H3C S3600 Series Ethernet Switches Operation Manual-Release 1510(V1.04)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration GuidesH3C S3600 Series Ethernet Switches Operation Manual-Release 1510(V1.04)
08-GVRP Operation
08-GVRP Operation 112 KB
Chapter 1  GVRP Configuration
1.1  Introduction to GVRP
GARP VLAN registration protocol (GVRP) is an implementation of generic attribute registration protocol (GARP). It maintains dynamic VLAN registration information and propagates the information to other switches by adopting the same mechanism as that of GARP.
&  Note:
GARP provides a mechanism for the switching members in a switched network to register, distribute and propagate information about VLANs, multicast addresses, and so on between each other.
After the GVRP feature is enabled on a switch, the switch receives the VLAN registration information from other switches to dynamically update the local VLAN registration information (including VLAN members, ports through which the VLAN members can be reached, and so on). The switch also propagates the local VLAN registration information to other switches so that all the switching devices in the same switched network can have the same VLAN information. The VLAN registration information includes not only the static registration information configured locally, but also the dynamic registration information received from other switches.
1.1.1  GVRP Mechanism
I. GARP timers
The information exchange between GARP members is completed by messages. The messages performing important functions for GARP fall into three types: Join, Leave and LeaveAll.
l           When a GARP entity expects other switches to register certain attribute information of its own, it sends out a Join message.
l           When a GARP entity expects other switches to unregister certain attribute information of its own, it sends out a Leave message.
l           Once a GARP entity starts up, it starts the LeaveAll timer. After the timer times out, the GARP entity sends out a LeaveAll message.
The Join message and the Leave message are used together to complete the unregistration and re-registration of information. Through message exchange, all the attribute information to be registered can be propagated to all the switches in the same switched network.
GARP uses the following timers:
l           Hold: When a GARP entity receives a piece of registration information, it does not send out a Join message immediately. Instead, to save the bandwidth resources, it starts the Hold timer and puts all received registration information before the timer times out into one Join message and sends out the message after the timer times out.
l           Join: To transmit the Join messages reliably to other entities, a GARP entity sends each Join message two times. The Join timer is used to define the interval at which each Join message is sent.
l           Leave: When a GARP entity expects to unregister a piece of attribute information, it sends out a Leave message. Any GARP entity receiving this message starts its Leave timer, and unregisters the attribute information if it does not receives a Join message again before the timer times out.
l           LeaveAll: Once a GARP entity starts up, it starts the LeaveAll timer, and sends out a LeaveALL message after the timer times out, so that other GARP entities can re-register all the attribute information on this entity. After that, the entity restarts the LeaveAll timer to begin a new cycle.
II. GVRP port registration mode
GVRP has the following three port registration modes: Normal, Fixed, and Forbidden.
l           Normal: In this mode, a port can dynamically register/deregister a VLAN and propagate the dynamic/static VLAN information.
l           Fixed: In this mode, a port cannot register/deregister a VLAN dynamically. It only propagates static VLAN information. That is, a trunk port only permits the packets of manually configured VLANs in this mode even if you configure the port to permit the packets of all the VLANs.
l           Forbidden: In this mode, a port cannot register/deregister VLANs. It only propagates VLAN 1 information. That is, a trunk port only permits the packets of the default VLAN (namely VLAN 1) in this mode even if you configure the port to permit the packets of all the VLANs.
III. GARP operation procedure
Through the mechanism of GARP, the configuration information on a GARP member will be propagated to the entire switched network. A GARP member can be a terminal workstation or a bridge; it instructs other GARP members to register/unregister its attribute information by declaration/recant, and register/unregister other GARP member's attribute information according to other member's declaration/recant.
The protocol packets of GARP entities use specific multicast MAC addresses as their destination MAC addresses. When receiving these packets, the switch distinguishes them by their destination MAC addresses and delivers them to different GARP application (for example, GVRP) for further processing.
1.1.2  GVRP Packet Format
The GVRP packets are in the following format:
Figure 1-1 Format of GVRP packets
The following table describes the fields of a GVRP packet.
Table 1-1 Description of GVRP packet fields
Value
Protocol ID
Protocol ID
1
Message
Each message consists of two parts: Attribute Type and Attribute List.
Attribute Type
Defined by the specific GARP application
The attribute type of GVRP is 0x01.
Attribute List
It contains multiple attributes.
Attribute
Each general attribute consists of three parts: Attribute Length, Attribute Event, and Attribute Value.
Each LeaveAll attribute consists of two parts: Attribute Length and LeaveAll Event.
Attribute Length
The length of the attribute
2 to 255
Attribute Event
The event described by the attribute
0: LeaveAll Event
1: JoinEmpty
2: JoinIn
3: LeaveEmpty
4: LeaveIn
5: Empty
Attribute Value
The value of the attribute
The attribute value of GVRP is the VID.
End Mark
End mark of the GVRP PDU.
1.1.3  Protocol Specifications
GVRP is defined in IEEE 802.1Q standard.
1.2  GVRP Configuration
The GVRP configuration tasks include configuring the timers, enabling GVRP, and configuring the GVRP port registration mode.
1.2.1  Configuration Prerequisite
The port on which GVRP will be enabled must be set to a trunk port.
1.2.2  Configuration Procedure
Table 1-2 Configuration procedure
Operation
Enter system view
Configure the LeaveAll timer
garp timer leaveall timer-value
Optional
By default, the LeaveAll timer is set to 1,000 centiseconds.
Enter Ethernet port view
Configure the Hold, Join, and Leave timers
garp timer { hold | join | leave } timer-value
Optional
By default, the Hold, Join, and Leave timers are set to 10, 20, and 60 centiseconds respectively.
Exit and return to system view
Enable GVRP globally
gvrp
Required
By default, GVRP is disabled globally.
Enable GVRP on the port
gvrp
Required
By default, GVRP is disabled on the port.
After you enable GVRP on a trunk port, you cannot change the port to a different type.
Configure GVRP port registration mode
gvrp registration { fixed | forbidden | normal }
Optional
You can choose one of the three modes.
By default, GVRP port registration mode is normal.
The timeout ranges of the timers vary depending on the timeout values you set for other timers. If you want to set the timeout time of a timer to a value out of the current range, you can set the timeout time of the associated timer to another value to change the timeout range of this timer.
The following table describes the relations between the timers:
Table 1-3 Relations between the timers
Timer
Lower threshold
Upper threshold
Hold
10 centiseconds
This upper threshold is less than or equal to one-half of the timeout time of the Join timer. You can change the threshold by changing the timeout time of the Join timer.
Join
This lower threshold is greater than or equal to twice the timeout time of the Hold timer. You can change the threshold by changing the timeout time of the Hold timer.
This upper threshold is less than one-half of the timeout time of the Leave timer. You can change the threshold by changing the timeout time of the Leave timer.
Leave
This lower threshold is greater than twice the timeout time of the Join timer. You can change the threshold by changing the timeout time of the Join timer.
This upper threshold is less than the timeout time of the LeaveAll timer. You can change the threshold by changing the timeout time of the LeaveAll timer.
LeaveAll
This lower threshold is greater than the timeout time of the Leave timer. You can change threshold by changing the timeout time of the Leave timer.
32,765 centiseconds
1.3  Displaying and Debugging GVRP
After the above configuration, you can use the display command in any view to display the configuration information and operating status of GVRP/GARP, and thus verify your configuration. You can use the reset command in user view to clear GARP statistics.
Table 1-4 Display and debug GVRP
Operation
Display GARP statistics
display garp statistics [ interface interface-list ]
The display command can be executed in any view.
Display the settings of the GARP timers
display garp timer [ interface interface-list ]
Display GVRP statistics
display gvrp statistics [ interface interface-list ]
Display the global GVRP status
display gvrp status
Clear GARP statistics
reset garp statistics [ interface interface-list ]
The reset command can be executed in user view.
1.4  GVRP Configuration Example
1.4.1  Network requirements
You need to enable GVRP on the switches to enable dynamic VLAN information registration and update between the switches.
1.4.2  Network diagram
Figure 1-2 Network diagram for GVRP configuration
1.4.3  Configuration procedure
l           Configure switch A.
# Enable GVRP globally.
<H3C> system-view
[H3C] gvrp
GVRP is enabled globally.
# Configure Ethernet1/0/1 to be a trunk port and to permit the packets of all the VLANs.
[H3C] interface Ethernet 1/0/1
[H3C-Ethernet1/0/1] port link-type trunk
[H3C-Ethernet1/0/1] port trunk permit vlan all
# Enable GVRP on the trunk port.
[H3C-Ethernet1/0/1] gvrp
GVRP is enabled on port Ethernet1/0/1.
l           Configure switch B.
<H3C> system-view
[H3C] gvrp
# Configure Ethernet1/0/2 to be a trunk port and to permit the packets of all the VLANs.
[H3C] interface Ethernet 1/0/2
[H3C-Ethernet1/0/2] port link-type trunk
[H3C-Ethernet1/0/2] port trunk permit vlan all
[H3C-Ethernet1/0/2] gvrp
GVRP is enabled on port Ethernet1/0/2.
