H3C S3100-52P Operation Manual-Release 1602(V1.01)
HomeSupportSwitchesS3100 SeriesConfigure & DeployConfiguration GuidesH3C S3100-52P Operation Manual-Release 1602(V1.01)
00-2Product Overview
00-2Product Overview 188.09 KB
Chapter 1  Obtaining the Documentation
Hangzhou H3C Technologies Co., Ltd. (hereafter referred to as H3C) provides various ways for you to obtain product documents and new feature releases in a convenient and timely manner. The documentations are available with:
l           CD-ROMs shipped with the devices
l           H3C website
l           Software release notes
1.1  CD-ROM
H3C delivers a CD-ROM together with each device. The CD-ROM contains a complete set of electronic documents of the product, including operation manuals and command manuals. After installing the reader program provided by the CD-ROM, you can search for the desired contents in a convenient way through the reader interface.
The contents in the manual are subject to update on an irregular basis due to product version upgrade or some other reasons. Therefore, the contents in the CD-ROM may not be the latest version. This manual serves the purpose of user guide only. Unless otherwise noted, all the information in the document set does not claim or imply any warranty. For the latest software documentation, go to the H3C website.
1.2  H3C Website
Perform the following steps to query and download the product documentation from the H3C website.
Table 1-1 Acquire product documentation from the H3C website
How to apply for an account
Access the homepage of H3C at http:// www.h3c.com and click the Registration link at the top right. In the displayed page, provide your information and click Submit.
How to get documentation
Approach 1:
In the homepage of H3C at http:// www.h3c.com, select Technical Support & Document > Technical Documents from the navigation menu at the top. Then select a product for its documents.
Approach 2:
In the homepage of H3C at http:// www.h3c.com, select Support > Technical Documents. Then select a product for its documents.
1.3  Software Release Notes
With software upgrade, new software features may be added. You can acquire the information about the newly added software features through software release notes.
Chapter 2  Correspondence Between Documentation and Software
2.1  Software Version
H3C S3100-52P Ethernet Switch Operation Manual-Release 1602 and H3C S3100-52P Ethernet Switch Command Manual-Release 1602 are for the software version of Release1602 of the S3100-52P product.
l           Compared with Release 1500, many new features are added in Release 1602. For details, refer to Table 2-1.
l           Compared with Release 1500, a feature is removed from Release 1602. For details, refer to Table 2-2.
l           Compared with Release 1500, two features are modified in Release 1602. For details, refer to Table 2-3.
Table 2-1 Added features in Release 1602
Added feature in Release 1602
Manual
Specifying the authentication mode for user level switching
01-CLI
Adopting HWTACACS authentication for user level switching
Copyright information is displayed when a Telnet user logs in
02-Login
Banner information is displayed when a user logs in through Web
Auto-negotiation rate configuration for the current port
08-Port Basic Configuration
Packet traffic threshold configuration for ports
Display of the statistics of discarded packets on ports
Configuration of the delay time of sending state-change traps for the current port
Inter-device port isolation
10-Port Isolation
New port security modes: macAddressAndUserLoginSecure and macAddressAndUserLoginSecureExt
11-Port Security-Port Binding
Destination MAC address update
13-MAC Address Table Management
STP maintainability
14-MSTP
802.1d-compliant traps
Support of IGMPv3 Snooping
16-Multicast Protocol
Support of IGMPv3 Snooping simulated joining
Support of suppressing flooding of unknown multicast traffic in the VLAN
Support of static member port configuration
Support of static router port configuration
Support of VLAN tag configuration for query messages
Online user handshake
17-802.1x and System-Guard
Support of 802.1x re-authentication configuration
Support of 802.1x re-authentication timeout configuration
Quick deployment of EAD
Support of domain delimiter configuration
18-AAA
Support of HWTACACS scheme configuration for ISP domain user level switching
Setting of MAC address format of the Calling-Station-Id (Type 31) field in RADIUS packets
Web authentication
19-Web Authentication
Support of fixed password configuration when a MAC address is used as a user name
20-MAC Address Authentication
Enhanced MAC authentication functions
ARP attack detection
21-ARP
ARP packet rate limiting
Support of Option 82 in DHCP Snooping
22-DHCP
IP filtering
DHCP packet rate limiting
Applying ACLs to VLANs
23-ACL
Configuration of inner VLAN information for Layer 2 ACLs
VLAN mapping
24-QoS-QoS Profile
Configuration of burst traffic for port rate limiting and traffic policing
Configuration of priority remarking in VLANs
Redirecting traffic to an aggregation port group and removing the outer VLAN tag after the traffic is redirected to the uplink port or the aggregation port group
Burst function
Creating a MIB view with the mask of a MIB subtree
27-SNMP-RMON
Encrypting a plain-text password
Adding interface description and interface type in linkUp/linkDown Trap message
Support of the DSA asymmetric key algorithm
29-SSH
Banner information of the FTP server
31-FTP-SFTP-TFTP
Displaying timestamp with the UTC time zone
32-Information Center
Configuration of real-time monitoring of system running status
33-System Maintenance and Debugging
Hot patching
Viewing and diagnosing hot-pluggable transceivers
Selective QinQ
34-VLAN-VPN
Support of multiple types of protocol packets for BPDU Tunneling
Customizing tunnel packet MAC addresses
Eight test types are added in HWPing, including DHCP test, FTP test, HTTP test, DNS test, SNMP test, Jitter test, TCP test, and UDP test
35-HWping
Maximum number of history records that can be saved
IPv6 management
36-IPv6 Management
Smart Link
38-Smart Link-Monitor Link
Monitor Link
Table 2-2 Deleted feature from Release 1602
Deleted feature
Manual
CLI language mode setting
Table 2-3 Modified features in Release 1602
Modified feature
Manual
Support of up to 128 characters in a domain name, compared with the original 24 characters
18-AAA
Sequence of selecting Web files
30-File System Management
2.2  Manual List
Manual name
H3C S3100-52P Ethernet Switch Installation Manual
Chapter 3  Product Overview
3.1  Preface
H3C S3100-52P Ethernet switch is a Layer 2 wire speed Ethernet switch developed by H3C independently. It is the intelligent and manageable switch designed for network environments where high performance, high port density, and ease of installation are required.
3.2  Switch Models
Table 3-1 lists the H3C S3100-52P Ethernet Switch model.
Table 3-1 Models in the S3100-52P
Model
Power supply unit (PSU)
Number of service ports
Number of 100 Mbps ports
Number of 1,000 Mbps uplink ports
Console port
H3C S3100-52P
AC-input
52
48 10/100 Mbps ports(electrical)
4 Gigabit (SFP) ports
1
3.3  Software Features
S3100-52P Ethernet Switch has abundant software features and can meet the requirements of different applications. Table 3-2 summarizes the features provided by each module.
Table 3-2 Service features of the S3100-52P
Part
Features
1 CLI
l      CLI
l      Hierarchically grouped commands
l      CLI online help
2 Login
l      Logging into a switch through the Console port
l      Logging into a switch through an Ethernet port by using Telnet or SSH
l      Logging into a switch through the Console port by using modem
l      Logging into a switch through Web or NMS
l      Controlling user login using ACL
3 Configuration File Management
Saving, restoring, and deleting the configuration file
4 VLAN
l      IEEE 802.1Q-compliant VLAN
l      Port-based VLAN
l      Protocol-based VLAN
5 IP Address and Performance
l      Configuring an IP address for a switch
l      Configuring the TCP attributes for a switch
l      Enabling/disabling the switch to send ICMP error messages
6 Voice VLAN
Voice VLAN
7 GVRP
GARP VLAN registration protocol (GVRP)
8 Port Basic Configuration
l      Configuring port auto-negotiation rate
l      Limiting traffic on a port
l      Setting broadcast storm suppression globally
l      Loopback detection supported
l      Cable test
9 Link Aggregation
Link aggregation control protocol (LACP)
10 Port Isolation
Port isolation group
11 Port Security-Port Binding
l      Multiple security modes
l      MAC address-to-IP address-to-port binding
12 DLDP
Device link detection protocol (DLDP)
13 MAC Address Table Managemen
l      Manually configuring dynamic, static, and black hole MAC addresses
l      Configuring the aging time for MAC addresses
l      MAC address learning limit
14 MSTP
l      STP/RSTP/MSTP
l      The following guard functions are available on an MSTP-enabled switch: BPDU guard, root guard, loop guard, TC-BPDU attack guard, and BPDU drop
l      Digest snooping
l      Rapid transition
l      VLAN-VPN TUNNEL
l       H3C-proprietary MSTP path cost standard
15 Static Route
Static route
16 Multicast
Internet group management protocol snooping (IGMP Snooping)
17802.1x and System Guard
l      802.1X authentication
l      Guest VLAN
l      Quick deployment of EAD
l      Huawei authentication bypass protocol (HABP)
l      System guard
18 AAA
l      Authentication, authorization, and accounting (AAA)
l      Remote authentication dial-In user service (RADIUS)
l      Huawei terminal access controller access control system (HWTACACS)
l      Endpoint admission defense (EAD)
19 Web Authentication
Web authentication
20 MAC Address Authentication
l      MAC address authentication
l      Enhanced MAC address authentication
21 ARP
l      Gratuitous ARP
l      Manually configuring ARP entries
l      ARP attack detection
l      ARP packet rate limiting
22 DHCP
l      DHCP client/BOOTP client
l      DHCP Snooping
l      Using Option82 in DHCP Snooping
l      DHCP packet rate limitation
23 ACL
l      Basic ACLs
l      Advanced ACLs
l      Layer 2 ACLs
l      User-defined ACLs
l      Applying ACLs on ports
l      Applying ACLs to VLANs
24 QoS-QoS Profile
l      Quality of Service (QoS)
l      QoS profile
25 Mirroring
l      Traffic mirroring
l      Local port mirroring
l      Remote port mirroring
26 Stack-Cluster
l      Stack
l      Huawei group management protocol (HGMP) v2
l      Neighbor discovery protocol (NDP)
l      Neighbor topology discovery protocol (NTDP)
27 SNMP-RMON
l      Simple network management protocol (SNMP) v3, compatible with SNMP v1/v2
l      Support of Trap parameters configuration
l      Remote monitoring (RMON)
28 NTP
Network time protocol (NTP)
29 SSH Terminal Service
Secure shell (SSH) v2.0, compatible with SSHv1.5
30 File System Management
l      File system configuration
l      File attribute configuration
31 FTP-SFTP-TFTP
l      Operating as an FTP server/FTP client
l      Operating as an SFTP server/SFTP client
l      Operating as a TFTP client
32 Information Center
l      System logs
l      Hierarchical alarms
l      Debugging information output
33 System Maintenance and Debugging
l      Loading Boot ROM and software in multiple ways
l      Basic system configuration and debugging
l      Network connectivity test
l      Device management
34 VLAN-VPN
l      VLAN VPN (QinQ)
l      Selective QinQ
l      BPDU Tunnel
l      Configuring VLAN VPN interior-layer priority replication
l      Configuring TPID value
35 HWPing
l      Operating as a HWPing server/HWPing client
l      Nine test types, including ICMP test, DHCP test, FTP test, HTTP test, DNS test, SNMP test, jitter test, TCP test, and UDP test
36 IPv6 Management
l      IPv6 management
l      IPv6 static route
l      IPv6 DNS
37 DNS
IPv4 Domain Name System (DNS)
38 Smart Link-Monitor Link
l      Smart Link
l      Monitor Link
Chapter 4  Networking Applications
You can deploy S3100-52P Ethernet switch on many types of networks, such as enterprise networks and broadband access networks. Following are several typical networking applications.
4.1  Broadband Ethernet Access for Residential Communities
On the broadband access network of a residential community, an S3100-52P Ethernet switch is located in the center. It is downlinked to S3100 series switches to reach the Ethernet users and uplinked to a core Layer 3 switch through a GE extension module to connect to the MAN backbone.
Figure 4-1 Connecting community Ethernet to MAN using S3100-52P Ethernet switch
4.2  Application for Connecting Branches or Small- to Medium-Sized Enterprises
For small-to medium-sized enterprises or branches of a large enterprise, S3100-52P Ethernet switch can serve as a downstream device connected to the backbone switch, and can be connected to the headquarters or other branches through Layer 3 switches or routers. As the enterprise size increases, the network also can expand by subtending the S3100-52P Ethernet switch.
Figure 4-2 S3100-52P Ethernet switch application in branch network of midsize/large enterprise
4.3  Application in Large Enterprise and Campus Networks
In a large enterprise or campus network, the S3100-52P Ethernet switch can operate on the access layer. They are uplinked to layer 3 switches, S3600 Series or S5600 Series for example; and uplinked to a layer 3 switch. These switches together provide a network-wide intranet solution that covers Gigabit-to-backbone and 100 Mbps-to-desktop.
Figure 4-3 S3100-52P Ethernet switch application in large enterprise and campus network
