H3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-01 IP Access Volume
09-Port Loopback Detection Commands
09-Port Loopback Detection Commands 32.27 KB
Chapter 1  Port Loopback Detection Commands
1.1  Port Detection Configuration Commands
1.1.1  display loopback-detection
View
Ethernet port view
None
Use the display loopback-detection command to display whether the port loopback detection function is enabled or not. If the function is enabled, the command will display the interval for detection, the VLANs enabled with detection function, the existing loops, and the ports which are shutdown for loop.
# Display whether the port loopback detection function is enabled or not.
<H3C> display loopback-detection
Loopback-detection is running on!
Detection interval time is 60 seconds!
Following vlans enable loopback-detection: 1
Following ports are detected for loop: GigabitEthernet2/1/1
Following ports are shutdown for loop: NULL
Table 1-1 Description on the fields of the display loopback-detection command
Port loopback detection function is enabled.
Detection interval is 60 seconds.
Ports on which loop exists
Ports which are shutdown for loop
1.1.2  loopback-detection control
undo loopback-detection control
View
Ethernet port view
None
Use the loopback-detection control command to configure the system to shut down the current port once the port is found in a loop in addition to sending a trap message.
Use the undo loopback-detection control command to disable the system from shutting down the current port when the port is found in a loop. Still, trap information will be reported.
By default, the system does not shut down the ports that are found in loop.
# Enable the system to shut down the current port once it is found in a loop.
<H3C> system-view
[H3C] interface GigabitEthernet 2/1/1
[H3C-GigabitEthernet2/1/1] loopback-detection control
1.1.3  loopback-detection disable
undo loopback-detection disable
View
Ethernet port view
None
Use the loopback-detection disable command to disable a port from sending loopback detection packets.
Use the undo loopback-detection disable command to re-enable a port to send loopback detection packets.
&  Note:
After you use the loopback-detection disable command on a port, the port no longer sends loopback detection packets. However, it still processes received loopback detection packets.
# Disable GigabitEthernet 2/1/1 from sending loopback detection packets.
<H3C> system-view
[H3C-GigabitEthernet2/1/1] loopback-detection disable
1.1.4  loopback-detection enable
undo loopback-detection enable
View
None
Use the loopback-detection enable command to enable the global port loopback detection function, so that the system can detect whether there is an external loop on each port in a VLAN which is enabled with the loopback detection function. If a loop is found on a port, the switch will give out an alarm or give out an alarm and shutdown the port according to your configuration.
Use the undo loopback-detection enable command to disable the global port loopback function.
By default, the global port loopback detection function is disabled.
Related commands: display loopback-detection.
# Enable the global port loopback detection function.
<H3C> system-view
[H3C] loopback-detection enable
1.1.5  loopback-detection enable vlan
loopback-detection enable vlan { vlanlist | all }
undo loopback-detection  enable vlan { vlanlist | all }
View
vlanlist: Defines one or multiple VLANs. You can provide up to 10 VLAN lists, by each of which you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID.
all: Enables loopback detection for all existing VLANs.
Use the loopback-detection enable vlan command to enable loopback detection on the specified VLAN(s) to check for loop on all ports in the VLAN(s).
Use the undo loopback-detection enable vlan command to disable loopback detection on the specified VLAN(s).
By default, loopback detection is disabled on all VLANs.
# Enable loopback detection for all ports in VLAN 2.
<H3C> system-view
[H3C] loopback-detection enable vlan 2
1.1.6  loopback-detection interval-time
loopback-detection interval-time time
undo loopback-detection interval-time
View
time: Interval in seconds at which external loopback detection is performed on ports, in the range of 10 to 7200. The default value is 60 seconds.
Use the loopback-detection interval-time command to set the interval at which the external loopback detection is performed on ports.
Use the undo loopback-detection interval-time command to restore the default interval.
# Set the interval for external loopback detection on ports to 120 seconds.
<H3C> system-view
[H3C] loopback-detection interval-time 120#
