1 Index
A
B
C
D
E
F
G
H
I
J
K
L
M
N
O
P
Q
R
S
T
U
V
W
X
Y
A
aaa abnormal-offline-record enable
aaa abnormal-offline-record max-number
aaa abnormal-offline-record mode
aaa authorize user-name netstream-sampler
aaa de-authorize user-name netstream-sampler
aaa default-domain
aaa deny-domain
aaa device-id
aaa login-failed alarm-threshold
aaa nas-id
aaa nas-id profile
aaa nas-id-profile
aaa nas-ip
aaa nas-port-id vlanid uppercase
aaa normal-offline-record enable
aaa normal-offline-record max-number
aaa normal-offline-record mode
aaa offline-record enable
aaa online-fail-record enable
aaa online-fail-record max-number
aaa online-fail-record mode
aaa permit-domain
aaa realtime-backup enable
aaa roam-domain
aaa session-limit
aaa shared-account-user no-family
aaa ssid
abort
abr-summary
abr-summary
ac interface
ac interface
ac mac-limit
ac statistics enable
accept target-hello
accept-label
accept-lifetime
accept-tolerance
access-limit
access-limit
access-limit
access-user authen-and-accounting without-ipv6-prefix
access-user auto-save enable
access-user flow-rate-calculate enable
access-user four-dimension-mode enable
access-user interface-switchto-backup keep-host-routes
access-user log enable
access-user online-fail-warning
access-user session-threshold
access-user url character-transfer
access-user user-detect packet-loss-ratio-threshold
accounting
accounting command
accounting default
accounting dual-stack
accounting ipoe
accounting lan-access
accounting login
accounting ppp
accounting pppoea
accounting quota-out
accounting start-delay
accounting start-fail
accounting update-fail
accounting-level
accounting-merge enable
accounting-method
accounting-method
accounting-on enable
accounting-on extended
acl
acl
acl copy
acl logging interval
acl resource log interval
acl resource threshold percent
acl trap interval
acl whitelist
action cli
action reboot
action switchover
action syslog
activate profile
activation-key
active instance
active region-configuration
add interface
additional-paths select-best
address
address range
address range
address-alloc-mode
address-family evpn (public instance view)
address-family evpn (VPN instance view)
address-family ipv4
address-family ipv4
address-family ipv4
address-family ipv4
address-family ipv4
address-family ipv4
address-family ipv4 (public instance view)
address-family ipv4 (VPN instance view)
address-family ipv4 flowspec (BGP instance view)
address-family ipv4 flowspec (BGP-VPN instance view)
address-family ipv4 flowspec (VPN instance view)
address-family ipv4 mdt
address-family ipv4 mvpn
address-family ipv4 sr-policy
address-family ipv6
address-family ipv6
address-family ipv6
address-family ipv6
address-family ipv6
address-family ipv6 (public instance view)
address-family ipv6 (VPN instance view)
address-family ipv6 flowspec (BGP instance view)
address-family ipv6 flowspec (BGP-VPN instance view)
address-family ipv6 flowspec (VPN instance view)
address-family ipv6 mvpn
address-family ipv6 savnet
address-family ipv6 sr-policy
address-family l2vpn
address-family l2vpn evpn
address-family link-state
address-family link-state vpn
address-family vpnv4
address-family vpnv4 flowspec
address-family vpnv6
address-family vpnv6 flowspec
adjust-udp-checksum enable
adjust-udp-checksum global enable
adjust-udp-checksum global enable (TWAMP Light responder view)
advantage-factor
advertise application link-attributes
advertise application link-attributes te
advertise ebgp enable
advertise evpn route
advertise l2vpn evpn
advertise l3vpn route
advertise link-attributes
advertise route-reoriginate
advertise slice-prefix-route (IS-IS IPv6 address family)
advertise srv6 locator
advertise-between-vrf clear-reflect-attributes
advertise-definition enable
advertise-label peer
advertise-label prefix-list
advertisement-interval
advertise-rib-active
affinity (SRv6 TE ODN dynamic view)
affinity (SRv6 TE policy constraints view)
affinity exclude-any
affinity include-all
affinity include-any
affinity location-set
affinity location-type
affinity program
affinity self
affinity-map
affinity-map
affinity-map
aftr-name
aggregate
aging-time
aging-time
ah authentication-algorithm
alias
allocate-new-ip enable
allow l2tp
allowed-frame-loss
allowed-jitter
allowed-loss-ratio
allowed-transfer-delay
ams
analyzer
analyzer id
ancp access-loop-configure
ancp enable
ancp neighbor
ancp oam
ancp session interval
ancp session retransmit
ancp source-interface
anycast enable
anycast rp (IPv6 PIM view)
anycast rp (PIM view)
apn
apn-field
apn-id inherit
apn-id instance
apn-id isolate policy
apn-id template
apn-id-ipv6 isolate-group
apn-id-ipv6 isolate-policy (VPN instance view)
append
app-group index
apply
apply access-vpn vpn-instance
apply aigp
apply as-path
apply comm-list delete
apply community
apply cost
apply cost-type
apply default-next-hop
apply default-srv6-be
apply default-srv6-policy
apply esi
apply extcommunity
apply extcommunity color
apply extcommunity soo
apply fast-reroute
apply flex-algo
apply flow
apply gateway-ip
apply ip-address next-hop
apply ip-precedence
apply ipv6 fast-reroute
apply ipv6 gateway-ip
apply ipv6 next-hop
apply isis
apply label-index
apply label-value
apply large-comm-list delete
apply large-community
apply loadshare
apply loadshare
apply local-preference
apply mpls-label
apply next-hop
apply next-hop
apply origin
apply output-interface
apply precedence
apply precedence
apply preference
apply preferred-value
apply prefix-priority
apply qos-local-id
apply srv6-be
apply srv6-be
apply srv6-policy
apply srv6-policy
apply tag
apply traffic-index
apply tunnel-policy
apply tunnel-selector
apply-label
apply-label per-route pop-go
archive configuration
archive configuration interval
archive configuration location
archive configuration max
archive configuration server
area
area
area-authentication send-only
area-authentication-mode
arp active-ack enable
arp attack-suppression check-interval
arp attack-suppression enable per-interface
arp attack-suppression suppression-time
arp attack-suppression threshold
arp authorized enable
arp check enable
arp check log enable
arp distributed-gateway dynamic-entry synchronize
arp filter binding
arp filter source
arp fixup
arp hardware reply enable
arp ip-conflict log prompt
arp ip-unnumbered learning enable
arp local-conflict record enable
arp mac-learning disable
arp max-learning-num
arp max-learning-number
arp rate-limit
arp rate-limit log enable
arp rate-limit log interval
arp resolving-route enable
arp resolving-route probe-count
arp resolving-route probe-interval
arp route-direct advertise
arp safe-guard enable
arp scan
arp sender-ip-range
arp send-gratuitous-arp
arp send-rate
arp smooth
arp snooping enable
arp source-mac
arp source-mac aging-time
arp source-mac check-interval
arp source-mac exclude-mac
arp source-mac threshold
arp source-suppression enable
arp source-suppression limit
arp static
arp suppression enable
arp suppression push interval
arp timer aging
arp user-ip-conflict record enable
arp user-move record enable
arp valid-check enable
arp vsrp-instance
arp vsrp-port
arp-advertising disable
asbr-summary
asbr-summary
ascii
as-notation dotted
as-path-limit
attribute 15 check-mode
attribute 25 car
attribute 31 mac-format
attribute 5 format
attribute 6 value
attribute 85 preferred
attribute 87 format
attribute convert (RADIUS DAS view)
attribute convert (RADIUS scheme view)
attribute reject (RADIUS DAS view)
attribute reject (RADIUS scheme view)
attribute remanent-volume
attribute translate
attribute vendor-id 2011 version
attribute-map
authen-fail
authen-radius-recover
authen-radius-unavailable online domain
authentication challenge
authentication default
authentication ipoe
authentication key
authentication lan-access
authentication lifetime
authentication login
authentication ppp
authentication super
authentication window-size
authentication-method
authentication-method none authorization-attribute
authentication-mode
authentication-mode
authentication-mode
authentication-server
authentication-timeout
authorization command
authorization default
authorization ipoe
authorization lan-access
authorization login
authorization ppp
authorization-attribute (ISP domain view)
authorization-attribute (local user view/user group view)
authorization-server
auto-bandwidth enable
auto-cost enable
autodeploy udisk enable
auto-discovery
auto-discovery
auto-discovery inter-as
auto-execute command
auto-report
autoroute enable (SRv6 TE policy group view)
autoroute enable (SRv6 TE policy view)
autoroute isis
autoroute metric (SRv6 TE policy group view)
autoroute metric (SRv6 TE policy view)
auto-rp enable (PIM view)
auto-tunnel backup
B
backoff
backup hot-standby
backup hot-standby
backup id
backup mode
backup route-advertise
backup startup-configuration
backup-opcode
backup-path exclude-srlg
backup-peer
backup-peer
backup-peer
balance
balance as-path-neglect
balance as-path-relax
balance igp-metric-ignore
balancing-lsp
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth queue
bandwidth-based-sharing
bandwidth-reference
bandwidth-reference
bandwidth-reference
basic slice-id
basic-service-ip-type
best-effort match dscp (DSCP forward type view)
best-effort match dscp (SRv6 TE policy group view)
best-effort match service-class (service class forward type view)
best-effort match service-class (SRv6 TE policy group view)
bestroute as-path-neglect
bestroute compare-ebgp
bestroute compare-med
bestroute encap-type
bestroute igp-metric-ignore
bestroute ipv6-nexthop
bestroute med-confederation
bestroute nexthop-priority
bestroute nexthop-resolved
bestroute nexthop-type
bestroute origin-as-validation
bestroute router-id-ignore
bestroute same-rd
bfd { no-bypass | bypass }
bfd all-interfaces adjust-cost
bfd all-interfaces enable
bfd all-interfaces session-restrict-adj
bfd all-interfaces template
bfd detect-multiplier
bfd discriminator
bfd echo
bfd enable
bfd ip-router-alert
bfd min-echo-receive-interval
bfd min-receive-interval
bfd min-transmit-interval
bfd srv6-encapsulation-mode encap
bfd static evpn-vpls-srv6
bfd static evpn-vpws-srv6
bfd static mpls-te
bfd static pw
bfd trigger path-down
bfr-id
bfr-neighbor
bfr-prefix
bgp
bgp apply-policy on-startup duration
bgp policy on-startup med
bgp update-delay on-startup
bgp update-delay on-startup prefix-list
bgp update-delay wait-other-protocol
bgp-policy
bgp-policy accounting
bier
bier bfr-prefix proxy
bier enable
bier enable
bier fast-reroute enable
bier ipv6 oam enable
bier sub-sub-tlv-type
bims-server
binary
bind group
bind interface
bind interface
bind nqa-entry
bind ssl-server-policy
bind s-trunk
bind vrrp ipv6 vrid
bind vrrp vrid
bind-attribute
binding
binding admin-pw
binding admin-pw
binding path-group-id
binding-destination
binding-path-id
binding-retry
binding-sid
binding-sid (SRv6 TE policy view)
bmp server
bmp server monitor all-vpn-instance
bmp server monitor current-instance
bmp server notify delay
bmp-route-trace
bootfile-name
boot-loader file
boot-loader update
bootrom backup
bootrom restore
bootrom update
bootrom-update security-check enable
boundary
bras auto-cut-user before-reboot
bras compatible old-style-commands enable
bras data-backup-mode
bras vsrp-instance
bras vsrp-port
bridge-forwarding enable
broadcast-suppression
bsm-fragment enable (IPv6 PIM view)
bsm-fragment enable (PIM view)
bsm-reflection enable (IPv6 PIM view)
bsm-reflection enable (PIM view)
bsr-policy (IPv6 PIM view)
bsr-policy (PIM view)
bsr-rp-mapping rfc2362 (IPv6 PIM view)
bum-forwarding dx2l-based
bye
bye
bypass
bypass enable
bypass-peer
bypass-peer
C
cache forward no-bypass
cache list
cache source-address
cache-sa-enable
candidate-paths
candidate-paths
car
car
car name
c-bsr (IPv6 PIM view)
c-bsr (PIM view)
cd
cd
cd
cdp voice-vlan
cdup
cdup
certificate-chain-sending enable
cfd ais enable
cfd ais level
cfd ais period
cfd ais-track link-status global
cfd ais-track link-status level
cfd ais-track link-status period
cfd ais-track link-status vlan
cfd cc enable
cfd cc interval
cfd dlm continual
cfd dlm threshold
cfd dm one-way
cfd dm one-way continual
cfd dm one-way duration start
cfd dm one-way duration stop
cfd dm two-way
cfd dm two-way continual
cfd dm two-way duration start
cfd dm two-way duration stop
cfd dm two-way threshold
cfd enable
cfd frame-count mode
cfd hardware-cc
cfd linktrace
cfd linktrace auto-detection
cfd loopback
cfd md
cfd mep
cfd meplist
cfd mip-rule
cfd service-instance
cfd slm
cfd slm continual
cfd slm duration start
cfd slm duration stop
cfd slm threshold
cfd synthetic-slm
cfd synthetic-slm continual
cfd synthetic-slm duration start
cfd synthetic-slm duration stop
cfd synthetic-slm threshold
cfd tst
cfd tst continual
chassis convert mode irf
check flow-route-configuration
check logfile
check region-configuration
check-origin-validation
checkzero
checkzero
ciphersuite
circuit-cost
cir-test enable
class ip-pool
class option-group
class pool
class range
classification
classifier behavior
clear bgp vpn-prefix-orf
cli
client
client
client
client
client acl
client enable
client-verify
clock datetime
clock protocol
clock summer-time
clock timezone
close
cmi threshold
c-multicast frr
codec-type
collector
collector id
color end-point
color end-point
color match dot1p
color match dscp
color match dscp (DSCP forward type view)
color match dscp (SRv6 TE policy group view)
color match service-class (service class forward type view)
color match service-class (SRv6 TE policy group view)
color network-slice
color-aware-mode enable
color-mapping
command
command accounting
command authorization
commit
commit
commit
community read
company
compare-different-as-med
condition
confederation id
confederation nonstandard
confederation peer-as
confidentiality-offset
config-end
config-mode
configuration commit auto-save path
configuration commit max-number
configuration encrypt
configuration reauthentication enable
configuration replace
configuration replace file
configuration report interval
configuration system-view-mode
connection
connection remote-site-id
connection-limit
connection-limit amount
connection-limit apply
connection-limit apply global
connection-limit log-suppress interval
connection-limit rate
constraints
continue
controller address
controller auxiliary
controller connect interval
controller echo-request interval
controller mode
control-plane
control-session
control-session timeout
control-word enable
control-word enable
copy
copyright-info enable
cost-style
crc-error bit-error-ratio algorithm-parameter
crc-error bit-error-ratio transfer-protocol
c-rp (IPv6 PIM view)
c-rp (PIM view)
crp-policy (IPv6 PIM view)
crp-policy (PIM view)
csid-proportion global-id-block
customlog format
customlog host
customlog host source
customlog timestamp
cut access-user
cwmp
cwmp acs default password
cwmp acs default url
cwmp acs default username
cwmp acs password
cwmp acs url
cwmp acs username
cwmp cpe connect interface
cwmp cpe connect retry
cwmp cpe inform interval
cwmp cpe inform interval enable
cwmp cpe inform time
cwmp cpe password
cwmp cpe provision-code
cwmp cpe stun enable
cwmp cpe username
cwmp cpe wait timeout
cwmp enable
D
dae-loose-check enable
dampening
dampening
dampening
dampening ibgp
dampening-log size
database-filter peer
databits
data-delay
data-fill
data-flow-format (HWTACACS scheme view)
data-flow-format (RADIUS scheme view)
data-group
data-holddown
datapath-id
data-size
data-size
dci enable
dcn
debug
debugging
default
default
default
default
default
default
default
default
default
default
default
default color
default cost
default cost
default ip-pool
default local-preference
default match (APN ID-based traffic steering)
default match (ARN ID-based traffic steering)
default match (TE class ID-based traffic steering)
default med
default pool
default preferred-value
default table-miss permit
default tag
default-color (public instance IPv4/IPv6 address family view)
default-color (VPN instance IPv4/IPv6 address family view)
default-color (VPN instance IPv4/IPv6 unicast address family view)
default-cost
default-cost
default-group
default-lac-group enable
default-logon-page
default-metric
default-pw-id
default-route
default-route imported
default-route update-first
default-route-advertise
default-send-key
delay
delay threshold
delay-measure disable
delay-measure enable
delay-profile link-based
delete
delete
delete
delete dynamic-flow
delete ip rpf-route-static
delete ipv6 rpf-route-static
delete ipv6 static-routes all
delete static-routes all
delete-delay
delete-delay (SRv6 TE ODN policy group view)
delete-delay (SRv6 TE ODN view)
depth
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description (cross-connect group view)
description (Flowspec interface group view)
description (local guest view)
description (user group view)
description (VPN instance view)
destination
destination host
destination ip
destination ipv6
destination mac
destination port
destination-group (subscription view)
destination-group (telemetry view)
destination-probing enable
destination-probing interval
detnetip device-id
detnetip flow
detnetip path
detnetip path-group
detnetoam enable
device-id
dhcp apply-policy
dhcp authorized-ip-conflict ignore
dhcp class
dhcp client dad enable
dhcp client dscp
dhcp client identifier
dhcp client-detect
dhcp conflict-ip-address offline
dhcp dscp
dhcp enable
dhcp flood-protection aging-time
dhcp flood-protection enable
dhcp flood-protection global enable
dhcp flood-protection threshold
dhcp interface-rate-suppression aging-time
dhcp interface-rate-suppression enable
dhcp interface-rate-suppression global enable
dhcp interface-rate-suppression threshold
dhcp log enable
dhcp option-group
dhcp policy
dhcp pool-group
dhcp rate-limit
dhcp relay always-unicast
dhcp relay check mac-address
dhcp relay client-information record
dhcp relay client-information refresh
dhcp relay client-information refresh enable
dhcp relay dhcp-server timeout
dhcp relay forward reply by-option82
dhcp relay gateway
dhcp relay information circuit-id
dhcp relay information enable
dhcp relay information remote-id
dhcp relay information strategy
dhcp relay master-server switch-delay
dhcp relay non-first-hop enable
dhcp relay release ip
dhcp relay release-agent
dhcp relay server-address
dhcp relay server-address algorithm
dhcp relay source-address
dhcp relay vsrp-instance
dhcp route-log enable
dhcp select
dhcp select relay proxy
dhcp server
dhcp server allocated-ip threshold
dhcp server always-broadcast
dhcp server apply ip-pool
dhcp server bootp ignore
dhcp server bootp reply-rfc-1048
dhcp server check mac-address
dhcp server database filename
dhcp server database update interval
dhcp server database update now
dhcp server database update stop
dhcp server forbidden-ip
dhcp server ip-pool
dhcp server multi-ip per-mac enable
dhcp server ping packets
dhcp server ping timeout
dhcp server policy-first enable
dhcp server relay information enable
dhcp server reply-exclude-option60
dhcp server request-ip-address check
dhcp session-mismatch action
dhcp smart-relay enable
dhcp snooping binding database filename
dhcp snooping binding database update interval
dhcp snooping binding database update now
dhcp snooping binding record
dhcp snooping check mac-address
dhcp snooping check request-message
dhcp snooping deny
dhcp snooping enable
dhcp snooping information circuit-id
dhcp snooping information enable
dhcp snooping information remote-id
dhcp snooping information strategy
dhcp snooping log enable
dhcp snooping max-learning-num
dhcp snooping trust
dhcp user offline
dhcp vsrp port
dhcp vsrp-instance
dhcp-option password encryption
dhcp-proxy enable
dhcp-server nak-count
dhcp-server remote-ip-check bypass
dhcp-server source-address
dhcp-server timeout
dhcpv6-follow-ipv6cp
dhcpv6-relay source-address
diagnostic-logfile save
diffserv-mode
diffserv-mode
diffserv-mode
dir
dir
dir
disable (explicit path view)
disable-dn-bit-check
disable-dn-bit-set
discard-route
discard-route
disconnect
discover-nak-count
display | { count | { begin | exclude | include } }
display | by-linenum
display >
display >>
display aaa abnormal-offline-record
display aaa max-online-users
display aaa normal-offline-record
display aaa offline-record
display aaa online-fail-record
display aaa online-offline-reason
display access-user
display access-user backup-state
display access-user offline-reason statistics
display access-user statistics
display access-user user-detect packet-loss-ratio
display acl
display acl whitelist
display adjacent-table
display adjacent-table log
display alarm
display alarm active
display alarm history
display alias
display ancp access-loop
display ancp neighbor
display ancp statistic
display apn-id-ipv6 binding-list
display apn-id-ipv6 brief
display apn-id-ipv6 forwarding isolate-group
display apn-id-ipv6 forwarding isolate-policy
display apn-id-ipv6 instance
display apn-id-ipv6 isolate-policy
display apn-id-ipv6 isolate-policy statistics
display apn-id-ipv6 vpn-mapping
display archive configuration
display arp
display arp attack-suppression configuration
display arp attack-suppression per-interface
display arp attack-suppression per-interface interface
display arp entry-limit
display arp ip-address
display arp log
display arp safe-guard statistics
display arp snooping
display arp source-mac
display arp source-mac configuration
display arp source-mac statistics
display arp source-suppression
display arp suppression vsi
display arp suppression xconnect-group
display arp timer aging
display arp user-ip-conflict record
display arp user-move record
display arp valid-check statistics
display arp vpn-instance
display bgp all peer summary
display bgp bmp server
display bgp bmp server monitor-peer
display bgp dampening parameter
display bgp dampening-log
display bgp egress-engineering ipv4
display bgp egress-engineering ipv6
display bgp egress-engineering peer-set
display bgp egress-engineering srv6 peer-set
display bgp group
display bgp group flowspec
display bgp instance-info
display bgp ipv6 savnet dpp
display bgp ipv6 savnet ingress-neighbor-as
display bgp ipv6 savnet prefix
display bgp ipv6 savnet sav
display bgp ipv6 savnet spa
display bgp isolate-group mapping-vpn
display bgp l2vpn auto-discovery
display bgp l2vpn evpn
display bgp l2vpn evpn dampened
display bgp l2vpn evpn flap-info
display bgp l2vpn evpn inlabel
display bgp l2vpn signaling
display bgp link-state
display bgp link-state flexible-algorithm-definition
display bgp link-state prefix-sid
display bgp link-state segment-list
display bgp link-state sr-algorithm
display bgp mirror remote-sid
display bgp network
display bgp non-stop-routing status
display bgp paths
display bgp peer
display bgp peer received prefix-list
display bgp route-target evpn
display bgp route-target l3vpn
display bgp route-target mvpn
display bgp route-trace
display bgp routing-table dampened
display bgp routing-table flap-info
display bgp routing-table ipv4 flowspec
display bgp routing-table ipv4 flowspec rib
display bgp routing-table ipv4 labeled-unicast
display bgp routing-table ipv4 labeled-unicast inlabel
display bgp routing-table ipv4 labeled-unicast outlabel
display bgp routing-table ipv4 mdt
display bgp routing-table ipv4 multicast
display bgp routing-table ipv4 mvpn
display bgp routing-table ipv4 rtfilter
display bgp routing-table ipv4 sr-policy
display bgp routing-table ipv4 unicast
display bgp routing-table ipv4 unicast inlabel
display bgp routing-table ipv4 unicast outlabel
display bgp routing-table ipv6 flowspec
display bgp routing-table ipv6 flowspec rib
display bgp routing-table ipv6 multicast
display bgp routing-table ipv6 mvpn
display bgp routing-table ipv6 sr-policy
display bgp routing-table ipv6 unicast
display bgp routing-table ipv6 unicast inlabel
display bgp routing-table ipv6 unicast outlabel
display bgp routing-table vpnv4
display bgp routing-table vpnv4 flowspec
display bgp routing-table vpnv4 inlabel
display bgp routing-table vpnv4 outlabel
display bgp routing-table vpnv4 source-type
display bgp routing-table vpnv6
display bgp routing-table vpnv6 flowspec
display bgp routing-table vpnv6 inlabel
display bgp routing-table vpnv6 outlabel
display bgp routing-table vpnv6 source-type
display bgp rpki server
display bgp rpki table
display bgp segment-routing label-range
display bgp segment-routing prefix-sid-map
display bgp slice-prefix
display bgp summary
display bgp troubleshooting
display bgp update-group
display bgp update-packet record
display bgp vpn-prefix-orf
display bgp-policy statistics
display bier forward ipv6 statistics
display bier inter-as bfr-info
display bier inter-as routing-table
display bier prefix
display bier protocol
display bier routing-table
display bier sub-domain
display boot-loader
display bootp client
display bras-interface access-user-count
display bras-interface configuration
display bras-interface users-by-vlan
display cfd ais
display cfd ais-track link-status
display cfd dlm history
display cfd dm one-way history
display cfd dm one-way statistics
display cfd dm two-way history
display cfd dm two-way statistics
display cfd linktrace-reply
display cfd linktrace-reply auto-detection
display cfd md
display cfd mep
display cfd meplist
display cfd mp
display cfd remote-mep
display cfd service-instance
display cfd slm history
display cfd slm statistics
display cfd status
display cfd synthetic-slm history
display cfd tst history
display clock
display configuration commit diff
display configuration commit list
display configuration report check-point
display configuration sessions
display connection-limit
display connection-limit ipv6-stat-nodes
display connection-limit statistics
display connection-limit stat-nodes
display copyright
display counters
display counters rate
display cpu-usage
display cpu-usage configuration
display cpu-usage history
display cpu-usage overload
display cpu-usage overload summary
display cpu-usage service
display crypto-engine
display crypto-engine statistics
display current energy-saving
display current-configuration
display current-configuration diff
display cwmp configuration
display cwmp status
display dcn
display dcn ne-info
display debugging
display default-configuration
display detnetip capability
display detnetip flow
display detnetip path
display detnetip path-group
display detnetoam delay-statistics
display detnetoam instance
display detnetoam statistics
display detnetoam timeslot-statistics
display device
display device manuinfo
display device manuinfo power
display dhcp address offline-record
display dhcp client
display dhcp control-plane distribute
display dhcp flood-protection
display dhcp interface-rate-suppression
display dhcp pool-group
display dhcp pool-group-usage
display dhcp pool-usage
display dhcp rate-limit
display dhcp relay client-information
display dhcp relay information
display dhcp relay packet statistics
display dhcp relay remote-server-info
display dhcp relay server-address
display dhcp server conflict
display dhcp server database
display dhcp server expired
display dhcp server free-ip
display dhcp server ip-in-use
display dhcp server packet statistics
display dhcp server pool
display dhcp server statistics
display dhcp snooping binding
display dhcp snooping binding database
display dhcp snooping information
display dhcp snooping packet statistics
display dhcp snooping trust
display dhcp-access count
display dhcp-access packet statistics
display dhcp-access user-table
display dhcpv6-access count
display dhcpv6-access packet statistics
display dhcpv6-access user-table
display diagnostic-information
display diagnostic-logfile summary
display diff
display dldp
display dldp statistics
display dns domain
display dns host
display dns server
display dns snooping host
display domain
display domain
display domain access-user statistics
display dot1x
display dot1x connection
display driver arp packet drop
display eigrp
display eigrp interface
display eigrp peer
display eigrp peer statistics
display eigrp statistics
display eigrp topology
display energy-saving mode
display environment
display esmc
display ethernet statistics
display evpn auto-discovery
display evpn auto-discovery spmsi
display evpn df-election
display evpn es
display evpn instance
display evpn ipv6 auto-discovery
display evpn mldp p2mp
display evpn route { igmp-js | igmp-ls | smet }
display evpn route arp
display evpn route arp suppression
display evpn route arp-mobility
display evpn route mac
display evpn route mac-mobility
display evpn route nd
display evpn route nd suppression
display evpn route nd-mobility
display evpn route vpws
display evpn route xconnect-group
display evpn routing-table
display evpn srv6 mirror remote-sid
display evpn track peer
display exception context
display exception filepath
display explicit-path
display fan
display fan-speed
display fib
display fib count
display flow-monitor
display flow-route
display flowspec flow-interface-group
display flowspec statistics
display ftp client source
display ftp-server
display ftp-user
display gir custom-profile
display gir snapshot
display gir snapshot compare
display gir system-mode
display grpc
display ha service-group
display hardware-failure-detection
display hardware-failure-protection
display health
display history-command
display history-command all
display hotkey
display http-redirect statistics
display hwtacacs scheme
display icmp statistics
display ifindex-constant configuration
display ifindex-constant map
display ifit flow dynamic
display ifit flow static
display ifit global-information
display ifit instance
display ifit srv6-segment-list
display ifit statistic
display ifit statistic-type
display ifmonitor
display ifmonitor background-traffic interface
display igmp attack-suppression configuration
display igmp attack-suppression entry
display igmp group
display igmp host group
display igmp host-tracking
display igmp interface
display igmp proxy group
display igmp proxy routing-table
display igmp ssm-mapping
display igmp user-info
display info-center
display info-center file-server
display info-center filter
display inqa analyzer
display inqa analyzer instance
display inqa analyzer instance ams
display inqa collector
display inqa collector instance
display inqa statistics loss
display install active
display install backup
display install committed
display interface
display interface
display interface
display interface bas-interface
display interface inloopback
display interface link-info
display interface loopback
display interface main
display interface null
display interface phy-option
display interface range
display interface register-tunnel
display interface tunnel
display interface ve-l2vpn
display interface ve-l3vpn
display interface virtual-ppp
display interface virtual-template
display interface vlan-interface
display interface vsi-interface
display ip abnormal-packet-defend statistics
display ip as-path
display ip community-list
display ip extcommunity-list
display ip fast-forwarding aging-time
display ip fast-forwarding cache
display ip fast-forwarding fragcache
display ip icmp fast-reply statistics
display ip interface
display ip interface brief
display ip large-community-list
display ip load-sharing mode
display ip netstream cache
display ip netstream cache archive
display ip netstream export
display ip netstream template
display ip option source-route statistics
display ip policy-based-route
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
display ip pool
display ip pool ip-status
display ip pool network item
display ip pool network statistics
display ip pool-group
display ip prefix-list
display ip proxy-forward cache
display ip rd-list
display ip rd-list
display ip routing-table
display ip routing-table acl
display ip routing-table ip-address
display ip routing-table prefix-list
display ip routing-table protocol
display ip routing-table record
display ip routing-table statistics
display ip routing-table summary
display ip source binding
display ip statistics
display ip subscriber abnormal-logout
display ip subscriber auto-save
display ip subscriber auto-save file-status
display ip subscriber auto-save statistics
display ip subscriber chasten user auth-failed
display ip subscriber chasten user quiet
display ip subscriber http-defense blocked-destination-ip
display ip subscriber http-defense free-destination-ip
display ip subscriber http-defense unblocked-destination-ip
display ip subscriber roam-record
display ip subscriber session
display ip subscriber static-session configuration
display ip subscriber unclassified-ip-defense
display ip urpf
display ip urpf discard statistics
display ip vpn-instance
display ip-cache
display ipsec history-error
display ipsec profile
display ipsec sa
display ipsec statistics
display ipsec transform-set
display ipsec tunnel
display ipv6 adjacent-table
display ipv6 adjacent-table log
display ipv6 dhcp address offline-record
display ipv6 dhcp client
display ipv6 dhcp client statistics
display ipv6 dhcp control-plane distribute
display ipv6 dhcp duid
display ipv6 dhcp flood-protection
display ipv6 dhcp interface-rate-suppression
display ipv6 dhcp option-group
display ipv6 dhcp pool
display ipv6 dhcp pool-group
display ipv6 dhcp pool-group-usage
display ipv6 dhcp pool-usage
display ipv6 dhcp prefix offline-record
display ipv6 dhcp prefix-pool
display ipv6 dhcp rate-limit
display ipv6 dhcp relay client-information address
display ipv6 dhcp relay client-information pd
display ipv6 dhcp relay client-information srv6-locator
display ipv6 dhcp relay packet statistics
display ipv6 dhcp relay remote-server-info
display ipv6 dhcp relay server-address
display ipv6 dhcp server
display ipv6 dhcp server conflict
display ipv6 dhcp server database
display ipv6 dhcp server expired-ip
display ipv6 dhcp server expired-pd
display ipv6 dhcp server free-ip
display ipv6 dhcp server free-pd
display ipv6 dhcp server free-srv6-locator
display ipv6 dhcp server ip-in-use
display ipv6 dhcp server packet statistics
display ipv6 dhcp server pd-in-use
display ipv6 dhcp server srv6-locator-in-use
display ipv6 dhcp server statistics
display ipv6 dhcp snooping binding
display ipv6 dhcp snooping binding database
display ipv6 dhcp snooping packet statistics
display ipv6 dhcp snooping trust
display ipv6 dhcp srv6-locator offline-record
display ipv6 dns server
display ipv6 fast-forwarding aging-time
display ipv6 fast-forwarding cache
display ipv6 fib
display ipv6 fib count
display ipv6 icmp statistics
display ipv6 icmpv6 fast-reply statistics
display ipv6 interface
display ipv6 interface prefix
display ipv6 l2-multicast ip
display ipv6 l2-multicast ip forwarding
display ipv6 l2-multicast mac
display ipv6 l2-multicast mac forwarding
display ipv6 mrib interface
display ipv6 multicast boundary
display ipv6 multicast fast-forwarding cache
display ipv6 multicast flow-statistic
display ipv6 multicast forwarding event
display ipv6 multicast forwarding-table
display ipv6 multicast global pim sm statistics
display ipv6 multicast pim sm statistics
display ipv6 multicast routing-table
display ipv6 multicast routing-table static
display ipv6 multicast rpf-info
display ipv6 multicast-vlan
display ipv6 multicast-vlan forwarding-table
display ipv6 multicast-vlan group
display ipv6 nd attack-suppression configuration
display ipv6 nd attack-suppression per-interface
display ipv6 nd attack-suppression per-interface interface
display ipv6 nd log
display ipv6 nd source-mac
display ipv6 nd source-mac configuration
display ipv6 nd source-mac statistics
display ipv6 nd suppression vsi
display ipv6 nd user-ip-conflict record
display ipv6 neighbors
display ipv6 neighbors count
display ipv6 neighbors entry-limit
display ipv6 neighbors vpn-instance
display ipv6 netstream cache
display ipv6 netstream cache archive
display ipv6 netstream export
display ipv6 netstream template
display ipv6 option source-route statistics
display ipv6 pathmtu
display ipv6 pim attack-suppression configuration register source-ip
display ipv6 pim attack-suppression entry register source-ip
display ipv6 pim bsr-info
display ipv6 pim claimed-route
display ipv6 pim c-rp
display ipv6 pim interface
display ipv6 pim neighbor
display ipv6 pim routing-table
display ipv6 pim rp-info
display ipv6 pim statistics
display ipv6 pim-snooping neighbor
display ipv6 pim-snooping router-port
display ipv6 pim-snooping routing-table
display ipv6 pim-snooping statistics
display ipv6 policy-based-route
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
display ipv6 pool
display ipv6 pool-group
display ipv6 prefix
display ipv6 prefix-list
display ipv6 proxy-forward cache
display ipv6 rawip
display ipv6 rawip verbose
display ipv6 rib attribute
display ipv6 rib nib
display ipv6 rib nib record
display ipv6 route-direct nib
display ipv6 router-renumber statistics
display ipv6 route-static nib
display ipv6 route-static routing-table
display ipv6 routing-table
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table prefix-list
display ipv6 routing-table protocol
display ipv6 routing-table record
display ipv6 routing-table statistics
display ipv6 routing-table summary
display ipv6 sava
display ipv6 sava packet-drop statistics
display ipv6 savnet entry
display ipv6 savnet packet-drop statistics
display ipv6 statistics
display ipv6 tcp
display ipv6 tcp anti-syn-flood flow-based entry
display ipv6 tcp anti-syn-flood flow-based entry count
display ipv6 tcp verbose
display ipv6 tcp-proxy
display ipv6 tcp-proxy port-info
display ipv6 udp
display ipv6 udp anti-flood flow-based entry
display ipv6 udp anti-flood flow-based entry count
display ipv6 udp verbose
display ipv6 urpf
display ipv6 urpf discard statistics
display ipv6-cache
display irf
display irf configuration
display irf link
display irf topology
display isis
display isis event-log graceful-restart
display isis event-log hello
display isis event-log lsp
display isis event-log non-stop-routing
display isis event-log peer
display isis event-log route-record
display isis event-log spf
display isis event-log updated-lsp
display isis flex-algo route
display isis flex-algo spf-tree
display isis frr summary
display isis global-flex-algo
display isis global-statistics
display isis graceful-restart status
display isis interface
display isis interface hello-sent
display isis local-flex-algo
display isis lsdb
display isis lsdb statistics
display isis mesh-group
display isis mpls te advertisement
display isis mpls te configured-sub-tlvs
display isis mpls te network
display isis mpls te tunnel
display isis name-table
display isis non-stop-routing status
display isis packet
display isis peer
display isis peer hello-received
display isis peer lsp-purge-received
display isis redistribute
display isis route
display isis route bier
display isis savnet sav-table
display isis segment-routing adjacency
display isis segment-routing global-block
display isis segment-routing ipv6 capability
display isis segment-routing ipv6 locator
display isis segment-routing prefix-sid-map
display isis segment-routing routing-table
display isis spf-tree
display isis spf-tree bier
display isis srv6 tunnel
display isis statistics
display isis troubleshooting
display isis trust-level-mapping
display ita policy
display kernel deadloop
display kernel deadloop configuration
display kernel exception
display kernel memory alloc-failure
display kernel memory fragment free
display kernel reboot
display kernel starvation
display kernel starvation configuration
display keychain
display l2tp aging
display l2tp control-packet statistics
display l2tp packet-limit configuration
display l2tp packet-limit statistics
display l2tp session
display l2tp session temporary
display l2tp statistics
display l2tp tunnel
display l2tp tunnel vsrp
display l2tp-group
display l2vpn auto-discovery
display l2vpn bgp
display l2vpn bgp
display l2vpn forwarding
display l2vpn forwarding evpn
display l2vpn forwarding evpn split-horizon
display l2vpn forwarding mldp p2mp
display l2vpn forwarding srv6
display l2vpn interface
display l2vpn ldp
display l2vpn ldp
display l2vpn mac-address
display l2vpn mldp p2mp
display l2vpn peer srv6
display l2vpn pw
display l2vpn pw
display l2vpn pw bfd
display l2vpn pw state-machine
display l2vpn pw-class
display l2vpn service-instance
display l2vpn statistics srv6-pw inbound
display l2vpn traffic-statistics interface
display l2vpn traffic-statistics pw
display l2vpn traffic-statistics srv6-pw
display l2vpn vsi
display l2vpn vsi
display l2vpn vsi
display l2vpn xconnect-group
display lacp system-id
display ldap scheme
display line
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation troubleshooting
display link-aggregation verbose
display link-flap protection
display link-state-change statistics interface
display lldp local-information
display lldp neighbor-information
display lldp statistics
display lldp status
display lldp tlv-config
display local-bill
display local-proxy-arp
display local-user
display logbuffer
display logbuffer summary
display logfile summary
display loopback-detection
display mac-address
display mac-address aging-time
display mac-address mac-learning
display mac-address mac-move
display macsec
display mad
display max-user history
display memory
display memory dma
display memory-threshold
display memory-threshold dma
display mirroring-group
display mirroring-group car
display mirroring-group car interface
display mka policy
display mka session
display mka statistics
display mld attack-suppression configuration
display mld attack-suppression entry
display mld group
display mld host-tracking
display mld interface
display mld proxy group
display mld proxy routing-table
display mld ssm-mapping
display mld user-info
display mld-snooping
display mld-snooping group
display mld-snooping host-tracking
display mld-snooping router-port
display mld-snooping static-group
display mld-snooping static-router-port
display mld-snooping statistics
display mode channel-bandwidth interface
display monitoring-group
display monitor-link group
display mpls bfd
display mpls color-mapping flex-algo
display mpls forwarding ilm
display mpls forwarding nhlfe
display mpls interface
display mpls label
display mpls ldp discovery
display mpls ldp error-packet
display mpls ldp fec
display mpls ldp igp sync
display mpls ldp interface
display mpls ldp lsp
display mpls ldp lsp fault-analysis
display mpls ldp parameter
display mpls ldp peer
display mpls ldp summary
display mpls ldp troubleshooting
display mpls lsp
display mpls lsp statistics
display mpls mldp lsp p2mp
display mpls multicast-lsp protocol mldp p2mp
display mpls multicast-lsp statistics p2mp
display mpls nib
display mpls nid
display mpls sbfd
display mpls static-cr-lsp
display mpls static-lsp
display mpls static-sr-mpls
display mpls static-sr-mpls prefix
display mpls statistics tunnel-interface
display mpls summary
display mpls te bidirectional
display mpls te binding-sid
display mpls te binding-sid ref-list
display mpls te bit-error-detection tunnel-interface
display mpls te default-parameter
display mpls te ds-te
display mpls te link-management bandwidth-allocation
display mpls te link-management srlg
display mpls te p2mp tunnel-interface
display mpls te pce discovery
display mpls te pce lspdb
display mpls te pce lspdb last-packet-detail
display mpls te pce parameter
display mpls te pce peer
display mpls te pce stateful neighbor
display mpls te pce statistics
display mpls te segment-routing tunnel path
display mpls te srlg
display mpls te tedb
display mpls te tunnel lsp-down-info
display mpls te tunnel lsp-event switch
display mpls te tunnel-interface
display mpls tunnel
display mrib interface
display msdp brief
display msdp non-stop-routing status
display msdp peer-status
display msdp sa-cache
display msdp sa-count
display multicast boundary
display multicast fast-forwarding cache
display multicast flow-statistic
display multicast forwarding event
display multicast forwarding-table
display multicast global pim sm statistics
display multicast pim sm statistics
display multicast routing-table
display multicast routing-table static
display multicast rpf-info
display multicast-service-prefix configuration
display multicast-src-dt configuration
display multicast-vlan
display multicast-vlan forwarding-table
display multicast-vlan group
display multicast-vpn c-multicast routing-table
display multicast-vpn data-group receive
display multicast-vpn data-group send
display multicast-vpn default-group
display multicast-vpn inclusive-tunnel
display multicast-vpn neighbor
display multicast-vpn selective-tunnel
display mvrp running-status
display mvrp state
display mvrp statistics
display nat address-group
display nat address-group resource-usage
display nat all
display nat dns-map
display nat eim
display nat eim statistics
display nat log
display nat no-pat
display nat outbound
display nat server
display nat server-group
display nat session
display nat static
display nat statistics
display netconf service
display netconf session
display network-clock self-test-result
display network-clock source
display network-clock status
display network-clock version
display network-slice bandwidth usage statistics
display network-slice binding-list
display network-slice color-mapping
display network-slice configuration
display network-slice slice-prefix
display network-slice statistics
display nqa history
display nqa reaction counters
display nqa reflector
display nqa result
display nqa rfc2544 group
display nqa server
display nqa statistics
display nqa twamp client
display nqa twamp client statistics
display nqa twamp server global-information
display nqa twamp server session
display nqa twamp-light client
display nqa twamp-light client statistics
display nqa twamp-light client test-session reaction counters
display nqa twamp-light responder
display nqa y1564 group
display ntp-service high-precision-time session
display ntp-service high-precision-time status
display ntp-service ipv6 sessions
display ntp-service sessions
display ntp-service status
display ntp-service trace
display oam
display oam configuration
display oam critical-event
display oam link-event
display openflow
display openflow auxiliary
display openflow flow-table
display openflow group
display openflow instance
display openflow meter
display openflow oap-context
display openflow summary
display openflow-controller datapath
display openflow-controller flow-table
display osi
display osi statistics
display ospf
display ospf abr-asbr
display ospf abr-summary
display ospf asbr-summary
display ospf attribute
display ospf event-log
display ospf event-log hello
display ospf fast-reroute lfa-candidate
display ospf global-statistics
display ospf graceful-restart
display ospf hostname-table
display ospf interface
display ospf interface hello
display ospf lsdb
display ospf mpls te advertisement
display ospf mpls te network
display ospf mpls te pce
display ospf mpls te tunnel
display ospf nexthop
display ospf non-stop-routing status
display ospf peer
display ospf peer statistics
display ospf request-queue
display ospf retrans-queue
display ospf routing
display ospf segment-routing adjacency
display ospf segment-routing global-block
display ospf segment-routing prefix-sid-map
display ospf segment-routing routing-table
display ospf sham-link
display ospf spf-tree
display ospf statistics
display ospf troubleshooting
display ospf vlink
display ospfv3
display ospfv3 abr-asbr
display ospfv3 abr-summary
display ospfv3 asbr-summary
display ospfv3 event-log
display ospfv3 flex-algo routing
display ospfv3 flex-algo spf-tree
display ospfv3 global-flex-algo
display ospfv3 global-statistics
display ospfv3 graceful-restart
display ospfv3 interface
display ospfv3 local-flex-algo
display ospfv3 lsdb
display ospfv3 nexthop
display ospfv3 non-stop-routing
display ospfv3 peer
display ospfv3 request-queue
display ospfv3 retrans-queue
display ospfv3 routing
display ospfv3 segment-routing ipv6 capability
display ospfv3 segment-routing ipv6 locator
display ospfv3 sham-link
display ospfv3 spf-tree
display ospfv3 srv6 tunnel
display ospfv3 statistics
display ospfv3 vlink
display packet-capture status
display packet-drop
display packet-filter
display packet-filter statistics
display packet-filter statistics sum
display packet-filter verbose
display packet-follow configuration
display packet-follow statistics
display password-control
display password-control blacklist
display password-control weak-password-file
display pce segment-routing ipv6 policy database
display pce segment-routing ipv6 policy initiate-cache
display performance-management statistics
display performance-management task
display pim attack-suppression configuration register source-ip
display pim attack-suppression entry register source-ip
display pim bsr-info
display pim claimed-route
display pim c-rp
display pim interface
display pim neighbor
display pim routing-table
display pim rp-info
display pim statistics
display pim-snooping neighbor
display pim-snooping router-port
display pim-snooping routing-table
display pim-snooping statistics
display placement location
display placement policy
display placement program
display placement reoptimize
display port
display portal ip-subscriber message statistics
display portal mac-trigger entry
display portal mac-trigger-server
display portal mac-trigger-server packet statistics
display portal packet statistics
display portal server
display portal session user-type
display port-isolate group
display port-working-mode
display power
display power-information
display power-off high-temp-board
display ppp chasten per-mac
display ppp chasten statistics
display ppp chasten user
display ppp keepalive packet-loss-ratio
display ppp packet statistics
display pppoe-agency acl statistics
display pppoe-agency packet statistics
display pppoe-agency session summary
display pppoe-server chasten configuration
display pppoe-server chasten per-interface
display pppoe-server chasten per-interface configuration
display pppoe-server chasten statistics
display pppoe-server chasten user
display pppoe-server packet statistics
display pppoe-server session summary
display pppoe-server throttled-mac
display process
display process cpu
display process log
display process memory
display process memory alloc-failure
display process memory fragment free
display process memory fragment used
display process memory heap
display process memory heap address
display process memory heap size
display proxy-arp
display ptp clock
display ptp corrections
display ptp foreign-masters-record
display ptp interface
display ptp parent
display ptp path-trace
display ptp port-history
display ptp statistics
display ptp time-property
display ptp tod corrections
display qinq
display qos car control-plane whitelist
display qos car interface
display qos car l2vpn-pw
display qos car name
display qos control-plane anti-attack
display qos control-plane logging
display qos drop-profile
display qos exclusive-bandwidth interface outbound
display qos forwarding-class
display qos forwarding-group
display qos forwarding-profile
display qos gts interface
display qos lr
display qos map-table
display qos map-table color
display qos map-table interface
display qos map-table name
display qos policy
display qos policy control-plane
display qos policy control-plane pre-defined
display qos policy global
display qos policy interface
display qos policy user-profile
display qos qmprofile configuration
display qos qmprofile interface
display qos queue interface
display qos queue-statistics
display qos queue-statistics interface
display qos queue-statistics user-id
display qos scheduler-policy
display qos scheduler-policy diagnosis interface
display qos scheduler-policy interface
display qos trust interface
display qos user-profile-car member-link-scheduler distribute
display qos vlan-policy
display qos weight
display qos wred interface
display qos wred table
display qos wred-profile
display qos-acl resource
display qos-queue buffer-usage
display qos-queue resource
display radius buffer (for RADIUS)
display radius dynamic-author proxy
display radius scheme
display radius server-load statistics
display radius statistics
display radius-proxy statistics
display radius-proxy user
display rawip
display rawip verbose
display resource-monitor
display rib attribute
display rib graceful-restart
display rib nib
display rib nib record
display rip
display rip database
display rip graceful-restart
display rip interface
display rip neighbor
display rip non-stop-routing
display rip route
display ripng
display ripng database
display ripng graceful-restart
display ripng interface
display ripng neighbor
display ripng non-stop-routing
display ripng route
display rmon alarm
display rmon event
display rmon eventlog
display rmon history
display rmon prialarm
display rmon statistics
display role
display role command-rule-group
display role feature
display role feature-group
display route-direct nib
display route-policy
display router id
display route-static nib
display route-static routing-table
display rsvp
display rsvp authentication
display rsvp lsp
display rsvp p2mp lsp
display rsvp p2mp request
display rsvp p2mp reservation
display rsvp p2mp sender
display rsvp peer
display rsvp request
display rsvp reservation
display rsvp sender
display rsvp statistics
display rtm environment
display rtm policy
display sampler
display saved-configuration
display scheduler job
display scheduler logfile
display scheduler reboot
display scheduler schedule
display security-logfile summary
display segment-routing ipv6 available-static-sid
display segment-routing ipv6 forwarding
display segment-routing ipv6 local-sid
display segment-routing ipv6 local-sid lib
display segment-routing ipv6 local-sid statistics
display segment-routing ipv6 locator
display segment-routing ipv6 locator-statistics
display segment-routing ipv6 remote-locator
display segment-routing ipv6 remote-sid
display segment-routing ipv6 sfc forwarding
display segment-routing ipv6 te bfd
display segment-routing ipv6 te database
display segment-routing ipv6 te forwarding
display segment-routing ipv6 te forwarding traffic-statistics
display segment-routing ipv6 te ipr
display segment-routing ipv6 te path-segment
display segment-routing ipv6 te policy
display segment-routing ipv6 te policy ifit
display segment-routing ipv6 te policy last-down-reason
display segment-routing ipv6 te policy slice-prefix
display segment-routing ipv6 te policy statistics
display segment-routing ipv6 te policy status
display segment-routing ipv6 te policy-group
display segment-routing ipv6 te policy-group apn-id-ipv6
display segment-routing ipv6 te policy-group last-down-reason
display segment-routing ipv6 te policy-group statistics
display segment-routing ipv6 te sbfd
display segment-routing ipv6 te segment-list
display segment-routing ipv6 te source-sid
display segment-routing label-block
display segment-routing mapping-server prefix-sid-map
display segment-routing te database
display segment-routing te forwarding
display segment-routing te policy
display segment-routing te policy last-down-reason
display segment-routing te policy statistics
display segment-routing te policy-group
display segment-routing te sbfd
display segment-routing te segment-list
display service policy
display service-instance-group
display session aging-time application
display session aging-time state
display session relation-table
display session statistics
display session statistics ipv4
display session statistics ipv6
display session statistics multicast
display session table ipv4
display session table ipv6
display session table multicast ipv4
display session table multicast ipv6
display slot-monitor
display sma-anti-spoof ipv6 address-prefix
display sma-anti-spoof ipv6 packet-tag
display snmp-agent community
display snmp-agent context
display snmp-agent denylist ip statistics
display snmp-agent group
display snmp-agent local-engineid
display snmp-agent mib-node
display snmp-agent mib-view
display snmp-agent remote
display snmp-agent statistics
display snmp-agent sys-info
display snmp-agent trap queue
display snmp-agent trapbuffer drop
display snmp-agent trapbuffer send
display snmp-agent trap-list
display snmp-agent usm-user
display sntp ipv6 sessions
display sntp sessions
display srpm delay-profile
display srpm delay-statistics
display srpm interface
display ssh client source
display ssh server
display ssh user-information
display ssh2 algorithm
display ssl client-policy
display ssl server-policy
display startup
display static-user interface-list
display stop-accounting-buffer (for HWTACACS)
display stop-accounting-buffer (for RADIUS)
display stp
display stp abnormal-port
display stp bpdu-statistics
display stp down-port
display stp history
display stp ignored-vlan
display stp region-configuration
display stp root
display stp tc
display s-trunk brief
display s-trunk member role-change
display s-trunk packet-statistics
display supervlan
display system stable state
display target-configuration
display tcp
display tcp anti-syn-flood flow-based configuration
display tcp anti-syn-flood flow-based entry
display tcp anti-syn-flood flow-based entry count
display tcp anti-syn-flood interface-based configuration
display tcp anti-syn-flood interface-based entry
display tcp anti-syn-flood interface-based entry count
display tcp statistics
display tcp trace cache-connection
display tcp trace cache-packet ip
display tcp trace cache-packet ipv6
display tcp trace information
display tcp verbose
display tcp-proxy
display tcp-proxy port-info
display te link-management bandwidth-allocation
display te link-management srlg
display telnet client
display this
display this interface
display time-range
display trace access-user
display trace-logfile summary
display track
display traffic behavior
display traffic classifier
display traffic-statistics vpn-instance
display transceiver alarm
display transceiver auto-laser-down
display transceiver brief
display transceiver diagnosis
display transceiver interface
display transceiver manuinfo
display transceiver status
display ttl-security statistics
display tunnel-info ipv6
display tunnel-policy
display tunnel-selector
display udp
display udp anti-flood flow-based configuration
display udp anti-flood flow-based entry
display udp anti-flood flow-based entry count
display udp anti-flood interface-based configuration
display udp anti-flood interface-based entry
display udp anti-flood interface-based entry count
display udp statistics
display udp verbose
display udp-helper interface
display user-group
display user-group
display user-group-profile
display user-interface
display userlog export
display user-profile
display user-profile interface
display user-profile l2vpn-pw
display users
display value-added-service user
display value-added-service user { ip-address | ipv6-address }
display value-added-service user policy
display value-added-service user user-id
display value-added-service user username
display version
display version-update-record
display vlan
display vlan brief
display vlan-group
display vrrp
display vrrp abnormal-info
display vrrp binding
display vrrp ipv6
display vrrp ipv6 abnormal-info
display vrrp ipv6 binding
display vrrp ipv6 statistics
display vrrp statistics
display vsi e-tree
display vsrp instance
display vsrp peer
display vxlan tunnel
displays-trunk verbose
distibute bgp-ls
distribute
distribute bgp-ls
distribute bgp-ls
distribute bgp-ls
distributed-gateway local
dldp authentication-mode
dldp authentication-password
dldp delaydown-timer
dldp enable
dldp global enable
dldp interval
dldp unidirectional-shutdown
dn-bit-check
dn-bit-set
dns cache ttl
dns domain
dns domain-name-group
dns domain-rule
dns dscp
dns proxy enable
dns redirect enable
dns server (DNS server group view)
dns server (system view/interface view)
dns server-group
dns snooping enable
dns source-interface
dns trust-interface
dns-list
dns-server
domain
domain default enable
domain if-unknown
domain-authentication send-only
domain-authentication-mode
domain-distinguisher
domain-id (OSPF view)
domain-id (OSPFv3 view)
domain-name
domain-name
domain-name
dot1x access-user log enable
dot1x authentication-method
dot1x domain-delimiter
dot1x duplicate-eapol-start discard
dot1x handshake
dot1x handshake reply enable
dot1x handshake secure
dot1x mandatory-domain
dot1x max-user
dot1x max-user-alarm
dot1x quiet-period
dot1x re-authenticate
dot1x re-authenticate { authentication-fail | server-unreachable } keep-online
dot1x retry
dot1x timer
downlink up-delay
drop-profile
drop-upon-invalid
drop-upon-mismatch enable
dscp
dscp
dscp
dscp
dscp
dscp
dscp
dscp
dscp
dscp
duplex
dynamic (SRv6 TE ODN view)
dynamic (SRv6 TE policy path preference view)
dynamic-authorization effective-attribute
dynamic-flow aging-time
E
easy-irf
ebgp-interface-sensitive
ecmp-frr-coexist enable
egress-engineering label delete-delay
egress-engineering link-delay
egress-engineering link-loss
egress-engineering metric-bandwidth advertisement enable
egress-engineering metric-bandwidth suppression
egress-engineering metric-delay advertisement enable
egress-engineering metric-delay suppression
egress-engineering metric-link-loss advertisement enable
egress-engineering metric-link-loss suppression
eigrp
eigrp metric
eigrp split-horizon
eigrp timer hello
eigrp timer hold
email
embedded-rp
enable
enable
enable (MLD-snooping view)
enable ipsec-profile
enable link-local-signaling
enable log updown
enable out-of-band-resynchronization
enable snmp trap updown
encap-data-enable
encapsulation
encapsulation
encapsulation
encapsulation
encapsulation eth out-interface
encapsulation ipv4 nexthop
encapsulation ipv6 nexthop
encapsulation source-address
encapsulation-mode
encapsulation-mode
encapsulation-mode encaps include local-end.x
encapsulation-mode insert include local-end.x
encapsulation-type
encoding
end-bier locator
end-point
end-point
end-rgb locator
end-x update-delay
entropy-label enable
entry-limit (MLD-snooping view)
error-packet size
escape-key
esi
esmc bundle
esmc enable
esn enable
esp authentication-algorithm
esp encryption-algorithm
e-tree
e-tree enable
e-tree leaf
e-tree mode
event cli
event hotplug
event interface
event process
event snmp oid
event snmp-notification
event syslog
event track
event-log
event-log
event-log route-record size
event-log size
event-log updated-lsp size
evpn df-election ac-influence enable
evpn df-election algorithm (interface view/IESI view)
evpn df-election algorithm (system view)
evpn df-election preference
evpn df-election preference non-revertive
evpn edge group
evpn encapsulation
evpn encapsulation binding instance
evpn encapsulation srv6
evpn encapsulation srv6 binding instance
evpn frr local (cross-connect group EVPN instance view)
evpn frr local (EVPN instance view/VSI EVPN instance view)
evpn frr remote
evpn instance
evpn irb asymmetric
evpn local-service-id remote-service-id
evpn mac re-originated enable
evpn mac-move local-suppression
evpn mpls routing-enable
evpn multihoming advertise disable
evpn multihoming advertise ignore-ethernet-tag
evpn multihoming re-originated mac
evpn multihoming re-originated mac age-time
evpn multihoming timer df-delay
evpn multihoming vpls-frr local
evpn multihoming vpws-frr local
evpn multihoming vxlan-frr local
evpn redundancy-mode
evpn route arp-mobility suppression
evpn route mac-mobility suppression
evpn route nd-mobility suppression
evpn timer ad-delay
evpn timer es-delay
evpn timer es-recovery
evpn track bfd
evpn track peer
evpn vpws local-service-id remote-service-id
evpn vpws-frr remote
exception filepath
exchange-port enable
exclude
exclude-any
exclude-attribute
exclude-srlg
exclude-srlg
exhaustion log enable
exhaustion trap enable
exit
exit()
expect data
expect ip
expect ipv6
expect status
expired
explicit segment-list
explicit-path
export host-route
export host-route
export route-policy
export route-policy
export route-policy
export route-policy
extcommunity vpn-target additive
ext-community-type (OSPF view)
ext-community-type (OSPFv3 view)
extcommunity-type usergroup-id
F
fail-open mode
failover-group
fan-speed
fan-speed set-rate
fast-leave (MLD-snooping view)
fast-reroute
fast-reroute
fast-reroute
fast-reroute
fast-reroute
fast-reroute enable
fast-reroute enable
fast-reroute microloop-avoidance enable
fast-reroute microloop-avoidance enable (IS-IS IPv6 address family)
fast-reroute microloop-avoidance enable (OSPFv3 view)
fast-reroute microloop-avoidance rib-update-delay
fast-reroute microloop-avoidance rib-update-delay (IS-IS IPv6 address family)
fast-reroute microloop-avoidance rib-update-delay (OSPFv3 view)
fast-reroute mirror delete-delay
fast-reroute mirror enable
fast-reroute primary-path-detect bfd
fast-reroute remote-lfa maximum-cost
fast-reroute remote-lfa prefix-list
fast-reroute remote-lfa tunnel ldp
fast-reroute route-policy
fast-reroute tiebreaker
fast-reroute tiebreaker (flexible algorithm view)
fast-reroute tiebreaker (IS-IS IPv4 unicast address family view/IS-IS IPv6 unicast address family view)
fast-reroute tiebreaker (OSPFv3 view)
fast-reroute ti-lfa
fast-reroute ti-lfa
fast-reroute ti-lfa enable
fast-reroute ti-lfa encaps
fast-reroute timer
fdisk
feature
fg-client
fib lifetime
fib log enable
fib max-number
fib smooth
fib switch-enhance
file prompt
filename
filter
filter
filter
filter
filter-policy export
filter-policy import
fixdisk
flag
flash-flood
flex-algo
flex-algo
flex-algo (IS-IS view)
flex-algo (segment routing view)
flex-algo algorithm
flexe config-mode
flooding disable
flow
flow
flow (analyzer AMS view)
flow (collector instance view)
flow standard-mode enable
flow-control
flow-control
flow-control receive enable
flow-entry max-limit
flow-interval
flow-interval
flow-label
flow-label
flow-monitor
flow-monitor add ip
flow-monitor add mpls
flow-monitor delete ip
flow-monitor delete mpls
flow-monitor fixup
flow-route (Flowspec IPv4 address family view, Flowspec IPv6 address family view)
flow-route (system view)
flow-route flow-interface-group
flow-route ipv6
flowspec
flowspec disable
flowspec refluence
flow-statistics frequency
flow-table
flush route-attribute
flush suboptimal-route
forbidden port
forbidden-address
forbidden-ip
forbidden-ip-range
forbidden-prefix
format
forward { no-bypass | bypass }
forward per-packet
forwarding mode
forwarding statistics
forwarding statistics enable
forwarding statistics interval
forwarding-class
forwarding-group (forwarding group match criterion view)
forwarding-group profile (scheduler-policy match criterion view)
forward-path-detection enable
forward-type (SRv6 TE ODN policy group view)
forward-type (SRv6 TE policy group view)
frame-size
free account
free ftp user
free ftp user-ip
free ftp user-ip ipv6
free line
free user-interface
free-rule
free-traffic threshold
frequency
ftp
ftp client ipv6 source
ftp client source
ftp client timeout
ftp ipv6
ftp maintain enable
ftp server acl
ftp server acl-deny-log enable
ftp server dscp
ftp server enable
ftp server ipv6 dscp
ftp server login-failed threshold-alarm
ftp server ssl-server-policy
ftp timeout
full-name
G
gateway
gateway subnet
gateway vsi-interface
gateway-list
gateway-list
gateway-list
g-bier mpra
get
get
gir custom-profile
gir snapshot add
gir snapshot create
gir snapshot delete
gir system-mode maintenance
gir system-mode maintenance maintenance-delay
gir system-mode maintenance revert-delay
gir system-mode maintenance snapshot-delay
global-block
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart enable
graceful-restart helper enable
graceful-restart helper strict-lsa-checking
graceful-restart interval
graceful-restart peer-reset
graceful-restart suppress-sa
graceful-restart t1
graceful-restart t2
graceful-restart t3
graceful-restart timer
graceful-restart timer purge-time
graceful-restart timer restart
graceful-restart timer wait-for-rib
gratuitous-arp mac-change retransmit
gratuitous-arp-learning enable
gratuitous-arp-sending enable
gre key
green
group
group
group
group
group
group-color
group-name
group-policy (MLD-snooping view)
grpc acl
grpc data-model
grpc enable
grpc idle-timeout
grpc log dial-in gnmi
grpc log dial-in rpc
grpc log dial-out
grpc pki domain
grpc port
grpc sensor-mode
grpc server enable
gts
gunzip
gzip
H
hardware-failure-protection aggregation
hardware-failure-protection auto-down
header
hello interval
hello lost
hello node-session
hello-option dr-priority (IPv6 PIM view)
hello-option dr-priority (PIM view)
hello-option holdtime (IPv6 PIM view)
hello-option holdtime (PIM view)
hello-option lan-delay (IPv6 PIM view)
hello-option lan-delay (PIM view)
hello-option neighbor-tracking (IPv6 PIM view)
hello-option neighbor-tracking (PIM view)
hello-option override-interval (IPv6 PIM view)
hello-option override-interval (PIM view)
help
help
hex-data-fill
high-performance-mode
history-command max-size
history-record enable
history-record keep-time
history-record number
holdtime join-prune (IPv6 PIM view)
holdtime join-prune (PIM view)
host-advertise
host-aging-time (MLD-snooping view)
hostname
host-route
host-tracking (MLD-snooping view)
host-tracking enable (IGMP view)
host-tracking enable (MLD view)
hotkey
http-redirect https-port
http-redirect https-rate-limit
http-redirect ssl-server-policy
hwtacacs nas-ip
hwtacacs scheme
hwtacacs-user change-password
I
iccn max-connect-speed
icmp-jitter-mode
icmpv6-error relay enable
identify-inner
identity-number
idle-timeout
ifindex-constant enable
ifindex-constant max-number
ifit delay-measure
ifit enable
ifit interval
ifit loss-measure
ifit measure mode
if-match
if-match
if-match
if-match
if-match acl
if-match acl
if-match as-path
if-match community
if-match community
if-match cost
if-match extcommunity
if-match interface
if-match ip
if-match ip
if-match ipv6
if-match ipv6
if-match large-community
if-match local-preference
if-match mpls-exp
if-match mpls-label
if-match protocol
if-match qos-local-id
if-match rd-list
if-match rd-list
if-match route-policy
if-match route-type
if-match rpki
if-match tag
ifmonitor crc-error
ifmonitor crc-error
ifmonitor giant
ifmonitor giant
ifmonitor input-buffer-drop
ifmonitor input-error
ifmonitor input-usage
ifmonitor output-buffer-drop
ifmonitor output-error
ifmonitor output-usage
ifmonitor runt
ifmonitor runt
ifstats sample-interval
igmp
igmp access-policy
igmp attack-defense
igmp attack-suppression aging-time
igmp attack-suppression check-interval
igmp attack-suppression enable
igmp attack-suppression threshold
igmp authorization-enable
igmp enable
igmp fast-leave
igmp group-policy
igmp host enable
igmp host-tracking { disable | enable }
igmp host-tracking limit
igmp join-by-session
igmp last-member-query-count
igmp last-member-query-interval
igmp log enable
igmp log suppress
igmp max-response-time
igmp other-querier-present-interval
igmp proxy enable
igmp proxy forwarding
igmp query-interval
igmp robust-count
igmp startup-query-count
igmp startup-query-interval
igmp static-group
igmp user-vlan-aggregation
igmp version
igmp vsrp-instance
igmp vsrp-load-balance
igmp vsrp-port
igmp vsrp-sync enable
ignore all-peers
ignore-ac-state
ignore-att
ignore-first-as
igp sync delay
igp sync delay on-restart
igp-metric inherit
import (flexible priority map view)
import (priority map view)
import bgp
import evpn mac-ip
import route-policy
import route-policy
import route-policy
import route-policy
import-bier
import-bier
import-rib
import-route
import-route
import-route
import-route
import-route
import-route
import-route
import-route isis level-1 into level-2
import-route isis level-2 into level-1
import-route isisv6 level-1 into level-2
import-route isisv6 level-2 into level-1
import-route limit
import-route multipath
import-route no-inherit-tag
import-route no-route-calculate
import-route sr-policy
import-route-append
import-source
in-band management vlan
include
include-all
include-any
inclusive-provider-tunnel
inclusive-tunnel dynamic
index
index
index apn-id match
index arn-id match
index instance isolate-group behavior
index prefix-name
index te-class match
info-center diagnostic-logfile directory
info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency
info-center diagnostic-logfile quota
info-center enable
info-center file-server transport-type
info-center file-server user
info-center filter
info-center format
info-center logbuffer
info-center logbuffer size
info-center logfile alarm-threshold
info-center logfile directory
info-center logfile enable
info-center logfile frequency
info-center logfile size-quota
info-center logging suppress duplicates
info-center logging suppress module
info-center loghost
info-center loghost locate-info with-sn
info-center loghost source
info-center security-logfile alarm-threshold
info-center security-logfile directory
info-center security-logfile enable
info-center security-logfile frequency
info-center security-logfile size-quota
info-center source
info-center synchronous
info-center syslog min-age
info-center syslog trap buffersize
info-center timestamp
info-center timestamp loghost
info-center trace-logfile directory
info-center trace-logfile enable
info-center trace-logfile frequency
info-center trace-logfile quota
in-group
inherit peer-locator
init-ttl
inner-type
inqa analyzer
inqa collector
inqa mp
inside ip
install activate
install commit
install deactivate
instance
instance
instance
instance (analyzer view)
instance (collector view)
instance (network slice view)
intelligent-policy-route
interface
interface
interface (Flowspec interface group view)
interface bridge-aggregation
interface flexe
interface flexe-group
interface loopback
interface null
interface policy deny
interface range
interface range name
interface route-aggregation
interface tunnel
interface vagg-bridge-port
interface ve-l2vpn
interface ve-l3vpn
interface virtual-bridge-port
interface-status-change
inter-level-tilfa level-1 enable
inter-protocol ecmp
inter-protocol fast-reroute
Interval
interval
ip
ip (MAC binding server view)
ip (portal authentication server view)
ip abnormal-packet-defend enable
ip address
ip address bootp-alloc
ip address dhcp-alloc
ip address ppp-negotiate
ip address te-tunnel unnumbered
ip address unnumbered
ip as-path
ip binding vpn-instance
ip community-list
ip dscp
ip fast-forwarding load-sharing
ip forward-broadcast
ip forwarding
ip forwarding-table save
ip host
ip icmp echo-reply traffic-priority
ip icmp error-interval
ip icmp fast-reply enable
ip icmp receive enable
ip icmp send enable
ip icmp source
ip irdp
ip irdp address
ip irdp interval
ip irdp lifetime
ip irdp multicast
ip irdp preference
ip local policy-based-route
ip mtu
ip netstream (interface view)
ip netstream (system view)
ip netstream aggregation
ip netstream aging
ip netstream cache archive enable
ip netstream export host (NetStream aggregation mode view)
ip netstream export host (system view)
ip netstream export rate
ip netstream export source
ip netstream export template refresh-rate
ip netstream export version
ip netstream max-entry
ip netstream mpls
ip netstream outbound sampler srv6-policy
ip netstream outbound srv6-policy
ip netstream sampler
ip netstream template rfc7011
ip netstream timeout active
ip netstream timeout inactive
ip option enable
ip option source-route enable
ip policy-based-route-log enable
ip pool
ip pool-group
ip prefix-list
ip public-instance
ip public-instance
ip rd-list
ip rd-list
ip reassemble local enable
ip redirects enable
ip route-static
ip route-static bfd
ip route-static default-preference
ip route-static fast-reroute auto
ip route-static primary-path-detect bfd
ip route-static recursive-lookup segment-routing-ipv6
ip route-static recursive-lookup tunnel
ip route-static vpn-instance
ip route-static-group
ip rpf-route-static
ip source binding (interface view)
ip subscriber 8021p
ip subscriber abnormal-logout max-user
ip subscriber access-block
ip subscriber access-delay
ip subscriber access-delay odd-even mac offset
ip subscriber access-line-id circuit-id trans-format
ip subscriber access-line-id remote-id trans-format
ip subscriber access-out
ip subscriber access-trigger loose
ip subscriber authentication chasten
ip subscriber authentication dot1x-retrigger
ip subscriber authentication dot1x-retrigger interval
ip subscriber authentication-method
ip subscriber auto-recover enable
ip subscriber auto-recover speed
ip subscriber auto-save max-user
ip subscriber auto-save-file
ip subscriber auto-save-file now
ip subscriber basic-service-ip-type
ip subscriber captive-bypass enable
ip subscriber dhcp domain
ip subscriber dhcp domain include
ip subscriber dhcp max-session
ip subscriber dhcp option60 match
ip subscriber dhcp password
ip subscriber dhcp rate-limit
ip subscriber dhcp username
ip subscriber dhcp-release-ip dot1x-offline
ip subscriber dhcpv6 match
ip subscriber dhcpv6 max-session
ip subscriber dhcpv6 password option16
ip subscriber dhcpv6 rate-limit
ip subscriber dot1x-offline user-offline
ip subscriber dscp
ip subscriber enable
ip subscriber family-leased
ip subscriber http-defense destination-ip enable
ip subscriber http-defense destination-ip threshold
ip subscriber http-fast-reply enable
ip subscriber if-match
ip subscriber initiator arp enable
ip subscriber initiator dhcp enable
ip subscriber initiator ndrs enable
ip subscriber initiator nsna enable
ip subscriber initiator unclassified-ip enable
ip subscriber initiator unclassified-ipv6 enable
ip subscriber interface-leased
ip subscriber ipv6-address-change send-accounting-update
ip subscriber l2vpn-leased
ip subscriber lease-end-time original
ip subscriber mac-auth domain
ip subscriber max-session
ip subscriber nas-port-id format
ip subscriber nas-port-id interface
ip subscriber nas-port-id nasinfo-insert
ip subscriber nas-port-type
ip subscriber ndrs domain
ip subscriber ndrs max-session
ip subscriber ndrs user-detect-address eui-64
ip subscriber ndrs username
ip subscriber ndrs wait-delegation-prefix
ip subscriber password
ip subscriber pre-auth domain
ip subscriber pre-auth track
ip subscriber reauth
ip subscriber recover-file
ip subscriber roam-group-mismatch dhcp fast-renew
ip subscriber roam-group-mismatch unclassified-ip roam
ip subscriber roaming enable
ip subscriber roam-record max
ip subscriber save-file
ip subscriber service-identify
ip subscriber session static (interface view)
ip subscriber session static (system view)
ip subscriber session static-leased
ip subscriber session-conflict action offline
ip subscriber static-dot1x-user enable
ip subscriber static-session request-online interval
ip subscriber subnet-leased
ip subscriber timer quiet
ip subscriber trust
ip subscriber trust aaa-authorized-ip
ip subscriber unclassified-ip domain
ip subscriber unclassified-ip ip match
ip subscriber unclassified-ip ipv6 match
ip subscriber unclassified-ip max-session
ip subscriber unclassified-ip username
ip subscriber unclassified-ip-defense block-period
ip subscriber unclassified-ip-defense enable
ip subscriber unclassified-ip-defense threshold
ip subscriber unclassified-ipv6 max-session
ip subscriber user-detect ip
ip subscriber user-detect ipv6
ip subscriber username
ip subscriber vlan
ip subscriber web-auth domain
ip subscriber web-redhcp enable
ip ttl-expires enable
ip unr
ip unreachables enable
ip urpf
ip urpf strict
ip verify source
ip vpn-instance (BGP instance view)
ip vpn-instance (system view)
ip-in-use threshold
ip-in-use threshold
ip-pool algorithm round-robin
ipr-policy
ipsec df-bit
ipsec fragmentation
ipsec global-df-bit
ipsec limit max-tunnel
ipsec logging packet enable
ipsec profile
ipsec sa global-duration
ipsec transform-set
ip-usage-warning
ipv4-address
ipv6
ipv6
ipv6 (APN view)
ipv6 accept-label
ipv6 address
ipv6 address anycast
ipv6 address auto
ipv6 address auto link-local
ipv6 address dhcp-alloc
ipv6 address duplicate-detect enable
ipv6 address duplicate-detect interval
ipv6 address eui-64
ipv6 address link-local
ipv6 address prefix-number
ipv6 advertise-label peer
ipv6 advertise-label prefix-list
ipv6 bandwidth-based-sharing
ipv6 dhcp advertise pd-route
ipv6 dhcp advertise srv6-locator-route
ipv6 dhcp apply-policy
ipv6 dhcp class
ipv6 dhcp client dscp
ipv6 dhcp client duid
ipv6 dhcp client pd
ipv6 dhcp client stateful
ipv6 dhcp client stateless enable
ipv6 dhcp client-detect
ipv6 dhcp conflict-ip-address offline
ipv6 dhcp dscp
ipv6 dhcp duid
ipv6 dhcp duid-mismatch offline
ipv6 dhcp flood-protection aging-time
ipv6 dhcp flood-protection enable
ipv6 dhcp flood-protection global enable
ipv6 dhcp flood-protection threshold
ipv6 dhcp interface-rate-suppression aging-time
ipv6 dhcp interface-rate-suppression enable
ipv6 dhcp interface-rate-suppression global enable
ipv6 dhcp interface-rate-suppression threshold
ipv6 dhcp log enable
ipv6 dhcp policy
ipv6 dhcp pool
ipv6 dhcp relay client-information record
ipv6 dhcp relay client-link-address enable
ipv6 dhcp relay gateway
ipv6 dhcp relay interface-id
ipv6 dhcp relay non-first-hop enable
ipv6 dhcp relay release-agent
ipv6 dhcp relay remote-id duid
ipv6 dhcp relay remote-id enable
ipv6 dhcp relay server-address algorithm
ipv6 dhcp relay source-address
ipv6 dhcp relay subscriber-id
ipv6 dhcp relay subscriber-id enable
ipv6 dhcp relay vsrp-instance
ipv6 dhcp remote-server
ipv6 dhcp route-log enable
ipv6 dhcp select
ipv6 dhcp server
ipv6 dhcp server apply pool
ipv6 dhcp server database filename
ipv6 dhcp server database update interval
ipv6 dhcp server database update now
ipv6 dhcp server database update stop
ipv6 dhcp server forbidden-address
ipv6 dhcp server forbidden-prefix
ipv6 dhcp server multi-ip per-mac enable
ipv6 dhcp session-mismatch action
ipv6 dhcp snooping binding database filename
ipv6 dhcp snooping binding database update interval
ipv6 dhcp snooping binding database update now
ipv6 dhcp snooping binding record
ipv6 dhcp snooping check request-message
ipv6 dhcp snooping deny
ipv6 dhcp snooping enable
ipv6 dhcp snooping log enable
ipv6 dhcp snooping max-learning-num
ipv6 dhcp snooping option interface-id enable
ipv6 dhcp snooping option interface-id string
ipv6 dhcp snooping option remote-id enable
ipv6 dhcp snooping option remote-id string
ipv6 dhcp vsrp port
ipv6 dhcp vsrp-instance
ipv6 dns dscp
ipv6 dns server (DNS server group view)
ipv6 dns server (system view)
ipv6 fast-forwarding load-sharing
ipv6 fib max-number
ipv6 forwarding
ipv6 hop-limit
ipv6 hoplimit-expires enable
ipv6 host
ipv6 icmpv6 echo-reply traffic-priority
ipv6 icmpv6 error-interval
ipv6 icmpv6 fast-reply enable
ipv6 icmpv6 receive enable
ipv6 icmpv6 send enable
ipv6 icmpv6 source
ipv6 import bgp
ipv6 local policy-based-route
ipv6 lsp-trigger
ipv6 mtu
ipv6 multicast forwarding-table cache-unknown per-entry
ipv6 multicast forwarding-table cache-unknown total
ipv6 multicast frr mode
ipv6 multicast frr monitor cycle
ipv6 multicast frr wtr
ipv6 multicast global limit pim sm
ipv6 multicast limit pim sm
ipv6 multicast rpf-fail-pkt flooding
ipv6 multicast rpf-fail-pkt trap-to-cpu
ipv6 multicast warm-root-standby monitor cycle
ipv6 multicast-vlan
ipv6 multicast-vlan entry-limit
ipv6 nd attack-suppression check-interval
ipv6 nd attack-suppression enable per-interface
ipv6 nd attack-suppression suppression-time
ipv6 nd attack-suppression threshold
ipv6 nd autoconfig other-flag
ipv6 nd check log enable
ipv6 nd dad attempts
ipv6 nd distributed-gateway dynamic-entry synchronize
ipv6 nd entry-limit record enable
ipv6 nd local-conflict record enable
ipv6 nd mac-check enable
ipv6 nd nd-miss record enable
ipv6 nd ns retrans-timer
ipv6 nd nud reachable-time
ipv6 nd probe rate-limit
ipv6 nd ra dns search-list
ipv6 nd ra dns search-list suppress
ipv6 nd ra dns server
ipv6 nd ra dns server suppress
ipv6 nd ra halt
ipv6 nd ra hop-limit unspecified
ipv6 nd ra interval
ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
ipv6 nd ra prefix default
ipv6 nd ra router-lifetime
ipv6 nd route-direct advertise
ipv6 nd router-preference
ipv6 nd source-mac
ipv6 nd source-mac aging-time
ipv6 nd source-mac check-interval
ipv6 nd source-mac exclude-mac
ipv6 nd source-mac threshold
ipv6 nd span-segment-learning enable
ipv6 nd suppression enable
ipv6 nd unsolicited-na-learning enable
ipv6 nd user-ip-conflict record enable
ipv6 nd vsrp-instance
ipv6 nd vsrp-port
ipv6 neighbor
ipv6 neighbor stale-aging
ipv6 neighbor timer stale-aging
ipv6 neighbors max-learning-num
ipv6 neighbors max-learning-number
ipv6 netstream (interface view)
ipv6 netstream (system view)
ipv6 netstream aggregation
ipv6 netstream cache archive enable
ipv6 netstream export host (IPv6 NetStream aggregation mode view)
ipv6 netstream export host (system view)
ipv6 netstream export rate
ipv6 netstream export source
ipv6 netstream export template refresh-rate
ipv6 netstream export version
ipv6 netstream max-entry
ipv6 netstream outbound srv6-policy
ipv6 netstream srv6 inner-packet
ipv6 netstream timeout active
ipv6 netstream timeout inactive
ipv6 option source-route enable
ipv6 pathmtu
ipv6 pathmtu age
ipv6 pim
ipv6 pim attack-suppression register source-ip aging-time
ipv6 pim attack-suppression register source-ip check-interval
ipv6 pim attack-suppression register source-ip enable
ipv6 pim attack-suppression register source-ip threshold
ipv6 pim bfd enable
ipv6 pim bsr-boundary
ipv6 pim dm
ipv6 pim hello-option dr-priority
ipv6 pim hello-option holdtime
ipv6 pim hello-option lan-delay
ipv6 pim hello-option neighbor-tracking
ipv6 pim hello-option override-interval
ipv6 pim holdtime join-prune
ipv6 pim join-policy
ipv6 pim log enable
ipv6 pim log suppress
ipv6 pim neighbor-policy
ipv6 pim passive
ipv6 pim require-genid
ipv6 pim sm
ipv6 pim state-refresh-capable
ipv6 pim timer graft-retry
ipv6 pim timer hello
ipv6 pim timer join-prune
ipv6 pim triggered-hello-delay
ipv6 pim-snooping enable
ipv6 pim-snooping graceful-restart join-aging-time
ipv6 pim-snooping graceful-restart neighbor-aging-time
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (system view)
ipv6 policy-based-route-log enable
ipv6 pool
ipv6 pool-group
ipv6 prefer temporary-address
ipv6 prefix
ipv6 prefix-list
ipv6 reassemble local enable
ipv6 redirects enable
ipv6 route-direct cost
ipv6 route-direct track
ipv6 router-renumber enable
ipv6 route-static
ipv6 route-static bfd
ipv6 route-static default-preference
ipv6 route-static fast-reroute auto
ipv6 route-static primary-path-detect bfd
ipv6 route-static recursive-lookup segment-routing-ipv6
ipv6 route-static vpn-instance
ipv6 rpf-route-static
ipv6 sava access-group
ipv6 sava enable
ipv6 sava import remote-route-tag
ipv6 sava log enable spoofing-packet
ipv6 sava packet-drop enable
ipv6 savnet deny
ipv6 savnet entry
ipv6 savnet log enable spoofing-packet
ipv6 savnet miig-tag
ipv6 savnet packet-drop enable
ipv6 savnet port-type
ipv6 temporary-address
ipv6 underlay enable
ipv6 unr
ipv6 unreachables enable
ipv6 urpf
ipv6 urpf strict
ipv6 virtual-address
ipv6-address
ipv6cp assign-interface-id
ipv6-pool algorithm round-robin
ipv6-usage-warning
irf auto-merge enable
irf auto-update enable
irf domain
irf link-delay
irf link-detect-time
irf mac-address
irf mac-address persistent
irf member
irf member description
irf member priority
irf member renumber
irf priority
irf-port
irf-port-configuration active
isis
isis adjacency-sid
isis affinity flex-algo
isis authentication send-only
isis authentication-mode
isis bfd adjust-cost
isis bfd adjust-cost exclude
isis bfd enable
isis bfd exclude
isis bfd session-restrict-adj
isis bfd session-restrict-adj exclude
isis bfd template
isis circuit-level
isis circuit-type p2p
isis cost
isis cost-fallback
isis dis-name
isis dis-priority
isis enable
isis fast-reroute lfa-backup exclude
isis fast-reroute remote-lfa disable
isis fast-reroute ti-lfa disable
isis ipv6 bfd adjust-cost
isis ipv6 bfd adjust-cost exclude
isis ipv6 bfd enable
isis ipv6 bfd exclude
isis ipv6 bfd session-restrict-adj
isis ipv6 bfd session-restrict-adj exclude
isis ipv6 bfd template
isis ipv6 cost
isis ipv6 cost-fallback
isis ipv6 enable
isis ipv6 fast-reroute lfa-backup exclude
isis ipv6 fast-reroute ti-lfa disable
isis ipv6 link-tag
isis ipv6 member-port suppress-flapping
isis ipv6 member-port suppress-flapping adjust-cost
isis ipv6 metric-delay normalize interval
isis ipv6 peer suppress-flapping
isis ipv6 peer suppress-flapping adjust-cost
isis ipv6 prefix-suppression
isis ipv6 primary-path-detect bfd
isis ipv6 primary-path-detect bfd exclude
isis ipv6 savnet enable
isis ipv6 tag
isis link-delay
isis link-loss
isis link-quality adjust-cost
isis lsp-flood-control
isis member-port link-delay
isis member-port link-loss
isis member-port suppress-flapping
isis member-port suppress-flapping adjust-cost
isis mesh-group
isis metric-delay normalize interval
isis mib-binding
isis peer hold-max-cost duration
isis peer suppress-flapping
isis peer suppress-flapping adjust-cost
isis peer-ip-check
isis prefix-sid
isis prefix-suppression
isis primary-path-detect bfd
isis primary-path-detect bfd exclude
isis silent
isis small-hello
isis tag
isis te-metric flex-algo
isis timer csnp
isis timer hello
isis timer holding-multiplier
isis timer lsp
isis timer retransmit
isis troubleshooting max-number
isis-system-id
is-level
is-name
is-name map
isolate enable
isolate enable
isolate enable
isolate enable
isolate-group mapping-vpn
isolate-group name
ispf enable
ispf enable
ispf enable
ita policy
ita-policy
J
jitter threshold
job
jp-pkt-size (IPv6 PIM view)
jp-pkt-size (PIM view)
json row-timestamp enable
jumboframe enable
jumboframe enable
K
keepalive
keep-all-routes
keep-multiplier
key
key
key (HWTACACS scheme view)
key (RADIUS scheme view)
keychain
keychain-authentication all
keychain-authentication peer
keychain-authentication prefix-list
key-string
L
l2tp aging
l2tp calling-number-avp encapsulate-format version1
l2tp enable
l2tp icrq-limit
l2tp lns calling-number-avp parse-vlan-format ascii
l2tp lns-link-adjustment
l2tp sccrq-limit
l2tp session-threshold
l2tp tsa-id
l2tp tunnel-id
l2tp tunnel-id
l2tp vsrp-port
l2tp-auto-client
l2tp-group
l2tp-group
l2tp-user radius-force
l2vpn arp-dual-forward enable
l2vpn bandwidth-based-sharing
l2vpn enable
l2vpn enable
l2vpn enable
l2vpn fast-forwarding srv6 virtual-ethernet
l2vpn ignore-ac-state
l2vpn log enable
l2vpn nd-dual-forward enable
l2vpn statistics interval
l2vpn switchover
l2vpn switchover
l2vpn-l3vpn enhance-mode enable
l3-vni
label-allocation-mode
label-distribution
labeled-route ignore-no-tunnel
lacp default-selected-port disable
lacp edge-port
lacp mode
lacp period short
lacp system-mac
lacp system-mac
lacp system-number
lacp system-number
lacp system-priority
last-listener-query-count (MLD view)
last-listener-query-interval (MLD view)
last-listener-query-interval (MLD-snooping view)
last-member-query-count (IGMP view)
last-member-query-interval (IGMP view)
lcd
ldap attribute-map
ldap scheme
ldap server
learning mode
limit
line
line class
link-aggregation bfd
link-aggregation bfd-compatible enable
link-aggregation global load-sharing algorithm
link-aggregation global load-sharing mode
link-aggregation ignore speed
link-aggregation ignore vlan
link-aggregation lacp isolate
link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mode local-first
link-aggregation mode
link-aggregation port-priority
link-aggregation primary-port
link-aggregation reversion delay
link-aggregation secondary-down
link-aggregation selected-port maximum
link-aggregation selected-port minimum
link-aggregation selected-port minimum percentage
link-aggregation switchover
link-bundle-interface
link-delay
link-delay
link-delay
link-flap protect enable
link-management periodic-flooding timer
link-quality crc-error bit-error-ratio
link-quality hardware-error enable
link-tag inherit enable
listening port
listen-port
lldp admin-status
lldp check-change-interval
lldp compliance admin-status cdp
lldp compliance cdp
lldp enable
lldp encapsulation snap
lldp fast-count
lldp global enable
lldp global tlv-enable basic-tlv management-address-tlv
lldp hold-multiplier
lldp ignore-pvid-inconsistency
lldp management-address
lldp management-address-format string
lldp max-credit
lldp mode
lldp notification interface-loop enable
lldp notification med-topology-change enable
lldp notification remote-change enable
lldp notification self-loop enable
lldp source-mac vlan
lldp timer fast-interval
lldp timer notification-interval
lldp timer reinit-delay
lldp timer tx-interval
lldp tlv-enable
lns-ip
load-balance hash-fields gtp-teid enable
load-sharing user-group
load-splitting (IPv6 MRIB view)
load-splitting (MRIB view)
local-bill enable
local-bill export
local-bill export-interval
local-bill export-url
local-binding-sid
local-block
local-guest auto-delete enable
local-guest email format
local-guest email sender
local-guest email smtp-server
local-guest generate
local-guest send-email
local-mac remove all-from-me
local-proxy-arp enable
local-proxy-nd enable
local-server log change-password-prompt
local-user
local-user-export
local-user-import
local-user-name check-mode
locator
locator-sbfd enable
lock
lock
lock
lock reauthentication
lock-key
log data-group-reuse
log enable
log enable
log record-size
logfile save
logging packet-drop { count-threshold | rate-threshold } *
logging packet-drop enable
logging packet-drop interval
login-dn
login-password
logon-page bind
logout-notify
log-peer-change
log-peer-change
log-peer-change
log-peer-change
log-route-flap
longest-match (IPv6 MRIB view)
longest-match (MRIB view)
loopback
loopback
loopback-detection action
loopback-detection enable
loopback-detection enable s-vid c-vid
loopback-detection interval-time
loopback-detection priority
loop-detect
loss threshold
loss-measure alarm
loss-measure enable continual
loss-measure enable duration
ls
ls
lsa-arrival-interval
lsa-arrival-interval suppress-flapping
lsa-generation-interval
lsa-generation-interval suppress-flapping
lsdb-overflow-interval
lsdb-overflow-limit
lsp-fragments-extend
lsp-length originate
lsp-length receive
lsp-trigger
lsr-id
lsr-path
M
mac-address
mac-address
mac-address
mac-address
mac-address
mac-address (interface view)
mac-address (system view)
mac-address mac-learning enable
mac-address mac-learning priority
mac-address max-mac-count
mac-address max-mac-count enable-forwarding
mac-address notification mac-move
mac-address notification mac-move suppression (interface view)
mac-address notification mac-move suppression (system view)
mac-address source-mac-check
mac-address static
mac-address timer
mac-advertising disable
mac-ip dynamic-mac aware
mac-learning enable
mac-learning forbidden
mac-limit (Ethernet service instance view)
mac-limit (VSI LDP PW view, VSI static PW view, auto-discovery VSI LDP signaling view, or auto-discovery VSI BGP signaling view)
macsec cipher-suite
macsec confidentiality-offset
macsec desire
macsec include-sci
macsec mka-session log enable
macsec replay-protection enable
macsec replay-protection window-size
macsec validation mode
mac-table limit (VSI view)
mac-table limit drop-unknown
mac-withdraw propagate
mad bfd dedicated
mad bfd enable
mad enable
mad exclude interface
mad ip address
mad restore
mailbox
maintenance-probe enable
management-port isolate enable
mandatory-chap
mandatory-lcp
map
mapping vni
master-server switch-delay
match
match
maxage-lsa route-calculate-delay
max-failure
maxhops
maximum load-balancing
maximum-sid-depth
max-response-time (IGMP view)
max-response-time (MLD view)
max-response-time (MLD-snooping view)
md5-authentication all
md5-authentication peer-lsr-id
md5-authentication prefix-list
md5sum
measure count
measure enable
measure enable
measure enable (analyzer instance view)
measure mode
memory-threshold
memory-threshold usage
memory-threshold usage resend-interval
metric
metric weights
metric-type
metric-type
mget
mirror remote-sid delete-delay
mirroring-group
mirroring-group car (interface view)
mirroring-group car (system view)
mirroring-group mirroring-cpu
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-egress
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
mirroring-group reflector-port
mirroring-group remote-probe vlan
mirror-to cpu
mirror-to interface
mirror-to local
mirror-to monitoring-group
mirror-to slot
mirror-to srv6-policy
mka apply policy
mka enable
mka policy
mka priority
mka psk
mka timer mka-life
mkdir
mkdir
mkdir
mld
mld access-policy
mld attack-suppression aging-time
mld attack-suppression check-interval
mld attack-suppression enable
mld attack-suppression threshold
mld authorization-enable
mld enable
mld fast-leave
mld group-policy
mld host-tracking { disable | enable }
mld host-tracking limit
mld join-by-session
mld last-listener-query-count
mld last-listener-query-interval
mld log enable
mld log suppress
mld max-response-time
mld non-stop-routing
mld other-querier-present-timeout
mld proxy enable
mld proxy forwarding
mld query-interval
mld robust-count
mld startup-query-count
mld startup-query-interval
mld static-group
mld user-vlan-aggregation
mld version
mld vsrp-instance
mld vsrp-load-balance
mld vsrp-port
mld vsrp-sync enable
mldp p2mp
mldp p2mp
mldp recursive-fec
mld-snooping
mld-snooping done source-ip
mld-snooping drop-unknown
mld-snooping enable
mld-snooping fast-leave
mld-snooping general-query source-ip
mld-snooping group-limit
mld-snooping group-policy
mld-snooping host-aging-time
mld-snooping host-join
mld-snooping last-listener-query-interval
mld-snooping max-response-time
mld-snooping overflow-replace
mld-snooping proxy enable
mld-snooping querier
mld-snooping query-interval
mld-snooping report source-ip
mld-snooping router-aging-time
mld-snooping router-port-deny
mld-snooping special-query source-ip
mld-snooping version
mode
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage threshold
monitor disk-usage disk
monitor disk-usage interval
monitor kernel deadloop action
monitor kernel deadloop enable
monitor kernel deadloop exclude-thread
monitor kernel deadloop time
monitor kernel memory fragment interval
monitor kernel memory fragment ratio
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
monitor process
monitor resend cpu-usage
monitor resend cpu-usage core-interval
monitor resend memory-threshold
monitor resend memory-threshold dma
monitor thread
monitoring-group
monitoring-port
monitor-link disable
monitor-link group
more
mount
move
mp
mpls bandwidth-based-sharing
mpls bfd (for LSP)
mpls bfd (for TE tunnel)
mpls bfd backup detect-multiplier
mpls bfd backup min-receive-interval
mpls bfd backup min-transmit-interval
mpls bfd detect-multiplier
mpls bfd enable
mpls bfd min-receive-interval
mpls bfd min-transmit-interval
mpls bfd passive enable
mpls bfd trigger tunnel-down
mpls bfd trigger tunnel-down enable
mpls enable
mpls entropy-label-capability enable
mpls forwarding split-horizon
mpls l3vpn fragment enable
mpls label advertise
mpls label range
mpls label-usage threshold-alarm percent
mpls ldp
mpls ldp enable
mpls ldp igp sync disable
mpls ldp ipv6 enable
mpls ldp local-lsr-id
mpls ldp sync (IS-IS view)
mpls ldp sync (OSPF view/OSPF area view)
mpls ldp timer
mpls ldp transport-address
mpls load-sharing mode
mpls lsr-id
mpls max-label
mpls mldp p2mp disable
mpls mtu
mpls periodic-tracert (for LSP)
mpls per-vrf-label range
mpls sbfd (for LSP)
mpls sbfd (for TE tunnel)
mpls sbfd flex-algo-lsp
mpls statistics
mpls statistics interval
mpls te
mpls te affinity-attribute
mpls te auto-bandwidth
mpls te auto-tunnel backup disable
mpls te backup
mpls te backup affinity-attribute
mpls te backup bandwidth
mpls te backup hop-limit
mpls te backup-path
mpls te bandwidth
mpls te bandwidth change thresholds
mpls te bfd detect-multiplier
mpls te bfd enable pce-initiated-lsp
mpls te bfd min-receive-interval
mpls te bfd min-transmit-interval
mpls te binding-sid
mpls te bit-error-detection threshold
mpls te delegation
mpls te detour
mpls te enable
mpls te enable (interface view)
mpls te enable (IS-IS view)
mpls te enable (OSPF area view)
mpls te fast-reroute
mpls te fast-reroute bypass-tunnel
mpls te forced-forwarding
mpls te hop-limit
mpls te igp advertise
mpls te igp metric
mpls te igp shortcut
mpls te link-attribute
mpls te load-share
mpls te loop-detection
mpls te lsp-tp outbound
mpls te max-link-bandwidth
mpls te max-reservable-bandwidth
mpls te max-reservable-bandwidth mam
mpls te metric
mpls te passive-delegate report-only
mpls te path
mpls te path verification
mpls te path-metric-type
mpls te path-selection adjacency-sid
mpls te priority
mpls te record-route
mpls te reoptimization (tunnel interface view)
mpls te reoptimization (user view)
mpls te reserved-for-binding
mpls te resv-style
mpls te retry
mpls te route-pinning
mpls te service-class
mpls te signaled-name
mpls te signaling
mpls te srlg
mpls te stateful-pce
mpls te static-cr-lsp
mpls te static-sr-mpls
mpls te statistics
mpls te statistics service-class interval
mpls te timer retry
mpls te tunnel-attribute prefer
mpls te tunnel-bfd detect-multiplier
mpls te tunnel-bfd enable
mpls te tunnel-bfd min-receive-interval
mpls te tunnel-bfd min-transmit-interval
mpls ttl expiration enable
mpls ttl propagate
mpls tunnel-bfd (for LSP)
mpls tunnel-bfd (for TE tunnel)
mpls tunnel-bfd detect-multiplier
mpls tunnel-bfd min-receive-interval
mpls tunnel-bfd min-transmit-interval
mpls tunnel-sbfd (for TE tunnel)
mpls-simulation enable
mput
mrp timer join
mrp timer leave
mrp timer leaveall
mrp timer periodic
msdp
msdp log enable
msdp log suppress
mtu
mtu
mtu
mtu
mtu
mtu
mtu
mtu
mtu
mtu
mtu
mtu-negotiate disable
multicast boundary
multicast extranet select-rpf
multicast frr mode
multicast frr wtr
multicast routing
multicast rpf-proxy-vector compatible
multicast-suppression unknown
multicast-vlan
multicast-vpn
multicast-vpn idf-selection source-group
multicast-vpn public-instance
multi-instance enable
multi-topology
mvpn-advertise-rt-import
mvrp enable
mvrp global enable
mvrp gvrp-compliance enable
mvrp registration
N
name
name
name bit-position
nas
nas-id
nas-id bind
nas-ip (HWTACACS scheme view)
nas-ip (RADIUS scheme view)
nas-port-type
nas-port-type
nat address-group
nat address-group-usage enable
nat address-group-usage threshold
nat alg
nat dns-map
nat hairpin enable
nat hardware-mode enable
nat hardware-mode port-alloc
nat hardware-mode server-limit
nat hardware-mode user-limit
nat log enable
nat log flow-active
nat log flow-begin
nat log flow-end
nat log format user-mac
nat mapping-behavior endpoint-independent { tcp | udp } *
nat outbound
nat server
nat server-group
nat static enable
nat static inbound
nat static inbound net-to-net
nat static outbound
nat static outbound net-to-net
nbns-list
nd mac-learning disable
ne-id
ne-ip
nesting-vpn
netbios-type
netconf capability specific-namespace
netconf edit-config full-replace enable
netconf idle-timeout
netconf log
netconf soap acl
netconf soap domain
netconf soap dscp
netconf soap enable
netconf soap https ssl-server-policy
netconf ssh server enable
netconf ssh server port
network
network
network
network
network
network
network short-cut
network-clock lpuport
network-clock source forcessm
network-clock source frequency
network-clock source priority
network-clock source sa-bit
network-clock source ssm
network-clock ssmcontrol
network-clock ssm-degrade-threshold
network-clock work-mode
network-entity
network-slice (SRv6 TE policy path preference view)
network-slice (static BFD session view)
network-slice (system view)
network-slice enable
newer
nexthop
nexthop interface (BGP IPv4 SR next hop view/BGP-VPN IPv4 SR next hop view/BGP-VPN IPv4 EVPN SR next hop view)
nexthop interface (BGP IPv6 SR next hop view/BGP-VPN IPv6 SR next hop view/BGP-VPN IPv6 EVPN SR next hop view)
next-hop ip
next-hop ipv6
nexthop recursive-lookup delay
nexthop recursive-lookup longest-match
nexthop recursive-lookup restrain
nexthop recursive-lookup restrain clear-interval
nexthop recursive-lookup restrain disable
nexthop recursive-lookup tunnel-backup
next-server
nextsid
nhop-only
no-fragment enable
nqa
nqa agent enable
nqa reflector
nqa report-ftp
nqa rfc2544 group
nqa schedule
nqa server enable
nqa server icmp-server
nqa server tcp-connect
nqa server udp-echo
nqa template
nqa twamp client
nqa twamp reflector
nqa twamp sender
nqa twamp server
nqa twamp-light sender
nqa y1564 group
nssa
nssa
ntp-service acl
ntp-service authentication enable
ntp-service authentication-keyid
ntp-service broadcast-client
ntp-service broadcast-server
ntp-service dscp
ntp-service enable
ntp-service high-precision-time client enable
ntp-service high-precision-time server enable
ntp-service inbound enable
ntp-service ipv6 acl
ntp-service ipv6 dscp
ntp-service ipv6 inbound enable
ntp-service ipv6 multicast-client
ntp-service ipv6 multicast-server
ntp-service ipv6 source
ntp-service ipv6 time-server enable
ntp-service ipv6 unicast-peer
ntp-service ipv6 unicast-server
ntp-service max-dynamic-sessions
ntp-service multicast-client
ntp-service multicast-server
ntp-service noquery enable
ntp-service refclock-master
ntp-service reliable authentication-keyid
ntp-service source
ntp-service time-offset-threshold
ntp-service time-server enable
ntp-service unicast-peer
ntp-service unicast-server
O
oam enable
oam errored-frame threshold
oam errored-frame window
oam errored-frame-period threshold
oam errored-frame-period window
oam errored-frame-seconds threshold
oam errored-frame-seconds window
oam errored-symbol-period threshold
oam errored-symbol-period window
oam global errored-frame threshold
oam global errored-frame window
oam global errored-frame-period threshold
oam global errored-frame-period window
oam global errored-frame-seconds threshold
oam global errored-frame-seconds window
oam global errored-symbol-period threshold
oam global errored-symbol-period window
oam global timer hello
oam global timer keepalive
oam mode
oam remote-failure action
oam remote-loopback
oam remote-loopback interface
oam remote-loopback reject-request
oam timer hello
oam timer keepalive
object
on-demand
on-demand-group
one-way delay-measure enable
one-way delay-measure global enable
opaque-capability enable
opcode
opcode end-am
opcode end-as
open
openflow instance
openflow instance oap-instance
openflow-instance
operation (FTP operation view)
operation (HTTP/HTTPS operation view)
operator
option
option
option-group
originating-rp
ospf
ospf adjacency-sid
ospf area
ospf authentication-mode
ospf bfd adjust-cost
ospf bfd adjust-cost suppress-flapping
ospf bfd enable
ospf cost
ospf cost-fallback
ospf database-filter
ospf dr-priority
ospf fast-reroute lfa-backup
ospf fast-reroute remote-lfa disable
ospf fast-reroute ti-lfa disable
ospf link-delay
ospf link-quality adjust-cost
ospf lsu-flood-control
ospf mib-binding
ospf mtu-enable
ospf multi-area
ospf multi-area authentication-mode
ospf multi-area cost
ospf multi-area link-quality adjust-cost
ospf multi-area mtu-enable
ospf multi-area packet-size
ospf multi-area timer dead
ospf multi-area timer hello
ospf multi-area timer retransmit
ospf multi-area trans-delay
ospf network-type
ospf packet-size
ospf peer hold-max-cost duration
ospf peer suppress-flapping
ospf peer suppress-flapping hold-down
ospf peer suppress-flapping hold-max-cost
ospf prefix-sid
ospf prefix-suppression
ospf primary-path-detect bfd
ospf silent
ospf timer dead
ospf timer hello
ospf timer poll
ospf timer retransmit
ospf trans-delay
ospf troubleshooting max-number
ospf ttl-security
ospf virtual-system
ospfv3
ospfv3 affinity flex-algo
ospfv3 area
ospfv3 authentication-mode
ospfv3 bfd adjust-cost
ospfv3 bfd adjust-cost suppress-flapping
ospfv3 bfd enable
ospfv3 cost
ospfv3 cost-fallback
ospfv3 database-filter
ospfv3 dr-priority
ospfv3 fast-reroute lfa-backup exclude
ospfv3 fast-reroute ti-lfa disable
ospfv3 ipsec-profile
ospfv3 link-delay
ospfv3 link-quality adjust-cost
ospfv3 link-tag
ospfv3 mib-binding
ospfv3 mtu-ignore
ospfv3 network-type
ospfv3 peer
ospfv3 peer hold-max-cost duration
ospfv3 peer-database-filter
ospfv3 prefix-suppression
ospfv3 primary-path-detect bfd
ospfv3 silent
ospfv3 timer dead
ospfv3 timer hello
ospfv3 timer poll
ospfv3 timer retransmit
ospfv3 trans-delay
ospfv3 virtual-system
other-querier-present-interval (IGMP view)
other-querier-present-timeout (MLD view)
out interface
out-group
output-delay
output-delay
overflow-replace (MLD-snooping view)
overload adjust-cost
P
packet-capture interface
packet-capture local interface
packet-capture read
packet-capture remote interface
packet-capture stop
packet-filter
packet-filter default deny
packet-filter default hardware-count
packet-filter global
packet-follow care
packet-follow counting
packet-follow receive interface
packet-follow receive match-rule
packet-follow receive match-rule acl
packet-follow send match-rule
packet-follow send match-rule acl
parity-error consistency-check log enable
parity-error consistency-check threshold
parity-error monitor log enable
parity-error monitor period
parity-error monitor threshold
parity-error unrecoverable log enable
parity-error unrecoverable period
parity-error unrecoverable reboot
parity-error unrecoverable threshold
passive
password
password (device management user view)
password (network access user view)
password-control { aging | composition | history | length } enable
password-control aging
password-control alert-before-expire
password-control blacklist user-info username-only
password-control change-password first-login enable
password-control change-password weak-password enable
password-control complexity
password-control composition
password-control enable
password-control expired-user-login
password-control history
password-control length
password-control login idle-time
password-control login-attempt
password-control password-blacklist
password-control per-user blacklist-limit
password-control super aging
password-control super composition
password-control super length
password-control update-interval
password-control weak-password-file activate
password-control weak-password-file deactivate
password-recovery enable
passwords
path exclude overload-node
path verification
path verification enable
path-metric-type
path-mtu
path-mtu reserved
path-mtu-discovery enable
pce address
pce capability segment-routing
pce capability segment-routing ipv6
pce deadtimer
pce delegation
pce keepalive
pce multi-delegate enable
pce passive-delegate report-only
pce peer delegation-priority
pce peer keychain
pce peer md5
pce peer source
pce redelegation-timeout
pce request-timeout
pce retain initiated-lsp
pce retain lsp-state
pce state-timeout
pce static
pce tolerance
pce-client
pcep (SRv6 TE ODN dynamic view)
pcep (SRv6 TE policy path preference dynamic view)
pcep log enable
pcep type
pd-in-use threshold
pd-monitor-mode enable
peer
peer
peer
peer
peer
peer
peer
peer (VSI auto-discovery LDP view or VSI auto-discovery BGP view)
peer (VSI LDP view or VSI static view)
peer additional-paths
peer advertise additional-paths best
peer advertise encap-type mpls
peer advertise encap-type srv6
peer advertise evpn mac-route detail-only
peer advertise original-route
peer advertise origin-as-validation
peer advertise user-group-id
peer advertise-community
peer advertise-ext-community
peer advertise-large-community
peer advertisement-interval
peer advertise-policy exist-policy
peer advertise-policy non-exist-policy
peer aigp
peer aigp send med
peer allow-as-loop
peer as-number (for a BGP peer group)
peer as-number (for a BGP peer)
peer as-path-acl
peer auto-discovery
peer bandwidth
peer bfd
peer bfd parameters
peer bmp server
peer capability bier
peer capability-advertise conventional
peer capability-advertise extended-message
peer capability-advertise orf non-standard
peer capability-advertise orf prefix-list
peer capability-advertise orf vpn-prefix
peer capability-advertise route-refresh
peer capability-advertise suppress-4-byte-as
peer cluster-id
peer connect-interface
peer default-route-advertise
peer default-route-advertise (BGP VPNv4 address family view)
peer default-route-advertise (BGP VPNv6 address family view)
peer description
peer description
peer designate-router
peer dscp
peer ebgp-max-hop
peer ebgp-nexthop-check ignore
peer egress-engineering
peer egress-engineering srv6
peer enable
peer fake-as
peer filter-policy
peer flap-dampen
peer graceful-restart timer restart extra
peer group
peer high-priority
peer ignore
peer ignore-first-as
peer ignore-originatorid
peer ipsec-profile
peer keep-all-routes
peer keychain
peer label-route-capability
peer local-graceful-restart enable
peer local-graceful-restart timer restart
peer local-graceful-restart timer wait-for-rib
peer log-change
peer low-memory-exempt
peer macip-route-limit
peer mesh-group
peer minimum-ttl
peer mpls-local-ifnet disable
peer mvpn-ipv6-rt-compatible
peer mvpn-rt-import
peer next-hop-invariable
peer next-hop-invariable (BGP VPNv4 address family view)
peer next-hop-invariable (BGP VPNv6 address family view)
peer next-hop-local
peer nexthop-recursive-policy disable
peer next-hop-vpn
peer next-hop-vpn
peer password
peer password
peer path-mtu-discovery enable
peer peer-set
peer peer-set
peer preferred-value
peer prefix-list
peer prefix-list
peer prefix-sid
peer prefix-sid
peer public-as-only
peer redirect ip rfc-compatible
peer redirect rt rfc-compatible
peer redirect-nexthop
peer reflect-client
peer reflect-client
peer reflect-nearby-group
peer re-originated
peer re-originated (BGP EVPN address family view)
peer re-originated (BGP VPNv4/VPNv6 address family view)
peer re-originated mac
peer request-sa-enable
peer route-limit
peer route-mode
peer route-policy
peer router-mac-local
peer route-server-client
peer route-update-interval
peer sa-cache-maximum
peer sa-policy
peer sa-request-policy
peer signaling
peer signaling
peer soo
peer source-address
peer srv6-endr-type
peer srv6-vpn compatible
peer substitute-as
peer suppress original-route
peer suppress re-originated
peer tcp-mss
peer timer
peer timer connect-retry
peer tracking
peer ttl-security
peer upe (BGP VPNv4 address family view)
peer upe (BGP VPNv6 address family view)
peer upe route-policy (BGP VPNv4 address family view)
peer upe route-policy (BGP VPNv6 address family view)
peer validation-disable
peer validation-redirect-disable
peer virtual-link
peer virtual-link link-delay
peer virtual-link te link administrative group
peer virtual-link te metric
peer virtual-link te srlg
peer virtual-link twamp-light test-session
peer vpn-orf ignore
peer-id
performance-management
performance-test enable
period
period
permit interface
permit vlan
permit vpn-instance
permit-port-type member-port
phone
pic
pic
pic
pic
pim
pim bfd enable
pim bsr-boundary
pim dm
pim join-policy
pim log enable
pim log suppress
pim neighbor-policy
pim passive
pim require-genid
pim sm
pim timer hello
pim-snooping enable
ping
ping { evpn | static } vpws srv6
ping bier
ping evpn vpls srv6
ping evpn vpws
ping evpn vsi
ping ipv6
ping ipv6-sid
ping mpls ipv4
ping mpls out-labels
ping mpls pw
ping mpls sr-policy
ping mpls te
ping srv6-te policy
pir-test enable
pki-domain (SSL client policy view)
pki-domain (SSL server policy view)
placement program
placement reoptimize
policy
policy
policy
policy color end-point
policy vpn-target
policy vpn-target
policy vpn-target
policy vpn-target
policy vpn-target
policy vpn-target
policy vpn-target
policy-based-route
policy-group
policy-group
pool
pool
port
port
port
port
port
port (MAC binding server view)
port (portal authentication server view)
port access vlan
port fec mode
port fec mode
port group interface
port hybrid pvid
port hybrid vlan
port ifmonitor crc-error
port ifmonitor crc-error bit-error-ratio
port ifmonitor giant
port ifmonitor input-buffer-drop
port ifmonitor input-error
port ifmonitor input-usage
port ifmonitor output-buffer-drop
port ifmonitor output-error
port ifmonitor output-usage
port ifmonitor runt
port ifmonitor runt
port link-aggregation group
port link-flap protect enable
port link-mode
port link-mode
port link-type
port monitor-link group
port s-mlag group
port trunk permit vlan
port trunk pvid
port trust-level enable
portal { bas-ip | bas-ipv6 } (system view/interface view)
portal access-info trust
portal apply mac-trigger-server
portal local-web-server
portal mac-trigger-server
portal server
port-isolate enable
port-isolate group
port-mode
port-type
port-working-mode
power control-mode
power-off high-temp-board clear
power-off high-temp-board enable
ppp accept remote-ip-address
ppp accept remote-ipv6-address
ppp authentication chasten
ppp authentication chasten per-mac
ppp authentication-mode
ppp chap password
ppp chap user
ppp ipcp dns
ppp ipcp remote-address match
ppp keepalive datacheck
ppp keepalive fast-reply enable
ppp lcp delay
ppp magic-number-check
ppp mru-check enable
ppp pap local-user
ppp session-threshold
ppp timer negotiate
ppp username check
pppoe-agency authentication domain
pppoe-agency bind
pppoe-agency forward
pppoe-agency log enable
pppoe-agency reply-port
pppoe-agency-relay enable
pppoe-agency-relay-group
pppoe-server access-delay
pppoe-server access-delay odd-even mac offset
pppoe-server access-line-id bas-info
pppoe-server access-line-id circuit-id trans-format
pppoe-server access-line-id content
pppoe-server access-line-id remote-id trans-format
pppoe-server access-line-id trust
pppoe-server access-line-id vxlan-info enable
pppoe-server bind
pppoe-server block
pppoe-server connection chasten
pppoe-server connection chasten option105
pppoe-server connection chasten per-interface
pppoe-server log enable
pppoe-server nas-port-id interface
pppoe-server padi-limit (unified devices)
pppoe-server service-name-tag exact-match
pppoe-server session-limit
pppoe-server session-limit per-mac
pppoe-server session-limit per-vlan
pppoe-server session-limit total
pppoe-server tag ac-name
pppoe-server tag ppp-max-payload
pppoe-server tag service-name
pppoe-server throttle per-mac
precedence dynamic arp
prefer-cipher
preference
preference
preference
preference
preference
preference
preference
preference
preference
preferred-path
prefix
prefix-pool
prefix-priority
prefix-priority
prefix-suppression
prefix-suppression
primap color-map-dp
primap pre-defined color
primary accounting (HWTACACS scheme view)
primary accounting (RADIUS scheme view)
primary authentication (HWTACACS scheme view)
primary authentication (RADIUS scheme view)
primary authorization
priority
priority
priority 8021p
priority-flow-control inner-port
priority-flow-control inner-port no-drop
private-4-byte-as
probe count
probe duration
probe interval
probe packet-interval
probe packet-number
probe packet-timeout
probe timeout
process core
prompt
propagate mapping
protect lsp-tunnel for-all-instance
protect srv6-tunnel for-all-instance
protection dual-receive
protocol
protocol
protocol
protocol inbound
protocol lifetime
protocol nexthop recursive-lookup
protocol udp-port
protocol-number
protocol-packet filter slow
protocol-version
provider-tunnel
proxy multipath (IGMP view)
proxy multipath (MLD view)
proxy peer-sid
proxy-arp enable
proxy-arp inter-vlan enable
proxy-nd enable
proxy-nd inter-vlan enable
ptp { tod0 | tod1 }
ptp active force-state
ptp alarm-threshold { time-lock | time-unlock }
ptp alarm-threshold clock-source-class
ptp alarm-threshold time-offset
ptp alarm-threshold time-offset-sum pk-pk
ptp announce-drop enable
ptp announce-interval
ptp announce-timeout
ptp asymmetry-correction
ptp clock-source
PTP clock-state enable
ptp clock-step
ptp delay-mechanism
ptp delay-resp-interval
ptp destination-mac
ptp domain
ptp dscp
ptp enable
ptp force-state
ptp ignore sync-uncertain
ptp local-priority
ptp max-steps-removed
ptp min-delayreq-interval
ptp mode
ptp notslave disable
ptp path-trace disable
ptp pdelay-req-interval
ptp port-mode
ptp priority clock-source
ptp profile
ptp refclock-master sync-utc
ptp slave-only
ptp source
ptp sync-uncertain enable
ptp syn-interval
ptp technical-standard
ptp time-offset
ptp transport-protocol
ptp unicast-destination
ptp unicast-negotiate
ptp utc
ptp utc offset
ptp vlan
pu-monitor-mode enable
purge-time
put
put
pv-limit
pw-class
pw-class (auto-discovery cross-connect group view)
pw-class (auto-discovery VSI view)
pw-class (system view)
pwd
pwd
pwd
pw-redundancy
pw-redundancy
pwsignaling
pw-type
pw-type
python
python filename
Q
qinq enable
qinq ethernet-type (interface view)
qinq-network enable
qos apply map-table name
qos apply policy (interface view, control plane view)
qos apply policy (user profile view)
qos apply policy global
qos apply qmprofile (interface view)
qos apply qmprofile (user group profile view, session group profile view)
qos apply scheduler-policy
qos apply user-profile (interface view)
qos apply user-profile (PW view)
qos apply wred-profile
qos car (control plane view)
qos car (interface view)
qos car (system view)
qos car anti-attack
qos car any (cross-connect PW view, VSI LDP PW view, VSI static PW view)
qos car any (user profile view)
qos car inbound host rate-limit
qos car percent (interface view)
qos car whitelist enable
qos drop-profile
qos exclusive-bandwidth
qos forwarding-group
qos forwarding-profile
qos gts (interface view)
qos gts (session group profile view)
qos gts (user group profile view)
qos lr
qos lr percent
qos map-table
qos map-table color
qos map-table name
qos member-link-scheduler distribute
qos overhead layer
qos policy
qos priority
qos qmprofile
qos queue
qos queue-statistics
qos reserved-bandwidth
qos scheduler-policy
qos session-group identify
qos trust
qos user-queue
qos vlan-policy
qos weight
qos weight outbound (user profile view, user group profile view, session group profile view)
qos wred apply
qos wred queue table
qos wred-profile
queue
queue
queue (WRED profile view)
queue af
queue ef
queue length
queue wfq
queue-length
R
radius attribute extended
radius attribute-test-group
radius authentication-request first
radius dscp
radius dynamic-author proxy
radius dynamic-author server
radius nas-ip
radius offline-reason-convert user-type ppp
radius offline-reason-mapping
radius report-dual-nas-ip enable
radius scheme
radius session-control client
radius session-control enable
radius source-ip
radius stop-accounting-buffer cache
radius stop-accounting-buffer overwrite-oldest
radius stop-accounting-buffer warning-threshold
radius trap-version
radius-proxy
radius-server authen-state-check interval
radius-server test-profile
rate-limit
rate-limit dual-stack separate
raw-request
reaction checked-element { jitter-ds | jitter-sd }
reaction checked-element { owd-ds | owd-sd }
reaction checked-element icpif
reaction checked-element mos
reaction checked-element packet-loss
reaction checked-element probe-duration
reaction checked-element probe-fail (for trap)
reaction checked-element probe-fail (for trigger)
reaction checked-element rtt
reaction checked-element two-way-delay
reaction checked-element two-way-jitter
reaction checked-element two-way-loss
reaction trap
reaction trigger per-probe
reaction trigger probe-fail
reaction trigger probe-pass
reboot
record-limit
red
redirect
redirect active-time
redirect ip recursive-lookup tunnel
redirect move-temporarily enable
redirect server
redundant-power energy-saving
reflect between-clients
reflect change-path-attribute
reflector cluster-id
refresh bgp
refresh delay
refresh interval
refresh ip-flow
refresh target-configuration
refresh-period
refresh-time
reget
region-name
register-policy (IPv6 PIM view)
register-policy (PIM view)
register-suppression-timeout (IPv6 PIM view)
register-suppression-timeout (PIM view)
register-whole-checksum (IPv6 PIM view)
register-whole-checksum (PIM view)
remark account-level
remark apn-id-ipv6 instance
remark arn-id
remark customer-dot1p
remark customer-vlan-id
remark dot1p
remark drop-precedence
remark dscp
remark forwarding-class
remark imposition-mpls-exp
remark ip-precedence
remark local-precedence
remark mpls-exp
remark network-slice
remark qos-local-id
remark service-class
remark service-dot1p
remark service-id
remark service-vlan-id
remark te-class
remark tunnel-dscp
remote address
remote address dhcp client-identifier
remote end-op
remote-locator
remote-server
remote-server
remote-server algorithm
remove
rename
rename
rename
reoptimization
repeat
report-aggregation (MLD-snooping view)
reserve expired-ip enable
reserve expired-ip mode
reserve expired-ipv6-address enable
reserve expired-ipv6-address mode
reserve expired-pd enable
reserve expired-pd mode
reserved-sid-start
reset
reset aaa abnormal-offline-record
reset aaa max-online-users
reset aaa normal-offline-record
reset aaa offline-record
reset aaa online-fail-record
reset access-user offline-reason statistics
reset access-user user-detect packet-loss-ratio
reset acl counter
reset alarm active
reset ancp access-loop
reset ancp neighbor
reset ancp statistics
reset apn-id-ipv6 isolate-policy statistics
reset arp
reset arp attack-suppression per-interface
reset arp attack-suppression per-interface statistics
reset arp safe-guard statistics
reset arp snooping
reset arp source-mac
reset arp source-mac statistics
reset arp suppression vsi
reset arp suppression xconnect-group
reset arp valid-check statistics
reset bgp
reset bgp all
reset bgp bmp server
reset bgp bmp server statistics
reset bgp dampening
reset bgp dampening-log
reset bgp flap-info
reset bgp rpki server
reset bgp update-packet record
reset bgp-policy statistics
reset bier forward ipv6 statistics
reset cfd dlm history
reset cfd dm one-way history
reset cfd dm two-way history
reset cfd slm history
reset cfd synthetic-slm history
reset cfd tst
reset configuration commit
reset connection-limit statistics
reset counters interface
reset counters interface inloopback
reset counters interface loopback
reset counters interface null
reset counters interface tunnel
reset counters interface ve-l2vpn
reset counters interface ve-l3vpn
reset counters interface virtual-ppp
reset counters interface vlan-interface
reset counters interface vsi-interface
reset counters mib interface
reset counters slot
reset crc-error bit-error-ratio status interface
reset crypto-engine statistics
reset detnetoam delay-statistics
reset detnetoam timeslot-statistics
reset dhcp address offline-record
reset dhcp flood-protection
reset dhcp interface-rate-suppression
reset dhcp pool-usage peak
reset dhcp rate-limit
reset dhcp relay client-information
reset dhcp relay packet statistics
reset dhcp server conflict
reset dhcp server expired
reset dhcp server ip-in-use
reset dhcp server packet statistics
reset dhcp snooping binding
reset dhcp snooping packet statistics
reset dhcp-access packet statistics
reset dhcpv6-access packet statistics
reset dldp statistics
reset dns host
reset dot1x access-user
reset dot1x statistics
reset driver arp packet drop
reset eigrp peer
reset eigrp process
reset eigrp statistics
reset ethernet statistics
reset evpn route arp-mobility suppression
reset evpn route mac-mobility suppression
reset evpn route nd-mobility suppression
reset exception context
reset flow-monitor entry
reset flow-monitor statistics
reset flowspec statistics
reset http-redirect statistics
reset hwtacacs statistics
reset ifindex-constant map
reset ifit statistic
reset igmp attack-suppression entry
reset igmp attack-suppression statistics
reset igmp group
reset ip abnormal-packet-defend statistics
reset ip as-path
reset ip fast-forwarding cache
reset ip icmp fast-reply statistics
reset ip netstream statistics
reset ip option source-route statistics
reset ip policy-based-route statistics
reset ip prefix-list
reset ip routing-table record
reset ip routing-table statistics protocol
reset ip statistics
reset ip subscriber abnormal-logout
reset ip subscriber chasten user auth-failed
reset ip subscriber chasten user quiet
reset ip subscriber http-defense destination-ip
reset ip subscriber roam-record
reset ip subscriber unclassified-ip-defense
reset ip urpf discard statistics
reset ipsec history-error
reset ipsec sa
reset ipsec statistics
reset ipv6 dhcp { address | locator | prefix } offline-record
reset ipv6 dhcp client statistics
reset ipv6 dhcp flood-protection
reset ipv6 dhcp interface-rate-suppression
reset ipv6 dhcp pool-usage peak
reset ipv6 dhcp rate-limit
reset ipv6 dhcp relay client-information address
reset ipv6 dhcp relay client-information pd
reset ipv6 dhcp relay client-information srv6-locator
reset ipv6 dhcp relay packet statistics
reset ipv6 dhcp server conflict
reset ipv6 dhcp server expired-ip
reset ipv6 dhcp server expired-pd
reset ipv6 dhcp server ip-in-use
reset ipv6 dhcp server packet statistics
reset ipv6 dhcp server pd-in-use
reset ipv6 dhcp server srv6-locator-in-use
reset ipv6 dhcp snooping binding
reset ipv6 dhcp snooping packet statistics
reset ipv6 fast-forwarding cache
reset ipv6 icmpv6 fast-reply statistics
reset ipv6 multicast fast-forwarding cache
reset ipv6 multicast forwarding event
reset ipv6 multicast forwarding-table
reset ipv6 multicast routing-table
reset ipv6 multicast-vlan group
reset ipv6 nd attack-suppression per-interface
reset ipv6 nd attack-suppression per-interface statistics
reset ipv6 nd source-mac
reset ipv6 nd source-mac statistics
reset ipv6 nd suppression vsi
reset ipv6 neighbors
reset ipv6 netstream statistics
reset ipv6 option source-route statistics
reset ipv6 pathmtu
reset ipv6 pim attack-suppression entry register source-ip
reset ipv6 pim attack-suppression statistics register source-ip
reset ipv6 pim-snooping statistics
reset ipv6 policy-based-route statistics
reset ipv6 prefix-list
reset ipv6 rib nib record
reset ipv6 router-renumber statistics
reset ipv6 routing-table record
reset ipv6 routing-table statistics protocol
reset ipv6 sava packet-drop statistics
reset ipv6 savnet packet-drop statistics
reset ipv6 statistics
reset ipv6 tcp anti-syn-flood flow-based entry
reset ipv6 tcp anti-syn-flood flow-based statistics
reset ipv6 udp anti-flood flow-based entry
reset ipv6 udp anti-flood flow-based statistics
reset ipv6 urpf discard statistics
reset isis all
reset isis event-log
reset isis event-log graceful-restart
reset isis event-log lsp
reset isis event-log non-stop-routing
reset isis event-log route-record
reset isis event-log spf
reset isis event-log updated-lsp
reset isis packet
reset isis peer
reset isis troubleshooting
reset kernel deadloop
reset kernel exception
reset kernel reboot
reset kernel starvation
reset l2tp aging
reset l2tp control-packet statistics
reset l2tp packet-limit statistics
reset l2tp statistics
reset l2tp tunnel
reset l2vpn mac-address
reset l2vpn statistics ac
reset l2vpn statistics pw
reset l2vpn statistics srv6-pw
reset l2vpn statistics tunnel
reset l2vpn statistics vsi
reset lacp statistics
reset link-state-change statistics interface
reset lldp statistics
reset logbuffer
reset max-user history
reset mka session
reset mka statistics
reset mld attack-suppression entry
reset mld attack-suppression statistics
reset mld group
reset mld-snooping group
reset mld-snooping router-port
reset mld-snooping statistics
reset mpls ldp
reset mpls ldp error-packet
reset mpls statistics
reset mpls statistics tunnel-interface
reset mpls te auto-bandwidth-adjustment timers
reset mpls te pce statistics
reset msdp peer
reset msdp sa-cache
reset msdp statistics
reset multicast fast-forwarding cache
reset multicast forwarding event
reset multicast forwarding-table
reset multicast routing-table
reset multicast-vlan group
reset mvrp statistics
reset nat eim
reset nat session
reset netconf service statistics
reset netconf session statistics
reset network-clock
reset network-slice statistics
reset nqa twamp statistics
reset nqa twamp-light statistics
reset oam
reset openflow instance statistics
reset osi statistics
reset ospf event-log
reset ospf event-log hello
reset ospf process
reset ospf redistribution
reset ospf statistics
reset ospf troubleshooting
reset ospfv3 event-log
reset ospfv3 process
reset ospfv3 redistribution
reset ospfv3 statistics
reset packet-drop interface
reset packet-filter statistics
reset packet-follow statistics
reset password-control blacklist
reset password-control history-record
reset pim attack-suppression entry register source-ip
reset pim attack-suppression statistics register source-ip
reset pim-snooping statistics
reset portal ip-subscriber message statistics
reset portal mac-trigger-server packet statistics
reset portal packet statistics
reset ppp chasten blocked-user
reset ppp chasten per-mac blocked
reset ppp keepalive packet-loss-ratio
reset ppp packet statistics
reset pppoe-agency
reset pppoe-agency acl statistics
reset pppoe-agency packet statistics
reset pppoe-server
reset pppoe-server chasten per-interface
reset pppoe-server chasten user
reset pppoe-server packet statistics
reset ptp statistics
reset qos car control-plane whitelist
reset qos car name
reset qos control-plane anti-attack
reset qos policy control-plane
reset qos policy global
reset qos queue-statistics user-id
reset qos statistics l2vpn-pw
reset qos vlan-policy
reset radius dynamic-author proxy statistics
reset radius server-load statistics
reset radius statistics
reset radius-proxy statistics
reset radius-proxy user
reset recycle-bin
reset rib nib record
reset rip process
reset rip statistics
reset ripng process
reset ripng statistics
reset rsvp
reset rsvp authentication
reset rsvp statistics
reset saved-configuration
reset scheduler logfile
reset segment-routing ipv6 te forwarding statistics
reset segment-routing te forwarding statistics
reset session relation-table
reset session statistics
reset session statistics multicast
reset session table
reset session table ipv4
reset session table ipv6
reset session table multicast
reset session table multicast ipv4
reset session table multicast ipv6
reset snmp-agent trapbuffer
reset srpm delay-statistics
reset stop-accounting-buffer (for HWTACACS)
reset stop-accounting-buffer (for RADIUS)
reset stp
reset s-trunk packet-statistics
reset target-configuration
reset tcp anti-syn-flood flow-based entry
reset tcp anti-syn-flood flow-based statistics
reset tcp anti-syn-flood interface-based entry
reset tcp anti-syn-flood interface-based statistics
reset tcp statistics
reset tcp trace cache
reset traffic-statistics vpn-instance
reset transceiver interface
reset ttl-security statistics
reset udp anti-flood flow-based entry
reset udp anti-flood flow-based statistics
reset udp anti-flood interface-based entry
reset udp anti-flood interface-based statistics
reset udp statistics
reset udp-helper statistics
reset userlog flow export
reset user-profile interface
reset version-update-record
reset vrrp ipv6 statistics
reset vrrp statistics
resolve-target
resolve-type
resource-monitor minor resend enable
resource-monitor output
resource-monitor resource
response-pending-limit
response-time
restart
restful http enable
restful https enable
restful https ssl-server-policy
restore factory-default
restore startup-configuration
restrain
restrain
restrain
restrict
retain local-label
retry
retry realtime-accounting
retry stop-accounting (HWTACACS scheme view)
retry stop-accounting (RADIUS scheme view)
return
reverse-binding-sid
revertive
revertive
revertive wtr
revertive wtr
revision-level
rewrite inbound tag
rewrite inbound tag
rewrite inbound tag
rewrite outbound tag
rfc1583 compatible
rhelp
rib
rip
rip authentication-mode
rip bfd
rip default-route
rip enable
rip input
rip max-packet-length
rip metricin
rip metricout
rip mib-binding
rip output
rip output-delay
rip poison-reverse
rip primary-path-detect bfd
rip split-horizon
rip summary-address
rip version
ripng
ripng default-route
ripng enable
ripng ipsec-profile
ripng metricin
ripng metricout
ripng output-delay
ripng poison-reverse
ripng primary-path-detect bfd echo
ripng split-horizon
ripng summary-address
rmdir
rmdir
rmdir
rmon alarm
rmon event
rmon history
rmon prialarm
rmon statistics
robust-count (IGMP view)
robust-count (MLD view)
role
role command-rule-group
role default-role enable
role feature-group
role root
root-ip
root-vlan
route match-destination
route match-source
route validation-mode include-as
route-aggregation different-mac-address enable
route-direct cost
route-direct track
route-distinguisher
route-distinguisher
route-distinguisher
route-distinguisher
route-distinguisher
route-distinguisher (VPN instance view)
route-limit
route-log enable
route-log enable
route-mode adj-rib-in
route-mode adj-rib-out
route-mode loc-rib
route-option bypass-route
route-policy
route-policy non-exist-deny
route-policy prefix-protocol-check
route-policy-change delay-time
router id
router id
router-aging-time (MLD-snooping view)
route-rate-limit
route-replicate (public instance IPv4 address family view)
route-replicate (public instance IPv6 address family view)
route-replicate (VPN instance IPv4 address family view)
route-replicate (VPN instance IPv6 address family view)
route-replicate enable
router-id
router-id
router-id
router-id (BGP instance view)
router-id (BGP-VPN instance view)
router-id filter
router-id filter
route-select delay
route-tag (OSPF view)
route-tag (OSPFv3 view)
route-tag-check enable
routing-table bgp-rib-only
routing-table limit
routing-table limit
routing-table limit
rpf proxy vector
rpf-frr enable
rpf-frr enable
rpki
rpki-limit
rr-filter
rr-filter
rr-filter
rr-filter (BGP VPNv4 address family view)
rr-filter (BGP VPNv6 address family view)
rstatus
rsvp
rsvp authentication challenge
rsvp authentication key
rsvp authentication lifetime
rsvp authentication window-size
rsvp bfd enable
rsvp enable
rsvp hello enable
rsvp reduction retransmit increment
rsvp reduction retransmit interval
rsvp reduction srefresh
rtm cli-policy
rtm environment
rtm event syslog buffer-size
rtm scheduler suspend
rtm tcl-policy
rule (command rule group view)
rule (IPv4 advanced ACL view)
rule (IPv4 basic ACL view)
rule (IPv6 advanced ACL view)
rule (IPv6 basic ACL view)
rule (Layer 2 ACL view)
rule (user role view)
rule comment
running-time
S
sa hex-key authentication
sa hex-key encryption
sa spi
sa string-key
sample interval
sampler
save
save current-configuration interval
savnet allowlist enable
savnet allowlist route-policy
savnet denylist enable
savnet denylist route-policy
savnet enable
savnet enable
savnet validation-as
savnet-entry expire-time
sbfd
sbfd
sbfd detect-multiplier
sbfd enable
sbfd min-receive-interval
sbfd min-transmit-interval
scheduler job
scheduler logfile size
scheduler reboot at
scheduler reboot delay
scheduler schedule
scheduler-unit
scp
scp ipv6
scp ipv6 suite-b
scp server enable
scp suite-b
screen-length
screen-length disable
search-base-dn
search-scope
secondary accounting (HWTACACS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (HWTACACS scheme view)
secondary authentication (RADIUS scheme view)
secondary authorization
secondary-web-server { ip | ipv6 }
security-enhanced level
security-level
security-logfile save
segment-list
segment-list
segment-routing
segment-routing adjacency enable
segment-routing adjacency-sid delete-delay
segment-routing global-block
segment-routing ipv6 (system view)
segment-routing ipv6 admin-tag
segment-routing ipv6 apply-sid all-nexthop (BGP IPv4/IPv6 address family view)
segment-routing ipv6 apply-sid all-nexthop (BGP-VPN IPv4/IPv6 address family view)
segment-routing ipv6 apply-sid compress (BGP IPv4/IPv6 address family view/BGP-VPN IPv4/IPv6 address family view)
segment-routing ipv6 apply-sid compress (cross-connect view, EVPN instance view, and VSI EVPN instance view)
segment-routing ipv6 apply-sid specify-nexthop (BGP IPv4/IPv6 address family view)
segment-routing ipv6 apply-sid specify-nexthop (BGP-VPN IPv4/IPv6 address family view)
segment-routing ipv6 best-effort
segment-routing ipv6 compatible locator-fixed-length
segment-routing ipv6 egress-engineering locator
segment-routing ipv6 end-x delete-delay
segment-routing ipv6 locator
segment-routing ipv6 locator (cross-connect view/EVPN instance view/VSI EVPN instance view)
segment-routing ipv6 locator (IS-IS IPv6 address family view)
segment-routing ipv6 locator (OSPFv3 process view)
segment-routing ipv6 primary-path-detect sid-bfd
segment-routing ipv6 private-srv6-extensions compatible
segment-routing ipv6 sid delete-delay
segment-routing ipv6 sid-sub-tlv-type
segment-routing ipv6 traffic-engineering
segment-routing label-advertise
segment-routing lsp-trigger
segment-routing mapping-server advertise-local
segment-routing mapping-server receive
segment-routing microloop-avoidance enable
segment-routing microloop-avoidance encaps
segment-routing microloop-avoidance rib-update-delay
segment-routing microloop-avoidance strict-sid-only
segment-routing mpls
segment-routing prefix-sid-map
segment-routing sr-prefer
segments
selective-flooding mac-address
selective-provider-tunnel
selective-tunnel delay
selective-tunnel dynamic
selective-tunnel holddown
select-seq load-balance-number
send
send-lifetime
sensor path
sensor-group (subscription view)
sensor-group (telemetry view)
sensor-path-flex
server
server
server connect-interface
server enable
server ipv6-address
server password
server port
server source-address
server tcp
server vpn-instance
server-block-action
server-detect (portal authentication server view)
server-load-sharing enable
server-load-sharing mode
server-register
server-timeout
server-type
server-type (MAC binding server view)
server-verify enable
service policy
service rate-limit mode (EDSG service policy view)
service rate-limit mode (ISP domain view)
service-class
service-class
service-class
service-id
service-instance
service-instance
service-instance
service-instance-group
service-type (ISP domain view)
service-type (local user view)
service-type srv6-segment-list
session
session aging-time application
session aging-time state
session persistent acl
session protection
session relation-table match destination-ip sip enable
session resources log disable
session statistics enable
session synchronization { dns | http } *
session synchronization delay
session synchronization enable
session synchronization preempt-mode delay
session-time include-idle-time
set authentication password
set-att
set-overload
seu-error unrecoverable reboot
sfc diffserv-mode
sfc ttl-mode
sftp
sftp client ipv6 source
sftp client source
sftp ipv6
sftp ipv6 suite-b
sftp server enable
sftp server idle-timeout
sftp suite-b
sha256sum
sham-link (OSPF area view)
sham-link (OSPFv3 area view)
shell
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown (cross-connect group view)
shutdown (MSDP view)
shutdown all-physical-interfaces
shutdown process
shutdown process
shutdown process
shutdown process
shutdown-interval
sid-algorithm
sid-limit
signaling-protocol
silent-interface
silent-interface
silent-interface
simulate snmp-trap
simulate syslog
sip-server
site
site
sleep instance
slice-encapsulation ipv6-source
slice-id { data-plane | flex-channel }
slice-id-reserved bit
slice-prefix
slot-monitor packet-drop
slot-user-warning-threshold
sma-anti-spoof ipv6 address-domain
sma-anti-spoof ipv6 enable
sma-anti-spoof ipv6 filter enable
sma-anti-spoof ipv6 port-type
sma-anti-spoof ipv6 server
sma-anti-spoof ipv6 sub-alliance
snmp context-name
snmp context-name
snmp context-name
snmp context-name
snmp trap rate-limit
snmp-agent
snmp-agent { inform | trap } source
snmp-agent acl
snmp-agent blacklist ip-block enable
snmp-agent calculate-password
snmp-agent community
snmp-agent community-map
snmp-agent context
snmp-agent denylist user activate
snmp-agent denylist user authfailure
snmp-agent denylist user enable
snmp-agent denylist user timeout
snmp-agent group
snmp-agent local-engineid
snmp-agent log
snmp-agent mib-view
snmp-agent packet max-size
snmp-agent packet response dscp
snmp-agent port
snmp-agent remote
snmp-agent silence enable
snmp-agent sys-info contact
snmp-agent sys-info location
snmp-agent sys-info version
snmp-agent target-host
snmp-agent trap bgp peer-state-change extended
snmp-agent trap enable
snmp-agent trap enable aaa
snmp-agent trap enable arp
snmp-agent trap enable bgp
snmp-agent trap enable dcn
snmp-agent trap enable dhcp server
snmp-agent trap enable dhcp-client
snmp-agent trap enable domain
snmp-agent trap enable evpn
snmp-agent trap enable fib
snmp-agent trap enable ifmonitor
snmp-agent trap enable igmp
snmp-agent trap enable ip-forwarding
snmp-agent trap enable ipsec
snmp-agent trap enable ipv6 dhcp server
snmp-agent trap enable ipv6 rib
snmp-agent trap enable isis
snmp-agent trap enable l2tp
snmp-agent trap enable l2vpn
snmp-agent trap enable l3vpn
snmp-agent trap enable ldp
snmp-agent trap enable ldp-private
snmp-agent trap enable local-bill
snmp-agent trap enable mac-address
snmp-agent trap enable mld
snmp-agent trap enable mld-snooping
snmp-agent trap enable mpls
snmp-agent trap enable mpls-private
snmp-agent trap enable mrib
snmp-agent trap enable mrib6
snmp-agent trap enable msdp
snmp-agent trap enable nat
snmp-agent trap enable nd
snmp-agent trap enable netconf
snmp-agent trap enable ospf
snmp-agent trap enable ospfv3
snmp-agent trap enable password-control
snmp-agent trap enable pcep-private
snmp-agent trap enable pim
snmp-agent trap enable pim6
snmp-agent trap enable ptp
snmp-agent trap enable qos
snmp-agent trap enable radius
snmp-agent trap enable rib
snmp-agent trap enable session resources
snmp-agent trap enable slot-monitor
snmp-agent trap enable slot-user-warning-threshold
snmp-agent trap enable sr-policy
snmp-agent trap enable srv6
snmp-agent trap enable srv6-policy
snmp-agent trap enable stp
snmp-agent trap enable syslog
snmp-agent trap enable tcp
snmp-agent trap enable te
snmp-agent trap enable te-private
snmp-agent trap enable user-group
snmp-agent trap enable user-warning-threshold
snmp-agent trap enable vrrp
snmp-agent trap enable vsrp
snmp-agent trap format
snmp-agent trap if-mib link extended
snmp-agent trap isis adjacency-state-change extended
snmp-agent trap life
snmp-agent trap log
snmp-agent trap ospf neighbor-state-change extended
snmp-agent trap periodical-interval
snmp-agent trap queue-size
snmp-agent trap withsn
snmp-agent usm-user { v1 | v2c }
snmp-agent usm-user v3
snmp-agent usm-user v3 user-role
sntp authentication enable
sntp authentication-keyid
sntp enable
sntp ipv6 unicast-server
sntp reliable authentication-keyid
sntp time-offset-threshold
sntp unicast-server
source
source
source interface
source interface (frame loss/latency/throughput/Y.1564 operation view/TWAMP Light client-session view)
source interface (ICMP echo/UDP tracert operation view)
source ip
source ipv6
source mac
source port
source-address
source-interface
source-ip
source-ip
source-lifetime (IPv6 PIM view)
source-lifetime (PIM view)
source-policy (IPv6 PIM view)
source-policy (PIM view)
sp
speed
speed
speed granularity
speed init
spf-schedule-interval
sponsor-department
sponsor-email
sponsor-full-name
spt-switch-threshold (IPv6 PIM view)
spt-switch-threshold (PIM view)
src-dt4 locator
src-dt6 locator
srpm
srpm delay-profile link-based query enable
srpm delay-profile link-based response enable
srpm destination
sr-policy backup hot-standby enable
sr-policy bfd first-fail-timer
sr-policy bfd trigger path-down enable
sr-policy log enable
sr-policy sbfd enable
sr-policy sbfd timer
sr-policy steering
sr-policy steering
sr-policy switch-delay delete-delay
sr-policy up-delay
sr-te frr enable
srv6 compress enable (IS-IS IPv6 address family view)
srv6 compress enable (OSPFv3 view)
srv6 compress enable (SRv6 view)
srv6-inter-as balance
srv6-inter-as enable
srv6-locator-pool
srv6-mpls-interworking enable
srv6-policy alarm-threshold
srv6-policy autoroute enable
srv6-policy backup hot-standby enable
srv6-policy bfd echo
srv6-policy bfd first-fail-timer
srv6-policy bfd no-bypass
srv6-policy bfd trigger path-down enable
srv6-policy calc-schedule-interval
srv6-policy color priority
srv6-policy drop-upon-invalid enable
srv6-policy encapsulation-mode
srv6-policy encapsulation-mode encaps include local-end.x
srv6-policy encapsulation-mode insert include local-end.x
srv6-policy forward no-bypass
srv6-policy forwarding statistics enable
srv6-policy forwarding statistics interval
srv6-policy ifit delay-measure enable
srv6-policy ifit interval
srv6-policy ifit loss-measure enable
srv6-policy ifit measure mode
srv6-policy immediate-reoptimization
srv6-policy locator
srv6-policy log enable
srv6-policy path verification enable
srv6-policy pce delegation enable
srv6-policy pce passive-delegate report-only enable
srv6-policy reoptimization
srv6-policy sbfd
srv6-policy suppress-flapping
srv6-policy suppress-flapping disable
srv6-policy switch-delay delete-delay
srv6-policy up-delay
srv6-pw-type
ssh client ipv6 source
ssh client source
ssh server acl
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
ssh server dscp
ssh server enable
ssh server ipv6 acl
ssh server ipv6 dscp
ssh server login-failed threshold-alarm
ssh server pki-domain
ssh server port
ssh server rekey-interval
ssh server whitelist aging-time
ssh server whitelist enable
ssh user
ssh2
ssh2 algorithm cipher
ssh2 algorithm key-exchange
ssh2 algorithm mac
ssh2 algorithm public-key
ssh2 ipv6
ssh2 ipv6 suite-b
ssh2 suite-b
ssl client-policy
ssl client-policy
ssl client-policy
ssl renegotiation disable
ssl server-policy
ssl version disable
ssl-client-policy
ssm-mapping (IGMP view)
ssm-mapping (MLD view)
ssm-policy (IPv6 PIM view)
ssm-policy (PIM view)
start (frame loss/latency/throughput/Y.1564 operation view/Y.1564 operation group view/RFC2544 operation group view)
start (TWAMP Light sender view)
start (TWAMP sender view)
startup saved-configuration
startup-query-count (IGMP view)
startup-query-count (MLD view)
startup-query-interval (IGMP view)
startup-query-interval (MLD view)
state (ISP domain view)
state (local user view)
state block time-range name
state primary
state secondary
state-refresh-hoplimit (IPv6 PIM view)
state-refresh-interval (IPv6 PIM view)
state-refresh-interval (PIM view)
state-refresh-rate-limit (IPv6 PIM view)
state-refresh-rate-limit (PIM view)
state-refresh-ttl (PIM view)
static-bind
static-bind
static-cr-lsp egress
static-cr-lsp ingress
static-cr-lsp transit
static-lsp egress
static-lsp ingress
static-lsp transit
static-rp (IPv6 PIM view)
static-rp (PIM view)
static-rpf-peer
static-sr-mpls adjacency
static-sr-mpls lsp
static-sr-mpls prefix
static-srv6 local-service-id remote-service-id
static-user interface-list
statistics enable
statistics enable
statistics enable
statistics enable (APN isolation policy view)
statistics enable (auto-discovery VSI LDP signaling PW view or auto-discovery VSI BGP signaling PW view)
statistics enable (cross-connect PW view)
statistics enable (Ethernet service instance view)
statistics enable (tunnel interface view)
statistics enable (VSI LDP PW view/VSI static PW view)
statistics enable (VSI view)
statistics hold-time
statistics interval
statistics interval
statistics interval
statistics interval (APN isolation policy view)
statistics l3-packet enable
statistics max-group
statistics task
statistics-interval
status
step
stop (frame loss/latency/throughput/Y.1564 operation view/Y.1564 operation group view/RFC2544 operation group view)
stop (TWAMP Light sender view)
stop (TWAMP sender view)
stop-accounting ignore
stop-accounting-buffer enable (HWTACACS scheme view)
stop-accounting-buffer enable (RADIUS scheme view)
stop-accounting-packet send-force
stopbits
stp bpdu-protection
stp bridge-diameter
stp compliance
stp config-digest-snooping
stp cost
stp edged-port
stp enable
stp global config-digest-snooping
stp global enable
stp global mcheck
stp ignored vlan
stp ignore-pvid-inconsistency
stp loop-protection
stp max-hops
stp mcheck
stp mode
stp no-agreement-check
stp pathcost-standard
stp point-to-point
stp port bpdu-protection
stp port priority
stp port shutdown permanent
stp port-log
stp priority
stp pvst-bpdu-protection
stp region-configuration
stp role-restriction
stp root primary
stp root secondary
stp root-protection
stp tc-protection
stp tc-protection threshold
stp tc-restriction
stp tc-snooping
stp timer forward-delay
stp timer hello
stp timer max-age
stp timer-factor
stp transmit-limit
stp vlan enable
straight-forwarding pw-to-ac
strict-check access-interface vpn-instance
strict-sid-only enable
s-trunk
s-trunk { ip | ipv6 }
s-trunk authentication key
s-trunk authentication mode
s-trunk bfd-session
s-trunk id
s-trunk interval
s-trunk ipv6 udp-port
s-trunk maintain enable
s-trunk port-role
s-trunk revert disable
s-trunk revert-delay
s-trunk role priority
s-trunk sequence enable
s-trunk timeout multiplier
s-trunk udp-port
stub
stub
stub-router
stub-router
sub-domain
subdomain-name
subscription
subslot-working-mode
subvlan
subvlan (IPv6 multicast VLAN view)
subvlan (multicast-VLAN view)
summary
summary
summary automatic
summary automatic
super
super authentication-mode
super default role
super password
super use-login-username
supervlan
suppress intra-te link-attributes
switch-delay
switch-delay
switch-period
synce state
synchronous mode
sysname
system
system forward-mode extended
system turbo enable
T
tar create
tar extract
tar list
targeted-peer
targeted-peer
target-only
tclquit
tclsh
tcp abnormal-packet-defend
tcp anti-naptha enable
tcp anti-syn-flood flow-based check-interval
tcp anti-syn-flood flow-based duration
tcp anti-syn-flood flow-based enable
tcp anti-syn-flood flow-based threshold
tcp anti-syn-flood interface-based check-interval
tcp anti-syn-flood interface-based duration
tcp anti-syn-flood interface-based enable
tcp anti-syn-flood interface-based threshold
tcp anti-syn-flood log enable
tcp check-state interval
tcp dscp
tcp log enable
tcp modify-mss
tcp mss
tcp path-mtu-discovery
tcp port
tcp state
tcp syn-cookie enable
tcp timer fin-timeout
tcp timer syn-timeout
tcp timestamps enable
tcp trace cache-mode
tcp trace enable
tcp trace filter
tcp trace max-packet-number
tcp trace memory-quota
tcp trace persist
tcp window
tcp-algorithm-id
tcp-connection backup
tcp-kind
tcp-port
te attribute enable
te attribute enable
te ipv6-router-id
te link-attribute
te max-reservable-bandwidth rdm
te metric
te srlg
technical-standard
telemetry
telnet
telnet client source
telnet ipv6
telnet server acl
telnet server acl-deny-log enable
telnet server dscp
telnet server enable
telnet server ipv6 acl
telnet server ipv6 dscp
telnet server ipv6 port
telnet server login-failed threshold-alarm
telnet server port
temperature-limit
template (APN ID instance view)
temporary address range
terminal debugging
terminal logging level
terminal monitor
terminal type
te-router-id
test-aaa
test-session (TWAMP control session view)
test-session (TWAMP Light client view)
test-session (TWAMP Light responder view)
test-session bind interface
test-session timeout
te-subtlv
tftp
tftp client ipv6 source
tftp client source
tftp ipv6
tftp-server acl
tftp-server domain-name
tftp-server ip-address
tftp-server ipv6 acl
threshold percentage
threshold remanent-volume
threshold weight
time at
time once
time repeating
time-delay
timer
timer aging
timer aging-lsp-lifetime
timer connect-retry
timer hello (IPv6 PIM view)
timer hello (PIM view)
timer join-prune (IPv6 PIM view)
timer join-prune (PIM view)
timer keepalive
timer lsp-arrival
timer lsp-flood suppress-flapping
timer lsp-generation
timer lsp-generation suppress-flapping
timer lsp-max-age
timer lsp-refresh
timer lsp-remaining-lifetime refresh
timer purge-zero-lsp route-calculate-delay
timer quiet (HWTACACS scheme view)
timer quiet (RADIUS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (HWTACACS scheme view)
timer response-timeout (RADIUS scheme view)
timer retry
timer route-calculate suppress-flapping
timer spf
timer triggered
timer triggered
time-range
timer-hold
timer-hold
timer-hold retry
timer-hold retry
timers
timers
timers active-time
timers graceful-restart purge-time
timers removal unused
timeslot
timestamp-format
tnl-policy
tos
trace access-user
trace-logfile save
trace-measure per-hop
tracert
tracert { evpn | static } vpws srv6
tracert bier
tracert evpn vpls srv6
tracert evpn vpws
tracert evpn vsi
tracert ipv6
tracert ipv6-sid
tracert mpls ipv4
tracert mpls out-labels
tracert mpls pw
tracert mpls sr-policy
tracert mpls te
tracert srv6-te policy
track
track bfd
track cfd
track failover-group
track interface
track interface physical
track interface protocol
track ip route reachability
track ipv6 route reachability
track l2vpn-network-state
track list boolean
track list threshold percentage
track list threshold weight
track nqa
track pw-state srv6
track vrrp
track vrrp ipv6
traffic backup
traffic behavior
traffic classifier
traffic statistics
traffic-engineering
traffic-engineering
traffic-policing-test enable
traffic-quota-out
traffic-separate
traffic-statistic enable
traffic-statistic include-interframe
traffic-statistics enable
traffic-statistics vpn-instance interval
transceiver auto-laser-down
transceiver auto-laser-down restart
transceiver auto-laser-down restart-mode
transceiver lane cdr
transceiver lane enable
transceiver power-mode
transform-set
transmit-network type
transmit-pacing
transmit-pacing
trust ip
trust ipv6
trust level
trust-level
trust-level-mapping enable
ttl
ttl-mode
ttl-mode
ttl-mode
ttl-security
tunnel
tunnel authentication
tunnel avp-hidden
tunnel discard ipv4-compatible-packet
tunnel global source-address
tunnel load-sharing
tunnel name
tunnel out-interface
tunnel password
tunnel route-static
tunnel source
tunnel statistics enable
tunnel statistics vxlan
tunnel statistics-mode
tunnel timer hello
tunnel tos
tunnel ttl
tunnel vpn-instance
tunnel vsrp source-ip
tunnel window receive
tunnel window send
tunnel-alarm enable
tunnel-bfd enable
tunnel-bfd min-echo-receive-interval
tunnel-number
tunnel-per-user
tunnel-policy
tunnel-policy (auto-discovery cross-connect view)
tunnel-policy (auto-discovery VSI view)
tunnel-policy (system view)
tunnel-policy-default select-seq load-balance-number
tunnel-selector
type
type
type
U
udp anti-flood flow-based check-interval
udp anti-flood flow-based destination-port
udp anti-flood flow-based duration
udp anti-flood flow-based enable
udp anti-flood flow-based exclude destination-port
udp anti-flood flow-based threshold
udp anti-flood interface-based check-interval
udp anti-flood interface-based duration
udp anti-flood interface-based enable
udp anti-flood interface-based threshold
udp anti-flood log enable
udp destination-port
udp source-port
udp-helper broadcast-map
udp-helper enable
udp-helper port
udp-helper server
umount
undelete
unicast-forwarding dx2-based
unicast-route label advertise
unicast-route recursive-lookup tunnel
unicast-suppression unknown
unknown-mac-route
unr preference
unr preference
unr tag
unr tag
update-first route-policy
update-first route-policy (BGP VPNv4 address family view)
update-first route-policy (BGP VPNv6 address family view)
update-packet record count
up-delay
up-delay
uplink up-port-threshold
url
user
user
user-address-type
user-group (system view)
user-group index
user-group-profile
user-interface
user-interface class
userlog flow export host
userlog flow export load-balancing
userlog flow export source-ip
userlog flow export timestamp localtime
userlog flow export version
userlog flow syslog
username
username-authorization apply
username-change action force-logout
user-name-format (HWTACACS scheme view)
user-name-format (RADIUS scheme view)
user-parameters
user-plane enable
user-policy interface-down online
user-profile
user-role
user-role
user-role
users-per-account
user-sync
using fiftygige
using fortygige
using hundredgige
using tengige
using twenty-fivegige
V
valid class
validate-source-address
validation mode
validation-check enable
validity-datetime (device management user view)
validity-datetime (local guest view)
vccv bfd
vccv cc
verbose
verify class
version
version
version
version
version (MLD-snooping view)
virtual-duid
virtual-system
virtual-system enable
vlan
vlan
vlan policy deny
vlan-group
vlan-list
vlan-mapping modulo
vlink-peer
vlink-peer
voice-config
vpls-id
vpn popgo
vpn prefix quota
vpn-id
vpn-id
vpn-instance
vpn-instance
vpn-instance
vpn-instance (HWTACACS scheme view)
vpn-instance (IP pool group view)
vpn-instance (IP pool view)
vpn-instance (IPv6 address pool group view)
vpn-instance (IPv6 address pool view)
vpn-instance (RADIUS scheme view)
vpn-instance match isolate-group
vpn-instance policy deny
vpn-instance-capability simple (OSPF view)
vpn-instance-capability simple (OSPFv3 view)
vpn-orf enable
vpn-route cross multipath
vpn-target
vpn-target
vpn-target
vpn-target
vpn-target
vpn-target
vrrp check-ttl enable
vrrp dot1q
vrrp dscp
vrrp ipv6 dot1q
vrrp ipv6 dscp
vrrp ipv6 isolate enable
vrrp ipv6 mode
vrrp ipv6 send-nd
vrrp ipv6 send-nd enhance enable
vrrp ipv6 state-transition-delay
vrrp ipv6 vrid
vrrp ipv6 vrid follow
vrrp ipv6 vrid ignore-interface-down
vrrp ipv6 vrid name
vrrp ipv6 vrid nd copy-to-member
vrrp ipv6 vrid preempt-mode
vrrp ipv6 vrid priority
vrrp ipv6 vrid shutdown
vrrp ipv6 vrid source-interface
vrrp ipv6 vrid timer advertise
vrrp ipv6 vrid track
vrrp isolate enable
vrrp mode
vrrp send-gratuitous-arp
vrrp send-gratuitous-arp enhance enable
vrrp state-transition-delay
vrrp version
vrrp vrid
vrrp vrid authentication-mode
vrrp vrid backup-arp
vrrp vrid checksum-standard
vrrp vrid follow
vrrp vrid gratuitous-arp copy-to-member
vrrp vrid ignore-interface-down
vrrp vrid initialize state-hold-time
vrrp vrid ipv6 initialize state-hold-time
vrrp vrid name
vrrp vrid preempt-mode
vrrp vrid priority
vrrp vrid shutdown
vrrp vrid source-interface
vrrp vrid timer advertise
vrrp vrid track
vrrp vrid vrrpv3-send-packet
vsi
vsi
vsrp instance (system view)
vsrp log enable
vsrp peer
vsrp-instance (IPv4/IPv6 address pool view)
vsrp-instance (L2TP group view)
vtep access port
vtep group member local
vtep group member remote
vxlan
vxlan invalid-vlan-tag discard
vxlan tunnel arp-learning disable
vxlan tunnel nd-learning disable
vxlan udp-port
W
wait-to-restore-period
warm-root-standby
web-server { url | ipv6-url } url
web-server url-parameter
weight
weighting-constant
wfq
work-mode analyzer
work-mode collector
X
xconnect vsi
xconnect vsi
xconnect-group
xml
Y
yellow
