H3C Low-End Ethernet Switches Configuration Examples(V1.04)
HomeSupportSwitchesS3100 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Examples(V1.04)
05-Routing Configuration Examples
05-Routing Configuration Examples 716.56 KB
Table of Contents
Chapter 1 Routing Overview.. 1-1
1.1 Overview. 1-1
1.1.1 Static Routing and Routing Protocols. 1-1
1.1.2 Routing Protocols Supported by the H3C Low-End Ethernet Switches. 1-1
1.2 Configuration Guide. 1-2
1.2.1 Configuration Task List 1-2
1.2.2 Static Route Configuration. 1-2
1.2.3 RIP Configuration. 1-3
1.2.4 OSPF Configuration. 1-9
1.2.5 BGP Configuration. 1-18
1.2.6 Route Policy Configuration. 1-29
Chapter 2 Configuration Examples. 2-1
2.1 Configuration Examples. 2-1
2.1.1 Static Routing Configuration Example. 2-1
2.1.2 RIP Configuration Examples. 2-2
2.1.3 DR Configuration Example. 2-4
2.1.4 OSPF Virtual Link Configuration Examples. 2-6
2.1.5 BGP Confederation Configuration Example. 2-9
2.1.6 BGP Route Reflector Configuration Example. 2-11
2.1.7 BGP Path Selection Configuration Example. 2-14
Chapter 3 Comprehensive Configuration Example. 3-1
3.1 Network Requirements. 3-1
3.1.1 Requirement Analysis, Network Diagram and Configuration Plan. 3-1
3.1.2 Devices Used for Networking. 3-3
3.1.3 Routing Protocols and Related Parameters on Devices. 3-3
3.1.4 Software Version. 3-4
3.2 Configuration Procedure. 3-4
3.2.1 Configuration Guide. 3-4
3.2.2 Basic Configuration. 3-4
3.2.3 Basic RIPv2/OSPF/BGP Configuration. 3-4
3.2.4 RIP, Static Route, and Routing Policy Configuration Example. 3-12
3.2.5 BGP and IGP Interaction Configuration Example. 3-13
3.2.6 Route Backup Configuration Example. 3-15
3.2.7 BGP MED Attribute Configuration Example. 3-16
3.3 Displaying the Whole Configuration on Devices. 3-20
3.3.1 Displaying the Whole Configuration on Devices. 3-20
3.4 Verifying the Configuration. 3-31
3.4.1 Verifying the Configuration of Routing Policy and Static Routes. 3-31
3.4.2 Verifying the BGP and IGP Interaction Configuration. 3-32
3.4.3 Verifying the Route Backup Configuration. 3-33
3.4.4 Verifying the MED Attribute Configuration. 3-34
3.5 Precautions. 3-36
1.1  Overview
I. Static routing
Static routing features zero overhead, simple configuration, and is applicable to simple and stable networks. But it requires human intervention when the network topology changes.
II. RIP
RIP is easy to configure and is insensitive to CPU and memory, so it is applicable to small and medium sized networks. However, it converges slowly and cannot eliminate route loops completely. In addition, periodic RIP updating multicasts or broadcasts consume many network resources.
III. OSPF
OSPF is complicated to configure and requires high-performance CPU and memory. It is applicable to medium and large sized networks. OSPF converges fast and can eliminate route loops completely. It supports area partition and provides hierarchical route management.
IV. BGP
BGP runs between ASs. Although complicated to configure, BGP features high reliability, stability, and scalability, has flexible and powerful routing policies and eliminates route loops completely.
Table 1-1 Routing protocols supported by the H3C low-end ethernet switches
               Routing
             Protocols
Model
RIP
OSPF
BGP
S3600-SI
S3600-EI
S5600
&  Note:
l      This configuration guide takes S5600 series Ethernet switches as an example.
l      For configuration precautions, see corresponding operation manuals and command manuals.
Table 1-2 Configuration task List
Details
Static route configuration
1.2.2
RIP configuration
1.2.3
OSPF configuration
1.2.4
BGP configuration
1.2.5
Table 1-3 Configure a static route
Operation
Remarks
Enter system view
ip route-static ip-address { mask | mask-length } { interface-type interface-number | next-hop } [ preference preference-value ] [ reject | blackhole ] [ detect-group group number ] [ description text ]
Required
By default, the system can obtain the route to the subnet directly connected to the router.
Table 1-4 RIP configuration tasks
Configuration task
Remarks
Related section
Configuring basic RIP functions
Enabling RIP
Required
1.2.3  I.
Setting the RIP operating status on an interface
Optional
1.2.3  II.
Specifying a RIP version
Optional
1.2.3  III.
Configuring RIP route control
Setting the additional routing metrics of an interface
Optional
1.2.3  IV.
Configuring RIP route summarization
Optional
1.2.3  V.
Disabling the receiving of host routes
Optional
1.2.3  VI.
Configuring RIP to filter incoming/outgoing routes
Optional
1.2.3  VII.
Setting RIP preference
Optional
1.2.3  VIII.
Enabling load sharing among interfaces
Optional
1.2.3  IX.
Configuring RIP to import routes from another protocol
Optional
1.2.3  X.
Adjusting and optimizing a RIP network
Configuring RIP timers
Optional
1.2.3  XI.
Configuring split horizon
Optional
1.2.3  XII.
Configuring RIP-1 packet zero field check
Optional
1.2.3  XIII.
Setting RIP-2 packet authentication mode
Optional
1.2.3  XIV.
Configuring RIP to unicast packets
Optional
1.2.3  XV.
I. Configuring Basic RIP Functions
Table 1-5 Enable RIP on the interfaces attached to a specified network segment
Operation
Remarks
Enter system view
Enable RIP and enter RIP view
rip
Required
Enable RIP on the specified interface
network network-address
Required
Disabled by default.
II. Setting the RIP operating status on an interface
Table 1-6 Set the RIP operating status on an interface
Operation
Remarks
Enter system view
Enter interface view
Enable the interface to receive RIP update packets
rip input
Optional
By default, all interfaces are allowed to send and receive RIP update packets.
Enable the interface to send RIP update packets
rip output
Enable the interface to receive and send RIP update packets
rip work
III. Specifying the RIP version on an interface
Table 1-7 Specify the RIP version on an interface
Operation
Remarks
Enter system view
Specify the version of the RIP running on the interface
rip version { 1 | 2 [ broadcast | multicast ] }
Optional
By default, the version of the RIP running on an interface is RIP-1.
IV. Setting the additional routing metrics of an interface
Additional metric is the metric added to the original metrics of RIP routes on an interface. It does not directly change the metric value of a RIP route in the routing table of a router, but will be added to incoming or outgoing RIP routes on the interface.
Table 1-8 Set additional routing metric
Operation
Remarks
Enter system view
Set the additional routing metric to be added for incoming RIP routes on this interface
rip metricin value
Optional
By default, the additional routing metric added for incoming routes on an interface is 0.
Set the additional routing metric to be added for outgoing RIP routes on this interface
rip metricout value
Optional
By default, the additional routing metric added for outgoing routes on an interface is 1.
V. Configuring RIP route summarization
Table 1-9 Configure RIP route summarization
Operation
Remarks
Enter system view
Enter RIP view
rip
Enable RIP-2 automatic route summarization
summary
Required
By default, RIP-2 automatic route summarization is enabled.
VI. Disabling the router from receiving host routes
Table 1-10 Disable the router from receiving host routes
Operation
Remarks
Enter system view
Enter RIP view
rip
undo host-route
Required
By default, the router receives host routes.
VII. Configuring RIP to filter incoming/outgoing routes
Table 1-11 Configure RIP to filter incoming/outgoing routes
Operation
Remarks
Enter system view
Enter RIP view
rip
Configure RIP to filter incoming routes
filter-policy { acl-number | ip-prefix ip-prefix-name [ gateway ip-prefix-name ] | route-policy route-policy-name } import
Required
By default, RIP does not filter any incoming route.
The gateway keyword is used to filter the incoming routes advertised from a specified address.
filter-policy gateway ip-prefix-name import
Configure RIP to filter outgoing routes
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol ] [ process-id ]
Required
By default, RIP does not filter any outgoing route.
filter-policy route-policy route-policy-name export
VIII. Setting RIP preference
Table 1-12 Set RIP preference
Operation
Remarks
Enter system view
Enter RIP view
rip
Set the RIP preference
preference value
Required
The default RIP preference is 100.
IX. Enabling load sharing among RIP interfaces
Table 1-13 Enable load sharing among RIP interfaces
Operation
Remarks
Enter system view
Enter RIP view
rip
traffic-share-across-interface
Required
By default, load sharing among RIP interfaces is disabled
X. Configuring RIP to redistribute routes from another protocol
Table 1-14 Configure RIP to import routes from another protocol
Operation
Remarks
Enter system view
Enter RIP view
rip
Configure a default cost for an incoming route
default cost value
Optional
1 by default.
Configure RIP to redistribute routes from another protocol
import-route protocol [ process-id ] [ cost value | route-policy route-policy-name ]*
Required
By default, RIP does redistribute any route from other protocols.
XI. Configuring RIP timers
Table 1-15 Configure RIP timers
Operation
Remarks
Enter system view
Enter RIP view
rip
Set the RIP timers
timers { update update-timer | timeout timeout-timer } *
Required
By default, the Update timer is set 30 seconds and the Timeout timer to 180 seconds.
XII. Configuring split horizon
Table 1-16 Configure split horizon
Operation
Remarks
Enter system view
Enable split horizon
rip split-horizon
Required
Enabled by default.
XIII. Configuring RIP-1 packet zero field check
Table 1-17 Configure RIP-1 packet zero field check
Operation
Remarks
Enter system view
Enter RIP view
rip
Enable the check of the “must be zero” field in RIP-1 packets
checkzero
Required
Enabled by default.
XIV. Setting RIP-2 packet authentication mode
Table 1-18 Set RIP-2 packet authentication mode
Operation
Remarks
Enter system view
rip authentication-mode { simple password | md5 { rfc2453 key-string | rfc2082 key-string key-id } }
Required
If you specify to use MD5 authentication, you must specify one of the following MD5 authentication types:
l      rfc2453 (this type supports the packet format defined in RFC 2453)
l      rfc2082 (this type supports the packet format defined in RFC 2082)
XV. Configuring RIP to unicast RIP packets
Table 1-19 Configure RIP to unicast RIP packets
Operation
Remarks
Enter system view
Enter RIP view
rip
peer ip-address
Required
When RIP runs on the link that does not support broadcast or multicast, you must configure RIP to unicast RIP packets.
Table 1-20 OSPF configuration tasks
Configuration task
Remarks
Related section
Basic OSPF configuration
Required
1.2.4  I.
OSPF area attribute configuration
Optional
1.2.4  II.
OSPF network type configuration
Configuring the network type of an OSPF interface
Optional
1.2.4  III.
Configuring an NBMA/P2MP neighbor
Optional
1.2.4  IV.
Configuring the DR priority on an OSPF interface
Optional
1.2.4  V.
OSPF route control
Configuring OSPF route summarization
Optional
1.2.4  VI.
Configuring OSPF to filter received routes
Optional
1.2.4  VII.
Configuring OSPF interface cost
Optional
1.2.4  VIII.
Configuring OSPF route priority
Optional
1.2.4  IX.
Configuring the maximum number of OSPF ECMP routes
Optional
1.2.4  X.
Configuring OSPF to redistribute external routes
Optional
1.2.4  XI.
OSPF network adjustment and optimization
Configuring OSPF timers
Optional
1.2.4  XII.
Configuring the LSA transmission delay
Optional
1.2.4  XIII.
Configuring the SPF calculation interval
Optional
1.2.4  XIV.
Disabling OSPF packet transmission on an interface
Optional
1.2.4  XV.
Configuring OSPF authentication
Optional
1.2.4  XVI.
Configuring the MTU field in DD packets
Optional
1.2.4  XVII.
Enabling OSPF logging of neighbor state changes
Optional
1.2.4  XVIII.
Configuring OSPF network management
Optional
1.2.4  XIX.
I. Basic OSPF configuration
Table 1-21 Basic OSPF configuration
Operation
Remarks
Enter system view
Configure the router ID
router id router-id
Optional
If multiple OSPF processes run on a router, you are recommended to use the router-id keyword in the ospf command to specify different router IDs for different processes.
Enable OSPF and enter OSPF view
ospf [ process-id [ router-id router-id ] ]
Required
Enter OSPF view.
Enter OSPF area view
area area-id
Configure the network segments in the area
Required
By default, an interface does not belong to any area.
II. Configuring OSPF Area Attributes
Table 1-22 Configure OSPF area attributes
Operation
Remarks
Enter system view
Enter OSPF view
area area-id
Configure the current area to be a stub area
stub [ no-summary ]
Optional
By default, no area is configured as a stub area.
Configure the current area to be an NSSA area
nssa [ default-route-advertise | no-import-route | no-summary ] *
Optional
By default, no area is configured as an NSSA area.
Configure the cost of the default route transmitted by OSPF to a stub or NSSA area
default-cost cost
Optional
This can be configured on an ABR only. By default, the cost of the default route to a stub or NSSA area is 1.
Create and configure a virtual link
vlink-peer router-id [ hello seconds | retransmit seconds | trans-delay seconds | dead seconds | simple password | md5 keyid key ] *
Optional
For a virtual link to take effect, you need to use this command at both ends of the virtual link and ensure consistent configurations of the hello, dead, and other parameters at both ends.
III. Configuring the Network Type of an OSPF Interface
Table 1-23 Configure the network type of an OSPF interface
Operation
Remarks
Enter system view
Configure the network type of the OSPF interface
ospf network-type { broadcast | nbma | p2mp [ unicast ] | p2p }
Optional
By default, the network type of an interface depends on the physical interface.
IV. Configuring an NBMA/P2MP Neighbor
Table 1-24 Configure NBMA/P2MP neighbor
Operation
Remarks
Enter system view
Enter OSPF view
Required
Configure an NBMA/P2MP neighbor
peer ip-address [ dr-priority dr-priority ]
Required
By default, the priority for the neighbor of an NBMA interface is 1.
V. Configuring the DR Priority on an OSPF Interface
Table 1-25 Configure the DR priority on an OSPF interface
Operation
Remarks
Enter system view
Configure the DR priority on the OSPF interface
ospf dr-priority priority
Optional
The default DR priority is 1.
VI. Configuring OSPF Route Summarization
Table 1-26 Configure ABR route summarization
Operation
Remarks
Enter system view
Enter OSPF view
Enter area view
area area-id
Enable ABR route summarization
abr-summary ip-address mask [ advertise | not-advertise ]
Required
This command takes effect only when it is configured on an ABR. By default, this function is disabled on an ABR.
Table 1-27 Configure ASBR route summarization
Operation
Remarks
Enter system view
Enter OSPF view
Enable ASBR route summarization
asbr-summary ip-address mask [ not-advertise | tag value ]
Required
This command takes effect only when it is configured on an ASBR. By default, summarization of imported routes is disabled.
VII. Configuring OSPF to Filter Received Routes
Table 1-28 Configure OSPF to filter received routes
Operation
Remarks
Enter system view
Enter OSPF view
Configure to filter the received routes
filter-policy { acl-number | ip-prefix ip-prefix-name | gateway ip-prefix-name } import
Required
By default, OSPF does not filter received routing information.
VIII. Configuring the OSPF Cost on an Interface
Table 1-29 Configure the OSPF cost on an interface
Operation
Remarks
Enter system view
Configure the OSPF cost on the interface
ospf cost value
Optional
By default, the interface calculates the OSPF cost according to the current baud rate on it. For a VLAN interface on the switch, a fixed value of 10 is used.
IX. Configuring OSPF Route Priority
Table 1-30 Configure OSPF route priority
Operation
Remarks
Enter system view
Enter OSPF view
preference [ ase ] value
Optional
By default, the OSPF route priority is 10 and the priority of OSPF ASE is 150.
X. Configuring the Maximum Number of OSPF ECMP Routes
Table 1-31 Configure the maximum number of OSPF ECMP routes
Operation
Remarks
Enter system view
Enter OSPF view
multi-path-number value
Optional
3 by default.
XI. Configuring OSPF to Redistribute External Routes
Table 1-32 Configure OSPF to redistribute external routes
Operation
Remarks
Enter system view
Enter OSPF view
Configure OSPF to redistribute routes from another protocol
import-route protocol [ process-id ] [ cost value | type value | tag value | route-policy route-policy-name ] *
Required
By default, OSPF does not import the routing information of other protocols.
Configure OSPF to filter outgoing routes
Optional
By default, OSPF does not filter advertised routes.
Enable OSPF to import the default route
default-route-advertise [ always | cost value | type type-value | route-policy route-policy-name ]*
Optional
By default, OSPF does not import the default route.
Configure the default parameters for redistributed routes, including cost, interval, limit, .tag, and type
default { cost value | interval seconds | limit routes | tag tag | type type } *
Optional
These parameters respectively default to:
l      Cost: 1
l      Interval: 1 (second)
l      Limit: 1000
l      Tag: 1
l      Type: 2
XII. Configuring OSPF Timers
Table 1-33 Configure OSPF timers
Operation
Remarks
Enter system view
Configure the hello interval on the interface
ospf timer hello seconds
Optional
By default, p2p and broadcast interfaces send Hello packets every 10 seconds; while p2mp and NBMA interfaces send Hello packets every 30 seconds.
Configure the poll interval on the NBMA interface
ospf timer poll seconds
Optional
By default, poll packets are sent every 40 seconds.
Configure the dead time of the neighboring router on the interface
ospf timer dead seconds
Optional
By default, the dead time for the OSPF neighboring router on a p2p or broadcast interface is 40 seconds and that for the OSPF neighboring router on a p2mp or NBMA interface is 120 seconds.
Configure the interval for retransmitting an LSA on an interface
ospf timer retransmit interval
Optional
By default, this interval is five seconds.
XIII. Configure the LSA transmission delay
Table 1-34 Configure the LSA transmission delay
Operation
Remarks
Enter system view
ospf trans-delay seconds
Optional
By default, the LSA transmission delay is one second.
XIV. Configuring the SPF Calculation Interval
Table 1-35 Configure the SPF calculation interval
Operation
Remarks
Enter system view
Enter OSPF view
spf-schedule-interval interval
Optional
By default, the SPF calculation interval is five seconds.
XV. Disabling OSPF Packet Transmission on an Interface
Table 1-36 Disable OSPF packet transmission on an interface
Operation
Remarks
Enter system view
Enter OSPF view
Disable OSPF packet transmission on a specified interface
silent-interface silent-interface-type silent-interface-number
Optional
By default, all the interfaces are allowed to transmit OSPF packets.
XVI. Configuring OSPF Authentication
Table 1-37 Configure OSPF authentication
Operation
Remarks
Enter system view
Enter OSPF view
area area-id
Configure the authentication mode of the OSPF area
authentication-mode { simple | md5 }
Required
By default, no authentication mode is configured for an area.
Return to OSPF view
Return to system view
Configure the authentication mode of the OSPF interface
ospf authentication-mode { simple password | md5 key-id key }
Optional
By default, OSPF packets are not authenticated on an interface.
XVII. Configuring the MTU Field in DD Packets
Table 1-38 Configure to fill the MTU field when an interface transmits DD packets
Operation
Remarks
Enter system view
Enter Ethernet interface view
Required
Enable the interface to fill in the MTU field when transmitting DD packets
ospf mtu-enable
Optional
By default, the MTU value is 0 when an interface transmits DD packets. That is, the actual MTU value of the interface is not filled in.
XVIII. Enabling OSPF Logging of Neighbor State Changes
Table 1-39 Enable OSPF logging of neighbor state changes
Operation
Remarks
Enter system view
Enter OSPF view
Enable the OSPF logging of neighbor state changes
log-peer-change
Required
XIX. Configuring OSPF Network Management
Table 1-40 Configure OSPF network management (NM)
Operation
Remarks
Enter system view
Configure OSPF MIB binding
ospf mib-binding process-id
Optional
By default, OSPF MIB is bound to the first enabled OSPF process.
Enable OSPF Trap sending
snmp-agent trap enable ospf [ process-id ] [ ifauthfail | ifcfgerror | ifrxbadpkt | ifstatechange | iftxretransmit | lsdbapproachoverflow | lsdboverflow | maxagelsa | nbrstatechange | originatelsa | vifauthfail | vifcfgerror | virifrxbadpkt | virifstatechange | viriftxretransmit | virnbrstatechange ]*
Optional
You can configure OSPF to send diversified SNMP TRAP messages and specify a certain OSPF process to send SNMP TRAP messages by process ID.
Table 1-41 BGP configuration tasks
Configuration task
Remarks
Related section
Configuring Basic BGP Functions
Required
1.2.5  I.
Configuring the way to advertise/receive routing information
Importing routes
Optional
1.2.5  II.
Configuring route aggregation
Optional
1.2.5  III.
Enabling Default Route Advertising
Optional
1.2.5  IV.
Configuring route reception filtering policies
Optional
1.2.5  V.
Configure route advertisement filtering policies
Optional
1.2.5  VI.
Disable BGP-IGP Route Synchronization
Optional
1.2.5  VII.
Configuring BGP Route Dampening
Optional
1.2.5  VIII.
Configuring BGP route attributes
Optional
1.2.5  IX.
Adjusting and optimizing a BGP network
Optional
1.2.5  X.
Configure a large-scale BGP network
Configuring BGP Peer Group
Required
1.2.5  XI.
Configuring BGP Community
Required
1.2.5  XII.
Configuring BGP RR
Optional
1.2.5  XIII.
Configuring BGP Confederation
Optional
1.2.5  XIV.
I. Configuring Basic BGP Functions
Table 1-1 Configure basic BGP functions
Operation
Enter system view
Enable BGP and enter BGP view
bgp as-number
Required
By default, BGP is disabled.
Specify the AS number for the BGP peers
By default, a peer is not assigned an AS number.
Assign a description string for a BGP peer/a BGP peer group
peer { group-name | ip-address } description description-text
Optional
By default, a peer/a peer group is not assigned a description string.
Activate a specified BGP peer
peer { group-name | ip-address } enable
Optional
By default, a BGP peer is active.
Enable BGP logging
log-peer-change
Optional
By default, BGP logging is enabled.
Specify the source interface for route update packets
peer { group-name | ip-address } connect-interface interface-type interface-number
Optional
By default, the source interface of the optimal route update packets is used as the source interface.
Allow routers that belong to non-directly connected networks to establish EBGP connections.
peer group-name ebgp-max-hop [ hop-count ]
Optional
By default, routers that belong to two non-directly connected networks cannot establish EBGP connections.
You can configure the maximum hops of EBGP connection by specifying the hop-count argument.
II. Importing Routes
Table 1-2 Import routes
Operation
Enter system view
Enable BGP, and enter BGP view
bgp as-number
Import the default route to the BGP routing table
default-route imported
Optional
By default, BGP does not import default routes to BGP routing table.
Import and advertise routing information generated by other protocols.
import-route protocol [ process-id ] [ med med-value | route-policy route-policy-name ]*
Required
By default, BGP does not import nor advertise the routing information generated by other protocols.
Advertise network segment routes to BGP routing table
network network-address [ mask ] [route-policy route-policy-name ]
Optional
By default, BGP does not advertise any network segment routes.
III. Configuring BGP Route Aggregation
Table 1-3 Configure BGP route aggregation
Operation
Enter system view
bgp as-number
Required
Enable automatic route aggregation
summary
Required
By default, routes are not aggregated.
Enable manual route aggregation
aggregate ip-address mask [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ]*
IV. Enabling Default Route Advertising
Table 1-4 Enable default rout advertising
Operation
Enter system view
Enter BGP view
bgp as-number
Enable default route advertising
peer  group-name default-route-advertise [ route-policy route-policy-name ]
Required
By default, a BGP router does not send default routes to a specified peer/peer group.
V. Configuring route reception filtering policies
Table 1-5 Configure route reception filtering policies
Operation
Enter system view
Enter BGP view
bgp as-number
Configure the global route reception filtering policy
filter-policy { acl-number | gateway ip-prefix-name | ip-prefix ip-prefix-name [ gateway ip-prefix-name ] } import
Required
By default, the incoming routing information is not filtered.
Reference a routing policy to filter routes from a peer/peer group
peer { group-name | ip-address } route-policy policy-name import
Required
By default, no route filtering policy is specified for a peer/peer group.
Filter the routing information from a peer/peer group
Reference an ACL to filter BGP routes from a peer/peer group
peer { group-name | ip-address } filter-policy acl-number import
Required
By default, no ACL-based BGP route filtering policy, AS path ACL-based BGP route filtering policy, or IP prefix list-based BGP route filtering policy is configured for a peer/peer group.
Reference an AS path ACL to filter routes from a peer/peer group
peer { group-name | ip-address } as-path-acl acl-number import
Reference an IP prefix list to filter routes from a peer/peer group
peer { group-name | ip-address } ip-prefix ip-prefix-name import
VI. Configure route advertisement filtering policies
Table 1-6 Configure route advertisement filtering policies
Operation
Enter system view
Enter BGP view
bgp as-number
Configure the global route advertisement filtering policy
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] ]
Required
By default, advertised routes are not filtered.
Reference a routing policy to filter the routes to a peer group
peer group-name route-policy route-policy-name export
Required
By default, no route advertising policy is specified for the routes advertised to a peer group.
Filter the routing information to a peer group
Reference an ACL to filter BGP routes to a peer group
peer  group-name  filter-policy acl-number export
Required
Not configured by default
Reference an AS path ACL to filter BGP routes to a peer group
peer group-name  as-path-acl acl-number export
Reference an IP prefix list to filter BGP routes to a peer group
peer group-name ip-prefix ip-prefix-name export
VII. Disable BGP-IGP Route Synchronization
Table 1-7 Disable BGP-IGP route synchronization
Operation
Enter system view
Enter BGP view
bgp as-number
undo synchronization
Required
By default, BGP routes and IGP routes are not synchronized.
VIII. Configuring BGP Route Dampening
Table 1-8 Configure BGP route dampening
Operation
Enter system view
Enter BGP view
bgp as-number
Configure BGP route dampening-related parameters
dampening [ half-life-reachable half-life-unreachable reuse suppress ceiling ] [ route-policy route-policy-name ]
Required
By default, route dampening is disabled. Other default route dampening-related parameters are as follows.
l      half-life-reachable: 15 (in minutes)
l      half-life-unreachable: 15 (in minutes)
l      reuse: 750
l      suppress: 2000
l      ceiling: 16,000
IX. Configuring BGP Route Attributes
Table 1-9 Configure BGP route attributes
Operation
Enter system view
Enter BGP view
bgp as-number
Configure the management preference of the exterior, interior and local routes
preference ebgp-value  ibgp-value local-value
Optional
By default, the management preference of the exterior, interior and local routes is 256, 256, and 130.
Set the default local preference
Optional
By default, the local preference defaults to 100.
Configure the MED attribute
Configure the default local MED value
default med med-value
Optional
By default, the med-value argument is 0.
Permit to compare the MED values of the routes coming from the neighbor routers in different ASs.
compare-different-as-med
Optional
By default, the compare of MED values of the routes coming from the neighbor routers in different ASs is disabled.
Configure the local address as the next hop address when a BGP router advertises a route.
peer group-name  next-hop-local
Required
In some network, to ensure an IBGP neighbor locates the correct next hop, you can configure the next hop address of a route to be the local address for a BGP router to advertise route information to IBGP peer groups.
Configure the AS_Path attribute
Configure the number of local AS number occurrences allowed
peer { group-name | ip-address } allow-as-loop [ number ]
Optional
By default, the number of local AS number occurrences allowed is 1.
Assign an AS number for a peer group
Optional
By default, the local AS number is not assigned to a peer group.
Configure that the BGP update packets only carry the pubic AS number in the AS_Path attribute when a peer sends BGP update packets to BGP peers.
peer group-name public-as-only
Optional
By default, a BGP update packet carries the private AS number.
X. Adjusting and Optimizing a BGP Network
Table 1-10 Adjust and optimize a BGP network
Operation
Enter system view
Enter BGP view
bgp as-number
Configure BGP timer
Configure the Keepalive time and Holdtime of BGP.
timer keepalive keepalive-interval hold holdtime-interval
Optional
By default, the keepalive time is 60 seconds, and holdtime is 180 seconds. The priority of the timer configured by the timer command is lower than that of the timer configured by the peer time command.
Configure the Keepalive time and holdtime of a specified peer/peer group.
peer { group-name | ip-address } timer  keepalive keepalive-interval hold holdtime-interval
Configure the interval at which a peer group sends the same route update packet
peer group-name route-update-interval seconds
Optional
By default, the interval at which a peer group sends the same route update packet to IBGP peers is 15 seconds, and to EBGP peers is 30 seconds.
Configure the number of route prefixes that can be learned from a BGP peer/peer group
peer { group-name | ip-address } route-limit prefix-number [ { alert-only | reconnect reconnect-time } | percentage-value ] *
Optional
By default, there is no limit on the number of route prefixes that can be learned from the BGP peer/peer group.
Perform soft refreshment of BGP connection manually
return
refresh bgp { all | ip-address | group group-name } [ multicast ] { import | export }
Optional
Enter BGP view again
bgp as-number
Configure BGP to perform MD5 authentication when establishing TCP connection
peer { group-name | ip-address } password { cipher | simple } password
Optional
By default, BGP dose not perform MD5 authentication when establishing TCP connection.
XI. Configuring BGP Peer Group
Table 1-11 Configure BGP peer group
Operation
Enter system view
Enter BGP view
bgp as-number
Create an IBGP peer group
group group-name [ internal ]
Optional
If the command is executed without the internal or external keyword, an IBGP peer group will be created. You can add multiple peers to the group, and the system will automatically create a peer in BGP view, and configure its AS number as the local AS number.
Add a peer to a peer group
peer ip-address group group-name [ as-number as-number ]
Create an EBGP peer group
group group-name external
Optional
You can add multiple peers to the group. The system automatically creates the peer in BGP view and specifies its AS number as the one of the peer group.
Configure the AS number of a peer group
Create a hybrid EBGP peer group
Optional
You can add multiple peers to the peer group.
Finish the session with the specified peer/peer group
peer { group-name | ip-address } shutdown
Optional
XII. Configuring BGP Community
Table 1-12 Configure BGP community
Operation
Enter system view
Enter BGP view
bgp as-number
Configure the peers to advertise community attribute to each other
peer group-name advertise-community
Required
By default, no community attribute or extended community attribute is advertised to any peer group.
Specify routing policy for the routes exported to the peer group
Required
By default, no routing policy is specified for the routes exported to the peer group.
XIII. Configuring BGP RR
Table 1-13 Configure BGP RR
Operation
Enter system view
Enter BGP view
bgp as-number
Configure the local router as the RR and configure the peer group as the client of the RR
peer group-name reflect-client
Required
By default, no RR or its client is configured.
Enable route reflection between clients
reflect between-clients
Optional
By default, route reflection is enabled between clients.
Configure cluster ID of an RR
reflector cluster-id cluster-id
Optional
By default, an RR uses its own router ID as the cluster ID.
XIV. Configuring BGP Confederation
Table 1-14 Configure BGP confederation
Operation
Enter system view
Enter BGP view
bgp as-number
Basic BGP confederation configuration
Configure confederation ID
confederation id as-number
Required
By default, no confederation ID is configured and no sub-AS is configured for a confederation.
Specify the sub-ASs included in a confederation
Configure the compatibility of a confederation
confederation nonstandard
Optional
By default, the confederation configured is consistent with the RFC 1965.
Table 1-15 Route Policy Configuration
Configuration task
Remarks
Related section
Configure an IP-prefix list
Configuring an ip-prefix list
Optional
1.2.6  I.
AS path list configuration
Optional
1.2.6  II.
Community list configuration
Optional
1.2.6  III.
Define a routing policy
Defining a Routing Policy
Required
1.2.6  IV.
Define if-match clauses
Optional
1.2.6  V.
Define apply clauses
Optional
1.2.6  VI.
I. Configuring an ip-prefix list
Table 1-1 Configure an IPv4 IP-prefix list
Operation
Remarks
Enter system view
ip ip-prefix ip-prefix-name [ index index-number ] { permit | deny } network len [ greater-equal greater-equal | less-equal less-equal ]
Required
By default, no IP-prefix list is specified.
II. AS path list configuration
Table 1-2 AS path list configuration
Operation
Enter system view
Configure AS path list
ip as-path-acl acl-number { permit | deny } as-regular-expression
Optional
By default, no AS path list is defined
III. Community list configuration
Table 1-3 Community list configuration
Operation
Enter system view
Configure basic community list
ip community-list basic-comm-list-number { permit | deny } [ aa:nn | internet | no-export-subconfed | no-advertise | no-export ]*
Optional
By default, no BGP community list is defined
Configure advanced community list
ip community-list adv-comm-list-number { permit | deny } comm-regular-expression
Optional
IV. Defining a Routing Policy
Table 1-4 Define a routing policy
Operation
Remarks
Enter system view
Define a routing policy and enter the routing policy view
route-policy route-policy-name { permit | deny } node node-number
Required
By default, no routing policy is defined.
V. Define if-match clauses
Table 1-5 Define if-match clauses
Operation
Enter system view
Enter the route-policy view
Required
Define a rule to match AS path of BGP routing information
if-match as-path as-path-number
Optional
Define a rule to match community attributes of BGP routing information
if-match community { basic-community-number [ whole-match ] | adv-community-number }
Optional
Define a rule to match the IP address of routing information
if-match { acl acl-number | ip-prefix ip-prefix-name }
Optional
By default, no matching is performed on the address of routing information.
Define a rule to match the routing cost of routing information
if-match cost value
Optional
By default, no matching is performed on the routing cost of routing information.
Define a rule to match the next-hop interface of routing information
if-match interface interface-type interface-number
Optional
By default, no matching is performed on the next-hop interface of routing information.
Define a rule to match the next-hop address of routing information
if-match ip next-hop { acl acl-number | ip-prefix ip-prefix-name }
Optional
By default, no matching is performed on the next-hop address of routing information.
Define a rule to match the tag field of OSPF routing information
if-match tag value
Optional
By default, no matching is performed on the tag field of OSPF routing information.
VI. Define apply clauses
Table 1-6 Define apply clauses
Operation
Enter system view
Required
Add specified AS number for as-path in BGP routing information
apply as-path as-number-1 [ as-number-2 [ as-number-3 ... ] ]
Optional
Configure community attributes for BGP routing information
apply community { none | [ aa:nn ] [ no-export-subconfed | no-export | no-advertise ]* [ additive ] }
Optional
Set next hop IP address for routing information
apply ip next-hop ip-address
Optional
Set local preference of BGP routing information
apply local-preference local-preference
Optional
Define an action to set the cost of routing information
apply cost value
Optional
By default, no action is defined to set the routing cost of routing information.
Set route cost type for routing information
apply cost-type [ internal | external ]
Optional
Set route source of BGP routing information
apply origin { igp | egp as-number | incomplete }
Optional
Define an action to set the tag field of routing information
apply tag value
Optional
By default, no action is defined to set the tag field of OSPF routing information.
&  Note:
The following configuration examples use the S5600 series switches.
I. Network requirements
1)         Requirement analysis:
A small company requires any two nodes in its network communicate with each other. The network should be simple and stable. The customer hopes to make the best use of the existing devices that do not support dynamic routing protocols.
Based on the customer requirements and networking environment, configure static routes to realize network interconnection.
2)         Network diagram
Figure 2-1 shows the network diagram.
Figure 2-1 Network diagram for static route configuration
II. Configuration procedure
Configure the switches:
# Configure static routes on Switch A.
[SwitchA] ip route-static 1.1.3.0 255.255.255.0 1.1.2.2
[SwitchA] ip route-static 1.1.4.0 255.255.255.0 1.1.2.2
[SwitchA] ip route-static 1.1.5.0 255.255.255.0 1.1.2.2
# Configure static routes on Switch B.
[SwitchB] ip route-static 1.1.2.0 255.255.255.0 1.1.3.1
[SwitchB] ip route-static 1.1.5.0 255.255.255.0 1.1.3.1
[SwitchB] ip route-static 1.1.1.0 255.255.255.0 1.1.3.1
# Configure static routes on Switch C.
[SwitchC] ip route-static 1.1.1.0 255.255.255.0 1.1.2.1
[SwitchC] ip route-static 1.1.4.0 255.255.255.0 1.1.3.2
Configure the hosts:
# Configure the default gateway as 1.1.5.1 on host A (omitted).
# Configure the default gateway as 1.1.4.1 on host B (omitted).
# Configure the default gateway as 1.1.1.1 on host C (omitted).
Now any two hosts or switches can communicate with each other.
A small company requires any two nodes in its network can communicate with each other.  The devices can dynamically adjust to network topology changes.
Based on the customer requirements and networking environment, use RIP to realize network interconnection.
2)         Network diagram
Figure 2-2 shows the network diagram.
Device
IP Address
Device
IP Address
Switch A
Vlan-int1
110.11.2.1/24
Switch B
Vlan-int1
110.11.2.2/24
Vlan-int2
155.10.1.1/24
Vlan-int3
196.38.165.1/24
Switch C
Vlan-int1
110.11.2.3/24
Vlan-int4
117.102.0.1/16
Figure 2-2 Network diagram for RIP configuration
&  Note:
Only RIP-related configurations are described below. Before performing the following configurations, make sure that the data link layer works normally and the IP addresses of the VLAN interfaces have been configured.
1)         Configure Switch A.
# Configure RIP.
[SwitchA] rip
[SwitchA-rip] network 110.11.2.0
[SwitchA-rip] network 155.10.1.0
2)         Configure Switch B.
# Configure RIP.
[SwitchB] rip
[SwitchB-rip] network 196.38.165.0
[SwitchB-rip] network 110.11.2.0
3)         Configure Switch C.
# Configure RIP.
[SwitchC] rip
[SwitchC-rip] network 117.102.0.0
[SwitchC-rip] network 110.11.2.0
Use OSPF to realize interconnection between devices in a broadcast network. Devices with higher performance should become the DR and BDR to improve network performance. Devices with lower performance are forbidden to take part in DB/BDR election.
Based on the customer requirements and networking environment, assign proper priorities to interfaces.
2)         Network diagram
Figure 2-3 shows the network diagram.
Device
IP address
Router ID
Interface priority
Switch A
Vlan-int1
196.1.1.1/24
1.1.1.1
100
Switch B
Vlan-int1
196.1.1.2/24
2.2.2.2
0
Switch C
Vlan-int1
196.1.1.3/24
3.3.3.3
2
Switch D
Vlan-int1
196.1.1.4/24
4.4.4.4
1
Figure 2-3 Network diagram for OSPF DR selection
# Configure Switch A.
[SwitchA] interface Vlan-interface 1
[SwitchA-Vlan-interface1] ip address 196.1.1.1 255.255.255.0
[SwitchA-Vlan-interface1] ospf dr-priority 100
[SwitchA] router id 1.1.1.1
[SwitchA] ospf
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 196.1.1.0 0.0.0.255
# Configure Switch B.
[SwitchB] interface Vlan-interface 1
[SwitchB-Vlan-interface1] ip address 196.1.1.2 255.255.255.0
[SwitchB-Vlan-interface1] ospf dr-priority 0
[SwitchB-Vlan-interface1] quit
[SwitchB] router id 2.2.2.2
[SwitchB] ospf
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 196.1.1.0 0.0.0.255
# Configure Switch C.
[SwitchC] interface Vlan-interface 1
[SwitchC-Vlan-interface1] ip address 196.1.1.3 255.255.255.0
[SwitchC-Vlan-interface1] ospf dr-priority 2
[SwitchC-Vlan-interface1] quit
[SwitchC] router id 3.3.3.3
[SwitchC] ospf
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 196.1.1.0 0.0.0.255
# Configure Switch D.
<SwitchD> system-view
[SwitchD] interface Vlan-interface 1
[SwitchD-Vlan-interface1] ip address 196.1.1.4 255.255.255.0
[SwitchD-Vlan-interface1] quit
[SwitchD] router id 4.4.4.4
[SwitchD] ospf
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 196.1.1.0 0.0.0.255
Use the display ospf peer command to display OSPF neighbors on Switch A. Note that Switch A has three neighbors.
The state of each neighbor is full. This means that Switch A has formed adjacencies with all neighbors. (Switch A and Switch C can act as the DR and BDR only when they establish adjacencies with all the switches in the network.) Switch A acts as the DR, while Switch C acts as the BDR. Any other neighbor is DRother (neither DR nor BDR).
# Change the priority of Switch B to 200.
[SwitchB-Vlan-interface1] ospf dr-priority 200
Use the display ospf peer command to display OSPF neighbors on Switch A. Note that the priority of Switch B is 200 now, but it is not the DR.
 The DR will be reelected only after the current DR fails to work. Shut down Switch A and use the display ospf peer command to display neighbors on Switch D. Note that Switch C that used to be the BDR becomes the DR and Switch B becomes the BDR.
If you shut down and then restart all the switches, Switch B with priority 200 will be elected as the DR and Switch A with priority 100 will be elected as the BDR, because such operation triggers a new round of DR/BDR election.
Devices in the network run OSPF to realize interconnection. The network is split into three areas: one backbone area and two non-backbone areas (Area 1 and Area 2). Area 2 has no direct connection to the backbone, and it has to reach the backbone through Area 1. The customer hopes that Area 2 can interconnect with other two areas.
Based on the customer requirements and networking environment, use a virtual link to connect Area 2 to the backbone area.
2)         Network diagram
Figure 2-4 shows the network diagram.
Device
IP address
Router ID
Switch A
Vlan-int1
196.1.1.2/24
1.1.1.1
Vlan-int2
197.1.1.2/24
Switch B
Vlan-int1
152.1.1.1/24
2.2.2.2
Vlan-int2
197.1.1.1/24
Figure 2-4 Network diagram for virtual link configuration
1)         Configure OSPF basic functions
[SwitchA-Vlan-interface1] ip address 196.1.1.2 255.255.255.0
[SwitchA-Vlan-interface2] ip address 197.1.1.2 255.255.255.0
[SwitchA] ospf
[SwitchA-ospf-1] area 1
[SwitchA-ospf-1-area-0.0.0.1] network 197.1.1.0 0.0.0.255
[SwitchA-ospf-1-area-0.0.0.1] quit
[SwitchA-ospf-1] quit
[SwitchB-Vlan-interface1] ip address 152.1.1.1 255.255.255.0
[SwitchB] interface Vlan-interface 2
[SwitchB-Vlan-interface2] ip address 197.1.1.1 255.255.255.0
[SwitchB] ospf
[SwitchB-ospf-1] area 1
[SwitchB-ospf-1-area-0.0.0.1] network 197.1.1.0 0.0.0.255
[SwitchB-ospf-1-area-0.0.0.1] quit
[SwitchB-ospf-1] area 2
[SwitchB-ospf-1-area-0.0.0.2] network 152.1.1.0 0.0.0.255
[SwitchB-ospf-1-area-0.0.0.2] quit
# Display the OSPF routing table on Switch A
[SwitchA] display ospf routing
                              Routing Tables
Routing for Network
Destination             Cost Type NextHop         AdvRouter        Area
196.1.1.0/24              10 Stub 196.1.1.2       1.1.1.1          0.0.0.0
197.1.1.0/24              10 Net  197.1.1.1       2.2.2.2          0.0.0.1
Total Nets: 2
  Intra Area: 2  Inter Area: 0  ASE: 0  NSSA: 0
&  Note:
Since Area2 has no direct connection to Area0, the routing table of RouterA has no route to Area2.
2)         Configure a virtual link
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.1] vlink-peer 2.2.2.2
[SwitchB-ospf-1-area-0.0.0.1] vlink-peer 1.1.1.1
# Display the OSPF routing table on Switch A.
[SwitchA]display ospf routing
                              Routing Tables
Routing for Network
152.1.1.0/24              20 SNet 197.1.1.1       2.2.2.2          0.0.0.0
Total Nets: 3
  Intra Area: 2  Inter Area: 1  ASE: 0  NSSA: 0
Switch A has learned the route 152.1.1.0/24 to Area2.
BGP runs in a large AS of a company. As the number of IBGP peers increases rapidly in the AS, more network resources for BGP communication are occupied. The customer hopes to reduce IBGP peers and decrease the CPU and network resources consumption of BGP without affecting device performance.
Based on user requirements, configure a BGP confederation to achieve the goal.
2)         Network diagram
Figure 2-5 shows the network diagram.
Device
IP address
AS
Switch A
Vlan-int 10
172.68.10.1/24
100
Vlan-int 50
10.1.1.1/24
Switch B
Vlan-int 10
172.68.10.2/24
Switch C
Vlan-int 10
172.68.10.3/24
Vlan-int 20
172.68.1.1/24
Vlan-int 30
156.10.1.1/24
Switch D
Vlan-int 20
172.68.1.2/24
Switch E
Vlan-int 30
156.10.1.2/24
200
Vlan-int 40
8.1.1.1/24
Figure 2-5 Network diagram for BGP AS confederation configuration
3)         Configuration plan
l           Split AS 100 into three sub-ASs: AS 1001, AS 1002, and AS 1003.
l           Run EBGP between AS 1001, AS1002, and AS 1003.
l            AS 1001, AS1002, and AS 1003 are fully meshed within themselves by running IBGP.
l           Run EBGP between AS 100 and AS 200.
[SwitchA] bgp 1001
[SwitchA-bgp] network 10.1.1.0 255.255.255.0
[SwitchA-bgp] confederation id 100
[SwitchA-bgp] confederation peer-as 1002 1003
[SwitchA-bgp] group confed1002 external
[SwitchA-bgp] peer 172.68.10.2 group confed1002 as-number 1002
[SwitchA-bgp] group confed1003 external
[SwitchA-bgp] peer 172.68.10.3 group confed1003 as-number 1003
[SwitchA-bgp] quit
[SwitchB] bgp 1002
[SwitchB-bgp] confederation id 100
[SwitchB-bgp] confederation peer-as 1001 1003
[SwitchB-bgp] group confed1001 external
[SwitchB-bgp] peer 172.68.10.1 group confed1001 as-number 1001
[SwitchB-bgp] group confed1003 external
[SwitchB-bgp] peer 172.68.10.3 group confed1003 as-number 1003
[SwitchC] bgp 1003
[SwitchC-bgp] confederation id 100
[SwitchC-bgp] confederation peer-as 1001 1002
[SwitchC-bgp] group confed1001 external
[SwitchC-bgp] peer 172.68.10.1 group confed1001 as-number 1001
[SwitchC-bgp] group confed1002 external
[SwitchC-bgp] peer 172.68.10.2 group confed1002 as-number 1002
[SwitchC-bgp] group ebgp200 external
[SwitchC-bgp] peer 156.10.1.2 group ebgp200 as-number 200
[SwitchC-bgp] group ibgp1003 internal
[SwitchC-bgp] peer 172.68.1.2 group ibgp1003
[SwitchD] bgp 1003
[SwitchD-bgp] confederation id 100
[SwitchD-bgp] group ibgp1003 internal
[SwitchD-bgp] peer 172.68.1.1 group ibgp1003
# Configure Switch E.
<SwitchE> system-view
[SwitchE] bgp 200
[SwitchE-bgp] network 8.1.1.0 255.255.255.0
[SwitchE-bgp] group ebgp100 external
[SwitchE-bgp] peer 156.10.1.1 group ebgp100 as-number 100
[SwitchE-bgp] quit
# Display the BGP routing table on Switch E.
[SwitchE] display bgp routing
Flags:  # - valid       ^ - active      I - internal
        D - damped      H - history     S - aggregate suppressed
    Dest/Mask          Next-Hop        Med        Local-pref Origin Path
#^  8.1.1.0/24         0.0.0.0         0          100         IGP
#^  10.1.1.0/24        156.10.1.1      0          100         IGP   100
  Routes total: 2
# Display the BGP routing table on Switch A.
[SwitchA] display bgp routing
  I 8.1.1.0/24      156.10.1.2    0        100         IGP     (1003) 200
#^  10.1.1.0/24     0.0.0.0       0        100         IGP
  Routes total: 2
The above display shows that sub-AS routing information is advertised only within the confederation. A device in an AS outside of the confederation, such as Switch E, cannot learn the sub-AS routing information within the confederation because it treats the confederation as a single AS.
BGP runs in a large AS of a company. As the number of IBGP peers increases rapidly in the AS, more network resources for BGP communication are occupied.  The customer hopes to reduce IBGP peers and decrease CPU and network resources consumption of BGP without affecting device performance. In addition, IBGP peers are partially interconnected in the AS.
Based on the requirements and networking environment, configure a BGP route reflector to achieve the goal.
2)         Network diagram
Figure 2-6 shows the network diagram.
Device
IP address
AS
Switch A
Vlan-int 100
1.1.1.1/8
100
Vlan-int 2
192.1.1.1/24
Switch B
Vlan-int 2
192.1.1.2/24
200
Vlan-int 3
193.1.1.2/24
Switch C
Vlan-int 3
193.1.1.1/24
Vlan-int 4
194.1.1.1/24
Switch D
Vlan-int 4
194.1.1.2/24
Figure 2-6 Network diagram for BGP route reflector configuration
l           Run EBGP between the peers in AS 100 and AS 200. Advertise network 1.0.0.0/8.
l           Run IBGP between the peers in AS 200. Configure a star topology for the AS. Specify the central device as a route reflector and other devices as clients.
1)         Configure switch A.
[SwitchA] interface Vlan-interface 2
[SwitchA-Vlan-interface2] ip address 192.1.1.1 255.255.255.0
[SwitchA-Vlan-interface2] interface Vlan-interface 100
[SwitchA-Vlan-interface100] ip address 1.1.1.1 255.0.0.0
[SwitchA] bgp 100
[SwitchA-bgp] group ex external
[SwitchA-bgp] peer 192.1.1.2 group ex as-number 200
[SwitchA-bgp] network 1.0.0.0 255.0.0.0
# Configure the VLAN interface IP addresses.
[SwitchB-Vlan-interface2] ip address 192.1.1.2 255.255.255.0
[SwitchB] interface Vlan-interface 3
[SwitchB-Vlan-interface3] ip address 193.1.1.2 255.255.255.0
# Configure BGP peers.
[SwitchB] bgp 200
[SwitchB-bgp] group ex external
[SwitchB-bgp] peer 192.1.1.1 group ex as-number 100
[SwitchB-bgp] group in internal
[SwitchB-bgp] peer 193.1.1.1 group in
[SwitchC] interface Vlan-interface 3
[SwitchC-Vlan-interface3] ip address 193.1.1.1 255.255.255.0
[SwitchC] interface vlan-Interface 4
[SwitchC-Vlan-interface4] ip address 194.1.1.1 255.255.255.0
[SwitchC-Vlan-interface4] quit
# Configure BGP peers and configure Switch C as the route reflector.
[SwitchC] bgp 200
[SwitchC-bgp] group rr internal
[SwitchC-bgp] peer rr reflect-client
[SwitchC-bgp] peer 193.1.1.2 group rr
[SwitchC-bgp] peer 194.1.1.2 group rr
4)         Configure Switch D.
# Configure the VLAN interface IP address.
[SwitchD] interface Vlan-interface 4
[SwitchD-Vlan-interface4] ip address 194.1.1.2 255.255.255.0
[SwitchD-Vlan-interface4] quit
# Configure the BGP peer.
[SwitchD] bgp 200
[SwitchD-bgp] group in internal
[SwitchD-bgp] peer 194.1.1.1 group in
Use the display bgp routing command to display the BGP routing table on Switch B. Note that Switch B has learned network 1.0.0.0.
Use the display bgp routing command to display the BGP routing table on Switch D. Note that Switch D has learned network 1.0.0.0.
A network consists of two ASs, which run BGP to communicate with each other. OSPF runs in one of them.
The requirement is to control the data forwarding path from AS 200 to AS 100.
The following give two plans to meet the requirement
l           Use the MED attribute to control the forwarding path for packets from AS 200 to AS 100.
l           Use the LOCAL_PREF attribute to control the forwarding path for packets from AS 200 to AS 100
2)         Network diagram
Figure 2-7 shows the network diagram.
Device
IP address
AS
Switch A
Vlan-int 101
1.1.1.1/8
100
Vlan-int 2
192.1.1.1/24
Vlan-int 3
193.1.1.1/24
Switch B
Vlan-int 2
192.1.1.2/24
200
Vlan-int 4
194.1.1.2/24
Switch C
Vlan-int 3
193.1.1.2/24
Vlan-int 5
195.1.1.2/24
Switch D
Vlan-int 4
194.1.1.1/24
Vlan-int 5
195.1.1.1/24
Figure 2-7 Network diagram for BGP path selection
l           Run EBGP between AS 100 and AS 200. Advertise network 1.0.0.0/8.
l           Run OSPF in AS 200 to realize network interconnection.
l           Run IBGP between Switch D and Switch B as well as between Switch D and Switch C.
l           Apply a routing policy on Switch A to modify the MED attribute of the route to be advertised to AS 200, making the data forwarding path from Switch D to AS 100 as Switch D – Switch C – Switch A.
l           Apply a routing policy on Switch C to modify the LOCAL_PREF attribute of the route to be advertised to Switch D, making the data forwarding path from AS 200 to AS 100 as Switch D – Switch C – Switch A.
[SwitchA] interface Vlan-interface 3
[SwitchA-Vlan-interface3] ip address 193.1.1.1 255.255.255.0
[SwitchA-Vlan-interface3] quit
[SwitchA] interface Vlan-interface 101
[SwitchA-Vlan-interface101] ip address 1.1.1.1 255.0.0.0
# Enable BGP.
[SwitchA] bgp 100
# Advertise network 1.0.0.0/8.
[SwitchA-bgp] group ex192 external
[SwitchA-bgp] peer 192.1.1.2 group ex192 as-number 200
[SwitchA-bgp] group ex193 external
[SwitchA-bgp] peer 193.1.1.2 group ex193 as-number 200
[SwitchA-bgp] quit
# Define ACL 2000 to permit the routes destined for 1.0.0.0/8.
[SwitchA] acl number 2000
[SwitchA-acl-basic-2000] rule permit source 1.0.0.0 0.255.255.255
[SwitchA-acl-basic-2000] rule deny source any
[SwitchA-acl-basic-2000] quit
# Create a routing policy named apply_med_50, and specify node 10 with the permit matching mode for the routing policy. Set the MED value of the route matching ACL 2000 to 50.
[SwitchA] route-policy apply_med_50 permit node 10
[SwitchA-route-policy] if-match acl 2000
[SwitchA-route-policy] apply cost 50
[SwitchA-route-policy] quit
# Create a routing policy named apply_med_100, and specify node 10 with the permit matching mode for the routing policy. Set the MED value of the route matching ACL 2000 to 100.
[SwitchA] route-policy apply_med_100 permit node 10
[SwitchA-route-policy] apply cost 100
# Apply the routing policy apply_med_50 to routing updates to the peer group ex193 (the peer 193.1.1.2) and apply_med_100 to routing updates to the peer group ex192 (the peer 192.1.1.2).
[SwitchA] bgp 100
[SwitchA-bgp] peer ex193 route-policy apply_med_50 export
[SwitchA-bgp] peer ex192 route-policy apply_med_100 export
[SwitchB] interface vlan 2
[SwitchB] interface Vlan-interface 4
[SwitchB-Vlan-interface4] ip address 194.1.1.2 255.255.255.0
[SwitchB-Vlan-interface4] quit
# Configure OSPF.
[SwitchB] ospf
[SwitchB-ospf-1-area-0.0.0.0] network 194.1.1.0 0.0.0.255
[SwitchB-ospf-1] quit
# Enable BGP, create a peer group, and add peers to the peer group.
[SwitchB] bgp 200
[SwitchB-bgp] undo synchronization
[SwitchB-bgp] peer 194.1.1.1 group in
[SwitchB-bgp] peer 195.1.1.2 group in
[SwitchC-Vlan-interface3] ip address 193.1.1.2 255.255.255.0
[SwitchC] interface Vlan-interface 5
[SwitchC-Vlan-interface5] ip address 195.1.1.2 255.255.255.0
[SwitchC-Vlan-interface5] quit
# Enable OSPF.
[SwitchC] ospf
[SwitchC-ospf-1-area-0.0.0.0] network 193.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 195.1.1.0 0.0.0.255
[SwitchC-ospf-1] quit
[SwitchC] bgp 200
[SwitchC-bgp] undo synchronization
[SwitchC-bgp] group ex external
[SwitchC-bgp] peer 193.1.1.1 group ex as-number 100
[SwitchC-bgp] group in internal
[SwitchC-bgp] peer 195.1.1.1 group in
[SwitchC-bgp] peer 194.1.1.2 group in
[SwitchD-Vlan-interface4] ip address 194.1.1.1 255.255.255.0
[SwitchD] interface Vlan-interface 5
[SwitchD-Vlan-interface5] ip address 195.1.1.1 255.255.255.0
[SwitchD-Vlan-interface5] quit
# Enable OSPF.
[SwitchD] ospf
[SwitchD-ospf-1-area-0.0.0.0] network 194.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 195.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 4.0.0.0 0.255.255.255
[SwitchD-ospf-1] quit
[SwitchD] bgp 200
[SwitchD-bgp] undo synchronization
[SwitchD-bgp] peer 195.1.1.2 group in
[SwitchD-bgp] peer 194.1.1.2 group in
l           To validate the configuration, you need to use the reset bgp all command on all the BGP peers.
l           Since the MED attribute of route 1.0.0.0 learned by Switch C is smaller than that learned by Switch B, Switch D selects the route 1.0.0.0 from Switch C.
l           If you do not configure MED attribute control on Switch A, setting the local preference attribute for route 1.0.0.0 on Switch C is another choice.
[SwitchC] acl number 2000
[SwitchC-acl-basic-2000] rule permit source 1.0.0.0 0.255.255.255
[SwitchC-acl-basic-2000] rule deny source any
[SwitchC-acl-basic-2000] quit
# Create a routing policy named localpref, and specify node 10 with the permit matching mode for the routing policy. Set the local preference value of the route matching ACL 2000 to 200
[SwitchC] route-policy localpref  permit node 10
[SwitchC-route-policy] if-match acl 2000
[SwitchC-route-policy] apply local-preference 200
[SwitchC-route-policy] quit
# Create a routing policy named localpref, and specify node 20 with the permit matching mode for the routing policy. Set the local preference value of the route to 100.
[SwitchC] route-policy localpref permit node 20
[SwitchC-route-policy] apply local-preference 100
# Apply the routing policy localpref to the routing information from the peer 193.1.1.1 (Switch A).
[SwitchC] bgp 200
[SwitchC-bgp] peer 193.1.1.1 route-policy localpref import
Since the local preference (200) of the route learned by Switch C is bigger than that learned by Switch B (100), Switch D prefers the route 1.0.0.0 from Switch C. Note that the local preference is not set for route 1.0.0.0 on Switch B, so the route uses the default value 100.
&  Note:
l      For details about routing protocols, see corresponding operation manuals of products.
l      For detailed commands, see corresponding command manuals of products.
l      The following examples use S3600 and S5600 series switches.
I. Requirement analysis
An ISP has four ASs: AS 100, AS 200, AS 300, and AS 400. AS 100 is the core layer. It connects AS 200, AS 300, and AS 400 and forwards data between them. AS 200, AS 300, and AS 400 constitutes the distribution layer. They provide access services for users. The specific requirements are as follows:
l           Fast convergence is required for AS 200 and AS 400 because their networks are quite large and complicated.
l           The network of AS 300 is small and simple. The devices in the network supports only RIP. Their performances are low and the capacities of routing tables are quite limited.
l           Access users in AS 200 require a very reliable network.
l           Access users in AS 200, AS 300, and AS 400 are accessible to each other.
l           S200_10 in AS 200 is connected with Layer 2 devices.
l           S300_B in AS 300 is connected with Layer 2 devices.
l           The data forwarding path needs to be controlled when users in AS 400 access AS 200 and AS 300.
l           An AS 300 access user is interconnected with the ISP through a single link.
II. Network diagram
Figure 3-1 shows the network diagram designed according to the requirements.
Figure 3-1 Network diagram
III. Configuration plan
l           Run BGP in AS 100 to interconnect with AS 200, AS 300, and AS 400. Use the MED attribute to control the forwarding path.
l           Run OSPF in AS 200. The device in AS 200 connecting to AS 100 runs both OSPF and BGP. Use static routes as backup routes to implement link redundancy and improve network reliability. Apply a routing policy when redistributing BGP routes for filtering.
l           Run OSPF in AS 400. The device in AS 400 connecting to AS 100 runs both OSPF and BGP. Apply a routing policy when redistributing BGP routes for filtering.
l           Run RIPv2 in AS 300. The device in AS 300 connecting to AS 100 runs both RIPv2 and BGP. Apply a routing policy when redistributing BGP routes for filtering.
l           AS 300 users use the combination of static routes, RIP, and routing policy to access the ISP.
l           Interaction between IGP and BGP is involved in the configuration. Since the default BGP preference is 256, when backup routes exist in the routing table, you need to modify the BGP preference in order to select the primary route as required.
3.1.2  Devices Used for Networking
Table 3-1 Device model and device name
Model
Device name
7500
S200/S300
5600
S100_1/S100_2/S400
3600
S200_0/S200_10/S300_A/S300_B/ S400_0
&  Note:
l      Either S7500 series Ethernet switches or S5600 series Ethernet switches can serve as S100_1/S100_2/S400/S200/S300.
l      You can use other partially layer 3 capable switches as S300_B.
3.1.3  Routing Protocols and Related Parameters on Devices
Table 3-2 Routing protocols supported by devices
Device name
Routing protocol
Router ID
AS
S100_1
BGP (IBGP&EBGP)
1.1.1.1
100
S100_2
BGP (IBGP&EBGP)
1.2.1.1
S200
BGP (EBGP)/OSPF
2.1.1.1
200
S200_0
OSPF
S200_10
OSPF/STATIC
S300
BGP (EBGP)/RIPv2
3.1.1.1
300
S300_A
RIPv2/STATIC
S300_B
RIPv2
S400
BGP (EBGP)/OSPF
4.1.1.1
400
S400_0
OSPF
3.1.4  Software Version
S3600 series Ethernet switches use Release 1510.
S5600 series Ethernet switches use Release 1510.
S7500 series Ethernet switches use Release 3130.
3.2  Configuration Procedure
3.2.1  Configuration Guide
Table 3-3 Configuration guide
Configuration task
Basic Configuration
Create VLANs and configure IP addresses for VLAN interfaces
Basic RIPv2/OSPF/BGP Configuration
Basic RIPv2/OSPF/BGP configuration
RIP, Static Route, and Routing Policy Configuration Example
 Using a routing policy, configure RIP to advertise route updates but does not receive route updates and use static routing to access the ISP.
BGP and IGP Interaction Configuration Example
IGP and BGP share routes. Apply a routing policy for BGP redistribution to IGP as required
Route Backup Configuration Example
To improve network reliability, run OSPF on the primary link and run static routing on the backup link to realize interconnection
BGP MED Attribute Configuration Example
Apply a routing policy to change the MED attribute of routes to control the forwarding path
3.2.2  Basic Configuration
Creating VLANs and configuring IP addresses for VLAN interfaces are omitted here, refer to Displaying the Whole Configuration for related information.
3.2.3  Basic RIPv2/OSPF/BGP Configuration
I. Basic RIPv2 configuration
Figure 3-2 shows the relevant network diagram of AS 300.
Device
IP address
S300
Vlan-int 14
206.1.4.2/24
S300_A
Vlan-int 14
206.1.4.1/24
Vlan-int 662
166.1.2.1/24
Vlan-int 665
166.1.5.2/24
S300_B
Vlan-int 662
166.1.2.2/24
Vlan-int 623
162.1.3.1/24
Vlan-int 624
162.1.4.1/24
Figure 3-2 Network diagram for RIPv2 configuration
l           Configure S300.
# Run RIP on the interface with the IP address 206.1.4.0.
<S300> system-view
[S300] rip
[S300-rip] network 206.1.4.0
# Disable RIPv2 route summarization.
[S300-rip] undo summary
[S300-rip] quit
# Run RIPv2 on VLAN-interface 14.
[S300] interface vlan-interface 14
[S300-Vlan-interface14] rip version 2
[S300-Vlan-interface14] quit
l           Configure S300_A.
# Run RIP on the interfaces on networks 206.1.4.0 and 166.1.0.0.
<S300_A> system-view
[S300_A] rip
[S300_A-rip] network 206.1.4.0
[S300_A-rip] network 166.1.0.0
[S300_A-rip] undo summary
[S300_A-rip] quit
# Run RIPv2 on VLAN-interface 14 and VLAN-interface 662.
[S300_A] interface vlan-interface 14
[S300_A-Vlan-interface14] rip version 2
[S300_A-Vlan-interface14] quit
[S300_A] interface vlan-interface 662
[S300_A-Vlan-interface662] rip version 2
[S300_A-Vlan-interface662] quit
l           Configure S300_B.
# Run RIP on the interfaces connected to networks 162.1.0.0 and 166.1.0.0.
<S300_B> system-view
[S300_B] rip
[S300_B-rip] network 162.1.0.0
[S300_B-rip] network 166.1.0.0
[S300_B-rip] undo summary
[S300_B-rip] quit
# Run RIPv2 on VLAN-interface 623, VLAN-interface 624, and VLAN-interface 662.
[S300_B] interface vlan-interface 623
[S300_B-Vlan-interface623] rip version 2
[S300_B-Vlan-interface623] quit
[S300_B] interface vlan-interface 624
[S300_B-Vlan-interface624] rip version 2
[S300_B-Vlan-interface624] quit
[S300_B] interface vlan-interface 662
[S300_B-Vlan-interface662] rip version 2
[S300_B-Vlan-interface662] quit
II. Basic OSPF configuration
Figure 3-3 shows the relevant network diagram of AS 200.
Device
IP address
Area
S200
Vlan-int 12
206.1.2.3/24
0
S200_0
Vlan-int 12
206.1.2.1/24
0
Vlan-int 661
166.1.1.1/24
10
S200_10
Vlan-int 661
166.1.1.2/24
10
Vlan-int 621
162.1.1.1/24
10
Vlan-int 622
162.1.2.1/24
10
Figure 3-3 Network diagram for OSPF configuration
l           Configure S200.
# Run OSPF on the interface connected to network 206.1.2.0/24 and specify its area ID as 0.
<S200> system-view
[S200] ospf
[S200-ospf-1] area 0
[S200-ospf-1-area-0.0.0.0] network 206.1.2.0 0.0.0.255
l           Configure S200_0.
<S200_0> system-view
[S200_0] ospf
[S200_0-ospf-1] area 0
[S200_0-ospf-1-area-0.0.0.0] network 206.1.2.0 0.0.0.255
[S200_0-ospf-1-area-0.0.0.0] quit
# Run OSPF on the interface connected to network 166.1.1.0/24 and specify its area ID as 10.
[S200_0-ospf-1] area 10
[S200_0-ospf-1-area-0.0.0.10] network 166.1.1.0 0.0.0.255
l           Configure S200_10.
# Run OSPF on interfaces connected to networks 162.1.1.0/24, 162.1.2.0/24, and 166.1.1.0/24 and specify their area ID as 10.
<S200_10> system-view
[S200_10] ospf
[S200_10-ospf-1] area 10
[S200_10-ospf-1-area-0.0.0.10] network 162.1.1.0 0.0.0.255
[S200_10-ospf-1-area-0.0.0.10] network 162.1.2.0 0.0.0.255
[S200_10-ospf-1-area-0.0.0.10] network 166.1.1.0 0.0.0.255
Figure 3-4 shows the network diagram of AS 400.
Device
IP address
Area
S400
Vlan-int 16
206.1.6.3/24
0
S400_0
Vlan-int 16
206.1.6.1/24
0
Vlan-int 663
166.1.3.1/24
0.0.1.44
Vlan-int 664
166.1.4.1/24
0.0.1.44
Figure 3-4 Network diagram for AS 400 configuration
l           Configure S400.
# Run OSPF on the interface connected to network 206.1.6.0/24 and specify its area ID as 0.
<S400> system-view
[S400] ospf
[S400-ospf-1] area 0
[S400-ospf-1-area-0.0.0.0] network 206.1.6.0 0.0.0.255
l           Configure S400_0.
<S400_0> system-view
[S400_0] ospf
[S400_0-ospf-1] area 0
[S400_0-ospf-1-area-0.0.0.0] network 206.1.6.0 0.0.0.255
[S400_0-ospf-1-area-0.0.0.0] quit
# Run OSPF on interfaces connected to networks 166.1.3.0/24 and 166.1.4.0/24 and specify their area ID as 0.0.1.44.
[S400_0-ospf-1] area 0.0.1.44
[S400_0-ospf-1-area-0.0.1.44] network 166.1.3.0 0.0.0.255
[S400_0-ospf-1-area-0.0.1.44] network 166.1.4.0 0.0.0.255
III. Basic BGP configuration
Figure 3-5 shows the relevant network diagram.
Device
IP address
Router ID
AS
S100_1
Vlan-int 11
196.1.1.1/24
1.1.1.1
100
Vlan-int 15
196.1.3.1/24
Vlan-int 31
196.3.1.1/24
S100_2
Vlan-int 22
196.2.2.1/24
1.2.1.1
Vlan-int 23
196.2.3.2/24
Vlan-int 31
196.3.1.2/24
S200
Vlan-int 11
196.1.1.3/24
2.1.1.1
200
Vlan-int 13
206.1.3.3/24
S300
Vlan-int 22
196.2.2.2/24
3.1.1.1
300
Vlan-int 13
206.1.3.2/24
S400
Vlan-int 15
196.1.3.3/24
4.1.1.1
400
Vlan-int 23
196.2.3.3/24
Figure 3-5 Network diagram for BGP configuration
l           Configure S100_1.
# Configure the router ID of S100_1 as 1.1.1.1.
<S100_1> system-view
[S100_1] router id 1.1.1.1
# Enable BGP and specify the local AS number as 100.
[S100_1] bgp 100
# Create IBGP peer group 100 and EBGP peer groups 200 and 400.
[S100_1-bgp] group 100 internal
[S100_1-bgp] group 200 external
[S100_1-bgp] group 400 external
# Add peer 196.3.1.2 in AS 100 into peer group 100; Add peer 196.1.1.3 in AS 200 into peer group 200; Add peer 196.1.3.3 in AS 400 into peer group 400.
[S100_1-bgp] peer 196.3.1.2 group 100
[S100_1-bgp] peer 196.1.1.3 group 200 as-number 200
[S100_1-bgp] peer 196.1.3.3 group 400 as-number 400
# Advertise networks 196.1.3.0, 196.3.1.0, and 196.1.1.0.
[S100_1-bgp] network 196.1.3.0
[S100_1-bgp] network 196.3.1.0
[S100_1-bgp] network 196.1.1.0
# Set the preferences of EBGP routes, IBGP routes, and local routes to 200.
[S100_1-bgp] preference 200 200 200
l           Configure S100_2.
# Configure the router ID of S200_2 as 1.2.1.1.
<S100_2> system-view
[S100_2] router id 1.2.1.1
[S100_2] bgp 100
# Create IBGP peer group 100 and EBGP peer groups 300 and 400.
[S100_2-bgp] group 100 internal
[S100_2-bgp] group 300 external
[S100_2-bgp] group 400 external
# Add peer 196.3.1.1 in AS 100 into peer group 100; Add peer 196.2.2.2 in AS 300 into peer group 300; Add peer 196.2.3.3 in AS 400 into peer group 400.
[S100_2-bgp] peer 196.3.1.1 group 100
[S100_2-bgp] peer 196.2.2.2 group 300 as-number 300
[S100_2-bgp] peer 196.2.3.3 group 400 as-number 400
# Advertise networks 196.2.2.0, 196.2.3.0, and 196.3.1.0.
[S100_2-bgp] network 196.2.2.0
[S100_2-bgp] network 196.2.3.0
[S100_2-bgp] network 196.3.1.0
[S100_2-bgp] preference 200 200 200
l           Configure S200.
# Configure the router ID of S200 as 2.1.1.1.
<S200> system-view
[S200] router id 2.1.1.1
# Enable BGP and specify the local AS number as 200.
[S200] bgp 200
# Create EBGP peer groups 100 and 300.
[S200-bgp] group 100 external
[S200-bgp] group 300 external
# Add peer 196.1.1.1 in AS 100 into peer group 100; Add peer 206.1.3.2 in AS 300 into peer group 300.
[S200-bgp] peer 196.1.1.1 group 100 as-number 100
[S200-bgp] peer 206.1.3.2 group 300 as-number 300
# Advertise networks 192.1.1.0 and 206.1.3.0.
[S200-bgp] network 192.1.1.0
[S200-bgp] network 206.1.3.0
[S200-bgp] preference 200 200 200
l           Configure S300.
# Configure the router ID of S300 as 3.1.1.1.
<S300> system-view
[S300] router id 3.1.1.1
# Enable BGP and specify the local AS number as 300.
[S300] bgp 300
# Create EBGP peer groups 100 and 200.
[S300-bgp] group 100 external
[S300-bgp] group 200 external
# Add peer 196.2.2.1 in AS 100 into peer group 100; Add peer 206.1.3.3 in AS 200 into peer group 200.
[S300-bgp] peer 196.2.2.1 group 100 as-number 100
[S300-bgp] peer 206.1.3.3 group 200 as-number 200
# Advertise networks 206.1.3.0 and 196.2.2.0.
[S300-bgp] network 206.1.3.0
[S300-bgp] network 196.2.2.0
[S300-bgp] preference 200 200 200
l           Configure S400.
# Configure the router ID of S400 as 4.1.1.1.
<S400> system-view
[S400] router id 4.1.1.1
# Enable BGP and specify the local AS number as 400.
[S400] bgp 400
# Create EBGP peer groups 100_1 and 100_2.
[S400-bgp] group 100_1 external
[S400-bgp] group 100_2 external
# Add peer 196.1.3.1 in AS 100 into peer group 100_1; Add peer 196.2.3.2 in AS 100 into peer group 100_2.
[S400-bgp] peer 196.1.3.1 group 100_1 as-number 100
[S400-bgp] peer 196.2.3.2 group 100_2 as-number 100
# Advertise networks 196.1.3.0 and 196.2.3.0.
[S400-bgp] network 196.1.3.0
[S400-bgp] network 196.2.3.0
[S400-bgp] preference 200 200 200
3.2.4  RIP, Static Route, and Routing Policy Configuration Example
As shown in Figure 3-6, RIPv2 runs on S300_A/S300_B. To control the number of routes learned by S300_B through RIP, allow S300_B to advertise routes to S300_A and forbid S300_B to receive routes advertised by S300_A. Packets from S300_B to S300_A are forwarded through the default route.
II. Network diagram
Device
IP address
S300_A
Vlan-int 662
166.1.2.1/24
S300_B
Vlan-int 662
166.1.2.2/24
Vlan-int 623
162.1.3.1/24
Vlan-int 624
162.1.4.1/24
Figure 3-6 Network diagram for RIP, static route, and routing policy configuration
III. Configuration procedure
# Create ACL 2000 and deny all packets.
[S300_B] acl number 2000
[S300_B-acl-basic-2000] rule deny source any
[S300_B-acl-basic-2000] quit
# Apply ACL 2000 to incoming RIP routes.
[S300_B] rip
[S300_B-rip] filter-policy 2000 import
# Configure a default route and specify the next-hop IP address as 166.1.2.1.
[S300_B] ip route-static 0.0.0.0 0.0.0.0 166.1.2.1 preference 60
3.2.5  BGP and IGP Interaction Configuration Example
As shown in Figure 3-7, OSPF and BGP run on S400/S200. RIPv2 and BGP run on S300. To ensure that devices in each AS can learn network topologies of other ASs, configure interaction between IGP and BGP to share routes. When redistributing routes from IGP to BGP, apply a routing policy to redistribute routes with IP prefixes 162.1.1.0/24, 162.1.2.0/24, 162.1.3.0/24, 162.1.4.0/24, 166.1.3.0/24, and 166.1.4.0/24 only.
II. Network diagram
Figure 3-7 Network diagram for BGP and IGP interaction
l           Configure interaction between IGP and BGP on S200.
# Redistribute OSPF routes into BGP.
<S200> system-view
[S200] bgp 200
[S200-bgp] import-route ospf 1
[S200-bgp] quit
# Define a prefix list named ospf_import and permit the routes with IP prefixes 162.1.3.0/24, 162.1.4.0/24, 166.1.3.0/24, or 166.1.4.0/24.
[S200] ip ip-prefix ospf_import index 10 permit 162.1.3.0 24
[S200] ip ip-prefix ospf_import index 20 permit 162.1.4.0 24
[S200] ip ip-prefix ospf_import index 30 permit 166.1.4.0 24
[S200] ip ip-prefix ospf_import index 40 permit 166.1.3.0 24
# Create a routing policy named ospf_import with the match mode as permit. Define an if-match clause to permit routes whose destination addresses match IP prefix list ospf_import.
[S200] route-policy ospf_import permit node 10
[S200-route-policy] if-match ip-prefix ospf_import
[S200-route-policy] quit
# Redistribute BGP routes into OSPF and apply routing policy ospf_import.
[S200] ospf
[S200-ospf-1] import-route bgp route-policy ospf_import
l           Configure interaction between IGP and BGP on S300.
# Redistribute RIP routes into BGP.
<S300> system-view
[S300] bgp 300
[S300-bgp] import-route rip
[S300-bgp] quit
# Define a prefix list named rip_import and permit the routes with IP prefixes 162.1.1.0/24, 162.1.2.0/24, 166.1.3.0/24, and 166.1.4.0/24.
[S300] ip ip-prefix rip_import index 10 permit 162.1.1.0 24
[S300] ip ip-prefix rip_import index 20 permit 162.1.2.0 24
[S300] ip ip-prefix rip_import index 30 permit 166.1.3.0 24
[S300] ip ip-prefix rip_import index 40 permit 166.1.4.0 24
# Create a routing policy named rip_import with the matching mode as permit. Define an if-match clause to permit routes whose destination addresses match IP prefix list rip_import.
[S300] route-policy rip_import permit node 10
[S300-route-policy] if-match ip-prefix rip_import
[S300-route-policy] quit
# Redistribute BGP routes into RIP and apply routing policy rip_import.
[S300] rip
[S300-rip] import-route bgp route-policy rip_import
l           Configure interaction between IGP and BGP on S400.
<S400> system-view
[S400] bgp 400
[S400-bgp] import-route ospf 1
[S400-bgp] quit
# Define a prefix list named ospf_import and permit the routes with IP prefixes 162.1.1.0/24, 162.1.2.0/24, 162.1.3.0/24, and 162.1.4.0/24.
[S400] ip ip-prefix ospf_import index 10 permit 162.1.1.0 24
[S400] ip ip-prefix ospf_import index 20 permit 162.1.2.0 24
[S400] ip ip-prefix ospf_import index 30 permit 162.1.3.0 24
[S400] ip ip-prefix ospf_import index 40 permit 162.1.4.0 24
# Create a routing policy named ospf_import with the match mode as permit. Define an if-match clause to permit the routes whose destination addresses match IP prefix list ospf_import.
[S400] route-policy ospf_import permit node 10
[S400-route-policy] if-match ip-prefix ospf_import
[S400-route-policy] quit
# Redistribute BGP routes into OSPF and apply the routing policy named ospf_import.
[S400] ospf
[S400-ospf-1] import-route bgp route-policy ospf_import
3.2.6  Route Backup Configuration Example
As shown in Figure 3-8, implement route backup on S200_10. Run OSPF between S200_10 and S200_0. The OSPF route is the primary route. Configure a default route between S200_10 and S300_A. This route is the backup route. When the primary route cannot work, the device switches to the backup route automatically. When the primary route becomes feasible, the device switches to the primary route automatically. To achieve the route backup of S200_10, configure a static route to S200_10 on S300_A and redistribute this route into RIPv2.
II. Network diagram
Device
IP address
AS
S300_A
Vlan-int 665
166.1.5.2/24
300
S200_10
Vlan-int 665
166.1.5.1/24
200
Vlan-int 621
162.1.1.1/24
Vlan-int 622
162.1.2.1/24
Figure 3-8 Network diagram for route backup
# Configure a default route on S200_10 and specify the next-hop IP address as 166.1.5.2. Set the default preference to 200.
[S200_10] ip route-static 0.0.0.0 0.0.0.0 166.1.5.2 preference 200
# Configure a static route on S300_A and specify the destination IP addresses as 162.1.1.0/24 and 162.1.2.0/24. Specify the next-hop IP address as 166.1.5.1 and the default preference to 200.
[S300_A] ip route-static 162.1.1.0 255.255.255.0 166.1.5.1 preference 200
[S300_A] ip route-static 162.1.2.0 255.255.255.0 166.1.5.1 preference 200
# Redistribute the static route into RIP.
[S300_A] rip
[S300_A-rip] import-route static
3.2.7  BGP MED Attribute Configuration Example
As shown in Figure 3-9, S100_1 forwards packets from S400 to S200_10. S100_2 forwards packets from S400 to S300_B. Modify the MED value to achieve this goal.
II. Network diagram
Device
IP address
AS
S200_10
Vlan-int 621
162.1.1.1/24
200
Vlan-int 622
162.1.2.1/24
S300_B
Vlan-int 623
162.1.3.1/24
300
Vlan-int 624
162.1.4.1/24
S400_0
Vlan-int 663
166.1.3.1/24
400
Vlan-int 664
166.1.4.1/24
Figure 3-9 Network diagram for MED attribute configuration
l           Configure S100_1.
# Define a prefix list named as200_1 and permit the route with IP prefix 162.1.1.0/24.
[S100_1] ip ip-prefix as200_1 index 10 permit 162.1.1.0 24
# Define a prefix list named as200_2 and permit the route with IP prefix 162.1.2.0/24.
[S100_1] ip ip-prefix as200_2 index 10 permit 162.1.2.0 24
# Define a prefix list named as300_1 and permit the route with IP prefix 162.1.3.0/24.
[S100_1] ip ip-prefix as300_1 index 10 permit 162.1.3.0 24
# Define a prefix list named as300_2 and permit the route with IP prefix 162.1.4.0/24.
[S100_1] ip ip-prefix as300_2 index 10 permit 162.1.4.0 24
# Define a prefix list named other and permit all the routes.
[S100_1] ip ip-prefix other index 10 permit 0.0.0.0 0 less-equal 32
# Create a routing policy named as200, and specify node 10 with the permit matching mode in the routing policy. Set the MED value of the route matching prefix list as200_1 to 100.
[S100_1] route-policy as200 permit node 10
[S100_1-route-policy] if-match ip-prefix as200_1
[S100_1-route-policy] apply cost 100
[S100_1-route-policy] quit
# Create node 20 with the matching mode as permit in routing policy as200.  Set the MED value of the route matching prefix list as200_2 to 100
[S100_1] route-policy as200 permit node 20
[S100_1-route-policy] if-match ip-prefix as200_2
# Create node 30 with the permit matching mode in routing policy as200.  Set the MED value of the route matching prefix list as300_1 to 200.
[S100_1] route-policy as200 permit node 30
[S100_1-route-policy] if-match ip-prefix as300_1
[S100_1-route-policy] apply cost 200
# Create node 40 with the permit matching mode in routing policy as200.  Set the MED value of the route matching prefix list as300_2 to 200.
[S100_1] route-policy as200 permit node 40
[S100_1-route-policy] if-match ip-prefix as300_2
# Create node 50 with the permit matching mode in routing policy as200. Permit all the routes.
[S100_1] route-policy as200 permit node 50
[S100_1-route-policy] if-match ip-prefix other
# Apply the routing policy as200 to the routes outgoing to peer group 400 (the peer 196.1.3.3).
[S100_1] bgp 100
[S100_1-bgp] peer 400 route-policy as200 export
l           Configure S100_2.
[S100_2] ip ip-prefix as200_1 index 10 permit 162.1.1.0 24
[S100_2] ip ip-prefix as200_2 index 10 permit 162.1.2.0 24
[S100_2] ip ip-prefix as300_1 index 10 permit 162.1.3.0 24
[S100_2] ip ip-prefix as300_2 index 10 permit 162.1.4.0 24
[S100_2] ip ip-prefix other index 10 permit 0.0.0.0 0 less-equal 32
# Create a routing policy named as300. Configure the node number as 10 and the matching mode as permit.  Set the MED value of the route matching prefix list as200_1 to 200.
[S100_2] route-policy as300 permit node 10
[S100_2-route-policy] if-match ip-prefix as200_1
[S100_2-route-policy] apply cost 200
[S100_2-route-policy] quit
# Create node 20 with the permit matching mode in routing policy as300. Set the MED value of the route matching prefix list as200_2 to 200.
[S100_2] route-policy as300 permit node 20
[S100_2-route-policy] if-match ip-prefix as200_2
# Create node 30 with the permit matching mode in routing policy as300.  Set the MED value of the route matching prefix list as300_1 to 100.
[S100_2] route-policy as300 permit node 30
[S100_2-route-policy] if-match ip-prefix as300_1
[S100_2-route-policy] apply cost 100
# Create node 40 with the permit matching mode in routing policy as300.  Set the MED value of the route matching prefix list as300_2 to 100.
[S100_2] route-policy as300 permit node 40
[S100_2-route-policy] if-match ip-prefix as300_2
# Create node 50 with the permit matching mode in routing policy as300 and permit all routes.
[S100_2] route-policy as300 permit node 50
[S100_2-route-policy] if-match ip-prefix other
# Apply routing policy as300 to the routes outgoing to peer group 400 (peer 196.2.3.3).
[S100_2] bgp 100
[S100_2-bgp] peer 400 route-policy as300 export
3.3  Displaying the Whole Configuration on Devices
3.3.1   Displaying the Whole Configuration on Devices
I. S100_1
<S100_1> display current-configuration
 sysname S100_1
 router id 1.1.1.1
vlan 11
vlan 15
vlan 31
interface Vlan-interface11
interface Vlan-interface15
 ip address 196.1.3.1 255.255.255.0
interface Vlan-interface31
 ip address 196.3.1.1 255.255.255.0
 undo fabric-port Cascade1/2/1 enable
 undo fabric-port Cascade1/2/2 enable
interface NULL0
bgp 100
 network 196.1.3.0
 network 196.3.1.0
 network 196.1.1.0
 group 100 internal
 group 200 external
 group 400 external
 apply cost 100
 apply cost 100
 apply cost 200
 apply cost 200
II. S100_2
<S100_2> display current-configuration
 sysname S100_2
 router id 1.2.1.1
vlan 22
vlan 23
vlan 31
interface Vlan-interface22
 ip address 196.2.2.1 255.255.255.0
interface Vlan-interface23
 ip address 196.2.3.2 255.255.255.0
 ip address 196.3.1.2 255.255.255.0
interface Cascade1/2/1
interface Cascade1/2/2
interface NULL0
bgp 100
 network 196.2.2.0
 network 196.2.3.0
 network 196.3.1.0
 group 100 internal
 group 300 external
 group 400 external
 apply cost 200
 apply cost 200
 apply cost 100
 apply cost 100
III. S200
<S200> display current-configuration
 sysname S200
 router id 2.1.1.1
vlan 11
vlan 12
vlan 13
interface Vlan-interface12
 ip address 206.1.2.3 255.255.255.0
interface Vlan-interface13
 ip address 206.1.3.3 255.255.255.0
bgp 200
 network 192.1.1.0
 network 206.1.3.0
 import-route ospf 1
 group 100 external
 group 300 external
ospf 1
 area 0.0.0.0
IV. S200_0
<S200_0> display current-configuration
 sysname S200_0
vlan 12
vlan 661
 ip address 206.1.2.1 255.255.255.0
interface Vlan-interface661
 ip address 166.1.1.1 255.255.255.0
ospf 1
 area 0.0.0.10
 area 0.0.0.0
V. S200_10
<S200_10> display current-configuration
 sysname S200_10
vlan 621 to 622
vlan 661
vlan 665
interface Vlan-interface621
 ip address 162.1.1.1 255.255.255.0
interface Vlan-interface622
 ip address 162.1.2.1 255.255.255.0
 ip address 166.1.1.2 255.255.255.0
interface Vlan-interface665
 ip address 166.1.5.1 255.255.255.0
ospf 1
 area 0.0.0.10
VI. S300
<S300> display current-configuration
 sysname S300
router id 3.1.1.1
vlan 13
vlan 14
vlan 22
 ip address 206.1.3.2 255.255.255.0
interface Vlan-interface14
 ip address 206.1.4.2 255.255.255.0
 rip version 2 multicast
 ip address 196.2.2.2 255.255.255.0
bgp 300
 network 206.1.3.0
 network 196.2.2.0
 import-route rip
 group 100 external
 group 200 external
rip
 undo summary
 network 206.1.4.0
VII. S300_A
<S300_A> display current-configuration
 sysname S300_A
vlan 14
vlan 662
vlan 665
 ip address 206.1.4.1 255.255.255.0
interface Vlan-interface662
 ip address 166.1.2.1 255.255.255.0
 ip address 166.1.5.2 255.255.255.0
rip
 undo summary
 network 206.1.4.0
 network 166.1.0.0
 import-route static
VIII. S300_B
<S300_B> display current-configuration
 sysname S300_B
acl number 2000
 rule 5 deny
vlan 623
vlan 624
vlan 662
interface Vlan-interface623
 ip address 162.1.3.1 255.255.255.0
interface Vlan-interface624
 ip address 162.1.4.1 255.255.255.0
 ip address 166.1.2.2 255.255.255.0
rip
 undo summary
 network 166.1.0.0
 network 162.1.0.0
IX. S400
<S400> display current-configuration
 sysname S400
 router id 4.1.1.1
vlan 15 to 16
vlan 23
 ip address 196.1.3.3 255.255.255.0
interface Vlan-interface16
 ip address 206.1.6.3 255.255.255.0
 ip address 196.2.3.3 255.255.255.0
interface NULL0
bgp 400
 network 196.1.3.0
 network 196.2.3.0
 import-route ospf 1
ospf 1
 area 0.0.0.0
 ip as-path-acl 1 permit ^100 200$
 ip as-path-acl 2 permit ^100 300$
X. S400_0
<S400_0> display current-configuration
 sysname S400_0
vlan 16
vlan 663 to 664
 ip address 206.1.6.1 255.255.255.0
interface Vlan-interface663
 ip address 166.1.3.1 255.255.255.0
interface Vlan-interface664
 ip address 166.1.4.1 255.255.255.0
ospf 1
 area 0.0.1.44
 area 0.0.0.0
3.4  Verifying the Configuration
3.4.1  Verifying the Configuration of Routing Policy and Static Routes
<S300_B> display ip routing-table
 Routing Table: public net
Destination/Mask   Protocol Pre  Cost  Nexthop     Interface
0.0.0.0/0            STATIC   60    0     166.1.2.1   Vlan-interface662
127.0.0.0/8          DIRECT   0     0     127.0.0.1   InLoopBack0
127.0.0.1/32         DIRECT   0     0         127.0.0.1   InLoopBack0
162.1.3.0/24         DIRECT   0     0     162.1.3.1   Vlan-interface623
162.1.3.1/32         DIRECT   0     0     127.0.0.1   InLoopBack0
162.1.4.0/24         DIRECT   0     0     162.1.4.1   Vlan-interface624
162.1.4.1/32         DIRECT   0     0     127.0.0.1   InLoopBack0
166.1.2.0/24         DIRECT   0     0     166.1.2.2   Vlan-interface662
166.1.2.2/32         DIRECT   0     0     127.0.0.1   InLoopBack0
<S300_B> tracert -a 162.1.3.1 166.1.4.1
 traceroute to 166.1.4.1(166.1.4.1) 30 hops max,40 bytes packet
 1 166.1.2.1 18 ms  3 ms  3 ms
 2 206.1.4.2 9 ms  4 ms  4 ms
 3 196.2.2.1 9 ms  9 ms  18 ms
 4 196.2.3.3 6 ms  3 ms  4 ms
 5 206.1.6.1 14 ms  4 ms  3 ms
3.4.2  Verifying the BGP and IGP Interaction Configuration
<S400_0> display ip routing-table
162.1.1.0/24       O_ASE     150   1       206.1.6.3    Vlan-interface16
162.1.2.0/24       O_ASE     150   1       206.1.6.3    Vlan-interface16
162.1.3.0/24       O_ASE     150   1       206.1.6.3    Vlan-interface16
162.1.4.0/24       O_ASE     150   1       206.1.6.3    Vlan-interface16
166.1.3.0/24       DIRECT    0     0       166.1.3.1    Vlan-interface663
166.1.3.1/32       DIRECT    0     0       127.0.0.1    InLoopBack0
166.1.4.0/24       DIRECT    0     0       166.1.4.1    Vlan-interface664
166.1.4.1/32       DIRECT    0     0       127.0.0.1    InLoopBack0
192.168.0.0/24     DIRECT    0     0      192.168.0.30 Vlan-interface1
192.168.0.30/32    DIRECT    0     0      127.0.0.1    InLoopBack0
206.1.6.0/24       DIRECT     0     0      206.1.6.1    Vlan-interface16
206.1.6.1/32       DIRECT     0     0      127.0.0.1    InLoopBack0
<S300_A> display ip routing-table
162.1.1.0/24       RIP       100  1       206.1.4.2       Vlan-interface14
162.1.2.0/24       RIP       100  1       206.1.4.2       Vlan-interface14
162.1.3.0/24       RIP       100  1       166.1.2.2       Vlan-interface662
162.1.4.0/24       RIP       100  1       166.1.2.2       Vlan-interface662
166.1.2.0/24       DIRECT     0    0      166.1.2.1       Vlan-interface662
166.1.2.1/32       DIRECT    0    0      127.0.0.1       InLoopBack0
166.1.3.0/24       RIP        100  1       206.1.4.2       Vlan-interface14
166.1.4.0/24       RIP         100  1         206.1.4.2       Vlan-interface14
166.1.5.0/24       DIRECT    0    0      166.1.5.2       Vlan-interface665
166.1.5.2/32       DIRECT    0    0      127.0.0.1       InLoopBack0
206.1.4.0/24       DIRECT    0    0      206.1.4.1       Vlan-interface14
206.1.4.1/32       DIRECT   0    0        127.0.0.1       InLoopBack0
<S200_10> display ip routing-table
0.0.0.0/0         STATIC    200  0      166.1.5.2   Vlan-interface665
162.1.1.0/24       DIRECT      0    0      162.1.1.1   Vlan-interface621
162.1.1.1/32       DIRECT      0    0      127.0.0.1   InLoopBack0
162.1.2.0/24       DIRECT      0    0     162.1.2.1    Vlan-interface622
162.1.2.1/32       DIRECT    0    0      127.0.0.1   InLoopBack0
162.1.3.0/24       O_ASE     150  1      166.1.1.1   Vlan-interface661
162.1.4.0/24       O_ASE     150  1      166.1.1.1   Vlan-interface661
166.1.1.0/24       DIRECT    0    0      166.1.1.2   Vlan-interface661
166.1.1.2/32       DIRECT    0    0      127.0.0.1   InLoopBack0
166.1.3.0/24       O_ASE     150  1      166.1.1.1   Vlan-interface661
166.1.4.0/24       O_ASE     150  1      166.1.1.1   Vlan-interface661
166.1.5.0/24       DIRECT    0    0      166.1.5.1   Vlan-interface665
166.1.5.1/32       DIRECT    0    0      127.0.0.1   InLoopBack0
206.1.2.0/24       OSPF      10   20     166.1.1.1   Vlan-interface661
3.4.3  Verifying the Route Backup Configuration
I. Verify the primary route is installed into the routing table
<S200_10> tracert -a 162.1.1.1 166.1.3.1
 traceroute to  166.1.3.1(166.1.3.1) 30 hops max,40 bytes packet
 1 166.1.1.1 10 ms  3 ms  3 ms
 2 206.1.2.3 13 ms  3 ms  5 ms
 3 196.1.1.1 9 ms  3 ms  4 ms
 4 196.1.3.3 12 ms  3 ms  3 ms
 5 206.1.6.1 14 ms  5 ms  3 ms
II. Verify the backup route is installed into the routing table after the primary one fails
 1 166.1.5.2 11 ms  3 ms  4 ms
 2 206.1.4.2 13 ms  3 ms  4 ms
 3 196.2.2.1 13 ms  3 ms  6 ms
 4 196.2.3.3 11 ms  3 ms  4 ms
 5 206.1.6.1 12 ms  3 ms  4 ms
3.4.4  Verifying the MED Attribute Configuration
I. Trace the packet forwarding path when the default MED is used
<S400_0> tracert -a 166.1.3.1 162.1.1.1
 traceroute to  162.1.1.1(162.1.1.1) 30 hops max,40 bytes packet
 1 206.1.6.3 11 ms  3 ms  7 ms
 2 196.1.3.1 10 ms  3 ms  8 ms
 3 196.1.1.3 8 ms  3 ms  3 ms
 4 206.1.2.1 13 ms  4 ms  3 ms
 5 166.1.1.2 13 ms  4 ms  3 ms
<S400_0> tracert -a 166.1.3.1 162.1.3.1
 traceroute to  162.1.3.1(162.1.3.1) 30 hops max,40 bytes packet
 1 206.1.6.3 11 ms  3 ms  3 ms
 2 196.1.3.1 14 ms  4 ms  5 ms
 3 196.3.1.2 10 ms  8 ms  17 ms
 4 196.2.2.2 14 ms  3 ms  3 ms
 5 206.1.4.1 13 ms  3 ms  3 ms
 6 166.1.2.2 13 ms  3 ms  4 ms
II. Trace the packet forwarding path after the MED is modified
# Create AS path ACL 1 and permit the routes whose AS_PATH starts with 100 and ends with 200.
[S400] ip as-path-acl 1 permit ^100 200$
# Display the routes that match AS path ACL 1.
<S400> display bgp routing as-path-acl 1
    Dest/Mask        Next-Hop      Med   Local-pref   Origin      Path ----------------------------------------------------------------------
#^  162.1.1.0/24      196.1.3.1        100    100           INC       100 200
#   162.1.1.0/24      196.2.3.2        200    100           INC       100 200
#^  162.1.2.0/24      196.1.3.1        100    100           INC       100 200
#   162.1.2.0/24      196.2.3.2        200    100           INC       100 200
#^  166.1.1.0/24      196.1.3.1        0          100           INC       100 200
#   166.1.1.0/24      196.2.3.2        0          100           INC       100 200
#^  206.1.3.0         196.1.3.1        0      100           IGP       100 200
# Create AS path ACL 2 and permit the routes whose AS_PATH starts with 100 and ends with 300.
[S400] ip as-path-acl 2 permit ^100 300$
# Display the routes that match AS path ACL 2.
<S400> display bgp routing as-path-acl 2
#^  162.1.3.0/24     196.2.3.2      100       100            INC      100 300
#   162.1.3.0/24     196.1.3.1      200       100            INC      100 300
#^  162.1.4.0/24     196.2.3.2      100       100            INC      100 300
#   162.1.4.0/24     196.1.3.1      200       100            INC      100 300
#^  166.1.2.0/24     196.1.3.1      0         100            INC      100 300
#   166.1.2.0/24     196.2.3.2      0         100            INC      100 300
#^  166.1.5.0/24     196.1.3.1      0         100            INC      100 300
#   166.1.5.0/24     196.2.3.2      0         100            INC      100 300
#   206.1.3.0         196.2.3.2      0         100           IGP      100 300
 1 206.1.6.3 9 ms  4 ms  3 ms
 2 196.1.3.1 13 ms  4 ms  3 ms
 3 196.1.1.3 14 ms  4 ms  3 ms
 4 206.1.2.1 12 ms  3 ms  3 ms
 1 206.1.6.3 10 ms  4 ms  3 ms
 2 196.2.3.2 13 ms  3 ms  5 ms
 3 196.2.2.2 12 ms  5 ms  3 ms
 4 206.1.4.1 12 ms  4 ms  3 ms
 5 166.1.2.2 14 ms  3 ms  5 ms
3.5  Precautions
In the configuration and verification process, pay attention to the following points:
l           Disable the Fabric function before enabling BGP on Fabric-capable devices.
l           To achieve the configuration goal, you are recommended to set the BGP preference to 200. For devices with static routes configured, set a preference for the static routes as required.
l           On S300_A, the backup route (static route) cannot be switched to the primary RIP route automatically, so you need to delete the backup route manually and then add it again.
l           Since the routing policy is applied when BGP routes are redistributed into IGP, some route entries may not be redistributed, so you are recommended to use the tracert –a /ping –a command to verify the configuration in the source address mode.
