H3C S3100-52P Operation Manual-Release 1602(V1.01)
HomeSupportSwitchesS3100 SeriesConfigure & DeployConfiguration GuidesH3C S3100-52P Operation Manual-Release 1602(V1.01)
30-File System Management Operation
30-File System Management Operation 56.36 KB
Chapter 1  File System Management Configuration
&  Note:
For information on the modification of the order for the device to select Web file when the device boots, refer to Booting with the Startup File.
1.1  File System Configuration
1.1.1  Introduction to File System
To facilitate management on the switch memory, S3100-52P Ethernet switches provide the file system function, allowing you to access and manage the files and directories. You can create, remove, copy or delete a file through command lines, and you can manage files using directories.
1.1.2  File System Configuration Tasks
Table 1-1 Configuration tasks on the file system
Operation
Remarks
Directory Operations
Optional
File Operations
Optional
Flash Memory Operations
Optional
Prompt Mode Configuration
Optional
&  Note:
S3100-52P Ethernet switches allow you to input a file path and file name in one of the following ways:
l      In universal resource locator (URL) format and starting with “unit1>flash:/”. or “flash:/” This method is used to specify a file in the current Flash memory. For example, the URL of a file named text.txt in the root directory of the switch is unit1>flash:/text.txt or flash:/text.txt.
l      Entering the path name or file name directly. This method can be used to specify a path or a file in the current work directory. For example, to access file text.txt in the current directory, you can directly input the file name text.txt as the file URL.
1.1.3  Directory Operations
The file system provides directory-related functions, such as:
l           Creating/deleting a directory
l           Displaying the current work directory, or contents in a specified directory
Table 1-2 describes the directory-related operations.
Perform the following configuration in user view.
Table 1-2 Directory operations
To do…
Use the command…
Remarks
Create a directory
mkdir directory
Optional
Delete a directory
rmdir directory
Optional
Display the current work directory
pwd
Optional
Display the information about specific directories and files
dir [ /all ] [ file-url ]
Optional
Enter a specified directory
cd directory
Optional
&  Note:
l      Only empty directories can be deleted by using the rmdir command.
l      In the output information of the dir /all command, deleted files (that is, those stored in the recycle bin) are embraced in brackets.
1.1.4  File Operations
The file system also provides file-related functions listed in Table 1-3.
Perform the following configuration in user view. Note that the execute command should be executed in system view.
Table 1-3 File operations
To do…
Use the command…
Remarks
Delete a file
delete [ /unreserved ] file-url
delete { running-files | standby-files } [ /unreserved ]
Optional
A deleted file can be restored by using the undelete command if you delete it by executing the delete command without specifying the /unreserved keyword.
Restore a file in the recycle bin
undelete file-url
Optional
Delete a file from the recycle bin
reset recycle-bin [ file-url ] [ /force ]
Optional
Rename a file
rename fileurl-source fileurl-dest
Optional
Copy a file
copy fileurl-source fileurl-dest
Optional
Move a file
move fileurl-source fileurl-dest
Optional
Display the content of a file
more file-url
Optional
Currently, the file system only supports displaying the contents of text files.
Display the information about a directory or a file
Optional
Enter system view
Execute the specified batch file
execute filename
Optional
This command should be executed in system view.
  Caution:
l      For deleted files whose names are the same, only the latest deleted file is kept in the recycle bin and can be restored.
l      The files which are deleted by the delete command without the /unreserved keyword are actually moved to the recycle bin and thus still take storage space. You can clear the recycle bin by using the reset recycle-bin command.
l      The dir /all command displays the files in the recycle bin in square brackets.
l      If the configuration files are deleted, the switch adopts the null configuration when it starts up next time.
1.1.5  Flash Memory Operations
Perform the following Flash memory operations using commands listed in Table 1-4.
Table 1-4 Operations on the Flash memory
To do…
Use the command…
Remarks
Format the Flash memory
format device
Required
Restore space on the Flash memory
fixdisk device
Required
  Caution:
The format operation leads to the loss of all files, including the configuration files, on the Flash memory and is irretrievable.
1.1.6  Prompt Mode Configuration
You can set the prompt mode of the current file system to alert or quiet. In alert mode, the file system will give a prompt for confirmation if you execute a command which may cause data loss, for example, deleting or overwriting a file. In quiet mode, such prompt will not be displayed.
Table 1-5 Configuration on prompt mode of file system
To do…
Use the command…
Remarks
Enter system view
Configure the prompt mode of the file system
file prompt { alert | quiet }
Required
By default, the prompt mode of the file system is alert.
1.1.7  File System Configuration Example
# Display all the files in the root directory of the file system.
<Sysname> dir /all
Directory of unit1>flash:/
   1 (*)   -rw-   3579326  Mar 28 2007 10:51:22   test.bin
   2 (*)   -rw-      1235  Apr 03 2000 16:04:52   config.cfg
   3       -rwh       151  Apr 03 2000 16:04:55   private-data.txt
   4       -rwh       716  Apr 04 2000 17:27:35   hostkey
   5       -rwh       572  Apr 04 2000 17:27:41   serverkey
   6       -rwh       548  Apr 04 2000 17:30:06   dsakey
   7       drw-         -  Apr 04 2000 23:04:21   test
7239 KB total (3585 KB free)
(*) -with main attribute   (b) -with backup attribute
(*b) -with both main and backup attribute
# Copy the file flash:/config.cfg to flash:/test/, with 1.cfg as the name of the new file.
<Sysname> copy flash:/config.cfg flash:/test/1.cfg
Copy unit1>flash:/config.cfg to unit1>flash:/test/1.cfg?[Y/N]:y
%Copy file unit1>flash:/config.cfg to unit1>flash:/test/1.cfg...Done.
# Display the file information after the copy operation.
<Sysname> dir /all
<Sysname> dir unit1>flash:/test/
Directory of unit1>flash:/test/
   1       -rw-      1235  Apr 05 2000 01:51:34   test.cfg
   2       -rw-      1235  Apr 05 2000 01:56:44   1.cfg
1.2  File Attribute Configuration
1.2.1  Introduction to File Attributes
The following three startup files support file attribute configuration:
l           App files: An app file is an executable file, with .bin as the extension.
l           Configuration files: A configuration file is used to store and restore configuration, with .cfg as the extension.
l           Web files: A Web file is used for Web-based network management, with .web as the extension.
The app files, configuration files, and Web files support three kinds of attributes: main, backup and none, as described in Table 1-6.
Table 1-6 Descriptions on file attributes
Attribute name
Feature
Identifier
main
Identifies main startup files. The main startup file is preferred for a switch to start up.
In the Flash memory, there can be only one app file, one configuration file and one Web file with the main attribute.
backup
Identifies backup startup files. The backup startup file is used after a switch fails to start up using the main startup file.
In the Flash memory, there can be only one app file, one configuration file and one Web file with the backup attribute.
(b)
none
Identifies files that are neither of main attribute nor backup attribute.
None
&  Note:
A file can have both the main and backup attributes. Files of this kind are labeled *b.
Note that, there can be only one app file, one configuration file and one Web file with the main attribute in the Flash memory. If a newly created file is configured to be with the main attribute, the existing file with the main attribute in the Flash memory will lose its main attribute. This circumstance also applies to the file with the backup attribute in the Flash memory.
File operations and file attribute operations are independent. For example, if you delete a file with the main attribute from the Flash memory, the other files in the flash memory will not possess the main attribute. If you download a valid file with the same name as the deleted file to the flash memory, the file will possess the main attribute.
After the Boot ROM of a switch is upgraded, the original default app file has the main attribute.
1.2.2  Booting with the Startup File
The device selects the main startup file as the preferred startup file. If the device fails to boot with the main startup file, it boots with the backup startup file.
For the Web file and configuration file, Hangzhou H3C Technologies Co., Ltd (referred to as H3C hereinafter) may provide corresponding default file when releasing software versions. When booting, the device selects the startup files based on certain order. The device selects Web files in the following steps:
1)         If the default Web file exists, the device will boot with the default Web file;
2)         If the default Web file does not exist, but the main Web file exists, the device will boot with the main Web file;
3)         If neither the default Web file nor the main Web file exists, but the backup Web exists, the device will boot with the backup Web file;
4)         If neither of the default Web file, main Web file and backup Web exists, the device considers that no Web file exists.
For the selection of the configuration file when the device boots, refer to the Configuration File Management part in this manual.
1.2.3  Configuring File Attributes
You can configure and view the main attribute or backup attribute of the startup file used for the next startup of a switch, and change the main or backup attribute of the file.
Perform the configuration listed in Table 1-7 in user view. The display commands can be executed in any view.
Table 1-7 Configure file attributes
To do…
Use the command…
Remarks
Configure the app file with the main attribute for the next startup
boot boot-loader file-url
Optional
Configure the app file with the backup attribute for the next startup
boot boot-loader backup-attribute file-url
Optional
Configure the Web file and its attribute
boot web-package webfile { backup | main }
Optional
Switch the file attributes between main and backup
boot attribute-switch { all | app | configuration | web }
Optional
Specify to enable user to use the customized password to enter the BOOT menu
startup bootrom-access enable
Optional
By default, the user is enabled to use the customized password to enter the BOOT menu.
Display the information about the app file used as the startup file
display boot-loader [ unit unit-id ]
Optional
Available in any view
Display information about the Web file used by the device
display web package
  Caution:
l      The configuration of the main or backup attribute of a Web file takes effect immediately without restarting the switch.
l      After upgrading a Web file, you need to specify the new Web file in the Boot menu after restarting the switch or specify a new Web file by using the boot web-package command. Otherwise, Web server cannot function normally.
l      Currently, a configuration file has the extension of cfg and resides in the root directory of the Flash memory.
l      For the detailed configuration of configuration file attributes, refer to the Configuration File Management module in this manual.
