- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-GIR commands
- 09-Automatic configuration commands
- 10-Target configuration management commands
- 11-Device management commands
- 12-Tcl commands
- 13-Python commands
| 11-Device management commands | 1.06 MB |
display cpu-usage configuration
display cpu-usage overload summary
display diagnostic-information
display hardware-failure-detection
display hardware-failure-protection
display kernel memory alloc-failure
display kernel memory fragment free
display power-off high-temp-board
display transceiver auto-laser-down
hardware-failure-protection aggregation
hardware-failure-protection auto-down
link-quality hardware-error enable
memory-threshold usage resend-interval
monitor kernel memory fragment interval
monitor kernel memory fragment ratio
monitor resend cpu-usage core-interval
monitor resend memory-threshold
monitor resend memory-threshold dma
parity-error consistency-check log enable
parity-error consistency-check threshold
parity-error monitor log enable
parity-error monitor threshold
parity-error unrecoverable log enable
parity-error unrecoverable period
parity-error unrecoverable reboot
parity-error unrecoverable threshold
power-off high-temp-board clear
power-off high-temp-board enable
resource-monitor minor resend enable
seu-error unrecoverable reboot
transceiver auto-laser-down restart
clock datetime
Use clock datetime to set the system time.
clock datetime time date
The factory-default system time is used.
time: Specifies a time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
date: Specifies a date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION: This command changes the system time, which affects the execution of system time-related features (for example, scheduled tasks) and collaborative operations of the device with other devices (for example, log reporting and statistics collection). Before executing this command, make sure you fully understand its impact on your live network. |
Correct system time is essential to network management and communication. You must configure the system time correctly before you run the device on the network.
For the device to use the local system time, execute the clock protocol none command and this command in turn. The specified system time takes effect immediately. Then, the device uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
If you set the time zone or daylight saving time after you execute this command, the device recalculates the system time. To view the system time, use the display clock command.
# Set the system time to 08:08:08 01/01/2012.
<Sysname> clock datetime 8:8:8 1/1/2012
# Set the system time to 08:10:00 01/01/2012.
<Sysname> clock datetime 8:10 2012/1/1
clock protocol
clock summer-time
clock timezone
display clock
clock protocol
Use clock protocol to specify the system time source.
Use undo clock protocol to restore the default.
clock protocol { none | { ntp | ptp } mdc mdc-id }
undo clock protocol
The device obtains the UTC time from an NTP time source.
none: Uses the system time set by using the clock datetime command.
ptp: Uses PTP to obtain the UTC time. You must configure PTP correctly. For more information about PTP and PTP configuration, see Network Management and Monitoring Configuration Guide.
ntp: Uses NTP to obtain the UTC time. You must configure NTP correctly. For more information about NTP and NTP configuration, see Network Management and Monitoring Configuration Guide.
mdc mdc-id: Specifies an MDC by its ID.
Operating mechanism
· If you execute the clock protocol none command, the device uses the locally set system time. The device then uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
· If you execute the clock protocol { ntp | ptp } command, the device obtains the UTC time through NTP or PTP and calculates the system time. The device then periodically synchronizes the UTC time and recalculates the system time.
The system time calculated by using the UTC time from an NTP or PTP time source is more precise.
# Configure the device to use the local system time.
[Sysname] clock protocol none
clock summer-time
Use clock summer-time to set the daylight saving time.
Use undo clock summer-time to restore the default.
The daylight saving time is not set.
name: Specifies a name for the daylight saving time schedule, a case-sensitive string of 1 to 32 characters.
start-time: Specifies the start time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
start-date: Specifies the start date in one of the following formats:
· MM/DD. The value range for MM is 1 to 12. The value range for DD varies by month.
· month week day, where:
¡ month—Takes January, February, March, April, May, June, July, August, September, October, November, or December.
¡ week—Represents week of the month. It takes first, second, third, fourth, fifth, or last.
¡ day—Takes Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, or Saturday.
end-time: Specifies the end time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
end-date: Specifies the end date in one of the following formats:
¡ month—Takes January, February, March, April, May, June, July, August, September, October, November or December.
add-time: Specifies the time to be added to the standard time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the daylight saving time, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same daylight saving time as the local time.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01 and 06:00:00 on 09/01.
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
clock datetime
clock timezone
display clock
clock timezone
Use clock timezone to set the time zone.
Use undo clock timezone to restore the default.
undo clock timezone
The UTC time zone is used.
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds an offset to the UTC time or local system time.
minus: Decreases the UTC time or local system time by an offset.
zone-offset: Specifies the offset in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the time zone, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same time zone as the local time.
# Set the name of the time zone to Z5, and add 5 hours to the UTC time or local system time.
[Sysname] clock timezone Z5 add 5
clock datetime
clock summer-time
display clock
command
Use command to assign a command to a job.
Use undo command to revoke a command.
command id command
undo command id
No command is assigned to a job.
Job view
id: Specifies an ID for the command, in the range of 0 to 4294967295. A command ID uniquely identifies a command in a job. Commands in a job are executed in ascending order of their command IDs.
command: Specifies the command to be assigned to the job.
To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
If you specify the ID of an existing command for another command, the existing command is replaced.
Make sure all commands in a schedule are compliant to the command syntax. The system does not examine the syntax when you assign a command to a job.
If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
A job cannot contain the telnet, ftp, ssh2, or monitor process command.
# Assign commands to the backupconfig job to back up the startup.cfg file to the TFTP server at 192.168.100.11.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# Assign commands to the shutdownGE job to shut down Ten-GigabitEthernet 0/0/15.
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface ten-gigabitethernet 0/0/15
[Sysname-job-shutdownGE] command 3 shutdown
scheduler job
copyright-info enable
Use copyright-info enable to enable copyright statement display.
Use undo copyright-info enable to disable copyright statement display.
Copyright statement display is enabled.
# Enable copyright statement display.
[Sysname] copyright-info enable
The device will display the following statement when a user logs in:
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
display alarm
Use display alarm to display alarm information.
In standalone mode:
display alarm [ slot slot-number ]
In IRF mode:
display alarm [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays alarm information for all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays alarm information for all cards. On this device, the slot-number argument represents the entire device and its value is fixed. (In IRF mode.)
If a power module, CPU, or fan is operating abnormally on the device, you can use the display alarm command to view the alarm information. To view historical alarms that have been cleared, use the display alarm history command. To view active alarms that were generated in the past and have not been cleared on the device, use the display alarm active command.
# Display alarm information.
<Sysname> display alarm
Slot CPU Level Info
0 0 ERROR Board is faulty
Slot |
Slot that generated the alarm. If the alarm was generated by the frame, this field displays a hyphen (-). |
Level |
Alarm severity. Possible values include ERROR, WARNING, NOTICE, and INFO, in descending order of severity. |
Info |
Detailed alarm information: · Board is faulty—The slot is starting up or faulty. · Fan n is absent—The specified fan is absent. · Power n is absent—The specified power supply is absent. · The temperature of sensor n exceeds the lower limit—The temperature of the specified sensor is lower than the low-temperature alarm threshold. · The temperature of sensor n exceeds the upper limit—The temperature of the specified sensor is higher than the high-temperature alarm threshold. |
Use display alarm active to display information about active alarms.
display alarm active [ module module-name ] [ verbose ]
module module-name: Specifies a module by its name. If you do not specify a module, this command displays alarm information for all modules.
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information.
# (In standalone mode.) Display information about active alarms.
<Sysname> display alarm active
Seq Module Level Time Info
24 BGP Minor 2023-11-08 20:11:55 BGP peer 14.1.1.99 state changed to IDLE.
23 IF Major 2023-11-08 20:33:10 Line protocol state on the interface M-GigabitEthernet0/0/0 changed to down.
Seq |
Alarm sequence number, assigned when an alarm occurs. |
Module |
Alarm module name. |
Level |
Alarm severity. The values include Critical, Major, Minor, and Warning, in descending order of severity. |
Time |
Time when the alarm occurs. |
Info |
Detailed alarm information. The values include: · Board state changed to Fault on slot n—The state of the specified slot changed to Fault. The slot might be starting up or might be faulty. · Slot n fan n is absent—The specified fan is absent. · Slot n fan n is failed—The specified fan is abnormal. · Slot n power n is absent—The specified power module is absent. · Slot n power n failed—The specified power module is abnormal. · Temperature is higher than the high-temperature alarming threshold on slot n sensor inflow—The temperature of the specified sensor has exceeded the high-temperature warning threshold. · Memory minor threshold has been exceeded on slot n—The amount of free memory space on the specified slot has exceeded the minor alarm threshold. · CPU usage is in minor alarm state on slot n—The CPU usage on the specified slot has exceeded the minor alarm threshold. · Interface-name: RX power is high!—The optical power on the specified interface is too high. · Interface-name:The bit error ratio exceeds the upper threshold—The bit error rate of the specified interface has exceeded the upper limit. · SSH user username (IP: IP-Address) connected to the server successfully—The specified SSH user at the specified IP address has logged in to the server successfully. · Member port xx of aggregation group xx changed to the inactive state, because xx.—The specified member port of the specified aggregation group changed to inactive for a reason. · The mpls ldp session status changes. (SessionState=$1, DiscontinuityTime=$2, StatsUnknownMesTypeErrors=$3, StatsUnknownTlvErrors=$4)—The status of an LDP session changes: ¡ $1: LDP session status, including nonexistent, initialized, openrec, opensent, and operational. For more information about LDP sessions states, see LDP commands in MPLS Command Reference. ¡ $2: Duration when the LDP session is in the operational state. ¡ $3: Times that the LDP session received unknown messages. ¡ $4: Times that the LDP session received unknown TLVs. · The number of routes received from the BGP peer exceeded the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6) ¡ $1: BGP instance name. ¡ $2: Address Family Identifier (AFI). ¡ $3: Subsequent Address Family Identifier (SAFI). ¡ $4: IP type of the BGP peer. ¡ $5: IP address of the BGP peer. ¡ $6: The maximum number of routes that the device can receive from a BGP peer. · BGP $1.$2: The number of routes from peer $3 ($4-$5) exceeds the limit $6. ¡ $1: BGP instance name. ¡ $2: VPN instance name. For a log message on public network, this field is null. ¡ $3: IP address of the BGP peer. ¡ $4: Address Family Identifier (AFI). ¡ $5: Subsequent Address Family Identifier (SAFI). ¡ $6: The maximum number of route prefixes that can be received from the peer. · BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has reached the threshold ($7). ¡ $1: BGP instance name. ¡ $2: VPN instance name. For a log message on public network, this field is null. ¡ $3: IP address of the BGP peer. ¡ $4: Address Family Identifier (AFI). ¡ $5: Subsequent Address Family Identifier (SAFI). ¡ $6: The maximum number of routes that the device can receive from a BGP peer. ¡ $7: The number of routes received by the device when the percentage of received routes to the maximum number of allowed routes reaches the alarm threshold. · The number of routes received from the BGP peer exceeded the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7). ¡ $1: BGP instance name. ¡ $2: Address Family Identifier (AFI). ¡ $3: Subsequent Address Family Identifier (SAFI). ¡ $4: IP type of the BGP peer. ¡ $5: IP address of the BGP peer. ¡ $6: The maximum number of routes that the device can receive from a BGP peer. ¡ $7: The number of routes received by the device when the percentage of received routes to the maximum number of allowed routes reaches the alarm threshold. · Address pool pool-name has run out of assignable subnets · Address pool pool-name has run out of IP addresses · Address pool group pool-group-name has run out of IP addresses · Address pool group pool-group-name has run out of assignable subnets · Address pool pool-name has run out of IPv6 prefix ranges · IPv6 pool pool-name has run out of addresses · Address pool pool-name has run out of IPv6 prefixes · IPv6 pool group pool-group-name has run out of addresses · Address pool group pool-group-name has run out of assignable subnets · Address pool group pool-group-name has run out of IPv6 prefix ranges · Memory alert has been triggered for reaching the minor threshold |
# (In standalone mode.) Display detailed information about active alarms.
<Sysname> display alarm active verbose
Module: IF
Alarm name: linkUpDown
Alarm source: interface M-GigabitEthernet0/0/0
Level: Major
Start time: 2023-11-09 09:31:25
Info: Line protocol state on the interface M-GigabitEthernet0/0/0 changed to down.
Seq |
Module |
Alarm source |
Location where the alarm occurs. |
Level |
Start time |
Info |
Detailed alarm information. |
# (In IRF mode.) Display information about active alarms.
Seq |
Module |
Level |
Time |
Time when an alarm occurs. |
Info |
Detailed alarm information. The values include: · Board state changed to Fault on chassis n slot n—The state of the specified card changed to Fault. The card might be starting up or might be faulty. · Chassis n slot n fan n is absent—The specified fan is absent. · Chassis n slot n fan n is failed—The specified fan is abnormal. · Chassis n slot n power n is absent—The specified power module is absent. · Chassis n slot n power n failed—The specified power module is abnormal. · Temperature is higher than the high-temperature alarming threshold on chassis n slot n sensor inflow—The temperature of the specified sensor has exceeded the high-temperature warning threshold. · Memory minor threshold has been exceeded on chassis n slot n—The amount of free memory space on the specified slot has exceeded the minor alarm threshold. · CPU usage is in minor alarm state on chassis n slot n—The CPU usage on the specified slot has exceeded the minor alarm threshold. · Interface-name: RX power is high!—The optical power on the specified interface is too high. · Interface-name:The bit error ratio exceeds the upper threshold—The bit error rate of the specified interface has exceeded the upper limit. · SSH user username (IP: IP-Address) connected to the server successfully—The specified SSH user at the specified IP address has logged in to the server successfully. · Member port xx of aggregation group xx changed to the inactive state, because xx.—The specified member port of the specified aggregation group changed to inactive for a reason. · The mpls ldp session status changes. (SessionState=$1, DiscontinuityTime=$2, StatsUnknownMesTypeErrors=$3, StatsUnknownTlvErrors=$4)—The status of an LDP session changes: ¡ $1: LDP session status, including nonexistent, initialized, openrec, opensent, and operational. ¡ $2: Duration when the LDP session is in the operational state. ¡ $3: Times that the LDP session received unknown messages. ¡ $4: Times that the LDP session received unknown TLVs. · The number of routes received from the BGP peer exceeded the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6) ¡ $1: BGP instance name. ¡ $2: Address Family Identifier (AFI). ¡ $3: Subsequent Address Family Identifier (SAFI). ¡ $4: IP type of the BGP peer. ¡ $5: IP address of the BGP peer. ¡ $6: The maximum number of routes that the device can receive from a BGP peer. · BGP $1.$2: The number of routes from peer $3 ($4-$5) exceeds the limit $6. ¡ $1: BGP instance name. ¡ $2: VPN instance name. For a log message on public network, this field is null. ¡ $3: IP address of the BGP peer. ¡ $4: Address Family Identifier (AFI). ¡ $5: Subsequent Address Family Identifier (SAFI). ¡ $6: The maximum number of route prefixes that can be received from the peer. · BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has reached the threshold ($7). ¡ $1: BGP instance name. ¡ $2: VPN instance name. For a log message on public network, this field is null. ¡ $3: IP address of the BGP peer. ¡ $4: Address Family Identifier (AFI). ¡ $5: Subsequent Address Family Identifier (SAFI). ¡ $6: The maximum number of routes that the device can receive from a BGP peer. ¡ $7: The number of routes received by the device when the percentage of received routes to the maximum number of allowed routes reaches the alarm threshold. · The number of routes received from the BGP peer exceeded the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7). ¡ $1: BGP instance name. ¡ $2: Address Family Identifier (AFI). ¡ $3: Subsequent Address Family Identifier (SAFI). ¡ $4: IP type of the BGP peer. ¡ $5: IP address of the BGP peer. ¡ $6: The maximum number of routes that the device can receive from a BGP peer. ¡ $7: The number of routes received by the device when the percentage of received routes to the maximum number of allowed routes reaches the alarm threshold. · Address pool pool-name has run out of assignable subnets · Address pool pool-name has run out of IP addresses · Address pool group pool-group-name has run out of IP addresses · Address pool group pool-group-name has run out of assignable subnets · Address pool pool-name has run out of IPv6 prefix ranges · IPv6 pool pool-name has run out of addresses · Address pool pool-name has run out of IPv6 prefixes · IPv6 pool group pool-group-name has run out of addresses · Address pool group pool-group-name has run out of assignable subnets · Address pool group pool-group-name has run out of IPv6 prefix ranges · Memory alert has been triggered for reaching the minor threshold |
# (In IRF mode.) Display detailed information about active alarms.
Seq 4
Module: IF
Level: Major
Table 5 Command output
Seq |
Module |
Alarm source |
Level |
Start time |
Info |
display alarm
Use display alarm history to display information about historical alarms that have been cleared.
display alarm history [ module module-name ] [ verbose ]
If a power module, CPU, or fan is operating abnormally on the device, use the display alarm command to view the alarm information. To view historical alarms that have been cleared, use the display alarm history command. To view active alarms that were generated in the past and have not been cleared on the device, use the display alarm active command.
# (In standalone mode.) Display brief information about historical alarms.
<Sysname> display alarm history
Seq Module Time Info
5 IF 2023-11-08 20:12:21 Line protocol state on the interface M-GigabitEthernet0/0/0 changed to up.
For information about the fields in the command output, see Table 2.
# (In standalone mode.) Display detailed information about historical alarms.
<Sysname> display alarm history verbose
Seq 4
Module: IF
Level: Major
Recovery time: 2023-11-09 09:42:01
Info: Line protocol state on the interface M-GigabitEthernet0/0/0 changed to up.
Table 6 Command output
Seq |
Alarm sequence number, assigned automatically by the system when an alarm occurs. |
Module |
AlarmPosition |
Start time |
Level |
Recovery time |
Time when an alarm is cleared. |
Info |
Detailed alarm information. The values include: · BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has fallen below the threshold ($7). ¡ $1: BGP instance name. ¡ $2: VPN instance name. For a log message on public network, this field is null. ¡ $3: IP address of the BGP peer. ¡ $4: Address Family Identifier (AFI). ¡ $5: Subsequent Address Family Identifier (SAFI). ¡ $6: The maximum number of routes that can be received from the peer. ¡ $7: The number of routes received by the device when the percentage of received routes to the maximum number of allowed routes reaches the alarm threshold. · The number of routes received from the BGP peer decreased below the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7). ¡ $1: BGP instance name. ¡ $2: Address Family Identifier (AFI). ¡ $3: Subsequent Address Family Identifier (SAFI). ¡ $4: IP type of the BGP peer. ¡ $5: IP address of the BGP peer. ¡ $6: The maximum number of routes that the device can receive from a BGP peer. ¡ $7: The number of routes received by the device when the percentage of received routes to the maximum number of allowed routes reaches the alarm threshold. · The number of routes received from the BGP peer decreased below the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6). ¡ $1: BGP instance name. ¡ $2: Address Family Identifier (AFI). ¡ $3: Subsequent Address Family Identifier (SAFI). ¡ $4: IP type of the BGP peer. ¡ $5: IP address of the BGP peer. ¡ $6: The maximum number of routes that the device can receive from a BGP peer. · BGP $1.$2: The number of routes from peer $3 ($4-$5) fell below the limit $6. ¡ $1: BGP instance name. ¡ $2: VPN instance name. For a log message on public network, this field is null. ¡ $3: IP address of the BGP peer. ¡ $4: Address Family Identifier (AFI). ¡ $5: Subsequent Address Family Identifier (SAFI). ¡ $6: The maximum number of routes that the device can receive from a BGP peer. · The subnet usage of pool pool-name has descended to or dropped below 90%. · The IP address usage of pool pool-name has descended to 90%. · The IP address usage of pool group pool-group-name has descended to 90%. · The subnet usage of pool group pool-group-name has descended to or dropped below 90%. · The IPv6 prefix range usage of address pool pool-name has descended to or dropped below 90%. · The IPv6 address usage of pool pool-name has dropped to or below 90%. · The IPv6 prefix usage of pool pool-name has descended to 90%. · The IPv6 address usage of pool group pool-group-name has dropped to or below 90%. · The subnet usage of pool group pool-group-name has descended to or dropped below 90%. · The IPv6 prefix range usage of address pool group pool-group-name has descended to or dropped below 90%. · The memory usage has returned to a normal state. |
# (In IRF mode.) Display brief information about historical alarms.
For information about the fields in the command output, see Table 4.
Seq 4
Module: IF
Level: Major
Table 7 Command output
Seq |
Module |
AlarmPosition |
Start time |
Level |
Recovery time |
Time when the alarm is cleared. |
Info |
display alarm
display clock
Use display clock to display the system time, date, time zone, and daylight saving time.
display clock
# Display the system time and date when the time zone is not specified.
<Sysname> display clock
10:09:00 UTC Fri 03/16/2015
The time is in the hour:minute:second.milliseconds format.
# Display the system time and date when the time zone Z5 is specified.
15:10:00 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# Display the system time and date when the time zone Z5 and daylight saving time PDT are specified.
15:11:00 Z5 Fri 03/16/2015
clock datetime
clock timezone
clock summer-time
display copyright
Use display copyright to display the copyright statement.
display copyright
# Display the copyright statement.
<Sysname> display copyright
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
In standalone mode:
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ]
In IRF mode:
display cpu-usage [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ]
control-plane: Displays CPU usage statistics for the control plane.
data-plane: Displays CPU usage statistics for the data plane.
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage statistics for all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command displays CPU usage statistics for all cards. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number.
core core-number: Specifies a CPU core by its number.
core all: Specifies all CPU cores.
If you do not specify the control-plane or data-plane keyword, the command displays the CPU usage statistics for the control plane.
If two hyphens (--) are displayed for the CPU usage during the most recent 5-second, 1-minute, and 5-minute intervals, the command might fail to obtain data from the database on the device. Try the command later.
# (In standalone mode.) Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
Slot 0 CPU 0 CPU usage:
1% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
# (In standalone mode.) Display the current CPU usage statistics in table form.
<Sysname> display cpu-usage summary
Slot CPU Last 5 sec Last 1 min Last 5 min
0 0 17% 29% 28%
Table 8 Command output
x% in last 5 seconds Last 5 sec |
Average CPU or CPU core usage during the most recent 5-second interval. |
y% in last 1 minute Last 1 min |
Average CPU or CPU core usage during the most recent 1-minute interval. |
z% in last 5 minutes Last 5 min |
Average CPU or CPU core usage during the most recent 5-minute interval. |
Use display cpu-usage configuration to display CPU usage monitoring settings.
In standalone mode:
In IRF mode:
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage monitoring settings for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command displays the CPU usage monitoring settings for the global active MPU. (In IRF mode.)
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 99%.
Current minor alarm threshold is 79%.
Current recovery threshold is 69%.
Table 9 Command output
CPU usage monitor is xxx. |
Whether CPU usage tracking is enabled. |
Current monitor interval is xxx. |
Sampling interval for CPU usage tracking. |
Current severe alarm threshold is xxx. |
Severe CPU usage alarm threshold. |
Current minor alarm threshold is xxx. |
Minor CPU usage alarm threshold. |
Current recovery-threshold is xxx. |
CPU usage recovery threshold. |
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage threshold
display cpu-usage history
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
In standalone mode:
In IRF mode:
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
job job-id: Specifies a process by its ID in the range of 1 to 2147483647. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Configuration Guide.
slot slot-number: Specifies a card by its slot number. If you specify a process but do not specify a card, this command displays the statistics for the process on the active MPU. If you do not specify any options, this command displays the statistics for all processes on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you specify a process but do not specify a card, this command displays the statistics for the process on the global active MPU. If you do not specify any options, this command displays the statistics for all processes on all cards. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you specify a process but do not specify a CPU, this command displays the statistics for the default CPU. If you do not specify a process or CPU, this command displays the historical statistics for all CPUs.
After CPU usage monitoring is enabled, the system regularly samples CPU usage and saves the samples to the history record buffer. This command displays the most recent 60 samples in a coordinate system as follows:
· The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
· The horizontal axis represents the time.
· Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# (In standalone mode.) Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
95%|
90%|
85%|
80%|
75%|
70%|
65%|
60%|
55%|
50%|
45%|
40%|
35%|
30%|
25%|
20%|
15%| #
10%| ### #
5%| ########
10 20 30 40 50 60 (minutes)
cpu-usage (Slot 0 CPU 0) last 60 minutes (SYSTEM)
The output shows the following items:
· Process name. The name SYSTEM represents the entire system.
· CPU that is holding the process: CPU 0 in slot 0.
· Historical CPU usage statistics for the entire system during the last 60 minutes.
¡ 12 minutes ago—Approximately 5%.
¡ 13 minutes ago—Approximately 10%.
¡ 14 minutes ago—Approximately 15%.
¡ 15 minutes ago—Approximately 10%.
¡ 16 and 17 minutes ago—Approximately 5%.
¡ 18 minutes ago—Approximately 10%.
¡ 19 minutes ago—Approximately 5%.
¡ Other time—2% or lower.
Use display cpu-usage overload to display CPU overload records.
In standalone mode:
display cpu-usage overload show-number [ stack-info ] slot slot-number [ cpu cpu-number ]
In IRF mode:
display cpu-usage overload show-number [ stack-info ] chassis chassis-number slot slot-number [ cpu cpu-number ]
show-number: Specifies the number of CPU overload records to be displayed, in the range of 1 to 10.
stack-info: Displays the stack information about the top three CPU resource-intensive processes. If you do not specify this keyword, the command does not display stack information.
slot slot-number: Specifies a card by its slot number. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# (In standalone mode.) Display the most recent CPU overload record of a slot, excluding the stack information about the top three CPU resource-intensive processes.
<Sysname> display cpu-usage overload 2 slot 0
CPU overload summary information:
Slot/CPU Time Overload status Processes
0/0 0000-00-00 00:00:00:000 No overloaded NA
No CPU overload history.
# (In IRF mode.) Display the most recent CPU overload record of a card, excluding the stack information about the top three CPU resource-intensive processes.
<Sysname> display cpu-usage overload 1 chassis 1 slot 0 cpu 0
Chassis/Slot/CPU Time Overload status Processes
1/0/0 2018-11-12 12:00:00:000 Recovered 300
2018-11-12 11:00:00:000 Minor alarm 400
2018-11-12 10:00:00:000 Severe alarm 500
2018-11-12 09:00:00:000 Minor alarm 400
CPU overload history on overload time 2018-11-12 11:00:00:000.
CPU utilization in recent 5 secs: 100.0%; 1 min: 100.0%; 5 mins: 100.0%.
Top services in recent 5 secs:
Service 5sec 1min 5min
SYSTEM 0.6% 0.0% 0.0%
BGP 0.6% 0.0% 0.0%
VLAN 0.6% 0.0% 0.0%
ND 0.5% 0.0% 0.0%
ARP 0.4% 0.0% 0.0%
AAA 0.0% 0.0% 0.0%
TUNNEL 0.4% 0.0% 0.0%
Top processes in recent 5 secs:
JID PID PPID CPU State Mem 5sec 1min 5min Name
811795 811795 811792 0 S 21584K 0.6% 0.0% 0.0% login
811801 811801 811799 0 S 21524K 0.6% 0.0% 0.0% login
811796 811796 811794 0 S 21524K 0.5% 0.0% 0.0% login
257 257 2 0 S 0K 0.0% 0.0% 0.0% [CLKM]
206 206 2 0 S 0K 0.0% 0.0% 0.0% [DIPC]
679 679 342 0 S 137324K 0.1% 0.0% 0.0% comsh
211 211 2 0 D 0K 0.0% 0.0% 0.0% [DTIM]
1778 1778 342 0 S 95352K 0.0% 0.0% 0.0% comsh
261 261 2 0 D 0K 0.0% 0.0% 0.0% [TEMP]
# (In IRF mode.) Display the most recent two CPU overload records of a card, including the stack information about the top three CPU resource-intensive processes.
<Sysname> display cpu-usage overload 2 stack-info chassis 1 slot 0 cpu 0
CPU overload information:
1/0/0 2018-11-12 11:00:00:000 Minor alarm 400
CPU utilization in 5 secs: 100.0%; 1 min: 100.0%; 5 mins: 100.0%.
BGP 0.6% 0.0% 0.0%
VLAN 0.6% 0.0% 0.0%
ND 0.5% 0.0% 0.0%
ARP 0.4% 0.0% 0.0%
AAA 0.0% 0.0% 0.0%
1 1 0 0 S 21584K 0.6% 0.0% 0.0% scmd
152 152 1 0 S 21524K 0.6% 0.0% 0.0% ifmgr
153 153 1 0 S 21524K 0.5% 0.0% 0.0% edev
805 805 804 0 S 21440K 0.4% 0.0% 0.0% login
Stack information of process 1 (scmd):
Thread LWP 1:
Switches: 2205
User stack:
#0 0x00007f957d47b320 in epoll_wait+0x14/0x2e
#1 0x0000000000422c1c in ScmMainThread+0x51/0x125
#2 0x0000000000422650 in main+0xd0/0xd7
#3 0x00007f957d4a7ad0 in __uClibc_main+0x242/0x26c
#4 0x0000000000407519 in _start+0x29/0x2a
Kernel stack:
[<ffffffff811eeca3>] ep_poll+0x2f3/0x370
[<ffffffff811eedf0>] SyS_epoll_wait+0xd0/0xe0
[<ffffffff814deb39>] system_call_fastpath+0x16/0x1b
[<ffffffffffffffff>] 0xffffffffffffffff
Stack information of process 152 (ifmgr):
Thread LWP 152:
Switches: 177
User stack:
#0 0x00007f4418429154 in pthread_cond_wait+0xc4/0x203
#1 0x00007f4416b138d0 in logicFlowRoutine+0x1b/0x49
#2 0x0000000000403e33 in main+0x12c/0x133
#3 0x00007f4415deaad0 in __uClibc_main+0x242/0x26c
#4 0x00000000004038f9 in _start+0x29/0x2a
Kernel stack:
[<ffffffff81107287>] futex_wait_queue_me+0xd7/0x140
[<ffffffff811074f0>] futex_wait+0x190/0x280
[<ffffffff81109725>] do_futex+0xe5/0xcf0
[<ffffffff8110a477>] SyS_futex+0x147/0x180
Thread LWP 154:
Switches: 3222
User stack:
#0 0x00007f4415dbe320 in epoll_wait+0x14/0x2e
#1 0x00007f4416b106ef in lipcRoutine+0x6f/0xa5
#2 0x00007f44184219e0 in ??
#3 0x00007f4418427fe5 in __clone+0x79/0x83
Kernel stack:
Thread LWP 156:
Switches: 3151
User stack:
#1 0x00007f4416b15cf8 in miscJobsRoutine+0x18/0x80
Kernel stack:
Stack information of process 153 (edev):
Thread LWP 153:
Switches: 163
User stack:
#0 0x00007f7d3c276320 in epoll_wait+0x14/0x2e
#1 0x0000000000413748 in main+0x9f/0x10f
#2 0x00007f7d3c2a2ad0 in __uClibc_main+0x242/0x26c
#3 0x00000000004082f9 in _start+0x29/0x2a
Kernel stack:
Thread LWP 155:
Switches: 1
User stack:
#0 0x00007f7d3c2a22fd in __read+0x2d/0x5e
#1 0x0000000000414be6 in EdevDisioctlThread+0x2d/0x72
#2 0x00007f7d3dacc9e0 in ??
#3 0x00007f7d3dad2fe5 in __clone+0x79/0x83
Kernel stack:
[<ffffffff811f15dd>] eventfd_ctx_read+0x15d/0x210
[<ffffffff811f16dd>] eventfd_read+0x4d/0x80
[<ffffffff811ab621>] vfs_read+0xa1/0x160
[<ffffffff811ab7c4>] SyS_read+0x54/0xc0
CPU Overload history on overload time 2018-11-12 10:00:00:000.
BGP 0.6% 0.0% 0.0%
VLAN 0.6% 0.0% 0.0%
ND 0.5% 0.0% 0.0%
ARP 0.4% 0.0% 0.0%
AAA 0.0% 0.0% 0.0%
Thread (LWP 1):
Switches: 2205
User stack:
Kernel stack:
Thread (LWP 152):
Switches: 177
User stack:
Kernel stack:
Thread (LWP 154):
Switches: 3222
User stack:
Kernel stack:
Thread (LWP 156):
Switches: 3151
User stack:
Kernel stack:
Thread (LWP 153):
Switches: 163
User stack:
Kernel stack:
Thread (LWP 155):
Switches: 1
User stack:
Kernel stack:
Time |
Time when the overload event occurred. If no overload events occurred, this field displays 0000-00-00 00:00:00:000. |
Overload status |
Overload status: · No overloaded—The CPU is not overloaded. This state is the initial state. · Minor alarm—The CPU load exceeded the minor alarm threshold. · Severe alarm—The CPU load exceeded the severe alarm threshold. · Recovered—The CPU load dropped below the CPU overload alarm-removed threshold. |
Processes |
Number of processes when the overload event occurred. If no overload events occurred, this field displays NA. |
CPU overload history on overload time 2018-11-12 10:00:00:000: |
Detailed CPU overload information. If no overload events occurred, this field displays No CPU overload history. |
Overload time |
Top services in recent 5 secs |
Top services within the most recent 5 seconds by usage, in descending order. |
Top processes in recent 5 secs |
Top CPU resource-intensive processes in recent 5 seconds by usage, in descending order. |
JID |
Job ID. A job ID uniquely identifies a process and does not change after a process reboot. |
PID |
Process ID. |
PPID |
ID of the parent process. |
CPU |
CPU where the process was running when it was most recently scheduled. |
State |
Process status: · R—The process is running or in the run queue. · S—The process is in interruptible sleeping state. · T—The process is in traced or stopped state. · D—The process is in uninterruptible sleeping state. · Z—The process is in zombie state. |
Mem |
Memory space used by the process. For a kernel thread, this field displays 0. |
5sec |
CPU utilization in the last 5 seconds. |
1min |
CPU utilization in the last minute. |
5min |
CPU utilization in the last 5 minutes. |
Name |
Process name. For a kernel thread, this field displays the name in a pair of brackets ([ ]). |
Stack information of process PID (process name): |
Stack information of a process. The PID indicates the process ID. |
Thread LWP 1: |
Child process of a traced process. |
Switches |
Total number of switches. |
User stack |
User space stack information. This field is displayed only for a process in the user space. |
Kernel stack |
Kernel space stack information. This field is displayed only for a process in the kernel space. |
Use display cpu-usage overload summary to display summary CPU overload information.
# (In standalone mode.) Display summary CPU overload information.
<Sysname> display cpu-usage overload summary
1/0 2018-11-12 12:00:00:000 Recovered 300
# (In IRF mode.) Display summary CPU overload information.
1/1/0 0000-00-00 00:00:00:000 No overloaded NA
1/2/0 2018-11-12 12:00:00:000 Recovered 300
1/3/0 0000-00-00 00:00:00:000 No overloaded NA
For information about the fields in the command output, see Table 10.
display cpu-usage service
Use display cpu-usage service to display CPU usage of all services.
In standalone mode:
display cpu-usage service [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display cpu-usage service [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays informtion for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you do not specify a CPU, this command displays information for all CPUs.
# Display CPU usage of all services.
<Sysname> display cpu-usage service slot 0
CPU utilization in 5 secs: 16.8%; 1 min: 4.7%; 5 mins: 4.7%
BGP 0.6% 0.0% 0.0%
VLAN 0.6% 0.0% 0.0%
ND 0.5% 0.0% 0.0%
ARP 0.4% 0.0% 0.0%
Table 11 Command output
CPU utilization in 5 secs: 16.8%; 1 min: 4.7%; 5 mins: 4.7% |
CPU usage within the most recent 5 seconds; CPU usage within the most recent 1 minute; CPU usage within 5 minutes |
Service |
Service ID that uniquely identifies a process. This ID will not change with the process restart. |
5sec |
CPU usage within the most recent 5 seconds |
1min |
CPU usage within the most recent 1 minute |
5min |
display process cpu (Network Management and Monitoring Command Reference)
display current energy-saving
Use display current energy-saving to display information about the current energy saving mode and energy saving policies.
# Display information about the current energy saving mode and policies.
<Sysname> display current energy-saving
Current energy-saving mode: basic
Enabled energy-saving policy including:
Automatic-transceiver-laser-shutdown
Redundant-power-modules-sleep
Interface-auto-sleep
Table 12 Command output
Enabled energy-saving policy including |
Current energy saving policies that take effect, including: · Fan-auto—Fan speed adjustment. · Serdes-down—Serdes energy saving. · Interface-auto-sleep—Interface sleep. · slice-auto-sleep—Slice sleep. · Redundant-power-modules-sleep—Redundant power module sleep. · Power-auto-down—Power auto shutdown. · Automatic-transceiver-laser-shutdown—Transceiver module sleep. |
energy-saving mode
display device
Use display device to display device information.
In standalone mode:
display device [ cf-card | flash | sd-card ] [ slot slot-number [ subslot subslot-number ] | verbose ]
In IRF mode:
display device [ cf-card | flash | sd-card ] [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] | verbose ]
cf-card: Displays CF card information.
flash: Displays flash memory information.
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards. On this device, the slot-number argument represents the entire device and its value is fixed.
subslot subslot-number: Specifies a subcard by its subslot number. If you do not specify a subcard, this command does not display information about any subcards.
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information, and does not display firewall card information.
If you do not specify the cf-card, flash, and sd-card keywords, this command displays information about cards.
# (In standalone mode.) Display device information.
<Sysname> display device
Table 13 Command output
Brd Type |
Hardware type of the card. |
Brd Status |
Card status: · Standby—The card is the standby MPU. · Master—The card is the active MPU. · Absent—The slot is not installed with a card. · Fault—The card is faulty and cannot start up. · Normal—The card is an interface card and is operating correctly. · Off—The card is not powered on. · Illegal—The current software version does not support the card. The card cannot operate correctly. · Offline—The card is isolated. · Mismatched—The card model is not supported on the device or the slot does not support the card. |
display device manuinfo
Use display device manuinfo to display electronic label information for the device.
In standalone mode:
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
In IRF mode:
display device manuinfo [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays electronic label information for all member devices. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays electronic label information of all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified.
An electronic label contains the permanent configuration information, including the hardware serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during hardware debugging or testing. This command displays only part of the electronic label information.
# (In standalone mode.) Display electronic label information for the device.
<Sysname> display device manuinfo
Table 14 Command output
DEVICE_NAME |
Device name. |
DEVICE_SERIAL_NUMBER |
Serial number. |
MAC_ADDRESS |
MAC address. |
MANUFACTURING_DATE |
Manufacturing date. |
VENDOR_NAME |
Vendor name. |
display device manuinfo power
Use display device manuinfo power to display electronic label information for a power module.
In standalone mode:
display device manuinfo power power-id
In IRF mode:
display device manuinfo chassis chassis-number power power-id
chassis chassis-number: Specifies an IRF member device by its member ID. (In IRF mode.)
power-id: Specifies a power module by its ID.
# (In standalone mode.) Display electronic label information for a power module.
<Sysname> display device manuinfo power 1
DEVICE_NAME |
Device name. |
Serial number. |
MAC_ADDRESS |
MAC address. |
VENDOR_NAME |
Vendor name. |
Use display diagnostic-information to display or save diagnostic information for features and hardware modules.
display diagnostic-information [ custom string | hardware | infrastructure | l2 | l3 | service ] [ key-info | verbose ] [ filename ] [ background ]
custom string: Specifies diagnostic information in custom diagnostic scenarios for the device. The value for the string argument varies by devcie model. The string argument specifies the name of a custom diagnositic scenario, in a string of 1 to 32 characters. You can execute the display diagnostic-information custom ? command to obtain the available custom diagnositic scenarios.
hardware: Specifies hardware-related diagnostic information.
infrastructure: Specifies diagnostic information for the fundamental features.
l2: Specifies diagnostic information for the Layer 2 features.
l3: Specifies diagnostic information for the Layer 3 features.
service: Specifies operating information for Layer 4 and upper-layer features.
key-info: Displays or saves only critical diagnostic information. The device might have a large amount of diagnostic information if an exception is present or after the device has run for a long period of time. Specifying this keyword reduces the command execution time and helps you focus on critical operating information. If you do not specify this keyword, the command displays or saves both critical and non-critical diagnostic information.
verbose: Saves detailed diagnostic information.
filename: Saves the information to a file. The filename argument must use the .tar.gz suffix. If you do not specify this argument, the command prompts you to choose whether to save the information to a file or display the information.
background: Saves diagnostic information in the background. If you do not specify this keyword, the system displays or saves diagnostic information in the CLI and you cannot execute other commands during the process. It is time consuming if a large amount of diagnostic information is to be collected. If you specify this keyword, the system saves diagnostic information in the background and users can execute other commands in the CLI during the process.
You can use one of the following methods to collect operating statistics for diagnostics and troubleshooting:
· Use separate display commands to collect diagnostic information by feature or module by module.
· Use the display diagnostic-information command to collect diagnostic information for multiple or all features and hardware modules.
To save storage space, the display diagnostic-information command automatically compresses information before saving information to a file. To view the file content:
1. Use the tar extract command to extract the file.
2. Use the gunzip command to decompress the extracted file.
3. Use the more command to view the content of the decompressed file.
If you abort the display diagnostic-information command, the gunzip command might not be able to decompress the extracted file. To decompress the extracted file, export the extracted file to a PC that is running Linux, and use the gunzip -c command.
If you do not specify any feature parameters, this command displays or saves the operating information for all features and modules.
If you do not specify a file name for the command, the system prompts you to choose whether to display or save the information. If you choose to save the information, the system automatically assigns a file name and displays the file name in brackets. For file name uniqueness, the file name includes the device name and the current system time. If the device name contains any of the following special characters, the system uses an underscore (_) to replace each special character: forward slashes (/), backward slashes (\), colons (:), asterisks (*), question marks (?), less than signs (<), greater than signs (>), and pipeline signs (|). For example, if the device name is A/B, the device name in the file name will be A_B, as in flash:/diag_A_B_20160101-000438.tar.gz.
This command does not support the |, >, or >> option.
While the device is executing this command, do not execute any other commands. Executing other commands might affect the collected diagnostic information.
# Display the diagnostic information for all features and modules.
14:03:55 UTC Thu 01/05/2012
# Save the diagnostic information for all features and modules to the default file.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
Press Enter when the system prompts you to enter the file name.
# Save the diagnostic information for all features and modules to the test.tar.gz file.
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
# Save the diagnostic information in the background to the default file.
<Sysname> display diagnostic-information background
Please input the file name (*.tar.gz)[flash:/diag_Sysname_20201215-163501.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20201215-163501.tar.gz in the background.
gunzip
more
tar extract
display energy-saving mode
Use display energy-saving mode to display detailed information about the energy saving modes of the device.
display energy-saving mode [ standard | basic | deep ]
standard: Specifies the standard energy saving mode.
basic: Specifies the basic energy saving mode.
deep: Specifies the deep energy saving mode. This mode is not supported in the current software version.
If you do not specify any keyword, this command displays detailed information about all energy saving mode.
# Display detailed information about all energy saving modes.
<Sysname> display energy-saving mode
Energy-saving mode: basic
Energy-saving mode: standard
Fan-auto
# Display detailed information about the basic energy saving mode.
<Sysname> display energy-saving mode basic
Table 16 Command output
display environment
Use display environment to display temperature information.
In standalone mode:
In IRF mode:
display environment [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays temperature information for all member devices. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified.
(In standalone mode.) This command displays information about all temperature sensors on the device if you do not specify a card.
(In IRF mode.) This command displays information about all temperature sensors in the IRF fabric if you do not specify an IRF member device. If you specify an IRF member device but do not specify a card, this command displays information about all sensors on the member device.
# (In standalone mode.) Display information about all temperature sensors on the device.
<Sysname> display environment
System temperature information (degree centigrade):
Slot Sensor Temperature Lower Warning Alarm Shutdown
0 inflow 1 25 0 48 60 NA
0 hotspot 1 31 0 80 95 NA
Table 17 Command output
System Temperature information (degree centigrade) |
Temperature information (°C). |
Slot |
slot ID. |
sensor |
Temperature sensor: · hotspot—Hotspot sensor. · inflow—Air inlet sensor. · outflow—Air outlet sensor. |
Temperature |
Current temperature. |
Lower |
Lower temperature limit. If the device does not support this field, this field displays NA. |
Warning |
Warning temperature threshold. If the device does not support this field, this field displays NA. |
Alarm |
Alarming temperature threshold. If the device does not support this field, this field displays NA. |
Shutdown |
Shutdown temperature threshold. When the sensor temperature reaches the limit, the system shuts down automatically. If the device does not support this field, this field displays NA. |
display fan
Use display fan to display fan tray operating status information.
In standalone mode:
display fan [ fan-id ]
In IRF mode:
display fan [ chassis chassis-number [ fan-id ] ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fan tray operating status information for all member devices. (In IRF mode.)
fan-id: Specifies a fan tray by its ID. If you do not specify a fan tray, this command displays operating status information for all fan trays at the specified position.
# Display the operating states of all fan trays.
<Sysname> display fan
Fan Frame 0 State: Normal
Table 18 Command output
Fan Frame |
Fan tray number. |
State |
Fan tray status: · Normal—The fan tray is operating correctly. · Fault—The fan tray is faulty. · Absent—The slot is not installed with a fan tray. |
display fan-speed
Use display fan-speed to display the current fan operating mode and the speeds of fans.
In standalone mode:
display fan-speed
In IRF mode:
display fan-speed [ chassis chassis-number ]
# (In standalone mode.) Display the current fan operating mode and the speeds of fans.
<Sysname> display fan-speed
Current fan speed mode is auto
Frame 0 fan 1 speed is 12012 (R.P.M)
Frame 0 fan 2 speed is 10465 (R.P.M)
Frame 1 fan 1 speed is 12457 (R.P.M)
Frame 1 fan 2 speed is 10297 (R.P.M)
Frame 2 fan 1 speed is 12251 (R.P.M)
Frame 2 fan 2 speed is 10416 (R.P.M)
display hardware-failure-detection
Use display hardware-failure-detection to display the hardware failure detection settings and the latest 10 fix records for each card.
(In standalone mode.) The fix records are stored on the active MPU. You can use this command to display the records for a card even if the card is removed or replaced. The fix records are lost only when you remove or power cycle the active MPU.
(In IRF mode.) The fix records are stored on the local active MPU. You can use this command to display the records for a card even if the card is removed or replaced. The fix records are lost only when you remove or power cycle the local active MPU.
# (In standalone mode.) Display hardware failure detection settings and fix records.
<Sysname> display hardware-failure-detection
Current level:
chip : warning
board : warning
forwarding : warning
Recent record:
--------------------------Slot 0 executed records:-----------------------------
--------------------------Slot 0 trapped records:-----------------------------
Table 19 Command output
Current level |
Fix actions specified for hardware failures. |
chip |
Fix action for hardware failures on components of cards. |
board |
Fix action for hardware failures on control paths. |
forwarding |
Fix action for hardware failures on the forwarding plane. |
Recent record |
Recent failure fix records. |
xxx executed records |
Fix records stored on an MPU. |
xxx trapped records |
Trap records stored on an MPU. |
display hardware-failure-protection
Use display hardware-failure-protection to display the hardware failure detection settings and the latest 10 fix records for each card.
display hardware-failure-protection [ aggregation | port { auto-down | interface-type interface-number } ]
aggregation: Displays the hardware failure protection settings for aggregation groups.
port: Displays the hardware failure protection settings for interfaces.
auto-down: Displays the interfaces on which hardware failure protection is enabled.
interface-type interface-number: Displays the hardware failure protection settings for an interface.
If you do not specify any option, the command displays all hardware failure protection settings on the device.
# Display all hardware failure protection settings.
<Sysname> display hardware-failure-protection
Aggregation: on
Port: XGE0/0/15 XGE0/0/16
# Display the interfaces on which hardware failure protection is enabled.
<Sysname> display hardware-failure-protection port auto-down
# Display whether hardware failure protection is enabled for interface Ten-GigabitEthernet 0/0/16.
<Sysname> display hardware-failure-protection port ten-gigabitethernet 0/0/16
Hardware failure protection is enabled on the interface. The system will shut down the interface when it detects a hardware failure on the interface.
Table 20 Command output
Aggregation |
Whether hardware failure protection is enabled for aggregation groups. |
Port |
Interfaces on which hardware failure protection is enabled. |
display health
Use display health to display CPU and memory usage.
In standalone mode:
display health [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display health [ chassis chassis-number [ slot slot-number [ cpu cpu-number ] ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays CPU and memory usage on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command displays CPU and memory usage on all cards. (In IRF mode.)
# (In standalone mode.) Display the CPU and memory usage on all cards.
<Sysname> display health
Slot CPU Role CPU Usage(%) Memory Usage(%) Used/Total(MB)
0 0 MPU(Master) 7 23 1902504/8130012
Table 21 Command output
Role |
Card role: · MPU(Master)—Active MPU. (In standalone mode.) · MPU(Standby)—Standby MPU. (In standalone mode.) · MPU(Master)—Global active MPU. (In IRF mode.) · MPU(Standby)—Global standby MPU. (In IRF mode.) · LPU—LPU. · Blade—Blade MPU. |
CPU Usage(%) |
Average CPU usage during the past 5 seconds, in percentage. |
Memory Usage(%) |
Memory usage in percentage. |
Used/Total(MB) |
Used memory size and total memory size in MB. |
display kernel memory alloc-failure
Use display kernel memory alloc-failure to display kernel memory allocation failure information.
In standalone mode:
display kernel memory alloc-failure [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display kernel memory fragment free [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays kernel memory allocation failure information for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command displays kernel memory allocation failure information for the global active MPU. (In IRF mode.)
# Display kernel memory allocation failure information.
<System> display kernel memory alloc-failure
kmalloc_tag failures: 55.
kcalloc_tag failures: 0.
kzalloc_tag failures: 0.
krealloc_tag failures: 0.
kmem_cache_alloc_tag failures: 0.
Table 22 Command output
kmalloc_tag failures |
Number of memory allocation failures on the use of kmalloc_tag. |
kcalloc_tag failures |
Number of memory allocation failures on the use of kcalloc_tag. |
kzalloc_tag failures |
Number of memory allocation failures on the use of kzalloc_tag. |
krealloc_tag failures |
Number of memory allocation failures on the use of krealloc_tag. |
kmem_cache_alloc_tag failures |
Number of memory allocation failures on the use of kmem_cache_alloc_tag. |
Use display kernel memory fragment free to display the kernel memory fragment statistics.
In standalone mode:
display kernel memory fragment free [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays kernel memory fragment statistics for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command displays kernel memory fragment statistics for the global active MPU. (In IRF mode.)
# Display the kernel memory fragment statistics.
<Sysname> display kernel memory fragment free
Kernel memory free ratio: 0.13%
cfq_io_context memory free (in kbytes): 0
LFIB_NhlfeEntryCache26 memory free (in kbytes): 0
LFIB_NhlfeEntryCache74 memory free (in kbytes): 0
L2VFIB_TUNNELBMP_Cache memory free (in kbytes): 0
NAT_SESSION_EXT_INFO memory free (in kbytes): 0
ARP_VSISUP_Entry_cache memory free (in kbytes): 0
LFIB_NhlfeEntryCache1 memory free (in kbytes): 0
FVN_FwdCache19 memory free (in kbytes): 0
Table 23 Command output
Kernel memory free ratio |
Memory fragment ratio in the kernel space. |
cfq_io_context memory free (in kbytes) |
Memory fragment size in the slab named cfq_io_context, in KB. |
display memory
Use display memory to display memory usage information.
In standalone mode:
In IRF mode:
display memory [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays memory usage for all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command displays memory usage for all MPUs. (In IRF mode.)
If two hyphens (--) are displayed for all the fields in a line of the command output, the command might fail to obtain data from the database on the device. Try the command later.
# (In standalone mode.) Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 0:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 984560 456128 528432 0 4 45616 53.7%
-/+ Buffers/Cache: 410508 574052
Swap: 0 0 0
LowMem: 739824 375552 364272 -- -- -- 49.2%
HighMem: 244736 80576 164160 -- -- -- 67.1%
# (In standalone mode.) Display brief memory usage information.
<Sysname> display memory summary
Slot CPU Total Used Free Buffers Caches FreeRatio
0 0 16274340 3701456 12572884 4080 344196 77.8%
Table 24 Command output
Mem |
Memory usage information. |
Total |
Total size of the physical memory space that can be allocated. The memory space is virtually divided into two parts. Part 1 is solely used for kernel code and kernel management functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1. |
Used |
Used physical memory. |
Free |
Free physical memory. |
Shared |
Physical memory shared by processes. If this field is not supported, two hyphens (--) are displayed. |
Buffers |
Physical memory used for buffers. If this field is not supported, two hyphens (--) are displayed. |
Cached Caches |
Physical memory used for caches. If this field is not supported, two hyphens (--) are displayed. |
FreeRatio |
Free memory ratio. |
-/+ Buffers/Cache |
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications. -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications. |
Swap |
Memory space for swapping. |
LowMem |
Low-memory usage information. |
HighMem |
High-memory usage information. |
display memory dma
Use display memory dma to display DMA memory usage information.
In standalone mode:
display memory dma [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display memory dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DMA memory usage information for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command displays DMA memory usage information for the global active MPU. (In IRF mode.)
# (In standalone mode.) Display DMA memory usage information for slot 0.
<System> display memory dma slot 0
DMA memory statistics measured in KB on slot 0:
Total Used Free FreeRatio
16384 6140 10244 63%
Table 25 Command output
Total |
Total size of the DMA memory space, including the free and used DMA memory. |
Used |
Used DMA memory. |
Free |
Free DMA memory. |
FreeRatio |
Free DMA memory ratio. |
display memory-threshold
Use display memory-threshold to display memory alarm thresholds and statistics.
In standalone mode:
In IRF mode:
display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the memory usage thresholds and statistics for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command displays the memory usage thresholds and statistics for the global active MPU. (In IRF mode.)
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
Minor: 64M
Severe: 48M
Critical: 32M
Normal: 96M
Current memory state: Normal
Event statistics:
[Back to normal state]
First notification: 2012-5-15 09:21:35.546
Latest notification: 2012-5-15 09:21:35.546
Total number of notifications sent: 1
[Enter minor low-memory state]
First notification at: 2012-5-15 09:07:05.941
Latest notification at: 2012-5-15 09:07:05.941
[Back to minor low-memory state]
First notification at: 0.0
Latest notification at: 0.0
Total number of notifications sent: 0
[Enter severe low-memory state]
[Back to severe low-memory state]
[Enter critical low-memory state]
Table 26 Command output
Free-memory thresholds Minor Severe Critical Normal Early-warning Secure |
Free-memory thresholds, including: · Minor—Minor alarm threshold in MB. If this field displays two hyphens (--), the device failed to obtain the minor alarm threshold. · Severe—Severe alarm threshold in MB. If this field displays two hyphens (--), the device failed to obtain the severe alarm threshold. · Critical—Critical alarm threshold in MB. If this field displays two hyphens (--), the device failed to obtain the critical alarm threshold. · Normal—Normal state threshold in MB. If this field displays two hyphens (--), the device failed to obtain the normal state threshold. · Early-warning—Early-warning threshold in MB. If this field displays two hyphens (--), the device failed to obtain the early-warning threshold. · Secure—Sufficient-memory threshold in MB. If this field displays two hyphens (--), the device failed to obtain the sufficient-memory threshold. |
Current free-memory state |
Current state of the free memory in the system: · Normal—Normal state. · Minor—Minor alarm threshold. · Severe—Severe alarm threshold. · Critical—Critical alarm threshold. · Normal (early-warning)—Early-warning threshold. · Normal (secure)—Sufficient-memory state. |
display memory-threshold dma
Use display memory-threshold dma to display DMA memory alarm information.
In standalone mode:
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display memory-threshold dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DMA memory alarm information for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command displays DMA memory alarm information for the global active MPU. (In IRF mode.)
# Display DMA memory alarm information.
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
Critical: 2048KB
Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
First notification: 0.0
Latest notification: 0.0
[Entered to critcal state]
First notificatio: 0.0
display port-working-mode
Use display port-working-mode to display port operating mode information for the device.
# Display port operating mode information.
<Sysname> display port-working-mode
Current port working mode: hg2-card. In this mode, only GE ports 1 to 6, XGE ports 7 to 26, HE ports 27 and 28, GE copper ports 31 to 34 and the card slot are available
Next port working mode: hg4-xp12. In this mode, only HGE ports 27 to 30 and XGE ports 15 to 26 are available
Table 27 Command output
Current port working mode |
Current port operating mode that takes effect on the device. |
Next port working mode |
Port operating mode specified for the next startup. |
port-working-mode
display power
Use display power to display power module information.
In standalone mode:
display power [ power-id ]
In IRF mode:
display power [ chassis chassis-number [ power-id ] ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays power module information for all member devices. (In IRF mode.)
power-id: Specifies a power module by its ID. If you do not specify a power module, this command displays information about all power modules at the specified position.
# Display brief power supply information.
<Sysname> display power
Power 0 State: Error
Power 1 State: Normal
Table 28 Command output
Power n State |
Power supply status. · Absent—The slot is not installed with a power supply. · Error—The power supply is faulty. · Normal—The power supply is operating correctly. |
display power-off high-temp-board
Use display power-off high-temp-board to display whether the overtemperature auto shutdown feature is enabled.
# Display whether the overtemperature auto shutdown feature is enabled.
<Sysname> display power-off high-temp-board
Power off high temperature board mode: Enable
display power-information
Use display power-information to display power information about power supplies and cards.
In standalone mode:
display power-information [ verbose ]
In IRF mode:
display power-information [ chassis chassis-number ] [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# (In standalone mode.) Display power information about power supplies and cards.
<Sysname> display power-information
Power control mode: strict
Device power: 450W
Surplus power: 50W
Slot No. Power(W)
0 400 reserve for mainboard
# (In standalone mode.) Display detailed power information about power supplies and cards.
<Sysname> display power-information verbose
Device power: 450W
Surplus power: 50W
Slot No. Power(W)
Power Status Name AC/DC Input(V) Input(A) Output(V) Output(A) Input(W)
Output(W) Rated(W)
0 Error PSR450-12A1 AC - - 0.00 0.00 -
0.00 0
1 Normal PSR450-12A1 AC - - 12.12 16.87 -
204.46 450
Current input total power: -
Current output total power: 204.46W
Slot No. Actual Vol(V) Actual Cur(A) Actual Power(W)
0 12.01 16.70 200.56
Table 29 Command output
Chassis n |
Member ID of an IRF member device. (In IRF mode.) |
Power control mode |
Power control mode of cards |
Device Power |
Rated power of the device. |
Surplus power |
Remaining power of the device. |
Slot No. |
Slot number of the card. |
Power(W) |
Maximum card power. |
reserve for mainboard |
Reserved power for the MPU. |
Power |
Slot number of the power supply. |
Status |
Power supply status. |
Name |
Power supply name. |
AC/DC |
Power supply type. |
Input(V) |
Input voltage of the power supply. |
Input(A) |
Input current of the power supply. |
Output(V) |
Output voltage of the power supply. |
Output(A) |
Output current of the power supply. |
Input(W) |
Input power of the power supply. |
Output(W) |
Output power of the power supply. |
Rated(W) |
Rated power of the power supply. |
Current input total power |
Total power of power supplies. |
Current output total power |
Total output power of power supplies. |
Actual Vol(V) |
Voltage of the card. |
Actual Cur(A) |
Current of the card. |
Actual Power(W) |
Power of the card. |
display resource-monitor
Use display resource-monitor to display resource monitoring information.
In standalone mode:
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display resource-monitor [ resource resource-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
resource resource-name: Specifies a resource type by its name.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays resource monitoring information for all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command displays resource monitoring information for all cards. (In IRF mode.)
# (In standalone mode.) Display ARP resource monitoring information.
<Sysname> display resource-monitor resource arpnd
Minor alarms resending: Enabled
slot 0:
Resource Minor Severe Free/Total
(percentage)
arpnd 50% 20% 99
Table 30 Command output
Minor alarms resending |
Status of the minor resource depletion alarm resending feature, Enabled or Disabled. |
Resource |
Monitored resource type. |
Minor (%) |
Minor resource depletion threshold, in percentage. |
Severe (%) |
Severe resource depletion threshold, in percentage. |
Free/Total (percentage) |
Numbers of available resources and total resources, in percentage. |
resource-monitor minor resend enable
display scheduler job
Use display scheduler job to display job configuration information.
job-name: Specifies a job by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a job, this command displays configuration information for all jobs.
# Display configuration information for all jobs.
<Sysname> display scheduler job
Job name: saveconfig
copy startup.cfg backup.cfg
Job name: backupconfig
Job name: 123
//The output shows that the device has three jobs: the first has one command, the second does not have any commands, and the third has two commands. Jobs are separated by blank lines.
display scheduler logfile
Use display scheduler logfile to display job execution log information.
# Display job execution log information.
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name : shutdown
Schedule name : shutdown
Execution time : Tue Dec 27 10:44:42 2011
Completion time : Tue Dec 27 10:44:47 2011
<Sysname>system-view
[Sysname]interface rang ten-gigabitethernet 0/0/15 to ten-gigabitethernet 0/0/17
[Sysname-if-range]shutdown
Table 31 Command output
Logfile Size |
Size of the log file, in bytes. |
Schedule name |
Schedule to which the job belongs. |
Execution time |
Time when the job was started. |
Completion time |
Time when the job was completed. If the job has never been executed or the job does not have any commands, this field is blank. |
Job output |
Commands in the job and their output. |
reset scheduler logfile
display scheduler reboot
Use display scheduler reboot to display the automatic reboot schedule.
# Display the automatic reboot schedule.
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2011 (in 1 hours and 39 minutes).
scheduler reboot at
scheduler reboot delay
display scheduler schedule
Use display scheduler schedule to display schedule information.
schedule-name: Specifies a schedule by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a schedule, this command displays information about all schedules.
# Display information about all schedules.
<Sysname> display scheduler schedule
Schedule type : Run once after 0 hours 2 minutes
Start time : Tue Dec 27 10:44:42 2011
Last execution time : Tue Dec 27 10:44:42 2011
Last completion time : Tue Dec 27 10:44:47 2011
Execution counts : 1
Job name Last execution status
shutdown Successful
Table 32 Command output
Schedule type |
Execution time setting of the schedule. If no execution time is specified, this field is not displayed. |
Start time |
Time to execute the schedule for the first time. If no execution time is specified, this field is not displayed. |
Last execution time |
Last time when the schedule was executed. If no execution time is specified, this field is not displayed. If the schedule has never been executed, "Yet to be executed" is displayed for this field. |
Last completion time |
Last time when the schedule was completed. If no execution time is specified, this field is not displayed. |
Execution counts |
Number of times the schedule has been executed. If the schedule has never been executed, this field is not displayed. |
Job name |
Name of a job under the schedule. |
Last execution status |
Result of the most recent execution: · Successful. · Failed. · Waiting—The device is executing the schedule and the job is waiting to be executed. · In process—The job is being executed. · -NA-—The execution time has not arrived yet. To view information about whether the commands in the job has been executed and the execution results, execute the display scheduler logfile command. |
display system stable state
Use display system stable state to display system stability and status information.
display system stable state[ summary ]
summary: Displays brief information about system stability and status, including system status, redundancy status, and NSR status. If you do not specify this keyword, the command displays detailed information about system status, redundancy status, and CPU role and status.
The device/card startup process takes some time. If the values of the status fields do not change to Stable, execute this command multiple times to identify the devices/cards that are not in Stable state. You can also use other commands to identify the faulty components. For example:
· Use the display device command to identify the device operating status.
· Use the display ha service-group command to display the status of HA service groups and identify the groups in batch backup state.
· Use the display system internal process state command in probe view to display service operating status.
The display ha service-group all command is automatically executed when you execute the display system stable state command. You can identify system stability and status through the display ha service-group all command. For more information about the display ha service-group all command, see process placement commands in High Availability Command Reference.
# Display brief information about system stability and status.
<Sysname> display system stable state summary
System state : Stable
Redundancy state : No redundancy
NSR state : No standby
# Display CPU status summary, redundancy status, and detailed information about CPU operation.
Redundancy state : No redundance
Slot CPU Role State
0 0 Active Stable
Table 33 Command output
System state |
Operating status summary of all CPUs: · Stable—All CPUs are operating stably. · Not ready—The CPUs are not operating stably. At least one CPU is not operating stably. |
Redundancy state |
System redundancy status: · Stable—Both MPUs are operating stably. You can perform a switchover. · No redundance—The system has only one MPU. You cannot perform a switchover. · Not ready—The system is not operating stably. You cannot perform a switchover. |
NSR state |
Readiness of modules for nonstop routing: · Ready—NSR is operating correctly. · Not ready—The NSR is not operating correctly. You cannot perform a process or active/standby switchover. · No standby—No standby MPU exists. · Not configured—No module is enabled with NSR. |
Role |
Role of the card in the system: · Active—The card is the active MPU. · Standby—The card is the standby MPU. · Other—The card is a service module. |
State |
Operating status of the card: · Stable—The card is operating stably. · Board inserted—The card has just been installed. · Kernel initiating—Card kernel is being initialized. · Service starting—Services are starting. · Service stopping—Services are stopping. · HA Batch backup—An HA batch backup is going on. · Interface data batch backup—An interface data batch backup is in progress. · Service module data batch backup—A service module data batch backup is in progress. |
The object is not operating stably. |
display device
display ha service-group (High Availability Command Reference)
display transceiver alarm
Use display transceiver alarm to display transceiver alarms.
display transceiver alarm { controller | interface } interface-type interface-number ]
controller [ interface-type interface-number ]: Specifies a controller interface by its type and number. If no interface is specified, this command applies to all controller interfaces.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
You can use the display transceiver alarm command to display alarms present on transceiver modules. If no error occurs, None is displayed.
Table 34 Command output on SFP/SFP28/SFP+/GBIC/SFF transceiver modules
RX signal loss |
Receive signal loss. |
RX power high alarm |
Alarm on a high receive optical power. |
RX power high warning |
Early warning on a high receive optical power. |
RX power low alarm |
Alarm on a low receive optical power. |
RX power low warning |
Early warning on a low receive optical power. |
TX fault |
Transmit fault. |
TX bias high alarm |
Alarm on a high transmit bias current. |
TX bias high warning |
Early warning on a high transmit bias current. |
TX bias low alarm |
Alarm on a low transmit bias current. |
TX power high warning |
Early warning on a high transmit optical power. |
TX power high alarm |
Alarm on a high transmit optical power. |
TX power low alarm |
Alarm on a low transmit optical power. |
TX power low warning |
Early warning on a low transmit optical power. |
Temp high alarm |
Alarm on a high temperature. |
Temp high warning |
Early warning on a high temperature. |
Temp low alarm |
Alarm on a low temperature. |
Temp low warning |
Early warning on a low temperature. |
Voltage high alarm |
Alarm on a high voltage. |
Voltage high warning |
Early warning on a high voltage. |
Voltage low alarm |
Alarm on a low voltage. |
Voltage low warning |
Early warning on a low voltage. |
Transceiver info I/O error |
N/A |
Transceiver info checksum error |
N/A |
Transceiver type and port configuration mismatch |
Transceiver type not supported by port hardware |
RX CDR loss of lock |
Receive CDR loss of lock, indicating poor signal. |
TX CDR loss of lock |
Transmit CDR loss of lock, indicating poor signal. |
Table 35 Command output on QSFP+/QSFP28 transceiver modules
Temp high alarm |
Temp high warning |
Temp low alarm |
Temp low warning |
Voltage low alarm |
RX loss of signal(channel x) |
Loss of receive signal in channel x. |
TX fault(channel x) |
Packet transmission fault in channel x. |
TX loss of signal(channel x) |
Loss of transmit signal in channel x. |
RX power high(channel x) |
Alarm on a high receive optical power in channel x. |
RX power low(channel x) |
Alarm on a low receive optical power in channel x. |
TX power high alarm(channel x) |
Alarm on a high transmit optical power in channel x. |
TX power high warning(channel x) |
Early warning on a high transmit optical power in channel x. |
TX power low alarm(channel x) |
Alarm on a low transmit optical power in channel x. |
TX power low warning(channel x) |
Early warning on a low transmit optical power in channel x. |
TX bias high(channel x) |
Alarm on a high bias current in channel x. |
TX bias low(channel x) |
Alarm on a low bias current in channel x. |
N/A |
N/A |
Transceiver type and port configuration mismatched |
The transceiver type does not match port configuration. |
Transceiver type not supported |
The transceiver type is not supported on the port. |
Table 36 Command output on CFP transceiver modules
TX jitter PLL unlocked |
Transmit Jitter PLL is out of lock. |
TX CMU unlocked |
Transmit CMU is out of lock. |
Overloaded |
Alarm on being overloaded. |
Loss of REFCLK input |
Alarm on loss of REFCLK input. |
Channel signals out of alignment |
Alarm on channel signals out of alignment. |
PLD or flash initialization error |
Power supply fault |
N/A |
CFP checksum error |
N/A |
TX bias high |
TX bias low |
Temp high |
Temp low |
Voltage high |
Voltage low |
RX signal loss in channel x |
Receive signal loss in in channel x. |
RX IC unlocked in channel x |
Receive IC is out of lock in channel x. |
RX FIFO error in channel x |
Receive FIFO error in channel x. |
TX signal loss in channel x |
Transmit signal loss in channel x. |
TX IC unlocked in channel x |
Transmit IC is out of lock in channel x. |
TX FIFO error in channel x |
Transmit FIFO error in channel x. |
APD supply fault in channel x |
Avalanche Photo Diode (APD) supply fault in channel x. |
TEC fault in channel x |
Thermoelectric Cooler (TEC) fault in channel x. |
Wavelength unlocked in channel x |
Optical signal wavelength is out of lock in channel x. |
RX power high in lane x |
Alarm on a high receive optical power in lane x. |
RX power low in lane x |
Alarm on a low receive optical power in lane x. |
TX power high in lane x |
Alarm on a high transmit optical power in lane x. |
TX power low in lane x |
Alarm on a low transmit optical power in lane x. |
TX bias high in lane x |
Alarm on a high bias current in lane x. |
TX bias low in lane x |
Alarm on a low bias current in lane x. |
Temp high in lane x |
Alarm on a high temperature in lane x. |
Temp low in lane x |
Alarm on a low temperature in lane x. |
N/A |
N/A |
Table 37 Command output on XFP transceiver modules
RX signal loss |
RX not ready |
The receive state is not ready. |
Receive CDR loss of lock. |
TX not ready |
The transmit state is not ready. |
TX fault |
Transmit fault. |
Transmit CDR loss of lock. |
TX bias low alarm |
TX bias low warning |
Early warning on a low transmit bias current. |
Module not ready |
The module is not ready. |
APD supply fault |
Avalanche Photo Diode (APD) supply fault. |
TEC fault |
Thermoelectric Cooler (TEC) fault. |
Wavelength unlocked |
Optical signal wavelength is out of lock. |
Temp high alarm |
Temp high warning |
Temp low alarm |
Temp low warning |
Voltage high alarm(3.3V) |
Alarm on a high voltage (3.3V). |
Voltage high warning(3.3V) |
Early warning on a high voltage (3.3V). |
Voltage low alarm(3.3V) |
Alarm on a low voltage (3.3V). |
Voltage low warning(3.3V) |
Early warning on a low voltage (3.3V). |
Voltage high alarm(5.5V) |
Alarm on a high voltage (5.5V). |
Voltage high warning(5.5V) |
Early warning on a high voltage (5.5V). |
Voltage low alarm(5.5V) |
Alarm on a low voltage (5.5V). |
Voltage low warning(5.5V) |
Early warning on a low voltage (5.5V). |
Voltage high alarm(1.8V) |
Alarm on a high voltage (1.8V). |
Voltage high warning(1.8V) |
Early warning on a high voltage (1.8V). |
Voltage low alarm(1.8V) |
Alarm on a low voltage (1.8V). |
Voltage low warning(1.8V) |
Early warning on a low voltage (1.8V). |
Voltage high alarm(5.2V) |
Alarm on a high voltage (5.2V). |
Voltage high warning(5.2V) |
Early warning on a high voltage (5.2V). |
Voltage low alarm(5.2V) |
Alarm on a low voltage (5.2V). |
Voltage low warning(5.2V) |
Early warning on a low voltage (5.2V). |
N/A |
N/A |
Table 38 shows the common transceiver alarm components. If no error occurs, "None" is displayed.
Table 38 Common transceiver alarm components
APD |
Avalanche photo diode |
PCS |
Physical coding sublayer |
PHY XS |
PHY extended sublayer |
PMA/PMD |
Physical medium attachment/physical medium dependent |
power |
Optical power |
REFCLK |
Reference clock |
RX |
Receive |
TEC |
Thermoelectric cooler |
Temp |
Temperature |
TX |
Transmit |
WIS |
WAN interface sublayer |
CDR |
Clock and data recovery |
CDR loss of lock |
Indicates that the signal is in bad condition. |
# Display the alarms present on the transceiver module in interface Ten-GigabitEthernet 0/0/15.
<Sysname> display transceiver alarm interface ten-gigabitethernet 0/0/15
Ten-GigabitEthernet0/0/15 transceiver current alarm information:
RX signal loss
RX power low
Table 39 Command output
transceiver current alarm information |
Alarms present on the transceiver module. |
RX signal loss |
Input signal loss occurred. |
RX power low |
Received power is low. |
display transceiver brief
Use display transceiver brief to display information about all transceiver modules, including transceiver module types, receive power, and transmit power.
# Display transceiver module types, receive power, and transmit power of all transceiver modules on the device.
<Sysname> display transceiver brief
Interface TransceiverType WaveL(nm) Mode Rx(dBm) Tx(dBm) Status
Current/Range Current/Range
XGE0/0/15 10G-10km-SFP 1310 SM -15.0/[-18.5,-3.0] -15.0/[-18.5,-3.0] Normal
XGE0/0/16 10G-10km-SFP 1310 SM -15.0/[-18.5,-3.0] -29.0/[-18.5,-3.0] Beyond threshold
XGE0/0/17 10G-10km-SFP 1310 SM NA/[-18.5,-3.0] NA/[-18.5,-3.0] Unknown
Table 40 Command output
Abbreviated Interface name. |
TransceiverType |
Type of the transceiver module, consisting of its speed, transmission distance, and form factor. Two hyphens (--) indicate that the device failed to obtain data or the transceiver module does not support obtaining type information. The system can display only the transceiver modules in the most common form factor for a speed, as follows: · 16 Gbps or lower—SFP transceiver module. · 40 Gbps—QSFP transceiver module. · 50 Gbps—QSFP28 transceiver module. · 100 Gbps—QSFP28 transceiver module. The system cannot display information about the transceiver modules in a form factor not listed above. |
WaveL |
Wavelength of the interface. Two hyphens (--) indicate that the device failed to obtain data or the transceiver module does not support obtaining wavelength information. |
Mode |
Mode of the transceiver module: · MM—Multi-mode. · SM—Single mode. · Two hyphens (--)—The device failed to obtain data or the transceiver module does not support obtaining mode information. |
Rx(dBm) Current/Range |
Current receive power/normal receive power range. Two hyphens (--) indicate that the device failed to obtain data or the transceiver module does not support obtaining power information. N/A indicates that the obtained power value is invalid. |
Tx(dBm) Current/Range |
Current transmit power/normal transmit power range. Two hyphens (--) indicate that the device failed to obtain data or the transceiver module does not support obtaining power information. N/A indicates that the obtained power value is invalid. |
Status |
Current power status: · Normal—The power is in the normal range. · Beyond threshold—The power exceeds the normal range. · Unknown—The status is unknown. · Two hyphens (--)—The device failed to obtain data or the transceiver module does not support obtaining status information. |
display transceiver auto-laser-down
Use display transceiver auto-laser-down to display information about auto laser shutdown.
display transceiver auto-laser-down { controller | interface } [ interfce-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command applies to all interfaces.
# Display information about auto laser shutdown for the transceiver module in interface Ten-GigabitEthernet 0/0/15.
<Sysname> display transceiver auto-laser-down interface ten-gigabitethernet 0/0/15
Interface Auto-laser-down Laser Restart Interval(s) Width(s)
status status mode
Ten-GigabitEthernet0/0/15 Enabled On Auto 100 2
Table 41 Command output
Auto-laser-down status |
Whether auto laser shutdown is enabled: · Enabled. · Disabled. |
Laser status |
Whether the transceiver laser is emitting light: · On—The laser is emitting light. · Off—The laser is not emitting light. |
Restart mode |
Restart mode of the transceiver laser: · Auto. · Manual. |
Interval(s) |
Interval between laser emissions after the laser restart, in seconds. |
Width(s) |
Pulse width (duration) of each light emission for detection after the laser restart, in seconds. |
display transceiver diagnosis
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
display transceiver diagnosis { controller | interface } [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface Ten-GigabitEthernet 0/0/15.
<Sysname> display transceiver diagnosis interface ten-gigabitethernet 0/0/15
Ten-GigabitEthernet0/0/15 transceiver diagnostic information:
Temp(C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
36 3.31 6.13 -35.64 -5.19
Alarm thresholds:
Temp(C) Voltage(V) Bias(mA) RX power(dBM) TX power(dBM)
High 50 3.55 1.44 -10.00 5.00
Low 30 3.01 1.01 -30.00 0.00
Warning thresholds:
High 45 3.25 1.25 -15.00 4.00
Low 25 2.85 0.85 -25.00 1.00
# Display the current values of the digital diagnosis parameters on the QSFP28 transceiver module in interface HundredGigE 0/0/27.
<Sysname> display transceiver diagnosis interface hundredgige 0/0/27
HundredGigE0/0/27 transceiver diagnostic information:
[module] Temp.(C) Voltage(V) Total RX power(dBm) Total TX power(dBm)
29 3.33 -33.61 8.41
[channel] Bias(mA) RX power(dBm) TX power(dBm)
1 0.00 -36.96 -36.96
2 0.00 -36.96 -36.96
3 0.00 -36.96 -36.96
4 0.00 -36.96 -36.96
Alarm thresholds:
Temp.(C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
High 75 3.47 13.00 3.40 5.00
Low -5 3.13 3.00 -14.00 -10.00
Warning thresholds:
High 70 3.45 11.00 2.40 3.00
Low 0 3.15 5.00 -11.00 -8.00
Total average launch power(dBm): 5.90
Table 42 Command output
transceiver diagnostic information |
Digital diagnosis information for the transceiver module in the interface. |
Temp(C) |
Temperature in °C, accurate to 1°C. |
Voltage(V) |
Voltage in V, accurate to 0.01 V. |
Total RX power(dBm) |
Total receive power in dBm, accurate to 0.01 dBm. |
Total TX power(dBm) |
Total transmit power in dBm, accurate to 0.01 dBm. |
Bias(mA) |
Bias current in mA, accurate to 0.01 mA. |
RX power(dBm) |
Receive power in dBm, accurate to 0.01 dBm. |
TX power(dBm) |
Transmit power in dBm, accurate to 0.01 dBm. |
Total average launch power(dBm) |
Total average launch power on the multi-lane transceiver module in dBM, accurate to 0.01 dBm. |
display transceiver interface
Use display transceiver interface to display the key parameters of transceiver modules.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface Ten-GigabitEthernet 0/0/15.
<Sysname> display transceiver interface ten-gigabitethernet 0/0/15
Ten-GigabitEthernet0/0/15 transceiver information:
Transceiver Type : 1000_BASE_SX_SFP
Connector Type : LC
Wavelength(nm) : 850
Transfer Distance(m) : 550(50um),275(62.5um)
Digital Diagnostic Monitoring : YES
Vendor Name : H3C
Table 43 Command output
Connector Type |
Connector types: · SC—Fiber connector developed by NTT. · LC—1.25 mm/RJ-45 fiber connector developed by Lucent. · RJ-45. · CX 4. |
Wavelength(nm) |
Central wavelength (in nm) of the transmit laser. If the transceiver supports multiple wavelengths, every two wavelength values are separated by a comma. For a copper cable, this field displays N/A. |
Transfer Distance(xx) |
Transmission distance, where xx indicates the distance unit: · km—Kilometers, for single-mode transceiver modules. · m—Meters, for other transceiver modules. If the transceiver module supports multiple types of transmission media, this field displays the transmission distance for each type, in the form of transmission distance (medium type). Transmission medium types include: · 9 um—9/125 µm single-mode fiber. · 50 um—50/125 µm multi-mode OM2 fiber. · 62.5um—62.5/125 um multi-mode OM1 fiber. · CX4—CX4 cable. · OM3—50 um multi-mode OM3 fiber. · OM4—50 um multi-mode OM4 fiber. · OM5—50 um multi-mode OM5 fiber. · STACK—Stack cable. · TP—Twisted pair. |
Digital Diagnostic Monitoring |
Support for digital diagnosis: · YES—Supported. · NO—Not supported. |
display transceiver manuinfo
Use display transceiver manuinfo to display electronic label information for transceiver modules.
display transceiver manuinfo { controller | interface } [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for all transceiver modules.
# Display electronic label information for the transceiver module in interface Ten-GigabitEthernet 0/0/15.
<Sysname> display transceiver manuinfo interface ten-gigabitethernet 0/0/15
Ten-GigabitEthernet0/0/15 transceiver manufacture information:
Manu. Serial Number : 213410A0000054000251
Manufacturing Date : 2012-09-01
Vendor Name : H3C
Table 44 Command output
Manu. Serial Number |
Serial number generated during production of the transceiver module. |
Manufacturing Date |
Date when the electronic label information was written to the transceiver module. |
display transceiver status
Use display transceiver status to display transceiver module status information.
display transceiver status { controller | interface } [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command applies to all interfaces.
If an error occurs on transceiver modules on the device, you can execute this command to obtain transceiver module status information. For example, you can identify whether a transceiver module is reset, power mode of a transceiver module, and operation information of each lane on the transceiver module.
This command is supported only on the SFP, QSFP, and QSFPDD transceiver modules.
# Display status information for the QSFP transceiver module in interface HundredGigE 0/0/27.
<Sysname> display transceiver status interface hundredgige 0/0/27
HundredGigE0/0/27 transceiver status information:
Initialization Complete Flag : Finish
Power Mode : High
Lane Tx Disable Tx CDR Rx CDR
Lane1 Yes ON OFF
Lane2 Yes ON OFF
Lane3 Yes ON OFF
Lane4 Yes ON OFF
Table 45 Command output
Initialization Complete Flag |
Whether the transceiver module has finished initialization: · Finish—The initialization has finished. · Unkown—No initialization status is detected. |
Power Mode |
Power mode of the transceiver module: · High. · Low. |
Tx Disable |
Whether packet transmission is enabled for a lane: · Yes—Packet transmission is disabled. · No—Packet transmission is enabled. |
Tx CDR |
Whether CDR on the transmit side is enabled: · On—Tx CDR is enabled. · Off—Tx CDR is disabled. |
Rx CDR |
Whether CDR on the receive side is enabled: · On—Rx CDR is enabled. · Off—Rx CDR is disabled. |
Lane |
Lane ID. |
# Display status information for the SFP transceiver module in interface Ten-GigabitEthernet 0/0/15.
<Sysname> display transceiver status interface ten-gigabitethernet 0/0/15
Ten-GigabitEthernet0/0/15 transceiver status information:
Hardware Tx Disable : YES
Table 46 Command output
Hardware Tx Disable |
Whether packet transmission is enabled for a lane via hardware pins: · Yes—Packet transmission is disabled. · No—Packet transmission is enabled. |
reset transceiver interface
transceiver cdr
transceiver lane enable
transceiver power-mode
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
display version-update-record
Use display version-update-record to display startup software image upgrade records.
The device records its current startup software version information whenever it starts up, and records all software version update information. Such information can survive reboots.
# Display the startup software image upgrade records.
<Sysname> display version-update-record
Record 1 (updated on Apr 18 2014 at 06:23:54):
*Name : boot-test.bin
Version : 7.1.053 Alpha 7153
Compile time: Mar 25 2014 15:52:43
*Name : system-test.bin
Record n |
Number of the startup software image upgrade record. Record 1 is the most recent record. |
Name |
Software image file name. |
The software image version changed during the upgrade. |
fan-speed
Use fan-speed to set the fan operating mode.
Use undo fan-speed to restore the default.
In standalone mode:
fan-speed { auto | high | middle | low }
undo fan-speed
In IRF mode:
fan-speed [ chassis chassis-number ] { auto | high | middle | low }
undo fan-speed
Fans operate in auto mode.
chassis chassis-number: Specifies an IRF member device by its member ID. (In IRF mode.)
auto: Operates at an adjustable speed. The device adjusts the speed automatically based on the card temperature. As a best practice, use this mode.
high: Operates at a higher speed to provide better cooling service.
middle: Operates at a middle speed.
low: Operates at a lower speed to reduce the noise at the cost of lower cooling service quality. This mode applies to noise-sensitive environments.
# (In standalone mode.) Set the fan operating mode to auto.
[Sysname] fan-speed auto
Fan speed changed successfully!
fan-speed set-rate
Use fan-speed set-rate to adjust the percentage of the current fan speed to the maximum fan speed.
In standalone mode:
fan-speed set-rate frame frame-id { add | sub } value
In IRF mode:
fan-speed set-rate chassis chasiss-number frame frame-id { add | sub } value
frame frame-id: Specifies a fan tray by its tray ID.
add: Increases the percentage of the current fan speed to the maximum fan speed.
sub: Decreases the percentage of the current fan speed to the maximum fan speed.
value: Specifies the value of the percentage to be adjusted, in the range of 1 to 10.
The larger the adjusted percentage is, the larger the range of the adjusted fan speed is.
After you execute the fan-speed set-rate command, you can execute the display fan-speed command to view fan speed information after adjustment.
You can execute the fan-speed set-rate command multiple times to adjust the fan speed. This command will not take effect if the fan speed has been adjusted to its maximum value.
# Increase the percentage of the current fan speed to the maximum fan speed by 5.
[Sysname] fan-speed set-rate frame 0 add 5
display fan-speed
forward per-packet
Use forward per-packet to specify the per-packet load sharing forwarding mode.
Use undo forward per-packet to restore the default.
In standalone mode:
forward per-packet [ slot slot-number ]
undo forward per-packet [ slot slot-number ]
In IRF mode:
forward per-packet [ chassis chassis-number slot slot-number ]
undo forward per-packet [ chassis chassis-number slot slot-number ]
The per-flow load sharing forwarding mode is used.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
This command is available only for testing.
Switching the load sharing forwarding mode might cause packet loss. Contact Technical Support before executing this command.
# Specify the per-packet load sharing forwarding mode.
forward-path-detection enable
Use forward-path-detection enable to enable data forwarding path failure detection.
Use undo forward-path-detection enable to disable data forwarding path failure detection.
Data forwarding path failure detection is enabled.
You can enable the device to automatically detect data forwarding path failures and output log information for notification.
# Enable data forwarding path failure detection.
[Sysname] forward-path-detection enable
Use hardware-failure-detection to specify the action to be taken in response to hardware failures.
Use undo hardware-failure-detection to restore the default.
hardware-failure-detection { chip | forwarding } { isolate | off | reset | warning }
undo hardware-failure-detection { chip | forwarding }
The system takes the action of warning in response to hardware failures on chips and the action of reset in response to hardware failures on the forwarding plane.
chip: Specifies failures on components of cards such as the chips, capacitances, resistances.
forwarding: Specifies failures on the forwarding plane (including services and other relevant items).
isolate: Takes one or more of the following actions:
· Shuts down the relevant ports.
· Prohibits loading software for the relevant cards.
· Isolates the relevant cards.
· Powers off the relevant cards to reduce impact from the failures.
off: Takes no action.
reset: Restarts the relevant components or cards to recover from failures.
warning: Sends traps to notify you of the failures.
The system automatically detects hardware failures on components, cards, and the forwarding plane. You can specify the actions to be taken in response to detected failures.
# Configure the device to send traps in response to failures on components.
[Sysname] hardware-failure-detection chip warning
hardware-failure-protection aggregation
Use hardware-failure-protection aggregation to enable hardware failure protection for aggregation groups.
Use undo hardware-failure-protection aggregation to disable hardware failure protection for aggregation groups.
Hardware failure protection is disabled for aggregation groups.
This command takes effect only when the hardware-failure-detection forwarding isolate command is executed.
When the hardware-failure-protection aggregation command is executed, the system uses the following rules when it detects a hardware failure on an aggregation group member interface:
· If the undo hardware-failure-protection auto-down command is executed on the member interface and the member interface is the only member in up state in the group, the system does not shut down the interface.
· If the undo hardware-failure-protection auto-down command is executed on the member interface and the member interface is not the only member in up state in the group, the system shuts down the interface.
· If the hardware-failure-protection auto-down command is executed on the member interface, the system shuts down the interface, whether or not the member interface is the only member in up state in the group.
This command does not take effect on a member interface in the following situations:
· Loopback testing is enabled (using the loopback { external | internal } command).
· The interface is forcibly brought up (using the port up-mode command).
· The interface is a physical IRF port.
· The undo hardware-failure-protection auto-down command is not executed on the interface.
# Enable hardware failure protection for aggregation groups.
[Sysname] hardware-failure-protection aggregation
Use hardware-failure-protection auto-down to enable hardware failure protection for an interface.
Use undo hardware-failure-protection auto-down to disable hardware failure protection for an interface.
Hardware failure protection is enabled for an interface.
Ethernet interface view
To ensure service continuity, verify that the interface has a backup link before configuring this command.
After you enable hardware failure protection on an interface, the system automatically shuts down the interface when it detects a hardware failure on the interface. An interface shut down this way is in Protect Down state. After the failure on an interface is removed, bring the interface up by using the undo shutdown command.
This command does not take effect on an interface in the following situations:
# Enable hardware failure protection on interface Ten-GigabitEthernet 0/0/15.
[Sysname] interface ten-gigabitethernet 0/0/15
[Sysname-Ten-GigabitEthernet0/0/15] hardware-failure-protection auto-down
header
Use header to configure a banner.
Use undo header to delete a banner.
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
No banner is configured.
legal: Configures the banner to be displayed before a user inputs the username and password to access the CLI.
login: Configures the banner to be displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner to be displayed before the legal banner appears.
shell: Configures the banner to be displayed before a user accesses user view.
text: Specifies the banner message. You can enter the banner message on the same line as the keywords or on different lines. For more information, see Fundamentals Configuration Guide.
# Configure the legal banner.
[Sysname] header legal
Welcome to use the legal banner%
job
Use job to assign a job to a schedule.
Use undo job to revoke a job.
job job-name
undo job job-name
No job is assigned to a schedule.
Schedule view
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
You can assign multiple jobs to a schedule. The jobs in a schedule are executed concurrently.
The jobs to be assigned to a schedule must already exist. To create a job, use the scheduler job command.
# Assign the save-job job to the saveconfig schedule.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
scheduler job
link-quality hardware-error enable
Use link-quality hardware-error enable to enable hardware detection reporting.
Use undo link-quality hardware-error enable to disable hardware detection reporting.
Hardware fault reporting is disabled.
Hardware detection is a mechanism of reliability that automatically triggers upper-layer service modules to take protective measures in response to hardware detection events. This can minimizes the impact of hardware faults on service operations.
When a hardware fault is detected, this feature allows the device to report information such as the fault location, fault cause, and fault status to the platform. The platform will record fault information and notify routing, aggregation, and other service modules. Service modules will adjust the cost value of routing and select ports for aggregation based on the fault information to avoid using faulty hardware for service traffic forwarding.
To view hardware fault causes, execute the display ifmonitor command. For more information about the display ifmonitor command, see error code detection commands in High Availability Command Reference.
# Enable hardware detection reporting.
[Sysname] link-quality hardware-error enable
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the default.
In standalone mode:
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value [ early-warning early-warning-value secure secure-value ]
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The free-memory thresholds vary by device model. To obtain the default free-memory thresholds, execute the undo memory-threshold and display memory-threshold commands in sequence.
ratio: Specifies free-memory thresholds in percentage. If you do not specify this keyword, the command sets free-memory thresholds in MB.
minor minor-value: Specifies the minor alarm threshold. This threshold must be equal to or less than the normal state threshold. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. This threshold must be equal to or less than the minor alarm threshold. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. This threshold must be equal to or less than the severe alarm threshold. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. This threshold must be equal to or less than the total memory size.
early-warning early-warning-value: Specifies the early-warning threshold. To view the value range for this threshold, enter a question mark (?) in the place of the early-warning-value argument. Setting this threshold to 0 disables the early warning feature.
secure secure-value: Specifies the sufficient-memory threshold. To view the value range for this threshold, enter a question mark (?) in the place of the secure-value argument.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets free-memory thresholds for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command sets free-memory thresholds for the global active MPU. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases to or below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules or processes.
For slots that support low memory, the system monitors only the amount of free low-memory space. You can use the display memory command to display memory usage information. If the LowMem field is displayed for a slot, the slot supports low memory.
For more information about the alarm thresholds, see Fundamentals Configuration Guide.
The system will restart a card if one of the following conditions is met:
· After a critical alarm occurs, the remaining free-memory value has been smaller than the critical alarm threshold for 30 seconds.
· The interval between two consecutive critical alarms is shorter than 30 seconds.
· The critical alarm has occurred three times within three minutes.
· After a critical alarm occurs, the system will periodically sample free memory space and predict if the free memory space will be exhausted within 30 seconds. If the prediction result indicates that the free memory space will be exhausted within 30 seconds, the system will restart the card.
Once the free memory space reaches the early warning, minor, severe, or critical alarm threshold, the device will display the current memory usage information when you log in to the device through console or Telnet login, or execute every command.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
Use memory-threshold dma to set DMA memory thresholds.
Use undo memory-threshold dma to restore the default.
In standalone mode:
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
memory-threshold dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The DMA memory alarm threshold is 2048 KB, and the normal state threshold is 4096 KB.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets DMA memory thresholds for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command sets DMA memory thresholds for the global active MPU. (In IRF mode.)
ratio: Specifies DMA memory thresholds in percentage.
critical critical-value: Specifies the DMA memory alarm threshold. If the ratio keyword is specified, the value range for the critical-value argument is 1 to 100 in percentage. If the ratio keyword is not specified, the value range is 0 to 3145728.
normal normal-value: Specifies the normal state threshold. If the ratio keyword is specified, the value range for the normal-value argument is 1 to 100 in percentage. If the ratio keyword is not specified, the value is in the range of critical-value to 3145728.
To ensure correct operation of the services that require DMA memory, the system monitors the amount of free DMA memory space regularly. If the amount of free DMA memory space decreases to or below the alarm threshold, the system generates a notification indicating that the DMA memory space is insufficient. If the amount of free DMA memory space increases above the normal state threshold, the system generates a notification indicating that the DMA memory space is sufficient.
# (In standalone mode.) Set the DMA memory alarm threshold and the normal state threshold to 32KB and 96 KB, respectively, for slot0.
<System> system-view
[System] memory-threshold dma slot 0 critical 32 normal 96
memory-threshold usage
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
In standalone mode:
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
In IRF mode:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100%.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the memory usage threshold for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command sets the memory usage threshold for the global active MPU. (In IRF mode.)
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
The device samples memory usage at 1-minute intervals. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
memory-threshold usage resend-interval
Use memory-threshold usage resend-interval to set the memory usage alarm resending interval.
Use undo memory-threshold usage resend-interval to restore the default.
In standalone mode:
memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage resend-interval interval-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage resend-interval
In IRF mode:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage resend-interval interval-value
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage resend-interval
The memory usage alarm resending interval is 300 seconds.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the interval for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command sets the interval for the global active MPU. (In IRF mode.)
resend-interval interval-value: Specifies the memory usage alarm resending interval in the range of 1 to 3600, in minutes.
The device samples memory usage periodically, and compares the sampled value with the memory usage thresholds. If the sampled value exceeds an alarm threshold, the device enters alarm state and generates an alarm (log and trap) to notify the administrator. If the memory usage remains in the alarm state after the memory usage alarm resending interval is reached, the device outputs the alarm again.
# In standalone mode:Set the memory usage alarm resending interval to 60 minutes for CPU 0 in slot 0.
[Sysname] memory-threshold slot 0 cpu 0 usage resend-interval 60
monitor cpu-usage enable
Use monitor cpu-usage enable to enable CPU usage monitoring.
Use undo monitor cpu-usage enable to disable CPU usage monitoring.
In standalone mode:
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU usage monitoring is enabled.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command enables CPU usage monitoring for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command enables CPU usage monitoring for the global active MPU. (In IRF mode.)
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage monitoring.
[Sysname] monitor cpu-usage enable
display cpu-usage configuration
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
Use undo monitor cpu-usage interval to restore the default.
In standalone mode:
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor cpu-usage interval interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The system samples CPU usage every 1 minute.
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage threshold
Use monitor cpu-usage threshold to set the CPU usage threshold.
Use undo monitor cpu-usage threshold to restore the default.
In standalone mode:
monitor cpu-usage threshold cpu-threshold [ minor-threshold minor-threshold recovery-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ minor-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor cpu-usage threshold cpu-threshold [ minor-threshold minor-threshold recovery-threshold recovery-threshold ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ minor-threshold recovery-threshold ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The severe CPU usage alarm threshold is 99%. The minor CPU usage alarm threshold is 79%. The CPU usage recovery threshold is 69%.
cpu-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range for this argument is 2 to 100.
minor-threshold minor-threshold: Specifies the minor CPU usage alarm threshold in percentage. The value range for this argument is 1 to the severe CPU usage alarm threshold minus 1. If you do not specify this option, the minor CPU usage alarm threshold is 80 percent of the severe CPU usage alarm threshold.
recovery-threshold recovery-threshold: Specifies the CPU usage recovery threshold in percentage. The value range for this argument is 0 to the minor CPU usage alarm threshold minus 1. If you do not specify this option, the CPU usage recovery threshold is 70 percent of the severe CPU usage alarm threshold.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the CPU usage threshold for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command sets the CPU usage threshold for the global active MPU. (In IRF mode.)
CAUTION: If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal service processing will be affected. |
The device samples CPU usage at 1-minute intervals. If the sample is greater than a CPU usage alarm threshold, the device sends a trap. If the sample is equal to or less than the CPU usage recovery threshold, the device determines that the CPU usage is normal.
# Set the severe CPU usage threshold to 80%.
[Sysname] monitor cpu-usage threshold 80
monitor disk-usage disk
Use monitor disk-usage disk to set the disk usage threshold.
Use undo monitor disk-usage disk to restore the default.
In standalone mode:
monitor disk-usage [ slot slot-number ] disk disk-name threshold threshold-value
undo monitor disk-usage [ slot slot-number ] disk disk-name threshold
In IRF mode:
monitor disk-usage [ chassis chassis-number slot slot-number ] disk disk-name threshold threshold-value
undo monitor disk-usage [ chassis chassis-number slot slot-number ] disk disk-name threshold
The disk usage threshold is 95%.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command applies to the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, the command applies to the global active MPU. (In IRF mode.)
disk disk-name: Specifies a disk by its name. This option is case sensitive. The system will prompt a parameter error if you enter this option incorrectly.
threshold threshold-value: Specifies the disk usage threshold in percentage, in the range of 1 to 100.
After you set the disk usage threshold, the device compares the usage of the disk with the threshold at each sampling. If the usage exceeds the threshold, the device sends a high disk usage alarm to the NETCONF module. For more information about the NETCONF module see Network Management and Monitoring Configuration Guide.
# Set the disk usage threshold to 80%.
[Sysname] monitor disk-usage disk flash threshold 80
monitor disk-usage interval
Use monitor disk-usage interval to set the disk usage sampling interval.
Use undo monitor disk-usage interval to restore the default.
monitor disk-usage interval interval
The disk usage sampling interval is 300 seconds.
interval interval-time: Specifies the disk usage sampling interval in seconds, a multiple of 5 in the range of 5 to 1800.
After you set the disk usage sampling interval, the device samples the disk usage at the specified intervals.
# Set the disk usage sampling interval to 120 seconds.
[Sysname] monitor disk-usage interval 120
monitor kernel memory fragment interval
Use monitor kernel memory fragment interval to set the interval for collecting kernel memory fragment information.
Use undo monitor kernel memory fragment interval to restore the default.
In standalone mode:
monitor kernel memory fragment interval interval-value [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel memory fragment interval [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor kernel memory fragment interval interval-value [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor kernel memory fragment interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The interval is five minutes for collecting kernel memory fragment information.
interval-value: Specifies the interval in minutes. The value range is 1 to 65535.
The device collects kernel memory fragment statistics at the intervals specified by this command. To view the statistics and identify whether the kernel memory fragment ratio is normal, execute the display kernel memory fragment free command.
# Set the interval for collecting memory fragment information to 5 minutes.
[System] monitor kernel memory fragment interval 5
monitor kernel memory fragment ratio
Use monitor kernel memory fragment ratio to set the kernel memory fragment ratio alarm threshold.
Use undo monitor kernel memory fragment ratio to restore the default.
In standalone mode:
monitor kernel memory fragment ratio ratio-value [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel memory fragment ratio [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor kernel memory fragment ratio ratio-value [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor kernel memory fragment ratio [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The kernel memory fragment ratio alarm threshold is 20%.
ratio ratio-value: Specifies the kernel memory fragment ratio alarm threshold in percentage, in the range of 1 to 100.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the kernel memory fragment ratio alarm threshold for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command sets the kernel memory fragment ratio alarm threshold for the global active MPU. (In IRF mode.)
A running kernel thread's process requires memory allocation from the system. The system allocates and releases this memory as a whole. If the process is still running and some memory blocks have been used but are no longer used, these memory blocks will not be released in advance. These free but currently unusable memory blocks are also referred to as memory fragments.
This command enables the device to monitor the kernel memory fragment ratio. If the kernel memory fragment ratio decreases to or below the alarm threshold, the kernel memory usage is low and an alarm notification is generated. If the kernel memory fragment ratio increases above the alarm threshold, the kernel memory usage returns to the normal state and a recovery notification is generated.
# (In standalone mode.) Set the kernel memory fragment ratio alarm threshold to 80 for slot 0.
[System] monitor kernel memory fragment ratio 80 slot 0
monitor resend cpu-usage
Use monitor resend cpu-usage to set CPU usage alarm resending intervals.
Use undo monitor resend cpu-usage to restore the default.
In standalone mode:
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor resend cpu-usage { minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The minor CPU usage alarm resending interval is 300 seconds. The severe CPU usage alarm resending interval is 60 seconds.
minor-interval minor-interval: Specifies the minor CPU usage alarm resending interval in seconds, a multiple of 5 in the range of 10 to 3600.
severe-interval severe-interval: Specifies the severe CPU usage alarm resending interval in seconds, a multiple of 5 in the range of 10 to 3600.
The device samples CPU usage at intervals, and compares the samples with CPU usage thresholds to identify the CPU usage status and send alarms or notifications accordingly.
In minor alarm state, the device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed. In severe alarm state, the device sends severe alarms periodically until the severe alarm is removed. This command sets the alarm resending intervals.
If you do not specify a keyword for the undo monitor resend cpu-usage command, the command restores the default minor and severe CPU usage alarm resending intervals.
# (In standalone mode.) Set the minor CPU usage alarm resending interval to 60 seconds for slot 0.
[Sysname] monitor resend cpu-usage minor-interval 60 slot 0 cpu 0
monitor resend cpu-usage core-interval
Use monitor resend cpu-usage core-interval to set CPU core usage alarm resending intervals.
Use undo monitor resend cpu-usage core-interval to restore the default.
In standalone mode:
monitor resend cpu-usage core-interval { minor-interval minor-interval | severe-interval severe-interval } * [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor resend cpu-usage core-interval { minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ minor-interval | severe-interval ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The minor CPU core usage alarm resending interval is 300 seconds and severe CPU core usage alarm resending interval is 60 seconds.
minor-interval minor-interval: Specifies the resending interval for minor CPU core usage alarms in seconds, a multiple of 5 in the range of 10 to 3600.
severe-interval severe-interval: Specifies the resending interval for severe CPU core usage alarms in seconds, a multiple of 5 in the range of 10 to 3600.
The device samples CPU core usage at intervals, and compares the samples with CPU core usage thresholds to identify the CPU core usage status and send alarms or notifications accordingly.
In minor alarm state, the device sends minor alarms periodically until the CPU core usage increases above the severe threshold or the minor alarm is removed. In severe alarm state, the device sends severe alarms periodically until the severe alarm is removed. This command sets the alarm resending intervals.
# Set the resending interval for minor CPU core usage alarms to 100 seconds and the resending interval for severe CPU core usage alarms 60 seconds.
[Sysname] monitor resend cpu-usage core-interval minor-interval 100 severe-interval 60
monitor resend memory-threshold
Use monitor resend memory-threshold to set free memory depletion alarm resending intervals.
Use undo monitor resend memory-threshold to restore the default.
In standalone mode:
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor resend memory-threshold { critical-interval critical-interval | early-warning-interval early-warning-interval | minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
· Early warning resending interval: 1 hour.
· Minor alarm resending interval: 12 hours.
· Severe alarm resending interval: 3 hours.
· Critical alarm resending interval: 1 hour.
critical-interval critical-interval: Specifies the critical alarm resending interval in hours, in the range of 1 to 48.
early-warning-interval early-warning-interval: Specifies the early warning resending interval in hours, in the range of 1 to 48.
minor-interval minor-interval: Specifies the minor alarm resending interval in hours, in the range of 1 to 48.
severe-interval severe-interval: Specifies the severe alarm resending interval in hours, in the range of 1 to 48.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets alarm resending intervals for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. If you do not specify a card, this command sets alarm resending intervals for the global active MPU. (In IRF mode.)
The device samples the amount of free memory space periodically and compares the sampled value with free-memory thresholds. If the sampled value decreases to or below a threshold, the device enters a memory depletion alarm state and sends an alarm.
In critical alarm state, the device sends critical alarm notifications periodically until the critical alarm is removed.
In a lower alarm state, the device sends notifications for the alarm state periodically until it enters a higher alarm state or the current alarm is removed.
You can use this command to change the alarm resending intervals.
# (In standalone mode.) Set the minor memory depletion alarm resending interval to 12 hours for CPU 0 in slot 0.
[Sysname] monitor resend memory-threshold minor-interval 12 slot 0 cpu 0
monitor resend memory-threshold dma
Use monitor resend memory-threshold dma to set the DMA memory alarm resending interval.
Use undo monitor resend memory-threshold dma to restore the default.
In standalone mode:
monitor resend memory-threshold dma critical-interval critical-interval [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold dma critical-interval [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor resend memory-threshold dma critical-interval critical-interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold dma critical-interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The DMA memory alarm resending interval is 300 seconds.
critical-interval critical-interval: Specifies the resending interval for the DMA memory alarms in seconds, in the range of 10 to 3600.
The device samples DMA memory usage at intervals, and compares the samples with the DMA memory alarm threshold to identify the DMA memory usage status and send alarms or notifications accordingly.
# Set the resending interval for the DMA memory alarms to 100 seconds.
[Sysname] monitor resend memory-threshold dma critical-interval 100<Sysname> system-view
parity-error consistency-check log enable
Use parity-error consistency-check log enable to enable consistency error logging for software and hardware forwarding entries.
Use undo parity-error consistency-check log enable to disable consistency error logging for software and hardware forwarding entries.
Consistency error logging is enabled for software and hardware forwarding entries.
To forward packets, the device generates hardware forwarding entries on forwarding chips and software forwarding entries in memory at the same time. The device automatically detects whether the hardware forwarding entries and the software forwarding entries are consistent.
With this command executed, if the number of consistency errors after a scan on software and hardware entries by forwarding chips reaches the logging threshold, the device generates and sends a log message to the information center module. The information center module determines how and where to send the message. For more information about the information center module, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable consistency error logging for software and hardware forwarding entries.
[Sysname] parity-error consistency-check log enable
parity-error consistency-check threshold
Use parity-error consistency-check threshold to set the logging threshold for consistency errors between software and hardware forwarding entries.
Use undo parity-error consistency-check threshold to restore the default.
parity-error consistency-check threshold value
The logging threshold is 10.
value: Specifies the logging threshold for consistency errors between software and hardware forwarding entries, in the range of 1 to 3600.
After you execute this command, if the number of consistency errors reaches the logging threshold after a scan on software and hardware forwarding entries, the device generates a log message.
# Set the logging threshold to 20 for consistency errors between software and hardware forwarding entries.
[Sysname] parity-error consistency-check threshold 20
parity-error consistency-check period
parity-error monitor log enable
Use parity-error monitor log enable to enable parity error and ECC error logging for entries on forwarding chips.
Use undo parity-error monitor log enable to disable parity error and ECC error logging for entries on forwarding chips.
Parity error and ECC error logging is enabled for entries on forwarding chips.
The device automatically detects parity errors and ECC errors in entries on forwarding chips.
After you execute this command, the device collects parity errors and ECC errors periodically. If the number of parity errors and ECC errors in a statistics period reaches the logging threshold, the device generates and sends a parity error and ECC error log message to the information center module. The information center module determines how and where to send the message. For more information about the information center module, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable parity error and ECC error logging for entries on forwarding chips.
[Sysname] parity-error monitor log enable
parity-error monitor period
parity-error monitor threshold
Use parity-error monitor period to set the parity error and ECC error statistics period for entries on forwarding chips.
Use undo parity-error monitor period to restore the default.
parity-error monitor period value
The parity error and ECC error statistics period is 300 seconds for entries on forwarding chips.
period: Specifies the parity error and ECC error statistics period in seconds, in the range of 1 to 86400.
The device automatically detects parity errors and ECC errors in entries on forwarding chips. The parity error and ECC error logging feature collects parity error and ECC error statistics periodically, and generates a log message if the number of parity error and ECC errors reaches the logging threshold.
This command determines the period for the device to collect parity error and ECC error statistics.
# Set the parity error and ECC error statistics period to 120 seconds.
[Sysname] parity-error monitor period 120
Use parity-error monitor threshold to set the parity error and ECC error logging threshold for entries on forwarding chips.
Use undo parity-error monitor threshold to restore the default.
parity-error monitor threshold value
The parity error and ECC error logging threshold is 50 for entries on forwarding chips.
value: Specifies the parity error and ECC error logging threshold for entries on forwarding chips, in the range of 1 to 86400.
The device detects parity error and ECC errors in entries on forwarding chips. The parity error and ECC error logging feature collects parity error and ECC error statistics periodically, and generates a log message if the number of parity error and ECC errors reaches the logging threshold. This command sets the logging threshold.
# Set the parity error and ECC error logging threshold to 8000 for entries on forwarding chips.
[Sysname] parity-error monitor threshold 8000
parity-error unrecoverable log enable
Use parity-error unrecoverable log enable to enable uncorrectable parity error and ECC error logging for entries on forwarding chips.
Use undo parity-error unrecoverable log enable to disable uncorrectable parity error and ECC error logging for entries on forwarding chips.
Uncorrectable parity error and ECC error logging is enabled for entries on forwarding chips
The device automatically detects parity errors and ECC errors in entries on forwarding chips and tries to correct the error when an error is detected. The uncorrectable parity error and ECC error logging feature enables the device to collect uncorrectable parity error and ECC error statistics periodically. If the number of uncorrectable parity errors and ECC errors reaches the logging threshold, the device generates and sends an uncorrectable parity error and ECC error log message to the information center module. The information center module determines how and where to send the log message. For more information about the information center module, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable uncorrectable parity error and ECC error logging for entries on forwarding chips
[Sysname] parity-error unrecoverable log enable
parity-error unrecoverable period
parity-error unrecoverable reboot
parity-error unrecoverable threshold
Use parity-error unrecoverable period to set the statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips.
Use undo parity-error unrecoverable period to restore the default.
parity-error unrecoverable period period
The statistics period is 60 seconds for uncorrectable parity errors and ECC errors for entries on forwarding chips.
period: Specifies the statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips, in the range of 1 to 86400, in seconds.
The device automatically detects parity errors and ECC errors in entries on forwarding chips and tries to correct the error when an error is detected. The uncorrectable parity error and ECC error logging feature enables the device to collect uncorrectable parity error and ECC error statistics periodically. If the number of uncorrectable parity errors and ECC errors reaches the logging threshold, the device generates an uncorrectable parity error and ECC error log message.
This command sets the period for the device to collect uncorrectable parity error and ECC error statistics.
# Set the statistics period for uncorrectable parity errors and ECC errors in entries on forwarding chips to 120 seconds.
[Sysname] parity-error unrecoverable period 120
Use parity-error unrecoverable reboot to enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
Use undo parity-error unrecoverable reboot to disable automatic system reboot upon generation of an uncorrectable parity error and ECC error log
The system reboots automatically upon generation of an uncorrectable parity error and ECC error log.
Uncorrectable parity errors and ECC errors in entries on forwarding chips might affect system services. To remove the errors from the entries on forwarding chips, you can execute this command to enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
If the card to be restarted is an MPU and the device is installed with only one MPU, this command will not take effect.
# Enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
[Sysname] parity-error unrecoverable reboot
Use parity-error unrecoverable threshold to set the logging threshold for uncorrectable parity errors and ECC errors on entries on forwarding chips.
Use undo parity-error unrecoverable threshold to restore the default.
parity-error unrecoverable threshold value
The logging threshold is 1 for uncorrectable parity errors and ECC errors in entries on forwarding chips.
value: Specifies the logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips, in the range of 1 to 86400.
# Set the logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips to 10.
[Sysname] parity-error unrecoverable log threshold 10
password-recovery enable
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
To access the device configuration without authentication, you must connect to the active MPU and access the BootWare menu while the MPU is starting up.
Availability of BootWare menu options depends on the password recovery capability setting. For more information, see the release notes.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
port-working-mode
Use port-working-mode to set the port operating mode for the device.
Use undo port-working-mode to restore the default.
port-working-mode { hg2-card | hg4-xp12 }
The port operating mode for the device is hg4-xp12.
hg2-card: Specifies the hg2-card mode. In this mode, only the following are available:
· Six GE ports (ports 1 through 6).
· 20 XGE ports (ports 7 through 26).
· Two HE ports (ports 27 and 28).
· Four GE copper ports (ports 31 through 34).
· Interface module slot.
hg4-xp12: Specifies the hg4-xp12 mode. In this mode, only 12 XGE ports (port 15 through 26) and four HE ports (.ports 27 through 30) are available.
# Set the port operating mode to hg2-card for the device.
[Sysname] port-working-mode hg2-card
power control-mode
Use power control-mode to set the card power-on control mode.
Use undo power control-mode to restore the default.
power control-mode { loose | strict }
The card power-on control mode is strict.
loose: Specifies the loose mode.
strict: Specifies the strict mode.
# Set the card power-on control mode to loose.
[Sysname] power control-mode loose
power-off high-temp-board clear
Use power-off high-temp-board clear to restore power supply for cards shut down because of overtemperature.
In standalone mode:
In IRF mode:
power-off high-temp-board clear chassis chassis-number
When the temperature on a card reaches the shutdown temperature threshold, the overtemperature auto shutdown feature automatically shuts down the card. You can use this command to power on the card as appropriate.
# Restore power supply for cards shut down because of overtemperature.
[Sysname] power-off high-temp-board clear
power-off high-temp-board enable
Use power-off high-temp-board enable to enable the overtemperature auto shutdown feature.
undo power-off high-temp-board enable
The overtemperature auto shutdown feature is enabled.
# Enable the overtemperature auto shutdown feature.
[Sysname] power-off high-temp-board enable
display power-off high-temp-board
reboot
Use reboot to reboot the device.
In standalone mode:
reboot [ slot slot-number [ subslot subslot-number ] ] [ force ]
In IRF mode:
reboot [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] ] [ force ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, the command reboots all IRF member devices. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. If you do not specify a card, the command reboots the IRF member device. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command reboots the entire device. On this device, the slot-number argument represents the entire device and its value is fixed. This command reboots the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
subslot subslot-number: Specifies a subcard by its subslot number. If you do not specify a subslot number, the command reboots the device.
force: Reboots the device immediately without performing software or hard disk check. If this keyword is not specified, the system first identifies whether the reboot might result in data loss or a system failure. For example, the system identifies whether the main system software image file exists and whether a write operation is in progress on a storage medium. If the reboot might cause problems, the system does not reboot the device.
CAUTION: · A reboot might interrupt network services. · Use the force keyword only when the device fails or a reboot command without the force keyword cannot perform a reboot correctly. A reboot command with the force keyword might result in file system corruption because it does not perform data protection. |
If the main startup software images are corrupt or missing, you must re-specify a set of main startup software images before executing the reboot command.
For data security, the device does not reboot if you reboot the device while the device is performing file operations.
# (In standalone mode.) Reboot the device. Save the running configuration at prompt.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# Reboot the device immediately without performing software check.
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
redundant-power energy-saving
Use redundant-power energy-saving to configure energy saving for excess power modules on the device.
Use undo redundant-power energy-saving to restore the default.
redundant-power energy-saving { enable | disable }
The energy saving feature of the excess power modules on the device is disabled.
enable: Enables energy saving for excess power modules.
disable: Disables energy saving for excess power modules.
This command can shuts down the output of the excess power modules on the device without affecting MCU operation. The excess power modules refer to additional power modules after you configure redundant power modules. Enabling energy saving for excess power modules does not affect the device operation or power module redundancy. The energy saving feature allows these excess power modules to automatically start up when power consumption increases.
# Enable energy saving for excess power modules.
[Sysname] redundant-power energy-saving enable
energy-saving mode
reset alarm active
Use reset alarm active to clear active alarm information on the device.
reset alarm active { all | sequence-number sequence-number }
The active alarm information on the device is not cleared.
Parameter
all: Specifies all active alarms.
sequence-number sequence-number: Specifies an active alarm by its sequence number, in the range of 1 to 4294967295.
When the system has information about active alarms, you can execute this command to manually clear these alarms. When clearing an active alarm, the system generates a trap message and saves it as a historical alarm for users to view if necessary. The system can generate trap messages only when SNMP is enabled on the device.
# Clear the active alarm with sequence number 1.
[Sysname] reset alarm active sequence-number 1
display alarm active
display alarm history
reset scheduler logfile
Use reset scheduler logfile to clear job execution log information.
# Clear job execution log information.
<Sysname> reset scheduler logfile
display scheduler logfile
reset transceiver interface
Use reset transceiver interface to reset a transceiver module.
reset transceiver interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command applies to all interfaces.
This command is disruptive. Use this command only when you cannot troubleshoot transceiver modules by using other methods.
This command will restart the transceiver module.
Only the QSFP and QSFPDD transceiver modules support this command.
# Reset the QSFP transceiver module in HundredGigE 0/0/27.
<Sysname> reset transceiver interface hundredgige 0/0/27
This operation causes services on the transceiver module to be down for a while. Continue? [Y/N]: Y
reset version-update-record
Use reset version-update-record to clear startup software image upgrade records.
# Clear the startup software image upgrade records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
display version-update-record
resource-monitor minor resend enable
Use resource-monitor minor resend enable to enable resending of minor resource depletion alarms.
Use undo resource-monitor minor resend enable to disable resending of minor resource depletion alarms.
Resending of minor resource depletion alarms is enabled.
When a resource type enters minor alarm state, the device issues a minor alarm. If the resource type stays in minor alarm state or changes from severe alarm state to minor alarm state, the device identifies whether resending of minor resource depletion alarms is enabled. If the feature is disabled, the device does not issue additional minor alarms. If the feature is enabled, the device resends minor alarms periodically.
The resending period is fixed at 24 hours for a severe alarm and is fixed at 7 * 24 hours for a minor alarm.
# Enable resending of minor resource depletion alarms.
[Sysname] resource-monitor minor resend enable
display resource-monitor
resource-monitor output
resource-monitor resource
Use resource-monitor output to specify destinations for resource depletion alarms.
Use undo resource-monitor output to remove destinations for resource depletion alarms.
undo resource-monitor output [ netconf-event | snmp-notification | syslog ] *
Resource depletion alarms are sent to NETCONF, SNMP, and the information center.
netconf-event: Sends resource depletion alarms to the NETCONF feature to encapsulate the alarms in NETCONF events. For more information, see NETCONF in Network Management and Monitoring Configuration Guide.
snmp-notification: Sends resource depletion alarms to the SNMP feature to encapsulate the alarms in SNMP traps and informs. For more information, see SNMP in Network Management and Monitoring Configuration Guide.
syslog: Sends resource depletion alarms to the information center to encapsulate the alarms in log messages. For more information, see information center in Network Management and Monitoring Configuration Guide.
If you do not specify any keywords for the undo resource-monitor output command, the command disables resource depletion alarm output.
# Specify the information center module as the output destination for resource depletion alarms.
[Sysname] resource-monitor output syslog
Use resource-monitor resource to set resource depletion thresholds.
Use undo resource-monitor resource to disable resource depletion thresholds.
In standalone mode:
resource-monitor resource resource-name slot slot-number cpu cpu-number { by-absolute | by-percent } minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
In IRF mode:
resource-monitor resource resource-name chassis chassis-number slot slot-number cpu cpu-number { by-absolute | by-percent } minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name chassis chassis-number slot slot-number cpu cpu-number
The default settings vary by resource type. Use the display resource-monitor command to display the resource depletion thresholds.
resource-name: Specifies a resource type by its name. The values for this argument are case insensitive and cannot be abbreviated. The resource types that can be monitored are as shown in Table 48. The resource types that can be monitored vary by device model.
Table 48 Resource types that can be monitored
Resource type |
acl_car |
CAR template resources. |
acl_counter |
ACL counter resources. |
arp |
ARP resources. |
arpnd |
ARP and ND resources. |
bfd_hardbfd_session |
Hardware BFD sessions |
bpa_counter_in |
Inbound BGP statistics resources. |
bpa_counter_out |
cfd_counterid_index |
CFD counterid index resources. |
cfd_watchdog_index |
CFD watchdog index resources. |
ecmp |
ECMP resources. |
efp_acl |
Outbound ACL resources. |
eth_subif_statistic |
Route subinterface statistics counter resources. |
flow_mirror |
Flow mirror resources. |
Ifp_acl |
Inbound ACL resources. |
ipmc |
Layer 3 multicast replication table resources. |
ipv4_acl |
IPv4 ACL resources. |
ipv4_defip |
IPv4 route reources. |
ipv4fib |
IPv4 FIB hardware entry resources. |
ipv4mc |
IPv4 multicast forwarding entry resources. |
ipv6_acl |
IPv6 ACL resources. |
ipv6_defip |
IPv6 route resources. |
ipv6_defip64 |
Resources for IPv6 routes with a prefix length of 0 to 64 bits. |
ipv6_defip128 |
Resources for IPv6 routes with a prefix length of 65 to 128 bits. |
ipv6_sr_list |
SRv6 list resources |
ipv6fib |
IPv6 FIB hardware entry resources. |
ipv6mc |
IPv6 multicst forwarding entry resources. |
mac |
MAC address table resources. |
maptable_in |
Inbound flexible priority mapping table resources. |
maptable_out |
Outbound flexible priority mapping table resources. |
mpls_cbts |
CBTS statistics resources. |
mpls_dynvpnid |
VXLAN flooding MAC resources. |
mpls_ecmplsp |
ECMP LSP resources. |
mpls_ilm |
ILM label resources. |
mpls_inlabel |
Inbound MPLS label resources. |
mpls_l3vpn |
Number of L3VPN instances. |
mpls_label |
Label index resources. |
mpls_lsp |
MPLS LSP statistics resources. |
mpls_outlabel |
Outbound MPLS label resources. |
mpls_te |
Configured number of MPLS TE tunnels |
mpls_outlif |
MPLS outlif resources. |
mpls_vp |
MPLS VP resources. |
mpls_vpls_pw |
Number of PWs for VPLS instances |
mpls_vpws |
Configured VPWS number. |
mpls_vsi |
Number of VSIs. |
mpls_vxlan_tunnel |
Number of VXLAN tunnels. |
mpls_vxlanvni |
VXLAN private wire statistics resources. |
mpls_pwrestrainres_0 |
PW rate limit resources. |
mtunnel |
Multicast tunnel interface resources. |
mpls_tecar_profile |
Profile resources of CAR rate limit for MPLS TE tunnels. |
mpls_tecar_tb |
TB resources of CAR rate limit for MPLS TE tunnels. |
nd |
ND resources. |
nexthop |
Next hop resources. |
nqa_client_1564 |
Number of NQA client 1564 sessions. |
nqa_client_2544 |
Number of NQA client 2544 sessions. |
nqa_client_twamplight |
Number of NQA client twamp sessions. |
nqa_reflector_remote |
Number of NQA server 1564 and 2544 sessions. |
nqa_reflector_twamplight |
NQA servertwamp sessions. |
nqa_veinlif |
NQA VEinlif resources. |
port_shape |
Main interface shaping resources. |
qinq_inlif_0 |
Subinterface QinQ Inlif entry resources where 0 indicates forwarding chip ID. |
qinq_inlif_tree_0 |
Subinterface QinQ Inlif tree entry resources, where 0 indicates forwarding chip ID. |
qos_queue |
QoS eight-queue resources. |
queue_shape |
Queue shaping resources. |
queue_shape_in |
Queue shaping resources in the inbound direction. |
queue_shape_out |
Queue shaping resources in the outbound direction. |
queue_buffer |
Queue buffer resources. |
queue_buffer_in |
Queue buffer resources in the inbound direction. |
queue_buffer_out |
Queue buffer resources in the outbound direction. |
rport |
Protocol port entry resources. |
sampler |
Sampler resources. |
share_policy_in |
Inbound shared MQC resources. |
share_policy_out |
Outbound shared MQC resources. |
subif_tb_in |
Inbound subinterface statistics resources. |
subif_tb_out |
Outbound subinterface statistics resources. |
subport_shape |
Subinterface shaping resources. |
tunnel |
Tunnel interface resources. |
v4mcpro |
IPv4 multicast entry resources. |
v6mcpro |
IPv6 multicast entry resources. |
vfp_acl |
VLAN-related ACL resources. |
wfq_weight |
Weight resources for weighted fair queuing. |
wred_table |
WRED template resources. |
bras_out |
Outbound BRAS user count resources. |
bras_in |
Inbound BRAS user count resources. |
bras_car |
CAR profile resources used by BRAS users. |
slot slot-number: Specifies a card by its slot number. On this device, the slot-number argument represents the entire device and its value is fixed. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. (In IRF mode.)
by-absolute: Specifies resource depletion thresholds by using absolute values.
by-percent: Specifies resource depletion thresholds in percentage.
minor-threshold minor-threshold: Specifies the minor resource depletion threshold. To view the value range, enter a question mark (?) in the place of the minor-threshold argument.
severe-threshold severe-threshold: Specifies the severe resource depletion threshold. To view the value range, enter a question mark (?) in the place of the severe-threshold argument.
After you execute this command for a resource type, the device monitors the available amount of the type of resources. The device samples the available amount at intervals, compares the sample with the resource depletion thresholds to identify the resource depletion status, and sends alarms as configured.
# (In standalone mode.) Set the minor resource depletion threshold to 30% and the severe resource depletion threshold to 10% for ARP entry resources on slot 0.
[Sysname] resource-monitor resource arpnd slot 0 cpu 0 by-percent minor-threshold 30 severe-threshold 10
restore factory-default
Use restore factory-default to restore the factory-default configuration for the device.
CAUTION: This command restores the device to the factory default settings. Before using this command, make sure you fully understand its impact on your live network. |
Use this command only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario.
The command takes effect after the device reboots.
# Restore the factory-default configuration for the device.
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
reboot
scheduler job
Use scheduler job to create a job and enter its view, or enter the view of an existing job.
Use undo scheduler job to delete a job.
scheduler job job-name
undo scheduler job job-name
No job exists.
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
A job can be referenced by multiple schedules. In job view, you can assign commands to the job.
# Create a job named backupconfig and enter job view.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
command
scheduler schedule
scheduler logfile size
Use scheduler logfile size to set the size of the job execution log file.
scheduler logfile size value
The size of the job execution log file is 16 KB.
value: Specifies the size of the job execution log file, in KB. The value range is 16 to 1024.
The job execution log file saves the execution information of jobs. If the file is full, old records are deleted to make room for new records. If the size of the log information to be written to the file is greater than the file size, the excessive information is not written to the file.
# Set the size of the job execution log file to 32 KB.
[Sysname] scheduler logfile size 32
scheduler reboot at
Use scheduler reboot at to specify the reboot date and time.
Use undo scheduler reboot to delete the reboot schedule configuration.
No reboot date or time is specified.
time: Specifies the reboot time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the reboot date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION: This command enables the device to reboot at a scheduled time, which causes service interruption. Before using this command, make sure you fully understand its impact on your live network. |
When the date argument is not specified, the system uses the following rules to determine the reboot time:
· If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
· If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and scheduler reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
For data security, the system does not reboot at the reboot time if a file operation is being performed.
# Configure the device to reboot at 12:00 p.m. This example assumes that the current time is 11:43 a.m. on June 6, 2011.
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2011 (in 0 hours and 16 minutes). Confirm? [Y/N]:
Use scheduler reboot delay to specify the reboot delay time.
scheduler reboot delay time
No reboot delay time is specified.
time: Specifies the reboot delay time in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and schedule reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
# Configure the device to reboot after 88 minutes. This example assumes that the current time is 11:48 a.m. on June 6, 2011.
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2011(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule
Use scheduler schedule to create a schedule and enter its view, or enter the view of an existing schedule.
Use undo scheduler schedule to delete a schedule.
undo scheduler schedule schedule-name
No schedule exists.
schedule-name: Specifies the schedule name, a case-sensitive string of 1 to 47 characters.
You can configure a schedule to have the device automatically run a command or a set of commands without administrative interference.
To configure a schedule:
1. Use the scheduler job command to create a job and enter job view.
2. Use the command command to assign commands to the job.
3. Use the scheduler schedule command to create a schedule and enter schedule view.
4. Use the job command to assign the job to the schedule. You can assign multiple jobs to a schedule. The jobs must already exist.
5. Use the user-role command to assign user roles to the schedule. You can assign up to 64 user roles to a schedule.
6. Use the time at, time once, or time repeating command to specify an execution time for the schedule. You can specify only one execution time for a schedule.
# Create a schedule named saveconfig.
[Sysname] scheduler schedule saveconfig
job
time at
seu-error unrecoverable reboot
Use seu-error unrecoverable reboot to enable automatic reboot of the device after an unrecoverable SEU error is detected on a chip of a card or interface subcard.
Use undo seu-error unrecoverable reboot to disable automatic reboot of the device after an unrecoverable SEU error is detected on a chip of a card or interface subcard.
The device automatically reboots after an unrecoverable SEU error is detected on a chip of a card or interface subcard.
# Enable automatic reboot of the device after an unrecoverable SEU error is detected on a chip of a card or interface subcard.
[Sysname] seu-error unrecoverable reboot
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port status detection timer setting is 30 seconds.
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. The value of 0 indicates that port status detection is not automatically performed, and you need to execute the undo shutdown command to restore the port status manually.
On a network enabled with loop detection or STP, the device starts a port status detection timer when a port is shut down by a protocol. If the port has been in down state before the timer expires, the device will set the port status to the port's physical status.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
· If T < T1, the port will be brought up after T1 – T seconds.
· If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The device name is H3C.
sysname: Specifies a name for the device, a string of 1 to 64 characters.
A device name identifies a device in a network and is used in CLI view prompts. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
system forward-mode extended
Use system forward-mode extended to set the system forwarding mode to extended.
Use undo system forward-mode extended to restore the default.
The system forwarding mode is standard.
In standard mode, the device operates in good condition.
In extended mode, the device records the logs of forwarding modules. This mode is used only for device maintenance.
A system forwarding mode change takes effect after a device reboot.
# Set the system forwarding mode to extended.
<Sysname> system
[Sysname] system forward-mode extended
Do you want to change the system forwarding mode? [Y/N]:y
System forwarding mode changed. For the change to take effect, save the running configuration and reboot the device.
system turbo enable
Use system turbo enable to enable system performance optimization.
Use undo system turbo enable to disable system performance optimization.
system turbo enable
This command is available only for testing.
Contact Technical Support before using this command.
# Enable system performance optimization.
<Sysname> system
subslot-working-mode
Use subslot-working-mode to set the operating mode of a subslot for a subcard.
Use undo subslot-working-mode to restore the default.
In standalone mode:
subslot-working-mode slot slot-number subslot subslot-number { ethernet | ethernet-flexe | detnet }
undo subslot-working-mode slot slot-number subslot subslot-number
In IRF mode:
subslot-working-mode chassis chassis-number slot slot-number subslot subslot-number { ethernet | ethernet-flexe | detnet }
undo subslot-working-mode chassis chassis-number slot slot-number subslot subslot-number
The operating mode of a subslot for a subcard is ethernet.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
subslot subslot-number: Specifies a subcard by it subslot number.
ethernet: Sets the subslot operating mode to ethernet. In this mode, an interface of the subcard installed to the specified subslot supports only standard Ethernet mode.
ethernet-flexe: Sets the subslot operating mode to ethernet-flexe. In this mode, an interface of the subcard installed to the specified subslot supports switching between standard Ethernet mode and flexible Ethernet mode.
detnet: Sets the subslot operating mode to detnet. In this mode, an interface of the subcard installed to the specified subslot supports only the detnet mode.
If a subcard installed in the specified subslot does not support this feature, the feature setting will be deleted or fails to be configured.
For information about switching between standard Ethernet mode and flexible Ethernet mode, see FlexE interface configuration in Interface Configuration Guide.
Follow these restrictions and guidelines:
· The subcard on the subslot reboots for the configuration to take effect.
· The device removes the settings not supported by the subcard interfaces in the subslot in the current operating mode.
# Set the operating mode of subslot 1 to ethernet-flexe.
<Sysname> system
[Sysname] subslot-working-mode slot 0 sublot 1 ethernet-flexe
Change of the subslot working mode will reboot the subcard. Continue? [Y/N]:
temperature-limit
Use temperature-limit to set the temperature alarm thresholds.
Use undo temperature-limit to restore the default.
In standalone mode:
temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number
In IRF mode:
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number
The defaults vary by temperature sensor model. To view the defaults, execute the undo temperature-limit and display environment commands in turn.
chassis chassis-number: Specifies an IRF member device by its member ID. (In IRF mode.)
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically located near a high-heat chip to monitor the chip temperature.
inflow: Configures temperature alarm thresholds for inlet sensors. An inflow sensor is located near an air inlet to monitor the ambient temperature.
outflow: Configures temperature alarm thresholds for outlet sensors. An outflow sensor is located near an air outlet to monitor the device temperature.
sensor-number: Specifies a sensor by its number. To view the value range, enter a question mark (?) in the place of this argument.
lowlimit: Specifies the low-temperature threshold in Celsius degrees. The value range varies by temperature sensor. To view the value range, enter a question mark (?) in the place of this argument.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold. To view the value range, enter a question mark (?) in the place of this argument.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the warning threshold. To view the value range, enter a question mark (?) in the place of this argument.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
· Sends log messages and traps.
· Sets LEDs on the device panel.
# (In standalone mode.) Set temperature alarm thresholds for hotspot sensor 1 in a slot.
[Sysname] temperature-limit slot 0 hotspot 1 -10 50 60
display environment
time at
Use time at to specify an execution date and time for a non-periodic schedule.
Use undo time to delete the execution date and time configuration for a non-periodic schedule.
time at time date
undo time
No execution time or date is specified for a non-periodic schedule.
Schedule view
time: Specifies the schedule execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the schedule execution date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
The specified time (date plus time) must be later than the current system time.
The time at command, the time once command, and the time repeating command overwrite each other. The most recently executed command takes effect.
# Configure the device to execute the saveconfig schedule at 01:01 a.m. on May 11, 2011.
[Sysname-schedule-saveconfig] time at 1:1 2011/05/11
scheduler schedule
time once
Use time once to specify one or more execution days and the execution time for a non-periodic schedule.
Use undo time to delete the execution day and time configuration for a non-periodic schedule.
time once delay time
undo time
No execution time or day is specified for a non-periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
month-date month-day: Specifies a day in the current month, in the range of 1 to 31. If you specify a day that does not exist in the current month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days for the schedule. Valid week day values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
delay time: Specifies the delay time for executing the schedule, in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
If the specified time has already occurred, the schedule will be executed at the specified time the following day.
If the day in the month has already occurred, the schedule will be executed at the specified day in the following month.
If the specified day in a week has already occurred, the schedule will be executed at the specified day in the following week.
# Configure the device to execute the saveconfig schedule once at 15:00.
[Sysname-schedule-saveconfig] time once at 15:00
Schedule starts at 15:00 5/11/2011.
# Configure the device to execute the saveconfig schedule once at 15:00 on the coming 15th day in a month.
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# Configure the device to execute the saveconfig schedule at 12:00 p.m. on the coming Monday and Friday.
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# Configure the device to execute the saveconfig schedule after 10 minutes.
[Sysname-schedule-saveconfig] time once delay 10
scheduler schedule
time repeating
Use time repeating to specify an execution time table for a periodic schedule.
Use undo time to delete the execution time table configuration for a periodic schedule.
time repeating [ at time [ date ] ] interval interval
undo time
No execution time table is specified for a periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the current system time is used as the execution time.
date: Specifies the start date for the periodic schedule, in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. If you do not specify this argument, the execution start date is the first day when the specified time arrives.
interval interval: Specifies the execution time interval in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59. When in the mm format, this argument must be equal to or greater than 1 minute.
month-date [ month-day | last ]: Specifies a day in a month, in the range 1 to 31. The last keyword indicates the last day of a month. If you specify a day that does not exist in a month, the configuration takes effect on that day in the next month.
The time repeating [ at time [ date ] ] interval interval command configures the device to execute a schedule at intervals from the specified time on.
The time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ] command configures the device to execute a schedule at the specified time on every specified day in a month or week.
The time at command, the time once command, and the time repeating command overwrite each other, whichever is executed most recently takes effect.
# Configure the device to execute the saveconfig schedule once an hour from 8:00 a.m. on.
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# Configure the device to execute the saveconfig schedule at 12:00 p.m. every day.
[Sysname-schedule-saveconfig] time repeating at 12:00
# Configure the device to execute the saveconfig schedule at 8:00 a.m. on the 5th of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# Configure the device to execute the saveconfig schedule at 8:00 a.m. on the last day of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# Configure the device to execute the saveconfig schedule at 8:00 a.m. every Friday and Saturday.
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
scheduler schedule
transceiver auto-laser-down
Use transceiver auto-laser-down to configure auto laser shutdown.
Use undo transceiver auto-laser-down to restore the default.
transceiver auto-laser-down { enable | disable | uniform-control }
The auto laser shutdown is under unified control.
Ethernet interface view
enable: Enables auto laser shutdown.
disable: Disables auto laser shutdown.
uniform-control: Puts auto laser shutdown under unified control. That is, the enabling status of auto laser shutdown depends on the energy saving mode of the device.
If you put auto laser shutdown under unified control, the enabling status of auto laser shutdown depends on the energy saving mode of the device:
· If the standard energy saving mode is set, auto laser shutdown is disabled.
If you execute this command to enable or disable auto laser shutdown, the enabling status of auto laser shutdown will not change with the energy saving mode of the device.
Only fiber interfaces that are not used for unidirectional communication support this command, and copper interfaces do not support this command.
The fiber interfaces that are connected to high-speed cables or fiber-to-copper transceiver modules do not support this command. If a fiber interface is connected to high-speed cables or fiber-to-copper transceiver modules, the system will clear all commands related with auto laser shutdown on this interface.
After auto laser shutdown is enabled, the transceiver laser on an interface will automatically shut down when the interface goes down. In this case, you need to execute transceiver auto-laser-down restart-mode to specify the laser restart mode to manually or automatically enable the laser to send pulses. If the auto restart mode is specified, the system will send pulses at intervals (100s by default) until the interface for the transceiver module comes up. Then, the laser can operate normally.
Support for this command depends on the card model. If a card inserted into the device does not support this command, you cannot execute this command.
# Enable auto laser shutdown for interface Ten-GigabitEthernet 0/0/15.
[Sysname] interface ten-gigabitethernet 0/0/15
[Sysname-Ten-GigabitEthernet0/0/15] transceiver auto-laser-down enable
display transceiver auto-laser-down
energy-saving mode
Use transceiver auto-laser-down restart to restart the laser of a transceiver module.
Before you execute this command, enable auto laser shutdown and specify the manual laser restart mode.
After the optical fiber recovers from failure, you can execute this command to start up the laser immediately.
# Manually restart the laser of the transceiver module in interface Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] transceiver auto-laser-down restart
Use transceiver auto-laser-down restart-mode to specify the restart mode for the laser of a transceiver module.
Use undo transceiver auto-laser-down restart-mode to restore the default.
transceiver auto-laser-down restart-mode { auto [ pulse-interval interval ] | manual } [ pulse-width width ]
The auto restart mode is specified for the laser of a transceiver module.
auto [ pulse-interval interval ]: Specifies the auto restart mode. In this mode, the laser sends pulses at an interval that is specified by the pulse-interval interval option after the laser restart, in seconds. The value for the interval argument varies by device model.
manual: Specifies the manual restart mode.
pulse-width width: Specifies the pulse width (duration) for optical detection after the laser restart, in seconds. The value for the width argument varies by device model.
Before you execute this command for a transceiver module, enable the auto laser shutdown for the transceiver module.
If the auto restart mode is specified for a laser, the laser sends pulses at an interval specified by the pulse-interval argument to detect whether the link is recovered.
To quickly restore data communication when you can obtain information about the fiber link recovery in time, you can specify the manual restart mode to make the laser emit light immediately. If the manual restart mode is specified, execute the transceiver auto-laser-down restart command for the laser to send a pulse when you need to restart the laser.
# Specify the manual restart mode for the laser of the transceiver module in Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] transceiver auto-laser-down restart-mode manual
# Specify the auto restart mode for the laser of the transceiver module in Ten-GigabitEthernet 0/0/15, the interval for sending pulses as 150s, and pulse width as 3s.
[Sysname-Ten-GigabitEthernet0/0/15] transceiver auto-laser-down restart-mode auto pulse-interval 150 pulse-width 3
transceiver lane cdr
Use transceiver lane cdr to configure CDR on a transmit or receive lane for a QSFP transceiver module.
Use undo transceiver lane cdr to restore the default.
transceiver lane [ lane-number ] cdr { tx | rx } { on | off }
undo transceiver lane [ lane-number ] cdr { tx | rx }
CDR is enabled on a transmit or receive lane on a QSFP transceiver module.
lane-number: Specifies a transceiver lane number, in the range of 1 to 4. If you do not specify a transceiver lane, the command applies to all transceiver lanes.
tx: Specifies the transmit link on the transceiver module.
rx: : Specifies the receive link on the transceiver module.
on: Enables CDR.
off: Disables CDR.
Enabling CDR can reduce the jitter to improve transmission performance, and disabling CDR degrades transmission performance. Both the enable and disable operations might cause oscillation on device ports.
The configuration by this command is saved in a register on the transceiver module. It is not saved to the configuration file.
This command is supported only on the QSFP transceiver modules.
# Enable CDR on the transmit side on the QSFP transceiver module in interface HundredGigE 0/0/27.
[Sysname] interface hundredgige 0/0/27
[Sysname-HundredGigE0/0/27] transceiver lane cdr tx on
This command will engage the internal retiming function of transceiver Tx route. Continue? [Y/N]:Y
# Disable CDR on the receive side on the QSFP transceiver module in interface HundredGigE 0/0/27.
[Sysname-HundredGigE0/0/27] transceiver lane cdr rx off
This command will enable an internal bypassing mode of transceiver Rx route, which directs traffic around the internal CDR. Continue? [Y/N]:Y
display transceiver status
transceiver lane enable
Use transceiver lane enable to enable a lane on a transceiver module.
Use undo transceiver lane to disable a lane on a transceiver module.
transceiver lane [ lane-number ] enable
undo transceiver lane [ lane-number ] enable
All lanes on a transceiver module are enabled.
lane-number: Specifies a lane by its number. If you do not specify a lane, this command enables all lanes on the transceiver module. The value range is fixed at 1 for an SFP transceiver module, 1 to 4 for a QSFP transceiver module, and 1 to 8 for a QSFPDD transceiver module. If you do not specify a lane, this command enables all lanes on the transceiver module.
Execute this command only to verify that a transceiver module operates correctly.
Disabling a lane will stop signal transmission on the lane.
Disabling a lane will stop signal transmission on the fiber port where the lane is located.
This setting is saved in a register on the transceiver module. It is not saved to the configuration file.
This command is supported only on the SFP, QSFP, and QSFPDD transceiver modules.
# Enable lane 1 on the QSFP transceiver module in interface HundredGigE 0/0/27.
[Sysname-HundredGigE0/0/27] transceiver lane 1 enable
transceiver power-mode
Use transceiver power-mode to set the power mode for a transceiver module.
Use undo transceiver power-mode to restore the default.
transceiver power-mode { high | low }
The transceiver module operates in high power mode.
A transceiver module typically operates in high power mode. If a transceiver module will be idle for a long time, you can switch it to low power mode to reduce power consumption. In low power mode, the transceiver module does not transmit signals. For a transceiver module to transmit signals, you must configure it to operate in high power mode.
This command is supported only on QSFP and QSFPDD transceiver modules.
# Configure the QSFP transceiver module in HundredGigE 0/0/27 to operate in high power mode.
[Sysname-HundredGigE0/0/27] transceiver power-mode high
# Configure the QSFP transceiver module in HundredGigE 0/0/27 to operate in low power mode.
[Sysname-HundredGigE0/0/27] transceiver power-mode low
This command will place the transceiver module in low-power-consumption mode, disabling the transceiver module from transmitting data. Continue? [Y/N]:Y
user-role
Use user-role to assign user roles to a schedule.
Use undo user-role to remove user roles from a schedule.
user-role role-name
undo user-role role-name
A schedule has the user roles of the schedule creator.
Schedule view
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Predefined user roles include network-admin, network-operator, and level-0 to level-15.
A schedule must have one or more user roles. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule. For more information about user roles, see the RBAC configuration in Fundamentals Configuration Guide.
A schedule can have a maximum of 64 user roles. After the limit is reached, you cannot assign additional user roles to the schedule.
The security log manager user role is mutually exclusive with other user roles. That is, if the security log manager user role has been assigned, the system will automatically remove the existing other user roles. If the other user roles have been assigned, the system will automatically remove the existing security log manager user role.
# Assign the rolename user role to the test schedule.
<sysname> system-view
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
# Assign the security-audit user role to the test schedule.
[Sysname-schedule-test]user-role security-audit
This operation will delete all other user roles for the schedule. Are you sure? [Y/N]:y
# Change the user role assigned to the test schedule from security-audit to network-admin.
[Sysname-schedule-test]user-role network-admin
This operation will delete security auditor user role for the schedule. Are you sure? [Y/N]:y
command
