13-High Availability Command Reference
HomeSupportRoutersCR16000-M1A SeriesCR16000-M1A SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C CR16000-M1A Router Command Reference-R8630Pxx-6W10213-High Availability Command Reference
02-CFD commands
02-CFD commands 596.25 KB
CFD commands· 1
cfd ais enable· 1
cfd ais level 1
cfd ais period· 2
cfd ais-track link-status global 3
cfd ais-track link-status level 3
cfd ais-track link-status period· 4
cfd ais-track link-status vlan· 5
cfd cc enable· 6
cfd cc interval 7
cfd dlm continual 8
cfd dlm threshold· 10
cfd dm one-way· 11
cfd dm one-way continual 12
cfd dm one-way duration start 13
cfd dm one-way duration stop· 14
cfd dm two-way· 15
cfd dm two-way continual 16
cfd dm two-way duration start 18
cfd dm two-way duration stop· 19
cfd dm two-way threshold· 19
cfd enable· 20
cfd frame-count mode· 21
cfd hardware-cc· 22
cfd linktrace· 23
cfd linktrace auto-detection· 24
cfd loopback· 25
cfd md· 26
cfd mep· 27
cfd meplist 29
cfd mip-rule· 30
cfd service-instance· 31
cfd slm·· 33
cfd slm continual 35
cfd slm duration start 36
cfd slm duration stop· 37
cfd slm threshold· 38
cfd synthetic-slm·· 39
cfd synthetic-slm continual 40
cfd synthetic-slm duration start 42
cfd synthetic-slm duration stop· 43
cfd synthetic-slm threshold· 43
cfd tst 44
cfd tst continual 45
display cfd ais· 47
display cfd ais-track link-status· 48
display cfd dlm history· 49
display cfd dm one-way history· 51
display cfd dm one-way statistics· 53
display cfd dm two-way history· 54
display cfd dm two-way statistics· 56
display cfd linktrace-reply· 57
display cfd linktrace-reply auto-detection· 58
display cfd md· 60
display cfd mep· 61
display cfd meplist 64
display cfd mp· 64
display cfd remote-mep· 65
display cfd service-instance· 67
display cfd slm history· 68
display cfd slm statistics· 70
display cfd status· 71
display cfd synthetic-slm history· 71
display cfd tst history· 74
reset cfd dlm history· 76
reset cfd dm one-way history· 77
reset cfd dm two-way history· 77
reset cfd slm history· 78
reset cfd synthetic-slm history· 78
reset cfd tst 79
CFD commands
cfd ais enable
Use cfd ais enable to enable AIS.
Use undo cfd ais enable to disable AIS.
cfd ais enable
undo cfd ais enable
AIS is disabled.
This command takes effect only in Ethernet networks.
# Enable AIS.
[Sysname] cfd ais enable
cfd ais level
cfd ais period
cfd ais level
Use cfd ais level to configure the AIS frame transmission level.
Use undo cfd ais level to remove the AIS frame transmission level.
cfd ais level level-value service-instance instance-id
undo cfd ais level level-value service-instance instance-id
The AIS frame transmission level is not configured.
level level-value: Specifies the AIS frame transmission level in the range of 1 to 7.
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767.
If no AIS frame transmission level is configured for a service instance, the MEPs in the service instance cannot send AIS frames.
This command can be configured only in Ethernet networks. You cannot specify a Layer 2 VPN service instance for the service-instance instance-id option.
# Configure the AIS frame transmission level as 3 in service instance 1.
[Sysname] cfd ais level 3 service-instance 1
cfd ais enable
cfd ais period
cfd ais period
Use cfd ais period to configure the AIS frame transmission period.
Use undo cfd ais period to remove the AIS frame transmission period.
cfd ais period period-value service-instance instance-id
undo cfd ais period period-value service-instance instance-id
The AIS frame transmission period is 1 second.
period period-value: Specifies the AIS frame transmission period in the range of 1 to 60 seconds.
# Configure the AIS frame transmission period as 60 seconds in service instance 1.
[Sysname] cfd ais period 60 service-instance 1
cfd ais enable
cfd ais level
Use cfd ais-track link-status global to enable interface status-AIS collaboration.
Use undo cfd ais-track link-status global to disable interface status-AIS collaboration.
Interface status-AIS collaboration is disabled.
# Enable interface status-AIS collaboration.
[Sysname] cfd ais-track link-status global
Use cfd ais-track link-status level to configure the EAIS frame transmission level.
Use undo cfd ais-track link-status level to restore the default.
cfd ais-track link-status level level-value
The EAIS frame transmission level is not configured.
Layer 2 FlexE logical interface view
level level-value: Specifies the EAIS frame transmission level in the range of 0 to 7.
If no EAIS frame transmission level is configured on an interface, the interface cannot send EAIS frames.
Follow these guidelines when you use the command:
·     Configurations in Ethernet interface view take effect only on the current interface.
·     Configurations in aggregate interface view take effect only on the current aggregate interface
·     Configurations on a member port take effect only when the member port leaves the aggregation group.
# Configure the EAIS frame transmission level as 3 on Ten-GigabitEthernet 0/0/15.
[Sysname] interface ten-gigabitethernet 0/0/15
[Sysname-Ten-GigabitEthernet0/0/15] cfd ais-track link-status level 3
Use cfd ais-track link-status period to configure the EAIS frame transmission period.
Use undo cfd ais-track link-status period to restore the default.
cfd ais-track link-status period period-value
The EAIS frame transmission period is not configured.
period period-value: Specifies the EAIS frame transmission period in the range of 1 to 60 seconds.
If no EAIS frame transmission period is configured on an interface, the interface cannot send EAIS frames.
·     Configurations in aggregate interface view take effect only on the current aggregate interface.
# Configure the EAIS frame transmission period as 60 seconds on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] cfd ais-track link-status period 60
Use cfd ais-track link-status vlan to specify the VLANs where the EAIS frames can be transmitted.
Use undo cfd ais-track link-status vlan to remove the VLANs where the EAIS frames can be transmitted.
cfd ais-track link-status vlan vlan-list
undo cfd ais-track link-status vlan vlan-list
The EAIS frames can be transmitted only within the default VLAN of the interface.
vlan vlan-list: Specifies the VLANs where the EAIS frames can be transmitted. The vlan-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id [ to vlan-id ]. The value range for VLAN IDs is 1 to 4094.
The EAIS frames are transmitted within the intersection of the VLANs specified with this command and the existing VLANs on the device.
If the command is executed multiple times, the combination of the VLANs specified in each command takes effect.
# On Ten-GigabitEthernet 0/0/15, specify VLANs 100 through 200 as the VLANs where the EAIS frames can be transmitted.
[Sysname-Ten-GigabitEthernet0/0/15] cfd ais-track link-status vlan 100 to 200
cfd cc enable
Use cfd cc enable to enable CCM sending on a specified MEP.
Use undo cfd cc enable to disable CCM sending on a specified MEP.
cfd cc service-instance instance-id mep mep-id enable
undo cfd cc service-instance instance-id mep mep-id enable
The CCM sending feature is disabled.
service-instance instance-id: Specifies the service instance ID in the range of 1 to 32767.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191.
·     If the MEP belongs to an MA that does not carry the VLAN attribute, configurations on a member port of an aggregate interface take effect only on the current member port.
·     If the MEP belongs to an MA that carries the VLAN attribute, configurations on a member port of an aggregate interface take effect only when the member port leaves the aggregation group.
In an Ethernet network, you can enable CCM sending only on Layer 2/Layer 3 Ethernet interfaces, Layer 2 FlexE logical interfaces, Layer 3 FlexE logical interfaces and Layer 2 aggregate interfaces.
In an MPLS Layer 2 VPN, you can enable CCM sending only on Layer 3 Ethernet interfaces, Layer 3 Ethernet subinterfaces, Layer 3 aggregate interfaces, Layer 3 FlexE logical interfaces, and Layer 3 aggregate subinterfaces.
Only inward-facing MEPs support enabling this feature on Layer 3 aggregate interfaces and Layer 3 aggregate subinterfaces.
# On Ten-GigabitEthernet 0/0/15, enable CCM sending on MEP 3 in service instance 5.
[Sysname-Ten-GigabitEthernet0/0/15] cfd cc service-instance 5 mep 3 enable
cfd cc interval
cfd cc interval
Use cfd cc interval to set the value of the interval field in the CCM messages.
Use undo cfd cc interval to remove the value of the interval field in the CCM messages.
cfd cc interval interval-value service-instance instance-id
undo cfd cc interval [ interval-value ] service-instance instance-id
The value of this field is 4 for all CCMs sent.
interval interval-value: Specifies the value of the interval field in CCM messages. The value range for the interval field is 1 to 7. The value for the interval field cannot be 1 or 2 on Ethernet networks.
When setting the CCM interval, use the settings described in Table 1.
Table 1 CCM interval field encoding
CCM interval field
Transmission interval
Maximum CCM lifetime
1
10/3 milliseconds
35/3 milliseconds
2
10 milliseconds
35 milliseconds
3
100 milliseconds
350 milliseconds
4
1 second
3.5 seconds
5
10 seconds
35 seconds
6
60 seconds
210 seconds
7
600 seconds
2100 seconds
# Set the value of the interval field to 3 in CCMs sent by MEPs in service instance 2.
[Sysname] cfd cc interval 3 service-instance 2
cfd cc enable
cfd dlm continual
Use cfd dlm continual to configure continual two-way loss measurement (LM).
Use undo cfd dlm continual to disable continual two-way LM.
cfd dlm continual service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ] [ dot1p dot1p-value ]
undo cfd dlm continual service-instance instance-id mep mep-id
Continual two-way LM is disabled.
mep mep-id: Specifies the source MEP by its ID in the range of 1 to 8191.
target-mac mac-address: Specifies the target MEP by its bridge MAC address, which is in the format of H-H-H.
target-mep target-mep-id: Specifies the target MEP by its ID in the range of 1 to 8191.
peer ip-address: Specifies a remote PE device by its LSR ID. This option is required only if the target MEP resides on a remote PE device in a VPLS network.
pw-id pw-id: Specifies a PW by its ID in the range of 1 to 4294967295.
dot1p dot1p-value: Specifies an 802.1p priority for CCM frames. The value range for the dot1p-value argument is 0 to 7. The default value is 7.
The two-way LM function measures the frame loss between the source and target MEPs by using CCMs. The source MEP calculates the number of lost frames according to the counter values of two consecutive CCMs received (the current CCM and the previous CCM).
To view the bridge MAC address of the target MEP, execute the display lacp system-id command on the target MEP.
For the two-way LM function to take effect, you must configure it on both the local and peer devices.
If the device supports hardware CC, you can specify the target MEP only by its MAC address. You cannot specify the target MEP by its ID.
If the frame counting mode is dot1p-based, you must specify the dot1p dot1p-value option. If the frame counting mode is port-based, do not specify the dot1p dot1p-value option.
To modify two-way LM settings for a source MEP, disable two-way LM and then reconfigure the function for the source MEP.
The two-way LM detection interval is the CCM interval. Before configuring two-way LM, configure the CCM interval field value to be greater than 2.
One-way LM and two-way LM cannot be configured at the same time for one source MEP. If you have configured short-period one-way LM or continual one-way LM, you can configure two-way LM only after you disable continual one-way LM or short-period one-way LM ends. If you have configured two-way LM, you can configure short-period one-way LM or continual one-way LM only after disable two-way LM.
To display the two-way LM result, use the display cfd dlm history command on the device where the source MEP or target MEP resides.
Two-way LM can be configured only in Layer 2 VPNs.
# Enable the continual two-way LM function to measure the frame loss between source MEP 1101 and target MEP 2001 in service instance 1.
[Sysname] cfd dlm continual service-instance 1 mep 1101 target-mep 2001
cfd cc interval
cfd slm
cfd slm continual
cfd dlm threshold
Use cfd dlm threshold to configure the lower limit and upper limit for continual two-way LM.
Use undo cfd dlm threshold to restore the default.
cfd dlm { far-end | near-end } threshold service-instance instance-id mep mep-id { lower-limit lower-limit | upper-limit upper-limit } *
undo cfd dlm { far-end | near-end } threshold service-instance instance-id mep mep-id [ lower-limit | upper-limit ]
The lower limit and upper limit for continual two-way LM are 0 and 100%, respectively, for both the source and target MEPs.
far-end: Configures the lower limit and upper limit for the target MEP.
near-end: Configures the lower limit and upper limit for the source MEP.
lower-limit lower-limit: Specifies the lower limit in percentage, in the range of 0 to 100. It can contain a maximum of 8 digits, including the dot (.), for example, 1.000001. The lower limit must be smaller than the upper limit.
upper-limit upper-limit: Specifies the upper limit in percentage, in the range of 0 to 100. It can contain a maximum of 8 digits, including the dot (.), for example, 1.000001.
This command takes effect only after you configure continual two-way LM.
When the packet loss ratio for the source MEP or target MEP reaches or exceeds the upper limit, the system displays a message about the situation.
When the packet loss ratios for both the source MEP and target MEP reach or fall below the lower limit, the system displays a message about the situation.
# Configure the lower limit and upper limit as 0.2% and 0.8%, respectively, for source MEP 1101 in service instance 1.
[Sysname] cfd dlm near-end threshold service-instance 1 mep 1101 lower-limit 0.2 upper-limit 0.8
cfd dlm continual
cfd dm one-way
Use cfd dm one-way to enable short-period one-way delay measurement (DM).
cfd dm one-way service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ] [dot1p dot1p-value ] [ number number ] [ interval interval ]
target-mac mac-address: Specifies the target MEP by its bridge MAC address in the format of H-H-H.
dot1p dot1p-value: Specifies an 802.1p priority for 1DM frames. The value range for the dot1p-value argument is 0 to 7. The default value is 7.
number number: Specifies the number of 1DM frames sent. The value range for the number argument is 2 to 10, and the default is 5.
interval interval: Specifies the 1DM frame sending interval, in seconds. The value takes 1, 10, 60, or 600. The default value is 1.
The short-period one-way DM function measures the one-way frame delay between the source and target MEPs by using 1DM frames.
You can implement one-way DM by using the following test types:
·     Continual one-way DM.
·     Short-period one-way DM.
·     Scheduled one-way DM.
You can configure only one of the test types for a source MEP. To change the test type, you must stop the ongoing test and then start a new test.
To view the short-period one-way delay test result, use the display cfd dm one-way history command on the target MEP.
As a best practice, do not configure this command on Ethernet networks.
# Enable the short-period one-way DM function to test the one-way frame delay from source MEP 1101 to target MEP 1003 in service instance 1.
<Sysname> cfd dm one-way service-instance 1 mep 1101 target-mep 1003
5 1DMs have been sent. Please check the result on the remote device.
Use cfd dm one-way continual to configure continual one-way DM.
Use undo cfd dm one-way continual to disable continual one-way DM.
cfd dm one-way continual service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ]  [ dot1p dot1p-value ] [ interval interval ]
undo cfd dm one-way continual service-instance instance-id mep mep-id
Continual one-way DM is disabled.
dot1p dot1p-value: Specifies the 802.1p priority of 1DM frames to be sent. The value range for the dot1p-value argument is 0 to 7, and the default is 7. The larger the value, the higher the priority.
interval interval: Specifies the interval for sending 1DM frames, in seconds. The value for the interval argument can be 1, 10, 60, or 600, and the default is 1.
Continual one-way DM continually sends 1DM frames at a configurable interval. It measures the one-way frame delay between the source and target MEPs after receiving the returned 1DM frames.
If the device supports hardware CC, you can only specify the target MEP by its MAC address. You cannot specify the target MEP by its ID.
To modify continual one-way DM settings for a source MEP, disable continual one-way DM and then reconfigure the function for the source MEP.
To display the continual one-way DM result, use the display cfd dm one-way history command on the device where the source MEP resides.
Inward-facing MEPs created in an Ethernet network do not support continual one-way DM.
# Configure continual one-way DM to test the frame delay between source MEP 1101 and target MEP 2001 in service instance 1.
[Sysname] cfd dm one-way continual service-instance 1 mep 1101 target-mep 2001
cfd dm two-way
Use cfd dm one-way duration start to start a scheduled one-way DM.
cfd dm one-way duration duration-time start service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ] [dot1p dot1p-value ] [ interval interval ]
duration-time: Specifies a one-way DM test duration in the range of 1 to 65535 seconds.
The scheduled one-way DM function measures the one-way frame delay between the source and target MEPs by using 1DM frames.
# Start a scheduled one-way DM to test the frame delay between source MEP 1101 and target MEP 1003 in service instance 1 within 60 seconds.
<Sysname> cfd dm one-way duration 60 start service-instance 1 mep 1101 target-mep 1003
cfd dm two-way
Use cfd dm one-way duration stop to stop a scheduled one-way DM.
cfd dm one-way duration stop service-instance instance-id mep mep-id
# Stop a scheduled one-way DM for source MEP 1101 in service instance 1.
<Sysname> cfd dm one-way duration stop service-instance 1 mep 1101
cfd dm two-way
Use cfd dm two-way to enable short-period two-way DM.
cfd dm two-way service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ] [ dot1p dot1p-value ] [ number number ] [ interval interval ]
dot1p dot1p-value: Specifies an 802.1p priority for DMMs. The value range for the dot1p-value argument is 0 to 7. The default value is 7.
number number: Specifies the number of DMM frames to be sent. The value range for the number argument is 2 to 10, and the default is 5.
interval interval: Specifies the DMM frame sending interval, in seconds. The value takes 1, 10, 60, or 600. The default value is 1.
The short-period two-way DM function measures the two-way frame delay between the source and target MEPs by using DMM frames and DMR frames.
You can implement two-way DM by using the following test types:
·     Continual two-way DM.
·     Short-period two-way DM.
·     Scheduled two-way DM.
In the current software version, two-way DM for Ehthernet network can achieve millisecond-level accuracy. Test results of less than 1 millisecond are displayed as 0 milliseconds.
# Enable the short-period two-way DM function to test the two-way frame delay between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd dm two-way service-instance 1 mep 1101 target-mep 2001
Frame delay:
Reply from 0010-fc00-6512: 10us
Reply from 0010-fc00-6512: 9us
Reply from 0010-fc00-6512: 11us
Reply from 0010-fc00-6512: 5us
Average: 8us
Frame jitter: 1us 2us 6us 0us
Average: 2us
Packet statistics:
Sent DMMs: 5        Received: 5        Lost: 0
Delay of the DMR frames returned from the MEP with MAC address 0010-FC00-6512.
Average
Average frame delay or average frame delay variation.
Sent DMMs
Number of sent DMM frames .
Received
Number of received DMR frames.
Lost
Number of lost DMM frames.
Use cfd dm two-way continual to enable continual two-way DM.
Use undo cfd dm two-way continual to disable continual two-way DM.
cfd dm two-way continual service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ] [ dot1p dot1p-value ] [ interval interval ]
undo cfd dm two-way continual service-instance instance-id mep mep-id
Continual two-way DM is disabled.
dot1p dot1p-value: Specifies an 802.1p priority for DMM frames. The value range for the dot1p-value argument is 0 to 7. The default value is 7.
Continual two-way DM continually sends DMM frames at a configurable interval. It measures the two-way frame delay between the source and target MEPs after receiving the returned DMR frames.
To modify continual two-way DM settings for a source MEP, disable continual two-way DM and then reconfigure the function for the source MEP.
To display the continual two-way DM result, use the display cfd dm two-way history command on the device where the source MEP resides.
Inward-facing MEPs created in an Ethernet network do not support continual two-way DM.
# Enable the continual two-way DM function to test the two-way frame delay between source MEP 1101 and target MEP 2001 in service instance 1.
[Sysname] cfd dm two-way continual service-instance 1 mep 1101 target-mep 2001
cfd dm two-way
Use cfd dm two-way duration start to start a scheduled two-way DM.
cfd dm two-way duration duration-time start service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ] [dot1p dot1p-value ] [ interval interval ]
duration-time: Specifies a two-way DM test duration in the range of 1 to 65535 seconds.
The scheduled two-way DM function measures the two-way frame delay between the source and target MEPs by using DMM frames and DMR frames.
# Start a scheduled two-way DM to test the two-way frame delay between source MEP 1101 and target MEP 1003 in service instance 1 within 60 seconds.
<Sysname> cfd dm two-way duration 60 start service-instance 1 mep 1101 target-mep 1003
cfd dm two-way
Use cfd dm two-way duration stop to stop a scheduled two-way DM.
cfd dm two-way duration stop service-instance instance-id mep mep-id
# Stop a scheduled two-way DM for source MEP 1101 in service instance 1.
<Sysname> cfd dm two-way duration stop service-instance 1 mep 1101
Use cfd dm two-way threshold to configure the lower limit and upper limit for continual two-way DM.
Use undo cfd dm two-way threshold to restore the default.
cfd dm two-way threshold service-instance instance-id mep mep-id { lower-limit lower-limit | upper-limit upper-limit } *
undo cfd dm two-way threshold service-instance instance-id mep mep-id [ lower-limit | upper-limit ]
The lower limit and upper limit for continual two-way DM are 0 and 4294967295 microseconds, respectively.
lower-limit lower-limit: Specifies the lower limit in the range of 0 to 4294967295 microseconds. The lower limit must be smaller than the upper limit.
upper-limit upper-limit: Specifies the upper limit in the range of 0 to 4294967295 microseconds.
This command takes effect only after you configure continual two-way DM.
If the delay time reaches or exceeds the upper limit for three consecutive times, the system displays a message about the situation.
If the delay time reaches or falls below the lower limit for three consecutive times, the system displays a message about the situation.
# Configure the continual two-way DM lower limit and upper limit as 10000 and 5000000 microseconds, respectively, for source MEP 1101 in service instance 1.
[Sysname] cfd dm two-way threshold service-instance 1 mep 1101 lower-limit 10000 upper-limit 5000000
cfd enable
Use cfd enable to enable CFD.
Use undo cfd enable to disable CFD.
cfd enable
undo cfd enable
CFD is disabled.
# Enable CFD.
[Sysname] cfd enable
Use cfd frame-count mode to configure the frame counting mode for LM.
Use undo frame-count mode to restore the default.
cfd frame-count mode { dot1p-based | port-based }
undo cfd frame-count mode
No frame counting mode is configured for LM.
dot1p-based: Counts packets by 802.1p priority.
port-based: Counts packets by interface.
To obtain accurate test results, configure the same frame counting mode on the source MEP and target MEP.
If the frame counting mode is dot1p-based, you must specify the dot1p dot1p-value option when configuring the cfd slm, cfd slm continual, and cfd dlm continual commands. If the frame counting mode is port-based, do not specify the dot1p dot1p-value option when configuring the cfd slm, cfd slm continual, and cfd dlm continual commands.
If LM has been configured for a MEP, the frame counting mode on the interface where the MEP resides cannot be modified.
This command can be configured only in MPLS Layer 2 VPNs.
# Configure the frame counting mode for LM as dot1p-based on Ten-GigabitEthernet 0/0/15.1.
[Sysname] interface ten-gigabitethernet 0/0/15.1
[Sysname-Ten-GigabitEthernet0/0/15.1] cfd frame-count mode dot1p-based
cfd dlm continual
cfd slm
cfd slm continual
cfd hardware-cc
Use cfd hardware-cc to enable hardware CC.
Use undo cfd hardware-cc to disable hardware CC.
cfd hardware-cc service-instance instance-id remote-mep mep-list
undo cfd hardware-cc service-instance instance-id remote-mep mep-list
Hardware CC is disabled.
remote-mep mep-list: Specifies remote MEPs. The mep-list argument specifies a space-separated list of up to 10 MEP items. Each item specifies a MEP ID or a range of MEP IDs in the form of mep-id [ to mep-id ]. The value range for MEP IDs is 1 to 8191.
This feature is supported in only Layer 2 VPNs.
In an MPLS Layer 2 VPN, you must configure this feature after configuring CC.
You can enable hardware CC on only Layer 3 aggregate interfaces and Layer 3 aggregate subinterfaces of inward-facing MEPs.
Do not modify the value of the interval field in CCM messages after hardware CC is enabled. If you modify the value of the interval field in CCM messages, hardware CC is automatically disabled.
# Enable hardware CC on Ten-GigabitEthernet 0/0/15 to detect remote MEP 5 in service instance 1.
[Sysname-Ten-GigabitEthernet0/0/15] cfd hardware-cc service-instance 1 remote-mep 5
# Enable hardware CC on Ten-GigabitEthernet 0/0/15.1 to detect remote MEP 5 in service instance 1.
[Sysname-Ten-GigabitEthernet0/0/15.1] cfd hardware-cc service-instance 1 remote-mep 5
cfd cc interval
cfd linktrace
Use cfd linktrace to identify the path between the source MEP and target MP.
cfd linktrace service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ ttl ttl-value ] [ hw-only ]
target-mac mac-address: Specifies the target MEP by its bridge MAC address, in the format of H-H-H.
target-map target-mep-id: Specifies the destination MEP by its ID in the range of 1 to 8191.
ttl ttl-value: Specifies the TTL value in the range of 1 to 255. The default value is 64.
hw-only: Sets the hw-only bits of the LTMs sent. If you specify this keyword, the source MEP or the target MIP does not flood LTM messages that have an unknown destination MAC address.
This command identifies the path between the source MEP and target MP by using LTMs and LTRs.
# Identify the path between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd linktrace service-instance 1 mep 1101 target-mep 2001
Linktrace to MEP 2001 with the sequence number 1101-43361:
MAC address               TTL     Last MAC         Relay action
0010-fc00-6512            63      0010-fc00-6500   Hit
Linktrace to target MEP 2001 with the sequence number 1101-43361.
MAC address
Source MAC address in the LTR messages.
TTL
TTL of the LTM when it passes the device.
Last MAC
MAC address of the last-hop device the LTM passes.
Relay action
Indicates whether the forwarding device found the destination MAC address in its MAC address table.
When the standard version (IEEE 802.1ag) of CFD is used:
·     Hit—The current device is the destination device.
·     FDB—The forwarding device found the destination MAC address.
·     MPDB—The destination MAC address is not found, or the destination MAC address is found in the MEP or MIP database.
Use cfd linktrace auto-detection to enable automatic sending of LTMs.
Use undo cfd linktrace auto-detection to disable automatic sending of LTMs.
cfd linktrace auto-detection [ size size-value ]
Automatic sending of LTMs is disabled.
size size-value: Specifies the size of the buffer used to store the auto-detection result, in the range of 1 to 100 (in terms of auto-detection times). The default value is 5, which means the buffer stores the results of the recent five auto-detections.
This command enables the source MEP to send LTMs when it fails to receive CCMs from the target MEP within 3.5 times the sending interval. The destination of the LTMs is the target MEP, and the TTL field value is 255. Based on the returned LTRs, the fault source can be located on the faulty link.
If you disable automatic LTM sending, the content stored in the buffer will be removed.
The outward-facing MEP on a hardware CC-supported card does not automatically send LTMs.
# Enable automatic LTM sending, and set the size of the buffer used to store the auto-detection result to 100 (in terms of auto-detection times).
[Sysname] cfd linktrace auto-detection size 100
cfd linktrace
cfd loopback
Use cfd loopback to enable loopback (LB).
cfd loopback service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ]
number number: Specifies the number of the sent LBMs packets. The value is in the range of 1 to 10. The default value is 5.
The LB function verifies link connectivity between the source MEP and the target MP by using LBMs and LBRs.
# Enable LB for the link between MEP 1101 and MEP 2001 in service instance 1 (assume that the link status is normal).
<Sysname> cfd loopback service-instance 1 mep 1101 target-mep 2001
Loopback to MEP 2001 with the sequence number start from 1101-43404:
Reply from 0010-fc00-6512: sequence number=1101-43404 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43405 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43406 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43407 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43408 Time=5ms
Sent: 5        Received: 5        Lost: 0
# Enable LB for the link between MEP 1101 and MEP 2001 in service instance 1 (assume that the link status is abnormal).
Sent: 5        Received: 0        Lost: 5
Sends LBMs to remote MEP 2001 with the sequence number starting with 1101-43404.
Reply from the MP with the MAC address 0010-FC00-6512.
sequence number
Sequence number in the LBR messages.
Time=5ms
The interval between the sending of LBMs and receiving of LBRs is 5 milliseconds.
Sent
Number of sent LBMs.
Received
Number of received LBRs.
Lost
Number of lost LBRs.
cfd md
Use cfd md to create an MD.
Use undo cfd md to delete an MD.
cfd md md-name [ index index-value ] level level-value [ md-id { dns dns-name | mac mac-address subnumber | none } ]
undo cfd md md-name
No MDs exist.
md md-name: Specifies the name of an MD, which is a string of 1 to 43 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark ('), comma (,), period (.), and slash (/).
index index-value: Specifies an MD index in the range of 1 to 4294967295. If you do not specify this option, the system automatically assigns the smallest index number that is not in use. As a best practice, use the index automatically assigned by the system.
level level-value: Specifies an MD level in the range of 0 to 7.
md-id: Specifies the MD name carried by packets sent by the MEP. If you do not provide this keyword, the MD name is represented by md-name.
dns dns-name: Specifies an MD name in the format of DNS name, where dns-name represents the DNS name.
mac mac-address subnumber: Specifies an MD name containing the MAC address and an integer. The mac-address argument represents the MAC address of the MD, and the subnumber argument is in the range of 0 to 65535.
none: Specifies that no MD name is carried in the packets sent by the MEP.
An MD name must be in compliant with the specifications in IEEE802.1ag-2007.
You can create only one MD with a specific level. MD cannot be created if you enter an invalid MD name or an existing MD name or the MD index is in use.
When deleting an MD, you will also delete the configurations related to that MD.
# Create an MD named test_md1, with its level being 3.
[Sysname] cfd md test_md1 level 3
# Create an MD named test_md2, and the MD name carried in the packet sent by the MEP comprises the MAC address 1-1-1 and integer 1.
[Sysname] cfd md test_md2 level 5 md-id mac 1-1-1 1
cfd mep
Use cfd mep to create a MEP.
Use undo cfd mep to delete a MEP.
In an Ethernet network:
·     Layer 2 Ethernet interface view or Layer 2 aggregate interface view:
cfd mep mep-id service-instance instance-id { inbound | outbound }
undo cfd mep mep-id service-instance instance-id
·     Layer 3 Ethernet interface view:
cfd mep mep-id service-instance instance-id outbound
In a Layer 2 VPN:
·     Layer 3 aggregate interface view or Layer 3 aggregate subinterface view:
cfd mep mep-id service-instance instance-id inbound
·     Layer 3 Ethernet subinterface view:
cfd mep mep-id service-instance instance-id [ vlan vlan-id | service-vid vlan-id customer-vid vlan-id ] outbound
No MEPs exist.
mep mep-id: Specifies the MEP ID, in the range of 1 to 8191.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
service-vid vlan-id: Specifies an outer VLAN (SVLAN) by its ID in the range of 1 to 4094.
customer-vid vlan-id: Specifies an inner VLAN (CVLAN) by its ID in the range of 1 to 4094.
inbound: Creates an inward-facing MEP.
outbound: Creates an outward-facing MEP.
In creating a MEP, the service instance you specified defines the MD and MA to which the MEP belongs.
You cannot create a MEP if the MEP ID is not included in the MEP list of the relevant service instance.
·     Configurations in Ethernet interface view or aggregate interface view take effect only on the current interface.
In an Ethernet network, you can create MEPs only on Layer 2 Ethernet interfaces, Layer 2 aggregate interfaces, Layer 2 FlexE logical interfaces, Layer 3 FlexE logical interfaces, and Layer 3 Ethernet interfaces.
In an MPLS Layer 2 VPN:
·     For L2VPN networking, you can create MEPs only on Layer 3 Ethernet interfaces, Layer 3 Ethernet subinterfaces, Layer 3 aggregate interfaces, Layer 3 FlexE logical interfaces, and Layer 3 aggregate subinterfaces.
·     For VPLS networking, you can create MEPs only on Layer 3 Ethernet interfaces, Layer 3 Ethernet subinterfaces, Layer 3 aggregate interfaces, Layer 3 FlexE logical interfaces, and Layer 3 aggregate subinterfaces.
·     Only one inward-facing MEP can be configured for a CFD service instance.
·     A MEP can only be configured on an AC interface to detect PW connectivity.
When configuring a MEP on a Layer 3 Ethernet subinterface, follow these restrictions and guidelines:
·     To specify the VLAN ID, you must first configure the vlan-type dot1q vid vlan-id-list command and specify the same value for the vlan-id-list and vlan vlan-id parameters. For more information about the vlan-type dot1q vid vlan-id-list command, see VLAN termination commands in Layer 2—LAN Switching Command Reference.
·     To specify the outer and inner VLAN IDs you must first configure the vlan-type dot1q vid second-dot1q command and set the same outer VLAN ID and the same inner VLAN ID in the two commands. For more information about the vlan-type dot1q vid second-dot1q command, see VLAN termination commands in Layer 2—LAN Switching Command Reference.
# In an Ethernet network, configure a MEP list in service instance 5, and create inward-facing MEP 3 in service instance 5 on Ten-GigabitEthernet 0/0/15.
[Sysname] cfd md test_md level 3
[Sysname] cfd service-instance 5 ma-id vlan-based md test_md vlan 100
[Sysname] cfd meplist 3 service-instance 5
[Sysname-Ten-GigabitEthernet0/0/15] cfd mep 3 service-instance 5 outbound
cfd meplist
vlan-type dot1q vid (Layer 2—LAN Switching Command Reference)
vlan-type dot1q vid second-dot1q (Layer 2—LAN Switching Command Reference)
cfd meplist
Use cfd meplist to create a MEP list.
Use undo cfd meplist to delete a MEP list.
cfd meplist mep-list service-instance instance-id
undo cfd meplist mep-list service-instance instance-id
No MEP list is created.
meplist mep-list: Specifies a space-separated list of up to 10 MEP items. Each item specifies a MEP ID or a range of MEP IDs in the form of mep-id 1 to mep-id 2. The value range for the MEP ID is 1 to 8191. The mep-id 2 must be equal to or greater than mep-id 1.
A MEP list is a collection of local MEPs allowed to be configured and the remote MEPs to be monitored in the same MA.
Before creating a MEP list, create the relevant MD and service instance.
After you delete a MEP list, all local MEP configurations based on this list are deleted.
# In an Ethernet network, create a MEP list that includes MEP 9 through MEP 15 in service instance 5.
[Sysname] cfd meplist 9 to 15 service-instance 5
cfd md
cfd mip-rule
Use cfd mip-rule to configure the rules for generating MIPs.
Use undo cfd mip-rule to remove the rules for generating MIPs and the MIPs created in a service instance.
cfd mip-rule { default | explicit } service-instance instance-id
undo cfd mip-rule [ default | explicit ] service-instance instance-id
No rules for generating MIPs are configured and the system does not automatically generate any MIPs.
default: Specifies the default rule. If no lower-level MIP exists on an interface, a MIP is created on the current level. A MIP can be created even if no MEP is configured on the interface.
explicit: Specifies the explicit rule. If no lower-level MIP exists and a lower-level MEP exists on an interface, a MIP is created at the current level. A MIP can be created only when a lower-level MEP is created on the interface.
The system automatically generates MIPs on each interface according to the rules configured.
# Configure the MIP generation rule as default in service instance 5.
[Sysname] cfd mip-rule default service-instance 5
Use cfd service-instance to create a service instance.
Use undo cfd service-instance to remove a service instance.
cfd service-instance instance-id ma-id { icc-based ma-name | integer ma-num | string ma-name | vlan-based [ vlan-id ] } [ ma-index index-value ] md md-name vlan vlan-id
undo cfd service-instance instance-id
cfd service-instance instance-id ma-id { icc-based ma-name | integer ma-num | string ma-name } [ ma-index index-value ] md md-name { xconnect-group group-name connection connection-name | vsi vsi-name }
No service instances exist.
ma-id: Creates an MA.
icc-based ma-name: Specifies that an MA is identified by an ICC. The ma-name argument is a string of 1 to 13 characters. An MA name must be compliant with the specifications in IEEE802.1ag-2007
integer ma-num: Specifies that an MA is identified by an integer, where the ma-num argument is in the range of 0 to 65535.
string ma-name: Specifies that an MA is identified by a string, where the ma-name argument is string of 1 to 45 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark ('), comma (,), period (.), and slash (/).
vlan-based [ vlan-id ]: Specifies that an MA is identified by a VLAN ID, where the vlan-id argument is in the range of 1 to 4094. If you do not provide the vlan-id argument, the VLAN ID specified by vlan vlan-id is used. If the vlan vlan-id option is not provided, you must specify the vlan-id argument for the vlan-based [ vlan-id ] option.
ma-index index-value: Specifies an MA index in the range of 1 to 4294967295. If you do not specify this option, the system automatically assigns the smallest index number that is not in use. As a best practice, use the index automatically assigned by the system.
md md-name: Specifies the name of an MD. The md-name argument is a string of 1 to 43 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark (’), comma (,), period (.), and slash (/).
vlan vlan-id: Specifies the VLAN that the MA serves. The value range for the vlan-id argument is 1 to 4094.
xconnect-group group-name: Specifies the cross-connect group that the MA serves. The group-name argument is a case-sensitive string of 1 to 31 characters excluding hyphens (-).
connection connection-name: Specifies the cross-connect that the MA serves. The connection-name argument is a case-sensitive string of 1 to 20 characters excluding hyphens (-).
vsi vsi-name: Specifies the VSI that the MA serves. The vsi-name argument is a case-sensitive string of 1 to 31 characters.
You must create the relevant MD before creating a service instance.
Deleting a service instance also deletes the configurations related to that service instance.
Deleting a service instance not only removes the connection between the service instance and the relevant MA, but also deletes the MA.
When you create a service instance in an Ethernet network, follow these restrictions and guidelines:
·     A service instance is indicated by an integer to represent an MA in an MD. An MA index uniquely identifies a specific MA in an MD. An MA index can be used in different MDs.
·     With the vlan-based [ vlan-id ] or vlan vlan-id option, the command creates an MA carrying the VLAN attribute. If you do not specify the option, the command creates an MA carrying no VLAN attribute.
In an MPLS Layer 2 VPN, you must create the relevant cross-connect group and cross-connect or the relevant VSI before creating a service instance. For more information about cross-connect groups and cross-connects, see MPLS L2VPN in MPLS Configuration Guide. For more information about VSIs, see VPLS in MPLS Configuration Guide.
The total number of characters of the ma-name and md-name arguments cannot exceed 45.
# Create a level-3 MD named test_md and create service instance 5, in which the MA is identified by a VLAN and serves VLAN 100.
# Create a level-4 MD named vpnmd and create service instance 10, in which the MA is identified by vpnma and serves cross-connect ac2pw in cross-connect group vpn1.
[Sysname] cfd md vpnmd level 4
[Sysname] cfd service-instance 10 ma-id string vpnma md vpnmd xconnect-group vpn1 connection ac2pw
cfd md
cfd slm
Use cfd slm to enable short-period one-way loss measurement.
cfd slm service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ] [ dot1p dot1p-value ] [ number number ] [ interval { interval | msec msec-interval } ]
dot1p dot1p-value: Specifies an 802.1p priority for LMM frames. The value range for the dot1p-value argument is 0 to 7. The default value is 7.
number number: Specifies the number of LMM frames to be sent. The value range for the number argument is 2 to 10, and the default is 5.
interval interval: Specifies the LMM frame sending interval, in seconds. The value takes 1, 10, 60, or 600. The default value is 1.
msec msec-interval: Specifies the LMM frame sending interval, in milliseconds. The value takes 100, 1000, 10000, 60000, or 600000. The default value is 1000.
The short-period one-way LM function measures the frame loss between the source and target MEPs by using LMM frames and LMR frames.
You can implement one-way LM by using the following test types:
·     Continual one-way LM.
·     Short-period one-way LM.
·     Scheduled one-way LM.
Before enabling short-period one-way LM in an MPLS Layer 2 VPN, you must configure the same frame counting mode on the source MEP and target MEP.
Short-period one-way LM and continual two-way LM cannot be configured at the same time for one source MEP. If you have configured short-period one-way LM, you can configure continual two-way LM only after the short-period one-way LM ends. If you have configured continual two-way LM, you can configure short-period one-way LM only after you disable continual two-way LM.
# Enable the short-period one-way LM function to measure the frame loss between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd slm service-instance 1 mep 1101 target-mep 2001
Far-end frame loss : 10                   Far-end frame loss rate : 10.00%
Near-end frame loss: 20                   Near-end frame loss rate: 20.00%
Far-end frame loss : 40                   Far-end frame loss rate : 40.00%
Near-end frame loss: 40                   Near-end frame loss rate: 40.00%
Far-end frame loss : 0                    Far-end frame loss rate : 0.00%
Near-end frame loss: 10                   Near-end frame loss rate: 10.00%
Far-end frame loss : 30                   Far-end frame loss rate : 30.00%
Near-end frame loss: 30                   Near-end frame loss rate: 30.00%
Average:
Far-end frame loss : 20                   Far-end frame loss rate : 20.00%
Near-end frame loss: 25                   Near-end frame loss rate: 25.00%
Packet statistics:
Sent LMMs: 5    Received: 5
Table 5 Command output
LMR frames returned from the target MEP with MAC address 0010-FC00-6512.
Far-end frame loss
Number of lost frames on the target MEP.
Near-end frame loss
Number of lost frames on the source MEP.
Frame loss ratio on the target MEP.
Frame loss ratio on the source MEP.
Average
Average number of lost frames.
Sent LMMs
Number of sent LMM frames.
Received
Number of received LMR frames.
cfd dlm continual
cfd slm continual
cfd slm continual
Use cfd slm continual to configure continual one-way LM.
Use undo cfd slm continual to disable continual one-way LM.
cfd slm continual service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ] [ dot1p dot1p-value ] [ interval { interval | msec msec-interval }] [ period period ]
undo cfd slm continual service-instance instance-id mep mep-id
Continual one-way LM is disabled.
period period: Specifies the statistics collection period in the range of 1 to 65535 seconds.
The continual one-way LM function measures the frame loss between the source and target MEPs by using LMM frames and LMR frames.
To modify continual one-way LM settings for a source MEP, disable continual one-way LM and then reconfigure the function for the source MEP.
Before enabling continual one-way LM in an MPLS Layer 2 VPN, you must configure the same frame counting mode on the source MEP and target MEP.
To display the continual one-way LM result, use the display cfd slm history command on the device where the source MEP resides.
Inward-facing MEPs created in an Ethernet network do not support continual one-way LM.
# Enable the continual one-way LM function to measure the frame loss between source MEP 1101 and target MEP 2001 in service instance 1.
[Sysname] cfd slm continual service-instance 1 mep 1101 target-mep 2001
cfd dlm continual
cfd slm
Use cfd slm duration start to start a scheduled one-way LM.
cfd slm duration duration-time start service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ] [ dot1p dot1p-value ] [ interval { interval | msec msec-interval }]
duration-time: Specifies a one-way LM test duration in the range of 1 to 65535 seconds.
The scheduled one-way LM function measures the frame loss between the source and target MEPs by using LMM frames and LMR frames.
Before starting a scheduled one-way LM in an MPLS Layer 2 VPN, you must configure the same frame counting mode on the source MEP and target MEP.
# Start a scheduled one-way LM to measure the frame loss between source MEP 1101 and target MEP 2001 in service instance 1 within 60 seconds.
[Sysname] cfd slm duration 60 start service-instance 1 mep 1101 target-mep 2001
cfd slm
cfd slm continual
Use cfd slm duration stop to stop a scheduled one-way LM.
cfd slm duration stop service-instance instance-id mep mep-id
# Stop a scheduled one-way LM for source MEP 1101 in service instance 1.
[Sysname] cfd slm duration stop service-instance 1 mep 1101
cfd slm threshold
Use cfd slm threshold to configure the lower limit and upper limit for continual one-way LM.
Use undo cfd slm threshold to restore the default.
cfd slm { far-end | near-end } threshold service-instance instance-id mep mep-id { lower-limit lower-limit | upper-limit upper-limit } *
undo cfd slm { far-end | near-end } threshold service-instance instance-id mep mep-id [ lower-limit | upper-limit ]
The lower limit and upper limit for continual one-way LM are 0 and 100%, respectively, for both the source and target MEPs.
This command takes effect only after you configure continual one-way LM.
If the packet loss ratio for the source MEP or target MEP reaches or exceeds the upper limit for three consecutive times, the system displays a message about the situation.
If the packet loss ratios for both the source MEP and target MEP reach or fall below the lower limit for three consecutive times, the system displays a message about the situation.
[Sysname] cfd slm near-end threshold service-instance 1 mep 1101 lower-limit 0.2 upper-limit 0.8
cfd slm continual
cfd synthetic-slm
Use cfd synthetic-slm to enable short-period single-ended synthetic LM.
cfd synthetic-slm service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ] [ interval msec-interval ]
number number: Specifies the number of SLM frames to be sent. The value range for the number argument is 1 to 100, and the default is 10.
interval msec-interval: Specifies the SLM frame sending interval in milliseconds. The value takes 100 or 1000. The default value is 1000.
The short-period single-ended synthetic LM function measures the frame loss between the source and target MEPs by using SLM frames and SLR frames.
You can implement single-ended synthetic LM by using the following test types:
·     Continual single-ended synthetic LM.
·     Short-period single-ended synthetic LM.
·     Scheduled single-ended synthetic LM.
This function is supported only in EVPN VPLS, EVPN VPWS, MPLS L2VPN, and VPLS networks.
# Enable the single-ended synthetic LM function to measure the frame loss between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd synthetic-slm service-instance 1 mep 1101 target-mep 2001
Please wait while testing is in progress.
Near-end frame send: 10                   Far-end frame send: 8
Near-end frame loss: 0                    Far-end frame loss: 2
Near-end frame loss rate: 0.00%           Far-end frame loss rate: 20.00%
Table 6 Command output
Near-end frame send
Number of SLM frames sent by the source MEP.
Far-end frame send
Number of SLM frames sent by the target MEP.
Near-end frame loss
Far-end frame loss
Use cfd synthetic-slm continual to enable continual single-ended synthetic LM.
Use undo cfd synthetic-slm continual to disable continual single-ended synthetic LM.
cfd synthetic-slm continual service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ] [ interval  msec-interval ]
undo cfd synthetic-slm continual service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id }
Continual single-ended synthetic LM is disabled.
interval msec-interval: Specifies the SLM frame sending interval, in milliseconds. The value takes 1000 or 10000. The default value is 1000.
number number: Specifies the number of SLM frames to be sent at a time. The value range for the number argument is 1 to 100, and the default is 10. After the number of SLM frames are sent, a frame loss measurement is performed.
The continual single-ended synthetic LM function measures the frame loss between the source and target MEPs by using SLM frames and SLR frames.
To display the continual single-ended synthetic LM result, use the display cfd synthetic-slm history command on the device where the source MEP resides.
# Enable the continual single-ended synthetic LM function to measure the frame loss between source MEP 1101 and target MEP 2001 in service instance 1.
[Sysname] cfd synthetic-slm continual service-instance 1 mep 1101 target-mep 2001
cfd synthetic-slm
Use cfd synthetic-slm duration start to start a scheduled single-ended synthetic LM.
cfd synthetic-slm duration duration-time start service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ] [ interval  msec-interval ]
duration-time: Specifies a single-ended synthetic LM test duration in the range of 1 to 65535 seconds.
The scheduled single-ended synthetic LM function measures the frame loss between the source and target MEPs by using SLM frames and SLR frames.
# Start a scheduled single-ended synthetic LM to measure the frame loss between source MEP 1101 and target MEP 2001 in service instance 1 within 100 seconds.
<Sysname> cfd synthetic-slm duration 100 start service-instance 1 mep 1101 target-mep 2001
cfd synthetic-slm
Use cfd synthetic-slm duration stop to stop a scheduled single-ended synthetic LM.
cfd synthetic-slm duration stop service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id }
# Stop a scheduled single-ended synthetic LM that measures the frame loss between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd synthetic-slm duration stop service-instance 1 mep 1101 target-mep 2001
Use cfd synthetic-slm threshold to configure the lower limit and upper limit for continual single-ended synthetic LM.
Use undo cfd synthetic-slm threshold to restore the default.
cfd synthetic-slm { far-end | near-end } threshold service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } { lower-limit lower-limit | upper-limit upper-limit } *
undo cfd synthetic-slm { far-end | near-end } threshold service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ lower-limit | upper-limit ]
The lower limit and upper limit for continual single-ended synthetic LM are 0 and 100%, respectively, for both the source and target MEPs.
This command takes effect only after you configure continual single-ended synthetic LM.
[Sysname] cfd synthetic-slm near-end threshold service-instance 1 mep 1101 target-mep 1102 lower-limit 0.2 upper-limit 0.8
cfd tst
Use cfd tst to enable short-period test (TST).
cfd tst service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ] [ length-of-test length ] [ pattern-of-test { all-zero | prbs } [ with-crc ] ]
number number: Specifies the number of sent TST frames. The value range for the number argument is 1 to 10, and the default is 5.
length-of-test length: Specifies the length of the Test TLV (Type/Length/Value) in the TST frame. The value range for the length argument is 4 to 1400, in bytes. The default value is 64.
pattern-of-test { all-zero | prbs } [ with-crc ]: Specifies the pattern of the Test TLV in the TST frame:
·     all-zero (all-zero value without CRC-32), which is the default pattern.
·     prbs (pseudo random bit sequence without CRC-32).
·     all-zero with-crc (all-zero value with CRC-32).
·     prbs with-crc (pseudo random bit sequence with CRC-32).
The short-period TST function detects bit errors between the source and target MEPs by using TST frames.
To view the TST test result, use the display cfd tst history command on the target MEP.
# Enable the TST function to test the bit errors between source MEP 1101 and target MEP 1003 in service instance 1.
<Sysname> cfd tst service-instance 1 mep 1101 target-mep 1003
5 TSTs have been sent. Please check the result on the remote device.
reset cfd tst
cfd tst continual
Use cfd tst continual to enable continual TST.
Use undo cfd tst continual to disable continual TST.
cfd tst continual service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ length-of-test length ] [ pattern-of-test { all-zero | prbs } [ with-crc ] ] [ interval interval ]
undo cfd tst continual service-instance instance-id mep mep-id
Continual TST is disabled.
interval interval: Specifies the TST frame sending interval, in milliseconds. The value takes 100 or 1000. The default value is 1000.
The continual TST function detects bit errors between the source and target MEPs by using TST frames.
To modify continual TST settings for a source MEP, disable continual TST and then reconfigure the function for the source MEP.
Short-period TST and continual TST cannot be configured at the same time for one source MEP. If you have configured continual TST, you can configure short-period TST only after you disable continual TST. If you have configured short-period TST, you can configure continual TST only after the short-period TST ends.
To view the continual TST test result, use the display cfd tst history command on the device where the target MEP resides.
This function can be configured only in Ethernet networks. Inward-facing MEPs created in an Ethernet network do not support this function.
# Enable the continual TST function to test the bit errors between source MEP 1101 and target MEP 2001 in service instance 1.
[Sysname] cfd tst continual service-instance 1 mep 1101 target-mep 2001
cfd tst
display cfd ais
Use display cfd ais to display the AIS configuration and information on the specified MEP or all MEPs.
display cfd ais [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the AIS configuration and information for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the AIS configuration and information for all MEPs.
# Display the AIS configuration and information for all the MEPs in all service instances.
<Sysname> display cfd ais
Service instance: 5
AIS level: 4    AIS period: 1s
MEP ID: 1
AIS condition: yes   Time to enter the condition: 2013/01/22 10:43:57
AIS state machine: Previous state: NO_RECEIVE
                   Current state: RECEIVE
MEP ID: 2
Service instance: 20
AIS level: 3    AIS period: 60s
MEP ID: 10
Service instance: 100
AIS level: 6    AIS period: 1s
MEP ID: 20
AIS condition: no    Time to enter the condition: 2013/01/22 11:40:01
AIS state machine: Previous state: IDLE
                   Current state: NO_RECEIVE
MEP ID: 50
AIS condition: no    Time to enter the condition: -
Table 7 Command output
Service instance
Service instance of the MEP.
AIS level
AIS period
AIS condition
AIS status:
·     yes—AIS is running.
·     no—AIS is not running.
Time when the AIS status began. (- means AIS is enabled but the MEP does not receive any AIS frame.)
AIS state machine
AIS frame receiving state machine.
Previous state
Previous state:
·     IDLE—Not activated.
·     NO_RECEIVE—Activated.
·     RECEIVE—AIS frames are received.
Current state
Current state:
display cfd ais-track link-status
Use display cfd ais-track link-status to display the configuration and information of the AIS associated with the interface status.
display cfd ais-track link-status [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays the configuration and information of the AIS associated with the status of all interfaces.
# Display the configuration and information of the AIS associated with the status of all interfaces.
<Sysname> display cfd ais-track link-status
AIS tracking link-status is enabled.
Interface Ten-GigabitEthernet0/0/15:
AIS level: 5          AIS period: 1s
Configured VLANs: 1, 10-100, 103
Send VLANs: 1, 10-100, 103
AIS condition: yes     Time to enter the condition: 2013/02/26 10:43:57
Interface Ten-GigabitEthernet0/0/16:
Configured VLANs: 1-4094
Send VLANs: 1-2000
AIS condition: yes     Time to enter the condition: 2013/02/26 10:44:57
Table 8 Command output
Interface status-AIS collaboration is enabled.
AIS tracking link-status is disabled
Interface status-AIS collaboration is disabled.
Interface that collaborates with AIS.
AIS level
EAIS frame transmission level on the interface.
AIS period
EAIS frame transmission period on the interface.
Configured VLANs
Send VLANs
Actual VLANs where the EAIS frames can be transmitted.
AIS condition
EAIS frame sending status:
·     yes—EAIS frames are being sent.
·     no—No EAIS frame is being sent.
Time when the EAIS frame sending started.
Use display cfd dlm history to display the two-way LM result.
display cfd dlm history [ service-instance instance-id [ mep mep-id ] ] [ number number ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the two-way LM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the two-way LM results for all MEPs.
number number: Specifies the number of most recent two-way LM result entries to be displayed, in the range of 1 to 64. The default is 5.
# Display the two-way LM result for source MEP 1101 in service instance 1.
<Sysname> display cfd dlm history service-instance 1 mep 1101
Total continual tests: 1
Service instance: 1
MEP ID: 1101
Send status: Testing
Test state: Active
Far-end frame loss : 1000        Far-end frame loss rate : 0.10%
Near-end frame loss: 2000        Near-end frame loss rate: 0.20%
Far-end frame loss : 4000        Far-end frame loss rate : 0.40%
Near-end frame loss: 4000        Near-end frame loss rate: 0.00%
Near-end frame loss: 1000        Near-end frame loss rate: 0.10%
Far-end frame loss : 3000        Far-end frame loss rate : 0.30%
Near-end frame loss: 3000        Near-end frame loss rate: 0.30%
Far-end frame loss : 2000        Far-end frame loss rate : 0.20%
Near-end frame loss: 1           Near-end frame loss rate: <0.01%
Average:
Near-end frame loss: 2500        Near-end frame loss rate: 0.25%
Table 9 Command output
Total number of continual two-way LM tests.
Send status
LM test status:
·     Testing—An LM test is in progress.
·     Init—An LM test is in initialization state and is about to start.
·     Stop—An LM test stopped.
If an LM test has never been performed on a source MEP, this field displays a hyphen (-).
Test state
Test state:
·     Active.
·     Inactive (reason). Table 10 shows possible reasons for this state.
·     -—Unknown.
CCM frames returned from the target MEP with MAC address 0010-FC00-6512.
Far-end frame loss
Near-end frame loss
Average
Table 10 Reasons for the Inactive state
Reason
cfd disable
CFD is disabled.
not support
The test type is not supported.
mep disable
The MEP is disabled.
target information error
The target MEP information is incorrect.
link down
The link state is down.
frame-count mode error
The frame counting mode setting is incorrect.
rmep failed
The CC fails.
cfd dlm continual
Use display cfd dm one-way history to display the one-way DM result.
display cfd dm one-way history [ service-instance instance-id [ mep mep-id ] ] [ number number ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the one-way DM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the one-way DM results for all MEPs.
number number: Specifies the number of most recent one-way DM result entries to be displayed, in the range of 1 to 64. The default is 5.
The one-way DM results for all inward-facing MEPs in a service instance are the same.
# Display the one-way DM results for all the MEPs in all service instances.
<Sysname> display cfd dm one-way history
Total continual tests: 3
Service instance: 1
MEP ID: 1003
Test state: Active
Frame delay: 11us 9us 10us 5us 5us
Delay average: 8us
Frame jitter: 2us 1us 5us 0us
Variation average: 2us
MEP ID: 1004
Test state: Active
Frame delay: 10us 9us 11us 4us 6us
Delay average: 8us
Frame jitter: 1us 2us 7us 2us
Variation average: 3us
Service instance: 2
No MEP exists in the service instance.
Service instance: 3
MEP ID: 1023
Remaining time: 100s
Test state: Active
Frame delay: 20us 9us 8us 7us 1us 5us 13us 17us 7us 5us
Delay average: 9us
Frame jitter: 11us 1us 1us 6us 4us 8us 4us 10us 2us
Variation average: 5us
Service instance: 4
MEP ID: 1023
Test state: Active
Table 11 Command output
Total number of continual one-way DM tests.
Service instance
Remaining time
Remaining time of the scheduled one-way DM test. This field is available only when scheduled one-way DM is configured.
Send status
DM test status:
·     Testing—A DM test is in progress.
·     Init—A DM  test is in initialization state and is about to start.
·     Stop—A DM test stopped.
If a DM test has never been performed on a source MEP, this field displays a hyphen (-).
Test state
Test state:
·     Active.
·     Inactive (reason). Table 12 shows possible reasons for this state.
·     -—Unknown.
Delay average
Average frame delay.
Variation average
Average frame delay variation.
Table 12 Reasons for the Inactive state
Reason
cfd disable
CFD is disabled.
not support
mep disable
link down
rmep failed
The CC fails.
cfd dm one-way
reset cfd dm one-way history
display cfd dm one-way statistics
Use display cfd dm one-way statistics to display the one-way DM packet statistics.
display cfd dm one-way statistics [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the one-way DM packet statistics for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the one-way DM packet statistics for all MEPs.
# Display the one-way DM packet statistics for all the MEPs in all service instances.
<Sysname> display cfd dm one-way statistics
Service instance: 1
MEP ID: 1101
  Sent: 100          Received: 100
MEP ID: 2101
Service instance: 2
MEP ID: 1101
  Sent: 10           Received: 10
Table 13 Command output
Service instance
Sent
Number of sent 1DM frames.
Received
Number of received 1DM frames.
cfd dm one-way
Use display cfd dm two-way history to display the two-way DM result.
display cfd dm two-way history [ service-instance instance-id [ mep mep-id ] ] [ number number ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the two-way DM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the two-way DM results for all MEPs.
number number: Specifies the number of most recent two-way DM result entries to be displayed, in the range of 1 to 64. The default is 5.
# Display the two-way DM results for all the MEPs in all service instances.
<Sysname> display cfd dm two-way history
Total continual tests: 2
Service instance: 1
MEP ID: 1003
Test state: Active
Frame delay:
Average: 8us
Average: 2us
MEP ID: 1004
Remaining time: 30s
Send status: Init
Test state: Inactive (cfd disable)
Frame delay:
Average: 8us
Average: 2us
Service instance: 2
Table 14 Command output
Total number of continual two-way DM tests.
Remaining time
Remaining time of the scheduled two-way DM test. This field is available only when scheduled two-way DM is configured.
Send status
DM test status:
Test state
Test state:
·     Active.
·     Inactive (reason). Table 15 shows possible reasons for this state.
·     -—Unknown.
Delay of DMR frames returned from the target MEP with MAC address 0010-FC00-6512.
Average
Table 15 Reasons for the Inactive state
Reason
cfd disable
CFD is disabled.
not support
mep disable
link down
rmep failed
The CC fails.
cfd dm two-way
display cfd dm two-way statistics
Use display cfd dm two-way statistics to display the two-way DM packet statistics.
display cfd dm two-way statistics [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the two-way DM packet statistics for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the two-way DM packet statistics for all MEPs.
# Display the two-way DM packet statistics for all the MEPs in all service instances.
<Sysname> display cfd dm two-way statistics
Service instance: 1
MEP ID: 1101
MEP ID: 2101
Service instance: 2
MEP ID: 1101
Table 16 Command output
Service instance
Sent
Number of sent DMM frames.
Received
cfd dm two-way
display cfd linktrace-reply
Use display cfd linktrace-reply to display the LTR information received by a MEP.
display cfd linktrace-reply [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies the service instance ID in the range of 1 to 32767. If you do not specify this option, the command displays the LTR information for all service instances.
mep mep-id: Specifies the ID of a MEP, in the range of 1 to 8191. If you do not specify this option, the command displays the LTR information for all MEPs.
This command displays only information about LTRs received by execution of the cfd linktrace command.
# Display the LTR information saved on all the MEPs in every service instance.
<Sysname> display cfd linktrace-reply
Service instance: 1       MEP ID: 1003
0000-fc00-6505            63      0000-fc00-6504    MPDB
000f-e269-a852            62      0000-fc00-6505    FDB
0000-fc00-6508            61      000f-e269-a852    Hit
Service instance: 2       MEP ID: 1023
Table 17 Command output
Service instance
Service instance to which the MEPs that send LTMs belong.
MEP ID
ID of the MEP that sends LTMs.
MAC address
Source MAC address in the LTR message.
TTL
Last MAC
Relay action
cfd linktrace
display cfd linktrace-reply auto-detection
Use display cfd linktrace-reply auto-detection to display information about the LTR messages received as responses to the automatically sent LTMs.
display cfd linktrace-reply auto-detection [ size size-value ]
size size-value: Specifies the times of recent auto-detections, in the range of 1 to 100. If you do not specify this option, the command displays all information in the buffer.
This command displays only information about LTRs received by execution of the cfd linktrace auto-detection command.
# Display the contents of the LTRs received as responses to the LTMs automatically sent.
<Sysname> display cfd linktrace-reply auto-detection
Service instance: 1       MEP ID: 1003    Time: 2013/05/22 10:43:57
Target MEP ID: 2005       TTL: 64
Service instance: 2       MEP ID: 1023    Time: 2013/05/22 10:44:06
Target MEP ID: 2025       TTL: 64
Table 18 Command output
Service instance
Service instance to which the MEPs that sent LTM messages belong.
MEP ID
Time
Time of the LTMs automatically sent.
Target MEP ID
ID of the target MEP.
TTL
Initial TTL of the automatically sent LTMs.
MAC address
TTL
Last MAC
Relay action
display cfd md
Use display cfd md to display the MD configuration information.
display cfd md
# Display the MD configuration information.
<Sysname> display cfd md
CFD is enabled.
Maintenance domains configured: 4 in total
Level  Index      Maintenance domain                          MD format  MD ID
0      1          md_0                                        CHARSTRING md_0
1      2          md_1                                        DNS        dns1
2      3          md_2                                        MAC        0001-00
01-0001-1
3      4          md_3                                        NONE       Without
 ID
Table 19 Command output
Number of MDs configured.
Level
Level of MD.
Index
MD index.
Maintenance domain
Name of MD.
MD format
MD name format:
·     CHARSTRING—Character string.
·     DNS—DNS name.
·     MAC—MAC address and an integer.
·     NONE—No MD name is carried.
MD ID
MD ID value:
·     A character string if the MD format is CHARSTRING.
·     A DNS name if the MD format is DNS.
·     A MAC address-subnumber if the MD format is MAC.
·     No ID if the MD format is NONE.
display cfd mep
Use display cfd mep to display the attribute and operating information of a MEP.
display cfd mep mep-id service-instance instance-id
# In an Ethernet network, display the attribute and operating information of MEP 50 in service instance 1.
<Sysname> display cfd mep 50 service-instance 1
Interface: Ten-GigabitEthernet0/0/16
Maintenance domain: md_0
Maintenance domain index: 1
Maintenance association: ma_0
Maintenance association index: 1
Level: 0        VLAN: 1         Direction: Outbound
Current state: Active          CCM send: Enabled
FNG state: FNG_DEFECT_REPORTED
CCM:
Current state: CCI_WAITING
Interval: 1s        SendCCM: 12018       ReceiveCCM: 24036
Loopback:
NextSeqNumber: 8877
SendLBR: 0          ReceiveInOrderLBR: 0          ReceiveOutOrderLBR: 0
SendLBM: 0          ReceiveLBM: 0
Linktrace:
NextSeqNumber: 8877
SendLTR: 0          ReceiveLTM: 0
SendLTM: 0          ReceiveLTR: 0
No CCM received from some remote MEPs.
One or more streams of error CCMs is received. The last received CCM:
Maintenance domain: (Without ID)
Maintenance association: matest1
MEP ID: 5      Sequence Number:0x50A
MAC Address: 0011-2233-4402
Received Time: 2013/03/06 13:01:34
One or more streams of cross-connect CCMs is received. The last received CCM:
Maintenance domain: mdtest1
Maintenance association:matest1
MEP ID: 6      Sequence Number:0x63A
MAC Address: 0011-2233-4401
Some other MEPs are transmitting the RDI bit.
Table 20 Command output
Interface on which the MEP is configured.
Maintenance domain
MD to which the MEP belongs. (If the MD does not have a name, this field is displayed as Without ID.)
Index of the MD to which the MEP belongs..
Index of the MA to which the MEP belongs.
Level
Level of the MD.
VLAN
VLAN to which the MA belongs.
EthSrv
Ethernet service instance for the MEP.
Direction
Direction of the MEPs.
Current state
State of MEP:
·     Active.
·     Inactive.
CCM send
Whether the MEP sends CCM.
FNG state
State of FNG (Fault Notification Generator):
·     FNG_RESET—A fault has been cleared.
·     FNG_DEFECT—A fault has been detected.
·     FNG_REPORT_DEFECT—Report a fault.
·     FNG_DEFECT_REPORTED—A fault has been reported.
·     FNG_DEFECT_CLEARING—A fault is being cleared.
If this field is not supported, a hyphen (-) is displayed.
CCM
Information related to CCM.
Current state
State of CCMs sent:
·     CCI_IDLE—Initial state.
·     CCI_WAITING—Sending state.
Interval
Interval to send CCM. Not supported means the MEP does not support CCM sending.
SendCCM
Number of CCMs that have been sent by the MEPs.
ReceiveCCM
Number of CCMs that have been received by the MEPs.
Loopback
Information related to Loopback.
NextSeqNumber
Sequence number of the next LBM to be sent.
SendLBR
Number of LBRs that have been sent. If the MEP is inward-facing, the number of LBRs will not be counted.
ReceiveInOrderLBR
Number of LBR messages received in correct sequence.
ReceiveOutOrderLBR
Number of LBR messages received out of order.
SendLBM
Number of LBMs that have been sent. If the MEP is inward-facing, the number of LBMs will not be counted.
ReceiveLBM
Number of LBMs that have been received.
Linktrace
Information related to linktrace.
NextSeqNumber
Sequence number of the next LTM to be sent.
SendLTR
Number of LTRs sent. If the MEP is inward-facing, the number of LTRs will not be counted.
ReceiveLTM
Number of LTMs received.
SendLTM
Number of LTMs that have been sent. If the MEP is inward-facing, the number of LTMs will not be counted.
ReceiveLTR
Number of LTRs that have been received.
Failure to receive CCMs from some remote MEPs. (This information is displayed only when some CCMs are lost.)
Display the content of the last error CCM when one or more error CCMs are received. (This information is displayed only when error CCMs are received.)
Maintenance domain
MD of the last error CCM message.
MA of the last error CCM message.
MEP
ID of the MEP that sent the last error CCM message.
Sequence Number
Sequence number of the last error CCM.
Received Time
Time when the last error CCM is received.
Cross-connect CCMs are received, and the content of the last cross-connect CCM is displayed. (This information is displayed only when cross-connect CCMs are received.)
CCMs with the RDI flag bits set are received from other MEPs. (This information is displayed only when this type of CCMs are received.)
display cfd meplist
Use display cfd meplist to display the MEP list in a service instance.
display cfd meplist [ service-instance instance-id ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays MEP lists in all service instances.
# Display the MEP list in service instance 5.
<Sysname> display cfd meplist service-instance 5
Service instance: 5
MEP list: 1 to 20, 30, 50.
display cfd mp
Use display cfd mp to display the MP information.
display cfd mp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays MP information for all interfaces.
The output is arranged by interface name. On an interface, the output shows MPs that serve VLANs, and then shows MPs that do not serve any VLANs. The MPs that serve VLANs are displayed in the ascending VLAN ID order. Within the same VLAN, the output is in the order of MIPs and MEPs (from high to low level). The MEPs that do not serve any VLANs are displayed by level (from high to low).
# Display the MP information on all interfaces.
<Sysname> display cfd mp
Interface Ten-GigabitEthernet0/0/15   VLAN 100
MIP              Level: 1    Service instance: 101
Maintenance domain: md_1
Maintenance domain index: 2
Maintenance association: ma_1
Maintenance association index: 2
MEP ID: 100      Level: 0    Service instance: 100    Direction: Outbound
Interface Ten-GigabitEthernet0/0/16   VLAN NONE
MEP ID: 101      Level: 2    Service instance: 102    Direction: Inbound
Maintenance domain: md_2
Maintenance domain index: 3
Maintenance association: ma_2
Maintenance association index: 3
Table 21 Command output
MP configuration of VLAN 100 on Ten-GigabitEthernet 0/0/15.
Configuration of the MP that does not serve any VLAN or configuration of the MP in an MPLS Layer 2 VPN.
MIP
A MIP in the MP.
Level
MD level to which the MP belongs.
Service instance
Service instance to which the MP belongs.
Maintenance domain
MD to which the MP belongs.
Index of the MD to which the MP belongs.
MA to which the MP belongs.
Index of the MA to which the MP belongs.
Direction
Direction of the MEP:
·     Inbound.
·     Outbound.
display cfd remote-mep
Use display cfd remote-mep to display information about a remote MEP.
display cfd remote-mep service-instance instance-id mep mep-id
# Display remote MEP information for MEP 10 in service instance 4.
<Sysname> display cfd remote-mep service-instance 4 mep 10
MEP ID   MAC address      State        Time                  MAC status
20       00e0-fc00-6565   OK           2013/03/06 02:36:38   UP
30       00e0-fc27-6502   OK           2013/03/06 02:36:38   DOWN
40       00e0-fc00-6510   FAILED       2013/03/06 02:36:39   DOWN
50       00e0-fc52-baa0   OK           2013/03/06 02:36:44   DOWN
60       0010-fc00-6502   OK           2013/03/06 02:36:42   DOWN
Table 22 Command output
MEP ID
ID of the remote MED.
MAC address
MAC address of the remote MEP device.
Running state of the remote MEP:
·     OK.
·     FAILED.
Time
Time when the remote MEP entered the FAILED or OK state for the last time.
MAC status
State of the interface indicated by the last CCM received from the remote MEP:
·     UP—The interface is ready to pass packets.
·     DOWN—The interface cannot pass packets.
·     TESTING—The interface is in some test mode.
·     UNKNOWN—The interface status cannot be determined.
·     DORMANT—The interface is not in a state to pass packets. Instead, it is in a pending state, waiting for some external event.
·     NOT-PRESENT—Some component of the interface is missing.
·     LLD—The interface is down due to state of the lower layer interfaces.
display cfd service-instance
Use display cfd service-instance to display the configuration information of service instances.
display cfd service-instance [ instance-id ]
instance-id: Specifies a service instance ID in the range of 1 to 32767. If you do not specify this argument, the command displays configuration information for all service instances.
# In an Ethernet network, display the configuration information of all service instances.
<Sysname> display cfd service-instance
Service instances configured (2 in total):
Service instance 5:
Maintenance domain: md_5
Maintenance domain index: 5
Maintenance association: ma_5
Maintenance association index: 5
Level: 5    VLAN: 5    MIP rule: NONE    CCM interval: 1s
Direction: Inbound
MEP ID: 730  Interface: Ten-GigabitEthernet0/0/15
Service instance 6:
Maintenance domain index: 6
Maintenance association: ma_6
Maintenance association index: 6
Level: 6    VLAN: 6    MIP rule: NONE    CCM interval: 1s
Direction: Outbound
MEP ID: 731  Interface: Ten-GigabitEthernet0/0/16
Table 23 Command output
Service instances are configured.
Number of service instances configured.
Service instance
Service instance ID.
Maintenance domain
MD of the service instance. (If the MD does not have a name, this field displays Without ID.)
Index of the MD to which the service instance belong.
MA of the service instance.
Index of the MA to which the service instance belong.
Xconnect-group
Cross-connect group name.
Xconnection
Cross-connect name.
Level
MD level.
VLAN
MIP rule
MIP generation rules configured on the service instance.
CCM interval
Interval to send CCMs.
Direction
Direction of the MEPs configured on the service instance.
MEP ID
ID of MEPs configured on the service instance.
Interface of the MEP configured on the service instance.
Use display cfd slm history to display the one-way LM result.
display cfd slm history [ service-instance instance-id [ mep mep-id ] ] [ number number ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the one-way LM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the one-way LM results for all MEPs.
number number: Specifies the number of most recent one-way LM result entries to be displayed, in the range of 1 to 64. The default is 5.
# Display the one-way LM result for source MEP 1101 in service instance 1.
<Sysname> display cfd slm history service-instance 1 mep 1101
Service instance: 1
MEP ID: 1101
Test state: Active
Average:
Packet statistics:
Sent LMMs: 100    Received: 100
Table 24 Command output
Total number of continual one-way LM tests.
Remaining time
Remaining time of the scheduled one-way LM test. This field is available only when scheduled one-way LM is configured.
Send status
LM test status:
Test state
Test state:
·     Active.
·     Inactive (reason). Table 25 shows possible reasons for this state.
·     -—Unknown.
Far-end frame loss
Near-end frame loss
Average
Table 25 Reasons for the Inactive state
Reason
cfd disable
CFD is disabled.
not support
mep disable
link down
rmep failed
The CC fails.
cfd slm
cfd slm continual
display cfd slm statistics
Use display cfd slm statistics to display the one-way LM packet statistics.
display cfd slm statistics [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the one-way LM packet statistics for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the one-way LM packet statistics for all MEPs.
# Display the one-way LM packet statistics for all the MEPs in all service instances.
<Sysname> display cfd slm statistics
Service instance: 1
MEP ID: 1101
MEP ID: 2101
Service instance: 2
MEP ID: 1101
Table 26 Command output
Service instance
Sent
Received
cfd slm
cfd slm continual
display cfd status
Use display cfd status to display the CFD and AIS status.
display cfd status
# Display the CFD and AIS status.
<Sysname> display cfd status
CFD is enabled.
AIS is disabled.
Table 27 Command output
AIS is enabled
AIS is enabled.
AIS is disabled
AIS is disabled.
Use display cfd synthetic-slm history to display the single-ended synthetic LM result.
display cfd synthetic-slm history [ service-instance instance-id [ mep mep-id [ target-mac mac-address | target-mep target-mep-id ] ] ] [ number number ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the single-ended synthetic LM results for all service instances.
mep mep-id: Specifies a source MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the single-ended synthetic LM results for all source MEPs.
[ target-mac mac-address | target-mep target-mep-id ]: Specifies a target MEP by its bridge MAC address, in the format of H-H-H, or specifies a target MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the single-ended synthetic LM results for all target MEPs of the source MEP.
# Display all single-ended synthetic LM results.
<Sysname> display cfd synthetic-slm history
Service instance: 1
Test instance: mep(1101) to target-mep(1102)
Remaining time: 120s
Test status: Active
Index 1
Index 2
Index 3
Index 4
Index 5
Near-end frame send: 10                   Far-end frame send: 10
Near-end frame loss: 0                    Far-end frame loss: 0
Near-end frame loss rate: 0.00%           Far-end frame loss rate: 0.00%
Average Near-end loss rate:   0.00%       Average Far-end loss rate: 16.00%
Maximum Near-end loss rate:   0.00%       Maximum Far-end loss rate: 20.00%
Minimum Near-end loss rate:   0.00%       Minimum Far-end loss rate:  0.00%
Service instance: 2
Test instance: mep(1201) to target-mac(0010-fc00-6512)
Test status: Active
Index 1
Index 2
Index 3
Index 4
Index 5
Table 28 Command output
Total number of continual single-ended synthetic LM tests.
Remaining time
Remaining time of the scheduled single-ended synthetic LM test. This field is available only when scheduled single-ended synthetic LM is configured.
Send status
LM test status:
Test status
Test status:
·     Active.
·     Inactive (reason). Table 29 shows possible reasons for this state.
·     -—Unknown.
Index
Number of times the test was performed. For example, Index 4 indicates that the test was performed for the fourth time.
Near-end frame send
Number of SLMs sent by the source MEP.
Far-end frame send
Number of SLRs sent by the target MEP.
Near-end frame loss
Number of lost SLRs sent by the target MEP.
Far-end frame loss
Number of lost SLMs sent by the source MEP.
Frame loss ratio of SLRs sent by the target MEP.
Frame loss ratio of SLMs sent by the source MEP.
Average frame loss ratio of SLRs received by the source MEP during the statistics collection interval.
Average frame loss ratio of SLMs received by the target MEP during the statistics collection interval.
Maximum frame loss ratio of SLRs received by the source MEP during the statistics collection interval.
Maximum frame loss ratio of SLMs received by the target MEP during the statistics collection interval.
Minimum frame loss ratio of SLRs received by the source MEP during the statistics collection interval.
Minimum frame loss ratio of SLMs received by the target MEP during the statistics collection interval.
Table 29 Reasons for the Inactive state
Reason
cfd disable
CFD is disabled.
not support
mep disable
link down
rmep failed
The CC fails.
cfd synthetic-slm
Use display cfd tst history to display the TST result.
display cfd tst history [ service-instance instance-id [ mep mep-id ] ] [ number number ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the TST results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the TST results for all MEPs.
number number: Specifies the number of most recent TST result entries to be displayed, in the range of 1 to 64. The default is 5.
The TST DM results for all inward-facing MEPs in a service instance are the same.
# Display the TST results for all the MEPs in all service instances.
<Sysname> display cfd tst history
Service instance: 1
MEP ID: 1003
Test state: Active
Received from 0010-fc00-6510, Bit True,  sequence number 0
Received from 0010-fc00-6510, Bit True,  sequence number 1
Received from 0010-fc00-6510, Bit True,  sequence number 2
Received from 0010-fc00-6510, Bit True,  sequence number 3
Received from 0010-fc00-6510, Bit True,  sequence number 4
Sent TST total number: 0
Received TST total number: 5
Received bit error TST number: 0
Percentage of error messages: 0.00%
Table 30 Command output
Service instance
Send status
TST test status:
·     Testing—A TST test is in progress.
·     Init—A TST test is in initialization state and is about to start.
·     Stop—A TST test stopped.
If a TST test has never been performed on a source MEP, this field displays a hyphen (-).
Test state
Test state:
·     Active.
·     Inactive (reason). Table 31 shows possible reasons for this state.
·     -—Unknown.
TST frame with sequence number 0 was received from the MEP with MAC address 0010-FC00-6510:
·     Bit True—No bit error occurred.
·     Bit False—Bit errors occurred.
Number of sent TST frames.
Number of received TST frames.
Number of received TST frames with bit errors.
Percentage of received TST frames with bit errors.
Table 31 Reasons for the Inactive state
Reason
cfd disable
CFD is disabled.
not support
mep disable
link down
rmep failed
The CC fails.
cfd tst
reset cfd tst
reset cfd dlm history
Use reset cfd dlm history to clear the two-way LM result.
reset cfd dlm history [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command clears the two-way LM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command clears the two-way LM results for all MEPs.
# Clear the two-way LM results for all MEPs in all service instances.
<Sysname> reset cfd dlm history
cfd dlm continual
Use reset cfd dm one-way history to clear the one-way DM result.
reset cfd dm one-way history [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command clears the one-way DM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command clears the one-way DM results for all MEPs.
Clearing the one-way DM result for an inward-facing MEP clears all one-way DM results for the service instance where the inward-facing MEP resides.
# Clear the one-way DM results for all MEPs in all service instances.
<Sysname> reset cfd dm one-way history
cfd dm one-way
reset cfd dm two-way history
Use reset cfd dm two-way history to clear the two-way DM result.
reset cfd dm two-way history [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command clears the two-way DM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command clears the two-way DM results for all MEPs.
# Clear the two-way DM results for all MEPs in all service instances.
<Sysname> reset cfd dm two-way history
cfd dm two-way
cfd dm two-way continual
reset cfd slm history
Use reset cfd slm history to clear the one-way LM result.
reset cfd slm history [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command clears the one-way LM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command clears the one-way LM results for all MEPs.
# Clear the one-way LM results for all MEPs in all service instances.
<Sysname> reset cfd slm history
cfd slm
cfd slm continual
reset cfd synthetic-slm history
Use reset cfd synthetic-slm history to clear the single-ended synthetic LM result.
reset cfd synthetic-slm history [ service-instance instance-id [ mep mep-id [ target-mac mac-address | target-mep target-mep-id ] ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command clears the single-ended synthetic LM results for all service instances.
mep mep-id: Specifies a source MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command clears the single-ended synthetic LM results for all source MEPs.
[ target-mac mac-address | target-mep target-mep-id ]: Specifies a target MEP by its bridge MAC address, in the format of H-H-H, or specifies a target MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command clears the single-ended synthetic LM results for all target MEPs.
# Clear the single-ended synthetic LM result for all MEPs in all service instances.
<Sysname> reset cfd synthetic-slm history
cfd synthetic-slm
reset cfd tst
Use reset cfd tst to clear the TST result.
reset cfd tst [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command clears the TST results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command clears the TST results for all MEPs.
Clearing the TST result for an inward-facing MEP clears all TST results for the service instance where the inward-facing MEP resides.
# Clear the TST results for all MEPs in all service instances.
<Sysname> reset cfd tst
cfd tst
display cfd tst
