19-VXLAN命令参考
01-VXLAN命令
本章节下载: 01-VXLAN命令  (754.15 KB)
01-VXLAN命令
1 VXLAN
1.1 VXLAN基础配置命令
1.1.1 ac statistics enable
1.1.2 arp suppression enable
1.1.3 description
1.1.4 display arp suppression vsi
1.1.5 display l2vpn interface
1.1.6 display l2vpn mac-address
1.1.7 display l2vpn vsi
1.1.8 display vxlan tunnel
1.1.9 flooding disable
1.1.10 l2vpn enable
1.1.11 l2vpn rewrite inbound tag
1.1.12 l2vpn statistics interval
1.1.13 mac-address static vsi
1.1.14 mtu
1.1.15 reserved vxlan
1.1.16 reset arp suppression vsi
1.1.17 reset l2vpn mac-address
1.1.18 reset l2vpn statistics ac
1.1.19 reset l2vpn statistics tunnel
1.1.20 reset l2vpn statistics vsi
1.1.21 selective-flooding mac-address
1.1.22 shutdown
1.1.23 statistics enable (VSI view)
1.1.24 tunnel
1.1.25 tunnel bfd enable
1.1.26 tunnel global source-address
1.1.27 tunnel statistics enable
1.1.28 vsi
1.1.29 vxlan
1.1.30 vxlan fast-forwarding enable
1.1.31 vxlan invalid-udp-checksum discard
1.1.32 vxlan ip-forwarding
1.1.33 vxlan local-mac report
1.1.34 vxlan source udp-port acl
1.1.35 vxlan source udp-port five-tuple
1.1.36 vxlan tunnel mac-learning disable
1.1.37 vxlan udp-port
1.1.38 xconnect vsi
1.2 VXLAN IP网关配置命令
1.2.1 arp distributed-gateway dynamic-entry synchronize
1.2.2 bandwidth
1.2.3 default
1.2.4 description
1.2.5 display interface vsi-interface
1.2.6 distributed-gateway local
1.2.7 gateway subnet
1.2.8 gateway vsi-interface
1.2.9 interface vsi-interface
1.2.10 mac-address
1.2.11 mtu
1.2.12 reset counters interface vsi-interface
1.2.13 shutdown
1.2.14 vtep group member local
1.2.15 vtep group member remote
1.2.16 vxlan tunnel arp-learning disable
1.3 OVSDB-VTEP配置命令
1.3.1 ovsdb server bootstrap ca-certificate
1.3.2 ovsdb server enable
1.3.3 ovsdb server pki domain
1.3.4 ovsdb server pssl
1.3.5 ovsdb server ptcp
1.3.6 ovsdb server ssl
1.3.7 ovsdb server tcp
1.3.8 vtep access port
1.3.9 vtep enable
1.3.10 vxlan tunnel flooding-proxy
1 VXLAN
1.1  VXLAN基础配置命令
ac statistics enable命令用来开启作为AC的三层接口的报文统计功能。
undo ac statistics enable命令用来关闭作为AC的三层接口的报文统计功能。
本命令的支持情况与设备型号有关,请以设备的实际情况为准。
F1000系列
型号
F1000-X-G5系列
F1000-A-G5、F1000-C-G5、F1000-C-G5-LI、F1000-E-G5、F1000-H-G5、F1000-S-G5
支持
F1000-X-G3系列
F1000-A-G3、F1000-C-G3、F1000-E-G3、F1000-S-G3
支持
F1000-X-G2系列
F1000-A-G2、F1000-C-G2、F1000-E-G2、F1000-S-G2
支持
F1000-9X0-AI系列
F1000-9390-AI、F1000-9385-AI、F1000-9380-AI、F1000-9370-AI、F1000-9360-AI、F1000-9350-AI、F1000-990-AI、F1000-980-AI、F1000-970-AI、F1000-960-AI、F1000-950-AI、F1000-930-AI、F1000-920-AI、F1000-9330-AI、F1000-9320-AI
支持
F1000-9310-AI、F1000-9305-AI、F1000-910-AI、F1000-905-AI
不支持
F1000-C83X0系列
F1000-C8395、F1000-C8390、F1000-C8385、F1000-C8380、F1000-C8370、F1000-C8360、F1000-C8350、F1000-C8330
支持
F1000-C8320、F1000-C8310、F1000-C8305
不支持
F1000-C81X0系列
F1000-C8180、F1000-C8170、F1000-C8160
支持
F1000-C8150、F1000-C8130、F1000-C8120、F1000-C8110
不支持
F1000-7X0-HI系列
F1000-770-HI、F1000-750-HI、F1000-740-HI、F1000-730-HI
支持
F1000-720-HI、F1000-710-HI
不支持
F1000-C-X系列
F1000-C-EI、F1000-C-HI、F1000-C-XI、F1000-E-XI
支持
F1000-V系列
F1000-E-VG
支持
F1000-S-VG
不支持
SecBlade IV
LSPM6FWD8、LSQM2FWDSC8
不支持
F100系列
型号
F100-X-G5系列
F100-E-G5
支持
F100-A-G5、F100-C-G5、F100-C-G5-EI、F100-C-G5-SI、F100-M-G5、F100-M-G5-EI、F100-S-G5
不支持
F100-X-G3系列
F100-A-G3、F100-E-G3
支持
F100-C-G3、F100-M-G3、F100-S-G3
不支持
F100-X-G2系列
F100-A-G2、F100-E-G2
支持
F100-C-G2、F100-M-G2、F100-S-G2
不支持
F100-WiNet系列
F100-A81-WiNet、F100-A80-WiNet、F100-A91-WiNet
支持
F100-C80-WiNet、F100-C60-WiNet、F100-C50-WiNet、F100-S80-WiNet
不支持
F100-C-A系列
F100-C-A6、F100-C-A5、F100-C-A3、F100-C-A2、F100-C-A1
不支持
F100-C-A6-WL、F100-C-A5-W、F100-C-A3-W
支持
F100-X-XI系列
F100-A-EI、F100-A-HI、F100-A-SI、F100-E-EI
支持
F100-C-EI、F100-C-HI、F100-A-XI、F100-C-XI、F100-S-HI、F100-S-XI
不支持
作为AC的三层接口的报文统计功能处于关闭状态。
三层以太网接口视图
三层聚合接口视图
context-admin
只有为三层接口绑定了VSI实例,报文统计功能才会生效。如果在报文统计过程中修改绑定的VSI,则报文统计重新开始。
# 在接口GigabitEthernet1/0/1上关联名为vsia的VSI并开启报文统计功能。
[Sysname-GigabitEthernet1/0/1] xconnect vsi vsia
[Sysname-GigabitEthernet1/0/1] ac statistics enable
·     display l2vpn interface verbose
·     reset l2vpn statistics ac
arp suppression enable命令用来开启ARP泛洪抑制功能。
undo arp suppression enable命令用来关闭ARP泛洪抑制功能。
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
F1000-9390-AI、F1000-9385-AI、F1000-9380-AI、F1000-9370-AI、F1000-9360-AI、F1000-9350-AI、F1000-9330-AI、F1000-9320-AI、F1000-9310-AI、F1000-9305-AI、F1000-990-AI、F1000-980-AI、F1000-970-AI、F1000-960-AI、F1000-950-AI、F1000-930-AI、F1000-920-AI、F1000-910-AI、F1000-905-AI
支持
F1000-C83X0系列
F1000-C8395、F1000-C8390、F1000-C8385、F1000-C8380、F1000-C8370、F1000-C8360、F1000-C8350、F1000-C8330、F1000-C8320、F1000-C8310、F1000-C8305
支持
F1000-C81X0系列
F1000-C8180、F1000-C8170、F1000-C8160、F1000-C8150、F1000-C8130、F1000-C8120、F1000-C8110
支持
F1000-7X0-HI系列
F1000-770-HI、F1000-750-HI、F1000-740-HI、F1000-730-HI、F1000-720-HI、F1000-710-HI
支持
F1000-C-X系列
支持
F1000-V系列
F1000-E-VG、F1000-S-VG
支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
F100-A-G5、F100-C-G5、F100-C-G5-EI、F100-C-G5-SI、F100-E-G5、F100-M-G5、F100-M-G5-EI、F100-S-G5
支持
F100-X-G3系列
F100-A-G3、F100-C-G3、F100-E-G3、F100-M-G3、F100-S-G3
支持
F100-X-G2系列
F100-A-G2、F100-C-G2、F100-E-G2、F100-M-G2、F100-S-G2
支持
F100-WiNet系列
F100-A80-WiNet、F100-C80-WiNet、F100-C60-WiNet、F100-C50-WiNet、F100-S80-WiNet、F100-A91-WiNet、F100-A81-WiNet
支持
F100-C-A系列
F100-C-A6、F100-C-A5、F100-C-A3、F100-C-A2、F100-C-A1、F100-C-A6-WL、F100-C-A5-W、F100-C-A3-W
支持
F100-X-XI系列
F100-A-EI、F100-A-HI、F100-A-SI、F100-C-EI、F100-C-HI、F100-A-XI、F100-C-XI、F100-E-EI、F100-S-HI、F100-S-XI
支持
ARP泛洪抑制功能处于关闭状态。
VSI视图
context-admin
为了避免广播发送的ARP请求报文过多占用核心网络带宽,VTEP从本地站点、VXLAN隧道接收到ARP请求和ARP应答报文后,根据该报文在本地建立ARP泛洪抑制表项。后续当VTEP收到本站点内虚拟机请求其它虚拟机MAC地址的ARP请求时,优先根据ARP泛洪抑制表项进行代答。如果没有对应的表项,则将ARP请求泛洪到核心网。ARP泛洪抑制功能可以大大减少ARP泛洪的次数。
# 在VSI vsi1下开启ARP泛洪抑制功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable
·     display arp suppression vsi
·     reset arp suppression vsi
1.1.3  description
description命令用来配置VSI的描述信息。
undo description命令用来恢复缺省情况。
未配置VSI的描述信息。
VSI视图
context-admin
text:VSI的描述信息,为1~80个字符的字符串,区分大小写。
# 配置名为vpn1的VSI的描述信息为“vsi for vpn1”。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
·     display l2vpn vsi
display arp suppression vsi命令用来显示VSI的ARP泛洪抑制表项信息。
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
支持
F1000-C83X0系列
支持
F1000-C81X0系列
支持
F1000-7X0-HI系列
支持
F1000-C-X系列
支持
F1000-V系列
支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
支持
F100-X-G3系列
支持
F100-X-G2系列
支持
F100-WiNet系列
支持
F100-C-A系列
支持
F100-X-XI系列
支持
context-admin
context-operator
name vsi-name:显示指定VSI的ARP泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的ARP泛洪抑制表项。
slot slot-number:显示指定成员设备的ARP泛洪抑制表项。slot-number表示设备在IRF中的成员编号。如果不指定本参数,将显示主设备上的ARP泛洪抑制表项。
count:显示ARP泛洪抑制表项的个数。
# 显示VSI的ARP泛洪抑制表项信息。
<Sysname> display arp suppression vsi
IP address      MAC address    Vsi Name                        Link ID    Aging
1.1.1.2         000f-e201-0101 vsi1                            0x70000    14
1.1.1.3         000f-e201-0202 vsi1                            0x80000    18
1.1.1.4         000f-e201-0203 vsi2                            0x90000    10
# 显示VSI的ARP泛洪抑制表项个数。
<Sysname> display arp suppression vsi count
Total entries: 3
表1-1 display arp suppression vsi命令显示信息描述表
IP address
ARP泛洪抑制表项的IP地址
MAC address
ARP泛洪抑制表项的MAC地址
Vsi Name
VSI名称
Link ID
ARP泛洪抑制表项的出链路标识符,用来在VSI内唯一标识一条AC或一条VXLAN隧道
Aging
ARP泛洪抑制表项的老化时间,单位为分钟
Total entries
ARP泛洪抑制表项的数目
·     arp suppression enable
display l2vpn interface命令用来显示与VSI关联的三层接口的L2VPN信息。
display l2vpn interface [ vsi vsi-name | interface-type interface-number ] [ verbose ]
context-admin
context-operator
vsi vsi-name:显示与指定VSI关联的三层接口的L2VPN信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
interface-type interface-number:显示指定接口的L2VPN信息。interface-type interface-number为接口类型和接口编号。
verbose:显示详细信息。如果未指定本参数,则显示简要信息。
执行本命令时,如果未指定任何参数,则显示所有与VSI关联的三层接口的L2VPN信息。
# 显示所有与VSI关联的三层接口的L2VPN简要信息。
<Sysname> display l2vpn interface
Total number of interfaces: 2, 1 up, 1 down
Interface                Owner                           Link ID   State    Type
GE1/0/1                  vxlan3                          1         Up       VSI
GE1/0/2                  vxlan4                          2         Down     VSI
表1-2 display l2vpn interface命令显示信息描述表
与VSI关联的三层接口的总数,及处于up和down状态的接口数目
与VSI关联的三层接口的名称
Owner
VSI名称
Link ID
接口对应AC在VSI内的链路标识符
接口的物理状态,取值包括Up和Down
接口对应的L2VPN类型,在VXLAN中取值为VSI
# 显示所有与VSI关联的三层接口的L2VPN详细信息。
<Sysname> display l2vpn interface verbose
Interface: GE1/0/1
    Owner         : vsi1
    Link ID       : 0
    State         : Up
    Type          : VSI
    Statistics    : Enabled
    Input Statistics:
      Octets   :994496
      Packets  :15539
    Output Statistics:
      Octets   :0
      Packets  :0
Interface: GE1/0/2
    Owner         : vsi2
    Link ID       : 0
    State         : Down
    Type          : VSI
    Input Statistics:
      Octets   :0
      Packets  :0
    Output Statistics:
      Octets   :0
      Packets  :0
表1-3 display l2vpn interface verbose命令显示信息描述表
接口名称
Owner
与接口关联的VSI名称
Link ID
接口对应AC在VSI内的链路标识符
接口的物理状态,取值包括Up和Down
Statistics
是否使能与VSI关联三层接口的统计功能,取值包括:
·     Enabled:使能了与VSI关联三层接口的统计功能
·     Disabled:关闭与VSI关联三层接口的统计功能
Input Statistics
与VSI关联三层接口的入方向报文统计信息,包括接收的字节数(Octets)、接收的报文数(Packets)
Output Statistics
与VSI关联三层接口的出方向报文统计信息,包括发送的字节数(Octets)、发送的报文数(Packets)
display l2vpn mac-address命令用来显示VSI的MAC地址表信息。
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count ]
context-admin
context-operator
vsi vsi-name:显示指定VSI的MAC地址表信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的MAC地址表信息。
dynamic:显示通过源MAC地址动态学习的MAC地址表项。如果不指定本参数,则显示所有类型的MAC地址表项,包括通过源MAC地址动态学习的本地和远端MAC地址表项和静态配置的远端MAC地址表项。VXLAN不支持静态配置本地MAC地址表项。
count:显示MAC地址表项的数目。如果不指定本参数,则显示MAC地址表项的具体信息。
# 显示所有VSI的MAC地址表信息。
<Sysname> display l2vpn mac-address
MAC Address      State    VSI Name                        Link ID/Name  Aging
0000-0000-000b   Static   vpn1                            Tunnel10      NotAging
0000-0000-000c   Dynamic  vpn1                            Tunnel60      Aging
0000-0000-000d   Dynamic  vpn1                            Tunnel99      Aging
--- 3 mac address(es) found  ---
# 显示所有VSI的MAC地址表项总数。
<Sysname> display l2vpn mac-address count
表1-4 display l2vpn mac-address命令显示信息描述表
MAC Address
MAC地址
MAC地址的状态,取值包括:
·     Dynamic:表示通过源MAC地址动态学习的本地或远端MAC地址表项
·     Static:表示静态配置的远端MAC地址表项
VSI Name
VSI名称
Link ID/Name
对于本端MAC地址,为MAC地址的出链路标识符,即AC在VSI内的链路标识符;对于远端MAC地址,为MAC地址对应的隧道接口名称
Aging
MAC地址表项是否老化,取值包括Aging和NotAging
XX mac address(es) found
VSI的MAC地址表项的总数
·     reset l2vpn mac-address
display l2vpn vsi命令用来显示VSI的信息。
display l2vpn vsi [ name vsi-name ] [ verbose ]
context-admin
context-operator
name vsi-name:显示指定VSI的信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的信息。
verbose:显示VSI的详细信息。如果不指定本参数,则显示VSI的简要信息。
# 显示所有VSI的简要信息。
<Sysname> display l2vpn vsi
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpna                            0               1500   Up
表1-5 display l2vpn vsi命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
MTU
VSI上配置的最大传输单元
VSI的状态,取值包括:
·     Up:up状态
·     Down:down状态
·     Admin down:通过shutdown命令手工关闭VSI
# 显示所有VSI的详细信息。
<Sysname> display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : -
  Broadcast Restrain      : -
  Multicast Restrain      : -
  Unknown Unicast Restrain: -
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : Disabled
  PW Redundancy           : Slave
  Service Class           : -
  Gateway Interface       : VSI-interface 100
  VXLAN ID                : 10
  Tunnel Statistics       : Disabled
  Tunnels:
    Tunnel Name          Link ID    State  Type      Flood Proxy  Split horizon
    Tunnel1              0x5000001  Up     Manual    Disabled     Enabled
    Tunnel2              0x5000002  Up     Manual    Disabled     Enabled
  ACs:
    AC                               Link ID    State
    GE1/0/1                          0          Up
表1-6 display l2vpn vsi verbose命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
VSI Description
VSI的描述信息,如果不配置,则此行不显示
VSI State
VSI的状态,取值包括:
·     Up:up状态
·     Down:down状态
·     Administratively down:通过shutdown命令手工关闭VSI
MTU
VSI上配置的最大传输单元
Bandwidth
VSI的已知单播流量的最大带宽值,单位为kbps;如果显示为“-”,表示不支持
Broadcast Restrain
VSI的广播抑制带宽值,单位为kbps;如果显示为“-”,表示不支持
Multicast Restrain
VSI的组播抑制带宽值,单位为kbps;如果显示为“-”,表示不支持
VSI的未知单播抑制带宽值,单位为kbps;如果显示为“-”,表示不支持
MAC Learning
是否使能了MAC地址学习功能
MAC Table Limit
VSI内MAC地址表项的最大数目;如果显示为“-”,表示不支持
MAC Learning Rate
MAC地址学习速率
Drop Unknown
当VSI内学习到的MAC地址数达到最大值后,是否禁止转发源MAC地址不在MAC地址表里的报文
Service Class
设备发送的VXLAN报文的隧道转发类的值
Gateway Interface
VSI网关虚接口编号
VXLAN ID
VXLAN编号
Tunnel Statistics
是否开启VXLAN隧道的报文统计功能,取值包括:
·     Enabled:开启VXLAN隧道的报文统计功能
·     Disabled:关闭VXLAN隧道的报文统计功能
Tunnels
与VXLAN关联的隧道信息
Tunnel Name
隧道名称
Link ID
隧道在VSI内的链路标识符
隧道状态,取值包括:
·     Up:Tunnel接口状态Up,隧道可正常转发数据
·     Blocked:该隧道为备用代理隧道,不进行数据转发,Tunnel接口状态Up‌
·     Defect:Tunnel接口状态Up,但是隧道的BFD检测功能检测到隧道故障,请检查VXLAN隧道配置及链路(暂不支持)
·     Down:Tunnel接口状态Down,隧道停止数据转发
VXLAN和VXLAN隧道的关联方式,取值包括:
·     Manual:表示手动关联VXLAN和VXLAN隧道
Flood Proxy
隧道是否开启了泛洪代理功能,取值包括:
·     Enabled:开启隧道的泛洪代理功能,即VXLAN内的广播、组播和未知单播流量将通过该Tunnel发送到代理服务器,由代理服务器进行复制并转发到其它远端VTEP
·     Disabled:关闭隧道的泛洪代理功能
Split horizon
隧道是否开启了水平分割功能,取值包括:
·     Enabled:开启隧道的水平分割功能,即从其他VXLAN隧道接收到的报文不能转发到该VXLAN隧道
·     Disabled:关闭隧道的水平分割功能,即从AC和VXLAN隧道接收到的报文均可以通过该VXLAN隧道转发
ACs
VSI的AC列表
AC
接入电路
Link ID
AC在VSI内的链路标识符
AC的状态,取值包括Up和Down
display vxlan tunnel命令用来显示与VXLAN关联的VXLAN隧道的信息。
display vxlan tunnel [ vxlan-id vxlan-id [ tunnel tunnel-number ] ]
context-admin
context-operator
vxlan-id:显示与指定VXLAN关联的隧道的信息。vxlan-id为VXLAN的编号,取值范围为0~16777215。不指定此参数,则显示所有与VXLAN关联的隧道的信息。
tunnel tunnel-number:显示与指定VXLAN关联的指定隧道的信息。tunnel-number为Tunnel的编号,取值范围为0~1023。不指定此参数,则显示与指定VXLAN关联的所有隧道的信息。
# 显示所有与VXLAN关联的隧道的信息。
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: vpna, Total tunnels: 3 (3 up, 0 down, 0 defect, 0 blocked)
Tunnel name          Link ID    State  Type         Flood proxy  Split horizon
# 显示与编号为10的VXLAN关联的隧道的信息。
<Sysname> display vxlan tunnel vxlan-id 10
# 显示与编号为10的VXLAN关联的隧道Tunnel0的信息。
<Sysname> display vxlan tunnel vxlan-id 10 tunnel 0
Interface: Tunnel0
  Link ID    : 0x5000000
  State      : Up
  Type       : Auto
  Flood Proxy: Disabled
    Input statistics:
      Octets : 994496
      Packets: 15539
    Output statistics:
      Octets : 0
      Packets: 0
表1-7 display vxlan tunnel命令显示信息描述表
已创建的VXLAN的总数
VXLAN ID
VXLAN ID
VSI name
VXLAN所属的VSI名称
Total tunnels
与VXLAN关联的隧道的总数,包括处于Up和Down状态的隧道总数
Tunnel name
隧道名称
Link ID
隧道在VXLAN内的链路标识符
隧道的状态,取值包括:
Flood proxy
隧道是否开启了泛洪代理功能,取值包括:
·     Enabled:开启隧道的泛洪代理功能。即该VXLAN内的广播、组播和未知单播流量将通过该Tunnel发送到代理服务器,由代理服务器进行复制并转发到其它远端VTEP
Split horizon
隧道是否开启了水平分割功能,取值包括:
Statistics
·     Enabled:开启了VXLAN隧道的报文统计功能
·     Disabled:关闭了VXLAN隧道的报文统计功能
Input Statistics
隧道入方向报文统计信息,包括接收的字节数(Octets)、接收的报文数(Packets)
Output Statistics
隧道出方向报文统计信息,包括发送的字节数(Octets)、发送的报文数(Packets)
·     tunnel
·     vxlan
flooding disable命令用来关闭VSI的泛洪功能。
undo flooding disable命令用来开启VSI的泛洪功能。
flooding disable
VSI的泛洪功能处于开启状态。
VSI视图
context-admin
缺省情况下,VTEP从本地站点内接收到目的MAC地址未知的单播数据帧后,会在该VXLAN内除接收接口外的所有本地接口和VXLAN隧道上泛洪该数据帧,将该数据帧发送给VXLAN内的所有站点。如果用户希望把该类数据帧限制在本地站点内,不通过VXLAN隧道将其转发到远端站点,则可以通过本命令手工禁止VXLAN对应VSI的泛洪功能。
# 关闭名称为vsi1的VSI的泛洪功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable
1.1.10  l2vpn enable
l2vpn enable命令用来开启L2VPN功能。
undo l2vpn enable命令用来关闭L2VPN功能。
l2vpn enable
undo l2vpn enable
L2VPN功能处于关闭状态。
context-admin
只有开启L2VPN功能后,才能进行L2VPN的相关配置。
# 开启L2VPN功能。
[Sysname] l2vpn enable
l2vpn rewrite inbound tag命令用来配置入方向报文的VLAN标签处理规则。
undo l2vpn rewrite inbound命令用来恢复缺省情况。
l2vpn rewrite inbound tag { nest { c-vid vlan-id | s-vid vlan-id [ c-vid vlan-id ] } | remark 1-to-2 s-vid vlan-id c-vid vlan-id } [ symmetric ]
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
支持
不支持
F1000-C83X0系列
支持
不支持
F1000-C81X0系列
支持
不支持
F1000-7X0-HI系列
支持
不支持
F1000-C-X系列
支持
F1000-V系列
F1000-E-VG
支持
F1000-S-VG
不支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
F100-E-G5
支持
不支持
F100-X-G3系列
F100-A-G3、F100-E-G3
支持
不支持
F100-X-G2系列
F100-A-G2、F100-E-G2
支持
不支持
F100-WiNet系列
支持
不支持
F100-C-A系列
不支持
支持
F100-X-XI系列
支持
不支持
不对入方向报文的VLAN标签进行处理。
三层以太网接口视图
三层聚合接口视图
context-admin
nest:表示添加标签。
c-vid:表示内层标签。
vlan-id:表示VLAN的编号,取值范围为1~4094。
s-vid:表示外层标签。
remark:表示映射标签。
1-to-2:表示1:2标签映射,即将原有报文中的一层标签映射为两层标签。
symmetric:表示对出方向报文进行相反的标签操作。如果不指定本参数,则表示不对出方向报文的VLAN标签进行处理。
不能通过重复执行本命令修改入方向报文的VLAN标签处理规则。如需修改,请先通过undo l2vpn rewrite inbound命令删除入方向报文的VLAN标签处理规则,再执行l2vpn rewrite inbound tag命令。
执行本命令时,需要注意:
·     l2vpn rewrite inbound tag nest s-vid vlan-id c-vid vlan-id命令只对不携带VLAN tag的报文生效。
·     l2vpn rewrite inbound tag remark 1-to-2命令只对携带一层VLAN tag的报文生效。
# 在三层以太网接口GigabitEthernet1/0/1上配置为入方向报文添加外层VLAN标签100,并剥离出方向报文的外层VLAN标签。
[Sysname-GigabitEthernet1/0/1] l2vpn rewrite inbound tag nest s-vid 100 symmetric
l2vpn statistics interval命令用来设置VXLAN统计信息收集的时间间隔。
undo l2vpn statistics interval命令用来恢复缺省情况。
l2vpn statistics interval interval
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
支持
不支持
F1000-C83X0系列
支持
不支持
F1000-C81X0系列
支持
不支持
F1000-7X0-HI系列
支持
不支持
F1000-C-X系列
支持
F1000-V系列
F1000-E-VG
支持
F1000-S-VG
不支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
F100-E-G5
支持
不支持
F100-X-G3系列
F100-A-G3、F100-E-G3
支持
不支持
F100-X-G2系列
F100-A-G2、F100-E-G2
支持
不支持
F100-WiNet系列
支持
不支持
F100-C-A系列
不支持
支持
F100-X-XI系列
支持
不支持
VXLAN统计信息收集的时间间隔为15分钟。
context-admin
interval:VXLAN统计信息收集的时间间隔,取值范围为30~65535,单位为秒。
VXLAN统计信息包括VSI的报文统计、与VXLAN关联的VXLAN隧道的报文统计和AC的报文统计。
# 配置VXLAN统计信息收集的时间间隔为30秒。
[Sysname] l2vpn statistics interval 30
mac-address static vsi命令用来添加静态远端MAC地址表项。
undo mac-address static vsi命令用来删除指定的静态远端MAC地址表项。
mac-address static mac-address interface tunnel tunnel-number vsi vsi-name
undo mac-address static [ mac-address ] [ interface tunnel tunnel-number ] vsi vsi-name
不存在静态的远端MAC地址表项。
context-admin
mac-address:MAC地址,格式为H-H-H,不支持组播MAC地址和全0的MAC地址。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
interface tunnel tunnel-number:指定远端MAC地址对应的VXLAN隧道接口。tunnel-number为VXLAN隧道接口的编号,取值范围为0~1023。
vsi vsi-name:指定远端MAC地址所属的VSI。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
远端MAC地址是指VTEP连接的远端站点内虚拟机的MAC地址。远端MAC地址既可以通过本命令静态配置,也可以通过报文中的源MAC地址学习。
对于远端MAC地址表项,interface tunnel interface-number参数指定的隧道接口必须与vsi vsi-name参数指定的VSI对应的VXLAN关联,否则配置将失败。
执行undo mac-address static vsi命令时如果没有指定任何参数,则删除该VSI下的所有静态MAC地址表项。
# 添加一条静态远端MAC地址表项:MAC地址为000f-e201-0101,VXLAN隧道接口为Tunnel1,MAC地址所属的VSI为vsi1。
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
·     vxlan tunnel mac-learning disable
1.1.14  mtu
mtu命令用来配置VSI的MTU(Maximum Transmission Unit,最大传输单元)值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
VSI的MTU值为1500字节。
VSI视图
context-admin
VSI下创建VXLAN后,该VSI的MTU值是指从AC上接收且通过VXLAN隧道转发的用户报文的最大长度。VSI内的其他报文不受该MTU值的限制。
如果MTU为缺省值1500或者用户报文长度小于等于MTU值,则不需要对报文进行分片;如果用户报文长度大于MTU值,则需要分片。
# 配置名为vxlan1的VSI的MTU值为1400字节。
[Sysname] vsi vxlan1
[Sysname-vsi-vxlan1] mtu 1400
·     display l2vpn vsi
reserved vxlan命令用来配置保留VXLAN。
undo reserved vxlan命令用来恢复缺省情况。
reserved vxlan vxlan-id
undo reserved vxlan
未指定保留VXLAN。
context-admin
vxlan-id:保留VXLAN的ID,取值范围为0~16777215。
只能在系统视图下配置一个全局保留VXLAN,该VXLAN不能与VSI下创建的VXLAN相同。
# 配置保留VXLAN为VXLAN 10000。
[Sysname] reserved vxlan 10000
reset arp suppression vsi命令用来清除VSI的ARP泛洪抑制表项。
reset arp suppression vsi [ name vsi-name ]
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
支持
F1000-C83X0系列
支持
F1000-C81X0系列
支持
F1000-7X0-HI系列
支持
F1000-C-X系列
支持
F1000-V系列
支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
支持
F100-X-G3系列
支持
F100-X-G2系列
支持
F100-WiNet系列
支持
F100-C-A系列
支持
F100-X-XI系列
支持
context-admin
name vsi-name:清除指定VSI的ARP泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI的ARP泛洪抑制表项。
# 清除所有VSI的ARP泛洪抑制表项。
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
reset l2vpn mac-address命令用来清除通过源MAC地址动态学习的MAC地址表项。
reset l2vpn mac-address [ vsi vsi-name ]
context-admin
vsi vsi-name:清除指定VSI动态学习的MAC地址表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI动态学习的MAC地址表项。
VSI通过源MAC地址学习到错误的MAC地址表项,或学习的MAC地址表项数目达到最大值时,可以执行本命令,以便重新学习MAC地址表项。
# 清除名为vpn1的VSI通过源MAC地址动态学习的MAC地址表项。
<Sysname> reset l2vpn mac-address vsi vpn1
·     display l2vpn mac-address vsi
reset l2vpn statistics ac命令用来清除AC的报文统计信息。
reset l2vpn statistics ac [ interface interface-type interface-number [ service-instance instance-id ] ]
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
支持
不支持
F1000-C83X0系列
支持
不支持
F1000-C81X0系列
支持
不支持
F1000-7X0-HI系列
支持
不支持
F1000-C-X系列
支持
F1000-V系列
F1000-E-VG
支持
F1000-S-VG
不支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
F100-E-G5
支持
不支持
F100-X-G3系列
F100-A-G3、F100-E-G3
支持
不支持
F100-X-G2系列
F100-A-G2、F100-E-G2
支持
不支持
F100-WiNet系列
支持
不支持
F100-C-A系列
不支持
支持
F100-X-XI系列
支持
不支持
context-admin
interface interface-type interface-number:清除指定接口的报文统计信息。interface-type interface-number表示接口类型和接口编号。
service-instance instance-id:清除指定以太网服务实例的报文统计信息。instance-id表示以太网服务实例的ID,取值范围为1~4096。如果指定了三层接口,则不允许指定以太网服务实例;如果指定了二层接口,则必须指定以太网服务实例。
执行本命令时,如果未指定任何参数,则清除所有AC的报文统计信息。
# 清除作为AC的三层接口GigabitEthernet1/0/1的报文统计信息。
<Sysname> reset l2vpn statistics ac interface gigabitethernet 1/0/1
·     ac statistics enable
·     display l2vpn service-instance verbose
·     statistics enable (Ethernet service instance view)
reset l2vpn statistics tunnel命令用来清除VXLAN隧道的报文统计信息。
reset l2vpn statistics tunnel [ vsi vsi-name ]
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
支持
不支持
F1000-C83X0系列
支持
不支持
F1000-C81X0系列
支持
不支持
F1000-7X0-HI系列
支持
不支持
F1000-C-X系列
支持
F1000-V系列
F1000-E-VG
支持
F1000-S-VG
不支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
F100-E-G5
支持
不支持
F100-X-G3系列
F100-A-G3、F100-E-G3
支持
不支持
F100-X-G2系列
F100-A-G2、F100-E-G2
支持
不支持
F100-WiNet系列
支持
不支持
F100-C-A系列
不支持
支持
F100-X-XI系列
支持
不支持
context-admin
vsi vsi-name:清除指定VSI内VXLAN隧道的报文统计信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VXLAN隧道的报文统计信息。
# 清除所有VXLAN隧道的报文统计信息。
<Sysname> reset l2vpn statistics tunnel
·     tunnel statistics enable (VSI view)
reset l2vpn statistics vsi命令用来清除VSI的报文统计信息。
reset l2vpn statistics vsi [ name vsi-name ]
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
支持
不支持
F1000-C83X0系列
支持
不支持
F1000-C81X0系列
支持
不支持
F1000-7X0-HI系列
支持
不支持
F1000-C-X系列
支持
F1000-V系列
F1000-E-VG
支持
F1000-S-VG
不支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
F100-E-G5
支持
不支持
F100-X-G3系列
F100-A-G3、F100-E-G3
支持
不支持
F100-X-G2系列
F100-A-G2、F100-E-G2
支持
不支持
F100-WiNet系列
支持
不支持
F100-C-A系列
不支持
支持
F100-X-XI系列
支持
不支持
context-admin
name vsi-name:清除指定VSI的报文统计信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI的信息。
# 清除本设备上所有VSI报文统计信息。
<Sysname> reset l2vpn statistics vsi
·     statistics enable (VSI view)
selective-flooding mac-addres命令用来配置VSI选择性泛洪的MAC地址。
undo selective-flooding mac-addres命令用来删除VSI的选择性泛洪MAC地址。
selective-flooding mac-addres mac-addres
undo selective-flooding mac-addres mac-addres
不存在VSI选择性泛洪MAC地址。
VSI视图
context-admin
mac-address:选择性泛洪的MAC地址。该MAC地址不能为全F。
通过flooding disable命令关闭VSI的泛洪功能后,为了将某些MAC地址的数据帧泛洪到远端站点以保证某些业务的流量在站点间互通,可以配置选择性泛洪的MAC地址。当数据帧的目的MAC地址匹配选择性泛洪的MAC地址时,该数据帧可以泛洪到远端站点。
# 在VSI vsi1下配置选择性泛洪的MAC地址为000f-e201-0101。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
·     flooding disable
1.1.22  shutdown
shutdown命令用来关闭VSI。
undo shutdown命令用来开启VSI。
shutdown
VSI处于开启状态。
VSI视图
context-admin
关闭VSI后,该VSI将不能提供二层交换服务。
关闭VSI功能通常用于暂时禁用二层交换服务,但还需要再次启用该服务的场景。关闭VSI后,该VSI所有已存在的配置保持不变。在关闭状态下还可以对VSI进行配置。VSI再次被开启后,基于最新的配置提供二层交换服务。
# 关闭名为vpn1的VSI。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
·     display l2vpn vsi
statistics enable命令用来开启VSI的报文统计功能。
undo statistics enable命令用来关闭VSI的报文统计功能。
statistics enable
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
支持
不支持
F1000-C83X0系列
支持
不支持
F1000-C81X0系列
支持
不支持
F1000-7X0-HI系列
支持
不支持
F1000-C-X系列
支持
F1000-V系列
F1000-E-VG
支持
F1000-S-VG
不支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
F100-E-G5
支持
不支持
F100-X-G3系列
F100-A-G3、F100-E-G3
支持
不支持
F100-X-G2系列
F100-A-G2、F100-E-G2
支持
不支持
F100-WiNet系列
支持
不支持
F100-C-A系列
不支持
支持
F100-X-XI系列
支持
不支持
VSI的报文统计功能处于关闭状态。
VSI视图
context-admin
# 开启名为vsi1的VSI的报文统计功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] statistics enable
·     display l2vpn vsi verbose
·     reset l2vpn statistics vsi
1.1.24  tunnel
tunnel命令用来配置VXLAN与VXLAN隧道关联。
undo tunnel命令用来取消VXLAN与指定隧道的关联。
undo tunnel tunnel-number
VXLAN未关联VXLAN隧道。
VXLAN视图
context-admin
tunnel-number:关联指定的VXLAN隧道。tunnel-number为隧道接口的编号,取值范围为0~1023。指定的隧道必须是VXLAN模式的隧道。
在VXLAN组网中,用户可以手工将VXLAN与VXLAN隧道关联。采用单播路由泛洪方式时,如果VTEP接收到某个VXLAN的泛洪流量,则将在与该VXLAN关联的所有VXLAN隧道上发送该流量,以便将流量转发给所有的远端VTEP。
一个VXLAN可以关联多条VXLAN隧道;一条VXLAN隧道可以关联多个VXLAN。
# 配置VXLAN隧道Tunnel1和Tunnel2与VXLAN 10000关联。
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
·     display vxlan tunnel
tunnel bfd enable命令用来开启隧道的BFD检测功能。
undo tunnel bfd enable命令用来关闭隧道的BFD检测功能。
tunnel bfd enable destination-mac mac-address
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
支持
不支持
F1000-C83X0系列
支持
不支持
F1000-C81X0系列
支持
不支持
F1000-7X0-HI系列
支持
不支持
F1000-C-X系列
支持
F1000-V系列
F1000-E-VG
支持
F1000-S-VG
不支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
F100-E-G5
支持
不支持
F100-X-G3系列
F100-A-G3、F100-E-G3
支持
不支持
F100-X-G2系列
F100-A-G2、F100-E-G2
支持
不支持
F100-WiNet系列
支持
不支持
F100-C-A系列
不支持
支持
F100-X-XI系列
支持
不支持
隧道的BFD检测功能处于关闭状态。
VXLAN模式Tunnel接口视图
context-admin
destination-mac mac-address:指定BFD报文的目的MAC地址。mac-address为BFD报文的目的MAC地址,格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
隧道的BFD检测功能用来避免VTEP设备无法感知或无法及时感知隧道的故障,导致报文转发失败。
隧道两端的VTEP设备上均需要开启隧道的BFD检测功能,并分别指定BFD报文的目的MAC地址为VXLAN隧道对端VTEP的桥MAC地址或组播MAC地址,以便对端VTEP设备可以接收并处理BFD报文。
开启隧道的BFD检测功能后,设备会自动建立单跳控制报文方式的BFD会话,对VXLAN隧道进行检测。检测方式为:
(1)     隧道两端的VTEP设备均周期性地向配置的目的MAC地址发送BFD控制报文,并对报文进行VXLAN隧道封装。
(2)     如果在5秒内未接收到对端发送的BFD控制报文,则将隧道状态置为Defect,隧道接口状态仍为Up。
(3)     VXLAN隧道故障排除后隧道状态将自动恢复为Up。
# 开启VXLAN隧道Tunnel9的BFD检测功能,并指定BFD报文的目的MAC地址为1-1-1。
[Sysname] interface tunnel 9 mode vxlan
[Sysname-Tunnel9] tunnel bfd enable destination-mac 1-1-1
tunnel global source-address命令用来配置VXLAN隧道的全局源地址。
undo tunnel global source-address命令用来恢复缺省情况。
tunnel global source-address { ipv4-address | ipv6 ipv6-address }
undo tunnel global source-address [ ipv6 ]
未配置VXLAN隧道的全局源地址。
context-admin
ipv4-address:隧道的全局源IPv4地址。
ipv6 ipv6-address:隧道的全局源IPv6地址。执行undo tunnel global source-address命令时,如果没有指定本参数,则表示删除VXLAN隧道的全局源IPv4地址。
目前仅VXLAN隧道支持全局源地址,其它类型的隧道不支持全局源地址。
如果隧道下未配置源地址或源接口,则隧道会使用全局源地址作为隧道的源地址。
VXLAN over IPv4隧道只会使用全局源IPv4地址,VXLAN over IPv6隧道只会使用全局源IPv6地址。
# 配置VXLAN隧道的全局源地址为1.1.1.1。
[Sysname] tunnel global source-address 1.1.1.1
tunnel statistics enable命令用来开启VSI实例内所有VXLAN隧道的报文统计功能。
undo tunnel statistics enable命令用来关闭VSI实例内所有VXLAN隧道的报文统计功能。
tunnel statistic enable
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
支持
不支持
F1000-C83X0系列
支持
不支持
F1000-C81X0系列
支持
不支持
F1000-7X0-HI系列
支持
不支持
F1000-C-X系列
支持
F1000-V系列
F1000-E-VG
支持
F1000-S-VG
不支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
F100-E-G5
支持
不支持
F100-X-G3系列
F100-A-G3、F100-E-G3
支持
不支持
F100-X-G2系列
F100-A-G2、F100-E-G2
支持
不支持
F100-WiNet系列
支持
不支持
F100-C-A系列
不支持
支持
F100-X-XI系列
支持
不支持
VSI实例内所有VXLAN隧道的报文统计功能处于关闭状态。
VSI视图
context-admin
开启VSI实例内所有VXLAN隧道的报文统计功能后,可以通过display vxlan tunnel命令查看统计信息。
开启本功能后,仅统计VXLAN隧道接收和发送的报文数目,不会统计VXLAN-DCI隧道接收和发送的报文数目。
# 开启VSI实例内所有VXLAN隧道的报文统计功能。
[Sysname] vsi vpna
[Sysname-vsi-vpna] tunnel statistics enable
1.1.28  vsi
vsi命令用来创建一个VSI,并进入VSI视图。如果指定的VSI已经存在,则直接进入VSI视图。
undo vsi命令用来删除指定的VSI。
vsi vsi-name
undo vsi vsi-name
不存在VSI。
context-admin
vsi-name:VSI的名称,为1~31个字符的字符串,区分大小写。
VSI是VTEP上为一个VXLAN提供二层交换服务的虚拟交换实例。VSI可以看作是VTEP上的一台基于VXLAN进行二层转发的虚拟交换机,它具有传统以太网交换机的所有功能,包括源MAC地址学习、MAC地址老化、泛洪等。VSI与VXLAN一一对应。
# 创建名为vxlan10的VSI,并进入VSI视图。
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
·     display l2vpn vsi
1.1.29  vxlan
vxlan命令用来创建VXLAN,并进入VXLAN视图。如果指定的VXLAN已经存在,则直接进入VXLAN视图。
undo vxlan命令用来恢复缺省情况。
vxlan vxlan-id
undo vxlan
不存在VXLAN。
VSI视图
context-admin
vxlan-id:VXLAN ID,取值范围为0~16777215。
在一个VSI下只能创建一个VXLAN。不同VSI下创建的VXLAN,其VXLAN ID不能相同。
# 在名称为vpna的VSI下创建编号为10000的VXLAN,并进入VXLAN视图。
[Sysname] vsi vpna
·     vsi
vxlan fast-forwarding enable命令用来开启VXLAN软件快速转发功能。
undo vxlan fast-forwarding enable命令用来关闭VXLAN软件快速转发功能。
VXLAN软件快速转发功能处于关闭状态。
context-admin
开启本功能后,数据报文通过VXLAN隧道进行软件转发时,不会进行QoS、安全等业务处理,直接进行转发,以提高处理性能。建议仅在VSI虚接口和VXLAN隧道对应的报文出接口上没有配置QoS、安全等业务,且需要加快VXLAN软件转发速度的场景下,开启本功能。
开启本功能后,如果到达VXLAN隧道目的端地址存在多条等价路由,只会从中选择一条路由转发VXLAN报文,不能在多条路由之间进行负载分担。
# 开启VXLAN软件快速转发功能。
<Sysname> system
[Sysname] vxlan fast-forwarding enable
vxlan invalid-udp-checksum discard命令用来配置丢弃UDP校验和检查失败的VXLAN报文。
undo vxlan invalid-udp-checksum discard命令用来恢复缺省情况。
不会检查VXLAN报文的UDP校验和。
context-admin
VTEP对二层数据帧进行封装时,将UDP校验和设置为0。缺省情况下,VTEP接收到VXLAN报文后,不会检查报文的UDP校验和。如果在VTEP上执行了本命令,则该VTEP会对接收的VXLAN报文的UDP校验和进行检查,校验和检查失败的报文将被丢弃。
为了兼容其他厂商的设备,UDP检验和为0和UDP检验和正确的报文均能通过VTEP的检查,被VTEP接收。
# 配置丢弃UDP校验和检查失败的VXLAN报文。
[Sysname] vxlan invalid-udp-checksum discard
vxlan ip-forwarding命令用来配置VXLAN隧道工作在三层转发模式。
undo vxlan ip-forwarding命令用来配置VXLAN隧道工作在二层转发模式。
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
支持
不支持
F1000-C83X0系列
支持
不支持
F1000-C81X0系列
支持
不支持
F1000-7X0-HI系列
支持
不支持
F1000-C-X系列
支持
F1000-V系列
F1000-E-VG
支持
F1000-S-VG
不支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
F100-E-G5
支持
不支持
F100-X-G3系列
F100-A-G3、F100-E-G3
支持
不支持
F100-X-G2系列
F100-A-G2、F100-E-G2
支持
不支持
F100-WiNet系列
支持
不支持
F100-C-A系列
不支持
支持
F100-X-XI系列
支持
不支持
vxlan ip-forwarding
VXLAN隧道工作在三层转发模式。
context-admin
当设备作为VTEP时,需要配置VXLAN隧道工作在二层转发模式,该模式下VTEP通过查找MAC地址表项对流量进行转发;当设备作为VXLAN IP网关时,需要配置VXLAN隧道工作在三层转发模式,该模式下VTEP设备通过查找ARP表项(IPv4网络)或ND表项(IPv6网络)对流量进行转发。
修改本配置前必须先删除设备上的所有VSI、VSI虚接口、VSI子接口和VXLAN隧道,否则将配置失败。
# 配置VXLAN隧道工作在三层转发模式。
[Sysname] vxlan ip-forwarding
vxlan local-mac report命令用来开启本地MAC地址的日志记录功能。
undo vxlan local-mac report命令用来关闭本地MAC地址的日志记录功能。
本地MAC地址的日志记录功能处于关闭状态。
context-admin
开启本地MAC地址的日志记录功能后,VXLAN会立即根据已经学习到的本地MAC地址表项生成日志信息,之后在增加或删除本地MAC地址时也将产生日志信息。生成的日志信息将被发送到设备的信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。
# 开启本地MAC地址的日志记录功能。
[Sysname] vxlan local-mac report
vxlan source udp-port acl命令用来为符合ACL规则的报文指定VXLAN封装的源UDP端口号。
undo vxlan source udp-port命令用来恢复缺省情况。
vxlan source udp-port port-number acl acl-number
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
支持
不支持
F1000-C83X0系列
支持
不支持
F1000-C81X0系列
支持
不支持
F1000-7X0-HI系列
支持
不支持
F1000-C-X系列
支持
F1000-V系列
F1000-E-VG
支持
F1000-S-VG
不支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
F100-E-G5
支持
不支持
F100-X-G3系列
F100-A-G3、F100-E-G3
支持
不支持
F100-X-G2系列
F100-A-G2、F100-E-G2
支持
不支持
F100-WiNet系列
支持
不支持
F100-C-A系列
不支持
支持
F100-X-XI系列
支持
不支持
根据内层报文的源和目的MAC地址自动生成VXLAN封装的源UDP端口号。
VXLAN模式Tunnel接口视图
context-admin
port-number:VXLAN封装的源UDP端口号,取值范围为1024~65535。建议用户使用1024到49151之间的值。
acl-number:指定需要匹配的ACL的编号,取值范围为3000~3999。本命令中指定的ACL只能是高级ACL。
执行本命令后,在对Tunnel接口上发送的报文进行VXLAN封装时,如果该报文符合指定的ACL规则,则为其封装本命令指定的源UDP端口号。为不同报文封装不同源UDP端口号后,IPsec可以根据源端口号匹配需要进行加密的报文,从而实现对特定的流量进行IPsec保护。
如果本命令中指定的ACL未创建或ACL中没有配置IP地址相关的规则,则按照缺省情况封装源UDP端口号。
若在Tunnel接口下同时配置本命令与vxlan source udp-port five-tuple命令,则优先使用本命令配置的UDP端口号。
本命令仅对IPv4站点网络生效。
仅手工创建的VXLAN隧道支持本命令。
在Tunnel接口下多次执行本命令时,仅最后一次执行的命令生效。
# 在VXLAN隧道Tunnel1上配置如果报文符合ACL规则3001,则对该报文进行VXLAN封装时源UDP端口号为50001。
[Sysname] interface tunnel 1 mode vxlan
[Sysname-Tunnel1] vxlan source udp-port 50001 acl 3001
·     acl(ACL和QoS命令参考/ACL)
·     vxlan source udp-port five-tuple
vxlan source udp-port five-tuple命令用来配置根据内层报文的五元组信息生成VXLAN封装的源UDP端口号。
undo vxlan source udp-port five-tuple命令用来恢复缺省情况。
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
支持
F1000-9X0-AI系列
支持
不支持
F1000-C83X0系列
支持
不支持
F1000-C81X0系列
支持
不支持
F1000-7X0-HI系列
支持
不支持
F1000-C-X系列
支持
F1000-V系列
F1000-E-VG
支持
F1000-S-VG
不支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
F100-E-G5
支持
不支持
F100-X-G3系列
F100-A-G3、F100-E-G3
支持
不支持
F100-X-G2系列
F100-A-G2、F100-E-G2
支持
不支持
F100-WiNet系列
支持
不支持
F100-C-A系列
不支持
支持
F100-X-XI系列
支持
不支持
VXLAN模式Tunnel接口视图
context-admin
本命令仅对IPv4站点网络生效。
仅手工创建的VXLAN隧道支持本命令。
Tunnel接口下同时配置vxlan source udp-port acl与vxlan source udp-port five-tuple命令时,如果报文能够匹配vxlan source udp-port acl命令指定的ACL,则优先使用vxlan source udp-port acl配置的源UDP端口号;否则,根据内层报文的五元组信息生成源UDP端口号。
# 在VXLAN隧道Tunnel1上配置根据内层报文的五元组信息生成VXLAN封装的源UDP端口号。
[Sysname-Tunnel1] vxlan source udp-port five-tuple
·     vxlan source udp-port acl
vxlan tunnel mac-learning disable命令用来关闭远端MAC地址自动学习功能。
undo vxlan tunnel mac-learning disable命令用来开启远端MAC地址自动学习功能。
远端MAC地址自动学习功能处于开启状态。
context-admin
如果网络中存在攻击,为了避免学习到错误的远端MAC地址,可以通过本命令手工关闭远端MAC地址自动学习功能。
# 关闭远端MAC地址自动学习功能。
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port命令用来配置VXLAN报文的目的UDP端口号。
undo vxlan udp-port命令用来恢复缺省情况。
vxlan udp-port port-number
undo vxlan udp-port
VXLAN报文的目的UDP端口号为4789。
context-admin
port-number:VXLAN报文的目的UDP端口号,取值范围为1~65535。建议不要将VXLAN报文的目的UDP端口号配置为知名端口,即1~1023之间的端口。
属于同一个VXLAN的VTEP设备上需要配置相同的UDP端口号。
# 配置VXLAN报文的目的UDP端口号为6666。
[Sysname] vxlan udp-port 6666
1.1.38  xconnect vsi
xconnect vsi命令用来将AC与VSI关联。
undo xconnect vsi命令用来恢复缺省情况。
xconnect vsi vsi-name [ track track-entry-number&<1-3> ]
undo xconnect vsi
AC未关联VSI。
context-admin
track track-entry-number&<1-3>:配置AC与指定Track项联动。track-entry-number为Track项的序号,取值范围为1~1024;&<1-3>表示前面的参数最多可以输入3次。指定本参数后,仅当关联的Track项中至少有一个状态为positive时,AC的状态才会up;否则,AC的状态为down。
在接口视图下执行本命令后,从接口接收到的报文将通过查找关联VSI的MAC地址表进行转发。
# 在接口GigabitEthernet1/0/1下关联名为vpn1的VSI。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-GigabitEthernet1/0/1] xconnect vsi vpn1
·     vsi
1.2  VXLAN IP网关配置命令
arp distributed-gateway dynamic-entry synchronize命令用来开启分布式网关的动态ARP表项同步功能。
undo arp distributed-gateway dynamic-entry synchronize命令用来关闭分布式网关的动态ARP表项同步功能。
分布式网关的动态ARP表项同步功能处于关闭状态。
context-admin
分布式VXLAN IP网关上开启本地代理ARP功能时,本地网关不会将目标IP地址为分布式网关VSI虚接口的ARP报文转发给其他网关,只有本地网关能够学习到ARP报文发送者的ARP表项。如果希望所有网关都能学习到该ARP表项,需要开启分布式网关的动态ARP表项同步功能。
分布式VXLAN IP网关之间也可以通过控制器在彼此之间同步ARP表项,此时无需开启本功能。
# 开启分布式网关的动态ARP表项同步功能。
[Sysname] arp distributed-gateway dynamic-entry synchronize
·     distributed-gateway local
·     local-proxy-arp enable(三层技术-IP业务命令参考/代理ARP)
1.2.2  bandwidth
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbps)。
VSI虚接口视图
context-admin
bandwidth-value:接口的期望带宽,取值范围为1~400000000,单位为kbps。
期望带宽供业务模块使用,不会对接口实际带宽造成影响。
# 配置接口VSI-interface100的期望带宽为10000kbps。
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] bandwidth 10000
1.2.3  default
default命令用来恢复接口的缺省配置。
default
VSI虚接口视图
context-admin
# 将接口VSI-interface100恢复为缺省配置。
[Sysname-Vsi-interface100] default
This command will restore the default settings. Continue? [Y/N]:y
1.2.4  description
description命令用来配置接口的描述信息。
接口的描述信息为“接口名 Interface”,例如:Vsi-interface100 Interface。
VSI虚接口视图
context-admin
text:接口的描述信息,为1~255个字符的字符串,区分大小写。
# 配置接口VSI-interface100的描述信息为“gateway for VXLAN 10”。
[Sysname-Vsi-interface100] description gateway for VXLAN 10
display interface vsi-interface命令用来显示VSI虚接口的相关信息。
display interface [ vsi-interface [ vsi-interface-id ] ] [ brief [ description | down ] ]
context-admin
context-operator
vsi-interface [ vsi-interface-id ]:指定VSI虚接口及其编号。vsi-interface-id为VSI虚接口的编号。如果不指定vsi-interface,则显示设备支持的所有接口的相关信息。
brief:显示接口的概要信息。如果不指定该参数,则显示接口的详细信息。
down:显示当前物理状态为down的接口的信息以及down的原因。如果不指定该参数,则不会根据接口物理状态来过滤显示信息。
# 显示接口VSI-interface100的相关信息。
<Sysname> display interface vsi-interface 100
Vsi-interface100
Current state: UP
Line protocol state: UP
Description: Vsi-interface100 Interface
Bandwidth: 1000000 kbps
IP packet frame type: Ethernet II, hardware address: 0011-2200-0102
IPv6 packet frame type: Ethernet II, hardware address: 0011-2200-0102
表1-8 display interface vsi-interface命令显示信息描述表
Vsi-interface100
Current state
接口的物理状态和管理状态,取值包括:
·     DOWN:该接口的管理状态为开启,但物理状态为关闭
·     UP:该接口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态,取值包括:
·     UP:表示该接口的链路层协议状态为开启
·     UP(spoofing):表示该接口的链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
·     DOWN:表示该接口的链路层协议状态为关闭
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
接口未配置IP地址,不能处理IP报文
接口IP地址。Type表示地址获取方式,取值如下:
·     Primary:手动配置的主地址
·     Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息
·     DHCP-allocated:通过DHCP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     BOOTP-allocated:通过BOOTP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     PPP-negotiated:PPP协商过程中由Server端分配的IP地址,详细介绍请参见“PPP和PPPoE配置指导”中的“PPP”
·     Unnumbered:借用其他接口的IP地址
·     MAD:成员设备上配置的MAD IP地址,详细介绍请参见“虚拟化技术配置指导”中的“IRF”
·     SSLVPN:SSL VPN AC接口的IP地址,详细介绍请参见“安全配置指导”中的“SSL VPN”
Type的取值情况与接口类型有关,请以实际情况为准
IP报文发送帧格式
hardware address
硬件地址
IPv6报文发送帧格式
Physical
接口的物理类型,取值为Unknown
baudrate
接口的波特率,单位为kbps
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直未执行reset counters interface命令清除过该接口下的统计信息,则显示Never)
最近300秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的包数
最近300秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的包数
总计输入的报文数,总计输入的字节,总计丢弃的输入报文数
总计输出的报文数,总计输出的字节,总计丢弃的输出报文数
# 显示所有VSI虚接口的概要信息。
<Sysname> display interface vsi-interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Vsi100               DOWN DOWN     --
# 显示接口VSI-interface100的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface vsi-interface 100 brief description
Brief information on interfaces in route mode:Brief information of interface(s) under route mode:
Vsi100               UP    UP      1.1.1.1         VSI-interface100
# 显示当前状态为down的接口的信息以及DOWN的原因。
Interface            Link   Cause
Vsi100               DOWN   Administratively
Vsi200               DOWN   Administratively
表1-9 display interface vsi-interface brief命令显示信息描述表
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员通过shutdown命令关闭,需要在该接口下执行undo shutdown命令才能恢复端口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个处于Standby状态的备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口
如果某接口的Protocol属性值中带有“(s)”字符串,则表示该接口的网络层协议状态显示是UP的,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
接口名称缩写
Link
接口物理连接状态,取值包括:
·     UP:表示本链路物理上是连通的
·     DOWN:表示本链路物理上是不通的
·     ADM:表示本链路被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态
·     Stby:表示该接口是一个处于Standby状态的备份接口
Protocol
接口的链路层协议状态,取值包括:
·     UP (s):表示该接口的链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
Primary IP
接口主IP地址。取值为“--”时,表示接口尚未配置IP地址
接口的描述信息
Cause
接口物理连接状态为down的原因,取值为:
·     Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态
·     Not connected:表示没有VSI关联该接口,或者关联该接口的VSI内没有AC或VXLAN隧道
·     reset counters interface vsi-interface
distributed-gateway local命令用来配置VSI虚接口为分布式网关接口。
undo distributed-gateway local命令用来恢复缺省情况。
VSI虚接口不是分布式网关接口。
VSI虚接口视图
context-admin
在分布式VXLAN IP网关组网中,多个网关上同一VXLAN的VSI虚接口需要配置相同的IP地址。为了避免IP地址冲突,需要在VSI虚接口上执行本命令,以防止VSI虚接口上报地址冲突,导致VSI虚接口不可用。
# 配置接口Vsi-interface100为分布式网关接口。
[Sysname-Vsi-interface100] distributed-gateway local
gateway subnet命令用来配置VSI所属的子网网段。
undo gateway subnet命令用来删除VSI所属的子网网段。
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
undo gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
未指定VSI所属的子网网段。
VSI视图
context-admin
ipv4-address:IPv4子网网段地址,为点分十进制格式。
wildcard-mask:IPv4地址掩码的反码,即将IPv4地址的掩码取反(0变1,1变0)。例如:子网掩码255.0.0.0的反码为0.255.255.255。其中,反码中的“1”表示忽略IPv4地址中对应的位,“0”表示必须保留此位。
ipv6-address prefix-length:IPv6地址及前缀长度。prefix-length为IPv6前缀长度,取值范围为1~128。
多个VXLAN共用一个VSI虚接口时,可以在VSI视图下通过本命令指定VSI所属的子网网段,通过子网网段判断报文所属的VSI,并在该VSI内转发报文。
在VSI视图下配置子网网段前,必须先为该VSI指定网关接口。取消为VSI指定网关接口时,会自动删除为该VSI指定的子网网段。
一个VSI视图下最多可以配置8个子网网段,包括IPv4子网和IPv6子网。
不能为指定了相同网关接口的不同VSI配置相同的子网网段。
# 配置名称为vxlan的VSI所属的子网网段为100.0.10.0/24。
[Sysname] vsi vxlan
[Sysname-vsi-vxlan] gateway subnet 100.0.10.0 0.0.0.255
gateway vsi-interface命令用来为VSI指定网关接口。
undo gateway vsi-interface命令用来恢复缺省情况。
gateway vsi-interface vsi-interface-id
未指定VSI的网关接口。
VSI视图
context-admin
vsi-interface-id:VSI网关虚接口的编号,取值范围为0~8191。
一个VSI只能指定一个网关接口。
不同的VSI可以指定相同的网关接口。
# 为VSI指定网关接口为Vsi-interface100。
[Sysname] vsi vpna
[Sysname-vsi-vpna] gateway vsi-interface 100
·     interface vsi-interface
interface vsi-interface命令用来创建VSI虚接口,并进入VSI虚接口视图。如果指定的VSI虚接口已经存在,则直接进入VSI虚接口视图。
undo interface vsi-interface命令用来删除指定的VSI虚接口。
interface vsi-interface vsi-interface-id
undo interface vsi-interface vsi-interface-id
不存在VSI虚接口。
context-admin
vsi-interface-id:VSI虚接口的编号,取值范围为0~8191。
# 创建VSI虚接口100,并进入VSI虚接口视图。
·     gateway vsi-interface
1.2.10  mac-address
mac-address命令用来配置VSI虚接口的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
缺省情况下,VSI虚接口未指定MAC地址。
VSI虚接口视图
context-admin
mac-address:MAC地址,形式为H-H-H。
# 配置VSI虚接口100的MAC地址为0001-0001-0001。
[Sysname-Vsi-interface100] mac-address 1-1-1
1.2.11  mtu
mtu命令用来配置接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
缺省情况下,接口的MTU值为1500字节。
VSI虚接口视图
context-admin
# 配置接口VSI-interface100的MTU值为1430字节。
[Sysname-Vsi-interface100] mtu 1430
reset counters interface vsi-interface命令用来清除VSI虚接口的统计信息。
reset counters interface [ vsi-interface [ vsi-interface-id ] ]
context-admin
vsi-interface [ vsi-interface-id ]:指定VSI虚接口及其编号。vsi-interface-id为VSI虚接口的编号。如果不指定vsi-interface,则清除设备支持的所有接口的统计信息。
# 清除接口VSI-interface100的统计信息。
<Sysname> reset counters interface vsi-interface 100
·     display interface vsi-interface
1.2.13  shutdown
shutdown命令用来关闭VSI虚接口。
undo shutdown命令用来开启VSI虚接口。
shutdown
VSI虚接口均处于开启状态。
VSI虚接口视图
context-admin
执行本命令会导致使用该接口作为网关的VXLAN网络不能进行三层通信,请谨慎使用。
# 关闭接口VSI-interface100。
[Sysname-Vsi-interface100] shutdown
vtep group member local命令用来将本设备加入VXLAN IP网关保护组,并配置本设备的成员地址。
undo vtep group member local命令用来取消本设备加入指定的VXLAN IP网关保护组。
vtep group group-ip member local member-ip
undo vtep group group-ip member local
设备未加入VXLAN IP网关保护组。
context-admin
group-ip:VXLAN IP网关保护组的VTEP IP地址,该地址必须是本设备上已经存在的地址。
member-ip:本设备在VXLAN IP网关保护组内的成员地址,该地址必须是设备上已经配置的地址。
成员地址不能和保护组的VTEP IP相同;同一个保护组中不同成员的成员地址也不能相同。
# 配置本设备加入VXLAN IP保护组,保护组的VTEP IP地址是1.1.1.1,本设备的成员地址为2.2.2.2。
[Sysname] vtep group 1.1.1.1 member local 2.2.2.2
·     vtep group member remote
vtep group member remote命令用来配置VXLAN IP网关保护组的成员地址列表。
undo vtep group member remote命令用来删除指定VXLAN IP网关保护组的成员地址列表。
vtep group group-ip member remote member-ip&<1-8>
undo vtep group group-ip member remote
未配置VXLAN IP网关保护组的成员地址列表。
context-admin
group-ip:VXLAN IP网关保护组的VTEP IP地址。
member-ip&<1-8>:VXLAN IP网关保护组成员IP地址列表。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
# 配置VXLAN IP网关保护组1.1.1.1包含的成员设备为2.2.2.2、3.3.3.3和4.4.4.4。
[Sysname] vtep group 1.1.1.1 member remote 2.2.2.2 3.3.3.3 4.4.4.4
·     vtep group member local
vxlan tunnel arp-learning disable命令用来关闭远端ARP自动学习功能。
undo vxlan tunnel arp-learning disable命令用来开启远端ARP自动学习功能。
远端ARP自动学习功能处于开启状态。
context-admin
缺省情况下,设备从VXLAN隧道接收到报文后可以自动学习远端虚拟机的ARP信息,即远端ARP信息。在SDN控制器组网下,当控制器和设备间进行表项同步时,可以通过vxlan tunnel arp-learning disable命令暂时关闭远端ARP自动学习功能,以节省占用的设备资源。同步完成后,再执行undo vxlan tunnel arp-learning disable命令开启远端ARP自动学习功能。
建议用户只在控制器和设备间同步表项的情况下执行vxlan tunnel arp-learning disable命令。
# 关闭远端ARP自动学习功能。
<Sysname> system
[Sysname] vxlan tunnel arp-learning disable
1.3  OVSDB-VTEP配置命令
本特性的支持情况与设备型号有关,请以设备的实际情况为准。
F1000系列
型号
F1000-X-G5系列
支持
F1000-X-G3系列
支持
F1000-X-G2系列
不支持
F1000-9X0-AI系列
支持
不支持
F1000-C83X0系列
支持
不支持
F1000-C81X0系列
不支持
F1000-7X0-HI系列
支持
不支持
F1000-C-X系列
不支持
支持
F1000-V系列
不支持
SecBlade IV
不支持
F100系列
型号
F100-X-G5系列
不支持
F100-X-G3系列
F100-A-G3、F100-E-G3、F100-C-G3、F100-M-G3、F100-S-G3
不支持
F100-X-G2系列
F100-A-G2、F100-E-G2、F100-C-G2、F100-M-G2、F100-S-G2
不支持
F100- WiNet系列
不支持
F100-A81-WiNet、F100-A91-WiNet
支持
F100-C-A系列
不支持
F100-X-XI系列
不支持
ovsdb server bootstrap ca-certificate命令用来指定与控制器进行SSL通信时使用的CA证书文件。
undo ovsdb server bootstrap ca-certificate命令用来恢复缺省情况。
ovsdb server bootstrap ca-certificate ca-filename
与控制器进行SSL通信时使用PKI域中的CA证书文件。
context-admin
ca-filename:表示与控制器进行SSL通信时使用的CA证书文件名称,不区分大小写,文件名称中不允许出现slot字样。只允许使用主用主控板的CA证书文件。
通过本命令指定与控制器进行SSL通信使用的CA证书文件时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
本命令指定的只能是主用主控板中的CA证书文件。如果指定的文件存在,直接使用。否则,使用开启OVSDB服务器时通过SSL连接获取的自签名证书,并通过本命令指定证书文件名。
执行本命令后,优先使用本命令指定的CA证书文件,不使用PKI域中的CA证书。
# 指定与控制器进行SSL通信时使用的CA证书文件为ca-new。
[Sysname] ovsdb server bootstrap ca-certificate ca-new
·     ovsdb server enable
·     ovsdb server pki domain
·     ovsdb server pssl
·     ovsdb server ssl
ovsdb server enable命令用来开启OVSDB服务器。
undo ovsdb server enable命令用来关闭OVSDB服务器。
ovsdb server enable
OVSDB服务器处于关闭状态。
context-admin
开启OVSDB服务器后,OVSDB服务器可以与控制器建立连接,接收控制器通过OVSDB控制协议发送的数据,并保存到本地OVSDB数据库中,从而实现控制器对VTEP设备进行VXLAN相关配置。
为了保证OVSDB服务器能够与控制器建立连接,在开启OVSDB服务器前,必须先配置至少一条与控制器的连接。
# 开启OVSDB服务器。
[Sysname] ovsdb server enable
ovsdb server pki domain命令用来指定与控制器进行SSL通信时使用的PKI域。
undo ovsdb bootstrap server pki domain命令用来恢复缺省情况。
ovsdb server pki domain domain-name
undo ovsdb server pki domain
未指定与控制器进行SSL通信时使用的PKI域。
context-admin
domain-name:表示与控制器进行SSL通信时使用的PKI域名称,为1~31个字符的字符串,区分大小写。指定的PKI域必须存在,并且PKI域中包含完整的证书和密钥。PKI域的详细介绍,请参见“安全配置指导”中的“PKI”。
与控制器进行SSL通信时需通过本命令指定PKI域。
通过本命令指定与控制器进行SSL通信时使用的PKI域时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
# 指定与控制器进行SSL通信时使用的PKI域为ovsdb_test。
[Sysname] ovsdb server pki domain ovsdb_test
·     ovsdb server bootstrap ca-certificate
·     ovsdb server pssl
·     ovsdb server ssl
ovsdb server pssl命令用来配置与控制器建立被动SSL连接。
undo ovsdb server pssl命令用来恢复缺省情况。
ovsdb server pssl [ port port-number ]
不会与控制器建立被动SSL连接。
context-admin
port port-number:指定与控制器建立SSL连接的端口号,OVSDB服务器监听该端口上的SSL连接请求。port-number取值范围为1~65535。如果不指定本参数,则监听6640端口。
配置与控制器建立被动SSL连接前,需先指定SSL通信中使用的PKI域。
通过本命令配置与控制器建立被动SSL连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
只能配置一个OVSDB服务器监听的SSL连接端口号。多次执行本命令,最后一次执行的命令生效。
# 配置与控制器建立被动SSL连接,监听端口号采用默认端口号。
[Sysname] ovsdb server pssl
·     ovsdb server ssl
ovsdb server ptcp命令用来配置与控制器建立被动TCP连接。
undo ovsdb server ptcp命令用来恢复缺省情况。
ovsdb server ptcp [ port port-number ]
不会与控制器建立被动TCP连接。
context-admin
port port-number:指定与控制器建立TCP连接的监听端口号,取值范围为1~65535,如果不指定本参数,则监听6640端口。
通过本命令配置与控制器建立被动TCP连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
只能配置一个OVSDB服务器监听的TCP连接端口号。多次执行本命令,最后一次执行的命令生效。
# 配置与控制器建立被动TCP连接,监听端口号采用默认端口号。
[Sysname] ovsdb server ptcp
·     ovsdb server tcp
ovsdb server ssl命令用来配置与控制器建立主动SSL连接。
undo ovsdb server ssl命令用来删除指定的主动SSL连接。
ovsdb server ssl ip ip-address port port-number
undo ovsdb server ssl ip ip-address port port-number
不会与控制器建立主动SSL连接。
context-admin
ssl ip-address:指定SSL连接的目的IP地址。
port port-number:指定SSL连接的目的端口号,取值范围为1~65535。
配置与控制器建立主动SSL连接前,需先指定SSL通信中使用的PKI域。
通过本命令配置与控制器建立主动SSL连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
OVSDB服务器最多只能配置8个与控制器的SSL主动连接。
# 配置与控制器建立主动SSL连接,指定目的IP地址为192.168.12.2、目的端口号为6632。
[Sysname] ovsdb server ssl ip 192.168.12.2 port 6632
·     ovsdb server pssl
ovsdb server tcp命令用来配置与控制器建立主动TCP连接。
undo ovsdb server tcp命令用来删除指定的主动TCP连接。
ovsdb server tcp ip ip-address port port-number
undo ovsdb server tcp ip ip-address port port-number
不会与控制器建立主动TCP连接。
context-admin
ip ip-address:指定TCP连接的目的IP地址。
port port-number:指定TCP连接的目的端口号。
通过本命令配置与控制器建立主动TCP连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
OVSDB服务器最多只能配置8个与控制器的TCP主动连接。
# 配置与控制器建立主动TCP连接,指定目的IP地址为192.168.12.2、目的端口号为6632。
[Sysname] ovsdb server tcp ip 192.168.12.2 port 6632
·     ovsdb server ptcp
vtep access port命令用来指定当前接口为用户侧的接入端口。
undo vtep access port命令用来恢复缺省情况。
vtep access port
当前接口不是用户侧的接入端口。
二层以太网接口视图
二层聚合接口视图
三层接口视图
context-admin
只有将接口配置为用户侧的接入端口后,控制器上才能够显示该端口并对其进行控制。
# 指定二层以太网接口GigabitEthernet1/0/1为用户侧的接入端口。
[Sysname-GigabitEthernet1/0/1] vtep access port
1.3.9  vtep enable
vtep enable命令用来开启OVSDB VTEP服务。
undo vtep enable命令用来关闭OVSDB VTEP服务。
vtep enable
undo vtep enable
OVSDB VTEP服务处于关闭状态。
context-admin
# 开启设备的OVSDB VTEP服务。
[Sysname] vtep enable
vxlan tunnel flooding-proxy命令用来开启组播隧道泛洪代理功能。
undo vxlan tunnel flooding-proxy命令用来关闭组播隧道泛洪代理功能。
组播隧道泛洪代理功能处于关闭状态。
context-admin
开启组播隧道泛洪代理功能后,系统会将控制器下发的组播隧道转换为具有泛洪代理功能的隧道。VXLAN内的广播、组播和未知单播流量将通过具有泛洪代理功能的隧道发送到泛洪代理服务器,由代理服务器进行复制并转发到其他远端VTEP。
采用泛洪代理(服务器复制)方式转发站点间的泛洪流量时,必须开启该功能。
执行undo vxlan tunnel flooding-proxy命令,不会改变已有隧道的泛洪代理模式。
# 开启组播隧道泛洪代理功能。
<Sysname> system
[Sysname] vxlan tunnel flooding-proxy
