08-BIER Command Reference
HomeSupportRoutersCR16000-M1A SeriesCR16000-M1A SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C CR16000-M1A Router Command Reference-R8630Pxx-6W10208-BIER Command Reference
01-BIER commands
01-BIER commands 236.22 KB
BIER commands
bfr-id
Use bfr-id to specify a BFR ID for a BIER edge device.
Use undo bfr-id to delete the BFR ID of a BIER edge device.
bfr-id bfr-id
undo bfr-id
The device does not have a BFR ID.
BIER sub-domain view
bfr-id: Specifies a BFR ID in the range of 1 to 65535.
A BFR refers to a BFIR or BFER. In a BIER sub-domain, a BFIR or BFER must have a unique BFR ID. If a BIER edge device belongs to more than one sub-domain, it can have the same or different BFR IDs in different sub-domains.
# Specify a BFR ID of 1000 for the device.
[Sysname] bier
[Sysname-bier] sub-domain 1 ipv6
[Sysname-bier-sub-domain-1-ipv6] bfr-id 1000
display bier sub-domain
bfr-neighbor
Use bfr-neighbor to specify a BFR neighbor and the BFR ID range of BIER edge devices that can be reached through the BFR neighbor.
Use undo bfr-neighbor to remove the specified BFR neighbor and BFR ID range.
bfr-neighbor { end-bier bierv6-sid | end-rgb msr6-sid | mpra ipv6-address } bfr-id bfr-id-start [ to bfr-id-end ] [ preference preference-value ]
undo bfr-neighbor { end-bier bierv6-sid | end-rgb msr6-sid | mpra ipv6-address } [ bfr-id bfr-id-start [ to bfr-id-end ] ]
No BFR neighbor and BFR ID range are specified.
end-bier bierv6-sid: Specifies a BFR neighbor by its IPv6 unicast address (End.BIER SID).
end-rgb msr6-sid: Specifies a BFR neighbor by its IPv6 unicast address (End.RGB SID).
mpra ipv6-address: Specifies a BFR neighbor by its IPv6 unicast address (MPRA).
bfr-id bfr-id-start: Specifies a single BFR ID (if you do not specify the to bfr-id-end option) or the start BFR ID of a BFR ID range (if you specify the to bfr-id-end option). The value range for the bfr-id-start argument is 1 to 65535.
to bfr-id-end: Specifies the end BFR ID of the BFR ID range, in the range of 2 to 65535.
preference preference-value: Specifies the priority of the link to reachable BFR IDs, in the range of 1 to 255. The default is 60. The smaller the priority value, the higher the priority.
Operating mechanism
In a cross-AS BIER deployment, if the ASBR in an AS does not support BIER forwarding, BIER packets cannot be forwarded among ASs. To solve this problem when the cross-AS routes are reachable, you can specify the BFR neighbor on the BFR directly connected to the ASBR and the BFR ID range of BIER edge devices that can be reached through the BFR neighbor.
In a cross-AS BIER deployment, you can configure the priorities of different links to the same BFR IDs reachable through a BFR neighbor to ensure reliable transmission of multicast traffic forwarding. The device selects the link with the highest priority to forward multicast traffic. If the link with the highest priority fails, the device quickly switch over the traffic to a low-priority link. If a large amount of multicast traffic, you can configure the same priority for different links to form ECMP links and load balances the traffic.
If all BFR IDs are removed or the undo bfr-neighbor command is executed, the corresponding BFR neighbor will be removed from the BIRT.
You can execute this command repeatedly to configure multiple BFR neighbors and multiple BFR ID ranges.
The maximum number of BFR IDs with the same priority reachable through one BFR neighbor is 4.
The configuration takes effect only on the BIRT of the local node and will not be advertised to other nodes.
The total number of BFR neighbors in all BIER sub-domains on the device cannot exceed 2000. The number of BFR IDs reachable through one BFR neighbor cannot exceed 256.
# In BIER sub-domain 1, specify 3000::1 as a BFR neighbor for G-BIER encapsulation and specify the BFR ID range as 100 to 300 and link priority as 50.
[Sysname] bier
[Sysname-bier-sub-domain-1-ipv6] bfr-neighbor mpra 3000::1 bfr-id 100 to 300 preference 50
encapsulation-type
bfr-prefix
Use bfr-prefix to specify a BFR prefix.
Use undo bfr-prefix to restore the default.
bfr-prefix interface interface-type interface-number
undo bfr-prefix
The device does not have a BFR prefix.
interface-type interface-number: Specifies an interface by its type and number. Only loopback interfaces are supported.
As an equivalent to a router ID in a routing protocol, a BFR prefix identifies a BFR in a sub-domain. In a sub-domain, a BFR must have a unique BFR prefix that is routable.
Only the IP address of a loopback interface can be configured as a BFR prefix. After the IP address of a loopback interface is configured as a BFR prefix, the loopback interface cannot be deleted.
If a BFR belongs to more than one sub-domain, it can have the same or different BFR prefixes in different sub-domains.
# Specify the IPv6 address of a loopback interface as the BFR prefix.
[Sysname] interface LoopBack 0
[Sysname-LoopBack0] ipv6 address 100::1 128
[Sysname-LoopBack0] quit
[Sysname] bier
[Sysname-bier] sub-domain 0 ipv6
[Sysname-bier-sub-domain-0-ipv6] bfr-prefix interface loopback 0
bier
Use bier to enable BIER and enter BIER view.
Use undo bier to disable BIER.
bier
undo bier
BIER is disabled.
Bit Index Explicit Replication (BIER) is a new architecture for the forwarding of multicast data packets. BIER encapsulates the destination nodes of multicast packets in a bit string. It does not require a protocol for explicitly building multicast distribution trees, nor does it require intermediate nodes to maintain any per-flow state.
BIER requires only the encapsulation of a bit string on the BEIR without requiring operating transit BFRs. BIER is applicable to quick deployment of multicast services through the controller in an SDN network.
The undo bier command will delete all settings in BIER view. Please use it with caution.
# Enable BIER and enter BIER view.
[Sysname] bier
[Sysname-bier]
bier bfr-prefix proxy
Use bier bfr-prefix proxy to enable BGP BFR prefix proxying.
Use undo bier bfr-prefix proxy to disable BGP BFR prefix proxying.
BGP BFR prefix proxying is disabled.
BGP IPv6 unicast address family view
In a cross-AS BIER deployment, the BFR ID range is used by the BIER to learn BFR IDs in another BIER domain. After being enabled with BGP BFR prefix proxying, an ASBR A node enabled with BGP BFR prefix proxying is called a BFR proxy node. An ASBR enabled with BGP BFR prefix proxying advertises cross-AS BFR ID range information. All multicast packets in an AS can be forwarded by the ASBR to other ASs. This prevents multicast traffic forwarding failures if the devices in an AS cannot generate correct forwarding entries.
Routes with local BIER information generated after the bier enable command is executed do not include BFR ID range information. Routes redistributed by using the import-bier command include BFR ID range information.
A BFR proxy node does not directly forward routes carrying BIER information learned from a BGP peer to other BGP peers and advertises them as follows:
1.     Advertises the BIER information (including BFR ID range information) in learned routes to the BIER module.
2.     The BIER module modifies the BFR prefix in the BIER information as the BFR prefix of the local node and summarizes received BFR ID range information.
3.     The BIER module advertises the modified BIER information to the BGP module. The BGP module generates a BGP route that carries the modified BIER information (including BFR ID range information) and sends it to BGP peers.
4.     After receiving the BGP route, an IBGP or EBPG peer generates cross-AS BIRT entry. The BRF prefix of the edge node is the BRF prefix of the BFR proxy node.
When a device forwards a cross-AS packet, it will encapsulate the MPRA of the BFR proxy node and sends the packet to the BFR proxy node. The BFR proxy node forwards the received packet according to the BIFT.
To avoid loops and ensure correct BIRT entries, perform this task only on one end of an EBGP session.
Before executing this command, you must execute the bier enable command.
# In the BGP IPv6 unicast address family, enable BGP BFR prefix proxying.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 unicast
[Sysname-bgp-default-ipv6] bier enable
[Sysname-bgp-default-ipv6] bier bfr-prefix proxy
bier enable
import-bier
peer capability bier
bier enable
Use bier enable to enable BIER for BGP.
Use undo bier enable to disable BIER for BGP
bier enable
undo bier enable
BIER is disabled for BGP.
Operating mechanism
In a BIER network, a node encapsulates the following BIER information in UPDATE messages:
·     BFR prefix—Encapsulated in the NLRI field.
·     BIER Path Attribute—A new attribute that contains information such as BIER sub-domain, BFR ID, BSL, and MPRA.
If BIER is enabled for BGP, BGP imports the BFR IDs and BFR prefixes from the BIER module and generates BGP routes carrying BIER information (excluding BFR ID range information).
The device generates a BGP IPv6 unicast route without BIER information and advertises the route to the BGP IPv6 unicast peers. The BGP IPv6 unicast route uses the locally configured MPRA and BFR prefix as the reachability prefix information of the NLRI field. The BGP IPv6 unicast route can guide the forwarding of BIER packets on devices that do not support BIER forwarding. If the peer capability bier command is also executed, the BGP routes generated by the local BFR prefix carry BIER path attributes can be advertised to the specified peer or peer group.
·     You must execute this command before executing the peer capability bier, bier bfr-prefix proxy, and import-bier commands.
·     To execute the undo bier enable command to disable BIER for BGP, you must first execute the undo peer capability bier, undo bier bfr-prefix proxy, and undo import-bier commands to disable the corresponding features.
# In the BGP IPv6 unicast address family, enable BIER for BGP.
[Sysname] bgp 100
bier local-prefix proxy
import-bier
display bier forward ipv6 statistics
Use display bier forward ipv6 statistics to display BIER packet statistics.
In standalone mode:
display bier forward ipv6 statistics slot slot-number
In IRF mode:
display bier forward ipv6 statistics chassis chassis-number slot slot-number
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
# Display BIER packet statistics.
<Sysname> display bier forward ipv6 statistics
BIER packet statistics:
  Entered BIER sub-domain packets :6
  Received packets: 5
  Received PHP packets: 5
  Forwarded packets: 12
  Sent to overlay packets: 3
BIER error statistics:
  Tunnel and BIFT info mismatch: 0
  Invalid BIFT encapsulation type: 0
  Invalid tunnel encapsulation type: 0
  Invalid packet encapsulation type: 0
  No memory error: 0
  Get vn error: 0
  Invalid tunnel ID: 0
  TTL value is zero: 0
  BitString non-zero: 0
  Bier head check error: 0
  Get BIFT error: 0
Number of packets that join the BIER sub-domain.
Number of packets that are processed by PHP.
Number of packets that are sent to the multicast flow overlay.
reset bier forward ipv6 statistics
display bier inter-as bfr-info
Use display bier inter-as bfr-info to display cross-AS BFR information.
display bier inter-as bfr-info [ sub-domain sub-domain-id ]
sub-domain sub-domain-id: Specifies a sub-domain by its ID in the range of 0 to 255. If you do not specify a BFR prefix, this command displays the cross-AS BFR information of all sub-domains.
The cross-AS BFR information is learned through EBGP and does not include the configuration of the bfr-neighbor mpra command.
# Display the cross-AS BFR information of sub-domain 3.
<Sysname> display bier inter-as bfr-info sub-domain 3
  Sub-domain 3
    BFR prefix: 300::1
     BFR-ID: 8
     AS number: 33
     Protocol: BGP
     Sub protocol: EBGP
     BFR ID range: 30 to 90, 100 to 105, 200 to 300
    BFR prefix: 400::1
     BFR-ID: 9
     AS number: 50
     Protocol: BGP
     Sub protocol: EBGP
     BFR ID range: 91 to 99
BFR prefix
BFR prefix of the ASBR in another domain.
BFR-ID
BFR ID of an ASBR in a neighboring domain.
AS number
Number of the AS where the BFR resides.
Protocol
Routing protocol that transfers cross-AS BFR information.
Sub protocol
Routing sub-protocol that transfers cross-AS BFR information.
BFR ID range
display bier prefix
display bier inter-as routing-table
Use display bier inter-as routing-table to display cross-AS BIRT information.
display bier inter-as routing-table [ sub-domain sub-domain-id [ bfr-id bfr-id-start [ to bfr-id-end ] ] ]
sub-domain sub-domain-id: Specifies a sub-domain by its ID in the range of 0 to 255. If you do not specify a BFR prefix, this command displays the cross-AS BIRT information of all sub-domains.
bfr-id bfr-id-start: Specifies a single BFR ID (if you do not specify the to bfr-id-end option) or the start BFR ID of a BFR ID range (if you specify the to bfr-id-end option). The value range for the bfr-id-start argument is 1 to 65535. If you do not specify BFR IDs, this command displays cross-AS BIRT information for all BFR IDs.
# Display the cross-AS BIRT information of all sub-domains.
<Sysname> display bier inter-as routing-table
  Sub-domain 0
    BFR ID: 2
      BFR prefix: 300::1
        AS: 30
        Protocol: IS-IS
        Preference: --
    BFR ID: 3
      BFR prefix: 3333::1
        AS: 40
        Protocol: EBGP
        Preference: --
      BFR prefix: 300::2
        AS: 40
        Protocol: EBGP
        Preference: --
    BFR ID: 4
      MPRA: 300::3
        AS: N/A
        Protocol: Static
        Preference: 60
BFR ID
BFR ID of the BFER.
AS
Number of AS where the BFR resides.
BFR prefix
BFR prefix of the edge node. It indicates that the BIER routing entry is dynamically learned through a routing protocol.
MPRA
MPRA of the edge node. It indicates that the BIER encapsulation type is G-BIER and the BIER routing entry is statically configured.
End.BIER SID
End.BIER SID of the edge node. It indicates that the BIER encapsulation type is BIERv6 and the BIER routing entry is statically configured.
Protocol
Preference
Link priority of the static route to BFR IDs reachable through a BFR neighbor. This field displays two hyphens (--) for a dynamic routing protocol.
display bier routing-table
display bier prefix
Use display bier prefix to display the BIER information of BFR prefixes.
display bier prefix [ prefix-ip ] [ sub-domain sub-domain-id [ bsl bsl-value ] ]
prefix-ip: Specifies a BFR prefix. If you do not specify a BFR prefix, this command displays the BIER information of all BFR prefixes.
sub-domain sub-domain-id: Specifies a sub-domain by its ID. If you do not specify a sub-domain ID, this command displays the BIER information of BFR prefixes in all sub-domain IDs.
bsl bsl-value: Specifies a BSL value. Valid values for the bsl-value argument are 64, 128, and 256.  If you do not specify a BSL value, this command displays the BIER information of BFR prefixes for all BSL values.
# Display the BIER information of all BFR prefixes.
<Sysname> display bier prefix
  Sub-domain 1
    Total BFR prefixes: 2
      BFR prefix: 100::1(LoopBack1)
        BFR ID: 4
        PHP: Disabled
        Encapsulation type: G-BIER
        Encapsulation MPRA: 200::1
        Encapsulation:
          BSL   Max-SI
          128   1
          256   0
      BFR prefix: 100::2
        BFR ID: 5
        PHP: Disabled
        Encapsulation MPRA: 300::1
        Encapsulation:
          BSL   Max-SI
          128   1
          256   0
        Inter-AS information:
          AS number  : 33
          AS number  : 40
# Display the BIER information of BFR prefix 100::1.
<Sysname> display bier prefix 100::1
  Sub-domain 0
    Total BFR prefixes: 1
        BFR ID: 4
        PHP: Disabled
        Encapsulation type: BIERv6
        Encapsulation End.BIER SID: 200::1
        Encapsulation:
          BSL   Max-SI
          128   1
          256   0
Total BFR prefixes
Total number of local BFR prefixes and remote BFR prefixes.
BFR prefix(LoopBack1)
Local BFR prefix, which is the IPv6 address of loopback interface 1.
BFR ID
This field displays 0 if no BFR ID is configured on a transit BFR.
PHP
BIER PHP enabling status:
·     Enabled.(BIER PHP cannot be enabled for the BFR in the current software version.)
·     Disabled.
Encapsulation MPRA
MPRA in G-BIER encapsulation.
End.BIER SID in BIERv6 encapsulation.
Encapsulation End.RGB SID
End.RGB SID in MSR6 encapsulation.
AS number
Number of the AS where the reachable BFRs reside.
BFR ID range
display bier protocol
Use display bier protocol to display the unicast routing protocols that registered with BIER.
# Display the unicast routing protocols that registered with BIER.
<Sysname> display bier protocol
 Protocol    Instance ID      Address family
 ISIS        -                IPv4/IPv6
Table 5 Command output
Protocol
Unicast routing protocols that registered with BIER. Only IS-IS and BGP are supported in the current software version.
Instance ID
Instance ID of the unicast routing protocol. This field is supported only for BGP. This field displays a hyphen (-) for IS-IS.
Address family
Address family supported by the unicast routing protocol.
Use display bier routing-table to display the BIER information of BFR prefixes.
display bier routing-table [ sub-domain sub-domain-id [ bsl bsl-value ] ] [ prefix prefix-ip ] [ verbose ]
sub-domain sub-domain-id: Specifies a sub-domain ID. If you do not specify a sub-domain ID, this command displays the BIRT information of all sub-domains.
bsl bsl-value: Specifies a BSL value. Valid values for the bsl-value argument are 64, 128, and 256.  If you do not specify a BSL value, this command displays the BIRT information of all BSL values.
prefix prefix-ip: Specifies a BFR prefix. If you do not specify a BFR prefix, this command displays the BIRT information of all BFR prefixes.
verbose: Displays detailed BIRT information. If you do not specify this keyword, the command displays brief BIRT information.
# Display brief BIRT information.
<Sysname> display bier routing-table
  Sub-domain 0
  Total BFERs: 2
    BFR ID: 1
    BFR prefix: 1::2(Local)
    PHP: Disabled
    Flag: Active
    BFR-conflicted nodes: N/A
    BFR neighbors: N/A
    BFR ID: 16
    BFR prefix: C::C
    PHP: Disabled
    Flag: Active
    BFR neighbors: 1
      BFR prefix: C::C
      NBRFlag:
      Next hop list:
      Out interface            Next hop                               NhFlag     Token
      XGE0/0/15                   FE80::A6FA:76FF:FEF5:E0FF                        Invalid
      XGE0/0/16                   FE80::A6FA:76FF:FEF6:E0FF                        Invalid
    BFR ID: 17
    BFR prefix: D::D
    PHP: Disabled
    Flag: Active
    BFR neighbors: 1
      BFR prefix: A::A
      NBRFlag:
      Next hop list:
      XGE0/0/17                   FE80::A6FA:76FF:FEF7:E0FF                        Invalid
      XGE0/0/18                   FE80::A6FA:76FF:FEF8:E0FF            B           Invalid
    BFR ID: 18
    BFR prefix: E::E
    PHP: Disabled
    Flag: Active
    BFR neighbors: 2
      BFR prefix: A::A
      NBRFlag:
      Next hop list:
      BFR prefix: B::B
      NBRFlag: B
      Next hop list:
      XGE0/0/19                   FE80::A6FA:76FF:FEF9:E0FF                        Invalid
# Display detailed BIRT information.
<Sysname> display bier routing-table verbose
  Sub-domain 0
  Total BFERs: 3
    BFR ID: 1
    PHP: Disabled
    Flag: Active
    Encapsulation MPRA: A::20
    Encapsulation:
      BSL  Max-SI
      64   0
      256  0
    BFR neighbors: N/A
    BFR ID: 16
    PHP:Disabled
    BFR prefix: C::C
    Flag: Active
    Encapsulation MPRA: C::20
    Encapsulation:
      BSL  Max-SI
      64   0
      256  1
    BFR neighbors: 1
      BFR prefix: C::C
      Underlay protocol: IS-IS
      Sub protocol: Level-1
      System ID: ab00.0000.0103
      Multi-topology: Standard
      Process ID: 1
      NBRFlag:
      Next hop list:
      XGE0/0/16                   FE80::A6FA:76FF:FEF5:E0FF                        Invalid
    BFR ID: 17
    PHP:Disabled
    BFR prefix: D::D
    Flag: Active
    Encapsulation MPRA: D::20
    Encapsulation:
      BSL  Max-SI
      64   0
      256  1
    BFR neighbors: 1
      BFR prefix: A::A
      System ID: ab00.0000.0104
      Process ID: 1
      NBRFlag:
      Next hop list:
    BFR ID: 18
    PHP:Disabled
    BFR prefix: E::E
    Flag: Active
    Encapsulation MPRA: E::20
    Encapsulation:
      BSL  Max-SI
      64   0
      256  1
    BFR neighbors: 2
      BFR prefix: A::A
      Process ID: 1
      NBRFlag:
      Next hop list:
      BFR prefix: B::B
      System ID: ab00.0000.0105
      Process ID: 1
      NBRFlag: B
      Next hop list:
Table 6 Command output
BFR prefix
(Local) indicates a local BFR prefix. If (Local) does not appear, the prefix is a remote BFR prefix. If a BFR ID conflict exists, this field displays N/A.
PHP
·     Disabled.
·     N/A—A BFR ID conflict exists.
Flag
BFER status:
·     Active—The BFER is available.
·     Conflict—A BFR ID conflict exists, and the BFER is unavailable.
Edge nodes that have conflicting BFR IDs. If no conflict exists, this field displays N/A.
BFR neighbors
If a BFR ID conflict exists, this field displays N/A. If no BFR neighbor exists, this field displays N/A.
Encapsulation MPRA
Underlay protocol
Routing protocol used to advertise BFR information.
Multi-topology
IS-IS IPv6 unicast topology mode:
·     Standard—IPv6 unicast topology standard mode.
·     Compatible—IPv6 unicast topology compatible mode. This value is not supported in the current software version.
Process ID
IS-IS process ID.
NBRFlag
Flag for the BFR neighbor reaching BFER:
·     A null value indicates that the reached BFR neighbor is the primary BFR neighbor.
·     A value of B indicates that the reached BFR neighbor is the backup BFR neighbor.
NhFlag
Next hop flag:
·     A null value indicates that the next-hop device is the primary next hop.
·     A value of B indicates that t the next-hop device is the backup next hop.
Token
LSP index number.
Use display bier sub-domain to display the BIER information of BFR prefixes.
display bier sub-domain [ sub-domain-id ]
sub-domain sub-domain-id: Specifies a sub-domain by its ID. If you do not specify a sub-domain, this command displays information about all sub-domains.
# Display information about all sub-domains.
<Sysname> display bier sub-domain
Total BIER subdomains: 1
  Sub-domain ID: 0
   Address family: IPv6
   BFR ID: 1
   PHP: Disabled
   TTL mode: Uniform
   TTL value: N/A
   Encapsulation:
     BSL       Max-SI
     256       2
# When the encapsulation type is G-BIER, display information about sub-domain 1.
<Sysname> display bier sub-domain 1
  Sub-domain ID: 1
   BFR ID: 1
   PHP: Disabled
   TTL mode: Uniform
   TTL value: N/A
   Encapsulation:
     BSL       Max-SI
     128       1
     256       2
# When the encapsulation type is BIERv6, display information about sub-domain 1.
  Sub-domain ID: 1
   BFR ID: 1
   PHP: Disabled
   TTL mode: Uniform
   TTL value: N/A
   Encapsulation End.BIER SID status: Valid
   Encapsulation:
     BSL       Max-SI
     128       1
     256       2
# When the encapsulation type is MSR6, display information about sub-domain 1.
  Sub-domain ID: 1
   BFR ID: 1
   PHP: Disabled
   TTL mode: Uniform
   TTL value: N/A
   Encapsulation type: MSR6
   Encapsulation End.RGB SID: 200::1
   Encapsulation End.RGB SID status: Valid
   Encapsulation:
     BSL       Max-SI
     128       1
     256       2
Table 7 Command output
Multi-topology
Address family
Only the IPv6 address family is supported in the current software version.
BFR prefix
Local BFR prefix and loopback interface associated with the prefix.
BFR ID
Local BFR ID.
PHP
·     Disabled.
TTL value
If the TTL mode is Uniform, this field displays N/A.
Encapsulation type
BIER encapsulation type: G-BIER or BIERv6. If no encapsulation type is configured, this field displays N/A.
Encapsulation MPRA
MPRA configured for G-BIER. If no MPRA is configured, this field displays N/A.
End.BIER SID configured for BIERv6. If no End.BIER SID is configured, this field displays N/A.
End.RGB SID configured for BIERv6. If no End.RGB SID is configured, this field displays N/A.
Indicates whether the configured End.BIER SID for BIERv6 is valid: Valid or Invalid.
Indicates whether the configured End.RGB SID for MSR6 is valid: Valid or Invalid.
Encapsulation
Encapsulation information. If no encapsulation type is configured, this field will not appear.
encapsulation-type
Use encapsulation-type to configure the encapsulation type, BSL, and maximum SI.
Use undo encapsulation-type to restore the default.
encapsulation-type { bierv6 | g-bier | msr6 } bsl bsl-value max-si max-si-value
undo encapsulation-type { bierv6 | g-bier | msr6 } bsl bsl-value
The encapsulation type, BSL, and maximum SI are not configured.
bierv6: Specifies Bit Index Explicit Replication IPv6 Encapsulation (BIERv6) as the encapsulation type.
g-bier: Specifies generalized BIER (G-BIER) as the encapsulation type.
msr6: Specifies Multicast Source Routing over IPv6 (MSR6) as the encapsulation type.
bsl bsl-value: Specifies the BSL. Valid values for the bsl-value argument are 64, 128, and 256.
max-si max-si-value: Specifies the maximum SI. An SI can a value in the range of 0 to the maximum SI. The value range for the max-si-value argument is 0 to 255.
Operating mechanism
The G-BIER, BIERv6, and MSR6 encapsulation types have the same packet forwarding process. The only difference is the packet header encapsulation format. For more information about the packet header encapsulation format, see BIER Configuration Guide.
BFRs in the same sub-domain must have the same BSL.
If the BSL is smaller than the maximum BFR ID in a sub-domain, a set identifier (SI) is used.
The maximum SI is (Maximum BFR ID–1)/BSL rounded down to the nearest integer. For example, if the maximum BFR ID is 1024 in a BIER sub-domain and the bit string length is 256, the bit string needs to be divided into four SIs (SI 0, SI 1, SI 2 and SI 3).
As a best practice to reduce the number of SIs and the number of encapsulated packets, configure contiguous BFR IDs.
To use BIERv6 or MSR6 encapsulation, make sure all BFRs in a sub-domain support SRv6. For more information about SRv6, see Segment Routing Configuration Guide.
# Specify the encapsulation type G-BIER, BSL 256, and maximum SI 2.
[Sysname] bier
[Sysname-bier-sub-domain-0-ipv6] encapsulation-type g-bier bsl 256 max-si 2
# Specify the encapsulation type BIERv6, BSL 256, and maximum SI 2.
[Sysname] bier
[Sysname-bier-sub-domain-0-ipv6] encapsulation-type bierv6 bsl 256 max-si 2
# Specify the encapsulation type MSR6, BSL 256, and maximum SI 2.
[Sysname] bier
[Sysname-bier-sub-domain-0-ipv6] encapsulation-type msr6 bsl 256 max-si 2
end-bier locator
Use end-bier locator to configure an End.BIER SID for a BFR in BIERv6.
Use undo end-bier locator to restore the default.
end-bier locator locator-name sid bierv6-sid
No End.BIER SID is configured for a BFR in BIERv6.
locator-name: Specifies an SRv6 SID locator by its name, a case-sensitive string of 1 to 31 characters.
sid bierv6-sid: Specifies a node IPv6 address of the SRv6 SID (End.BIER SID of a BFR in BIERv6).
Before executing an End.BIER SID, you must configure the encapsulation type as BIERv6 by using the encapsulation-type command.
Operating mechanism
An End.BIER SID is a SID defined in BIERv6 and represented as an IPv6 address. When the encapsulation type is BIERv6, you must configure a routable IPv6 address (End.BIER SID) used for BIERv6 forwarding in a sub-domain. The IPv6 address is carried in the IS-IS sub-sub-TLV to be advertised to neighbors as the destination IPv6 address in BIERv6 packets.
When a BFR receives a BIERv6 packet, it compares the destination IPv6 address in the packet with the configured End.BIER SID. If they are the same, the BFR performs BIERv6 forwarding on the packet. If they are different, the BFR performs IPv6 forwarding on the packet.
For the sid bierv6-sid option to take effect, you must configure the static length (the static static-length option) for the specified locator.
The specified locator cannot be associated with the Flex-Algo algorithm.
For the specified End.BIER SID to take effect, it must be in the range of the static start SRv6 SID to the static end SRv6 SID of the locator. To view the static start SRv6 SID and the static end SRv6 SID, see the Static SID start and Static SID end fields, respectively, in the display segment-routing ipv6 locator command output. For more information about the display segment-routing ipv6 locator command, see SRv6 commands in Segment Routing Command Reference.
A BFR must have a unique End.BIER SID in a sub-domain.
# Specify 2001::1 as the End.BIER SID for locator abc.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] locator abc ipv6-prefix 2001:: 64 static 32
[Sysname-segment-routing-ipv6] quit
[Sysname] bier
[Sysname-bier-sub-domain-0-ipv6] end-bier locator abc sid 2001::1
encapsulation-type
locator (Segment Routing Command Reference)
end-rgb locator
Use end-rgb locator to configure an End.RGB SID for a BFR in MSR6.
Use undo end-rgb locator to restore the default.
end-rgb locator locator-name sid msr6-sid
No End.RGB SID is configured for a BFR in MSR6.
sid msr6-sid: Specifies a node IPv6 address of the SRv6 SID (End.RGB SID of a BFR in MSR6).
Before executing an End.RGB SID, you must configure the encapsulation type as MSR6 by using the encapsulation-type command.
Operating mechanism
An End.RGB SID is a SID defined in MSR6 and represented as an IPv6 address. When the encapsulation type is MSR6, you must configure a routable IPv6 address (End.RGB SID) used for MSR6 forwarding in a sub-domain. The IPv6 address is carried in the IS-IS sub-sub-TLV to be advertised to neighbors as the destination IPv6 address in MSR6 packets.
When a BFR receives an MSR6 packet, it compares the destination IPv6 address in the packet with the configured End.RGB SID. If they are the same, the BFR performs MSR6 forwarding on the packet. If they are different, the BFR performs IPv6 forwarding on the packet.
For the sid msr6-sid option to take effect, you must configure the static length (the static static-length option) for the specified locator.
For the specified End.RGB SID to take effect, it must be in the range of the static start SRv6 SID to the static end SRv6 SID of the locator. To view the static start SRv6 SID and the static end SRv6 SID, see the Static SID start and Static SID end fields, respectively, in the display segment-routing ipv6 locator command output. For more information about the display segment-routing ipv6 locator command, see SRv6 commands in Segment Routing Command Reference.
A BFR must have a unique End.RGB SID in a sub-domain.
# Specify 2001::1 as the End.RGB SID for locator abc.
[Sysname] rgb
[Sysname-rgb] sub-domain 0 ipv6
[Sysname-rgb-sub-domain-0-ipv6] encapsulation-type msr6 bsl 256 max-si 2
[Sysname-rgb-sub-domain-0-ipv6] end-rgb locator abc sid 2001::1
display rgb sub-domain
encapsulation-type
g-bier mpra
Use g-bier mpra to configure a reserved address for the G-BIER multicast policy.
Use undo g-bier mpra to restore the default.
g-bier mpra ipv6-address
undo g-bier mpra
No reserved address for the G-BIER multicast policy is configured.
ipv6-address: Specifies an IPv6 address as the reserved address for the G-BIER multicast policy.
Before executing this command, you must configure the encapsulation type as G-BIER by using the encapsulation-type command.
Operating mechanism
When the encapsulation type is G-BIER, you must configure a routable IPv6 address reserved for the G-BIER multicast policy in a sub-domain. The IPv6 address is carried in the IS-IS sub-sub-TLV and BGP sub_sub_TLV to be advertised to neighbors as the destination IPv6 address in G-BIER packets.
When a BFR receives a G-BIER packet, it compares the destination IPv6 address in the packet with the configured IPv6 address. If they are the same, the BFR performs BIER forwarding on the packet. If they are different, the BFR performs IP forwarding on the packet.
A BFR must have a unique reserved address in a sub-domain.
# Configure 2001:0:5054:ff::fe5c:8350 as the reserved address for the G-BIER multicast policy.
[Sysname] bier
[Sysname-bier-sub-domain-0-ipv6] g-bier mpra 2001:0:5054:ff::fe5c:8350
encapsulation-type
import-bier
Use import-bier to enable BGP to redistribute the BIER information from an IGP.
Use undo import-bier to disable BGP from redistributing the BIER information from an IGP.
import-bier isisv6 { process-id | all-processes }
undo import-bier isisv6 { process-id | all-processes }
BGP does not redistribute the BIER information from an IGP.
isisv6: Redistributes the BIER information of IPv6 IS-IS routes.
process-id: Specifies a process by its number in the range of 1 to 65535.
all-processes: Redistributes the BIER information from all processes of the specified routing protocol.
The imported BIER information includes the BFR ID range information. The following rules apply to the inclusion of BFR ID range information when BGP routes generated based on the BIER information are advertised:
·     If BGP BFR prefix proxying is not enabled:
¡     The BFR ID range information is not included when BGP routes are advertised to an IBGP peer.
¡     The BFR ID range information is included when BGP routes are advertised to an EBGP peer.
·     If BGP BFR prefix proxying is enabled, the BFR ID range information is included when BGP routes are advertised to either an EBGP peer or an  IBGP peer.
After you redistribute the BIER information from all processes of a routing protocol by using the all-processes keyword, this command does not take effect on any processes of the protocol.
# In the BGP IPv6 unicast address family, redistribute the BIER information from a process 1 of IPv6 IS-IS.
[Sysname] bgp 100
[Sysname-bgp-default-ipv6] import-bier isisv6 1
bier enable
Use peer capability bier to enable the device to exchange routes with BIER path attributes with a peer or peer group.
Use undo peer capability bier to disable the device from exchanging routes with BIER path attributes with a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability bier
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability bier
The device cannot exchange routes with BIER path attributes with any peers or peer groups.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
ipv4-address: Specifies a peer by its IPv4 address. The peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the subnet.
ipv6-address: Specifies a peer by its IPv6 address. The peer must have been created.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command specifies all dynamic peers in the subnet.
With this command executed, BGP will advertise received BIER information to the BIER module for it to generate a BIRT, which guides the forwarding of multicast packets.
The device cannot exchange routes with BIER path attributes with peers or peer groups other than the specified peer or peer group.
# Enable BGP to exchange routes with BIER path attributes with a peer or peer group.
[Sysname] bgp 100
[Sysname-bgp-default-ipv6] peer 2001::1 capability bier
bier enable
primary-path-detect bfd
Use primary-path-detect bfd to configure detecting the reachbility of the primary next hop through BFD session.
Use undo primary-path-detect bfd to restore the default.
primary-path-detect bfd { ctrl | echo }
Reachability detection for the primary next hot through BFS session is not configured.
ctrl: Use BFD session detection of control packets to detect the reachability.
echo: Use BFD session detection of echo packets to detect the reachability.
Application scenarios
After enabling the BIER fast reroute capability, data traffic will quickly switch to a backup path to continue forwarding in the event of a link or node failure, thereby minimizing the loss of data traffic. Under normal conditions, the path used for data traffic forwarding is called the primary path, and the device on the primary path's next hop is known as the primary next hop.
In this scenario, this command can be configured to detect whether the primary next hop is reachable through a BFD session and to specify the working mode of this BFD session as either control packet mode or echo packet mode.
Operating mechanism
With this feature configured, the device automatically creates a BFD session to monitor the primary next hop, improving the convergence speed of traffic switching in the event of a failure of the primary next hop.
·     Before configuring this feature, use the bier fast-reroute enable command to enable the BIER fast reroute capability.
For more information about BIER fast reroute, see Layer 3 — IP Routing Configuration Guide.
·     A BFD session using the control packet mode requires negotiation between both ends to be successfully established. Therefore, toconfigure the BFD session with control packet mode to detect whether the primary next hop is reachable, first use bfd static to create a static BFD session on the primary next hop that meets the following requirements:
¡     The working mode is control packet mode.
¡     The detection method is single-hop detection.
¡     The session source IP address is the destination IP address of the BFD session automatically created on the local end.
¡     The session destination IP address is the source IP address of the BFD session automatically created on the local end.
¡     The remote identifier is the local identifier of the BFD session automatically created on the local end.
For detailed information on creating static BFD sessions, see High Availability Configuration Guide.
·     If you execute this command multiple times, the most recent configuration takes effect.
# Configure detecting the reachbility of the primary next hop through BFD session of control packets.
[Sysname] bier
[Sysname-bier-sub-domain-1-ipv6] primary-path-detect bfd ctrl
bfd static (High Availability Command Reference)
bier fast-reroute enable (Layer 3 — IP Routing Command Reference)
warm-root-standby (IP Mutilcast Command Reference)
Use reset bier forward ipv6 statistics to clear BIER packet statistics.
In standalone mode:
reset bier forward ipv6 statistics [ slot slot-number ]
In IRF mode:
reset bier forward ipv6 statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears BIER packet statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays BIER packet statistics for all cards. (In IRF mode.)
# Clear BIER packet statistics.
<Sysname> reset bier forward ipv6 statistics
sub-domain
Use sub-domain to assign the device to a sub-domain and enter sub-domain view.
Use undo sub-domain to remove the device from the sub-domain.
sub-domain sub-domain-id ipv6
undo sub-domain sub-domain-id
The device does not belong to any sub-domain.
BIER view
ipv6: Indicates that the device is in an IPv6 network.
All BFRs in a network are referred to as a BIER domain. A BIER domain can contain one or more sub-domains.
To use BIER, you must assign the device to one or more sub-domains.
The maximum number of sub-domains supported on a device is 8.
# Assign the device to sub-domain 2.
[Sysname] bier
[Sysname-bier] sub-domain 2 ipv6
[Sysname-bier-sub-domain-2-ipv6]
ttl-mode
Use ttl-mode to configure a TTL processing mode.
Use undo ttl-mode to restore the default.
ttl-mode { pipe ttl ttl-value | uniform }
undo ttl-mode
On a BFIR, the TTL processing mode is pipe and the TTL is 255. On a BFER, the TTL processing mode is uniform.
pipe ttl-value: Specifies the pipe mode. The value range for the ttl-value argument is 1 to 255. On a BFER, the ttl-value argument does not take effect.
uniform: Specifies the uniform mode.
When acting as a public network tunnel, a BIER can process TTLs in the following modes:
·     uniform—When the ingress node of a public network tunnel adds a BIER header to a multicast packet, it copies the TTL value to the TTL field of the BIER packet. When a BFER decapsulates the BIER packet, it copies the TTL value back to the TTL field of the multicast packet. In this mode, nodes in the public network are visible to packets in the user network. The TTL value of the BIER packet decreases by 1 per hop in the BIER tunnel. A tracert operation can display the actual path that the packet travels.
·     pipe—When the ingress node of a public network tunnel adds a BIER header to a multicast packet, it populates the TTL field in the BIER with the configured TTL value instead of copying the TTL value of the multicast packet. When a BFER decapsulates the BIER packet, it does not modify the TTL value the multicast packet. In this mode, nodes in the public network are invisible to packets in the user network. The TTL value of the BIER packet decreases by 1 per hop in the BIER tunnel. A tracert operation does not display each node in the public network so the public network structure is hidden.
The BFIR and BFERs must be configured with the same TTL processing mode.
# Specify the TTL processing mode as pipe and set the TTL to 225.
[Sysname] bier
[Sysname-bier-sub-domain-1-ipv6] ttl-mode pipe ttl 225
