- H3C S3600 Series Ethernet Switches Operation Manual-Release 1510(V1.04)
- 00-1Cover
- 00-2Product Overview
- 01-CLI Operation
- 02-Login Operation
- 03-Configuration File Management Operation
- 04-VLAN Operation
- 05-IP Address and Performance Configuration Operation
- 06-Management VLAN Operation
- 07-Voice VLAN Operation
- 08-GVRP Operation
- 09-Port Basic Configuration Operation
- 10-Link Aggregation Operation
- 11-Port Isolation Operation
- 12-Port Security-Port Binding Operation
- 13-DLDP Operation
- 14-MAC Address Table Operation
- 15-Auto Detect Operation
- 16-MSTP Operation
- 17-Routing Protocol Operation
- 18-Multicast Operation
- 19-802.1x Operation
- 20-AAA-RADIUS-HWTACACS-EAD Operation
- 21-VRRP Operation
- 22-Centralized MAC Address Authentication Operation
- 23-ARP Operation
- 24-DHCP Operation
- 25-ACL Operation
- 26-QoS-QoS Profile Operation
- 27-Web Cache Redirection Operation
- 28-Mirroring Operation
- 29-IRF Fabric Operation
- 30-Cluster Operation
- 31-PoE-PoE Profile Operation
- 32-UDP Helper Operation
- 33-SNMP-RMON Operation
- 34-NTP Operation
- 35-SSH Terminal Service Operation
- 36-File System Management Operation
- 37-FTP and TFTP Operation
- 38-Information Center Operation
- 39-System Maintenance and Debugging Operation
- 40-VLAN-VPN Operation
- 41-HWPing Operation
- 42-DNS Operation
- 43-Access Management Operation
- 44-Appendix
| 03-Configuration File Management Operation | 41 KB |
Table of Contents
Chapter 1 Configuration File Management
1.1 Introduction to Configuration File
1.2 Configuration File-Related Operations
A configuration file records and stores user configurations performed to a switch. It also enables users to check switch configurations easily.
Upon powered on, a switch loads the configuration file known as saved-configuration file, which resides in the Flash, for initialization. If the Flash contains no configuration file, the system performs initialization using the default settings. Comparing to saved-configuration file, the configuration file which is currently adopted by a switch is known as the current-configuration.
A configuration file conforms to the following conventions:
l The content of a configuration file is a series of commands.
l Only the non-default configuration parameters are saved.
l The commands are grouped into sections by command view. The commands that are of the same command view are grouped into one section. Sections are separated by empty lines or comment lines. (A line is a comment line if it starts with the character “#”.)
l The sections are listed in this order: system configuration section, physical port configuration section, logical interface configuration section, routing protocol configuration section, and so on.
l A configuration file ends with a “return”.
You can perform the following operations on an S3600 Ethernet switch:
l Saving the current configuration to a configuration file
l Removing a configuration file from the Flash
l Checking/Setting the configuration file to be used when the switch starts the next time
l Setting a configuration file to be the primary/secondary configuration file
Perform the following configuration in user view.
Table 1-1 Configure a configuration file
Operation |
Command |
Save the current configuration to a specified configuration file and specify the configuration file to be the primary/secondary configuration file |
save [ cfgfile | [ safely ] [ backup | main ] ] |
Optional The save command can be executed in any view. |
Remove a specific configuration file from the Flash |
reset saved-configuration [ backup | main ] |
Optional |
Specify the name and attribute of the configuration file to be used in the next startup |
startup saved-configuration cfgfile [ backup | main ] |
Optional By default, the switch uses the main configuration file in the next startup. |
Specify that the switch starts without loading the configuration file |
undo startup saved-configuration [ unit unit-id ] |
Optional |
Display the primary configuration file |
display saved-configuration [ unit unit-id ] [ by-linenum ] |
Optional The display command can be executed in any view. |
Display the current configuration |
display current-configuration [ configuration [ configuration-type ] | interface [ interface-type ] [ interface-number ] | vlan [ vlan-id ] ] [ by-linenum ] [ | { begin | include | exclude } regular-expression ] |
Display the configuration performed in the current view |
display this [ by-linenum ] |
Display the information about the configuration file to be used for startup. |
display startup [ unit unit-id ] |
Caution:
Currently, the extension of a configuration file is cfg. Configuration files are saved in the root directory of the Flash.
In the following conditions, it may be necessary for you to remove the configuration files from the Flash:
l The system software does not match the configuration file after the software of the Ethernet switch is updated.
l The configuration files in the Flash are damaged. The common reason is that wrong configuration files are loaded.
You can save the current configuration files in one of the following two ways:
l If the safely keyword is not provided, the system saves the configuration files in the fast mode. In this mode, the configuration files are saved fast. However, the configuration files will be lost if the device is restarted or the power is off when the configuration files are being saved.
l If the safely keyword is provided, the system saves the configuration files in the safe mode. In this mode, the configuration files are saved slowly. However, the configuration files will be saved in the Flash if the device is restarted or the power is off when the configuration files are being saved.
You are recommended to adopt the fast saving mode in the conditions of stable power and adopt the safe mode in the conditions of unstable power or remote maintenance.
& Note:
l You are recommended to use the save command to save the configuration before restarting a device, so that the current configuration remains after the device is restarted.
l If you use the save command to save the current configuration file without specifying any option, the configuration file is saved as the name of the configuration file used in this start. If the device is started using the default configuration file this time, the current configuration file is saved as the name of the default configuration file.
l If you use the save command after a fabric is formed on the switch, the units in the fabric save their own startup configuration files automatically.
