H3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
03-Link Aggregation Configuration Commands
03-Link Aggregation Configuration Commands 68.89 KB
Chapter 1  Link Aggregation Configuration Commands
1.1  Link Aggregation Configuration Commands
1.1.1  debugging lacp packet
debugging lacp packet [ interface interface-type interface-number [ to interface-type interface-number ] ]
undo debugging lacp packet [ interface interface-type interface-number [ to interface-type interface-number ] ]
View
interface interface-type interface-number [ to interface-type interface-number ]: Specifies a port or ports. The command without the parameter to specifies one port, while the command with the parameter to specifies several contiguous ports. interface-type indicates port type. interface-number indicates port number.
Use the debugging lacp packet command to enable LACP packet debugging for the port. If you do not specify a port, the command enables packet debugging on all LACP-enabled ports.
Use the undo debugging lacp packet command to disable LACP packet debugging for the port.
# Enable LACP packet debugging for Ethernet port Ethernet 1/1/1.
<H3C> debugging lacp packet interface ethernet1/1/1
1.1.2  debugging lacp state
debugging lacp state [ interface interface-type interface-number [ to interface-type interface-number ] ] { { actor-churn | mux | partner-churn | ptx | rx } * | all }
undo debugging lacp state [ interface interface-type interface-number [ to interface-type interface-number ] ] { { actor-churn | mux | partner-churn | ptx | rx } * | all }
View
actor-churn: Actor-churn state machine debugging switch.
mux: MUX state machine debugging switch.
partner-churn: Partner-churn state machine debugging switch.
ptx: PTX state machine debugging switch.
rx: RX state machine debugging switch.
all: debugging switch of all state machines.
Use the debugging lacp state command to enable LACP state machine debugging for the port.
Use the undo debugging lacp state command to disable LACP state machine debugging for the port.
# Enable debugging of all LACP state machines.
<H3C> debugging lacp state all
1.1.3  debugging link-aggregation error
undo debugging link-aggregation error
View
None
Use the debugging link-aggregation error command to enable link aggregation error debugging.
Use the undo debugging link-aggregation error command to disable link aggregation error debugging.
# Enable link aggregation error debugging.
<H3C> debugging link-aggregation error
1.1.4  debugging link-aggregation event
undo debugging link-aggregation event
View
None
Use the debugging link-aggregation event command to enable link aggregation event debugging.
Use the undo debugging link-aggregation event command to disable link aggregation event debugging.
# Enable link aggregation event debugging.
<H3C> debugging link-aggregation event
1.1.5  display lacp system-id
View
None
Use the display lacp system-id command to display the device ID of local system, including system priority and system MAC address.
Related commands: link-aggregation.
# Display the device ID of the local system.
<H3C> display lacp system-id
 Actor System ID: 0x8000, 00e0-fc00-0100
Table 1-1 Description on the fields of the display lacp system-id command
Actor System ID
The device ID of the local system, including system priority and system MAC address.
1.1.6  display lacp timer
display lacp timer
View
None
Use the display lacp timer command to display the LACP fast period timer and LACP slow period timer.
Related commands: lacp timer slow.
# Display the LACP fast period timer and LACP slow period timer.
<H3C> display lacp timer
LACP fast period timer:1(s)
LACP slow period timer:30(s)
1.1.7  display link-aggregation interface
display link-aggregation interface interface-type interface-number [ to interface-type interface-number ]
View
interface { interface-type interface-number [ to interface-type interface-number ]: interface-type specifies port type and interface-number specifies port number. You can specify a port with the first interface-type interface-number or specify a port range with the interface-type interface-number to interface-type interface-number where the end port must be greater than the start port.
Use the display link-aggregation interface command to display detailed link aggregation information for a port or a range of ports.
The output displays the aggregation group ID, local port priority, operation key, flag, and peer information including the system ID, port number, port priority, operation key, and flag.
Note that since a manual aggregation group cannot get the information of the peer end, every item of the peer end is displayed as 0, which does not indicate the actual state of the peer system.
# Display detailed link aggregation information of Ethernet 2/1/1.
<H3C> display link-aggregation interface ethernet2/1/1
 Ethernet2/1/1:
   Attached AggID: 1
   Local:
     Port-Priority: 32768, Oper key: 1, Flag: 0x00
   Remote:
     System ID: 0x0, 0000-0000-0000
     Port Number: 0, Port-Priority: 0, Oper-key: 0, Flag: 0x00
Received LACP Packets: 0 packet(s), Illegal: 0 packet(s)
   Sent LACP Packets: 0 packet(s)
Table 1-2 Description on the fields of the display link-aggregation interface command
Attached AggID
Aggregation group ID for the specified port
Local:
Port priority, operation key, LACP state flag of the local end
Remote:
System ID, port priority, operation key, LACP state flag of the remote end
Statistics about received LACP packets
Statistics about sent LACP packets
1.1.8  display link-aggregation summary
View
None
Use the display link-aggregation summary command to display the summary of all aggregation groups, including local device ID, aggregation group ID, aggregate group type, peer device ID, number of selected ports, number of standby ports, load sharing type and master port number.
# Display the summary of all link aggregation groups.
<H3C> display link-aggregation summary
Aggregation Group Type:D -- Dynamic, S -- Static , M -- Manual
Actor ID: 0x8000, 00e0-fc23-0d90
  AL  AL   Partner ID            Select Standby Share Master
  ID  Type                       Ports  Ports   Type  Port
  1   M    none                    2      0       Shar  GigabitEthernet3/1/1
  3   M    none                  4      0      Shar  Ethernet4/1/45
Table 1-3 Description on the fields of the display link-aggregation summary command
Actor ID
Local device ID
AL ID
AL Type
Aggregation group type
Partner ID
Peer device ID
Select Ports
Number of selected ports
Standby Ports
Number of standby ports
Share Type
Load sharing type
Master Port
Master port number
1.1.9  display link-aggregation verbose
display link-aggregation verbose [ agg-id ]
View
agg-id: Aggregation group ID, which must be existing ones, in the range of 1 to 920. IDs 1 through 31 indicate manual or static aggregation groups; IDs 32 through 192 are reserved; IDs 193 through 920 indicate dynamic aggregation groups.
Use the display link-aggregation verbose command to view detailed information of a designated port, including aggregation group ID, aggregation group type, load sharing type, aggregation group description and detailed local information (system ID, member ports, port status, port priority, flag, operation key, link status) and detailed remote information (local port, indexes of remote ports, port priority, flag, operation key and system ID, here local and remote are in a relative sense).
Note that since the manual aggregation group cannot get the information of the peer end, every item of the peer end is displayed as 0, which does not indicate the actual status of the peer system.
# Display the detailed information of aggregation group 5.
<H3C>display link-aggregation verbose 5
Aggregation ID: 5,  AggregationType: Manual,   Loadsharing Type: Shar
Aggregation Description:
System ID: 0x0, 00e0-fc00-1312
Port Status: S -- Selected,  T -- sTandby,  U -- Unselected
Local:
    Port                    Status  Priority Flag Oper-Key Link-Status
    Ethernet9/1/9           S       32768    0x00 8        Down
    Ethernet9/1/10          S       32768    0x00 8        Down
Remote:
    Actor                   Partner Priority Flag Oper-Key SystemID
    Ethernet9/1/9           0       0        0x00 0        0x0,0000-0000-0000
    Ethernet9/1/10          0       0        0x00 0        0x0,0000-0000-0000
Table 1-4 Description on the fields of the display link-aggregation verbose command
Aggregation ID
Aggregation Type
Aggregation group type, which can be dynamic, static and manual
Loadsharing Type
Load sharing type
Aggregation group description
System ID
Local device ID
Port State
Port state
Local:
Port  Status  Priority  Flag  Oper-key Link-Status
Other information of the local end, including member ports, port state, port priority, flag bit , operation key and link status.
Remote:
Actor  Partner  Priority  Flag  Oper-key SystemID
Detailed information about the peer device, including local port, peer port index, port priority, flag, operation key and device ID
1.1.10  lacp enable
lacp enable
undo lacp enable
View
Ethernet port view
None
Use the lacp enable command to enable LACP.
Use the undo lacp enable command to disable LACP.
# Enable LACP for Ethernet port Ethernet1/1/1.
<H3C> system-view
[H3C] interface Ethernet1/1/1
[H3C-Ethernet1/1/1] lacp enable
1.1.11  lacp port-priority
lacp port-priority port-priority-value
undo lacp port-priority
View
Ethernet port view
port-priority-value: Port priority, in the range of 0 to 65,535. The default is 32,768.
Use the lacp port-priority command to configure port priority.
Use the undo lacp port-priority command to restore the default port priority.
Related commands: display link-aggregation verbose, display link-aggregation interface.
# Set port priority to 64.
<H3C> system-view
[H3C-Ethernet1/1/1] lacp port-priority 64
1.1.12  lacp system-priority
lacp system-priority system-priority-value
undo lacp system-priority
View
system-priority-value: System priority, in the range of 0 to 65,535. By default, it is 32,768.
Use the lacp system-priority command to configure system priority.
Use the undo lacp system-priority command to restore the default system priority.
Related commands: display lacp system-id.
# Set system priority to 64.
<H3C> system-view
[H3C] lacp system-priority 64
1.1.13  lacp timer slow
lacp timer slow interval
undo lacp timer slow
View
interval: Slow period timer value (in seconds), in the range of 1 to 30. The default is 30.
Use the lacp timer slow command to set the LACP slow period timer.
Use the undo lacp timer slow command to restore the default.
# Set the LACP slow period timer to 2 seconds.
<H3C> system-view
[H3C] lacp timer slow 2
1.1.14  link-aggregation
link-aggregation interface-type  interface-number1 to interface-type interface-number2 [ both ]
View
interface-type interface-name1: Starting Ethernet port joined the Ethernet link aggregation.
interface-type interface-name2: End Ethernet port joined the Ethernet link aggregation.
both: Specifies the aggregation group to balance load for inbound and outbound packets.
Use the link-aggregation command to add a range of ports to an aggregation group.
Note: After a port is added to an aggregation group, the ARP configuration of the port will be lost.
Related commands: link-aggregation group mode, port link-aggregation group.
# Configure to balance load for inbound and outbound packets.
<H3C> system-view
[H3C] link-aggregation ethernet2/1/1 to ethernet2/1/2 both
1.1.15  link-aggregation extend
undo link-aggregation extend
View
None
Use the link-aggregation extend command to enable aggregation resource extension.
Use the undo link-aggregation extend command to remove the configuration.
By default, idle aggregation resources are allocated from 7 to 0 for special port aggregation. With aggregation resource extension enabled, idle aggregation resources are allocated from 31 to 0 for special port aggregation. Special ports include RprGE ports and 10GE ports that are not of wire speed.
By default, aggregation resource extension is disabled.
&  Note:
As for the aggregation resource extension, note that:
l      The function is unavailable to devices containing C-type LPUs.
l      The function cannot be disabled when special link aggregations are allocated the aggregation resources numbered from 7 to 31.
# Enable aggregation resource extension.
<H3C> system-view
[H3C] link-aggregation extend
# Remove aggregation resource extension configuration.
<H3C> system-view
[H3C] undo link-aggregation extend
1.1.16  link-aggregation group description
link-aggregation group agg-id description alname
undo link-aggregation group agg-id description
View
agg-id: Aggregation group ID, in the range of 1 to 31. IDs At present, you can configure the static and dynamic aggregation groups only.
alname: Aggregation group name, character string with 1 to 32 characters.
Use the link-aggregation group description command to configure description for an aggregation group.
Use the undo link-aggregation group description command to delete aggregation group description.
Note that you cannot configure the description for a dynamic aggregation group.
Related commands: display link-aggregation verbose.
# Configure myal1 as the description of aggregation group 22.
<H3C> system-view
[H3C] link-aggregation group 22 description myal1
1.1.17  link-aggregation group mode
link-aggregation group agg-id mode { manual | static }
View
Use the link-aggregation group mode command to create an aggregation group.
Use the undo link-aggregation group command to delete an aggregation group.
&  Note:
Port aggregation includes manual aggregation, static aggregation and dynamic aggregation.
l      In the manual aggregation mode, ports working at different rates can be aggregated. Manual aggregation can be load balancing aggregation if the aggregation resource is available. In this case, if the traffic rate shared by a low-rate port exceeds the maximum rate of the port, packets may be lost.
l      In the static aggregation mode, ports working at different rates can also be aggregated. However, the Selected/Standby state of statically aggregated ports is determined by the transmission rate. Only the ports with the maximum rate and in full-duplex mode can be selected to forward traffic, while other standby ports do not forward traffic.
# Create manual aggregation group 22.
<H3C> system-view
[H3C] link-aggregation group 22 mode manual
1.1.18  port link-aggregation group
port link-aggregation group agg-id
undo port link-aggregation group
View
Ethernet port view
agg-id: Aggregation group ID, in the range of 1 to 31. IDs At present, you can add the static and dynamic aggregation groups only.
Use the port link-aggregation group command to add an Ethernet port into a manual or static aggregation group.
Use the undo port link-aggregation group command to delete an Ethernet port from an aggregation group.
# Add Ethernet2/1/1 into aggregation group 22.
<H3C> system-view
[H3C] interface Ethernet2/1/1
[H3C-Ethernet2/1/1] port link-aggregation group 22
1.1.19  reset lacp statistics
reset lacp statistics [ interface interface-type interface-number [ to interface-type interface-number ] ]
View
Use the reset lacp statistics command to clear LACP statistics for the specified port or ports. If no port is specified, the command clears LACP statistics for all ports.
Related commands: display link-aggregation interface.
# Clear LACP statistics for all Ethernet ports.
<H3C> reset lacp statistics
