information of Ethernet 2/1/1.
<H3C> display interface ethernet2/1/1
Ethernet2/1/1 current state : UP
 IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 00e0-fc00-85ff
 The Maximum Transmit Unit is 1500
 Media type is twisted pair, loopback not set
 Port hardware type is 100_BASE_TX
 100Mbps-speed mode, full-duplex mode
 Flow-control is not enabled
 The Maximum Frame Length is 1552
 Broadcast MAX-ratio: 100%
 Allow jumbo frame to pass
 MixInsert-Port VPN status: not enable MixInsert access
 PVID: 48
 Mdi type: auto
 Port link-type: access
  Tagged   VLAN ID : none
  Untagged VLAN ID : 48
 Last 300 seconds input:  0 packets/sec 61 bits/sec       1%
 Last 300 seconds output:  0 packets/sec 0 bits/sec       1%
 Input(total):  54 packets, 7465 bytes
          42 broadcasts, 5 multicasts
 Input(normal):  54 packets, 7465 bytes
          - broadcasts, - multicasts
 Input:  0 input errors, 0 runts, 0 giants,  0 throttles, 0 CRC
          0 frame,  0 overruns, - aborts, 0 ignored, - parity errors
 Output(total): 1 packets, 64 bytes
          0 broadcasts, 0 multicasts, 0 pauses
 Output(normal): 1 packets, 64 bytes
          - broadcasts, - multicasts, 0 pauses
 Output: 0 output errors,  - underruns, - buffer failures
          0 aborts, 0 deferred, - collisions, 0 late collisions
          - lost carrier, - no carrier
 Receive Packet Peak Value Info: 7215 bytes, happened at 03:30:35 3-7-2001
 Transmit Packet Peak Value Info: 64 bytes, happened at 03:30:35 3-7-2001
Table 1-1 Description on the fields of the display interface command
The current status of Ethernet port (enabled or disabled)
Ethernet frame format
Hardware address
Port hardware address
Maximum transmit unit
Media type
Type of media
loopback not set
Port loopback test status
Port hardware type
Port hardware type
100 Mbps-speed mode, full-duplex mode
Both the duplex mode and the rate are set to auto-negotiation. The rate of 100 Mbps and the mode of full-duplex are adopted after negotiating with its peer
Port flow control status
Maximum length of the Ethernet frames that can pass the port
Broadcast MAX-ratio
Port broadcast storm suppression ratio
Jumbo frame is allowed to pass the port
Port VPN status
Port VPN status (enable or not VPN access)
PVID
Port default VLAN ID
Mdi type
Cable type
Port link-type
Port link type
Tagged VLAN ID
The VLANs with packets tagged
Untagged VLAN ID
The VLANs with packets untagged
Last 300 seconds input:  0 packets/sec 0 bits/sec
The input/output rate and the passing packet number on this port in the last 300 seconds.
Input(total):  0 packets, 0 bytes
 Input(normal):  0 packets, 0 bytes
 Output(total): 0 packets, 0 bytes
 Output(normal): 0 packets, 0 bytes
The statistics information of input/output packets and errors on this port. “-” indicates that the item doesn’t supported by the switch.
1.1.6  display jumboframe configuration
View
None
Use the display jumboframe configuration command to view the Jumbo frame configuration on all cards. The supported Jumbo frame length ranges, as well as the default values, may vary by card.
# Display the current Jumboframe configuration in the system.
[H3C] display jumboframe configuration
The jumboframe configuration at present:
Slot 2:
1.1.7  display port
View
hybrid: Displays hybrid ports.
trunk: Displays trunk ports.
Use the display port command to display hybrid or trunk ports.
If a hybrid or trunk port is present, the output displays the port name and VLANs on the port.
# Display hybrid ports.
<H3C> display port hybrid
Interface                VLAN passing:
Ethernet3/1/1            Tagged  : 3, 5, 7, 9, 11
                         Untagged: 1-2, 4, 6,
Ethernet3/1/2            Tagged  : none
                         Untagged: 1
The output shows that two hybrid ports are present on the device: Ethernet 3/1/1 and Ethernet 3/1/2. Ethernet 3/1/1 carries tagged VLANs 3, 5, 7, 9, and 11, and untagged VLANs 1, 2, 4, and 6. Ethernet 3/1/2 carries untagged VLAN 1 but no tagged VLANs.
# Display trunk ports.
<H3C> display port trunk
Ethernet3/1/3            1, 3-5, 10
Ethernet3/1/4            none
Ethernet3/1/7            1
The output shows that three trunk ports are present on the device: Ethernet 3/1/3, Ethernet 3/1/4, Ethernet 3/1/7. Ethernet 3/1/3 carries VLANs 1, 3, 4, 5, and 10. Ethernet 3/1/4 carries no VLANs. Ethernet 3/1/7 carries VLAN 1.
1.1.8  display transceiver alarm
View
Default Level
2: System level
interface-type interface-number: Interface type and interface number.
Use the display transceiver alarm command to display the current alarm information of the optical transceiver plugged in the specified port or all optical transceivers if no port is specified.
If no error has occurred, None is displayed.
# Display the current alarm information of the pluggable transceiver in interface GigabitEthernet 1/1/1.
<H3C> display transceiver alarm interface GigabitEthernet 1/1/1
GigabitEthernet1/1/1 transceiver current alarm information:
  TX fault
  PCS receive local fault
  Laser temperature fault
The following table describes the output that the display transceiver alarm command may display.
Table 1-2 Description on the fields of the display transceiver alarm command
Remarks
RX loss of signal
Receive signal is lost.
RX power high
Receive power level is high.
RX power low
Receive power level is low.
TX fault
Transmit fault
TX bias high
Transmit bias current is high.
TX bias low
Transmit bias current is low.
TX power high
Transmit power is high.
TX power low
Transmit power is low.
Temp high
Temperature is high.
Temp low
Temperature is low.
Voltage high
Voltage is high.
Voltage low
Voltage is low.
Transceiver info I/O error
Transceiver information read and write error
Transceiver info checksum error
Transceiver information checksum error
Transceiver type and port configuration mismatch
The transceiver type does not match the port configuration.
Transceiver type not supported by port hardware
The transceiver type is not supported on the port.
RX not ready
Receiver is not ready
RX CDR loss of lock
Receive clock cannot be recovered.
TX not ready
Transmitter is not ready.
TX fault
Transmit fault
TX CDR loss of lock
Transmit clock cannot be recovered.
Module not ready
Module is not ready.
APD supply fault
Avalanche photo diode (APD) supply fault
TEC fault
Thermoelectric cooler (TEC) fault
Wavelength unlocked
Wavelength of optical signal exceeds the manufacturer’s tolerance.
Transceiver type does not match port configuration.
Transceiver type is not supported on the port.
WIS local fault
Local fault of the WAN interface sublayer (WIS)
Receive optical power fault
PMA/PMD receiver local fault
Physical medium attachment/physical medium dependent (PMA/PMD) receiver local fault
Local fault of the physical coding sublayer (PCS) receiver
PHY XS receive local fault
Local fault of the PHY extended sublayer (PHY XS) receiver
Laser bias current fault
Laser output power fault
1.1.9  display transceiver diagnosis
View
Default Level
2: System level
Use the display transceiver diagnosis command to display the currently measured values of the diagnosis parameters for the pluggable optical transceiver in the specified port or all transceivers if no port is specified.
&  Note:
The diagnosis information is available only for H3C customized anti-spoofing transceivers.
# Display the currently measured values of the digital diagnosis parameters for the optical transceiver plugged in interface GigabitEthernet 1/1/1.
<H3C> display transceiver diagnosis interface GigabitEthernet 1/1/1
GigabitEthernet1/1/1 transceiver diagnostic information:
Temp.(°C)  Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
40         3.3         1.1          20.0              -30.0
Table 1-3 Description on the fields of the display transceiver diagnosis command
Temp.(°C)
Digital diagnosis parameter – temperature in degrees centigrade
Voltage(V)
Digital diagnosis parameter – voltage, in V, accurate to the first decimal place.
Bias(mA)
Digital diagnosis parameter – bias current, in mA, accurate to the first decimal place.
RX power(dBM)
Digital diagnosis parameter – receive power, in dBM, accurate to the first decimal place.
TX power(dBM)
Digital diagnosis parameter – transmit power, in dBM, accurate to the first decimal place.
&  Note:
N/A is displayed for parameters not supported on the device.
1.1.10  display transceiver interface
View
Default Level
2: System level
Use the display transceiver interface command to display the major parameters of the optical transceiver plugged in the specified port or all optical transceivers if no port is specified.
# Display the major parameters of the optical transceiver plugged in interface GigabitEthernet 1/1/1.
<H3C> display transceiver interface GigabitEthernet 1/1/1
GigabitEthernet1/1/1 transceiver information:
  Transceiver Type                   : 1000_BASE_LX_SFP
  Connector Type                 : LC
  Wavelength(nm)                 : 1310
  Transfer Distance              : 10km(9um)
  Digital Diagnostic Monitoring  : YES
  Vendor Name                        : H3C
Table 1-4 Description on the fields of the display transceiver interface command
Transceiver Type
Physical type of the transceiver
Connector Type
Type of the connectors of the transceiver:
l      Optical connectors, SC or LC
l      Other connectors, RJ-45, CX 4, or any other type
Wavelength(nm)
Wavelength (in nm) of the transmit laser. If the transceiver supports multiple wavelengths, they are separated by commas (,).
Transfer Distance
Maximum transmission distance. If the transceiver supports multiple transmission media, their values are displayed separated by commas (,) each followed by the corresponding medium enclosed in brackets. The following are possible transmission media:
l      9 um: 9/125 μm single-mode fiber
l      50 um: 50/125 μm multi-mode fiber
l      62.5 um: 62.5/125 μm multi-mode fiber
l      TP: twisted pair
l      CX4: CX4 cable
l      STACK: stack cable
Indicates support for digital diagnosis, YES for supported and NO for not supported.
Vendor Name
Module vendor
l      For an H3C customized anti-spoofing transceiver: the vendor name in the RFID1 of the module is displayed.
l      For other transceivers: The original vendor names on the modules are displayed.
Note: RFID = radio frequency identification (also called e-tag)
1.1.11  display transceiver manuinfo interface
View
Default Level
2: System level
Use the display transceiver manuinfo interface command to display the radio frequency identification (RFID) information of the pluggable optical transceiver in the specified port or all optical transceivers if no port is specified.
# Display the RFID information of the optical transceiver plugged in interface GigabitEthernet 1/1/1.
<H3C> display transceiver manuinfo interface GigabitEthernet 1/1/1
GigabitEthernet1/1/1 transceiver manufacture information:
  Manu. Serial Number        : 213410A0000054000251
  Manufacturing Date     : 2005-09-01
  Vendor Name                : H3C
Table 1-5 Description on the fields of display transceiver manuinfo interface
Manu. Serial Number
Serial number generated for an H3C customized optical transceiver during transceiver debugging and testing. The information is stored in the RFID.
Manufacturing Date
Debugging and testing date.
Vendor Name
The specified vendor name for the transceiver. The information is stored in the RFID.
1.1.12  duplex
duplex { auto | full | half }
undo duplex
View
Ethernet port view
auto: Operates in auto-negotiation mode.
full: Operates in full-duplex mode.
half: Operates in half-duplex mode.
Use the duplex command to configure the duplex mode of the Ethernet port.
Use the undo duplex command to restore the default.
By default, an Ethernet port operates in auto-negotiation mode.
Related commands: speed.
# Configure Ethernet 2/1/1 to operate in auto-negotiation mode.
<H3C> system-view
[H3C-Ethernet2/1/1] duplex auto
1.1.13  flag
flag { j0 | j1 } { sdh | sonet } flag-value
undo flag { j0 | j1 } { sdh | sonet }
View
Gigabit Ethernet port view
j0: Specifies the trace field in the regeneration section. The field is a section overhead field and is used to test the connectivity of the connection between two ports on the section level. The field is default by default.
j1: Specifies the channel trace field, which is a high-order channel overhead field. The field is used to test the connectivity of the connection between two ports on the channel level. The field is a string of 1 to 63 characters and is default by default.
sdh: Specifies the frame format as SDH. For 10 GE WAN interfaces, the frame format can only be SDH.
sonet: Specifies the frame format as SONET.
flag-value: Value of the overhead to be set. The range of this argument varies with the keyword specified, as listed below.
l           C2: 0x0 to 0xFF.
l           J0 in SDH frame format: a string of 1 to 15 characters.
l           J1 in SDH frame format: a string of 1 to 15 characters.
l           J0 in SONET frame format: 0x0 to 0x7F.
Use the flag command to set an overhead field for a port.
Use the undo flag command to restore an overhead field of a port to the default value.
Note that the flag command is available only to GE ports in WAN mode.
# Set the overhead field j0 for the 10 GE WAN port GigabitEthernet 4/2/1.
<H3C> system-view
[H3C] interface GigabitEthernet4/2/1
[H3C-GigabitEthernet4/2/1] port-mode wan
[H3C-GigabitEthernet4/2/1] flag j0 sdh 1
1.1.14  flow-control
flow-control
undo flow-control
View
Ethernet port view
None
Use the flow-control command to enable flow control on the Ethernet port to avoid discarding data packets due to congestion.
Use the undo flow-control command to disable flow control.
By default, flow control is disabled on an Ethernet port.
# Enable flow control on Ethernet 2/1/1.
<H3C> system-view
[H3C-Ethernet2/1/1] flow-control
1.1.15  flow-interval
flow-interval interval
undo flow-interval
View
Ethernet port view
interval: Interval of performing statistics on ports in seconds, in the range of 5 to 300.
Use the flow interval command to set the interval for collecting statistics on ports. The switch collects the statistics about the average speed during the interval.
Use the undo flow-interval to restore the interval to the default.
By default, the interval for collecting statistics on ports is 300 seconds.
Related commands: display interface.
# Set the interval of collecting statistics on Ethernet 3/1/1 to 100 seconds.
<H3C>system-view
[H3C]interface Ethernet 3/1/1
[H3C-Ethernet3/1/1] flow-interval 100
# Restore the interval of collecting statistics on Ethernet 3/1/1 to the default value.
[H3C-Ethernet3/1/1] undo flow-interval
1.1.16  interface
View
interface-type: Specifies the port type. It can be Aux, Ethernet, Loopback, M-Ethernet, NULL, VLAN-interface, GigabitEthernet and 10-GigabitEthernet, POS, RPR.
interface-number: Specifies the port number. It adopts slot-number/subslot-number/ port-number format. slot-number specifies the LPU slot number of the port. For S9505, it ranges from 2 to 6. For S9508, it ranges from 0 to 3 and 6 to 9 (slot number 4 and 5 are SRPU). For S9512, it ranges from 0 to 5 and 8 to 13 (slot number 6 and 7 are SRPU). subslot-number specifies the sub-slot number of the port and ranges from 1 to 3. port-number specifies the port number on the daughter card. It is 1 or ranges from 1 to 12, 20, or 48, depending on the service board type. M-Ethernet is used to update and maintain. It ranges from 0/0/0.
Use the interface command to enter various types of Ethernet port views.
Before you can configure the related parameters of a type of Ethernet port, you must first use this command to enter the Ethernet port view of this type.
# Enter the Ethernet 2/1/1 port view.
<H3C> system-view
[H3C] interface ethernet2/1/1
1.1.17  jumboframe enable
jumboframe enable [ jumboframe-value ] slot slot-number
jumboframe disable slot slot-number
View
slot-number: Specifies the slot number of the card.
jumboframe-value: Specifies the maximum size (in bytes) of jumbo frames permitted to pass the card.
Use the jumboframe enable command to permit jumbo frames to pass the card on the specified slot and set the maximum size of Jumbo frames.
Use the jumboframe disable slot command to prohibit jumbo frames from passing the card on the specified slot.
By default, jumbo frame is permitted to pass cards.
Related commands: display jumboframe configuration.
&  Note:
The system supports discrete values of Jumbo frame size ranging from 1,552 to 10,240. However, effective Jumbo frame values fall into several sections: the effective Jumbo frame sizes for the 1,552-9,022 section are 1,552 and 9,022, that for the 9,023-9,192 section is 9,192, and that for the 9,193-10,240 section is 10,240.
# Permit jumbo frames to pass the card on slot 6 and set the maximum size of Jumbo frames to 9022.
<H3C> system-view
[H3C] jumboframe enable 9022 slot 6
1.1.18  link-status hold
link-status hold hold-time
undo link-status hold
View
hold-time: Link-state hold time in seconds. If this argument is set to 0, the state change of a link is reported to the upper layer without delay. If this argument is set to an integer other than 0, link state change will be reported after the specified interval instead of immediately.
Use the link-status hold command to set the link-state hold time.
Use the undo link-status hold command to restore the default link-state hold time.
By default, the link-state hold time is 3 seconds.
# Set the link-state hold time to 5 seconds.
<H3C> system-view
[H3C] link-status hold 5
# Set the link-state hold time to 0 seconds.
<H3C> system-view
[H3C] link-status hold 0
1.1.19  loopback
undo loopback
View
Ethernet port view
external: Places the Ethernet port in an external loopback. Currently, the Ethernet ports on the S9500 series do not support this mode.
internal: Places the Ethernet port in an internal loopback.
Use the loopback command to enable loopback on the Ethernet port.
Use the undo loopback command to disable loopback on the Ethernet port.
By default, loopback is disabled on Ethernet ports.
# Place Ethernet 2/1/1 to operate in internal loopback mode.
<H3C>system-view
[H3C]interface ethernet2/1/1
[H3C-Ethernet2/1/1] loopback internal
1.1.20  mdi
mdi { across | auto | normal }
undo mdi
View
Ethernet port view
across: Network cable type is cross-over cable.
auto: Network cable will be recognized whether it is straight-through cable or cross-over cable.
normal: Network cable of the port is straight-through cable.
Use the mdi command to configure the network cable type of the Ethernet ports.
Use the undo mdi command to restore the default type.
By default, the network cable type will be recognized automatically.
  Caution:
This command only takes effect on the 10/100 Mbps and 10/100/1,000 Mbps electrical ports.
# Configure the network cable type of Ethernet port Ethernet 2/1/1 as auto.
<H3C> system-view
[H3C-Ethernet2/1/1] mdi auto
1.1.21  multicast-suppression
multicast-suppression { ratio | bandwidth bandwidth }
undo multicast-suppression
View
Ethernet port view
ratio: Specifies a percentage of the total bandwidth for multicasts on the Ethernet port. The value range is 1 to 100. The smaller the ratio is, the smaller the multicast traffic is allowed.
bandwidth: Specifies the maximum bandwidth for multicasts on the port. The value range is 1 to the maximum port bandwidth.
Use the multicast-suppression command to enable multicast suppression. When doing this, you can set the percentage of total port bandwidth for multicasts or set the maximum port bandwidth for multicasts. Multicasts that cross the threshold will be suppressed.
Use the undo multicast-suppression command to disable multicast suppression.
By default, all broadcasts are allowed to pass, that is the ratio argument is set to 100.
The multicast suppression setting you configured with the multicast-suppression command will overwrite the previous multicast suppression setting, if any.
  Caution:
l      You cannot enable both multicast suppression and broadcast suppression simultaneously on the same card. Namely, once you have enabled broadcast suppression on some ports of a card, you cannot enable multicast suppression on the other ports of the card, and vice versa. Although the commands are based on ports, the mutual exclusion between these two commands is based on cards.
Related commands: broadcast-suppression.
# Set the threshold that triggers multicast suppression to 40%.
<H3C> system-view
[H3C]interface Ethernet 2/1/1
[H3C-Ethernet2/1/1] multicast-suppression 40
# Set the maximum multicast traffic size that triggers multicast suppression to 40 Mbps.
[H3C-Ethernet2/1/1] multicast-suppression bandwidth 40
# Disable multicast suppression.
[H3C-Ethernet2/1/1] undo multicast-suppression
1.1.22  port access vlan
port access vlan vlan-id
undo port access vlan
View
Ethernet port view
vlan-id: VLAN ID defined in IEEE802.1Q, ranging from 2 to 4094.
Use the port access vlan command to assign the access port to the specified VLAN.
Use the undo port access vlan command to restore the default.
By default, all Ethernet ports are access ports and belong to VLAN 1.
The condition for using this command is that the VLAN indicated in vlan-id must exist.
# Assign Ethernet 2/1/1 to VLAN 3 (assuming VLAN 3 already exists).
<H3C> system-view
[H3C-Ethernet2/1/1] port access vlan 3
1.1.23  port hybrid pvid vlan
port hybrid pvid vlan vlan-id
undo port hybrid pvid
View
Ethernet port view
vlan-id: VLAN ID defined in IEEE802.1Q, ranging from 1 to 4094 and the default vlan-id is 1.
Use the port hybrid pvid vlan command to configure the default VLAN ID of the local hybrid port.
Use the undo port hybrid pvid command to restore the default VLAN ID of the local hybrid port.
The default VLAN ID of local hybrid port shall be consistent with that of the peer one, otherwise, the packet cannot be properly transmitted.
Related commands: port link-type.
# Configure the default VLAN of the hybrid port Ethernet 2/1/1 as VLAN 100.
<H3C> system-view
[H3C-Ethernet2/1/1] port hybrid pvid vlan 100
1.1.24  port hybrid vlan
undo port hybrid vlan vlan-id-list
View
Ethernet port view
vlan-id-list: vlan-id-list = [ vlan-id1 [ to vlan-id2 ] ]&<1-10>: Specifies which VLAN the hybrid port will be added to. It can be discrete. The vlan-id ranges from 1 to 4,094. &<1-10> indicates that the former parameter can be input 10 times repeatedly at most.
untagged: Packet of specified VLAN will not have tag.
Use the port hybrid vlan command to assign the hybrid port to the specified existing VLAN.
Use the undo port hybrid vlan command to remove the hybrid port from the specified VLAN.
A hybrid port can be assigned to multiple VLANs. If the port hybrid vlan vlan-id-list { tagged | untagged } command is used for many times, the VLANs carried by the hybrid port is the set of vlan-id-list.
Before assigning a hybrid port to a VLAN, create the VLAN first.
# Assign hybrid port Ethernet 2/1/1 to VLANs 2, 4, and 50 through 100 in tagged mode.
<H3C> system-view
[H3C-Ethernet2/1/1] port hybrid vlan 2 4 50 to 100 tagged
1.1.25  port link-type
undo port link-type
View
Ethernet port view
access: Configures the port as an access port.
hybrid: Configures the port as a hybrid port.
trunk: Configures the port as a trunk port
Use the port link-type command to configure the link type of the Ethernet port.
Use the undo port link-type command to restore the default.
To change the link type of a port from trunk to hybrid or vice versa, you must set the link type to access first.
By default, the link type of a port is access.
# Configure Ethernet 2/1/1 as a trunk port.
<H3C> system-view
[H3C-Ethernet2/1/1] port link-type trunk
1.1.26  port-mode
port-mode { wan | lan }
undo port-mode
View
Ethernet port view
wan: Configures the port to work in WAN mode. Use this mode for connecting to an SDH network. This mode is available only on 10-GE ports.
lan: Configures the port to work in LAN mode. Use this mode for connecting to Ethernet.
Use the port-mode command to configure the network mode of the port.
Use the undo port-mode command to restore the default.
By default, Ethernet ports work in LAN mode.
&  Note:
Ports on the XP4CA and XP4B boards do not support the WAN mode.
# Set GigabitEthernet 2/1/1 to work in WAN mode.
<H3C> system-view
[H3C] interface GigabitEthernet2/1/1
[H3C-GigabitEthernet2/1/1] port-mode wan
# Restore the default (LAN) mode on GigabitEthernet 2/1/1.
[H3C-GigabitEthernet2/1/1] undo port-mode
1.1.27  port trunk permit vlan
undo port trunk permit vlan { vlan-id-list | all }
View
Ethernet port view
vlan-id-list: vlan-id-list = [ vlan-id1 [ to vlan-id2 ] ] & <1-10> is the VLAN range joined by the trunk port. It can be discrete. The vlan-id ranges from 2 to 4,094. &<1-10> indicates that the former parameter can be input 10 times repeatedly at most.
all: Assigns the trunk port to all VLANs.
Use the port trunk permit vlan command to assign the trunk port to the specified VLAN(s).
Use the undo port trunk permit vlan command to remove the trunk port from the specified VLAN(s).
A trunk port can be assigned to multiple VLANs. If the port trunk permit vlan command is used many times, the VLANs that the trunk port belongs to are the set of these vlan-id-list.
# Remove the trunk port from the default VLAN.
<H3C> system-view
[H3C] interface Ethernet2/1/1
[H3C-Ethernet2/1/1] undo port trunk permit vlan 1
# Assign the trunk port to all VLANs.
[H3C-Ethernet2/1/1] port trunk permit vlan all
1.1.28  port trunk pvid vlan
port trunk pvid vlan vlan-id
undo port trunk pvid
View
Ethernet port view
vlan-id: VLAN ID defined in IEEE802.1Q, ranging from 1 to 4,094 and the default vlan-id is 1.
Use the port trunk pvid vlan command to configure the default VLAN ID of the trunk port.
Use the undo port trunk pvid command to restore the default.
The default VLAN ID of the local trunk port should be consistent with that of the peer one. Otherwise, the packets cannot be properly transmitted.
# Configure the default VLAN of the trunk port Ethernet 2/1/1 as 100.
<H3C> system-view
[H3C-Ethernet2/1/1] port trunk pvid vlan 100
1.1.29  reset counters interface
reset counters interface [ interface-type | interface-type interface-number ]
View
Use the reset counters interface command to clear statistics for ports.
If the port type and number are not specified, the statistics of all ports are cleared. If only the port type is specified, all the statistics of the ports of this type are cleared. If both port type and port number are specified, only the statistics of the specified port are cleared.
This command cannot clear the statistics of 802.1x-enabled ports.
# Clear the statistics of Ethernet port Ethernet 2/1/1.
<H3C> reset counters interface ethernet2/1/1
1.1.30  shutdown
shutdown
View
Ethernet port view
None
Use the shutdown command to disable the Ethernet port.
Use the undo shutdown command to enable the Ethernet port.
By default, the Ethernet port is enabled.
# Enable Ethernet 2/1/1.
<H3C> system-view
[H3C-Ethernet2/1/1] undo shutdown
1.1.31  speed
speed { 10 | 100 | 1000 | 10000 | auto }
undo speed
View
Ethernet port view
10: Speed on the port is 10 Mbps.
100: Speed on the port is 100 Mbps.
1000: Speed on the port is 1,000 Mbps.
10000: Speed on the port is 10 Gbps.
auto: Port speed is in peer auto-negotiation status.
Use the speed command to configure the port speed.
Use the undo speed command to restore the default speed.
The optional parameters of this command are determined by the port types and duplex modes. For example, the 10/100/1,000 Mbps electrical ports support three optional parameters including 10 Mbps, 100 Mbps, and 1,000 Mbps. You can select proper port speed as you require. But when the duplex mode is changed into half duplex mode, the port speed can be set to 1,000 Mbps or auto.
By default, the speed is auto.
Related commands: duplex.
# Configure Ethernet 2/1/1 port speed as 100 Mbps.
<H3C> system-view
[H3C-Ethernet2/1/1] speed 100
1.1.32  vlan filter enable
vlan filter enable
vlan filter disable
View
Ethernet port view
None
Use the vlan filter enable command to enable the VLAN filtering function for a port.
Use the vlan filter disable command to disable the VLAN filtering function for the port.
By default, the VLAN filtering function is enabled on a port.
# Enable the VLAN filtering function on Ethernet 2/1/1.
<H3C> system-view
[H3C-Ethernet2/1/1] vlan filter enable
1.1.33  vlan-vpn enable
vlan-vpn enable
undo vlan-vpn
View
Ethernet port view
None
Use the vlan-vpn enable command to enable VLAN VPN on the port.
Use the undo vlan-vpn command to disable VLAN VPN on the port.
Note that if anyone of GVRP, STP, NTP or 802.1x has been enabled on a port, VLAN VPN cannot be enabled on it.
By default, VLAN VPN is disabled on a port.
# Enable VLAN VPN on Ethernet 2/1/1.
<H3C> system-view
[H3C-Ethernet2/1/1] vlan-vpn enable
