H3C Low-End Ethernet Switches Configuration Examples(V1.04)
HomeSupportSwitchesS3100 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Examples(V1.04)
06-Multicast Protocol Configuration Examples
06-Multicast Protocol Configuration Examples 329.5 KB
Keywords: IGMP, PIM-DM, PIM-SM, MSDP, IGMP Snooping
Abstract: This document introduces how to configure multicast functions on Ethernet switches in practical networking, based on three typical networking scenarios:
1. Deployment of PIM-DM plus IGMP, with and without IGMP Snooping respectively. Multicast group filtering in IGMP and IGMP Snooping is mainly described for this scenario.
2. Deployment of PIM-SM plus IGMP, with and without IGMP Snooping respectively. Simulated joining is mainly described for this scenario.
3. IGMP Snooping only. The function of dropping unknown multicast data is mainly described for this scenario.
Acronyms: Internet Group Management Protocol (IGMP), Internet Group Management Protocol Snooping (IGMP Snooping), Protocol Independent Multicast Dense Mode (PIM-DM), Protocol Independent Multicast Sparse Mode (PIM-SM), Multicast Source Discovery Protocol (MSDP)
Chapter 1  Multicast Protocol Overview
1.1  Overview
Different from unicast and broadcast, the multicast technique efficiently addresses the issue of point-to-multipoint data transmission. By allowing high-efficiency point-to-multipoint data transmission, multicast greatly saves network bandwidth and reduces network load.
With the multicast technique, service providers can easily provide new value-added services, such as live Webcasting, Web TV, distance learning, Telemedicine, Web radio, real-time videoconferencing, and other bandwidth- and time-critical information services.
I. IGMP
As a TCP/IP protocol responsible for IP multicast group membership management, the Internet Group Management Protocol (IGMP) is used by IP hosts to establish and maintain their multicast group memberships to the immediately neighboring multicast router.
II. PIM
Protocol Independent Multicast (PIM) provides IP multicast forwarding by leveraging unicast routing tables generated by static routing or any unicast routing protocol, such as the Routing Information Protocol (RIP), Open Shortest Path First (OSPF), Intermediate System to Intermediate System (IS-IS), or the Border Gateway Protocol (BGP). PIM uses the unicast routing table to perform reverse path forwarding (RPF) check in multicast forwarding.
Based on the forwarding mechanism, PIM falls into two modes:
l           PIM-DM
l           PIM-SM
PIM-DM is a type of dense mode multicast protocol. It uses the “push mode” for multicast forwarding, suitable for small-sized networks with densely distributed multicast group members. .
PIM-SM is a type of sparse mode multicast protocol. It uses the “pull mode” for multicast forwarding, suitable for large- and medium-sized networks with sparsely and widely distributed multicast group members.
III. IGMP Snooping
Internet Group Management Protocol Snooping (IGMP Snooping) is a multicast monitoring mechanism that runs on Layer 2 devices to manage and control multicast groups. By analyzing received IGMP messages, a Layer 2 device running IGMP Snooping establishes mappings between ports and MAC multicast groups and forwards multicast data based on these mappings.
IV. MSDP
The Multicast Source Discovery Protocol (MSDP) is an inter-domain multicast solution for the interconnection of PIM-SM domains. It is used to discover the multicast source information in other PIM-SM domains.
Within a PIM-SM domain, the multicast source registers only with the local rendezvous point (RP). Therefore, the RP knows all the sources within its own domain only. If there is a mechanism that allows RPs of different PIM-SM domains to share their multicast source information, the information of active sources in other domains can be delivered to the local receivers, so that multicast data can be transmitted among different domains. MSDP achieves this objective. By setting up MSDP peering relationships among RPs of different domains, MSDP propagates source active (SA) messages, which carry multicast source information, between these MSDP peers, thus to allow multicast traffic to flow between different PIM-SM domains.
V. IGMP Proxy
When a multicast routing protocol (such as PIM-DM) is deployed on a large network, many stub networks may exist. It is tedious work to configure and manage these stub networks.
To minimize the workload of such configuration and management without affecting the multicast connections of the multicast networks, you can configure IGMP Proxy on a Layer 3 switch in the edge networks, so that the Layer 3 switch forwards the IGMP join and IGMP leave messages sent by the hosts attached to it. After the IGMP Proxy configuration, the Layer 3 switch is no longer a PIM neighbor to the external network; instead, it is a host. The Layer 3 switch receives multicast data for a multicast group only when a member of that group is directly attached to it.
1.2  Support of Multicast Features
Multicast features supported by the H3C series Ethernet switches vary with device models. For details, see the corresponding operation manuals. Table 1-1 lists the multicast features supported by H3C series Ethernet switches.
Table 1-1 Multicast features supported by the H3C low-end ethernet  switches
Feature
Model
IGMP Snooping
IGMP
PIM
MSDP
S3600-EI
l
l
l
l
S3600-SI
l
S5600
l
l
l
l
S5100
l
S3100-SI
l
1.3  Configuration Guidance
The following configuration guidance describes the configuration of multicast features based on the implementations on the S5600 series Ethernet switches. For more information, see the corresponding operation manuals.
1.3.1  Configuring IGMP Snooping
Complete these tasks to configure IGMP Snooping:
Configuration task
Remarks
Enabling IGMP Snooping
Required
Configuring IGMP-Snooping timers
Optional
Configuring fast leave processing
Optional
Configuring a multicast group filter
Optional
Configuring the maximum number of multicast groups that can be joined on a port
Optional
Configuring IGMP Snooping querier
Optional
I. Enabling IGMP Snooping
Follow these steps to enable IGMP Snooping:
To do...
Use the command...
Remarks
Enter system view
Enable IGMP Snooping
igmp-snooping enable
Required
Disabled by default.
Enter VLAN view
vlan vlan-id
Required
II. Configuring IGMP-Snooping timers
Follow these steps to configure IGMP-Snooping timers:
To do...
Use the command...
Remarks
Enter system view
Configure an aging timer of router port
igmp-snooping router-aging-time seconds
Optional
By default, the router port aging time is 105 seconds.
Configure a response-to-query timer
igmp-snooping max-response-time seconds
Optional
By default, the maximum response-to-query time is 10 seconds.
Configure an aging timer of a member port of a multicast group
igmp-snooping host-aging-time seconds
Optional
By default, the aging time of the multicast group member port is 260 seconds.
III. Configuring fast leave processing
1)         Configure fast leave processing in system view
Follow these steps to configure fast leave processing in system view:
To do...
Use the command...
Remarks
Enter system view
igmp-snooping fast-leave [ vlan vlan-list ]
Required
Disabled by default
2)         Configure fast leave in Ethernet port view
Follow these steps to configure fast leave processing in Ethernet port view:
To do...
Use the command...
Remarks
Enter system view
Enter Ethernet port view
Required
Disabled by default
IV. Configuring a multicast group filter
1)         Configure a multicast group filter in system view
Follow these steps to configure a multicast group filter in system view:
To do...
Use the command...
Remarks
Enter system view
igmp-snooping group-policy acl-number [ vlan vlan-list ]
Required
Disabled by default
2)         Configure a multicast group filter in Ethernet port view
Follow these steps to configure a multicast group filter in Ethernet port view:
To do...
Use the command...
Remarks
Enter system view
Required
Disabled by default
V. Configuring the maximum number of multicast groups that can be joined on a port
Follow these steps to configure the maximum number of multicast groups that can be joined on a port:
To do...
Use the command...
Remarks
Enter system view
Configure maximum number of multicast groups that can be joined on the port
igmp-snooping group-limit limit [ vlan vlan-list [ overflow-replace ] ]
Required
The system default is 255.
VI. Configuring IGMP Snooping querier
Follow these steps to configure IGMP Snooping querier:
To do...
Use the command...
Remarks
Enter system view
Required
Disabled by default
Enter VLAN view
vlan vlan-id
Required
Disabled by default
Enable IGMP-Snooping querier
igmp-snooping querier
Required
Disabled by default
Configure the query interval
igmp-snooping query-interval seconds
Optional
The system default is 60 seconds.
Configure a source IP address for general query messages
igmp-snooping general-query source-ip { current-interface | ip-address }
Optional
The system default is 0.0.0.0.
1.3.2  Configuring IGMP
Complete these tasks to configure IGMP:
Configuration task
Remarks
Enabling IGMP
Required
Configuring IGMP version
Optional
Configuring parameters related to IGMP queries
Optional
Configuring the maximum allowed number of multicast groups
Optional
Optional
Configuring simulated joining
Optional
Configuring IGMP proxy
Optional
Removing joined IGMP groups from an interface
Optional
I. Enabling IGMP
Follow these steps to enable IGMP:
To do...
Use the command...
Remarks
Enter system view
Enable multicast routing
multicast routing-enable
Enter VLAN interface view
interface Vlan-interface interface-number
Enabling IGMP
igmp enable
Required
Disabled by default
  Caution:
The following configurations in this chapter are implemented after multicast routing is enabled on the device and IGMP is enabled on the corresponding interface.
II. Configuring IGMP version
Follow these steps to configure IGMP version:
To do...
Use the command...
Remarks
Enter system view
Configure IGMP version
igmp version { 1 | 2 }
Required
IGMPv2 by default
  Caution:
The device cannot switch from one IGMP version to another automatically. All switches on the same subnet must run the same version of IGMP.
III. Configuring parameters related to IGMP queries
Follow these steps to configure parameters related to IGMP queries:
To do...
Use the command...
Remarks
Enter system view
Configure IGMP query interval
igmp timer query seconds
Optional
Configure the IGMP last member query interval
igmp lastmember-queryinterval seconds
Optional
The system default is 1 second.
Configure the IGMP last member query count
igmp robust-count robust-value
Optional
The system default is two.
Configure the IGMP other querier present interval
igmp timer other-querier-present seconds
Optional
The system default is 120 seconds, twice the interval specified by the igmp timer query command.
Configure the maximum response time
igmp max-response-time seconds
Optional
The system default is 10 seconds.
IV. Configuring the maximum allowed number of multicast groups
Follow these steps to configure the maximum number of multicast groups allowed to be joined on an interface:
To do...
Use the command...
Remarks
Enter system view
Configure the maximum number of multicast groups allowed on the interface
igmp group-limit limit
Required
The system default is 256.
  Caution:
If you configure the maximum number of multicast groups allowed on an interface to 1, a new group joined on the interface automatically supersedes the existing one.
If the number of existing multicast groups is larger than the limit configured on the interface, the system will remove the oldest entries automatically until the number of multicast groups on the interface conforms to the configured limit.
1)         Configure a multicast group filter in VLAN interface view
Follow these steps to configure a multicast group filter in VLAN interface view:
To do...
Use the command...
Remarks
Enter system view
igmp group-policy acl-number [ 1 | 2 | port interface-type interface-number [ to interface-type interface-number ] ]
Optional
No filter is configured by default.
2)         Configuring a multicast group filter in Ethernet port view
To do...
Use the command...
Remarks
Enter system view
igmp group-policy acl-number vlan vlan-id
Optional
No multicast group filter is configured by default. The port must belong to the specified VLAN.
VI. Configuring simulated joining
1)         Configure simulated joining in VLAN interface view
Follow these steps to configure simulated joining in VLAN interface view:
To do...
Use the command...
Remarks
Enter system view
igmp host-join group-address port interface-list
Optional
Disabled by default
2)         Configure simulated joining in Ethernet port view
To do...
Use the command...
Remarks
Enter system view
igmp host-join group-address vlan vlan-id
Optional
Disabled by default
  Caution:
Before configuring simulated joining, you must enable IGMP in VLAN interface view.
If you configure a port as a simulated host in Ethernet port view, the Ethernet port must belong to the specified VLAN; otherwise the configuration does not take effect.
VII. Configuring IGMP proxy
Follow these steps to configure IGMP proxy:
To do...
Use the command...
Remarks
Enter system view
Required
Enable IGMP
igmp enable
Required
Configure IGMP proxy
igmp proxy Vlan-interface interface-number
Required
Disabled by default
  Caution:
l      You must enable PIM on the interface before configuring the igmp proxy command. Otherwise, the IGMP proxy feature does not take effect.
l      One interface cannot serve as the proxy interface for two or more interfaces.
l      When you configure the IP address of the interface that will serve as an IGMP proxy, make sure that the IP address is not the lowest on this subnet to prevent this interface from being elected as the IGMP querier on the subnet, as this will result in failure of multicast data forwarding.
VIII. Removing joined IGMP groups from an interface
Follow these steps to remove joined IGMP groups from an interface:
To do...
Use the command...
Remarks
Remove the specified group or all groups from the specified interface or all interfaces
reset igmp group { all | interface interface-type interface-number { all | group-address [ group-mask ] } }
The reset command available in user view.
  Caution:
After a multicast group is removed from an interface, hosts attached to interface can join the multicast group again.
1.3.3  Configuring PIM
I. Configuring PIM-DM
Follow these steps to configure PIM-DM:
To do...
Use the command...
Remarks
Enter system view
Required
Disabled by default
Enter PIM view
pim
Configure a multicast source or multicast source-group filter
source-policy acl-number
Optional
You can define the related IP addresses in an ACL.
Enable PIM-DM
pim dm
Required
Configure the hello interval on the interface
pim timer hello seconds
Optional
The system default is 30 seconds.
Configure a limit on the number of PIM neighbors on the interface
pim neighbor-limit limit
Optional
The default value is 128.
Configure the filtering policy for PIM neighbors
pim neighbor-policy acl-number
Optional
Disabled by default
II. Configuring PIM-SM
Follow these steps to configure PIM-SM:
To do...
Use the command...
Remarks
Enter system view
Required
Disabled by default
Enter PIM view
pim
Optional
Configure a C-BSR
c-bsr interface-type interface-number hash-mask-len [ priority ]
Optional
By default, no C-BSR is configured. The default priority is 0.
Configure a C-RP
c-rp interface-type interface-number [ group-policy acl-number | priority priority ]*
Optional
By default, no C-RP is configured. The default priority is 0.
Configure a static RP
static-rp rp-address [ acl-number ]
Optional
No static RP is configured by default.
Configure a legal BSR address range
bsr-policy acl-number
Optional
No legal BSR address range is configured by default.
Configure a legal C-RP address range
crp-policy acl-number
Optional
You can define the related IP address ranges in an ACL.
No legal C-RP address range is configured by default.
Configure to filter the register messages from RP to DR
register-policy acl-number
Optional
Disable RPT-to-SPT switchover
spt-switch-threshold infinity [ group-policy acl-number [ order order-value ] ]
Optional
By default, the device switches to the SPT immediately after it receives the first multicast packet from the RPT.
Enable PIM-SM
pim sm
Required
Configuring a PIM-SM domain boundary
pim bsr-boundary
Optional
By default, no PIM-SM domain boundary is configured
Optional
Configure the maximum number of PIM neighbors allowed on the interface
Optional
Optional
Disabled by default
1.3.4  Configuring MSDP
I. Configuring MSDP basic functions
Follow these steps to configure MSDP basic functions:
To do...
Use the command...
Remarks
Enter system view
Enable MSDP and enter MSDP view
msdp
Required
Create an MSDP peer connection
peer peer-address connect-interface interface-type interface-number
Required
You need to configure related parameters on both devices between which the peer connection is to be created. The peer ID is an address pair (the IP address of the local interface and the IP address of the remote MSDP peer).
Configure a static RPF peer
static-rpf-peer peer-address [ rp-policy ip-prefix-name ]
Optional
For an area with only one MSDP peer, if BGP or MBGP is not running, you need to configure a static RPF peer.
II. Configuring MSDP peer connections
Complete these tasks to configure connection between MSDP peers:
Configuration task
Remarks
Configure description information for MSDP peer
Required
Configure an MSDP mesh group
Optional
Configure MSDP peer connection control
Optional
1)         Configure description information for MSDP peers
Follow these steps to configure description information of an MSDP peer:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Configure description information for an MSDP peer
peer peer-address description text
Optional
No description information is configured for MSDP peers by default.
2)         Configure an MSDP mesh group
Follow these steps to configure an MSDP mesh group:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Add an MSDP peer in a mesh group
peer peer-address mesh-group name
Required
An MSDP peer does not belong to any mesh group by default.
&  Note:
l      Before grouping multiple routers into an MSDP mesh group, make sure that these routers are interconnected with one another.
l      To add different MSDP peers into an MSDP mesh group, configure the same mesh group name on them.
l      An MSDP peer can belong to only one mesh group. A newly configured mesh group name supersedes the existing one.
3)         Configure MSDP peer connection control
Follow these steps to configure MSDP peer connection control:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Shut down an MSDP peer
shutdown peer-address
Optional
By default, MSDP peers are connected.
Configure the MSDP peer connection retry period
timer retry seconds
Optional
III. Configuring SA message delivery
Complete these tasks to configure SA message delivery:
Configuration task
Remarks
Configure the RP address in SA message
Optional
Configure the SA message cache
Optional
Configure SA message transmission and filtering
Optional
Configure a rule for filtering multicast sources in SA messages
Optional
Configure a filtering rule for receiving or forwarding SA messages
Optional
1)         Configure the RP address in SA messages
Follow these steps to configure the RP address in SA messages:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
originating-rp interface-type interface-number
Optional
By default, the RP address in an SA message is the PIM RP address.
&  Note:
In Anycast RP application, C-BSR and C-RP must be configured on different devices or ports.
2)         Configure the SA message cache
Follow these steps to configure the SA message cache:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Enable the SA message cache mechanism
cache-sa-enable
Optional
Enabled by default
Configure the maximum number of SA messages the router can cache
peer peer-address sa-cache-maximum sa-limit
Optional
The system default is 2048.
3)         Configure SA message transmission and filtering
Follow these steps to configure SA message transmission and filtering:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
cache-sa-enable
Optional
After receiving an SA message, a router caches SA state by default.
Enable the router to send SA requests to the designated MSDP peer
peer peer-address request-sa-enable
Optional
By default, upon receiving a new Join message, a router does not send an SA request message to its designated MSDP peer; instead it waits for the next SA message.
Configure a filtering rule for SA requests from the specified MSDP peer
peer peer-address sa-request-policy [ acl acl-number ]
Optional
Be default, a router receives all SA request messages from its MSDP peer.
4)         Configure a rule for filtering multicast sources in SA messages
Follow these steps to configure a rule for filtering the multicast sources of SA messages:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
Configure multicast source filtering at SA message creation
import-source [ acl acl-number ]
Optional
By default, SA messages advertise all the (S, G) entries in the domain.
5)         Configure a filtering rule for receiving or forwarding SA messages
Follow these steps to configure a filtering rule for receiving or forwarding SA messages:
To do...
Use the command...
Remarks
Enter system view
Enter MSDP view
msdp
peer peer-address sa-policy { import | export } [ acl acl-number ]
Optional
By default, no filtering rule is configured for receiving or forwarding SA messages, namely, all SA messages from MSDP peers will be accepted or forwarded.
Configure the minimum TTL required for an SA-encapsulated multicast packet to be forwarded to the specified MSDP peer
peer peer-address minimum-ttl ttl-value
Optional
Chapter 2  Multicast Protocol Configuration Examples
2.1  PIM-DM plus IGMP plus IGMP Snooping Configuration Example
2.1.1  Requirement Analysis
When users receive voice on demand (VOD) information through multicast, the information receiving mode may vary based on user requirements:
1)         To avoid video broadcast at Layer 2, IGMP Snooping is enabled on Switch E, through which Host A and Host B receive the multicast data.
2)         To ensure reliable and stable reception of multicast data, Switch B and Switch C provide uplink backup for the directly attached stub network N1, which comprises multicast receivers Host C and Host D.
3)         All the Layer 3 switches run RIP for unicast routing and run PIM-DM for multicast routing.
2.1.2  Configuration Plan
1)         Switch D connects to the network that comprises the multicast source (Source) through VLAN-interface 300.
2)         Switch A connects to Switch E through VLAN-interface 100, and to Switch D through VLAN-interface 103.
3)         Switch B and Switch C connect to stub network N1 through their respective VLAN-interface 200, and to Switch D through VLAN-interface 101 and VLAN-interface 102 respectively.
4)         Enable IGMPv2 on VLAN-interface 100 of Switch A. Enable IGMP Snooping on Switch E and in VLAN 100. Run IGMPv2 on Switch B, Switch C, and the hosts in stub network N1. Typically, Switch B acts as the IGMP querier.
2.1.3  Network Diagram
Device
IP address
Ports
Switch A
Vlan-int100
10.110.1.1/24
Ethernet1/0/1
Vlan-int103
192.168.1.1/24
Ethernet1/0/2
Switch B
Vlan-int200
10.110.2.1/24
Ethernet1/0/1
Vlan-int101
192.168.2.1/24
Ethernet1/0/2
Switch C
Vlan-int200
10.110.2.2/24
Ethernet1/0/1
Vlan-int102
192.168.3.1/24
Ethernet1/0/2
Switch D
Vlan-int300
10.110.5.1/24
Ethernet1/0/1
Vlan-int103
192.168.1.2/24
Ethernet1/0/2
Vlan-int101
192.168.2.2/24
Ethernet1/0/3
Vlan-int102
192.168.3.2/24
Ethernet1/0/4
Switch E
Vlan 100
Ethernet1/0/1, Ethernet1/0/2, Ethernet1/0/3
Figure 2-1 Network diagram for PIM-DM plus IGMP plus IGMP Snooping configuration
2.1.4  Configuration Procedure
I. Configuring VLANs, VLAN interfaces and IP addresses on each switch
# Configure VLANs, VLAN interfaces, and their IP addresses on Switch A.
[SwitchA] vlan 100
[SwitchA-vlan100] port Ethernet 1/0/1
[SwitchA-vlan100] quit
[SwitchA] vlan 103
[SwitchA-vlan103] port Ethernet 1/0/2
[SwitchA-vlan103] quit
[SwitchA] interface Vlan-interface 100
[SwitchA-Vlan-interface100] ip address 10.110.1.1 24
[SwitchA] interface Vlan-interface 103
[SwitchA-Vlan-interface103] ip address 192.168.1.1 24
Configure VLANs, VLAN interfaces, and their IP addresses on other switches as per Figure 2-1. The detailed configuration steps are omitted here.
II. Configuring the unicast routing protocol
# Enable RIP on Switch A, and then enable RIP on subnets 192.168.1.0 and 10.110.1.0.
[SwitchA] rip
[SwitchA- rip] network 192.168.1.0
[SwitchA- rip] network 10.110.1.0
[SwitchA- rip] quit
The configuration on Switch B, Switch C, and Switch D is similar to the configuration on Switch A.
III. Configuring the multicast protocols
# Enable IP multicast routing on Switch A, enable PIM-DM on each interface, and then enable IGMPv2 on VLAN-interface 100.
[SwitchA] multicast routing-enable
[SwitchA-Vlan-interface100] igmp enable
[SwitchA-Vlan-interface100] pim dm
The configuration on Switch B and Switch C is similar to the configuration on Switch A.
# Enable multicast routing on Switch D, and enable PIM-DM on each interface.
<SwitchD> system-view
[SwitchD] multicast routing-enable
[SwitchD] interface vlan-interface 300
[SwitchD-Vlan-interface300] pim dm
[SwitchD-Vlan-interface300] quit
[SwitchD-Vlan-interface103] pim dm
[SwitchD] interface vlan-interface 101
[SwitchD-Vlan-interface101] pim dm
[SwitchD-Vlan-interface101] quit
[SwitchD] interface vlan-interface 102
[SwitchD-Vlan-interface102] pim dm
[SwitchD-Vlan-interface102] quit
# Enable IGMP Snooping on Switch E, and enable IGMP Snooping in VLAN 100.
<SwitchE> system-view
[SwitchE] igmp-snooping enable
  Enable IGMP-Snooping ok.
[SwitchE] vlan 100
[SwitchE-vlan100] igmp-snooping enable
[SwitchE-vlan100] quit
IV. Verifying the configuration
Now start sending multicast data to multicast group 224.1.1.1 from Source and start receiving the multicast data on Host A, and take the following steps to verify the configurations made on the switches.
1)         Check whether the multicast stream can flow to Host A.
# View the PIM neighboring relationships on Switch D.
<SwitchD> display pim neighbor
Neighbor's Address  Interface Name                 Uptime    Expires
192.168.2.1         Vlan-interface101               02:45:04  00:04:46
192.168.3.1         Vlan-interface102               02:42:24  00:04:45
192.168.1.1         Vlan-interface103               02:43:44  00:05:44
# View the multicast forwarding table of Switch D.
<SwitchD>display multicast forwarding-table
Multicast Forwarding Cache Table
Total 1 entries: 0 entry created by IP, 1 entries created by protocol
00001. (10.110.5.110, 224.1.1.1), iif Vlan-interface1, 1 oifs,
     Protocol Create
     List of outgoing interface:
       01: Vlan-interface101
     Matched 181 pkts(271500 bytes), Wrong If 0 pkts
     Forwarded 130 pkts(195000 bytes)
Total 1 entries Listed
# View the multicast forwarding table of Switch A.
<SwitchA>display multicast forwarding-table
Total 1 entry: 0 entry created by IP, 1 entry created by protocol
00001. (10.110.5.110, 224.1.1.1), iif Vlan-interface101, 1 oifs,
     Protocol Create
       01: Vlan-interface100
     Matched 451 pkts(676500 bytes), Wrong If 0 pkts
     Forwarded 451 pkts(676500 bytes)
Total 1 entry Listed
Matched 1 entry
# View the multicast group information that contains port information on Switch A.
<SwitchA> display mpm group
  Total 1 IP Group(s).
  Total 1 MAC Group(s).
  Vlan(id):101.
    Total 0 IP Group(s).
    Total 0 MAC Group(s).
    Router port(s):Ethernet1/0/2
  Vlan(id):200.
    Router port(s):
    IP group(s):the following ip group(s) match to one mac group.
        IP group address:224.1.1.1
        Host port(s):Ethernet1/0/15
    MAC group(s):
        MAC group address:0100-5e01-0101
# View the information about the multicast group entries created by IGMP Snooping on Switch E.
<SwitchE> display igmp-snooping group
  Vlan(id):100.
        Host port(s):Ethernet1/0/19
    MAC group(s):
The above-mentioned information shows that multicast forwarding entries have been correctly established on Switch D and Switch A, and multicast traffic can successfully flow to Host A.
2)         Configure IGMP Snooping multicast group filtering on Switch E
# Configure to filter the packets for the multicast group 224.1.1.1 on Switch E.
[SwitchE-acl-basic-2000] rule deny source 224.1.1.1 0
[SwitchE-acl-basic-2000] rule permit source any
[SwitchE-acl-basic-2000] quit
[SwitchE]igmp-snooping group-policy 2000 vlan 100
# View multicast forwarding entries on Switch A.
<SwitchA> display multicast forwarding-table
00001. (10.110.5.100, 224.1.1.1), iif Vlan-interface101, 0 oifs,
     Protocol Create
     Matched 5 pkts(7500 bytes), Wrong If 0 pkts
     Forwarded 0 pkts(0 bytes)
As shown above, Switch A has stopped forwarding multicast data for the multicast group 224.1.1.1.
# View multicast group information on Switch E.
  Vlan(id):200.
    Router port(s):Ethernet1/0/19
With multicast group filtering enabled, the corresponding ports drop IGMP reports for the filtered group and will be removed for that group when their respective port aging timer expires.
3)         Configure IGMP multicast group filtering on Switch A.
# Disable multicast group filtering on Switch E.
[SwitchE] undo igmp-snooping group-policy
&  Note:
To verify the configuration of IGMP multicast group filtering on Switch A, disable IGMP Snooping multicast group filtering on Switch E first.
Configure to filter the multicast group 224.1.1.1 on VLAN-interface 100 of Switch A, and then display the multicast forwarding entries of Switch A.
# Configure to filter the multicast group 224.1.1.1 on VLAN-interface 100 of Switch A.
[SwitchA] acl number 2000
[SwitchA-acl-basic-2000] rule deny source  224.1.1.1 0
[SwitchA-acl-basic-2000] rule permit source any
[SwitchA-acl-basic-2000] quit
[SwitchA-Vlan-interface100] igmp group-policy 2000
[SwitchA-Vlan-interface100] return
     Protocol Create
# View multicast group information on Switch A.
<SwitchA> display igmp group
 Total 0 IGMP groups reported on this router
After multicast group filtering is enabled, the corresponding port cannot receive IGMP reports. Thus, the corresponding multicast groups are deleted after the port aging timer expires.
&  Note:
As shown above, IGMP Snooping multicast group filtering has the same function as IGMP multicast group filtering. You can use either approach based on the specific situation.
2.2  PIM-SM plus IGMP plus IGMP Snooping Configuration Examples
2.2.1  Requirement Analysis
When users receive VOD information through multicast, the information receiving mode may vary based on user requirements:
1)         To avoid broadcasting of the video information at Layer 2, IGMP Snooping is enabled on Switch E, through which Host A and Host B receive the multicast data.
3)         Configure the PIM-SM domain as a single-BSR domain. Run OSPF for unicast routing in the domain.
2.2.2  Configuration Plan
2)         Switch A connects to Switch F through VLAN-interface 100, and to Switch D and Switch E through VLAN-interface 101 and VLAN-interface 102 respectively.
3)         Switch B and Switch C connect to stub network N1 through their respective VLAN-interface 200, and to Switch E through VLAN-interface 103 and VLAN-interface 104 respectively.
4)         It is required that VLAN-interface 105 of Switch D and VLAN-interface 102 of Switch E act as C-BSR and C-RP.
5)         IGMPv2 is required on VLAN-interface 100 of Switch A. IGMP Snooping is required on Switch F and in VLAN 100. IGMPv2 is also required between Switch B, Switch C, and stub network N1. Typically, Switch B acts as the querier.
2.2.3  Network Diagram
Device
IP address
Ports
Switch A
Vlan-int100
10.110.1.1/24
Ethernet1/0/1
Vlan-int101
192.168.1.1/24
Ethernet1/0/2
Vlan-int102
192.168.9.1/24
Ethernet1/0/3
Switch B
Vlan-int200
10.110.2.1/24
Ethernet1/0/1
Vlan-int103
192.168.2.1/24
Ethernet1/0/2
Switch C
Vlan-int200
10.110.2.2/24
Ethernet1/0/1
Vlan-int104
192.168.3.1/24
Ethernet1/0/2
Switch D
Vlanint300
10.110.5.1/24
Ethernet1/0/1
Vlanint101
192.168.1.2/24
Ethernet1/0/2
Vlanint105
192.168.4.2/24
Ethernet1/0/3
Switch E
Vlanint104
192.168.3.2/24
Ethernet1/0/3
Vlanint103
192.168.2.2/24
Ethernet1/0/2
Vlanint102
192.168.9.2/24
Ethernet1/0/1
Vlanint105
192.168.4.1/24
Ethernet1/0/4
Switch F
Vlan 100
Figure 2-2 Network diagram for PIM-SM plus IGMP plus IGMP Snooping configuration
2.2.4  Configuration Procedure
I. Configuring VLANs, VLAN interfaces and IP addresses for each switch
[SwitchA] vlan 100
[SwitchA] vlan 101
[SwitchA-vlan101] port Ethernet 1/0/2
[SwitchA-vlan101] quit
[SwitchA] vlan 102
[SwitchA-vlan102] port Ethernet 1/0/3
[SwitchA-vlan102] quit
[SwitchA] interface Vlan-interface 101
[SwitchA-Vlan-interface101] ip address 192.168.1.1 24
[SwitchA] interface Vlan-interface 102
[SwitchA-Vlan-interface102] ip address 192.168.9.1 24
Configure VLANs, VLAN interfaces, and their IP addresses on other switches as per Figure 2-2. The detailed configuration steps are omitted here.
# Configure a router ID and enable OSPF on Switch A.
<SwitchA> system-view.
[SwitchA]router id 1.1.1.1
[SwitchA]ospf
[SwitchA-ospf-1]area 0
[SwitchA-ospf-1-area-0.0.0.0]network 10.110.1.0 0.0.0.255
[SwitchA-ospf-1-area-0.0.0.0]network 192.168.1.0 0.0.0.255
[SwitchA-ospf-1-area-0.0.0.0]network 192.168.9.0 0.0.0.255
The configuration on Switch B, Switch C, Switch D, and Switch E is similar to the configuration on Switch A.
# Enable IP multicast routing on Switch A, enable PIM-SM on each interface, and then enable IGMPv2 on VLAN-interface 100.
[SwitchA-Vlan-interface102] pim sm
&  Note:
It is necessary to enable IGMP only on interfaces with attached multicast receivers. As the default IGMP version is IGMPv2, it is not necessary to use the version configuration command on the interface.
The configuration on Switch B and Switch C is similar to that on Switch A. The configuration on Switch D and Switch E is also similar to that on Switch A except that it is not necessary to enable IGMP on the corresponding interfaces on these two switches.
# Configure the group range to be served by the RP and configure a C-BSR and a C-RP on Switch D.
[SwitchD] acl number 2005
[SwitchD-acl-basic-2005] rule permit source 225.1.1.0 0.0.0.255
[SwitchD-acl-basic-2005] quit
[SwitchD] pim
[SwitchD-pim] c-bsr vlan-interface 105 24 2
[SwitchD-pim] c-rp vlan-interface 105 group-policy 2005 priority 2
[SwitchD-pim] quit
# Configure the group range to be served by the RP and configure a C-BSR and a C-RP on Switch E.
[SwitchE] acl number 2005
[SwitchE-acl-basic-2005] rule permit source 225.1.1.0 0.0.0.255
[SwitchE-acl-basic-2005] quit
[SwitchE] pim
[SwitchE-pim] c-bsr vlan-interface 102 24 1
[SwitchE-pim] c-rp vlan-interface 102 group-policy 2005 priority 1
[SwitchE-pim] quit
# Enable IGMP Snooping globally on Switch E, and enable IGMP Snooping in VLAN 100.
<SwitchF> system-view
[SwitchF] igmp-snooping enable
[SwitchF] vlan 100
[SwitchF-vlan100] igmp-snooping enable
[SwitchF-vlan100] quit
Now start sending multicast data to multicast group 225.1.1.1 from Source and start receiving the multicast data on Host A and Host C, and take the following steps to verify the configurations made on the switches.
1)         Check whether the multicast stream flows to Host A and Host C.
# View PIM neighboring relationships on Switch E.
<SwitchE> display pim neighbor
192.168.9.1         Vlan-interface102               02:47:04  00:01:42
192.168.2.1         Vlan-interface103               02:45:04  00:04:46
192.168.3.1         Vlan-interface104               02:42:24  00:04:45
192.168.4.2         Vlan-interface105               02:43:44  00:05:44
# View BSR information on Switch E.
<SwitchE> display pim bsr-info
  Current BSR Address: 192.168.4.2
             Priority: 2
          Mask Length: 24
              Expires: 00:01:39
  Local Host is C-BSR: 192.168.9.2
             Priority: 1
          Mask Length: 24
# View RP information on Switch E.
<SwitchE> display pim rp-info
 PIM-SM RP-SET information:
    BSR is: 192.168.4.2
    Group/MaskLen: 225.1.1.0/24
      RP 192.168.9.2
        Version: 2
        Priority: 1
        Uptime: 00:03:15
        Expires: 00:01:14
      RP 192.168.4.2
        Version: 2
        Priority: 2
        Uptime: 00:04:25
        Expires: 00:01:09
# View PIM routing table entries on Switch A.
<SwitchA> display pim routing-table
PIM-SM Routing Table
Total 1 (S,G) entries, 1 (*,G) entries, 0 (*,*,RP) entry
(*, 225.1.1.1), RP 192.168.9.2
    Protocol 0x20: PIMSM, Flag 0x2003: RPT WC NULL_IIF
    Uptime: 00:23:21, never timeout
    Upstream interface: Vlan-interface102, RPF neighbor: 192.168.9.2
    Downstream interface list:
      Vlan-interface100, Protocol 0x1: IGMP, never timeout
(10.110.5.100, 225.1.1.1)
    Protocol 0x20: PIMSM, Flag 0x80004: SPT
    Uptime: 00:03:43, Timeout in 199 sec
Matched 1 (S,G) entries, 1 (*,G) entries, 0 (*,*,RP) entry
The information on Switch B and Switch C is similar to that on Switch A.
# View PIM routing table entries on Switch D.
<SwitchD> display pim routing-table
Total 1 (S,G) entry, 0 (*,G) entry, 0 (*,*,RP) entry
    Protocol 0x20: PIMSM, Flag 0x4: SPT
    Uptime: 00:03:03, Timeout in 27 sec
    Upstream interface: Vlan-interface300, RPF neighbor: NULL
      Vlan-interface101, Protocol 0x200: SPT, timeout in 147 sec
      Vlan-interface105, Protocol 0x200: SPT, timeout in 145 sec
Matched 1 (S,G) entry, 0 (*,G) entry, 0 (*,*,RP) entry
# View PIM routing table entries on Switch E.
<SwitchE> display pim routing-table
Total 1 (S,G) entry, 1 (*,G) entry, 0 (*,*,RP) entry
(*,225.1.1.1), RP 192.168.9.2
    Uptime: 00:02:34, Timeout in 176 sec
    Upstream interface: Null, RPF neighbor: 0.0.0.0
      Vlan-interface102, Protocol 0x100: RPT, timeout in 176 sec
      Vlan-interface103, Protocol 0x100: SPT, timeout in 135 sec
    Upstream interface: Vlan-interface105, RPF neighbor: 192.168.4.2
      Vlan-interface102, Protocol 0x200: SPT, timeout in 147 sec
      Vlan-interface103, Protocol 0x200: SPT, timeout in 145 sec
Matched 1 (S,G) entry, 1 (*,G) entry, 0 (*,*,RP) entry
# View the information about multicast group entries created by IGMP Snooping on Switch F.
<SwitchF> display igmp-snooping group
  Vlan(id):100.
        IP group address:225.1.1.1
    MAC group(s):
# View multicast group information that contains port information on Switch B.
<SwitchB> display mpm group
  Vlan(id):200.
    Router port(s):
        Host port(s):Ethernet1/0/24
    MAC group(s):
  Vlan(id):103.
    Router port(s):Ethernet1/0/10
As shown above, multicast traffic can successfully flow to Host A and Host C.
Configure simulated joining on Switch B, thus to prevent the multicast switch from considering that no multicast receiver exist on the subnet due to some reason and removing the corresponding path from the multicast forwarding tree.
# Configure Ethernet 1/0/21 as a simulated host to join multicast group 225.1.1.1.
[SwitchB] interface Vlan-interface 200
[SwitchB-Vlan-interface200] igmp host-join 225.1.1.1 port Ethernet 1/0/21
  Vlan(id):200.
    Router port(s):
        Host port(s):Ethernet1/0/21             Ethernet1/0/24
    MAC group(s):
  Vlan(id):103.
As shown above, Ethernet 1/0/21 has become a member port for multicast group 225.1.1.1.
2.3  IGMP Snooping-Only Configuration Examples
2.3.1  Network Requirements
In case that it is unnecessary or infeasible to build a Layer-3 multicast network, enabling IGMP Snooping on all the devices in a Layer 2 network can implement some multicast functions.
2.3.2  Configuration Plan
1)         As shown in Figure 2-3, in a Layer-2 network without Layer-3 devices, Switch C connects to the multicast source through Ethernet 1/0/3. At least one receiver is attached to Switch B and Switch C respectively.
2)         Enable IGMP Snooping on Switch A, Switch B, and Switch C, with Switch A acting as the IGMP Snooping querier.
3)         Enable Switch A and Switch B to drop unknown multicast traffic so that multicast traffic for unknown multicast groups are not flooded in the VLAN.
2.3.3  Network Diagram
Figure 2-3 Network diagram for IGMP Snooping–only configuration
2.3.4  Configuration Procedure
I. Configuring switch A
# Enable IGMP Snooping globally.
[SwitchA] igmp-snooping enable
# Create VLAN 100, add Ethernet 1/0/1 and Ethernet 1/0/2 into VLAN 100, and then enable IGMP Snooping in this VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port Ethernet 1/0/1 Ethernet 1/0/2
[SwitchA-vlan100] igmp-snooping enable
# Enable IGMP Snooping querier in VLAN 100.
[SwitchA-vlan100] igmp-snooping querier
# Enable the function of dropping unknown multicast packets.
[SwitchA] unknown-multicast drop enable
II. Configuring Switch B
[SwitchB] igmp-snooping enable
# Create VLAN 100, add Ethernet 1/0/1 through Ethernet 1/0/3 into VLAN 100, and then enable IGMP Snooping in this VLAN.
[SwitchB] vlan 100
[SwitchB-vlan100] port Ethernet 1/0/1 to Ethernet 1/0/3
[SwitchB-vlan100] igmp-snooping enable
[SwitchB-vlan100] quit
[SwitchB] unknown-multicast drop enable
III. Configuring Switch C
<SwitchC system-view
[SwitchC] igmp-snooping enable
[SwitchC] vlan 100
[SwitchC-vlan100] port Ethernet 1/0/1 to Ethernet 1/0/3
[SwitchC-vlan100] igmp-snooping enable
  Caution:
Switch C is not the IGMP Snooping querier, so it does not have member ports for non-directly-connected hosts, and the corresponding forwarding entries cannot be created on it. Therefore, do not enable the function of dropping unknown multicast packets on Switch C. To avoid impact on the network and on Switch C caused by multicast flooding, it is recommended to enable IGMP Snooping querier on the switch to which the multicast source is directly attached.
1)         View information on Switch B.
# View IGMP packet statistics on Switch B.
<SwitchB> display igmp-snooping statistics
  Received IGMP general query packet(s) number:16.
  Received IGMP specific query packet(s) number:3.
  Received IGMP V1 report packet(s) number:0.
  Received IGMP V2 report packet(s) number:53.
  Received IGMP leave packet(s) number:1.
  Received error IGMP packet(s) number:0.
  Sent IGMP specific query packet(s) number:1.
Switch B received IGMP general queries sent by the querier and IGMP reports from receivers.
# View multicast group information on Switch B.
<Switch B> display igmp-snooping group
  Vlan(id):100.
    MAC group(s):
        MAC group address:0100-5e7f-fffe
As shown above, a forwarding entry for the multicast group 224.1.1.1 has been created on Switch A, with Ethernet 1/0/1 as the router port and Ethernet 1/0/2 as the member port.
2)         View information on Switch A.
# View IGMP packet statistics on Switch A.
<SwitchA> display igmp-snooping statistics
  Received IGMP general query packet(s) number:0.
  Received IGMP specific query packet(s) number:0.
Switch A receives IGMP reports from the receivers.
<Switch A> display igmp-snooping group
  Vlan(id):100.
    Router port(s):
    MAC group(s):
As shown above, a forwarding entry for the multicast group 224.1.1.1 has been created on Switch A, with Ethernet 1/0/1 as the member port. Acting as the IGMP Snooping querier, Switch A does not have a router port.
3)         View information on Switch C.
# View IGMP packet statistics on Switch C.
<SwitchC> display igmp-snooping statistics
  Received IGMP general query packet(s) number:10.
  Received IGMP V2 report packet(s) number:0.
  Received IGMP leave packet(s) number:.0
  Sent IGMP specific query packet(s) number:0.
Switch C received only IGMP general queries from the querier.
# View multicast group information on Switch C.
<Switch C> display igmp-snooping group
Vlan(id):100.
As shown above, no forwarding entries have been created on Switch C. The switch must flood multicast data in the VLAN to allow the multicast data to flow to the receivers downstream; therefore, do not enable the function of dropping unknown multicast packets on Switch C.
2.4  MSDP Configuration Examples
2.4.1  Network Requirements
To enable communication between receivers and multicast sources in different PIM-SM domains, use MSDP to establish MSDP peering relationships between the RPs of different PIM-SM domains, so that these RPs can forward SA messages between PIM-SM domains to share multicast source information.
2.4.2  Configuration Plan
l           Two ISPs maintain their respective ASs, AS 100 and AS 200. OSPF runs within each AS, and BGP is deployed for interoperability between the two ASs.
l           PIM-SM 1 belongs to AS 100. PIM-SM 2 and PIM-SM 3 belong to AS 200.
l           Both PIM-SM domains have 0 or 1 multicast source and at least one receiver. OSPF runs within each domain for unicast routing.
l           The respective loopback interfaces, Loopback 0, of Switch C, Switch D and Switch F are configured as C-BSRs and C-RPs of the respective PIM-SM domains.
l           Establish MSDP peering relationship between Switch C and Switch D through EBGP. Establish MSDP peering relationship between Switch D and Switch F through IBGP.
2.4.3  Network Diagram
Device
IP address
Device
IP address
SwitchA
Vlan-int100
10.110.1.2/24
Switch D
Vlan-int300
10.110.4.1/24
Vlan-int200
10.110.6.1/24
Vlan-int102
192.168.3.1/24
Vlan-int300
10.110.5.1/24
Vlan-int101
192.168.1.2/24
SwitchB
Vlan-int100
10.110.7.1/24
Loop0
2.2.2.2/32
Vlan-int200
10.110.2.2/24
Switch E
Vlan-int100
10.110.8.1/24
Vlan-int300
10.110.5.2/24
Vlan-int200
10.110.9.1/24
Switch C
Vlan-int100
10.110.1.1/24
Vlan-int300
10.110.4.2/24
Vlan-int200
10.110.2.1/24
Loop0
2.2.2.2/32
Vlan-int101
192.168.1.1/24
Switch F
Vlan-int400
10.110.3.1/24
Loop0
1.1.1.1/32
Vlan-int102
192.168.3.2/24
Loop0
3.3.3.3/32
SwitchG
Vlan-int100
10.110.10.1/24
Vlan-int400
10.110.3.2/24
Figure 2-4 Network diagram for MSDP configuration
2.4.4  Configuration Procedure
I. Configuring an interface IP address and a unicast routing protocol for each switch
Configure an IP address and a subnet mask for each interface as per Figure 2-4. The detailed configuration steps are not discussed in this document.
Configure OSPF for interoperation between switches in each PIM-SM domain. Ensure the network-layer interoperation among Switch A, Switch B and Switch C in PIM-SM 1, the network-layer interoperation between Switch D and Switch E in PIM-SM 2, and the network-layer interoperation between Switch F and Switch G in PIM-SM 3, and ensure the dynamic update of routing information between the switches in each PIM-SM domain through the unicast routing protocol.
II. Configuring a unicast routing protocol for each AS
# Configure OSPF on Switch C.
<SwitchC> system-view.
[SwitchC]ospf
[SwitchC-ospf-1]area 0
[SwitchC-ospf-1-area-0.0.0.0]network 10.110.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0]network 10.110.2.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0]network 1.1.1.1 0.0.0.0
The configuration on Switch A, Switch B, Switch D, Switch E, Switch F and Switch G is similar to the configuration on Switch C.
III. Configuring a multicast routing protocol
1)         Enable IP multicast routing, enable PIM-SM on each interface, and enable IGMP on the interfaces connected with receivers.
# Enable IP multicast routing on Switch A, enable PIM-SM on each interface, and enable IGMP on VLAN-interface 200.
[SwitchA-Vlan-interface200] pim sm
[SwitchA-Vlan-interface200] igmp enable
[SwitchA] interface vlan-interface 300
The configuration on Switch E and Switch G is similar to the configuration on Switch A. The specific configuration steps are omitted here.
# Enable IP multicast routing on Switch C and enable PIM-SM on each interface.
[SwitchC] multicast routing-enable
[SwitchC-Vlan-interface100] pim sm
[SwitchC-Vlan-interface200] pim sm
[SwitchC] interface vlan-interface 101
[SwitchC-Vlan-interface101] pim sm
The configuration on Switch B, Switch D, and Switch F is similar to the configuration on Switch C. The specific configuration steps are omitted here.
# Configure a BSR boundary on Switch C.
[SwitchC-Vlan-interface101] pim bsr-boundary
[SwitchC-Vlan-interface101] quit
The configuration on Switch D and Switch F is similar to the configuration on Switch C.
2)         Configure the position of interface Loopback 0, C-BSR, and C-RP.
# Configure the position of Loopback 0, C-BSR, and C-RP on Switch C.
[SwitchC-LoopBack0] ip address 1.1.1.1 255.255.255.255
[SwitchC-LoopBack0] pim sm
[SwitchC-LoopBack0] quit
[SwitchC] pim
[SwitchC-pim] c-bsr loopback 0 24
[SwitchC-pim] c-rp loopback 0
[SwitchC-pim] quit
IV. Configuring inter-AS BGP for mutual route redistribution between BGP and OSPF
# Configure EBGP on Switch C, and configure OSPF route redistribution.
[SwitchC] bgp 100
[SwitchC-bgp] group 100 external
[SwitchC-bgp] peer 192.168.1.2 group 100 as-number 200
[SwitchC-bgp] import-route ospf 1
[SwitchC-bgp] import-route direct
[SwitchC-bgp] quit
# Configure IBGP and EBGP on Switch D, and configure OSPF route redistribution.
[SwitchD] bgp 200
[SwitchD-bgp] group 100 external
[SwitchD-bgp] group 200
[SwitchD-bgp] peer 192.168.1.1 group 100 as-number 100
[SwitchD-bgp] peer 192.168.3.2 group 200
[SwitchD-bgp] import-route ospf 1
[SwitchD-bgp] import-route direct
[SwitchD-bgp] quit
# Configure IBGP on Switch F, and configure OSPF route redistribution.
[SwitchF] bgp 200
[SwitchF-bgp] group 200
[SwitchF-bgp] peer 192.168.3.1 group 200
[SwitchF-bgp] import-route ospf 1
[SwitchF-bgp] import-route direct
[SwitchF-bgp] quit
# Configure BGP route redistribution to OSPF on Switch C.
[SwitchC] ospf 1
[SwitchC-ospf-1] import-route bgp
[SwitchC-ospf-1] quit
Carry out the display bgp peer command to view the BGP peering relationships between the switches. For example:
# View the information about BGP peering relationships on Switch C.
[SwitchC] display bgp peer
    Peer        AS-num Ver Queued-Tx    Msg-Rx    Msg-Tx    Up/Down  State
192.168.1.2       200  4          0        950        945   15:41:14 Established
# View the information about BGP peering relationships on Switch D.
[SwitchD] display bgp peer
192.168.1.1       100  4          0        946        953   15:43:32 Established
192.168.3.2       200  4          0        946        954   15:41:18 Established
# View the information about BGP peering relationships on Switch F.
[SwitchF] display bgp peer
192.168.3.1       200  4          0        953        948   15:42:23 Established
V. Configuring MSDP peers
# Configure an MSDP peer on Switch C.
[SwitchC] msdp
[SwitchC-msdp] peer 192.168.1.2 connect-interface vlan-interface 101
[SwitchC-msdp] quit
# Configure an MSDP peer on Switch D.
[SwitchD] msdp
[SwitchD-msdp] peer 192.168.1.1 connect-interface vlan-interface 101
[SwitchD-msdp] peer 192.168.3.2 connect-interface vlan-interface 102
[SwitchD-msdp] quit
# Configure MSDP peers on Switch F.
[SwitchF] msdp
[SwitchF-msdp] peer 192.168.3.1 connect-interface vlan-interface 102
[SwitchF-msdp] quit
When the multicast source Source 1 sends multicast information, receivers in PIM-SM2 and PIM-SM3 can receive the multicast data. You can use the display msdp brief command to view the brief information of MSDP peering relationships between the switches. For example:
# View the brief information about MSDP peering relationships on Switch C.
[SwitchC] display msdp brief
MSDP Peer Brief Information
 Peer's Address     State     Up/Down time    AS     SA Count   Reset Count
 192.168.1.2         Up        00:12:27         200    13         0
# View the brief information about MSDP peering relationships on Switch D.
[SwitchD] display msdp brief
 192.168.3.2         Up        00:15:32         200    8          0
 192.168.1.1         UP        00:06:39         100    13         0
# View the brief information about MSDP peering relationships on Switch F.
[SwitchF] display msdp brief
 192.168.3.1         UP         01:07:08        200    8          0
# View the detailed MSDP peer information on Switch C.
[SwitchC] display msdp peer-status
  MSDP Peer 192.168.1.2, AS 200
  Description:
  Information about connection status:
    State: Up
    Up/down time: 00:15:47
    Resets: 0
    Connection interface: Vlan-interface101 (192.168.1.1)
    Number of sent/received messages: 16/16
    Number of discarded output messages: 0
    Elapsed time since last connection or counters clear: 00:17:51
  Information about (Source, Group)-based SA filtering policy:
    Import policy: none
    Export policy: none
  Information about SA-Requests:
    Policy to accept SA-Request messages: none
    Sending SA-Requests status: disable
  Minimum TTL to forward SA with encapsulated data: 0
  SAs learned from this peer: 0, SA-cache maximum for the peer: none
  Input queue size: 0, Output queue size: 0
  Counters for MSDP message:
    Count of RPF check failure: 0
    Incoming/outgoing SA messages: 0/0
    Incoming/outgoing SA requests: 0/0
    Incoming/outgoing SA responses: 0/0
    Incoming/outgoing data packets: 0/0
