H3C S3100-52P Operation Manual-Release 1602(V1.01)
HomeSupportSwitchesS3100 SeriesConfigure & DeployConfiguration GuidesH3C S3100-52P Operation Manual-Release 1602(V1.01)
08-Port Basic Configuration Operation
08-Port Basic Configuration Operation 107.56 KB
Chapter 1  Port Basic Configuration
When performing port basic configuration, go to these sections for information you are interested in:
l           Ethernet Port Configuration
l           Ethernet Port Configuration Example
l           Troubleshooting Ethernet Port Configuration
&  Note:
l      The auto-negotiation speed configuration is added to this manual. For details, refer to Configuring Port Auto-Negotiation Speed.
l      The storm control function is added to this manual. For details, refer to Configuring Storm Control on a Port.
l      The displaying and maintaining of the statistics on dropped packets is added to this manual. For details, refer to Displaying and Maintaining Basic Port Configuration.
l      The port state change delay configuration is added to this manual. For details, refer to Setting the Port State Change Delay.
l      Disable a port from generating UP/Down log is added to this manual. For details, refer to Disabling Up/Down Log Output on a Port.
1.1  Ethernet Port Configuration
1.1.1  Initially Configuring a Port
Follow these steps to initially configure a port:
To do...
Use the command...
Remarks
Enter system view
Enter Ethernet port view
Enable the Ethernet port
Optional
By default, the port is enabled.
Use the shutdown command to disable the port.
Set the description string for the Ethernet port
Optional
By default, the description string of an Ethernet port is null.
Set the duplex mode of the Ethernet port
duplex { auto | full | half }
Optional
By default, the duplex mode of the port is auto (auto-negotiation).
Set the speed of the Ethernet port
speed { 10 | 100 | 1000 | auto }
Optional
l      By default, the speed of an Ethernet port is determined through auto-negotiation (the auto keyword).
l      Use the 1000 keyword for Gigabit Ethernet ports only.
Set the medium dependent interface (MDI) mode of the Ethernet port
mdi { across | auto | normal }
Optional
Be default, the MDI mode of an Ethernet port is auto.
Set the maximum frame size allowed on the Ethernet port to 9,216 bytes
jumboframe enable
Optional
By default, the maximum frame size allowed on an Ethernet is 9,216 bytes. To set the maximum frame size allowed on an Ethernet port to 1,536 bytes, use the undo jumboframe enable command.
1.1.2  Configuring Port Auto-Negotiation Speed
You can configure an auto-negotiation speed for a port by using the speed auto command.
Take a 10/100/1000 Mbps port as an example.
l           If you expect that 10 Mbps is the only available auto-negotiation speed of the port, you just need to configure speed auto 10.
l           If you expect that 10 Mbps and 100 Mbps are the available auto-negotiation speeds of the port, you just need to configure speed auto 10 100.
l           If you expect that 10 Mbps and 1000 Mbps are the available auto-negotiation speeds of the port, you just need to configure speed auto 10 1000.
Follow these steps to configure auto-negotiation speeds for a port:
To do...
Use the command...
Remarks
Enter system view
Enter Ethernet interface view
Configure the available auto-negotiation speed(s) for the port
speed auto [ 10 | 100 | 1000 ]*
Optional
l      By default, the port speed is determined through auto-negotiation.
&  Note:
l      Only ports on the front panel of the device support the auto-negotiation speed configuration feature. And ports on the extended interface card do not support this feature currently.
l      After you configure auto-negotiation speed(s) for a port, if you execute the undo speed command or the speed auto command, the auto-negotiation speed setting of the port restores to the default setting.
l      The effect of executing speed auto 10 100 1000 equals to that of executing speed auto, that is, the port is configured to support all the auto-negotiation speeds: 10 Mbps, 100 Mbps, and 1000 Mbps.
1.1.3  Limiting Traffic on individual Ports
By performing the following configurations, you can limit the incoming broadcast/multicast/unknown unicast traffic on individual ports. When a type of incoming traffic exceeds the threshold you set, the system drops the packets exceeding the traffic limit to reduce the traffic ratio of this type to the reasonable range, so as to keep normal network service.
Follow these steps to limit traffic on port:
To do...
Use the command...
Remarks
Enter system view
Limit broadcast traffic received on each port
broadcast-suppression { ratio | pps max-pps }
Optional
By default, the switch does not suppress broadcast traffic.
Limit broadcast traffic received on the current port
Optional
Limit multicast traffic received on the current port
multicast-suppression { ratio | pps max-pps }
Optional
By default, the switch does not suppress multicast traffic.
Limit unknown unicast traffic received on the current port
unicast-suppression { ratio | pps max-pps }
Optional
By default, the switch does not suppress unknown unicast traffic.
1.1.4  Enabling Flow Control on a Port
Flow control is enabled on both the local and peer switches. If congestion occurs on the local switch:
l           The local switch sends a message to notify the peer switch of stopping sending packets to itself or reducing the sending rate temporarily.
l           The peer switch will stop sending packets to the local switch or reduce the sending rate temporarily when it receives the message; and vice versa. By this way, packet loss is avoided and the network service operates normally.
Follow these steps to enable flow control on a port:
To do...
Use the command...
Remarks
Enter system view
Enable flow control on the Ethernet port
flow-control
Required
By default, flow control is not enabled on the port.
1.1.5  Duplicating the Configuration of a Port to Other Ports
To make other ports have the same configuration as that of a specific port, you can duplicate the configuration of a port to specific ports.
Specifically, the following types of port configuration can be duplicated from one port to other ports: VLAN configuration, protocol-based VLAN configuration, LACP configuration, QoS configuration, GARP configuration, STP configuration and initial port configuration. Refer to the command manual for the configurations that can be duplicated.
Follow these steps to duplicate the configuration of a port to specific ports:
To do...
Use the command...
Remarks
Enter system view
Duplicate the configuration of a port to specific ports
copy configuration source { interface-type interface-number | aggregation-group source-agg-id } destination { interface-list [ aggregation-group destination-agg-id ] | aggregation-group destination-agg-id }
Required
&  Note:
l      If you specify a source aggregation group ID, the system will use the port with the smallest port number in the aggregation group as the source.
l      If you specify a destination aggregation group ID, the configuration of the source port will be copied to all ports in the aggregation group and all ports in the group will have the same configuration as that of the source port.
1.1.6  Configuring Loopback Detection for an Ethernet Port
Loopback detection is used to monitor if loopback occurs on a switch port.
After you enable loopback detection on Ethernet ports, the switch can monitor if external loopback occurs on them. If there is a loopback port found, the switch will put it under control.
l           If loopback is found on an access port, the system disables the port, sends a Trap message to the client and removes the corresponding MAC forwarding entry.
l           If loopback is found on a trunk or hybrid port, the system sends a Trap message to the client. When the loopback port control function is enabled on these ports, the system disables the port, sends a Trap message to the client and removes the corresponding MAC forwarding entry.
Follow these steps to configure loopback detection for an Ethernet port:
To do...
Use the command...
Remarks
Enter system view
Enable loopback detection globally
loopback-detection enable
Required
By default, loopback detection is disabled globally.
Set the interval for performing port loopback detection
loopback-detection interval-time time
Optional
The default is 30 seconds.
Enable loopback detection on a specified port
Required
By default, port loopback detection is disabled.
Enable loopback port control on the trunk or hybrid port
loopback-detection control enable
Optional
By default, loopback port control is not enabled.
Configure the system to run loopback detection on all VLANs of the current trunk or hybrid port
loopback-detection per-vlan enable
Optional
By default, the system runs loopback detection only on the default VLAN of the current trunk or hybrid port.
  Caution:
l      To enable loopback detection on a specific port, you must use the loopback-detection enable command in both system view and the specific port view.
l      After you use the undo loopback-detection enable command in system view, loopback detection will be disabled on all ports.
1.1.7  Enabling Loopback Test
You can configure the Ethernet port to run loopback test to check if it operates normally. The port running loopback test cannot forward data packets normally. The loopback test terminates automatically after a specific period.
Follow these steps to enable loopback test:
To do...
Use the command...
Remarks
Enter system view
Enable loopback test
Required
&  Note:
l      external: Performs external loop test. In the external loop test, self-loop headers  must be used on the port of the switch ( for 100M port, the self-loop headers are made from four cores of the 8-core cables, for 1000M port, the self-loop header are made from eight cores of the 8-core cables, then the packets forwarded by the port will be received by itself.). The external loop test can locate the hardware failures on the port.
l      internal: Performs internal loop test. In the internal loop test, self loop is established in the switching chip to locate the chip failure which is related to the port.
Note that:
l           After you use the shutdown command on a port, the port cannot run loopback test.
l           You cannot use the speed, duplex, mdi and shutdown commands on the ports running loopback test.
l           Some ports do not support loopback test, and corresponding prompts will be given when you perform loopback test on them.
1.1.8  Enabling the System to Test Connected Cable
You can enable the system to test the cable connected to a specific port. The test result will be returned in five seconds. The system can test these attributes of the cable: Receive and transmit directions (RX and TX), short circuit/open circuit or not, the length of the faulty cable.
Follow these steps to enable the system to test connected cables:
To do...
Use the command...
Remarks
Enter system view
Enable the system to test connected cables
virtual-cable-test
Required
1.1.9  Configuring the Interval to Perform Statistical Analysis on Port Traffic
By performing the following configuration, you can set the interval to perform statistical analysis on the traffic of a port.
When you use the display interface interface-type interface-number command to display the information of a port, the system performs statistical analysis on the traffic flow passing through the port during the specified interval and displays the average rates in the interval. For example, if you set this interval to 100 seconds, the displayed information is as follows:
 Last 100 seconds input:  0 packets/sec 0 bytes/sec
 Last 100 seconds output:  0 packets/sec 0 bytes/sec
Follow these steps to set the interval to perform statistical analysis on port traffic:
To do...
Use the command...
Remarks
Enter system view
Set the interval to perform statistical analysis on port traffic
flow-interval interval
Optional
By default, this interval is 300 seconds.
1.1.10  Enabling Giant-Frame Statistics Function
The giant-frame statistics function is used to ensure normal data transmission and to facilitate statistics and analysis of unusual traffic on the network.
Follow these steps to enable the giant-frame statistics function:
To do...
Use the command...
Remarks
Enter system view
Enable the giant-frame statistics function
giant-frame statistics enable
Required
By default, the giant-frame statistics function is not enabled.
1.1.11  Disabling Up/Down Log Output on a Port
An Ethernet port has three physical link statuses: Up, Down, and Administratively Down. For status transition conditions, refer to the description of the display brief interface command in Basic Port Configuration Command.
When the physical link status of an Ethernet port changes between Up and Down or Up and Administratively Down, the switch will generate Up/Down log and send the log information to the terminal automatically by default. If the status of Ethernet ports in a network changes frequently, large amount of log information may be sent to the terminal, which consumes more network resources. Additionally, too frequent log information is not convenient for you to view.
You can limit the amount of the log information sent to the terminal by disabling the Up/Down log output function on some Ethernet ports selectively. For information about log output settings, refer to the Information Center module.
Follow these steps to disable UP/Down log output on a port:
To do...
Use the command...
Remarks
Enter system view
undo enable log updown
Required
By default, UP/Down log output is enabled.
1.1.12  Configuring Storm Control on a Port
The storm control function is used to control traffic received on an Ethernet port.
l           With traffic upper and lower thresholds specified on a port, the system periodically collects statistics about the broadcast/multicast/unicast/ traffic on the port. Once it finds that a type of traffic exceeds the specified upper threshold, it blocks this type of traffic on the port or directly shuts down the port, and outputs trap/log information according to your configuration.
l           When a type of traffic on the port falls back to the specified lower threshold, the system cancels the blocking of this type of traffic on the port or brings up the port to restore traffic forwarding for the port, and outputs log/trap information according to your configuration.
Follow these steps to configure storm control on a port:
To do...
Use the command...
Remarks
Enter system view
Set the upper and lower thresholds of broadcast/multicast/unicast traffic received on the port
storm-constrain { broadcast | multicast | unicast } max-packets min-packets pps
Required
Set the action to be taken when a type of traffic received on the port exceeds the upper threshold.
Optional
By default, no action is taken when a type of traffic reaches the upper threshold.
Enable log/trap information to be output when a type of traffic received on the port exceeds the upper threshold or falls below the lower threshold
storm-constrain enable { log | trap }
Optional
Enabled by default.
Return to system view
Set the interval at which the port collects traffic statistics
storm-constrain interval interval-value
Optional
It is 10 seconds by default.
&  Note:
l      If the broadcast-suppression command, multicast-suppression command or unicast suppression command is configured on a port, you cannot configure the storm control function on the port, and vice versa.
l      You are not recommended to set the upper and lower traffic thresholds to the same value.
l      If you specify the block keyword when executing the storm-constrain control command, only the packets beyond the upper thresholds are blocked when the overall traffic exceeds the upper threshold. In this case, the blocked packets are still taken into account when generating traffic statistics. If you specify the shutdown keyword when executing the command, the port will be shut down when the traffic passing through the port exceeds the upper threshold. You bring up the port again by executing the undo shutdown or the undo storm-constrain { all | broadcast | multicast | unicast } command.
1.1.13  Setting the Port State Change Delay
During a short period after you connect your switch to another device, the connecting port may go up and down frequently due to hardware compatibility, resulting in service interruption.
To avoid situations like this, you may introduce a port state change delay.
  Caution:
The port state change delay takes effect when the port goes down but not when the port goes up.
Follow these steps to set the port state change delay:
To do …
Use the command …
Remarks
Enter system view
Set the port state change delay
link-delay delay-time
Required
Defaults to 0, which indicates the port state changes without any delay.
&  Note:
The delay configured in this way does not take effect for ports in DLDP down state. For information about the DLDP down state, refer to DLDP.
1.1.14  Displaying and Maintaining Basic Port Configuration
To do...
Use the command...
Remarks
Display port configuration information
display interface [ interface-type | interface-type interface-number ]
Available in any view
Display the enable/disable status of port loopback detection
display loopback-detection
Display brief information about port configuration
display brief interface [ interface-type [ interface-number ] ] [ | { begin | include | exclude } regular-expression ]
Display port information about a specified unit
display unit unit-id interface
Display the storm control configurations.
display storm-constrain [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Display the statistics on the packets dropped on a port or all ports
display packet-drop { interface [ interface-type interface-number ] | summary }
Display the information about the port with the link-delay command configured
display link-delay
Clear the statistics on packets dropped on a port or all ports
reset packet-drop interface [ interface-type interface-number ]
Available in user view
Clear port statistics
reset counters interface [ interface-type | interface-type interface-number ]
After 802.1x is enabled on a port, clearing the statistics on the port will not work.
1.2  Ethernet Port Configuration Example
I. Network requirements
l           Switch A and Switch B are connected to each other through two trunk port (Ethernet 1/0/1).
l           Configure the default VLAN ID of both Ethernet 1/0/1 to 100.
l           Allow the packets of VLAN 2, VLAN 6 through VLAN 50 and VLAN 100 to pass both Ethernet 1/0/1.
II. Network diagram
Figure 1-1 Network diagram for Ethernet port configuration
III. Configuration procedure
&  Note:
l      Only the configuration for Switch A is listed below. The configuration for Switch B is similar to that of Switch A.
l      This example supposes that VLAN 2, VLAN 6 through VLAN 50 and VLAN 100 have been created.
# Enter Ethernet 1/0/1 port view.
# Set Ethernet 1/0/1 as a trunk port.
[Sysname-Ethernet1/0/1] port link-type trunk
# Allow packets of VLAN 2, VLAN 6 through VLAN 50 and VLAN 100 to pass Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] port trunk permit vlan 2 6 to 50 100
# Configure the default VLAN ID of Ethernet 1/0/1 to 100.
[Sysname-Ethernet1/0/1] port trunk pvid vlan 100
1.3  Troubleshooting Ethernet Port Configuration
Symptom: Fail to configure the default VLAN ID of an Ethernet port.
Solution: Take the following steps.
l           Use the display interface or display port command to check if the port is a trunk port or a hybrid port.
l           If the port is not a trunk or hybrid port, configure it to be a trunk or hybrid port.
l           Configure the default VLAN ID of the port.
