03-设备管理命令参考
03-硬件资源管理命令
本章节下载 03-硬件资源管理命令  (694.16 KB)
03-硬件资源管理命令
  录
1 硬件资源管理
1.1 硬件资源管理配置命令
1.1.1 alarm cache
1.1.2 card-mode
1.1.3 display alarm
1.1.4 display alarm active
1.1.5 display alarm history
1.1.6 display cpu-usage
1.1.7 display cpu-usage configuration
1.1.8 display cpu-usage history
1.1.9 display cpu-usage overload
1.1.10 display cpu-usage overload summary
1.1.11 display device
1.1.12 display device manuinfo
1.1.13 display device manuinfo chassis-only
1.1.14 display device manuinfo fan
1.1.15 display device manuinfo power
1.1.16 display environment
1.1.17 display fan
1.1.18 display memory
1.1.19 display memory dma
1.1.20 display memory-threshold
1.1.21 display memory-threshold dma
1.1.22 display power-supply
1.1.23 display resource-monitor
1.1.24 display system memory process status
1.1.25 display transceiver alarm
1.1.26 display transceiver diagnosis
1.1.27 display transceiver interface
1.1.28 display transceiver itu-channel
1.1.29 display transceiver manuinfo
1.1.30 fan auto-control-mode
1.1.31 itu-channel
1.1.32 memory reclaim cache
1.1.33 memory reclaim process
1.1.34 memory-threshold
1.1.35 memory-threshold dma
1.1.36 memory-threshold usage
1.1.37 monitor cpu-usage enable
1.1.38 monitor cpu-usage interval
1.1.39 monitor cpu-usage statistics-interval core
1.1.40 monitor cpu-usage threshold
1.1.41 monitor cpu-usage threshold core
1.1.42 monitor disk-usage disk
1.1.43 monitor disk-usage interval
1.1.44 monitor resend cpu-usage
1.1.45 monitor resend cpu-usage core-interval
1.1.46 monitor resend memory-threshold dma
1.1.47 reset alarm active
1.1.48 resource-monitor minor resend enable
1.1.49 resource-monitor output
1.1.50 resource-monitor resource
1.1.51 shutdown-interval
1 硬件资源管理
1.1  硬件资源管理配置命令
1.1.1  alarm cache
alarm cache命令用来配置设备的告警信息缓存数量上限。
undo alarm cache命令用来恢复缺省情况。
alarm cache { max-history-count history-count  | max-sync-count sync-count }*
undo alarm cache [ max-history-count | max-sync-count ]*
本命令的支持情况与设备型号有关,请以设备实际情况为准。
型号
MSR1008
不支持
MSR1004-G
不支持
MSR1004-G-5GCN
不支持
MSR1104-G、MSR1104-G-DSL-CAT6
支持
MSR2630E-X1
不支持
MSR3610E-X1、MSR3610E-X1-DP
不支持
MSR3610-G-X3-DP、MSR3610-G-X3、MSR3610-G-X3-DP-DC、
MSR3610-G-X3-DC
不支持
MSR3620-G-X3
支持
型号
MSR2660-XS
不支持
MSR2680-XS
不支持
型号
MSR2600-12X-WiNet
不支持
MSR2610-13X-WiNet
不支持
告警信息缓存数量上限与设备的型号有关,请以设备的实际情况为准。
max-sync-count sync-count:表示重发告警信息缓冲数量上限,sync-count表示重发告警信息缓冲的最大数量,不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
max-history-count history-count:表示历史告警信息缓冲数量上限。history-count表示历史告警信息缓冲的最大数量,不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
通过配置设备的告警信息缓存数量上限,用户可以控制重发告警信息和历史告警信息的缓冲区大小。
# 配置重发告警信息缓冲数量上限为10000,配置历史告警信息缓冲数量上限为3000。
[Sysname] alarm cache max-sync-count 100000 max-history-count 3000
·     display alarm history
1.1.2  card-mode
card-mode命令用来配置接口卡的工作模式。
card-mode slot slot-number subslot subslot-number mode-name
本命令的支持情况与设备型号有关,详细说明如下表所示。
型号
MSR1008
支持
MSR1004-G
支持
MSR1004-G-5GCN
支持
不支持
MSR2630E-X1
支持
支持
MSR3610-G-X3-DC
支持
MSR3620-G-X3
支持
型号
MSR2660-XS
支持
MSR2680-XS
支持
型号
MSR2600-12X-WiNet
支持
MSR2610-13X-WiNet
支持
本命令的缺省情况与接口卡的型号有关,请以实际情况为准。
slot slot-number:表示单板所在的槽位号。‌对于本产品,slot-number只能为固定取值,表示整台设备。
subslot subslot-number:子卡所在的子槽位号。
mode-name:指定接口卡的工作模式。取值为:(mode-name的实际取值与接口卡的型号有关,请以接口卡的实际情况为准)
·     fe1:配置接口模块的工作模式为FE1(Fractional E1)模式。配置后,该接口模块上的所有接口可作为WAN E1-F接口使用。关于WAN E1-F接口的详细介绍请参见“接口管理配置指导”中“WAN接口”。
模式切换后必须重启设备或热插拔接口卡(如果接口卡支持热插拔),新配置的模式才会生效,还是配置后新模式立即生效,与设备的型号有关,请以设备的实际情况为准。
# 将位于指定接口卡的工作模式配置为oc-3-pos模式。‌‌
[Sysname] card-mode slot 2 subslot 1 oc-3-pos
Please reboot or hot-swap the card or subcard (if supported) to make the configuration take effect.
1.1.3  display alarm
display alarm命令用来显示设备硬件的告警信息。
display alarm [ slot slot-number ]
slot slot-number:显示指定单板的告警信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。‌对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。
# 显示设备硬件的告警信息。‌‌
<Sysname> display alarm
Slot CPU Level   Info
1    0   ERROR   faulty
表1-1 display alarm命令显示信息描述表
Slot
产生告警的slot,显示为“-”,表示产生告警的元件位于机框上
CPU
告警CPU的编号
Level
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO
Info
告警的详细信息。取值为:
·     faulty:表示该slot处于faulty状态(该slot可能正在启动,或者当前处于故障状态)
·     Fan n is absent:风扇n当前不在位
·     Power n is absent:电源n当前不在位
·     Power n is faulty:电源n处于异常状态
·     The temperature of sensor n exceeds the lower limit:传感器n的温度低于低温门限
·     The temperature of sensor n exceeds the upper limit:传感器n的温度高于高温门限
display alarm active命令用来显示设备当前仍未恢复的告警信息。
display alarm active [ verbose ]
型号
MSR1008
不支持
MSR1004-G
不支持
MSR1004-G-5GCN
不支持
支持
MSR2630E-X1
不支持
不支持
MSR3610-G-X3-DC
不支持
MSR3620-G-X3
支持
型号
MSR2660-XS
不支持
MSR2680-XS
不支持
型号
MSR2600-12X-WiNet
不支持
MSR2610-13X-WiNet
不支持
verbose:显示告警项的详细信息。不指定该参数时,显示告警项的概要信息。
当设备运行异常时,使用display alarm命令可以查看到相应的告警信息。对于过去发生的、已经恢复的告警可以使用display alarm history命令查看;对于过去发生的、当前仍未恢复的告警可以使用display alarm active命令查看。
# 显示设备当前仍未恢复的告警详细信息。‌
<Sysname> display alarm active verbose
Seq 4
Alarm Name: MemThresholdsevere
Object ID: H3C
Alarm ID: 0x8520003
Alarm Type: Environmental Alarm
Alarm Source: slot 0
Level: Major
Alarm Status: Active
Start Time: 2025-02-21 09:31:25
  Info: Free memory dropped below severe alarm threshold on slot 0.
Additional Text: N/A
表1-2 display alarm active verbose命令显示信息描述表
Seq
告警序列号,告警发生时由系统自动分配
Alarm Name
告警的名称
Object ID
告警对象对应的设备名称
Alarm ID
告警对象的ID
Alarm Type
告警类型,取值包括:
·     Communication Alarm
·     Equipment Alarm
·     Processing Failure
·     Environmental Alarm
·     Quality of Service Alarm
Alarm Source
告警对象所在位置
Level
告警的级别,级别由高到低依次为Critical、Major、Minor、Warning
Alarm Status
告警状态,取值包括:
·     Active
·     Recover
Start Time
告警发生时间
Info
告警的详细信息
Additional Text
告警附件信息,无附加信息显示“N/A”
# 显示设备当前仍未恢复的告警信息。‌‌
<Sysname>display alarm active
Seq         Level    Time                 Info
24          Major    2020-01-11 12:40:00  CPU usage is in minor alarm state on slot 1 cpu 0.
23           Minor    2020-01-11 12:30:00  Memory usage is in minor alarm state on slot 1 cpu 0.
22           Warning  2020-01-11 12:30:00  Interface GigabitEthernet0/0/1 changed to DOWN state.
表1-3 display alarm active命令显示信息描述表
Seq
告警序列号,告警发生时分配。
Level
Time
告警产生的时间
Info
告警的详细信息
# 显示设备当前仍未恢复的告警详细信息。‌‌
Seq 8
Alarm Name: Environmental Alarm
Object ID: H3C
Alarm ID: 0x1570004
Level: Major
Start Time: 2025-02-21 05:35:25
  Info: Free memory dropped below minor alarm threshold on slot 0.
表1-4 display alarm active verbose命令显示信息描述表
Seq
告警序列号,告警发生时由系统自动分配
Alarm Name
告警的名称
Object ID
告警对象对应的设备名称
Alarm ID
告警对象的ID
Alarm Type
告警类型,取值包括:
·     Equipment Alarm
Alarm Source
告警对象所在位置
Level
Alarm Status
告警状态,取值包括:
·     Active
·     Recover
Start Time
告警发生时间
Info
告警的详细信息
Additional Text
告警附件信息,无附加信息显示“N/A”
display alarm history命令用来显示设备告警历史信息。
display alarm history [ verbose ]
型号
MSR1008
不支持
MSR1004-G
不支持
MSR1004-G-5GCN
不支持
支持
MSR2630E-X1
不支持
不支持
MSR3610-G-X3-DC
不支持
MSR3620-G-X3
支持
型号
MSR2660-XS
不支持
MSR2680-XS
不支持
型号
MSR2600-12X-WiNet
不支持
MSR2610-13X-WiNet
不支持
verbose:显示告警项的详细信息。不指定该参数时,显示概要信息。
本命令最多可显示的信息条数与设备的型号有关,请以设备的实际情况为准。
# 显示设备告警历史信息。‌‌
<Sysname> display alarm history
Seq         Time                 Info
23          2020-01-11 12:40:00  CPU usage severe alarm cleared on slot 1 cpu 0.
22          2020-01-11 12:30:00  Memory usage severe alarm cleared on slot 1 cpu 0.
21          2020-01-11 12:30:00  Physical state of GigabitEthernet0/0/1 changed back to UP.
20          2020-01-11 12:30:00 Protocol state of GigabitEthernet0/0/1 changed back to UP.
表1-5 display alarm active命令显示信息描述表
Seq
告警序列号,告警发生时分配。
Time
告警产生的时间
Info
告警的详细信息
# 显示设备告警历史信息详细内容。‌‌
<Sysname> display alarm history verbose
Seq 24
Alarm Name: CPUUsageMajor
Object ID: H3C
Alarm ID: 0x8520003
Alarm Type: Communication Alarm
Alarm Source: GigabitEthernet0/0/1
Level: Minor
Occurred at: 2025-02-21 12:30:00
  Info: CPU usage severe alarm occurred on state slot 1 cpu 0.
Cleared at: 2025-02-21 12:40:30
  Info: CPU usage severe alarm cleared on slot 1 cpu 0.
Seq 23
Alarm Name: MemoryUsageMajor
Object ID: H3C
Alarm ID: 0x8520003
Level: Major
Occurred at: 2025-02-21 12:35:00
  Info: Memory usage severe alarm occurred on slot 1 cpu 0.
Cleared at: 2025-02-21 12:45:30
  Info: Memory usage severe alarm cleared on slot 1 cpu 0.
表1-6 display alarm history verbose命令显示信息描述表
Seq
告警序列号,告警发生时由系统自动分配
Alarm Name
告警的名称
Object ID
告警对象对应的设备名称
Alarm ID
告警对象的ID
Alarm Type
告警类型,取值包括:
·     Equipment Alarm
Alarm Source
告警对象所在位置
Level
Occurred at
告警发生时间
Cleared at
告警恢复时间
Info
告警的详细信息
Additional Text
告警附件信息,无附加信息显示“N/A”
display cpu-usage命令用来显示CPU利用率的统计信息。
display cpu-usage [ data-plane ][ summary ] [ slot slot-number ]
data-plane:显示数据平面对CPU利用率的统计信息。本参数的支持情况与设备的型号有关,请以设备的实际情况为准。
summary:以列表形式显示CPU利用率的统计信息。不指定该参数时,以区段形式显示CPU利用率的统计信息。
slot slot-number:显示指定单板的CPU利用率的统计信息。slot-number表示单板所在的槽位号。不指定该参数时,显示的是所有单板的相应信息。‌
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号。
core { core-number | all }:显示CPU核利用率的统计信息。其中,all表示显示所有CPU核利用率的统计信息;core-number表示CPU核的编号,显示指定CPU核利用率的统计信息。
当最近5秒、最近1分钟、最近5分钟的CPU利用率取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 以段的形式显示当前CPU利用率统计信息。‌‌
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# 以表的形式显示当前CPU利用率统计信息。‌‌
<Sysname> display cpu-usage summary
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
表1-7 display cpu-usage命令显示信息描述表
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU的平均利用率。该字段显示的是最近一个5秒统计周期内CPU的平均利用率
Last 5 sec
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU的平均利用率。该字段显示的是最近一个5秒统计周期内CPU的平均利用率。如果Last 5 sec的取值为“--”,则表示不支持统计该信息
1% in last 1 minute
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU的平均利用率
Last 1 min
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU的平均利用率。如果Last 1 min的取值为“--”,则表示不支持统计该信息
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU的平均利用率
Last 5 min
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU的平均利用率。如果Last 5 min的取值为“--”,则表示不支持统计该信息
display cpu-usage configuration命令用来显示CPU监控功能的相关配置。
slot slot-number:表示单板所在的槽位号。不指定该参数时,显示的是主用主控板上的相应信息。‌
cpu cpu-number:表示CPU的编号。
# 显示CPU监控功能的相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 90%.
Current minor alarm threshold is 80%.
Current recovery threshold is 40%.
Current severe alarm threshold is 85% for the following cores: 0.
Current minor alarm threshold is 8% for the following cores: 0.
Current recovery threshold is 5% for the following cores: 0.
Current statistics interval is 90 seconds for the following cores: 0.
表1-8 display cpu-usage configuration命令显示信息描述表
CPU利用率历史记录功能处于开启状态
CPU利用率历史记录的采样周期为60秒
CPU利用率严重级别告警门限为90%
CPU利用率轻度级别告警门限为80%
Current recovery-threshold is 40%.
CPU利用率恢复门限为40%
CPU核利用率的严重级阈值。本字段的支持情况与设备的型号有关,请以设备的实际情况为准
CPU核利用率的轻度级阈值。本字段的支持情况与设备的型号有关,请以设备的实际情况为准
CPU核利用率的恢复级阈值。本字段的支持情况与设备的型号有关,请以设备的实际情况为准
CPU核利用率的统计周期。本字段的支持情况与设备的型号有关,请以设备的实际情况为准
·     monitor cpu-usage enable
·     monitor cpu-usage interval
·     monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
job job-id:显示指定进程的CPU利用率的历史信息。job-id表示进程的编号,取值范围为1~2147483647。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理和监控命令参考”中的“系统维护与调试”。
slot slot-number:显示指定单板的CPU利用率的历史信息。slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是主用主控板上指定进程的相应信息。‌
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号。当不指定job和该参数时,表示所有CPU。当指定job参数,但不指定该参数时,表示默认CPU。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
·     纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
·     横坐标表示时间,时间越靠左表示距离当前时间越近。
·     用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示CPU利用率的历史记录。‌‌
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明系统(用“SYSTEM”表示,运行在Slot 1 CPU 0上)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
display cpu-usage overload命令用来显示CPU过载记录的具体信息。
display cpu-usage overload show-number [ stack-info ] slot slot-number [ cpu cpu-number ]
show-number:显示指定数目的CPU过载记录的具体信息,取值范围为1~10。
stack-info:显示CPU过载时,占用CPU最多的前三条进程的堆栈信息。不指定该参数时,不会显示堆栈信息。
slot slot-number:指定单板。slot-number为单板所在的槽位号。‌
CPU过载记录的具体信息包括CPU过载记录的汇总信息、CPU过载时占用CPU较多的进程的信息以及占用CPU最多的前三条进程的堆栈信息。
# 显示指定单板最近1次CPU过载记录的具体信息,不包括占用CPU最多的前三条进程的堆栈信息。‌‌
<Sysname> display cpu-usage overload 2 slot 1
CPU overload summary information:
Slot/CPU          Time                     Overload status    Processes
1/0               0000-00-00 00:00:00:000  No overloaded      NA
No CPU overload history.
表1-9 display cpu-usage overload命令显示信息描述表
CPU的简要过载信息
Time
过载时间,未过载时显示0000-00-00 00:00:00:000
Overload status
过载状态,取值为:
·     No overloaded:未过载状态,初始状态
·     Minor alarm:低级别过载状态,超过低级别告警门限
·     Severe alarm:高级别过载状态,超过高级别告警门限
·     Recovered:过载恢复状态,降到恢复门限以下
Processes
过载时的进程数目,没有过载时显示NA
CPU overload history on overload time 2018-11-12 10:00:00:000:
CPU的详细过载信息,如果没有显示No CPU overload history.
Overload time
过载时间,没有过载时显示0000-00-00 00:00:00:000
CPU utilization in recent 5 secs: 100.0%; 1 min: 100.0%; 5 mins: 100.0%
系统最近5秒CPU使用率;最近1分钟CPU使用率;最近5分钟CPU使用率
Top processes in recent 5 secs
按5 sec利用率由高到低排序
JID
任务编号(用于唯一标识一个进程,该编号不会随着进程的重启而改变)
PID
进程编号
PPID
父进程编号
CPU
进程最近一次被调度时,所在的CPU
进程状态,可能的取值为:
·     R:running,运行状态或处于运行队列
·     S:sleeping,可中断睡眠状态
·     T:traced or stopped,暂停状态
·     D:uninterruptible sleep,不可中断睡眠状态
·     Z:zombie,僵死状态
Mem
进程所使用的内存大小(内核线程该项显示为0)
5sec
最近5秒钟内进程的CPU使用率
1min
最近1分钟内进程的CPU使用率
5min
最近5分钟内进程的CPU使用率
Name
进程名称(如果进程名称带有“[ ]”标记,则表示该进程为内核线程)
Stack information of process 1 (scmd):
进程的堆栈信息,进程的PID为1,进程名称为scmd
Thread LWP 1:
被跟踪进程的子进程
Switches
调度计数
User stack
用户态堆栈信息,仅用户态进程显示该信息
Kernel stack
内核态堆栈信息,仅内核态进程显示该信息
·     display cpu-usage overload summary
display cpu-usage overload summary命令用来显示所有CPU过载记录的汇总信息。
# 显示所有CPU过载记录的汇总信息。‌‌
<Sysname> display cpu-usage overload summary
1/0               2018-11-12 12:00:00:000  Recovered          300
                  2018-11-12 11:00:00:000  Minor alarm        400
                  2018-11-12 10:00:00:000  Severe alarm       500
                  2018-11-12 09:00:00:000 Minor alarm        400
表1-10 display cpu-usage overload summary命令显示信息描述表
CPU的简要过载信息
Time
Overload status
过载状态,取值为:
Processes
过载时的进程数目,没有过载时显示NA
display device命令用来显示设备硬件信息。
display device[ harddisk ][ slot slot-number [ subslot subslot-number ] | verbose ]
harddisk:显示硬盘的信息。
harddisk参数的支持情况与设备型号有关,请以设备实际情况为准。
型号
MSR1008
不支持
MSR1004-G
不支持
MSR1004-G-5GCN
不支持
不支持
MSR2630E-X1
支持
不支持
MSR3610-G-X3-DC
不支持
MSR3620-G-X3
不支持
型号
MSR2660-XS
不支持
MSR2680-XS
支持
型号
MSR2600-12X-WiNet
不支持
MSR2610-13X-WiNet
支持
slot slot-number:显示指定单板的信息。slot-number表示单板所在的槽位号。不指定该参数时,表示所有单板。‌‌‌
subslot subslot-number:显示指定子卡的信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息,且此时不会显示防火墙插卡的信息。
# 显示设备硬件信息。‌
<Sysname> display device
显示信息略......
表1-11 display device命令显示信息描述表
Slot No.
槽位号
Board type
设备的名称
Status
设备的状态:
·     Fault表示该设备不能正常工作
·     Normal表示该设备处于正常工作状态
Primary
主备状态:
·     Standby表示该板是备用主控板
·     Master表示该板是主用主控板
SubSlots
子卡槽位数量
display device manuinfo命令用来显示设备硬件的电子标签信息。
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
slot slot-number:显示指定单板的电子标签信息。slot-number表示单板所在的槽位号。不输入该参数时,显示所有单板的相应信息。‌‌‌
subslot subslot-number:显示指定子卡的电子标签信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
电子标签信息也可以称为永久配置数据或档案信息等,在硬件的调测(调试、测试)过程中被写入到设备的存储器件中,包括硬件的名称、生产序列号、MAC地址、制造商等信息。
# 显示设备硬件的电子标签信息。
<Sysname> display device manuinfo
显示信息略……。
display device manuinfo chassis-only命令用来显示背板的电子标签信息。
型号
MSR1008
支持
MSR1004-G
支持
MSR1004-G-5GCN
支持
支持
MSR2630E-X1
支持
支持
MSR3610-G-X3-DC
支持
MSR3620-G-X3
不支持
型号
MSR2660-XS
支持
MSR2680-XS
支持
型号
MSR2600-12X-WiNet
支持
MSR2610-13X-WiNet
支持
# 显示机框背板的电子标签信息。
<Sysname> display device manuinfo chassis-only
显示信息略……。
display device manuinfo fan命令用来显示风扇的电子标签信息。
display device manuinfo fan fan-id
型号
MSR1008
支持
MSR1004-G
支持
MSR1004-G-5GCN
支持
支持
MSR2630E-X1
支持
支持
MSR3610-G-X3-DC
支持
MSR3620-G-X3
不支持
型号
MSR2660-XS
支持
MSR2680-XS
支持
型号
MSR2600-12X-WiNet
支持
MSR2610-13X-WiNet
支持
fan-id:表示设备上风扇的ID编号。
# 显示指定风扇的电子标签信息。
<Sysname> display device manuinfo fan 1
显示信息略……。
display device manuinfo power命令用来显示电源的电子标签信息。
display device manuinfo power power-id
power-id:表示设备上电源的ID编号。
# 显示指定电源的电子标签信息。‌‌
<Sysname> display device manuinfo power 1
显示信息略……。
display environment命令用来显示设备上温度传感器的温度信息。
slot slot-number:显示设备中指定单板上的温度传感器的温度信息。slot-number表示单板所在的槽位号。不指定该参数时,显示所有单板的对应信息。‌‌‌
不指定slot参数时,显示的是设备上所有温度传感器的温度信息。‌
# 显示设备上所有温度传感器的温度信息。‌‌
<Sysname> display environment
 System temperature information (degree centigrade):
 Slot  Sensor       Temperature  Lower       Warning       Alarm       Shutdown
 1     hotspot 1    38           10          40            50          100
 1     hotspot 2    42           10          50            80          100
表1-12 display environment命令显示信息描述表
System Temperature information (degree centigrade)
系统温度信息,单位为摄氏度
sensor
温度传感器
·     hotspot:表示热点温度传感器
·     inflow:表示入风口温度传感器
·     outflow:表示出风口温度传感器
Slot
当显示数字时表示指定slot上温度传感器的温度信息
Temperature
当前温度
Lower
低温告警门限。当显示为NA时,表示不支持该门限
Warning
一般级(Warning)高温告警门限。当显示为NA时,表示不支持该门限
Alarm
严重级(Alarm)高温告警门限。当显示为NA时,表示不支持该门限
Shutdown
关断级(Shutdown)高温告警门限,当温度传感器的温度大于该门限时,设备会自动关闭。当显示为NA时,表示不支持该门限
1.1.17  display fan
display fan命令用来显示风扇的工作状态。
display fan [ fan-id ]
fan-id:表示设备内置风扇的编号。不指定该参数时,表示指定位置的所有风扇。
# 显示风扇的工作状态。
<Sysname> display fan
Fan No.     State       Speed
0           Normal      60
1           Normal      60
表1-13 display fan命令显示信息描述表
Fan No.
设备上风扇的编号
风扇状态:
·     Absent:风扇不在位
·     Normal:风扇正常工作
·     Fault:风扇故障
Speed
风扇转速
display memory命令用来显示内存使用情况。
summary:显示内存使用情况的简要信息。不指定该参数时,显示内存使用情况的详细信息。
slot slot-number:表示单板所在的槽位号,不指定时显示当前所有单板的内存使用情况。‌
cpu cpu-number:表示CPU编号。
当显示信息中某一行所有参数的取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 显示设备的内存使用情况的详细信息。‌‌
<Sysname> display memory
Memory statistics are measured in KB(Available):
Slot 0:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:      16335164   4145632  12189532         0      8596   2472508       77.5%
-/+ Buffers/Cache:   1664528  14670636
Swap:            0         0         0
Container memory statistics are measured in KB(Available):
Slot 0:
             Total      Used      Free  UsageRatio
Mem:      16335164   2357588  12189532       14.4%
# 显示设备的内存使用情况的简要信息。‌‌
<Sysname> display memory summary
Slot CPU        Total      Used      Free  Buffers    Caches FreeRatio
   0   0     16335164   4144720  12190444     8596   2472508     77.5%
Slot CPU        Total      Used      Free  UsageRatio
   0   0     16335164   2358048  12190444       14.4%
表1-14 display memory命令显示信息描述表
物理设备中可用内存使用情况,以下统计信息均以KB为单位
Mem
内存使用信息
Total
系统可分配的物理内存的大小
设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小
Used
整个系统已用的物理内存大小
Free
整个系统可用的物理内存大小
Shared
多个进程共享的物理内存总额。取值为“--”时,表示不支持统计该参数的值
Buffers
已使用的文件缓冲区的大小。取值为“--”时,表示不支持统计该参数的值
Cached
高速缓冲寄存器已使用的内存大小。取值为“--”时,表示不支持统计该参数的值
Caches
高速缓冲寄存器已使用的内存大小
FreeRatio
整个系统物理内存的空闲率
-/+ buffers/cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小
Swap
交换分区的使用信息
display memory dma命令用来显示DMA内存的使用情况。
display memory dma [ slot slot-number [ cpu cpu-number ] ]
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。‌
# 显示slot1的DMA内存使用相关信息。‌‌
<System> display memory dma slot 1
DMA memory statistics measured in KB on slot 1:
Total        Used         Free         FreeRatio
16384        6140         10244        63%
表1-15 display memory dma 命令显示信息描述表
系统使用DMA内存情况,单位为KB
Total
内存分片的总个数,为Free和Used之和
Used
系统已使用的DMA内存大小
Free
系统可使用的DMA内存大小
FreeRatio
Free与Total的比率,可以反映系统DMA内存的空闲率
display memory-threshold命令用来显示内存告警门限相关信息。
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示主用主控板。‌
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
    Minor: 256M
    Severe: 192M
    Critical: 128M
    Normal: 320M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Enter minor low-memory state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to minor low-memory state]
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
表1-16 display memory-threshold命令显示信息描述表
内存利用率阈值
Free-memory thresholds
    Minor
    Severe
    Critical
    Normal
    Early-warning
    Secure
剩余内存门限阈值:
·     Minor:一级告警门限,单位为MB
·     Severe:二级告警门限,单位为MB
·     Critical:三级告警门限,单位为MB
·     Normal:恢复到正常状态的阈值,单位为MB
·     Early-warning:预警门限,单位为MB
·     Secure:恢复预警门限状态的阈值,单位为MB
Current free-memory state
系统当前内存使用状态:
·     Normal:正常状态
·     Minor:一级告警门限状态
·     Severe:二级告警门限状态
·     Critical:三级告警门限状态
·     Normal (early-warning):预告警状态
·     Normal (secure):安全状态
Free-memory event statistics:
门限事件统计信息,事件分为:
·     Back to secure state:恢复到预警前的状态
·     Entered early-warning state:进入预告警门限状态
·     Back to normal state:内存恢复到正常状态
·     Entered minor alarm state:进入一级告警门限状态
·     Back to minor alarm state:恢复到一级告警前的状态
·     Entered severe alarm state:进入二级告警门限状态
·     Back to severe alarm state:恢复到二级告警前的状态
·     Entered critical alarm state:进入三级告警门限状态
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
Total number of notification send
事件发生的总次数
display memory-threshold dma命令用来显示DMA内存告警相关信息。
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
# 显示DMA内存告警相关信息。
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
    Critical: 2048KB
    Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
 [Entered to critcal state]
表1-17 display memory-threshold dma 命令显示信息描述表
    Critical:
    Normal:
DMA内存告警阈值(单位为KB):
·     Critical:告警阈值
·     Normal:告警恢复阈值
DMA内存的当前状态:
·     Critical:告警状态
·     Normal:正常状态
告警事件统计信息,事件分为:
·     Entered to critcal state:进入告警状态
First notification
告警事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
Latest notification
告警事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
告警事件发生的总次数
display power-supply命令用来显示电源管理功能的相关信息。
display power-supply [ verbose ]
verbose:显示电源管理功能的详细信息。不指定该参数时,显示电源管理功能的简要信息。
# 显示电源管理功能的相关信息(该显示信息与设备的型号有关,请以设备的实际情况为准)。
<Sysname> display power-supply
display resource-monitor命令用来显示资源监控功能的相关信息。
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
resource resource-name:需要监测的资源的名称。
slot slot-number:显示指定单板的资源告警事件通知功能的相关信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。‌
cpu cpu-number:显示指定CPU的资源告警事件通知功能的相关信息。cpu-number表示需要检测的资源所在CPU的编号。
# 显示资源监控功能的相关信息。
<Sysname> display resource-monitor resource
Minor alarms resending: Enabled
Slot 0:
Resource                         Minor Severe Free/Total
                                 (%)   (%)    (absolute)
acl_rule                         20    10     10239/10240
ipv4fib                          20    10     199981/200000
ipv6fib                          20    10     199992/200000
表1-18 display resource-monitor命令显示信息描述表
周期发送低级别资源告警通知功能的开启状态:
·     Enabled:表示该功能已开启
·     Disabled:表示该功能未开启
Resource
监控资源的名称
Minor
低级别告警门限,单位为百分比
Severe
高级别门限,单位为百分比
Free/Total
(absolute)
剩余资源的数量/该资源的总数,用绝对值形式表示
·     resource-monitor minor resend enable
·     resource-monitor resource
display system memory process status命令用来显示进程对内存的占用信息。
display system memory process status [ slot slot-number [ cpu cpu-number ] ]
此命令适用于用户需要查看当前设备各进程的内存占用情况时。通过该命令,用户可以快速了解各进程的内存使用情况,从而进行性能分析和故障排查。
# 显示进程对内存的占用信息。
<Sysname> display system memory process status
        JID      Total   Reclaim       Heap  Reclaim heap    Process name
          1       5220         0       1160             0    scmd
        331       1096         0         72             0    dbus-daemon
        333      11002         0       2784             0    drv_app
        392         12      7732          0          5704    cpfagentd
        395          8      2116          0           112    mdcagentd
        396          8      1920          0           240    lipcd
        398          8      1960          0           192    fsd
        399      28316      1568      16576          1312    dbmd
---- More ----
表1-19 display system memory process status命令显示信息描述表
JID
Total
进程实际使用的物理内存大小,包括独占内存和共享内存
Reclaim
进程回收内存的大小
Heap
在进程的PSS中堆内存所占空间的大小
Reclaim heap
在进程的回收内存中堆内存所占空间的大小
Process name
进程的名称
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见“display transceiver alarm命令输出信息描述表”。如果没有故障,则显示为None。
表1-20 SFP/SFP+/GBIC/SFF的display transceiver alarm命令输出信息描述表
RX signal loss
接收信号丢失
RX power high alarm
接收光功率高告警
RX power high warning
接收光功率高预警
RX power low alarm
接收光功率低告警
RX power low warning
接收光功率低预警
TX fault
发送错误
TX bias high alarm
偏置电流高告警
TX bias high warning
偏置电流高预警
TX bias low alarm
偏置电流低告警
TX bias low warning
偏置电流低预警
TX power high alarm
发送光功率高告警
TX power high warning
发送光功率高预警
TX power low alarm
发送光功率低告警
TX power low warning
发送光功率低预警
Temp high alarm
温度高告警
Temp high warning
温度高预警
Temp low alarm
温度低告警
Temp low warning
温度低预警
Voltage high alarm
电压高告警
Voltage high warning
电压高预警
Voltage low alarm
电压低告警
Voltage low warning
电压低预警
Transceiver info I/O error
模块信息读写错误
Transceiver info checksum error
模块信息校验和错误
Transceiver type and port configuration mismatch
模块类型和端口配置不匹配
Transceiver type not supported by port hardware
端口不支持该模块类型
TEC fault
TEC(Thermoelectric Cooler,热点冷却器)错误。仅HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A)、SFP-XG-LH80-Tunable光模块支持显示该信息
Wavelength unlocked
光信号波长失锁。仅HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A)、SFP-XG-LH80-Tunable光模块支持显示该信息
Tx is not ready due to tuning
光信号波长改变时发射端处于准备过程状态告警。仅HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A)、SFP-XG-LH80-Tunable光模块支持显示该信息
RX CDR loss of lock
接收侧CDR失锁,表示信号不好
TX CDR loss of lock
发送侧CDR失锁,表示信号不好
表1-21 QSFP+/QSFP28的display transceiver alarm命令输出信息描述表
Temp high alarm
温度高告警
Temp high warning
温度高预警
Temp low alarm
温度低告警
Temp low warning
温度低预警
Voltage high alarm
电压高告警
电压高预警
Voltage low alarm
电压低告警
Voltage low warning
电压低预警
RX loss of signal(channel x)
通道x接收到的信号丢失,单通道光模块不显示“(channel x)”字段
TX fault(channel x)
通道x发送报文时出错,单通道光模块不显示“(channel x)”字段
TX loss of signal(channel x)
通道x发送的信号丢失,单通道光模块不显示“(channel x)”字段
RX power high(channel x)
通道x接收到的光的功率太高,单通道光模块不显示“(channel x)”字段
RX power low(channel x)
通道x接收到的光的功率太低,单通道光模块不显示“(channel x)”字段
TX power high alarm(channel x)
通道x发送光功率高告警,单通道光模块不显示“(channel x)”字段
TX power high warning(channel x)
通道x发送光功率高预警,单通道光模块不显示“(channel x)”字段
TX power low alarm(channel x)
通道x发送光功率低告警,单通道光模块不显示“(channel x)”字段
TX power low warning(channel x)
通道x发送光功率低预警,单通道光模块不显示“(channel x)”字段
TX bias high(channel x)
通道x的偏置电流高,单通道光模块不显示“(channel x)”字段
TX bias low(channel x)
通道x的偏置电流低,单通道光模块不显示“(channel x)”字段
模块读写错误
模块信息校验和错误
Transceiver type and port configuration mismatched
模块类型和端口配置不匹配
端口不支持该类型的模块
表1-22 CFP的display transceiver alarm命令输出信息描述表
TX jitter PLL unlocked
发送Jitter PLL失锁
TX CMU unlocked
发送CMU失锁
Overloaded
负载过大
Loss of REFCLK input
缺乏参考时钟
Channel signals out of alignment
主机通道信号不对齐
PLD or flash initialization error
初始化错误
Power supply fault
电源错误
CFP checksum error
校验和错误
TX bias high
偏置电流高
TX bias low
偏置电流低
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
RX signal loss in channel x
通道x接收到的信号丢失
RX IC unlocked in channel x
通道x接收到的IC时钟失锁
RX FIFO error in channel x
通道x接收到FIFO错误
TX signal loss in channel x
通道x发送的信号丢失
TX IC unlocked in channel x
通道x发送的IC时钟失锁
TX FIFO error in channel x
主机通道x的发送FIFO出错
主机通道x发送的IC时钟失锁
APD supply fault in channel x
通道x出现APD错误
TEC fault in channel x
通道x出现TEC错误
Wavelength unlocked in channel x
通道x的光信号波长失锁
RX power high in lane x
通道x接收到的光的功率太高
RX power low in lane x
通道x接收到的光的功率太低
TX power high in lane x
通道x发送的光的功率太高
TX power low in lane x
通道x发送的光的功率太低
TX bias high in lane x
通道x的偏置电流高
TX bias low in lane x
通道x的偏置电流低
Temp high in lane x
通道x的温度高
Temp low in lane x
通道x的温度低
模块读写错误
模块信息校验和错误
模块类型和端口配置不匹配
端口不支持该类型的模块
表1-23 XFP的display transceiver alarm命令输出信息描述表
RX signal loss
接收信号丢失
RX not ready
接收状态未就绪
RX CDR loss of lock
RX CDR时钟失锁
RX power high alarm
接收光功率高告警
接收光功率高预警
RX power low alarm
接收光功率低告警
接收光功率低预警
TX not ready
发送状态未就绪
TX fault
发送错误
TX CDR loss of lock
TX CDR时钟失锁
TX bias high alarm
偏置电流高告警
偏置电流高预警
TX bias low alarm
偏置电流低告警
TX bias low warning
偏置电流低预警
TX power high alarm
发送光功率高告警
发送光功率高预警
TX power low alarm
发送光功率低告警
发送光功率低预警
Module not ready
模块状态未就绪
APD supply fault
APD(Avalanche Photo Diode,雪崩光电二极管)错误
TEC fault
Wavelength unlocked
光信号波长失锁
Temp high alarm
温度高告警
Temp high warning
温度高预警
Temp low alarm
温度低告警
Temp low warning
温度低预警
Voltage high alarm(3.3V)
电压高告警(3.3V)
Voltage high warning(3.3V)
电压高预警(3.3V)
Voltage low alarm(3.3V)
电压低告警(3.3V)
Voltage low warning(3.3V)
电压低预警(3.3V)
Voltage high alarm(5.5V)
电压高告警(5.5V)
Voltage high warning(5.5V)
电压高预警(5.5V)
Voltage low alarm(5.5V)
电压低告警(5.5V)
Voltage low warning(5.5V)
电压低预警(5.5V)
Voltage high alarm(1.8V)
电压高告警(1.8V)
Voltage high warning(1.8V)
电压高预警(1.8V)
Voltage low alarm(1.8V)
电压低告警(1.8V)
Voltage low warning(1.8V)
电压低预警(1.8V)
Voltage high alarm(5.2V)
电压高告警(5.2V)
Voltage high warning(5.2V)
电压高预警(5.2V)
Voltage low alarm(5.2V)
电压低告警(5.2V)
Voltage low warning(5.2V)
电压低预警(5.2V)
模块信息读写错误
模块信息校验错误
模块类型和端口配置不匹配
端口不支持该模块类型
表1-24 XENPAK的display transceiver alarm命令输出信息描述表
WIS local fault
WIS(WAN Interface Sublayer)本地错误
Receive optical power fault
接收光功率错误
PMA/PMD receiver local fault
PMA/PMD(Physical Medium Attachment/Physical Medium Dependent)接收器本地错误
PCS receive local fault
PCS(Physical Coding Sublayer)接收本地错误
PHY XS receive local fault
PHY XS(PHY Extended Sublayer)接收本地错误
RX power high
接收光功率高
RX power low
接收光功率低
Laser bias current fault
激光器偏置电流错误
Laser temperature fault
激光器温度错误
Laser output power fault
激光器输出光功率错误
TX fault
发送器错误
PMA/PMD接收器本地错误
PCS接收本地错误
PHY XS接收本地错误
TX bias high
偏置电流高
TX bias low
偏置电流低
TX power high
发送光功率高
TX power low
发送光功率低
Temp high
温度高
Temp low
温度低
模块信息I/O错误
模块信息校验错误
模块类型和端口配置不匹配
端口不支持该模块类型
表1-25 QSFP-DD光模块的display transceiver alarm命令输出信息描述表
Data path firmware fault
数据通道固件错误
Module firmware fault
模块固件错误
Module state changed
模块状态改变
Data path state changed in channel x
通道x的数据路径状态改变
TX loss in channel x
通道x的发送信号丢失
TX CDR LOL in channel x
通道x的TX 时钟和数据恢复失锁
TX input eq fault in channel x
通道x的TX输入均衡错误
RX CDR LOL in channel x
通道x的RX 时钟和数据恢复失锁
Loss of reference clock
基准时钟丢失
L-host pattern generator LOL in channel x
通道x的主机端码型发生器失锁
L-media pattern generator LOL in channel x
通道x的介质端模式发生器失锁
L-host pattern checker LOL in channel x
通道x的主机端码型检查器失锁
L-media pattern checker LOL in channel x
通道x的介质端模式检查器失锁
TEC Current high
制冷器工作电流/制冷器的额定电流高告警
TEC Current low
制冷器工作电流/制冷器的额定电流低告警
Laser Temperature high
激光器温度高告警
Laser Temperature low
激光器温度低告警
Temp high warning
模块温度高预警
Temp low warning
模块温度低预警
模块电压高预警
Voltage low warning
模块电压低预警
RX power high warning(channel x)
通道x的接收功率高预警
RX power low warning(channel x)
通道x的接收功率低预警
通道x的发送功率高预警
通道x的发送功率低预警
TX bias high warning(channel x)
通道x的发送电流高预警
TX bias low warning(channel x)
通道x的发送电流低预警
TEC Current high warning
制冷器工作电流/制冷器的额定电流高预警
TEC Current low warning
制冷器工作电流/制冷器的额定电流低预警
Laser Temperature high warning
激光器温度高预警
Laser Temperature low warning
激光器温度低预警
VDM: Laser temperature high alarm
VDM(Versatile diagnostics monitoring,多功能诊断监控)中的激光器温度高告警
VDM: Laser temperature low alarm(channel x)
VDM中通道x的激光器温度低告警
VDM: Host current pre-FEC BER high alarm(channel x)
VDM中通道x主机侧前向纠错误码率高告警
VDM: Host current pre-FEC BER low alarm(channel x)
VDM中通道x主机侧前向纠错误码率低告警
VDM: Media current pre-FEC BER high alarm(channel x)
VDM中通道x介质侧前向纠错误码率高告警
VDM: Media current pre-FEC BER low alarm(channel x)
VDM中通道x介质侧前向纠错误码率低告警
VDM: Media current pre-FEC BER high warning(channel x)
VDM中通道x介质侧前向纠错误码率高预警
VDM: Media current pre-FEC BER low warning(channel x)
VDM中通道x介质侧前向纠错误码率低预警
VDM: RX Total Power high alarm(channel 1)
VDM中通道1接收总功率高告警
VDM: RX Total Power low alarm(channel 1)
VDM中通道1接收总功率低告警
VDM: RX Total Power high warning(channel 1)
VDM中通道1接收总功率高预警
VDM: RX Total Power low warning(channel 1)
VDM中通道1接收总功率低预警
Media-side Rx Loss of Frame
介质侧接收丢失的帧数
Media-side Rx Loss of Multi-Frame
介质侧接收丢失的多帧数
VDM: CFO high alarm
VDM中CFO(Carrier Frequency Offset载波频率偏移)高告警
VDM: CFO low alarm
VDM中CFO低告警
# 显示接口GigabitEthernet0/0/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface gigabitethernet 0/0/1
GigabitEthernet0/0/1 transceiver current alarm information:
  RX signal loss
  RX power low alarm
表1-26 display transceiver alarm显示信息描述表
接口光模块当前故障告警信息
RX signal loss
接收信号丢失
RX power low alarm
接收光功率低告警
接收光功率低预警
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet0/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface gigabitethernet 0/0/1
GigabitEthernet0/0/1 transceiver diagnostic information:
    Temp(C)   Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36        3.31        6.13      -35.64          -5.19
  Alarm thresholds:
           Temp(C)    Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   50         3.55        1.44      -10.00         5.00
    Low    30         3.01        1.01      -30.00         0.00
  Warning thresholds:
    High   45         3.25        1.25      -15.00         4.00
    Low    25         2.85        0.85      -25.00         1.00
表1-27 display transceiver diagnosis显示信息描述表
接口插入的光模块的数字诊断信息
当前的诊断参数
Temp.(C)
数字诊断参数——温度,单位为°C,精确到1°C
Voltage(V)
数字诊断参数——电压,单位为V,精确到0.01V
Bias(mA)
数字诊断参数——偏置电流,单位为mA,精确到0.01mA
Total RX power(dBm)
数字诊断参数——总接收光功率,单位为dBm,精确到0.01dBm
Total TX power(dBm)
数字诊断参数——总发送光功率,单位为dBm,精确到0.01dBm
RX power(dBm)
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm
TX power(dBm)
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm
Alarm thresholds
告警门限
High
高告警门限或高预警门限
Low
低告警门限或低预警门限
Warning threshold
预警门限
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
interface-type interface-number:显示接口上插入的可插拔接口模块的主要特征参数。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet0/0/1上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface gigabitethernet 0/0/1
GigabitEthernet0/0/1 transceiver information:
Transceiver Type                : 10G_BASE_SR_SFP
  Connector Type                : LC
  Wavelength(nm)                : 850
  Transfer Distance(m)          : 80(OM2),20(OM1),300(OM3)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : H3C
  Ordering Name                 :SFP-XG-SX-MM850-D
表1-28 display transceiver interface命令显示信息描述表
可插拔接口模块信息
Transceiver Type
可插拔接口模块的物理型号
Connector Type
可插拔接口模块的连接器类型,其中:
·     光纤连接器包括SC(SC Connector,NTT公司推出的拔插锁紧式光纤连接器)、LC(LC Connector,Lucent公司推出的1.25mm/RJ45锁紧式光纤连接器)两种类型
·     其他连接器包括RJ-45、CX4等类型
Wavelength(nm)
·     光模块:显示发送激光中心波长,单位nm;对于支持多条不同波长光路的模块(例如10GBASE-LX4模块),各个波长值之间用逗号分隔
·     电模块:显示为“N/A”
Transfer Distance(xx)
传输距离,对于单模模块,xx显示为km,其他模块xx显示为m。当模块支持多种传输介质时,各个传输距离值之间用逗号分隔。距离值后面括号里包含对应的“传输介质”。下面是各个介质的名称:
·     9um:表示9/125um单模光纤
·     50um:表示50/125um OM2多模光纤
·     62.5um:表示62.5/125um OM1多模光纤
·     CX4:表示CX4电缆
·     OM3:表示50um OM3多模光纤
·     OM4:表示50um OM4多模光纤
·     OM5:表示50um OM5多模光纤
·     STACK:表示堆叠线
·     TP:表示双绞线
Max power(W)
光模块的最大功耗
对数字诊断功能的支持情况,其中:
·     YES:表示支持数字诊断
·     NO:表示不支持数字诊断
Vendor Name
模块生产或定制厂商名称
Ordering Name
可插拔接口模块的对外型号
display transceiver itu-channel命令用来显示光模块的ITU通道信息。
display transceiver itu-channel interface [ interface-type interface-number [ supported-channel ] ]
interface:显示接口上插入的光模块当前使用的ITU通道的信息。
interface-type interface-number:显示指定光模块当前使用的ITU通道的信息。interface-type interface-number表示接口类型和接口编号。不指定该参数时,表示所有接口上光模块当前使用的ITU通道的信息。
supported-channel:仅显示接口支持配置的ITU通道的信息。不指定该参数时,仅显示光模块当前使用的ITU通道的信息。
本命令仅SFP-XG-LH80-Tunable光模块支持。
# 显示GigabitEthernet0/0/1上插入的光模块当前使用的ITU通道的信息。
<Sysname> display transceiver itu-channel interface gigabitethernet 0/0/1
Interface                           Channel        WaveLength(nm)  Frequency(THz)
GE0/0/1                             1              1566.72         191.35
# 显示GigabitEthernet0/0/1上插入的光模块支持配置的ITU通道的信息。
<Sysname> display transceiver itu-channel interface gigabitethernet 0/0/1 supported-channel
ITU channel settings supported on GigabitEthernet0/0/1 :
1          1566.72           191.35
2          1566.31           191.40
3          1565.90           191.45
4          1565.50           191.50
5          1565.09           191.55
6          1564.68           191.60
7          1564.27           191.65
8          1563.86           191.70
其它显示信息略……。
表1-29 display transceiver itu-channel interface命令显示信息描述表
光模块所在接口的简称
Channel
ITU通道编号
WaveLength(nm)
通道编号对应的波长,单位为nm,精确到0.01nm。取值为“-”时,表示对应接口显示ITU通道信息失败,失败原因有:
·     该接口上未插入光模块
·     该接口上光模块不支持配置ITU通道编号
·     光模块获取ITU通道信息失败
·     设备不支持光模块上当前存储的ITU通道编号
Frequency(THz)
通道编号对应的频率,单位为THZ,精确到0.01THZ。取值为“-”时,表示对应接口显示ITU通道信息失败,失败原因有:
·     该接口上未插入光模块
·     光模块获取ITU通道信息失败
·     itu-channel
display transceiver manuinfo命令用于显示可插拔接口模块的电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet0/0/1上插入的可插拔接口模块的电子标签信息。
<Sysname> display transceiver manuinfo interface gigabitethernet 0/0/1
GigabitEthernet0/0/1 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2019-09-01
  Vendor Name          : H3C
表1-30 display transceiver manuinfo命令显示信息描述表
Manu. Serial Number
在调测(调试、测试)过程中生成的序列号
Manufacturing Date
调测日期,取值为调测平台计算机的系统日期
Vendor Name
定制厂商名称,即H3C
fan auto-control-mode命令用来配置风扇的工作模式。
undo fan auto-control-mode命令用来恢复缺省情况。
fan auto-control-mode { balance | low-temperature | silence }
型号
MSR1008
不支持
MSR1004-G
不支持
MSR1004-G-5GCN
不支持
不支持
MSR2630E-X1
不支持
不支持
MSR3610-G-X3-DP、MSR3610-G-X3、MSR3610-G-X3-DP-DC、MSR3610-G-X3-DC
不支持
MSR3620-G-X3
支持
型号
MSR2660-XS
不支持
MSR2680-XS
不支持
型号
MSR2600-12X-WiNet
不支持
MSR2610-13X-WiNet
不支持
风扇工作在均衡模式。
balance:配置风扇工作在均衡模式。该模式下风扇的转速和噪音介于低温模式和静音模式之间,在优先保证散热的情况下尽量降低噪音。
low-temperature:配置风扇工作在低温模式。该模式下风扇转速较高,以便优先保证单板在较低的温度下工作。
silence:配置设备工作在静音模式。该模式下风扇转速较低、噪音较小,但是单板温度比低温模式略高。在对噪音比较敏感的场合推荐使用此模式。
# 配置风扇工作在静音模式。
[Sysname] fan auto-control-mode silence
1.1.31  itu-channel
itu-channel命令用来配置光模块的ITU通道编号。
undo itu-channel命令用来恢复缺省情况。
itu-channel channel-number
undo itu-channel
光模块的ITU通道编号为1。
以太网接口视图
channel-number:表示光模块的ITU通道编号。
配置该命令后,设备会将ITU通道编号保存在光模块内部的寄存器中,不会保存到配置文件中。
# 将GigabitEthernet0/0/1上插入的光模块的ITU通道编号配置为2。
[Sysname] interface gigabitethernet 0/0/1
[Sysname-GigabitEthernet0/0/1] itu-channel 2
Changing the channel number causes the service to be down for a while. Continue? [Y/N]:Y
·     display transceiver itu-channel
memory reclaim cache命令用来回收Cache内存。
memory reclaim cache [ slot slot-number [ cpu cpu-number ] ]
型号
MSR1008
支持
MSR1004-G
支持
MSR1004-G-5GCN
支持
不支持
MSR2630E-X1
不支持
不支持
MSR3610-G-X3-DC
不支持
MSR3620-G-X3
不支持
型号
MSR2660-XS
支持
MSR2680-XS
不支持
型号
MSR2600-12X-WiNet
支持
MSR2610-13X-WiNet
不支持
此命令适用于当设备Cache内存使用率较高时,用户可以通过回收Cache内存来释放资源。该命令主要用于改善设备性能,特别是在设备负载较高或内存紧张的情况下。
# 回收Cache内存。
<Sysname> memory reclaim cache
Executing this command might affect device performance. Proceed only if you understand the impact. Continue?[Y/N]:y
memory reclaim process命令用来回收指定进程的可回收内存。
memory reclaim process { all | job job-id } [ slot slot-number [ cpu cpu-number ] ]
型号
MSR1008
支持
MSR1004-G
支持
MSR1004-G-5GCN
支持
不支持
MSR2630E-X1
不支持
不支持
MSR3610-G-X3-DC
不支持
MSR3620-G-X3
不支持
型号
MSR2660-XS
支持
MSR2680-XS
不支持
型号
MSR2600-12X-WiNet
支持
MSR2610-13X-WiNet
不支持
all:回收所有进程的可回收内存,进程的支持由业务决定。
job job-id:任务编号,用于唯一标识一个进程,该编号不会随着进程的重启而改变,取值范围为1~2147483647。
当设备的内存使用率较高时,用户可以使用此命令回收特定进程的可回收内存,从而优化内存使用效率。执行本命令后,设备会压缩进程不常用的页面,从而达到回收内存的效果。
# 回收job-id为1的进程堆内存。
<Sysname> memory reclaim process job 1
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复缺省情况。
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
本命令的缺省情况与设备的型号有关,请以设备的实际情况为准。
ratio表示以百分比形式配置门限。不指定该参数时,表示配置的是门限的大小,单位为MB。
minor minor-value:一级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
severe severe-value:二级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
critical critical-value:三级告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小。输入该参数的值时可通过输入?,来获取该参数的取值范围。
early-warning early-warning-value:预警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级别的告警功能。本参数的缺省情况与设备的型号有关,请以设备的实际情况为准。
secure secure-value:预警恢复门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。本参数的缺省情况与设备的型号有关,请以设备的实际情况为准。
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示主用主控板。‌对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。
系统实时监控剩余空闲内存大小,当条件达到一级、二级、三级告警门限或者恢复正常状态门限时,就产生相应的告警/告警解除通知,通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
设备监控的是系统内存中剩余空闲内存的大小,使用display memory命令可以查看系统内存的使用情况。(不支持低端内存的设备)
设备监控的是低端内存中剩余空闲内存的大小,使用display memory命令可以查看低端内存的使用情况。(支持低端内存的设备)
对于支持低端内存的slot,设备监控的是低端内存中剩余空闲内存的大小;对于不支持低端内存的slot,设备监控的是系统内存中剩余空闲内存的大小。执行display memory命令,如果显示信息中包含LowMem字段,则表示该slot支持低端内存。(部分单板支持低端内存的设备)
除了一级、二级、三级告警,设备还支持预警功能。预警门限用于内存使用率尚处于正常范围内,但需要提醒用户提前关注内存的情况。预警恢复门限用于解除预警。
关于告警门限的详细介绍请参见“设备管理配置指导”中的“硬件资源管理”。
满足以下条件时,系统会重启单板。
·     产生三级告警后,剩余空闲内存值持续小于三级告警门限,其时长到达30秒,则系统会重启单板。
·     如果连续产生两次三级告警的时间间隔小于30秒,则系统会重启单板。
·     如果3分钟内产生三次三级告警,则系统会重启单板。
·     产生三级告警后,系统将会周期采样,预测剩余空闲内存是否会在30秒之内耗尽,如果预测结果为会在30秒之内耗尽,则系统会重启单板。
系统监控到剩余空闲内存值达到一级、二级、三级告警门限以及预告警门限后,用户在Console或Telnet登录设备,以及执行每条命令时,都会显示当前内存使用情况。
内存告警事件的发送周期如下:持续1小时超过预告警门限则上报一次预告警事件通知,持续12小时超过一级告警门限则上报一次一级告警事件通知,持续3小时超过二级告警门限则上报一次二级告警事件通知,持续1小时超过三级告警门限则上报一次三级告警事件通知。
# 配置一级、二级、三级告警门限分别为64MB、48MB、32MB,当剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# 配置一级、二级、三级告警门限分别为设备总内存的3%、2%、1%,当剩余空闲内存大于设备总内存的5%时,恢复到正常状态。
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
·     display memory-threshold
memory-threshold dma命令用来配置DMA(Direct Memory Access,直接内存存取)内存告警阈值。
undo memory-threshold dma命令用来恢复缺省情况。
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
缺省情况下,告警阈值为2048KB,告警恢复阈值为4096KB。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。‌对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。
ratio:以百分比配置阈值。
critical critical-value:告警阈值。当指定ratio参数时,critical-value为百分比,取值范围为0~100;当不指定ratio参数时,critical-value单位为KB,不同型号的设备取值范围不同,请以设备的实际情况为准。
normal normal-value:告警恢复阈值。当指定ratio参数时,normal-value为百分比;当不指定ratio参数时,normal-value单位为KB。设备会根据critical-value的配置值自动调整normal-value的取值范围,请以设备的实际情况为准。
部分业务的运行需要使用DMA内存,如果DMA内存不足,会导致业务模块功能异常。系统周期监控DMA空闲内存大小:当DMA空闲内存小于或等于告警阈值,产生告警事件,表示DMA内存可能不足;当DMA空闲内存大于告警恢复阈值,产生告警解除事件,表示DMA内存充足。
# 配置Slot 1的DMA内存告警的阈值为32KB,告警恢复阈值为96KB。‌‌
[Sysname] memory-threshold dma slot 1 critical 32 normal 96
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
内存利用率阈值为100%。
slot slot-number:表示单板所在的槽位号,不指定该参数时,表示主用主控板。‌对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率阈值比较。当采样值大时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold usage 80
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。‌对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
·     display cpu-usage configuration
·     display cpu-usage history
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
undo monitor cpu-usage interval命令用来恢复缺省情况。
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录采样周期为1分钟。
interval:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min,不区分大小写。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage statistics-interval core命令用来配置CPU核利用率的统计周期。
undo monitor cpu-usage statistics-interval core命令用来恢复缺省情况。
monitor cpu-usage statistics-interval interval slot slot-number cpu cpu-number core core-id-list
undo monitor cpu-usage statistics-interval slot slot-number cpu cpu-number core core-id-list
缺省情况下,CPU核利用率信息统计间隔时间为60秒。
intervalCPU核利用率信息的统计周期,取值范围为10~3600,单位为秒。配置的统计周期建议是采样周期的整数倍,采样周期是5秒,不是整数倍时,实际生效统计周期为最接近配置值、但小于配置值的、采样周期整数倍。例如,采样周期是5秒,配置统计周期为12秒,则实际生效的统计周期是10秒。
core-id-list:表示CPU核的编号列表。表示方式为core-id-list = { core-id1 [ to core-id2 ] }&<1-10>core-id2的值要大于或等于core-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
系统按5秒周期对CPU核的利用率进行采样,然后对统计周期内的采样值进行计算,并将计算值和用户配置的CPU核利用率的门限比较。当计算值大于门限值时,则认为CPU核利用率过高,设备会发送告警信息并记录日志。
# 配置slot 1 cpu 0 core 0利用率的统计周期为60秒。‌‌
[Sysname] monitor cpu-usage statistics-interval 60 slot 1 cpu 0 core 0
·     monitor cpu-usage threshold core
·     monitor resend cpu-usage core-interval
monitor cpu-usage threshold命令用来配置CPU利用率告警门限。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
monitor cpu-usage threshold severe-threshold [ minor-threshold minor-threshold] [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold  [ minor-threshold ] [ slot slot-number [ cpu cpu-number ] ]
缺省情况下,CPU利用率高级别告警门限为99%,低级别告警门限为80%。
severe-threshold:CPU利用率高级别告警门限,取值范围为2~100,单位为百分比。
minor-threshold minor-threshold:CPU利用率低级别告警门限,取值范围为1~“severe-threshold的配置值减1”,单位为百分比。不指定该参数时,该参数的取值为severe-threshold*0.8。
系统每隔1分钟会对CPU以及CPU核的利用率进行采样,并将采样值和用户配置的告警门限比较。当采样值大时,则认为利用率过高,设备会进行相应的处理。
# 配置CPU利用率告警门限为90%。
[Sysname] monitor cpu-usage threshold 90
monitor cpu-usage threshold core命令用来配置CPU核利用率告警门限。
undo monitor cpu-usage threshold core命令用来恢复缺省情况。
monitor cpu-usage threshold severe-threshold [ minor-threshold minor-threshold recovery-threshold recovery-threshold ] slot slot-number cpu cpu-number core core-id-list
undo monitor cpu-usage threshold [ minor-threshold recovery-threshold ] slot slot-number cpu cpu-number core core-id-list
缺省情况下,CPU利用率高级别告警门限为99%,低级别告警门限为98%,恢复门限为79%。
severe-threshold:CPU核利用率高级别告警门限,取值范围为2~100,单位为百分比。
minor-threshold minor-threshold:CPU核利用率低级别告警门限,取值范围为1~“severe-threshold的配置值减1”,单位为百分比。不指定该参数时,该参数的取值为severe-threshold*0.8。
recovery-threshold recovery-threshold:CPU核利用率恢复门限,取值范围为0~“minor-threshold的配置值减1”,单位为百分比。不指定该参数时,该参数的取值为severe-threshold*0.7。
core core-id-list:表示CPU核的编号列表。表示方式为core-id-list = { core-id1 [ to core-id2 ] }&<1-10>core-id2的值要大于或等于core-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
# 配置slot 1 cpu 0 core 0的利用率高级别告警门限为90%。‌‌
[Sysname] monitor cpu-usage threshold 90 slot 1 cpu 0 core 0
·     monitor cpu-usage statistics-interval core
monitor disk-usage disk命令用来配置磁盘利用率告警门限。
undo monitor disk-usage disk命令用来恢复缺省情况。
monitor disk-usage [ slot slot-number ] disk disk-name threshold threshold-value
undo monitor disk-usage [ slot slot-number ] disk disk-name threshold
disk disk-name:表示磁盘的名称。输入该参数时,请完整输入,需要区分大小写,否则,系统会提示参数错误。
threshold threshold-value:表示磁盘利用率告警门限,为百分比数值,取值范围为1~100。
配置本命令后,系统会按照指定周期(可通过monitor disk-usage interval命令配置)对磁盘利用率进行采样,并将采样值和用户配置的告警门限比较。当采样值大时,则认为磁盘利用率过高,系统会将磁盘利用率过高事件通知给NETCONF模块。通过NETCONF功能,可以将这个信息反馈给用户。关于NETCONF的详细介绍请参见“网络管理和监控配置指导”中的“NETCONF”。
# 配置磁盘利用率告警门限为80%。
[Sysname] monitor disk-usage disk flash threshold 80
·     monitor disk-usage interval
monitor disk-usage interval命令用来配置磁盘利用率的采样周期。
undo monitor disk-usage interval命令用来恢复缺省情况。
monitor disk-usage interval interval
磁盘利用率的采样周期为300秒。
interval:磁盘利用率的采样周期,取值范围为5~1800,且必须为5的倍数,单位为秒。
配置本命令后,系统会按照指定周期对磁盘利用率进行采样。
# 配置磁盘利用率的采样周期为120秒。
[Sysname] monitor disk-usage interval 120
·     monitor disk-usage disk
monitor resend cpu-usage命令用来配置发送CPU告警事件的间隔。
undo monitor resend cpu-usage命令用来取消CPU告警事件发送间隔的配置。
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
持续300秒超过低级别告警门限则上报一次CPU低级别告警事件,持续60秒超过高级别告警门限则上报一次CPU高级别告警事件。
minor-interval minor-interval:CPU低级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
severe-interval severe-interval:CPU高级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对CPU使用率进行采样,并将采样值与告警门限进行比较。当采样值从小于或等于变成大于某级别告警门限时,CPU将进入该级别告警状态并生成相应的告警事件。
CPU处于低级别告警状态时,会周期发送CPU低级别告警事件,直到CPU进入高级别告警状态或者低级别告警状态解除。CPU处于高级别告警状态时,会周期发送CPU高级别告警事件,直到高级别告警状态解除。使用本命令可以修改CPU告警事件的发送周期。
执行undo monitor resend cpu-usage命令不指定minor-intervalsevere-interval参数时,表示将这两个参数恢复到缺省情况。当指定某一个参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0低级别告警事件的发送周期为60秒。‌‌
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
monitor resend cpu-usage core-interval命令用来配置发送CPU核告警事件的间隔。
undo monitor resend cpu-usage core-interval命令用来取消CPU核告警事件发送间隔的配置。
monitor resend cpu-usage core-interval { minor-interval minor-interval | severe-interval severe-interval } * [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
发送CPU核低级别事件告警间隔时间为300秒,发送CPU核高级别事件告警间隔时间为60秒。
minor-interval minor-interval:CPU核低级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
severe-interval severe-interval:CPU核高级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对CPU核使用率进行统计,并将统计值与告警门限进行比较。当统计值从小于或等于变成大于告警门限时,CPU核将进入该告警状态并生成告警事件。
CPU核处于告警状态时,会周期发送CPU核告警事件,直到CPU核告警状态解除。使用本命令可以修改CPU核告警事件的发送周期。
# 配置设备上所有CPU核发送告警事件的间隔:低级别告警为100秒、高级别告警为60秒。
[Sysname] monitor resend cpu-usage core-interval minor-interval 100 severe-interval 60
monitor resend memory-threshold dma命令用来配置发送DMA内存告警事件的间隔。
undo monitor resend memory-threshold dma命令用来恢复缺省情况。
monitor resend memory-threshold dma critical-interval critical-interval [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold dma critical-interval [ slot slot-number [ cpu cpu-number ] ]
缺省情况下,DMA内存告警事件的间隔为300秒。
critical-interval:DMA内存告警事件周期发送的间隔,取值范围为10~3600,单位为秒。
设备定期对DMA内存使用率进行统计,并将统计值与告警门限进行比较。当统计值从小于或等于变成大于告警门限时,DMA内存将进入该告警状态并生成告警事件。
# 配置发送DMA内存告警事件的间隔为100秒。
[Sysname] monitor resend memory-threshold dma critical-interval 100
reset alarm active命令用来清除设备当前仍未恢复的告警信息。
reset alarm active { all | sequence-number sequence-number }
型号
MSR1008
不支持
MSR1004-G
不支持
MSR1004-G-5GCN
不支持
支持
MSR2630E-X1
不支持
不支持
MSR3610-G-X3-DC
不支持
MSR3620-G-X3
支持
型号
MSR2660-XS
不支持
MSR2680-XS
不支持
型号
MSR2600-12X-WiNet
不支持
MSR2610-13X-WiNet
不支持
未清除设备当前仍未恢复的告警信息。
all:清除设备当前仍未恢复的所有告警信息。
sequence-number sequence-number:清除指定序列号的未恢复的告警信息。sequence-number表示告警信息的序列号,取值范围为1~4294967295。
当系统中存在无法恢复的告警记录信息时,用户可使用该命令自主清除其告警记录信息。在手动清除当前正在发生的告警记录信息时,系统会打印一条Trap信息,并将这条告警信息存储到历史告警信息中,以便用户随时查看历史告警记录信息。需要注意的是,只有在设备开启SNMP功能时,系统才会打印Trap信息。
# 清除序列号为1的未恢复告警信息。
[Sysname] reset alarm active sequence-number 1
·     display alarm active
resource-monitor minor resend enable命令用来开启周期发送低级别资源告警通知功能。
undo resource-monitor minor resend enable命令用来关闭周期发送低级别资源告警通知功能。
周期发送低级别资源告警通知功能处于开启状态。
如果剩余的资源小于或等于低级别告警门限且大于高级别告警门限,则资源进入低级别告警状态,并生成低级别告警通知。
当资源一直处于低级别告警状态时:
·     开启周期发送低级别资源告警通知功能后,第一次达到低级别告警状态时,会生成低级别告警通知,后续还会周期生成低级别告警通知。当剩余资源达到更高级别告警门限时,将会生成更高级别的告警通知,暂时抑制低级别的告警通知。直到高级别的告警状态解除,再周期输出低级别的告警通知。
·     关闭周期发送低级别资源告警通知功能后,只有第一次达到低级别告警状态时,才生成低级别告警通知,不会连续生成低级别告警通知。
高级别告警通知重发功能一直处于开启状态,不能通过命令行配置。
高级别告警通知的重发周期是24小时,低级别告警通知的重发周期是7x24小时,不能配置。
# 开启周期发送低级别资源告警通知功能。
<sysname> system-view
[Sysname] resource-monitor minor resend enable
·     display resource-monitor
·     resource-monitor output
resource-monitor output命令用来配置资源告警通知的输出方向。
undo resource-monitor output命令用来关闭资源告警通知的输出方向。
undo resource-monitor output [ netconf-event | snmp-notification | syslog ]*
资源告警通知会同时向NETCONF、SNMP、信息中心三个方向输出。
netconf-event:将资源告警通知输出到NETCONF模块。
syslog:将资源告警通知输出到信息中心模块。
snmp-notification:将资源告警通知输出到SNMP模块。
设备会实时监控一些重要资源的是使用情况,当达到指定门限时,设备会生成对应的资源告警通知,这些通知可以输出到以下三个方向:
·     NETCONF模块。通过配置NETCONF模块的参数,可以将资源告警通知以NETCONF事件的形式发送给用户。关于NETCONF的详细介绍请参见“网络管理和监控配置指导”中的“NETCONF”。
·     信息中心模块。通过配置信息中心模块的参数,可以将资源告警通知以系统日志的形式发送给用户。关于信息中心的详细介绍请参见“设备管理配置指导”中的“信息中心”。
·     SNMP模块。通过配置SNMP模块的参数,可以将资源告警通知以Trap或者Inform消息的形式发送给用户。关于SNMP的详细介绍请参见“网络管理和监控配置指导”中的“SNMP”。
执行undo resource-monitor output命令,并且不指定可选参数时,表示资源告警通知不会向NETCONF、SNMP、信息中心三个方向输出。
# 将资源告警通知输出到信息中心模块。
[Sysname] resource-monitor output syslog
resource-monitor resource命令用来配置生成资源告警通知的门限。
undo resource-monitor resource命令用来取消资源告警通知的门限配置。
resource-monitor resource resource-name slot slot-number cpu cpu-number { by-absolute | by-percent } minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
不同类型资源的缺省情况不同,请使用display resource-monitor命令查看。
resource-name:需要监测的资源的名称,不区分大小写,需要完整输入参数的值。
表1-31 设备可监测的资源描述表
取值
含义
acl_rule
ACL规则资源
ipv4fib
IPv4 FIB硬件表项资源
ipv6fib
IPv6 FIB硬件表项资源
slot slot-number:表示监测指定单板上的资源。slot-number表示单板所在的槽位号。‌对于本产品,slot-number只能为固定取值,表示整台设备。
cpu cpu-number:表示监测指定CPU上的资源。cpu-number表示在CPU的编号。
by-absolute:以绝对值的方式配置告警门限。
by-percent:以百分比的方式配置告警门限。
minor-threshold minor-threshold:低级别告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
severe-threshold severe-threshold:高级别门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
配置本命令后,设备会监测资源的剩余情况,周期采样监测对象的值,并和配置的告警门限进行比较。当达到条件时,设备会生成告警通知。
# 配置slot 1上ARP资源的低级别门限为30%,高级别门限为10%。‌‌
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent  minor-threshold 30 severe-threshold 10
shutdown-interval命令用来配置端口状态检测定时器的时长。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval interval
端口状态检测定时器的时长为30秒。
interval:端口状态检测定时器的时长,取值范围为0~300,单位为秒。取值为0时,表示系统不自动检测端口状态,需要用户执行undo shutdown命令手动恢复端口状态。
应用场景
在开启环路检测功能的网络中,当环路检测的处理模式被设置为“Shutdown模式”后,若设备检测到端口出现环路,会自动关闭该端口并启动一个检测端口状态的定时器。有关环路检测功能的相关介绍,请参见“二层技术-以太网交换配置指导”中的“环路检测”。
在开启BPDU保护功能的网络中,若边缘端口收到了BPDU,则系统就将这些端口关闭并启动一个检测端口状态的定时器,同时通知网管这些端口已被生成树协议关闭。有关BPDU保护功能的相关介绍,请参见“二层技术-以太网交换配置指导”中的“生成树”。
工作机制
如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,系统会自动将端口恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口的时间间隔为T。
·     若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
·     若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被生成树协议关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被生成树协议关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置端口状态检测定时器的时长为100秒。
[Sysname] shutdown-interval 100
·     loopback-detection action(二层技术-以太网交换命令手册/环路检测)
·     loopback-detection global action(二层技术-以太网交换命令手册/环路检测)
·     stp bpdu-protection(二层技术-以太网交换命令手册/生成树)
·     stp port bpdu-protection(二层技术-以太网交换命令手册/生成树)
