14-Network Management and Monitoring Command Reference
HomeSupportRoutersCR16000-M1A SeriesCR16000-M1A SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C CR16000-M1A Router Command Reference-R8630Pxx-6W10214-Network Management and Monitoring Command Reference
15-Sampler commands
15-Sampler commands 53.54 KB
Sampler commands
display sampler
Use display sampler to display configuration information for a sampler.
In standalone mode:
display sampler [ sampler-name ] [ slot slot-number ]
In IRF mode:
display sampler [ sampler-name ] [ chassis chassis-number slot slot-number ]
sampler-name: Specifies a sampler by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a sampler, this command displays configuration information for all samplers.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for the global active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# Display the configuration information about sampler samp1.
<Sysname> display sampler samp1
 Sampler name: samp1
  Mode: fixed;  Packet-interval: 4; IsNpower: Y
Sampler name
Name of the sampler.
Mode
Sampling mode, including fixed mode and random mode.
Packet-interval
Sampling rate.
IsNpower
Whether the sampling rate is 2 to the nth power:
·     Y—Yes.
·     N—No.
sampler
Use sampler to create a sampler.
Use undo sampler to delete a sampler.
sampler sampler-name mode { fixed | random } packet-interval [ n-power ] rate
undo sampler sampler-name
No samplers exist.
fixed: Specifies the fixed sampling mode. A sampler in this mode selects the first packet per sampling.
random: Specifies the random sampling mode. A sampler in this mode randomly selects a packet out of a group of packets. Which packet is selected for each sampling varies.
n-power: Specifies the sampling rate as 2 to the nth power.
rate: Specifies the sampling rate.
·     If the n-power keyword is specified, the sampling rate is 2 to the nth power, where n is value for the rate argument in the range of 0 to 13. For example, if the rate argument is set to 3, one packet is selected from 8 (2 to the 3th power) packets in each sampling.
·     If the n-power keyword is not specified, the sampling rate is the value for the rate argument in the range of 1 to 16320. For example, if the rate argument is set to 100, one packet is selected from 100 packets in each sampling.
(In standalone mode.) (In IRF mode.) This command takes effect on all cards.
# Create sampler abc in fixed sampling mode. Set the sampling rate to 8.
[Sysname] sampler abc mode fixed packet-interval 8
