H3C S3600 Series Ethernet Switches Operation Manual-Release 1510(V1.04)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration GuidesH3C S3600 Series Ethernet Switches Operation Manual-Release 1510(V1.04)
09-Port Basic Configuration Operation
09-Port Basic Configuration Operation 103 KB
Chapter 1  Port Basic Configuration
1.1  Ethernet Port Overview
1.1.1  Types and Numbers of Ethernet Ports
Table 1-1 lists the types and numbers of the ports available on the H3C S3600 series Ethernet switches.
Table 1-1 Models in the S3600 series
Model
Number of service ports
Number of 100 Mbps ports
Number of 1000 Mbps uplink ports
Console port
H3C S3600-28P-SI
28
24 10/100 Mbps (electrical)
4 (SFP)
1
H3C S3600-28P-PWR-SI
28
4 (SFP)
1
H3C S3600-28TP-SI
28
2 (SFP)
2 10/100/1000 Mbps (electrical)
1
H3C S3600-52P-SI
52
48 10/100 Mbps (electrical)
4 (SFP)
1
H3C S3600-28P-EI
28
4 (SFP)
1
H3C S3600-28F-EI
28
24 100 Mbps (SFP)
2 (SFP)
1
H3C S3600-28P-PWR-EI
28
4 (SFP)
1
H3C S3600-52P-EI
52
4 (SFP)
1
H3C S3600-52P-PWR-EI
52
4 (SFP)
1
H3C S3600-52P-PWR-SI
52
4 (SFP)
1
1.1.2  Link Types of Ethernet Ports
An Ethernet port on an S3600 switch can operate in one of the three link types:
l           Access: An access port can belong to only one VLAN, and is generally used to connect user PCs.
l           Trunk: A trunk port can belong to more than one VLAN. It can receive/send packets from/to multiple VLANs, and is generally used to connect another switch.
l           Hybrid: A hybrid port can belong to more than one VLAN. It can receive/send packets from/to multiple VLANs, and can be used to connect either a switch or user PCs.
&  Note:
A hybrid port allows the packets of multiple VLANs to be sent without tags, but a trunk port only allows the packets of the default VLAN to be sent without tags.
You can configure all the three types of ports on the same device. However, note that you cannot directly switch a port between trunk and hybrid and you must set the port as access before the switching. For example, to change a trunk port to hybrid, you must first set it as access and then hybrid.
1.1.3  Configuring the Default VLAN ID for an Ethernet Port
An access port can belong to only one VLAN. Therefore, the VLAN an access port belongs to is also the default VLAN of the access port. A hybrid/trunk port can belong to several VLANs, and so a default VLAN ID for the port is required.
After you configure default VLAN IDs for Ethernet ports, the packets passing through the ports are processed in different ways depending on different situations. See Table 1-2 for details.
Table 1-2 Processing of incoming/outgoing packets
Port type
Processing of an incoming packet
Processing of an outgoing packet
If the packet does not carry a VLAN tag
If the packet carries a VLAN tag
Access
Receive the packet and add the default tag to the packet.
l      If the VLAN ID is just the default VLAN ID, receive the packet.
l      If the VLAN ID is not the default VLAN ID, discard the packet.
Deprive the tag from the packet and send the packet.
Trunk
l      If the VLAN ID is not the default VLAN ID but is one of the VLAN IDs allowed to pass through the port, receive the packet.
l      If the VLAN ID is neither the default VLAN ID, nor one of the VLAN IDs allowed to pass through the port, discard the packet.
l      If the VLAN ID is just the default VLAN ID, deprive the tag and send the packet.
l      If the VLAN ID is not the default VLAN ID, keep the original tag unchanged and send the packet.
Hybrid
Send the packet if the VLAN ID is allowed to pass through the port. Use the port hybrid vlan command to configure whether the port tags the packet when sending a packet in this VLAN (including default VLAN).
  Caution:
You are recommended to set the default VLAN ID of the local hybrid or trunk ports to the same value as that of the hybrid or trunk ports on the peer switch. Otherwise, packet forwarding may fail on the ports.
1.1.4  Adding an Ethernet Port to Specified VLANs
You can add the specified Ethernet port to a specified VLAN. After that, the Ethernet port can forward the packets of the specified VLAN, so that the VLAN on this switch can intercommunicate with the same VLAN on the peer switch.
An access port can only be added to one VLAN, while hybrid and trunk ports can be added to multiple VLANs.
&  Note:
The access ports or hybrid ports must be added to an existing VLAN.
1.2  Ethernet Port Configuration
1.2.1  Initially Configuring a Port
Table 1-3 Initially configure a port
Operation
Remarks
Enter system view
Enter Ethernet port view
Enable the Ethernet port
Optional
By default, the port is enabled.
Use the shutdown command to disable the port.
Set the description of the Ethernet port
Optional
By default, no description is defined for the port.
Set the duplex mode of the Ethernet port
duplex { auto | full | half }
Optional
By default, the duplex mode of the port is auto (auto-negotiation).
Set the speed of the Ethernet port
speed { 10 | 100 | 1000 | auto }
Optional
By default, the speed of the port is auto (auto-negotiation).
Set the medium dependent interface (MDI) attribute of the Ethernet port
mdi { across | auto | normal }
Optional
Be default, the MDI attribute of the port is auto.
Allow jumbo frames that are not larger than 9216 bytes to pass through the Ethernet port
jumboframe enable
Optional
By default, jumbo frames that are not larger than 9216 bytes are allowed to pass through the port.
1.2.2  Limiting Traffic on individual Ports
By performing the following configurations, you can limit different types of incoming traffic on individual ports. When a type of incoming traffic exceeds the threshold you set, the system drops the packets exceeding the traffic limit to reduce the traffic ratio of this type to the reasonable range, so as to keep normal network service.
Table 1-4 Limit traffic on port
Operation
Remarks
Enter system view
Limit broadcast traffic received on each port
broadcast-suppression { ratio | pps max-pps }
Optional
By default, the switch does not suppress broadcast traffic.
Limit broadcast traffic received on the current port
Optional
Limit multicast traffic received on the current port
multicast-suppression { ratio | pps max-pps }
Optional
By default, the switch does not suppress multicast traffic.
Limit unknown unicast traffic received on the current port
unicast-suppression { ratio | pps max-pps }
Optional
By default, the switch does not suppress unknown unicast traffic.
1.2.3  Enabling Flow Control on a Port
Flow control is enabled on both the local and peer switches. If congestion occurs on the local switch:
l           The local switch sends a message to notify the peer switch of stopping sending packets to itself or reducing the sending rate temporarily.
l           The peer switch will stop sending packets to the local switch or reduce the sending rate temporarily when it receives the message; and vice versa. By this way, packet loss is avoided and the network service operates normally.
Table 1-5 Enable flow control on a port
Operation
Remarks
Enter system view
Enable flow control on the Ethernet port
flow-control
By default, flow control is not enabled on the port.
1.2.4  Configuring Access Port Attribute
Table 1-6 Configure access port attribute
Operation
Remarks
Enter system view
Set the link type of the port to access
port link-type access
Optional
By default, the link type of a port is access.
Add the current access port to a specified VLAN
port access vlan vlan-id
Optional
1.2.5  Configuring Hybrid Port Attribute
Table 1-7 Configure hybrid port attribute
Operation
Remarks
Enter system view
Set the link type of the port to hybrid
port link-type hybrid
Required
Set the default VLAN ID for the hybrid port
port hybrid pvid vlan vlan-id
Optional
If no default VLAN ID is set for a hybrid port, VLAN 1 (system default VLAN) is used as the default VLAN of the port.
Add the current hybrid port to a specified VLAN
Optional
For a hybrid port, you can configure whether the system keeps VLAN tags when the packets of the specified VLANs are forwarded on this port.
1.2.6  Configuring Trunk Port Attribute
Table 1-8 Configure trunk port attribute
Operation
Remarks
Enter system view
System-view
Set the link type of the port to trunk
port link-type trunk
Required
Set the default VLAN ID for the trunk port
port trunk pvid vlan vlan-id
Optional
If no default VLAN ID is set for a trunk port, VLAN 1 (system default VLAN) is used as the default VLAN of the port.
Add the current trunk port to a specified VLAN
Optional
1.2.7  Copying the Configuration of a Port to Other Ports
To make some other ports have the same configuration as that of a specific port, you can copy the configuration of the specific port to the ports.
Specifically, the following types of port configuration can be copied from one port to other ports: VLAN configuration, protocol-based VLAN configuration, LACP configuration, QoS configuration, GARP configuration, STP configuration and initial port configuration.
l           VLAN configuration: includes IDs of the VLANs allowed on the port and the default VLAN ID of the port;
l           Protocol-based VLAN configuration: includes IDs and indexes of the protocol-based VLANs allowed on the port;
l           Link aggregation control protocol (LACP) configuration: includes LACP enable/disable status;
&  Note:
The copy command can only be used to copy the configuration of LACP’s enable state, but not to copy the configuration of aggregation group, i.e., you can not add a port to the aggregation group bye the command.
l           QoS configuration: includes rate limit, port priority, and default 802.1p priority on the port;
l           STP configuration: includes STP enable/disable status on the port, link attribute on the port (point-to-point or non-point-to-point), STP priority, path cost, packet transmission rate limit, whether loop protection is enabled, whether root protection is enabled, and whether the port is an edge port;
l           Generic attribute registration protocol (GARP) configuration: includes GVRP enable/disable status, timer settings, and registration mode;
l           Port configuration: includes link type of the port, port rate and duplex mode.
Table 1-9 Copy the configuration of a port to other ports
Operation
Remarks
Enter system view
copy configuration source { interface-type interface-number | aggregation-group source-agg-id } destination { interface-list [ aggregation-group destination-agg-id ] | aggregation-group destination-agg-id }
Required
&  Note:
l      If you specify a source aggregation group ID, the system will use the port with the smallest port number in the aggregation group as the source.
l      If you specify a destination aggregation group ID, the configuration of the source port will be copied to all ports in the aggregation group and all ports in the group will have the same configuration as that of the source port.
1.2.8  Configuring Loopback Detection for an Ethernet Port
Loopback detection is used to monitor if loopback occurs on a switch port.
After you enable loopback detection on Ethernet ports, the switch can monitor if external loopback occurs on them. If there is a loopback port found, the switch will put it under control.
l           If loopback is found on an access port, the system disables the port, sends a Trap message to the client and removes the corresponding MAC forwarding entry.
l           If loopback is found on a trunk or hybrid port, the system sends a Trap message to the client. When the loopback port control function is enabled on these ports, the system disables the port, sends a Trap message to the client and removes the corresponding MAC forwarding entry.
Table 1-10 Set loopback detection for an Ethernet port
Operation
Remarks
Enter system view
Enable loopback detection globally
loopback-detection enable
Optional
By default, loopback detection is disabled globally.
Set time interval for port loopback detection
loopback-detection interval-time time
Optional
The default interval is 30 seconds.
Enable loopback detection on a specified port
Optional
By default, port loopback detection is disabled.
Enable loopback port control on the trunk or hybrid port
loopback-detection control enable
Optional
By default, loopback port control is not enabled.
Configure the system to run loopback detection on all VLANs of the current trunk or hybrid port
loopback-detection per-vlan enable
Optional
By default, the system runs loopback detection only on the default VLAN of the current trunk or hybrid port.
Display port loopback detection information
display loopback-detection
Optional
You can use the command in any view.
  Caution:
l      To enable loopback detection on a specific port, you must use the loopback-detection enable command in both system view and the specific port view.
l      After you use the undo loopback-detection enable command in system view, loopback detection will be disabled on all ports.
1.2.9  Configuring the Ethernet Port to Run Loopback Test
You can configure the Ethernet port to run loopback test to check if it operates normally. The port running loopback test cannot forward data packets normally. The loopback test terminates automatically after a specific period.
Table 1-11 Configure the Ethernet port to run loopback test
Operation
Remarks
Enter system view
Optional
&  Note:
l      external: Performs external loop test. In the external loop test, self-loop headers must be used on the port of the switch ( for 100M port, the self-loop headers are made from four cores of the 8-core cables, for 1000M port, the self-loop header are made from eight cores of the 8-core cables, then the packets forwarded by the port will be received by itself.). The external loop test can locate the hardware failures on the port.
l      internal: Performs internal loop test. In the internal loop test, self loop is established in the switching chip to locate the chip failure which is related to the port.
After you use the shutdown command on a port, the port cannot run loopback test. You cannot use the speed, duplex, mdi and shutdown commands on the ports running loopback test. Some ports do not support loopback test, and corresponding prompts will be given when you perform loopback test on them.
1.2.10  Enabling the System to Test Connected Cable
You can enable the system to test the cable connected to a specific port. The test result will be returned in five seconds. The system can test these attributes of the cable: Receive and transmit directions (RX and TX), short circuit/open circuit or not, the length of the faulty cable.
Table 1-12 Enable the system to test connected cables
Operation
Remarks
Enter system view
virtual-cable-test
Required
1.2.11  Configuring the Interval to Perform Statistical Analysis on Port Traffic
By performing the following configuration, you can set the interval to perform statistical analysis on the traffic of a port.
When you use the display interface interface-type interface-number command to display the information of a port, the system performs statistical analysis on the traffic flow passing through the port during the specified interval and displays the average rates in the interval. For example, if you set this interval to 100 seconds, the displayed information is as follows:
 Last 100 seconds input:  0 packets/sec 0 bytes/sec
 Last 100 seconds output:  0 packets/sec 0 bytes/sec
Table 1-13 Set the interval to perform statistical analysis on port traffic
Operation
Enter system view
flow-interval interval
Optional
By default, this interval is 300 seconds.
1.2.12  Enabling Giant-Frame Statistics Function
The giant-frame statistics function is used to ensure transmission of network traffic and to facilitate statistics and analysis of unusual traffic on the network.
Table 1-14 Enable the giant-frame statistics function
Operation
Enter system view
giant-frame statistics enable
Optional
By default, the giant-frame statistics function is not enabled.
1.2.13  Displaying Basic Port Configuration
After the above configurations, you can execute the display commands in any view to display information about Ethernet ports, so as to verify your configurations.
You can execute the reset counters command in user view to clear the statistics of Ethernet ports.
Table 1-15 Display basic port configuration
Operation
Remarks
Display port configuration information
display interface [ interface-type | interface-type interface-number ]
You can execute the display commands in any view.
Display information about a specified optical port
display transceiver-information interface interface-type interface-number
Display the enable/disable status of port loopback detection
Display brief information about port configuration
display brief interface [ interface-type interface-number ] [ | { begin | include | exclude } string ]
Display the hybrid or trunk ports
Display port information about a specified unit
display unit unit-id interface
Clear port statistics
reset counters interface [ interface-type | interface-type interface-number ]
You can execute the reset command in user view.
After 802.1x is enabled on a port, clearing the statistics on the port will not work.
1.3  Ethernet Port Configuration Example
I. Network requirements
l           Switch A and Switch B are connected to each other through two trunk port (Ethernet1/0/1).
l           Configure the default VLAN ID of both Ethernet1/0/1 to 100.
l           Allow the packets of VLAN 2, VLAN 6 through VLAN 50 and VLAN 100 to pass both Ethernet1/0/1.
II. Network diagram
Figure 1-1 Network diagram for Ethernet port configuration
III. Configuration procedure
&  Note:
l      Only the configuration for Switch A is listed below. The configuration for Switch B is similar to that of Switch A.
l      This example supposes that VLAN 2, VLAN 6 through VLAN 50 and VLAN 100 have been created.
# Enter Ethernet port view of Ethernet1/0/1.
<H3C> system-view
[H3C] interface ethernet1/0/1
# Set Ethernet1/0/1 as a trunk port.
[H3C-Ethernet1/0/1] port link-type trunk
# Allow packets of VLAN 2, VLAN 6 through VLAN 50 and VLAN 100 to pass Ethernet1/0/1.
[H3C-Ethernet1/0/1] port trunk permit vlan 2 6 to 50 100
# Configure the default VLAN ID of Ethernet1/0/1 to 100.
[H3C-Ethernet1/0/1] port trunk pvid vlan 100
1.4  Troubleshooting Ethernet Port Configuration
Symptom: Fail to configure the default VLAN ID of a port.
Solution: Take the following steps.
l           Use the display interface or display port command to check if the port is a trunk port or a hybrid port. If not, configure it to a trunk port or a hybrid port.
l           Configure the default VLAN ID.
