21-NAT Command Reference
HomeSupportRoutersCR16000-M1A SeriesCR16000-M1A SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C CR16000-M1A Router Command Reference-R8630Pxx-6W10221-NAT Command Reference
Table of Contents
Related Documents
01-NAT commands
01-NAT commands 551.63 KB
NAT commands
Generic NAT commands
address
Use address to add an address range to a NAT address group.
Use undo address to remove an address range from a NAT address group.
address start-address end-address
undo address start-address end-address
No address ranges exist.
NAT address group view
start-address end-address: Specifies the start and end IP addresses of the address range. The end address must not be lower than the start address. If they are the same, the address range has only one IP address. Each address range can contain a maximum of 65536 addresses.
Application scenarios
A NAT address group is a set of address ranges. The source address in a packet destined for an external network is translated into an address in one of the address ranges.
When you execute this command in a NAT address group, follow these restrictions and guidelines:
·     You can add multiple address ranges to a NAT address group. Make sure the address ranges do not overlap in the NAT address group.
·     The device supports a maximum of 65536 address ranges in total for all NAT address groups.
·     If the NAT address group has been used by a NAT rule, you cannot use the undo address command to delete addresses from the group.
# Add two address ranges to an address group.
[Sysname] nat address-group 2
[Sysname-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-address-group-2] address 10.1.1.20 10.1.1.30
global-ip-pool
nat address-group
display nat address-group
Use display nat address-group to display NAT address group configuration.
display nat address-group [ group-id ]
group-id: Specifies the ID of a NAT address group. The value range for this argument is 0 to 65535. If you do not specify this argument, the command displays the configuration for all NAT address groups.
# Display configuration information about all NAT address groups.
<Sysname> display nat address-group
NAT address group information:
  Totally 8 NAT address groups.
  Address group name/ID: group1/1
    Port range: 1024-65535
    Address information:
      Start address         End address
      202.110.10.10         202.110.10.15
  Address group name/ID: group2/2
      202.110.10.20         202.110.10.25
      202.110.10.30         202.110.10.35
  Address group name/ID: group3/3
      202.110.10.40         202.110.10.50
Totally n NAT address groups
Total number of parent NAT address groups.
Name and ID of the NAT address group.
VPN instance
Name of the VPN instance to which the NAT address group is bound. The command output does not display this field if you did not bind the NAT address group to a VPN instance when you executed the nat address-group command.
Port range
Port range for public IP addresses.
TCP port limit
Maximum number of ports that can be assigned to the TCP protocol. This field is not displayed if the maximum number is not set.
UDP port limit
Maximum number of ports that can be assigned to the UDP protocol. This field is not displayed if the maximum number is not set.
ICMP port limit
Maximum number of ports that can be assigned to the ICMP protocol. This field is not displayed if the maximum number is not set.
Port limit in total
Maximum number of ports that can be assigned to the TCP, UDP, and ICMP protocols. This field is not displayed if the maximum number is not set.
Instance name/ID
Name and ID of the NAT instance bound to the NAT address group.
Totally n sub NAT address groups
Number of child address groups generated by the parent NAT address group.
Address information
Information about the address ranges in the address group.
Start address
Start IP address of an address range. If you do not specify a start address, this field displays three hyphens (---).
End address
End IP address of an address range. If you do not specify an end address for the range, this field displays three hyphens (---).
Config status
Status of the NAT address group configuration:
·     Active—The configuration is taking effective.
·     Inactive—The configuration is not taking effective.
Reasons for inactive status
Reasons why the NAT address group configuration does not take effect. This field is available when the Config status field displays Inactive.
The following are possible reasons that the system might display:
·     The following items don't exist: address, and VPN instance
·     The following items don't exist: VPN instance
# Display configuration for NAT address group 1.
<Sysname> display nat address-group 1
    VPN instance: vpn1
    Instance name/ID: nat1/1
    Config status: Active
VPN instance
Port range
Instance name/ID
Name and ID of the NAT instance.
Address information
Start address
End address
End IP address of an address range. If you do not specify an end address, this field displays three hyphens (---).
Config status
Reasons why the NAT address group configuration does not take effect. This field is available when the Config status field displays Inactive. Possible reasons:
nat address-group
display nat all
Use display nat all to display all NAT configuration information.
display nat all
# (In standalone mode.) Display all NAT configuration information.
<Sysname> display nat all
NAT hardware mode : Disabled
  Totally 6 NAT address groups.
  Address group name/ID: 1/1
    VPN instance: vpn1
  Address group name/ID: 2/2
  Address group name/ID: 3/3
  Address group name/ID: 4/4
    Port range: 10001-65535
    Port block size: 500
    Extended block number: 1
      202.110.10.60         202.110.10.65
  Address group name/ID: 5/5
    Port block size: 6400
    Extended block size: 64
    TCP port limit: 1000
    UDP port limit: 2000
    ICMP port limit: 3000
    Port limit in total: 6000
      202.110.10.70         202.110.10.75
  Address group name/ID: 6/6
    Config status: Inactive
    Reasons for inactive status:
NAT server group information:
  Totally 3 NAT server groups.
  Group Number        Inside IP             Port        Weight
  1                   192.168.0.26          23          100
                      192.168.0.27          23          500
  2                   ---                   ---         ---
  3                   192.168.0.26          69          100
NAT outbound information:
  Totally 2 NAT outbound rules.
  Interface: Ten-GigabitEthernet0/0/16
    ACL: 2036         Address group: 1      Port-preserved: Y
    NO-PAT: N         Reversible: N
    ACL: 2037         Address group: 1      Port-preserved: N
    NO-PAT: Y         Reversible: Y
    VPN instance: vpn_nat
NAT internal server information:
  Totally 4 internal servers.
  Interface: Ten-GigabitEthernet0/0/17
    Protocol: 6(TCP)
    Global IP/port: 50.1.1.1/23
    Local IP/port : 192.168.10.15/23
    ACL           : 2000
    Config status : Active
  Interface: Ten-GigabitEthernet0/0/18
    Protocol: 6(TCP)
    Global IP/port: 50.1.1.1/23-30
    Local IP/port : 192.168.10.15-192.168.10.22/23
    Global VPN    : vpn1
    Local VPN     : vpn3
    Protocol: 255(Reserved)
    Global IP/port: 50.1.1.100/---
    Local IP/port : 192.168.10.150/---
    Global VPN    : vpn2
    Local VPN     : vpn4
    ACL           : 3000
  Interface: Ten-GigabitEthernet0/0/19
    Protocol: 17(UDP)
    Global IP/port: 50.1.1.2/23
    Local IP/port : server group 1
                    192.168.0.26/23       (Connections: 10)
                    192.168.0.27/23       (Connections: 20)
    Global VPN    : vpn1
    Local VPN     : vpn3
Static NAT mappings:
  Totally 2 inbound static NAT mappings.
  Net-to-net:
    Global IP    : 2.2.2.1 – 2.2.2.255
    Local IP     : 1.1.1.0
    Netmask      : 255.255.255.0
    Global VPN   : vpn2
    Local VPN    : vpn1
    ACL          : 2000
    Reversible   : Y
  IP-to-IP:
    Global IP    : 5.5.5.5
    Local IP     : 4.4.4.4
    Global VPN   : vpn3
    Local VPN    : vpn4
    ACL          : 2001
    Reversible   : Y
  Totally 2 outbound static NAT mappings.
  Net-to-net:
    Local IP     : 1.1.1.1 - 1.1.1.255
    Global IP    : 2.2.2.0
    Local VPN    : vpn1
    Global VPN   : vpn2
    ACL          : 2000
    Reversible   : Y
  IP-to-IP:
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    Local VPN    : vpn1
    Global VPN   : vpn2
    ACL:         : 2001
    Reversible   : Y
Interfaces enabled with static NAT:
  Totally 2 interfaces enabled with static NAT.
  Interface: Ten-GigabitEthernet0/0/20
NAT DNS mappings:
  Totally 2 NAT DNS mappings.
  Domain name  : www.example.com
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Domain name  : service.example.com
  Global IP    : 10.1.1.1
  Global port  : 12
  Protocol     : TCP(6)
NAT logging:
  Log enable               : Disabled
  Flow-begin               : Disabled
  Flow-end                 : Disabled
  Flow-active              : Disabled
  Port-block-assign        : Disabled
  Port-block-withdraw      : Disabled
  Port-alloc-fail          : Enabled
  Port-block-alloc-fail    : Disabled
  Port-usage               : Disabled
  Port-block-usage         : Enabled(90%)
  Address-group-usage      : Enabled(Threshold: 90%)
  Bandwidth-usage          : Enabled(Threshold: 90%)
NAT hairpinning:
  Totally 2 interfaces enabled with NAT hairpinning.
NAT mapping behavior:
  Mapping mode : Endpoint-Independent (TCP-5-Tuple)
  ACL          : 2050
NAT ALG:
  DNS        : Disabled
  FTP        : Enabled
  H323       : Disabled
  ICMP-ERROR : Enabled
  ILS        : Disabled
  MGCP       : Disabled
  NBT        : Disabled
  PPTP       : Disabled
  RTSP       : Enabled
  RSH        : Disabled
  SCCP       : Disabled
  SIP        : Disabled
  SQLNET     : Disabled
  TFTP       : Disabled
  XDMCP      : Disabled
NAT port block group information:
  Totally 3 NAT port block groups.
  Port block group 1:
    Block size: 256
    Local IP address information:
      Start address        End address          VPN instance
      172.16.1.1           172.16.1.254         ---
      192.168.1.1          192.168.1.254        ---
      192.168.3.1          192.168.3.254        ---
    Global IP pool information:
      201.1.1.1            201.1.1.10
      201.1.1.21           201.1.1.25
  Port block group 2:
    Port range: 10001-30000
    Block size: 500
      10.1.1.1             10.1.10.255          ---
      202.10.10.101        202.10.10.120
  Port block group 3:
    Block size: 256
NAT outbound port block group information:
  Totally 2 outbound port block group items.
    Port-block-group: 2
    Port-block-group: 10
    Config status   : Inactive
      The following items don't exist or aren't effective: port block group.
NAT Agency ALG:
  FTP        : Enabled
  SIP        : Disabled
NAT extended port block report to RADIUS: Disabled
NAT hardware ignore-flowredirect-method : Disabled
NAT hardware aging-accelerate dns : Disabled
The output shows all NAT configuration information. Table 3 describes only the fields for the output of the nat hairpin enable, nat mapping-behavior, and nat alg commands.
NAT hardware mode
Enabling status of hardware NAT:
·     Enabled.
·     Disabled.
Information about the NAT address group. See Table 1 for output description.
Information about the internal server group. See Table 16 for output description.
Outbound dynamic NAT configuration. See Table 9 for output description.
NAT Server configuration. See Table 10 for output description.
Static NAT mappings
Static NAT mappings. See Table 12 for output description.
NAT DNS mappings
NAT DNS mappings. See Table 4 for output description.
NAT logging
NAT logging configuration. See Table 7 for output description.
NAT hairpinning
NAT hairpin configuration. If NAT hairpin is not configured, this field is not displayed.
Totally n interfaces enabled NAT hairpinning
Number of interfaces with NAT hairpin enabled.
NAT hairpin-enabled interface.
Config status
Status of the NAT hairpin configuration: Active.
Mapping behavior mode of PAT:
·     Connection-dependent.
·     Endpoint-Independent (TCP)—The mapping mode is endpoint-independent and only EIM entries for TCP connections are created.
·     Endpoint-Independent (TCP-5-Tuple)—The mapping mode is endpoint-independent, and 5-tuple session entries and EIM entries for TCP connections are created.
·     Endpoint-Independent (UDP)—The mapping mode is endpoint-independent and only EIM entries for UDP connections are created.
·     Endpoint-Independent (UDP-5-Tuple)—The mapping mode is endpoint-independent, and 5-tuple session entries and EIM entries for UDP connections are created.
ACL
ACL number or name. If no ACL is specified for NAT, this field displays hyphens (---).
Config status
Status of the NAT mapping behavior configuration:
·     Active—The configuration is taking effect.
·     Inactive—The configuration is not taking effect.
Reasons why the NAT mapping behavior configuration does not take effect. This field is available when the Config status field displays Inactive.
NAT ALG
NAT ALG configuration for different protocols.
NAT Agency ALG
Enabling status of ALG for PPPoE agency user packets:
·     Enabled.
·     Disabled.
Enabling status of NAT ignoring the traffic redirection method:
·     Enabled.
·     Disabled.
Enabling status of NAT accelerating the aging of session entries and EIM entries generated during DNS packet processing:
·     Enabled.
·     Disabled.
display nat dns-map
Use display nat dns-map to display NAT DNS mapping configuration.
display nat dns-map
# Display NAT DNS mapping configuration.
<Sysname> display nat dns-map
NAT DNS mapping information:
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Global port  : 12
  Protocol     : TCP(6)
Information about the NAT DNS mappings.
Totally n NAT DNS mappings
Total number of NAT DNS mappings.
Information about NAT DNS mappings.
Domain name
Domain name of the internal server.
Global IP
Public IP address of the internal server.
·     If Easy IP is configured, this field displays the IP address of the specified interface.
·     If you do not specify a public IP address, this field displays hyphens (---).
Global port
Public port number of the internal server.
Protocol
Protocol name and number of the internal server.
Config status
Status of the DNS mapping configuration:
Reasons why the DNS mapping configuration does not take effect. This field is available when the Config status field displays Inactive.
nat dns-map
display nat eim
Use display nat eim to display information about NAT Endpoint-Independent Mapping (EIM) entries.
In standalone mode:
display nat eim [ slot slot-number ] [ protocol { icmp | tcp | udp } ] [ local-ip { b4 ipv6-address | local-ip } ] [ local-port local-port ] [ global-ip global-ip ] [ global-port global-port ] [ local-vpn local-vpn-instance-name ]
In IRF mode:
display nat eim [ chassis chassis-number slot slot-number ] [ protocol { icmp | tcp | udp } ] [ local-ip { b4 ipv6-address | local-ip } ] [ local-port local-port ] [ global-ip global-ip ] [ global-port global-port ] [ local-vpn local-vpn-instance-name ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays EIM entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays EIM entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
protocol: Specifies a protocol by its type.
icmp: Specifies the ICMP protocol.
tcp: Specifies the TCP protocol.
udp: Specifies the UDP protocol.
local-ip local-ip: Displays EIM entry information for a private IP address. The local-ip argument specifies a private IP address.
local-ip b4 ipv6-address: Displays EIM entry information for a B4 device IP address. The ipv6-address argument specifies the IPv6 address of a B4 device.
local-port local-port: Displays EIM entry information for a private port. The local-port argument specifies a private port number in the range of 0 to 65535.
global-ip global-ip: Displays EIM entry information for a public IP address. The global-ip argument specifies a public IP address.
global-port global-port: Displays EIM entry information for a public port. The global-port argument specifies a public port number in the range of 0 to 65535.
local-vpn vpn-instance-name: Displays information about EIM entries that contain the specified MPLS L3VPN instance to which private users belong. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must be the VPN instance carried in the packets sent from the private users to the public network, which corresponds to Local VPN for address translation.
EIM entries are created when PAT operates in EIM mode. An EIM entry is a three-tuple (source IP address, source port number, and protocol type) entry, and it records the mapping between a private address/port and a public address/port.
The EIM entry provides the following functions:
·     The same EIM entry applies to subsequent connections initiated from the same source IP and port.
·     The EIM entries allow reverse translation for connections initiated from external hosts to internal hosts.
If you do not specify the local-ip, local-port, global-ip, vpn-instance, or global-port keyword, this command displays information about all EIM entries for ICMP, TCP, and UDP protocols.
# (In standalone mode.) Display information about all NAT EIM entries on the specified slot.
<Sysname> display nat eim slot 0
Slot 0:
Local  IP/port: 192.168.100.100/1024
Global IP/port: 200.100.1.100/2048
Destination IP/port: 202.38.1.1/21
DS-Lite tunnel peer: -
Local  VPN: vpn1
Global VPN: vpn2
Protocol: TCP(6)
Failover group name: -
Local  IP/port: 192.168.100.200/2048
Global IP/port: 200.100.1.200/4096
Protocol: UDP(17)
Total entries found: 2
# (In standalone mode.) Display information about NAT EIM entries for TCP on the specified slot.
<Sysname> display nat eim slot 1 protocol tcp
Slot 0:
Local  VPN: vpn1
Global VPN: vpn2
Protocol: TCP(6)
Total entries found: 1
# (In standalone mode.) Display information about NAT EIM entries for VPN instance vpn1 to which private users belong on the specified slot.
<Sysname> display nat eim local-vpn vpn1
Slot 0:
Local  VPN: vpn1
Global VPN: vpn2
Protocol: TCP(6)
Table 5 Command output
Local  IP/port
Private IP address and port number.
Global IP/port
Public IP address and port number after address translation of the private IP address and port number.
Destination IP/port
Destination IP address and port number.
DS-Lite tunnel peer
DS-Lite tunnel B4 address. If the session does not belong to any DS-Lite tunnel, this field displays a hyphen (-).
Local VPN
MPLS L3VPN instance to which the private IP address belongs. If the private IP address does not belong to any VPN instance, this field is not displayed.
Global VPN
MPLS L3VPN instance to which the public IP address belongs. If the public IP address does not belong to any VPN instance, this field is not displayed.
Protocol
Protocol name and number.
Failover group name
Failover group name. If no failover group is specified, this field displays a hyphen (-).
Total entries found
Total number of EIM entries.
nat outbound
display nat eim statistics
Use display nat eim statistics to display NAT EIM entry statistics.
In standalone mode:
display nat eim statistics [ slot slot-number ]
In IRF mode:
display nat eim statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays EIM entry statistics on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays EIM entry statistics on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
The NAT EIM entry statistics includes the following information:
·     The number of EIM entries.
·     The creation rate of EIM entries for TCP.
·     The creation rate of EIM entries for UDP.
# (In standalone mode.) Display EIM entry statistics for the specified slot.
<Sysname> display nat eim statistics slot 0
EIM: Total EIM entries.
TCP: Total EIM entries for TCP.
UDP: Total EIM entries for UDP.
Rate: Creating rate of EIM entries.
TCP rate: Creating rate of EIM entries for TCP.
UDP rate: Creating rate of EIM entries for UDP.
Slot EIM       TCP       UDP       Rate          TCP rate      UDP rate
                                  (entries/s)   (entries/s)   (entries/s)
0    0         0         0         0             0             0
Table 6 Command output
Total EIM entries
Total number of EIM entries for TCP.
Total number of EIM entries for UDP.
Creation rate of EIM entries.
Creation rate of EIM entries for TCP.
Creation rate of EIM entries for UDP.
display nat log
Use display nat log to display NAT logging configuration.
display nat log
# Display NAT logging configuration. (Interface-based NAT.)
<Sysname> display nat log
NAT logging:
  Log format user-mac      : Disabled
  Flow-end                 : Disabled
Table 7 Command output
NAT logging
Log enable
Whether NAT logging is enabled.
·     Enabled—NAT logging is enabled. If an ACL is specified for NAT logging, this field also displays the ACL number or name.
·     Disabled—NAT logging is disabled.
Log format user-mac
Whether configuring the system logs to carry the MAC addresses of online users in a NAT+BRAS scenario is enabled.
Flow-begin
Whether logging is enabled for NAT session establishment events.
Flow-end
Whether logging is enabled for NAT session removal events.
Flow-active
Whether logging is enabled for active NAT flows. If logging for active NAT flows is enabled, this field also displays the interval in minutes at which active flow logs are generated.
Address-group-usage
Whether logging is enabled for resource usage in address groups. If logging for resource usage in address groups is enabled, this field also displays the usage threshold in percentage.
nat log enable
nat log flow-active
nat log flow-begin
display nat no-pat
Use display nat no-pat command to display information about NAT NO-PAT entries.
In standalone mode:
display nat no-pat [ slot slot-number ]
In IRF mode:
display nat no-pat [ chassis chassis-number slot slot-number ]
Default user roles
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays NO-PAT entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays NO-PAT entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
A NO-PAT entry records the mapping between a private address and a public address.
The NO-PAT entry provides the following functions:
·     The same entry applies to subsequent connections initiated from the same source IP address.
·     The NO-PAT entries allow reverse translation for connections initiated from external hosts to internal hosts.
Outbound NO-PAT address translations create their own NO-PAT tables. These two types of tables are displayed separately.
# (In standalone mode.) Display information about NO-PAT entries for the specified slot.
<Sysname> display nat no-pat slot 0
Slot 0:
Global  IP: 200.100.1.100
Local   IP: 192.168.100.100
Global VPN: vpn2
Local  VPN: vpn1
Reversible: N
Type      : Inbound
Local   IP: 192.168.100.200
Global  IP: 200.100.1.200
Reversible: Y
Type      : Outbound
Table 8 Command output
Global  IP
Public IP address.
Local   IP
Private IP address.
Local VPN
Global VPN
Reversible
Whether reverse address translation is allowed:
·     Y—Reverse address translation is allowed.
·     N—Reverse address translation is not allowed.
Type of the NO-PAT entry:
·     Inbound—A NO-PAT entry created during inbound dynamic NAT.
·     Outbound—A NO-PAT entry created during outbound dynamic NAT.
Total entries found
Total number of NO-PAT entries.
nat outbound
display nat outbound
Use display nat outbound to display information about outbound dynamic NAT.
# (In standalone mode.) Display information about outbound dynamic NAT.
<Sysname> display nat outbound
  Interface: Ten-GigabitEthernet0/0/15
    ACL: 2037         Address group: 2      Port-preserved: N
Table 9 Command output
Information about outbound dynamic NAT.
Totally n NAT outbound rules
Total number of outbound dynamic NAT rules.
Interface where the outbound dynamic NAT rule is configured.
ACL
IPv4 ACL number or name. If no IPv4 ACL is specified for outbound dynamic NAT, this field displays hyphens (---).
Address group
Address group used by the outbound dynamic NAT rule. If no address group is specified for address translation, the field displays hyphens (---).
Port-preserved
Whether to try to preserve the port numbers for PAT.
NO-PAT
Whether NO-PAT is used:
·     YNO-PAT is used.
·     NPAT is used.
Reversible
VPN instance
MPLS L3VPN instance to which the NAT address group belongs. If the NAT address group does not belong to any VPN instance, the field is not displayed.
Config status
Status of the outbound dynamic NAT configuration:
Reasons why the outbound dynamic NAT configuration does not take effect. This field is available when the Config status field displays Inactive.
·     The following items don't exist or aren't effective: global VPN, interface IP address, address group, and ACL.
·     NAT address conflicts.
nat outbound
display nat server
Use display nat server to display NAT server mappings.
display nat server
# (In standalone mode.) Display NAT server mappings.
<Sysname> display nat server
    Protocol: 6(TCP)
    Protocol: 6(TCP)
    Global VPN    : vpn1
    Local VPN     : vpn3
    Global VPN    : vpn2
    Local VPN     : vpn4
    Protocol: 17(UDP)
                    1.1.1.1/21            (Connections: 10)
                    192.168.100.200/80    (Connections: 20)
    Global VPN    : vpn1
    Local VPN     : vpn10
Table 10 Command output
Information about NAT server mappings.
Totally n internal servers
Total number of NAT server mappings.
Interface where the NAT server mapping is configured.
Protocol
Protocol number and name of the internal server.
Global IP/port
Public IP address and port number of the internal server.
·     Global IP—A single IP address or an IP address range. If you use Easy IP, this field displays the IP address of the specified interface. If you do not specify an address for the interface, the Global IP field displays hyphens (---).
·     port—A single port number or a port number range. If no port number is in the specified protocol, the port field displays hyphens (---).
Local IP/port
For common NAT server mappings, this field displays the private IP address and port number of the server.
·     Local IP—A single IP address or an IP address range.
For load sharing NAT server mappings, this field displays the internal server group ID, IP address, port number, and number of connections of each member.
Global VPN
MPLS L3VPN instance to which the public IP addresses belong. If the public IP addresses do not belong to any VPN instance, this field is not displayed.
Local VPN
MPLS L3VPN instance to which the private IP addresses belong. If the private IP addresses do not belong to any VPN instance, this field is not displayed.
ACL
ACL number or name. If no ACL is specified, this field is not displayed.
Config status
Status of the NAT server mapping configuration:
Reasons why the NAT server mapping does not take effect. This field is available when the Config status field displays Inactive. The following are possible reasons that the system might display:
·     The following items don't exist or aren't effective: local VPN, global VPN, interface IP address, server group, and ACL—The MPLS L3VPN instance to which the private IP addresses belong, MPLS L3VPN instance to which the public IP addresses belong, interface IP addresses, server group, or ACL does not exist or is not effective.
·     Server configuration conflicts—A NAT server configuration conflict has occurred.
·     NAT address conflicts—A NAT address conflict has occurred.
nat server
display nat session
Use display nat session to display sessions that have been NATed.
In standalone mode:
display nat session [ { source-ip source-ip | destination-ip destination-ip } * [ vpn-instance vpn-instance-name ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ slot slot-number ] [ brief | verbose ]
In IRF mode:
display nat session [ { source-ip source-ip | destination-ip destination-ip } * [ vpn-instance vpn-instance-name ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ chassis chassis-number slot slot-number ] [ brief | verbose ]
source-ip source-ip: Displays NAT sessions for the source IP address specified by the source-ip argument. The IP address must be the source IP address of the packet that triggers the session establishment.
destination-ip destination-ip: Displays NAT sessions for the destination IP address specified by the destination-ip argument. The IP address must be the destination IP address of the packet that triggers the session establishment.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The VPN must be the VPN inside the packet. If you do not specify a VPN instance, this command displays NAT sessions that do not belong to any VPN instance.
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }: Displays IPv4 unicast session entries for the specified protocol. If you do not specify a protocol, the command displays NAT session entries for all supported protocols. Supported IPv4 transport layer protocols include DCCP, ICMP, RawIP, SCTP, TCP, UDP, and UDP-Lite.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays NAT sessions on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays NAT sessions on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
brief: Display brief information about NAT sessions.
verbose: Display detailed information about NAT sessions. If you do not specify this keyword, this command displays brief information about NAT sessions.
If you do not specify any parameters, this command displays detailed information about all NAT sessions.
# (In standalone mode.) Display detailed information about NAT sessions for the specified slot.
<Sysname> display nat session slot 0 verbose
Slot 0:
Initiator:
  Source      IP/port: 192.168.1.18/1877
  Destination IP/port: 192.168.1.55/22
  VPN instance/VLAN ID/VLL ID: -/-/-
  Protocol: TCP(6)
  Inbound interface: Ten-GigabitEthernet0/0/15
Responder:
  Source      IP/port: 192.168.1.55/22
  Destination IP/port: 192.168.1.10/1877
  Protocol: TCP(6)
  Inbound interface: Ten-GigabitEthernet0/0/16
State: TCP_SYN_SENT
Application: SSH
Start time: 2011-07-29 19:12:36
Role: Standby
Initiator->Responder:         1 packets         48 bytes
Responder->Initiator:         0 packets          0 bytes
Total sessions found: 1
# (In standalone mode.) Display brief information about NAT sessions for the specified slot.
<Sysname> display nat session slot 0 brief
Slot 0:
Protocol   Source IP/port      Destination IP/port    Global IP/port
TCP        10.2.1.58/2477      20.1.1.2/1025          30.2.4.9/226
Table 11 Command output
CPU
Number of the CPU.
Source IP/port
Source IP address and port number.
Destination IP/port
DS-Lite tunnel peer
Destination address of the DS-Lite tunnel interface. If the session does not belong to any DS-Lite tunnel, this field displays a hyphen (-).
The fields identify the following information:
·     VPN instance—MPLS L3VPN instance to which the session belongs.
·     VLAN ID—VLAN to which the session belongs for Layer 2 forwarding.
·     VLL ID—INLINE to which the session belongs for Layer 2 forwarding.
If no VPN instance, VLAN ID, or VLL ID is specified, a hyphen (-) is displayed for the related field.
Protocol
Transport layer protocol type: DCCP, ICMP, Raw IP, SCTP, TCP, UDP, or UDP-Lite.
Inbound interface
Input interface.
NAT session status.
Application
Application layer protocol type, such as FTP and DNS.
This field displays OTHER for the protocol types identified by non-well-known ports.
Start time
Time when the session starts.
TTL
Remaining NAT session lifetime in seconds.
Number of packets and packet bytes from the initiator to the responder.
Number of packets and packet bytes from the responder to the initiator.
Total number of sessions.
Source IP/port
Source IP address and port number of the initiator.
Destination IP/port
Destination IP address and port number of the initiator.
Global IP/port
Public IP address and port number.
reset nat session
display nat static
Use display nat static to display static NAT mappings.
display nat static
# (In standalone mode.) Display static NAT mappings.
<Sysname> display nat static
  Net-to-net:
    Global IP    : 1.1.1.1 - 1.1.1.255
    Local IP     : 2.2.2.0
    Global VPN   : vpn2
    Local VPN    : vpn1
    ACL          : 2000
    Reversible   : Y
  IP-to-IP:
    Global IP   : 5.5.5.5
    Local IP     : 4.4.4.4
    Global VPN   : vpn3
    Local VPN    : vpn4
    ACL          : 2001
    Reversible   : Y
  Net-to-net:
    Global IP    : 2.2.2.0
    Local VPN    : vpn1
    Global VPN   : vpn2
    ACL          : 2000
    Reversible   : Y
  IP-to-IP:
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    Local VPN    : vpn4
    Global VPN   : vpn3
    ACL:         : 2000
    Reversible   : Y
Table 12 Command output
Static NAT mappings
Information about static NAT mappings.
Totally n inbound static NAT mappings
Total number of inbound static NAT mappings.
Totally n outbound static NAT mappings
Total number of outbound static NAT mappings.
Net-to-net
Net-to-net static NAT mapping.
IP-to-IP
One-to-one static NAT mapping.
Local IP
Private IP address or address range.
Global IP
Public IP address or address range.
Netmask
Network mask.
Local VPN
Global VPN
ACL
Reversible
Whether reverse address translation is allowed. If reverse address translation is allowed, this field displays Y. If reverse address translation is not allowed, this field is not displayed.
Interfaces that are enabled with static NAT.
Totally n interfaces enabled with static NAT
Total number of interfaces enabled with static NAT.
Interface enabled with static NAT.
Packet type ignore
Whether the NAT device checks the protocol packet type when TCP, ICMP, or SCTP packet exchanges trigger the creation of session entries.
·     If this field displays Y, the NAT device does not check the protocol packet type.
·     If this field is not displayed, the NAT device checks the protocol packet type.
Config status
Status of the static NAT mapping configuration:
Reasons why the static NAT mapping configuration does not take effect. This field is available when the Config status field displays Inactive. The following are possible reasons that the system might display:
·     The following items don't exist or aren't effective: local VPN, global VPN, and ACL—The MPLS L3VPN instance to which the private IP addresses belong, MPLS L3VPN instance to which the public IP addresses belong, or ACL does not exist or is not effective.
·     NAT address conflicts—A NAT address conflict occurred.
nat static
nat static net-to-net
nat static enable
display nat statistics
Use display nat statistics to display NAT statistics.
In standalone mode:
display nat statistics [ summary ] [ slot slot-number ]
In IRF mode:
display nat statistics [ summary ] [ chassis chassis-number slot slot-number ]
summary: Displays NAT statistics summary. If you do not specify this keyword, this command displays detailed NAT statistics.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays NAT statistics on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays NAT statistics on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# Display detailed information about all NAT statistics.
<Sysname> display nat statistics
Slot 0:
  Total session entries: 100
  Total EIM entries: 1
  Total inbound NO-PAT entries: 0
  Total outbound NO-PAT entries: 0
  Total PAT entries: 0
Table 13 Command output
Number of NAT session entries.
Total EIM entries
Number of EIM entries.
Number of inbound NO-PAT entries.
Number of outbound NO-PAT entries.
Total PAT entries
Number of PAT entries.
nat address-group
Use nat address-group to create a NAT address group and enter its view, or enter the view of an existing NAT address group.
Use undo nat address-group to delete a NAT address group.
nat address-group group-id [ vpn-instance vpn-instance-name ]
undo nat address-group group-id
No NAT address groups exist.
group-id: Assigns an ID to the NAT address group. The value range for this argument is 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To create an address group for the public network, do not specify this option.
A NAT address group can contain multiple address ranges.. Dynamic NAT translates the source IP address of a packet to an IP address in the address group.
For interface-based NAT, you can only use the address command to add address ranges to an address group.
Recommended configuration
In scenarios where public address resources are limited and users in different VPNs must be assigned with the same public addresses, you can bind different address groups that contain overlapping address ranges to different VPN instances.
Route advertisement
After you specify an address group for address translation, NAT advertises host routes for all addresses in the address group to the public network or VPN instance.
·     If the address group is not bound to a VPN instance, the advertised host routes belong to the public network.
·     If the address group is bound to a VPN instance, the advertised host routes belong to the VPN instance.
You can configure multiple address groups for the public network or a VPN instance. However, you must make sure they do not contain overlapping address ranges.
When you delete or edit a NAT address group, follow these restrictions and guidelines:
·     You cannot use the undo nat address-group command to delete a NAT address group in use.
·     You cannot repeat the nat address-group command to change the VPN instance bound to a NAT address group. To change the VPN instance, first execute the undo nat address-group command to delete the NAT address group. Then, execute the nat address-group command to re-create the NAT address group and bind it to a new VPN instance.
·     You can bind a NAT address group to a VPN instance when you perform either of the following tasks, but not both:
¡     Execute the nat address-group command to create the address group.
¡     Execute the nat inbound or nat outbound command to specify the address group for inbound or outbound dynamic NAT, respectively.
If the NAT address group has been bound to a VPN instance when you perform either of the tasks, you cannot specify a VPN instance for it.
# Create a NAT address group numbered 1.
[Sysname] nat address-group 1
address
display nat all
nat outbound
port-block
port-single-alloc
nat address-group-usage enable
Use nat address-group-usage enable to enable logging for resource usage in NAT address groups.
Use undo nat address-group-usage enable to disable logging for resource usage in NAT address groups.
Logging for resource usage in NAT address groups is enabled.
By default, logging for resource usage in NAT address groups is enabled. A log is generated when the resource usage in a NAT address group reaches or exceeds 90%. Disable this feature when the device outputs too many log messages or such logs are not of interest.
# Disable logging for resource usage in NAT address groups.
[Sysname] undo nat address-group-usage enable
display nat all
display nat log
nat address-group-usage threshold
Use nat address-group-usage threshold to set the threshold for resource usage in NAT address groups.
Use undo nat address-group-usage threshold to restore the default.
nat address-group-usage threshold threshold-value
The threshold for resource usage in NAT address groups is 90%.
threshold-value: Specifies a threshold in percentage. The value range is 40 to 100.
Operating mechanism
The device generates a log in the following scenarios:
·     The device reports a threshold violation event when the resource usage in a NAT address group reaches or exceeds the threshold.
·     The device reports a resource usage recovery event when the resource usage in a NAT address group drops below 87.5% of the threshold.
This command takes effect only after you enable both NAT logging and logging for resource usage in NAT address groups.
# Set the threshold for resource usage in NAT address groups to 80%.
[Sysname] nat log enable
[Sysname] nat address-group-usage enable
[Sysname] nat address-group-usage threshold 80
nat log enable
nat alg
Use nat alg to enable NAT ALG for the specified or all supported protocols.
Use undo nat alg to disable NAT ALG for the specified or all supported protocols.
nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet |tftp | xdmcp }
NAT ALG is disabled for all supported protocols except for FTP, ICMP error packets, and RTSP.
all: Enables NAT ALG for all supported protocols.
dns: Enables NAT ALG for DNS.
ftp: Enables NAT ALG for FTP.
H323: Enables NAT ALG for H323.
icmp-error: Enables NAT ALG for ICMP error packets.
ils: Enables NAT ALG for ILS.
mgcp: Enables NAT ALG for MGCP.
nbt: Enables NAT ALG for NBT.
pptp: Enables NAT ALG for PPTP.
rsh: Enables NAT ALG for RSH.
rtsp: Enables NAT ALG for RTSP.
sccp: Enables NAT ALG for SCCP.
sip: Enables NAT ALG for SIP.
sqlnet: Enables NAT ALG for SQLNET.
tftp: Enables NAT ALG for TFTP.
xdmcp: Enables NAT ALG for XDMCP.
Operating mechanism
NAT ALG translates address or port information in the application layer payload to ensure connection establishment.
For example, an FTP application includes a data connection and a control connection. The IP address and port number for the data connection depend on the payload information of the control connection. This requires NAT ALG to translate the address and port information to establish the data connection.
After you execute the nat alg h323 command, you cannot execute the nat mapping-behavior endpoint-independent { tcp | udp } * command in system view. After you execute the nat mapping-behavior endpoint-independent { tcp | udp } * command in system view, you cannot execute the nat alg h323 command.
# Enable NAT ALG for FTP.
[Sysname] nat alg ftp
display nat all
nat dns-map
Use nat dns-map to configure a NAT DNS mapping.
Use undo nat dns-map to remove a NAT DNS mapping.
nat dns-map domain domain-name protocol pro-type { interface interface-type interface-number | ip global-ip } port global-port
undo nat dns-map domain domain-name
No NAT DNS mappings exist.
domain domain-name: Specifies the domain name of an internal server. A domain name is a dot-separated case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.) (for example, example.com). The domain name can contain a maximum of 253 characters, and each separated string contains no more than 63 characters.
protocol pro-type: Specifies the type of the protocol used by the internal server, tcp or udp.
interface interface-type interface-number: Enables Easy IP to use the IP address of the interface specified by its type and number as the public address of the internal server.
ip global-ip: Specifies the public IP address used by the internal server to provide services for the external network.
port global-port: Specifies the public port number used by the internal server to provide services for the external network. The port number format can be one of the following:
·     A number in the range of 1 to 65535.
·     A protocol name, a string of 1 to 15 characters. For example, ftp and telnet.
NAT DNS mapping must cooperate with the NAT Server feature.
Operating mechanism
NAT DNS mapping maps the domain name of an internal server to the public IP address, public port number, and protocol type of the internal server. NAT Server maps the public IP and port to the private IP and port of the internal server. The cooperation allows an internal host to access an internal server on the same private network by using the domain name of the internal server when the DNS server is on the public network. The DNS reply from the external DNS server contains only the domain name and public IP address of the internal server in the payload. The NAT interface might have multiple internal servers configured with the same public IP address but different private IP addresses. DNS ALG might find an incorrect internal server by using only the public IP address. If a DNS mapping is configured, DNS ALG can obtain the public IP address, public port number, and protocol type of the internal server by using the domain name. Then it can find the correct internal server by using the public IP address, public port number, and protocol type of the internal server.
You can configure multiple NAT DNS mappings.
# Configure a NAT DNS mapping to map the domain name www.example.com to the public IP address 202.112.0.1, public port number 12345, and protocol type TCP.
[Sysname] nat dns-map domain www.example.com protocol tcp ip 202.112.0.1 port 12345
display nat all
display nat dns-map
nat server
nat log enable
Use nat log enable to enable NAT logging.
Use undo nat log enable to disable NAT logging.
nat log enable [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat log enable
acl: Specifies an ACL.
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name ipv4-acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter and to avoid confusion, it cannot be all.
You must enable NAT logging before you enable the following features: NAT session logging (logging for active NAT flows, NAT flow establishment events, and NAT flow removal events), NAT444 user logging, and logging for resource usage in NAT address groups.
The acl keyword takes effect only for NAT session logging. If an ACL is specified, flows matching the permit rule might trigger NAT session logs. If you do not specify an ACL, all flows processed by NAT might trigger NAT session logs.
# Enable NAT logging.
display nat all
display nat log
nat log flow-active
nat log flow-begin
nat log flow-end
nat log format user-mac
nat log port-block port-usage threshold
nat log port-block usage enable
nat log flow-active
Use nat log flow-active to enable logging for active NAT flows and set the logging interval.
Use undo nat log flow-active to disable logging for active NAT flows.
nat log flow-active time-value
Logging for active NAT flows is disabled.
time-value: Specifies the interval for logging active NAT flows, in the range of 10 to 120 minutes.
Active NAT flows are NAT sessions that last for a long time or undeleted EIM entries. To periodically record the connection state of active NAT flows, enable this feature.
Operating mechanism
The logging feature helps track active NAT flows by periodically logging the active NAT flows.
This command takes effect only after you use the nat log enable command to enable NAT logging.
If you specify an ACL when you execute the nat log enable command, only flows matching the permit rule might trigger active NAT flow logs. If you do not specify any ACL when you execute the nat log enable command, all flows processed by NAT might trigger active NAT flow logs.
# Enable logging for active NAT flows and set the logging interval to 10 minutes.
[Sysname] nat log flow-active 10
display nat all
display nat log
nat log enable
nat log flow-begin
Use nat log flow-begin to enable logging for NAT flow (NAT session or EIM entry)  establishment events.
Use undo nat log flow-begin to disable logging for NAT flow establishment events.
nat log flow-begin
Logging for NAT flow establishment events is disabled.
If you specify an ACL when you execute the nat log enable command, only flows matching the permit rule might trigger NAT flow establishment logs. If you do not specify any ACL when you execute the nat log enable command, all flows processed by NAT might trigger NAT flow establishment logs.
# Enable logging for NAT flow establishment events.
[Sysname] nat log flow-begin
display nat all
display nat log
nat log enable
nat log flow-end
Use nat log flow-end to enable logging for NAT flow removal events.
Use undo nat log flow-end to disable logging for NAT flow removal events.
nat log flow-end
Logging for NAT flow removal events is disabled.
If you specify an ACL when you execute the nat log enable command, only flows matching the permit rule might trigger NAT flow removal logs. If you do not specify any ACL when you execute the nat log enable command, all flows processed by NAT might trigger NAT flow removal logs.
# Enable logging for NAT flow removal events.
[Sysname] nat log flow-end
display nat all
display nat log
nat log enable
Use nat log format user-mac to configure the system logs to carry the MAC addresses of online users in a NAT+BRAS scenario.
Use undo nat log format user-mac to restore the default.
The system logs do not carry the MAC addresses of online users in a NAT+BRAS scenario.
After you configure this command, the system logs controlled by the following commands will carry the MAC addresses of online users in a NAT+BRAS scenario:
·     nat log port-block port-usage threshold
·     nat log port-alloc-fail
# Configure the system logs to carry the MAC addresses of online users in a NAT+BRAS scenario.
[Sysname] nat log format user-mac
display nat log
nat log enable
Use nat mapping-behavior endpoint-independent to specify the Endpoint-Independent Mapping mode for PAT.
Use undo nat mapping-behavior endpoint-independent to restore the default.
nat mapping-behavior endpoint-independent { tcp [ tcp-5-tuple ] | udp [ udp-5-tuple ] } *
Connection-Dependent Mapping applies.
tcp: Creates EIM entries for TCP connections.
udp: Creates EIM entries for UDP connections.
tcp-5-tuple: Creates five-tuple (source IP, source port, protocol, destination address, and destination port) session entries for TCP connections. If you do not specify this keyword, only EIM entries are created.
udp-5-tuple: Creates five-tuple (source IP, source port, protocol, destination address, and destination port) session entries for UDP connections. If you do not specify this keyword, only EIM entries are created.
PAT supports the following types of NAT mappings:
·     Endpoint-Independent Mapping—Uses the same IP and port mapping (EIM entry) for packets from the same source and port to any destination. EIM allows external hosts to access the internal hosts by using the translated IP address and port. It allows internal hosts behind different NAT gateways to access each other.
·     Connection-Dependent Mapping—Uses the same IP and port mapping for packets of the same connection. Different IP and port mappings are used for different connections although the connections might have the same source IP address and port number. It is secure because it allows an external host to access an internal host only under the condition that the internal host has previously accessed the external host.
When you specify the EIM mode for PAT, follow these restrictions and guidelines:
·     For interface-based NAT, you cannot execute the nat mapping-behavior endpoint-independent { tcp | udp } * command in system view if any one of the following commands has been executed on the device:
¡     nat static outbound.
¡     nat static outbound net-to-net.
¡     nat alg h323.
·     For interface-based NAT, you cannot execute the nat mapping-behavior endpoint-independent { tcp [ tcp-5-tuple ] | udp [ udp-5-tuple ] } * command in system view if load sharing NAT server mappings have been configured on the device.
After you execute the nat mapping-behavior endpoint-independent command, EIM entries and five-tuple session entries are always created for ICMP connections.
The existing and newly configured dynamic NO-PAT rules do not take effect if you specify the Endpoint-Independent Mapping mode for outbound dynamic PAT rules.
# Apply the Endpoint-Independent Mapping mode and create EIM entries for TCP packet address translation.
[Sysname] nat mapping-behavior endpoint-independent tcp
display nat eim
nat outbound
nat server (interface-based NAT)
nat static outbound
nat outbound
Use nat outbound to configure an outbound dynamic NAT rule.
Use undo nat outbound to delete an outbound dynamic NAT rule.
NO-PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] address-group group-id [ vpn-instance vpn-instance-name ] no-pat [ reversible ]
undo nat outbound [ ipv4-acl-number | name ipv4-acl-name ]
PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] [ address-group group-id ] [ vpn-instance vpn-instance-name ] [ port-preserved ]
No outbound dynamic NAT rules exist.
Interface view
address-group group-id: Specifies an address group for NAT. The value range for the group-id argument is 0 to 65535. If you do not specify an address group, the IP address of the interface is used as the NAT address. Easy IP is used.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the addresses in the address group belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the addresses in the address group do not belong to any VPN instance, do not specify this option.
no-pat: Uses NO-PAT for outbound NAT. If you do not specify this keyword, PAT is used. PAT only supports TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the external network to the internal network. To deploy configuration successfully, do not specify this keyword after you enable hardware NAT.
port-preserved: Tries to preserve port number for PAT.
For outbound dynamic NAT, address mappings between the private and public networks are dynamically generated during connection establishment. Use outbound dynamic NAT in scenarios where a large number of internal users need to access the external network.
Operating mechanism
Outbound dynamic NAT supports the following modes:
·     PAT—Performs both IP address translation and port translation. The PAT mode allows external hosts to actively access the internal hosts if the Endpoint-Independent Mapping behavior is used.
·     NO-PAT—Performs only IP address translation. The NO-PAT mode allows external hosts to actively access the internal hosts if you specify the reversible keyword. If an ACL is specified, reverse address translation only applies to packets permitted by ACL reverse matching. ACL reverse matching works as follows:
¡     Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
¡     Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
When you specify a NAT address group, follow these restrictions and guidelines:
·     An address group cannot be used by the nat outbound command in both PAT and NO-PAT modes.
·     You can bind a NAT address group to a VPN instance when you execute the nat address-group or nat outbound command, but not both. If you have bound a NAT address group to a VPN instance by using one command, you cannot bind it to a VPN instance when you execute the other command.
If you specify the EIM mode for PAT by executing the nat mapping-behavior endpoint-independent command in system view, NO-PAT configurations do not take effect.
When you specify an ACL, follow these restrictions and guidelines:
·     After you enable hardware NAT, the ACL can only filter packets by IP address, port number, protocol type, and VPN.
·     An ACL can be used by only one outbound dynamic NAT rule on an interface or in a NAT instance.
·     If you configure multiple outbound dynamic NAT rules, only one outbound dynamic NAT rule can contain no ACL.
·     If you specify an ACL, NAT translates the source IP addresses of outgoing packets permitted by the ACL into IP addresses in the address group. If you do not specify an ACL, NAT translates all packets.
·     Outbound dynamic NAT rules with ACLs configured on an interface or in a NAT instance take precedence over those without ACLs. The device matches packets against ACLs based on either the ACL names or ACL numbers. ACL names take precedence over ACL numbers.
¡     ACL names—The device matches packets based on the alphabetical order of the ACL names.
¡     ACL numbers—A higher ACL number indicates higher priority.
When you add outbound dynamic NAT rules, follow these restrictions and guidelines:
·     An ACL uniquely identifies an outbound dynamic NAT rule. If an outbound dynamic NAT rule does not reference an ACL, it permits all packets to pass. You cannot edit an outbound dynamic NAT rule by repeating this command. For example, you cannot repeat this command to change the PAT mode to NO-PAT mode. To edit a rule, use the undo nat outbound command to delete the rule first, and then execute the nat outbound command.
·     You can repeat this command to configure multiple outbound dynamic NAT rules with different ACLs specified on an interface or in a NAT instance.
The vpn-instance parameter is required if you deploy outbound dynamic NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
# Configure ACL 2001 to permit packets only from subnet 10.110.10.0/24 to pass through.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 10.110.10.0 0.0.0.255
[Sysname-acl-ipv4-basic-2001] rule deny
# Create address group 1 and add the address range of 202.110.10.10 to 202.110.10.12 to the group.
[Sysname-address-group-1] address 202.110.10.10 202.110.10.12
[Sysname-address-group-1] quit
# Configure an outbound dynamic PAT rule on interface Ten-GigabitEthernet 0/0/15 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname] interface ten-gigabitethernet 0/0/15
[Sysname-Ten-GigabitEthernet0/0/15] nat outbound 2001 address-group 1
[Sysname-Ten-GigabitEthernet0/0/15] quit
Or
# Configure an outbound NO-PAT rule on interface Ten-GigabitEthernet 0/0/15 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-Ten-GigabitEthernet0/0/15] nat outbound 2001 address-group 1 no-pat
Or
# Enable Easy IP to use the IP address of Ten-GigabitEthernet 0/0/15 as the translated address.
[Sysname-Ten-GigabitEthernet 0/0/15] nat outbound 2001
[Sysname-Ten-GigabitEthernet 0/0/15] quit
Or
# Configure an outbound NO-PAT rule on Ten-GigabitEthernet 0/0/15 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1. Enable reverse address translation.
[Sysname-Ten-GigabitEthernet0/0/15] nat outbound 2001 address-group 1 no-pat reversible
address
display nat eim
nat static enable
Use nat static enable to enable static NAT on an interface.
Use undo nat static enable to disable static NAT on an interface.
nat static enable
Static NAT is disabled.
Interface view
Static NAT mappings take effect on an interface only after you enable static NAT on the interface.
# Configure an outbound static NAT mapping between private IP address 192.168.1.1 and public IP address 2.2.2.2, and enable static NAT on Ten-GigabitEthernet 0/0/15.
[Sysname] nat static outbound 192.168.1.1 2.2.2.2
[Sysname-Ten-GigabitEthernet0/0/15] nat static enable
display nat all
display nat static
nat static
nat static outbound
Use nat static outbound to configure a one-to-one mapping for outbound static NAT.
Use undo nat static outbound to remove a one-to-one mapping for outbound static NAT.
nat static outbound local-ip [ vpn-instance local-vpn-instance-name ] global-ip [ vpn-instance global-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ packet-type-ignore ]
undo nat static outbound local-ip [ vpn-instance local-vpn-instance-name ]
No NAT mappings exist.
local-ip: Specifies a private IP address.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private IP address belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private IP address does not belong to any VPN instance, do not specify this option.
global-ip: Specifies a public IP address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public IP address belongs. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP address does not belong to any VPN instance, do not specify this option.
acl: Specifies an ACL to define the destination IP addresses that internal hosts can access. To deploy configuration successfully, do not specify this keyword after you enable hardware NAT.
ipv4-acl-number: Specifies an ACL by its number in the range of 3000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the external network to the public IP address. To deploy configuration successfully, do not specify this keyword after you enable hardware NAT.
packet-type-ignore: Ignores the protocol packet type when the device creates session entries for TCP, ICMP, or SCTP. If you do not specify this keyword, the NAT device checks the protocol packet type and creates session entries for only protocol packets that pass the check. For example, the NAT device creates session entries for TCP packets only when the packet type is SYN or ACK.
Operating mechanism
When the source IP address of an outgoing packet matches the local-ip, the IP address is translated into the global-ip. When the destination IP address of an incoming packet matches the global-ip, the destination IP address is translated into the local-ip.
Static NAT takes precedence over dynamic NAT when both are configured on an interface.
You can configure multiple outbound static NAT mappings by using the nat static outbound command and the nat static outbound net-to-net command.
The vpn-instance parameter is required if you deploy outbound static NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
In an asymmetric routing scenario, if a session contains different types of protocol packets that are forwarded by different NAT devices, protocol packets of some types might be discarded. As a result, session status cannot be updated through protocol packet exchanges, causing abnormal service traffic forwarding. To avoid such an issue, specify the packet-type-ignore keyword when you use this command.
·     If you do not specify an ACL, the source address of all outgoing packets and the destination address of all incoming packets are translated.
·     If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP address.
·     If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
¡     Translates the destination IP address of the packet according to the mapping, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
After you execute the nat static outbound command, you cannot execute the nat mapping-behavior endpoint-independent { tcp | udp } * command in system view. After you execute the nat mapping-behavior endpoint-independent { tcp | udp } * command in system view, you cannot execute the nat static outbound command.
# Configure an outbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
# Configure outbound static NAT, and allow the internal user 192.168.1.1 to access the external network 3.3.3.0/24 by using the public IP address 2.2.2.2.
[Sysname] acl advanced 3001
[Sysname-acl-ipv4-adv-3001] rule permit ip destination 3.3.3.0 0.0.0.255
[Sysname-acl-ipv4-adv-3001] quit
[Sysname] nat static outbound 192.168.1.1 2.2.2.2 acl 3001
display nat all
display nat static
nat static enable
Use nat static outbound net-to-net to configure a net-to-net outbound static NAT mapping.
Use undo nat static outbound net-to-net to remove the specified net-to-net outbound static NAT mapping.
nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-vpn-instance-name ] global global-network { mask-length | mask } [ vpn-instance global-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ]
undo nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-vpn-instance-name ]
local-start-address local-end-address: Specifies a private address range which can contain a maximum of 256 addresses. The local-end-address must not be lower than local-start-address. If they are the same, only one private address is specified.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private IP addresses belong. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private IP addresses do not belong to any VPN instance, do not specify this option.
global-network: Specifies a public network address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public network address belongs. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public network address does not belong to any VPN instance, do not specify this option.
mask-length: Specifies the mask length of the public network address, in the range of 8 to 31.
mask: Specifies the mask of the public network address.
ipv4-acl-number: Specifies an ACL number in the range of 3000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the external network to the public IP addresses. For the configuration to take effect, specify a CGN-type failover group. To deploy configuration successfully, do not specify this keyword after you enable hardware NAT.
Operating mechanism
Specify a private network through a start address and an end address, and a public network through a public address and a mask.
When the source address of a packet from the internal network matches the private address range, the source address is translated into a public address in the public address range. When the destination address of a packet from the external network matches the public address range, the destination address is translated into a private address in the private address range.
The private end address cannot be greater than the greatest IP address in the subnet determined by the private start address and the public network mask. For example, the public address is 2.2.2.0 with a mask 255.255.255.0, and the private start address is 1.1.1.100. The private end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
·     If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP addresses.
·     If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
After you execute the nat static outbound net-to-net command, you cannot execute the nat mapping-behavior endpoint-independent { tcp | udp } * command in system view. After you execute the nat mapping-behavior endpoint-independent { tcp | udp } * command in system view, you cannot execute the nat static outbound net-to-net command.
# Configure an outbound static NAT mapping between private network address 192.168.1.0/24 and public network address 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24
# Configure outbound static NAT. Allow internal users on subnet 192.168.1.0/24 to access the external subnet 3.3.3.0/24 by using public IP addresses on subnet 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24 acl 3001
display nat all
display nat static
nat static enable
reset nat eim
Use reset nat eim to delete NAT EIM entries.
In standalone mode:
reset nat eim [ protocol { icmp | tcp | udp } ] [ local-ip { b4 ipv6-address | local-ip } ] [ local-port local-port ] [ global-ip global-ip ] [ global-port global-port ] [ local-vpn local-vpn-instance-name ] [ slot slot-number ]
In IRF mode:
reset nat eim [ protocol { icmp | tcp | udp } ] [ local-ip { b4 ipv6-address | local-ip } ] [ local-port local-port ] [ global-ip global-ip ] [ global-port global-port ] [ local-vpn local-vpn-instance-name ] [ chassis chassis-number slot slot-number ]
protocol: Specifies a protocol by its type. If you do not specify this keyword, the command deletes NAT EIM entries of all protocol types.
local-ip b4 ipv6-address: Deletes the EIM entry for a B4 device IPv6 address. The ipv6-address argument specifies the IPv6 address of a B4 device.
local-ip local-ip: Deletes the EIM entry for a private IP address. The local-ip argument specifies a private IP address.
local-port local-port: Deletes the EIM entry for a private port. The local-port argument specifies a private port number in the range of 0 to 65535.
global-ip global-ip: Deletes the EIM entry for a public IP address. The global-ip argument specifies a public IP address.
global-port global-port: Deletes the EIM entry for a public port. The global-port argument specifies a public port number in the range of 0 to 65535.
local-vpn vpn-instance-name: Deletes EIM entries that contain the specified MPLS L3VPN instance to which private users belong. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must be the VPN instance carried in the packets sent from the private users to the public network, which corresponds to Local VPN for address translation.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command deletes NAT EIM entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command deletes NAT EIM entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
If you do not specify the local-ip, local-port, global-ip, local-vpn, or global-port keyword, this command deletes all EIM entries for ICMP, TCP, and UDP protocols.
# (In standalone mode.) Delete all NAT EIM entries for the specified slot.
<Sysname> reset nat eimslot 0
display nat session
reset nat session
Use reset nat session to clear NAT sessions.
In standalone mode:
reset nat session [ protocol { tcp | udp } ] [ slot slot-number ]
In IRF mode:
reset nat session [ protocol { tcp | udp } ] [ chassis chassis-number slot slot-number ]
protocol: Specifies a protocol by its type. If you do not specify this keyword, the command clears NAT sessions of all protocol types.
tcp: Specifies the TCP protocol.
udp: Specifies the UDP protocol.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears NAT sessions on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears NAT sessions on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# (In standalone mode.) Clear NAT sessions for the specified slot.
<Sysname> reset nat session slot 0
display nat session
snmp-agent trap enable nat
Use snmp-agent trap enable nat to enable SNMP notifications for NAT.
Use undo snmp-agent trap enable nat to disable SNMP notifications for NAT.
snmp-agent trap enable nat [ address-group-usage ]
undo snmp-agent trap enable nat [ address-group-usage ]
SNMP notifications are enabled for NAT.
address-group-usage: Enables SNMP notifications for the resource usage in a NAT address group.
The device generates an SNMP notification in the following scenarios:
If SNMP notifications are enabled for the address group resource usage:
·     The device reports a threshold violation event when the address group resource usage reaches or exceeds the threshold.
·     The device reports a threshold recovery event when the address group resource usage drops below 87.5% of the threshold from a threshold crossing value.
To set the threshold for address group resource usage, execute the nat address-group-usage threshold command.
For the notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
To enable or disable all SNMP notifications for NAT, do not specify any parameters.
# Enable all SNMP notifications for NAT.
[Sysname] snmp-agent trap enable nat
Interface-based NAT commands
display nat address-group resource-usage
Use display nat address-group resource-usage to display the NAT address group resource usage.
display nat address-group [ group-id ] resource-usage [ verbose ]
group-id: Specifies the ID of a NAT address group. The value range for this argument varies by device model. If you do not specify this argument, the command displays the address usage of all NAT address groups.
verbose: Displays the overall resource usage of a NAT address group and the resource usage of each group member. If you do not specify this keyword, the command displays only the overall resource usage of the NAT address group.
The resource usage of a NAT address group includes the following information:
·     Address usage—Ratio of the number of used IP addresses to the total number of IP addresses. The used IP addresses are public IP addresses that have been assigned to users for address translation.
·     Port usage—Ratio of the number of assigned ports to the total number of ports. If you set the maximum number of VPN users sharing one single public address in PAT mode by using the nat per-global-ip user-limit command, the port usage might be different. This is normal and needs no actions.
# Display the address resource usage of NAT address group 1.
<Sysname> display nat address-group 1 resource-usage
  Address group name/ID: group1/1
    VPN instance: vpn1
    Port range: 1024-10000
    Nat per-global-ip user-limit:4096
    Port-single-alloc
    Total IP addresses: 12
    Used IP addresses: 12
    IP usage: 100%
    Port usage: 12%
    Address information:
      Start address         End address
      202.110.10.10         202.110.10.15
      202.110.10.20         202.110.10.25
    Config status: Active
Table 14 Command output
Totally n NAT address groups
Total number of NAT address groups.
Name and ID of the NAT address group.
VPN instance
Name of the VPN instance to which the NAT address group is bound. The command output does not display this field if you did not bind the NAT address group to a VPN instance when you executed the nat address-group command.
Port range
Port range for public IP addresses.
Maximum number of VPN users sharing one single public address in PAT mode.
Port-single-alloc
Port-by-port allocation method. This field is not displayed if this method is not set.
Instance name/ID
Name and ID of the NAT instance bound to the NAT address group.
Total IP addresses
Total number of IP addresses that the NAT address group contains. This field displays 0 if no failover group is bound to the NAT address group.
Used IP addresses
Total number of IP addresses that the NAT address group has used. This field displays 0 if no failover group is bound to the NAT address group.
IP usage
Address usage of the NAT address group. The value is displayed as follows:
·     If the address usage is greater than 0% but less than 1%, this field displays 1%.
·     If the address usage is greater than 1%, this field displays a value that is rounded down to the nearest integer.
Port usage
Port usage of the NAT address group. The value is displayed as follows:
·     If the port usage is greater than 0% but less than 1%, this field displays 1%.
·     If the port usage is greater than 1%, this field displays a value that is rounded down to the nearest integer.
Address information
Information about the address ranges in the address group.
Start address
Start IP address of an address range. If you do not specify a start address, this field displays three hyphens (---).
End address
End IP address of an address range. If you do not specify an end address for the range, this field displays three hyphens (---).
Config status
Status of the NAT address group:
·     Active—The NAT address group is taking effective.
·     Inactive—The NAT address group is not taking effective.
Reasons for inactive status
Reasons why the NAT address group configuration does not take effect. This field is available when the Config status field displays Inactive.
·     The following items don't exist: address, and VPN instance
·     The following items don't exist: VPN instance
# Display the overall resource usage of all NAT address groups and the resource usage of each group member.
<Sysname> display nat address-group resource-usage verbose
NAT address group information:
  Totally 1 NAT address groups.
  Address group name/ID: 1/1
    Port range: 1000-1020
    Instance name/ID: a/1
    Total IP addresses: 51
    IP usage: 1%
    Port usage: 1%
    Port usage of group members:
      Start address         End address         Port usage
      110.1.1.1             110.1.1.1           100%
      111.1.1.1             111.1.1.50          0%
Table 15 Command output
VPN instance
Port range
TCP port limit
Maximum number of ports that can be assigned to the TCP protocol. This field is not displayed if the maximum number is not set.
UDP port limit
Maximum number of ports that can be assigned to the UDP protocol. This field is not displayed if the maximum number is not set.
ICMP port limit
Maximum number of ports that can be assigned to the ICMP protocol. This field is not displayed if the maximum number is not set.
Port limit in total
Maximum number of ports that can be assigned to the TCP, UDP, and ICMP protocols. This field is not displayed if the maximum number is not set.
Instance name/ID
Name and ID of the NAT instance.
IP usage
·     This field displays 0 if no failover group is bound to the NAT address group.
Port usage
Port usage of the address ranges in the address group. This field displays 0 if no failover group is bound to the NAT address group.
Start address
End address
End IP address of an address range. If you do not specify an end address, this field displays three hyphens (---).
Config status
Reasons why the NAT address group configuration does not take effect. This field is available when the Config status field displays Inactive. Possible reasons:
nat address-group
display nat server-group
Use display nat server-group to display internal server group configuration.
display nat server-group [ group-id ]
group-id: Specifies the ID of the internal server group. The value range for this argument is 0 to 65535. If you do not specify this argument, the command displays configuration about all internal server groups.
# Display configuration about all internal server groups.
<Sysname> display nat server-group
NAT server group information:
  Totally 3 NAT server groups.
  Group Number        Inside IP             Port        Weight
  1                   192.168.0.26          23          100
                      192.168.0.27          23          500
  2                   ---                   ---         ---
  3                   192.168.0.26          69          100
# Display configuration about internal server group 1.
<Sysname> display nat server-group 1
                      192.168.0.27          23          500
Table 16 Command output
Information about NAT server groups.
Totally n NAT server groups
Total number of NAT server groups.
Group Number
Inside IP
Private IP address of a member in the internal server group. If no address is specified, this field displays hyphens (---).
Port
Private port number of a member in the internal server group. If no port number is specified, this field displays hyphens (---).
Weight
Weight of a member in the internal server group. If no weight value is specified, this field displays hyphens (---).
nat server-group
inside ip
Use inside ip to add a member to an internal server group.
Use undo inside ip to remove a member from an internal server group.
inside ip inside-ip port port-number [ weight weight-value ]
undo inside ip inside-ip port port-number
No members exist in an internal server group.
Internal server group view
inside-ip: Specifies the IP address of an internal server. You can add a maximum of 16 members to an internal server group.
port port-number: Specifies the port number of an internal server, in the range of 1 to 65535.
weight weight-value: Specifies the weight of the internal server. The value range is 1 to 1000, and the default value is 100. An internal server with a larger weight receives a larger percentage of connections in the internal server group.
# Add a member with IP address 10.1.1.2 and port number 30 to internal server group 1.
[Sysname] nat server-group 1
[Sysname-nat-server-group-1] inside ip 10.1.1.2 port 30
nat server-group
nat hairpin enable
Use nat hairpin enable to enable NAT hairpin.
Use undo nat hairpin enable to disable NAT hairpin.
nat hairpin enable
NAT hairpin is enabled, and cannot be disabled.
Interface view
Application scenarios
NAT hairpin allows internal hosts to access each other or allows internal hosts to access internal servers. It must cooperate with NAT Server, outbound dynamic NAT, or outbound static NAT. The source and destination IP addresses of the packets are translated on the interface connected to the internal network.
After you enable hardware NAT by using the nat hardware-mode enable command, the device automatically enables NAT hairpin on all interfaces. You cannot enable or disable NAT hairpin on interfaces by using the nat hairpin enable or undo nat hairpin enable command, respectively. If you enable NAT hairpin on interfaces first, the device automatically deletes configuration for the nat hairpin enable command once hardware NAT is enabled.
# Enable NAT hairpin on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] nat hairpin enable
display nat all
Use nat hardware-mode enable to enable hardware NAT.
Use undo nat hardware-mode enable to disable hardware NAT.
Hardware NAT is disabled.
For software NAT, the CPU processes NAT services. Software NAT has high requirements for CPU performance.
For hardware NAT, the hardware chip processes NAT services. Hardware NAT transfers the features that consume CPU performance to the hardware chip for processing, so that the CPU can timely process other important tasks. Hardware NAT performance is not limited by the CPU performance.
Hardware NAT is provided by the hardware chip of an interface card, which is applicable to scenarios that have high requirements for NAT processing performance. In the current software version, hardware NAT supports few commands, and only interface-based NAT supports hardware NAT.
Enable hardware NAT on the device in scenarios that meet the following conditions:
·     The device is installed with an interface card that supports hardware NAT.
·     The commands supported by hardware NAT can meet service requirements.
·     The scenarios have high requirements for NAT processing performance.
As a best practice, do not enable hardware NAT in other scenarios.
When you use the hardware chip of an interface card for processing NAT services, redirect traffic to the interface card as follows:
·     To redirect traffic from the public network to the private network, use the nat service command and specify the interface card.
·     To redirect traffic from the private network to the public network, configure a QoS policy to redirect traffic to the interface card specified in the nat service command.
Hardware NAT supports the following commands:
·     nat address-group
·     address
·     nat alg
·     nat hairpin enable
·     nat log enable
·     nat log flow-begin
·     nat log flow-end
·     nat outbound
·     nat server
·     nat service
·     nat static enable
·     nat static inbound
·     nat static inbound net-to-net
·     nat static outbound
·     nat static outbound net-to-net
For information about support for the parameters in a command, see the corresponding command in this document.
After you enable hardware NAT and complete NAT settings, you can use the following commands to display and verify the configuration. To clear NAT sessions, execute the reset command in user view.
·     display nat address-group
·     display nat all
·     display nat log
·     display nat outbound
·     display nat server
·     display nat session
·     display nat static
·     display nat statistics
·     reset nat session
When you enable or disable hardware NAT, follow these restrictions and guidelines:
·     After you execute the nat hardware-mode enable command, the device automatically deletes configuration not supported by hardware NAT.
·     If you execute the nat hardware-mode enable command and then execute the undo nat hardware-mode enable command, the device does not restore the deleted configuration.
·     When you enable or disable hardware NAT, the device automatically deletes all the existing session entries and relation entries.
# Enable hardware NAT.
[Sysname] nat hardware-mode enable
address
display nat all
display nat log
display nat server
display nat session
display nat static
nat address-group
nat alg
nat hairpin enable
nat log enable
nat log flow-begin
nat log flow-end
nat outbound
nat server
nat service
nat static enable
nat static inbound
nat static outbound
reset nat session
nat hardware-mode port-alloc
Use nat hardware-mode port-alloc to set the maximum number of attempts for hardware NAT to allocate ports in PAT mode.
Use undo nat hardware-mode port-alloc to restore the default.
nat hardware-mode port-alloc number
Hardware NAT attempts to allocate ports in PAT mode up to three times.
number: Specifies the maximum number of attempts for hardware NAT to allocate ports. The value range is 3 to 255.
When the device enabled with hardware NAT allocates ports, a conflict in five-tuple after NAT or a port collision causes port allocation failure. In this case, the NAT device automatically attempts to allocate another available port to the private user. Use this command to set the maximum number of attempts for hardware NAT to allocate ports.
More port collisions indicate greater network delay and processing workload, affecting network performance. As a best practice, use the default setting. To change the maximum number of attempts for hardware NAT to allocate ports, contact H3C Support to make sure the specified maximum number can meet service expectations.
This command takes effect only after you enable hardware NAT by using the nat hardware-mode enable command.
# Set the maximum number of attempts to 10 for hardware NAT to allocate ports in PAT mode.
[Sysname] nat hardware-mode port-alloc 10
nat hardware-mode server-limit
Use nat hardware-mode server-limit to set the maximum number of sessions that all public users can establish to access internal servers for hardware NAT.
Use undo nat hardware-mode server-limit to restore the default.
nat hardware-mode server-limit number
All public users can establish up to 262144 sessions to access internal servers for hardware NAT.
number: Specifies the maximum number of sessions that all public users can establish to access internal servers for hardware NAT. The value range is 1 to 1048575.
Too many sessions established by public users to access internal servers consume a large number of device session resources. As a result, other users cannot establish new sessions. Use this command to set the maximum number of sessions that all public users can establish to access internal servers.
As a best practice, use the default setting. To change the maximum number of sessions that all public users can establish to access internal servers for hardware NAT, contact H3C Support to make sure the specified maximum number can meet service expectations.
# Set the maximum number of sessions that all public users can establish to access internal servers for hardware NAT to 30000.
[Sysname] nat hardware-mode server-limit 30000
nat hardware-mode user-limit
Use nat hardware-mode user-limit to set the maximum number of sessions that can be established per user for hardware NAT.
Use undo nat hardware-mode user-limit to restore the default.
nat hardware-mode user-limit number
A user can establish up to 1024 sessions for hardware NAT.
number: Specifies the maximum number of sessions that can be established per user for hardware NAT, in the range of 1 to 65535.
Too many sessions established by a single user consume a large number of device port resources and session resources. As a result, other users cannot establish new connections to access the external network. Use this command to set the maximum number of sessions that can be established per user.
As a best practice, use the default setting. To change the maximum number of sessions that can be established per user for hardware NAT, contact H3C Support to make sure the specified maximum number can meet service expectations.
# Set the maximum number of sessions that can be established per user for hardware NAT to 5000.
[Sysname] nat hardware-mode user-limit 5000
nat server
Use nat server to create a NAT server mapping (also called NAT server rule). The mapping maps the private IP address and port of an internal server to a public address and port.
Use undo nat server to delete a mapping.
Common NAT server mapping:
·     A single public address with no or a single public port:
nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ] inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ reversible ]
undo nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ]
·     A single public address with consecutive public ports:
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ] inside { { local-address | local-address1 local-address2 } local-port | local-address local-port1 local-port2 } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ]
·     Consecutive public addresses with no single public port:
nat server protocol pro-type global global-address1 global-address2 [ vpn-instance global-vpn-instance-name ] inside { local-address | local-address1 local-address2 } [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat server protocol pro-type global global-address1 global-address2 [ global-port ] [ vpn-instance global-vpn-instance-name ]
·     Consecutive public addresses with a single public port:
nat server protocol pro-type global global-address1 global-address2 global-port [ vpn-instance global-vpn-instance-name ] inside { local-address [ local-port1 local-port2 ] | [ local-address | local-address1 local-address2 ] [ local-port ] } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat server protocol pro-type global global-address1 global-address2 global-port [ vpn-instance global-vpn-instance-name ]
Load sharing NAT server mapping:
nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-vpn-instance-name ] inside server-group group-id [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-vpn-instance-name ]
ACL-based NAT server mapping:
nat server global { ipv4-acl-number | name ipv4-acl-name } inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ]
undo nat server global { ipv4-acl-number | name ipv4-acl-name }
No NAT server mappings exist.
Interface view
protocol pro-type: Specifies a protocol type. When the protocol is TCP or UDP, NAT Server can be configured with port information. If you do not specify a protocol type, the command applies to packets of all protocols. The protocol type format can be one of the following:
·     A number in the range of 1 to 255.
·     A protocol name of icmp, tcp, or udp.
global: Specifies the external network information that the server uses to provide services to the external network.
global-address: Specifies the public address of an internal server.
global-address1 global address2: Specifies a public IP address range, which can include a maximum of 10000 addresses. The global-address1 argument specifies the start address, and the global address2 argument specifies the end address that must be greater than the start address.
current-interface: Enables Easy IP on the current interface. The primary IP address of the interface is used as the public address for the internal server.
interface interface-type interface-number: Enables Easy IP on the interface specified by its type and number. The primary IP address of the interface is used as the public address for the internal server. Only loopback interfaces are supported.
global-port: Specifies the public port number. The public port number format can be one of the following:
·     A protocol name, a string of 1 to 15 characters. For example, http and telnet.
global-port1 global-port2: Specifies a public port number range, which can include a maximum of 256 ports. The global-port1 argument specifies the start port, and the global-port2 argument specifies the end port that must be greater than the start port. The public port number format can be one of the following:
·     A number in the range of 1 to 65535. Both the start port and the end port support this format.
·     A protocol name, a string of 1 to 15 characters. For example, http and telnet. Only the start port supports this format.
inside: Specifies the internal information of the server.
local-address: Specifies the private IP address of an internal server.
local-address1 local-address2: Specifies a private IP address range. The local-address1 argument specifies the start address, and the local-address2 argument specifies the end address that must be greater than the start address. The number of addresses in the range must equal the number of ports in the public port number range.
local-port: Specifies the private port number. The private port number format can be one of the following:
·     A number in the range of 1 to 65535, excluding FTP port 20.
local-port1 local-port2: Specifies a private port number range, which can include a maximum of 256 ports. The local-port1 argument specifies the start port, and the local-port2 argument specifies the end port that must be greater than the start port. The private port number format can be one of the following:
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public IP addresses of NAT server mappings belong. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP addresses do not belong to any VPN instance, do not specify this option.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the internal server belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the internal server does not belong to any VPN instance, do not specify this option.
server-group group-id: Specifies the internal server group to which the internal server belongs. With this parameter, the load sharing NAT Server feature is configured. The group-id argument specifies the internal server group ID. The value range for this argument is 0 to 65535. This option is not supported by hardware NAT.
acl: Specifies an ACL. If you specify an ACL, only packets permitted by the ACL can be translated by using the mapping. This keyword is not supported by hardware NAT.
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by internal servers to the external network. It translates the private IP addresses of the internal servers to their public IP addresses.
You can configure the NAT server mapping to allow internal servers (such as Web, FTP, Telnet, POP3, and DNS servers) in the internal network or an MPLS VPN instance to provide services for external users.
Operating mechanism
NAT server mappings are usually configured on the interface connected to the external network on a NAT device. By using the global-address and global-port arguments, external users can access the internal server at local-address and local-port.
The following table describes the address-port mappings between an external network and an internal network for NAT Server.
Table 17 Address-port mappings for NAT Server
External network
Internal network
One public address
One private address
One public address and one public port number
One private address and one private port number
One public address and N consecutive public port numbers
N consecutive private addresses and one private port number
One private address and N consecutive private port numbers
N consecutive public addresses
One private address
N consecutive public addresses and one public port number
One internal server group
Public addresses matching an ACL
One private address
Recommended configuration (internal servers using Easy IP)
As a best practice, do not configure Easy IP for multiple internal servers by using the same interface.
If the IP address of an interface used by Easy IP changes and conflicts with the IP address of an internal server not using Easy IP, the Easy IP configuration becomes invalid. If the conflicted address is modified to an unconflicting address or the internal server configuration without Easy IP is removed, the Easy IP configuration takes effect.
Recommended configuration (load shared internal servers)
When you configure load shared internal servers, you must make sure a user uses the same public address and public port to access the same service on an internal server. For this purpose, make sure value N in the following mappings is equal to or less than the number of servers in the internal server group:
·     One public address and N consecutive public port numbers are mapped to one internal server group.
·     N consecutive public addresses and one public port number are mapped to one internal server group.
Recommended configuration (VPN networks)
The vpn-instance parameter is required if you deploy NAT Server for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
The number of the nat server commands that can be configured on an interface varies by device model. The mapping of the protocol type, public address, and public port number must be unique for an internal server on an interface. This restriction also applies when Easy IP is used. The number of internal servers that each command can define equals the number of public ports in the specified public port range.
When the protocol type is not udp (protocol number 17) or tcp (protocol number 6), you can configure only one-to-one IP address mappings. To avoid incorrect operation of NAT and packet loss, do not specify the same IP address for the global-address argument and the local-address argument.
After you configure load sharing NAT server mappings, you cannot execute the nat mapping-behavior endpoint-independent { tcp [ tcp-5-tuple ] | udp [ udp-5-tuple ] } * command in system view. After you execute the nat mapping-behavior endpoint-independent { tcp [ tcp-5-tuple ] | udp [ udp-5-tuple ] } * command in system view, you cannot configure load sharing NAT server mappings.
For ACL-based NAT server mappings, the device matches packets against ACLs based on either the ACL names or ACL numbers. ACL names take precedence over ACL numbers.
·     ACL names—The device matches packets based on the alphabetical order of the ACL names.
·     ACL numbers—A higher ACL number indicates higher priority.
# Allow external users to access the internal Web server at 10.110.10.10 through https://202.110.10.10:8080.
[Sysname-Ten-GigabitEthernet0/0/15] nat server protocol tcp global 202.110.10.10 8080 inside 10.110.10.10 https
# Allow external users to access the internal FTP server at 10.110.10.11 in the VPN instance vrf10 through ftp://202.110.10.10.
[Sysname-Ten-GigabitEthernet0/0/15] nat server protocol tcp global 202.110.10.10 21 inside 10.110.10.11 vpn-instance vrf10
# Allow external hosts to ping the host at 10.110.10.12 in the VPN instance vrf10 by using the ping 202.110.10.11 command.
[Sysname-Ten-GigabitEthernet0/0/15] nat server protocol icmp global 202.110.10.11 inside 10.110.10.12 vpn-instance vrf10
# Allow external hosts to access the Telnet services of internal servers at 10.110.10.1 to 10.110.10.100 in the VPN instance vrf10 through the public address 202.110.10.10 and port numbers from 1001 to 1100. As a result, a user can Telnet to 202.110.10.10:1001 to access 10.110.10.1, Telnet to 202.110.10.10:1002 to access 10.110.10.2, and so on.
[Sysname-Ten-GigabitEthernet0/0/15] nat server protocol tcp global 202.110.10.10 1001 1100 inside 10.110.10.1 10.110.10.100 telnet vpn-instance vrf10
# Configure ACL-based NAT Server to allow users to use IP addresses in subnet 192.168.0.0/24 to access the internal server at 10.0.0.172.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule 5 permit ip destination 192.168.0.0 0.0.0.255
[Sysname-Ten-GigabitEthernet0/0/15] nat server global 3000 inside 10.0.0.172
display nat all
display nat server
nat server-group
nat server-group
Use nat server-group to create an internal server group and enter its view, or enter the view of an existing internal server group.
Use undo nat server-group to delete an internal server group.
nat server-group group-id
undo nat server-group group-id
No internal server groups exist.
group-id: Assigns an ID to the internal server group. The value range for this argument is 0 to 65535.
An internal server group can contain multiple members configured by the inside ip command.
# Create internal server group 1.
display nat all
inside ip
nat server
nat static inbound
Use nat static inbound to configure a one-to-one mapping for inbound static NAT.
Use undo nat static inbound to delete a one-to-one mapping for inbound static NAT.
nat static inbound global-ip [ vpn-instance global-vpn-instance-name ] local-ip [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ packet-type-ignore ]
undo nat static inbound global-ip [ vpn-instance global-vpn-instance-name ]
acl: Specifies an ACL to identify the internal hosts that can access the external network. To deploy configuration successfully, do not specify this keyword after you enable hardware NAT.
name ipv4-acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter and to avoid confusion, it cannot be all.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP address. To deploy configuration successfully, do not specify this keyword after you enable hardware NAT.
For address translation from a public IP address to a private IP address, configure inbound one-to-one static NAT.
·     When the destination IP address of a packet from the private network to the public network matches the local-ip, the destination IP address is translated into the global-ip.
·     When the source IP address of a packet from the public network to the private network matches the global-ip, the source IP address is translated into the local-ip.
·     If you do not specify an ACL, the source address of all incoming packets and the destination address of all outgoing packets are translated.
·     If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP address.
·     If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
You can configure multiple inbound static NAT mappings by using the nat static inbound command and the nat static inbound net-to-net command.
The vpn-instance parameter is required if you deploy inbound static NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
# Configure an inbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
[Sysname] nat static inbound 2.2.2.2 192.168.1.1
display nat all
display nat static
nat static enable
Use nat static inbound net-to-net to configure a net-to-net mapping for inbound static NAT.
Use undo nat static inbound net-to-net to remove a net-to-net mapping for inbound static NAT.
nat static inbound net-to-net global-start-address global-end-address [ vpn-instance global-vpn-instance-name ] local local-network { mask-length | mask } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ]
undo nat static inbound net-to-net global-start-address global-end-address [ vpn-instance global-vpn-instance-name ]
global-start-address global-end-address: Specifies a public address range which can contain a maximum of 256 addresses. The global-end-address must not be lower than global-start-address. If they are the same, only one public address is specified.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public IP addresses belong. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP addresses do not belong to any VPN instance, do not specify this option.
local-network: Specifies a private network address.
mask-length: Specifies the mask length of the private network address, in the range of 8 to 31.
mask: Specifies the mask of the private network address.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private network address belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private network address does not belong to any VPN instance, do not specify this option.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP addresses. To deploy configuration successfully, do not specify this keyword after you enable hardware NAT.
For address translation from a public network to a private network, configure inbound net-to-net static NAT.
Operating mechanism
·     When the destination IP address of a packet from the private network matches the private address range, the destination IP address is translated into a public address in the public address range.
·     When the source IP address of a packet from the public network matches the public address range, the source IP address is translated into a private address in the private address range.
Specify a public network through a start address and an end address, and a private network through a private address and a mask.
The public end address cannot be greater than the greatest IP address in the subnet determined by the public start address and the private network mask. For example, if the private address is 2.2.2.0 with a mask 255.255.255.0 and the public start address is 1.1.1.100, the public end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
·     If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP addresses.
·     If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
# Configure an inbound static NAT between public network address 202.100.1.0/24 and private network address 192.168.1.0/24.
[Sysname] nat static inbound net-to-net 202.100.1.1 202.100.1.255 local 192.168.1.0 24
display nat all
display nat static
nat static enable
