02-PFC命令
本章节下载: 02-PFC命令 (341.63 KB)
1.1.1 display priority-flow-control
1.1.2 priority-flow-control (Ethernet interface view)
1.1.3 priority-flow-control (System view)
1.1.4 priority-flow-control deadlock auto-recover action
1.1.5 priority-flow-control deadlock auto-recover cos
1.1.6 priority-flow-control deadlock cos
1.1.7 priority-flow-control deadlock enable
1.1.8 priority-flow-control deadlock precision
1.1.9 priority-flow-control deadlock recover
1.1.10 priority-flow-control deadlock recover-mode
1.1.11 priority-flow-control deadlock threshold
1.1.12 priority-flow-control dot1p headroom
1.1.13 priority-flow-control dot1p ingress-buffer dynamic
1.1.14 priority-flow-control dot1p ingress-buffer static
1.1.15 priority-flow-control dot1p ingress-threshold-offset
1.1.16 priority-flow-control dot1p reserved-buffer
1.1.17 priority-flow-control early-warning inpps
1.1.18 priority-flow-control early-warning outpps
1.1.19 priority-flow-control no-drop dot1p (Ethernet interface view)
1.1.20 priority-flow-control no-drop dot1p (System view)
1.1.21 priority-flow-control config-style
1.1.22 priority-flow-control poolid headroom
设备支持通过hardware-resource voq-mode命令配置VOQ队列的模式,具体请参见“设备管理配置指导”中的“硬件资源管理”。当前支持配置4队列和8队列两种模式,不同队列模式下,CoS值与802.1p优先级的对应关系不同,具体如下:
· 当配置为4队列时,CoS 0 对应802.1p 0和802.1p 1,CoS 1对应802.1p 2和802.1p 3,CoS 2对应802.1p 4和802.1p 5,CoS 3对应802.1p 6和802.1p 7。此模式下,请勿将CoS值配置为4~7。
· 当配置为8队列时,CoS 0 对应802.1p 0,CoS 1对应802.1p 1,CoS 2对应802.1p 2,CoS 3对应802.1p 3,CoS 4 对应802.1p 4,CoS 5对应802.1p 5,CoS 6对应802.1p 6,CoS 7对应802.1p 7。
· 仅NCP支持PFC功能。
display priority-flow-control命令用来显示接口的PFC(Priority-based Flow Control,基于优先级的流量控制)信息。
display priority-flow-control interface [ interface-type [ interface-number ] ]
interface-type:显示指定类型接口的PFC信息。interface-type表示接口类型。不指定该参数时,则显示设备上所有以太网接口的PFC信息。
interface-number:显示指定接口的PFC信息。interface-number表示接口编号。不指定该参数时,显示设备上指定类型的以太网接口的PFC信息。
# 显示所有接口的PFC信息。
<Sysname> display priority-flow-control interface
Interface AdminMode OperMode Dot1pList Prio Recv Send Inpps Outpps DL DLRecover
400GE100/0/1 Enabled Enabled
表1-1 display priority-flow-control interface命令显示信息描述表
接口简名 |
AdminMode |
本地配置的PFC功能的状态 |
OperMode |
PFC功能状态的协商结果 |
Dot1pList |
开启PFC功能的802.1p优先级队列 |
Prio |
开启PFC功能的802.1p优先级 |
Recv |
对应优先级收到的流控事件数 |
Sent |
对应优先级发送的流控事件数 |
Inpps |
对应优先级入方向接收PFC帧的速率,单位为pps |
Outpps |
对应优先级出方向发送PFC帧的速率,单位为pps |
DL |
PFC死锁次数 |
DLRecover |
PFC死锁恢复次数 |
· priority-flow-control
· priority-flow-control no-drop dot1p
priority-flow-control命令用来配置接口的PFC功能。
undo priority-flow-control命令用来关闭PFC功能。
priority-flow-control { auto | enable [ receive | send ] }
PFC功能处于关闭状态。
以太网接口视图
auto:表示与对端自动协商是否开启PFC功能。
enable:表示强制开启PFC功能。
receive:表示开启报文接收方向的PFC功能。
send:表示开启报文发送方向的PFC功能。
如果本端和对端设备的PFC功能处于使能状态,并配置了priority-flow-control no-drop dot1p dot1p-list命令,则当本端收到的802.1p优先级在dot1p-list范围内的报文发生拥塞时,会通知对端设备暂时停止向本端发送对应优先级的报文;拥塞解除后,再通知对端继续发送对应优先级的报文。从而保证本设备在转发802.1p优先级在dot1p-list范围内的报文时不丢包。
报文接收方向的PFC功能是指设备仅能接收的PFC PAUSE帧,不能发送PFC PAUSE帧。报文发送方向的PFC功能是指仅能发送的PFC PAUSE帧,不能接收PFC PAUSE帧。当未指定receive和send参数时,表示开启报文接收方向和报文发送方向的PFC功能。
多次在系统视图和接口视图下执行本命令,最后一次执行的命令生效。
# 在以太网接口FourHundredGigE1/0/1上开启PFC功能。
[Sysname] interface fourhundredgige 1/0/1
[Sysname-FourHundredGigE1/0/1] priority-flow-control enable
· display priority-flow-control
· priority-flow-control (System view)
priority-flow-control命令用来开启所有接口的PFC功能。
undo priority-flow-control命令用来关闭所有接口的PFC功能。
PFC功能处于关闭状态。
enable:表示强制开启PFC功能。
# 开启所有接口的PFC功能。
[Sysname] priority-flow-control enable
· priority-flow-control (Ethernet interface view)
priority-flow-control deadlock auto-recover action命令用来配置设备在自动恢复PFC死锁检测的延迟时间内对报文的处理动作。
undo priority-flow-control deadlock auto-recover action命令用来恢复缺省情况。
priority-flow-control deadlock auto-recover action { discard | forwarding }
设备在自动恢复PFC死锁检测的延迟时间内转发收到的数据报文。
discard:丢弃收到的数据报文。
forwarding:转发收到的数据报文。
当设备进入PFC死锁状态后,用户可以使用本命令配置设备在自动恢复死锁检测的延迟时间内对数据报文丢弃或者转发。
# 配置当设备进入PFC死锁状态后对数据报文进行丢弃。
[Sysname] priority-flow-control deadlock auto-recover action discard
· priority-flow-control deadlock cos
· priority-flow-control deadlock enable
priority-flow-control deadlock auto-recover cos命令用来配置PFC死锁检测自动恢复的延迟周期。
undo priority-flow-control deadlock auto-recover cos命令用来删除PFC死锁检测自动恢复的延迟周期。
priority-flow-control deadlock auto-recover cos cos-value delay delay-time
undo priority-flow-control deadlock auto-recover cos [ cos-value ]
未配置PFC死锁检测的恢复周期。
cos cos-value:报文CoS值,取值范围为0~7。
delay delay-time:PFC死锁检测自动恢复的延迟周期,取值范围为50~1500。
PFC死锁检测功能可以按周期检测携带指定CoS值的报文是否发生死锁,在设备进入PFC死锁状态后,设备自动恢复时会在延迟周期结束后恢复PFC死锁检测功能。延迟恢复周期由auto-recover-delay delay-time和PFC死锁检测定时器的精度共同决定。
本命令仅在PFC死锁检测功能的恢复方式为自动恢复时生效。
指定的CoS值必须在priority-flow-control no-drop dot1p命令配置的802.1p优先级内。
对于不同CoS值可以配置相同的延迟恢复周期。
对于同一CoS值,多次执行本命令,最后一次执行的命令生效。
# 配置CoS值为1的PFC死锁自动恢复的延迟周期为50。
[Sysname] priority-flow-control deadlock auto-recover cos 1 delay 5
· priority-flow-control deadlock precision
priority-flow-control deadlock cos命令用来配置PFC死锁检测的周期。
undo priority-flow-control deadlock cos命令用来删除PFC死锁检测的周期。
priority-flow-control deadlock cos cos-value interval interval
undo priority-flow-control deadlock cos [ cos-value ]
未配置PFC死锁检测的周期。
interval interval:PFC死锁检测周期,取值范围为1~15。
PFC死锁检测功能可以按周期检测携带指定CoS值的报文是否发生死锁。检测周期由interval interval和PFC死锁检测定时器的精度共同决定。
本命令配置的PFC死锁检测的周期对所有队列均生效。
# 配置CoS值为1的PFC死锁检测周期为5。
[Sysname] priority-flow-control deadlock cos 1 interval 5
priority-flow-control deadlock enable命令用来开启PFC死锁检测功能。
undo priority-flow-control deadlock enable命令用来关闭PFC死锁检测功能。
PFC死锁检测功能处于关闭状态。
以太网接口视图
开启指定802.1p优先级的PFC功能后(通过priority-flow-control和priority-flow-control no-drop dot1p命令配置),当指定优先级的报文形成环路时,会导致数据缓冲区内报文无法转发,此时设备进入PFC死锁状态。
通过本命令开启或关闭某个端口的PFC死锁检测功能会联动其它端口同时开启或关闭PFC死锁检测功能,具体联动的端口可参见设备上打印的提示信息。
对一个端口进行死锁状态检测时,若发现多个队列处于死锁状态,只对最高优先级的队列进行上报。
通过配置本命令,可以定期检测设备是否处于PFC死锁状态,并解除PFC死锁状态。
# 在FourHundredGigE1/0/1下开启PFC死锁检测功能。
[Sysname-FourHundredGigE1/0/1] priority-flow-control deadlock enable
priority-flow-control deadlock precision命令用来配置PFC死锁检测定时器的精度。
undo priority-flow-control deadlock precision命令用来恢复缺省情况。
priority-flow-control deadlock precision { high | low | normal }
PFC死锁检测定时器的精度为普通精度。
high:表示使用高精度的PFC死锁检测定时器。
low:表示使用低精度的PFC死锁检测定时器。
normal:表示使用普通精度的PFC死锁检测定时器。
使用本命令可调整PFC死锁检测定时器的精度,从而控制PFC死锁检测时间。
# 配置PFC死锁检测定时器精度为高精度。
[Sysname] priority-flow-control deadlock precision high
priority-flow-control deadlock recover命令用来手工恢复PFC死锁检测功能。
以太网接口视图
当配置了手工恢复方式,设备能解除死锁状态,但同时死锁检测功能和PFC功能会暂时失效,需要手工执行本命令来恢复PFC死锁检测功能。恢复PFC死锁检测功能的同时可以让PFC功能继续生效。
# 在FourHundredGigE1/0/1下恢复PFC死锁检测功能。
[Sysname-FourHundredGigE1/0/1] priority-flow-control deadlock recover
· priority-flow-control deadlock recover-mode
priority-flow-control deadlock recover-mode命令用来配置PFC死锁检测功能的恢复方式。
undo priority-flow-control deadlock recover-mode命令用来恢复缺省情况。
priority-flow-control deadlock recover-mode { auto | manual }
PFC死锁检测功能恢复方式为自动恢复方式。
以太网接口视图
auto:配置PFC死锁检测功能的恢复方式为自动恢复。
manual:配置PFC死锁检测功能的恢复方式为手工恢复。
当设备检测到PFC死锁状态后,设备自动恢复时会在延迟周期结束后解除PFC死锁状态,恢复PFC功能和PFC死锁检测功能。在PFC死锁检测自动恢复的延迟周期内,设备将关闭PFC功能和PFC死锁检测功能,以便报文能够正常转发。PFC死锁状态解除后,用户可采用自动或手工方式来恢复PFC死锁检测功能。恢复PFC死锁检测功能会让PFC功能继续生效。所以,通常情况下,使用自动恢复方式即可。当报文环路无法消除,设备频繁处于PFC死锁状态时,用户可以使用手工恢复方式,并尽快排除故障,再执行priority-flow-control deadlock recover命令,恢复PFC死锁检测功能和PFC功能。
# 在FourHundredGigE1/0/1下配置PFC死锁检测功能恢复方式为手工恢复。
[Sysname-FourHundredGigE1/0/1] priority-flow-control deadlock recover-mode manual
priority-flow-control deadlock threshold命令用来配置在指定周期内发生PFC死锁的上限次数。
undo priority-flow-control deadlock threshold命令用来恢复缺省情况。
priority-flow-control deadlock threshold cos cos-value period period count count
undo priority-flow-control deadlock threshold cos [ cos-value ]
未配置指定周期内发生PFC死锁的上限次数。
period period:发生PFC死锁次数的检测周期,取值范围为1~60,单位为秒。
count count:指定周期内发生PFC死锁的上限次数,取值范围为1~500,单位为次数。
当配置该命令后,在指定周期内端口发生PFC死锁的次数达到配置值时,设备将关闭对应端口的PFC功能,此时用户需要排除故障手工执行undo priority-flow-control deadlock threshold命令恢复对应端口的PFC功能。
本命令配置的发生PFC死锁次数的检测周期需要大于priority-flow-control deadlock cos命令配置的PFC死锁检测周期,以便确认设备是否频繁处于PFC死锁状态。
对于不同CoS值可以配置相同的检测周期。
# 配置5秒周期内发生PFC死锁的上限次数为100。
[Sysname] priority-flow-control deadlock threshold cos 1 period 5 count 100
priority-flow-control dot1p headroom命令用来配置Headroom缓存门限。
undo priority-flow-control dot1p headroom命令用来恢复缺省情况。
priority-flow-control dot1p dot1p headroom headroom-number
undo priority-flow-control dot1p dot1p headroom
未配置Headroom缓存门限。
以太网接口视图
dot1p:802.1p优先级,取值范围为0~7。
headroom-number:Headroom缓存门限,256~300000000。
在配置本命令前,需执行priority-flow-control no-drop dot1p命令开启指定802.1p优先级的PFC功能,以及priority-flow-control enable命令开启接口的PFC功能。
多次执行本命令或者priority-flow-control no-drop dot1p (Ethernet interface view)命令,配置同一802.1p优先级的Headroom缓存门限,最后一次执行的命令中指定的headroom-number值生效。
当两个直接相连的接口传输数据时,需要使用接口的缓存空间来缓冲接收的数据。接口的传输距离越大,接口需要的数据缓存空间越大。可通过PFC功能配置设备在长距离传输的Headroom缓存门限,来实现报文的零丢弃。
# 配置Headroom缓存门限为1000。
<sysname> system-view
[Sysname-FourHundredGigE1/0/1] priority-flow-control dot1p 1 headroom 1000
priority-flow-control dot1p ingress-buffer dynamic命令用来配置动态反压帧触发门限。
undo priority-flow-control dot1p ingress-buffer dynamic命令用来恢复缺省情况。
priority-flow-control dot1p dot1p ingress-buffer dynamic ratio
undo priority-flow-control dot1p dot1p ingress-buffer
未配置动态反压帧触发门限。
以太网接口视图
ratio:动态反压帧触发门限,即可用空间的百分比,取值范围为0~90。
多次执行本命令,同一802.1p优先级的动态反压帧触发门限配置,最后一次执行的命令生效。
# 配置动态反压帧触发门限为30。
[Sysname-FourHundredGigE1/0/1] priority-flow-control dot1p 1 ingress-buffer dynamic 30
priority-flow-control dot1p ingress-buffer static命令用来配置静态反压帧触发门限。
undo priority-flow-control dot1p ingress-buffer static命令用来恢复缺省情况。
priority-flow-control dot1p dot1p ingress-buffer static threshold
未配置静态反压帧触发门限。
以太网接口视图
threshold:静态反压帧触发门限,取值范围为1024~200000000。
多次执行本命令,同一802.1p优先级的静态反压帧触发门限配置,最后一次执行的命令生效。
# 配置静态反压帧触发门限为1000。
[Sysname-FourHundredGigE1/0/1] priority-flow-control dot1p 1 ingress-buffer static 1000
priority-flow-control dot1p ingress-threshold-offset命令用来配置反压帧停止门限与触发门限间的偏移量。
undo priority-flow-control dot1p ingress-threshold-offset命令用来恢复缺省情况。
priority-flow-control dot1p dot1p ingress-threshold-offset offset-number
undo priority-flow-control dot1p dot1p ingress-threshold-offset
未配置反压帧停止门限与触发门限间的偏移量。
以太网接口视图
offset-number:反压帧停止门限与触发门限间的偏移量,取值范围为256~1000000。
# 配置反压帧停止门限与触发门限间的偏移量为1000。
[Sysname-FourHundredGigE1/0/1] priority-flow-control dot1p 1 ingress-threshold-offset 1000
priority-flow-control dot1p reserved-buffer命令用来配置PFC预留门限。
undo priority-flow-control dot1p reserved-buffer命令用来恢复缺省情况。
priority-flow-control dot1p dot1p reserved-buffer reserved-number
undo priority-flow-control dot1p dot1p reserved-buffer
未配置PFC预留门限。
以太网接口视图
reserved-number:PFC预留门限,取值范围为256~100000。
多次执行本命令或者priority-flow-control no-drop dot1p (Ethernet interface view)命令,配置同一802.1p优先级的PFC预留门限,最后一次执行的命令中指定的reserved-number值生效。
# 配置PFC预留门限为1000。
[Sysname-FourHundredGigE1/0/1] priority-flow-control dot1p 1 reserved-buffer 1000
priority-flow-control early-warning inpps命令用来配置入方向PFC报文的预警门限。
undo priority-flow-control early-warning inpps命令用来删除入方向PFC报文的预警门限。
priority-flow-control early-warning dot1p dot1p-list inpps pps-value
undo priority-flow-control early-warning [ dot1p dot1p-list ] inpps
未配置入方向PFC报文的预警门限。
以太网接口视图
dot1p dot1p-list:802.1p优先级(dot1p优先级)列表,例如:1,3-5。(表示数值区间时使用连字符“-”,数值之间用英文格式的逗号“,”分隔,最多可配置16个字符)
inpps pps-value:指定接口每秒接收的PFC帧数量,单位为pps,取值范围为1~159783010。
用户可根据实际组网情况,配置接口入方向PFC报文的预警门限。预警门限用于PFC报文传输速率处于正常范围内,但需要提醒用户提前关注的情况。
当接口接收PFC报文的速率达到预警门限时,系统会生成Trap和日志信息来提醒用户,以提前发现网络中的一些异常问题。例如:
· 对端设备网卡故障,不停地持续高速发送PFC帧,可以配置入方向预警门限进行监控。
· 本设备故障后不停发送PFC帧,可以配置出方向预警门限进行监控。
· 如果有双向监控需求的,可以在入和出方向都配置预警门限进行监控。
仅当PFC功能处于开启状态时,才会统计该接口接收的PFC帧数量,本命令配置的预警门限才能生效。
# 配置入方向802.1p优先级为7的PFC报文的预警门限为80pps。
[Sysname-FourHundredGigE1/0/1] priority-flow-control early-warning dot1p 7 inpps 80
priority-flow-control early-warning outpps命令用来配置出方向PFC报文的预警门限。
undo priority-flow-control early-warning outpps命令用来删除出方向PFC报文的预警门限。
priority-flow-control early-warning dot1p dot1p-list outpps pps-value
undo priority-flow-control early-warning [ dot1p dot1p-list ] outpps
未配置出方向PFC报文的预警门限。
以太网接口视图
outpps pps-value:指定接口每秒发送PFC帧数量,单位为pps,取值范围为1~159783010。
用户可根据实际组网情况,配置接口出方向PFC报文的预警门限。预警门限用于PFC报文传输速率处于正常范围内,但需要提醒用户提前关注的情况。
当接口发送PFC报文的速率达到预警门限时,系统会生成Trap和日志信息来提醒用户,以提前发现网络中的一些异常问题。例如:
仅当PFC功能处于开启状态时,才会统计该接口发送的PFC帧数量,本命令配置的预警门限才能生效。
# 配置出方向802.1p优先级为1的PFC报文的预警门限为50pps。
[Sysname-FourHundredGigE1/0/1] priority-flow-control early-warning dot1p 1 outpps 50
priority-flow-control no-drop dot1p命令用来开启指定802.1p优先级的PFC功能,并配置PFC门限。
undo priority-flow-control no-drop dot1p命令用来关闭指定802.1p优先级的PFC功能。
priority-flow-control no-drop dot1p dot1p-list [ pause-threshold { threshold-value | ratio threshold-ratio } [ headroom headroom-value | pause-threshold-offset offset-value | reserved-buffer reserved-value ] * ]
undo priority-flow-control no-drop dot1p [ dot1p dot1p-list ]
所有802.1p优先级的PFC功能都处于关闭状态。
以太网接口视图
dot1p-list:802.1p优先级(dot1p优先级)列表,例如:1,3-5(表示数值区间时使用连字符“-”,数值之间用英文格式的逗号“,”分隔,最多可配置16个字符)。如果执行undo命令时未指定本参数,则表示关闭所有802.1p优先级的PFC功能。
pause-threshold:指定反压帧触发门限。如果未指定本参数,则表示各个PFC门限采用缺省值。
threshold-value:以绝对值方式配置反压帧触发门限,取值范围为1024~200000000。
ratio threshold-ratio:以百分比方式配置反压帧触发门限,取值范围为1~90。
headroom headroom-value:表示指定队列的Headroom缓冲区资源上限,用cell个数表示,取值范围为256~300000000。
pause-threshold-offset offset-value:反压帧停止门限与触发门限间的偏移量,取值范围为256~1000000。
reserved-buffer reserved-value:表示指定队列的PFC预留门限,取值范围为256~1000000。
开启指定802.1p优先级的PFC功能后,会为PFC的各种门限设置一个缺省值,此缺省值在一般的组网环境下是效果较好的参数组合,不建议用户自行调整使用。
设备提供对PFC门限进行配置,合理利用接口存储空间。目前提供以下门限设置:
· Headroom缓存门限:Headroom是接口转发芯片上的一种存储空间,它里面包含更小的存储单元cell,用于缓存接口收到的报文。指定队列最多可使用的cell资源的个数后,当队列已使用的cell资源达到上限后,接口会丢弃收到的报文。
· 反压帧触发门限:Herdroom缓冲区中某802.1p优先级报文在该存储空间的使用cell资源上限。达到上限后,会触发PFC功能。反压帧触发门限的配置方式为:
¡ 绝对值方式:指定反压帧触发门限大小,即静态态反压帧触发门限。
¡ 百分比方式:指定反压帧触发门限百分比,即动态反压帧触发门限。
· 反压帧停止门限与触发门限间的偏移量:当触发反压帧触发门限后,当某802.1p优先级报文使用的cell资源减小了一个固定值时,不会再触发PFC功能。
· PFC预留门限:Herdroom缓冲区中为某802.1p优先级报文预留的cell资源。
# 在以太网接口FourHundredGigE1/0/1上配置PFC功能的开启模式为自动协商模式,并开启802.1p优先级5的PFC功能。
[Sysname-FourHundredGigE1/0/1] priority-flow-control auto
[Sysname-FourHundredGigE1/0/1] priority-flow-control no-drop dot1p 5
· priority-flow-control no-drop dot1p (System view)
priority-flow-control no-drop dot1p命令用来开启所有接口下指定802.1p优先级的PFC功能。
undo priority-flow-control no-drop dot1p命令用来关闭所有接口下指定802.1p优先级的PFC功能。
所有接口下802.1p优先级的PFC功能都处于关闭状态。
如果本端和对端设备的PFC功能处于使能状态,并配置了本命令,则当本端收到的802.1p优先级在dot1p-list范围内的报文发生拥塞时,会通知对端设备暂时停止向本端发送对应优先级的报文;拥塞解除后,再通知对端继续发送对应优先级的报文。从而保证本设备在转发802.1p优先级在dot1p-list范围内的报文时不丢包。有关802.1p优先级的介绍,请参见“ACL和QoS配置指导”中的“QoS”。
# 开启所有接口802.1p优先级5的PFC功能。
[Sysname] priority-flow-control no-drop dot1p 5
· priority-flow-control no-drop dot1p (Ethernet interface view)
priority-flow-control config-style命令用来配置802.1p优先级的PFC功能的显示风格。
undo priority-flow-control config-style命令用来恢复缺省情况。
priority-flow-control config-style { individual | unified }
PFC功能的显示风格为一体化显示风格。
individual:独立显示风格。
unified:一体化显示风格。
通过priority-flow-control no-drop dot1p命令配置指定802.1p优先级的PFC功能和PFC门限后,可以执行本命令修改接口下的显示风格:
· 指定individual参数时,采用独立显示风格。接口下显示风格为:
# 开启802.1p优先级5的PFC功能,并配置各个PFC门限。
[Sysname] priority-flow-control config-style individual
[Sysname-FourHundredGigE1/0/1] priority-flow-control no-drop dot1p 5 pause-threshold ratio 5 headroom 491 pause-threshold-offset 12 reserved-buffer 17
[Sysname-FourHundredGigE1/0/1] display this
interface FourHundredGigE1/0/1
port link-mode bridge
priority-flow-control dot1p 5 headroom 491
priority-flow-control dot1p 5 reserved-buffer 17
priority-flow-control dot1p 5 ingress-buffer dynamic 5
priority-flow-control dot1p 5 ingress-threshold-offset 12
return
· 指定unified参数时,采用一体化显示风格。接口下显示风格为:
[Sysname] priority-flow-control config-style unified
return
# 配置所有接口下802.1p优先级的PFC功能的显示风格为一体化显示风格。
<System> system-view
[System] priority-flow-control config-style unified
priority-flow-control poolid headroom命令用来配置服务池(Service Pool)的可使用的Headroom缓冲区资源上限。
undo priority-flow-control poolid headroom命令恢复缺省情况。
priority-flow-control poolid service-pool-id headroom headroom-number
undo priority-flow-control [ poolid service-pool-id ] headroom
服务池的可使用的Headroom缓冲区资源上限为16384字节。
poolid service-pool-id:Service Pool编号,取值为0。如果执行undo命令时未指定本参数,则表示所有Service Pool。
headroom-number:表示指定服务池可以使用的Headroom缓冲区资源上限,用cell(或字节)的个数表示,取值范围为256~300000000。
Headroom是接口转发芯片上的一种存储空间,它里面包含更小的存储单元cell,用于缓存接口收到的报文。通过本命令可以配置指定Service Pool最多可使用的cell资源的个数(或字节数)。当Service Pool已使用的cell资源(或字节数)达到本命令配置的值后,接口会丢弃收到的报文。
通常情况下,无需配置本命令,使用缺省情况即可。如需配置,请在专业人员的指导下进行。
# 配置Service Pool 0的最大可用cell资源数为10000。
[Sysname] priority-flow-control poolid 0 headroom 10000
· priority-flow-control no-drop dot1p(System view)
· priority-flow-control no-drop dot1p(Ethernet interface view)
