12-WLAN高级功能命令参考
01-WLAN网络调优命令
本章节下载: 01-WLAN网络调优命令  (462.51 KB)
01-WLAN网络调优命令
1 WLAN网络调优
1.1 WLAN网络调优配置命令
1.1.1 option 4-way-handshake resend
1.1.2 option 4-way-handshake retry
1.1.3 option broadcast-multicast-buffer
1.1.4 option capacity-adjust
1.1.5 option channel-reuse-optimization
1.1.6 option channel-share
1.1.7 option client fast-forwarding
1.1.8 option client hide-node-protection
1.1.9 option client reconnect
1.1.10 option client reject
1.1.11 option directional-antenna-selection
1.1.12 option dot11n-restraint
1.1.13 option immediate-transmit
1.1.14 option keep-active
1.1.15 option max-interfer-threshold
1.1.16 option non-local-packet rate-limit cir
1.1.17 option optimize-link-performance
1.1.18 option power-supply
1.1.19 option probe-response-try
1.1.20 option rate-algorithm emr
1.1.21 option roam-navigation
1.1.22 option rx-broadcast-all
1.1.23 option rx-opportunity-optimize
1.1.24 option signal-ignore
1.1.25 option smart-chip-protection
1.1.26 option subway-band-width
1.1.27 option tpc
1.1.28 option x-share quiet
1.1.29 rrop anti-bmc default-action
1.1.30 rrop anti-bmc network
1.1.31 rrop anti-bmc protocol arp mode
1.1.32 rrop anti-bmc protocol ipv6
1.1.33 rrop anti-bmc protocol nd mode
1.1.34 rrop anti-bmc rate-limit
1.1.35 rrop anti-bmc rate-limit pps
1.1.36 rrop anti-bmc upstream client-rate-limit
1.1.37 rrop anti-bmc upstream client-rate-limit pps
1.1.38 rrop arp ap-proxy-gateway
1.1.39 rrop client fast-keep-alive
1.1.40 rrop flow-schedule mode
1.1.41 rrop software-retry
1.1.42 rrop traffic-policy priority tcp
1.1.43 rrop traffic-policy priority udp
1.1.44 rrop ul-arp attack-suppression
1.1.45 rrop ul-bpdu forward enable
1.1.46 sacp roam-optimize traffic-hold enable
1.1.47 sacp application forwarding-acceleration enable
1.1.48 scap application optimization enable oppo
1.1.49 wlan client inspect
1 WLAN网络调优
1.1  WLAN网络调优配置命令
option 4-way-handshake resend命令用来配置设备发送EAPOL-Key报文的最大重传次数和重传时间间隔。
undo option 4-way-handshake resend命令用来恢复缺省情况。
option 4-way-handshake resend max-count [ interval interval ]
设备发送EAPOL-Key报文的最大重传次数为3次,重传时间间隔为300毫秒。
无线服务模板视图
resend max-count:表示设备发送EAPOL-Key报文的最大重传次数,取值范围为0~3。
interval interval:表示设备发送EAPOL-Key报文的重传时间间隔,取值范围为200~500,单位为毫秒。
在RSNA安全机制密钥协商过程中,设备和用户会通过4个EAPOL-Key报文的两轮交互,完成一次协商,最终协商出密钥。
当用户网络状况较差的情况下,设备可能无法接收到用户回应的EAPOL-Key报文,导致密钥协商失败,用户无法上线。可以通过本命令适当改变EAPOL-Key报文的最大重传次数及重传时间间隔,增加密钥协商成功的概率。
密钥协商的重传机制如下,设备首先会根据配置的最大重传次数进行第一轮的密钥协商:
·     若协商成功,则根据配置的最大重传次数继续进行第二轮的协商:
¡     若协商成功,则用户上线。
¡     若协商失败,则根据配置的最大重试次数继续进行第二轮的密钥协商,如果协商成功,则用户上线,否则,用户下线。
·     若协商失败,则根据配置的最大重试次数继续进行第一轮的密钥协商:
¡     若协商成功,则根据配置的最大重传次数继续进行第二轮的协商。
¡     若协商失败,用户下线。
# 在无线服务模板下,配置设备发送EAPOL-Key报文的最大重传次数为1次,重传时间间隔为400毫秒。
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] option 4-way-handshake resend 1 interval 400
·     option 4-way-handshake retry
option 4-way-handshake retry命令用来配置设备发送EAPOL-Key报文的最大重试次数和重试时间间隔。
undo option 4-way-handshake retry命令用来恢复缺省情况。
option 4-way-handshake retry max-count [ interval interval ]
设备发送EAPOL-Key报文的最大重试次数为3,重试时间间隔为5秒。
无线服务模板视图
retry max-count:表示设备发送EAPOL-Key报文的最大重试次数,取值范围为0~3。
interval interval:表示设备发送EAPOL-Key报文的重试时间间隔,取值范围为2~5,单位为秒。
在RSNA安全机制密钥协商过程中,设备和用户会通过EAPOL-Key报文进行四次握手协商出密钥。如果设备发送EAPOL-Key报文后,没有收到用户回复的EAPOL-Key报文,会按照最大重传次数重传报文,直到重传次数达到最大重传次数后,如果仍然没有收到用户回复的EAPOL-Key报文,则按EAPOL-Key报文最大重试次数重传EAPOL-Key报文。
每次重试发送,都会按重传机制下的密钥协商过程发送EAPOL-Key报文。如果达到最大重试次数后,仍然没有收到用户回复的EAPOL-Key报文,用户下线。
多次执行本命令,最后一次执行的命令生效。
# 在无线服务模板下,配置设备发送EAPOL-Key报文的最大重试次数为2次,重试时间间隔为3秒。
[Sysname-wlan-st-service1] option 4-way-handshake retry 2 interval 3
·     option 4-way-handshake resend
option broadcast-multicast-buffer enable命令用来开启组播/广播报文缓存功能。
option broadcast-multicast-buffer disable命令用来关闭组播/广播报文缓存功能。
undo option broadcast-multicast-buffer命令用来恢复缺省情况。
option broadcast-multicast-buffer { disable | enable [ limit limit ] }
Radio视图下,继承AP组配置。
AP组Radio视图下,组播/广播报文缓存功能处于开启状态。
Radio视图
AP组Radio视图
limit limit:配置缓存组播/广播报文的个数,取值范围为1~600,缺省值为100。
组播/广播报文缓存功能开启后,当AP检测到WLAN网络中有与之关联的无线客户端处于休眠状态时,则会先将待发送组播或广播报文缓存下来,在一定时间之后再将这些缓存的广播和组播报文发送出去。
对于实时的组播业务,将组播报文缓存会导致整个网络的组播报文经历先被缓存,再发送的过程,对其它处于非休眠状态的无线客户端产生影响。
关闭组播/广播报文缓存功能后,AP发送的所有组播、广播报文将不再受休眠中的无线客户端的影响,实现了组播和广播报文的快速及时发送。
# 关闭组播/广播报文缓存功能。(Radio视图)
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] option broadcast-multicast-buffer disable
# 关闭组播/广播报文缓存功能。(AP组Radio视图)
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] ap-model WA6320
[Sysname-wlan-ap-group-1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option broadcast-multicast-buffer disable
option capacity-adjust enable命令用来开启功率补偿功能。
option capacity-adjust disable命令用来关闭功率补偿功能。
undo option capacity-adjust命令用来恢复缺省情况。
option capacity-adjust { disable | enable [ all ] { increase | decrease } value }
Radio视图下,继承AP组配置。
AP组Radio视图下,功率补偿功能处于关闭状态。
Radio视图
AP组Radio视图
all:配置所有速率的发送功率,如果不指定该参数则配置基本速率的发送功率。
increase:提高指定速率的发送功率。
decrease:降低指定速率的发送功率。
value:配置指定速率发送功率提高或降低的值,取值范围为1~27,单位为dBm。
配置功率补偿功能后,射频芯片忽略校准信息设置的最大功率值,使用调整之后的功率值发送报文。
# 开启功率补偿功能,配置所有速率的发送功率提高1dBm。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option capacity-adjust all increase 1
# 开启功率补偿功能,配置所有速率的发送功率提高1dBm。(AP组Radio视图)
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA6320
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option capacity-adjust all increase 1
option channel-reuse-optimization enable命令用来开启AP间信道重用提升功能。
option channel-reuse-optimization disable命令用来关闭AP间信道重用提升功能。
undo option channel-reuse-optimization命令用来恢复缺省情况。
option channel-reuse-optimization { disable | enable level level }
Radio视图下,继承AP组配置。
AP组Radio视图下,AP间信道重用提升功能处于关闭状态。
Radio视图
AP组Radio视图
level level:AP间信道重用能力级别,取值范围为1~10,建议值为6。
调整AP间信道重用提升功能主要是调整AP设备感知到的环境噪声,即通过设置的信道重用能力级别,对AP接收报文的信号强度和发送报文时的信道空闲检测进行判断,最终忽略掉信号强度低于信道重用能力级别的所有报文的影响,确保AP能够有更多机会获得射频资源,提高AP的发送能力。在多AP密集部署的环境中,可以提高同信道AP的整体性能。
# 开启AP间信道重用提升功能,并配置能力级别为5。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option channel-reuse-optimization enable level 5
# 开启AP间信道重用提升功能,并配置能力级别为5。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option channel-reuse-optimization enable level 5
option channel-share enable命令用来开启调整AP间信道共享功能。
option channel-share disable命令用来关闭调整AP间信道共享功能。
undo channel-share命令用来恢复缺省情况。
option channel-share { disable | enable power-level power-level }
undo channel-share
Radio视图下,继承AP组配置。
AP组Radio视图下,调整AP间信道共享功能处于关闭状态。
Radio视图
AP组Radio视图
power-level power-level:AP可以感知的射频信号的功率级别,取值范围为1~40,建议配置为30。
当AP发送报文的时候,会检测信道内的射频信号,判断信道是否被占用,如果检测到的射频信号的功率级别低于AP可以感知的射频信号的功率级别,AP认为信道处于空闲状态,并会继续发送报文;否则AP会认为信道已经被其他设备占用,会暂停发送报文,继续等待机会重新获取信道。这就增大了信道重叠范围,降低了AP在信道空间存在数据时发送报文的机会,避免信道冲突和干扰。
# 开启调整AP间信道共享功能,并设置可以感知的无线报文的功率级别为30。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option channel-share enable power-level 30
# 开启调整AP间信道共享功能,并设置可以感知的无线报文的功率级别为30。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option channel-share enable power-level 30
option client fast-forwarding enable 命令用来开启客户端数据快速转发功能。
option client fast-forwarding disable命令用来关闭客户端数据快速转发功能。
undo option client fast-forwarding命令用来恢复缺省情况。
option client fast-forwarding { disable | enable level level-value }
Radio视图下,继承AP组配置。
AP组Radio视图下,客户端数据快速转发功能处于关闭状态。
Radio视图
AP组Radio视图
level level-value:客户端数据快速转发级别,取值范围为1~4。
开启本功能后,AP向无线客户端发送数据报文时,不会进行额外的业务处理(比如校验、统计),直接进行转发,以提高处理性能。
配置本功能后,若配置level发生改变,AP会重启并生效配置。
# 开启客户端数据快速转发功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option client fast-forwarding enable level 1
# 开启客户端数据快速转发功能。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option client fast-forwarding enable level 1
option client hide-node-protection enable命令用来开启隐藏节点保护功能。
option client hide-node-protection disable命令用来关闭隐藏节点保护功能。
undo option client hide-node-protection命令用来恢复缺省情况。
option client hide-node-protection { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,隐藏节点保护功能处于关闭状态。
Radio视图
AP组Radio视图
本功能只对工作在802.11g、802.11n与802.11ac频段的无线客户端生效。
开启本功能后,AP将通知无线客户端在发送报文前使用RTS帧或者CTS帧清空传输区域,规避来自隐藏节点的干扰。
# 开启隐藏节点保护功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option client hide-node-protection enable
# 开启隐藏节点保护功能。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option client hide-node-protection enable
option client reconnect enable命令用来开启主动触发客户端重连接功能。
option client reconnect disable命令用来关闭主动触发客户端重连接功能。
undo option client reconnect命令用来恢复缺省情况。
option client reconnect { disable | enable [ rssi rssi-value ] [ interval interval ] }
Radio视图下,继承AP组配置。
AP组Radio视图下,主动触发客户端重连接功能处于关闭状态。
Radio视图
AP组Radio视图
rssi rssi-value:无线客户端信号强度门限值,取值范围为5~100,缺省值为10,建议值为20。
interval interval:探测无线客户端信号强度的时间间隔,取值范围为3~10,单位为秒,缺省值为3。
开启本功能后,当无线客户端信号强度持续变弱且低于门限值时,AP会主动地向无线客户端发送解除认证帧报文,给无线客户端一次重新连接或者漫游的机会。
# 开启主动触发客户端重连接功能,配置接入信号强度门限值为30,探测客户端信号强度时间间隔为5秒。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option client reconnect enable rssi 30 interval 5
# 开启主动触发客户端重连接功能,配置接入信号强度门限值为30,探测客户端信号强度时间间隔为5秒。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option client reconnect enable rssi 30 interval 5
option client reject enable命令用来开启禁止弱信号客户端接入功能。
option client reject disable命令用来关闭禁止弱信号客户端接入功能。
undo option client reject命令用来恢复缺省情况。
option client reject { disable | enable [ rssi rssi-value ] }
Radio视图下,继承AP组配置。
AP组Radio视图下,禁止弱信号客户端接入功能处于关闭状态。
Radio视图
AP组Radio视图
rssi rssi-value:无线客户端信号强度门限值,取值范围为5~100,缺省值为10,建议值为10。
开启本功能后,当无线客户端信号强度低于门限值时,AP将拒绝此类客户端接入。拒绝信号比较低的无线客户端接入到WLAN网络中,既可以避免低信号客户端占用较多的信道资源,同时可以减少对其他客户端的影响,提升整个WLAN网络的应用效果。
如果无线客户端在接入WLAN网络后信号强度变弱直到低于信号强度门限值时,AP不会主动让该无线客户端下线,但如果客户端的无线连接断开再重新请求接入,则AP将拒绝此类客户端接入。
# 开启禁止弱信号客户端接入功能,并配置信号强度门限值为30。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option client reject enable rssi 30
# 开启禁止弱信号客户端接入功能,并配置信号强度门限值为30。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option client reject enable rssi 30
option directional-antenna-selection enable命令用来开启定向天线动态选择功能。
option directional-antenna-selection disable命令用来关闭定向天线动态选择功能。
undo option directional-antenna-selection命令用来恢复缺省情况。
option directional-antenna-selection { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,定向天线动态选择功能处于关闭状态。
Radio视图
AP组Radio视图
开启本功能后,AP会根据室外CPE设备传输信号的方式以及信号强度,动态去调整AP自身的信号发送方式,以此提升客户端能够感知的信号强度,改善用户体验。
# 开启定向天线动态选择功能。(Radio视图)
[Sysname] wlan ap ap1 model WA2620X
[Sysname-wlan-ap-ap1-radio-1] option directional-antenna-selection enable
# 开启定向天线动态选择功能。(AP组Radio视图)
[Sysname-wlan-ap-group-1] ap-model WA2620X
[Sysname-wlan-ap-group-1-ap-model-WA2620X] radio 1
[Sysname-wlan-ap-group-1-ap-model-WA2620X-radio-1] option directional-antenna-selection enable
option dot11n-restraint enable命令用来开启802.11n报文发送抑制功能。
option dot11n-restraint disable命令用来关闭802.11n报文发送抑制功能。
undo option dot11n-restraint命令用来恢复缺省情况。
option dot11n-restraint { disable | enable packet-number packet-number packet-length packet-length } [ inbound | outbound ] [ tid tid-number ]
Radio视图下,继承AP组配置。
AP组Radio视图下,802.11n报文发送抑制功能处于关闭状态。
Radio视图
AP组Radio视图
packet-number packet-number:可以聚合的最大报文个数,取值范围为1~64,建议配置为8。
packet-length packet-length:聚合后报文的最大长度,取值范围为2000~380000,单位为字节,建议配置为6000。
inbound:表示在入方向配置802.11n报文发送抑制功能。
outbound:表示在出方向配置802.11n报文发送抑制功能。
tid tid-number:WMM定义了四种接入类型,相应的有各自的优先级队列,tid表示对指定优先级的报文配置802.11n报文发送抑制功能,取值范围为0~7,0和3表示AC-BE(尽力而为队列),1和2表示AC-BK(背景队列),4和5表示AC-VI(视频队列),6和7表示AC-VO(语音队列)。未配置本参数表示对所有接入类型的报文配置802.11n报文发送抑制功能。
802.11n报文发送抑制功能在AP发送报文时,对802.11n客户端的A-MPDU聚合过程进行控制,通过配置可以聚合的报文个数不超过配置的“最大报文个数”,聚合后的报文总长度不超过配置的“最大报文长度”来达到抑制802.11n报文发送的目的。
# 开启802.11n报文发送抑制功能,配置最大报文个数30个,最大报文长度10000字节。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option dot11n-restraint enable packet-number 30 packet-length 10000
# 开启802.11n报文发送抑制功能,配置最大报文个数30个,最大报文长度10000字节。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option dot11n-restraint enable packet-number 30 packet-length 10000
option immediate-transmit enable命令用来开启报文即刻发送功能。
option immediate-transmit disable命令用来关闭报文即刻发送功能。
undo option immediate-transmit命令用来恢复缺省情况。
option immediate-transmit { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,报文即刻发送功能处于关闭状态。
Radio视图
AP组Radio视图
开启该功能后,AP在发送报文前将不再进行信道冲突检测,节省了网络开销,达到了提升网络吞吐量的作用,但是可能会导致隐藏节点问题。关闭该功能后,无线设备之间通过RTS/CTS报文的交互进行快速的信道冲突检测,避免了无线设备之间的通信冲突。
# 关闭报文即刻发送功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option immediate-transmit disable
# 关闭报文即刻发送功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option immediate-transmit disable
option keep-active enable命令用来开启缩短客户端休眠时间功能。
option keep-active disable命令用来关闭缩短客户端休眠时间功能。
undo option keep-active命令用来恢复缺省情况。
option keep-active { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,缩短客户端休眠时间功能处于关闭状态。
Radio视图
AP组Radio视图
当无线客户端进入休眠状态后,通过定时监听Beacon帧中的TIM(Traffic Indication Map,数据待传指示信息)来判断AP是否为其缓存了报文,如果AP为其缓存了报文则终止休眠状态,与AP进行数据通信,开启缩短客户端休眠时间功能后,AP通过修改Beacon帧中的TIM,缩短了客户端的休眠时间,从而提高了传输效率。
# 开启缩短客户端休眠时间功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option keep-active enable
# 开启缩短客户端休眠时间功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model- WA6320-radio-1] option keep-active enable
option max-interfer-threshold enable命令用来配置最大干扰门限。
option max-interfer-threshold disable命令用来取消配置的最大干扰门限。
undo max-interfer-threshold命令用来恢复缺省情况。
option max-interfer-threshold { disable | enable value }
Radio视图下,继承AP组配置。
AP组Radio视图下,未配置最大干扰门限。
Radio视图
AP组Radio视图
value:最大干扰门限的功率值,取值范围为20~120,单位为dBm,缺省值为50。
该功能可以用来调节AP对同信道非WLAN干扰信号的敏感度,以应对一些特殊的应用场景。
# 配置最大干扰门限的功率值30。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option max-interfer-threshold enable 30
# 配置最大干扰门限的功率值30。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option max-interfer-threshold enable 30
option non-local-packet rate-limit cir命令用来配置非本机BSSID报文的限制速率。
undo option non-local-packet rate-limit cir命令用来恢复默认缺省情况。
option non-local-packet rate-limit cir cir
cir取值为0,不限制非本机BSSID报文的速率。
Radio视图
cir cir:非本机BSSID报文的承诺信息速率,取值范围为1~1300000,单位为Kbps。
当AP开启扫描业务(例如无线探针、WLAN定位、WIPS)后,Radio接口可能会收到很多非本机BSSID的报文,导致设备无法及时处理本机BSSID的业务报文、CPU占用率过高。
可以通过本配置,限制非本机BSSID报文的接收速率,保证本机BSSID报文的处理速率。
# 配置非本机BSSID报文的承诺速率为8Kbps。
[Sysname-wlan-ap-ap1-radio-1] option non-local-packet rate-limit cir 8000
option optimize-link-performance { inbound | outbound } enable命令用来开启优化通信链路性能功能。
option optimize-link-performance { inbound | outbound } disable命令用来关闭优化通信链路性能功能。
undo optimize-link-performance命令用来恢复缺省情况。
option optimize-link-performance { inbound | outbound } { disable | enable } [ value ]
undo optimize-link-performance { inbound | outbound }
Radio视图下,继承AP组配置。
AP组Radio视图下,优化通信链路性能功能处于关闭状态。
Radio视图
AP组Radio视图
inbound:配置优化下行通信链路性能。
outbound:配置优化上行通信链路性能。
value:链路性能优化报文分片门限长度,取值范围为0~2048,单位为字节。
Radio视图下配置的优先级高于AP组Radio视图下的配置。
# 配置优化上行通信链路性能,报文分片门限值为100字节。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option optimize-link-performance outbound enable 100
# 配置优化上行通信链路性能,报文分片门限值为100字节。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model- WA6320-radio-1] option optimize-link-performance outbound enable 100
option power-supply enable命令用来开启AP根据供电模式调整射频发射功率功能。
option power-supply disable命令用来关闭AP根据供电模式调整射频发射功率功能。
undo power-supply命令用来恢复缺省情况。
option power-supply { disable | enable { local | poe | poeplus } }
undo power-supply
Radio视图下,继承AP组配置。
AP组Radio视图下,AP根据供电模式调整射频发射功率功能处于关闭状态。
Radio视图
AP组Radio视图
local:配置本地供电模式下的射频发射功率。
poe:配置PoE供电模式下的射频发射功率。
poeplus:配置PoE+供电模式下的射频发射功率。
# 配置AP调整射频发射功率为PoE+供电模式下的射频发射功率。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option power-supply enable poeplus
# 配置AP调整射频发射功率为PoE+供电模式下的射频发射功率。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option power-supply enable poeplus
option probe-response-try enable命令用来开启Probe response报文的最大发送次数功能。
option probe-response-try disable命令用来关闭Probe response报文的最大发送次数功能。
undo probe-response-try命令用来恢复缺省情况。
option probe-response-try { disable | enable number }
Radio视图下,继承AP组配置。
AP组Radio视图下,Probe response报文的最大发送次数功能处于关闭状态,即不限制Probe response报文的最大发送次数。
Radio视图
AP组Radio视图
number:Probe response发送的最大次数,取值范围为1~16。
在高密部署场景下,通过调整Probe response报文的最大发送次数,有效减少射频口Probe response报文发送的数量,节约了射频资源,有利于提高整个网络的应用效果。
# 配置Probe response报文的最大发送次数为10。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option probe-response-try enable 10
# 配置Probe response报文的最大发送次数为10。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option probe-response-try enable 10
option rate-algorithm emr enable命令用来开启EMR发送速率算法。
option rate-algorithm emr disable命令用来关闭EMR发送速率算法。
undo option rate-algorithm emr命令用来恢复缺省情况。
option rate-algorithm emr { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,禁用EMR发送速率算法,射频口将选择优先保证最大吞吐量的速率算法发送数据。
Radio视图
AP组Radio视图
启用EMR发送速率算法后,射频口将采用EMR(Ensure Minimum Rate,保障最低速率)发送速率算法发送数据,优先保证数据连接可靠性。
使用本功能可能会导致整网的吞吐量下降。
# 配置EMR发送速率算法。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option rate-algorithm emr enable
# 配置EMR发送速率算法。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option rate-algorithm emr enable
option roam-navigation enable命令用来开启漫游导航功能。
option roam-navigation disable命令用来关闭漫游导航功能。
undo option roam-navigation命令用来恢复缺省情况。
option roam-navigation { disable | enable rssi rssi-value { beacon-power power-value | probe-response-power power-value } }
Radio视图下,继承AP组配置。
AP组Radio视图下,漫游导航功能处于关闭状态。
Radio视图
AP组Radio视图
rssi rssi-value:漫游导航的信号参考值,取值范围为1~50,建议值为20。
beacon-power power-value:Beacon帧发射功率,取值范围为1~30,单位为dBm,建议值为10。
probe-response-power power-value:Probe response帧发射功率,取值范围为1~30,单位为dBm,建议值为10。
配置了Beacon帧的发射功率,则只有Beacon帧发射功率受控,其他报文功率使用默认值发射;配置了Probe response帧的发射功率,则只有Probe response帧的发射功率受控,其他报文功率使用默认值发射
# 开启漫游导航功能,配置漫游导航的信号参考值为10,降低Beacon帧的发射功率为10。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option roam-navigation enable rssi 10 beacon-power 10
# 开启漫游导航功能,配置漫游导航的信号参考值为10,降低Probe response帧的发射功率为10。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model- WA6320-radio-1] option roam-navigation enable rssi 10 probe-response-power 10
option rx-broadcast-all enable命令用来开启接收所有广播报文功能。
option rx-broadcast-all disable命令用来关闭接收所有广播报文功能。
undo rx-broadcast-all命令用来恢复缺省情况。
option rx-broadcast-all { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,接收所有广播报文功能处于关闭状态。
Radio视图
AP组Radio视图
无线网络中潜在的攻击者会仿冒其他设备的名义发送攻击报文,以达到破坏无线网络正常工作的目的,这种攻击称之为Spoofing攻击。Spoofing攻击检测支持对仿冒AP名义发送的广播解除认证和广播解除关联报文进行检测,因此,AP如果需要检测当前开启的射频下的所有的Spoofing攻击,就需要开启接收所有广播报文的功能。
该功能在支持802.11ac协议AP的5G射频上不生效。
# 开启接收所有广播报文功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option rx-broadcast-all enable
# 开启接收所有广播报文功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option rx-broadcast-all enable
option rx-opportunity-optimize enable命令用来开启射频接收优化功能。
option rx-opportunity-optimize disable命令用来关闭射频接收优化功能。
undo option rx-opportunity-optimize命令用来恢复缺省情况。
option rx-opportunity-optimize { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,射频接收优化功能处于关闭状态。
Radio视图
AP组Radio视图
开启该功能后,射频会调整接收报文的时机,使信号达到最佳接收的效果。
# 开启射频接收优化功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option rx-opportunity-optimize enable
# 开启射频接收优化功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option rx-opportunity-optimize enable
option signal-ignore enable命令用来开启AP忽略弱信号报文功能。
option signal-ignore disable命令用来关闭AP忽略弱信号报文功能。
undo option signal-ignore命令用来恢复缺省情况。
option signal-ignore { disable | enable rssi rssi-value }
Radio视图下,继承AP组配置。
AP组Radio视图下,AP忽略弱信号报文功能处于关闭状态,即AP不忽略弱信号报文。
Radio视图
AP组Radio视图
rssi rssi-value:信号强度门限值,取值范围为1~30,建议值为10。
AP开启了忽略弱信号无线报文功能后,提高了自身的发送机率,但有可能对其它的同信道设备造成冲突和干扰。
# 开启AP忽略弱信号报文功能,并配置AP忽略弱信号报文的门限值为10。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option signal-ignore enable rssi 10
# 开启AP忽略弱信号报文功能,并配置AP忽略弱信号报文的门限值为10。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option signal-ignore enable rssi 10
option smart-chip-protection enable命令用来开启射频芯片智能保护功能。
option smart-chip-protection disable命令用来关闭射频芯片智能保护功能。
undo option smart-chip-protection命令用来恢复缺省情况。
option smart-chip-protection { disable | enable interval interval }
Radio视图下,继承AP组配置。
AP组Radio视图下,射频芯片智能保护功能处于关闭状态。
Radio视图
AP组Radio视图
interval interval:射频芯片智能保护功能开启的时间间隔,取值范围为1~24,单位为小时。
配置本命令后,射频芯片智能保护功能将定期开启。
# 开启射频芯片智能保护功能,并配置智能保护功能开启的时间间隔为10小时。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option smart-chip-protection enable interval 10
# 开启射频芯片智能保护功能,并配置智能保护功能开启的时间间隔为10小时。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option smart-chip-protection enable interval 10
option subway-band-width enable命令用来开启窄带功能。
option subway-band-width disable命令用来关闭窄带功能。
undo subway-band-width命令用来恢复缺省情况。
option subway-band-width { disable | enable { 5 | 10 } }
Radio视图下,继承AP组配置。
AP组Radio视图下,窄带功能处于关闭状态。
Radio视图
AP组Radio视图
5:表示射频接口工作在5M的带宽模式下。
10:表示射频接口工作在10M的带宽模式下。
开启窄带功能后,可以增强信号的抗干扰能力,同时带宽变窄后,受到频谱内其他信号干扰的几率也会降低。
# 开启窄带功能,配置带宽为5M。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] option subway-band-width enable 5
# 开启窄带功能,配置带宽为5M。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option subway-band-width enable 5
1.1.27  option tpc
option tpc enable命令用来开启基于客户端信号强度的逐包功率控制功能。
option tpc disable命令用来关闭基于客户端信号强度的逐包功率控制功能。
undo option tpc命令用来恢复缺省情况。
option tpc { disable | enable [ minpower minpower | powerstep powerstep | rssistep rssistep | rssithreshold rssithreshold ] }
undo option tpc
Radio视图下,继承AP组配置。
AP组Radio视图下,基于客户端信号强度的逐包功率控制功能处于关闭状态。
Radio视图
AP组Radio视图
minpower minpower:配置基于客户端信号强度的逐包功率控制时AP的最小发射功率。取值范围为1~27,缺省值为10。
powerstep powerstep:配置基于客户端信号强度的逐包功率控制时AP发射功率下降的步长值。取值范围为1~15,缺省值为5。
rssistep rssistep:配置基于客户端信号强度的逐包功率控制时RSSI值调整的步长值。取值范围为1~20,缺省值为10。
rssithreshold rssithreshold:配置基于客户端信号强度的逐包功率控制功能的RSSI阈值。取值范围为20~95,缺省值为65。
逐包功率控制功能可以动态选择报文的发射功率,通过动态调整发射功率的大小,实现对信号覆盖范围的调整。例如,对于信号强度较好的无线客户端,AP设备可以使用较低的发射功率,同样可以达到与使用固定发射功率相同的数据传输效果。较低的发射功率不但减少了AP设备的能耗和辐射,更加的绿色环保,而且可以有效地控制报文的影响范围,减少对周围设备的干扰,在整体上提升用户对于WLAN网络使用的感受。
# 开启逐包功率控制功能,配置最小功率为20。(Radio视图)
[Sysname-wlan-ap-ap1] radio 2
[Sysname-wlan-ap-ap1-radio-2] option tpc enable minpower 20
# 开启逐包功率控制功能,配置最小功率为20。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320] radio 2
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-2] option tpc enable minpower 20
option x-share quiet enable命令用来开启静谧模式。
option x-share quiet disable命令用来关闭静谧模式。
undo option x-share quiet命令用来恢复缺省情况。
option x-share quiet { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,静谧模式处于关闭状态。
Radio视图
AP组Radio视图
仅X分系列AP产品支持配置静谧模式,开启该功能后,可以达到环保节能和降低辐射的效果。
# 开启静谧模式功能。(Radio视图)
[Sysname] wlan ap ap1 model WA4320i-X
[Sysname-wlan-ap-ap1-radio-1] option x-share quiet enable
# 开启静谧模式功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1] ap-model WA4320i-X
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-X] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-X-radio-1] option x-share quiet enable
rrop anti-bmc default-action permit命令用来配置允许AP向Radio接口发送网络中的广播和组播报文。
rrop anti-bmc default-action deny命令用来配置拒绝AP向Radio接口发送网络中的广播和组播报文。
undo rrop anti-bmc default-action命令用来恢复缺省情况。
rrop anti-bmc default-action { deny | permit }
AP视图:继承AP组配置。
AP组视图:允许AP向Radio接口发送网络中的广播和组播报文。
AP视图
AP组视图
·     当配置rrop anti-bmc default-action permit命令后,AP会对接收到的所有广播和组播报文正常转发。
·     当配置rrop anti-bmc default-action deny命令后,AP会丢弃所有的广播和组播报文。
·     如果同时开启了广播和组播报文控制功能(rrop anti-bmc network enable),则报文按照广播和组播报文控制功能的规则处理。
·     本功能仅支持软件转发,不支持硬件转发。
# 配置拒绝AP向Radio接口发送网络中的广播和组播报文。(AP视图)
[Sysname-wlan-ap-ap1] rrop anti-bmc default-action deny
# 配置拒绝AP向Radio接口发送网络中的广播和组播报文。(AP组视图)
[Sysname] wlan ap-group 10
[Sysname-ap-group10] rrop anti-bmc default-action deny
·     rrop anti-bmc network
rrop anti-bmc network enable命令用来开启网络中的广播和组播报文控制功能。
rrop anti-bmc network disable命令用来关闭网络中的广播和组播报文控制功能。
undo rrop anti-bmc network命令用来恢复缺省情况。
rrop anti-bmc network { disable | { ipv4-simple | ipv6-simple | ipv4-and-ipv6-simple } enable }
AP视图:AP组有配置的情况下,继承AP组配置;AP组无配置的情况下,继承系统视图配置。
AP组视图:继承系统视图配置。
系统视图:缺省情况下,IPv4网络基本广播和组播报文控制功能处于开启状态;当设备以出厂配置启动时,IPv4和IPv6网络基本广播和组播报文控制功能处于开启状态。
ipv4-simple:IPv4网络基本报文。
ipv6-simple:IPv6网络基本报文。
ipv4-and-ipv6-simple:IPv4和IPv6网络的基本报文。
AP视图
AP组视图
开启IPv4网络基本广播和组播报文控制功能后,当AP收到有线侧广播和组播报文后,AP会在本地对ARP广播报文进行广播转单播,对DHCP广播请求报文进行丢弃,对其他IPv4基本广播和组播报文正常处理,如果同时配置了rrop anti-bmc default-action deny命令,则对其他IPv4基本广播和组播报文丢弃处理。
开启IPv6网络基本组播报文控制功能后,当AP收到有线侧组播报文后,AP会在本地对RS报文和DHCPv6请求报文进行丢弃,对RA和NS报文转单播,对其他IPv6基本组播报文正常处理,如果同时配置了rrop anti-bmc default-action deny或rrop anti-bmc protocol ipv6 deny命令,则对其他IPv6基本组播报文丢弃处理。
本功能仅支持软件转发,不支持硬件转发。
# 开启IPv4网络基本广播和组播报文控制功能。(AP视图)
[Sysname-wlan-ap-ap1] rrop anti-bmc network ipv4-simple enable
# 开启IPv4网络基本广播和组播报文控制功能。(AP组视图)
[Sysname] wlan ap-group group1
[Sysname-ap-group-group1] rrop anti-bmc network ipv4-simple enable
# 开启IPv4网络基本广播和组播报文控制功能。(系统视图)
[Sysname] rrop anti-bmc network ipv4-simple enable
rrop anti-bmc protocol arp mode命令用来配置广播和组播报文控制功能对ARP广播报文的处理动作。
undo rrop anti-bmc protocol arp命令用来恢复缺省情况。
rrop anti-bmc protocol arp mode { proxy-reply | unicast-forward }
AP视图:AP组有配置的情况下,继承AP组配置;AP组无配置的情况下,继承系统视图的配置。
AP组视图:继承系统视图的配置。
系统视图:AP对下行ARP广播报文的处理动作为广播转单播。
AP视图
AP组视图
proxy-reply:AP对ARP广播报文进行代答处理。
unicast-forward:AP对ARP广播报文进行广播转单播处理。
通过本功能配置AP收到有线侧的ARP广播报文的处理动作,以减少无线网络中的ARP广播报文的数量:
·     代答处理:当ARP请求目标的IP地址匹配AP的终端地址表项时,AP不转发ARP请求报文,而是直接代替ARP请求目标回应ARP应答报文,报文的发送端地址为ARP请求目标的IP地址,报文的发送端MAC地址和链路层的源MAC地址均为客户端地址表项中目标IP地址对应的MAC地址。
·     广播转单播处理:当ARP请求目标的IP地址匹配AP的终端地址表项时,本端设备将ARP请求报文内部的目标MAC地址和链路层的目的MAC地址均修改为终端地址表项中与目标IP地址对应的MAC地址,然后单播转发ARP请求报文。
通过rrop anti-bmc network ipv4-simple enable命令开启IPv4网络中的广播和组播报文控制功能后,本功能才生效。
# 配置AP对收到有线侧的ARP广播报文进行代答处理。(AP视图)
[Sysname-wlan-ap-ap1] rrop anti-bmc protocol arp mode proxy-reply
# 配置AP对收到有线侧的ARP广播报文进行代答处理。(AP组视图)
[Sysname-ap-group-group1] rrop anti-bmc protocol arp mode proxy-reply
# 配置AP对收到有线侧的ARP广播报文进行代答处理。(系统视图)
[Sysname] rrop anti-bmc protocol arp mode proxy-reply
rrop anti-bmc protocol ipv6 continue命令用来配置继续匹配下一条规则。
rrop anti-bmc protocol ipv6 deny命令用来配置拒绝AP向Radio接口发送网络中的IPv6组播报文。
undo rrop anti-bmc protocol ipv6命令用来恢复缺省情况。
rrop anti-bmc protocol ipv6 { continue | deny }
AP视图:继承AP组配置。
AP组视图:继承rrop anti-bmc default-action命令的配置。
AP视图
AP组视图
·     当配置rrop anti-bmc protocol ipv6 continue命令后,AP继续匹配rrop anti-bmc default-action命令的配置。
·     当配置rrop anti-bmc protocol ipv6 deny命令后,AP会丢弃所有的广播和组播报文,如果同时开启了广播和组播报文控制功能(rrop anti-bmc network enable),则报文按照广播和组播报文控制功能的规则处理。
# 配置拒绝AP向Radio接口发送网络中的IPv6组播报文。(AP视图)
[Sysname-wlan-ap-ap1] rrop anti-bmc protocol ipv6 deny
# 配置拒绝AP向Radio接口发送网络中的IPv6组播报文。(AP组视图)
[Sysname-ap-group-group1] rrop anti-bmc protocol ipv6 deny
·     rrop anti-bmc default-action
rrop anti-bmc protocol nd mode命令用来配置广播和组播报文控制功能对ND组播报文的处理动作。
undo rrop anti-bmc protocol nd命令用来恢复缺省动作。
rrop anti-bmc protocol nd mode { proxy-reply | unicast-forward }
AP视图:AP组有配置的情况下,继承AP组配置;AP组无配置的情况下,继承全局配置。
AP组视图:继承全局配置。
系统视图:AP对下行ND组播报文的处理动作为转单播。
AP视图
AP组视图
proxy-reply:AP对ND组播报文进行代答处理。
unicast-forward:AP对ND组播报文进行转单播处理。
通过本功能配置AP对收到有线侧的ND组播报文的处理动作,以减少无线网络中的ND组播报文的数量:
·     代答处理:当ND请求目标的IP地址匹配AP的终端地址表项时,AP不转发ND请求报文,而是直接代替ARP请求目标回应ND应答报文,报文的发送端地址为ND请求目标的IP地址,报文的发送端MAC地址和链路层的源MAC地址均为客户端地址表项中目标IP地址对应的MAC地址。
·     转单播处理:当ND请求目标的IP地址匹配AP的终端地址表项时,本端设备将ND请求报文内部的目标MAC地址和链路层的目的MAC地址均修改为终端地址表项中与目标IP地址对应的MAC地址,然后单播转发ND请求报文。
通过rrop anti-bmc network ipv6-simple enable命令开启IPv6网络中的广播和组播报文控制功能后,本功能才生效。
# 配置AP对收到有线侧的ND组播报文进行代答处理。(AP视图)
[Sysname-wlan-ap-ap1] rrop anti-bmc protocol nd mode proxy-reply
# 配置AP对收到有线侧的ND组播报文进行代答处理。(AP组视图)
[Sysname-ap-group-group1] rrop anti-bmc protocol nd mode proxy-reply
# 配置AP对收到有线侧的ND组播报文进行代答处理。(系统视图)
[Sysname] rrop anti-bmc protocol nd mode proxy-reply
rrop anti-bmc rate-limit enable命令用来开启下行报文限速功能。
rrop anti-bmc rate-limit disable命令用来关闭下行报文限速功能。
undo rrop anti-bmc rate-limit命令用来恢复缺省情况。
rrop anti-bmc { broadcast | multicast } rate-limit { disable | enable }
undo rrop anti-bmc { broadcast | multicast } rate-limit
AP视图
AP组视图
AP视图:继承AP组配置。
AP组视图:下行报文限速功能处于关闭状态。
broadcast:广播报文。
multicast:组播报文。
本功能用来对AP下行发送广播和组播报文的速率进行限制,来提高Radio接口的有效使用率。
# 开启下行广播报文限速功能。(AP视图)
[Sysname-wlan-ap-ap1] rrop anti-bmc broadcast rate-limit enable
# 开启下行广播报文限速功能。(AP组视图)
[Sysname-ap-group-group1] rrop anti-bmc broadcast rate-limit enable
·     rrop anti-bmc rate-limit pps
rrop anti-bmc rate-limit pps命令用来配置报文的下行限速速率。
undo rrop anti-bmc rate-limit pps命令用来恢复缺省情况。
rrop anti-bmc { broadcast | multicast } rate-limit pps max-pps
undo rrop anti-bmc { broadcast | multicast } rate-limit pps
AP视图
AP组视图
AP视图:继承AP组配置。
AP组视图:未配置报文的下行限速速率。
broadcast:广播报文。
multicast:组播报文。
pps max-pps:允许AP每秒最多发送下行报文包数,取值范围为1~1410000。
下行报文限速功能处于开启状态时,配置本命令后,当AP下行发送的报文速率超过限定值后,AP将丢弃超出限速速率的报文。
# 配置广播报文的下行限速速率为每秒1024个报文。(AP视图)
[Sysname-wlan-ap-ap1] rrop anti-bmc broadcast rate-limit pps 1024
# 配置广播报文的下行限速速率为每秒1024个报文。(AP组视图)
[Sysname-ap-group-group1] rrop anti-bmc broadcast rate-limit pps 1024
rrop anti-bmc upstream client-rate-limit enable命令用来开启上行报文限速功能。
rrop anti-bmc upstream client-rate-limit disable命令用来关闭上行报文限速功能。
undo rrop anti-bmc upstream client-rate-limit命令用来恢复缺省情况。
AP视图/AP组视图:
rrop anti-bmc { broadcast | multicast } upstream client-rate-limit { disable | enable }
undo rrop anti-bmc { broadcast | multicast } upstream client-rate-limit
系统视图:
rrop anti-bmc { broadcast | multicast } upstream client-rate-limit enable
AP视图
AP组视图
AP视图:继承AP组配置。
AP组视图:继承系统视图配置。
系统视图:上行报文限速功能处于关闭状态。
broadcast:广播报文。
multicast:组播报文。
AP收到无线客户端发送的大量广播组播报文,会对网关造成冲击,影响网关的正常工作。开启本功能后,可以对AP收到的广播组播报文进行限速处理。
# 开启上行广播报文限速功能。(AP视图)
[Sysname-wlan-ap-ap1] rrop anti-bmc broadcast upstream client-rate-limit enable
# 开启上行广播报文限速功能。(AP组视图)
[Sysname-ap-group-group1] rrop anti-bmc broadcast upstream client-rate-limit enable
# 开启上行广播报文限速功能。(系统视图)
[Sysname] rrop anti-bmc broadcast upstream client-rate-limit enable
·     rrop anti-bmc upstream client-rate-limit pps
rrop anti-bmc upstream client-rate-limit pps命令用来配置报文的上行限速速率。
undo rrop anti-bmc upstream client-rate-limit pps命令用来恢复缺省情况。
rrop anti-bmc { broadcast | multicast } upstream client-rate-limit pps max-pps
undo rrop anti-bmc { broadcast | multicast } upstream client-rate-limit pps
AP视图
AP组视图
AP视图:继承AP组配置
AP组视图:继承系统视图配置。
系统视图:未配置报文的上行限速速率。
broadcast:广播报文。
multicast:组播报文。
pps max-pps:允许AP每秒最多发送上行报文包数,取值范围为1~1410000。
上行报文限速功能处于开启状态时,配置本命令后,当AP上行发送的报文速率超过限定值后,AP将丢弃超出限速速率的报文。
# 配置广播报文的上行限速速率为每秒1024个报文。(AP视图)
[Sysname-wlan-ap-ap1] rrop anti-bmc broadcast upstream client-rate-limit pps 1024
# 配置广播报文的上行限速速率为每秒1024个报文。(AP组视图)
[Sysname-ap-group-group1] rrop anti-bmc broadcast upstream client-rate-limit pps 1024
# 配置广播报文的上行限速速率为每秒1024个报文。(系统视图)
[Sysname] rrop anti-bmc broadcast upstream client-rate-limit pps 1024
rrop arp ap-proxy-gateway enable命令用来开启AP代替网关响应ARP请求功能。
rrop arp ap-proxy-gateway disable命令用来关闭AP代替网关响应ARP请求功能。
undo rrop arp ap-proxy-gateway命令用来恢复缺省情况。
rrop arp ap-proxy-gateway { disable | enable [ count count ] }
AP组视图:继承系统视图配置。
系统视图:缺省情况下,AP代替网关响应ARP请求功能处于关闭状态;当设备以出厂配置启动时,AP代替网关响应ARP请求功能处于开启状态。
count count:一个代答周期内AP代答客户端发送给网关的ARP请求报文的个数,取值范围为1~4096,缺省值为10。
AP视图
AP组视图
开启本功能后,AP会对收到的无线客户端发送给网关的ARP请求报文进行响应代答。为了避免代答期间,网关的MAC地址发生变化,当一个周期内AP代答报文个数超过配置的个数时,AP会转发一个ARP请求报文给网关,由网关直接处理:
·     若网关答复,则使用新的网关MAC地址,并且进入下一个响应代答周期。
·     若网关未答复,则继续使用上一个周期的网关MAC地址,并且进入下一个响应代答周期。
当网关任务繁重或者网络状况不佳时,建议开启本功能,从而降低网关业务压力。
# 开启AP代替网关响应ARP请求功能。(AP视图)
[Sysname-wlan-ap-ap1] rrop arp ap-proxy-gateway enable
#开启AP代替网关响应ARP请求功能。(AP组视图)
[Sysname-ap-group-group1] rrop arp ap-proxy-gateway enable
# 开启AP代替网关响应ARP请求功能。(系统视图)
[Sysname] rrop arp ap-proxy-gateway enable
rrop client fast-keep-alive enable命令用来开启客户端快速保活功能。
rrop client fast-keep-alive disable命令用来关闭客户端快速保活功能。
undo rrop client fast-keep-alive命令用来恢复缺省情况。
rrop client fast-keep-alive { disable | enable [ count count-value ] [ interval interval-value] }
Radio视图下,继承AP组配置。
AP组Radio视图下,客户端快速保活功能处于开启状态。
Radio视图
AP组Radio视图
count count-value:客户端保活检测的次数,取值范围为128~2048,缺省值为1024。
interval interval-value:客户端保活检测的周期,取值范围为3~60,单位为秒,缺省值为10。
快速保活功能通过配置AP向客户端发送单播报文的次数来快速的确认客户端是否在线。AP将单播报文当做保活检测报文,以count-value个单播报文为一组。在一个保活检测周期内(interval-value时间内),如果有三组单播报文均没有收到客户端的应答,则判断客户端不在线,AP断开与客户端的连接,以提高射频资源的利用率。
本功能主要用于人员流动性较大的场景,当网络环境较差时,可以适当降低客户端保活检测的次数或降低客户端保活检测的周期时长。当人员稳定情况下,推荐使用默认配置。
# 开启客户端快速保活功能,客户端保活检测次数为300。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] rrop client fast-keep-alive enable count 300
# 开启客户端快速保活功能,客户端保活检测次数为300。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] rrop client fast-keep-alive enable count 300
·     client keep-alive(无线AC应用)
rrop flow-schedule mode命令用来配置AP的流量调度模式。
undo rrop flow-schedule mode命令用来恢复缺省情况。
rrop flow-schedule mode { balanced | quick-speed | intelligent [ channel-usage-threshold threshold-value | max max-value | min min-value ] }
Radio视图
AP组Radio视图
Radio视图下,继承AP组配置。
AP组Radio视图下,AP的流量调度为极速模式。
balanced:均衡模式。配置该模式后,终端会被平均分配带宽。
quick-speed:极速模式。配置该模式后,终端将依据自身流量自由竞争带宽。
intelligent:智能模式。配置该模式后,终端会被平均分配带宽,空闲终端在保障自身带宽的前提下,会将空闲的带宽根据算法分配给大流量终端。
channel-usage-threshold threshold-value:智能调度门限值,threshold-value为信道利用率,的取值范围为1~99%。信道使用率小于配置值时,智能模式将自动关闭并使用缺省的极速模式,信道利用率大于等于threshold-value时,自动恢复为智能模式。若不指定threshold-value,则表示无论信道使用率为多少,智能模式将会一直处于开启状态。
max max-value:终端的最大限制速率,max-value的取值范围为16~1700000,单位为Kbps。
min min-value:终端的最小限制速率,min-value的取值范围为16~1700000,单位为Kbps,配置的max-value需要大于min-value。
使用场景
建议在需要保证公平性的场景,如办公场景,使用均衡模式;在终端数量较少的场景,或需要保证大流量终端性能的场景,使用极速模式,该模式下大流量终端可以尽可能取得更高的带宽;在终端数量较多,且存在大量空闲终端的场景使用智能模式,以提高带宽的利用率。
工作机制
配置AP的流量调度模式后,设备会根据信道使用率,最大选速信息,终端数目等信息计算当前可用带宽总量,并依照不同模式为接入的终端分配可用带宽。
本功能优先级比基于射频的客户端限速速率功能要低,当通过client-rate-limit enable命令开启了基于射频的客户端限速速率功能时,终端的限速速率以client-rate-limit enable命令的配置为准。
# 配置AP的流量调度模式为均衡模式。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] rrop flow-schedule mode balanced
# 配置AP的流量调度模式为均衡模式。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] rrop flow-schedule mode balanced
rrop software-retry enable命令用来开启软件重传报文功能。
rrop software-retry disable命令用来关闭软件重传报文功能。
undo rrop software-retry命令用来恢复缺省情况。
rrop software-retry { unicast [ eap ] | broadcast-multicast } enable count count
rrop software-retry { unicast [ eap ] | broadcast-multicast } disable
undo rrop software-retry { unicast [ eap ] | broadcast-multicast }
Radio视图下,继承AP组配置。
AP组Radio视图下,所有类型报文重传次数与设备型号相关。
Radio视图
AP组Radio视图
unicast:配置单播报文重传次数。
eap:配置EAP报文重传次数。
broadcast-multicast:配置广播和组播报文的重传次数。
count count:配置报文重传次数,取值范围为1~16。
# 恢复EAP报文的重传次数为缺省配置。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] undo rrop software-retry unicast eap
# 恢复广播和组播报文的重传次数为缺省配置。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] undo rrop software-retry broadcast-multicast
rrop traffic-policy priority tcp命令用来配置TCP报文的DSCP优先级。
undo rrop traffic-policy priority tcp命令用来删除已配置的TCP报文的DSCP优先级。
rrop traffic-policy priority tcp port-num-list dscp value
undo rrop traffic-policy priority tcp { port-num-list | all }
AP视图:继承AP组配置。
AP组视图:未配置TCP报文的DSCP优先级。
AP视图
AP组视图
port-num-list:TCP端口列表,port-num-list={ value }&<1-20>,取值范围为1~65535,&<1-20>表示在一条命令中最多可以配置20个端口号。
dscp value:指定报文的DSCP优先级,取值范围为0~63。
all:表示删除所有已配置的TCP报文的DSCP优先级。
DSCP优先级用来体现报文自身的优先等级,决定报文传输的优先程度。配置的DSCP优先级的取值越大,报文的优先级越高。执行本命令后,会将指定端口号的TCP报文的DSCP优先级修改为指定的值。
本功能仅对下行报文生效。
多次配置本命令时,如果配置的DSCP优先级相同,端口进行叠加,最多叠加20个;如果配置的DSCP优先级不同,则最后一次执行的命令生效。
# 配置TCP端口号为8001、8002的报文DSCP优先级为50。(AP视图)
[Sysname-wlan-ap-ap1] rrop traffic-policy priority tcp 8001 8002 dscp 50
# 配置TCP端口号为8001、8002的报文的DSCP优先级为50。(AP组视图)
[Sysname-wlan-ap-group-group1] rrop traffic-policy priority tcp 8001 8002 dscp 50
rrop traffic-policy priority udp命令用来配置UDP报文的DSCP优先级。
undo rrop traffic-policy priority udp命令用来删除已配置的UDP报文的DSCP优先级。
rrop traffic-policy priority udp port-num-list dscp value
undo rrop traffic-policy priority udp { port-num-list | all }
AP视图:继承AP组配置。
AP组视图:未配置UDP报文的DSCP优先级。
AP视图
AP组视图
port-num-list:UDP端口列表,port-num-list={ value }&<1-20>,取值范围为1~65535,&<1-20>表示在一条命令中最多可以配置20个端口号。
dscp value:指定端口报文的DSCP优先级,取值范围为0~63。
all:表示删除所有已配置的UDP报文的DSCP优先级。
DSCP优先级用来体现报文自身的优先等级,决定报文传输的优先程度。配置的DSCP优先级的取值越大,报文的优先级越高。执行本命令后,会将指定端口号的UDP报文的DSCP优先级修改为指定的值。
本功能仅对下行报文生效。
多次配置本命令时,如果配置的DSCP优先级相同,端口进行叠加,最多叠加20个,如果配置的DSCP优先级不同,则最后一次执行的命令生效。
# 配置UDP端口号为8001、8002的报文DSCP优先级为50。(AP视图)
[Sysname-wlan-ap-ap1] rrop traffic-policy priority udp 8001 8002 dscp 50
# 配置UDP端口号为8001、8002的报文DSCP优先级为50。(AP组视图)
[Sysname-wlan-ap-group-group1] rrop traffic-policy priority udp 8001 8002 dscp 50
rrop ul-arp attack-suppression enable命令用来开启AP上行ARP攻击抑制功能。
rrop ul-arp attack-suppression disable命令用来关闭AP上行ARP攻击抑制功能。
undo rrop ul-arp attack-suppression enable命令用来恢复缺省情况。
rrop ul-arp attack-suppression { disable | enable [ threshold threshold-value ] [ block-time time ] }
AP组视图:继承系统视图配置。
系统视图:上行ARP攻击抑制功能处于关闭状态。
AP视图
AP组视图
threshold threshold-value:1秒内AP接收无线客户端ARP报文数量的门限值,取值范围为2~4096,缺省值为10。
block-time time:AP上行ARP攻击抑制阻断时间间隔,取值范围为10~6000,单位为秒,缺省值为60。
开启本功能后,在1秒内,当AP收到某一无线客户端的ARP请求/应答报文个数超过门限值时,则认为受到了该无线客户端的ARP报文攻击,AP会在配置的阻断时间间隔内丢弃该无线客户端的所有ARP请求/应答报文。当环境中无线客户端发送的ARP报文过多时,建议开启本功能。
需要注意的是,本功能不限制无线客户端请求网关的ARP报文。
# 开启AP上行ARP攻击抑制功能。(AP视图)
[Sysname-wlan-ap-ap1] rrop ul-arp attack-suppression enable
# 开启AP上行ARP攻击抑制功能。(AP组视图)
[Sysname-ap-group-group1] rrop ul-arp attack-suppression enable
# 开启AP上行ARP攻击抑制功能。(系统视图)
[Sysname] rrop ul-arp attack-suppression enable
rrop ul-bpdu forward enable命令用来开启AP放通上行STP BPDU功能。
undo rrop ul-bpdu forward命令用来关闭AP放通上行STP BPDU功能。
AP放通上行的STP BPDU功能处于关闭状态。
大部分组网中,无线终端处于网络的边缘,不需要参与STP计算,某些终端会主动发送STP BPDU报文,此时会影响整网的STP计算。AP会默认丢弃“client->有线”的BPDU报文,使能本功能可以放通这种报文。
需要注意的是,本功能不限制MESH组网中的STP BPDU报文。
# 开启AP放通上行STP BPDU功能。
[Sysname] rrop ul-bpdu forward enable
sacp roam-optimize traffic-hold enable命令用来开启漫游优化流量保持功能。
undo sacp roam-optimize traffic-hold enable命令用来关闭漫游优化流量保持功能。
漫游优化流量保持功能处于关闭状态。
无线服务模板视图
开启漫游优化流量保持功能后,设备可以在客户端漫游期间缓存需要发送给客户端的数据报文,待客户端漫游成功后,再将缓存的数据报文重新发送给客户端,减少了客户端漫游期间丢包的数量。关闭本功能,设备一段时间后会对缓存的数据报文做老化处理,不再重新发送给客户端。对于丢包数量要求较严格的漫游场景,建议开启本功能。
本功能仅当客户端关联位置和数据报文转发位置在AC上时生效。
本功能不支持分层AC组网和AC间漫游组网。
# 开启漫游优化流量保持功能。
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] sacp roam-optimize traffic-hold enable
本命令的支持情况与AP设备的型号有关,请以设备的实际情况为准。
sacp application forwarding-acceleration enable命令用来开启应用流量转发加速功能。
undo sacp application forwarding-acceleration enable命令用来关闭应用流量转发加速功能。
应用流量转发加速功能处于关闭状态。
无线服务模板视图
本功能可以提升无线客户端应用流量的下行传输速度,例如:语音通话、视频会议等,提升用户使用体验。
开启本功能后,本功能会占用较多的内存资源。请根据实际需要,谨慎开启本功能。
# 开启应用流量转发加速功能。
[Sysname-wlan-st-service] sacp application forwarding-acceleration enable
sacp application optimization enable oppo命令用来开启应用流量优化功能。
undo sacp application optimization enable oppo命令用来关闭应用流量优化功能。
sacp application optimization enable oppo [ dual-wifi | qos | monitor-link | private-ft ]
undo sacp application optimization enable oppo [ dual-wifi | qos | monitor-link | private-ft ]
应用流量优化功能处于关闭状态。
无线服务模板视图
dual-wifi:指定双Wi-Fi应用流量优化功能。
qos:指定QoS应用流量优化功能。
monitor-link:指定全链路监控功能。
private-ft:指定FT兼容模式。
应用流量优化功能包括双Wi-Fi应用流量优化、QoS应用流量优化、全链路监控功能和FT兼容模式:
·     双Wi-Fi应用流量优化:设备上开启双Wi-Fi应用流量优化,并在无线客户端上开启双Wi-Fi功能后,客户端会和AP建立备Wi-Fi链路,该Wi-Fi链路主要用于主Wi-Fi链路的备份传输,数据报文会同时在主Wi-Fi链路和辅助Wi-Fi链路上传输,以提高客户端应用流量传输的可靠性。
·     QoS应用流量优化:开启QoS应用流量优化后,设备会优先处理高优先级的报文,以提高无线客户端音视频应用流量的下行传输速度。
·     全链路监控功能:设备上开启全链路监控功能后,设备会监控AP上行链路到无线终端链路的状态,并取得终端的名称、MAC地址、信号强度和重传率等信息,以在设备上查看到更详细的终端信息,并辅助了解应用流量优化后的效果。
·     FT兼容模式:在终端存在FT适配不佳的环境中,可以开启FT兼容模式让特定终端启用FT协议接入,提升漫游体验。
分层AC组网中,不支持配置本功能。
# 开启QoS应用流量优化功能。
[Sysname] wlan service-template test
[Sysname-wlan-st-test] sacp application optimization enable oppo qos
·     display system internal wlan client dual-wifi cache
wlan client inspect enable命令用来开启客户端深度解析功能。
wlan client inspect disable命令用来关闭客户端深度解析功能。
undo wlan client inspect命令用来恢复缺省情况。
wlan client inspect { disable | enable }
AP视图下,继承AP组配置。
AP组视图下,客户端深度解析功能处于关闭状态。
AP视图
AP组视图
深度解析功能可帮助管理员更清晰地查看终端在上线前后的报文交互过程及交互耗时。
目前支持深度解析的事件为上线事件、上线失败事件和DHCP续约事件。
# 开启客户端深度解析功能。(AP视图)
[Sysname-wlan-ap-ap1] wlan client inspect enable
# 开启客户端深度解析功能。(AP组视图)
[Sysname-ap-group-group1] wlan client inspect enable
