19-WLAN RRM命令
本章节下载: 19-WLAN RRM命令 (848.07 KB)
1.1.1 adjacent-channel interference trap threshold
1.1.3 adjacency-factor radio-selection
1.1.5 calibrate-bandwidth mode
1.1.6 calibrate-bandwidth monitoring time-range
1.1.7 calibrate-bandwidth self-decisive
1.1.8 calibrate-channel 2.4g channel-set-optimization enable
1.1.9 calibrate-channel 2.4g channel-set-optimization neighbor-threshold
1.1.10 calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent
1.1.11 calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent-per-set
1.1.12 calibrate-channel 2.4g channel-usage-threshold
1.1.13 calibrate-channel 2.4g crc-error-threshold
1.1.14 calibrate-channel 2.4g interference-threshold
1.1.15 calibrate-channel 2.4g noise-threshold
1.1.16 calibrate-channel 2.4g receive-service-traffic threshold
1.1.17 calibrate-channel 2.4g retransmission-threshold
1.1.18 calibrate-channel 2.4g tolerance-level
1.1.19 calibrate-channel 5g channel-usage-threshold
1.1.20 calibrate-channel 5g crc-error-threshold
1.1.21 calibrate-channel 5g interference-threshold
1.1.22 calibrate-channel 5g noise-threshold
1.1.23 calibrate-channel 5g receive-service-traffic threshold
1.1.24 calibrate-channel 5g retransmission-threshold
1.1.25 calibrate-channel 5g tolerance-level
1.1.26 calibrate-channel 6g channel-usage-threshold
1.1.27 calibrate-channel 6g crc-error-threshold
1.1.28 calibrate-channel 6g interference-threshold
1.1.29 calibrate-channel 6g noise-threshold
1.1.30 calibrate-channel 6g receive-service-traffic threshold
1.1.31 calibrate-channel 6g retransmission-threshold
1.1.32 calibrate-channel 6g tolerance-level
1.1.33 calibrate-channel channel-set-optimization
1.1.34 calibrate-channel channel-set-optimization neighbor-threshold
1.1.35 calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent
1.1.36 calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent-per-set
1.1.37 calibrate-channel interference–threshold
1.1.39 calibrate-channel monitoring time-range
1.1.40 calibrate-channel pronto
1.1.41 calibrate-channel receive-service-traffic threshold
1.1.42 calibrate-channel scheduled enable
1.1.43 calibrate-channel scheduled time
1.1.44 calibrate-channel self-decisive
1.1.45 calibrate-channel self-decisive sensitivity
1.1.46 calibrate-channel suppression
1.1.47 calibrate-channel track spectrum-analysis
1.1.48 calibrate-power 2.4g adjacency-factor
1.1.49 calibrate-power 2.4g coverage rssi-threshold
1.1.50 calibrate-power 2.4g coverage weak-signal-client ratio
1.1.51 calibrate-power 2.4g coverage weak-signal-client threshold
1.1.52 calibrate-power 2.4g coverage weak-signal-packet ratio
1.1.53 calibrate-power 2.4g coverage weak-signal-packet threshold
1.1.54 calibrate-power 2.4g threshold
1.1.55 calibrate-power 5g adjacency-factor
1.1.56 calibrate-power 5g coverage rssi-threshold
1.1.57 calibrate-power 5g coverage weak-signal-client ratio
1.1.58 calibrate-power 5g coverage weak-signal-client threshold
1.1.59 calibrate-power 5g coverage weak-signal-packet ratio
1.1.60 calibrate-power 5g coverage weak-signal-packet threshold
1.1.61 calibrate-power 5g threshold
1.1.62 calibrate-power 6g adjacency-factor
1.1.63 calibrate-power 6g coverage rssi-threshold
1.1.64 calibrate-power 6g coverage weak-signal-client ratio
1.1.65 calibrate-power 6g coverage weak-signal-client threshold
1.1.66 calibrate-power 6g coverage weak-signal-packet ratio
1.1.67 calibrate-power 6g coverage weak-signal-packet threshold
1.1.68 calibrate-power 6g threshold
1.1.69 calibrate-power coverage enable
1.1.70 calibrate-power mode { coverage | custom | density }
1.1.71 calibrate-power mode { periodic | scheduled }
1.1.72 calibrate-power monitoring time-range
1.1.73 calibrate-power power-range
1.1.74 calibrate-power self-decisive
1.1.75 calibrate-power threshold
1.1.77 channel-usage-threshold
1.1.78 co-channel interference trap threshold
1.1.81 display wlan calibrate-channel pronto history
1.1.82 display wlan rrm baseline
1.1.83 display wlan rrm baseline apply-history
1.1.84 display wlan rrm high-density filter history
1.1.85 display wlan rrm-calibration-group
1.1.86 display wlan rrm-history ap
1.1.87 display wlan rrm-status ap
1.1.92 snmp-agent trap enable wlan rrm
1.1.94 wlan calibrate-bandwidth pronto ap
1.1.95 wlan calibrate-bandwidth pronto use-monitoring-data ap
1.1.96 wlan calibrate-channel pronto ap
1.1.97 wlan calibrate-channel pronto use-monitoring-data ap
1.1.98 wlan calibrate-power pronto ap
1.1.99 wlan calibrate-power pronto use-monitoring-data ap
1.1.100 wlan rrm baseline apply
1.1.101 wlan rrm baseline remove
1.1.102 wlan rrm baseline save
1.1.103 wlan rrm calibration-bandwidth interval
1.1.104 wlan rrm calibration-channel ap
1.1.105 wlan rrm calibration-channel interval
1.1.106 wlan rrm calibration-power interval
1.1.107 wlan rrm high-density filter
1.1.108 wlan rrm-calibration-group
adjacent-channel interference trap threshold命令用来配置邻频干扰告警阈值。
undo adjacent-channel interference trap threshold命令用来恢复缺省情况。
adjacent-channel interference trap threshold threshold
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承AP组全局Radio RRM配置。
AP组全局Radio RRM视图:继承全局配置。
全局配置视图:邻频干扰告警阈值为60dBm。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
threshold threshold:邻频干扰告警阈值,取值范围为10~90,单位为dBm。
由于邻频干扰越高越影响用户正常使用,所以可以通过配置本命令设置邻频干扰告警阈值,当邻频干扰超过一定阈值后,设备会向网络管理系统发送trap告警信息,通知网络管理员消除干扰,以保证用户可以正常使用。
# 配置邻频干扰告警阈值为16。(RRM视图)
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] rrm
[Sysname-wlan-ap-ap1-radio-1-rrm] adjacent-channel interference trap threshold 16
# 配置邻频干扰告警阈值为16。(AP组RRM视图)
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] ap-model WA6320
[Sysname-wlan-ap-group-group1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1] rrm
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] adjacent-channel interference trap threshold 16
# 配置邻频干扰告警阈值为16。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1] radio 5g
[Sysname-wlan-ap-group-group1-radio-5g] rrm
[Sysname-wlan-ap-group-group1-radio-5g-rrm] adjacent-channel interference trap threshold 16
# 配置邻频干扰告警阈值为16。(全局配置视图)
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] adjacent-channel interference trap threshold 16
· co-channel interference trap threshold
adjacency-factor命令用来配置邻居因子。
undo adjacency-factor命令用来恢复缺省情况。
adjacency-factor neighbor
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
neighbor:邻居因子,取值范围为1~16。
邻居因子既作为功率比较门限,也用于在功率比较时选择一个功率值来和功率调整门限进行比较。
· 功率比较门限:当检测到Radio信息的其它Radio的数目达到功率比较门限,AC才会进行功率比较,判断出是否调整Radio的功率。否则,将Radio的发射功率调整为最大发射功率。以邻居因子等于3为例,则当检测到Radio信息的其它Radio的数目达到3个时,AC才会进行功率比较。
· 选择用于功率比较的功率值:功率比较时,AC会将其它Radio检测到的该Radio功率值进行从大到小排序后,挑选出排名与邻居因子相同的功率值,即,如果邻居因子为3,则选择排名第3位的功率值来和功率调整门限进行比较。
RRM视图下配置的优先级高于AP组RRM视图下的配置,AP组RRM视图下配置的优先级高于全局视图下的配置。
# 配置邻居因子为7。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] adjacency-factor 7
# 配置邻居因子为7。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] adjacency-factor 7
adjacency-factor radio-selection命令用来配置参与邻居因子计算的邻居选择方式。
undo adjacency-factor radio-selection命令用来恢复缺省情况。
adjacency-factor radio-selection { all-channel | overlapping-channel }
RRM视图:继承AP组RRM配置。
AP组RRM视图:参与邻居因子计算的邻居选择方式为全信道邻居选择。
RRM视图
AP组RRM视图
all-channel:全信道邻居选择方式。
overlapping-channel:频谱交叠邻居选择方式。
全信道邻居选择方式可以更严格的控制信号覆盖范围;频谱交叠邻居选择方式可以更精确的调整功率大小,在不对其它有频谱交集的信道造成更多干扰的同时,可以扩大信号的覆盖范围。
参与邻居因子计算的邻居选择方式有两种:全信道邻居选择与频谱交叠邻居选择。
· 全信道邻居选择:在所有支持的信道上捕获到本Radio所发射无线信号的同一AC管理的其它Radio,计算邻居因子时将依据这些Radio的邻居报告。
· 频谱交叠邻居选择:在有频谱交集的信道上捕获到本Radio所发射无线信号的同一AC管理的其它Radio,计算邻居因子时将依据这些Radio的邻居报告。
# 配置参与邻居因子计算的邻居选择方式为频谱交叠邻居选择。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] adjacency-factor radio-selection overlapping-channel
# 配置参与邻居因子计算的邻居选择方式为频谱交叠邻居选择。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] adjacency-factor radio-selection overlapping-channel
ap name命令用来将指定的Radio加入到RRM保持调整组中。
undo ap name用来删除RRM保持调整组中的Radio。
ap name ap-name radio radio-id
undo ap { name ap-name [ radio radio-id ] | all }
RRM保持调整组中不存在任何AP的Radio。
RRM保持调整组视图
name ap-name:加入RRM保持调整组的AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
radio radio-id:将AP的射频加入RRM保持调整组,其中radio-id为射频编号。如果未指定本参数,则删除RRM保持调整组中指定AP的所有射频。
all:删除RRM保持调整组中的所有射频。
加入RRM保持调整组的Radio必须已经存在。
一个Radio只能加入一个RRM保持调整组,将Radio加入到新的RRM保持调整组中,则原先的RRM保持调整组会删除该Radio。
# 将ap1的Radio 2加入到ID为10的RRM保持调整组中。
[Sysname] wlan rrm-calibration-group 10
[Sysname-wlan-rrm-calibration-group-10] ap name ap1 radio 2
calibrate-bandwidth mode命令用来配置自动频宽调整模式。
undo calibrate-bandwidth mode命令用来恢复缺省情况。
RRM视图/AP组RRM视图/AP组全局Radio RRM视图:
calibrate-bandwidth mode { periodic | scheduled }
全局配置视图:
calibrate-bandwidth { 5g | 6g } mode { periodic | scheduled }
undo calibrate-bandwidth { 5g | 6g } mode
RRM视图:继承AP组RRM配置。
全局配置视图:自动频宽调整模式为周期性调整。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
periodic:周期性调整。
scheduled:定时调整。
5g:配置所有AP的5GHz频段射频的自动频宽调整模式。
6g:配置所有AP的6GHz频段射频的自动频宽调整模式。
周期性调整模式下,AC按用户设置的调整周期重复进行信道质量检测,根据检测结果评估是否需要进行频宽调整。
定时调整模式下,设备在指定的时间段收集信道质量信息,而后进行信道质量的评估并决定是否调整频宽。
# 配置自动频宽调整模式为定时调整。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-bandwidth self-decisive enable
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-bandwidth mode scheduled
# 配置自动频宽调整模式为定时调整。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-bandwidth self-decisive enable
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-bandwidth mode scheduled
# 配置自动频宽调整模式为定时调整。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1-radio-5g-rrm] calibrate-bandwidth self-decisive enable
[Sysname-wlan-ap-group-group1-radio-5g-rrm] calibrate-bandwidth mode scheduled
# 配置5GHz频段射频的自动频宽调整模式为定时调整。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-bandwidth 5g mode scheduled
calibrate-bandwidth monitoring time-range命令用来为频宽调整功能指定收集环境信息的时间段。
undo calibrate-bandwidth monitoring time-range命令用来取消为频宽调整功能指定收集环境信息的时间段。
calibrate-bandwidth monitoring time-range time-range-name
全局配置视图:
calibrate-bandwidth { 5g | 6g } monitoring time-range time-range-name
undo calibrate-bandwidth { 5g | 6g } monitoring time-range
RRM视图:继承AP组RRM配置。
AP组全局 Radio RRM视图:继承全局配置。
全局配置视图:未指定用于收集射频环境信息的时间段。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
time-range-name:指定时间段的名称,为1~63个字符的字符串,不区分大小写。为避免混淆,时间段的名称不允许使用英文单词all。
5g:配置所有AP的5GHz频段射频收集射频环境信息的时间段。
6g:配置所有AP的6GHz频段射频收集射频环境信息的时间段。
为频宽调整功能指定收集环境信息的时间段后,AC将在指定的时间段内收集射频环境信息,并生成信道报告与邻居报告,为频宽调整提供依据。
# 为频宽调整功能指定收集环境信息的时间段,该时间段名称为time1。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-bandwidth monitoring time-range time1
# 为频宽调整功能指定收集环境信息的时间段,该时间段名称为time1。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-bandwidth monitoring time-range time1
# 为频宽调整功能指定收集环境信息的时间段,该时间段名称为time1。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1-radio-5g-rrm] calibrate-bandwidth monitoring time-range time1
# 为5GHz频段频宽调整功能指定收集环境信息的时间段,该时间段名称为time1。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-bandwidth 5g monitoring time-range time1
calibrate-bandwidth self-decisive enable命令用来开启自动频宽调整。
calibrate-bandwidth self-decisive disable命令用来关闭自动频宽调整。
undo calibrate-bandwidth self-decisive命令用来恢复缺省情况。
calibrate-bandwidth self-decisive { disable | enable }
全局配置视图:
calibrate-bandwidth self-decisive enable { 5g | 6g | all }
undo calibrate-bandwidth self-decisive enable { 5g | 6g | all }
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承AP组全局Radio RRM视图。
全局配置视图:自动频宽调整处于关闭状态。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
5g:开启或关闭所有AP的5GHz频段射频的自动频宽调整功能。
6g:开启或关闭所有AP的6GHz频段射频的自动频宽调整功能。
all:开启或关闭所有AP的5GHz和6GHz频段射频的自动频宽调整功能。
当某射频的邻居Radio数量过多时,需要降低频宽,以减少干扰;当某射频的邻居Radio数量较少时,需要增大频宽,以提高数据传输速率。增大频宽或减小频宽是通过将相邻的信道绑定或拆分完成的。
开启自动频宽调整后,AC在每一个自动频宽调整周期到达时,都会开始频宽调整流程。
本命令仅对5GHz和6GHz频段射频生效。
# 开启自动频宽调整。(RRM视图)
# 开启自动频宽调整。(AP组RRM视图)
# 开启自动频宽调整。(AP组全局Radio RRM视图)
# 开启所有AP的5GHz频段射频的自动频宽调整功能。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-bandwidth self-decisive enable
calibrate-channel 2.4g channel-set-optimization enable命令用来开启2.4GHz射频的正交信道优选功能。
undo calibrate-channel 2.4g channel-set-optimization enable命令用来关闭2.4GHz射频的正交信道优选功能。
2.4GHz射频的正交信道优选功能处于开启状态。
全局配置视图
在某些高密场景中,可能部署了多个厂商的无线AP设备。由于不同厂商的AP不能统一管理、规划(例如:不同厂商的AP使用了不同的正交信道组),会造成2.4GHz射频的工作信道相互产生干扰,极大地影响了用户的使用体验。
通过本命令开启2.4GHz射频的正交信道优选功能后,AC设备将根据该射频检测到的邻居以及非管理邻居的工作信道情况来选取第三方厂商AP使用的最优正交信道组。当AC设备进行自动信道调整时,就会使用第三方厂商AP使用的最优正交信道组进行信道调整,最大程度地降低不同厂商AP之间的工作信道干扰。
设备支持选取5组正交信道组,分别为(1、6、11)、(1、7、13)、(2、7、12)、(3、8、13)、(4、9、14)。
射频邻居类型包括如下两种:
· 管理邻居:表示当前射频检测到的同一AC下的其他AP Radio。
· 非管理邻居:表示当前射频检测到的非同一AC下的其他AP Radio。
满足以下所有条件时,设备将会对当前2.4GHz射频进行正交信道组优选:
· 2.4GHz射频检测到的总邻居数量达到或超过配置的阈值。
· 2.4GHz射频检测到的非管理邻居的占比(非管理邻居数/总邻居数)达到或超过配置的阈值。
· 2.4GHz射频检测到的单个正交信道组的非管理邻居占比(单个正交信道组的非管理邻居数/总邻居数)达到或超过配置的阈值。
# 关闭所有AP的2.4GHz射频的正交信道优选功能。
[Sysname-wlan-global-configuration] undo calibrate-channel 2.4g channel-set-optimization enable
· calibrate-channel 2.4g channel-set-optimization neighbor-threshold
· calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent
· calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent-per-set
· calibrate-channel channel-set-optimization
· calibrate-channel channel-set-optimization neighbor-threshold
· calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent
· calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent-per-set
calibrate-channel 2.4g channel-set-optimization neighbor-threshold命令用来配置2.4GHz射频正交信道优选功能的邻居数阈值。
undo calibrate-channel 2.4g channel-set-optimization neighbor-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g channel-set-optimization neighbor-threshold count
2.4GHz射频正交信道优选功能的邻居数阈值为10。
全局配置视图
count:2.4GHz射频正交信道优选功能的邻居数阈值,取值范围为1~1000。
# 配置所有AP的2.4GHz射频正交信道优选功能的邻居数阈值为11。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g channel-set-optimization neighbor-threshold 11
· calibrate-channel 2.4g channel-set-optimization enable
calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent命令用来配置2.4GHz射频正交信道优选功能的非管理邻居占比阈值。
undo calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent命令用来恢复缺省情况。
calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent percent
2.4GHz射频正交信道优选功能的非管理邻居占比阈值为50。
全局配置视图
percent:2.4GHz射频正交信道优选功能的非管理邻居占比阈值,取值范围为1~100,单位为百分比。
# 配置所有AP的2.4GHz射频正交信道优选功能的非管理邻居占比阈值为20%。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent 20
calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent-per-set命令用来配置2.4GHz射频正交信道优选功能的单个正交信道组的非管理邻居占比阈值。
undo calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent-per-set命令用来恢复缺省情况。
calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent-per-set percent
2.4GHz射频正交信道优选功能的单个正交信道组的非管理邻居占比阈值为10。
全局配置视图
percent:2.4GHz射频正交信道优选功能的单个正交信道组的非管理邻居占比阈值,取值范围为1~100,单位为百分比。
# 配置所有AP的2.4GHz射频正交信道优选功能的单个正交信道组的非管理邻居占比阈值为20%。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent-per-set 20
calibrate-channel 2.4g channel-usage-threshold命令用来配置2.4GHz频段信道使用率门限值。
undo calibrate-channel 2.4g channel-usage-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g channel-usage-threshold percent percent
undo calibrate-channel 2.4g channel-usage-threshold percent
2.4GHz频段信道使用率门限值为60。
全局配置视图
percent percent:信道使用率门限值,以百分比表示,取值范围为1~100。
在满足以下所有条件时,设备将进行信道质量计算:
· 射频口在当前信道收发的报文占报文处理能力的百分比达到门限值;
· 干扰在信道使用率中的占比达到门限值;
· 射频接收流量中业务流量未达到设定的阈值。
# 配置所有AP的2.4GHz频段信道使用率门限值为40。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g channel-usage-threshold percent 40
· calibrate-channel 2.4g interference-threshold
· calibrate-channel 2.4g receive-service-traffic threshold
calibrate-channel 2.4g crc-error-threshold命令用来配置2.4GHz频段信道的CRC错误门限值。
undo calibrate-channel 2.4g crc-error-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g crc-error-threshold percent
2.4GHz频段信道的CRC错误门限值为0。
全局配置视图
percent:CRC错误门限值,取值范围为0~100,单位为百分比。取值为0时表示自动信道调整不考虑CRC错误门限值。
CRC错误门限值是触发自动信道调整的条件之一。当AC检测到2.4GHz频段信道中CRC错误的帧占所有802.11帧的百分比达到或超过设定值时,将触发自动信道调整。
RRM视图下CRC错误门限值配置的优先级高于AP组RRM视图下的配置,AP组RRM视图下CRC错误门限值配置的优先级高于全局视图下的配置。
# 配置所有AP的2.4GHz频段信道的CRC错误门限值为10,即CRC错误率达到或超过10%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g crc-error-threshold 10
· crc-error-threshold
calibrate-channel 2.4g interference-threshold命令用来配置2.4GHz频段干扰在信道使用率中的占比门限值。
undo calibrate-channel 2.4g interference-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g interference-threshold percent percent
undo calibrate-channel 2.4g interference-threshold percent
2.4GHz频段干扰在信道使用率中的占比门限值为70。
全局配置视图
percent percent:干扰在信道使用率中的占比门限值,以百分比表示,取值范围为0~100。
增大门限值将降低自动信道调整的概率,减小门限值将提高自动信道调整的概率。
# 配置所有AP的2.4GHz频段干扰在信道使用率的占比门限值为50%。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g interference-threshold percent 50
· calibrate-channel 2.4g channel-usage-threshold
calibrate-channel 2.4g noise-threshold命令用来配置2.4GHz频段信道噪声门限值。
undo calibrate-channel 2.4g noise-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g noise-threshold value
2.4GHz频段信道噪声门限值为0。
全局配置视图
value:噪声门限值,取值范围为0~127,代表功率范围为0~-127dBm,即噪声门限值越大,表示的噪声越小。取值为0时表示自动信道调整不考虑噪声因素。
噪声门限值是触发自动信道调整的条件之一。当AC检测到2.4GHz频段信道中的噪声达到或超过设定的门限值时,将触发自动信道调整。
# 配置所有AP的2.4GHz频段信道噪声门限值为50,即噪声达到或超过-50dBm时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g noise-threshold 50
calibrate-channel 2.4g receive-service-traffic threshold命令用来配置2.4GHz频段射频接收流量中业务流量阈值。
undo calibrate-channel 2.4g receive-service-traffic threshold命令用来恢复缺省情况。
calibrate-channel 2.4g receive-service-traffic threshold value
2.4GHz频段射频接收流量中业务流量阈值为10Mbps。
全局配置视图
threshold value:业务流量阈值,取值范围为0~1000,单位为Mbps。
设备对AP的2.4GHz频段射频接收的流量进行判断。若接收流量中的业务流量达到设定的阈值,则表示终端与射频间的流量为正常的业务流量;若未达到设定的阈值,则表示射频接收了大量的干扰流量,需要对当前的工作信道进行调整。
# 配置所有AP的2.4GHz频段射频接收流量中业务流量阈值为30Mbps。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g receive-service-traffic threshold 30
calibrate-channel 2.4g retransmission-threshold命令用来配置2.4GHz频段信道重传门限值。
undo calibrate-channel 2.4g retransmission-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g retransmission-threshold value
2.4GHz频段信道重传门限值为0。
全局配置视图
value:重传门限值,取值范围为0~100,单位为百分比。取值为0时表示自动信道调整不考虑重传因素。
重传是触发自动信道调整的条件之一。当AC检测到2.4GHz频段信道的重传率达到或超过设定的门限值时,将触发自动信道调整。
# 配置所有AP的2.4GHz频段信道重传门限值为50,即重传率达到或超过50%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g retransmission-threshold 50
calibrate-channel 2.4g tolerance-level命令用来配置2.4GHz频段信道的容限系数。
undo calibrate-channel 2.4g tolerance-level命令用来恢复缺省情况。
calibrate-channel 2.4g tolerance-level percent
2.4GHz频段信道的容限系数为1。
全局配置视图
percent:容限系数,取值范围为0~100,单位为百分比。取值为0时表示2.4GHz频段信道在进行自动信道调整时不考虑容限系数。
容限系数为信道调整前后,两信道的信道质量差值。
AC开始计算信道质量后,只有在备选信道质量优于当前信道且达到或超过容限系数时,备选信道才会被应用。
RRM视图下容限系数配置的优先级高于AP组RRM视图下的配置,AP组RRM视图下容限系数配置的优先级高于全局视图下的配置。
# 配置所有AP的2.4GHz频段信道的容限系数为10,即两信道的信道质量差值达到或超过10时进行信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g tolerance-level 10
· tolerance-level
calibrate-channel 5g channel-usage-threshold命令用来配置5GHz频段信道使用率门限值。
undo calibrate-channel 5g channel-usage-threshold命令用来恢复缺省情况。
calibrate-channel 5g channel-usage-threshold percent percent
undo calibrate-channel 5g channel-usage-threshold percent
5GHz频段信道使用率门限值为60。
全局配置视图
# 配置所有AP的5GHz频段信道使用率门限值为40。
[Sysname-wlan-global-configuration] calibrate-channel 5g channel-usage-threshold percent 40
· calibrate-channel 5g interference-threshold
· calibrate-channel 5g receive-service-traffic threshold
calibrate-channel 5g crc-error-threshold命令用来配置5GHz频段信道的CRC错误门限值。
undo calibrate-channel 5g crc-error-threshold命令用来恢复缺省情况。
calibrate-channel 5g crc-error-threshold percent
5GHz频段信道的CRC错误门限值为0。
全局配置视图
CRC错误门限值是触发自动信道调整的条件之一。当AC检测到5GHz频段信道中CRC错误的帧占所有802.11帧的百分比达到或超过设定值时,将触发自动信道调整。
# 配置所有AP的5GHz频段信道的CRC错误门限值为10,即CRC错误率达到或超过10%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 5g crc-error-threshold 10
calibrate-channel 5g interference-threshold命令用来配置5GHz频段干扰在信道使用率中的占比门限值。
undo calibrate-channel 5g interference-threshold命令用来恢复缺省情况。
calibrate-channel 5g interference-threshold percent percent
undo calibrate-channel 5g interference-threshold percent
5GHz频段干扰在信道使用率中的占比门限值为70。
全局配置视图
# 配置所有AP的5GHz频段干扰在信道使用率的占比门限值为50%。
[Sysname-wlan-global-configuration] calibrate-channel 5g interference-threshold percent 50
· calibrate-channel 5g channel-usage-threshold
calibrate-channel 5g noise-threshold命令用来配置5GHz频段信道噪声门限值。
undo calibrate-channel 5g noise-threshold命令用来恢复缺省情况。
calibrate-channel 5g noise-threshold value
5GHz频段信道噪声门限值为0。
全局配置视图
value:噪声门限值,取值范围为0~127,代表功率范围为0~-127dBm,即噪声门限值越大,表示噪声越小。取值为0时表示自动信道调整不考虑噪声因素。
噪声门限值是触发自动信道调整的条件之一。当AC检测到5GHz频段信道中的噪声达到或超过设定的门限值时,将触发自动信道调整。
# 配置所有AP的5GHz频段信道噪声门限值为50,即噪声达到或超过-50dBm时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 5g noise-threshold 50
calibrate-channel 5g receive-service-traffic threshold命令用来配置5GHz频段射频接收流量中业务流量阈值。
undo calibrate-channel 5g receive-service-traffic threshold命令用来恢复缺省情况。
calibrate-channel 5g receive-service-traffic threshold value
5GHz频段射频接收流量中业务流量阈值为10Mbps。
全局配置视图
设备对AP的5GHz频段射频接收的流量进行判断。若接收流量中的业务流量达到设定的阈值,则表示终端与射频间的流量为正常的业务流量;若未达到设定的阈值,则表示射频接收了大量的干扰流量,需要对当前的工作信道进行调整。
# 配置所有AP的5GHz频段射频接收流量中业务流量阈值为30Mbps。
[Sysname-wlan-global-configuration] calibrate-channel 5g receive-service-traffic threshold 30
calibrate-channel 5g retransmission-threshold命令用来配置5GHz频段信道重传门限值。
undo calibrate-channel 5g retransmission-threshold命令用来恢复缺省情况。
calibrate-channel 5g retransmission-threshold value
5GHz频段信道重传门限值为0。
全局配置视图
重传是触发自动信道调整的条件之一。当AC检测到5GHz频段信道的重传率达到或超过设定的门限值时,将触发自动信道调整。
# 配置所有AP的5GHz频段信道重传门限值为50,即重传率达到或超过50%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 5g retransmission-threshold 50
calibrate-channel 5g tolerance-level命令用来配置5GHz频段信道的容限系数。
undo calibrate-channel 5g tolerance-level命令用来恢复缺省情况。
calibrate-channel 5g tolerance-level percent
5GHz频段信道的容限系数为0。
全局配置视图
percent:容限系数,取值范围为0~100,单位为百分比。取值为0时表示5GHz频段信道在进行自动信道调整时不考虑容限系数。
# 配置所有AP的5GHz频段信道的容限系数为10,即两信道的信道质量差值达到或超过10时进行信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 5g tolerance-level 10
· tolerance-level
calibrate-channel 6g channel-usage-threshold命令用来配置6GHz频段信道使用率门限值。
undo calibrate-channel 6g channel-usage-threshold命令用来恢复缺省情况。
calibrate-channel 6g channel-usage-threshold percent percent
undo calibrate-channel 6g channel-usage-threshold percent
6GHz频段信道使用率门限值为60。
全局配置视图
# 配置所有AP的6GHz频段信道使用率门限值为40。
[Sysname-wlan-global-configuration] calibrate-channel 6g channel-usage-threshold percent 40
· calibrate-channel 6g interference-threshold
· calibrate-channel 6g receive-service-traffic threshold
calibrate-channel 6g crc-error-threshold命令用来配置6GHz频段信道的CRC错误门限值。
undo calibrate-channel 6g crc-error-threshold命令用来恢复缺省情况。
calibrate-channel 6g crc-error-threshold percent
6GHz频段信道的CRC错误门限值为0。
全局配置视图
CRC错误门限值是触发自动信道调整的条件之一。当AC检测到6GHz频段信道中CRC错误的帧占所有802.11帧的百分比达到或超过设定值时,将触发自动信道调整。
# 配置所有AP的6GHz频段信道的CRC错误门限值为10,即CRC错误率达到或超过10%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 6g crc-error-threshold 10
calibrate-channel 6g interference-threshold命令用来配置6GHz频段干扰在信道使用率中的占比门限值。
undo calibrate-channel 6g interference-threshold命令用来恢复缺省情况。
calibrate-channel 6g interference-threshold percent percent
undo calibrate-channel 6g interference-threshold percent
6GHz频段干扰在信道使用率中的占比门限值为70。
全局配置视图
# 配置所有AP的6GHz频段干扰在信道使用率的占比门限值为50%。
[Sysname-wlan-global-configuration] calibrate-channel 6g interference-threshold percent 50
· calibrate-channel 6g channel-usage-threshold
calibrate-channel 6g noise-threshold命令用来配置6GHz频段信道噪声门限值。
undo calibrate-channel 6g noise-threshold命令用来恢复缺省情况。
calibrate-channel 6g noise-threshold value
6GHz频段信道噪声门限值为0。
全局配置视图
噪声门限值是触发自动信道调整的条件之一。当AC检测到6GHz频段信道中的噪声达到或超过设定的门限值时,将触发自动信道调整。
# 配置所有AP的6GHz频段信道噪声门限值为50,即噪声达到或超过-50dBm时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 6g noise-threshold 50
calibrate-channel 6g receive-service-traffic threshold命令用来配置6GHz频段射频接收流量中业务流量阈值。
undo calibrate-channel 6g receive-service-traffic threshold命令用来恢复缺省情况。
calibrate-channel 6g receive-service-traffic threshold value
6GHz频段射频接收流量中业务流量阈值为10Mbps。
全局配置视图
设备对AP的6GHz频段射频接收的流量进行判断。若接收流量中的业务流量达到设定的阈值,则表示终端与射频间的流量为正常的业务流量;若未达到设定的阈值,则表示射频接收了大量的干扰流量,需要对当前的工作信道进行调整。
# 配置所有AP的6GHz频段射频接收流量中业务流量阈值为30Mbps。
[Sysname-wlan-global-configuration] calibrate-channel 6g receive-service-traffic threshold 30
calibrate-channel 6g retransmission-threshold命令用来配置6GHz频段信道重传门限值。
undo calibrate-channel 6g retransmission-threshold命令用来恢复缺省情况。
calibrate-channel 6g retransmission-threshold value
6GHz频段信道重传门限值为0。
全局配置视图
重传是触发自动信道调整的条件之一。当AC检测到6GHz频段信道的重传率达到或超过设定的门限值时,将触发自动信道调整。
# 配置所有AP的6GHz频段信道重传门限值为50,即重传率达到或超过50%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 6g retransmission-threshold 50
calibrate-channel 6g tolerance-level命令用来配置6GHz频段信道的容限系数。
undo calibrate-channel 6g tolerance-level命令用来恢复缺省情况。
calibrate-channel 6g tolerance-level percent
6GHz频段信道的容限系数为0。
全局配置视图
percent:容限系数,取值范围为0~100,单位为百分比。取值为0时表示6GHz频段信道在进行自动信道调整时不考虑容限系数。
# 配置所有AP的6GHz频段信道的容限系数为10,即两信道的信道质量差值达到或超过10时进行信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 6g tolerance-level 10
· tolerance-level
calibrate-channel channel-set-optimization enable命令用来开启2.4GHz射频的正交信道优选功能。
calibrate-channel channel-set-optimization disable命令用来关闭2.4GHz射频的正交信道优选功能。
undo calibrate-channel channel-set-optimization命令用来恢复缺省情况。
calibrate-channel channel-set-optimization { disable | enable }
RRM视图:继承AP组RRM配置。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
射频邻居类型包括如下两种:
本命令仅对2.4GHz射频生效。
RRM视图下配置的优先级高于AP组RRM视图下的配置,AP组RRM视图下配置的优先级高于AP组全局Radio RRM视图下的配置,AP组全局Radio RRM视图下配置的优先级高于全局视图下的配置。
# 开启2.4GHz射频的正交信道优选功能。(RRM视图)
[Sysname-wlan-ap-ap1] radio 2
[Sysname-wlan-ap-ap1-radio-2] rrm
[Sysname-wlan-ap-ap1-radio-2-rrm] calibrate-channel channel-set-optimization enable
#开启2.4GHz射频的正交信道优选功能。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320] radio 2
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-2] rrm
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-2-rrm] calibrate-channel channel-set-optimization enable
# 开启2.4GHz射频的正交信道优选功能。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1] radio 2.4g
[Sysname-wlan-ap-group-group1-radio-2.4g] rrm
[Sysname-wlan-ap-group-group1-radio-2.4g-rrm] calibrate-channel channel-set-optimization enable
calibrate-channel channel-set-optimization neighbor-threshold命令用来配置2.4GHz射频正交信道优选功能的邻居数阈值。
undo calibrate-channel channel-set-optimization neighbor-threshold命令用来恢复缺省情况。
calibrate-channel channel-set-optimization neighbor-threshold count
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
本命令仅对2.4GHz射频生效。
# 配置2.4GHz射频正交信道优选功能的邻居数阈值为11。(RRM视图)
[Sysname-wlan-ap-ap1-radio-2-rrm] calibrate-channel channel-set-optimization neighbor-threshold 11
# 配置2.4GHz射频正交信道优选功能的邻居数阈值为11。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-2-rrm] calibrate-channel channel-set-optimization neighbor-threshold 11
calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent命令用来配置2.4GHz射频正交信道优选功能的非管理邻居占比阈值。
undo calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent命令用来恢复缺省情况。
calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent percent
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
本命令仅对2.4GHz射频生效。
# 配置2.4GHz射频正交信道优选功能的非管理邻居占比阈值为20%。(RRM视图)
[Sysname-wlan-ap-ap1-radio-2-rrm] calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent 20
# 配置2.4GHz射频正交信道优选功能的非管理邻居占比阈值为20%。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-2-rrm] calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent 20
calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent-per-set命令用来配置2.4GHz射频正交信道优选功能的单个正交信道组的非管理邻居占比阈值。
undo calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent-per-set命令用来恢复缺省情况。
calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent-per-set percent
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
本命令仅对2.4GHz射频生效。
# 配置2.4GHz射频正交信道优选功能的单个正交信道组的非管理邻居占比阈值为20%。(RRM视图)
[Sysname-wlan-ap-ap1-radio-2-rrm] calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent-per-set 20
# 配置2.4GHz射频正交信道优选功能的单个正交信道组的非管理邻居占比阈值为20%。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-2-rrm] calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent-per-set 20
calibrate-channel interference-threshold命令用来配置干扰在信道使用率中的占比门限值。
undo calibrate-channel interference-threshold命令用来恢复缺省情况。
calibrate-channel interference-threshold percent percent
undo calibrate-channel interference-threshold percent
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
percent percent:干扰在信道使用率中的占比门限值,取值范围为0~100,单位为百分比。
# 配置干扰在信道使用率的占比门限值为50%。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel interference-threshold percent 50
# 配置干扰在信道使用率的占比门限值为50%。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel interference-threshold percent 50
· calibrate-channel receive-service-traffic threshold
· channel-usage-threshold
calibrate-channel mode命令用来配置自动信道调整模式。
undo calibrate-channel mode命令用来恢复缺省情况。
calibrate-channel mode { periodic | scheduled }
全局配置视图:
calibrate-channel { 2.4g | 5g | 6g } mode { periodic | scheduled }
undo calibrate-channel { 2.4g | 5g | 6g } mode
RRM视图:继承AP组RRM配置。
全局配置视图:自动信道调整模式为周期性调整。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
periodic:周期性调整。
scheduled:定时调整。
2.4g:配置所有AP的2.4GHz频段射频的信道调整模式。
5g:配置所有AP的5GHz频段射频的信道调整模式。
6g:配置所有AP的6GHz频段射频的信道调整模式。
周期性调整模式下,AC按用户设置的调整周期重复进行信道质量检测,根据检测结果评估是否需要进行信道调整。
定时调整模式下,设备在指定的时间段收集信道质量信息,而后进行信道质量的评估并决定是否调整信道。
# 配置自动信道调整模式为定时调整。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel self-decisive enable
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel mode scheduled
# 配置自动信道调整模式为定时调整。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel self-decisive enable
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel mode scheduled
# 配置自动信道调整模式为定时调整。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1-radio-5g-rrm] calibrate-channel mode scheduled
# 配置所有AP的5GHz频段自动信道调整模式为定时调整。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-channel 5g mode scheduled
· calibrate-channel monitoring time-range
· calibrate-channel pronto
· wlan rrm calibration-channel interval
calibrate-channel monitoring time-range命令用来为信道质量检测功能指定时间段。
undo calibrate-channel monitoring time-range命令用来取消为信道质量检测功能指定的时间段。
calibrate-channel monitoring time-range time-range-name
全局配置视图:
calibrate-channel { 2.4g | 5g | 6g } monitoring time-range time-range-name
undo calibrate-channel { 2.4g | 5g | 6g } monitoring time-range
RRM视图:继承AP组RRM配置。
AP组全局 Radio RRM 视图:继承全局配置。
全局配置视图:未指定时间段用于收集射频环境信息。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
2.4g:配置所有AP的2.4GHz频段射频收集射频环境信息的时间段。
为信道质量检测功能指定时间段后,AC将在指定的时间段内执行信道质量检测任务,并收集数据生成信道报告与邻居报告,为信道质量评估提供依据。
# 为信道质量检测功能指定时间段,该时间段名称为time1。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel monitoring time-range time1
# 为信道质量检测功能指定时间段,该时间段名称为time1。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel monitoring time-range time1
# 为信道质量检测功能指定时间段,该时间段名称为time1。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1-radio-2.4g-rrm] calibrate-channel monitoring time-range time1
# 为信道质量检测功能指定时间段,该时间段名称为time1。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-channel 2.4g monitoring time-range time1
· time-range
calibrate-channel pronto命令用来执行一次信道自动调整。
RRM视图
AP组RRM视图
本命令用于定时自动信道调整。
# 执行一次信道自动调整。(RRM视图)
[Sysname] scheduler job calibration1
[Sysname-job-calibration1] command 1 system-view
[Sysname-job-calibration1] command 2 wlan ap ap1
[Sysname-job-calibration1] command 3 radio 1
[Sysname-job-calibration1] command 4 rrm
[Sysname-job-calibration1] command 5 calibrate-channel pronto
# 执行一次信道自动调整。(AP组RRM视图)
[Sysname] scheduler job calibration2
[Sysname-job-calibration2] command 1 system-view
[Sysname-job-calibration2] command 2 wlan ap-group g1
[Sysname-job-calibration2] command 3 ap-model WA6320
[Sysname-job-calibration2] command 4 radio 1
[Sysname-job-calibration2] command 5 rrm
[Sysname-job-calibration2] command 6 calibrate-channel pronto
calibrate-channel receive-service-traffic threshold命令用来配置射频接收流量中业务流量阈值。
undo calibrate-channel receive-service-traffic threshold命令用来恢复缺省情况。
calibrate-channel receive-service-traffic threshold value
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
设备对AP射频接收的流量进行判断。若接收流量中的业务流量达到设定的阈值,则表示终端与射频间的流量为正常的业务流量;若未达到设定的阈值,则表示射频接收了大量的干扰流量,需要对当前的工作信道进行调整。
# 配置射频接收流量中业务流量阈值为30Mbps。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel receive-service-traffic threshold 30
# 配置射频接收流量中业务流量阈值为30Mbps。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel receive-service-traffic threshold 30
· calibrate-channel interference-threshold
calibrate-channel scheduled enable命令用来开启信道定时调整功能。
undo Calibrate-channel scheduled enable命令用来关闭信道定时调整功能。
calibrate-channel scheduled enable { 2.4g | 5g | 6g | all }
undo calibrate-channel scheduled enable { 2.4g | 5g | 6g | all }
信道定时调整功能处于关闭状态。
全局配置视图
2.4g:配置AP的2.4GHz频段射频的信道定时调整功能。
5g:配置AP的5GHz频段射频的信道定时调整功能。
6g:配置AP的6GHz频段射频的信道定时调整功能。
all:配置AP的2.4GHz、5GHz和6Ghz频段射频的信道定时调整功能。
该命令用于开启或关闭信道定时调整功能,适用于需要定时优化信道质量的网络环境。
在信道定时调整功能开启的情况下,到达信道定时调整的时间后,AP会立即开始收集信道质量信息,而后根据收集到的信道质量信息进行评估,并依据评估结果决定是否调整信道。
# 开启AP的所有频段射频的信道定时调整功能。
[Sysname-wlan-global-configuration] calibrate-channel scheduled enable all
· calibrate-channel scheduled time
calibrate-channel scheduled time命令用来配置信道定时调整的时间。
undo calibrate-channel scheduled time命令用来恢复缺省情况。
calibrate-channel scheduled time time
信道定时调整的时间为凌晨三点。
全局配置视图
time:信道定时调整的时间,格式为hh:mm。
# 配置信道定时调整的时间为中午12点。
[Sysname-wlan-global-configuration] calibrate-channel scheduled time 12:00
· calibrate-channel scheduled enable
calibrate-channel self-decisive enable命令用来开启自动信道调整。
calibrate-channel self-decisive disable命令用来关闭自动信道调整。
undo calibrate-channel self-decisive命令用来恢复缺省情况。
calibrate-channel self-decisive { disable | enable }
全局配置视图:
calibrate-channel self-decisive enable { 2.4g | 5g | 6g | all }
undo calibrate-channel self-decisive enable { 2.4g | 5g | 6g | all }
RRM视图:继承AP组RRM配置。
全局配置视图:自动信道调整处于关闭状态。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
2.4g:开启或关闭所有AP的2.4GHz频段射频的自动信道调整功能。
5g:开启或关闭所有AP的5GHz频段射频的自动信道调整功能。
6g:开启或关闭所有AP的6GHz频段射频的自动信道调整功能。
all:开启或关闭所有AP的2.4GHz、5GHz和6GHz频段射频的自动信道调整功能。
开启自动信道调整后,AC将按照自动信道调整模式来执行信道的检测、评估和调整。
# 开启自动信道调整。(RRM视图)
# 开启自动信道调整。(AP组RRM视图)
# 开启自动信道调整。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1-radio-2.4g-rrm] calibrate-channel self-decisive enable
# 开启所有AP的2.4GHz、5GHz和6GHz频段射频的自动信道调整功能。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-channel self-decisive enable all
· calibrate-channel mode
calibrate-channel self-decisive sensitivity命令用来配置自动信道调整的敏感度模式。
undo calibrate-channel self-decisive sensitivity命令用来恢复缺省情况。
calibrate-channel self-decisive sensitivity { custom | high | low | medium }
RRM视图:继承AP组RRM配置。
AP组RRM视图:自动信道调整敏感度模式为自定义。
RRM视图
AP组RRM视图
custom:自定义敏感度模式的自动信道调整。
high:高敏感度模式的自动信道调整,此模式下设备容易进行自动信道调整。
low:低敏感度模式的自动信道调整,此模式下设备不易进行自动信道调整。
medium:中等敏感度的自动信道调整,此模式下设备进行自动信道调整的难易程度适中。
配置自动信道调整敏感度模式为自定义模式后,可根据实际环境调整信道干扰门限、CRC错误门限和容限系数。
配置自动信道调整敏感度模式时应注意:
· 在自定义模式与高/中/低敏感度模式间切换时,自动信道调整配置参数(包括信道干扰门限、CRC错误门限和容限系数)都将被恢复为缺省值(不同模式,缺省值不同),并且不能手工修改这些缺省值。自定义模式下手工配置的各自动信道调整参数如有需要应在切换前做记录。
· 自动信道调整参数(包括信道干扰门限、CRC错误门限和容限系数)只有在自定义敏感度模式下才能手工配置。
# 配置自动信道调整的敏感度模式为低敏感度模式。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel self-decisive sensitivity low
# 配置自动信道调整的敏感度模式为高敏感度模式。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel self-decisive sensitivity high
· interference-threshold
· tolerance-level
calibrate-channel suppression enable命令用来开启自动信道调整抑制功能。
calibrate-channel suppression disable命令用来关闭自动信道调整抑制功能。
undo calibrate-channel suppression命令用来恢复缺省情况。
calibrate-channel suppression { disable | enable [ client-number number ] }
全局配置视图:
calibrate-channel { 2.4g | 5g | 6g } suppression enable [ client-number number ]
undo calibrate-channel { 2.4g | 5g | 6g } suppression
RRM视图:继承AP组RRM配置。
全局配置视图:自动信道调整抑制功能处于关闭状态,自动信道调整不受在线客户端数影响。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
client-number number:上线客户端数量,取值范围为1~124,缺省值为124。
进行信道调整会导致在线客户端掉线,影响用户的正常接入。当自动信道调整模式为周期性调整,且本功能为开启状态时,若在线客户端数达到或超过配置的阈值时,不进行本周期的自动信道调整,以保证工作信道的稳定。
本功能仅适用于周期性自动信道调整。
# 开启自动信道调整抑制功能,当在线客户端数达到或超过124个,则阻止此次自动信道调整。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel mode periodic
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel suppression enable
# 关闭自动信道调整抑制功能,周期性自动信道调整不受在线客户端数影响。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel mode periodic
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel suppression disable
# 开启自动信道调整抑制功能,当在线客户端数达到或超过100个,则阻止此次自动信道调整。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1-radio-2.4g-rrm] calibrate-channel suppression enable client-number 100
# 开启自动信道调整抑制功能,当在线客户端数达到或超过100个,则阻止此次自动信道调整。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-channel 2.4g suppression enable client-number 100
calibrate-channel track spectrum-analysis enable命令用来开启WSA联动。
calibrate-channel track spectrum-analysis disable用来关闭WSA联动。
undo calibrate-channel track spectrum-analysis用来恢复缺省情况。
calibrate-channel track spectrum-analysis { disable | enable }
全局配置视图:
calibrate-channel track spectrum-analysis enable { 2.4g | 5g | 6g | all }
undo calibrate-channel track spectrum-analysis enable { 2.4g | 5g | 6g | all }
RRM视图:继承AP组RRM配置。
全局配置视图:WSA联动处于关闭状态。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
2.4g:开启或关闭所有AP的2.4GHz频段射频的WSA功能。
5g:开启或关闭所有AP的5GHz频段射频的WSA功能。
6g:开启或关闭所有AP的6GHz频段射频的WSA功能。
all:开启或关闭所有AP的2.4GHz、5GHz和6GHz频段射频的WSA功能。
开启WSA(Wireless Spectrum Analysis,无线频谱分析)联动后,当频谱分析检测到信道质量变差达到调整门限时,会触发一次自动信道调整。关于WSA的介绍和配置请参见“WLAN配置指导”中的“频谱分析”。
# 开启WSA联动。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel track spectrum-analysis enable
# 开启WSA联动。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel track spectrum-analysis enable
# 开启WSA联动。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1-radio-5g-rrm] calibrate-channel track spectrum-analysis enable
# 开启2.4GHz频段射频的WSA联动。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-channel track spectrum-analysis enable 2.4g
· spectrum-analysis calibrate-channel sensitivity(WLAN命令参考/频谱分析)
calibrate-power 2.4g adjacency-factor命令用来配置2.4GHz频段邻居因子。
undo calibrate-power 2.4g adjacency-factor命令用来恢复缺省情况。
calibrate-power 2.4g adjacency-factor neighbor
2.4GHz频段邻居因子为2。
全局配置视图
# 配置所有AP的2.4GHz频段邻居因子为7。
[Sysname-wlan-global-configuration] calibrate-power 2.4g adjacency-factor 7
calibrate-power 2.4g coverage rssi-threshold命令用来配置2.4GHz频段客户端报文的RSSI门限值。
undo calibrate-power 2.4g coverage rssi-threshold命令用来恢复缺省情况。
calibrate-power 2.4g coverage rssi-threshold rssi
2.4GHz频段客户端报文的RSSI门限值为20。
全局配置视图
rssi:2.4GHz频段客户端报文的RSSI门限值,取值范围为1~100。
当设备检测到客户端报文的RSSI值小于本命令配置的RSSI门限值时,设备将会判定该报文属于弱信号报文。
# 配置所有AP的2.4GHz频段客户端报文的RSSI门限值为80。
[Sysname-wlan-global-configuration] calibrate-power 2.4g coverage rssi-threshold 80
· calibrate-power 2.4g coverage weak-signal-client ratio
· calibrate-power 2.4g coverage weak-signal-client threshold
· calibrate-power 2.4g coverage weak-signal-packet ratio
· calibrate-power 2.4g coverage weak-signal-packet threshold
· calibrate-power coverage enable
calibrate-power 2.4g coverage weak-signal-client ratio命令用来配置2.4GHz频段弱信号客户端数量占比门限值。
undo calibrate-power 2.4g coverage weak-signal-client ratio命令用来恢复缺省情况。
calibrate-power 2.4g coverage weak-signal-client ratio percent
2.4GHz频段弱信号客户端数量占比门限值为25。
全局配置视图
percent:2.4GHz频段弱信号客户端数量占比门限值,取值范围为1~100,单位为百分比。
满足以下所有条件时,设备将会判定当前射频存在覆盖盲区:
· 射频下关联的弱信号客户端数量达到或超过命令calibrate-power 2.4g coverage weak-signal-client threshold配置的门限值;
· 射频下关联的弱信号客户端数量占比达到或超过本命令配置的门限值。
# 配置所有AP的2.4GHz频段弱信号客户端数量占比门限值为30%。
[Sysname-wlan-global-configuration] calibrate-power 2.4g coverage weak-signal-client ratio 30
· calibrate-power 2.4g coverage rssi-threshold
calibrate-power 2.4g coverage weak-signal-client threshold命令用来配置2.4GHz频段弱信号客户端数量门限值。
undo calibrate-power 2.4g coverage weak-signal-client threshold命令用来恢复缺省情况。
calibrate-power 2.4g coverage weak-signal-client threshold counts
2.4GHz频段弱信号客户端数量门限值为3。
全局配置视图
counts:2.4GHz频段弱信号客户端数量门限值,取值范围为1~75。
· 射频下关联的弱信号客户端数量达到或超过本命令配置的门限值;
· 射频下关联的弱信号客户端数量占比达到或超过命令calibrate-power 2.4g coverage weak-signal-client ratio配置的门限值。
# 配置所有AP的2.4GHz频段弱信号客户端数量门限值为20。
[Sysname-wlan-global-configuration] calibrate-power 2.4g coverage weak-signal-client threshold 20
calibrate-power 2.4g coverage weak-signal-packet ratio命令用来配置2.4GHz频段客户端弱信号报文数量占比门限值。
undo calibrate-power 2.4g coverage weak-signal-packet ratio命令用来恢复缺省情况。
calibrate-power 2.4g coverage weak-signal-packet ratio percent
2.4GHz频段客户端弱信号报文数量占比门限值为20。
全局配置视图
percent:2.4GHz频段客户端弱信号报文数量占比门限值,取值范围为1~100,单位为百分比。
满足以下所有条件时,设备将会判定该客户端属于弱信号客户端:
· 客户端的弱信号报文数量达到或超过命令calibrate-power 2.4g coverage weak-signal-packet threshold配置的门限值;
· 客户端的弱信号报文数量占比达到或超过本命令配置的门限值。
# 配置所有AP的2.4GHz频段客户端弱信号报文数量占比门限值为20%。
[Sysname-wlan-global-configuration] calibrate-power 2.4g coverage weak-signal-packet ratio 20
calibrate-power 2.4g coverage weak-signal-packet threshold命令用来配置2.4GHz频段客户端弱信号报文数量门限值。
undo calibrate-power 2.4g coverage weak-signal-packet threshold命令用来恢复缺省情况。
calibrate-power 2.4g coverage weak-signal-packet threshold packets
2.4GHz频段客户端弱信号报文数量门限值为5。
全局配置视图
packets:2.4GHz频段客户端弱信号报文数量门限值,取值范围为1~255。
· 客户端的弱信号报文数量达到或超过本命令配置的门限值;
· 客户端的弱信号报文数量占比达到或超过命令calibrate-power 2.4g coverage weak-signal-packet ratio配置的门限值。
# 配置所有AP的2.4GHz频段客户端弱信号报文数量门限值为20。
[Sysname-wlan-global-configuration] calibrate-power 2.4g coverage weak-signal-packet threshold 20
calibrate-power 2.4g threshold命令用来配置2.4GHz频段功率调整门限值。
undo calibrate-power 2.4g threshold命令用来恢复缺省情况。
calibrate-power 2.4g threshold value
功率调整门限值为65。
全局配置视图
threshold value:功率调整门限值,取值范围为1~196,代表功率范围为-1dBm~-196dBm。功率门限值越大,表示功率越小。
需要合理设置门限值,既保证AP上的Radio有较大的覆盖范围,不会出现弱信号,满足正常的使用需求,同时也要减少AP间相互干扰。
# 配置所有AP的2.4GHz频段功率调整门限值为-70dBm。
[Sysname-wlan-global-configuration] calibrate-power 2.4g threshold 70
calibrate-power 5g adjacency-factor命令用来配置5GHz频段邻居因子。
undo calibrate-power 5g adjacency-factor命令用来恢复缺省情况。
calibrate-power 5g adjacency-factor neighbor
5GHz频段邻居因子为2。
全局配置视图
# 配置所有AP的5GHz频段邻居因子为7。
[Sysname-wlan-global-configuration] calibrate-power 5g adjacency-factor 7
calibrate-power 5g coverage rssi-threshold命令用来配置5GHz频段客户端报文的RSSI门限值。
undo calibrate-power 5g coverage rssi-threshold命令用来恢复缺省情况。
calibrate-power 5g coverage rssi-threshold rssi
5GHz频段客户端报文的RSSI门限值为25。
全局配置视图
rssi:5GHz频段客户端报文的RSSI门限值,取值范围为1~100。
# 配置所有AP的5GHz频段客户端报文的RSSI门限值为80。
[Sysname-wlan-global-configuration] calibrate-power 5g coverage rssi-threshold 80
· calibrate-power 5g coverage weak-signal-client ratio
· calibrate-power 5g coverage weak-signal-client threshold
· calibrate-power 5g coverage weak-signal-packet ratio
· calibrate-power 5g coverage weak-signal-packet threshold
calibrate-power 5g coverage weak-signal-client ratio命令用来配置5GHz频段弱信号客户端数量占比门限值。
undo calibrate-power 5g coverage weak-signal-client ratio命令用来恢复缺省情况。
calibrate-power 5g coverage weak-signal-client ratio percent
5GHz频段弱信号客户端数量占比门限值为25。
全局配置视图
percent:5GHz频段弱信号客户端数量占比门限值,取值范围为1~100,单位为百分比。
· 射频下关联的弱信号客户端数量达到或超过命令calibrate-power 5g coverage weak-signal-client threshold配置的门限值;
# 配置所有AP的5GHz频段弱信号客户端数量占比门限值为30%。
[Sysname-wlan-global-configuration] calibrate-power 5g coverage weak-signal-client ratio 30
· calibrate-power 5g coverage rssi-threshold
calibrate-power 5g coverage weak-signal-client threshold命令用来配置5GHz频段弱信号客户端数量门限值。
undo calibrate-power 5g coverage weak-signal-client threshold命令用来恢复缺省情况。
calibrate-power 5g coverage weak-signal-client threshold counts
5GHz频段弱信号客户端数量门限值为3。
全局配置视图
counts:5GHz频段弱信号客户端数量门限值,取值范围为1~75。
· 射频下关联的弱信号客户端数量占比达到或超过命令calibrate-power 5g coverage weak-signal-client ratio配置的门限值。
# 配置所有AP的5GHz频段弱信号客户端数量门限值为20。
[Sysname-wlan-global-configuration] calibrate-power 5g coverage weak-signal-client threshold 20
calibrate-power 5g coverage weak-signal-packet ratio命令用来配置5GHz频段客户端弱信号报文数量占比门限值。
undo calibrate-power 5g coverage weak-signal-packet ratio命令用来恢复缺省情况。
calibrate-power 5g coverage weak-signal-packet ratio percent
5GHz频段客户端弱信号报文数量占比门限值为20。
全局配置视图
percent:5GHz频段客户端弱信号报文数量占比门限值,取值范围为1~100,单位为百分比。
· 客户端的弱信号报文数量达到或超过命令calibrate-power 5g coverage weak-signal-packet threshold配置的门限值;
# 配置所有AP的5GHz频段客户端弱信号报文数量占比门限值为20%。
[Sysname-wlan-global-configuration] calibrate-power 5g coverage weak-signal-packet ratio 20
calibrate-power 5g coverage weak-signal-packet threshold命令用来配置5GHz频段客户端弱信号报文数量门限值。
undo calibrate-power 5g coverage weak-signal-packet threshold命令用来恢复缺省情况。
calibrate-power 5g coverage weak-signal-packet threshold packets
5GHz频段客户端弱信号报文数量门限值为5。
全局配置视图
packets:5GHz频段客户端弱信号报文数量门限值,取值范围为1~255。
· 客户端的弱信号报文数量占比达到或超过命令calibrate-power 5g coverage weak-signal-packet ratio配置的门限值。
# 配置所有AP的5GHz频段客户端弱信号报文数量门限值为20。
[Sysname-wlan-global-configuration] calibrate-power 5g coverage weak-signal-packet threshold 20
calibrate-power 5g threshold命令用来配置5GHz频段功率调整门限值。
undo calibrate-power 5g threshold命令用来恢复缺省情况。
calibrate-power 5g threshold value
功率调整门限值为65。
全局配置视图
# 配置所有AP的5GHz频段功率调整门限值为-75dBm。
[Sysname-wlan-global-configuration] calibrate-power 5g threshold 75
calibrate-power 6g adjacency-factor命令用来配置6GHz频段邻居因子。
undo calibrate-power 6g adjacency-factor命令用来恢复缺省情况。
calibrate-power 6g adjacency-factor neighbor
6GHz频段邻居因子为2。
全局配置视图
# 配置所有AP的6GHz频段邻居因子为7。
[Sysname-wlan-global-configuration] calibrate-power 6g adjacency-factor 7
calibrate-power 6g coverage rssi-threshold命令用来配置6GHz频段客户端报文的RSSI门限值。
undo calibrate-power 6g coverage rssi-threshold命令用来恢复缺省情况。
calibrate-power 6g coverage rssi-threshold rssi
6GHz频段客户端报文的RSSI门限值为25。
全局配置视图
rssi:6GHz频段客户端报文的RSSI门限值,取值范围为1~100。
# 配置所有AP的6GHz频段客户端报文的RSSI门限值为80。
[Sysname-wlan-global-configuration] calibrate-power 6g coverage rssi-threshold 80
· calibrate-power 6g coverage weak-signal-client ratio
· calibrate-power 6g coverage weak-signal-client threshold
· calibrate-power 6g coverage weak-signal-packet ratio
· calibrate-power 6g coverage weak-signal-packet threshold
calibrate-power 6g coverage weak-signal-client ratio命令用来配置6GHz频段弱信号客户端数量占比门限值。
undo calibrate-power 6g coverage weak-signal-client ratio命令用来恢复缺省情况。
calibrate-power 6g coverage weak-signal-client ratio percent
6GHz频段弱信号客户端数量占比门限值为25。
全局配置视图
percent:6GHz频段弱信号客户端数量占比门限值,取值范围为1~100,单位为百分比。
· 射频下关联的弱信号客户端数量达到或超过命令calibrate-power 6g coverage weak-signal-client threshold配置的门限值;
# 配置所有AP的6GHz频段弱信号客户端数量占比门限值为30%。
[Sysname-wlan-global-configuration] calibrate-power 6g coverage weak-signal-client ratio 30
· calibrate-power 6g coverage rssi-threshold
calibrate-power 6g coverage weak-signal-client threshold命令用来配置6GHz频段弱信号客户端数量门限值。
undo calibrate-power 6g coverage weak-signal-client threshold命令用来恢复缺省情况。
calibrate-power 6g coverage weak-signal-client threshold counts
6GHz频段弱信号客户端数量门限值为3。
全局配置视图
counts:6GHz频段弱信号客户端数量门限值,取值范围为1~75。
· 射频下关联的弱信号客户端数量占比达到或超过命令calibrate-power 6g coverage weak-signal-client ratio配置的门限值。
# 配置所有AP的6GHz频段弱信号客户端数量门限值为20。
[Sysname-wlan-global-configuration] calibrate-power 6g coverage weak-signal-client threshold 20
calibrate-power 6g coverage weak-signal-packet ratio命令用来配置6GHz频段客户端弱信号报文数量占比门限值。
undo calibrate-power 6g coverage weak-signal-packet ratio命令用来恢复缺省情况。
calibrate-power 6g coverage weak-signal-packet ratio percent
6GHz频段客户端弱信号报文数量占比门限值为20。
全局配置视图
percent:6GHz频段客户端弱信号报文数量占比门限值,取值范围为1~100,单位为百分比。
· 客户端的弱信号报文数量达到或超过命令calibrate-power 6g coverage weak-signal-packet threshold配置的门限值;
# 配置所有AP的6GHz频段客户端弱信号报文数量占比门限值为20%。
[Sysname-wlan-global-configuration] calibrate-power 6g coverage weak-signal-packet ratio 20
calibrate-power 6g coverage weak-signal-packet threshold命令用来配置6GHz频段客户端弱信号报文数量门限值。
undo calibrate-power 6g coverage weak-signal-packet threshold命令用来恢复缺省情况。
calibrate-power 6g coverage weak-signal-packet threshold packets
6GHz频段客户端弱信号报文数量门限值为5。
全局配置视图
packets:6GHz频段客户端弱信号报文数量门限值,取值范围为1~255。
· 客户端的弱信号报文数量占比达到或超过命令calibrate-power 6g coverage weak-signal-packet ratio配置的门限值。
# 配置所有AP的6GHz频段客户端弱信号报文数量门限值为20。
[Sysname-wlan-global-configuration] calibrate-power 6g coverage weak-signal-packet threshold 20
calibrate-power 6g threshold命令用来配置6GHz频段功率调整门限值。
undo calibrate-power 6g threshold命令用来恢复缺省情况。
calibrate-power 6g threshold value
功率调整门限值为65。
全局配置视图
# 配置所有AP的6GHz频段功率调整门限值为-75dBm。
[Sysname-wlan-global-configuration] calibrate-power 6g threshold 75
calibrate-power coverage enable命令用来开启射频覆盖盲区探测功能。
calibrate-power coverage disable命令用来关闭射频覆盖盲区探测功能。
undo calibrate-power coverage命令用来恢复缺省情况。
Radio视图/AP组Radio视图:
calibrate-power coverage { disable | enable }
全局配置视图:
calibrate-power coverage enable { 2.4g | 5g | all }
undo calibrate-power coverage enable { 2.4g | 5g | all }
Radio视图:继承AP组Radio配置。
AP组Radio视图:继承全局配置。
全局配置视图:射频覆盖盲区探测功能处于关闭状态。
Radio视图
AP组Radio视图
全局配置视图
2.4g:开启或关闭所有AP的2.4GHz频段射频的覆盖盲区探测功能。
5g:开启或关闭所有AP的5GHz频段射频的覆盖盲区探测功能。
all:开启或关闭所有AP的2.4GHz和5GHz频段射频的覆盖盲区探测功能。
通过本命令开启射频覆盖盲区探测功能后,AC设备将根据无线客户端的信号情况来判定射频是否存在覆盖盲区(即弱信号覆盖区域),如果存在,当AC设备进行自动功率调整时,就会适当增大AP的射频功率。
· 射频下关联的弱信号客户端数量达到或超过配置的门限值;
· 射频下关联的弱信号客户端数量占比达到或超过配置的门限值。
· 客户端的弱信号报文数量达到或超过配置的门限值;
· 客户端的弱信号报文数量占比达到或超过配置的门限值。
当客户端报文的RSSI值小于配置的RSSI门限值时,设备将会判定该报文属于弱信号报文。
开启射频覆盖盲区探测功能后,建议通过命令wlan rrm calibration-power interval配置的自动功率调整周期不小于11分钟。
# 开启射频的覆盖盲区探测功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] calibrate-power coverage enable
#开启射频的覆盖盲区探测功能。(AP组Radio视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1] calibrate-power coverage enable
# 开启所有AP的2.4GHz频段射频的覆盖盲区探测功能。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-power coverage enable 2.4g
calibrate-power mode命令用来配置自动功率调整的场景模式。
undo calibrate-power mode命令用来恢复缺省情况。
RRM视图:继承AP组RRM配置。
AP组RRM视图:自动功率调整的场景模式为自定义模式。
RRM视图
AP组RRM视图
coverage:覆盖模式,该模式下功率调整方式偏向于扩大AP信号的覆盖范围,适用于AP数量较少的无线环境。
custom:自定义模式,AC根据手动配置的功率调整参数来进行功率调整。
density:高密模式,该模式下的功率调整方式偏向于避免AP之间的信号干扰,适用于AP数量较多,存在大量信号重叠区域的无线环境。
覆盖模式和高密模式使用系统定义的功率调整参数进行自动功率调整,自定义模式使用手动配置的功率调整参数进行自动功率调整。
# 配置自动功率调整的场景模式为覆盖模式。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power mode coverage
# 配置自动功率调整的场景模式为高密模式。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power mode density
calibrate-power mode命令用来配置自动功率调整模式。
undo calibrate-power mode { periodic | scheduled }
全局配置视图:
calibrate-power { 2.4g | 5g | 6g } mode { periodic | scheduled }
undo calibrate-power { 2.4g | 5g | 6g } mode { periodic | scheduled }
RRM视图:继承AP组RRM配置。
全局配置视图:自动功率调整模式为周期性调整。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
periodic:周期性调整。
scheduled:定时调整。
2.4g:配置所有AP的2.4GHz频段射频的功率调整模式。
5g:配置所有AP的5GHz频段射频的功率调整模式。
6g:配置所有AP的6GHz频段射频的功率调整模式。
周期性调整模式下,AC按用户设置的调整周期重复进行信道质量检测,根据检测结果评估是否需要进行功率调整。
定时调整模式下,设备在指定的时间段收集信道质量信息,而后进行信道质量的评估并决定是否调整功率。
# 配置自动功率调整模式为定时调整。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power self-decisive enable
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power mode scheduled
# 配置自动功率调整模式为定时调整。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power self-decisive enable
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power mode scheduled
# 配置AP组全局5GHz射频的自动功率调整模式为定时调整。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1-radio-5g-rrm] calibrate-power self-decisive enable
[Sysname-wlan-ap-group-group1-radio-5g-rrm] calibrate-power mode scheduled
# 配置所有AP的2.4GHz射频的自动功率调整模式为定时调整。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-power 2.4g mode scheduled
calibrate-power monitoring time-range命令用来为功率调整功能指定收集环境信息的时间段。
undo calibrate-power monitoring time-range命令用来取消为功率调整功能指定收集环境信息的时间段。
calibrate-power monitoring time-range time-range-name
全局配置视图:
calibrate-power { 2.4g | 5g | 6g } monitoring time-range time-range-name
undo calibrate-power { 2.4g | 5g | 6g } monitoring time-range
RRM视图:继承AP组RRM配置。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
为功率调整功能指定收集环境信息的时间段后,AC将在指定的时间段内收集射频环境信息,并生成信道报告与邻居报告,为功率调整提供依据。
# 为功率调整功能指定收集环境信息的时间段,该时间段名称为time1。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power monitoring time-range time1
# 为功率调整功能指定收集环境信息的时间段,该时间段名称为time1。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power monitoring time-range time1
# 为功率调整功能指定收集环境信息的时间段,该时间段名称为time1。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1-radio-2.4g-rrm] calibrate-power monitoring time-range time1
# 为2.4GHz频段功率调整功能指定收集环境信息的时间段,该时间段名称为time1。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-power 2.4g monitoring time-range time1
calibrate-power power-range命令用来配置功率调整的范围。
undo calibrate-power power-range命令用来恢复缺省情况。
calibrate-power power-range min-power to max-power
全局配置视图:
calibrate-power { 2.4g | 5g | 6g } power-range min-power to max-power
undo calibrate-power { 2.4g | 5g | 6g } power-range
RRM视图:继承AP组RRM配置。
全局配置视图:2.4GHz频段射频的最小发射功率为6dBm,5GHz和6GHz频段射频的最小发射功率为11dBm。2.4GHz、5GHz和6GHz频段射频的最大发射功率与射频缺省支持的最大功率保持一致。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
min-power:射频的最小发射功率,取值范围为1~20,单位为dBm。
max-power:射频的最大发射功率,取值范围为1~27,单位为dBm。
该命令适用于需要在不同的视图下配置射频发射功率范围的情况,以确保射频发射功率在正常范围内,并且不会超出设置的范围值。
在配置该命令前,需要对RRM视图、AP组RRM视图、AP组全局Radio RRM视图和全局配置视图的相关参数有一定的了解,同时需要注意各视图下配置的优先级关系和合理性。
# 配置功率调整的范围为15~20dBm。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power power-range 15 to 20
# 配置功率调整的范围为15~20dBm。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power power-range 15 to 20
# 配置AP组全局5GHz射频的功率调整范围为15~20dBm。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1-radio-5g-rrm] calibrate-power power-range 15 to 20
# 配置所有AP的2.4GHz频段射频的功率调整范围为15~20dBm。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-power 2.4g power-range 15 to 20
calibrate-power self-decisive enable命令用来开启自动功率调整。
calibrate-power self-decisive disable命令用来关闭自动功率调整。
undo calibrate-power self-decisive命令用来恢复缺省情况。
calibrate-power self-decisive { disable | enable }
全局配置视图:
calibrate-power self-decisive enable { 2.4g | 5g | 6g | all }
undo calibrate-power self-decisive enable { 2.4g | 5g | 6g | all }
RRM视图:继承AP组RRM配置。
全局配置视图:自动功率调整处于关闭状态。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
2.4g:开启或关闭所有AP的2.4GHz频段射频的自动功率调整功能。
5g:开启或关闭所有AP的5GHz频段射频的自动功率调整功能。
6g:开启或关闭所有AP的6GHz频段射频的自动功率调整功能。
all:开启或关闭所有AP的2.4GHz、5GHz和6GHz频段射频的自动功率调整功能。
开启自动功率调整后,AC在每一个自动功率调整周期到达时,都会开始功率调整流程。
若为射频配置了最大传输功率,则当前射频的自动功率调整功能将失效。
# 开启自动功率调整。(RRM视图)
# 开启自动功率调整。(AP组RRM视图)
# 开启自动功率调整。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1-radio-2.4g-rrm] calibrate-power self-decisive enable
# 开启所有AP的2.4GHz、5GHz和6GHz频段射频的自动功率调整功能。(全局配置视图)
[Sysname-wlan-global-configuration] calibrate-power self-decisive enable all
· wlan rrm calibration-power interval
calibrate-power threshold命令用来配置功率调整门限值。
undo calibrate-power threshold命令用来恢复缺省情况。
calibrate-power threshold value
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
threshold value:功率调整门限值,取值范围为1~196,代表功率范围为-1dBm~-196dBm。即功率门限值越大,表示的功率值越小。
# 配置功率调整门限值为-70dBm。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power threshold 70
# 配置功率调整门限值为-70dBm。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power threshold 70
channel holddown-time命令用来配置信道保持时长。
undo channel holddown-time命令用来恢复缺省情况。
channel holddown-time minutes
信道保持时长为720分钟。
RRM保持调整组视图
minutes:信道保持时长,取值范围为10~1440,单位为分钟。
加入到RRM保持调整组的射频信道在每次调整后的信道保持时长内将不作调整。
# 为RRM保持调整组10配置信道保持时长为600分钟。
[Sysname-wlan-rrm-calibration-group-10] channel holddown-time 600
channel-usage-threshold命令用来配置信道使用率门限值。
undo channel-usage-threshold命令用来恢复缺省情况。
undo channel-usage-threshold percent
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
percent percent:信道使用率门限值,取值范围为1~100,单位为百分比。
# 配置信道使用率门限值为40。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] channel-usage-threshold percent 40
# 配置信道使用率门限值为40。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] channel-usage-threshold percent 40
co-channel interference trap threshold命令用来配置同频干扰告警阈值。
undo co-channel interference trap threshold命令用来恢复缺省情况。
co-channel interference trap threshold threshold
RRM视图:继承AP组RRM配置。
全局配置视图:同频干扰告警阈值为60dBm。
RRM视图
AP组RRM视图
AP组全局Radio RRM视图
全局配置视图
threshold threshold:同频干扰告警阈值,取值范围为10~90,单位为dBm。
由于同频干扰越高越影响用户正常使用,所以可以通过配置本命令设置同频干扰告警阈值,当同频干扰超过一定阈值后,设备会向网络管理系统发送trap告警信息,通知网络管理员消除干扰,以保证用户可以正常使用。
# 配置同频干扰告警阈值为16。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] co-channel interference trap threshold 16
# 配置同频干扰告警阈值为16。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] co-channel interference trap threshold 16
# 配置同频干扰告警阈值为16。(AP组全局Radio RRM视图)
[Sysname-wlan-ap-group-group1-radio-5g-rrm] co-channel interference trap threshold 16
# 配置同频干扰告警阈值为16。(全局配置视图)
[Sysname] wlan g1obal-configuration
[Sysname-wlan-global-configuration] co-channel interference trap threshold 16
· adjacent-channel interference trap threshold
crc-error-threshold命令用来配置CRC错误门限值。
undo crc-error-threshold命令用来恢复缺省情况。
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
CRC错误门限值是触发自动信道调整的条件之一,当AC检测到信道中CRC错误的帧占所有802.11帧的百分比超过设定值时,将触发信道调整。
# 配置CRC错误门限值为50,即CRC错误率达到或超过50%时触发自动信道调整。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] crc-error-threshold 50
# 配置CRC错误门限值为50,即CRC错误率达到或超过50%时触发自动信道调整。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] crc-error-threshold 50
description命令用来配置RRM保持调整组的描述信息。
undo description命令用来恢复缺省情况。
不存在RRM保持调整组的描述信息。
RRM保持调整组视图
text:RRM保持调整组的描述信息,为1~64个字符的字符串,区分大小写。
# 配置RRM保持调整组10的描述信息为office。
[Sysname-wlan-rrm-calibration-group-10] description office
display wlan calibrate-channel pronto history命令用来显示手动触发信道调整的历史记录。
当用户手动触发信道调整后,系统会记录这次调整的相关信息,如触发时间、调整结果等,并将其存储在历史记录中。用户可以通过该命令查看历史记录,以评估无线环境的优化效果。
本命令最多显示10条调整的历史记录,超出后会覆盖最早时间的记录。
# 显示手动触发信道调整的历史记录。
[Sysname] display wlan calibrate-channel pronto history
Time Frequency band Optimization
2024-09-20 15:31:04 2.4GHz 20%
2024-09-20 15:31:04 5GHz 0%(Already Best)
2024-09-20 15:31:04 6GHz 0%(Already Best)
表1-1 display wlan calibrate-channel pronto history命令显示信息描述表
Time |
触发调整的日期和时间 |
Frequency band |
射频的频段 |
Optimization |
优化提升的百分比 Already Best表示当前信道已是最优,没有提升 |
display wlan rrm baseline命令用来显示射频工作参数基线的信息。
display wlan rrm baseline { all | name baseline-name } [ verbose ]
all:显示所有已保存的射频工作参数基线信息。
name baseline-name:显示已保存的射频工作参数基线信息。其中baseline-name表示基线的名称,为1~32个字符的字符串,不区分大小写。
verbose:显示射频工作参数基线的详细信息。若不指定本参数,则显示基线的概要信息。
射频工作参数基线中保存了当前用户不具有location权限的AP的射频信息时,该用户无法查看此射频工作参数基线。
# 显示所有已保存基线的概要信息。
<Sysname> display wlan rrm baseline all
Baseline name : apbaseline
Radio range : AP
Created at : 2015-06-22 19:56:31
Baseline name : groupbaseline
Radio range : AP group
Created at : 2015-06-22 19:56:12
Baseline name : globalbaseline
Radio range : Global
Created at : 2015-06-22 19:55:12
表1-2 display wlan rrm baseline all命令显示信息描述表
Baseline name |
射频工作参数基线的名称 |
Radio range |
射频工作参数基线中保存的射频的范围,取值包括: · AP:AP的射频 · AP group:AP组内的射频 · Global:AC上所有AP的射频 |
Created at |
射频工作参数基线的创建时间 |
# 显示所有已保存射频工作参数基线的详细信息。
<Sysname> display wlan rrm baseline all verbose
Radio range : AP
APName RadioID RadioType Bandwidth Channel Power RegionCode
ap1 2 dot11gn 20 13 20 CN
ap1 1 dot11an 40 157 20 CN
ap2 1 dot11an 40 149 20 CN
ap1 1 dot11an 40 149 20 CN
ap2 2 dot11gn 20 1 20 CN
表1-3 display wlan rrm baseline all verbose命令显示信息描述表
Baseline name |
射频工作参数基线的名称 |
Radio range |
Created at |
射频工作参数基线的创建时间 |
APName |
AP的名称 |
RadioID |
射频号 |
RadioType |
射频类型 |
Bandwidth |
射频带宽 |
Channel |
射频工作信道 |
Power |
射频传输功率,单位为dBm |
RegionCode |
AP的区域码 |
display wlan rrm baseline apply-history命令用来显示应用射频工作参数基线的历史信息。
display wlan rrm baseline apply-history [ verbose ]
verbose:射频工作参数基线的详细历史信息。若不指定本参数,则显示射频工作参数基线的简要历史信息。
本命令用来显示最近十次应用射频工作参数基线的历史记录,如果应用不足十次,则显示全部。
# 显示应用射频工作参数基线的简要历史信息。
<Sysname> display wlan rrm baseline apply-history
Applied at : 2016-01-23 12:19:50
Applied to : global
# 显示应用射频工作参数基线的详细历史信息。
<Sysname> display wlan rrm baseline apply-history verbose
Applied to : global
Radios : 6
Success : 4
Failure : 2
Failure reason
Radio doesn't exist : 0
Radio is down : 0
Mismatching radio type : 0
Mismatching region code : 1
Ineffective service template : 0
Illegal channel : 0
Mismatching bandwidth : 1
Channel locked : 0
Channel fixed : 0
Within channel holddown time : 0
Mismatching channel gap policy: 0
Power locked : 0
Within power holddown time : 0
Power lower than min. power : 0
Power greater than max. power : 0
表1-4 display wlan rrm baseline apply-history命令显示信息描述表
Name |
射频工作参数基线的名称 |
Applied at |
射频工作参数基线的应用时间 |
Applied to |
射频工作参数基线的应用范围,取值为: · ap:应用于指定AP · apgroup:应用于指定AP组 · global:应用于全局 |
Radio count |
射频工作参数基线中的射频总数目 |
Success |
射频工作参数基线应用成功的射频数目 |
Failure |
射频工作参数基线应用失败的射频数目 |
Failure reason |
射频工作参数基线应用失败原因 |
Radio doesn’t exist |
射频不存在 |
Radio is down |
射频状态为Down |
Mismatching radio type |
射频工作参数基线中保存的射频类型与实际射频类型不匹配 |
Mismatching region code |
射频工作参数基线中保存的AP的区域码与实际情况不匹配 |
Ineffective service template |
无线服务未生效 |
Illegal channel |
射频工作参数基线中保存的射频工作信道不合法 |
Mismatching bandwidth |
射频工作参数基线中保存的射频带宽与实际射频带宽不匹配 |
Channel locked |
工作信道被锁定 |
Channel fixed |
射频工作信道已手动配置为固定值 |
Within channel holddown time |
当前工作信道处于信道保持调整期 |
Mismatching channel gap policy |
射频工作参数基线中保存的射频工作信道与信道间隔策略选取的信道不匹配 |
Power locked |
射频功率被锁定 |
Within power holddown time |
当前射频功率处于功率保持调整期 |
Power lower than min. power |
射频工作参数基线中保存的射频功率小于配置的最小传输功率 |
Power greater than max. power |
射频工作参数基线中保存的射频功率大于配置的最大传输功率 |
· wlan rrm baseline apply name
display wlan rrm high-density filter history命令用来显示高密场景下已筛选的射频关闭列表的历史信息。
通过本命令可以显示最近5次筛选的射频关闭列表的信息。建议用户根据筛选结果手动关闭射频列表中的射频,降低高密场景下AP射频之间的干扰。
# 显示高密场景下已筛选的射频关闭列表的历史信息。
<Sysname> display wlan rrm high-density filter history
Date Time : 2019-06-22 19:55:12
Range : group1 (AP group)
Frequency-band : 2.4GHz
2.4GHz shutdown list :
AP name RID Channel
ap1 2 1
ap2 2 6
ap3 2 11
5GHz shutdown list :
AP name RID Channel
6GHz shutdown list :
AP name RID Channel
Date Time : 2019-06-29 09:59:16
Range : All AP
Frequency-band : 5GHz
AP name RID Channel
AP name RID Channel
ap11 1 36
ap12 1 40
ap13 1 44
AP name RID Channel
表1-5 display wlan rrm high-density filter history命令显示信息描述表
Date Time |
筛选时间 |
Range |
筛选的AP范围,取值包括: · group-name (AP group):表示从指定AP组内筛选需要关闭的射频 · All AP:表示从所有AP范围内筛选需要关闭的射频 |
Frequency-band |
筛选的射频类型,取值包括: · 2.4GHz:筛选2.4GHz射频 · 5GHz:筛选5GHz射频 · 6GHz:筛选6GHz射频 · 2.4GHz/5GHz/6GHz:筛选2.4GHz、5GHz和6GHz射频 |
2.4GHz shutdown list |
已筛选的2.4GHz射频关闭列表 |
5GHz shutdown list |
已筛选的5GHz射频关闭列表 |
6GHz shutdown list |
已筛选的6GHz射频关闭列表 |
AP name |
AP名称 |
RID |
Radio ID |
Channel |
AP射频的工作信道 |
· wlan rrm high-density filter
display wlan rrm-calibration-group命令用来显示RRM保持调整组的相关信息。
display wlan rrm-calibration-group { all | group-id }
all:所有RRM保持调整组。
group-id:RRM保持调整组的ID。不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
# 显示RRM保持调整组10的相关信息。
<Sysname> display wlan rrm-calibration-group 10
RRM Calibration Group Information
Group ID : 10
Description : office
Channel holddown time : 720 minutes
Power holddown time : 60 minutes
Location name : default-location
Group members : ap4-radio2, ap3-radio2
表1-6 display wlan rrm-calibration-group命令显示信息描述表
Group ID |
RRM保持调整组的ID |
RRM保持调整组的描述信息 |
Channel holddown time |
信道保持时长 |
Power holddown time |
功率保持时长 |
Location name |
地区标识名称 在分层AC架构下: · 为AP组/RRM保持调整组标记指定的地区标识后,该AP组/RRM保持调整组将在逻辑上被划分到地区标识所标识的地域 · 在Web页面上,系统将根据管理员的用户角色过滤AP组/RRM保持调整组,管理员只能查看并管理与用户角色的地区标识相同的AP组/RRM保持调整组和标记了default-location的AP/RRM保持调整组 |
Group members |
加入RRM保持调整组的Radio |
display wlan rrm-history ap命令用来显示RRM调整历史信息。
display wlan rrm-history ap { all | name ap-name }
all:所有AP。
name ap-name:AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
该命令显示所有或指定AP上最近3次改变的信道或功率的详细信息。显示输出包括改变时间、触发原因、功率、干扰等参数。
# 显示ap1的RRM历史信息。
<Sysname> display wlan rrm-history ap name ap1
AP RRM History
Flags : I - Interference, P - Packets discarded, F - Retransmission,
R - Radar select, C - Coverage, B - Channelbusy
M – Manual D – Bandwidth O - Others
S - Scheduled
AP RRM History : ap1
Radio : 1 Basic BSSID : 000f-e2ff-7700
Ch Power BW Load Util Intf Reason Date Time
(dBm) (MHz) (%) (%) (%) (yyyy-mm-dd) (hh:mm:ss)
Before 36 20 20 24 2 21 -P------- 2014-07-07 17:31:50
After 40 20 20 9 0 8 - - -
Before 40 20 20 54 1 53 IP------- 2014-07-08 12:19:50
After 36 20 20 10 0 10 - - -
Before 36 20 20 29 1 28 -------D- 2014-07-08 12:59:50
After 36 20 40 30 0 29 - - -
表1-7 display wlan rrm-history命令显示信息描述表
Radio |
AP的Radio ID |
Basic BSSID |
基本服务集标识 |
Ch |
Radio的工作信道 |
Power (dBm) |
Radio的发射功率,单位为dBm |
BW (MHz) |
Radio的运行频宽,单位为MHz |
Load (%) |
信道的负载,以百分比表示 |
Util (%) |
信道的利用率,以百分比表示 |
Intf (%) |
信道检测到的干扰,以百分比表示 |
Reason |
调整的原因,包括以下取值: · I:干扰 · P:丢包 · F:重传 · R:规避雷达信号后,选用更优信道 · C:信号覆盖 · B:信道繁忙 · M:手动信道调整 · D:频宽调整 · S:定时调整 · O:其它原因 |
Date |
调整的日期 |
Time |
调整的时间 |
display wlan rrm-status ap命令用来显示AP上射频的RRM详细信息。
display wlan rrm-status ap { all | name ap-name } [ neighbor-type { managed | unmanaged } ]
all:所有AP。
neighbor-type:根据邻居类型显示探测到的RRM详细信息。如果不指定本参数,则显示AP能探测到的所有邻居类型的RRM详细信息。
managed:显示AP能探测到的管理邻居Radio的RRM详细信息。
unmanaged:显示AP能探测到的非管理邻居Radio的RRM详细信息。
如果信道和功率调整都处于关闭状态,则执行此命令时,不会显示信道报告和邻居报告。
# 显示ap1的信道和功率调整详细信息。
<Sysname> display wlan rrm-status ap name ap1
AP RRM Profile : ap1
Radio : 1 Basic BSSID : 70f9-6d31-2fe0
Channel : 157 Tx Power (dBm) : 18
Ch Nbrs Load Util Intf PER Retry Radar Last Detected At
36 0 0 - 0 0 - - 2020-04-10 09:35:01
40 0 0 - 0 0 - - 2020-04-10 09:35:01
44 0 0 - 0 0 - - 2020-04-10 09:35:01
48 0 0 - 0 0 - - 2020-04-10 09:35:01
52 0 0 - 0 0 - - 2020-04-10 09:35:01
56 0 0 - 0 0 - - 2020-04-10 09:35:01
60 0 0 - 0 0 - - 2020-04-10 09:35:01
64 0 0 - 0 0 - - 2020-04-10 09:35:01
100 0 0 - 0 0 - - 2020-04-10 09:35:01
104 0 0 - 0 0 - - 2020-04-10 09:35:01
108 0 0 - 0 0 - - 2020-04-10 09:35:01
112 0 0 - 0 0 - - 2020-04-10 09:35:01
116 0 0 - 0 0 - - 2020-04-10 09:35:01
132 0 0 - 0 0 - - 2020-04-10 09:35:01
136 0 0 - 0 0 - - 2020-04-10 09:35:01
140 0 0 - 0 0 - - 2020-04-10 09:35:01
149 1 0 - 0 0 - - 2020-04-10 09:35:01
153 4 0 - 0 0 - - 2020-04-10 09:35:01
157 0 0 0 0 0 0 - 2020-04-10 09:35:01
161 2 0 - 0 0 - - 2020-04-10 09:35:01
165 0 0 - 0 0 - - 2020-04-10 09:35:01
Nbr-MACAddress Ch Intf SignalStrength Type Last Detected At
(%) (dBm)
000f-e212-ff01 161 0 -60 Unmanaged 2020-04-10 09:39:03
5866-ba74-e461 153 0 -72 Unmanaged 2020-04-10 09:39:03
70f9-6d30-9020 153 0 -40 Managed 2020-04-10 09:39:03
70f9-6d31-3080 149 0 -54 Managed 2020-04-10 09:39:03
70f9-6d31-34e0 161 0 -59 Managed 2020-04-10 09:39:03
7425-8a86-bbe0 153 0 -48 Unmanaged 2020-04-10 09:39:03
7425-8a86-c720 153 0 -63 Unmanaged 2020-04-10 09:39:03
Radio : 2 Basic BSSID : 70f9-6d31-2ff0
Channel : 1 Tx Power (dBm) : 19
1 6 4 0 4 0 0 - 2020-04-10 09:33:06
6 4 2 - 2 0 - - 2020-04-10 09:33:06
11 6 2 - 2 0 - - 2020-04-10 09:33:06
(%) (dBm)
000f-e212-ff11 1 49 -77 Unmanaged 2020-04-10 09:31:05
0023-89e1-ed00 11 0 -87 Unmanaged 2020-04-10 09:31:05
006a-55f6-ae10 1 57 -88 Unmanaged 2020-04-10 09:31:05
5866-ba64-aa31 1 10 -60 Unmanaged 2020-04-10 09:31:05
5866-ba74-e471 6 0 -76 Unmanaged 2020-04-10 09:31:05
5866-baa9-a610 11 0 -62 Unmanaged 2020-04-10 09:31:05
70f9-6d30-9030 6 0 -63 Managed 2020-04-10 09:31:05
70f9-6d31-3090 1 51 -86 Managed 2020-04-10 09:31:05
70f9-6d31-34f0 6 0 -85 Managed 2020-04-10 09:33:09
7425-8a86-bbf0 6 0 -73 Unmanaged 2020-04-10 09:33:09
7425-8a86-c731 11 0 -93 Unmanaged 2020-04-10 09:33:09
80f6-2ec0-3330 11 0 -76 Unmanaged 2020-04-10 09:33:09
80f6-2ec0-3331 11 0 -73 Unmanaged 2020-04-10 09:33:09
80f6-2edd-d2d0 1 40 -60 Unmanaged 2020-04-10 09:33:09
80f6-2edd-d2d1 1 44 -68 Unmanaged 2020-04-10 09:33:09
80f6-2ede-0b30 11 0 -74 Unmanaged 2020-04-10 09:33:09
表1-8 display wlan rrm-status命令显示信息描述表
Radio |
AP的Radio ID |
Basic BSSID |
基本服务集标识 |
Channel |
Radio当前的工作信道 |
Tx Power |
Radio的发射功率 |
Ch |
Radio支持的工作信道 |
Nbrs |
信道中的邻居Radio数量 |
Load |
信道的负载,以百分比表示。信道的负载指的是在该信道上,AP发送报文/接收客户端的报文和干扰,这里的干扰指该AP接收到其它AP和客户端发送的错误报文 |
Util |
信道利用率,以百分比表示。信道利用率指的是在该信道上,AP发送报文/接收客户端的报文 |
Intf |
信道检测到的干扰,以百分比表示 |
PER |
信道检测到的误码率,以百分比表示 |
Retry |
信道检测到的重传率,以百分比表示 |
Radar |
雷达检测状态: · -表示没有检测到雷达 · Detected表示检测到雷达 |
Nbr-MACAddress |
邻居AP的Radio接口的MAC地址 |
SignalStrength |
检测到邻居Radio的信号强度,以dBm为单位 |
Type |
AP类型: · Unmanaged:该AP上的Radio能探到的非管理邻居Radio · Managed:该AP上的Radio能探测到的管理邻居Radio |
Last Detected At |
最近一次检测到信道和邻居有效数据的时间 |
interference-threshold命令用来配置信道干扰门限值。
undo interference-threshold命令用来恢复缺省情况。
RRM视图:继承AP组RRM配置。
AP组RRM视图:信道干扰门限值为0。
RRM视图
AP组RRM视图
percent:信道干扰门限,取值范围为0~100,单位为百分比。取值为0时表示自动信道调整不参考信道干扰门限。
信道干扰门限值是触发自动信道调整的条件之一,当AC检测到信道中的干扰帧占所有数据帧的百分比超过设定值时,触发信道调整。干扰帧是指目的不是当前工作射频的帧。
# 配置信道干扰门限值为60。(RRM视图)
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] rrm
[Sysname-wlan-ap-ap1-radio-1-rrm] interference-threshold 60
# 配置信道干扰门限值为60。(AP组RRM视图)
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] ap-model WA6320
[Sysname-wlan-ap-group-group1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1] rrm
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] interference-threshold 60
power holddown-time命令用来配置功率保持时长。
undo power holddown-time命令用来恢复缺省情况。
power holddown-time minutes
功率保持时长为60分钟。
RRM保持调整组视图
minutes:功率保持时长,取值范围为10~1440,单位为分钟。
加入到RRM保持调整组的射频功率在每次调整后的功率保持时长内将不作调整。
# 为RRM保持调整组10配置功率保持时长为600分钟。
[Sysname] wlan rrm-calibration-group 10
[Sysname-wlan-rrm-calibration-group-10] power holddown-time 600
rrm命令用来进入RRM(Radio Resource Management,射频资源管理)视图。
rrm
不存在RRM视图。
Radio视图
AP组Radio视图
AP组全局Radio视图
# 进入RRM视图。(Radio视图)
# 进入RRM视图。(AP组Radio视图)
#进入RRM视图。(AP组全局Radio视图)
[Sysname-wlan-ap-group-group1] radio 5g
[Sysname-wlan-ap-group-group1-radio-5g] rrm
scan-only enable命令用来开启射频的扫描功能。
scan-only disable命令用来关闭射频的扫描功能。
undo scan-only命令用来恢复缺省情况。
scan-only { disable | enable }
undo scan-only
RRM视图:继承AP组RRM配置。
AP组RRM视图:射频的扫描功能处于关闭状态。
RRM视图
AP组RRM视图
开启射频的扫描功能后,AP将对无线环境进行扫描与数据采集工作,周期性的将数据上报给AC,由AC生成信道报告和邻居报告。信道报告与邻居报告的详细内容可通过display wlan rrm-status ap命令查看。
配置自动信道调整或自动功率调整会开启射频的扫描功能。因此,如果已经配置了自动信道调整或自动功率调整,则不需要配置本命令。
# 开启射频的信道扫描功能。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] scan-only enable
# 开启射频的信道扫描功能。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] scan-only enable
· display wlan rrm-status ap
snmp-agent trap enable wlan rrm命令用来开启RRM告警功能。
undo snmp-agent trap enable wlan rrm命令用来关闭RRM告警功能。
RRM告警功能处于关闭状态。
开启RRM的告警功能之后,射频资源管理会生成告警信息,以向网管软件报告本模块的重要事件。该信息将发送至SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 开启RRM的告警功能。
[Sysname] snmp-agent trap enable wlan rrm
tolerance-level命令用来配置容限系数。
undo tolerance-level命令用来恢复缺省情况。
RRM视图:继承AP组RRM配置。
AP组RRM视图:继承全局配置。
RRM视图
AP组RRM视图
percent:容限系数,以百分比表示,取值范围为0~100。0表示信道调整计算不参考容限系数。
# 配置容限系数为25。(RRM视图)
[Sysname-wlan-ap-ap1-radio-1-rrm] tolerance-level 25
# 配置容限系数为25。(AP组RRM视图)
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] tolerance-level 25
wlan calibrate-bandwidth pronto ap命令用来手动触发指定AP的射频进行自动频宽调整。
wlan calibrate-bandwidth pronto ap { all | ap-group group-name } { 5g | 6g | all }
all:手动触发所有AP的射频进行自动频宽调整。
ap-group group-name:手动触发指定AP组内所有AP的射频进行自动频宽调整。group-name为AP组的名称,为1~31个字符的字符串,不区分大小写。
5g:手动触发AP的5GHz频段射频进行自动频宽调整。
6g:手动触发AP的6GHz频段射频进行自动频宽调整。
all:手动触发AP的5GHz和6GHz频段射频进行自动频宽调整。
执行本命令可能会占用较多系统资源,请谨慎使用。
# 手动触发所有AP的5GHz和6GHz频段射频进行自动频宽调整。
[Sysname] wlan calibrate-bandwidth pronto ap all all
wlan calibrate-bandwidth pronto use-monitoring-data ap命令用来在定时调整模式下触发指定AP的射频进行自动频宽调整。
wlan calibrate-bandwidth pronto use-monitoring-data ap { all | ap-group group-name } { 5g | 6g | all }
all:在定时调整模式下触发所有AP的射频进行自动频宽调整。
ap-group group-name:在定时调整模式下触发指定AP组内所有AP的射频进行自动频宽调整。group-name为AP组的名称,为1~31个字符的字符串,不区分大小写。
5g:在定时调整模式下触发AP的5GHz频段射频进行自动频宽调整。
6g:在定时调整模式下触发AP的6GHz频段射频进行自动频宽调整。
all:在定时调整模式下触发AP的5GHz和6GHz频段射频进行自动频宽调整。
在干扰严重的区域,频繁进行自动频宽调整可能会影响用户的正常网络使用。可通过配置定时自动频宽调整功能,使AC仅在命令calibrate-bandwidth monitoring time-range指定的时间段内收集射频环境信息,生成信道报告与邻居报告,然后根据报告进行定时调整。
# 在定时调整模式下触发所有AP的5GHz和6GHz频段射频进行自动频宽调整。
[Sysname] scheduler job rrm
[Sysname-job-rrm] command 1 system-view
[Sysname-job-rrm] command 2 wlan calibrate-bandwidth pronto use-monitoring-data ap all all
· calibrate-bandwidth mode
· calibrate-bandwidth monitoring time-range
wlan calibrate-channel pronto ap命令用来手动触发AP射频进行自动信道调整。
wlan calibrate-channel pronto ap { all | ap-group group-name } { 2.4g | 5g | 6g | all }
all:手动触发所有AP的射频进行自动信道调整。
ap-group group-name:手动触发指定AP组内AP的射频进行自动信道调整。group-name为AP组的名称,为1~31个字符的字符串,不区分大小写。
2.4g:手动触发AP的2.4GHz频段射频进行自动信道调整。
5g:手动触发AP的5GHz频段射频进行自动信道调整。
6g:手动触发AP的6GHz频段射频进行自动信道调整。
all:手动触发AP的2.4GHz、5GHz和6GHz频段射频进行自动信道调整。
执行wlan calibrate-channel pronto ap命令可能会占用较多系统资源,请谨慎使用。
执行本命令后的16分钟内,所有AP或者指定AP组的射频将周期性的在工作信道提供无线服务和非工作信道扫描。射频在非工作信道扫描期间可能造成在线终端的报文丢失,建议在网络维护期内执行本命令。
# 手动触发所有AP的2.4GHz、5GHz和6GHz频段射频进行自动信道调整。
[Sysname] wlan calibrate-channel pronto ap all all
This operation will change the working channel of all radios and might cause packet loss. Continue? [Y/N]
wlan calibrate-channel pronto use-monitoring-data ap命令用来在定时调整模式下触发指定AP的指定射频进行自动信道调整。
wlan calibrate-channel pronto use-monitoring-data ap { all | ap-group group-name } { 2.4g | 5g | 6g | all }
all:在定时调整模式下触发所有AP的指定射频进行自动信道调整。
ap-group group-name:在定时调整模式下触发指定AP组内所有AP的指定射频进行自动信道调整。group-name为AP组的名称,为1~31个字符的字符串,不区分大小写。
2.4g:在定时调整模式下触发指定AP的2.4GHz频段射频进行自动信道调整。
5g:在定时调整模式下触发指定AP的5GHz频段射频进行自动信道调整。
6g:在定时调整模式下触发指定AP的6GHz频段射频进行自动信道调整。
all:在定时调整模式下触发指定AP的2.4GHz、5GHz和6GHz频段射频进行自动信道调整。
在干扰严重的区域,频繁进行自动信道调整可能会影响用户的正常网络使用。可通过配置定时自动信道调整功能,使AC仅在命令calibrate-channel monitoring time-range指定的时间段内收集射频环境信息,生成信道报告与邻居报告,然后根据报告进行定时调整。
# 在定时调整模式下触发所有AP的2.4GHz、5GHz和6GHz频段射频进行自动信道调整。
[Sysname-job-rrm] command 2 wlan calibrate-channel pronto use-monitoring-data ap all all
wlan calibrate-power pronto ap命令用来手动触发AP的射频进行自动功率调整。
wlan calibrate-power pronto ap { all | ap-group group-name } { 2.4g | 5g | 6g | all }
all:手动触发所有AP的射频进行自动功率调整。
ap-group group-name:手动触发指定AP组内AP的射频进行自动功率调整。group-name为AP组的名称,为1~31个字符的字符串,不区分大小写。
2.4g:手动触发AP的2.4GHz频段射频进行自动功率调整。
5g:手动触发AP的5GHz频段射频进行自动功率调整。
6g:手动触发AP的6GHz频段射频进行自动功率调整。
all:手动触发AP的2.4GHz、5GHz和6GHz频段射频进行自动功率调整。
执行wlan calibrate-power pronto ap命令可能会占用较多系统资源,请谨慎使用。
本功能对已经配置了最大传输功率的射频不生效。
# 手动触发所有AP的2.4GHz、5GHz和6GHz频段射频进行自动功率调整。
[Sysname] wlan calibrate-power pronto ap all all
wlan calibrate-power pronto use-monitoring-data ap命令用来在定时调整模式下触发指定AP的指定射频进行自动功率调整。
wlan calibrate-power pronto use-monitoring-data ap { all | ap-group group-name } { 2.4g | 5g | 6g | all }
all:在定时调整模式下触发所有AP的指定射频进行自动功率调整。
ap-group group-name:在定时调整模式下触发指定AP组内所有AP的指定射频进行自动功率调整。group-name为AP组的名称,为1~31个字符的字符串,不区分大小写。
2.4g:在定时调整模式下触发指定AP的2.4GHz频段射频进行自动功率调整。
5g:在定时调整模式下触发指定AP的5GHz频段射频进行自动功率调整。
6g:在定时调整模式下触发指定AP的6GHz频段射频进行自动功率调整。
all:在定时调整模式下触发指定AP的2.4GHz、5GHz和6GHz频段射频进行自动功率调整。
在干扰严重的区域,频繁进行自动功率调整可能会影响用户的正常网络使用。可通过配置定时自动功率调整功能,使AC仅在命令calibrate-power monitoring time-range指定的时间段内收集射频环境信息,生成信道报告与邻居报告,然后根据报告进行定时调整。
# 在定时调整模式下触发所有AP的2.4GHz、5GHz和6GHz频段射频进行自动功率调整。
[Sysname-job-rrm] command 2 wlan calibrate-power pronto use-monitoring-data ap all all
· calibrate-power mode
· calibrate-power monitoring time-range
wlan rrm baseline apply命令用来将射频工作参数基线应用到对应的射频。
wlan rrm baseline apply name baseline-name
name baseline-name:射频工作参数基线的名称,为1~32个字符的字符串,不区分大小写。
当射频工作参数基线处于以下任一情况时,将无法应用射频工作参数基线到对应的射频。
· 射频工作参数基线中保存了当前用户不具有location权限的AP的射频信息。
· 射频工作参数基线为start_config_baseline.csv。
# 应用名称为bl的射频工作参数基线。
[Sysname] wlan rrm baseline apply name bl
· display wlan rrm baseline apply-history
· wlan rrm baseline save
wlan rrm baseline remove命令用来删除射频工作参数基线。
wlan rrm baseline remove name baseline-name
射频工作参数基线中保存了当前用户不具有location权限的AP的射频信息时,该用户无法删除此射频工作参数基线。
# 删除名称为bl的射频工作参数基线。
[Sysname] wlan rrm baseline remove name bl
wlan rrm baseline save命令用来将当前射频的工作参数保存为工作参数基线。
wlan rrm baseline save name baseline-name { ap ap-name [ radio radio-id ] | ap-group group-name [ ap-model ap-model ] [ radio radio-id ] | global }
ap ap-name:AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。指定本参数时,该AP必须已存在。
radio radio-id:AP射频的编号。如果未指定本参数,将保存指定AP/AP组下指定型号的所有射频的工作参数。
ap-group group-name:AP组的名称,为1~31个字符的字符串,不区分大小写。指定本参数时,该AP组必须已存在。
ap-model ap-model:AP型号名称。若不指定本参数,将保存AP组下指定或所有射频的工作参数。
global:AC上的所有射频。
如果当前射频的工作信道与功率值合适,则可以使用本命令将射频的信道、功率值存储为射频工作参数基线,在需要的时候重新应用这些保存的值。
射频工作参数基线将以.csv文件的形式被保存到文件系统中。
# 将AP1上Radio 1的工作参数保存为射频工作参数基线,名称为ap1-1。
[Sysname] wlan rrm baseline save name ap1-1 ap ap1 radio 1
# 将AP1上AP组Radio 1的工作参数保存为射频工作参数基线,名称为ap1g1-1。
[Sysname] wlan rrm baseline save name ap1g1-1 ap-group group1 ap-model WA6320 radio 1
# 将AC上所有射频的工作参数保存为射频工作参数基线,名称为global。
[Sysname] wlan rrm baseline save name global global
wlan rrm calibration-bandwidth interval命令用来配置自动频宽调整周期。
undo wlan rrm calibration-bandwidth interval命令用来恢复缺省情况。
wlan rrm calibration-bandwidth interval minutes
自动频宽调整周期为13分钟。
minutes:自动频宽调整周期,取值范围为3~1440,单位为分钟。
# 配置自动频宽调整周期为10分钟。
[Sysname] wlan rrm calibration-bandwidth interval 10
· calibrate-bandwidth self-decisive
wlan rrm calibration-channel ap命令用来手动触发指定AP的射频进行自动信道调整。
wlan rrm calibration-channel ap name ap-name [ radio radio-id ] [ force ]
name ap-name:指定进行自动信道调整的AP。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
radio radio-id:指定进行自动信道调整的AP射频,其中radio-id为射频编号,本参数的取值范围与AP型号有关,请以设备的实际情况为准。如果未指定本参数,将对指定AP的所有射频进行信道调整。
force:不进行信道质量检测、计算,直接调整信道。如果未指定本参数,射频将经过信道质量检测、计算后调整信道。
配置本命令可让指定的AP射频强制进行一次自动信道调整,或者执行一次标准的信道调整流程(先进行信道质量检测,而后进行信道质量计算,最后进行信道调整)。
同时对多个射频进行信道调整时,某一个射频的信道调整结果不影响其它射频的调整。
配置本命令并指定force参数时,调整后的信道不一定是最优信道;配置本命令但未指定force参数时,最终是否能够调整信道与信道质量分析结果有关。
无论是否指定force参数,执行本命令后,设备会花费几分钟时间进行信道扫描、收集信道数据。在此期间:
· 终端的部分报文将被丢弃。
· 不应关闭射频开关、修改信道扫描相关配置、修改WLAN RRM相关配置。
本功能在分层组网和内置AP中不生效。
# 手动触发ap1的radio 1进行强制自动信道调整。
[Sysname] wlan rrm calibration-channel ap name ap1 radio 1 force
wlan rrm calibration-channel interval命令用来配置自动信道调整周期。
undo wlan rrm calibration-channel interval命令用来恢复缺省情况。
wlan rrm calibration-channel interval minutes
自动信道调整周期为23分钟。
minutes:自动信道调整周期,取值范围为3~1440,单位为分钟。
# 配置自动信道调整周期为10分钟。
[Sysname] wlan rrm calibration-channel interval 10
· calibrate-channel self-decisive
wlan rrm calibration-power interval命令用来配置自动功率调整周期。
undo wlan rrm calibration-power interval命令用来恢复缺省情况。
wlan rrm calibration-power interval minutes
自动功率调整周期为11分钟。
minutes:自动功率调整周期,取值范围为3~180,单位为分钟。
# 配置自动功率调整周期为10分钟。
[Sysname] wlan rrm calibration-power interval 10
· calibrate-power self-decisive
wlan rrm high-density filter命令用来筛选高密场景下需要关闭的AP射频。
wlan rrm high-density filter { all | ap-group group-name } { 2.4g | 5g | 6g | all }
all:表示从所有AP范围内筛选需要关闭的射频。
ap-group group-name:表示从指定AP组内筛选需要关闭的射频。group-name表示AP组的名称,为1~31个字符的字符串,不区分大小写。指定本参数时,该AP组必须已存在。
2.4g:筛选指定范围内AP的2.4GHz射频。
5g:筛选指定范围内AP的5GHz射频。
6g:筛选指定范围内AP的6GHz射频。
all:筛选指定范围内AP的2.4GHz、5GHz和6GHz射频。
在高密部署场景下,因为信道数量有限,相邻AP之间不可避免的会存在一定的干扰,且AP部署密度越高,干扰就越大。此种情况下,当无论如何调整信道都无法降低干扰时,可以通过配置本命令筛选高密场景下需要关闭的AP射频,然后通过命令display wlan rrm high-density filter history查看已筛选的射频关闭列表,并根据显示结果手动关闭该列表中的射频,降低高密场景下射频之间的干扰。
# 在AP组group1内筛选需要关闭的5GHz射频。
[Sysname] wlan rrm high-density filter ap-group group1 5g
# 在所有AP范围内筛选需要关闭的2.4GHz、5GHz和6GHz射频。
[Sysname] wlan rrm high-density filter all all
· display wlan rrm high-density filter history
wlan rrm-calibration-group命令用来创建RRM保持调整组并进入RRM保持调整组视图。如果指定的RRM保持调整组已经存在,则直接进入保持调整组视图。
undo wlan rrm-calibration-group命令用来删除已创建的RRM保持调整组。
wlan rrm-calibration-group group-id
undo wlan rrm-calibration-group { all | group-id }
不存在RRM保持调整组。
all:所有的RRM保持调整组。
group-id:RRM保持调整组的ID,取值范围为1~128。
# 创建ID为10的RRM保持调整组。
