11-网络管理和监控命令参考
15-VCF Fabric命令
本章节下载: 15-VCF Fabric命令  (200.95 KB)
15-VCF Fabric命令
1 VCF Fabric
1.1  VCF Fabric配置命令
1.1.1  display vcf-fabric role
display vcf-fabric role命令用来查看设备在VCF Fabric中的角色。
设备在VCF Fabric中的角色可通过vcf-fabric role命令进行配置,配置后的角色可以通过本命令查看。
# 查看设备在VCF Fabric中的角色。
<System> display vcf-fabric role
Default role: access
Current role: access
表1-1 display vcf-fabric role命令显示信息描述表
Default role
设备缺省的VCF Fabric角色
Current role
设备当前配置的VCF Fabric角色
1.1.2  display vcf-fabric underlay autoconfigure
display vcf-fabric underlay autoconfigure命令用来查看Underlay网络的自动化配置信息。
通过模板文件进行Underlay网络的自动配置后,可通过本命令查看Underlay网络的自动化配置信息。
# 查看Underlay网络自动化配置信息。
<Sysname> display vcf-fabric underlay autoconfigure
success command:
          system
          clock timezone beijing add 08:00:00
          system
          lldp global enable
          lldp compliance cdp
          system
          ospf 1
          graceful-restart ietf
          area 0.0.0.0
          system
          interface LoopBack0
          system
          l2vpn enable
          system
          vxlan tunnel arp-learning disable
          system
          stp global enable
          system
          ntp-service enable
          ntp-service unicast-peer 172.16.1.136
          system
          netconf soap https enable
          restful https enable
          system
          info-center loghost 172.16.1.136
          system
          local-user aaa
          password ******
          service-type https
          system
          line vty 0 63
          authentication-mode scheme
          system
          bgp 100
          graceful-restart
          address-family l2vpn evpn
          system
          vcf-fabric topology enable
          system
          neutron
          rabbit user openstack
          rabbit password ******
          rabbit host ip 172.16.1.136
          restful user aaa password ******
          vpn-target 1:1 export-extcommunity
          vsi-mac 789c-2f5f-0200
          network-type distributed-vxlan
          proxy-arp enable
          l2agent enable
          l3agent enable
          system
          snmp-agent
          snmp-agent packet max-size 4096
          snmp-agent community read public
          snmp-agent community write private
          snmp-agent sys-info version all
Uplink interface:
        Ten-GigabitEthernet1/0/1
        Ten-GigabitEthernet1/0/2
Downlink interface:
        Ten-GigabitEthernet1/0/3
        Ten-GigabitEthernet1/0/4
AP-side interfaces:
        GigabitEthernet1/0/7
        GigabitEthernet1/0/8
Loopback0 IP allocation:
        Device_MAC         Loopback_IP       Management_IP     State
        a43c-adae-0400     200.1.1.6         172.16.1.193      Up
        a43c-9aa7-0100     200.1.1.4         172.16.1.152      Up
Loopback1 IP allocation:
        a43c-adae-0400     100.1.1.6         172.16.1.193      Up
        a43c-9aa7-0100     100.1.1.4         172.16.1.152      Up
Aggregation configuration:
        AggrID: 7
        interface: Ten-GigabitEthernet1/0/5
        interface: Ten-GigabitEthernet1/0/6
IRF allocation:
        Self Bridge Mac: a43c-adae-0400
        IRF Status: Yes
        Member List: [1, 2]
BGP peer configuration:
        Device_MAC: 265b-208d-0300
        Device_role:leaf
        BGP peer list:
                200.1.4.5
        Device_MAC: 1ea6-06a4-0500
        Device_role:spine
        BGP peer list:
                200.1.4.4
                200.1.4.7
        Device_MAC: 1ead-aed1-0600
        Device_role:leaf
        BGP peer list:
                200.1.4.5
        Device_role:leaf
        BGP peer list:
                200.1.4.5
        Device_role:spine
        BGP peer list:
                200.1.4.4
                200.1.4.7
        Device_role:leaf
        BGP peer list:
                200.1.4.5
表1-2 display vcf-fabric underlay autoconfigure命令显示信息描述表
success command
配置自动化过程中,已经成功执行的命令行
Uplink interface
设备的上行口
Downlink interface
设备的下行口
AP-side interfaces
设备连接AP的接口
为Loopback接口分配的IP地址列表
为Loopback1接口分配的IP地址列表
Aggregation configurations
二层聚合组信息
IRF allocation
IRF配置信息,包括:IRF的桥MAC地址、IRF状态和成员设备编号
BGP配置信息,当组网为spine-aggr-leaf三层拓扑时,仅在master spine设备上显示,显示信息包含所有spine和leaf设备的bgp peer信息
·     vcf-fabric underlay autoconfigure
1.1.3  display vcf-fabric underlay template-version
display vcf-fabric underlay template-version命令用来查看VCF Fabric自动配置功能支持的模板版本和当前自动部署使用的模板版本。
通过此命令查看到的VCF Fabric自动配置功能支持的模板版本为最高版本,格式为“x.y”。实际部署时,采用的模板版本中的“x”可小于等于最高版本;若大于最高版本,可能导致通过模板文件进行自动部署失败。模板版本中的“y”取值不影响兼容性,不同取值仅对应不同的静态配置组合。
# VCF Fabric的Underlay自动部署未启动时,查看模板版本。
<Sysname> display vcf-fabric underlay template-version
Supported template version: 14.0
Current template version: Not available
# VCF Fabric的Underlay自动部署完成后,查看模板版本。
Supported template version: 1.0
Current template version: 1.0
表1-3 display vcf-fabric underlay template-version命令显示信息描述表
支持的模板版本
当前运行的模板版本
·     若显示为Not available表示Underlay自动部署未启动
·     若显示为None表示Underlay自动部署已完成,但模板未包含版本号
1.1.4  vcf-fabric topology enable
vcf-fabric topology enable命令用来开启VCF Fabric网络拓扑发现功能。
undo vcf-fabric topology enable命令用来关闭VCF Fabric网络拓扑发现功能。
VCF Fabric网络拓扑发现功能处于关闭状态。
# 开启VCF Fabric网络拓扑发现功能。
[Sysname] vcf-fabric topology enable
1.1.5  vcf-fabric underlay autoconfigure
vcf-fabric underlay autoconfigure命令用来采用指定的模板文件进行Underlay网络的自动配置。
undo vcf-fabric underlay autoconfigure命令用来取消自动化配置。
vcf-fabric underlay autoconfigure template
未指定进行Underlay网络自动配置的模板文件。
template:模板文件名,以“.template”为后缀,从存储介质名称开始包括后缀名最多可输入127个字符,不区分大小写。
用户预先通过TFTP等方式将模板文件保存到本地设备,执行本命令后,设备将采用指定的模板文件进行Underlay网络的自动配置。
执行undo vcf-fabric underlay autoconfigure命令取消自动化配置后,如果再次使用vcf-fabric underlay autoconfigure重新指定模板文件,会导致Spine分配给Leaf设备的Loopback IP地址变化,从而使Leaf设备暂时下线再重新上线。
# 采用模板文件vlan_leaf.template进行Underlay网络的自动配置。
[Sysname] vcf-fabric underlay autoconfigure vlan_leaf.template
1.1.6  vcf-fabric underlay netconf-username
vcf-fabric underlay netconf-username命令用来设置Spine设备通过Netconf收集全局拓扑时使用的用户名。
undo vcf-fabric underlay netconf-username命令用来恢复缺省情况。
vcf-fabric underlay netconf-username username
Spine设备通过Netconf收集全局拓扑时,使用模板文件中定义的用户名。
username:Spine设备通过Netconf收集全局拓扑时使用的用户名,为1~63个字符的字符串,区分大小写。
在VCF Fabric组网中,Underlay网络自动化部署时,Spine设备使用模板中定义的用户名和密码与Underlay网络中的设备建立Netconf连接,通过Netconf收集全局拓扑信息。自动化部署完成后,若用户手动更改Underlay网络设备上的用户名或密码,会导致Spine设备与其断开Netconf连接,Spine设备无法感知Underlay网络的拓扑变化。此时,可以在Spine设备上执行本命令修改Netconf操作使用的用户名,使其与Underlay网络设备上的用户名保持一致,并重新建立Netconf连接,以便进行拓扑收集。
在VCF Fabric组网中,所有Underlay网络设备上用于建立Netconf连接的用户名和密码必须相同。
# 设置Spine设备通过Netconf收集全局拓扑时,使用的用户名为aaa。
[Sysname] vcf-fabric underlay netconf-username aaa
1.1.7  vcf-fabric underlay netconf-password
vcf-fabric underlay netconf-password命令用来设置Spine设备通过Netconf收集全局拓扑时使用的密码。
undo vcf-fabric netconf-underlay password命令用来恢复缺省情况。
vcf-fabric underlay netconf-password { cipher | simple } string
undo vcf-fabric underlay netconf-password
Spine设备通过Netconf收集全局拓扑时,使用模板文件中定义的密码。
cipher:以密文方式设置密码。
simple:以明文方式设置密码,该密码将以密文形式存储。
string:Spine设备通过Netconf收集全局拓扑时使用的密码,区分大小写。明文密码为1~63个字符的字符串;密文密码为1~127个字符的字符串。
在VCF Fabric组网中,Underlay网络自动化部署时,Spine设备使用模板中定义的用户名和密码与Underlay网络中的设备建立Netconf连接,通过Netconf收集全局拓扑信息。自动化部署完成后,若用户手动更改Underlay网络设备上的用户名或密码,会导致Spine设备与其断开Netconf连接,Spine设备无法感知Underlay网络的拓扑变化。此时,可以在Spine设备上执行本命令修改Netconf操作使用的密码,使其与Underlay网络设备上的密码保持一致,并重新建立Netconf连接,以便进行拓扑收集。
# 设置Spine设备通过Netconf收集全局拓扑时,使用的密码为明文aaa。
[Sysname] vcf-fabric underlay netconf-password simple aaa
1.1.8  vcf-fabric underlay pause
vcf-fabric underlay pause命令用来暂停Underlay网络的自动配置功能。
undo vcf-fabric underlay pause命令用来重新启动Underlay网络的自动配置功能。
Underlay网络的自动配置功能处于非暂停状态。
设备已经启动Underlay网络的自动配置功能后,可利用本命令暂停自动配置功能。
# 暂停Underlay网络的自动配置功能。
<sysname> system-view
[sysname] vcf-fabric underlay pause
