01-基础配置命令参考
11-设备管理命令
本章节下载: 11-设备管理命令  (1.12 MB)
11-设备管理命令
1 设备管理
1.1 设备管理配置命令
1.1.1 clock datetime
1.1.2 clock protocol
1.1.3 clock summer-time
1.1.4 clock timezone
1.1.5 command
1.1.6 copyright-info enable
1.1.7 display alarm active
1.1.8 display alarm history
1.1.9 display clock
1.1.10 display copyright
1.1.11 display cpu-usage
1.1.12 display cpu-usage configuration
1.1.13 display cpu-usage history
1.1.14 display device
1.1.15 display device manuinfo
1.1.16 display device manuinfo fan
1.1.17 display device manuinfo power
1.1.18 display device uptime
1.1.19 display diagnostic-information
1.1.20 display dying-gasp host
1.1.21 display environment
1.1.22 display fan
1.1.23 display kernel memory alloc-failure
1.1.24 display kernel memory fragment free
1.1.25 display memory
1.1.26 display memory dma
1.1.27 display memory-threshold
1.1.28 display memory-threshold dma
1.1.29 display power
1.1.30 display resource-monitor
1.1.31 display scheduler job
1.1.32 display scheduler logfile
1.1.33 display scheduler reboot
1.1.34 display scheduler schedule
1.1.35 display system health
1.1.36 display system health history
1.1.37 display system stable state
1.1.38 display transceiver alarm
1.1.39 display transceiver diagnosis
1.1.40 display transceiver eyediagram-diagnosis
1.1.41 display transceiver health
1.1.42 display transceiver interface
1.1.43 display transceiver manuinfo
1.1.44 display transceiver power
1.1.45 display version
1.1.46 display version-update-record
1.1.47 dying-gasp host
1.1.48 dying-gasp source
1.1.49 fan ignore-absent
1.1.50 hardware-alarm disable
1.1.51 header
1.1.52 job
1.1.53 locator blink
1.1.54 memory-threshold
1.1.55 memory-threshold dma
1.1.56 memory-threshold usage
1.1.57 monitor cpu-usage enable
1.1.58 monitor cpu-usage interval
1.1.59 monitor cpu-usage logging interval
1.1.60 monitor cpu-usage threshold
1.1.61 monitor memory-usage logging interval
1.1.62 monitor resend cpu-usage
1.1.63 monitor resend memory-threshold
1.1.64 monitor resend memory-threshold dma
1.1.65 parity-error consistency-check log enable
1.1.66 parity-error consistency-check period
1.1.67 parity-error consistency-check threshold
1.1.68 parity-error monitor log enable
1.1.69 parity-error monitor period
1.1.70 parity-error monitor threshold
1.1.71 parity-error unrecoverable log enable
1.1.72 parity-error unrecoverable period
1.1.73 parity-error unrecoverable reboot
1.1.74 parity-error unrecoverable threshold
1.1.75 password-recovery enable
1.1.76 push-button mode enable
1.1.77 reboot
1.1.78 reset scheduler logfile
1.1.79 reset version-update-record
1.1.80 resource-monitor minor resend enable
1.1.81 resource-monitor output
1.1.82 resource-monitor resource
1.1.83 restore factory-default
1.1.84 scheduler job
1.1.85 scheduler logfile size
1.1.86 scheduler reboot at
1.1.87 scheduler reboot delay
1.1.88 scheduler schedule
1.1.89 shutdown-interval
1.1.90 sysid
1.1.91 sysname
1.1.92 temperature-limit
1.1.93 time at
1.1.94 time once
1.1.95 time repeating
1.1.96 transceiver health check enable
1.1.97 transceiver health weight
1.1.98 transceiver monitor enable
1.1.99 transceiver monitor interval
1.1.100 transceiver rx-power high-threshold
1.1.101 transceiver rx-power low-threshold
1.1.102 transceiver rx-power change-threshold
1.1.103 transceiver tx-power high-threshold
1.1.104 transceiver tx-power low-threshold
1.1.105 transceiver tx-power change-threshold
1.1.106 usb disable
1.1.107 user-role
1 设备管理
1.1  设备管理配置命令
clock datetime命令用来配置设备的系统时间。
clock datetime time date
设备的系统时间为UTC时间2011年1月1日零点。
time:配置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。比如将time参数配置为0表示零点。
date:配置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
执行本命令会修改设备的系统时间,会影响和系统时间相关特性的执行(例如定时执行任务功能),以及和其他设备的协同操作(例如日志上报和统计),请谨慎执行。
请先配置clock protocol none命令,再执行本命令。clock datetime命令中指定的时间会立即生效,作为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
设备断电重启后,该命令会恢复到缺省情况,需要重新配置。
# 配置设备的系统时间为2015年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2015
# 配置设备的系统时间为2015年1月1日8时10分。
<Sysname> clock datetime 8:10 2015/1/1
·     clock protocol
·     clock summer-time
·     clock timezone
·     display clock
clock protocol命令用来配置系统时间的获取方式。
undo clock protocol命令用来恢复缺省情况。
clock protocol { none | ntp }
undo clock protocol
通过NTP协议获取时间。
none:表示通过命令行配置系统时间。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议获取时间。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
系统时间的获取方式有:
·     配置clock protocol none命令后,通过clock datetime命令直接配置。clock datetime命令中指定的时间即为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
·     配置clock protocol ntp命令后,通过NTP协议从网络中获取时间。该方式下,设备会周期性的同步服务器的UTC(Coordinated Universal Time,国际协调时间)时间,并用同步得到的UTC时间和设备上配置的本地时区、夏令时参数运算,得出当前的系统时间。该方式获取的时间比命令行配置的时间更精准,推荐使用。
多次执行本命令,最后一次执行的命令生效。
# 配置获取UTC时间的方式为通过命令行配置。
[Sysname] clock protocol none
clock summer-time命令用来配置夏令时。
undo clock summer-time命令用来恢复缺省情况。
未配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
·     直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
·     分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:January、February、March、April、May、June、July、August、September、October、November或December;然后输入开始的星期,用当月的第几个星期表示,取值如下:first、second、third、fourth、fifth或last;最后输入起始日,取值为Sunday、Monday、Tuesday、Wednesday、Thursday、Friday或Saturday。
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
·     直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
配置该命令后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
请将所有网络设备的夏令时和当地夏令时保持一致。
# 配置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
·     clock datetime
·     clock timezone
·     display clock
clock timezone命令用来配置系统所在的时区。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
系统所在的时区为零时区,即设备采用UTC时间。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
请将所有网络设备的时区和当地地理时区保持一致。
# 配置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
·     clock datetime
·     clock summer-time
·     display clock
1.1.5  command
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
通过command分配的命令行必须是设备上可成功执行的命令行,不包括telnet、ftp、ssh2和monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
如果需要分配的命令(假设为A)是用户视图下的命令,则直接使用command命令分配即可;如果需要分配的命令(假设为A)是非用户视图下的命令,则必须先分配进入A所在视图的命令(指定较小的id值),再分配A。
定时执行任务时,设备不会与用户交互信息。当需要用户交互确认时,系统将自动输入“Y”或“Yes”;当需要用户交互输入字符信息时,系统将自动输入缺省字符串,没有缺省字符串的将自动输入空字符串。
# 为名称为backupconfig的Job分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# 为Job(假设名称为shutdownGE)分配命令,以便将接口GigabitEthernet1/0/1关闭。
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface gigabitethernet 1/0/1
[Sysname-job-shutdownGE] command 3 shutdown
·     scheduler job
copyright-info enable命令用来开启版权信息显示功能。
undo copyright-info enable命令用来关闭版权信息显示功能。
版权信息显示功能处于开启状态。
# 开启版权信息显示功能。
[Sysname] copyright-info enable
重新登录设备后,会显示如下信息:
* Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                                 *
display alarm active命令用来显示设备当前仍未恢复的告警信息。
display alarm active [ verbose ]
verbose:显示告警项的详细信息。不指定该参数时,显示告警项的概要信息。
当设备的电源、CPU、风扇等运行异常时,使用display alarm命令可以查看到相应的告警信息。对于过去发生的、已经恢复的告警可以使用display alarm history命令查看;对于过去发生的、当前仍未恢复的告警可以使用display alarm active命令查看。
# 显示设备当前仍未恢复的告警信息。‌‌
<Sysname> display alarm active
Seq    Level    Time                  Info
24     Warning  2020-01-11  12:40:00  CPU usage is in minor alarm state on slot 1.
23     Warning  2020-01-11  12:30:00  Memory minor threshold has been exceeded on slot 1.
22     Minor    2020-01-11  12:18:00  Board state changed to Fault on slot 1.
表1-1 display alarm active命令显示信息描述表
Seq
告警序列号,告警发生时分配。
Level
告警的级别,级别由高到低依次为Critical、Major、Minor、Warning
Time
告警产生的时间
Info
告警的详细信息,涉及风扇、电源、设备温度等硬件故障,主要取值包括:
·     Board state changed to Fault on slot xx:slot xx变成Fault状态(该slot可能正在启动,或者处于故障状态)
·     Slot xx fan xx is absent:Slot xx上风扇xx未插入
·     Slot xx fan xx is failed:Slot xx上风扇xx处于异常状态
·     Slot xx power xx is absent:Slot xx上电源xx未插入
·     Slot xx power xx failed:Slot xx上电源xx处于异常状态
·     Temperature is higher than the high-temperature alarming threshold on slot xx sensor inflow xx:slot xx上的传感器xx的温度高于高温门限
·     Memory minor threshold has been exceeded on slot xx:slot xx的空闲内存高于minor门限
·     CPU usage is in minor alarm state on slot xx:slot xx的CPU使用率高于minor门限
·     Interface-name: RX power is high!:接口Interface-name光功率过高
·     Interface-name:The bit error ratio exceeds the upper threshold:接口Interface-name误码率超过了上限
·     SSH user username (IP: IP-Address) connected to the server successfully:SSH用户的用户名(IP:IP地址)成功登录服务器
·     Member port xx of aggregation group xx changed to the inactive state, because xx.:聚合xx内成员接口xx因为xx原因非选中
·     The mpls ldp session status changes. (SessionState=$1, DiscontinuityTime=$2, StatsUnknownMesTypeErrors=$3, StatsUnknownTlvErrors=$4):LDP会话状态变化
¡     $1:LDP会话状态,取值包括:nonexistent,initialized,openrec,opensent,operational
¡     $2:LDP会话处于Operational状态的持续时间
¡     $3:LDP会话收到未知信息的次数
¡     $4:LDP会话收到未知TLV的次数
·     The number of routes received from the BGP peer exceeded the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6):从BGP对等体收到的路由数量超过允许接收的最大路由数量
¡     $1:BGP实例名称
¡     $2:地址族标识符
¡     $3:子地址族标识符
¡     $4:BGP对等体的IP地址类型
¡     $5:BGP对等体的IP地址
¡     $6:为指定BGP对等体配置的允许设备接收的最大路由数量
·     BGP $1.$2: The number of routes from peer $3 ($4-$5) exceeds the limit $6.:从对等体学到的路由数量超过了允许的最大路由数量
¡     $1:BGP实例名称
¡     $2:VPN实例名称。如果是公网内的日志信息,则显示为空
¡     $3:BGP对等体的IP地址
¡     $4:地址族标识符
¡     $5:子地址族标识符
¡     $6:允许从对等体接收的最大路由前缀数量
·     BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has reached the threshold ($7):接收的路由数量占允许的最大路由数量的百分比达到了阈值
¡     $1:BGP实例名称
¡     $3:BGP对等体的IP地址
¡     $4:地址族标识符
¡     $5:子地址族标识符
¡     $7:设备接收的路由数量与允许接收的最大数量的百分比达到告警阈值时,设备接收到的具体路由数量
·     The number of routes received from the BGP peer exceeded the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7):从BGP对等体收到的路由数量超过告警阈值
¡     $1:BGP实例名称
¡     $2:地址族标识符
¡     $3:子地址族标识符
¡     $4:BGP对等体的IP地址类型
¡     $5:BGP对等体的IP地址
# 显示设备当前仍未恢复的告警信息详细内容。‌‌
<Sysname> display alarm active verbose
Seq 4
Alarm name: BoardStatus
Alarm source: slot 2
Level: Minor
Start time: 2022-05-16 18:58:46
  Info: Board state changed to Fault on slot 2.
表1-2 display alarm active verbose命令显示信息描述表
Seq
告警序列号,告警发生时由系统自动分配
Alarm name
告警的名称
Alarm source
告警对象所在位置
Level
Start time
告警发生时间
Info
告警的详细信息
·     display alarm
·     display alarm history
display alarm history命令用来显示已经恢复的告警信息。
display alarm history [ verbose ]
verbose:显示告警项的详细信息。不指定该参数时,显示概要信息。
本命令最多可显示的信息条数与设备的型号有关,请以设备的实际情况为准。
# 显示设备告警历史信息。‌‌
<Sysname> display alarm history
Seq        Time                  Info
23         2020-01-11 12:40:00 CPU usage recovered to normal state on slot 1.
本命令显示信息描述表请参见“display alarm active”中的“display alarm active命令显示信息描述表”。
# 显示设备告警历史信息详细内容。‌‌
<Sysname> display alarm history verbose
Seq 23
Alarm name: CPUUsageMinor
Alarm position: slot 1
Start time: 2020-01-11 12:30:00
Level: Warning
Info: CPU usage is in minor alarm state on slot 1
Recovery time: 2020-01-11 12:40:30
Info: CPU usage minor alarm removed on slot 1.
表1-3 display alarm history verbose命令显示信息描述表
Seq
告警序列号,告警发生时由系统自动分配
Alarm name
告警的名称
AlarmPosition
告警对象所在位置
Start time
告警发生时间
Level
Recovery time
告警恢复时间
Info
告警的详细信息,取值主要包括:
·     BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has fallen below the threshold ($7):从BGP对等体收到的路由数量降低到告警阈值以下
¡     $1:BGP实例名称
¡     $3:BGP对等体的IP地址
¡     $4:地址族标识符
¡     $5:子地址族标识符
¡     $6:允许从对等体接收的最大路由数量
·     The number of routes received from the BGP peer decreased below the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7).:从BGP对等体收到的路由数量降低到告警阈值以下
¡     $1:BGP实例名称
¡     $2:地址族标识符
¡     $3:子地址族标识符
¡     $4:BGP对等体的IP地址类型
¡     $5:BGP对等体的IP地址
·     The number of routes received from the BGP peer decreased below the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6):从BGP对等体收到的路由数量降低到允许接收的最大路由数量以下
¡     $1:BGP实例名称
¡     $2:地址族标识符
¡     $3:子地址族标识符
¡     $4:BGP对等体的IP地址类型
¡     $5:BGP对等体的IP地址
·     BGP $1.$2: The number of routes from peer $3 ($4-$5) fell below the limit $6.:从对等体学到的路由数量降低到了允许的最大路由数量以下
¡     $1:BGP实例名称
¡     $3:BGP对等体的IP地址
¡     $4:地址族标识符
¡     $5:子地址族标识符
·     display alarm
·     display alarm active
1.1.9  display clock
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
# 未配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00.258 UTC Fri 03/16/2015
显示信息中,时间的格式采用“时:分:秒.毫秒”的格式。
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00.152 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00.211 Z5 Fri 03/16/2015
·     clock datetime
·     clock timezone
·     clock summer-time
display copyright命令用来显示设备的版权信息。
display copyright
# 显示设备的版权信息。
<Sysname> display copyright
显示信息略……。
display cpu-usage命令用来显示CPU利用率的统计信息。
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number| all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ] ]
control-plane:显示控制平面CPU利用率的统计信息。不指定control-plane和data-plane参数时,显示整个CPU利用率的统计信息。
data-plane:显示数据平面CPU利用率的统计信息。不指定control-plane和data-plane参数时,显示整个CPU利用率的统计信息。
summary:以列表形式显示CPU利用率的统计信息。不指定该参数时,以区段形式显示CPU利用率的统计信息。
slot slot-number:显示指定成员设备的CPU利用率的统计信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,显示的是所有成员设备的相应信息。‌‌
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号。
core { core-number | all }:显示CPU核利用率的统计信息。其中,all表示显示所有CPU核利用率的统计信息;core-number表示CPU核的编号,显示指定CPU核利用率的统计信息。
当最近5秒、最近1分钟、最近5分钟的CPU利用率取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 以段的形式显示当前CPU利用率统计信息。‌‌
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# 以表的形式显示当前CPU利用率统计信息。‌‌
<Sysname> display cpu-usage summary
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
表1-4 display cpu-usage命令显示信息描述表
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU或CPU核的平均利用率。该字段显示的是最近一个5秒统计周期内CPU或CPU核的平均利用率
Last 5 sec
1% in last 1 minute
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU或CPU核的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU或CPU核的平均利用率
Last 1 min
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU或CPU核的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU或CPU核的平均利用率
Last 5 min
display cpu-usage configuration命令用来显示CPU利用率监控功能的相关配置。
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,显示的是主设备上的相应信息。‌‌
cpu cpu-number:表示CPU的编号。
# 显示CPU利用率监控功能的相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 90%.
Current severe alarm threshold is 85% for the following cores: 0.
Current minor alarm threshold is 80%.
Current recovery-threshold is 40%.
表1-5 display cpu-usage configuration命令显示信息描述表
CPU利用率历史记录功能处于开启状态
CPU利用率历史记录的采样周期为60秒
编号为0的CPU核利用率的高级别告警门限为85%,其它CPU以及CPU核利用率的告警门限为90%
CPU低级别告警门限为80%
CPU恢复门限为40%
·     monitor cpu-usage enable
·     monitor cpu-usage interval
·     monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
job job-id:显示指定进程的CPU利用率的历史信息。job-id表示进程的编号,取值范围为1~2147483647。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控”中的“系统维护与调试”。
slot slot-number:显示指定成员设备的CPU利用率的历史信息。slot-number表示设备在IRF中的成员编号。当不指定job和该参数时,显示的是所有成员设备上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是主设备上指定进程的相应信息。‌‌
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号。当不指定job和该参数时,表示所有CPU。当指定job参数,但不指定该参数时,表示默认CPU。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
·     纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
·     横坐标表示时间,时间越靠左表示距离当前时间越近。
·     用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示CPU利用率的历史记录。‌‌
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明系统(用“SYSTEM”表示,运行在Slot 1 CPU 0上)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
display device命令用来显示设备信息。
display device [ flash | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
flash:显示Flash的信息。
usb:显示USB接口的信息。
slot slot-number:显示指定成员设备的信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。‌‌
subslot subslot-number:显示指定子卡的信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息。
不指定flash和usb参数时,显示成员设备的信息。‌
# 显示设备信息。‌
<Sysname> display device
Slot Type                 State    Subslot  Soft Ver             Patch Ver
1    S5200-54S-PWR-EI-G   Master   0        S5200EIG-6009P13     None
表1-6 display device命令显示信息描述表
设备类型
设备在IRF中的角色,取值为:
·     Master:表示IRF中的主设备
·     Standby:表示IRF中的从设备
Soft Ver
设备上运行的软件版本
Patch Ver
当前设备上运行的、最新发布的热补丁版本。取值为None时表示没有安装热补丁
若同时安装了叠加补丁和非叠加补丁,则显示最新发布的叠加补丁。关于叠加补丁和非叠加补丁的介绍请参见“基础配置指导”中的“软件升级”
display device manuinfo命令用来显示设备的电子标签信息。
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
slot slot-number:显示指定成员设备的电子标签信息。slot-number表示设备在IRF中的成员编号。不输入该参数时,显示所有成员设备的相应信息。‌‌
subslot subslot-number:显示指定子卡的电子标签信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
电子标签信息也可以称为永久配置数据或档案信息等,在硬件的调测(调试、测试)过程中被写入到设备的存储器件中,包括硬件的名称、生产序列号、MAC地址、制造商等信息。
# 显示设备的电子标签信息。
<Sysname> display device manuinfo
显示信息略……。
display device manuinfo fan命令用来显示风扇的电子标签信息。
display device manuinfo slot slot-number fan fan-id
slot slot-number:表示设备在IRF中的成员编号。‌‌
fan-id:表示设备上风扇的ID编号。
# 显示指定风扇的电子标签信息。‌
<Sysname> display device manuinfo slot 1 fan 1
显示信息略……。
display device manuinfo power命令用来显示电源的电子标签信息。
display device manuinfo slot slot-number power power-id
power-id:表示设备上电源的ID编号。
# 显示指定电源的电子标签信息。‌
<Sysname> display device manuinfo slot 1 power 1
显示信息略……。
display device uptime命令用来显示成员设备最近一次启动后的运行时长。‌
# 显示成员设备最近一次启动后的运行时长。‌
<Sysname> display device uptime
Slot Type                 State    Subslot  UP time(DD:HH:MM)
1    S5200-36S-PWR-HI-G   Master   0        0000:04:28
display diagnostic-information命令用来收集诊断信息。
display diagnostic-information [ hardware | ifmgr | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
hardware:收集硬件相关的诊断信息。
ifmgr:收集IFMGR模块相关诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
key-info:收集关键诊断信息。当设备异常或者运行时间较长时,可能会产生较多诊断信息,此时,使用该关键字,即可以收集到关键的诊断信息,又可以缩短诊断信息的收集时间。不指定该参数时,收集当前全部诊断信息。
filename:表示将收集到的诊断信息保存到指定文件。filename表示文件的名称,后缀必须为“.tar.gz”。不指定该参数时,用户可根据提示信息选择将诊断信息保存到指定文件或者是直接显示诊断信息。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个模块的诊断信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,收集多个模块的诊断信息。
使用该命令,用户可以直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,因为诊断信息较多,系统会自动将该文件压缩后保存,文件名后缀为“.tar.gz”。如果要在设备上查看该文件的内容,请执行以下操作:
(1)     使用tar extract命令将文件XXXX.tar.gz解包成文件XXXX.gz。
(2)     使用gunzip命令将文件XXXX.gz解包成文件XXXX。
(3)     使用more命令查看文件XXXX的内容。
如果收集诊断文件过程半途中止,可能导致gunzip命令无法正常解压,但诊断文件中仍包括已经生成的诊断信息,可以将诊断文件传输到PC上使用Linux系统下的gunzip -c命令解压查看。
不指定filename参数执行display diagnostic-information命令时,系统会要求用户选择显示诊断信息还是将诊断信息保存到文件中。如果用户选择保存诊断信息,且当系统提示用户输入文件名时直接回车,设备会自动将当前诊断信息保存到一个新文件,并使用设备名称和当前系统时间为该文件命名,以免和现有文件重名,导致现有文件被覆盖。如果设备名称中包含“/”、“\”、“:”、“*”、“?”、“<”、“>”、“|”、“"”等特殊字符,在给诊断文件命名时,这些特殊字符会被转换为下划线“_”。比如设备的名称为A/B,设备会使用形如flash:/diag_A_B_20160101-000438.tar.gz的字符串为新生成的诊断文件命名。
未指定hardware、infrastructure、l2、l3和service参数时,将收集设备产生的所有诊断信息。
该命令不支持“|”、“>”和“>>”参数。
执行本命令收集诊断信息时,请不要配置设备,以免影响收集结果。
# 收集系统当前各个功能模块运行的统计信息。
14:03:55 UTC Thu 01/05/2015
显示信息略……。
# 将收集到的诊断信息保存到缺省诊断文件。
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
请在“Please input the file name”提示信息处,直接回车。
# 将收集到的诊断信息保存到文件test.tar.gz。
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
·     gunzip(基础配置命令参考/文件系统管理)
·     more(基础配置命令参考/文件系统管理)
·     tar extract(基础配置命令参考/文件系统管理)
display dying-gasp host命令用来显示接收断电告警的目的主机的信息。
# 显示接收断电告警的目的主机的信息。
<sysname> display dying-gasp host
IPv4 address: 1.1.1.0
Message type: SNMP Trap
Securityname: p1
Version: V1
IPv4 address: 1.1.1.1
Message type: Syslog
表1-7 display dying-gasp host命令显示信息描述表
IPv4 address
接收断电告警信息的目的主机的IPv4地址
IPv6 address
接收断电告警信息的目的主机的IPv6地址
VPN instance
接收断电告警的目的主机所属VPN的名称
Message type
发送断电告警时使用的消息类型,取值为:
·     SNMP Trap:表示以SNMP Trap形式发送断电告警
·     Syslog:表示以日志形式发送断电告警
Securityname
以SNMP Trap形式发送断电告警信息时的SNMP安全字
Version
以SNMP Trap形式发送断电告警信息时的SNMP版本信息,取值为:v1、v2c
·     dying-gasp host
display environment命令用来显示设备上温度传感器的温度信息。
slot slot-number:显示IRF中指定成员设备上的温度传感器的温度信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,显示的是IRF中所有温度传感器的温度信息。不指定该参数时,显示所有成员设备的对应信息。‌‌
# 显示设备上所有温度传感器的温度信息。‌‌
<Sysname> display environment
 System temperature information (degree centigrade):
Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 1     hotspot 1 41           0      60       65     NA
 1     hotspot 2 68           0      100      117    NA
 1     hotspot 3 56           0      100      117    NA
表1-8 display environment命令显示信息描述表
System Temperature information (degree centigrade)
系统温度信息,单位为摄氏度
sensor
温度传感器
·     hotspot:表示热点温度传感器
·     inflow:表示入风口温度传感器
·     outflow:表示出风口温度传感器
Slot
当显示数字时表示指定slot上温度传感器的温度信息
Temperature
当前温度
Lower
低温告警门限。当显示为NA时,表示不支持该门限
Warning
一般级(Warning)高温告警门限。当显示为NA时,表示不支持该门限
Alarm
严重级(Alarm)高温告警门限。当显示为NA时,表示不支持该门限
Shutdown
关断级(Shutdown)高温告警门限,当温度传感器的温度大于该门限时,设备会自动关闭。当显示为NA时,表示不支持该门限
1.1.22  display fan
display fan命令用来显示风扇的工作状态。
display fan [ slot slot-number [ fan-id ] ] [ verbose ]
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有风扇。‌‌
fan-id:表示设备内置风扇的编号。不指定该参数时,表示指定位置的所有风扇。
verbose:显示设备内置风扇的详细信息。不指定该参数时,显示设备内置风扇的简要信息。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
Slot 1:
 Fan 1 State: Normal
 Airflow Direction: Power-to-port
 Fan 2 State: Normal
 Fan 3 State: Normal
 Fan 4 State: Normal
 Fan 5 State: Normal
表1-9 display fan命令显示信息描述表
Slot 1
设备的成员编号
Fan 1
设备上风扇的编号
风扇状态:
·     Absent:风扇不在位
·     Normal:风扇正常工作
·     Fault:风扇故障
Airflow Direction
风扇模块的实际风道方向:
·     Port-to-power:风扇从端口侧向电源侧抽风,即风向从前向后
·     Power-to-port:风扇从电源侧向端口侧吹风,即风向从后向前
display kernel memory alloc-failure命令用来显示内核内存申请失败信息。
display kernel memory alloc-failure [ slot slot-number [ cpu cpu-number ] ]
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示指定Master设备。‌
# 显示内核内存申请失败信息。
<System> display kernel memory alloc-failure
kmalloc_tag failures: 55.
kcalloc_tag failures: 0.
kzalloc_tag failures: 0.
krealloc_tag failures: 0.
kmem_cache_alloc_tag failures: 0.
表1-10 display kernel memory alloc-failure 命令显示信息描述表
调用kmalloc_tag申请内存失败的次数
调用kcalloc_tag申请内存失败的次数
调用kzalloc_tag申请内存失败的次数
调用krealloc_tag申请内存失败的次数
调用kmem_cache_alloc_tag申请内存失败的次数
display kernel memory fragment free命令用来显示内核空间空闲内存的统计信息。
display kernel memory fragment free [ slot slot-number [ cpu cpu-number ] ]
# 显示内核空间空闲内存的统计信息。
<Sysname> display kernel memory fragment free
Kernel memory free ratio:  0.13%
cfq_io_context                   memory free (in kbytes): 0
LFIB_NhlfeEntryCache26           memory free (in kbytes): 0
LFIB_NhlfeEntryCache74           memory free (in kbytes): 0
L2VFIB_TUNNELBMP_Cache           memory free (in kbytes): 0
NAT_SESSION_EXT_INFO             memory free (in kbytes): 0
ARP_VSISUP_Entry_cache           memory free (in kbytes): 0
LFIB_NhlfeEntryCache1            memory free (in kbytes): 0
FVN_FwdCache19                   memory free (in kbytes): 0
---- More ----
表1-11 display kernel memory fragment 命令显示信息描述表
内核空间空闲内存占内核空间总内存的比例
Slab名为cfq_io_context的空闲内存大小,单位为千字节
display memory命令用来显示内存使用情况。
summary:显示内存使用情况的简要信息。不指定该参数时,显示内存使用情况的详细信息。
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。‌‌
cpu cpu-number:表示CPU编号。
当显示信息中某一行所有参数的取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 显示设备的内存使用情况的详细信息。‌‌
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:       3956640    891056   3065584         0      4364    188384       77.7%
-/+ Buffers/Cache:    698308   3258332
Swap:            0         0         0
# 显示设备的内存使用情况的简要信息。‌‌
<Sysname> display memory summary
Slot CPU        Total      Used      Free  Buffers    Caches FreeRatio
   1   0       984560    456128    528432        4     45616     53.7%
表1-12 display memory命令显示信息描述表
系统内存使用情况,以下统计信息均以KB为单位
Mem
内存使用信息
Total
系统可分配的物理内存的大小
设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销以及ISSU功能运行等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小
Used
整个系统已用的物理内存大小
Free
整个系统可用的物理内存大小
Shared
多个进程共享的物理内存总额。取值为“--”时,表示不支持统计该参数的值
Buffers
已使用的文件缓冲区的大小。取值为“--”时,表示不支持统计该参数的值
Cached
高速缓冲寄存器已使用的内存大小。当系统内存告警时,高速缓冲寄存器中的部分内存可主动释放供其他业务使用。取值为“--”时,表示不支持统计该参数的值
Caches
FreeRatio
整个系统物理内存的空闲率。包含当前剩余空闲内存以及高速缓冲寄存器中当前正在使用但是内存告警状态下可主动释放的内存
-/+ buffers/cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小
Swap
交换分区的使用信息
display memory dma命令用来显示DMA内存的使用情况。
display memory dma [ slot slot-number [ cpu cpu-number ] ]
# 显示slot1的DMA内存使用相关信息。‌‌
<System> display memory dma slot 1
DMA memory statistics measured in KB on slot 1:
Total        Used         Free         FreeRatio
16384        6140         10244        63%
表1-13 display memory dma 命令显示信息描述表
系统使用DMA内存情况,单位为KB
Total
内存分片的总个数,为Free和Used之和
Used
系统已使用的DMA内存大小
Free
系统可使用的DMA内存大小
FreeRatio
Free与Total的比率,可以反映系统DMA内存的空闲率
display memory-threshold命令用来显示内存告警门限相关信息。
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示主设备。‌‌
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory thresholds:
    Minor: 386M
    Severe: 270M
    Critical: 154M
    Normal: 502M
    Early-warning: 618M
    Secure: 695M
Current free-memory state: Normal (secure)
Free-memory event statistics:
 [Back to secure state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Entered early-warning state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to normal state]
 [Entered minor alarm state]
 [Back to minor alarm state]
 [Entered severe alarm state]
 [Back to severe alarm state]
 [Entered critical alarm state]
表1-14 display memory-threshold命令显示信息描述表
内存利用率阈值
Free-memory thresholds
    Minor
    Severe
    Critical
    Normal
    Early-warning
    Secure
剩余内存门限阈值:
·     Minor:一级告警门限,单位为MB
·     Severe:二级告警门限,单位为MB
·     Critical:三级告警门限,单位为MB
·     Normal:恢复到正常状态的阈值,单位为MB
·     Early-warning:预告警门限,单位为MB(仅S5200-HI-G系列支持)
·     Secure:恢复预告警门限状态的阈值,单位为MB(仅S5200-HI-G系列支持)
系统当前内存使用状态:
·     Normal:正常状态
·     Minor:一级告警门限状态
·     Severe:二级告警门限状态
·     Critical:三级告警门限状态
·     Normal (early-warning):预告警状态(仅S5200-HI-G系列支持)
·     Normal (secure):安全状态(仅S5200-HI-G系列支持)
门限事件统计信息,事件分为:
·     Back to secure state:恢复到预告警前的状态
·     Entered early-warning state:进入预告警门限状态
·     Back to normal state:内存恢复到正常状态
·     Entered minor alarm state:进入一级告警门限状态
·     Back to minor alarm state:恢复到一级告警前的状态
·     Entered severe alarm state:进入二级告警门限状态
·     Back to severe alarm state:恢复到二级告警前的状态
·     Entered critical alarm state:进入三级告警门限状态
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
Total number of notification send
事件发生的总次数
display memory-threshold dma命令用来显示DMA内存告警相关信息。
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
# 显示DMA内存告警相关信息。
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
    Critical: 2048KB
    Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
 [Entered to critcal state]
表1-15 display memory-threshold dma 命令显示信息描述表
    Critical:
    Normal:
DMA内存告警阈值(单位为KB):
·     Critical:告警阈值
·     Normal:告警恢复阈值
DMA内存的当前状态:
·     Critical:告警状态
·     Normal:正常状态
告警事件统计信息,事件分为:
·     Entered to critcal state:进入告警状态
First notification
告警事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
Latest notification
告警事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
告警事件发生的总次数
display power命令用来显示设备电源的信息。
display power [ slot slot-number [ power-id | verbose ] ]
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有电源。‌‌
power-id:表示电源模块的编号。不指定该参数时,表示指定位置的所有电源。
verbose:显示电源的详细信息。不指定该参数时,显示电源的简要信息。
# 显示设备电源的简要信息。
<Sysname> display power
Slot 1:
 Input Power: -- W
 PowerID  State  Mode   Current(A)  Voltage(V)  Power(W) FanDirection
 1        Normal AC     10.3        12.0        121.0    --
 2        Absent --     --          --          --       --
表1-16 display power命令显示信息描述表
Input Power
设备的额定功率
PowerID
设备上的电源模块编号
电源模块的状态
·     Absent:电源不在位
·     Normal:电源正常工作
·     Fault:电源故障
Mode
电源模块的类型,取值为:
·     AC:表示交流电源
·     DC:表示直流电源
Current(A)
电源输出电流,单位为安,显示为“--”表示设备暂不支持统计该信息
Voltage(V)
电源输出电压,单位为伏,显示为“--”表示设备暂不支持统计该信息
Power(W)
电源输出功率,单位为瓦,显示为“--”表示设备暂不支持统计该信息
FanDirection
电源模块内风扇的吹风方向,取值为:
·     PowerToPort:电源侧进风、端口侧出风
·     PortToPower:端口侧进风、电源侧出风
·     --:设备暂不支持统计该信息
# 显示电源的详细信息。‌
<Sysname> display power slot 1 verbose
System power information on slot 1:
 Power modules installed: 1
 Power modules usable: 1
 Rated power: 450 W
 Usable power: 450 W
 Used power: 0.0 W
 Redundant power: -- W
 Total DC output: 10.1 A
 PowerID State   InVoltage(V) InPower(W) OutVoltage(V) OutCurrent(A) OutPower(W)
 1       Normal  --           --         11.9          10.1          120.0
表1-17 display power verbose命令显示信息描述表
设备上电源系统的相关信息
设备中已安装的电源模块数量
设备中可用的电源模块数量
Rated power
处于Normal状态的电源模块的额定功率之和,单位为瓦
Usable power
处于Normal状态的电源模块可分配的功率之和,单位为瓦
Used power
当前已分配的功率,单位为瓦
Redundant power
电源系统实际的冗余功率,单位为瓦
Total DC output
设备中所有电源模块输出电流值的和,单位为安
PowerID
设备上电源模块的编号
display resource-monitor命令用来显示资源监控功能的相关信息。
仅S5200-HI-G系列交换机支持本命令。
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
resource resource-name:需要监测的资源的名称。参数的取值请参见resource-monitor resource命令的设备可监测的资源描述表。
slot slot-number:显示指定成员设备的资源告警事件通知功能的相关信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,则表示所有成员设备。‌
cpu cpu-number:显示指定CPU的资源告警事件通知功能的相关信息。cpu-number表示需要检测的资源所在CPU的编号。
# 显示ARP资源监控的相关信息。‌‌
<Sysname> display resource-monitor resource arp
Minor alarms resending: Enabled
Slot 1:
Resource                         Minor Severe Free/Total
                                 (%)   (%)    (absolute)
arp                              50    20     90095/90098
表1-18 display resource-monitor命令显示信息描述表
周期发送低级别资源告警通知功能的开启状态:
·     Enabled:表示该功能已开启
·     Disabled:表示该功能未开启
Resource
监控资源的名称
Minor
低级别告警门限,单位为百分比
Severe
高级别门限,单位为百分比
Free/Total
(absolute)
剩余资源的数量/该资源的总数,用绝对值形式表示
·     resource-monitor minor resend enable
·     resource-monitor resource
display scheduler job命令用来显示Job的配置信息。
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示Job的执行日志信息。
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[Sysname-if-range]shutdown
表1-19 display scheduler logfile命令显示信息描述表
Logfile Size
Schedule日志文件的大小,单位为字节
Job name
Job的名称
Schedule name
Schedule的名称
Execution time
开始执行Job的时间
Completion time
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息)
Job output
Job中的命令执行时的输出信息
·     reset scheduler logfile
display scheduler reboot命令用来显示定时重启功能的相关配置。
# 显示定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
·     scheduler reboot at
·     scheduler reboot delay
display scheduler schedule命令用来显示Schedule的相关信息。
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 显示所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2015
Last execution time  : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts     : 1
Job name                                          Last execution status
shutdown                                          Successful
表1-20 display scheduler schedule命令显示信息描述表
Schedule name
Schedule的名称
Schedule type
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息
Start time
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Last execution time
Schedule上一开始执行的时间
·     如果没有为Schedule配置执行时间,则不会显示该信息
·     如果还没有执行,则显示Yet to be executed
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Execution counts
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息
Job name
Schedule下关联的Job的名称
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看)
·     Successful:表示执行成功
·     Failed:表示执行失败
·     Waiting:表示正在等待被执行
·     In process:表示正在执行
·     -NA-:表示还没有到执行时间
display system health命令用来显示设备的健康状态。
display system health [ slot slot-number ]
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,则表示主设备。‌
设备会定期执行一系列检查,以便了解设备是否处于健康状态。检查项在设备出厂时已固定,检查结果可供设备内部业务模块(例如IRF等)使用, 也可通过本命令供用户查看。
# 显示设备健康状态。
<Sysname> display system health
Slot 1 health: Normal(0)
    Memory: Normal(0)
    Communication: Normal(0)
    DBM monitor: Normal(0)
    Chip jam: Normal(0)
    CPU deadloop: Normal(0)
    Forwarding channel: Normal(0)
    HG: Normal(0)
    LSW CPU: Normal(0)
    LSW port: Normal(0)
    Board status: Normal(0)
    Fan status: Normal(0)
    Temperature: Normal(0)
表1-21 display system health命令显示信息描述表
Health: Normal(0)
系统的健康状态。取值为:
·     Normal(0):表示系统健康
·     Faulty(n):表示系统不健康,n表示健康值,取值越大越不健康
Memory
内存检测
Communication
通信检测
DBM monitor
DBM进程异常检测
Chip jam
芯片堵死定时检测
CPU deadloop
CPU死循环检测
Forwarding channel
框式设备跨板业务检测
HG
单板间HG检测
LSW CPU
LSW CPU故障检测
LSW port
LSW端口检测
Board status
单板状态检测
Fan status
风扇状态检测
Temperature status
温度传感器状态检测
·     display system health history
display system health history命令用来显示系统健康状态变化的历史信息。
display system health history [ slot slot-number ]
# 显示系统健康状态变化的历史信息。
<Sysname> display system health history
Health: Faulty(1)
  Chip jam:
    Faulty(1)  2019-10-10 18:00:00 on slot 1
    Normal(0)  2019-10-08 17:00:00 on slot 1
    Faulty(1)  2019-10-07 18:00:00 on slot 1
表1-22 display system health history命令显示信息描述表
Health: Normal(0)
系统当前的健康状态。取值为:
·     Normal(0):表示系统健康
Chip jam:
健康检测结果有变化的检测项的历史信息,设备支持的检测项请参见“display system health”中的“display system health命令显示信息描述表”,每个测试项最多显示30条系统健康状态变化的历史信息
Faulty(1)  2019-10-10 18:00:00 on slot 1表示slot 1在2019-10-10 18:00:00状态变为Faulty(1)
display system stable state命令用来显示系统的稳定状态。
display system stable state [ summary ]
summary:显示系统稳定状态的汇总信息,该信息包括CPU的运行状态和NSR的稳定状态。不指定该参数时,显示CPU的运行状态和CPU运行状态的详细信息。
在进行ISSU升级或主备倒换前,请先执行该命令,检查设备是否处于稳定状态。如果System State未处于Stable状态,不能进行ISSU升级;如果Redundancy Stable未处于Stable状态,不能进行主备倒换。
系统处于不稳定状态时,需要结合相关命令查看设备的具体情况。例如:
·     通过display device命令查看设备是否处于故障状态。
·     通过display ha service-group命令查看HA服务组的状态,以找出未批备完成的模块。
·     通过Probe视图下的display system internal process state命令查看服务启动状态。
操作时,建议多次执行命令,以确认稳定状态的连续性。
# 显示系统稳定状态的汇总信息。
<Sysname> display system stable state summary
System state      : Stable
Redundancy state  : No redundancy
NSR     state     : No standby
# 显示系统的稳定状态。‌
Redundancy state: No redundancy
  Slot   CPU   Role      State
  1      0     Active    Stable
表1-23 display system stable state命令显示信息描述表
System state
所有成员设备运行状态的汇总:
·     Stable:稳定运行,表示所有成员设备均处于稳定运行状态
·     Not ready:未稳定,此时不能进行ISSU升级
Redundancy state
主备状态:
·     Stable:主备状态稳定,可以倒换
·     No redundancy:系统无冗余,不能倒换
·     Not ready:未稳定,不可以倒换
NSR state
各模块NSR(Nonstop Routing,不间断路由)状态的汇总,取值为:
·     Ready:稳定状态,表示所有开启的NSR功能均能正常工作
·     Not ready:未稳定状态,此时不能进行进程倒换或者主备倒换、ISSU升级
·     No standby:没有备设备
·     Not configured:未开启NSR功能
Role
成员设备在系统中的身份:
·     Active:主设备
·     Standby:备设备,提供冗余备份
成员设备状态:
·     Stable:成员设备稳定运行
·     Board inserted:成员设备加入
·     Kernel initiating:成员设备内核初始化
·     Service starting:成员设备上的服务正在启动
·     Service stopping:成员设备上的服务正在关闭
·     HA Batch backup:HA批量备份中
·     Interface data batch backup:接口管理批量备份未完成
当前对象处于未稳定状态
·     display device
·     display ha service-group(可靠性命令参考/进程分布优化)
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见“display transceiver alarm命令输出信息描述表”。如果没有故障,则显示为None。
表1-24 SFP+/SFP28的display transceiver alarm命令输出信息描述表
RX signal loss
接收信号丢失
RX power high alarm
接收光功率高告警
RX power high warning
接收光功率高预警
RX power low alarm
接收光功率低告警
RX power low warning
接收光功率低预警
TX fault
发送错误
TX bias high alarm
偏置电流高告警
TX bias high warning
偏置电流高预警
TX bias low alarm
偏置电流低告警
TX bias low warning
偏置电流低预警
TX power high alarm
发送光功率高告警
TX power high warning
发送光功率高预警
TX power low alarm
发送光功率低告警
TX power low warning
发送光功率低预警
Temp high alarm
温度高告警
Temp high warning
温度高预警
Temp low alarm
温度低告警
Temp low warning
温度低预警
Voltage high alarm
电压高告警
Voltage high warning
电压高预警
Voltage low alarm
电压低告警
Voltage low warning
电压低预警
Transceiver info I/O error
模块信息读写错误
Transceiver info checksum error
模块信息校验和错误
Transceiver type and port configuration mismatch
模块类型和端口配置不匹配
Transceiver type not supported by port hardware
端口不支持该模块类型
TEC error
TEC(Thermoelectric Cooler,热点冷却器)错误。仅SFP-XG-LH80-Tunable光模块支持显示该信息
Wavelength unlocked
光信号波长失锁。仅SFP-XG-LH80-Tunable光模块支持显示该信息
Tx is not ready due to tunning
光信号波长改变时发射端处于准备过程状态告警。仅SFP-XG-LH80-Tunable光模块支持显示该信息
Tx dither not supported
不支持发送抖动。SFP-XG-LH80-Tunable
Excessive RX power change
接收光功率变化量过大告警
Excessive TX power change
发送光功率变化量过大告警
Excessive TX bias change
偏置电流变化量过大告警
Excessive temp change
温度变化量过大告警
User-set TX power high
用户自定义发送光功率高告警
User-set TX power low
用户自定义发送光功率低告警
User-set RX power high
用户自定义接收光功率高告警
User-set RX power low
用户自定义接收光功率低告警
RX CDR loss of lock
接收侧CDR失锁,表示信号不好
TX CDR loss of lock
发送侧CDR失锁,表示信号不好
表1-25 QSFP+/QSFP28的display transceiver alarm命令输出信息描述表
Temp high alarm
温度高告警
Temp high warning
温度高预警
Temp low alarm
温度低告警
Temp low warning
温度低预警
Voltage high alarm
电压高告警
电压高预警
Voltage low alarm
电压低告警
Voltage low warning
电压低预警
RX loss of signal(channel x)
通道x接收到的信号丢失
TX fault(channel x)
通道x发送报文时出错
TX loss of signal(channel x)
通道x发送的信号丢失
RX power high(channel x)
通道x接收到的光的功率太高
RX power low(channel x)
通道x接收到的光的功率太低
TX power high alarm(channel x)
通道x发送光功率高告警
TX power high warning(channel x)
通道x发送光功率高预警
TX power low alarm(channel x)
通道x发送光功率低告警
TX power low warning(channel x)
通道x发送光功率低预警
TX bias high(channel x)
通道x的偏置电流高
TX bias low(channel x)
通道x的偏置电流低
模块读写错误
模块信息校验和错误
Transceiver type and port configuration mismatched
模块类型和端口配置不匹配
端口不支持该类型的模块
Excessive RX power change(channel x)
通道x接收光功率变化量过大告警
Excessive TX power change(channel x)
通道x发送光功率变化量过大告警
Excessive TX bias change(channel x)
通道x偏置电流变化量过大告警
温度变化量过大告警
User-set TX power high(channel x)
通道x用户自定义发送光功率高告警
User-set TX power low(channel x)
通道x用户自定义发送光功率低告警
User-set RX power high(channel x)
通道x用户自定义接收光功率高告警
User-set RX power low(channel x)
通道x用户自定义接收光功率低告警
# 显示接口GigabitEthernet1/0/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver current alarm information:
  RX signal loss
  RX power low alarm
表1-26 display transceiver alarm显示信息描述表
接口光模块当前故障告警信息
RX signal loss
接收信号丢失
RX power low alarm
接收光功率低告警
接收光功率低预警
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet1/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver diagnostic information:
    Temp.(C)   Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36         3.31        6.13      -35.64          -5.19
  Alarm thresholds:
    High  50         3.55        1.44      -10.00         5.00
    Low   30         3.01        1.01      -30.00         0.00
  Warning thresholds:
          Temp(C)    Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High  45         3.25        1.25      -15.00         4.00
    Low   25         2.85        0.85      -25.00         1.00
  User-set power thresholds:
    High  -11.40         N/A
    Low   -26.00         0.10
表1-27 display transceiver diagnosis显示信息描述表
接口插入的光模块的数字诊断信息
当前的诊断参数
Wave.er(nm)
波长偏移,单位为nm,精确到0.001nm。仅SFP-XG-LH80-Tunable光模块支持显示该字段
Freq.er(GHz)
频率偏移,单位为GHZ,精确到0.1GHZ。仅SFP-XG-LH80-Tunable光模块支持显示该字段
Temp.(C)
数字诊断参数——温度,单位为°C,精确到1°C
Voltage(V)
数字诊断参数——电压,单位为V,精确到0.01V
Bias(mA)
数字诊断参数——偏置电流,单位为mA,精确到0.01mA
Total RX power(dBm)
数字诊断参数——总接收光功率,单位为dBm,精确到0.01dBm
Total TX power(dBm)
数字诊断参数——总发送光功率,单位为dBm,精确到0.01dBm
RX power(dBm)
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm
TX power(dBm)
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm
Alarm thresholds
告警门限
High
高告警门限或高预警门限
Low
低告警门限或低预警门限
Warning threshold
预警门限
Warning threshold
预警门限
用户自定义功率告警门限
RX power(dBm)
用户自定义接收光功率门限值,单位为dBm,精确到0.01dBm
TX power(dBm)
用户自定义发送光功率门限值,单位为dBm,精确到0.01dBm
display transceiver eyediagram-diagnosis命令用来诊断可插拔光模块,并以眼图的形式显示诊断信息。
display transceiver eyediagram-diagnosis interface [ interface-type interface-number ]
interface [ interface-type interface-number ]:诊断接口上插入的可插拔光模块,并以眼图的形式显示诊断信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
本命令是用于模仿专业检测仪器测试数据传输的质量,通过获取芯片上接收数据的采样值,以眼图的形式输出可插拔光模块的诊断结果,方便用户分析和评估可插拔光模块的数据传输质量。
通过眼图分析可插拔光模块的数据传输质量的简要方法:
·     眼睛区域越大,眼睛形状越清晰,表明数据传输信号越稳定,质量越好。眼睛区域是位于中心线(即0mV线)上下的空白区域。
·     眼睛区域中没有数字,表明数据传输质量好;眼睛区域中存在数字,表明数据传输质量不好。
# 诊断接口GigabitEthernet1/0/1上插入的可插拔光模块,并以眼图的形式输出诊断结果。
<Sysname> display transceiver eyediagram-diagnosis interface gigabitethernet 1/0/1
This operation might consume a large amount of system resources. It might cause unknown risks and might take several minutes. Continue?[Y/N]:y
    | EYESCAN Phy: 0x0e1 lane_mask: 0x01                                 |
Each character N represents approximate error rate 1e-N at that location
  UI/64  : -30  -25  -20  -15  -10  -5    0    5    10   15   20   25   30
   128mV : 111111111111111111111111112222322222222211111111111111111111111
   124mV : 111111111111111111111111122233332222222221111111111111111111111
   120mV : 111111111111111111111111222333333332222222211111111111111111111
   115mV : 111111111111111111111112223334443333222222221111111111111111111
   111mV : 111111111111111111111122233344444333322222222111111111111111111
   107mV : 111111111111111111111122233445544433332222222211111111111111111
   103mV : 111111111111111111111222334456655544333332222222111111111111111
    99mV : 111111111111111111112223344566665544433333222222211111111111111
    95mV : 11111111111111111111222344556776655443333322222221111111111111
    91mV : 11111111111111111112223345567  :766554443333222222111111111111
    86mV : 11111111111111111122233455677  :  76655444333322222211111111111
    82mV : 111111111111111111223344567----+---7665544433322222221111111111
    78mV : 111111111111111112223345667    :    :76655444333222222111111111
    74mV : 11111111111111112223345677:    :    :77665544333322222111111111
    70mV : 1111111111111111223344567 7    :    :   76655443332222211111111
    66mV : 1111111111111112223345677 :    :    :    7665444333222221111111
    62mV : 111111111111112223345667--+----+----+----+776554433322222111111
    57mV : 111111111111112223445677  :    :    :    :76655443332222111111
    53mV : 1111111111111222334566    :    :    :    :  7765544333222211111
    49mV : 1111111111112223345567    :    :    :    :    76554333222221111
    45mV : 111111111111222334567:    :    :    :    :    :7655443322222111
    41mV : 111111111112223345677+----+----+----+----+----+7765544332222211
    37mV : 11111111112223344567 :    :    :    :    :    :776544333222211
    33mV : 11111111112223345667 :    :    :    :    :    :   7654433322221
    28mV : 1111111112223344567  :    :    :    :    :    :   7765443322222
    24mV : 111111111222334567   :    :    :    :    :    :    765543332222
    20mV : 111111112223345567---+----+----+----+----+----+----+76544333222
    16mV : 11111112222344567    :    :    :    :    :    :    :7654433222
    12mV : 1111111222334567:    :    :    :    :    :    :    :77655433322
     8mV : 1111112223344567:    :    :    :    :    :    :    :  765543322
     4mV : 111111222334566 :    :    :    :    :    :    :    :  776544332
     0mV : 111111222344567-+----+----+----+----+----+----+----+----6554332
    -4mV : 111111222344567 :    :    :    :    :    :    :    :   76544332
    -8mV : 111111222334567 :    :    :    :    :    :    :    :  765443332
   -12mV : 1111112223344567:    :    :    :    :    :    :    :7655433322
   -16mV : 1111111222334567:    :    :    :    :    :    :    :7654433222
   -20mV : 11111112222344567----+----+----+----+----+----+----776544333222
   -24mV : 111111112223345677   :    :    :    :    :    :    765543332222
   -28mV : 111111111222334567   :    :    :    :    :    :   7665443332222
   -33mV : 1111111111222344567  :    :    :    :    :    :  77654433322221
   -37mV : 1111111111222334567  :    :    :    :    :    :766544333222211
   -41mV : 11111111111223344567-+----+----+----+----+----+7765544332222211
   -45mV : 11111111111222334566 :    :    :    :    :    77655443332222111
   -49mV : 1111111111112223345677    :    :    :    :    76554433322221111
   -53mV : 1111111111111222344567    :    :    :    :  7765544333222221111
   -57mV :1111111111111222334567    :    :    :    :77655443332222211111
   -62mV : 111111111111112223445677--+----+----+----+776654433332222211111
   -66mV : 111111111111111223345567  :    :    :    7765544333222222111111
   -70mV : 1111111111111112223345667 :    :    :    7655443333222221111111
   -74mV :11111111111111112223345667 :    :    :  766554433322222211111111
   -78mV :111111111111111112233445677    :    :  776554433322222211111111
   -82mV : 111111111111111112223345567----+----766554443332222221111111111
   -86mV : 1111111111111111112223345567   :    765544433322222221111111111
   -91mV : 11111111111111111112233445667  :   7665444333322222211111111111
   -95mV : 111111111111111111122233445667 :7766554433332222222111111111111
   -99mV : 111111111111111111112223344566777665544333322222221111111111111
  -103mV : 111111111111111111111223334556676655443333222222211111111111111
  -107mV : 111111111111111111111222333445565544333322222222111111111111111
  -111mV : 111111111111111111111122233444554443333222222221111111111111111
  -115mV : 111111111111111111111112223334444433332222222211111111111111111
  -120mV : 111111111111111111111111222333444333322222222111111111111111111
  -124mV : 111111111111111111111111222233333332222222211111111111111111111
  -128mV : 111111111111111111111111122223333322222222111111111111111111111
  UI/64  :-30  -25  -20  -15  -10  -5    0    5    10   15   20   25   30
display transceiver health命令用来显示光模块的健康度信息。
display transceiver health interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。不指定该参数,表示所有接口。
# 显示接口GigabitEthernet1/0/1上插入的可插拔光模块的健康度信息。
[Sysname] display transceiver health interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver health information:
LinkStatus health: 10
Transceiver health:
  Temp.    Voltage    Bias    RX power    TX power   Total
  10       10         10      10          10         10
表1-28 display transceiver health显示信息描述表
Transceiver health
接口的光模块健康度信息
LinkStatus health
链路健康度,其计算方法与错包率健康度有关:
·     当错包率健康度为1时,则链路健康度=1
·     当错包率健康度为2~9时:链路健康度=(接收光功率健康度+丢包率健康度)/2
·     当错包率健康度为10时,则链路健康度=(接收光功率健康度+10)/2+0.5的值取整
Temp
温度健康度
Voltage
电压健康度
Bias
偏置电流健康度
RX power
接收光功率健康度
TX power
发送光功率健康度
Total
接口的光模块总体健康度,计算方式为下方每一个元素健康度乘以对应权重值之和
·     transceiver health check enable
·     transceiver health weight
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
# 显示接口GigabitEthernet1/0/1上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface gigabitethernet 1/0/1
显示信息略……。
display transceiver manuinfo命令用于显示可插拔接口模块的电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口Ten-GigabitEthernet1/0/1上插入的可插拔接口模块的电子标签信息。
<Sysname> display transceiver manuinfo interface ten-gigabitethernet 1/0/1
显示信息略……。
display transceiver power命令用来显示可插拔光模块的功耗信息。
display transceiver power interface [ interface-type interface-number ]
interface interface-type interface-number:显示接口上插入的可插拔光模块的功耗信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示设备所有可插拔接口模块的功耗。
<Sysname> display transceiver power interface
Interface       Transceiver type         Current power(w)    Max power(w)
GE1/0/1         100G_BASE_SR4_QSFP28     2.30                3.50
GE1/0/2         100G_BASE_LR4_QSFP28     2.50                4.00
GE1/0/3         100G_BASE_ER4_QSFP28     3.51                5.00
GE1/0/4         Absent                   --                  --
GE1/0/5         100G_BASE_SR4_QSFP28     --                  --
GE1/0/6         10G_BASE_LR_SFP          --                  1.50
         10G_BASE_LR_SFP          1.00                --
Current total power  : 9.31w
Maximum total Power  : 15.5w
# 显示接口GigabitEthernet1/0/1上插入的可插拔接口模块的功耗。
<Sysname> display transceiver power interface gigabitethernet 1/0/1
GE1/0/1           10G_BASE_LR_SFP              1.00                1.50
表1-29 display transceiver power命令信息显示描述表
接口简称
Transceiver type
模块类型
Current power(w)
当前功耗,单位为w,精确到0.01w
Max power(w)
最大功耗,单位为w,精确到0.01w
Current total power
当前总功耗,单位为w,精确到0.01w
Max total power
最大总功耗,单位为w,精确到0.01w
display version命令用来显示系统版本信息。
display version
# 查看系统版本信息。
<Sysname> display version
显示信息略……。
display version-update-record命令用来显示启动软件包版本更新操作的记录。
设备启动时会记录当前使用的启动软件包版本信息,如果在运行过程中进行启动软件包版本更新操作,系统会记录该次更新的简要信息,包括升级时间和版本,以便管理员了解相关信息。设备重启这些记录也不会被删除。
# 显示设备启动软件包版本更新操作的记录。
<Sysname> display version-update-record
Record 1  (updated on Apr 18 2015 at 06:23:54):
 *Name        : boot-test.bin
  Version     : 7.1.070 Test 0001
  Compile time: Mar 25 2015 15:52:43
 *Name        : system-test.bin
表1-30 display version-update-record命令显示信息描述表
Record n (updated on Apr 18 2014 at 06:23:54)
最近的第n次更新时间,最多显示10次。Record 1为最新的一次更新
*Name
软件包的名称。带*符号,表示软件包的版本和升级前的版本有变化;不带*符号,表示版本没有变化
Version
软件包的版本号
Compile time
版本编译时间
·     reset version-update-record
dying-gasp host命令用来配置接收断电告警的目的主机的参数。
undo dying-gasp host命令用来取消指定目的主机参数的配置。
dying-gasp host { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] snmp-trap version { v1 | v2c | v3 [ authentication | privacy ] } securityname security-string
dying-gasp host { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] syslog
undo dying-gasp host { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] { snmp-trap | syslog }
未配置接收断电告警的目的主机的参数。
ip-address:接收断电告警的目的主机的IPv4地址。
ipv6 ipv6-address:接收断电告警的目的主机的IPv6地址。
vpn-instance vpn-instance-name:指定目的主机所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示目的主机位于公网中。
snmp-trap:表示以SNMP Trap形式发送断电告警。
version:表示以SNMP Trap形式发送断电告警的版本信息:
·     v1:SNMPv1版本。
·     v2c:SNMPv2c版本。
·     v3:SNMPv3版本。不指定authentication和privacy参数时,表示不认证不加密。
¡     authentication:表示对报文进行认证但不加密。
¡     privacy:表示对报文进行认证和加密。
securityname security-string:表示SNMP安全字,为SNMPv1、SNMPv2c的团体名或SNMPv3的用户名,为1~32个字符的字符串。
syslog:表示以日志形式发送断电告警。
SNMP Trap和日志的形式可同时配置,也可只配置一种。
多次配置该命令可指定多个目的主机,使得设备可以向多个主机发送断电告警信息。
配置向网管发送SNMP v3 Trap形式的断电告警信息时,必须使用snmp-agent usm-user命令创建对应的SNMP v3用户,且用户所属组的认证级别必须与本命令中配置的认证级别一致,用户的认证加密参数配置必须和网管侧配置一致。否则,设备无法给网管发送SNMP v3 Trap形式的断电告警信息。
# 配置向1.1.1.1发送SNMP v1 Trap形式的断电告警信息,使用的SNMP安全字为public。
[Sysname] dying-gasp host 1.1.1.1 snmp-trap version v1 securityname public
·     dying-gasp source
·     display dying-gasp host
dying-gasp source命令用来配置发送断电告警的源接口。
undo dying-gasp source命令用来恢复缺省情况。
dying-gasp source interface-type interface-number
未配置发送断电告警的源接口。在IPv4网络中,设备将使用报文出接口的主IPv4地址作为发送断电告警报文的源IP地址;在IPv6网络中,设备自动选择断电告警报文的源IPv6地址,具体选择原则请参见RFC 3484。
interface-type interface-number:表示接口的类型和接口编号。
配置该命令后,系统会使用指定接口的主IPv4地址/IPv6地址作为发送断电告警报文的源IP地址。即便本设备使用不同的出端口发送Trap/日志报文,目的主机都可以使用该IP地址唯一标识本设备。
如果源接口下未配置IP地址,则该命令不生效,设备会仍使用报文出接口的主IP地址作为发送断电告警报文的源IP地址。在源接口配置了IP地址后,发送断电告警时,该配置会自动生效。
# 配置发送断电告警的源接口为M-GigabitEthernet0/0/0。
[Sysname] dying-gasp source M-GigabitEthernet 0/0/0
·     dying-gasp host
fan ignore-absent命令用来配置忽略风扇的Absent状态。
undo fan ignore-absent命令用来恢复缺省情况。
fan ignore-absent
设备不会忽略风扇的Absent状态。
系统会按周期轮询风扇的状态,当未检测到风扇时,系统会将风扇的状态标识为Absent,并输出日志和Trap信息,提醒用户尽快安装风扇,以免影响设备通风散热。如果设备安装了外置风扇,能正常通风散热,则可以使用本命令,忽略风扇的Absent状态,停止输出相应的日志和Trap信息。
# 忽略风扇的Absent状态。
[Sysname] fan ignore-absent
After you configure this command, the device does not provide traps or log messages when it detects that one or more fans are absent. You must make sure that the device is well-ventilated. Continue?[Y/N] y
hardware-alarm disable命令用来关闭硬件资源告警的发送功能。
hardware-alarm { syslog | trap } resource-type { all | board | bus | chip-channel | chip-port | device | disk | fan | interface | power | subcard | transceiver | voltage } disable
undo hardware-alarm { syslog | trap } resource-type { all | board | bus | chip-channel | chip-port |  device | disk | fan | interface | power | subcard | transceiver | voltage } disable
所有硬件资源告警的发送功能处于开启状态。
all:所有硬件资源告警信息的发送功能。
bus:与总线相关的资源告警信息的发送功能。
chip-channel:与芯片通道相关的资源告警信息的发送功能。
chip-port:与芯片端口相关的资源告警信息的发送功能。
device:与设备相关的资源告警信息的发送功能。
disk:与磁盘相关的资源告警信息的发送功能。
fan:与风扇相关的资源告警信息的发送功能。
interface:与接口相关的资源告警信息的发送功能。
syslog:硬件资源告警日志信息的发送功能。
Subcard:与子卡相关的资源告警信息的发送功能。
transceiver:与光模块相关的资源告警信息的发送功能。
trap:硬件资源告警Trap信息的发送功能。
power:与电源相关的资源告警信息的发送功能。
voltage:与电压相关的资源告警信息的发送功能。
# 关闭所有硬件的资源告警Trap信息的发送功能。
<Sysname> system
[Sysname] hardware-alarm trap resource-type all disable
# 关闭与设备相关的资源告警日志信息的发送功能。
<Sysname> system
[Sysname] hardware-alarm syslog resource-type device disable
1.1.51  header
header命令用来配置欢迎信息。
undo header命令用来取消配置的欢迎信息。
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
未配置欢迎信息。
legal:配置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:配置登录验证时的欢迎信息。
motd:配置登录终端界面前的欢迎信息。
shell:配置用户登录进入用户视图时的欢迎信息。
text:欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 配置legal欢迎信息。
[Sysname] header legal
Welcome to use the legal banner%
1.1.52  job
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
未为Schedule分配Job。
Schedule视图
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
·     scheduler job
·     scheduler schedule
locator blink blink-time命令用来定位设备的位置。
locator blink stop命令用来停止定位。
locator [ slot slot-number ] blink blink-time
locator [ slot slot-number ] blink stop
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示对所有设备进行操作。‌‌
blink-time:闪烁的持续时间,取值范围为5~120,单位为秒。
stop:停止闪烁。
配置locator blink blink-time命令后,指定设备上用于定位的LED灯会以间隔快闪的方式闪烁,并持续指定的时间。用户可根据LED灯的指示来定位设备所在的位置。
blink-time时间到或者执行locator blink stop命令,则定位闪烁的LED灯会恢复正常点亮状态。
# 开始定位。
<Sysname> locator blink 30
# 结束定位。
<Sysname> locator blink stop
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复缺省情况。
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
对于S5200-HI-G系列交换机,缺省情况下一级告警门限为190MB,二级告警门限为133MB,三级告警门限为76MB,系统恢复到正常的内存门限为247MB,预告警门限为304MB,预告警解除门限为342MB。
对于S5200-EI-G系列交换机,缺省情况下一级告警门限为56MB,二级告警门限为52MB,三级告警门限为48MB,系统恢复到正常的内存门限为64MB。
ratio:表示以百分比形式配置门限。不指定该参数时,表示配置的是门限的大小,单位为MB。
minor minor-value:一级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
severe severe-value:二级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
critical critical-value:三级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小。输入该参数的值时可通过输入?,来获取该参数的取值范围。
early-warning early-warning-value:预告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级别的告警功能。
仅S5200-HI-G系列交换机支持本参数。
secure secure-value:预告警恢复门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
系统实时监控剩余空闲内存大小,当条件达到一级、二级、三级告警门限或者恢复正常状态门限时,就产生相应的告警/告警解除通知,通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
设备监控的是系统内存中剩余空闲内存的大小,使用display memory命令可以查看系统内存的使用情况。
除了一级、二级、三级告警,设备还支持预告警功能。预告警门限用于内存使用率尚处于正常范围内,但需要提醒用户提前关注内存的情况。预告警恢复门限用于解除预告警。
关于告警门限的详细介绍请参见“基础配置指导”中的“设备管理”。
满足以下条件时,系统会重启设备。
·     产生三级告警后,剩余空闲内存值持续小于三级告警门限,其时长到达30秒,则系统会重启设备。
·     如果连续产生两次三级告警的时间间隔小于30秒,则系统会重启设备。
·     如果3分钟内产生三次三级告警,则系统会重启设备。
·     产生三级告警后,系统将会周期采样,预测剩余空闲内存是否会在30秒之内耗尽,如果预测结果为会在30秒之内耗尽,则系统会重启设备。
# 配置一级、二级、三级告警门限分别为64MB、48MB、32MB,当剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# 配置一级、二级、三级告警门限分别为设备总内存的3%、2%、1%,当剩余空闲内存大于设备总内存的5%时,恢复到正常状态。
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
·     display memory-threshold
memory-threshold dma命令用来配置DMA(Direct Memory Access,直接内存存取)内存告警阈值。
undo memory-threshold dma命令用来恢复缺省情况。
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
DMA内存告警阈值为2048KB,告警恢复阈值为4096KB
ratio:以百分比配置阈值。
critical critical-value:告警阈值。当指定ratio参数时,critical-value为百分比,取值范围为0~100;当不指定ratio参数时,critical-value单位为KB。
normal normal-value:告警恢复阈值。当指定ratio参数时,normal-value为百分比;当不指定ratio参数时,normal-value单位为KB。设备会根据critical-value的配置值自动调整normal-value的取值范围,请以设备的实际情况为准。
部分业务的运行需要使用DMA内存,如果DMA内存不足,会导致业务模块功能异常。系统周期监控DMA空闲内存大小:当DMA空闲内存小于或等于告警阈值,产生告警事件,表示DMA内存可能不足;当DMA空闲内存大于告警恢复阈值,产生告警解除事件,表示DMA内存充足。
# 配置Slot 1的DMA内存告警的阈值为32KB,告警恢复阈值为96KB。‌‌
[Sysname] memory-threshold dma slot 1 critical 32 normal 96
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
内存利用率阈值为100%。
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率阈值比较。当采样值大时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold usage 80
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
slot slot-number:表示设备在IRF中的成员编号,不指定表示主设备。‌‌
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
·     display cpu-usage configuration
·     display cpu-usage history
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
undo monitor cpu-usage interval命令用来恢复缺省情况。
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录采样周期为1分钟。
interval:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min,不区分大小写。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
1.1.59  monitor cpu-usage logging interval
monitor cpu-usage logging interval命令用来开启周期性输出CPU利用率日志功能。
undo monitor cpu-usage logging interval命令用来关闭周期性输出CPU利用率日志功能。
monitor cpu-usage logging interval interval-time
周期性输出CPU利用率日志功能处于关闭状态。
interval-time:周期性输出CPU利用率日志的时间间隔,取值为5~300中5的整数倍,单位为秒。
# 开启周期性输出CPU利用率日志信功能,且时间间隔为60秒。
[Sysname] monitor cpu-usage logging interval 60
1.1.60  monitor cpu-usage threshold
monitor cpu-usage threshold命令用来配置CPU利用率告警门限。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] }
undo monitor cpu-usage threshold { minor-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] | slot slot-number cpu cpu-number }
CPU利用率高级别告警门限为99%,低级别告警门限为80%,恢复门限为60%。
severe-threshold:CPU利用率高级别告警门限,取值范围为2~100,单位为百分比。
minor-threshold minor-threshold:CPU利用率低级别告警门限,取值范围为1~“severe-threshold的配置值减1”,单位为百分比。
recovery-threshold recovery-threshold:CPU利用率恢复门限,取值范围为0~“minor-threshold的配置值减1”,单位为百分比。
系统每隔1分钟会对CPU的利用率进行采样,并将采样值和用户配置的告警门限比较。当采样值大时,则认为利用率过高,设备会进行相应的处理。
# 配置CPU利用率高级别告警门限为90%,低级别告警门限为80%,恢复门限为70%。
[Sysname] monitor cpu-usage threshold 90 minor-threshold 80 recovery-threshold 70
1.1.61  monitor memory-usage logging interval
monitor memory-usage logging interval命令用来开启周期性输出内存利用率日志功能。
undo monitor memory-usage logging命令用来关闭周期性输出内存利用率日志功能。
monitor memory-usage logging interval interval-time
undo monitor memory- usage logging interval
周期性输出内存利用率日志功能处于关闭状态。
interval-time:周期性输出内存利用率日志的时间间隔,取值为5~300中5的整数倍,单位为秒。
# 开启周期性输出内存利用率日志信功能,且时间间隔为60秒。
[Sysname] monitor memory-usage logging interval 60
1.1.62  monitor resend cpu-usage
monitor resend cpu-usage命令用来配置发送CPU告警事件的间隔。
undo monitor resend cpu-usage命令用来取消CPU告警事件发送间隔的配置。
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
持续300秒超过低级别告警门限则上报一次CPU低级别告警事件,持续60秒超过高级别告警门限则上报一次CPU高级别告警事件。
minor-interval minor-interval:CPU低级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
severe-interval severe-interval:CPU高级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对CPU使用率进行采样,并将采样值与告警门限进行比较。当采样值从小于或等于变成大于某级别告警门限时,CPU将进入该级别告警状态并生成相应的告警事件。
CPU处于低级别告警状态时,会周期发送CPU低级别告警事件,直到CPU进入高级别告警状态或者低级别告警状态解除。CPU处于高级别告警状态时,会周期发送CPU高级别告警事件,直到高级别告警状态解除。使用本命令可以修改CPU告警事件的发送周期。
执行undo monitor resend cpu-usage命令不指定minor-interval和severe-interval参数时,表示将这两个参数恢复到缺省情况。当指定某个(些)参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0低级别告警事件的发送周期为60秒。‌‌
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
1.1.63  monitor resend memory-threshold
monitor resend memory-threshold命令用来配置发送内存告警事件的间隔。
undo monitor resend memory-threshold命令用来取消内存告警事件发送间隔的配置。
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
对于S5200-HI-G系列交换机,缺省情况下持续1小时超过预告警门限则上报一次预告警事件通知,持续12小时超过一级告警门限则上报一次一级告警事件通知,持续3小时超过二级告警门限则上报一次二级告警事件通知,持续1小时超过三级告警门限则上报一次三级告警事件通知。
对于S5200-EI-G系列交换机,缺省情况下持续12小时超过一级告警门限则上报一次一级告警事件通知,持续3小时超过二级告警门限则上报一次二级告警事件通知,持续1小时超过三级告警门限则上报一次三级告警事件通知。
critical-interval critical-interval:内存三级告警事件周期发送的间隔,取值范围1~48,单位为小时。
early-warning-interval early-warning-interval:内存预告警事件周期发送的间隔,取值范围1~48,单位为小时。
minor-interval minor-interval:内存一级告警事件周期发送的间隔,取值范围1~48,单位为小时。
severe-interval severe-interval:内存二级告警事件周期发送的间隔,取值范围1~48,单位为小时。
设备定期对内存剩余值进行采样,并将采样值与告警门限进行比较。当采样值从大于变成小于或等于某级别告警门限时,内存将进入该级别告警状态并生成相应的告警事件。
内存支持多个级别的告警,这些告警的严重程度从高到低依次为:内存三级告警、内存二级告警、内存一级告警、内存预告警。
内存处于低级别告警状态时,会周期发送内存低级别告警事件,直到设备进入更高级别告警状态或者低级别告警状态解除。内存处于高级别告警状态时,会周期发送内存高级别告警事件,直到高级别告警状态解除。使用本命令可以修改内存告警事件的发送周期。
执行undo monitor resend memory-threshold命令并不指定critical-interval、early-warning-interval、minor-interval和severe-interval参数时,表示将这些参数均恢复到缺省情况。当指定某个(些)参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0内存一级告警事件的发送周期为12小时。‌‌
[Sysname] monitor resend memory-threshold minor-interval 12 slot 1 cpu 0
1.1.64  monitor resend memory-threshold dma
monitor resend memory-threshold dma命令用来配置发送DMA内存告警事件的间隔。
undo monitor resend memory-threshold dma命令用来恢复缺省情况。
仅S5200-EI-G系列交换机支持本命令。
monitor resend memory-threshold dma critical-interval critical-interval [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold dma critical-interval [ slot slot-number [ cpu cpu-number ] ]
本命令的缺省情况与设备的型号有关,请以设备的实际情况为准。
DMA内存告警事件周期发送的间隔为300秒。
critical-interval:DMA内存告警事件周期发送的间隔,取值范围为10~3600,单位为秒。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示指定Master设备。‌‌
设备定期对DMA内存使用率进行统计,并将统计值与告警门限进行比较。当统计值从小于或等于变成大于告警门限时,DMA内存将进入该告警状态并生成告警事件。
# 配置发送DMA内存告警事件的间隔为100秒。
[Sysname] monitor resend memory-threshold dma critical-interval 100
1.1.65  parity-error consistency-check log enable
parity-error consistency-check log enable命令用来开启软硬件表项一致性检查日志信息功能。
undo parity-error consistency-check log enable命令用来关闭软硬件表项一致性检查日志信息功能。
软硬件表项一致性检查日志信息功能处于开启状态。
设备在运行过程中,会对转发芯片中的硬件表项和软件表项进行一致性检查。配置本命令后,在采样周期内,如果检查软硬件表项的不一致次数达到通过parity-error consistency-check threshold命令配置的错误次数阈值,则生成软硬件表项一致性检查日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启软硬件表项一致性检查日志信息功能。
[Sysname] parity-error consistency-check log enable
·     parity-error consistency-check threshold
·     parity-error consistency-check period
1.1.66  parity-error consistency-check period
parity-error consistency-check period命令用来配置软硬件表项一致性检查错误日志的发送周期。
undo parity-error consistency-check period命令用来恢复缺省情况
parity-error consistency-check period value
软硬件表项一致性检查错误日志的发送周期为3600秒。
value:表示软硬件表项一致性检查错误日志的发送周期,取值范围为600~31536000,单位为秒。
设备在运行过程中,会同时在转发芯片中生成硬件表项以及CPU内存中生成软件镜像表项用于指导报文转发。设备会自动检测这两个表项是否一致。配置本命令后,设备会按周期收集软硬件表项一致性检查错误发生的次数。建议将周期设置为大于3600秒。
# 配置软硬件表项一致性检查错误的日志发送周期为600秒。
[Sysname] parity-error consistency-check period 600
·     parity-error consistency-check log enable
1.1.67  parity-error consistency-check threshold
parity-error consistency-check threshold命令用来配置软硬件表项一致性检查的错误次数阈值。
undo parity-error consistency-check threshold命令用来恢复缺省情况。
parity-error consistency-check threshold value
软硬件表项一致性检查的错误次数阈值为10次。
value:表示软硬件表项一致性检查的错误次数阈值,取值范围为1~2147483647,单位为次数。
在开启软硬件表项一致性检查日志信息功能后,配置本命令后,设备在软硬件表项一致性检查错误次数的采样周期内,当检查到软硬件表项不一致的错误次数达到配置的阈值时,会生成软硬件表项一致性检查日志信息。
# 配置软硬件表项一致性检查的错误次数阈值为20次。
[Sysname] parity-error consistency-check threshold 20
1.1.68  parity-error monitor log enable
parity-error monitor log enable命令用来开启硬件表项奇偶校验和ECC校验日志信息功能。
undo parity-error monitor log enable命令用来关闭硬件表项奇偶校验和ECC校验日志信息功能。
硬件表项奇偶校验和ECC校验日志信息功能处于开启状态。
设备在运行过程中,会自动对转发芯片中硬件表项进行奇偶校验和ECC校验,并记录错误次数。配置本命令后,在通过parity-error monitor period命令配置的采样周期内,如果硬件表项的奇偶校验和ECC校验的错误次数达到通过parity-error monitor threshold命令配置的错误次数阈值,则生成硬件表项奇偶校验和ECC校验日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启硬件表项奇偶校验和ECC校验日志信息功能。
[Sysname] parity-error monitor log enable
·     parity-error monitor period
·     parity-error monitor threshold
1.1.69  parity-error monitor period
parity-error monitor period命令用来配置硬件表项奇偶校验和ECC校验错误次数的采样周期。
undo parity-error monitor period命令用来恢复缺省情况。
parity-error monitor period period
硬件表项奇偶校验和ECC校验错误次数的采样周期为60秒。
period:表示硬件表项奇偶校验和ECC校验错误次数的采样周期,取值范围为1~86400,单位为秒。
在开启硬件表项奇偶校验和ECC校验日志信息功能后,配置本命令后,设备在配置的硬件表项内,当硬件表项奇偶校验和ECC校验的错误次数达到阈值时,会生成硬件表项奇偶校验和ECC校验日志信息。
# 配置奇偶校验和ECC校验错误次数的采样周期为120秒。
[Sysname] parity-error monitor period 120
·     parity-error monitor log enable
1.1.70  parity-error monitor threshold
parity-error monitor threshold命令用来配置硬件表项奇偶校验和ECC校验的错误次数阈值。
undo parity-error monitor threshold命令用来恢复缺省情况。
parity-error monitor threshold value
硬件表项奇偶校验和ECC校验的错误次数阈值为5000次。
value:表示硬件表项奇偶校验和ECC校验的错误次数阈值,取值范围为1~1000000,单位为次数。
在开启硬件表项奇偶校验和ECC校验日志信息功能后,配置本命令后,设备在硬件表项奇偶校验和ECC校验错误次数的采样周期内,当校验错误次数达到配置的阈值时,会生成硬件表项奇偶校验和ECC校验日志信息。
# 配置硬件表项奇偶校验和ECC校验的错误次数阈值为8000次。
[Sysname] parity-error monitor threshold 8000
1.1.71  parity-error unrecoverable log enable
parity-error unrecoverable log enable命令用来开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
undo parity-error unrecoverable log enable命令用来关闭关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能处于开启状态。
设备在运行过程中,会对转发芯片中的硬件表项进行奇偶校验和ECC校验。在硬件表项奇偶校验和ECC校验发现错误时,会尝试恢复这些错误。配置本命令后,当一些关键硬件表项的校验错误不可恢复时,在通过parity-error unrecoverable period命令配置的采样周期内,如果关键硬件表项的校验错误不可恢复的次数达到通过parity-error unrecoverable threshold命令配置的不可恢复次数阈值,则会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
[Sysname] parity-error unrecoverable log enable
·     parity-error unrecoverable period
·     parity-error unrecoverable reboot
·     parity-error unrecoverable threshold
1.1.72  parity-error unrecoverable period
parity-error unrecoverable period命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期。
undo parity-error unrecoverable period命令用来恢复缺省情况。
parity-error unrecoverable period period
关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为60秒。
period:表示关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期,取值范围为1~86400,单位为秒。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在配置的采样周期内,当关键硬件表项奇偶校验和ECC校验错误的不可恢复次数达到阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为120秒。
[Sysname] parity-error unrecoverable period 120
·     parity-error unrecoverable log enable
1.1.73  parity-error unrecoverable reboot
parity-error unrecoverable reboot命令用来开启生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后设备自动重启功能。
undo parity-error unrecoverable reboot命令用来关闭生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后设备自动重启功能。
生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后设备自动重启。
如果设备转发芯片上关键硬件表项发生奇偶校验和ECC校验错误,且不可恢复时,可能会影响业务正常进行,则需要配置本命令,使设备通过重启来恢复关键硬件表项。
配置本命令后,当设备生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后,将自动重启。
# 开启生成关键硬件表项不可恢复日志信息后设备的自动重启功能。
[Sysname] parity-error unrecoverable reboot
1.1.74  parity-error unrecoverable threshold
parity-error unrecoverable threshold命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值。
undo parity-error unrecoverable threshold命令用来恢复缺省情况。
parity-error unrecoverable threshold value
关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为1。
value:表示关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值,取值范围为1~1000000,单位为次数。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期内,当校验错误不可恢复次数达到配置的阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为10。
[Sysname] parity-error unrecoverable log threshold 10
1.1.75  password-recovery enable
password-recovery enable命令用来开启密码恢复功能。
undo password-recovery enable命令用来关闭密码恢复功能。
密码恢复功能处于开启状态。
清除认证密码的操作必须在主设备的启动过程中进入BootWare菜单进行。‌
BootWare菜单中支持配置的选项与密码恢复功能的配置有关,详见设备的版本说明书。
# 关闭密码恢复功能。
[Sysname] undo password-recovery enable
1.1.76  push-button mode enable
push-button mode enable命令用来开启Mode按键的特殊动作功能。
undo push-button mode enable用来恢复缺省情况。
仅S5200-EI-G系列支持一键上云指示灯的机型支持本命令。
Mode按键的特殊动作功能处于关闭状态。
缺省情况下,设备前面板的Mode按键和“端口模式指示灯”、“端口状态指示灯”相结合,可以从不同角度详细显示端口的工作状态,从而使用户获取更多的设备信息。按压Mode按键时长不同,效果不同:
·     按压0~5秒钟:切换“端口状态指示灯”显示的端口状态类型。
·     按压5秒钟以上:无效果。
执行本命令后,使“端口状态指示灯模式切换按钮”可以执行一键上云动作,按压“端口状态指示灯模式切换按钮”的效果如下:
·     5秒钟以内:维持原功能,用于切换“端口状态指示灯”显示的端口信息。
·     5~10秒钟:执行一键上云动作。设备会与云平台建立连接,一键上云指示灯以1Hz的频率闪烁蓝灯代表连接建立中,连接建立完成后,管理员可以手动将设备添加至云平台,此时一键上云指示灯蓝色长亮。如果设备已经与云平台建立连接,则按压5~10秒钟会使设备断开与云平台的连接,此时一键上云指示灯长灭。
·     10秒钟以上:不执行任何动作,相当于没有按下按键。当长按至10秒钟时,一键上云指示灯会以3Hz的频率闪烁一次蓝灯以提示。
# 开启Mode按键的特殊动作功能。
[Sysname] push-button mode enable
1.1.77  reboot
reboot命令用来重启设备。
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,会重启整个IRF。‌‌
force:强制重启:
·     不指定该参数时,重启设备,系统会做一些保护性检查(如启动文件是否存在,是否正在写磁盘等),若检查不通过则退出处理,不会重启设备;
·     指定该参数时,系统将不进行任何检查,直接执行重启操作。
·     重新启动可能会导致业务中断,请谨慎使用该命令。
如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
重启主设备时,如果备设备不存在,会重启整个IRF;如果备设备存在并稳定运行,会引起主备倒换。当系统中有成员设备处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响IRF和成员设备的运行。可使用display system stable state命令来显示IRF的稳定状态。
# 重启设备,并保存配置文件。‌‌
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# 强制重启设备。
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
·     display system stable state
1.1.78  reset scheduler logfile
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
·     display scheduler logfile
1.1.79  reset version-update-record
reset version-update-record命令用来清除启动软件包版本更新操作的记录。
# 清除设备启动软件包版本更新操作的记录。
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
·     display version-update-record
1.1.80  resource-monitor minor resend enable
resource-monitor minor resend enable命令用来开启周期发送低级别资源告警通知功能。
undo resource-monitor minor resend enable命令用来关闭周期发送低级别资源告警通知功能。
周期发送低级别资源告警通知功能处于开启状态。
如果剩余的资源小于或等于低级别告警门限且大于高级别告警门限,则资源进入低级别告警状态,并生成低级别告警通知。
当资源一直处于低级别告警状态时:
·     开启周期发送低级别资源告警通知功能后,第一次达到低级别告警状态时,会生成低级别告警通知,后续还会周期生成低级别告警通知。当剩余资源达到更高级别告警门限时,将会生成更高级别的告警通知,暂时抑制低级别的告警通知。直到高级别的告警状态解除,再周期输出低级别的告警通知。
·     关闭周期发送低级别资源告警通知功能后,只有第一次达到低级别告警状态时,才生成低级别告警通知,不会连续生成低级别告警通知。
高级别告警通知重发功能一直处于开启状态,不能通过命令行配置。
高级别告警通知的重发周期是24小时,低级别告警通知的重发周期是7x24小时,不能配置。
# 开启周期发送低级别资源告警通知功能。
<sysname> system-view
[Sysname] resource-monitor minor resend enable
·     display resource-monitor
·     resource-monitor output
1.1.81  resource-monitor output
resource-monitor output命令用来配置资源告警通知的输出方向。
undo resource-monitor output命令用来关闭资源告警通知的输出方向。
undo resource-monitor output [ netconf-event | snmp-notification | syslog ]*
资源告警通知会同时向NETCONF、SNMP、信息中心三个方向输出。
netconf-event:将资源告警通知输出到NETCONF模块。
syslog:将资源告警通知输出到信息中心模块。
snmp-notification:将资源告警通知输出到SNMP模块。
设备会实时监控一些重要资源的是使用情况,当达到指定门限时,设备会生成对应的资源告警通知,这些通知可以输出到以下三个方向:
·     NETCONF模块。通过配置NETCONF模块的参数,可以将资源告警通知以NETCONF事件的形式发送给用户。关于NETCONF的详细介绍请参见“网络管理和监控配置指导”中的“NETCONF”。
·     信息中心模块。通过配置信息中心模块的参数,可以将资源告警通知以系统日志的形式发送给用户。关于信息中心的详细介绍请参见“网络管理和监控配置指导”中的“信息中心”。
·     SNMP模块。通过配置SNMP模块的参数,可以将资源告警通知以Trap或者Inform消息的形式发送给用户。关于SNMP的详细介绍请参见“网络管理和监控配置指导”中的“SNMP”。
执行undo resource-monitor output命令,并且不指定可选参数时,表示资源告警通知不会向NETCONF、SNMP、信息中心三个方向输出。
# 将资源告警通知输出到信息中心模块。
[Sysname] resource-monitor output syslog
1.1.82  resource-monitor resource
resource-monitor resource命令用来配置生成资源告警通知的门限。
undo resource-monitor resource命令用来取消资源告警通知的门限配置。
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
不同类型资源的缺省情况不同,请使用display resource-monitor命令查看。
resource-name:需要监测的资源的名称,不区分大小写,需要完整输入参数的值。参数的取值请参见下表。
表1-31 设备可监测的资源描述表
取值
含义
agg_group
聚合组资源
agg_member
聚合组成员端口资源
arp
ARP表项资源
ecmpgroup
等价路由组资源
egs_acl
出方向acl资源
egs_counter
出方向counter资源
egs_meter
出方向meter资源
igs_acl
入方向acl资源
igs_counter
入方向counter资源
igs_meter_0
入方向meter资源
input_flowrate
入方向报文速率资源
ipmc
三层组播复制表资源
ipv6
IPv6路由表项资源
l2mc
VLAN内组播复制表资源
mac
MAC地址表项资源
mqcin
入方向MQC资源
mqcout
出方向MQC资源
nd
ND表项资源
nexthoppool1
Underlay下一跳资源池资源
openflow
OpenFlow资源
output_flowrate
出方向报文速率资源
pbr
PBR资源
pfilterin
入方向包过滤资源
pfilterout
出方向包过滤资源
route
路由表项资源
rport
三层以太网接口资源
stg
STP实例资源
vlaninterface
VLAN接口资源
vrf
VPN实例资源
slot slot-number:表示监测指定成员设备上的资源。slot-number表示设备在IRF中的成员编号。‌
cpu cpu-number:表示监测指定CPU上的资源。cpu-number表示在CPU的编号。
by-percent:以百分比的方式配置告警门限。
minor-threshold minor-threshold:低级别告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
severe-threshold severe-threshold:高级别告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
配置本命令后,设备会监测资源的剩余情况,周期采样监测对象的值,并和配置的告警门限进行比较。当达到条件时,设备会生成告警通知。
# 配置slot 1上ARP资源的低级别门限为30%,高级别门限为10%。‌‌
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent  minor-threshold 30 severe-threshold 10
1.1.83  restore factory-default
restore factory-default命令用来将设备恢复到出厂状态。
使用本命令会将设备恢复到出厂状态,请谨慎使用。
当设备使用场景更改,或者设备出现故障时,可以使用本命令来将设备恢复到出厂状态。
# 将设备恢复到出厂状态。
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
·     reboot
1.1.84  scheduler job
scheduler job命令用来创建Job,并进入Job视图。如果指定的Job已存在,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
不存在Job。
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
·     command
1.1.85  scheduler logfile size
scheduler logfile size命令用来配置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户配置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 配置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
1.1.86  scheduler reboot at
scheduler reboot at命令用来配置设备重启的具体时间和日期。
undo scheduler reboot命令用来取消定时重启配置。
未配置设备重启的具体时间和日期。
time:设备重启的时间,格式为HH:MM。HH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     YYYY的取值范围为2000~2035;
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
本命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
如果没有指定date参数,并且:
·     配置的时间点在当前时间之后,则设备将在当天的该时间点重启;
·     配置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot at、scheduler reboot delay命令,最后一次执行的命令生效。
# 假设系统的当前时间为2015年6月6日11:43,配置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
1.1.87  scheduler reboot delay
scheduler reboot delay命令用来配置重启设备的延迟时间。
scheduler reboot delay time
未配置重启设备的延迟时间。
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
·     使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2015年6月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
1.1.88  scheduler schedule
scheduler schedule命令用来创建Schedule,并进入相应的Schedule视图。如果指定的Schedule已存在,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
不存在Schedule。
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1)     使用scheduler job命令创建Job。
(2)     在Job视图下,使用command命令配置需要执行的命令。
(3)     使用scheduler schedule命令创建Schedule。
(4)     在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5)     在Schedule视图下,使用user-role命令为Schedule配置用户角色。一个Schedule下最多可以分配64个角色。
(6)     在Schedule视图下,使用time at、time once或者time repeating命令来配置任务执行的时间。一个Schedule下只能配置一个执行时间。
# 创建名为saveconfig的Schedule。
·     job
·     time at
·     time once
1.1.89  shutdown-interval
shutdown-interval命令用来配置端口状态检测定时器的时长。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval interval
端口状态检测定时器的时长为30秒。
interval:端口状态检测定时器的时长,取值范围为0~300,单位为秒。取值为0时,表示系统不自动检测端口状态,需要用户执行undo shutdown命令手动恢复端口状态。
应用场景
在开启环路检测功能的网络中,当环路检测的处理模式被设置为“Shutdown模式”后。若设备检测到端口出现环路,会自动关闭该端口并启动一个检测端口状态的定时器。有关环路检测功能的相关介绍,请参见“二层技术-以太网交换配置指导”中的“环路检测”。
在开启BPDU保护功能的网络中,若边缘端口收到了BPDU,则系统就将这些端口关闭并启动一个检测端口状态的定时器,同时通知网管这些端口已被生成树协议关闭。有关BPDU保护功能的相关介绍,请参见“二层技术-以太网交换配置指导”中的“生成树”。
工作机制
如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,系统会自动将端口恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口的时间间隔为T。
·     若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
·     若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被生成树协议关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被生成树协议关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置端口状态检测定时器的时长为100秒。
[Sysname] shutdown-interval 100
·     loopback-detection action(二层技术-以太网交换命令手册/环路检测)
·     loopback-detection global action(二层技术-以太网交换命令手册/环路检测)
·     stp bpdu-protection(二层技术-以太网交换命令手册/生成树)
·     stp port bpdu-protection(二层技术-以太网交换命令手册/生成树)
1.1.90  sysid
sysid命令用来配置设备的网元信息。
undo sysid命令用来恢复缺省情况。
sysid system-id
undo sysid
未配置设备的网元信息。
system-id:表示设备的网元信息,可用于表示设备的位置信息、功能信息、用户自定义的名字标记等。
# 配置网元信息为position-hall,表明设备位置在大厅。
[Sysname] sysid positon-hall
1.1.91  sysname
sysname命令用来配置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备的名称为H3C。
sysname:设备名称,为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 配置设备的名称为R2000。
[Sysname] sysname R2000
[R2000]
1.1.92  temperature-limit
temperature-limit命令用于配置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
temperature-limit slot slot-number hotspot sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number
不同温度传感器的温度门限可能不同,请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看设备的缺省温度告警门限。
slot slot-number:配置指定成员设备上温度传感器的温度门限。slot-number表示设备在IRF中的成员编号。‌‌
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
sensor-number:温度传感器的编号,输入该参数的值时可通过输入?,来获取该参数的取值范围。
lowlimit:低温告警门限,单位为摄氏度。不同温度传感器的低温告警门限取值范围不同,输入该参数的值时可通过输入?,来获取该参数的取值范围。
warninglimit:一般级高温告警门限,单位为摄氏度,必须大于低温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
alarmlimit:严重级高温告警门限,单位为摄氏度,必须大于一般级高温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
如果温度低于低温告警门限、高于一般级或严重级高温门限,系统均会生成相应的日志信息和告警信息提示用户,并通过设备面板上的指示灯来告警,以便用户及时进行处理。
# 配置指定slot上热点1号温度传感器,低温门限为-10摄氏度,一般级高温门限为50摄氏度,严重级高温门限为60摄氏度。‌‌
[sysname] temperature-limit slot 1 hotspot 1 -10 50 60
·     display environment
1.1.93  time at
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
未为Schedule配置执行时间。
Schedule视图
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time at、time once或time repeating命令时,最后一次执行的命令生效。
# 配置2015年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
1.1.94  time once
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
未为Schedule配置执行时间。
Schedule视图
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
1.1.95  time repeating
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval
undo time
未配置重复执行Schedule的时间。
Schedule视图
at time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
interval interval:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
·     使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
1.1.96  transceiver health check enable
transceiver health check enable命令用来开启光模块健康度检测功能。
undo transceiver health check enable命令用来关闭光模块健康度检测功能。
光模块健康度检测功能处于关闭状态。
# 开启光模块健康度检测功能。
[Sysname] transceiver health check enable
·     display transceiver health
1.1.97  transceiver health weight
transceiver health weight命令用来配置光模块健康度的计算权重。
undo transceiver health命令用来恢复缺省情况。
transceiver health weight temp temp-weight voltage volage-weight bias bias-weight rxpower rxpower-weight txpower txpower-weight
undo transceiver health weight
光模块健康度的计算权重如下:temp权重值为15,voltage权重值为5,bias权重值为30,rxpower权重值为10,txpower权重值为40。
temp temp-weight:表示光模块的温度在健康度中的计算权重,取值范围为1~96。
voltage volage-weight:表示光模块的电压在健康度中的计算权重,取值范围为1~96。
bias bias-weight:表示光模块的偏置电流在健康度中的计算权重,取值范围为1~96。
rxpower rxpower-weight:表示光模块的发送光功率健康度在健康度中的计算权重,取值范围为1~96。
txpower txpower-weight:表示光模块的接收光功率健康度在健康度中的计算权重,取值范围为1~96。
本命令可配置用于光模块健康度检测计算的5个诊断参数的计算权重。诊断参数分别为temp、voltage、bias、rxpower和txpower。
光模块健康度的各个诊断参数的计算权重值之和必须为100。
# 配置光模块健康度的计算权重,temp、voltage、bias、rxpower和txpower的计算权重值均为20。
[Sysname] transceiver health weight temp 20 voltage 20 bias 20 rxpower 20 txpower 20
1.1.98  transceiver monitor enable
transceiver monitor enable命令用来开启光模块监控功能。
undo transceiver monitor enable命令用来关闭光模块监控功能。
光模块监控功能处于关闭状态。
开启光模块监控功能后,设备会按周期检查光模块的参数(例如光模块的输出功率、输入功率等),当参数的采样值达到软件设定的阈值时,会生成相应的日志提醒用户。
# 使能光模块监控功能。
[Sysname] transceiver monitor enable
·     transceiver monitor interval
1.1.99  transceiver monitor interval
transceiver monitor interval命令用来配置光模块的监控周期。
undo transceiver monitor interval命令用来恢复缺省情况。
transceiver monitor interval interval
光模块的监控周期是600秒。
interval:表示光模块的监控周期,取值范围为300~3600,单位为秒。
开启光模块监控功能后,本命令才生效。
# 配置光模块监控周期为500秒。
[Sysname] transceiver monitor interval 500
·     transceiver monitor enable
1.1.100  transceiver rx-power high-threshold
transceiver rx-power high-threshold命令用来配置光模块接收功率告警上限。
undo transceiver rx-power high-threshold命令用来恢复缺省情况。
transceiver rx-power high-threshold power-value
未配置光模块接收功率告警上限。
以太网接口视图
power-value:表示光模块接收功率的告警阈值,单位为dBm,精度为0.01。不同型号的光模块支持的取值范围不同,请以光模块的实际情况为准。
工作机制
通过执行transceiver rx-power high-threshold命令,用户可以在光模块接收功率的固有预警门限和固有告警门限范围内设置告警阈值。当光模块接收功率超过用户设置的告警阈值时,系统将打印告警信息。例如,当前光模块的告警上限范围为3.00dBm~5.00dBm,用户可以设置告警上限为4.40dBm。
可以通过display transceiver diagnosis命令查看光模块的告警门限值,确保设置的告警阈值配置成功。
注意事项
本功能仅适用于支持数字诊断功能的SFP、SFP+系列光模块,且不适用于400G ZR光模块、400G ZR+光模块和光转电模块。
当光模块为多通道模块,则配置对所有通道生效。
# 设置GigabitEthernet1/0/1上插入的光模块接收功率的告警上限为4.40dBm。
[Sysname-GigabitEthernet1/0/1] transceiver rx-power high-threshold 4.40
·     display transceiver diagnosis
·     transceiver rx-power change-threshold
·     transceiver rx-power low-threshold
1.1.101  transceiver rx-power low-threshold
transceiver rx-power low-threshold命令用来配置光模块接收功率告警下限。
undo transceiver rx-power low-threshold命令用来恢复缺省情况。
transceiver rx-power low-threshold power-value
未配置光模块接收功率告警下限。
以太网接口视图
工作机制
通过执行transceiver rx-power low-threshold命令,用户可以在光模块接收功率的固有预警门限和固有告警门限范围内设置告警阈值。当光模块接收功率低于用户设置的告警阈值时,系统将打印告警信息。例如,当前光模块的告警下限范围为-14.00dBm~-11.00dBm,用户可以设置告警下限为-13.00dBm。
可以通过display transceiver diagnosis命令查看光模块的告警阈值,确保设置的告警阈值配置成功。
注意事项
# 设置GigabitEthernet1/0/1上插入的光模块接收功率的告警下限为-13.00dBm。
[Sysname-GigabitEthernet1/0/1] transceiver rx-power low-threshold -13.00
·     transceiver rx-power high-threshold
1.1.102  transceiver rx-power change-threshold
transceiver rx-power change-threshold命令用来配置光模块接收功率变化幅值的告警阈值。
undo transceiver rx-power change-threshold命令用来恢复缺省情况。
transceiver rx-power change-threshold power-value
光模块接收功率变化幅值的告警阈值为5.00dBm。
以太网接口视图
power-value:表示光模块接收功率变化幅值的告警阈值,单位为dBm,精度为0.01。不同型号的光模块支持的取值范围不同,请以光模块的实际情况为准。
应用场景
通过设置光模块接收功率变化幅值的告警阈值,系统能够在光模块接收功率发生显著变化时及时提供告警。
工作机制
光模块在链路首次启动并稳定后的初始接收光功率被设定为基准值。执行transceiver rx-power change-threshold命令后,系统将周期性地检查光模块的发送光功率。如果发现接收光功率相对于基准值的变化超过用户设定的阈值,系统将判断为接收光功率发生了重大变化,从而触发告警。例如,用户设置的告警阈值为20.00dBm,链路首次启动并稳定后的初始接收光功率为-15.00dBm,若当前接收光功率降到-36.00dBm或升高到6.00dBm时,系统会触发告警。
注意事项
# 设置GigabitEthernet1/0/1上插入的光模块接收功率变化幅值的告警阈值为4.00dBm。
[Sysname-GigabitEthernet1/0/1] transceiver rx-power change-threashold 4.00
1.1.103  transceiver tx-power high-threshold
transceiver tx-power high-threshold命令用来配置光模块发送功率告警上限。
undo transceiver tx-power high-threshold命令用来恢复缺省情况。
transceiver tx-power high-threshold power-value
未配置光模块发送功率告警上限。
以太网接口视图
power-value:表示光模块发送功率的告警阈值,单位为dBm,精度为0.01。
工作机制
通过执行transceiver tx-power high-threshold命令,用户可以在光模块发送功率的固有预警门限和固有告警门限范围内设置告警阈值。当光模块发送功率超过用户设置的告警阈值时,系统将打印告警信息。例如,当前光模块的告警上限范围为3.00dBm~5.00dBm,用户可以设置告警上限为4.40dBm。
注意事项
# 设置GigabitEthernet1/0/1上插入的光模块发送功率的告警上限为4.40dBm。
[Sysname-GigabitEthernet1/0/1] transceiver tx-power high-threshold 4.40
·     transceiver tx-power change-threshold
·     transceiver tx-power low-threshold
1.1.104  transceiver tx-power low-threshold
transceiver tx-power low-threshold命令用来配置光模块发送功率告警下限。
undo transceiver tx-power low-threshold命令用来恢复缺省情况。
transceiver tx-power low-threshold power-value
未配置光模块发送功率告警下限。
以太网接口视图
工作机制
通过执行transceiver tx-power low-threshold命令,用户可以在光模块发送功率的固有预警门限和固有告警门限范围内设置告警阈值。当光模块发送功率低于用户设置的告警阈值时,系统将打印告警信息。例如,当前光模块的告警下限范围为-14.00dBm~-11.00dBm,用户可以设置告警下限为-13.00dBm。
注意事项
# 设置GigabitEthernet1/0/1上插入的光模块发送功率的告警下限为-13.00dBm。
[Sysname-GigabitEthernet1/0/1] transceiver tx-power low-threshold -13.00
·     transceiver tx-power high-threshold
1.1.105  transceiver tx-power change-threshold
transceiver tx-power change-threshold命令用来配置光模块发送功率变化幅值的告警阈值。
undo transceiver tx-power change-threshold命令用来恢复缺省情况。
transceiver tx-power change-threshold power-value
光模块发送功率变化幅值的告警阈值为4.00dBm。
以太网接口视图
power-value:表示光模块发送功率变化幅值的告警阈值,单位为dBm,精度为0.01。不同型号的光模块支持的取值范围不同,请以光模块的实际情况为准。
应用场景
通过设置光模块发送功率变化幅值的告警阈值,系统能够在光模块发送功率发生显著变化时及时提供告警。
工作机制
光模块在链路首次启动并稳定后的初始发送光功率被设定为基准值。执行transceiver tx-power change-threshold命令后,系统将周期性地检查光模块的发送光功率。如果发现发送光功率相对于基准值的变化超过用户设定的阈值,系统将判断为发送光功率发生了重大变化,从而触发告警。例如,用户设置的告警阈值为20.00dBm,链路首次启动并稳定后的初始发送光功率为-15.00dBm,若当前发送光功率降到-36.00dBm或升高到6.00dBm时,系统会触发告警。
注意事项
# 设置GigabitEthernet1/0/1上插入的光模块发送功率变化幅值的告警阈值为5.00dBm。
[Sysname-GigabitEthernet1/0/1] transceiver tx-power change-threashold 5.00
1.1.106  usb disable
usb disable命令用来关闭USB接口。
undo usb disable命令用来开启USB接口。
usb disable
undo usb disable
设备上所有的USB接口处于开启状态。
用户可通过USB口进行文件的上传和下载。缺省状态下USB口处于开启状态,用户可根据需要关闭USB口。
在执行usb disable命令前,请先使用umount命令卸载所有USB分区,否则命令执行失败。有关umount命令的详细介绍,请参见“基础配置命令参考”中的“文件系统管理”。
# 打开USB接口。
[Sysname] undo usb disable
1.1.107  user-role
user-role命令用来配置执行Schedule时使用的用户角色。
undo user-role命令用来将已经配置的用户角色从Schedule中删除。
user-role role-name
undo user-role role-name
执行Schedule时使用的用户角色,为创建该Schedule的用户的用户角色。
Schedule视图
role-name:用户角色的名称,为1~63个字符的字符串,区分大小写。可以是系统预定义的角色名称,包括network-admin、network-operator、level-0~level-15,也可以是自定义的用户角色名称。
设备支持的每条命令执行时都需要相应的用户角色。只有本命令中配置的用户角色具有权限,Schedule中的command命令中指定的命令行才能执行。关于用户角色的详细描述请参见“基础配置指导”中的“RBAC”。
同一Schedule最多可配置64个用户角色,超过该上限后,新配置会执行失败。
# 配置执行定时任务test时使用的用户角色为rolename。
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
·     command
