- 15-BRAS Services Command Reference
- 01-AAA commands
- 02-ANCP commands
- 03-PPP commands
- 04-DHCP commands
- 05-DHCPv6 commands
- 06-User profile commands
- 07-Connection limit commands
- 08-L2TP commands
- 09-PPPoE commands
- 10-IPoE commands
- 11-802.1X commands (Layer 3)
- 12-UCM commands
- 13-Value-added services commands
| 09-PPPoE commands | 630.24 KB |
display pppoe-server chasten configuration
display pppoe-server chasten per-interface
display pppoe-server chasten per-interface configuration
display pppoe-server chasten statistics
display pppoe-server chasten user
display pppoe-server packet statistics
display pppoe-server session summary
display pppoe-server throttled-mac
pppoe-server access-delay odd-even mac offset
pppoe-server access-line-id bas-info
pppoe-server access-line-id circuit-id trans-format
pppoe-server access-line-id content
pppoe-server access-line-id remote-id trans-format
pppoe-server access-line-id trust
pppoe-server access-line-id vxlan-info enable
pppoe-server connection chasten
pppoe-server connection chasten option105
pppoe-server connection chasten per-interface
pppoe-server nas-port-id interface
pppoe-server padi-limit (unified devices)
pppoe-server service-name-tag exact-match
pppoe-server session-limit per-mac
pppoe-server session-limit per-vlan
pppoe-server session-limit total
pppoe-server tag ppp-max-payload
reset pppoe-server chasten per-interface
reset pppoe-server chasten user
reset pppoe-server packet statistics
display pppoe-agency acl statistics
display pppoe-agency packet statistics
display pppoe-agency session summary
pppoe-agency authentication domain
reset pppoe-agency acl statistics
reset pppoe-agency packet statistics
PPPoE commands
PPPoE server commands
Use display pppoe-server chasten configuration to display PPPoE user blocking configuration information.
display pppoe-server chasten configuration [ global | interface interface-type interface-number ]
global: Displays global PPPoE user blocking configuration information.
interface interface-type interface-number: Displays PPPoE user blocking configuration information on an interface specified by its type and number. Make sure the interface has PPPoE user blocking enabled. Otherwise, information is not displayed for the interface.
If you do not specify any parameter, this command displays global PPPoE user blocking configuration information and the PPPoE user blocking configuration information of all interfaces.
# Display PPPoE user blocking configuration information.
<Sysname> display pppoe-server chasten configuration
Global configuration:
Method: MAC Quickoffline: Y
Multi-sessions-permac: Y Requests: 6
Request-period(S): 60 Blocking-period(S): 300
Method: Option105 Quickoffline: N
Interface: XGE0/0/15
Interface: XGE0/0/16
Multi-sessions-permac: N Requests: 10
Request-period(S): 100 Blocking-period(S): 1000
Global configuration |
Global PPPoE user blocking configuration information. |
PPPoE user blocking configuration information on the interface. |
Method |
Detection type of PPPoE user blocking: · MAC—MAC-based PPPoE user blocking. · Option105—Option105-based PPPoE user blocking. |
Quickoffline |
Blocking type: · Y—The users are blocked because the number of times users go offline immediately after coming online reach the limit during the detection period. · N—The users are blocked because the connection requests reach the limit during the detection period. |
Multi-sessions-permac |
When PPPoE users are blocked based on MAC address, whether a single user is permitted to establish multiple PPPoE sessions: · Y—Permitted. · N—Not permitted. |
Requests |
Times of PPPoE connection requests. |
Request-period(S) |
Detection period in seconds. |
Blocking-period(S) |
PPPoE user blocking period in seconds. |
Use display pppoe-server chasten per-interface to display the PPPoE protocol packet attack prevention entries.
In standalone mode:
display pppoe-server chasten per-interface [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
display pppoe-server chasten per-interface [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the PPPoE protocol packet attack prevention entries of all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
If you do not specify any parameter, this command displays the PPPoE protocol packet attack prevention entries of all interfaces.
# (In IRF mode.) Display the PPPoE protocol packet attack prevention entries of all interfaces.
<Sysname> display pppoe-server chasten per-interface
Slot 0:
Interface Lifetime(S) Agetime(S) DrvStatus Drops
XGE0/0/15 1200 2000 Active 3000
XGE0/0/16 1000 1500 Inactive 0
Interface name. |
Lifetime(S) |
Lifetime of the attack prevention entry, in seconds. |
Agetime(S) |
Aging time of the attack prevention entry, in seconds. After the timer times out, rate-limiting on PPPoE protocol packets received on the interface is canceled. |
DrvStatus |
Status of issuing the attack prevention entry to the driver: · Active—The entry is successfully issued to the driver. Only entries in this state take effect. · Inactive—The entry failed to be issued to the driver, or the entry is not issued to the driver because the device does not support this entry. |
Drops |
Number of PPPoE protocol packets dropped on the interface. |
Use display pppoe-server chasten per-interface configuration to display the PPPoE protocol packet attack prevention configuration information.
display pppoe-server chasten per-interface configuration [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the PPPoE protocol packet attack prevention configuration information of all interfaces.
#Display the PPPoE protocol packet attack prevention configuration information of al interfaces.
<Sysname> display pppoe-server chasten per-interface configuration
Interface Number Interval(S) Rate-limit-period(S)
XGE0/0/15 6 60 300
XGE0/0/16 10 100 1000
Interface name. |
Number |
Number of PPPoE protocol packets received. |
Interval(S) |
Detection interval of the PPPoE protocol packet attack prevention feature, in seconds. |
Rate-limit-period(S) |
Period for which the PPPoE protocol packets are rate-limited, in seconds. |
Use display pppoe-server chasten user to display statistics about PPPoE user blocking.
In standalone mode:
display pppoe-server chasten statistics [ mac-address | option105 ] [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
display pppoe-server chasten statistics [ mac-address | option105 ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
mac-address: Specifies MAC-based user blocking information.
option105: Specifies option105-based user blocking information.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays PPPoE user blocking statistics for all interfaces.
If you do not specify any keywords, the command displays all PPPoE user blocking statistics. For a blocked PPPoE user, this command displays the blocking entries generated for the user on all slots. For how blocking entries are generated, see the pppoe-server connection chasten command and the pppoe-server connection chasten option105 command.
#Display PPPoE user blocking statistics on Ten-GigabitEthernet 0/0/15.
<Sysname> display pppoe-server chasten statistics interface ten-gigabitethernet 0/0/15
Statistics of users possibly to be blocked:
Non-quickoffline by MAC : 0
Quickoffline by MAC : 0
Non-quickoffline by Option105 : 0
Quickoffline by Option105 : 0
Statistics of users blocked:
Quickoffline by MAC : 1
Statistics of users possibly to be blocked |
Statistics of PPPoE users who might be blocked (the blocking feature has detected these users but the blocking conditions have not been met). |
Non-quickoffline by MAC |
Number of MAC-based users blocked because the PPP connection requests reach the limit during the detection period. |
Quickoffline by MAC |
Number of MAC-based users blocked because the number of times users go offline immediately after coming online reach the limit during the detection period. |
Non-quickoffline by Option105 |
Number of option105-based users blocked because the connection requests reach the limit during the detection period. |
Quickoffline by Option105 |
Number of option105-based users blocked because the number of times users go offline immediately after coming online reach the limit during the detection period. |
Use display pppoe-server chasten user to display information about blocked PPPoE users.
In standalone mode:
display pppoe-server chasten user [ mac-address [ mac-address ] | option105 [ circuit-id circuit-id ] [ remote-id remote-id ] ] [ interface interface-type interface-number ] [ slot slot-number ] [ verbose ]
In IRF mode:
display pppoe-server chasten user [ mac-address [ mac-address ] | option105 [ circuit-id circuit-id ] [ remote-id remote-id ] ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ] [ verbose ]
mac-address: Specifies the MAC-based blocked PPPoE users..
mac-address: Specifies a user's MAC address in the format of H-H-H. If you specify the mac-address keyword but do not specify this argument, the command displays information about all MAC-based blocked PPPoE users.
option105: Specifies option105-based blocked PPPoE users.
circuit-id circuit-id: Specifies fuzzy matching of a circuit ID, a case-sensitive string of 1 to 127 characters. For example, if the circuit-id argument is abc, information about users whose circuit IDs contain abc will be displayed.
remote-id remote-id: Specifies fuzzy matching of a remote ID, a case-sensitive string of 1 to 127 characters. For example, if the remote-id argument is abc, information about users whose remote IDs contain abc will be displayed.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays information about blocked PPPoE users on all interfaces.
verbose: Displays detailed information about blocked PPPoE users.
If you do not specify any keywords, the command displays brief information about all blocked PPPoE users.
# (In standalone mode.) Display brief information about all blocked PPPoE users.
<Sysname> display pppoe-server chasten user slot 0
Slot 0:
Type: N-non-Quickoffline Q-Quickoffline
MAC/Option105 VLAN ID Interface Aging(S) Type Drops
0001-0001-0001 N/A XGE0/0/15 89 N 1000
circuitid:123 N/A XGE0/0/15 10 Q 1000
remoteid:abcde
# (In standalone mode.) Display detailed information about all blocked PPPoE users.
<Sysname> display pppoe-server chasten user interface ten-gigabitethernet 0/0/15 verbose
Slot 0:
MAC address: 0001-0001-0001
VLAN ID: N/A
Aging(S): 89
Type: Non-Quickoffline
Drops: 1000
Lifetime(S): 1000
DrvStatus: Active
Option105: (circuitid:123 remoteid:abcde)
Vlan ID: N/A
Aging(S): 10
Type: Quickoffline
Drops: 1000
Lifetime(S): 1000
DrvStatus: Inactive
Table 5 Command output
MAC/Option105 |
MAC-based or option105-based blocked PPPoE users: · For a MAC-based user, the MAC address is displayed. · For an option105-based user, the circuit ID and remote ID are displayed. |
VLAN ID |
VLAN to which a blocked user belongs. This field displays only the outermost VLAN information if the user has multiple VLAN tags. This field displays N/A for a user that does not have VLAN information, for example, an option105-based user. |
Access interface for a blocked user. |
Aging(S) |
this field indicates the remaining blocking time for a blocked user. When the timer times out, the user is unblocked. On devices in data plane mode, this field is insignificant and displays 0. |
Type |
Blocking type: · N (or Non-Quickoffline)—Non-quickoffline users, the users that are blocked because the connection requests reach the limit during the detection period. · Q (or Quickoffline)—Quickoffline users, the users that are blocked because the number of times users go offline immediately after coming online reach the limit during the detection period. |
Drops |
Number of PPPoE protocol packets that have been dropped for a blocked user. |
Lifetime(S) |
DrvStatus |
Status of issuing the attack prevention entry to the driver: · Active—The entry is successfully issued to the driver. Only entries in this state take effect. · Inactive—The entry is not issued to the driver or the entry fails to be issued to the driver. |
Use display pppoe-server packet statistics to display PPPoE server negotiation packet statistics.
In standalone mode:
display pppoe-server packet statistics [ slot slot-number ]
In IRF mode:
display pppoe-server packet statistics [ chassis chassis-number slot slot-number ]
# (In standalone mode.) Display PPPoE server negotiation packet statistics for the specified slot.
<Sysname> display pppoe-server packet statistics slot 0
PPPoE server packet statistics in slot 0:
RECV_PADI_PKT : 10 DISCARD_PADI_PKT : 0
SEND_PADO_PKT : 10
RECV_PADR_PKT : 10 DISCARD_PADR_PKT : 0
SEND_PADS_PKT : 10
RECV_PADT_PKT : 9 DISCARD_PADT_PKT : 0
SEND_PADT_PKT : 9
Table 6 Command output
RECV_PADI_PKT |
Number of received PADI packets. |
DISCARD_PADI_PKT |
Number of discarded PADI packets. |
SEND_PADO_PKT |
Number of sent PADO packets. |
RECV_PADR_PKT |
Number of received PADR packets. |
DISCARD_PADR_PKT |
Number of discarded PADR packets. |
SEND_PADS_PKT |
Number of sent PADS packets. |
RECV_PADT_PKT |
Number of received PADT packets. |
DISCARD_PADT_PKT |
Number of discarded PADT packets. |
SEND_PADT_PKT |
Number of sent PADT packets. |
pppoe-server block
Use display pppoe-server session summary to display summary PPPoE session information.
In standalone mode:
display pppoe-server session summary [ [ interface interface-type interface-number | slot slot-number ] | mac-address mac-address ] *
In IRF mode:
display pppoe-server session summary [ [ interface interface-type interface-number | chassis chassis-number slot slot-number ] | mac-address mac-address ] *
slot slot-number: Specifies a card by its slot number. On this device, the slot-number argument represents the entire device and its value is fixed. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. (In IRF mode.)
mac-address mac-address: Specifies a PPPoE user by its MAC address in the format of H-H-H.
Summary PPPoE session information on a physical interface can be displayed only on the card where the interface resides. Summary PPPoE session information on a logical interface can be displayed on all cards.
#Display summary PPPoE session information on Ten-GigabitEthernet 0/0/15.
<Sysname> display pppoe-server session summary interface ten-gigabitethernet 0/0/15
Total PPPoE sessions: 2
Ethernet interface: XGE0/0/15 Session ID: 1
PPP index: 0x140000105 State: PADR_RCVD
Remote MAC: 00e0-1500-7100 Local MAC: 00e0-1400-7300
Service VLAN: N/A Customer VLAN: N/A
Ethernet interface: XGE0/0/15 Session ID: 2
PPP index: 0x150000105 State: OPEN
Remote MAC:00e0-1600-7200 Local MAC: 00e0-1400-7300
# (In standalone mode.) Display summary PPPoE session information on the MPU in the specified slot.
<Sysname> display pppoe-server session summary slot 0
Total PPPoE sessions on slot 0: 2
Local PPPoE sessions on slot 0: 1
Ethernet interface: XGE0/0/16 Session ID: 1
PPP index: 0x140000105 State: OPEN
Remote MAC: 0000-0000-0005 Local MAC: 0000-5e00-0101
Ethernet interface: RAGG1 Session ID: 2
Remote MAC: 0050-56c0-0005 Local MAC: 0000-5e00-0102
Table 7 Command output
Total PPPoE sessions |
Total number of PPPoE sessions. When a slot is specified in this command, this field displays the total number of PPPoE sessions coming online through physical interfaces in the slot and all global PPPoE sessions in the system. |
Local PPPoE sessions |
Total number of PPPoE sessions. · The PPPoE sessions coming online through a physical interface are counted on the slot of the physical interface. · (In standalone mode.) The PPPoE sessions coming online through a global interface are counted on the slot of the active MPU. · (In IRF mode.) The PPPoE sessions coming online through a global interface are counted on the slot of the global active MPU. When an interface is specified, this field is not displayed. |
Ethernet interface |
Interface where the PPPoE session is present. |
Session ID |
PPPoE session ID. |
PPP index |
Index of the PPP session. |
PPP interface |
Virtual access interface created for the PPPoE session. |
State |
PPPoE session state: · PADR RCVD—The PPPoE session is being negotiated. · Open—The PPPoE session has been successfully established. · OFFLINE—The PPPoE session is being deleted. · BACKUP—The PPPoE session on the backup VSRP peer is to be activated. |
RemoteMAC |
MAC address of the remote end. |
LocalMAC |
MAC address of the local end. |
Service VLAN |
Service provider VLAN. N/A means no service provider VLAN is available. |
Customer VLAN |
Customer VLAN. N/A means no customer VLAN is available. |
reset pppoe-server
Use display pppoe-server throttled-mac to display information about blocked users.
In standalone mode:
display pppoe-server throttled-mac { slot slot-number | interface interface-type interface-number }
In IRF mode:
display pppoe-server throttled-mac { chassis chassis-number slot slot-number | interface interface-type interface-number }
#Display information about blocked users on Ten-GigabitEthernet 0/0/15.
<Sysname> display pppoe-server throttled-mac interface ten-gigabitethernet 0/0/15
Total 3 client MACs:
Interface Remote MAC Start time Remaining time(s)
XGE0/0/15 00e0-1500-4100 2019-12-01,12:10:30 55
XGE0/0/15 00e0-1500-4000 2019-12-01,12:10:40 65
XGE0/0/15 00e0-1500-3300 2019-12-01,12:10:50 75
Table 8 Command output
Interface at which the user is blocked. |
Remote MAC |
MAC address of the user. |
Start time |
Time to start blocking users. |
Remaining time(s) |
Time left for blocking users, in seconds. |
Use pppoe-server access-delay to set the response delay time for PPPoE users on an interface.
Use undo pppoe-server access-delay to restore the default.
pppoe-server access-delay delay-time [ even-mac | odd-mac ]
undo pppoe-server access-delay [ even-mac | odd-mac ]
No response delay time is set for PPPoE users on an interface.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
L3VE interface/subinterface view
delay-time: Specifies the response delay time for PPPoE users, in the range of 10 to 25500 milliseconds.
even-mac: Specifies users with even MAC addresses.
odd-mac: Specifies users with odd MAC addresses.
Application scenarios
This feature is suitable for administrators to deploy multiple BRAS devices in the network, and distribute user loads and backups among these devices based on odd/even MAC addresses.
As shown in Figure 1, to provide device-level backup and traffic load balancing, two BRAS devices are deployed in the network, with the following configurations:
· Configure BRAS A to delay responses for users with even MAC addresses, and maintain the default setting (no response delay) for users with odd MAC addresses.
· Configure BRAS B to delay responses for users with odd MAC addresses, and maintain the default setting (no response delay) for users with even MAC addresses.
In this case, under normal circumstances, BRAS A responds to the online requests of users with odd MAC addresses before BRAS B, so users with odd MAC addresses prefer to come online through BRAS A. Similarly, BRAS B responds to the online requests of users with even MAC addresses before BRAS A, so users with even MAC addresses prefer to come online through BRAS B. This achieves load balancing of user traffic between BRAS A and BRAS B.
Figure 1 Response delay time functionality (both BRAS devices operate correctly)
As shown in Figure 2, when a BRAS device (assuming BRAS A) malfunctions, BRAS B provides access services for all users, thus achieving device-level backup.
· For users with odd MAC addresses who have not come online before the failure of BRAS A, these users can directly come online through BRAS B.
· For users with odd MAC addresses who have come online before the failure of BRAS A, these users must disconnect first before they can come online through BRAS B.
Figure 2 Response delay time functionality (one BRAS device fails)
Operating mechanism
With the response delay time set for PPPoE user access, the system delays responses to the online requests of PPPoE users according to the configured time. You can set different response delay times for users with odd and even MAC addresses respectively.
· In this scenario, you must configure address isolation between BRAS devices. Public address pools, private address pools, and NAS-IP addresses must be uniquely configured on each BRAS device and cannot be cross-utilized. If you cannot do that, route issues might occur. For example, if NAS-IP address 1.1.1.1 is configured on one BRAS device, then you cannot configure the NAS-IP address on another BRAS device as 1.1.1.1.
· You can use this feature in conjunction with the pppoe-server access-delay odd-even mac offset command to flexibly deploy access response delay strategies for odd and even MAC users based on MAC address offsets. For more information, see the pppoe-server access-delay odd-even mac offset command.
· This feature takes effect only for PPPoE users that attempt to come online afterward and has no impact on currently online PPPoE users.
#Set the response delay time for PPPoE users to 10000 milliseconds on Ten-GigabitEthernet 0/0/15.
[Sysname] interface ten-gigabitethernet 0/0/15
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server access-delay 10000
Use pppoe-server access-delay odd-even mac offset to specify the MAC address offset for response delay of PPPoE user access.
Use undo pppoe-server access-delay odd-even mac offset to restore the default.
pppoe-server access-delay odd-even mac offset offset-value
No offset is specified for matching the MAC addresses of PPPoE users. The parity of the MAC address is determined by the lowest bit of the MAC address (using the left-high and right-low principle).
offset-value: Specifies the user MAC address offset in the range of 1 to 47 bits.
The parity bit is used by the BRAS device to determine the parity of a user's MAC address. In this context, the bit value of 0 indicates an even MAC address, while a value of 1 indicates an odd MAC address.
By default, the device only selects the lowest bit of a user's MAC address as the parity bit to determine the parity of the MAC address. It then uses the delay time configured by the pppoe-server access-delay command to delay the response to the user's online requests based on the parity of the MAC address.
To flexibly specify a certain bit in a user's MAC address as the basis for determining the parity of the address, you can specify the offset.
Operating mechanism
With the MAC address offset specified, when the device receives a PPPoE user's online request, it uses the principle of offsetting from the low bit to the high bit. The (offset-value+1)th bit of the user's MAC address is as the offset parity bit to determine whether the user's MAC address is odd or even. Then, based on the delay time for odd or even MAC addresses, the device delays the response to the user's online request.
For example, as shown in Figure 3, for a PPPoE user with MAC address 0012-3400-ABCD, the parity bit value for this MAC address is 1 by default, indicating an odd MAC address. If you set the offset value to 17 bits, the parity bit (starting from the default parity bit, the 17+1=18th bit) value for this user's MAC address becomes 0, indicating an even MAC address.
Figure 3 MAC address offset calculation
· This feature must be used together with the pppoe-server access-delay command. If pppoe-server access-delay is not configured, the device responds to the access requests of PPPoE users immediately regardless of the configured MAC address offset value.
#Configure response delay for PPPoE users with odd MAC addresses, set the delay time to 10000 milliseconds, and set the MAC address offset to 17 bits.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server access-delay 10000 odd-mac
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server access-delay odd-even mac offset 17
Use pppoe-server access-line-id bas-info to configure the NAS-Port-ID attribute to automatically include BAS information on an interface.
Use undo pppoe-server access-line-id bas-info to restore the default.
pppoe-server access-line-id bas-info [ cn-163 | cn-163-redback ]
The NAS-Port-ID attribute does not automatically include BAS information on an interface.
cn-163: Specifies the China-Telecom 163 format for the BAS information.
cn-163-redback: Specifies the China-Telecom 163 Redback format for the BAS information.
Operating mechanism
The BAS information formats include the following formats:
· China-Telecom format—The China-Telecom format is {eth|trunk|atm} NAS_slot/NAS_subslot/NAS_port:XPI.XCI. The format refers to the user access interface information on the BRAS, including upstream interface, VLAN, and VPI/VCI information:
¡ When Ethernet/DSL is used, XPI.XCI refers to VLAN information.
¡ When ATM/DSL is used, XPI.XCI refers to VPI/VCI information.
For example, eth 3/1/1:4096.2345 includes the following user access interface information:
¡ The type of the upstream interface is Ethernet interface.
¡ The interface is located at slot 3, subslot 1, and port 1 .
¡ The outer VLAN ID is 4096 (which means an invalid VLAN), and the inner VLAN ID is 2345.
The device uses three-dimensional interfaces to communicate with servers by default. On an IRF fabric, when you need to specify the access IRF member device of a user on the AAA server, use the access-user four-dimension-mode enable command to configure the device to use four-dimensional interfaces to communicate with AAA servers. In this case, the BAS information in China Telecom format is {eth|trunk|atm} NAS_chassis/NAS_slot/NAS_subslot/NAS_port:XPI.XCI.
· China-Telecom 163 format—Table 9 shows the China-Telecom 163 format, where:
¡ NAS_slot, NAS_subslot, and NAS_port refer to the numbering information of the PPPoE user access interface on the BRAS.
¡ vpi and vci refer to VPI and VCI information.
¡ vlanid and vlanid2 refer to inner VLAN and outer VLAN, respectively. Value for the vlanid of the primary interface is fixed at 0.
The device uses three-dimensional interfaces to communicate with servers by default. On an IRF fabric, when you need to specify the access IRF member device of a user on the AAA server, use the access-user four-dimension-mode enable command to configure the device to use four-dimensional interfaces to communicate with AAA servers. For example, for a main interface on an IRF fabric, the BAS information is China Telecom 163 format is: chassis=NAS_chassis;slot=NAS_slot;subslot=NAS_subslot;port=NAS_port;vlanid=VLAN id.
Table 9 BAS information in China-Telecom 163 format
Interface type |
Format |
ATM interface |
slot=NAS_slot;subslot=NAS_subslot;port=NAS_port;vpi=XPI;vci=XCI; |
Primary interface or interface that does not carry inner VLAN or outer VLAN information. |
slot=NAS_slot;subslot=NAS_subslot;port=NAS_port;vlanid=VLAN id; |
Interface that carries inner VLAN and outer VLAN information. |
slot=NAS_slot;subslot=NAS_subslot;port=NAS_port;vlanid=VLAN id;vlanid2=VLAN id2; |
· China-Telecom 163 Redback format—The China-Telecom 163 Redback format is the same as the China-Telecom 163 format except in the VLAN information. In the China-Telecom 163 Redback format, the vlanid and vlanid2 fields refer to outer VLAN and inner VLAN, respectively. In the other sections, both BAS information in the China-Telecom 163 format and BAS information in the China-Telecom 163 Redback format are described in the China-Telecom 163 format as an example.
This command specifies whether to automatically insert BAS information into the NAS-Port-ID attribute:
· If you disable the function of automatically inserting BAS information, for information about the content in the NAS-Port-ID attribute that the BRAS sends to the RADIUS server, see the pppoe-server access-line-id content command.
· If you enable the function of automatically inserting BAS information and execute the pppoe-server access-line-id trust command, the contents are generated as follows for the NAS-Port-ID attribute that the BRAS sends to the RADIUS server:
¡ If BAS information in China Telecom 163 format is inserted, the BAS information is inserted before the circuit-id field. The BAS information+circuit-id combination is sent to the RADIUS server as the NAS-Port-ID attribute.
¡ If BAS information in China Telecom format is inserted, the BAS information and the user access information on the DSLAM in the original circuit-id information are used to construct the circuit-id in China Telecom format. The circuit-id in China Telecom format is sent to the RADIUS server as the NAS-Port-ID attribute.
· If you enable the function of automatically inserting BAS information but do not execute the pppoe-server access-line-id trust command, the device does not copies the circuit-id or remote-id in packets to the NAS-Port-ID attribute. In this case, the NAS-Port-ID attribute sent to the RADIUS server contains only the BAS information as follows:
¡ If BAS information in China Telecom 163 format is inserted, the BAS information in China Telecom 163 format is sent to the RADIUS server as the NAS-Port-ID attribute.
¡ If BAS information in China Telecom format is inserted, the BAS information in China Telecom format is sent to the RADIUS server as the NAS-Port-ID attribute.
This feature involves the use of the access-user four-dimension-mode enable command. Before using this feature, see BRAS Services Command Reference for detailed guidelines on how to use the access-user four-dimension-mode enable command.
If you do not specify any keyword, BAS information in the China-Telecom format is included.
The RADIUS server cannot correctly parse a NAS-Port-ID attribute that includes the remote-id and BAS information. When you execute this command together with the pppoe-server access-line-id trust command, make sure the NAS-Port-ID attribute sent to the RADIUS sever does not include the remote-id.
#Configure the NAS-Port-ID attribute to automatically include BAS information on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server access-line-id bas-info
access-user four-dimension-mode enable (BRAS Services Command Reference)
Use pppoe-server access-line-id circuit-id trans-format to configure the transmission format for the circuit-id in access line ID on an interface.
Use undo pppoe-server access-line-id circuit-id trans-format to restore the default.
pppoe-server access-line-id circuit-id trans-format { ascii | hex }
The transmission format for the circuit-id in access line ID is a string of characters on an interface.
ascii: Specifies the character string format. For example, the circuit-id 00010002 is transmitted in the form of 01 08 30 30 30 31 30 30 30 32.
hex: Specifies the hexadecimal format. For example, the circuit-id 00010002 is transmitted in the form of 01 04 00 01 00 02.
#Configure Ten-GigabitEthernet 0/0/15 to use the hexadecimal format to transmit the circuit-id.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server access-line-id circuit-id trans-format hex
Use pppoe-server access-line-id content to configure the content of the NAS-Port-ID attribute delivered to the RADIUS server on an interface.
Use undo pppoe-server access-line-id content to restore the default.
pppoe-server access-line-id content { all [ separator ] | circuit-id | remote-id }
The NAS-Port-ID attribute contains only the circuit-id on an interface.
all: Sends both the circuit-id and remote-id.
separator: Specifies a separator that is one character long. By default, the value is a blank space. The circuit-id and remote-id are connected by the separator.
circuit-id: Sends only the circuit-id.
remote-id: Sends only the remote-id.
Operating mechanism
The PPPoE server on a BRAS uses the RADIUS NAS-Port-ID attribute to send the access line ID received from a DSLAM device to the RADIUS server. The access line ID contains the circuit-id and remote-id. The RADIUS server compares the received NAS-Port-ID attribute with the local line ID information to verify the location of the user.
For more information about the circuit-id, see the pppoe-server access-line-id circuit-id parse-mode command.
For more information about the remote-id, see pppoe-server access-line-id remote-id trans-format the command.
Do not use a character that exists in the circuit-id or remote-id as the separator. Otherwise, the RADIUS server might fail to parse the ID information.
This command takes effect only when the pppoe-server access-line-id trust command is executed.
When the pppoe-server access-line-id bas-info command is not executed, the following rules apply:
· If the pppoe-server access-line-id trust command is executed, the following rules apply:
¡ If the circuit-id or remote-id configured in the pppoe-server access-line-id content command is effective (non-null), the specified circuit-id or remote-id is sent to the RADIUS server as the NAS-Port-ID attribute. The exception is that, when the nas logic-port command is also executed in a UP backup network, the NAS-PORT-ID attribute sent to the RADIUS server contains BAS information in China Telecom 163 format plus the circuit-id or remote-id configured by using the pppoe-server access-line-id content command.
¡ If the circuit-id or remote-id configured in the pppoe-server access-line-id content command is null, the BAS information in China Telecom 163 format is sent to the RADIUS server as the NAS-Port-ID attribute. For more information, see the pppoe-server access-line-id bas-info command.
· If the pppoe-server access-line-id trust command is not executed, the BAS information in China Telecom 163 format is sent to the RADIUS server as the NAS-Port-ID attribute. For more information, see the pppoe-server access-line-id bas-info command.
If the pppoe-server access-line-id bas-info command is executed, this command determines the content of the NAS-Port-ID attribute.
#Configure Ten-GigabitEthernet 0/0/15 to deliver only the circuit-id to the RADIUS server.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server access-line-id content circuit-id
Use pppoe-server access-line-id remote-id trans-format to configure the transmission format for the remote-id in the access line ID on an interface.
Use undo pppoe-server access-line-id remote-id trans-format to restore the default.
pppoe-server access-line-id remote-id trans-format { ascii | hex }
The transmission format for the remote-id is a string of characters on an interface.
The remote-id is the system MAC address of a PPPoE relay device (for example, DSLAM). It can be transmitted in character strings or hexadecimal format.
#Configure Ten-GigabitEthernet 0/0/15 to use the hexadecimal format to transmit the remote-id.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server access-line-id remote-id trans-format hex
Use pppoe-server access-line-id trust to configure the PPPoE server to trust the access line ID in received packets on an interface.
Use undo pppoe-server access-line-id trust to restore the default.
The PPPoE server does not trust the access line ID in received packets on an interface.
This command enables the PPPoE server to copy the circuit-id and remote-id in a received packet, to the NAS-PORT-ID attribute.
If this command is not executed, the PPPoE server does not copy the circuit-id and remote-id in a received packet to the NAS-PORT-ID attribute.
#Configure Ten-GigabitEthernet 0/0/15 to trust the access line ID in received packets.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server access-line-id trust
Use pppoe-server access-line-id vxlan-info enable to insert the VXLAN information in the NAS-Port-ID attribute.
Use undo pppoe-server access-line-id vxlan-info enable to restore the default.
The VXLAN information is not inserted into the NAS-Port-ID attribute.
The VXLAN information is inserted into the following fields in the NAS-Port-ID attribute:
· BAS information is China Telecom format.
· DSLAM uplink interface information in the circuit ID in China Telecom format.
The two fields above are in the same format. For more information, see the pppoe-server access-line-id bas-info command.
For example, if the information is ge 3/1/1:4075.2345 before the VXLAN information is inserted, the information is ge 3/1/1: 4294967295.4075.2345 after the VXLAN information is inserted. The newly added 4294967295 is a VXLAN ID. 4294967295 indicates an invalid VXLAN.
#Insert the VXLAN information into the NAS-Port-ID attribute on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server access-line-id vxlan-info enable
pppoe-server bind
Use pppoe-server bind to enable the PPPoE server on an interface and bind the interface to a VT interface.
Use undo pppoe-server bind to disable the PPPoE server on an interface.
pppoe-server bind virtual-template number
The PPPoE server is disabled on an interface.
virtual template number: Specifies a VT interface by its number. The value range for the number argument is 0 to 1023.
A PPPoE server-enabled interface must be bound to an existing VT interface.
When online PPPoE users exist on an interface, you cannot directly use the undo pppoe-server bind command to disable the PPPoE server on the interface. To do that, first log out all online PPPoE users on the interface, and then execute the undo pppoe-server bind command.
If the interface has been bound to a VT interface, you cannot use this command to bind the interface to another VT interface. To do that, disable the PPPoE server on the interface first.
On an interface, the pppoe-server bind command and the pppoe-agency bind command are mutually exclusive.
#Enable the PPPoE server on Ten-GigabitEthernet 0/0/15 and bind the interface to interface Virtual-Template 1.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server bind virtual-template 1
pppoe-server block
Use pppoe-server block to forbid PPPoE users on an interface from coming online.
Use undo pppoe-server block to restore the default.
pppoe-server block
PPPoE users on an interface are permitted to come online.
Operating mechanism
With this command executed on an interface, the interface directly drops received PADI and PADR packets to forbid users from coming online through this interface.
This command does not affect existing PPPoE users.
#Forbid PPPoE users on Ten-GigabitEthernet 0/0/15 from coming online.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server block
Use pppoe-server connection chasten to enable MAC-based user blocking.
Use undo pppoe-server connection chasten to disable MAC-based user blocking.
pppoe-server connection chasten [ quickoffline ] [ multi-sessions-permac ] requests request-period blocking-period
undo pppoe-server connection chasten [ quickoffline ]
In interface view, MAC-based user blocking is disabled.
In system view, a MAC-based PPPoE user will be blocked for 300 seconds if the user fails authentication consecutively for 120 times within 60 seconds.
quickoffline: Specifies the users that go offline immediately after coming online. If you specify this keyword, users that go offline immediately after coming online for requests times within request-period seconds will be blocked for blocking-period seconds. If you do not specify this keyword, users that send PPPoE requests for requests times within request-period seconds will be blocked for blocking-period seconds.
multi-sessions-permac: Specifies a user that establishes multiple PPPoE sessions. You must specify this keyword if multiple sessions exist on a MAC address.
requests: Specifies the number of PPPoE connection requests, in the range of 1 to 10000.
request-period: Specifies the detection period in the range of 1 to 3600 seconds.
blocking-period: Specifies the blocking period in the range of 0 to 3600 seconds. The value of 0 means that users will not be blocked even when they meet the blocking conditions.
Operating mechanism
If you execute this command, the device uniquely identifies a blocked user by using its MAC address, the outermost VLAN ID, and the access interface.
In the unified scenario, when the blocking conditions are met, blocking entries are generated only for the slots hosting interfaces actually receiving packets. For example, when a user accessing a Layer 3 aggregate interface meets the blocking conditions, the blocking entries are generated only on the slots hosting member ports of the Layer 3 aggregate interface.
The following commands can be configured on the same interface or subinterface:
· pppoe-server connection chasten quickoffline [ multi-sessions-permac ] requests request-period blocking-period
· pppoe-server connection chasten [ multi-sessions-permac ] requests request-period blocking-period
The pppoe-server connection chasten quickoffline [ multi-sessions-permac ] requests request-period blocking-period command will override existing configuration of the following commands:
· pppoe-server connection chasten option105 quickoffline requests request-period blocking-period
The pppoe-server connection chasten [ multi-sessions-permac ] requests request-period blocking-period command will override existing configuration of the following commands:
· pppoe-server connection chasten option105 requests request-period blocking-period
If you execute this command in system view, the command applies to all PPPoE users. If you execute this command in interface view, the command applies to PPPoE users accessing the interface. If you execute this command in both system view and interface view, a user is blocked in the view whose blocking conditions are met first.
The modified configuration in this command takes effect only on newly blocked users and does not affect existing blocked users. For example, if you modify the blocking period before it expires, the remaining blocking time is still based on the previously configured blocking period.
# Configure the device to block a user for 1000 seconds by its MAC address if the user sends 100 PPPoE connection requests within 500 seconds.
[Sysname] pppoe-server connection chasten 100 500 1000
Use pppoe-server connection chasten option105 to enable option105-based user blocking.
Use undo pppoe-server connection chasten option105 to disable option105-based user blocking.
pppoe-server connection chasten option105 [ quickoffline ] requests request-period blocking-period
undo pppoe-server connection chasten option105 [ quickoffline ]
Option105-based user blocking is disabled.
quickoffline: Specifies the users that come online. If you specify this keyword, users that come online for requests times within request-period seconds will be blocked for blocking-period seconds. If you do not specify this keyword, users that send PPPoE connection requests for requests times within request-period seconds will be blocked for blocking-period seconds.
Operating mechanism
If you execute this command, the device uniquely identifies a blocked user by using its circuit ID, remote ID, and the access interface.
The pppoe-server connection chasten option105 quickoffline requests request-period blocking-period command will override existing configuration of the following commands:
The pppoe-server connection chasten option105 requests request-period blocking-period command will override existing configuration of the following commands:
# Configure the device to block a user for 1000 seconds by its option105 if the user sends 100 PPPoE connection requests within 500 seconds.
[Sysname] pppoe-server connection chasten option105 100 500 1000
Use pppoe-server connection chasten per-interface to enable PPPoE protocol packet attack prevention.
Use undo pppoe-server connection chasten per-interface to disable PPPoE protocol packet attack prevention.
pppoe-server connection chasten per-interface number interval rate-limit-period
PPPoE protocol packet attack prevention is disabled.
number: Specifies the number of PPPoE protocol packets received, in the range of 1 to 10000.
interval: Specifies the detection interval of the PPPoE protocol packet attack prevention feature, in the range of 1 to 3600 seconds.
rate-limit-period: Specifies the period for which the PPPoE protocol packets are rate-limited, in the range of 0 to 3600 seconds. The value of 0 means that users are not rate-limited even when the conditions are met.
In the Discovery phase of the PPPoE link establishment process, the PPPoE client sends PADI or PADR packets to find the PPPoE server that can provide the access service. After the PPPoE session is established, the PPPoE client can send PADT packets at any time to terminate the PPPoE session.
To prevent a large number of users frequently coming online and going offline or illegal users from initiating protocol packet attacks, which will occupy a large number of system resources, you can configure the PPPoE protocol packet attack prevention feature.
Operating mechanism
With this feature configured, if the number of protocol packets that the PPPoE server receives within the detection interval exceeds the specified number, the PPPoE protocol packets received from the interface will be rate-limited. During the rate-limiting period, the excess PPPoE protocol packets are dropped. At the same time, the device still performs attack prevention detection for the interface within the rate-limiting period. If the number of PPPoE protocol packets dropped meets the formula (number of dropped packets × interval ≥ number ×rate-limit-period) before the rate-limiting period expires, one more rate-limiting period is added. After the rate-limiting period expires, the rate-limiting on the PPPoE protocol packets received from the interface is cancelled.
You can execute this command in system view and in interface view. The configuration in system view takes effect on all interfaces, and the configuration in interface view takes effect only on the current interface. If this command is executed in both system view and interface view, the command in interface view takes priority.
If the configured rate-limit period is modified before it expires, the remaining rate-limit time for rate-limited users is the newly configured rate-limit period no matter whether other parameters are modified. For example, if the previously configured rate-limit period is 3000 seconds and it is modified as 2500 seconds when the remaining rate-limit time is 2000 seconds, rate-limited users will continue to be rate limited for 2500 seconds.
#Configure PPPoE protocol attack prevention on Ten-GigabitEthernet 0/0/15. When the number of PPPoE protocol packets received from the interface exceeds 1000 within 60 seconds, the packets received from the interface will be rate-limited for 300 seconds.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server connection chasten per-interface 1000 60 300
pppoe-server log enable
Use pppoe-server log enable to enable the PPPoE logging feature.
Use undo pppoe-server log enable to disable the PPPoE logging feature.
The PPPoE logging feature is disabled.
You can enable the PPPoE logging feature to meet the security audit (for example, source tracing) requirements. The PPPoE logging feature enables the device to generate PPPoE logs and send them to the information center. Logs are generated when the following requirements are met:
· The number of PPPoE sessions reaches the upper limit for an interface, user, VLAN, or the system.
· New users request to come online.
Operating mechanism
A log entry records the interface-based, MAC-based, VLAN-based, or system-based session limit. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
Recommended configuration
As a best practice, disable this feature to prevent excessive PPPoE log output.
# Enable the PPPoE logging feature.
[Sysname] pppoe-server log enable
Use pppoe-server nas-port-id interface to configure a device to use information of the specified interface to fill in the NAS-Port-ID attribute.
Use undo pppoe-server nas-port-id to restore the default.
pppoe-server nas-port-id interface interface-type interface-number
Information about the interface through which the user comes online is used to fill in the NAS-Port-ID attribute.
interface interface-type interface-number: Specifies an interface by its type and number. The specified interface must be the PPPoE user's access interface. In the current software version, the interface number can contain one, two, three, or four tiers. In each tier, the number is in the range of 0 to 65534. For example, for a 3-tier interface number, the minimum interface number is 0/0/0, and the maximum interface number is 65534/65534/65534. Specify the interface number according to the actual conditions.
a device uses information about the interface through which a user comes online to fill in the NAS-Port-ID attribute and sends it to the RADIUS server by default. In some special applications, when you need to manually specify the access interface information to be filled in the NAS-Port-ID attribute, you can use this command. For example, suppose the RADIUS server restricts user A's access to only interface A. When user A accesses through interface B and you do not want to modify the RADIUS server configuration, you can execute this command to use information about interface A to fill in the NAS-Port-ID attribute for user A and send the attribute to the RADIUS server.
Operating mechanism
When the BAS information format is China-Telecom 163 and the pppoe-server nas-port-id interface command is executed, the following rules apply:
· If the access-user four-dimension-mode enable command is also executed, the interface information specified in the pppoe-server nas-port-id interface command will be used to fill in the following access interface information field in the NAS-PORT-ID attribute:
¡ chassis=NAS_chassis;slot=NAS_slot;subslot=NAS_subslot;port=NAS_port.
· If the access-user four-dimension-mode enable command is not executed, the interface information specified in the pppoe-server nas-port-id interface command will be used to fill in the following access interface information field in the NAS-PORT-ID attribute: slot=NAS_slot;subslot=NAS_subslot;port=NAS_port.
When the BAS information format is China-Telecom and the pppoe-server nas-port-id interface command is executed, the following rules apply:
· If the access-user four-dimension-mode enable command is also executed, the interface information specified in the pppoe-server nas-port-id interface command will be used to fill in the following NAS information field in the NAS-PORT-ID attribute:
¡ {eth|trunk|atm} NAS_chassis/NAS_slot/NAS_subslot/NAS_port.
· If the access-user four-dimension-mode enable command is not executed, the interface information specified in the pppoe-server nas-port-id interface command will be used to fill in the following access interface information field in the NAS-PORT-ID attribute: {eth|trunk|atm} NAS_slot/NAS_subslot/NAS_port.
This command takes effect only when the pppoe-server access-line-id bas-info command is executed on the device.
# Configure the device to use information of Ten-GigabitEthernet 0/0/16 to fill in the NAS-Port-ID attribute.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server nas-port-id interface ten-gigabitethernet 0/0/16
Use pppoe-server padi-limit to set the maximum number of PADI packets that the device can receive per second.
Use undo pppoe-server padi-limit to restore the default.
In standalone mode:
pppoe-server padi-limit slot slot-number number
undo pppoe-server padi-limit slot slot-number
In IRF mode:
pppoe-server padi-limit chassis chassis-number slot slot-number number
undo pppoe-server padi-limit chassis chassis-number slot slot-number
The default settings vary by MPU model. For more information, see the configuration guide.
number: Specifies the PADI packet receiving rate limit in the range of 1 to 6000.
When device reboot or version update is performed, the burst of online requests might affect the device performance. To avoid device performance degradation and make sure the device can process PADI packets correctly, use this command to adjust the PADI packet receiving rate limit.
# (In standalone mode.) Set the maximum number of PADI packets that slot 3 can receive per second to 100.
[Sysname] pppoe-server padi-limit slot 0 100
Use pppoe-server service-name-tag exact-match to set the service name matching mode to exact match for the PPPoE server on an interface.
Use undo pppoe-server service-name-tag exact-match to restore the default.
The service name matching mode for the PPPoE server on an interface is fuzzy match.
Upon receiving a PADI or a PADR packet from a PPPoE client, the PPPoE server compares its service name with the service-name tag field of the packet. The server accepts the session establishment request only if the field matches the service name. Table 10 describes different matching rules in different matching modes.
Table 10 Service name matching rules
Matching mode |
PPPoE client |
PPPoE server |
Result |
Exact match |
No service name is specified. |
The number of configured service names is less than 8. |
Success |
The number of configured service names is 8. |
Failure |
A service name is specified. |
A service name that is the same as that of the client is configured. |
Success |
A service name that is the same as that of the client is not configured. |
Failure |
Fuzzy match |
Any configuration. |
Success |
A service name that is the same as that of the client is configured, or the number of configured service names is less than 8. |
Success |
A service name that is the same as that of the client is not configured, or the number of configured service names is 8. |
Failure |
#Set the service name matching mode to exact match for the PPPoE server on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server service-name-tag exact-match
· pppoe-server tag service-name
Use pppoe-server session-limit to set the maximum number of PPPoE sessions on an interface.
Use undo pppoe-server session-limit to restore the default.
pppoe-server session-limit number
The number of PPPoE sessions on an interface is not limited.
number: Specifies the maximum number of PPPoE sessions on an interface, in the range of 1 to 65534.
PPPoE can establish a session when none of the following limits are reached:
· Limit for a user on an interface.
· Limit for a VLAN on an interface.
· Limit on an interface.
· Limit on a card.
If the configured limit is smaller than the number of existing online sessions on the interface, the configuration succeeds. The configuration does not affect the existing online sessions. However, new sessions cannot be established on the interface.
#Set the maximum number of PPPoE sessions on Ten-GigabitEthernet 0/0/15 to 50.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server session-limit 50
Use pppoe-server session-limit per-mac to set the maximum number of PPPoE sessions for a user on an interface.
Use undo pppoe-server session-limit per-mac to restore the default.
pppoe-server session-limit per-mac number
A user can create a maximum of one PPPoE session on an interface.
number: Specifies the maximum number of PPPoE sessions for a user, in the range of 1 to 65534.
A user is identified by a MAC address.
· Limit on a card.
If the number argument is set to 1, when the device receives a PADR packet whose MAC address is the same as an online user, the following happens:
· If the online user has finished NCP negotiation for less than 30 seconds, the device discards the received PADR packet and the user remains online.
· If the online user has finished NCP negotiation for more than 30 seconds, the device sends a PADT packet to notify the user to go offline and deletes the session.
To generate DHCP client IDs based on PPP sessions, execute the remote address dhcp client-identifier command with the session-info keyword when the following requirements are met:
· The number argument is set to 2 or greater than 2.
· PPPoE users obtain IP addresses from the IP address pool.
#Set the maximum number of PPPoE sessions for a user on Ten-GigabitEthernet 0/0/15.1 to 50.
[Sysname] interface ten-gigabitethernet 0/0/15.1
[Sysname-Ten-GigabitEthernet0/0/15.1] pppoe-server session-limit per-mac 50
· pppoe-server session-limit total
Use pppoe-server session-limit per-vlan to set the maximum number of PPPoE sessions for a VLAN on an interface.
Use undo pppoe-server session-limit per-vlan to restore the default.
pppoe-server session-limit per-vlan number
The number of PPPoE sessions for a VLAN on an interface is not limited.
L3VE subinterface view
number: Specifies the maximum number of PPPoE sessions for a VLAN, in the range of 1 to 65534.
· Limit on a card.
#Set the maximum number of PPPoE sessions for a VLAN on Ten-GigabitEthernet 0/0/15.1 to 50.
[Sysname-Ten-GigabitEthernet0/0/15.1] pppoe-server session-limit per-vlan 50
pppoe-server sessions limit
pppoe-server sessions limit per-mac
pppoe-server sessions limit total
Use pppoe-server session-limit total to set the maximum number of PPPoE sessions on a device.
Use undo pppoe-server session-limit total to restore the default.
In standalone mode:
pppoe-server session-limit slot slot-number total number
undo pppoe-server session-limit slot slot-number total
In IRF mode:
pppoe-server session-limit chassis chassis-number slot slot-number total number
undo pppoe-server session-limit chassis chassis-number slot slot-number total
The number of PPPoE sessions on a card is not limited.
total number: Specifies the maximum number of PPPoE sessions on a device, in the range of 1 to 2147483647.
· (In standalone mode.) (In IRF mode.) Limit on a card.
(In standalone mode.) If you execute this command on the active MPU, this command only limits the total number of PPPoE sessions created on all global interfaces. If you execute this command on the standby MPU, the setting takes effect only after the MPU changes to be the active MPU upon an active/standby switchover.
(In IRF mode.) If you execute this command on the global active MPU, this command only limits the total number of PPPoE sessions created on all global interfaces. If you execute this command on any other MPUs in the IRF fabric, the setting takes effect only after the MPU changes to be the global active MPU upon an active/standby switchover.
# (In standalone mode.) Set the maximum number of PPPoE sessions on the specified slot to 3000.
[Sysname] pppoe-server session-limit slot 0 total 3000
pppoe-server tag ac-name
Use pppoe-server tag ac-name to set the access concentrator (AC) name for the PPPoE server on an interface.
Use undo pppoe-server tag ac-name to restore the default.
pppoe-server tag ac-name name
The AC name for the PPPoE server is the device name on an interface.
name: Specifies an AC name, a case-sensitive string of 1 to 64 characters.
The PPPoE server sends its AC name in PADO packets. PPPoE clients choose a PPPoE server by AC name.
The device does not support an AC name comprised of all blank spaces.
#Specify the AC name for the PPPoE server on Ten-GigabitEthernet 0/0/15 as pppoes.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server tag ac-name pppoes
pppoe-server tag ppp-max-payload
Use pppoe-server tag ppp-max-payload to enable the PPPoE server to support the ppp-max-payload tag and set a range for the tag on an interface.
Use undo pppoe-server tag ppp-max-payload to restore the default.
pppoe-server tag ppp-max-payload [ minimum min-number maximum max-number ]
The PPPoE server does not support ppp-max-payload tag on an interface. The PPPoE server ignores the ppp-max-payload tag in PADI or PADS packets from clients, and returns a PADO or PADS packets without the ppp-max-payload tag.
minimum min-number: Specifies the minimum value for the PPP maximum payload, in the range of 64 to 9600 bytes. The default value is 1492 bytes.
maximum max-number: Specifies the maximum value for the PPP maximum payload, in the range of 64 to 9600 bytes. The default value is 1500 bytes. The max-number argument must be equal or greater than the min-number argument.
This command enables the PPPoE server to forward large PPP packets with a payload larger than 1492 bytes and reduces fragmentation.
Operating mechanism
If the ppp-max-payload tag sent by the PPPoE client is within the tag range, the PPPoE server returns a PADO or PADS packet that includes the tag. If not, the PPPoE server determines that the received packets are invalid, and it does not return a PADO or PADS packet.
Operating mechanism
The jumboframe enable command can change the size of jumbo frames supported by the interface. The maximum size of the jumbo frames configured by the jumboframe enable command should be larger than the maximum value configured by the pppoe-server tag ppp-max-payload command.
#Enable the PPPoE server to support the ppp-max-payload tag and set the value for the PPP maximum payload to be in the range of 1494 to 1580 bytes on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server tag ppp-max-payload minimum 1494 maximum 1508
jumboframe enable (Interface Command References)
Use pppoe-server tag service-name to set a service name for a PPPoE server on an interface.
Use undo pppoe-server tag service-name to delete the specified service name.
pppoe-server tag service-name name
undo pppoe-server tag service-name name
A PPPoE server does not have a service name.
name: Specifies a service name, a case-sensitive string of 1 to 64 characters.
Service names identify the traffic destined for PPPoE servers when multiple PPPoE servers are providing services on the network. Likewise, the PPPoE server provides services to a specific PPPoE client based on the service name configured on the PPPoE server.
Operating mechanism
Upon receiving a PADI or a PADR packet from a PPPoE client, the PPPoE server compares its service name with the service-name tag field of the packet. The server accepts the session establishment request only if the field matches the service name. Service names support fuzzy match and exact match. For information about the match rules of fuzzy match and exact match, see the pppoe-server service-name-tag exact-match command.
Up to eight service names can be configured on an interface.
#Set the service name to pppoes for the PPPoE server on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server tag service-name pppoes
pppoe-server throttle per-mac
Use pppoe-server throttle per-mac to set the PPPoE access limit on an interface.
Use undo pppoe-server throttle per-mac to restore the default.
pppoe-server throttle per-mac session-requests session-request-period blocking-period
The PPPoE access rate is not limited on an interface.
session-requests: Specifies the maximum number of PPPoE session requests from a user within the monitoring time. The value range is 1 to 100000.
session-request-period: Specifies the monitoring time in the range of 1 to 3600 seconds.
blocking-period: Specifies the blocking time in the range of 1 to 3600 seconds.
This command limits the rate at which a user (identified by MAC address) can create PPPoE sessions on an interface. If the number of PPPoE requests within the monitoring time reaches the configured threshold, the device discards the excessive requests, and outputs log messages. If the blocking time is set to 0, the device does not block any requests, and it only outputs log messages.
The device uses a monitoring table and a blocking table to control PPP access rates.
· Monitoring table—Stores a maximum of 8000 monitoring entries. Each entry records the number of PPPoE sessions created by a user within the monitoring time. When the monitoring entries reach the maximum, the system stops monitoring and blocking session requests from new users. The aging time of monitoring entries is determined by the session-request-period argument. When the timer expires, the system starts a new round of monitoring for the user.
· Blocking table—Stores a maximum of 8000 blocking entries. The system creates a blocking entry if the access rate of a user reaches the threshold, and blocks requests from that user. When the blocking entries reach the maximum, the system stops blocking session requests from new users and it only outputs log messages. The aging time of the blocking entries is determined by the blocking-period argument. When the timer expires, the system starts a new round of monitoring for the user.
If the access rate setting is changed, the system removes all monitoring and blocking entries, and uses the new settings to limit PPPoE access rates.
#Block PPPoE session requests of a PPPoE user for 10 seconds when the PPPoE user sends 100 requests within 80 seconds on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-server throttle per-mac 100 80 10
reset pppoe-server
Use reset pppoe-server to clear PPPoE sessions on the PPPoE server.
reset pppoe-server { all | [ interface interface-type interface-number | mac-address mac-address ] * | virtual-template number }
all: Clears all PPPoE sessions.
virtual-template number: Specifies a VT interface by its number.
This command clears PPPoE sessions and forcibly logs out the corresponding users.
# Clear established sessions on Virtual-template 1 on the PPPoE server.
<Sysname> reset pppoe-server virtual-template 1
reset pppoe-server chasten per-interface
Use reset pppoe-server chasten per-interface to clear PPPoE protocol packet attack prevention entry information.
In standalone mode:
reset pppoe-server chasten per-interface [ packets ] [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
reset pppoe-server chasten per-interface [ packets ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
packets: Clears only dropped packet statistics of PPPoE protocol packet attack prevention entries. If you do not specify this keyword, this command clears information of PPPoE protocol packet attack prevention entries.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears PPPoE protocol packet attack prevention entry information of all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
If you specify only the packets keyword, this command clears dropped packet statistics in PPPoE protocol packet attack prevention entry information of all interfaces.
If you do not specify any parameter, this command clears PPPoE protocol packet attack prevention entry information of all interfaces.
#Clear PPPoE protocol packet attack prevention entry information on Ten-GigabitEthernet 0/0/15.
<Sysname> reset pppoe-server chasten per-interface interface ten-gigabitethernet 0/0/15
reset pppoe-server chasten user
Use reset pppoe-server chasten user to clear information of blocked PPPoE users.
In standalone mode:
reset pppoe-server chasten user [ packets ] [ mac-address [ mac-address ] | option105 [ circuit-id circuit-id ] [ remote-id remote-id ] ] [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
reset pppoe-server chasten user [ packets ] [ mac-address [ mac-address ] | option105 [ circuit-id circuit-id ] [ remote-id remote-id ] ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
packets: Clears only dropped packet statistics of blocked PPPoE users. If you do not specify this keyword, this command clears information of blocked PPPoE users.
mac-address [ mac-address ]: Specifies a MAC address in the H-H-H format. If you do not specify the mac-address argument, this command clears information of PPPoE users blocked based on MAC address.
option105: Clears information of PPPoE users blocked based on option 105.
circuit-id circuit-id: Specifies fuzzy matching of a circuit ID, a case-sensitive string of 1 to 127 characters. For example, if the circuit-id argument is abc, information of blocked PPPoE users whose circuit IDs contain abc will be cleared.
remote-id remote-id: Specifies fuzzy matching of a remote ID, a case-sensitive string of 1 to 127 characters. For example, if the remote-id argument is abc, information of blocked PPPoE users whose remote IDs contain abc will be cleared.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, this command clears information of blocked PPPoE users on all interfaces.
By default, the blocking state of blocked users are not cleared until the blocking period times out. During the blocking period, packets from these PPPoE users are dropped.
Use this command without specifying the packets keyword to clear the blocking state of blocked users. Then, the users can perform authentication to come online when the device receives packets from these users.
If you specify only the packets keyword, this command clears dropped packet statistics of all blocked PPPoE users.
If you do not specify any parameter, this command clears information of all blocked PPPoE users.
#Clear information of blocked PPPoE users on interface Ten-GigabitEthernet 0/0/15.
<Sysname> reset pppoe-server chasten user interface ten-gigabitethernet 0/0/15
display pppoe-server chasten statistics
display pppoe-server chasten user
reset pppoe-server packet statistics
Use reset pppoe-server packet statistics to clear PPPoE server negotiation packet statistics.
In standalone mode:
reset pppoe-server packet statistics [ slot slot-number ]
In IRF mode:
reset pppoe-server packet statistics [ chassis chassis-number slot slot-number ]
# (In standalone mode.) Clear PPPoE server negotiation packet statistics for the specified slot.
<Sysname> reset pppoe-server packet statistics slot 0
display pppoe-server packet statistics
PPPoE agency commands
display pppoe-agency acl statistics
Use display pppoe-agency acl statistics to display statistics of packets matching ACLs in the PPPoE agency application.
In standalone mode:
display pppoe-agency { ipv4 | ipv6 } acl statistics user-group user-group-name slot slot-number
In IRF mode:
display pppoe-agency { ipv4 | ipv6 } acl statistics user-group user-group-name chassis chassis-number slot slot-number
ipv4: Specifies IPv4 ACLs.
ipv6: Specifies IPv6 ACLs.
user-group user-group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters.
slot slot-number: Specifies a card by its slot number. On this device, the slot-number argument represents the entire device and its value is fixed. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. (In IRF mode.)
This command displays only statistics of incoming packets matching ACL rules with the counting keyword specified.
To use this command to display statistics of matching packets in the PPPoE agency application, make sure the ACL rules specified in the pppoe-agency forward command in a user group have the counting keyword specified.
# (In standalone mode.) Display statistics of incoming packets of the specified slot matching IPv4 ACLs in user group group001 in the PPPoE agency application.
<Sysname> display pppoe-agency ipv4 acl statistics user-group group001 slot 0
User-group: group001
Inbound policy:
IPv4 ACL 3001, Hardware-count
rule 0 permit destination 2.2.2.2 0 counting (2 packets 203 Bytes)
rule 5 permit destination 1.1.1.1 0 counting (5 packets 603 Bytes)
rule 10 permit destination 3.3.3.3 0 counting (No Counting Resource)
Table 11 Command output
User-group |
User group name. |
IPv4 ACL acl-number |
IPv4 ACL acl-number was successfully applied. |
IPv6 ACL acl-number |
IPv6 ACL acl-number was successfully applied. |
Hardware-count |
ACL rule match counting in hardware has been successfully enabled. |
Hardware-count (Failed) |
The device has failed to enable counting ACL rule matches in hardware. |
Hardware-count(Not enough resources to complete the operation.) |
The device has failed to enable counting ACL rule matches in hardware because the resources are insufficient. |
Hardware-count(The operation is not supported.) |
The device has failed to enable counting ACL rule matches in hardware because this operation is not supported. |
2 packets 203 Bytes |
Two packets of 203 bytes match the rule. |
No Counting Resource |
Insufficient hardware counting resources. |
reset pppoe-agency acl statistics
display pppoe-agency packet statistics
Use display pppoe-agency packet statistics to display the PPPoE agency negotiation packet statistics.
In standalone mode:
display pppoe-agency packet statistics [ slot slot-number ]
In IRF mode:
display pppoe-agency packet statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# (In standalone mode.) Display the PPPoE agency negotiation packet statistics of the specified slot.
<Sysname> display pppoe-agency packet statistics slot 0
PPPoE agency packet statistics in slot 0:
SEND_PADI_PKT : 0
RECV_PADO_PKT : 0 DISCARD_PADO_PKT : 0
SEND_PADR_PKT : 0
RECV_PADS_PKT : 0 DISCARD_PADS_PKT : 0
RECV_PADT_PKT : 0 DISCARD_PADT_PKT : 0
SEND_PADT_PKT : 0
Table 12 Command output
SEND_PADI_PKT |
Number of PADI packets sent. |
RECV_PADO_PKT |
Number of PADO packets received. |
DISCARD_PADO_PKT |
Number of dropped PADO packets received. |
SEND_PADR_PKT |
Number of PADR packets sent. |
RECV_PADS_PKT |
Number of PADS packets received. |
DISCARD_PADS_PKT |
Number of dropped PADS packets received. |
RECV_PADT_PKT |
Number of PADT packets received. |
DISCARD_PADT_PKT |
Number of dropped PADT packets received. |
SEND_PADT_PKT |
Number of PADT packets sent. |
display pppoe-agency session summary
Use display pppoe-agency session summary to display summary information of the PPPoE agency user sessions.
In standalone mode:
display pppoe-agency session summary [ interface interface-type interface-number | slot slot-number ]
In IRF mode:
display pppoe-agency session summary [ interface interface-type interface-number | chassis chassis-number slot slot-number ]
Session information of PPPoE agency users coming online through a physical interface is displayed only on the card hosting the physical interface and the MPU. Session information of global PPPoE agency users coming online through a logical interface is displayed on all cards.
# Display summary information of the PPPoE agency user sessions on Ten-GigabitEthernet 0/0/15.
<Sysname> display pppoe-agency session summary interface ten-gigabitethernet 0/0/15
Total PPPoE agency sessions: 2
Ethernet interface: XGE0/0/15 Session ID: 1
PPP index: 0x140000105 State: PADR_SEND
Remote MAC: 00e0-1500-7100 Local MAC: 00e0-1400-7300
Service VLAN: N/A Customer VLAN: N/A
Local session ID: 1
Ethernet interface: XGE0/0/15 Session ID: 2
PPP index: 0x150000105 State: OPEN
Remote MAC: 00e0-1600-7200 Local MAC: 00e0-1400-7300
Local session ID: 2
# (In standalone mode.) Display summary information of the PPPoE agency user sessions on the specified slot.
Total PPPoE agency sessions on slot 0: 2
Local PPPoE agency sessions on slot 0: 1
Ethernet interface: XGE0/0/16 Session ID: 1
PPP index: 0x140000105 State: OPEN
Remote MAC: 0000-0000-0005 Local MAC: 0000-5e00-0101
Local session ID: 1
Ethernet interface: RAGG1 Session ID: 2
Remote MAC: 0050-56c0-0005 Local MAC: 0000-5e00-0102
Local session ID: 2
Table 13 Command output
Total PPPoE agency sessions |
Total number of PPPoE agency user sessions. When a slot is specified in this command, this command displays the total number of PPPoE agency user sessions coming online through physical interfaces in the specified slot and all global PPPoE agency user sessions in the system. |
Local PPPoE agency sessions |
Number of local PPPoE agency user sessions. For this field, the following rules apply: · The statistics of sessions of PPPoE agency users coming online through a physical interface are displayed on the slot hosting the physical interface. · The statistics of sessions of PPPoE agency users coming online through a global interface are displayed on the slot hosting the active MPU. (In standalone mode.) · The statistics of sessions of PPPoE agency users coming online through a global interface are displayed on the slot hosting the global active MPU. (In IRF mode.) (This field is not displayed if an interface is specified in this command.) |
Ethernet interface |
Interface bound to a PPPoE agency user session. |
Session ID |
ID of a PPPoE agency user session. |
PPP index |
PPP session index information |
State |
State of a PPPoE agency user session: · PADI_SEND—The PPPoE session is being created and in the session discovery phase. · PADR_SEND—The PPPoE session is being created and in the session negotiation phase. · OPEN—The PPPoE session is open. · OFFLINE—The PPPoE session is being deleted. · INIT—The PPPoE session is to be activated. |
Remote MAC |
Remote MAC address. |
Local MAC |
Local MAC address. |
Service VLAN |
Service provider VLAN. This field displays N/A if no service VLAN is available. |
Customer VLAN |
Customer VLAN. This field displays N/A if no customer VLAN is available. |
Local session ID |
ID of a local PPPoE agency session. |
pppoe-agency authentication domain
Use pppoe-agency authentication domain to configure the authentication domain for PPPoE agency users.
Use undo pppoe-agency authentication to restore the default.
pppoe-agency authentication domain domain-name
No authentication domain is configured for PPPoE agency users.
User group view
domain-name: Specifies a PPPoE agency user authentication domain, a case-insensitive string of 1 to 255 characters. The domain name cannot contain the following special characters: /\|”:*?<>@.
When a campus BRAS simulates a PPPoE client and initiates PPPoE dialup for network access to the PPPoE server of the corresponding ISP according to the PPPoE agency group name carried in the COA messages, the BRAS first authenticates the PPPoE agency user according to the authentication domain specified in the pppoe-agency authentication domain command. If no authentication domain is specified by the pppoe-agency authentication domain command or the specified authentication domain does not exist, the BRAS uses the authentication domain selected by the AAA module, and the username and password used for authentication are issued by the AAA service through COA messages. PPPoE agency can succeed only when the campus BRAS successfully authenticates the PPPoE agency user and the ISP PPPoE server successfully authenticates the PPPoE client. If the authentication on any end fails, PPPoE agency fails. In this case, the user can access only the internal network, and cannot access the external network.
This command is mutually exclusive with the following commands:
· pppoe-agency-relay enable
· pppoe-agency-relay-group
# Configure authentication domain dm1 for PPPoE agency users in user group group1.
[Sysname] user-group group1
[Sysname-ugroup-group1] pppoe-agency authentication domain dm1
domain (BRAS Services Command Reference)
pppoe-agency bind
pppoe-agency bind
Use pppoe-agency bind to enable the PPPoE agency on an interface and bind the interface to a PPPoE agency group.
Use undo pppoe-agency bind to disable the PPPoE agency on an interface.
pppoe-agency bind virtual-template number pppoe-agency-group pppoe-agency-group-name [ nat-instance instance-name ]
The PPPoE agency is disabled on an interface.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
L3VE interface/subinterface view
virtual-template number: Specifies a VT interface by its number. The value range for this field is 0 to 1023.
pppoe-agency-group pppoe-agency-group-name: Specifies a PPPoE agency group by its name, a case-insensitive string of 1 to 31 characters. The PPPoE agency group name can only be authorized by the AAA server through the Framed-Pool attribute. The value for the pppoe-agency-group-name argument specified in this command must be the same as the value for the Framed-Pool attribute authorized by the AAA server to the PPPoE agency users.
· In unified PPPoE agency mode, a PPPoE agency group uniquely identifies the ISP to which an agency user belongs.
· In PPPoE agency gateway mode, the network includes the following types depending on the deployment position of the PPPoE agency gateway:
¡ School-side agency gateway network—A PPPoE agency group name uniquely identifies the ISP to which an agency user belongs.
¡ ISP-side agency gateway network—A PPPoE agency group name uniquely identifies the school to which an agency user belongs.
nat-instance instance-name: Binds the interface to a NAT instance when you enable the multi-endpoint single account feature for PPPoE agency. This binds corporate network IP mappings. The instance-name argument specifies a NAT instance by its name, a case-sensitive string of 1 to 31 characters.
Operating mechanism
With this feature configured, the device that provides the PPPoE agency feature operates in either of the following modes:
· Unified PPPoE agency mode—When a campus BRAS user initiates the agency process, the campus BRAS will select one interface that matches the PPPoE agency group name carried in COA messages from the interfaces with the pppoe-agency bind command executed (PPPoE agency interfaces, called agency interface for short). Then, the campus BRAS will use the selected interface to simulate a PPPoE client and initiate PPPoE dialup for network access to the PPPoE server of the corresponding ISP.
· PPPoE agency gateway mode—When a campus BRAS user initiates the agency process, the PPPoE agency gateway will select one interface that matches the PPPoE agency group name carried in COA messages from the interfaces with the pppoe-agency bind command executed (PPPoE agency interfaces, called agency interface for short). Then, the PPPoE agency gateway will use the selected interface to simulate a PPPoE client and initiate PPPoE dialup for network access to the PPPoE server of the corresponding ISP.
If the PPPoE agency group name carried in the COA messages authorized to a user matches the pppoe-agency-group-name argument value configured on multiple interfaces, the device will select the interface with the least online PPPoE agency users to simulate a PPPoE client for the user to perform PPPoE dialup. If multiple interfaces meet the requirements, the device randomly selects one from them.
Restrictions and cautions
When the PPPoE agency is enabled on an interface, the VT interface bound to the interface must exist.
When online PPPoE agency users exist on an interface, you cannot directly use the undo pppoe-agency bind command to disable the PPPoE agency on the interface. To do that, first log out all online PPPoE agency users on the interface, and then execute the undo pppoe-agency bind command.
If an interface has the PPPoE agency enabled and is bound to a VT interface, you cannot directly use this command to bind the interface to a new VT interface. To do that, first disable the PPPoE agency on the interface, and then re-enable the PPPoE agency on the interface and bind it to a new VT interface.
If both the PPPoE client and PPPoE agency are enabled on an interface, the PPPoE client does not take effect.
# Enable the PPPoE agency on Ten-GigabitEthernet 0/0/15, and bind Ten-GigabitEthernet 0/0/15 to VT interface 1 and PPPoE agency group 1.
[Sysname-Ten-GigabitEthernet0/0/15] pppoe-agency bind virtual-template 1 pppoe-agency-group 1
If the pppoe-agency multi-host function is enabled, please specify the nat-instance.
Use pppoe-agency forward to configure a PPPoE agency forwarding policy.
Use undo pppoe-agency forward to restore the default.
pppoe-agency forward { ipv4 | ipv6 } acl { acl-number | name acl-name }
undo pppoe-agency forward { ipv4 | ipv6 }
No PPPoE agency forwarding policy is configured.
User group view
acl: Performs PPPoE agency forwarding for traffic based on ACLs. Traffic matching the specified ACL is considered as internal network traffic and directly forwarded. Traffic not matching the specified ACL is considered as external network traffic and forwarded through the PPPoE agency.
· acl-number: Specifies an ACL by its number, in the range of 3000 to 3999 (advanced ACL) .
· name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. It must start with an English letter. To avoid confusion, it cannot be all.
When specifying an ACL, follow these restrictions and guidelines:
· Do not specify the user-group keyword in any ACL rule. If you do that, the PPPoE agency function based on the ACL is not available.
· If the specified ACL does not exist or does not have any rules, all traffic is external network traffic and must be forwarded through the PPPoE agency.
· In the specified ACL, the following rules apply:
¡ If a rule has the vpn-instance keyword specified, the rule takes effect only on users in the specified VPN instance, and user traffic matching the ACL rule in the specified VPN instance is considered as internal network traffic and directly forwarded.
¡ If a rule does not have the vpn-instance keyword specified, the rule takes effect only on all users (including users in VPN instances). When user traffic is compared with the ACL rule, its VPN attributes are ignored. User traffic matching the ACL rule is considered as internal network traffic and directly forwarded.
# Configure user group group1 to directly forward traffic matching IPv4 ACL 3000 and forward non-matching traffic through the PPPoE agency or drop the non-matching traffic.
[Sysname-ugroup-group1] pppoe-agency forward ipv4 acl 3000
pppoe-agency bind
user-group (BRAS Services Command Reference)
pppoe-agency log enable
Use pppoe-agency log enable to enable the PPPoE agency logging feature.
Use undo pppoe-agency log enable to disable the PPPoE agency logging feature.
The PPPoE agency logging feature is disabled.
IMPORTANT: As a best practice, disable this feature to prevent excessive PPPoE agency log output. |
You can enable the PPPoE agency logging feature to meet the security audit (for example, source tracing) requirements. The PPPoE agency logging feature enables the BRAS device to generate PPPoE agency logs and send them to the information center. Logs are generated when PPPoE agency users come online.
A log entry records mapping between the internal IP address and the IP address assigned by the ISP to a PPPoE agency user. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
# Enable the PPPoE agency logging feature.
[Sysname] pppoe-agency log enable
Use pppoe-agency-relay enable to enable the PPPoE agency gateway feature.
Use undo pppoe-agency-relay enable to disable the PPPoE agency gateway feature.
The PPPoE agency gateway feature is disabled.
Application scenarios
On a PPPoE agency network, the device that provide the PPPoE agency feature operates in either of the following modes:
· Unified PPPoE agency mode—In this mode, the campus BRAS also acts as the PPPoE agency device. The campus BRAS provides both BRAS access authentication and PPPoE agency features for campus network users.
· PPPoE agency gateway mode—In this mode, a separate ISP BRAS (PPPoE agency gateway) rather than the campus BRAS provides the PPPoE agency feature. Depending on the deployment position, the PPPoE agency gateways include the following types:
¡ School-side agency gateway—Deployed on the campus network.
¡ ISP-side agency gateway—Deployed on the ISP network.
To use a BRAS as a PPPoE agency gateway, you can enable the PPPoE agency gateway feature on that BRAS. With the PPPoE agency gateway feature enabled, the BRAS will be used as a dedicated PPPoE agency gateway and will no longer support the unified PPPoE agency mode.
When online PPPoEA users exist on a PPPoE agency gateway, you cannot execute the undo pppoe-agency-relay enable command to disable the PPPoE agency gateway feature. To do that, first execute the cut access-user command to log off all PPPoEA users, and then execute the undo pppoe-agency-relay enable command.
PPPoE agency gateways are used only for PPPoE agency networking. Non-PPPoE agency services (such as IPoE or L2TP) cannot be deployed on PPPoE agency gateways. Before executing this command on an agency gateway, make sure no non-PPPoEA users are online on the agency gateway. If non-PPPoEA users are online on the agency gateway, you cannot execute this command.
· pppoe-agency authentication domain
· pppoe-agency forward
# Enable the PPPoE agency gateway feature.
[Sysname] pppoe-agency-relay enable
Use pppoe-agency-relay-group to bind an interface to a PPPoE agency group.
Use undo pppoe-agency-relay-group to unbind an interface from a PPPoE agency group.
pppoe-agency-relay-group pppoe-agency-group-name interface interface-type interface-number [ peer-ip peer-ip-address ]
undo pppoe-agency-relay-group pppoe-agency-group-name interface interface-type interface-number
An interface is not bound to any PPPoE agency group.
pppoe-agency-group-name: Specifies a PPPoE agency group by its name, a case-insensitive string of 1 to 31 characters. The PPPoE agency group name can only be authorized by the AAA server through the Framed-Pool attribute. The value for the pppoe-agency-group-name argument specified in this command must be the same as the value for the Framed-Pool attribute authorized by the AAA server to the PPPoE agency users. Among them:
· School-side agency gateway network—A PPPoE agency group name uniquely identifies the ISP to which an agency user belongs.
· ISP-side agency gateway network—A PPPoE agency group name uniquely identifies the school to which an agency user belongs.
interface interface-type interface-number: Specifies a PPPoE agency gateway access interface (called agency gateway access interface for short) by its type and number. The interface connects the PPPoE agency gateway to the campus BRAS.
peer-ip peer-ip-address: Specifies the IPv4 address of the physical interface or the global interface (for example, Layer 3 aggregate interface) of the physical interface connecting the peer device to the PPPoE agency gateway access interface. The interface specified by the peer-ip-address argument can be either a main interface or subinterface. When the multi-endpoint single account feature is enabled, do not specify this parameter. When the multi-endpoint single account feature is disabled, you must specify this parameter.
Operating mechanism
(School-side agency gateway)
On a school-side agency gateway network, the PPPoE agency gateway, as a school device, might be uplinked to multiple ISPs through different PPPoE agency interfaces. To differentiate traffic from different ISPs, use this command to bind the following elements:
· The PPPoE agency gateway access interface that is allocated to an ISP and connects to the campus BRAS.
· The agency group of the ISP.
For example, perform the following tasks for ISP A on the PPPoE agency gateway as shown in Figure 4:
· Use the pppoe-agency-relay-group command to bind the PPPoE agency gateway access interface Port B to the PPPoE agency group of ISP A.
· Use the pppoe-agency bind command to bind the PPPoE agency interface Port D to the PPPoE agency group of ISP A.
In this case, when the PPPoE agency gateway receives uplink traffic from users at school A through access interface Port B, it forwards the traffic through PPPoE agency interface Port D. Similarly, when the PPPoE agency gateway receives downlink traffic to users at school A through PPPoE agency interface Port D, it forwards the traffic through access interface Port B.
(ISP-side agency gateway)
On an ISP-side agency gateway network, the PPPoE agency gateway, as an ISP device, might be downlinked to multiple schools through different PPPoE agency gateway access interfaces. To differentiate traffic of users from different schools, you must use this command to bind the following elements:
· The interface connecting to the specified school on the PPPoE agency gateway.
· The agency group of the school.
For example, perform the following tasks on the PPPoE agency gateway for school A as shown in Figure 5:
· Use the pppoe-agency-relay-group command to bind the PPPoE agency gateway access interface Port B to the PPPoE agency group of school A.
· Use the pppoe-agency bind command to bind PPPoE agency interface Port D to the PPPoE agency group of school A.
On the school-side PPPoE agency gateway, multiple ISPs cannot share the same PPPoE agency gateway access interface or PPPoE agency interface. Each ISP must have an exclusive pair of PPPoE agency gateway access interface and PPPoE agency interface, which can be main interfaces or subinterfaces.
On the ISP-side PPPoE agency gateway, multiple schools cannot share the same PPPoE agency gateway access interface or PPPoE agency interface. Each school must have an exclusive pair of PPPoE agency gateway access interface and PPPoE agency interface, which can be main interfaces or subinterfaces.
At a time, a PPPoE agency gateway access interface can be bound to only one PPPoE agency group, and vice versa. To change a binding between PPPoE agency group and PPPoE agency gateway access interface, first execute the undo pppoe-agency-relay-group command to remove the binding, and then execute the pppoe-agency-relay-group command to configure a new binding.
When online PPPoEA users exist on the PPPoE agency interface bound to a PPPoE agency group, follow these restrictions and guidelines:
· You cannot directly execute the undo pppoe-agency-relay-group command to remove the binding. To do that, first log off all online PPPoEA users on the PPPoE agency interface bound to the PPPoE agency group, and then execute the undo pppoe-agency-relay-group command.
· You cannot directly execute this command to modify the binding between the PPPoE agency group and the PPPoE agency gateway access interface. To do that, follow these steps:
¡ First, log off all online PPPoEA users on the PPPoE agency interface bound to the PPPoE agency group.
¡ Next, execute the undo pppoe-agency-relay-group command to remove the binding.
¡ Finally, execute the pppoe-agency-relay-group command to configure a new binding.
# Bind the specified interface to the PPPoE agency group.
[Sysname] pppoe-agency-relay-group school1 interface ten-gigabitethernet 0/0/15 peer-ip 1.1.1.1
pppoe-agency bind
reset pppoe-agency
Use reset pppoe-agency to clear the PPPoE agency sessions on the PPPoE agency.
reset pppoe-agency { all | interface interface-type interface-number | virtual-template number }
all: Specifies all PPPoE agency sessions.
This command clears PPPoE agency sessions and forcibly logs out agency users.
# Clear the PPPoE agency sessions on Virtual-Template 1 on the PPPoE agency.
<Sysname> reset pppoe-agency virtual-template 1
Use reset pppoe-agency acl statistics to clear statistics of packets matching ACLs in the PPPoE agency application.
In standalone mode:
reset pppoe-agency { ipv4 | ipv6 } acl statistics user-group user-group-name slot slot-number
In IRF mode:
reset pppoe-agency { ipv4 | ipv6 } acl statistics user-group user-group-name chassis chassis-number slot slot-number
# (In standalone mode.) Clear statistics of packets of the specified slot matching IPv4 ACLs in user group group001.
<Sysname> reset pppoe-agency ipv4 acl statistics user-group group001 slot 0
reset pppoe-agency packet statistics
Use reset pppoe-agency packet statistics to clear the PPPoE agency negotiation packet statistics.
In standalone mode:
reset pppoe-agency packet statistics [ slot slot-number ]
In IRF mode:
reset pppoe-agency packet statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears entries for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears entries for the global active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
# Clear the PPPoE agency negotiation packet statistics on the device.
