21-物联网命令参考
01-物联网AP命令
本章节下载: 01-物联网AP命令  (512.40 KB)
01-物联网AP命令
1 物联网AP
1.1 物联网AP配置命令
1.1.1 can speed
1.1.2 description
1.1.3 display iot module
1.1.4 display wlan module firmware-upgrade history
1.1.5 display wlan module-information
1.1.6 iot auto-module
1.1.7 iot auto-module persistent
1.1.8 iot auto-module persistent all
1.1.9 iot connect-aliyun
1.1.10 iot engine port-redistribute
1.1.11 iot engine-address
1.1.12 iot location module
1.1.13 iot location rssi
1.1.14 iot module led-mode
1.1.15 iot module-model engine-address
1.1.16 iot module-model engine-domain
1.1.17 iot packet length-field
1.1.18 iot packet format
1.1.19 iot report-format
1.1.20 iot report-mode
1.1.21 iot report-version
1.1.22 iot zigbee keepalive interval
1.1.23 module
1.1.24 module enable
1.1.25 module firmware-upgrade
1.1.26 port-type switch
1.1.27 rfid-tracking ble active-scan
1.1.28 rfid-tracking ble active-scan time-range
1.1.29 rfid-tracking ble advertisement
1.1.30 rfid-tracking ble advertisement { disable | enable }
1.1.31 rfid-tracking ble advertisement interval
1.1.32 rfid-tracking iot
1.1.33 rfid-tracking iot rssi threshold
1.1.34 rfid-tracking iot sampling interval
1.1.35 rfid-tracking iot sampling module
1.1.36 serial-number
1.1.37 tx-power
1.1.38 type
1.1.39 uart baudrate
1.1.40 wlan execute module firmware-upgrade
1.1.41 wlan execute module led-flash
1.1.42 wlan execute module reset
1.1.43 wlan execute module restore-factory
1.1.44 zigbee channel
1.1.45 zigbee encryption
1.1.46 zigbee endpoint profile-id
1.1.47 zigbee link- key
1.1.48 zigbee network-key
1.1.49 zigbee pan-id
1.1.50 zigbee permit-join duration
1 物联网AP
物联网AP支持情况与AP设备的型号有关,请以设备的实际情况为准。
1.1  物联网AP配置命令
1.1.1  can speed
can speed命令用来配置物联网模块的CAN链路速率。
undo can speed命令用来恢复缺省情况。
can speed { 500 | 1000 }
undo can speed
物联网模块CAN链路速率为500kbps。
Module视图
500:物联网模块CAN链路以500kbps速率工作。
1000:物联网模块CAN链路以1000kbps速率工作。
在AP和物联网模块通过有线网络连接的组网模型中,主节点(物联网AP下连的第一个物联网模块)与各个从节点(主节点下挂的其余所有物联网模块)之间使用CAN(Controller Area Network)总线协议通信,这段链路称为CAN链路。通过配置本命令可调整该CAN链路的数据传输速率。
当CAN链路在单位时间内需要传输更多数据时,可以通过配置本命令提高CAN链路速率。其余场景推荐使用缺省配置。
CAN链路以1000kbps速率工作时要求该链路长度不超过40米。
本命令仅支持在主节点上配置,从节点能够自动适应主节点的速率配置。
# 配置物联网AP ap1下挂的主节点的CAN链路速率为1000kbps。
[Sysname] wlan ap ap1 model uap300
[Sysname-ap-ap1] module 1
[Sysname-ap-ap1-module-1] can speed 1000
·     display wlan module-information
1.1.2  description
description命令用来配置物联网模块的描述信息。
undo description命令用来恢复缺省情况。
未配置物联网模块的描述信息。
Module视图
text:物联网模块描述信息,为1~64个字符的字符串,区分大小写。
当物联网AP安装或连接多个物联网模块时,可以根据物联网模块的型号、所处地理位置以及用途来配置描述信息,以便区别和管理各物联网模块。
# 配置物联网模块1的描述信息为L3-office。
[Sysname] wlan ap ap1 model WA4320i-X-R
[Sysname-wlan-ap-ap1] module 1
[Sysname-wlan-ap-ap1-module-1] description L3-office
display iot module命令用来显示物联网AP及其连接的物联网模块的信息。
display iot module { all | name ap-name }
all:显示所有带有IoT接口的物联网无线接入点及其连接的物联网模块的信息。
name ap-name:显示指定带有IoT接口的物联网无线接入点及其连接的物联网模块的信息。其中ap-name表示物联网无线接入点的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
# 显示所有带有IoT接口的物联网无线接入点及其连接的物联网模块的信息。
<System> display iot module all
AP name          : ap1
AP model         : UAP300
Serial ID        : 219801A0TA9154G01020
MAC address      : 00f0-e212-00f1
Modules          : 6
 Port ID: 3
  ModuleID   Model     SerialNumber          H/W Ver  S/W Ver  LastRebootReason
  2          T300M-X   T3001234567898765431  Ver.A    E1102    Other
  3          T300-X    T3001234567898765432  Ver.A    E1102    Power on
  4          T300-X    T3001234567898765433  Ver.A    E1102    Other
 Port ID: 4
  5          T300M-X   T3001234567898766541  Ver.A    E1102    Other
  6          T300-X    T3001234567898762584  Ver.A    E1102    Other
  7          T300-X    T3001234567898769654  Ver.A    E1102    Power on
AP name          : ap2
AP model         : UAP300
Serial ID        : 219801A0TA9154G01131
MAC address      : 00f1-e242-00f1
Modules          : 3
 Port ID: 3
  2          T300M-X   T3001234567898765435  Ver.A     E1102    Power on
  6          T300-X    T3001234567898765434  Ver.A     E1102    Power on
表1-1 display iot module all命令显示信息描述表
AP name
AP名称
AP model
AP型号
Serial ID
AP序列号
MAC address
AP的MAC地址
Modules
AP上连接的在线物联网模块个数
Port ID
物联网模块连接的AP端口的ID
ModuleID
物联网模块的ID
Model
物联网模块型号
SerialNumber
物联网模块序列号
H/W Ver
物联网模块硬件版本号
S/W Ver
物联网模块软件版本号
LastRebootReason
物联网模块上次重启的原因,取值包括:
·     Power on:断电重启
·     Soft reset:软重启
·     WDG:看门狗重启
·     CAN_TASK_FAIL:CAN任务创建失败重启
·     UART_TASK_FAIL:UART任务创建失败重启
·     DEV_TASK_FAIL:设备管理任务创建失败重启
·     EMAC_TASK_FAIL:ETH以太任务创建失败重启
·     RIPC:RIPC通道超时重启
·     Rate:CAN速率自适应失败重启
·     Scheduler:任务调度失败重启
·     Reserved:预留
·     Hard fault:CPU硬件失效重启
·     MPU fault:CPU存储管理错误重启
·     Bus fault:CPU总线错误重启
·     Usage fault:CPU错误应用重启
·     Other:预留
display wlan module firmware-upgrade history命令用来显示指定模块固件版本的升级信息。
display wlan module firmware-upgrade history { all | ap ap-name module module-id }
all:显示所有模块固件版本的升级信息。
ap ap-name:显示指定AP上的模块的固件版本的升级信息。ap-name表示AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
module-id:显示指定模块的固件版本升级信息。其中module-id为物联网模块ID,本参数的取值范围与AP型号有关,请以设备的实际情况为准。
本命令用于查看自AC设备启动以来,模块的固件版本手动升级的历史记录信息。模块固件版本手动或自动升级后的版本号可通过display wlan module-information命令查看。
# 查看所有模块的升级信息。
<Sysname> display wlan module firmware-upgrade history all
Total number of APs: 3
AP name  Module ID  Last upgrade time         Upgrade status  SW Version
ap1      1          Mon Nov  2 13:54:23 2015  Success         12-09-02-22
ap1      2          Mon Nov  2 13:54:23 2015  Upgrading       12-09-02-22
ap2      1          N/A                          N/A             12-09-02-22
ap3      1          Mon Nov  2 13:54:23 2015  Failed            12-09-02-22
表1-2 display wlan module firmware-upgrade history命令显示信息描述表
AP name
AP 名称
Module ID
模块 ID
Last upgrade time
上一次升级时间
Upgrade status
升级状态:
·     N/A:无信息
·     Succeeded:成功
·     Failed:失败
·     Upgrading:正在升级
SW Version
软件版本
display wlan module-information命令用来显示指定AP上的物联网模块信息。
display wlan module-information { all | ap ap-name module { all | module-id } } [ online ]
all:显示所有AP上的所有物联网模块信息。
ap ap-name:显示指定AP上的物联网模块信息。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
module all:显示所有物联网模块的信息。
module module-id:显示指定物联网模块的信息。其中module-id为物联网模块ID,本参数的取值范围与AP型号有关,请以设备的实际情况为准。
online:显示在线的模块信息。
# 显示ap1上物联网模块1的信息。
<Sysname> display wlan module-information ap ap1 module 1
Module administrative type     : RFID
Module physical type           : IOT
Model                          : EW100-R
HW version                     : Ver.A
SW version                     : A1101
Serial ID                      : 219801A19C816CE00020
Module MAC                     : d461-fefc-ff70
Module physical status         : Normal
Module administrative status   : Enabled
Description                    : Not configured
CAN speed                      : 500 kbps
UART baudrate                  : Auto
表1-3 display wlan module-information命令显示信息描述表
配置模块类型:
·     NotConfig:表示未配置
·     BLE:蓝牙模块类型
·     RFID:RFID模块类型
·     ZIGBEE:ZigBee模块类型
模块物理类型:
·     N/A:无信息
·     H3C:H3C模块
·     IOT:第三方模块
Model
模块型号信息,如果无法获取到模块的型号信息,显示N/A
HW version
模块硬件版本
SW version
模块软件版本
Serial ID
模块序列号
Module MAC
模块MAC地址
模块物理状态:
·     Unavailable:不可用
·     Normal:在位
·     Absent:不在位
配置模块状态:
·     Enabled:开启
·     Disabled:关闭
物联网模块的描述信息
CAN speed
物联网模块链路CAN速率,单位为kbps,包括以下取值:
·     500 kbps:CAN链路速率为500kbps
·     1000 kbps:CAN链路速率为1000kbps
本字段仅支持在主节点上显示
UART baudrate
物联网模块UART波特率,单位为B(baud),包括以下取值:
·     Auto:自适应波特率
·     115200 B(auto):自适应波特率为115200baud
·     921600 B(auto):自适应波特率为921600baud
·     115200 B:波特率使用固定值115200baud
·     921600 B:波特率使用固定值921600baud
本字段仅支持在物联网AP下挂的物联网模块上显示
iot auto-module enable命令用来开启物联网模块自动上线功能。
iot auto-module disable命令用来关闭物联网模块自动上线功能。
undo iot auto-module enable命令用来恢复缺省情况。
iot auto-module { disable | enable }
AP视图:继承AP组配置。
AP组视图:物联网模块自动上线功能处于关闭状态。
AP视图
AP组视图
开启本功能后,自动上线类型的物联网模块无需手工配置模块的序列号,即可完成自动上线。
本命令仅在物联网模块与通过网络连接的物联网AP连接时生效。
AP视图下的配置优先级高于AP组视图下的配置。
# 开启物联网模块自动上线功能。(AP视图)
[Sysname-wlan-ap-ap1] iot auto-module enable
# 开启物联网模块自动上线功能。(AP组视图)
[Sysname] wlan ap-group 10
[Sysname-wlan-ap-group-10] iot auto-module enable
iot auto-module persistent enable命令用来开启自动上线物联网模块固化功能。
iot auto-module persistent disable命令用来关闭自动上线物联网模块固化功能。
undo iot auto-module persistent enable命令用来恢复缺省情况。
iot auto-module persistent { disable | enable }
AP视图:继承AP组配置。
AP组视图:自动上线物联网模块固化功能处于关闭状态。
AP视图
AP组视图
开启本功能后,后续接入的自动上线物联网模块将自动固化为手工上线模块,且自动配置模块序列号。而此前已上线的自动上线物联网模块不会被固化为手工上线模块。
仅手工上线物联网模块支持参数配置,自动上线物联网模块不支持参数配置。
# 开启自动上线物联网模块固化功能。(AP视图)
[Sysname-wlan-ap-ap1] iot auto-module persistent enable
# 开启自动上线物联网模块固化功能。(AP组视图)
[Sysname-wlan-ap-group-10] iot auto-module persistent enable
iot auto-module persistent all命令用来将所有已上线的自动上线物联网模块固化为手工上线模块。
AP视图
AP组视图
配置本命令后,所有已上线的自动上线物联网模块将固化为手工上线模块,并且自动配置模块序列号。
本功能仅在物联网模块与通过网络连接的物联网AP连接时生效。
# 将所有已上线的自动上线物联网模块固化为手工上线模块。(AP视图)
[Sysname-wlan-ap-ap1] iot auto-module persistent all
# 将所有已上线的自动上线模块固化为手工上线模块。(AP组视图)
[Sysname-wlan-ap-group-10] iot auto-module persistent all
·     serial-number
iot connect-aliyun命令用来配置AP连接到阿里云物联网平台。
undo iot connect-aliyun命令用来恢复缺省情况。
iot connect-aliyun productkey key productsecret secret
AP视图:AP组有配置的情况下,继承AP组配置;AP组无配置的情况下,继承全局配置。
AP组视图:继承全局配置。
全局配置视图:未配置AP连接到阿里云物联网平台。
AP视图
AP 组视图
全局配置视图
productkey key:表示由阿里云物联网平台颁发的产品标识,为1~20个字符的字符串,区分大小写。
productsecret secret:表示由阿里云物联网平台颁发的产品密钥,为1~64个字符的字符串,区分大小写。
配置该命令后,AP会自动向阿里云物联网平台发起连接,阿里云物联网平台会根据配置的产品标识和产品密钥进行身份验证,如果认证成功,AP会连接到阿里云物联网平台,AP首次与阿里云物联网平台建立连接后,阿里云物联网平台会为AP下发设备密钥。
# 配置UAP300连接到阿里云物联网平台。(AP视图)
[Sysname] wlan ap ap1 model UAP300
[Sysname-ap-ap1] iot connect-aliyun productkey a1LybAwXSUL productsecret HG4I1BHKS0Rd4eR
# 配置UAP300连接到阿里云物联网平台。(AP组视图)
[Sysname-ap-group10] iot connect-aliyun productkey a1LybAwXSUL productsecret HG4I1BHKS0Rd4eR
# 配置UAP300连接到阿里云物联网平台。(全局配置视图)
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] iot connect-aliyun productkey a1LybAwXSUL productsecret HG4I1BHKS0Rd4eR
iot engine port-redistribute enable命令用来开启物联网服务器端口重分配功能。
iot engine port-redistribute disable命令用来关闭物联网服务器端口重分配功能。
undo iot engine port-redistribute命令用来恢复缺省情况。
iot engine port-redistribute { disable | enable }
AP组视图:继承全局配置。
全局配置视图:物联网服务器端口重分配功能处于关闭状态,物联网服务器不会重新分配端口。
AP视图
AP组视图
全局配置视图
开启本功能后,物联网AP周期性向物联网服务器发送端口重分配请求,以获得新的端口,在收到响应报文后停止发送请求报文。
当物联网服务器要求物联网AP与服务器新端口交互报文时,必须配置本功能获取新端口。
若因物联网服务器、物联网AP掉电或重启等原因导致分配的端口失效,则本功能需要先关闭再开启,以重新获得端口号。
AP视图下的配置优先级高于AP组视图下的配置,AP组视图下的配置优先级高于全局配置视图下的配置。
# 开启物联网服务器端口重分配功能。(AP视图)
[Sysname-wlan-ap-ap1] iot engine port-redistribute enable
# 开启物联网服务器端口重分配功能。(AP组视图)
[Sysname-wlan-ap-group-10] iot engine port-redistribute enable
# 开启物联网服务器端口重分配功能。(全局配置视图)
[Sysname-wlan-global-configuration] iot engine port-redistribute enable
·     iot engine-address
iot engine-address命令用来配置物联网服务器的IPv4地址和端口号。
undo iot engine-address命令用来恢复缺省情况。
iot engine-address engine-address engine-port engine-port
AP组视图:继承全局配置。
全局配置视图:未配置物联网服务器的IPv4地址和端口号。
AP视图
AP组视图
全局配置视图
engine-address:表示物联网服务器的IPv4地址。
engine-port:表示物联网服务器的端口号,取值范围为1~65535。
配置物联网服务器的IPv4地址和端口号后,AP上的物联网类型模块才可以和物联网服务器进行信息交互。
只有AP上安装有物联网类型的模块时,才需要进行本配置。蓝牙类型模块所使用的服务器由rfid-tracking ble engine-address engine-port命令指定,关于rfid-tracking ble engine-address engine-port命令的详细介绍,请参见“WLAN高级功能命令参考”中的“WLAN定位”。
# 配置物联网服务器的IPv4地址为192.168.10.10,端口号为3000。(AP视图)
[Sysname-ap-ap1] iot engine-address 192.168.10.10 engine-port 3000
# 配置物联网服务器IPv4地址为192.168.10.10,端口号为3000。(AP组视图)
[Sysname-ap-group10] iot engine-address 192.168.10.10 engine-port 3000
# 配置物联网服务器IPv4地址为192.168.10.10,端口号为3000。(全局配置视图)
[Sysname-wlan-global-configuration] iot engine-address 192.168.10.10 engine-port 3000
iot location module命令用来配置物联网模块的位置。
undo iot location module命令用来恢复缺省情况。
iot location module module-id-list1&<1-2> inside module-id-list2&<1-2> outside
未配置物联网模块的位置。
AP视图
module-id-list1&<1-2>:指定校内物联网模块的ID,&<1-2>表示前面的参数最多可以输入2次,取值范围与设备实际支持的最大模块个数有关请以设备实际情况为准。
inside:配置进出校检测功能中物联网模块的位置为校内。
module-id-list2&<1-2>:指定校外物联网模块的ID,&<1-2>表示前面的参数最多可以输入2次,取值范围与设备实际支持的最大模块个数有关请以设备实际情况为准。
outside:配置进出校检测功能中物联网模块的位置为校外。
当在同一物联网AP下同时指定了校内和校外的物联网模块之后,物联网AP会开启进出校检测功能。
# 指定进出校检测功能中物联网模块1、2的位置为校内物联网模块4、5的位置为校外。
[Sysname-wlan-ap-ap1] iot location module 1 2 inside 4 5 outside
·     rfid-tracking iot
·     iot location rssi
iot location rssi命令用来配置进出校检测功能的计算参数。
undo iot location rssi命令用来恢复缺省情况。
iot location rssi period period valid-rssi value diff-rssi value
计算RSSI平均值的周期为6秒,有效RSSI平均值为70,有效RSSI差值为5。
AP视图
period period:指定计算RSSI平均值的周期,取值范围为2~30,只能输入2的倍数,单位为秒。
valid-rssi value:表示有效RSSI平均值,取值范围为1~100,数值越小表示信号强度越强。
diff-rssi value:表示有效RSSI差值,校内物联网模块计算所得的RSSI平均值和校外物联网模块计算所得的RSSI平均值的差值需大于等于该有效RSSI差值,取值范围为1~100。
设备会根据手环的RSSI变化来判断手环的进出校,物联网模块每隔1秒上报1个手环的定位报文,物联网AP会在指定的取值周期内计算校内物联网模块的RSSI平均值和校外物联网模块的RSSI平均值,当计算的RSSI平均值存在差值并且差值大于设置的有效RSSI差值时,物联网AP会判定该数据为有效数据,并生成进校或者出校信息,将消息报文发送到云平台。
# 配置进出校检测功能,计算RSSI平均值的取值周期为8秒,有效RSSI平均值为75,有效RSSI差值为3。
[Sysname-wlan-ap-ap1] iot location rssi period 8 valid-rssi 75 diff-rssi 3
·     iot location module
·     rfid-tracking iot
iot module led-mode命令用来配置物联网模块上LED灯的闪烁模式。
undo iot module led-mode命令用来恢复缺省情况。
iot module led-mode { normal | quiet }
Module视图:继承AP组Module配置。
AP组Module视图:物联网模块上所有LED灯处于正常闪烁模式。
Module视图
AP组Module视图
normal:指定LED闪烁模式为normal模式,表示LED正常闪烁。
quiet:指定LED闪烁模式为quiet模式,表示所有LED常灭。
指定型号物联网AP下连的物联网模块上通常会有LED指示灯,normal模式下,不同阶段有不同的闪烁方式。如果LED的正常闪烁对用户产生了不必要的干扰,可通过本命令将其置为quiet模式。
# 配置物联网模块上LED灯处于normal模式。(Module视图)
[Sysname-wlan-ap-ap1-module-1] iot module led-mode normal
# 配置物联网模块上LED灯处于quiet模式。(AP组Module视图)
[Sysname] wlan ap-group g1
[Sysname-wlan-ap-group-g1] ap-model UAP300
[Sysname-wlan-ap-group-g1-ap-model-UAP300] module 1
[Sysname-wlan-ap-group-g1-ap-model-UAP300] iot module led-mode quiet
iot module-model engine-address命令用来为指定类型的物联网模块配置物联网服务器的地址和端口号。
undo iot module-model engine-address命令用来删除配置的物联网服务器的地址和端口号。
iot module-model { ew100-r | t100-a | t300bp0r | t300er0r | t300pb0u | t300rt0r | tp100-r} engine-address ip ipv4-address engine-port engine-port
iot module-model { t300-r| t300-z} engine-address { ip ipv4-address | ipv6 ipv6-address } engine-port engine-port
undo iot module-model { ew100-r | t100-a | t300-r| t300-z | t300bp0r | t300er0r | t300pb0u | t300rt0r | tp100-r} engine-address
未配置物联网服务器的地址和端口号。
AP视图
AP组视图
ew100-r:指定物联网模块类型为EW100-R。
t100-a:指定物联网模块类型为T100-A。
t300bp0r:指定物联网模块类型为T300BP0R。
t300er0r:指定物联网模块类型为T300ER0R。
t300pb0u:指定物联网模块类型为T300PB0U。
t300rt0r:指定物联网模块类型为T300RT0R。
tp100-r:指定物联网模块类型为T100-TP。
t300-r:指定物联网模块类型为T300-R。
t300-z:指定物联网模块类型为T300-Z。
ip ipv4-address:物联网服务器的IPv4地址。
ipv6 ipv6-address:物联网服务器的IPv6地址。
当不同的物联网模块混插在同一物联网AP下时,需要为不同的物联网模块配置对应的物联网服务器地址和端口号,连接到物联网AP的物联网模块才能与指定的物联网服务器进行信息交互。
# 为T300-R类型的物联网模块配置物联网服务器的地址为192.168.1.1,端口号为3155。(AP视图)
[Sysname-ap-ap1] iot module-model t300-r engine-address ip 192.168.1.1 engine-port 3155
# 为T300-R类型的物联网模块配置物联网服务器的地址为192.168.1.1,端口号为3155。(AP组视图)
[Sysname-ap-group10]  iot module-model t300-r engine-address ip 192.168.1.1 engine-port 3155
iot module-model engine-domain命令用来为指定类型的物联网模块配置物联网服务器的域名和端口号。
undo iot module-model engine-domain命令用来删除配置的物联网服务器的域名和端口号。
iot module-model { T300-R | T300-Z } engine-domain { ip | ipv6 } domain-name engine-port engine-port
undo iot module-model { T300-R | T300-Z } engine-domain
未配置物联网服务器的域名和端口号。
AP视图
AP组视图
T300-R:指定物联网模块类型为T300-R。
T300-Z:指定物联网模块类型为T300-Z。
ip:物联网服务器的IPv4域名。
ipv6:物联网服务器的IPv6域名。
domain-name:物联网服务器的域名,由“.”分隔的字符串组成,包括“.”在内,为1~253个字符的字符串,且每两个“.”之间的字符为1~63个字符的字符串。不区分大小写,字符串中可以包含字母、数字、“-”及下划线“_”。
# 为T300-R类型的物联网模块配置物联网服务器的域名为111,端口号为3155。(AP视图)
[Sysname-ap-ap1] iot module-model T300-R ip engine-domain 111 engine-port 3155
# 为T300-R类型的物联网模块配置物联网服务器的域名为111,端口号为3155。(AP组视图)
[Sysname-ap-group10] iot module-model T300-R ip engine-domain 111 engine-port 3155
iot packet length-field命令用来配置物联网模块的报文长度字段值。
undo iot packet length-field命令用来恢复缺省情况。
iot packet length-field { 8 | 6 }
Module视图:继承AP组配置。
AP组Module视图:物联网模块的报文长度字段值为8比特。
Module视图
AP组Module视图
8:物联网模块的报文长度字段值为8比特。
6:物联网模块的报文长度字段值为6比特。
不同物联网终端支持的报文长度可能不同,Length字段的取值需要根据实际使用的终端的类型进行设置。目前海康的终端只支持Length字段的取值为6比特,手环支持Length字段的值为8比特。
仅在物联网模块类型为RFID时支持配置本命令。
# 配置物联网模块的报文长度字段值为6比特。(Module视图)
[Sysname-wlan-ap-ap1-module-1] iot packet length-field 6
# 配置物联网模块的报文长度字段的值为6比特。(AP组Module视图)
[Sysname-wlan-ap-group-1] ap-model UAP300
[Sysname-wlan-ap-group-1-ap-model-UAP300] module 1
iot packet format命令用来配置物联网模块允许接收的报文格式。
undo iot packet format命令用来恢复缺省情况。
iot packet format { h3c | hik | marktrace }
物联网模块允许接收的报文格式为h3c。
Module视图
h3c:表示h3c报文格式。
hik:表示海康报文格式。
marktrace :表示华士精成报文格式。
# 配置物联网模块允许接收的报文格式为海康。
[Sysname-wlan-ap-ap1-module-1] iot packet format hik
iot report-format命令用来配置AP上报物联网报文的格式。
undo iot report-format命令用来恢复缺省情况。
iot report-format { general | transparent }
AP组视图:继承全局配置。
全局配置视图:AP上报物联网报文的格式为透传格式。
AP视图
AP组视图
全局配置视图
general:通用格式,上报的报文中包括物联网数据、AP MAC地址、模块ID等。
transparent:透传格式,上报的报文仅携带物联网数据。
用户需要根据物联网模块的类型选择合适的报文格式。例如,ANT模块使用通用格式,医惠模块使用透传格式。
# 配置AP上报物联网报文的格式为通用格式。(AP视图)
[Sysname-ap-ap1] iot report-format general
# 配置AP上报物联网报文的格式为通用格式。(AP组视图)
[Sysname-ap-group10] iot report-format general
# 配置AP上报物联网报文的格式为通用格式。(全局配置视图)
[Sysname]wlan global-configuration
[Sysname-wlan-global-configuration] iot report-format general
iot report-mode命令用来配置AP上报物联网报文的模式。
undo iot report-mode命令用来恢复缺省情况。
iot report-mode { central | local }
AP组视图:继承全局配置。
全局配置视图:AP上报物联网报文的模式为本地模式。
AP视图
AP组视图
全局配置视图
central:集中模式,即AP从物联网模块收到报文后进行封装,然后发送给AC,再由AC发送给物联网服务器或云平台。
local:本地模式,即AP从物联网模块收到报文后进行封装,而后直接发送给物联网服务器。
# 配置AP上报物联网报文的模式为集中模式(AP视图)
[Sysname-wlan-ap-ap1] iot report-mode central
# 配置AP上报物联网报文的模式为集中模式(AP组视图)
[Sysname-wlan-ap-group10] iot report-mode central
# 配置AP上报物联网报文的模式为集中模式。(全局配置视图)
[Sysname-wlan-global-configuration] iot report-mode central
iot report-version命令用来配置上报终端版本信息到云平台。
iot report-version rx-module rx-module-id tx-module tx-module-id endpoint-type { smart-card | tag | watch | wristband }
AP视图
rx-module rx-module-id:指定接收终端保活报文的模块,其中rx-module-ID为物联网模块ID,本参数的取值范围与AP型号有关,请以设备的实际情况为准。
tx-module tx-module-id:指定发送上传终端版本指令的模块,其中tx-module-ID为物联网模块ID,本参数的取值范围与AP型号有关,请以设备的实际情况为准。
endpoint-type:指定终端设备的类型。
smart-card:指定终端设备类型为智能卡。
tag:指定终端设备类型为标签。
watch:指定终端设备类型为手表。
wristband:指定终端设备类型为手环。
由于物联网模块是单双工的工作方式,所以需要配置不同的模块接收和发送报文,并且需要保证两个模块均为RFID模块,且信号覆盖范围相互重叠,接收终端保活报文的模块监听终端的保活报文,在监听到保活报文后发送上传终端版本指令的模块会向终端广播下发指令,使终端上报版本信息,最终呈现在云平台上。
# 上报标签版本信息到云平台。
[Sysname-wlan-ap-ap1] iot report-version rx-module 1 tx-module 2 endpoint-type tag
iot zigbee keepalive interval命令用来配置AP向ZigBee服务器发送保活报文的时间间隔。
undo iot zigbee keepalive interval命令用来恢复缺省情况。
iot zigbee keepalive interval interval
AP组配置:继承全局配置。
全局配置视图:发送保活的时间间隔为15秒。
AP视图
AP组视图
全局配置视图
interval:AP向ZigBee服务器发送保活报文的时间间隔,取值范围为1~3600,单位为秒。
AP和ZigBee服务器之间通过保活报文来刷新AP所在的私网到ZigBee服务器所在公网的NAT映射表项,如果长时间未刷新NAT映射表项,在NAT映射表项老化后会导致公网到私网的网络不通。
# 配置AP向ZigBee服务器发送保活报文的时间间隔为60秒。(AP视图)
[Sysname-wlan-ap-ap1]iot zigbee keepalive interval 60
# 配置AP向ZigBee服务器发送保活报文的时间间隔为60秒。(AP组视图)
[Sysname-ap-group10]iot zigbee keepalive interval 60
# 配置AP向ZigBee服务器发送保活报文的时间间隔为60秒。(全局配置视图)
[Sysname-wlan-global-configuration]iot zigbee keepalive interval 60
1.1.23  module
module命令用来进入Module视图。
module module-id
AP视图
AP组ap-model视图
module-id:物联网模块ID,本参数的取值范围与AP型号有关,请以设备的实际情况为准。
进入Module视图后可以对安装在AP上的物联网模块进行配置和管理。
# 进入Module视图。(AP视图)
# 进入AP组Module视图。(AP组ap-model视图)
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-apgroup1] ap-model WA4320i-X-R
[Sysname-wlan-ap-apgroup1-ap-model-WA4320i-X-R] module 1
[Sysname-wlan-ap-group-1-ap-model-WA4320i-X-R-module-1]
module enable命令用来启动物联网模块。
module disable命令用来禁用物联网模块。
undo module命令用来恢复缺省情况。
undo module
AP组Module视图:物联网模块处于禁用状态。
Module视图
AP组Module视图
Module视图下的配置优先级高于AP组Module视图下的配置。
# 启动物联网模块1。(Module视图)
[Sysname-wlan-ap-ap1-module-1] module enable
# 启动物联网模块1。(AP组Module视图)
[Sysname-wlan-ap-group-1] ap-model WA4320i-X-R
[Sysname-wlan-ap-group-1-ap-model-WA4320i-X-R] module 1
[Sysname-wlan-ap-group-1-ap-model-WA4320i-X-R-module-1] module enable
module firmware-upgrade enable命令用来开启物联网模块版本自动升级功能。
module firmware-upgrade disable命令用来关闭物联网模块版本自动升级功能。
undo firmware-upgrade命令用来恢复缺省情况。
module firmware-upgrade { disable | enable }
undo module firmware-upgrade
AP组Module视图:物联网模块版本自动升级功能处于开启状态。
Module视图
AP组Module视图
开启物联网模块版本自动升级功能后,AP会立即检查模块的软件版本与AP版本文件中的模块软件版本是否一致,如果不一致,则将模块的软件版本升级为AP版本文件中的软件版本。
物联网模块版本自动升级功能处于开启状态下,AP每次重启后都会执行上述模块版本升级操作。
在物联网模块版本升级期间,请不要对AP与物联网模块相连的接口进行shutdown操作。
# 开启物联网模块版本自动升级功能。(Module视图)
[Sysname-wlan-ap-ap1-module-1] module firmware-upgrade enable
# 开启物联网模块版本自动升级功能。(AP组Module视图)
[Sysname-wlan-ap-group-10] ap-model WA4320i-X-R
[Sysname-wlan-ap-group-10-ap-model-WA4320i-X-R] module 1
[Sysname-wlan-ap-group-10-ap-model-WA4320i-X-R-module-1] module firmware-upgrade enable
本命令的支持情况与物联网AP的型号有关,请以设备的实际情况为准。
port-type switch命令用来切换AP上物联网接口的接口类型。
undo port-type switch命令用来将指定物联网接口的类型恢复为缺省情况。
port-type switch number port-number { auto | gigabitethernet | iot }
undo port-type switch number port-number
AP视图:继承AP组ap-model配置。
AP组ap-model视图:AP上物联网接口的接口类型为Auto。
AP视图
AP组ap-model视图
number port-number:接口编号,取值范围与AP设备的型号有关,请以设备的实际情况为准。可选择多个接口,用空格分隔。
auto:将接口的接口类型切换为自适应。
gigabitethernet:将接口的接口类型切换为GigabitEthernet。
iot:将接口的接口类型切换为IoT(Internet of Things,物联网)。
当AP支持物联网接口时,该接口可以在Auto类型、IoT类型与GigabitEthernet类型间切换。Auto类型可以自动识别下连网络,自动切换接口类型。若明确需要通过网络连接物联网模块时,应将接口配置为IoT类型;若明确需要通过物联网接口连接以太网时,应将接口配置为GigabitEthernet类型。
AP视图下的配置优先级高于AP组ap-model视图下的配置。
# 将UAP300的接口3切换为GigabitEthernet类型。(AP视图)
[Sysname-wlan-ap-ap1] port-type switch number 3 gigabitethernet
# 将UAP300的接口3切换为GigabitEthernet类型。(AP组ap-model视图)
[Sysname-wlan-ap-group-1-ap-model-UAP300] port-type switch number 3 gigabitethernet
rfid-tracking ble active-scan enable命令用来开启BLE主动扫描功能。
rfid-tracking ble active-scan disable命令用来关闭BLE主动扫描功能。
undo rfid-tracking ble active-scan命令用来恢复缺省情况。
rfid-tracking ble active-scan { disable | enable }
Module视图:继承AP组Module视图配置。
AP组Module视图:BLE主动扫描功能处于关闭状态。
Module视图
AP组Module视图
# 开启BLE主动扫描功能。(Module视图)
[Sysname-wlan-ap-ap1] module-1
[Sysname-wlan-ap-ap1-module-1] rfid-tracking ble active-scan enable
# 开启BLE主动扫描功能。(AP组Module视图)
[Sysname-wlan-ap-group-1-ap-model-UAP300-module-1] rfid-tracking ble active-scan enable
·     rfid-tracking ble active-scan time-range
rfid-tracking ble active-scan time-range命令用来配置BLE主动扫描功能的工作时间段。
undo rfid-tracking ble active-scan time-range命令用来恢复缺省情况。
rfid-tracking ble active-scan time-range start-time to end-time
AP组Module视图:BLE主动扫描功能的工作时间段为00:00~24:00。
Module视图
AP组Module视图
start-time to end-time:指定周期时间段的范围start-time表示起始时间,格式为hh:mm,取值范围为00:00~23:59;end-time表示结束时间,格式为hh:mm,取值范围为00:01~24:00,且结束时间必须大于起始时间。
# 配置BLE主动扫描功能的工作时间段为06:00~08:00。(Module视图)
[Sysname-wlan-ap-ap1-module-1] rfid-tracking ble active-scan time-range 06:00 to 08:00
# 配置BLE主动扫描功能的工作时间段为06:00~08:00。(AP组Module视图)
[Sysname-wlan-ap-group-1-ap-model-UAP300-module-1] rfid-tracking ble active-scan time-range 06:00 to 08:00
rfid-tracking ble advertisement命令用来配置BLE模块的通告信息。
undo rfid-tracking ble advertisement命令用来恢复缺省情况。
rfid-tracking ble advertisement { major-id major-id | measured-power measured-power | minor-id minor-id | uuid uuid }
undo rfid-tracking ble advertisement { major-id | measured-power | minor-id | uuid }
AP组Module视图:BLE模块通告的UUID为E1CC5B618C06428E8720FE619DB80193,Major ID为1,Minor ID为1,Measured power为-58dBm。
Module视图
AP组Module视图
major-id major-id:BLE模块通告的Major ID,取值范围为0~65535。
measured-power measured-power:BLE模块通告的Measured power,取值范围为0~127,代表信号强度值的范围为-127~0dBm,取值越大表示的信号强度值越小。Measured power为通告接收设备在距iBeacon设备1米时测得的iBeacon设备的信号强度,用于计算通告接收设备与iBeacon设备间的距离。
minor-id minor-id:BLE模块通告的Minor ID,取值范围为0~65535。
uuid uuid:BLE模块通告的UUID,取值为32个字符的16进制数0~f。
物联网模块发送携带有Major ID、Minor ID、UUID和Measured power的通告信息,接收到该通告信息的应用软件会根据通告信息采取特定的行动以实现其软件功能。
# 配置BLE模块1通告的Major ID为4,Minor ID为4,UUID为34ae56115098ca67321a11256bca3007,Measured power为30。(Module视图)
[Sysname] wlan ap ap1 model WA4320-ACN-B
[Sysname-ap-ap1-module-1] rfid-tracking ble advertisement major-id 4
[Sysname-ap-ap1-module-1] rfid-tracking ble advertisement minor-id 4
[Sysname-ap-ap1-module-1] rfid-tracking ble advertisement uuid 34ae56115098ca67321a11256bca3007
[Sysname-ap-ap1-module-1] rfid-tracking ble advertisement measured-power 30
# 配置BLE模块1通告的Major ID为4,Minor ID为4,UUID为34ae56115098ca67321a11256bca3007,Measured power为30。(AP组Module视图)
[Sysname-wlan-ap-group-1] ap-model WA4320-ACN-B
[Sysname-wlan-ap-group-1-ap-model-WA4320-ACN-B] module 1
[Sysname-wlan-ap-group-1-ap-model-WA4320-ACN-B-module-1] rfid-tracking ble advertisement major-id 4
[Sysname-wlan-ap-group-1-ap-model-WA4320-ACN-B-module-1] rfid-tracking ble advertisement minor-id 4
[Sysname-wlan-ap-group-1-ap-model-WA4320-ACN-B-module-1] rfid-tracking ble advertisement uuid 34ae56115098ca67321a11256bca3007
measured-power 30
·     rfid-tracking ble advertisement
·     rfid-tracking ble advertisement interval
rfid-tracking ble advertisement enable命令用来开启BLE模块的通告发送功能。
rfid-tracking ble advertisement disable命令用来关闭BLE模块的通告发送功能。
AP组Module视图:BLE模块的通告发送功能处于关闭状态。
Module视图
AP组Module视图
开启BLE模块的通告发送功能后,BLE模块将广播iBeacon通告,iBeacon通告包含UUID、Major ID和Minor ID等内容。
该命令仅在BLE定位功能处于开启状态且物联网模块类型为蓝牙模块时才会生效。有关BLE定位功能的详细介绍请参见“WLAN高级功能配置指导”中的“WLAN定位”。
# 开启BLE模块1的通告发送功能。(Module视图)
[Sysname-ap-ap1-module-1] rfid-tracking ble advertisement enable
# 开启BLE模块1的通告发送功能。(AP组Module视图)
[Sysname-wlan-ap-group-1-ap-model-WA4320-ACN-B-module-1] rfid-tracking ble advertisement enable
·     rfid-tracking ble(WLAN高级功能命令参考/WLAN定位)
rfid-tracking ble advertisement interval命令用来配置BLE模块发送通告的时间间隔。
undo rfid-tracking ble advertisement interval命令用来恢复缺省情况。
rfid-tracking ble advertisement [ ad-number ] interval interval
undo rfid-tracking ble advertisement [ ad-number ] interval
AP组Module视图:BLE模块发送通告的时间间隔为1秒。
Module视图
AP组Module视图
ad-number:配置BLE模块的指定通告。若未指定本参数,则表示配置BLE模块通告1的发送时间间隔。
interval:发送通告的时间间隔,取值范围为50~1000,步长为10,单位为厘秒(100厘秒=1秒)。
# 配置BLE模块1发送通告的时间间隔为2秒。(Module视图)
[Sysname-ap-ap1-module-1] rfid-tracking ble advertisement interval 200
# 配置BLE模块1发送通告的时间间隔为2秒。(AP组Module视图)
[Sysname-wlan-ap-group-1-ap-model-WA4320-ACN-B-module-1] rfid-tracking ble advertisement interval 200
rfid-tracking iot enable命令用来开启IoT(Internet of Things,物联网)定位功能。
rfid-tracking iot disable命令用来关闭IoT定位功能。
undo rfid-tracking iot命令用来恢复缺省情况。
rfid-tracking iot { disable | enable }
AP组视图:继承全局配置。
全局配置视图:IoT定位功能处于关闭状态。
AP视图
AP组视图
全局配置视图
当需要物联网模块开启扫描并接收报文时,必须开启IoT定位功能。
开启IoT定位功能后:
·     物联网AP通过其上安装(或连接)的RFID模块识别手环发来的所有报文,并转发至云平台,云平台将根据上报的报文计算手环的大致位置。
·     物联网AP通过其上连接的ZigBee模块识别标准ZigBee设备(终端节点)发来的所有报文,并转发至云平台,云平台将根据上报的报文进行解析、存储。
# 开启IoT定位功能。(AP视图)
[Sysname-wlan-ap-ap1] rfid-tracking iot enable
# 开启IoT定位功能。(AP组视图)
[Sysname-wlan-ap-group-10] rfid-tracking iot enable
# 开启IoT定位功能。(全局配置视图)
[Sysname-wlan-global-configuration] rfid-tracking iot enable
rfid-tracking iot rssi threshold命令用来配置过滤定位报文的RSSI门限值。
undo rfid-tracking iot rssi threshold命令用来恢复缺省情况。
rfid-tracking iot rssi threshold rssi-threshold
Module视图:继承AP组配置。
AP组Module视图:未配置过滤定位报文的RSSI门限值。
Module视图
AP组Module视图
rssi-threshold:过滤定位报文的RSSI门限值,取值范围为-127~125。
该命令仅在模块类型配置为RFID或BLE时才允许配置。每款插卡实际范围如下表所示。若所配RSSI值不在插卡的实际范围之内,插卡会恢复默认配置即不过滤定位报文。
表1-4 插卡支持的取值范围表
插卡型号
RFID模式
BLE模式
T300-R
5~100
-127~20
T300-B
5~100
-127~20
T301-R
5~100
-127~20
# 配置过滤定位报文的RSSI门限值为30。(Module视图)
[Sysname-wlan-ap-ap1-module-1] rfid-tracking iot rssi threshold 30
# 配置过滤定位报文的RSSI门限值为30。(AP组Module视图)
[Sysname-wlan-ap-group-1-ap-model-UAP300-module-1] rfid-tracking iot rssi threshold 30
·     rfid-tracking iot
rfid-tracking iot sampling interval命令用来配置物联网模块上报定位报文的采样周期。
undo rfid-tracking iot sampling interval命令用来恢复缺省情况。
rfid-tracking iot sampling interval interval
物联网模块上报定位报文的采样周期为10秒。
AP视图
interval:物联网模块上报定位报文的采样周期,取值范围为2~60,单位为秒。
物联网AP会对物联网模块上报的定位报文进行采样并上报给AC,比如在配置采样周期为20后,物联网AP会在1~20个定位报文中选取其中RSSI最大的一个报文进行采样。
# 物联网模块上报定位报文的采样周期为5秒。
[Sysname-wlan-ap-ap1] rfid-tracking iot sampling interval 5
·     rfid-tracking iot sampling module
rfid-tracking iot sampling module命令用来开启物联网模块上报定位报文采样功能。
undo rfid-tracking iot sampling module命令用来关闭物联网模块上报定位报文采样功能。
rfid-tracking iot sampling module { all | module-id1 [ to module-id2 ] }
undo rfid-tracking iot sampling module { all | module-id1 [ to module-id2 ] }
物联网模块上报定位报文采样功能处于关闭状态。
AP视图
all:表示所有物联网模块。
module-id1:第一个指定ID并开启上报定位报文采样功能的物联网模块,不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
module-id2:最后一个指定ID并开启上报定位报文采样功能的物联网模块,不同型号的设备支持的取值范围不同,请以设备的实际情况为准,该参数取值不能小于module-id1。
开启IoT定位功能后,物联网手环缺省每秒上报一个定位报文到物联网模块,物联网模块将收到的定位报文通过物联网AP上报给AC,由AC对定位报文进行处理,在某些场景下物联网手环处于长期静止或者活动频率很低的状态,此时上报的定位报文过多会影响AC处理报文的整体性能,通过开启物联网模块上报定位报文采样功能,使物联网AP按照一定的频率对指定的物联网模块上报的定位报文进行采样,减少上报给AC处理的报文数量。
当物联网模块的报文长度字段值为6比特时,物联网模块上报定位报文采样功能不可用。
# 在物联网模块1上开启上报定位报文采样功能。
[Sysname-wlan-ap-ap1] rfid-tracking iot sampling module 1
·     rfid-tracking iot sampling interval
serial-number命令用来配置物联网模块的序列号。
undo serial-number命令用来恢复缺省情况。
serial-number serial-number
undo serial-number
未配置物联网模块的序列号。
Module视图
serial-number:指定物联网模块的序列号,序列号为每个物联网模块的唯一标识,为1~31个字符的字符串,不区分大小写。
当物联网模块是通过网络与AP连接,且配置的序列号和模块的序列号相匹配时,物联网模块才能在AP上完成手工上线;当物联网模块安装在AP上时,配置的序列号不生效,模块将直接在AP上上线。
对于通过网络与AP连接并上线的模块,改变和删除序列号将导致模块下线。
# 配置物联网模块的序列号为210235A1BSC123000050。
[Sysname-wlan-ap-ap1-module-1] serial-number 210235A1BSC123000050
1.1.37  tx-power
tx-power命令用来配置物联网模块的发送功率级别。
undo tx-power命令用来恢复缺省情况。
tx-power power-level}
undo tx-power
AP组Module视图:发送功率的级别为1,即模块的发送功率为4dBm。
Module视图
AP组Module视图
power-level:发送功率的级别,取值范围为1~4,功率级别和对应的功率值如下:
·     1级:4dBm
·     2级:-1dBm
·     3级:-5dBm
·     4级:-9dBm
物联网模块的发送功率支持功率级别和功率值两种配置方式。当用户需要的发送功率不是四个级别定义的功率时,可以根据物联网模块类型以及射频芯片等属性直接配置发送功率的数值。
# 配置模块1的发送功率级别为4。(Module视图)
[Sysname-ap-ap1-module-1] tx-power 4
# 配置模块1的发送功率级别为4。(AP组Module视图)
[Sysname-wlan-ap-group-1-ap-model-WA4320-ACN-B-module-1] tx-power 4
[Sysname] wlan ap ap1 model QX-W1110
[Sysname-wlan-ap-group-1] ap-model QX-W1110
[Sysname-wlan-ap-group-1-ap-model-QX-W1110] module 1
[Sysname-wlan-ap-group-1-ap-model-QX-W1110-module-1] tx-power 4
1.1.38  type
type命令用来配置AP支持的物联网模块类型。
undo type命令用来恢复缺省情况。
type { ble | rfid | uwb | zigbee }
undo type
AP组Module视图:未配置AP支持的物联网模块类型。
Module视图
AP组Module视图
ble:配置AP支持使用蓝牙类型的模块。
rfid:配置AP支持使用RFID类型的模块。
uwb:配置AP支持使用UWB类型的模块。
zigbee:配置AP支持使用ZigBee类型的模块。
只有配置了AP支持的物联网模块类型,并且配置的模块类型与AP上的物联网模块类型一致,物联网模块才能正常工作。
切换模块类型后,当前模块类型支持的所有命令行可配置,而不支持的命令行将被删除并且不可配置。
# 配置AP支持模块1的类型为ZigBee类型。(Module视图)
[Sysname-wlan-ap-ap1-module-1] type zigbee
# 配置AP支持模块1的类型为ZigBee类型。(AP组Module视图)
[Sysname-wlan-ap-group-1-ap-model-UAP300-module-1] type zigbee
uart baudrate命令用来配置物联网模块UART波特率。
undo uart baudrate命令用来恢复缺省情况。
uart baudrate { auto | 115200 | 921600 }
undo uart baudrate
物联网模块UART波特率自适应其上的插卡的波特率。
Module视图
auto:物联网模块串口自适应波特率。
115200:物联网模块串口以115200baud速率工作。
921600:物联网模块串口以921600baud速率工作。
物联网模块UART(Universal Asynchronous Receiver/Transmitter)波特率表示物联网模块串口通信速率。推荐使用自适应波特率配置,若已知物联网模块上的插卡的波特率,建议将物联网模块UART波特率配置为与之相同的固定波特率值。
# 配置物联网AP ap1下挂的模块1的UART波特率为自适应波特率。
[Sysname-ap-ap1-module-1] uart baudrate auto
wlan execute module firmware-upgrade命令用来手动升级模块版本。
wlan execute module firmware-upgrade ap ap-name module module-id firmware-path filepath
ap ap-name:升级指定AP上的模块。ap-name表示AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
module module-id:升级指定模块。其中module-id为物联网模块ID,本参数的取值范围与AP型号有关,请以设备的实际情况为准。
firmware-path filepath:设备上存放模块版本文件的路径。
当物联网模块版本自动升级功能处于开启状态时,若手动升级的模块版本与AP版本文件中的软件版本不同,则在重启AP后,AP会将物联网模块版本自动升级并覆盖手动升级的版本。因此,在执行本命令之前,请先使用module firmware-update disable命令关闭物联网模块版本自动升级功能。
# 从路径flash:/a.ipe中获取模块版本对ap1上的模块1的版本进行升级。
[Sysname] wlan execute module firmware-upgrade ap ap1 module 1 firmware-path flash:/a.ipe
·     display wlan module firmware-upgrade history
wlan execute module led-flash命令用来配置物联网模块上LED灯进行闪烁示意。
wlan execute module led-flash ap ap-name module module-id
ap ap-name:指定AP上的模块。ap-name表示AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
module module-id:指定模块上LED灯进行闪烁示意。其中module-id为物联网模块ID,本参数的取值范围与AP型号有关,请以设备的实际情况为准。
若需要查看指定物联网AP的指定Module对应的实际物联网模块所在位置,可通过配置本命令使该物联网模块上的所有LED灯进行持续20秒的闪烁,闪烁频率为每秒钟闪一次。
# 配置ap1的module 1对应的物联网模块的LED灯进行闪烁示意。
[Sysname] wlan execute module led-flash ap ap1 module 1
wlan execute module reset命令用来重启AP上的物联网模块。
wlan execute module reset ap ap-name module module-id
ap ap-name:重启指定AP上的物联网模块。ap-name表示AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
module module-id:重启指定物联网模块。其中module-id为物联网模块ID,本参数的取值范围与AP型号有关,请以设备的实际情况为准。
# 重启ap1上的物联网模块1。
[Sysname] wlan execute module reset ap ap1 module 1
本命令的支持情况与物联网模块的型号有关,请以设备的实际情况为准。
wlan execute module restore-factory命令用来将AP上的物联网模块恢复到出厂配置。
wlan execute module restore-factory ap ap-name module module-id
ap ap-name:将指定AP上的物联网模块恢复到出厂配置。ap-name表示AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
module module-id:将指定物联网模块恢复到出厂配置。其中module-id为物联网模块ID,本参数的取值范围与AP型号有关,请以设备的实际情况为准。
如需清除物联网模块上所有已有的配置,可配置本命令,恢复该物联网模块各参数的出厂配置。
本功能仅会清除物联网模块上已应用的配置,不会清除AC上Module视图下的配置。待物联网模块重启后,AC上Module视图下的所有配置会重新下发到物联网模块上。
此操作执行后,模块会立即重启,并恢复到出厂配置。
# 将ap1上的模块1恢复到出厂配置。
[Sysname] wlan execute module restore-factory ap ap1 module 1
zigbee channel命令用来配置ZigBee模块使用的工作信道。
undo zigbee channel命令用来恢复缺省情况。
zigbee channel channel-number
undo zigbee channel
AP组Module视图:ZigBee模块使用11号信道。
Module视图
AP组Module视图
channel-number:工作信道编号,取值范围为11~26。
ZigBee模块与标准ZigBee设备(终端节点)必须使用相同的工作信道才能完成连接。
# 配置ZigBee模块1使用20号信道。(Module视图)
[Sysname-wlan-ap-ap1-module-1] zigbee channel 20
# 配置ZigBee模块1使用20号信道。(AP组Module视图)
[Sysname-wlan-ap-group-1-ap-model-UAP300-module-1] zigbee channel 20
zigbee encryption enable命令用来开启ZigBee网络的加密功能。
zigbee encryption disable命令用来关闭ZigBee网络的加密功能。
undo zigbee encryption命令用来恢复缺省情况。
zigbee encryption { disable | enable }
ZigBee网络的加密功能处于关闭状态。
Module视图
开启/关闭ZigBee网络的加密功能由ZigBee终端决定,当ZigBee终端需要加密通信时,此时必须开启ZigBee网络的加密功能,加密采用AES-128加密算法。开启加密功能后,ZigBee网络内的设备以密文进行通信,保证了网络的安全性。
# 开启ZigBee网络的加密功能。
[Sysname-wlan-ap-ap1-module-1] zigbee encryption enable
zigbee endpoint profile-id命令用来配置ZigBee端点标识符和Profile ID。
undo zigbee endpoint profile-id命令用来恢复缺省情况。
zigbee endpoint identifier profile-id profile-id
undo zigbee endpoint identifier profile-id profile-id
AP组Module视图:ZigBee端点标识符与Profile ID均为1。
Module视图
AP组Module视图
identifierr:端点标识符,取值范围为数字1~240。
profile-id:Profile编号,取值范围为0~65535。
ZigBee模块与标准ZigBee设备(终端节点)必须配置相同的ZigBee端点和Profile ID才能正常通信。
# 配置ZigBee模块1的ZigBee端点标识符为30,Profile ID为200。(Module视图)
[Sysname-wlan-ap-ap1-module-1] zigbee endpoint 30 profile-id 200
# 配置ZigBee模块1的ZigBee端点标识符为30,Profile ID为200。(AP组Module视图)
[Sysname-wlan-ap-group-1-ap-model-UAP300-module-1] zigbee endpoint 30 profile-id 200
zigbee link-key命令用来配置ZigBee连接密钥。
undo zigbee link-key命令用来恢复缺省情况。
zigbee link-key { cipher | simple } string
以明文方式设置ZigBee连接密钥为ZigBeeAlliance0'。
Module视图
cipher:以密文方式设置ZigBee连接密钥。
simple:以明文方式设置ZigBee连接密钥,该密码将以密文形式存储。
string:密码字符串,区分大小写。明文密码为1~16个字符的字符串,每位字符用两位十六进制数表示,对应该字符的ASCII码,字符串样式为XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX。需要注意,不得包含ASCII码为0的字符。密文密码为1~53个字符的字符串。
ZigBee连接密钥用于在设备入网时,对给终端下发的ZigBee网络密钥进行加密,即仅在设备入网阶段匹配,若终端的连接密钥与配置相同则允许终端入网,若不匹配则不能入网。
# 配置ZigBee连接密钥为明文1234-1234-1234-1234-1234-1234-1234-1234。
[Sysname-wlan-ap-ap1-module-1] zigbee link-key simple 1234-1234-1234-1234-1234-1234-1234-1234
zigbee network-key命令用来配置ZigBee网络层密钥。
undo zigbee network-key命令用来恢复缺省情况。
zigbee network-key { cipher | simple } string
ZigBee 网络层密钥为明文0x01-0x03-0x05-0x07-0x09-0x0B-0x0D-0x0F-0x00-0x02-0x04-0x06-0x08-0x0A-0x0C-0x0D。
Module视图
cipher:以密文方式设置ZigBee网络层密钥。
simple:以明文方式设置ZigBee网络层密钥,该密码将以密文形式存储。
string:密码字符串,区分大小写。明文密码为固定16个字符的字符串,每位字符用两位十六进制数对应的ASCII码表示,字符串样式为XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX。需要注意,不得包含ASCII码为0的字符。密文密码为53个字符的字符串。
ZigBee网络层密钥用于ZigBee网络层加密,具体实现依赖ZigBee协议栈,命令行仅用于下发密钥。
# 配置ZigBee网络层密钥为明文1234-1234-1234-1234-1234-1234-1234-1234。
[Sysname-wlan-ap-ap1-module-1] zigbee network-key simple 1234-1234-1234-1234-1234-1234-1234-1234
zigbee pan-id命令用来配置ZigBee网络ID。
undo zigbee pan-id命令用来恢复缺省情况。
zigbee pan-id pan-id
undo zigbee pan-id
ZigBee网络ID为0~65534间的随机数,且不与已探测到的ZigBee网络ID相同。
Module视图
pan-id pan-id:ZigBee网络的标识符,取值范围为0~65534。
ZigBee模块与标准ZigBee设备(终端节点)连接之前,必须将本ZigBee模块的网络ID配置为对端ZigBee设备的网络ID。
为避免冲突,信号范围相互覆盖的ZigBee网络的网络ID不能相同。
# 配置ZigBee模块1的ZigBee网络ID为300。
[Sysname-wlan-ap-ap1-module-1] zigbee pan-id 300
zigbee permit-join duration命令用来配置允许ZigBee设备加入网络的时间。
zigbee permit-join duration time
不允许ZigBee设备加入网络。
Module视图
time:指定允许ZigBee设备加入网络的时间,取值范围为1~254,单位为秒。
当指定时间到期后,不允许ZigBee设备加入网络。
# 配置在10秒内允许ZigBee设备加入网络。
[Sysname-wlan-ap-ap1-module-1] zigbee permit-join duration 10
