21-网络管理和监控命令参考
08-PTP命令
本章节下载 08-PTP命令  (677.07 KB)
08-PTP命令
目
1 PTP
1.1 PTP公共配置命令
1.1.1 display ptp clock
1.1.2 display ptp corrections
1.1.3 display ptp foreign-masters-record
1.1.4 display ptp interface
1.1.5 display ptp parent
1.1.6 display ptp path-trace
1.1.7 display ptp port-history
1.1.8 display ptp statistics
1.1.9 display ptp time-property
1.1.10 ptp alarm-threshold { time-lock | time-unlock }
1.1.11 ptp alarm-threshold time-offset-sum pk-pk
1.1.12 ptp asymmetry-correction
1.1.13 ptp global enable
1.1.14 ptp max-steps-removed
1.1.15 ptp path-trace disable
1.1.16 ptp time-offset
1.1.17 reset ptp statistics
1.1.18 snmp-agent trap enable ptp
1.2 PTP(IEEE 1588v2)专属配置命令
1.2.1 ptp active force-state
1.2.2 ptp alarm-threshold clock-source-class
1.2.3 ptp alarm-threshold time-offset
1.2.4 ptp announce-interval
1.2.5 ptp announce-timeout
1.2.6 ptp clock-source
1.2.7 ptp clock-state enable
1.2.8 ptp clock-step
1.2.9 ptp delay-mechanism
1.2.10 ptp destination-mac
1.2.11 ptp domain
1.2.12 ptp enable
1.2.13 ptp force-state
1.2.14 ptp ignore sync-uncertain
1.2.15 ptp min-delayreq-interval
1.2.16 ptp mode
1.2.17 ptp priority
1.2.18 ptp profile 1588v2
1.2.19 ptp slave-only
1.2.20 ptp sync-uncertain enable
1.2.21 ptp syn-interval
1.2.22 ptp technical-standard
1.3 PTP(ITU-T G.8275.1)专属配置命令
1.3.1 ptp active force-state
1.3.2 ptp alarm-threshold clock-source-class
1.3.3 ptp alarm-threshold time-offset
1.3.4 ptp announce-interval
1.3.5 ptp announce-timeout
1.3.6 ptp clock-source
1.3.7 ptp clock-state enable
1.3.8 ptp clock-step
1.3.9 ptp destination-mac
1.3.10 ptp domain
1.3.11 ptp enable
1.3.12 ptp force-state
1.3.13 ptp ignore sync-uncertain
1.3.14 ptp local-priority
1.3.15 ptp min-delayreq-interval
1.3.16 ptp mode
1.3.17 ptp notslave disable
1.3.18 ptp priority
1.3.19 ptp profile g8275.1
1.3.20 ptp sync-uncertain enable
1.3.21 ptp syn-interval
1.3.22 ptp technical-standard
1 PTP
1.1  PTP公共配置命令
display ptp clock命令用来显示设备的PTP时钟信息。
display ptp clock
推荐配置
请先配置PTP协议标准、时钟节点类型和PTP域,否则,显示信息为空。
# 显示设备的PTP时钟信息。
<Sysname> display ptp clock
PTP global state    : Enable
PTP profile         : IEEE 1588 Version 2
PTP mode            : BC
Slave only          : No
Sync uncertain      : Disabled
Clock state         : Disabled
Clock ID            : AD0000-FFFE-000000
Clock type          : Local
Clock domain        : 1
Number of PTP ports : 0
Priority1     : 128
Priority2     : 128
Clock quality :
 Class                 : 248
 Accuracy              : 254
 Offset (log variance) : 65535
Offset from master  : 0 (ns)
Mean path delay     : 0 (ns)
Steps removed       : 0
Local clock time    : Mon Jul 6 12:30:08 2020
Clock source info:
 Clock   Pri1 Pri2 Accuracy Class TimeSrc Direction In-Status Offset(log variance)
 Local   128  128  254      248   160     N/A       N/A       65535
表1-1 display ptp clock命令显示信息描述表
PTP global state
全局PTP功能状态,取值包括:
·     Enabled:全局PTP功能处于开启状态
·     Disabled:全局PTP功能处于关闭状态
PTP profile
PTP协议遵循的标准:
·     IEEE 1588 Version 2:PTP协议遵循IEEE1588 version 2标准
·     ITU-T G.8275.1:PTP协议遵循ITU-T G.8275.1标准
PTP mode
时钟节点类型,取值包括:
·     BC:表示BC类型(IEEE 1588 Version 2协议支持)
·     OC:表示OC类型(IEEE 1588 Version 2支持)
·     T-BC:表示T-BC类型(ITU-T G.8275.1协议支持)
·     T-TSC:表示T-TSC类型(ITU-T G.8275.1协议支持)
Slave only
OC的工作模式是否为Slave only,取值包括:
·     Yes:表示是
·     No:表示不是
Sync uncertain
SyncUncertain功能的开启状态:
·     Disabled:表示未开启
·     Enabled:表示开启
Clock state
PTP时钟所处状态:
·     Disabled:表示时钟状态功能未开启
·     Free-Run:表示自由运行状态
·     Acquiring:表示捕获状态
·     Locked:表示锁定状态
·     Holdover:表示保持状态
Clock ID
本设备的时钟编号,用于唯一标识一台PTP设备
Clock type
本设备的时钟类型,取值包括:
·     Local:本地时钟
Clock domain
本设备所在的PTP域
Number of PTP ports
PTP接口的数量
Priority1
本设备上时钟第一优先级的值
Priority2
本设备上时钟第二优先级的值
Clock quality
时钟品质特性
Class
本设备上时钟的时间等级值
Accuracy
本设备上时钟的时间精度值
最优时钟的偏差度量
Offset from master
与主节点的时钟偏差,单位为纳秒,N/A表示无意义
Mean path delay
平均路径延时,单位为纳秒,N/A表示无意义
Steps removed
最优时钟到本时钟节点的跳数,N/A表示无意义
Local clock time
当前的本地系统时间
Clock source info
时钟源的信息
Clock
时钟源,取值为Local,表示本地时钟源
Pri1
本设备上时钟第一优先级的值
Pri2
本设备上时钟第二优先级的值
LP
本设备上时钟本地优先级的值(仅ITU-T G.8275.1协议标准下显示)
TimeSrc
时钟的属性
Direction
本设备的时钟类型为Local时,本字段显示为N/A
In-Status
display ptp corrections命令用来显示从接口时间校正的历史信息。
工作机制
如果配置了PTP协议标准、时钟节点和PTP域,且设备存在从接口,当设备每通过从接口进行一次时间/频率同步时,就会记录一条对应信息,此时,执行本命令才能看到显示信息。若从接口更换,记录会被清空。
# 显示从接口时间校正的历史信息。
<Sysname> display ptp corrections
Correction time          Corrections(s,ns)     Rate ratio   Slave port
Mar 11 03:14:54 2019     0,74                  0.999999973  GE2/0/1
Mar 11 03:14:55 2019    -1,17                  0.999999980  GE2/0/1
表1-2 display ptp corrections命令显示信息描述表
Sync State
当前实例的时间是否可用于同步本设备的系统时钟:
•       Active:可以
•       Inactive:不可以
Correction time
时间偏差的校正时间
Corrections(s,ns)
时间偏差(秒,纳秒),N/A表示本次没有校正
Rate ratio
本接口与主接口的频率比,N/A表示本次没有校正
Slave port
从接口名称
display ptp foreign-masters-record命令用来显示外部主节点的信息。
display ptp foreign-masters-record [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上的外部主节点信息,interface-type interface-number表示接口类型和接口编号。如未指定本参数,显示所有接口的相应信息。
工作机制
配置了时钟节点类型和PTP域,且设备存在Slave、Passive或Uncalibrated状态的接口时,才可以显示外部主节点的信息,否则无显示信息。
# 显示所有接口的外部主节点信息。
<Sysname> display ptp foreign-masters-record
P1=Priority1, P2=Priority2, LP=LocalPriority, C=Class, A=Accuracy,
OSLV=Offset-scaled-log-variance, SR=Steps-removed
GM=Grandmaster
Clock ID             P1  P2  LP  C   A   OSLV   SR  GM  Interface
62214E-FFFE-B20100   128 128 N/A 248 254 65535  0   Yes GE2/0/1
表1-3 display ptp foreign-masters-record命令显示信息描述表
Clock ID
外部主时钟节点的编号
P1
时钟第一优先级的值
P2
时钟第二优先级的值
LP
对端节点的优先级(仅ITU-T G.8275.1协议标准下显示)
取值为N/A时,表示不支持
C
时钟的时间等级值
A
时钟的时间精度值
OSLV
最优时钟的偏差度量
SR
最优时钟到该时钟节点的跳数
GM
最优时钟节点:
·     Yes:表示该节点是最优时钟节点
·     No:表示该节点不是最优时钟节点
PTP接口的名称
display ptp interface命令用来显示接口的PTP运行信息。
display ptp interface [ interface-type interface-number ]
display ptp interface brief
interface-type interface-number:详细显示指定接口的PTP运行信息,interface-type interface-number表示接口类型和接口编号。如未指定本参数,将显示所有接口的PTP运行信息。
brief:简要显示所有接口的PTP运行信息。如果未指定本参数,将详细显示指定接口或所有接口的PTP运行信息。
工作机制
当接口开启了PTP功能,则可以显示接口详细信息。当接口PTP功能实际工作时,才可以显示接口简要信息,否则无显示信息。
注意事项
不指定allinstance参数时,显示缺省实例0的相应信息。
# 简要显示所有接口的PTP运行信息。
<Sysname> display ptp interface brief
State        Delay mechanism  Clock step  Asymmetry correction  Name
Slave        E2E              Two         0                     GE2/0/1
Passive      E2E              Two         0                     GE2/0/2
# 详细显示接口GigabitEthernet2/0/1的PTP运行信息。
<Sysname> display ptp interface gigabitethernet 2/0/1
Clock ID                    : 000FE2-FFFE-FF0000
Port number                 : 15
PTP version                 : 2
PTP enable                  : Enabled
Transport of PTP            : User Datagram Protocol (IPv4)
Unicast destination address : 10.10.10.2
DSCP priority               : 56
Port state                  : Slave
Force state                 : No
Clock step                  : Two
Asymmetry correction        : 0
Delay mechanism             : End to End
Announce interval (log mean)           : 1
Announce receipt time out              : 3
Sync interval (log mean)               : 2
Delay request interval (log mean)      : 2
Peer delay request interval (log mean) : 0
Mean path delay                        : 1357 (ns)
表1-4 display ptp interface命令显示信息描述表
PTP接口的状态,取值包括:
·     Slave:接口状态为Slave,跟踪外部时间信息
·     Uncalibrated:接口状态为Uncalibrated,Slave状态前的临时状态
·     Passive:接口状态为Passive(接口收到对端的Announce报文后,计算出的状态),不跟踪外部时间信息,也不对外发布时间信息
·     Master:接口状态为Master,对外发布时间信息
·     Premaster:接口状态为Premaster,Master状态前的临时状态
·     Listening:接口状态为Listening(接口初始化后,即进入Listening状态),不跟踪外部时间信息,也不对外发布时间信息
·     Faulty:接口状态为Faulty,该状态为PTP协议的错误状态(即检测到错误),接口不处理PTP协议报文
·     Disabled:接口状态为Disabled,接口上PTP协议未运行,接口不处理协议报文
·     Initializing:接口状态为Initializing,接口位于初始化状态,接口不处理协议报文
·     N/A:表示无意义
Delay mechanism
接口的延时测量机制,取值包括:
·     End to End:请求应答机制
·     Peer to Peer:端延时机制
Clock step
时间戳的携带模式,取值包括:
·     One:表示单步模式
·     Two:表示双步模式
非对称延迟校正时间,单位为纳秒
Name
PTP接口的名称
Clock ID
接口所在设备的时钟编号
Port number
接口号
PTP version
PTP版本号:取值只能为2,表示PTP版本号为2
PTP enable
接口的PTP激活状态,取值包括:
·     Enabled:表示接口的PTP处于激活状态
·     Disabled:表示接口的PTP处于未激活状态
Transport of PTP
PTP报文封装格式,取值包括:
·     User Datagram Protocol (IPv4):PTP报文采用UDP封装格式(网络层协议为IPv4)
·     IEEE 802.3/Ethernet:PTP报文采用IEEE 802.3/Ethernet封装格式
Dot1p priority
PTP报文的802.1p优先级。
Force state
是否配置强制状态生效,取值包括:
·     Yes:表示已配置
·     No:表示未配置
Announce报文的发送周期=2interval(单位为秒),本字段就是interval的值
Announce报文的接收超时倍数,在倍数的发送周期内,若未收到主节点的Announce报文,则认为主节点失效
Sync报文的发送周期=2interval(单位为秒),本字段就是interval的值
Delay_Req报文的最小发送周期=2interval(单位为秒),本字段就是interval的值
Delay response interval (log mean)
发送Delay_Resp报文的发送周期=2interval(单位为秒),本字段就是interval的值
Local priority
NotSlave
NotSlave属性(仅ITU-T G.8275.1协议标准下显示)
Mean path delay
接口与对端的平均路径延时,单位为纳秒
display ptp parent命令用来显示PTP设备主节点信息。
display ptp parent
在以下情景下执行本命令显示信息为空:
·     PTP协议标准、时钟节点类型和PTP域三个参数中至少有一项未配置。
·     时钟节点类型指定为TC。
·     使用ptp active force-state命令配置了强制状态生效。
# 显示PTP设备主节点信息。
<Sysname> display ptp parent
Parent clock:
 Parent clock ID                         : 000FE2-FFFE-FF0005
 Parent port number                      : 15
 Observed parent offset (log variance)   : N/A
 Observed parent clock phase change rate : N/A
Grandmaster clock:
 Grandmaster clock ID: 000FE2-FFFE-FF0000
 Grandmaster clock quality:
  Class                 : 248
  Accuracy              : 254
  Priority1             : 128
  Priority2             : 128
表1-5 display ptp parent命令显示信息描述表
Parent clock
主时钟信息
Parent clock ID
主时钟的编号
Parent port number
主时钟节点的输出接口号
主时钟节点的偏差度量,N/A表示无意义
主时钟节点的相位变化比率,N/A表示无意义
Grandmaster clock
最优时钟节点信息
最优时钟节点编号
最优时钟节点属性
Class
最优时钟的时间等级值
Accuracy
最优时钟的时间精度值
最优时钟的偏差度量
Priority1
最优时钟第一优先级的值
Priority2
最优时钟第二优先级的值
·     ptp active force-state
·     ptp domain
·     ptp mode
·     ptp profile
display ptp path-trace命令用来显示PTP时钟的路径追踪信息。
工作机制
执行本命令将从主时钟开始,按顺序显示PTP同步时钟路径上的时钟节点。
注意事项
以下情景执行本命令,显示信息将为空:
# 显示PTP时钟的路径信息。
<Sysname> display ptp path-trace
Sequence number       Clock ID
1                     000FE2-FFFE-FF0000
2                     000FE3-FFFE-F90000
3                     000FE4-FFFE-F50000
4                     000FE5-FFFE-F20000
5                     000FE6-FFFE-F70000
表1-6 display ptp path-trace命令显示信息描述表
Sequence number
路径上时钟节点的序列号
Clock ID
路径追踪时钟节点的编号
·     ptp domain
·     ptp mode
·     ptp profile
display ptp port-history命令用来显示PTP接口角色变化的历史信息。
display ptp port-history [ interface interface-type interface-number ]
interface interface-type interface-number:表示接口类型和接口编号。不指定该参数时,表示所有接口。
# 显示设备缺省实例0下所有PTP接口角色变化的历史信息。
<Sysname> display ptp port-history
Interface: GigabitEthernet2/0/1
 Role change: Disabled -> Listening
 Time       : Apr 15 08:56:50 2020
 IfBMCInfo  : 0 255 255 255 255 65535 65535 65535 65535 65535 6
 Role change: Listening -> Master
 Time       : Apr 15 08:56:56 2020
表1-7 display ptp port-history命令显示信息描述表
PTP接口的名称
Role change
PTP端口的角色变化
Time
端口角色计算时间
IfBMCInfo
接口BMC信息:
·     使用IEEE 1588 Version 2时,由协议类型、第一优先级、时钟等级、时钟精度、第二优先级、发送端口号、接收端口号、源端口号、跳数、偏差度量、端口号组成,以空格分隔
·     使用8275.1协议时,由协议类型、本地优先级、时钟等级、时钟精度、第二优先级、发送端口号、接收端口号、源端口号、跳数、偏差度量、端口号组成,以空格分隔
display ptp statistics命令用来显示PTP统计信息。
display ptp statistics [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上的PTP统计信息。interface-type interface-number表示接口类型和接口编号。如未指定本参数,将显示所有接口的PTP统计信息。
推荐配置
# 显示接口GigabitEthernet2/0/1上的PTP统计信息。
<Sysname> display ptp statistics interface gigabitethernet 2/0/1
                     Received packets
Announce :0          Sync      :0          Signaling          :0
DelayReq :0          DelayResp :0          FollowUp           :0
                     Sent packets
Announce :476        Sync      :2543       Signaling          :0
DelayReq :0          DelayResp :0          FollowUp           :2542
                     Discarded packets
# 显示所有接口上的PTP统计信息。
Interface : GigabitEthernet2/0/1
                     Received packets
Announce :2353       Sync      :4700       Signaling          :0
DelayReq :0          DelayResp :4450       FollowUp           :4700
                     Sent packets
Announce :8          Sync      :14         Signaling          :0
DelayReq :4450       DelayResp :0          FollowUp           :14
                     Discarded packets
Announce :0          Sync      :4          Signaling          :0
DelayReq :0          DelayResp :0          FollowUp           :4
表1-8 display ptp statistics命令显示信息描述表
Received packets
接口收到的PTP协议报文数量的统计信息
Sent packets
接口发出的PTP协议报文数量的统计信息
Discarded packets
接口丢弃的PTP协议报文数量的统计信息
·     ptp domain
·     ptp mode
·     ptp profile
display ptp time-property命令用来显示PTP时钟节点时间信息。
在以下情景下执行本命令显示信息为空:
·     时钟节点类型指定为TC。
# 显示PTP时钟节点时间信息。
<Sysname> display ptp time-property
PTP clock time property:
 Current UTC offset valid : True
 Current UTC offset       : 33
 Leap59 : Yes
 Leap61 : No
 Time traceable      : True
 Frequency traceable : True
 PTP timescale       : True
 Time source         : 0xA0 (Internal oscillator)
 Sync uncertain      : False
表1-9 display ptp time-property命令显示信息描述表
PTP时钟节点时间信息
当前偏移量是否有效:
·     True:有效
·     False:无效
Current UTC offset
最优时钟的UTC时间相对于TAI时间的累计偏移量(单位为秒)
Leap59
是否对累计偏移量减一:
·     Yes:表示是
·     No:表示不是
Leap61
是否对累计偏移量加一:
·     Yes:表示是
·     No:表示不是
Time traceable
时间可跟踪性:
·     True:PTP时间可跟踪
·     False:PTP时间不可跟踪
Frequency traceable
频率可跟踪性:
·     True:频率可跟踪
·     False:频率不可跟踪
PTP timescale
PTP时间标识:
·     True:PTP时间标识
·     False:非PTP时间标识
Time source
最优时钟的时钟类别,取值包括:
·     Atomic clock:原子时钟
·     GPS:Global Positioning System,全球定位系统
·     Handset:手持设备
·     Internal oscillator:内部震荡器
·     NTP:Network Time Protocol,网络时间协议
·     Other:其他
·     PTP:Precision Time Protocol,精确时间协议
·     Terrestrial radio:陆基无线电
·     Unknown:未知
Sync uncertain
同步的上游时钟源是否为不可靠时钟,取值包括:
·     True:表示同步的上游时钟源为不可靠时钟
·     False:表示同步的上游时钟源为可靠时钟
·     ptp domain
·     ptp mode
·     ptp profile
ptp alarm-threshold { time-lock threshold-value | time-unlock unlock-value } *命令用来配置PTP时间锁定阈值和失锁阈值。
undo ptp alarm-threshold { time-lock | time-unlock } *命令用来恢复缺省情况。
ptp alarm-threshold { time-lock lock-value | time-unlock unlock-value } *
PTP时间锁定阈值为8000ns,失锁阈值为300000ns。
time-lock lock-value:PTP时间锁定阈值,取值范围为5~20000,单位为ns。
time-unlock unlock-value:PTP时间失锁阈值,取值范围为10~500000,单位为ns。
工作机制
当PTP时钟源的时间偏移大于unlock-value时,PTP时间为失锁状态,触发时钟失锁日志。当PTP时钟源的时间偏移由大于配置值恢复到小于等于lock-value时,PTP时间恢复为锁定状态,触发时钟锁定日志。
配置准备
必须先配置PTP协议标准和时钟节点后,才允许配置该命令。
注意事项
失锁阈值必须要大于或等于锁定阈值。
多次执行本命令:
·     可以分别配置锁定阈值和失锁阈值。
·     当配置的是同一阈值时,则最新的配置生效。
# 配置PTP时间锁定阈值为100ns。
[Sysname] ptp profile 1588v2
[Sysname] ptp mode bc
[Sysname] ptp domain 30
[Sysname] ptp alarm-threshold time-lock 100
·     ptp domain
·     ptp mode
·     ptp profile
ptp alarm-threshold time-offset-sum pk-pk命令用来配置PTP源时间偏差累加和的峰峰值日志输出参数。
undo ptp alarm-threshold time-offset-sum pk-pk命令用来恢复缺省情况。
ptp alarm-threshold time-offset-sum pk-pk threshold-value
PTP源时间偏差累加和的峰峰值日志输出参数为500ns。
threshold-value:表示PTP源时间偏差累加和的峰峰值日志输出参数值,取值范围为0~2000,单位为ns。
工作机制
每隔一段时间,PTP会计算一次源时间偏差累加和的峰峰值并将该值与本命令配置的日志输出参数值进行比较,大于等于该阈值则生成对应日志。
配置准备
# 配置PTP源时间偏差累加和的峰峰值日志输出参数值为1500ns。
[Sysname] ptp alarm-threshold time-offset-sum pk-pk 1500
·     ptp domain
·     ptp mode
·     ptp profile
ptp asymmetry-correction命令用来配置非对称延迟校正时间。
undo ptp asymmetry-correction命令用来恢复缺省情况。
ptp asymmetry-correction { minus | plus } value
接口的非对称延迟校正时间为0纳秒,即不进行校正。
三层以太网接口视图
minus:表示进行负的非对称延迟校正。
plus:表示进行正的非对称延迟校正。
value:表示非对称延迟的校正时间值,取值范围为0~2000000,单位为纳秒。
必须先配置PTP协议标准、时钟节点类型和PTP域后,才允许配置该命令。
# 在接口GigabitEthernet2/0/1上配置非对称延迟的校正时间100纳秒。
[Sysname-GigabitEthernet2/0/1] ptp asymmetry-correction plus 100
·     ptp domain
·     ptp mode
·     ptp profile
ptp global enable命令用来开启全局PTP功能。
undo ptp global enable命令用来关闭全局PTP功能。
ptp global enable
全局PTP功能处于开启状态。
只有全局PTP功能和接口下的PTP功能均处于开启状态,接口的PTP功能才能运行。
# 开启全局PTP功能。
[Sysname] ptp global enable
·     ptp enable
ptp max-steps-removed命令用来配置时间同步设备的最大跳数。
undo ptp max-steps-removed命令用来恢复缺省情况。
ptp max-steps-removed step-removed-value
时间同步设备的最大跳数为255。
step-removed-value:表示时间同步设备的最大跳数,取值范围为1~255。
工作机制
配置该命令后,从时钟源到时钟节点路径上的时钟节点个数不能超过该命令配置的值,超出的时钟节点将无法同步时钟。
配置准备
# 配置时间同步设备的最大跳数为20。
[Sysname] ptp max-steps-removed 20
·     ptp profile
·     ptp mode
ptp path-trace disable命令用来关闭PTP路径追踪功能。
undo ptp path-trace disable命令用来开启PTP路径追踪功能。
PTP路径追踪功能处于开启状态。
应用场景
路径追踪功能用来获取时钟信号从最优时钟到本设备所经过的时钟节点的信息。
配置准备
注意事项
只有路径上所有时钟节点均开启路径追踪功能,才能获取到完整的路径追踪信息。如果路径上有设备不支持路径追踪功能,请关闭该功能,以免引起PTP报文互通问题。
# 关闭PTP路径追踪功能。
[Sysname] ptp path-trace disable
·     display ptp path-trace
·     ptp mode
·     ptp profile
ptp time-offset命令用来配置PTP Offset异常的阈值和PTP时间同步的抑制次数。
undo ptp time-offset命令用来恢复缺省情况。
ptp time-offset { suppression-count suppression-count | suppression-threshold threshold-value } *
undo ptp time-offset { suppression-count | suppression-threshold } *
PTP Offset异常的阈值为300000纳秒,PTP时间同步的抑制次数为2次。
suppression-count suppression-count表示PTP时间同步的抑制次数,取值范围为4~80。
suppression-threshold threshold-value:表示判定PTP Offset异常的阈值,取值范围为50~1000000,单位为纳秒。
应用场景
本命令用于防时钟源跳变,通过该机制,设备能够有效应对时钟跳变,确保在时钟源稳定后恢复时间同步,避免因时钟突变导致的时间同步错误。
工作机制
PTP同步的基本原理如下:确认了时钟之间的主从关系之后,主、从时钟之间交互PTP协议报文并记录报文的收发时间,通过计算PTP协议报文往返的时间差来计算主、从时钟之间的往返总延时。如果两个方向的传输延时相同,则往返总延时的一半就是单向延时。从时钟根据这个单向延时、主时钟上Sync报文的发送时间和从时钟上接收Sync报文的时间差计算时间偏差Offset,从时钟按照该时间偏差来调整本地时间,就可以实现从时钟与主时钟的同步。
配置本命令后,若时钟处于稳定同步状态,但当前采样点的Offset值大于threshold-value,设备会判定时钟源发生了时钟跳变,并暂停本次PTP时间同步。设备将根据以下规则判断后续时钟信号是否需要同步:
·     正常同步条件:若下一个采样点Offset值小于或等于threshold-value,PTP将继续同步PTP时间。
·     暂停同步条件:若后续的Offset值仍大于threshold-value,PTP将不会同步PTP时间,直到抑制次数达到预设值。此时,设备认为主时钟已恢复稳定。当设备接收到下一个PTP时钟信号时,无论其Offset值是否超过threshold-value,均会进行同步。
示例说明:假设suppression-count=5、suppression-threshold=3,当Offset值≤3时,设备正常同步PTP时间;若时钟突变导致Offset值>3,设备将暂停同步该时钟信号(如图1-1中的P0~P5,Offset值大于3,设备不会进行时间同步)。设备最多暂停同步suppression-count个时钟信号,而在P6时刻,无论其Offset值是否超过threshold-value,设备均会进行同步。
图1-1 PTP防时钟跳变示意图
配置准备
必须先配置PTP协议标准、时钟节点和PTP域后,才允许配置该命令。
注意事项
多次执行本命令:
·     可以配置异常Offset阈值和抑制次数。
# 系统视图下配置PTP Offset异常的阈值为5000纳秒。
[Sysname] ptp time-offset suppression-threshold 5000
·     ptp domain
·     ptp mode
·     ptp profile
reset ptp statistics命令用来清除PTP的统计信息。
reset ptp statistics [ interface interface-type interface-number ]
interface interface-type interface-number:清除指定接口下的统计信息。interface-type interface-number表示接口类型和接口编号。未指定本参数时,表示清除所有接口下的PTP统计信息。
# 清除接口GigabitEthernet2/0/1上PTP的统计信息。
<Sysname> reset ptp statistics interface gigabitethernet 2/0/1
·     display ptp statistics
snmp-agent trap enable ptp命令用来开启PTP模块的告警功能。
undo snmp-agent trap enable ptp命令用来关闭PTP模块的告警功能。
PTP模块的告警功能处于开启状态。
应用场景
开启PTP模块的告警功能后,PTP模块会生成告警信息,用于报告该模块的重要事件。
工作机制
生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
# 开启PTP模块的告警功能。
[Sysname] snmp-agent trap enable ptp
·     display snmp-agent trap-list(网络管理和监控命令参考/SNMP
ptp active force-state命令用来配置强制状态生效。
undo ptp active force-state命令用来恢复缺省情况。
未配置强制状态生效。
应用场景
PTP接口角色修改之后需要使用本命令激活才能生效。
配置准备
# 配置强制状态生效。
[Sysname] ptp active force-state
·     ptp domain
·     ptp mode
·     ptp profile
·     ptp force-state
ptp alarm-threshold clock-source-class命令用来配置时钟源劣化日志输出参数。
undo ptp alarm-threshold clock-source-class命令用来恢复缺省情况。
ptp alarm-threshold clock-source-class class-value
时钟源劣化日志输出参数为6。
class-value:表示时钟源劣化日志输出参数的值,取值范围为0~255。
工作机制
PTP时钟源存在时钟等级属性,而ToD外接时钟源的时钟等级由ptp clock-source命令的class参数配置,class参数的数值越高时钟等级越低,表示时钟精度越低。若当前选用PTP时钟源的时钟等级数值超出或恢复到时钟源劣化日志输出参数值,则输出时钟源劣化日志信息提示。
配置准备
# 配置时间源劣化日志输出参数值为20。
[Sysname] ptp alarm-threshold clock-source-class 20
·     ptp clock-source
·     ptp domain
·     ptp mode
·     ptp profile
ptp alarm-threshold time-offset命令用来配置PTP源绝对时间差日志输出参数。
undo ptp alarm-threshold time-offset命令用来恢复缺省情况。
ptp alarm-threshold time-offset time-offset-value
PTP源绝对时间差日志输出参数为500ns。
time-offset-value:表示PTP源绝对时间差日志输出参数的值,取值范围为200~1000,单位为ns。
工作机制
若设备通过外接的Tod时钟源直接获取时钟信号,设备将定期计算外部时钟与PTP时钟的绝对时间差,计算周期由固定的定时器决定。当差值超过PTP源绝对时间差日志输出参数值时,则输出PTP源绝对时间差日志信息提示。
配置准备
# 配置PTP源绝对时间差日志输出参数值为800。
[Sysname] ptp alarm-threshold time-offset 800
·     ptp domain
·     ptp mode
·     ptp profile
ptp announce-interval命令用来配置Announce报文的发送周期。
undo ptp announce-interval命令用来恢复缺省情况。
ptp announce-interval interval
当PTP协议标准为IEEE 1588 version 2时,interval的值为1,Announce报文的发送周期为2(即21)秒。
三层以太网接口视图
interval:Announce报文的发送周期=2interval,单位为秒。当PTP协议标准为IEEE 1588 version 2时,interval的取值范围为0~4。
配置准备
# 在接口GigabitEthernet2/0/1上配置Announce报文的发送周期为4(即22)秒。
[Sysname-GigabitEthernet2/0/1] ptp announce-interval 2
·     ptp domain
·     ptp mode
·     ptp profile
ptp announce-timeout命令用来配置Announce报文的接收超时倍数。
undo ptp announce-timeout命令用来恢复缺省情况。
ptp announce-timeout multiple-value
Announce报文的接收超时倍数为10。
三层以太网接口视图
multiple-value:表示Announce报文的接收超时倍数,取值范围为2~10。
工作机制
主节点会周期性地发送Announce报文给从节点。如果从节点在报文的接收超时时间内未收到主节点发来的Announce报文,便认为该主节点失效。接收超时时间=接收超时倍数×主节点发送Announce报文的周期。
配置准备
推荐配置
为了保证PTP网络的稳定,请根据网络环境配置合理的值。一般情况下,建议将Announce报文的接收超时倍数配置为5~7。
# 在接口GigabitEthernet2/0/1上配置Announce报文的接收超时倍数为5。
[Sysname-GigabitEthernet2/0/1] ptp announce-timeout 5
·     ptp announce-interval
·     ptp domain
·     ptp mode
·     ptp profile
ptp clock-source命令用来配置时钟源的相关参数。
undo ptp clock-source命令用来将指定的参数恢复缺省情况。
配置本地时钟源参数:
ptp clock-source local { accuracy acc-value | class class-value | time-source ts-value }
undo ptp clock-source local { accuracy | class | time-source }
PTP协议标准为IEEE 1588 version 2时,本地时钟源的时间精度值和时间等级值与设备实际情况有关,时钟偏差度量值为65535,时钟属性值为160。其中时钟偏差度量值为固定不可配置。
accuracy acc-value:表示时钟的时间精度。acc-value为时间精度值,取值范围为0~255,数值越小精度越高,具体取值及其含义如表1-10所示。
表1-10 时间精度值及其含义
时间精度值(十六进制)
含义
00~1F
Reserved(保留)
20
时间精确到25纳秒(1纳秒=10-9秒)以内
21
时间精确到100纳秒以内
22
时间精确到250纳秒以内
23
时间精确到1微秒(1微秒=10-6秒)以内
24
时间精确到2.5微秒以内
25
时间精确到10微秒以内
26
时间精确到25微秒以内
27
时间精确到100微秒以内
28
时间精确到250微秒以内
29
时间精确到1毫秒(1毫秒=10-3秒)以内
2A
时间精确到2.5毫秒以内
2B
时间精确到10毫秒以内
2C
时间精确到25毫秒以内
2D
时间精确到100毫秒以内
2E
时间精确到250毫秒以内
2F
时间精确到1秒以内
30
时间精确到10秒以内
31
时间精确到大于10秒
32~7F
Reserved(保留)
80~FD
For use by alternate PTP profiles(为PTP协议标准预留)
FE
Unknown(未知)
FF
Reserved(保留)
class class-value:表示时钟的时间等级。class-value为时间等级值,取值范围为0~255,数值越小等级越高,具体取值及其含义如表1-11所示(未列出的取值均被协议所保留,不建议配置)。
表1-11 时间等级值及其含义
时间等级值(十进制)
含义
6
表示与主参考时间源保持同步的时钟节点,由PTP来分配时间。时间等级值为6的时钟节点不可成为该域中其他时钟的从时钟
7
表示先前时间等级值为6、但已无法与特定用途时间源保持同步的时钟节点,已进入续任模式且满足续任条件的时钟节点,由PTP来分配时间。时间等级值为7的时钟节点不可成为该域中其他时钟的从时钟
13
表示与特定用途的时间源保持同步的时钟节点,由ARB来分配时间。时间等级值为13的时钟节点不可成为该域中其他时钟的从时钟
14
表示先前时间等级值为13、但已无法与特定用途时间源保持同步的时钟节点,已进入续任模式且满足续任条件的时钟节点,由ARB来分配时间。时间等级值为14的时钟节点不可成为该域中其他时钟的从时钟
52
表示时间等级值为7的时钟节点由于不满足续任条件而降级为备选时钟A。时间等级值为52的时钟节点不可成为该域中其他时钟的从时钟
58
表示时间等级值为14的时钟节点由于不满足续任条件而降级为备选时钟A。时间等级值为58的时钟节点不可成为该域中其他时钟的从时钟
150
时钟的频率同步于一个频率精度是±1 ppm(百万分之一)的参考源,这个参考源先前同步于主参考时间源。时间由PTP来分配
158
时钟的频率同步于一个频率精度是±10 ppm(百万分之一)的参考源,这个参考源先前同步于主参考时间源。时间由PTP来分配
187
表示时间等级值为7的时钟节点由于不满足续任条件而降级为备选时钟B。时间等级值为187的时钟节点可成为该域中其他时钟的从时钟
193
表示时间等级值为14的时钟节点由于不满足续任条件而降级为备选时钟B。时间等级值为193的时钟节点可成为该域中其他时钟的从时钟
220
时钟的频率同步于一个频率精度是±1 ppm(百万分之一)的参考源,这个参考源先前同步于主参考时间源。时间由ARB来分配
228
时钟的频率同步于一个频率精度是±10 ppm(百万分之一)的参考源,这个参考源先前同步于主参考时间源。时间由ARB来分配
248
时间等级值的缺省取值
255
表示工作模式为Slave-only的时钟节点
time-source ts-value:表示时钟的属性。ts-value为属性值,取值范围为0~255,具体取值及其含义如表1-12所示(未列出的取值均被协议所保留)。
表1-12 属性值及其含义
属性值(十六进制)
含义
10
Atomic clock(原子时钟)
20
GPS(Global Positioning System,全球定位系统)
30
Terrestrial radio(陆基无线电)
40
PTP(Precision Time Protocol,精确时间协议)
50
NTP(Network Time Protocol,网络时间协议)
60
Handset(手持设备)
90
Other(其他)
A0
Internal oscillator(内部震荡器)
F0
表示一款主时钟,该时钟的时间源于一个周期性的同步信号,这个信号的时间是未定义、与真实时间无关的,时间由ARB来分配
F1
表示一款主时钟,该时钟的时间源于本地时间源,随后通过一个周期性的同步信号进行时间同步。该时钟的精度取决于同步信号的频率精度
F2~FE
FF
Reserved(保留)
配置准备
注意事项
多次执行本命令,可以指定不同的参数进行配置,如果重复配置同一参数,则最后一次配置生效。
# 系统视图下配置本地时钟源的时间精度值为44。
[Sysname] ptp clock-source local accuracy 44
·     ptp domain
·     ptp mode
·     ptp profile
ptp clock-state enable命令用来开启时钟状态功能。
undo ptp clock-state enable命令用来关闭时钟状态功能。
时钟状态功能处于关闭状态。
工作机制
开启PTP时钟状态功能后,PTP模块会将时钟运行过程划分为四种状态:自由运行状态、捕获状态、锁定状态、保持状态。使用这个状态机制,能增加PTP域时钟的稳定性。
·     自由运行状态:该状态下PTP时钟未与任何时间源同步。
·     捕获状态:该状态下PTP时钟处于与时间源同步的过程之中。
·     锁定状态:该状态下PTP时钟与某个时间源同步,并且误差在设备可接受的精度范围内。
·     保持状态:PTP时钟曾经和某个时间源同步,当前不再与任一时间源同步,但它仍然使用之前同步时获取到的时钟信息。
配置准备
必须先配置PTP协议标准和时钟节点,才允许配置该命令。
注意事项
本命令和ptp technical-standard命令互斥,配置了一个则不允许配置另一个。
# 开启时钟状态功能。
[Sysname] ptp clock-state enable
·     ptp domain
·     ptp mode
·     ptp profile
·     ptp technical-standard
ptp clock-step命令用来配置时间戳的携带模式。
undo ptp clock-step命令用来恢复缺省情况。
ptp clock-step one-step
undo ptp clock-step
时间戳的携带模式为单步模式。
三层以太网接口视图
one-step:表示时间戳的携带模式为单步模式。
# 在接口GigabitEthernet2/0/1上配置时间戳的携带模式为单步模式。
[Sysname-GigabitEthernet2/0/1] ptp clock-step one-step
·     ptp domain
·     ptp mode
·     ptp profile
ptp delay-mechanism命令用来配置BC或OC的延时测量机制。
undo ptp delay-mechanism命令用来恢复缺省情况。
ptp delay-mechanism e2e
当PTP协议标准为IEEE 1588 version 2时,缺省延时测量机制为请求应答机制。
三层以太网接口视图
e2e:表示请求应答机制。
配置准备
# 配置设备的时钟节点类型为BC,并在接口GigabitEthernet2/0/1上配置延时测量机制为请求应答机制。
[Sysname-GigabitEthernet2/0/1] ptp delay-mechanism e2e
·     ptp domain
·     ptp mode
·     ptp profile
ptp destination-mac命令用来配置非Pdelay报文的目的MAC地址。
undo ptp destination-mac命令用来恢复缺省情况。
ptp destination-mac mac-address
非Pdelay报文的目的MAC地址为011B-1900-0000。
三层以太网接口视图
mac-address:表示非Pdelay报文的目的MAC地址,取值为0180-C200-000E或011B-1900-0000。
工作机制
当PTP报文封装格式为IEEE 802.3/Ethernet,设备使用目的MAC地址和其他节点交互PTP报文。
配置准备
注意事项
该命令在PTP报文采用IEEE 802.3/Ethernet封装格式时才生效。
# 在接口GigabitEthernet2/0/1上配置非Pdelay报文的目的MAC地址为0180-C200-000E。
[Sysname-GigabitEthernet2/0/1] ptp destination-mac 0180-c200-000e
·     ptp domain
·     ptp mode
·     ptp profile
1.2.11  ptp domain
ptp domain命令用来配置设备所属的PTP域。
undo ptp domain命令用来恢复缺省情况。
ptp domain domain-number
undo ptp domain
不存在PTP域。
domain-number:表示设备加入的PTP域。当PTP协议标准为IEEE 1588 version 2时,domain-number的取值范围为0~255。
配置准备
必须先配置PTP协议标准、时钟节点类型后,才允许配置该命令。
注意事项
删除PTP域,将导致PTP不能工作,原PTP域相关的除PTP协议标准和时钟节点类型外的配置将全部删除。
# 配置设备所属的PTP域为30。
·     ptp mode
·     ptp profile
1.2.12  ptp enable
ptp enable命令用来开启接口的PTP功能。
undo ptp enable命令用来关闭接口的PTP功能。
ptp enable
undo ptp enable
接口的PTP功能处于关闭状态。
三层以太网接口视图
配置准备
推荐配置
建议在完成PTP相关参数配置后,再在接口上开启PTP功能。
注意事项
当设备时钟节点类型为OC时,只允许在一个接口上开启PTP功能。
# 配置设备的时钟节点类型为OC,并在接口GigabitEthernet2/0/1上开启PTP功能。
[Sysname] ptp mode oc
[Sysname-GigabitEthernet2/0/1] ptp enable
·     ptp domain
·     ptp mode
·     ptp profile
ptp force-state命令用来配置PTP接口角色。
undo ptp force-state命令用来恢复缺省情况。
ptp force-state { master | passive | slave }
PTP接口的角色由BMC算法自动生成。
三层以太网接口视图
master:表示PTP接口的角色为主接口。
passive:表示PTP接口的角色为被动接口。
slave:表示PTP接口的角色为从接口。
配置准备
推荐配置
建议使用BMC协议自动协商PTP接口角色。如果使用命令强制修改PTP接口的角色,则整个PTP域内的所有PTP接口均需手工使用ptp force-state命令配置角色,否则,会导致PTP域内未配置角色的接口PTP功能不生效,域内时钟不能同步。
注意事项
一台设备上最多只允许配置一个从接口。
PTP接口角色修改之后需要使用ptp active force-state激活才能生效。
# 配置设备的时钟节点类型为BC,并配置PTP接口GigabitEthernet2/0/1的角色为从接口。
[Sysname-GigabitEthernet2/0/1] ptp force-state slave
·     ptp domain
·     ptp mode
·     ptp profile
·     ptp slave-only
ptp ignore sync-uncertain命令用来忽略对synchronizationUncertain标记位的检测。
undo ptp ignore sync-uncertain命令用来开启对synchronizationUncertain标记位的检测。
设备对synchronizationUncertain标记位的检测功能处于开启状态。
应用场景
本命令用于设备对上游节点发送的PTP信息进行同步时,不检测PTP报文中携带的synchronizationUncertain标记,直接进行时间同步。
工作机制
缺省情况下,设备会对Announce报文中的synchronizationUncertain位进行检测:
·     synchronizationUncertain位取值为1表示非锁定。
·     synchronizationUncertain位取值为0表示锁定。
当检测到上游节点发送同步信息处于非锁定状态时,本设备不会使用该同步信息进行时间同步;当上游节点发送的同步信息处于锁定状态时,本设备才会使用该同步信息进行时间同步。
通常情况下,无需配置本命令。如果上游设备的时钟信号十分可靠,可以忽略对synchronizationUncertain标记位的检测,可配置本命令。配置本命令后,设备不检测同步信息是否处于锁定状态,直接进行时间同步。
注意事项
# 忽略对synchronizationUncertain标记位的检测。
[Sysname] ptp ignore sync-uncertain
·     ptp domain
·     ptp mode
·     ptp profile
ptp min-delayreq-interval命令用来配置Delay_Req报文的最小发送周期。
undo ptp min-delayreq-interval命令用来恢复缺省情况。
ptp min-delayreq-interval interval
当PTP协议标准为IEEE 1588 version 2时,interval的值为0,Delay_Req报文的最小发送周期为1(即20)秒。
三层以太网接口视图
interval:Delay_Req报文的最小发送周期=2interval,单位为秒。当PTP协议标准为IEEE 1588 version 2时,interval的取值范围为-4~6。
工作机制
当从时钟收到Sync报文时,会答复Delay_Req报文并启动Delay_Req报文发送定时器,定时器的值由本命令配置。定时器在超时前再次收到Sync报文不会答复Delay_Req报文,超时后收到Sync报文才会答复。
配置准备
注意事项
对于时钟节点间采用组播通信方式的网络,只有主时钟上配置的本命令生效,在从时钟上配置的不生效。主时钟通过PTP报文将该参数的值传递给从时钟,从而控制从时钟发送Delay_Req报文的周期。在从时钟上使用display ptp interface命令可以查看本命令的实际生效值。
对于时钟节点间采用单播通信方式的网络,本功能在从时钟本地配置生效,主时钟无法干预。
# 在接口GigabitEthernet2/0/1上配置Delay_Req报文的最小发送周期为4(即22)秒。
[Sysname-GigabitEthernet2/0/1] ptp min-delayreq-interval 2
·     ptp domain
·     ptp mode
·     ptp profile
·     ptp syn-interval
1.2.16  ptp mode
ptp mode命令用来配置设备的时钟节点类型。
undo ptp mode命令用来恢复缺省情况。
ptp mode { bc | oc }
undo ptp mode
未配置时钟节点类型。
bc:表示时钟节点类型为BC(Boundary Clock,边界时钟)。
oc:表示时钟节点类型为OC(Ordinary Clock,普通时钟)。
修改设备的时钟节点类型时,除PTP协议标准类型外,其他PTP配置将恢复到缺省情况。
配置准备
必须先配置PTP协议标准后,才允许配置该命令。
注意事项
·     每台设备只能配置一种时钟节点类型。
切换或删除时钟节点类型时,PTP除节点类型外的所有配置将恢复为当前协议标准的缺省配置。
# 配置设备的时钟节点类型为BC。
·     ptp profile
1.2.17  ptp priority
ptp priority clock-source命令用来配置时钟参与BMC算法的优先级参数。
undo ptp priority clock-source命令用来将指定的优先级恢复缺省情况。
ptp priority clock-source local { priority1 priority1 | priority2 priority2 }
undo ptp priority clock-source local { priority1 | priority2 }
当PTP协议标准为IEEE 1588 version 2时,时钟第一、二优先级均为128。
local:表示配置本地时钟的优先级参数。
priority1 priority1:表示时钟的第一优先级。priority1为第一优先级的值,取值范围为0~255,数值越小优先级越高。
priority2 priority2:表示时钟的第二优先级。priority2为第二优先级的值。当PTP协议标准为IEEE 1588 version 2时,取值范围为0~255,数值越小优先级越高。
工作机制
本地优先级不会随报文发送出去。
配置准备
# 配置本地时钟的第一优先级值为10。
[Sysname] ptp priority clock-source local priority1 10
·     ptp domain
·     ptp mode
·     ptp profile
ptp profile 1588v2命令用来配置设备采用的PTP协议标准为IEEE 1588 version 2。
undo ptp profile命令用来恢复缺省情况。
ptp profile 1588v2
undo ptp profile
未配置设备采用的PTP协议标准,PTP协议不运行。
配置准备
必须首先配置设备支持的PTP协议标准,否则不允许执行其他PTP配置命令。
注意事项
修改设备所用的PTP协议标准时,之前标准下的所有PTP配置将恢复到缺省情况。
# 配置设备采用的PTP协议标准为IEEE 1588 version 2。
ptp slave-only命令用来配置OC的工作模式为Slave-only,即OC只能作为从时钟。
undo ptp slave-only命令用来恢复缺省情况。
ptp slave-only
undo ptp slave-only
OC的工作模式不是Slave-only,即OC既可作为主时钟也可作为从时钟。
配置准备
只有当设备的时钟节点类型为OC,且配置了PTP协议标准、时钟节点类型和PTP域时,才允许配置该命令。
注意事项
当OC的工作模式为Slave-only时,也允许将其PTP接口强制配置为主接口或被动接口,通过ptp force-state命令进行生效配置。
# 配置设备的时钟节点类型为OC,并配置其工作模式为Slave-only。
[Sysname] ptp slave-only
·     ptp domain
·     ptp force-state
·     ptp mode
·     ptp profile
ptp sync-uncertain enable命令用来开启SyncUncertain功能。
undo ptp sync-uncertain enable命令用来关闭SyncUncertain功能。
SyncUncertain功能处于关闭状态。
应用场景
当设备需要将自己的非锁定状态通知下游设备时,请开启SyncUncertain功能。
工作机制
缺省情况下,设备只会将上游节点的锁定和非锁定状态传递给下游节点,不会将自己的锁定、非锁定状态传递给下游节点。
开启本功能后,设备会通过Announce报文中的synchronizationUncertain位,将自己的锁定和非锁定状态通告给下游节点。当下游节点收到非锁定的同步信息时,不与设备进行时间同步;当下游节点收到锁定的同步信息时,才与设备进行时间同步。
配置准备
# 在系统视图下开启SyncUncertain功能。
[Sysname] ptp sync-uncertain enable
·     ptp domain
·     ptp mode
·     ptp profile
ptp syn-interval命令用来配置Sync报文的发送周期。
undo ptp syn-interval命令用来恢复缺省情况。
ptp syn-interval interval
当PTP协议标准为IEEE 1588 version 2时,interval的值为0,Sync报文的发送周期为1(即20)秒。
三层以太网接口视图
interval:Sync报文的发送周期=2interval,单位为秒。当PTP协议标准为IEEE 1588 version 2时,interval的取值范围为-3~1。
# 在接口GigabitEthernet2/0/1上配置Sync报文的发送周期为2(即21)秒。
[Sysname-GigabitEthernet2/0/1] ptp syn-interval 1
·     ptp domain
·     ptp mode
·     ptp profile
ptp technical-standard命令用来配置PTP技术标准。
undo ptp technical-standard命令用来恢复缺省情况。
ptp technical-standard cmcc
使用缺省PTP技术标准。
cmcc:表示中国移动技术标准。
注意事项
本命令和ptp clock-state enable命令互斥,配置了一个则不允许配置另一个。
# 配置PTP技术标准为cmcc。
[Sysname] ptp technical-standard unicom
Parameters of Clock Attribute will be restored to the default values. Continue? [Y/N]:y
·     ptp clock-source
·     ptp clock-state enable
·     ptp mode
·     ptp profile
未配置强制状态生效。
应用场景
配置准备
注意事项
当时钟节点类型为T-TSC时,不允许配置该命令。
# 配置强制状态生效。
[Sysname] ptp profile g8275.1
[Sysname] ptp mode t-bc
·     ptp domain
·     ptp mode
·     ptp profile
·     ptp force-state
时钟源劣化日志输出参数为6。
工作机制
配置准备
·     ptp clock-source
·     ptp domain
·     ptp mode
·     ptp profile
工作机制
配置准备
# 配置PTP源绝对时间差日志输出参数值为800ns。
·     ptp domain
·     ptp mode
·     ptp profile
当PTP协议标准为ITU-T G.8275.1时,interval的值为-3,Announce报文的发送周期为1/8(即2-3)秒。
三层以太网接口视图
interval:Announce报文的发送周期=2interval,单位为秒。当PTP协议标准为ITU-T G.8275.1时,interval的取值范围为-3~6。
# 在接口GigabitEthernet2/0/1上配置Announce报文的发送周期为1(即20)秒。
[Sysname-GigabitEthernet2/0/1] ptp announce-interval 0
·     ptp domain
·     ptp mode
·     ptp profile
三层以太网接口视图
工作机制
配置准备
推荐配置
·     ptp domain
·     ptp mode
·     ptp profile
配置本地时钟源参数:
PTP协议标准为ITU-T G.8275.1且时钟节点类型为T-BC:
·     使用缺省PTP技术标准时,本地时钟源的时间精度值和时间等级值与设备实际情况有关,时钟偏差度量值为65535,时钟属性值为160。其中时钟偏差度量值为固定不可配置。
·     配置PTP OAM技术标准时,本地时钟源的时间精度值为254,时间等级值为165,时钟偏差度量值为65535,时钟属性值为160。其中时钟偏差度量值为固定不可配置。
·     配置PTP Unicom技术标准时,本地时钟源的时间精度值为254,时间等级值为248,时钟偏差度量值为65535,时钟属性值为160。其中时钟偏差度量值为固定不可配置。
accuracy acc-value:表示时钟的时间精度。acc-value为时间精度值,取值范围为0~255,数值越小精度越高,具体取值及其含义如表1-13所示。
表1-13 时间精度值及其含义
时间精度值(十六进制)
含义
00~1F
Reserved(保留)
20
21
时间精确到100纳秒以内
22
时间精确到250纳秒以内
23
24
时间精确到2.5微秒以内
25
时间精确到10微秒以内
26
时间精确到25微秒以内
27
时间精确到100微秒以内
28
时间精确到250微秒以内
29
2A
时间精确到2.5毫秒以内
2B
时间精确到10毫秒以内
2C
时间精确到25毫秒以内
2D
时间精确到100毫秒以内
2E
时间精确到250毫秒以内
2F
时间精确到1秒以内
30
时间精确到10秒以内
31
时间精确到大于10秒
32~7F
Reserved(保留)
80~FD
FE
Unknown(未知)
FF
Reserved(保留)
class class-value:表示时钟的时间等级。class-value为时间等级值,取值范围为0~255,数值越小等级越高,具体取值及其含义如表1-14所示(未列出的取值均被协议所保留,不建议配置)。
表1-14 时间等级值及其含义
时间等级值(十进制)
含义
6
7
13
14
52
58
150
158
187
193
220
228
248
时间等级值的缺省取值
255
time-source ts-value:表示时钟的属性。ts-value为属性值,取值范围为0~255,具体取值及其含义如表1-15所示(未列出的取值均被协议所保留)。
表1-15 属性值及其含义
属性值(十六进制)
含义
10
Atomic clock(原子时钟)
20
30
40
50
60
Handset(手持设备)
90
Other(其他)
A0
F0
F1
F2~FE
FF
Reserved(保留)
配置准备
注意事项
多次执行本命令,可以指定不同的参数进行配置。如果重复配置同一参数,则最后一次配置生效。
·     ptp domain
·     ptp mode
·     ptp profile
时钟状态功能处于关闭状态。
工作机制
配置准备
注意事项
# 开启时钟状态功能。
·     ptp domain
·     ptp mode
·     ptp profile
undo ptp clock-step
时间戳的携带模式为单步模式。
三层以太网接口视图
·     ptp domain
·     ptp mode
·     ptp profile
三层以太网接口视图
工作机制
配置准备
注意事项
·     ptp domain
·     ptp mode
·     ptp profile
1.3.10  ptp domain
undo ptp domain
不存在PTP域。
domain-number:表示设备加入的PTP域。当PTP协议标准为ITU-T G.8275.1时,domain-number的取值范围为24~43。
配置准备
注意事项
# 配置设备所属的PTP域为30。
·     ptp mode
·     ptp profile
1.3.11  ptp enable
ptp enable
undo ptp enable
接口的PTP功能处于关闭状态。
三层以太网接口视图
配置准备
推荐配置
注意事项
当设备时钟节点类型为T-TSC时,只允许在一个接口上开启PTP功能。
# 配置设备的时钟节点类型为T-BC,并在接口GigabitEthernet2/0/1上开启PTP功能。
·     ptp domain
·     ptp mode
·     ptp profile
PTP接口的角色由BMC算法自动生成。
三层以太网接口视图
配置准备
推荐配置
注意事项
一台设备上最多只允许配置一个从接口。
当节点类型为T-TSC时,不允许配置该命令。
# 配置设备的时钟节点类型为T-BC,并配置PTP接口GigabitEthernet2/0/1的角色为从接口。
·     ptp domain
·     ptp mode
·     ptp profile
应用场景
工作机制
注意事项
·     ptp domain
·     ptp mode
·     ptp profile
ptp local-priority命令用来配置对端节点的优先级参数。
undo ptp local-priority 命令用来恢复缺省情况。
ptp local-priority local-priority
对端节点的优先级参数值为128。
三层以太网接口视图
local-priority:表示指定对端节点的优先级参数,取值范围为1~255,数值越小优先级越高。
工作机制
时钟节点上开启PTP协议的每个接口都会有一个优先级。该优先级是作为对端节点的一个优先级,参与BMC算法。可以通过配置该参数来影响对端节点能否成为最优时钟。
对端节点的本地时钟优先级参数不能通过Announce报文传递,所以在本节点和对端节点相连的PTP接口下配置优先级代替对端节点的时钟优先级。
配置准备
# 在接口GigabitEthernet2/0/1上配置接口的本地优先级为10。
[Sysname-GigabitEthernet2/0/1] ptp local-priority 10
·     ptp profile
·     ptp mode
当PTP协议标准为ITU-T G.8275.1时,interval的值为-4,Delay_Req报文的最小发送周期为1/16(即2-4)秒。
三层以太网接口视图
interval:Delay_Req报文的最小发送周期=2interval,单位为秒。当PTP协议标准为ITU-T G.8275.1时,interval的取值范围为-4~6。
工作机制
配置准备
注意事项
·     ptp domain
·     ptp mode
·     ptp profile
·     ptp syn-interval
1.3.16  ptp mode
ptp mode { t-bc | t-tsc }
undo ptp mode
未配置时钟节点类型。
t-bc:表示时钟节点类型为T-BC(Telecom Boundary Clock,电信边界时钟)。
t-tsc:表示时钟节点类型为T-TSC(Telecom Time Slave Clock,电信时间从时钟)。
配置准备
注意事项
·     每台设备只能配置一种时钟节点类型。
# 配置设备的时钟节点类型为T-BC。
·     ptp profile
ptp notslave disable命令用来配置PTP接口的NotSlave属性为关闭状态。
undo ptp notslave disable命令用来恢复缺省情况。
PTP接口的NotSlave属性为开启状态。
三层以太网接口视图
应用场景
使用该功能可以在PTP域内灵活控制主从节点的改变。
工作机制
PTP接口的NotSlave属性是指时钟节点的接口自动选举自身所在节点为主节点的属性。
当接口的NotSlave属性为开启状态时,该接口则自动选举自身所在节点为主节点,并向外发送PTP时钟同步消息。
在同一个PTP域内,需要关闭所有接口的NotSlave属性才能进行PTP域的主从节点选举。
配置准备
注意事项
对于ITU-T G.8275.1协议,仅T-BC时钟节点支持本命令。
T-BC上端口有master-only属性,若想做从端口,需要配置ptp notslave disable命令。
# 在接口GigabitEthernet2/0/1上配置接口的NotSlave属性为关闭状态。
[Sysname-GigabitEthernet2/0/1] ptp notslave disable
·     ptp profile
·     ptp mode
1.3.18  ptp priority
ptp priority clock-source local { local-priority local-priority | priority2 priority2 }
undo ptp priority clock-source local { local-priority | priority2 }
当PTP协议标准为ITU-T G.8275.1时,时钟第一优先级为128,T-BC类型节点时钟第二优先级为128,T-TSC类型节点时钟第二优先级为255,时钟本地优先级为128。
local-priority local-priority:表示时钟的本地优先级。local-priority:表示本地优先级的值,取值范围为1~255,数值越小优先级越高。
priority2 priority2:表示时钟的第二优先级。priority2为第二优先级的值。当PTP协议标准为ITU-T G.8275.1时,T-BC类型节点取值范围为0~255,数值越小优先级越高,T-TSC类型节点取值为255,不可配置。ITU-T G.8275.1第一优先级的值为128,不可配置。
工作机制
本地优先级不会随报文发送出去。
配置准备
# 配置本地时钟的第二优先级值为10。
[Sysname] ptp priority clock-source local priority2 10
·     ptp domain
·     ptp mode
·     ptp profile
ptp profile g8275.1命令用来配置设备采用的PTP协议标准为ITU-T G.8275.1。
ptp profile g8275.1
undo ptp profile
配置准备
注意事项
# 配置设备采用的PTP协议标准为ITU-T G.8275.1。
应用场景
工作机制
配置准备
·     ptp domain
·     ptp mode
·     ptp profile
当PTP协议标准为ITU-T G.8275.1时,interval的值为-4,Sync报文的发送周期为1/16(即2-4)秒。
三层以太网接口视图
interval:Sync报文的发送周期=2interval,单位为秒,当PTP协议标准为ITU-T G.8275.1时,interval的取值范围为-4~6。
·     ptp domain
·     ptp mode
·     ptp profile
ptp technical-standard { oam | unicom }
使用缺省PTP技术标准。
oam:表示OAM技术标准。
unicom:表示Unicom技术标准。
工作机制
OAM技术标准和Unicom技术标准的时钟源相关参数accuracyclasstime-sourceoffsetscaled-logvariance缺省值不同。
配置准备
注意事项
不同PTP技术标准的时钟源相关参数accuracyclasstime-sourceoffsetscaled-logvariance缺省值不同。
# 配置PTP技术标准为Unicom。
·     ptp clock-source
·     ptp mode
·     ptp profile
