17-DPI深度安全命令参考
01-应用层检测引擎命令
本章节下载: 01-应用层检测引擎命令  (590.48 KB)
01-应用层检测引擎命令
1 应用层检测引擎
1.1 应用层检测引擎配置命令
1.1.1 app-profile
1.1.2 block-period
1.1.3 capture-limit
1.1.4 capture-storage
1.1.5 capture-upload zip
1.1.6 description
1.1.7 display inspect smb-breakpoint-resume table
1.1.8 display inspect status
1.1.9 export repeating-at
1.1.10 export url
1.1.11 import block warning-file
1.1.12 import warning-file
1.1.13 inspect activate
1.1.14 inspect auto-bypass
1.1.15 inspect block-source parameter-profile
1.1.16 inspect bypass
1.1.17 inspect bypass application
1.1.18 inspect bypass ot-protocol
1.1.19 inspect bypass protocol
1.1.20 inspect cache-option maximum
1.1.21 inspect capture parameter-profile
1.1.22 inspect cloud-server-protocol
1.1.23 inspect cookie-decode disable
1.1.24 inspect coverage
1.1.25 inspect cpu-threshold disable
1.1.26 inspect detect all-file-type disable
1.1.27 inspect domain-whitelist enable
1.1.28 inspect file-uncompr-len
1.1.29 inspect file-fixed-length
1.1.30 inspect file-fixed-length enable
1.1.31 inspect file-uncompr-layer
1.1.32 inspect http-initial-transaction enable
1.1.33 inspect http-stream max-length
1.1.34 inspect ips log-details enable
1.1.35 inspect ips log-details signature-content enable
1.1.36 inspect log-details max-size
1.1.37 inspect logging parameter-profile
1.1.38 inspect optimization disable
1.1.39 inspect packet maximum
1.1.40 inspect proxy-server
1.1.41 inspect raw-packet max-length
1.1.42 inspect record-filename nfs maximum
1.1.43 inspect redirect parameter-profile
1.1.44 inspect signature auto-update source
1.1.45 inspect smb-reassemble enable
1.1.46 inspect source-port-identify enable
1.1.47 inspect ssl san-detect enable
1.1.48 inspect stream-fixed-length
1.1.49 inspect stream-fixed-length disable
1.1.50 inspect tcp-reassemble enable
1.1.51 inspect tcp-reassemble max-segment
1.1.52 inspect transparent enable
1.1.53 inspect uncompress maximum
1.1.54 inspect url-filter warning parameter-profile
1.1.55 inspect warning parameter-profile
1.1.56 log
1.1.57 log language
1.1.58 redirect-url
1.1.59 reset block warning-file
1.1.60 reset inspect smb-breakpoint-resume table
1.1.61 reset warning-file
1 应用层检测引擎
1.1  应用层检测引擎配置命令
1.1.1  app-profile
app-profile命令用来创建DPI应用profile,并进入DPI应用profile视图。如果指定的DPI应用profile已经存在,则直接进入DPI应用profile视图。
undo app-profile命令用来删除指定的DPI应用profile。
app-profile profile-name
undo app-profile profile-name
不存在DPI应用profile。
profile-name:表示DPI应用profile的名称,为1~63个字符的字符串,不区分大小写,且只能为字母、数字、下划线。
DPI(Deep Packet Inspection,深度报文检测)应用profile是一个安全业务模板,通过在DPI应用profile中引用DPI各业务策略(例如URL过滤),并将其应用于安全策略规则中来实现报文的应用层检测功能。
# 创建一个名称为abc的DPI应用profile,并进入DPI应用profile视图。
[Sysname] app-profile abc
[Sysname-app-profile-abc]
1.1.2  block-period
block-period命令用来配置报文源IP地址被阻断的时长。
undo block-period命令用来恢复缺省情况。
block-period period
undo block-period
报文源IP地址被阻断的时长为1800秒。
应用层检测引擎的源阻断动作参数profile视图
period:表示报文源IP地址被阻断的时长,取值范围为1~86400,单位为秒。
如果设备上同时开启了黑名单过滤功能,则报文的源IP地址被添加到IP黑名单表项后的老化时间为源阻断动作参数profile中配置的阻断时长。阻断时长之内,后续来自该源IP地址的报文将直接被黑名单过滤功能丢弃,不再进入应用层检测引擎中检测。
如果设备上未开启黑名单过滤功能,报文的源IP地址仍会被添加到IP黑名单表项中,但IP黑名单功能并未生效,后续来自该源IP地址的报文不会被黑名单过滤功能丢弃,仍将进入应用层检测引擎中处理。
有关黑名单过滤功能的详细介绍,请参见“安全配置指导”中的“攻击检测与防范”。
# 在名称为b1的应用层检测引擎源阻断动作参数profile中,配置报文源IP地址被阻断的时长为3600秒。
[Sysname] inspect block-source parameter-profile b1
[Sysname-inspect-block-source-b1] block-period 3600
·     blacklist global enable(安全命令参考/攻击检测与防范)
·     inspect block-source parameter-profile
1.1.3  capture-limit
capture-limit命令用来配置捕获报文上传阈值的最大字节数。
undo capture-limit命令用来恢复缺省情况。
capture-limit kilobytes
undo capture-limit
捕获报文上传阈值的最大字节数为512千字节。
应用层检测引擎的捕获动作参数profile视图
kilobytes:表示捕获报文上传阈值的最大字节数,取值范围为0~102400,单位为千字节。
捕获到的报文将被缓存到设备本地,当缓存的报文字节数达到指定上限值时,系统会将缓存的报文上传到指定的URL上,并清空本地缓存,同时继续捕获并上传新的报文。如果配置捕获报文的最大字节数为0,则系统会将捕获到的报文立刻上传到指定的URL上。
# 在名称为c1的应用层检测引擎捕获动作参数profile中,配置捕获报文的最大值为1024千字节。
[Sysname] inspect capture parameter-profile c1
[Sysname-inspect-capture-c1] capture-limit 1024
·     export repeating-at
·     export url
·     inspect capture parameter-profile
capture-storage命令用来配置捕获报文的存储空间限制。
undo capture-storage命令用来恢复缺省情况。
capture-storage { max-cache-percentage percent-number | max-session-size session-size } *
undo capture-storage [ max-cache-percentage | max-session-size ]
最大缓存空间占设备总内存空间的5%、每会话捕获报文的最大字节数为64KB。
应用层检测引擎的捕获动作参数profile视图。
max-cache-percentage percent-number:表示捕获报文的最大缓存空间占设备总内存空间的百分比,取值范围为5~20。
max-session-size session-size:表示每会话捕获报文的最大字节数,取值范围为64~10240,单位为千字节。
捕获报文的缓存过程如下:
(1)     ‍当会话缓存报文的总字节数达到设置的每会话捕获报文的最大字节数时,系统会将缓存报文保存到指定的捕获文件中,并清空缓存数据。
(2)     当缓存报文的总字节数达到设置的捕获报文的最大缓存空间占设备总内存空间的百分比时,系统会停止新建会话的报文缓存,已缓存的会话不受影响。
管理员需要根据实际需求和设备内存情况调整捕获报文的存储空间限制参数。例如,如需获取较多的捕获报文来进行取证分析或者设备内存的剩余存储空间充足时,可以适当提高捕获报文的存储空间限制参数,以便设备可以缓存更多的捕获报文。
本功能仅对IPS业务生效。
# 在名称为c1的应用层检测引擎捕获动作参数profile中,配置最大缓存空间占设备总内存空间的百分比为10、每会话捕获报文的最大字节数1024KB。
[Sysname-inspect-capture-c1] capture-storage max-cache-percentage 10 max-session-size 1024
capture-upload zip命令用来配置将捕获报文以ZIP格式打包上传。
undo capture-upload zip命令用来恢复缺省情况。
capture-upload zip
undo capture-upload
捕获报文以PCAP格式单包上传。
zip:表示捕获报文的上传格式为ZIP。
本功能用于将所有捕获报文以ZIP压缩包的格式统一打包上传,相对于默认的单报文上传,可以提升文件上传效率,同时方便管理员对整个事件进行回溯分析。
本功能仅对IPS业务生效。
# 在名称为c1的应用层检测引擎捕获动作参数profile中,配置将捕获报文以ZIP格式打包上传。
[Sysname-inspect-capture-c1] capture-upload zip
·     ips capture-cache(DPI深度安全命令/IPS)
1.1.6  description
description命令用来配置应用层检测引擎捕获动作参数profile的描述信息。
undo description命令用来恢复缺省情况。
未配置应用层检测引擎捕获动作参数profile的描述信息。
text:应用层检测引擎捕获动作参数profile的描述信息,为1~127个字符的字符串,不区分大小写。
通过合理编写描述信息,便于管理员快速理解应用层检测引擎捕获动作参数profile的作用,有利于后期维护。
# 在名称为c1的应用层检测引擎捕获动作参数profile中,配置描述信息为capture。
[Sysname-inspect-capture-c1] description capture
display inspect smb-breakpoint-resume table命令用来显示SMB协议断点续传表的信息。
display inspect smb-breakpoint-resume table { ipv4 | ipv6 }
SMB协议具有断点续传的功能,即当文件在传输过程中被阻断时,后续文件可能会通过创建新会话的方式继续传输。当SMB协议传输的文件在经过DPI业务(如文件过滤)处理后,最终被执行了丢弃、源阻断、重定向或重置动作时,设备会创建SMB协议断点续传表,记录报文的源IP、目的IP、源VRF、目的VRF以及文件名称等。当设备接收到SMB协议的续传文件时,会将续传文件信息与断点续传表进行匹配,如果匹配成功,则对续传文件继续执行上一次的动作。保证文件可以被成功阻断或执行其他操作。
管理员可通过本命令查看SMB协议断点续传表的信息,便于对被执行了丢弃等动作的文件的信息进行分析。
# 显示SMB协议断点续传表的信息。
<Sysname> display inspect smb-breakpoint-resume table ipv4
Slot 1:
Smb-breakpoint-resume table information:
Source IP: 1.1.1.1
Destination IP: 2.2.2.2
Source VRF: public
Destination VRF: public
MDC ID: 1
File name: test.txt
表1-1 display inspect smb-breakpoint-resume table命令显示信息描述表
Source IP
源IP
Destination IP
目的IP
Source VRF
源VRF,如果属于公网则显示为public
Destination VRF
目的VRF,如果属于公网则显示为public
MDC ID
MDC ID
File name
文件名称
·     reset inspect smb-breakpoint-resume table
display inspect status命令用来显示应用层检测引擎的工作状态。
# 显示应用层检测引擎的运行状态。
<Sysname> display inspect status
Chassis 0 Slot 1:
 Running status: Normal
表1-2 display inspect status命令显示信息描述表
Running status
应用层检测引擎的运行状态,包括如下取值:
·     DPI administratively disabled:管理员手工关闭了应用层检测引擎
·     DPI auto-bypass for protocol xxx:应用层检测引擎自动关闭了对XXX协议报文的检测功能
·     DPI disabled due to high CPU usage:因为CPU使用率过高导致应用层检测引擎被关闭
·     Normal:应用层检测引擎处于正常工作状态
Usage threshold has already been reached for the following CPU cores: xxx
CPU核XXX已超过利用率阈值门限,应用层检测引擎不再使用该CPU核处理业务
仅当出现CPU核超过利用率阈值门限的情况下才会出现此字段
·     monitor cpu-usage threshold core(基础配置命令参考/设备管理)
export repeating-at命令用来配置每天定时上传捕获报文的时间。
undo export repeating-at命令用来恢复缺省情况。
export repeating-at time
每天凌晨1点定时上传捕获报文。
time:表示每天上传捕获报文的时间,格式为hh:mm:ss,取值范围为00:00:00~23:59:59。
每天指定的时间到达时,无论本地缓存是否达到最大值,系统将向指定的URL上传缓存的捕获报文,并清空本地缓存。
# 在名称为c1的应用层检测引擎捕获动作参数profile中,配置每天定时上传捕获报文的时间为凌晨2点。
[Sysname-inspect-capture-c1] export repeating-at 02:00:00
·     capture-limit
·     export url
1.1.10  export url
export url命令用来配置上传捕获报文的URL。
undo export url命令用来恢复缺省情况。
export url url-string [ user username [ password { cipher cipher-string | simple simple-string } ] ]
undo export url
未配置上传捕获报文的URL。
url-string:表示用于上传捕获报文的URL,为1~255个字符的字符串。仅支持FTP、TFTP和HTTPS协议。
user username:表示登录远程FTP服务器用户名。user-name表示用户名,为1~31个字符的字符串,区分大小写,不能包括“\”、“|”、“/”、“:”、“*”、“?”、“<”、“>”和“@”。
password:表示登录远程FTP服务器的密码。
cipher:表示FTP服务器的密码是密文。
simple:表示FTP服务器的密码是明文,该密码将以密文形式存储。
cipher-string:FTP服务器的密文密码,区分大小写,为1~73个字符的字符串。
simple-string:FTP服务器的明文密码,区分大小写,为1~31个字符的字符串。
本地缓存的捕获的报文字节数达到指定上限值或者每天指定的时间到达时,系统会将缓存的报文上传到指定的URL。如果未配置上传捕获报文的URL,则系统依然会上传捕获到的报文并清空本地缓存,但是会上传失败。
仅在配置基于FTP协议的URL时,支持使用FTP服务器的用户名和密码。
仅IPS业务支持配置基于HTTPS协议的上传捕获报文的URL。
# 在名称为c1的应用层检测引擎捕获动作参数profile中,配置上传捕获报文的URL为tftp://192.168.100.100/upload。
[Sysname-inspect-capture-c1] export url tftp://192.168.100.100/upload
·     capture-limit
import block warning-file命令用来导入防病毒告警文件。
import block warning-file file-path
设备使用缺省文件里的告警信息:The site you are accessing has a security risk and thereby is blocked.
防病毒告警动作参数profile视图
file-path:表示防病毒告警文件的存放路径,为1~200个字符的字符串。
本命令用于导入防病毒告警文件,告警文件中可配置具体告警信息。告警信息出现在设备返回给客户端浏览器的提示窗口中,用来提示用户访问的内容有病毒,并且已阻断该访问。
导入的告警文件保存在dpi/av/warning目录下,并将其命名为av-httpDeclare-xxx,其中xxx表示对应的告警动作参数profile的名称。
仅支持导入html和txt类型的告警文件。
告警文件支持以下导入方式:
·     本地导入:使用本地保存的告警文件导入。
·     FTP/TFTP导入:通过FTP/TFTP方式下载远程服务器上保存的告警文件,并导入该告警文件信息。
参数file-path的取值与导入的方式有关。本地导入时参数file-path取值请参见表1-3;FTP/TFTP导入时参数file-path取值请参见表1-4。
表1-3 本地导入时参数file-path取值说明表
导入场景
参数file-path取值
告警文件的存储位置与当前工作路径一致
filename
可以执行pwd命令查看当前工作路径
有关pwd命令的详细介绍请参见“基础配置命令参考”中的“文件系统管理”
告警文件的存储位置与当前工作路径不一致,且在相同存储介质上
filename
需要先执行cd命令将工作路径切换至告警文件所在目录下
有关cd命令的详细介绍请参见“基础配置命令参考”中的“文件系统管理”
告警文件的存储位置与当前工作路径不在相同存储介质上
path/filename
需要先执行cd命令将工作路径切换至告警文件所在存储介质的根目录下,再指定告警文件的相对路径
表1-4 FTP/TFTP导入时参数file-path取值说明表
导入场景
参数file-path取值
告警文件存储在开启FTP服务的远程服务器上
ftp://username:password@server/filename
username为登录FTP服务器的用户名,password为登录FTP服务器的密码,server为FTP服务器的IP地址或主机名
当FTP的用户名和密码中使用了“:”、“@”和“/”三种特殊字符时,需要将这三种特殊字符替换为其对应的转义字符“%3A或%3a”、“%40”和“%2F或%2f”
告警文件存储在开启TFTP服务的远程服务器上
tftp://server/filename
server为TFTP服务器的IP地址或主机名
当采用FTP/TFTP方式导入告警文件时,如果指定的是服务器的主机名,则需要确保设备能通过静态或动态域名解析方式获得FTP/TFTP服务器的IP地址,并与之路由可达。否则,设备导入告警文件会失败。有关域名解析功能的详细配置请参见“网络互通配置指导” 中的“域名解析”。
# 采用TFTP的方式导入防病毒告警文件,文件远程路径为:tftp://192.168.0.1/warning.txt。
[Sysname] inspect warning parameter-profile warn
[Sysname-inspect-warning-warn] import block warning-file tftp://192.168.0.1/warning.txt
#采用FTP的方式导入防病毒告警文件,文件远程路径为:ftp://user:[email protected]/warning.txt,用户名为user,密码为password。
[Sysname-inspect-warning-warn] import block warning-file ftp://user:[email protected]/warning.txt
# 采用本地方式导入防病毒告警文件,文件本地路径为cfa0:/warning.txt,且当前工作路径为cfa0。
[Sysname-inspect-warning-warn] import block warning-file warning.txt
import warning-file命令用来导入URL过滤告警文件。
import warning-file file-path
存在一个名称为uflt-xxx.html的告警文件,其中xxx表示URL过滤告警动作参数profile的名称。
URL过滤告警动作参数profile视图
file-path:表示告警文件的存放路径,为1~200个字符的字符串。
缺省告警信息文件中包含的告警信息内容如下:
Web Access Blocked
Your access to this website was denied. To access this webpage, contact Technical Support.
·     Reason:XXX
·     Category:XXX
·     URL:XXXX
其中,设备会根据实际情况显示Reason、Category和URL的具体内容。
·     Reason:表示客户端访问的URL被阻断的原因。包括如下取值。
¡     当客户端访问的URL因命中URL过滤黑名单而被阻断时,此字段将显示为:The URL of the website hit the URL blacklist.
¡     当客户端访问的URL因命中自定义URL分类而被阻断时,此字段将显示为:The URL of the website hit a user-defined URL category.
¡     当客户端访问的URL因命中预定义URL分类而被阻断时,此字段将显示为The URL of the website hit a predefined URL category.
¡     当客户端访问的URL因未命中白名单模式下的白名单而被阻断时,此字段将显示为:No matching whitelist entry was found for the website in whitelist mode.
¡     当客户端访问的URL因未匹配到任何允许访问的URL分类而被阻断时,此字段将显示为:The URL of the website did not match any accessible URL category.
¡     当客户端访问的URL因命中URL信誉特征库而被阻断时,此字段将显示为:The URL of the website hit the URL reputation signature library.
·     Category:表示客户端访问的URL所属的自定义分类、预定义分类或URL信誉的攻击分类。
·     URL:表示客户端访问的URL。
当缺省的告警信息不满足实际需求时,管理员可以自行编辑一个HTML或TXT类型的告警文件(该告警文件不支持自动填充URL信息),并通过本命令导入到设备中。设备会将导入的告警文件中的内容放入缺省告警信息文件中,覆盖原有内容。当设备阻断客户端访问的URL后,会向客户端浏览器的提示框中显示更新后的告警信息。
告警文件支持以下导入方式:
·     本地导入:导入设备本地保存的告警文件。
·     FTP/TFTP导入:通过FTP/TFTP方式导入远程服务器上保存的告警文件。
多次执行本命令,最后一次执行的命令生效。
当设备检测到基于QUIC协议的URL时,不会向客户端发送具体的告警信息。
参数file-path的取值与导入的方式有关。本地导入时参数file-path取值请参见表1-5;FTP/TFTP导入时参数file-path取值请参见表1-6。
表1-5 本地导入时参数file-path取值说明表
导入场景
参数file-path取值
告警文件的存储位置与当前工作路径一致
filename
可以执行pwd命令查看当前工作路径
filename
path/filename
表1-6 FTP/TFTP导入时参数file-path取值说明表
导入场景
参数file-path取值
# 采用TFTP的方式导入URL过滤告警文件,文件远程路径为:tftp://192.168.0.1/warning.txt。
[Sysname] inspect url-filter warning parameter-profile warn
[Sysname-inspect-url-filter-warning-warn] import warning-file tftp://192.168.0.1/warning.txt
# 采用FTP的方式导入URL过滤告警文件,文件远程路径为:ftp://user:[email protected]/warning.txt,用户名为user,密码为password。
[Sysname-inspect-url-filter-warning-warn] import warning-file ftp://user:[email protected]/warning.txt
# 采用本地方式导入URL过滤告警文件,文件本地路径为cfa0:/warning.txt,且当前工作路径为cfa0。
[Sysname-inspect-url-filter-warning-warn] import warning-file warning.txt
inspect activate命令用来激活DPI各业务模块的策略和规则配置。
inspect activate
DPI各业务模块的策略和规则被创建、修改和删除后会自动激活。
执行此命令会暂时中断DPI业务的处理,可能导致其他基于DPI功能的业务同时出现中断。例如,安全策略无法对应用进行访问控制等。
缺省情况下,当任意一个DPI业务模块(比如URL过滤业务)发生配置变更时(即策略或规则被创建、修改和删除),系统将会检测在20秒的间隔时间内是否再次发生了配置变更,并根据判断结果执行如下操作:
·     如果间隔时间内未发生任何配置变更,则系统将在下一个间隔时间结束时执行一次激活操作,使这些策略和规则的配置生效。
·     如果间隔时间内再次发生了配置变更,则系统将继续按照间隔时间周期性地检测是否发生配置变更。
如果希望对发生变化的业务的策略或规则立即进行激活,可执行inspect activate命令手工激活。
# 激活DPI各业务模块的策略和规则配置。
[Sysname] inspect activate
inspect auto-bypass enable命令用来开启应用层检测引擎自动关闭对指定协议报文的检测功能。
undo inspect auto-bypass enable命令用来关闭应用层检测引擎自动关闭对指定协议报文的检测功能。
应用层检测引擎自动关闭指定协议报文的检测功能处于关闭状态。
开启本功能后,如果应用层检测引擎对某个协议报文的检测导致设备出现异常并重启的情况时,则当系统重启后,应用层检测引擎将自动关闭对该协议报文的检测功能,跳过对此协议报文的处理。
# 开启应用层检测引擎自动关闭对指定协议报文的检测功能。
[Sysname] inspect auto-bypass enable
This feature might cause some functions of the DPI engine to be unavailable. Continue? [Y/N]:y
inspect block-source parameter-profile命令用来创建应用层检测引擎的源阻断动作参数profile,并进入源阻断动作参数profile视图。如果指定的源阻断动作参数profile已经存在,则直接进入源阻断动作参数profile视图。
undo inspect block-source parameter-profile命令用来删除应用层检测引擎的源阻断动作参数profile。
inspect block-source parameter-profile parameter-name
undo inspect block-source parameter-profile parameter-name
不存在源阻断动作参数profile。
parameter-name:表示源阻断动作参数profile的名称,为1~63个字符的字符串,不区分大小写。
进入源阻断动作参数profile视图后,可以配置对报文执行源阻断动作时采用的特定参数,比如阻断时长。
# 创建名称为b1的应用层检测引擎源阻断动作参数profile,并进入源阻断动作参数profile视图。
·     block-period
inspect bypass命令用来关闭应用层检测引擎功能。
undo inspect bypass命令用来开启应用层检测引擎功能。
inspect bypass
undo inspect bypass
应用层检测引擎功能处于开启状态。
关闭应用层检测引擎功能后,系统将不会对接收到的报文进行DPI深度安全处理。可能导致其他基于DPI功能的业务出现中断。例如,安全策略无法对应用进行访问控制等。
应用层检测引擎对报文的检测是一个复杂且会占用一定的系统资源的过程。开启应用层检测功能后,如果出现CPU使用率过高等情况时,可以通过关闭此功能来保证设备的正常运行。
# 关闭应用层检测引擎功能。
[Sysname] inspect bypass
·     display inspect status
inspect bypass application命令用来关闭应用层检测引擎对指定应用流量的检测功能。
undo inspect bypass application命令用来开启应用层检测引擎对指定应用流量的检测功能。
inspect bypass application app-name
undo inspect bypass application [ app-name ]
应用层检测引擎对所有应用流量都进行检测。
app-name:表示应用名称,可通过输入“?”获取支持配置的应用名称。当执行undo命令时,如果不指定本参数,则表示应用层检测引擎对所有应用流量都进行检测。
开启本功能后,应用层检测引擎不对指定的应用进行DPI业务检测。
# 关闭应用层检测引擎对指定应用流量的检测功能。
[Sysname] inspect bypass application localhost
inspect bypass ot-protocol命令用来手工关闭应用层检测引擎对指定工控协议报文的检测功能。
undo inspect bypass ot-protocol命令用来手工开启应用层检测引擎对指定工控协议报文的检测功能。
inspect bypass ot-protocol { all | ethernet-ip | modbus | opcua | s7 }
undo inspect bypass ot-protocol { all | ethernet-ip | modbus | opcua | s7 }
应用层检测引擎对所有支持的工控协议都进行检测。
all:表示关闭应用层检测引擎对所有支持工控协议报文的检测功能。
ethernet-ip:表示关闭应用层检测引擎对EtherNet.IP协议报文的检测功能。
modbus:表示关闭应用层检测引擎对Modbus协议报文的检测功能。
opcua:表示关闭应用层检测引擎对OPC.UA协议报文的检测功能。
s7:表示关闭应用层检测引擎对S7.Protocol协议报文的检测功能。
建议在如下场景中配置本命令关闭应用层检测引擎对指定工控协议报文的检测功能:
·     当组网环境中不需要对某些工控协议的报文进行检测时,可以关闭应用层检测引擎对该协议报文的检测,以减少对设备资源的占用,提升设备性能。
·     当应用层检测引擎对某个工控协议报文的检测导致设备出现异常并重启的情况时,可单独关闭引擎对该协议报文的检测功能,规避由检测该协议报文带来的问题,同时又不影响引擎对其他协议报文的检测。
# 手工关闭应用层检测引擎对所有支持的工控协议报文的检测功能。
[Sysname] inspect bypass ot-protocol all
This command might cause the DPI engine to be unavailable for all operational technology protocols. Continue? [Y/N]:y
inspect bypass protocol命令用来手工关闭应用层检测引擎对指定协议报文的检测功能。
undo inspect bypass protocol命令用来手工开启应用层检测引擎对指定协议报文的检测功能。
inspect bypass protocol { dns | ftp | ftp-data | http | https | ibm-db2 | imap | mongodb-protocol | ms-sql-s | mysql-protocol | nfs | pop3 | postgresql-protocol | quic | rtmp | sip | smb | smtp | sqlnet | telnet | tftp } *
undo inspect bypass protocol [ dns | ftp | ftp-data | http | https | ibm-db2 | imap | mongodb-protocol | ms-sql-s | mysql-protocol | nfs | pop3 | postgresql-protocol | quic | rtmp | sip | smb | smtp | sqlnet | telnet | tftp ] *
应用层检测引擎对所有支持的协议都进行检测。
dns:表示关闭应用层检测引擎对DNS协议报文的检测功能。
ftp:表示关闭应用层检测引擎对FTP协议报文的检测功能。
ftp-data:表示关闭应用层检测引擎对FTP-DATA协议报文的检测功能。
http:表示关闭应用层检测引擎对HTTP协议报文的检测功能。
https:表示关闭应用层检测引擎对HTTPS协议报文的检测功能。
ibm-db2:表示关闭应用层检测引擎对IBM DB2协议报文的检测功能。
imap:表示关闭应用层检测引擎对IMAP协议报文的检测功能。
mongodb-protocol:表示关闭应用层检测引擎对MongoDB协议报文的检测功能。
ms-sql-s:表示关闭应用层检测引擎对Microsoft SQL Server协议报文的检测功能。
mysql-protocol:表示关闭应用层检测引擎对MySQL协议报文的检测功能。
nfs:表示关闭应用层检测引擎对NFS协议报文的检测功能。
pop3:表示关闭应用层检测引擎对POP3协议报文的检测功能。
postgresql-protocol:表示关闭应用层检测引擎对PostgreSQL协议报文的检测功能。
quic:表示关闭应用层检测引擎对QUIC协议报文的检测功能。
rtmp:表示关闭应用层检测引擎对RTMP协议报文的检测功能。
sip:表示关闭应用层检测引擎对SIP协议报文的检测功能。
smb:表示关闭应用层检测引擎对SMB协议报文的检测功能。
smtp:表示关闭应用层检测引擎对SMTP协议报文的检测功能。
sqlnet:表示关闭应用层检测引擎对SQLNet协议报文的检测功能。
telnet:表示关闭应用层检测引擎对TELNET协议报文的检测功能。
tftp:表示关闭应用层检测引擎对TFTP协议报文的检测功能。
执行undo inspect bypass protocol命令时,如果不指定任何参数,则表示开启应用层检测引擎对所有协议报文的检测功能。
建议在如下场景中配置本命令关闭应用层检测引擎对指定协议报文的检测功能:
·     当组网环境中不需要对某些协议的报文进行检测时,可以关闭应用层检测引擎对该协议报文的检测,以减少对设备资源的占用,提升设备性能。
·     当应用层检测引擎对某个协议报文的检测导致设备出现异常并重启的情况时,可单独关闭引擎对该协议报文的检测功能,规避由检测该协议报文带来的问题,同时又不影响引擎对其他协议报文的检测。
# 手工关闭应用层检测引擎对HTTP协议报文的检测功能。
[Sysname] inspect bypass protocol http
This feature might cause the DPI engine to be unavailable for the specified protocols. Continue? [Y/N]:y
inspect cache-option maximum命令用来配置应用层检测引擎缓存待检测规则的选项的最大数目。
undo cache-option命令用来恢复缺省情况。
inspect cache-option maximum max-number
undo inspect cache-option
应用层检测引擎缓存待检测规则的选项的最大数目为32。
max-number:指定应用层检测引擎在检测报文时,对每条TCP/UDP流缓存待检测规则的选项的最大数目,取值范围为1~254。
应用层检测引擎中的检测规则是由各个DPI业务模块中的规则或特征转换而成。一个检测规则可以对应多个关键字,每个关键字可对应多个选项。仅当关键字和选项全部匹配,该检测规则才能匹配成功。
当应用层检测引擎在检测一条TCP/UDP数据流时,首先匹配上了一个关键字,此时还不能确定检测规则是否匹配成功,还需要对该关键字所对应的所有选项进行匹配。若当前报文不能匹配到某个选项,则需要将该选项缓存,以便后续报文与之匹配;若选项成功匹配,则不进行缓存,继续匹配下一个选项。直到所有选项均成功匹配,数据流才能与该检测规则成功匹配。
通常,使用缺省配置即可满足用户需求。但是在某些场景中,为了提高应用层检测引擎对TCP/UDP数据流应用或行为的识别能力和准确率,需要将应用层检测引擎当前缓存待检测选项的最大数调高,调高后,每条数据流占用的内存可能会上升。同理某些场景下,设备内存使用率偏高,可以调低此参数,提高设备性能,以保证基础的数据转发正常进行。
# 配置应用层检测引擎缓存待检测规则的选项的最大数目为4。
[Sysname] inspect cache-option maximum 4
inspect capture parameter-profile命令用来创建应用层检测引擎的捕获动作参数profile,并进入捕获动作参数profile视图。如果指定的捕获动作参数profile已经存在,则直接进入捕获动作参数profile视图。
undo inspect capture parameter-profile命令用来删除应用层检测引擎的捕获动作参数profile。
inspect capture parameter-profile parameter-name
undo inspect capture parameter-profile parameter-name
不存在捕获动作参数profile。
profile-name:捕获动作参数profile的名称,为1~63个字符的字符串,不区分大小写。
进入捕获动作参数profile视图后,可以配置执行报文捕获动作时采用的特定参数,比如本地缓存报文的最大值字节数。目前,仅IPS功能支持。
# 创建名称为c1的应用层检测引擎捕获动作参数profile,并进入捕获动作参数profile视图。
·     capture-limit
·     export url
inspect cloud-server-protocol命令用来配置云端查询服务器协议。
undo inspect cloud-server-protocol命令用来恢复缺省情况。
inspect cloud-server-protocol { dtls | https }
云端查询服务器协议为DTLS。
dtls:表示(Datagram Transport Layer Security,数据报传输层安全)是一种用于保护数据报协议的安全协议。
https:表示(HyperText Transfer Protocol Secure)是一种用于通过安全通信通道传输超文本数据的协议。
应用场景
云端查询服务器协议主要应用于适用于低延迟和所有需要保护数据传输安全的场景,如实时通信、在线银行、社交媒体平台、邮件服务和任何需要用户身份验证和数据加密的Web应用等。
注意事项
本命令仅支持配置防病毒和URL过滤业务的云端查询服务器协议。
当需要使用代理服务器进行云端查询服务时,请务必先将协议配置为HTTPS,以确保数据传输的安全性和完整性。
# 配置云查服务器连接协议为https。
[Sysname] inspect cloud-server-protocol https
inspect cookie-decode disable命令用来关闭Cookie解码功能。
undo inspect cookie-decode disable命令用来开启Cookie解码功能。
Cookie解码功能处于开启状态。
工作机制
Cookie解码功能用于将设备获取到的Cookie中编码后的字符串转换回原始的字符串形式,以便正确读取和处理存储在其中的数据,更好地识别出其中的攻击特征或病毒特征等。
Cookie解码功能会占用大量的内存和CPU资源,当设备资源不足时,可选择关闭Cookie解码功能以减少对资源的影响。
# 关闭Cookie解码功能。
[Sysname] inspect  cookie-decode disable
inspect coverage命令用来配置应用层检测引擎检测率模式。
undo inspect coverage命令用来恢复缺省情况。
inspect coverage { balanced | large-coverage | high-performance | user-defined }
应用层检测引擎检测率模式为平衡模式。
balanced:表示平衡模式。该模式下,设备会在性能和检测率之间进行调整,以达到平衡状态。
large-coverage:表示高检测率模式。该模式下,设备会适当的牺牲性能,以达到最佳的引擎检测率。
high-performance:表示最佳性能模式。该模式下,设备会适当降低引擎检测率,以保证最佳性能。
user-defined:表示自定义模式。该模式下,用户可以根据需求调整应用层检测引擎的检测长度。
为了适应不同场景下对设备性能和检测率的不同需求,应用层检测引擎支持如下几种选项供选择:
·     balanced:适用于大多数场景,设备在性能和检测率之间可以达到平衡状态。此模式下,应用层检测引擎对FTP协议、HTTP协议、SMB协议、NFS协议和与E-mail相关协议数据流的最大检测长度均为64千字节;MD5最大检测长度为2048千字节。
·     large-coverage:适用于对检测率要求较高的场景,设备将提升检测率,但同时会对性能产生一定影响。此模式下,应用层检测引擎对FTP协议、HTTP协议、SMB协议、NFS协议和与E-mail相关协议数据流的最大检测长度均为128千字节;MD5最大检测长度为5120千字节。
·     high-performance:适用于对设备性能要求较高的场景,设备可在保证一定检测率的前提下,提升性能。此模式下,应用层检测引擎对FTP协议、HTTP协议、SMB协议、NFS协议和与E-mail相关协议数据流的最大检测长度均为32千字节;MD5最大检测长度为32千字节。
·     user-defined:适用于对检测率和性能有精确要求的场景。此模式下,可以自定义应用层检测引擎对各协议数据流的最大检测长度(通过inspect stream-fixed-length命令配置)。
# 配置应用层检测引擎检测率模式为自定义模式。
[Sysname] inspect coverage user-defined
·     inspect stream-fixed-length enable
·     inspect file-fixed-length enable
inspect cpu-threshold disable命令用来关闭CPU门限响应功能。
undo inspect cpu-threshold disable命令用来开启CPU门限响应功能。
CPU门限响应功能处于开启状态。
应用层检测引擎对报文的检测是一个比较复杂且会占用一定系统资源的过程。当设备的CPU利用率较高时,应用层检测引擎CPU门限响应功能会启动如下机制来缓解系统资源紧张的问题。
·     当CPU利用率达到设备上配置的CPU利用率阈值时,系统会自动关闭应用层检测引擎的检测功能来保证设备的正常运行。
·     当设备的CPU利用率恢复到或低于设备上配置的CPU利用率恢复阈值时,系统会恢复应用层检测引擎的检测功能。
在系统CPU占用率较高的情况下,不建议用户配置此命令。
# 关闭CPU门限响应功能。
[Sysname] inspect cpu-threshold disable
·     inspect bypass
·     inspect stream-fixed-length disable
inspect detect all-file-type disable命令用来关闭全类型文件检测功能。
undo inspect detect all-file-type disable命令用来开启全类型文件检测功能。
全类型文件检测功能处于开启状态。
工作机制
缺省情况下,应用层检测引擎会对所有类型的文件都进行检测,以提升IPS和防病毒等业务的检测成功率,但是当网络中传输的文件数量过多、文件过大时,会消耗大量的系统资源,降低设备处理性能。此时,管理员可通过关闭全类型文件检测功能,仅对部分类型的文件进行检测,以降低对设备处理性能的影响。
关闭全类型文件检测功能后,设备不会对音视频文件、图片文件和CODE类文件进行DPI业务检测,同时,对于HTML类文件,最多支持检测20KB的数据。
对于C文件,关闭全类型文件检测功能后,设备会检查是否存在引用数据过滤策略的安全策略规则。若存在,则对C文件进行检测;不存在,则不对C文件进行检测。开启或关闭全类型文件检测功能对于裸包的检测没有影响,裸包检测由inspect raw-packet max-length length-value命令控制,不受全类型文件检测功能影响。
# 关闭全类型文件检测功能。
[Sysname] inspect detect all-file-type disable
inspect domain-whitelist enable命令用来开启域名白名单功能。
undo inspect domain-whitelist enable命令用来关闭域名白名单功能。
域名白名单功能处于关闭状态。
工作机制
域名白名单功能依托APR特征库中内置的高可信度知名域名列表优化设备处理能力。通过跳过对这些域名下载文件的MD5规则匹配,减少不必要的计算和分析,从而节约设备资源并提升设备性能。
开启域名白名单功能后,应用层检测引擎不会对匹配域名白名单的HTTP流量和解密后的HTTPS流量进行MD5规则匹配,而特征匹配和其他DPI业务检测仍正常进行。
注意事项
使用域名白名单功能前,建议先将APR特征库升级到最新版本。
对于未经解密的HTTPS流量,如果匹配域名白名单,则跳过所有DPI业务检测,从而提升处理速度和系统性能。
# 开启域名白名单功能。
[Sysname] inspect domain-whitelist enable
inspect file-uncompr-len命令用来配置可解压缩数据上限。
undo inspect file-uncompr-len命令用来恢复缺省情况。
inspect file-uncompr-len max-size
可解压缩数据上限为100MB。
max-size:表示可解压缩数据上限,取值范围为1~200,单位为MB。
可解压缩数据上限是指设备解压一个文件时可解压缩数据的最大值。到达上限后,该文件的剩余数据不再进行解压。
如果配置的可解压缩数据过大,当设备频繁收到过大的压缩文件时,设备将一直解压缩一个文件,会影响后续文件的解压缩,并影响设备的转发性能;如果配置的可解压缩数据过小,设备将不能识别压缩文件中的部分内容,从而对DPI业务(例如防病毒和数据过滤业务)的检测结果产生影响。请管理员合理配置此参数。
目前,仅支持解压缩ZIP和GZIP格式的文件。
# 配置最大解压缩数据大小为150MB。
[Sysname] inspect file-uncompr-len 150
inspect file-fixed-length命令用来配置应用层检测引擎检测文件的固定长度。
undo inspect file-fixed-length命令用来恢复缺省情况。
inspect file-fixed-length { email | ftp | http | nfs | smb } * length-value
应用层检测引擎对基于FTP协议、HTTP协议、NFS协议、SMB协议和与E-mail相关协议传输的文件固定检测长度均为64千字节。
email:表示配置基于E-mail相关协议传输的文件的固定检测长度,支持的E-mail协议包括SMTP、POP3和IMAP。
ftp:表示配置基于FTP协议传输的文件的固定检测长度。
http:表示配置基于HTTP协议传输的文件的固定检测长度。
nfs:表示配置基于NFS协议传输的文件的固定检测长度。
smb:表示配置基于SMB协议传输的文件的固定检测长度。
length-value:文件的固定检测长度,取值范围为1~2048,单位为KB。
本命令仅在应用层检测引擎检测率模式为自定义模式时(通过inspect coverage user-defined命令配置)支持配置。
由于病毒特征一般都位于文件的前半部分,可配置文件的固定检测长度,对超过长度的文件内容不再进行检测,从而提高设备的检测效率。
如果一条数据流中包含多个文件,则每个文件均仅检测配置的固定长度内的内容。
由于文件在数据流中传输,所以配置的文件固定检测长度必须小于等于数据流固定检测长度(通过inspect stream-fixed-length命令配置)。
# 配置应用层检测引擎检测基于HTTP协议传输的文件的固定检测长度为128KB。
[Sysname] inspect file-fixed-length http 128
·     inspect coverage user-defined
inspect file-fixed-length enable命令用来开启应用层检测引擎检测固定长度文件功能。
undo inspect file-fixed-length enable命令用来关闭应用层检测引擎检测固定长度文件功能。
应用层检测引擎检测固定长度文件功能处于关闭状态,不对文件检测长度进行限制。
本功能用于限制应用层检测引擎只检测每条数据流中固定长度内的文件内容,超出固定长度后的文件内容不再检测。
开启本功能后,会导致超过出固定长度的文件内容无法识别,可能会对数据过滤等业务产生影响。
# 开启应用层检测引擎检测固定长度文件功能。
[Sysname] inspect file-fixed-length enable
inspect file-uncompr-layer命令用来配置可解压缩文件层数上限。
undo inspect file-uncompr-layer命令用来恢复缺省情况。
inspect file-uncompr-layer max-layer
可解压缩文件层数上限为3。
max-layer:表示可解压缩文件层数上限,取值范围0~20。当此参数配置为0时,表示不对文件进行解压缩。
当需要检测的内容存在多层压缩的文件时,可配置本命令设置可解压缩文件的层数。当超过配置的可解压缩文件的层数时,设备将不对超出层数上限的文件进行解压缩,直接按照压缩文件格式进行特征匹配等处理。
如果配置的层数过大,当设备频繁收到多层压缩的文件时,设备将一直解压缩一个文件,会影响后续文件的解压缩,并消耗大量的设备内存;如果配置的层数过小,可能导致压缩文件中的原始文件内容无法正确识别,从而对DPI业务(例如防病毒和数据过滤业务)的检测结果产生影响。请管理员合理配置此参数。
设备仅支持对ZIP和GZIP类型文件进行解压缩。
# 配置最大解压缩文件层数为5。
[Sysname] inspect file-uncompr-layer 5
·     inspect file-uncompr-len
inspect http-initial-transaction enable命令用来开启应用层检测引擎仅检测HTTP流量首次事务功能。
undo inspect http-initial-transaction enable命令用来关闭应用层检测引擎仅检测HTTP流量首次事务功能。
应用层检测引擎仅检测HTTP流量首次事务功能处于关闭状态。
工作机制
HTTP流量的首个事务,通常是指一个HTTP会话中的第一个“请求-响应”过程,在这个过程中,客户端发起一个HTTP请求到服务器,然后服务器返回一个HTTP响应。首个事务是建立客户端和服务器之间通信的起点,后续的事务可以在首个事务的基础上进行。首次事务往往包含了打开网页或开始一个新的HTTP会话所必需的关键信息。许多网络威胁和入侵行为,如恶意软件分发、钓鱼攻击或命令和控制(C&C)通信,常在HTTP会话的开始阶段进行。因此,首次事务的检测通常可以识别出潜在的安全威胁。
在大流量场景下,对整个HTTP会话的所有事务都进行检测会大大降低设备的吞吐性能,在对设备吞吐性能要求较高的场景下,可通过开启本功能,使应用层检测引擎仅专注于分析和审查每个HTTP会话中的第一次交互。从而有助于提高设备的吞吐性能,可实现对大规模HTTP流量的安全监控。
# 开启应用层检测引擎仅检测HTTP流量首次事务功能。
[Sysname] inspect http-initial-transaction enable
inspect http-stream max-length命令用来配置每条HTTP流量的最大检测长度。
undo inspect http-stream max-length命令用来恢复缺省情况。
inspect http-stream max-length length-value
未对每条HTTP流量的最大检测长度进行限制,整条流全检测。
length-value:每条HTTP流量的最大检测长度,取值范围为1~1024,单位为KB。
工作机制
本功能用于限制应用层检测引擎对每条HTTP流量的最大检测长度,配置本功能后,设备仅检测阈值范围内的数据内容,对超过长度的内容不再进行DPI业务检测,从而提升DPI业务处理性能。
# 配置每条HTTP流量的最大检测长度为1024KB。
[Sysname] inspect http-stream max-length 1024
inspect ips log-details enable命令用来开启IPS日志记录报文详情功能。
undo inspect ips log-details enable命令用来关闭IPS日志记录报文详情功能。
IPS日志记录报文详情功能处于关闭状态。
开启本功能后,设备将缓存报文的详情信息,并记录在IPS日志中,方便用户了解报文详情。例如,对于HTTP报文,当响应报文中检测到攻击特征时,IPS日志中将记录其请求报文的HOST字段,以及响应报文的响应行信息,包括状态码、状态信息等。
开启本功能后,会占用系统的缓存资源,建议仅在关心报文的详细信息的情况下开启此功能。
# 开启IPS日志记录报文详情功能。
[Sysname] inspect ips log-details enable
inspect ips log-details signature-content enable命令用来开启IPS日志记录攻击特征详情功能。
undo inspect ips log-details signature-content enable命令用来关闭IPS日志记录攻击特征详情功能。
IPS记录攻击特征详情功能处于关闭状态。
开启功能后,设备将缓存命中的攻击特征的详情信息,并记录在IPS日志中,方便用户了解特征详情。
攻击特征详情仅在KAFKA日志中体现,关于KAFKA日志配置的详细介绍请参见“快速日志输出配置指导”中的“配置快速日志输出到Kafka服务器”。
开启本功能后,会占用系统的内存资源,建议仅在关心攻击特征详细信息的情况下开启此功能。
# 开启IPS日志记录攻击特征详情功能。
[Sysname] inspect ips log-details signature-content enable
inspect log-details max-size命令用来配置内存中可缓存的IPS日志报文详情字段的存储空间上限值。
undo inspect log-details max-size命令用来恢复缺省情况。
inspect log-details max-size max-size-value
内存中可缓存的IPS日志报文详情字段的存储空间上限值由设备实际内存计算得出。
max-size-value:指定内存中可缓存的IPS日志报文详情字段的存储空间上限值,取值范围为1~524288,单位为MB。
工作机制
开启IPS日志记录报文详情功能后(通过inspect ips log-details enable命令配置),设备会使用内存来缓存报文中的HOST、URI等字段。当组网环境中存在大量HTTP报文时,可能会消耗大量的设备内存,导致设备整机的并发性能下降。此时,可通过调整内存中可缓存的IPS日志报文详情字段的存储空间上限值来控制对内存的占用。调低上限值,可降低对内存的消耗,但有些IPS日志中可能无法正常显示报文详情字段;调高此参数,可能会提升IPS日志显示报文详情字段的成功率,但同时会降低设备的并发性能。请管理员根据实际需求进行调整。
# 内存中可缓存的IPS日志报文详情字段的存储空间上限值为524288MB。
[Sysname] inspect log-details max-size 524288
·     inspect ips log-details enable
inspect logging parameter-profile命令用来创建应用层检测引擎的日志动作参数profile,并进入日志动作参数profile视图。如果指定的日志动作参数profile已经存在,则直接进入日志动作参数profile视图。
undo inspect logging parameter-profile命令用来删除应用层检测引擎的日志动作参数profile。
inspect logging parameter-profile parameter-name
undo inspect logging parameter-profile parameter-name
不存在日志动作参数profile。
profile-name:日志动作参数profile的名称,为1~63个字符的字符串,不区分大小写。
进入日志动作的参数profile视图后,可以配置生成报文日志时采用的特定参数,比如输出日志的方式。
# 创建名称为log1的应用层检测引擎的日志动作参数profile,并进入日志动作参数profile视图。
[Sysname] inspect logging parameter-profile log1
[Sysname-inspect-logging-log1]
·     log
inspect optimization disable命令用来关闭指定的应用层检测引擎的优化调试功能。
undo inspect optimization disable命令用来开启指定的应用层检测引擎的优化调试功能。
inspect optimization [ chunk | no-acsignature | raw | uncompress | url-normalization ] disable
undo inspect optimization [ chunk | no-acsignature | raw | uncompress | url-normalization ] disable
应用层检测引擎的所有优化调试功能处于开启状态。
chunk:表示应用层检测引擎对Chunk格式报文进行解码的优化调试功能。
no-acsignature:表示应用层检测引擎对没有关键字检测规则进行检测的优化调试功能。
raw:表示应用层检测引擎对未经解码TCP/UDP的应用层载荷字段进行检测的优化调试功能。
uncompress:表示应用层检测引擎对HTTP Body字段进行解压缩的优化调试功能。
url-normalization:表示应用层检测引擎对HTTP URL字段进行正规化校准的优化调试功能。
如果不指定任何参数,则表示关闭或开启应用层检测引擎的所有优化调试功能。
有关应用层检测引擎的各种优化调试功能的详细介绍如下:
·     应用层检测引擎对Chunk格式报文进行解码的优化调试功能:Chunk是HTTP协议载荷(Body)的一种传输方式,对于以Chunk方式传输的HTTP协议的载荷,需要先对其进行解码以获取真正的载荷内容。但是在某些应用场景下,设备的处理性能不能满足用户基本的通信需求,这时,关闭应用层检测引擎解码Chunk格式报文的功能,可以提高设备的吞吐量。但是配置关闭应用层检测引擎解码Chunk格式报文的功能后,应用层检测引擎对某些针对安全漏洞的攻击行为不能被识别。
·     应用层检测引擎对没有关键字检测规则进行检测的优化调试功能:没有关键字的检测规则是指此规则不是基于字符串匹配进行检测,而是基于报文的端口号、错误码等字段进行检测。缺省情况下应用层检测引擎对没有关键字的检测规则进行检测,但是在某些场景下,如果设备的吞吐量较差,不能满足客户基本的通信需求,此时可以配置应用层检测引擎对没有关键字的检测规则不进行检测,以提高设备的性能,保证用户最基础的网络通信。
·     应用层检测引擎对未经解码TCP/UDP的应用层载荷字段进行检测的优化调试功能:有些TCP/UDP数据流的应用层协议(例如HTTP、SMTP、POP3、IMAP4)涉及编码和解码处理,而对该类数据流的应用层内容的检测需要在对报文载荷进行解码之后进行。如果当前设备的处理性能不能满足用户基本的通信需求,可以通过该命令取消对未解码的应用层载荷字段的检测,以提高设备的吞吐量。但是配置此功能后,应用层检测引擎对报文载荷内容的应用或行为的识别能力会受到影响。
·     应用层检测引擎对HTTP Body字段进行解压缩的优化调试功能:如果报文的HTTP Body字段是压缩编码,应用层检测引擎需要先对HTTP Body字段进行解压缩后,才能对此字段的内容进行检测。但是在某些应用场景下,设备的处理性能不能满足用户基本的通信需求,这时,可以通过配置此命令来取消对HTTP Body字段的压缩编码进行解压缩处理,以提高设备的吞吐量。但是配置此功能后,应用层检测引擎对某些针对安全漏洞的攻击行为不能被识别。
·     应用层检测引擎对HTTP URL字段进行正规化校准的优化调试功能:对HTTP URL字段进行正规化校准功能是指把URL中绝对路径字调整为常规路径格式,对特殊的路径字段进行调整和正确性检查。例如报文URL中绝对路径部分输入的是test/dpi/../index.html,正规化处理后是test/index.html。但是在某些应用场景下,设备的处理性能不能满足用户基本的通信需求,这时,可以通过配置此命令来取消对HTTP URL字段进行正规化校准处理,以提高设备的吞吐量。但是配置此功能后,应用层检测引擎对某些针对安全漏洞的攻击行为不能被识别。
# 关闭应用层检测引擎的所有优化调试功能。
[Sysname] inspect optimization disable
inspect packet maximum命令用来配置应用层检测引擎可检测有载荷内容的报文的最大数目。
undo inspect packet命令用来恢复缺省情况。
inspect packet maximum max-number
undo inspect packet
应用层检测引擎可检测有载荷内容的报文的最大数目为32。
max-number:指定应用层检测引擎检测有载荷内容的报文的最大数目,取值范围为1~254。
应用层检测引擎在对一个数据流的第一个有载荷内容的报文进行检测时,如果没有匹配上任何检测规则,则需要继续检测此数据流的第二个有载荷内容的报文,以此类推。如果直到设备设置的最大报文检测个数还未匹配上任何检测规则,则表示对此数据流匹配失败,并直接允许此数据流通过。
通常,使用缺省配置即可满足应用需求。但是在某些应用场景中,应用层检测引擎在检测有载荷内容的报文的个数达到指定的个数之后,仍然不能识别当前报文应用层信息的应用或行为,此时需要调高这个参数。调高此参数后,设备的吞吐量性能会下降,但是应用识别的成功率会增加。同理在设备吞吐量较差,不能满足客户需求的应用场景中,此时需要调低这个参数,调低参数后,吞吐量会增加,但是应用识别成功率会降低。
# 配置应用层检测引擎可检测有载荷内容的报文的最大数目为16。
[Sysname] inspect packet maximum 16
inspect proxy-server命令用来配置DPI代理服务器相关参数。
undo inspect proxy-server命令用来恢复缺省情况。
inspect proxy-server { domain domain-name | ip ip-address } [ port port-number ] [ user user-name password { cipher | simple } string ]
未配置DPI代理服务器相关参数。
domain domain-name:指定代理服务器的域名。domain-name表示代理服务器的域名,为3~63个字符的字符串,区分大小写。
ip ip-address:指定代理服务器的IP地址,仅支持IPv4类型地址。
port port-number:指定代理服务器的端口号,取值范围为1~65535,缺省值为80。
user user-name:指定登录代理服务器的用户名。user-name表示用户名,为1~31个字符的字符串,区分大小写。
password:指定登录代理服务器的用户密码。
cipher:表示以密文方式设置密码。
simple:表示以明文方式设置密码,该密码将以密文形式存储。
string:密码字符串,区分大小写。明文密码为1~31个字符的字符串,密文密码为1~73个字符的字符串。
当DPI业务模块(例如URL过滤业务)需要配合云端服务器使用时,若设备不能连接到官方网站,则可配置一个代理服务器使设备连接到云端服务器,进行相应业务,比如防病毒云端查询、信誉云端查询、特征库在线升级等。
# 配置代理服务器域名为www.example.com,端口号为8888,登录代理服务器的用户名和密码均为admin。
[Sysname] inspect proxy-server domain www.example.com port 8888 user admin password simple admin
inspect raw-packet max-length命令用来配置应用层检测引擎对裸包的最大检测长度。
undo inspect raw-packet max-length命令用来恢复缺省情况。
应用层检测引擎对裸包的最大检测长度为32KB。
length-value:应用层检测引擎对裸包的最大检测长度,取值范围为1~1024,单位为KB。
工作机制
应用层检测引擎对裸包(即未经解码的TCP/UDP的应用层载荷字段)的检测会消耗大量的设备资源、降低设备处理性能,如需在开启裸包检测功能的同时降低对设备性能影响,可通过配置本命令限制应用层检测引擎对裸包的检测长度。
配置本功能后,设备将仅对阈值范围内的裸包内容进行检测,而忽略超出该长度的部分,可提高设备的处理速度和吞吐量,但是同时也可能使得部分潜在的安全威胁无法被成功识别。请根据实际情况配置本功能。
注意事项
本功能仅在开启了裸包检测功能后生效,即执行undo inspect optimization rawdisable命令。
# 配置裸包最大检测长度为128KB。
[Sysname] inspect raw-packet max-length 128
inspect record-filename nfs maximum命令用来配置应用层检测引擎记录NFS协议文件名数量的上限值。
undo inspect record-filename nfs命令用来恢复缺省情况。
inspect record-filename nfs maximum max-number
应用层检测引擎记录NFS协议文件名数量的上限值由设备实际内存计算得出。
max-number:指定应用层检测引擎记录NFS协议文件名数量的上限值,取值范围为0~4294967295。其中,当取值为0时,表示不对应用层检测引擎记录的NFS协议文件名数量进行限制。
应用层检测引擎在对文件进行检测时,会使用特定的存储结构记录文件名,用于展示在日志中,方便用户获取文件信息。该记录过程会占用一定的内存,且检测的文件数量越多,对内存占用就越大,可能会降低设备的并发性能。当实际组网环境中大量使用NFS协议传输文件时,管理员可通过配置本功能,限制应用层检测引擎记录的基于NFS协议传输的文件的文件名数量。在对设备并发性能要求较高的场景下,可减少记录的文件名数量,降低对内存的消耗;在对设备并发性能要求较低的场景下,可调高此参数,增加记录的文件名数量,方便用户获取更多的文件信息。请管理员根据实际需求配置此功能。
# 配置应用层检测引擎可记录NFS协议文件名数量的上限值为110000。
[Sysname] inspect record-filename nfs maximum 110000
inspect redirect parameter-profile命令用来创建应用层检测引擎的重定向动作参数profile,并进入重定向动作参数profile视图。如果指定的重定向动作参数profile已经存在,则直接进入重定向动作参数profile视图。
undo inspect redirect parameter-profile命令用来删除应用层检测引擎的重定向动作参数profile。
inspect redirect parameter-profile parameter-name
undo inspect redirect parameter-profile parameter-name
不存在重定向动作参数profile。
parameter-name:重定向动作参数profile的名称,为1~63个字符的字符串,不区分大小写。
进入重定向动作参数profile视图后,可以配置对报文执行重定向动作时采用的特定参数,比如对报文重定向的URL。
# 创建名称为r1的应用层检测引擎重定向动作参数profile,并进入重定向动作参数profile视图。
[Sysname] inspect redirect parameter-profile r1
[Sysname-inspect-redirect-r1]
inspect signature auto-update source命令用来配置特征库在线升级时发送给服务器的请求报文的源IP地址。
undo inspect signature auto-update source命令用来恢复缺省情况。
inspect signature auto-update source { ip | ipv6 } { ip-address | interface interface-type interface-number }
特征库在线升级时发送给服务器的请求报文的源IP地址为系统根据路由表项查找到的出接口的地址。
ip ip-address:指定特征库在线升级时发送给服务器的请求报文的源IPv4地址。
ipv6 ip-address:指定特征库在线升级时发送给服务器的请求报文的源IPv6地址。
interface interface-type interface-number:指定该接口的主IPv4地址或接口上最小的IPv6地址为源IP地址。
如果管理员希望特征库在线升级时发送给特征库服务器的请求报文的源IP地址是一个特定的地址时,则需要配置此命令。例如,当组网环境中设备发出的报文需要经过NAT地址转换后才能访问特征库服务器时,则需要管理员通过本命令指定一个符合NAT地址转换规则的IP地址(其中,如果设备需要经过一台独立的NAT设备进行地址转换时,本命令指定的IP地址必须可以与NAT设备三层路由可达),使设备发出的报文经由NAT地址转换后访问特征库服务器。
# 配置特征库在线升级时发送给服务器的请求报文的源IP地址为1.1.1.1。
[Sysname] inspect signature auto-update source ip 1.1.1.1
inspect smb-reassemble enable命令用来开启SMB协议报文重组功能。
undo inspect smb-reassemble enable命令用来关闭SMB协议报文重组功能。
SMB协议报文重组功能处于关闭状态。
大量的SMB协议的乱序报文极有可能会造成应用层检测引擎对此协议报文检测失败。为了提高应用层检测引擎对SMB协议报文检测的准确率,可以在设备上开启SMB协议报文重组功能。
当设备接收到乱序的SMB报文时,会将此报文和来自于同一条数据流的后续报文暂时保存至缓冲区,进行报文重组,完成重组后再送往后续流程处理。
# 开启SMB协议报文重组功能。
[Sysname] inspect smb-reassemble enable
inspect source-port-identify enable命令用来开启基于源端口的应用识别功能。
undo inspect source-port-identify enable命令用来关闭基于源端口的应用识别功能。
基于源端口的应用识别功能处于关闭状态。
如果网络中的流量种类单一、源端口固定,但无法通过目的端口对其进行基于端口的应用识别或无法基于流量特征进行内容识别时,可以开启本功能,对流量进行源端口识别,将源端口为固定端口的流量识别为访问特定类型应用的流量。
开启本功能后,可能会造成应用识别结果的误报,请管理员根据组网环境的实际情况配置。
# 开启基于源端口的应用识别功能。
<sysname> system-view
[sysname] inspect source-port-identify enable
inspect ssl san-detect enable命令用来开启SSL SAN检测功能。
undo inspect ssl san-detect enable命令用来关闭SSL SAN检测功能。
SSL SAN检测功能处于关闭状态。
应用场景
为增强网络环境中HTTPS报文的安全检测能力,特别是在涉及多域名或IP地址的复杂应用场景下,建议启用SSL SAN(Subject Alternative Name)检测功能。该功能可实现对SSL证书的全面验证,有效识别异常证书,从而防范中间人攻击等安全风险。
工作机制
本功能需要配合HTTPS流量过滤功能(https-filter enable)使用。启用后,设备将通过解析SSL加密报文中的SAN扩展字段,将其与用户实际请求的域名或IP地址进行比对验证,并与预设的URL过滤规则进行匹配,最终实现对加密流量的精准URL过滤控制。
# 开启SSL SAN检测功能。
[Sysname] inspect ssl san-detect enable
·     https-filter enable(DPI深度安全命令参考/URL过滤)
inspect stream-fixed-length命令用来配置应用层检测引擎对报文的最大检测长度。
undo inspect stream-fixed-length命令用来恢复缺省情况。
inspect stream-fixed-length { audio-video | dns | email | ftp | http | https | imaps | nfs | pop3s | quic | rtmp | sip | smb | smtps | telnet | tftp } * length
应用层检测引擎对FTP协议、HTTP协议、NFS协议、SMB协议、QUIC协议和与E-mail相关协议(包括SMTP、POP3和IMAP协议)报文最大检测长度与应用层检测引擎的检测率模式有关(通过inspect coverage命令配置),请以当前检测率模式的最大检测长度为准;对音频和视频类应用报文以及DNS协议、HTTPS协议、IMAPS协议、POP3S协议、RTMP协议、SIP协议、SMTPS协议、Telnet协议和TFTP协议报文的检测长度不进行限制。
audio-video:表示设置音视频应用报文的最大检测长度。
dns:表示设置DNS协议报文的最大检测长度。
email:表示设置与E-mail协议相关类型报文的最大检测长度,支持的E-mail协议包括SMTP、POP3和IMAP。
ftp:表示设置FTP协议类型报文的最大检测长度。
http:表示设置HTTP协议类型报文的最大检测长度。
https:表示设置HTTPS协议报文的最大检测长度。
imaps:表示设置IMAPS协议报文的最大检测长度。
nfs:表示设置NFS协议类型报文的最大检测长度。
pop3s:表示设置POP3S协议报文的最大检测长度。
quic:表示设置QUIC协议报文的最大检测长度。
rtmp:表示设置RTMP协议报文的最大检测长度。
smb:表示设置SMB协议类型报文的最大检测长度。
sip:表示设置SIP协议报文的最大检测长度。
smtps:表示设置SMTPS协议报文的最大检测长度。
telnet:表示设置Telnet协议报文的最大检测长度。
tftp:表示设置TFTP协议报文的最大检测长度。
length:表示设置报文的最大检测长度,取值范围为1~2048,单位为千字节。
调高此参数后,设备的吞吐量性能会下降,但是应用层信息识别的成功率会提高;同理调低参数后,设备的吞吐量会增加,但是应用层信息识别的成功率会降低。
# 配置应用层检测引擎对FTP协议类型报文的最大检测长度为35千字节,HTTP协议类型报文的最大检测长度为40千字节。
[Sysname] inspect stream-fixed-length ftp 35 http 40
·     inspect cpu-threshold disable
inspect stream-fixed-length disable命令用来关闭应用层检测引擎对报文的最大检测长度限制功能。
undo inspect stream-fixed-length disable命令用来开启应用层检测引擎对报文的最大检测长度限制功能。
应用层检测引擎对报文的最大检测长度限制功能处于开启状态。
本功能仅在应用层检测引擎检测率模式为自定义模式时(通过inspect coverage user-defined命令配置)支持配置。
本功能用于限制应用层检测引擎对协议报文和音视频应用报文的最大检测长度,当引擎已检测的报文长度达到限制值时,引擎将不对后续报文进行检测。
当组网环境中对应用层信息识别的成功率要求较高时,可通过关闭应用层检测引擎对报文的最大检测长度限制功能,提升应用层信息识别的成功率。
# 关闭应用层检测引擎对报文的最大检测长度限制功能。
[Sysname] inspect stream-fixed-length disable
inspect tcp-reassemble enable命令用来开启TCP数据段重组功能。
undo inspect tcp-reassemble enable命令用来关闭TCP数据段重组功能。
TCP数据段重组功能处于关闭状态。
大量的TCP乱序数据段极有可能会造成应用层检测引擎对此TCP数据流检测失败。例如应用层检测引擎需要检测TCP载荷中是否包含关键字“this is a secret”。由于数据段乱序,可能含有“a secret”的数据段先到达设备,含有“this is”的数据段后到达设备,这样就会造成应用层检测引擎对此TCP数据流检测失败。
为了提高应用层检测引擎对TCP数据流检测的准确率,可以在设备上开启TCP数据段重组功能。当接收到乱序的TCP数据段时,设备会将此数据段和来自于同一条数据流的后续数据段暂时保存至缓冲区,进行TCP数据段重组,完成数据段重组后再送往后续流程处理。
若缓冲区中已缓存的数据段数目达到最大值(可以通过inspect tcp-reassemble max-segment命令来配置)时仍无法成功重组,则设备直接将已缓存的乱序数据段和此条数据流的所有后续TCP数据段送往后续流程处理,不再进行TCP重组。这样可以降低对设备转发性能的影响。
# 开启TCP数据段重组功能。
[Sysname] inspect tcp-reassemble enable
·     inspect tcp-reassemble max-segment
inspect tcp-reassemble max-segment命令用来配置TCP重组缓冲区可缓存的TCP数据段最大数目。
undo inspect tcp-reassemble max-segment命令用来恢复缺省情况。
inspect tcp-reassemble max-segment max-number
TCP重组缓冲区可缓存的TCP数据段最大数目为10。
max-number:表示TCP重组缓冲区可缓存的TCP数据段最大数目,取值范围为10~50。
在存在大量TCP乱序数据段的网络环境中,调高此参数,则可提高应用层检测引擎对TCP数据段检测的准确率,但设备转发性能可能会下降。若调低此参数可避免因长时间缓存TCP数据段而造成设备转发性能下降,但应用层检测引擎对TCP数据段检测的准确率会降低。请根据实际情况调整此参数。
本命令仅在开启TCP数据段重组功能后生效。
# 配置TCP重组缓冲区中可缓存的TCP数据段最大数目为20。
[Sysname] inspect tcp-reassemble max-segment 20
·     inspect tcp-reassemble enable
inspect transparent enable命令用来开启应用层检测引擎透传DPI业务流量功能。
undo inspect transparent enable命令用来关闭应用层检测透传DPI业务流量功能。
应用层检测引擎透传DPI业务流量功能处于开启状态。
当组网环境中存在非对称流量时,即同一条流量的报文来回路径不一致,可能导致流量的正反向报文被送到不同的设备,这将会导致DPI业务无法正常处理,例如防病毒业务无法识别出病毒文件等。为了解决上述问题,应用层检测引擎默认会在设备间透传DPI业务流量,使同一条流量的正反向报文最终会被送到同一台设备。
但是,透传流量的过程会消耗设备资源,降低设备性能。当组网环境中对设备性能要求较高且可以接受损失一部分DPI业务检测准确性的风险时,可通过关闭应用层检测引擎透传DPI业务流量功能,降低对设备性能的影响。
# 关闭应用层检测引擎透传DPI业务流量功能。
[Sysname] undo inspect transparent enable
inspect uncompress maximum命令用来配置应用层检测引擎解压缩文件的总次数上限值。
undo inspect uncompress maximum命令用来恢复缺省情况。
inspect uncompress maximum max-number
应用层检测引擎解压缩文件的总次数上限值由设备实际内存计算得出。
max-number:指定应用层检测引擎解压缩文件的总次数的上限值,取值范围为0~4294967295。其中,当取值为0时,表示不对应用层检测引擎的解压缩文件总次数进行限制。
应用层检测引擎每进行一次解压缩操作都会消耗一定的设备内存。当解压缩的次数较多时,可能会消耗大量的设备内存,导致设备整机的并发性能下降。此时,可通过配置解压缩次数的上限值来控制对内存的占用。调低上限值,可降低对内存的消耗,但应用层检测引擎的检测成功率可能会降低;调高此参数,可能会提升应用层检测引擎的检测成功率,但同时会降低设备的并发性能。请管理员根据实际需求配置此功能。
# 配置应用层检测引擎解压缩文件的总次数上限值为120000。
[Sysname] inspect uncompress maximum 120000
inspect url-filter warning parameter-profile命令用来创建应用层检测引擎的URL过滤告警动作参数profile,并进入URL过滤告警动作参数profile视图。如果指定的URL过滤告警动作参数profile已经存在,则直接进入URL过滤告警动作参数profile视图。
undo inspect url-filter warning parameter-profile命令用来删除应用层检测引擎的URL过滤告警动作参数profile。
inspect url-filter warning parameter-profile profile-name
undo inspect url-filter warning parameter-profile profile-name
不存在URL过滤告警动作参数profile。
profile-name:URL过滤告警动作参数profile的名称,为1~63个字符的字符串,只支持数字、字母、下划线,不区分大小写。
创建URL过滤告警动作参数profile后,可通过导入告警文件的方式配置告警信息。
# 创建名称为c1的应用层检测引擎的URL过滤告警动作参数profile,并进入URL过滤告警动作参数profile视图。
[Sysname] inspect url-filter warning parameter-profile c1
[Sysname-inspect-url-filter-warning-c1]
·     import warning-file
inspect warning parameter-profile命令用来创建应用层检测引擎的防病毒告警动作参数profile,并进入防病毒告警动作参数profile视图。如果指定的防病毒告警动作参数profile已经存在,则直接进入防病毒告警动作参数profile视图。
undo inspect warning parameter-profile命令用来删除应用层检测引擎的防病毒告警动作参数profile。
inspect warning parameter-profile profile-name
undo inspect  warning parameter-profile profile-name
不存在防病毒告警动作参数profile。
profile-name:防病毒告警动作参数profile的名称,为1~63个字符的字符串,只支持数字、字母、下划线,不区分大小写。
创建防病毒告警动作参数profile后,可通过导入告警文件的方式配置告警信息。
# 创建名称为w1的应用层检测引擎的防病毒告警动作参数profile,并进入防病毒告警动作参数profile视图。
[Sysname] inspect warning parameter-profile w1
[Sysname-inspect-warning-w1]
·     import block warning-file
·     reset block warning-file
·     warning parameter-profile(DPI深度安全命令参考/防病毒)
1.1.56  log
log命令用来配置记录报文日志的方式。
undo log命令用来取消指定的记录报文日志的方式。
log syslog
undo log syslog
报文日志被输出到信息中心。
应用层检测引擎的日志动作参数profile视图
syslog:表示将日志输出到信息中心。
# 在名称为log1的应用层检测引擎日志动作参数profile中,配置将生成的报文日志输出到信息中心。
[Sysname-inspect-logging-log1] log syslog
·     inspect logging parameter-profile
1.1.57  log language
log language命令用来配置记录IPS日志使用的语言为中文。
undo log language命令用来恢复缺省情况。
log language chinese
undo log language chinese
记录报文日志使用的语言为英文。
执行本命令后,设备输出的日志中,仅IPS日志的威胁名称字段使用中文描述,其它日志信息仍然为英文。有关IPS日志的详情介绍,请参见“DPI深度安全命令参考”中的“IPS”。
# 在名称为log1的应用层检测引擎日志动作参数profile中,配置记录IPS日志使用的语言为中文。
[Sysname-inspect-log-para-log1] log language chinese
1.1.58  redirect-url
redirect-url命令用来配置重定向URL。
undo redirect-url命令用来恢复缺省情况。
redirect-url url-string
undo redirect-url
未配置重定向URL。
应用层检测引擎的重定向动作参数profile视图
url-string:表示重定向URL,为9~63个字符的字符串,区分大小写。该URL必须以http://或https://开头,例如https://www.example.com。
当需要把匹配成功的报文重定向到某个Web界面时,可以通过执行此命令来指定重定向URL。
# 配置重定向URL为https://www.example.com/upload。
[Sysname-inspect-redirect-r1] redirect-url https://www.example.com/upload
·     inspect redirect parameter-profile
reset block warning-file命令用来重置防病毒告警文件内容。
防病毒告警动作参数profile视图
本命令用来将防病毒告警文件中的告警信息重置为缺省文件中的告警信息。
# 在名称为w1的应用层检测引擎的防病毒告警动作参数profile中,重置告警文件内容。
[Sysname-inspect-warning-w1] reset block warning-file
reset inspect smb-breakpoint-resume table命令用来清除SMB协议断点续传表的信息。
reset inspect smb-breakpoint-resume table { ipv4 | ipv6 }
# 清除SMB协议断点续传表的信息。
<Sysname> reset inspect smb-breakpoint-resume table ipv4
·     display inspect smb-breakpoint-resume table
reset warning-file命令用来重置URL过滤告警文件内容。
reset warning-file
本命令用来将URL过滤告警文件中的内容恢复为缺省告警信息。
# 在名称为c1的应用层检测引擎的URL过滤告警动作参数profile中,重置URL过滤告警文件内容。
[Sysname-inspect-url-filter-warning-c1] reset warning-file
