04-Layer 2—LAN Switching Command Reference
HomeSupportRoutersCR16000-M1A SeriesCR16000-M1A SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C CR16000-M1A Router Command Reference-R8630Pxx-6W10204-Layer 2—LAN Switching Command Reference
06-QinQ commands
06-QinQ commands 58.19 KB
QinQ commands
In this document:
·     Customer network VLANs (CVLANs), also called inner VLANs, refer to VLANs that a customer uses on the private network.
·     Service provider network VLANs (SVLANs), also called outer VLANs, refer to VLANs that a service provider uses to transmit VLAN tagged traffic for customers.
display qinq
Use display qinq to display QinQ-enabled interfaces.
display qinq [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays all QinQ-enabled interfaces.
If QinQ is not enabled on any interfaces, this command does not provide any output.
# Enable QinQ on Ten-GigabitEthernet 0/0/15. Then, verify that QinQ is enabled on the interface.
[Sysname] interface ten-gigabitethernet 0/0/15
[Sysname-Ten-GigabitEthernet0/0/15] qinq enable
[Sysname-Ten-GigabitEthernet0/0/15] display qinq interface ten-gigabitethernet 0/0/15
# Enable QinQ on Ten-GigabitEthernet 0/0/15 and Ten-GigabitEthernet 0/0/17. Then, verify that QinQ is enabled on the interfaces.
[Sysname-Ten-GigabitEthernet0/0/15] quit
[Sysname] interface ten-gigabitethernet 0/0/17
[Sysname-Ten-GigabitEthernet0/0/17] qinq enable
[Sysname-Ten-GigabitEthernet0/0/17] display qinq
qinq enable
qinq enable
Use qinq enable to enable QinQ on an interface.
Use undo qinq enable to disable QinQ on an interface.
qinq enable
undo qinq enable
QinQ is disabled on interfaces.
You can enable QinQ on the port only when the link type of the port is access. If the link type of the port is hybrid or trunk, QinQ is not supported.
[Sysname-Ten-GigabitEthernet0/0/15] port link-type access
display qinq
qinq ethernet-type (interface view)
Use qinq ethernet-type to set the TPID value in SVLAN tags on an interface.
Use undo qinq ethernet-type to restore the default TPID value in SVLAN tags on an interface.
qinq ethernet-type service-tag hex-value
undo qinq ethernet-type service-tag
The TPID value in SVLAN tags is 8100 in hexadecimal notation.
service-tag: Sets the TPID value in the SVLAN tag.
hex-value: Sets a hexadecimal TPID value in the range of 1 to ffff, excluding the reserved EtherType values listed in Table 1.
Table 1 Reserved EtherType values
Protocol type
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86dd
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
LLDP
0x88cc
802.1X
0x888e
802.1ag
0x8902
Cluster
0x88a7
Reserved
0xfffd/0xfffe/0xffff
# Set the TPID value in the SVLAN tags to 9100 (hexadecimal) on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] qinq ethernet-type service-tag 9100
