07-常用命令介绍
01-H3C P3100 GPON OLT常用命令介绍
本章节下载 01-H3C P3100 GPON OLT常用命令介绍  (1.39 MB)
H3C P3100系列GPON OLT交换机
常用命令
Copyright © 2025 新华三技术有限公司 版权所有,保留一切权利。
本文档中的信息可能变动,恕不另行通知。
  录
1 CLI简介
1.1 CLI登录/注销
1.1.1 登录Login
1.1.2 注销Logout
1.2 CLI命令模式
1.2.1 EXEC
1.2.2 Privileged EXEC
1.2.3 CONFIG Management
1.2.4 CONFIG Terminal
1.3 CLI访问级别
1.4 CLI语法规范
1.5 如何获得帮助
1.6 热键
2 EXEC命令
2.1 enable
3 Privileged EXEC命令
3.1 clear counters
3.2 clear counters gpon-olt
3.2.1 clear counters gpon-olt ont
3.2.2 clear counters gpon-olt nni
3.2.3 clear counters gpon-olt ont-counts
3.3 clear counters giga-ethernet
3.4 clear counters link-aggregation
3.5 clear counters loopback
3.6 clear counters vlan
3.7 clear igmp-statistics
3.8 clear ip pppoe vlan-option statistics
3.9 clear pon-mac-addresses
3.10 clear mac-addresses
3.11 clear spanning- tree
3.12 configure management
3.13 configure terminal
3.14 debug
3.15 disable
4 Global命令
4.1 cls
4.2 exit
4.3 help
4.4 history
4.5 logout
4.6 ping
4.7 show
4.8 telnet
4.9 traceroute
4.10 tree
4.11 who
5 Configure Management命令
5.1 anti-attack
5.2 anti-mac-spoofing
5.3 apply-mgmt-access-list
5.4 apply-mgmt-acl-profile
5.5 banner
5.6 boot system flash
5.7 boot system ftp
5.8 bootrom-update
5.9 diagnose ont-info
5.10 diagnose optical-path
5.11 diagnose system
5.12 enable password
5.13 file-system chkdsk
5.14 file-system copy
5.15 file-system format
5.16 file-system list
5.17 file-system mkdir
5.18 file-system remove
5.19 file-system rename
5.20 filter-alarm
5.21 ftp
5.22 ip access-list
5.23 kill
5.24 logging alarm-threshold
5.25 logging console
5.26 logging flash
5.27 logging format
5.28 logging host
5.29 logging no host
5.30 modify-upgrade-ont-list
5.31 monitor pon olt-mismatch-monitor
5.32 monitor pon olt-pause-frames-monitoring
5.33 no cdr
5.34 no filter-alarm
5.35 onu-mngt-ip
5.36 out-band interface fast-ethernet ip address
5.37 pm interface
5.38 pon-routing
5.39 reboot
5.40 reload-upgrade-ont-list
5.41 save
5.42 set factory default
5.43 show-option
5.44 system access-node-id
5.45 system clock
5.46 system contact
5.47 system description
5.48 system device-id
5.49 system hostname
5.50 system ip-filter
5.51 system location
5.52 system management-ttl
5.53 system reserved-vlan-base
5.54 system timeout
5.55 system tpid
5.56 system vendor
5.57 temperature
5.58 tftp
5.59 uplink-mode
5.60 user accesslevel
5.61 user add
5.62 user delete
5.63 user password
5.64 user-auth-method
6 Configure Terminal命令
6.1 access-list
6.1.1 配置MAC ACL规则
6.1.2 配置IP标准ACL规则
6.1.3 配置IP扩展ACL规则
6.2 anti-rogueont
6.3 clear-alarm
6.4 clear-database-acl
6.5 export
6.6 host-route
6.7 import
6.8 interface gpon-olt
6.9 interface giga-ethernet
6.10 interface link-aggregation
6.11 no interface link-aggregation
6.12 interface loopback
6.13 no interface loopback
6.14 no interface pon-protection-group
6.15 interface pon-protection-group
6.15.1 member-ports
6.15.2 manual-switch
6.16 interface vlan
6.17 no interface vlan
6.18 Interface range
6.19 ip default-gateway
6.20 ip igmp mode
6.21 ip igmp parameter last-member-query-interval
6.22 ip igmp parameter query-interval
6.23 ip igmp parameter query-response-interval
6.24 ip igmp parameter robustness
6.25 ip igmp snooping
6.26 ip igmp static-group
6.27 ip igmp mode snooping-with-proxy
6.28 ip multicast vlan
6.29 ip multicast vlan-to-gem
6.30 ip multicast-routing
6.31 ip pppoe valn-option
6.32 ip sntp poll-interval
6.33 ip sntp sync
6.34 ip sntp time-zone
6.35 loop-detect ether-type
6.36 loop-detect interval
6.37 loop-detect recover-time
6.38 mac-address-table aging-time
6.39 mac-address-table static
6.40 mac-filter
6.41 mls qos
6.42 monitor
6.43 no gpon profile mac-filter
6.44 no gpon profile multicast-dynamic
6.45 no gpon profile multicast-oper
6.46 no gpon profile multicast-static
6.47 no gpon profile multicast-userview
6.48 no gpon profile dba
6.49 no gpon profile voip-sip-server
6.50 no gpon profile rate-ctrl
6.51 no gpon profile vportsvc
6.52 no gpon profile tcont-svc
6.53 no gpon profile tcont-bind
6.54 no gpon profile flow
6.55 olt-opm
6.55.1 alarm
6.55.2 olt-port
6.55.3 ont
6.55.4 status
6.55.5 time
6.56 gpon
6.56.1 ont authentication
6.56.2 show ont-authentication-mode
6.56.3 profile
6.56.4 show gpon profile dba
6.56.5 Show gpon profile rate-ctrl
6.56.6 show gpon profile vportsvc
6.56.7 show gpon profile tcont-svc
6.56.8 show gpon profile tcont-bind
6.56.9 show gpon profile flow
6.56.10 show gpon profile multicast-oper
6.56.11 show gpon profile multicast-static
6.57 ont-upgrade
6.57.1 auto-upgrade
6.57.2 manual-upgrade
6.57.3 upgrade-ftp
6.58 service sntp client
6.59 sntp server
6.60 spanning-tree mode
6.61 spanning-tree vlan
6.62 user-isolation
6.63 vlan
6.63.1 name
6.63.2 member
6.63.3 pvid
6.63.4 ip igmp snooping
6.64 vlan-option
6.65 vlan-range
7 GE 接口命令
7.1 interface giga-ethernet
7.1.1 add-to
7.1.2 apply-access-list
7.1.3 apply-acl-profile
7.1.4 auto-negotiation
7.1.5 delete-from vlan
7.1.6 description
7.1.7 flowcontrol
7.1.8 ingress-filter
7.1.9 interface-mode
7.1.10 ip address
7.1.11 ip igmp last-member-query-interval
7.1.12 ip igmp query-interval
7.1.13 ip igmp query-response-interval
7.1.14 ip igmp robutness
7.1.15 ip igmp startup-query-interval
7.1.16 ip igmp static-group
7.1.17 ip igmp unsolicited-report-interval
7.1.18 ip igmp version
7.1.19 ip igmp-proxy
7.1.20 ip multicast filter
7.1.21 ipg
7.1.22 max-frame
7.1.23 mls qos
7.1.24 mls qos map trust
7.1.25 mls qos map dscp-cos
7.1.26 mls qos map dscp-mutation
7.1.27 mls qos map ip-prec-dscp
7.1.28 mls qos queue-set
7.1.29 pvid
7.1.30 rate-limit
7.1.31 shutdown
7.1.32 spanning-tree link-type
7.1.33 spanning-tree mst <mst-id> cost
7.1.34 spanning-tree mst <mst-id>port-priority
7.1.35 spanning-tree portfast
7.1.36 spanning-tree vlan <vlan-id> cost
7.1.37 spanning-tree vlan <vlan-id> port-priority
7.1.38 spanning-tree vlan <vlan-id> portfast
7.1.39 storm-control
7.1.40 switchport
8 Link Aggregation命令
8.1 interface link-aggregation
8.1.1 add-to vlan
8.1.2 apply-access-list
8.1.3 apply-acl-profile
8.1.4 delete-from vlan
8.1.5 description
8.1.6 flowcontrol
8.1.7 ingress-filter
8.1.8 ip address
8.1.9 ip igmp last-member-query-interval
8.1.10 ip igmp query-interval
8.1.11 ip igmp query-response-interval
8.1.12 ip igmp robutness
8.1.13 ip igmp startup-query-interval
8.1.14 ip igmp static-group
8.1.15 ip igmp unsolicited-report-interval
8.1.16 ip igmp version
8.1.17 ip igmp-proxy
8.1.18 ip multicast filter
8.1.19 load-balance
8.1.20 max-frame
8.1.21 member
8.1.22 mls qos
8.1.23 mls qos map
8.1.24 mls qos map dscp-cos
8.1.25 mls qos map dscp-mutation
8.1.26 mls qos map ip-prec-dscp
8.1.27 mls qos queue-set
8.1.28 pvid
8.1.29 shutdown
8.1.30 spanning-tree link-type
8.1.31 spanning-tree mst <mst id> cost
8.1.32 spanning-tree mst <mst id>port-priority
8.1.33 spanning-tree portfast
8.1.34 spanning-tree vlan <vlan-id> path-cost
8.1.35 spanning-tree vlan <vlan-id> priority
8.1.36 storm-control
8.1.37 switchport
9 Loopback命令
9.1 interface loopback
9.1.1 description
9.1.2 ip address
9.1.3 shutdown
10 Interface Range命令
10.1 interface range
10.1.1 mls qos
10.1.2 mls qos map trust
10.1.3 mls qos map dscp-cos
10.1.4 mls qos map dscp-mutation
10.1.5 mls qos map ip-prec-dscp
10.1.6 mls qos queue-set
10.1.7 pvid
10.1.8 switchport
11 Interface VLAN命令
11.1 interface vlan
11.1.1 apply-access-list
11.1.2 apply-acl-profile
11.1.3 description
11.1.4 ip address
11.1.5 ip igmp last-member-query-interval
11.1.6 ip igmp query-interval
11.1.7 ip igmp query-response-interval
11.1.8 ip igmp robutness
11.1.9 ip igmp startup-query-interval
11.1.10 ip igmp static-group
11.1.11 ip igmp unsolicited-report-interval
11.1.12 ip igmp version
11.1.13 ip igmp-proxy
11.1.14 member-vlan
11.1.15 shutdown
11.1.16 super-svi
12 Interface GPON-OLT命令
12.1 interface gpon-olt
12.1.1 active
12.1.2 deactive
12.1.3 all-ont
12.1.4 description
12.1.5 disable
12.1.6 enable
12.1.7 fec-tx
12.1.8 key-exchange ctrl
12.1.9 key-exchange-interval
12.1.10 ont-discovery-mode
12.1.11 ont-discovery-interval
12.1.12 transceiver type
12.1.13 ont
12.1.14 no ont
12.1.15 pon-max-distance
12.1.16 reset
12.1.17 shutdown
12.1.18 vlantranslate
13 ONT命令
13.1.1 ont
13.1.2 reset
13.1.3 activate
13.1.4 deactivate
13.1.5 description
13.1.6 show ont-info
13.1.7 virtual-port
13.1.8 no virtual-port
13.1.9 eth-uni activate/deactivate
13.1.10 eth-uni config
13.1.11 eth-uni poe
13.1.12 no eth-uni
13.1.13 fec-tx
13.1.14 ip-host
13.1.15 no ip-host
13.1.16 loop-detect
13.1.17 mac-filter
13.1.18 no mac-filter
13.1.19 mac-limit
13.1.20 multicast
13.1.21 no multicast
13.1.22 enable
13.1.23 disable
13.1.24 ont-pots-uni
13.1.25 no ont-pots-uni
13.1.26 port-vlan
13.1.27 no rate-limit
13.1.28 rate-limit downstream
13.1.29 rate-limit upstream
13.1.30 rogue-ont
13.1.31 service
13.1.32 no service
13.1.33 vlan-filter
13.1.34 no vlan-filter
14 Show命令
14.1 show access-lists
14.2 show acl-applied-interface
14.3 show alarm
14.4 show alarm-filter
14.5 show alarm-history
14.6 show alarm-log
14.7 show anti-rogueont
14.8 show banner
14.9 show boot
14.10 show clock
14.11 show configuration
14.12 show cpld
14.13 show cpu
14.14 show database-acl-record
14.15 show event-log
14.16 show fan
14.17 show gpon profile
14.18 show host-route
14.19 show interface description
14.20 show interface gpon-olt..broadcast gem-port
14.21 show interface gpon-olt..counters gemport
14.22 show interface gpon-olt..counters mulitcast
14.23 show interface gpon-olt..counters nni
14.24 show interface gpon-olt..ont
14.25 show interface gpon-olt..gpon-link
14.26 show interface gpon-olt..key-exchange-ctrl
14.27 show interface gpon-olt..key-exchange-interval
14.28 show interface gpon-olt..ont..brief
14.29 show interface gpon-olt..ont..capability
14.30 show interface gpon-olt..ont..eth-uni
14.31 show interface gpon-olt..ont..loop-detect
14.32 show interface gpon-olt..ont..mac-address
14.33 show interface gpon-olt..ont..mac-filter
14.34 show interface gpon-olt..ont..optical-info
14.35 show interface gpon-olt..ont..port-vlan
14.36 show interface gpon-olt..ont..profile
14.37 show interface gpon-olt..ont..summary
14.38 show interface gpon-olt..ont..uni-status
14.39 show interface gpon-olt..ont..virtual-port
14.40 show interface gpon-olt..ont-performance
14.41 show interface gpon-olt..ont-range.. mac-address
14.42 show interface gpon-olt..ont-range.. brief
14.43 show interface gpon-olt..ont-range..capability
14.44 show interface gpon-olt..ont-range..loop-detec
14.45 show interface gpon-olt..ont-range..summary
14.46 show interface link-aggregation
14.47 show interface gpon-olt..ont-registered
14.48 show configuration running interface-gpon-olt
14.49 show interface gpon-olt..ont-unbound
14.50 show interface gpon-olt..counters
14.51 show interface gpon-olt…optical-info
14.52 show interface gpon-olt..pon-max-distance
14.53 show interface gpon-olt..transceiver type
14.54 show interface giga-ethernet..counters
14.55 show interface giga-ethernet..optical-info
14.56 show interface giga-ethernet..switchport
14.57 show interface loopback
14.58 show interface management in-band
14.59 show interface pon-protection-group
14.60 show interface super-vlan
14.61 show interface vlan
14.62 show ip igmp debug-traces
14.63 show ip igmp snooping
14.64 show ip igmp static-group
14.65 show ip igmp statistics
14.66 show ip interface brief
14.67 show ip pppoe vlan-option statistics
14.68 show ip sntp
14.69 show leds
14.70 show link-aggregation summary
14.71 show mac-address-table
14.72 show mac-age-time
14.73 show mac-filter
14.74 show management ip route
14.75 show memory
14.76 show mls qos
14.77 show mls qos maps
14.78 show mls qos queue-set
14.79 show monitor session
14.80 show multicast-group-author
14.81 show multicast-log
14.82 show multicast-vlan
14.83 show multicast-vlan-to-multi-gem
14.84 show ont-authentication-mode
14.85 show ont-unbound
14.86 show onu-upgrade
14.87 show pm
14.88 show preview-group
14.89 show spanning-tree mst
14.90 show spanning-tree vlan
14.91 show syslog
14.92 show system
14.93 show task
14.94 show temperature
14.95 show user
14.96 show user-isolation
14.97 show version
14.98 show vlan
14.99 show ont-info
15 缩写术语
1 CLI简介
该手册介绍H3C P3108和P3116的CLI命令。
1.1  CLI登录/注销
CLI管理PC的COM口可通过Console线直连到P3116串口。通过运行终端仿真程序(如Windows 超级终端)设置如下属性:
每秒比特:115200bps
数据位:8
奇偶校验:无
停止位:1
流量控制:无
登录P3116后会出现下一节中描述的提示。
1.1.1  登录Login
以下是通过Telnet登录P3116的例子:
从Windows开始菜单选择[开始/运行],输入以下命令。缺省的端口号为23:
> telnet 192.168.2.251
建立与P3116的连接后,屏幕会出现以下POST提示:
Username:
Password:
如果没有出现POST提示,应检查网络连接。输入用户名和口令:
Login: admin
Password: *****
对于P3116,缺省的管理员用户名和口令都是admin。guest(只读)的用户名和口令都是guest。
输入正确的用户名和口令后,会出现以下系统提示,表示登录成功,系统将进入EXEC命令模式接口。根据用户账户的权限,可以进入不同的CLI命令模式。
telnet@P3116>
1.1.2  注销Logout
有两种注销CLI的方式(正常退出与异常退出)。
·     正常退出
任何命令模式都可以采用logout命令终止当前的CLI连接。
·     异常退出
异常退出包括任何连接的断开,包括在配置时段内用户没有任何操作,发生超时中断。
1.2  CLI命令模式
CLI命令分为以下模式:
1.2.1  EXEC
EXEC: 允许用户查看基本系统信息并对连接进行核实,但不允许更改配置。
EXEC和较低的模式中,命令提示为telnet@P3116>
Privileged EXEC: 除了允许用户访问所有EXEC模式命令外,还允许访问不要求保存的配置命令。Privileged EXEC用户不能访问系统配置文件。通过在EXEC提示框中输入enable可以访问Privileged EXEC模式。
在Privileged EXEC 模式中,命令提示为telnet@P3116#
管理配置模式允许对P3116执行管理任务。可以在Privileged EXEC模式输入configure management进入该模式。
Management Configuration(管理配置)模式的提示为telnet@P3116(config-mgmt)#
CONFIG Terminal: 该命令模式允许用户更改设备配置。更改的配置可保存到闪存并在重启时恢复。CONFIG 命令模式包含单个端口、VLAN和其他配置区域的子模式。在Privileged EXEC提示框中输入config terminal 可进入Global Configuration (全局配置)模式。请参考CLI命令模式及提示。
Global Configuration(全局配置)模式的提示为telnet@P3116(config-t)#
1. OLT子配置
OLT子配置模式允许对特定的OLT逻辑参数进行逐个端口的分配和修改。在Global Configuration模式输入interface gpon-olt <module/port>可进入该模式。
OLT Configuration(OLT配置)模式的提示为telnet@P3116(config-if-gpon-olt-module/port)#
2. ONT子配置
ONT子配置模式允许配置ONU逻辑端口信息。在OLT配置模式输入ont <logical-port>可进入该模式。
ONU Configuration(ONU配置)模式的提示为telnet@P3116(config-if-gpon-ont-module/port/logicalport)#
表1-1 CLI命令模式和提示
CLI命令模式
提示
配置内容
访问方法
访问控制
EXEC
telnet@P3116>
允许用户查看系统基本信息并对连接进行查验,例如:ping。
登录
本地账户验证
Privileged EXEC
telnet@P3116#
允许用户访问所有的EXEC模式命令,也允许访问不需保存的配置命令。
在EXEC模式输入enable[口令]
如果设置了口令,则必须输入。
配置P3116管理参数。
在Privileged EXEC模式输入configure management 命令。
输入exit返回Privileged EXEC模式。
Terminal Configuration
配置pon参数。
在Privileged EXEC模式输入configure terminal命令。
OLT sub Configuration
telnet@P3116(config-t-if-olt-1/1)#
配置OLT参数。
在configure terminal模式输入interface epon-olt <module/port>命令。
输入exit返回configure terminal模式。
Gigabit interface sub Configuration
telnet@P3116(config-t-if-ge-1/1)#
配置千兆以太网参数。
在configure terminal模式输入interface giga-ethernet <module/port>命令。
linkAggreration interface sub Configuration
telnet@P3116(config-t-if-lg-1)#
配置链路汇聚参数。
在configure terminal模式输入interface link-aggregation <linkid>命令。
Interface range sub Configuration
telnet@P3116(config-t-if-range-ge2/1-3)#
配置范围参数。
在configure terminal模式输入interface range <rangeid>命令。
Interface loopback sub Configuration
telnet@P3116(config-t-if-lpb-1)#
配置环回参数。
在configure terminal模式输入interface loopback <lookbackid>命令。
VLAN sub Configuration
telnet@P3116(config-t-vlan-333)#
配置VLAN参数。
在configure terminal模式输入接口vlan<vlanid>命令。
ONU upgrade sub Configuration
telnet@P3116(config-t-onu-ugp)#
配置ONU升级参数。
在configure terminal模式输入onu-upgrade命令。
ONU sub Configuration
telnet@P3116(config-if-gpon-ont-1/1/1)#
配置ONU参数。
在配置OLT子模式输入onu<onuid>命令。
输入exit返回配置OLT子模式。
退出CLI说明:
退出(exit):该命令用于退出当前模式并返回下一级模式。如果当前模式为EXEC命令模式,CLI连接会终止。
注销(logout):该命令用于从任何命令模式终止当前的CLI连接。
1.3  CLI访问级别
每个命令都有一个访问级别(0、1、2、10)。以下是访问级别的说明:
访问级别:
0:只读用户:只能读取配置信息
1:端口级用户:用户有权进行端口级别的配置读/写访问,但不允许更改系统配置。
2:Power用户:用户可以控制整个系统,但不包括其他登录账户的配置。
10:管理员:用户可以控制整个系统,包括其他登录账户的配置。
1.4  CLI语法规范
CLI命令包括命令本身以及必需的和/或可选的参数。为了精确地表示完整的CLI命令,采用以下规范:
语法:static-mac-address <MAC-addr> {vlan <VLAN-ID>} {port <port-num>} [cos <value>]
说明:
·     黑体字符表示命令本身或命令关键字
·     “<>”中的文本为必选参数
·     “{}”中的文本为带关键字的必选参数
·     “[]”中的文本为可选参数
·     “<>”或 “[]”之外的文本为命令关键字或命令本身
·     “|”分隔的多个可选项为多选的必选参数,表示必须选择其中一项。
根据以上定义的规范,命令statis-mac-address<MAC-addr>为必选参数,{vlan <VLAN-ID>}为带关键字的必选参数,[cos <value>]为可选参数(cos为关键字)。第一个命令中的enable|disable为多选的必选参数。
1.5  如何获得帮助
P3116 CLI提供各种帮助和快捷键。表1-2列出了CLI提供的主要帮助信息。
表1-2 如何获得帮助
方法
功能
在任何LCI命令级别输入“?”。
显示该命令级别的所有可用命令。
缩略命令项+“?”。
显示特定字符串开始的命令列表(命令与问号之间没有空格)。
命令+空格+“?”。
显示命令的完整语法和简要说明。
缩略命令项+<tab>
系统会自动完成该命令中当前关键字的整个输入。
如果输入的命令和/或关键字不完整,但其长度足够使系统识别该命令,
系统会执行该局部命令,与完整命令一样。
在任何LCI命令级别输入“tree”。
显示树型格式的CLI命令级别的所有可用命令。
“Ctrl-P”或向上光标键↑
调用最新的输入命令。用户可采用“↑”查看最后的20个命令。
历史
输入history显示最新的30个命令。
当命令+“?”显示有<cr>但回车无法下发,表明该命令行参数配置不完整,需要继续补充其他参数后再下发。
例1
telnet@P3116> ?
enable               - Turn on privileged commands
 cls                  - Clear the screen
 exit                 - Exit intermediate mode
 help                 - Description of the interactive help system
 history              - Show command history
 logout               - Log off this system
 ping                 - Ping command
 show                 - Show running system information
 telnet               - Telnet to host
 traceroute           - Trace route to destination
 tree                 - Show command tree
 who                  - Display users currently logged in
telnet@P3116>
2
telnet@P3116(config-t)#exp + ?
export
telnet@P3116(config-t)#export
3
telnet@P3116# configure t + <Tab>
telnet@P3116# configure terminal
1.6  热键
表1-3 热键
热键
功能
Enter
执行命令/输入中间模式
Ctrl-z
输入命令并返回根提示框。如果没有输入命令,将返回根提示框。
Ctrl-e
将光标移到一行字符的结尾。
Esc-b
将光标向后移一个字。
Esc-f
将光标向前移一个字。
Backspace
光标左移同时删除字符,直到删除整行字符。
Ctrl-d
删除当前字符。
Ctrl-u
删除光标前的文本。
Ctrl-k
删除光标后的文本。
Ctrl-a
将光标移到一行字符的开始。
Esc-d
删除该字的剩余部分。
Ctrl-w
删除光标前的字。
Ctrl-p
获取前一个命令历史。
Ctrl-n
获取下一个命令历史。
Up arrow
向上逐个查看命令历史。
Down arrow
向下逐个查看命令历史。直到出现当前命令。
Ctrl-t
将当前字符与上一个字符换位。
2 EXEC命令
2.1  enable
该命令用于激活privileged EXEC级别。如果用户的访问级别等于或大于2,那么不需要检查激活口令。
语法:enable
访问级别:0
说明:激活privileged EXEC级别。
3 Privileged EXEC命令
3.1  clear counters
语法:clear counters
访问级别:2
说明:将系统中的所有计数器清零。
语法:clear counters gpon-olt <1/port>|<all>
取值范围:
<1/port>|<all>:{1/1..1/16} | all
说明:将特定或所有OLT的计数器清零。
访问级别:0
语法1:clear counters gpon-olt <1/port> ont<ont port> [gemport <ont port/vport>]
取值范围:
<1/port>:{1..16}
<ont port/vport>:{{1..64}/{1..16}}
说明:重置相应OLT下相应onu的所有或者特定的gemport计数器。
访问级别:0
语法1:clear counters gpon-olt <1/port> nni
取值范围:
<1/port>:{1..16}
说明:重置相应OLT下的nni计数器。
访问级别:0
语法1:clear counters gpon-olt <1/port> ont-counts <ontid>
取值范围:
<1/port>:{1..16}
<ontid>:  {1..64}
说明:重置相应OLT下的onu计数器。
访问级别:2
语法:clear counters giga-ethernet <module/port>
取值范围:
<module/port>:单接口,如:1/2 或者接口范围{1/{1-16}或2/{1-4}}
说明:将特定千兆以太网的计数器清零。
访问级别:2
语法:clear counters link-aggregation <linkid>
取值范围:
< linkid >:{1..32}
说明:将特定链路汇聚接口的计数器清零。
访问级别:2
语法:clear counters loopback <lid>
取值范围:
<lid>:<0..16>
说明:将特定环回接口的计数器清零。
访问级别:2
语法:clear counters vlan <vid>
取值范围:
< vid >: {1..4094}
说明:将特定VLAN的计数器清零。
访问级别:2
语法:clear igmp-statistics
说明:清除所有IGMP统计。
访问级别:2
该命令用于重置L2 PPPOE中继计数器。
语法:clear ip pppoe vlan-option statistics
访问级别:2
语法:clear pon-mac-addresses [1/port]
取值范围:
[1/port] :port{1..16}
说明:该命令用于删除所有gpon动态MAC地址。
访问级别:2
该命令用于删除所有动态MAC地址。
语法:clear mac-addresses
访问级别:2
该命令用于将所有或特定接口的生成树计数器清零。
语法1:clear spanning-tree counters
语法2:clear spaaning-tree counters interface { giga-ethernet< mdule/port> } | {link-aggregation <1..32>}
访问级别:2
该命令用于进入管理配置模式。
语法:configure management
访问级别:1
该命令用于进入终端配置模式。
语法:configure terminal
访问级别:1
3.14  debug
该命令用于进入DEBUG模式。
语法:debug
访问级别:10
除了本章介绍的命令,详细说明请参考第五章“调测命令”。
3.15  disable
该命令用于关闭特权级别。
语法:disable
访问级别:0
4 Global命令
4.1  cls
该命令用于把屏幕清空。
语法:cls
访问级别:0
4.2  exit
该命令用于退出中间模式。
语法:exit [all]
说明:采用参数[all]返回EXEC模式。
访问级别:0
4.3  help
该命令用于显示命令帮助。
语法:help
访问级别:0
4.4  history
该命令用于显示命令历史。
语法:history
访问级别:0
4.5  logout
该命令用于注销系统。
语法:logout
访问级别:0
4.6  ping
该命令用于发送ICMP echo数据包,可携带的参数选项用于:
·     设置源IP;
·     设置TX数据包的数量;
·     设置数据包长度;
·     支持连续模式。
语法:ping <destination-ip-address> [source-ip-address]
ping <destination-ip-address> [source-ip-address] pklen <packet-length> [repeat <repeat-count >]
ping <destination-ip-address> [source-ip-address] repeat <repeat-count > [pklen <packet-length> ]
取值范围:
packet-length:28-4096字节
repeat-count:1..65500
说明:如果<ip-address>不是路由IP,则指定缺省网关。
访问级别:0
4.7  show
该命令用于显示运行系统信息。
语法:show
 <parameters>
说明:显示运行系统信息。
访问级别:0
4.8  telnet
该命令用于通过特定端口telnet远端主机或服务器。
语法:telnet <A.B.C.D> <port-number>
说明:通过带端口号的端口Telnet到IP地址为<A.B.C.D>的主机。
访问级别:2
4.9  traceroute
该命令用于跟踪路由IP地址。源IP地址可随意指定。最大跳数(TTL)也可随意指定。
语法:traceroute <destination-ip-address> [source-ip-address] [max-hops <hops-number>]
取值范围:
hops-number:生存时间(TTL)值,范围是1-128
访问级别:2
4.10  tree
该命令用于显示带有可选命令语法的命令树。
语法:tree [-syntax]
说明:
无参数时,将以树型结构显示当前的所有命令。若使用参数[-syntax],将显示该命令的详细信息,包括命令中可使用的所有参数及其范围。
访问级别:0
4.11  who
该命令用于显示当前的登录用户。
语法:who
访问级别:0
5.1  anti-attack
该命令用于应用/关闭管理接口的ACL配置文件。运行该命令可防止软件或硬件受到攻击。
语法:[no] anti-attack <software|hardware>
访问级别:2
该命令用于应用管理ACL配置文件。
语法:anti-mac-spoofing <enable|disable>
访问级别:2
取值范围:
<enable|disable>:启用或禁用MAC伪装。
该命令用于应用管理ACL配置文件。
语法:apply-mgmt-acl-access-list <files-string>
访问级别:2
取值范围:
<files-string>:
ACL单个文件(<file1>),如:a1,或
ACL多个文件(<file1、file2..file7..>),如:a1、a2..a5...
这是最多有200个字符的字符串。
该命令用于将ACL配置文件应用到管理接口。
语法:
apply-mgmt-acl-profile <profileid>
[no] apply-mgmt-acl-profile
取值范围:
Profile id:ACL配置文件号,(1..32)
访问级别:2
5.5  banner
该命令用于配置登录横幅。
语法:banner
访问级别:0
该命令用于配置从闪存启动系统时的映像文件。
语法:boot system flash <filename>
取值范围:
<filename>:最多20个字符
访问级别:2
5.7  boot system ftp
该命令用于配置从FTP服务器启动系统。
语法:boot system ftp <A.B.C.D> <user-name> <user-password> <system-image-file-name>
访问级别:2
取值范围:
A.B.C.D:下载文件的IP地址
user-name:登录用户名—最多20个字符(包括文字和数字)的字符串
user-password:登录用户口令—最多20个字符(包括文字和数字)的字符串
system-image-file-name:系统映像文件名—最多64个字符的字符串
5.8  bootrom-update
该命令用于更新bootrom映像文件。
语法:bootrom-update <host IP address> <user-name> <user-password> < boot-rom-file-name>
取值范围:
user-name:登录用户名—最多23个字符(包括文字和数字)的字符串
user-password:登录用户口令—最多15个字符(包括文字和数字)的字符串
boot-rom-file-name:boot rom文件名—最多63个字符的字符串
访问级别:2
说明:话单服务器配置。
该命令用于诊断ONT信息。
语法:diagnose ont-info <1/port> <ont id>
取值范围:
<1/port>:port{1..16}
<ont id>:{1..64}
访问级别:2
该命令用于光路诊断。
语法:diagnose optical-path <1/port>
取值范围:
访问级别:2
该命令用于诊断系统信息。
语法:diagnose system
取值范围:
访问级别:2
设置/清除命令enable的登录用户名和口令。
语法:
enable password <login-username> <password>
no enable password <login-username>
取值范围:
<login-username>:登录用户名—最多15个字符的字符串
<password>:明文(cleartext)的“enable”口令—最多15个字符的字符串。
访问级别:2
进行文件系统的一致性检查。
语法:file-system chkdsk <volname>
取值范围:
<volname>:目录名,请参考flash或nvm。取值范围是:nvm:、nvm:/、flash:或flash:/。
访问级别:2
拷贝文件。
语法:file-system copy <src> <dst>
取值范围:
<src>:源文件名,最多254个字符
<dst>:目的文件名,最多254个字符
访问级别:2
将内存格式化。
语法:file-system format <dst-device>
取值范围:
<dst-device>:目录名,最多254个字符。请参考闪存或NVM内存。
访问级别:2
列出BBS系统中的所有文件或某个目录中的文件。
语法:file-system list [directory]
取值范围:
[directory]:目录名, /tffs/ or /ramdisk:0/ 最多64个字符
访问级别:2
创建BBS系统中的目录。
语法:file-system mkdir <directory>
取值范围:
<directory>:最多64个字符的目录名
访问级别:2
删除文件。
语法:file-system remove <filename>
取值范围:
<filename>:需要删除的文件名称,最多254个字符
访问级别:2
将文件重命名。
语法:file-system rename <src> <dst>
取值范围:
<src>:带路径的原文件名称,最多254个字符
<dst>:带路径的新文件名称,最多254个字符
访问级别:2
5.20  filter-alarm
该命令用于配置告警过滤。
语法:filter-alarm <index>
[class <none | communication | qos | equipment | procerror | environment>]
缺省值:none
[severity <none | critical | major | minor | warning | clear>]
缺省值:none
[status <disabled | enabled>]
缺省值:disable
[entity <entity-value>] [slot<instance-slot-value>] [port <instance-port-value>] [lport <instance-lport-value>] [uinport<instance-uniport-value>] [group <instance-group-value>]
[pc<pc-value>] [sp<sp-value>]
取值范围:
<index>:<1-64>,告警过滤的索引号。
<entity-value>:<0 -5000>
¡     2001- node
¡     2002 - module
¡     2003 - Fan module
¡     2004 - Power module
¡     2005 - shelf
¡     2006 - shelf groupid
¡     2007 - port
¡     2008 - onu
¡     2009 - onu uni port
<instance-slot-value>:<0 - 1>
<instance-port-value>:<0 - 4>
<instance-lport-value>:<0-64>
<instance-uniport-value>:<0 - 24>
<instance-group-value>:<0 - 64>
<pc-value>:<0 - 5000>
<sp-value>:<0 - 5000>
访问级别:2
配置模式:CONFIG Management模式
5.21  ftp
该命令用于上载或下载文件。
语法:ftp <ftp-host-ip> <get|put> <login-user-name> <login-password> <local-file-name-with-path> <remote-file- name-string >
取值范围:
<get|put>:
¡     get:从远端主机获取文件
¡     put:将文件放到远端主机
<login-user-name>:登录用户名,为最多23个字符的字符串
<login-password>:登录口令,为最多15个字符的字符串
<local-file-name-with-path>:格式:闪存:/文件名,为最多63个字符的字符串
<remote-file-name-string>:最多63个字符的字符串
访问级别:2
5.22  ip access-list
该命令用于配置telnet访问列表。
语法:[no] ip access-list <telnet> <A.B.C.D> <net mask>
访问级别:2
5.23  kill
该命令用于关闭当前运行会话外的其它telnet会话。
语法:kill
访问级别:10
该命令用于配置日志告警门限。
语法1:logging alarm-threshold cpu <cpu_usage_percentage>
说明:设置总的CPU利用率。
语法2:logging alarm-threshold memory < memory_usage_percentage>
说明:设置总的内存利用率。
语法3:logging alarm-threshold task-cpu <task_cpu_usage_percentage>
说明:设置某个CPU进程的利用率。
取值范围:
< cpu_usage_percentage>:0-89、<task_cpu_usage_percentage>: 0-49、
< memory_usage_permillage>:0-949
访问级别:2
该命令用于设置控制台日志告警级别。
语法:logging console <severity-level>
取值范围:
<severity-level>:有两种方式设置告警级别。
·     alerts|critical|debugging|emergencies|errors|informational|notifications|warnings
·     <1..8>的告警级别。
表5-1 级别说明
名称
级别
含义
alerts
2
需要马上采取行动。
critical
3
危急情况
debugging
8
调测消息
emergencies
1
系统不能用。
errors
4
错误情况
informational
7
上报消息
notifications
6
正常但有重要的情况
warnings
5
警告情况
缺省值:debugging
访问级别:2
5.26  logging flash
设置闪存日志告警级别。
语法:logging flash <alarm|event|others> <severity-level>
取值范围:
·     alerts|critical|emergencies|errors
·     <1..8>的告警级别。
表5-2 级别说明
名称
级别
含义
alerts
2
需要马上采取行动。
critical
3
危急情况
emergencies
1
系统不能用。
errors
4
错误情况
缺省值:alerts
访问级别:2
5.27  logging format
该命令用于设置系统日志格式。
语法:logging format <non-rfc3164|rfc3164>
取值范围:
non-rfc3164或rfc3164
缺省值:non-rfc3164
访问级别:2
5.28  logging host
语法:logging host <ip> [port-number] facility <facility code> <severity-level>
取值范围:
<port-number>:1-65535
<facility code >:auth; dhcp; eth; pon; sys; syslog; user
表5-3 设备代码说明
名称
含义
auth
授权系统
dhcp
动态主机配置协议
eth
以太网接口
pon
无源光网络
sys
系统
syslog
系统日志
user
用户进程
·     alerts|critical|debuggibg|emergencies|errors|informational|notifications|warnings
·     <1..8>的告警级别。
表5-4 级别说明
名称
级别
含义
alerts
2
需要马上采取行动。
critical
3
危急情况
debugging
8
调测消息
emergencies
1
系统不能用。
errors
4
错误情况
informational
7
消息
notifications
6
正常但有重要的情况
warnings
5
警告情况
访问级别:2
取消命令或设置为缺省值。
语法:logging no host <ip>
访问级别:2
添加或修改支持升级的onu类型。
语法:modify-upgrade-ont-list <hw-type> <description> <epuipment-id> [hw_rv]
取值范围:
<hw-type> :ont硬件类型
<description> :ont的表述
<epuipment-id>:ont的设备id
[hw_rv]:ont硬件版本(如果ont 硬件版本不是0)
访问级别:0
该命令用于OLT不匹配监测。
语法:monitor pon olt-mismatch-monitoring <disabled|enabled>
取值范围:
<disabled|enabled> 是否开启OLT不匹配监测
访问级别:10
该命令用于是否监视OLT暂停帧。
语法:monitor pon olt-pause-frames-monitoring <disabled|enabled>
取值范围:
<disabled|enabled> 是否开启OLT暂停帧监视。
访问级别:10
5.33  no cdr
该命令用于删除详细通话记录。
语法1:no cdr logging
语法2:no cdr server
说明:语法1 用于禁用cdr日志记录;语法2 用于删除服务器上的呼叫详细记录
访问级别:2
该命令用于删除告警过滤。
语法:no filter-alarm <index>
取值范围:
<index>:{1..64}
访问级别:2
5.35  onu-mngt-ip
该命令用于配置ONT管理IP地址。
语法: onu-mngt-ip <ip> <ipmask> <gateway>
取值范围:
<ip> :<A.B.C.D> ONU管理IP地址
<ipmask>:<A.B.C.D> ONU管理IP MASK地址
 <gateway>:<A.B.C.D> ONU管理IP Geteway地址
访问级别:2
该命令用于配置带外管理接口IP地址。
语法:
out-band interface fast-ethernet ip address <ip> <mask>
out-band interface fast-ethernet no ip address
访问级别:2
5.37  pm interface
该命令用于使能[去使能]性能管理信息。
语法1:[no] pm interface gpon-olt <module/port>
语法2:[no] pm interface gpon-olt <module/port> onu <onuid>
语法3:[no] pm interface giga-ethernet <module/port>
访问级别:2
取值范围:
<module/port>:({1}/{1..16}),最多31个字符的字符串
<onuid>:1-64
<module/port>:接口范围{1/{1-16}或2/{1-4}}
5.38  pon-routing
该命令用于配置Pon路由功能。
语法: pon-routing <operation>
取值范围:
<operation> :enable|disable
访问级别:0
5.39  reboot
该命令用于重启P3116系统。
语法:reboot
访问级别:10
该命令用于该命令用于更新ONT List 表项。
语法:reload-upgrade-ont-list
访问级别:0
5.41  save
该命令用于将运行配置保存到启动配置文件。
语法:save
访问级别:1
说明:将运行配置保存到闪存文件系统。
该命令用于将系统配置重置为出厂初始值。系统重启后生效。
语法:set factory default
访问级别:2
5.43  show-option
该命令用于设置CLI命令显示的选项。
语法:show-option < all | partial >
说明:
all | partial:该可选参数指示系统一次显示某个显示命令的所有或部分结果。
访问级别:2
该命令用于设置dhcp option82 接入节点编号。
语法:system access-node-id <name>
取值范围:
<name>: dhcp option82接入节点编号,最多可达50chars。
访问级别:2
5.45  system clock
该命令用于管理系统时钟。
语法:system clock <time> <date>
取值范围:
<time>:当前时间,小时:分钟:秒(HH:MM:SS),为最多8个字符的字符串
<date>:当前日期,年-月-日(YYYY-MM-DD),为最多10个字符的字符串
访问级别:2
5.46  system contact
该命令用于设置系统联系信息。
语法:system contact <contact>
取值范围:
<contact>:最多255个字符(包括文字与数字)的系统联系信息文本字符串
访问级别:2
该命令用于识别mib对象系统说明的文本。
语法:system description <description>
取值范围:
<description>:最多255个字符(包括文字与数字)的系统说明文本字符串
访问级别:2
该命令用于配置系统设备ID。
语法:system device-id <ID-string>
取值范围:
<ID-string>:系统设备ID,为最多30个字符的字符串。
访问级别:2
该命令用于重命名该交换路由器。
语法:system hostname <name>
取值范围:
<name>:最多31个字符(包括文字与数字)的系统主机名文本字符串
访问级别:2
该命令用于配置系统IP过滤器。
语法:system ip-filter <enable|disable>
取值范围:enable|disable ,缺省值:disable
说明:激活/关闭系统IP过滤器配置。
访问级别:2
该命令配置系统位置字符串,作为mib对象中的sysContact。
语法:system location <location>
取值范围:
<location>:最多255个字符(包括文字与数字)的系统位置文本字符串
访问级别:2
该命令用于配置系统管理的ttl值。
语法:system management-ttl <value>
取值范围:
<1..255>
访问级别:2
该命令用于配置系统保留的VLAN号。
语法:system reserved-vlan-base <vlan-id>
取值范围:2..4085
访问级别:2
5.54  system timeout
该命令用于设置系统超时,单位为秒。
语法:system timeout <sys-time>
取值范围:
 sys-time:60-3600秒
访问级别:2
5.55  system tpid
该命令设置系统的TPID值。
语法:system tpid <tpid-value>
取值范围:
<tpid-value>:x8100-0xffff, 缺省为0x88a8,最多达6 chars。
访问级别:2
5.56  system vendor
该命令用于设定系统运营商。
语法:system vendor <vendor-name>
取值范围:
<vendor-name>:运营商,最多16个字符。
访问级别:2
5.57  temperature
该命令用于配置设备温度极限值。
语法:temperature ceiling < temperature -value>
取值范围:
温度值:0-70
缺省值:70
访问级别:1
5.58  tftp
该命令用于上载或下载映像。
语法:tftp <host-ip> <get|put> <local-file- name-with-path> <remote-file- name-string >
访问级别:2
取值范围:
<local-file-name-with-path>:格式:闪存:/文件名(最多63个字符的字符串)
访问级别:2
5.59  uplink-mode
该命令用于设置上行模式。
语法:uplink-mode<internal|external>
取值范围:
<internal|external>:内部为前端,外部为CSM。
访问级别:0
该命令用于更改用户的访问级别。
语法:user accesslevel <usename> <0|1|2|10>
取值范围:
<usename>:用户登录名,为最多15个字符的字符串
10:管理员
2:完全访问(超级用户)
1:端口配置访问
0:只读访问
访问级别:10
5.61  user add
该命令用于添加新的用户账户。
语法:user add <username> <password> <0|1|2|10>
取值范围:
< password >:用户登录口令,为最多15个字符的字符串
10:管理员
2:完全访问(超级用户)
1:端口配置访问
0:只读访问
访问级别:10
5.62  user delete
该命令用于删除用户账户。
语法:user delete <username>
访问级别:10
5.63  user password
该命令用于更改用户名为<username>的用户口令。
语法:user password <username> [new-password <newpasswordvalue> confirm-password <newpasswordvalue>]
取值范围:
<username>:用户名,为最多15个字符的字符串。
< newpasswordvalue >:用户登录口令,为最多15个字符的字符串。
访问级别:10
说明:当按下<cr>键时,会显示“输入新口令”。输入口令后,会显示“确认新口令”。然后再次输入口令。
该命令用于配置CLI登录用户身份验证方法。
语法:user-auth-method system-database
访问级别:2
6.1  access-list
配置地址解析协议(ARP)、IP或MAC访问列表。
语法1:[no] access-list arp <arp-access-file-name>
语法2:[no] access-list ip <extended|standard> <ip-access-file-name>
语法3:[no] access-list mac <mac-access-file-name>
取值范围:
<arp-access-file-name>:ARP ACL存储文件名,为最多20个字符的字符串。
<ip-access-file-name>:IP扩展/标准ACL存储文件名,为最多20个字符的字符串。
<mac-access-file-name>:MAC ACL存储文件名,为最多20个字符的字符串。
访问级别:2
配置模式:CONFIG Terminal模式
6.1.1  配置MAC ACL规则
以下CLI命令用于定义MAC访问列表的ACL规则。
语法1:
[no] deny | permit <untag|tag> <ether-type_value> smac <any |src-addr> dmac <any |dst-addr> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
语法2:
[no] remark <new_prio> <new_vlan> <untag|tag> <ether-type_value> smac <any |src-addr> dmac <any |dst-addr> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
语法3:
[no] redirect_ucast <out_untag|out_tag> <out_port> <untag|tag> <ether-type_value> smac <any |src-addr> dmac <any |dst-addr> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
语法4:
[no] rate_limit <bandwidth> <burst-size> <untag|tag> <ether-type_value> smac <any |src-addr> dmac <any |dst-addr> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
取值范围:
·     <type_value>, <length_value>:
¡     <0~0xFFFF>, 指定包的类型,长度;
¡     <0~0xFFFF/0~0xFFFF>,指定包的类型,长度以及掩码;
·     <new_prio>:<0..7>,新优先级;
·     <bandwidth>:<1..10000000>,速率限制的带宽,单位为kbps。
·     <burst-size>:<0..7> , 突发大小, (4 << {0~7}) Kbps。
·     {vlan|priority} <value>: 指定可选值;
¡     Vlan: 1~4094/NULL,掩码:1~0xfff
¡     Priority: 0~7/NULL,掩码:0x0~0x7
6.1.2  配置IP标准ACL规则
以下CLI命令用于定义IP标准访问列表的ACL规则。
语法1:
[no]deny|permit{EtherII-untag|EtherII-tag|802_3-untag|802_3-tag}sip<any|host/A.B.C.D|A.B.C.D/A.B.C.D> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
语法2:
[no]remark<new_prio> <next-hop-value>{EtherII-untag|EtherII-tag|802_3-untag|802_3-tag}sip<any|host/A.B.C.D|A.B.C.D/A.B.C.D> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
语法3:
[no]redirect_ucast<out_untag|out_tag> <out_port>{EtherII-untag|EtherII-tag|802_3-untag|802_3-tag}sip<any|host/A.B.C.D|A.B.C.D/A.B.C.D> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
语法4:
[no]rate_limit<bandwidth> <burst-size>{EtherII-untag|EtherII-tag|802_3-untag|802_3-tag}sip<any|host/A.B.C.D|A.B.C.D/A.B.C.D> opt1 {vlan|priority} <value> opt2 {vlan|priority} <value>
取值范围:
·     <new_prio>:<0..7|NULL>,新优先级;
·     <bandwidth>:<1..1048567>,速率限制的带宽,单位为kbps。
·     <next-hop-value>:
¡     <A.B.C.D>,下一跳地址;
¡     <A.B.C.D/A.B.C.D> ,下一跳地址及其掩码;
¡     <NULL>,没有下一跳。
¡     Vlan: 1~4094,掩码:1~0xfff
¡     Priority: 0~7,掩码:0x0~0x7
6.1.3  配置IP扩展ACL规则
以下CLI命令用于定义IP扩展访问列表的ACL规则。
语法1:
[no]deny| permit {EtherII-untag|EtherII-tag|802_3-untag|802_3-tag} protocol <protocol> src<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|host/A.B.C.D|A.B.C.D/A.B.C.Dt>dst<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|any|host/A.B.C.D|A.B.C.D/A.B.C.D>[opt1{vlan|dscp|priority|option|fragment} <value>] [opt2{vlan|dscp|priority|option|fragment} <value> ] [opt3 {vlan|dscp|priority|option|fragment} <value> ] [opt4 {vlan|dscp|priority|option|fragment} <value> ] [opt5 {vlan|dscp|priority|option|fragment} <value> ]
语法2:
no] remark {<new_prio|new_dscp> <value>} <next-hop-value> protocol <protocol> src<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|host/A.B.C.D|A.B.C.D/A.B.C.Dt>dst<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|any|host/A.B.C.D|A.B.C.D/A.B.C.D>[opt1{vlan|dscp|priority|option|fragment} <value>] [opt2{vlan|dscp|priority|option|fragment} <value> ] [opt3 {vlan|dscp|priority|option|fragment} <value> ] [opt4 {vlan|dscp|priority|option|fragment} <value> ] [opt5 {vlan|dscp|priority|option|fragment} <value> ]
语法3:
 [no]redirect_ucast<out_untag|out_tag> <out_port>{EtherII-untag|EtherII-tag|802_3-untag|802_3-tag}protocol<protocol>src<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|host/A.B.C.D|A.B.C.D/A.B.C.Dt>dst<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|any|host/A.B.C.D|A.B.C.D/A.B.C.D>[opt1{vlan|dscp|priority|option|fragment} <value>] [opt2{vlan|dscp|priority|option|fragment} <value> ] [opt3 {vlan|dscp|priority|option|fragment} <value> ] [opt4 {vlan|dscp|priority|option|fragment} <value> ] [opt5 {vlan|dscp|priority|option|fragment} <value> ]
语法4:
[no]rate_limit<bandwidth> <burst-size>{EtherII-untag|EtherII-tag|802_3-untag|802_3-tag}protocol<protocol>src<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|host/A.B.C.D|A.B.C.D/A.B.C.Dt>dst<any|host/A.B.C.D|A.B.C.D/A.B.C.D> <any|any|host/A.B.C.D|A.B.C.D/A.B.C.D>[opt1{vlan|dscp|priority|option|fragment} <value>] [opt2{vlan|dscp|priority|option|fragment} <value>] [opt3{vlan|dscp|priority|option|fragment} <value>] [opt4{vlan|dscp|priority|option|fragment} <value> ] [opt5 {vlan|dscp|priority|option|fragment} <value> ]
取值范围:
·     <bandwidth>:<1..1048576>,速率限制的带宽,单位为kbps。
·     <new_dscp>:<0..63|NULL>,新dscp;
·     <next-hop-value>:
¡     <A.B.C.D>,下一跳地址;
¡     <NULL>,没有下一跳。
·     <protocol>:
<1..255>,指定IP头中的协议号
<TCP|UDP|ICMP|IGMP|IPINIP|EGP|IGP|OSPF>,指定IP头中的协议名
<IP>,指定IP头为任意协议
{vlan|dscp|priority|option|fragment} <value>: 指定可选值:
¡     Vlan:1~4094 ,掩码:1~0xfff
¡     Dscp:0~63 ,掩码: 0~0x3f
¡     Priority:0~7 ,掩码:0x0~0x7
¡     Option:1-2,1表示带option,2表示不带option
¡     Fragment:1-2;1表示有1- more fragment, 2-no fragment
6.2  anti-rogueont
该命令用于配置功能反流氓onu。
语法:anti-rogueont <linkid> <enable/disable> [manual|auto]
取值范围:
<linkid>:{1..16}
<enable/disable>: 是否开启反流氓onu 功能
[manual|auto]:配置反流氓onu模式:手动/自动
访问级别:2
6.3  clear-alarm
该命令用于清楚系统告警。
语法:clear-alarm <index>
取值范围:
<index>:单个数字,取值范围为:1~512。
访问级别:2
该命令用于清除数据库ACL配置文件、字段和规则。
语法:clear-database-acl [profileid|name_string]
取值范围:
[profileid]:<1..32>
[name_string]:访问列表中的ACL文件名,为最多20个字符的字符串。
访问级别:2
6.5  export
该命令用于将数据库中的ACL配置文件导出到文件系统。
语法:export < profile-name&path >
取值范围:
<profile-name&path>:带目录的ACL配置文件名,如:flash:/abc.txt,最多64个字符(带目录)。文件应保存于闪存。
访问级别:2
6.6  host-route
该命令用于添加主机路由。
语法1:host-route <A.B.C.D> interface giga-interface <module/port>
取值范围:
<A.B.C.D>:主机路由项的IP地址
<module/port>:单接口,(1/{1..16} or 2/{1..4})如:2/2,为最多32个字符的字符串
语法2:host-route <A.B.C.D> interface link-aggregation <lag-ID>
取值范围:
<lag-ID>:链路汇聚接口号:1至32
语法3:host-route <A.B.C.D> interface vlan <VLAN-ID> [sub-vlan <sub-VLAN-ID>] {member <ge<module#/port#> or lg#>}
取值范围:
<VLAN-ID>:超级VLAN ID,范围为1至4094
<sub-VLAN-ID>:子VLAN ID,范围为1至4094
<ge<module#/port#> or lg#>:单接口(ge<module#/port#> or lg#),为最多256个字符的ASCII字符串
访问级别:2
语法4: no host-route <A.B.C.D>
说明:删除路由。
访问级别:2
6.7  import
该命令用于从文件系统导入ACL配置文件。
语法:import <ACL-porfile-name> to <[classfier <class-id>] [profile<profile-id>]
取值范围:
<ACL-porfile-name>:string,64
<class-id>:1..32
<profile-id>:1..360
访问级别:2
该命令用于配置特定的GPON-OLT接口。
语法:interface gpon-olt <port>
取值范围:
<port>:单接口,{1-16}
系统提示:
telnet@P3116(config-t)# interface gpon-olt 1/1
telnet@P3116(config-t-if-gpon-olt-1/1)#
访问级别:1
有关GPON OLT接口配置模式下的命令的详细说明请参见Interface GPON-OLT命令
该命令用于进入GE端口配置模式。
语法:interface giga-ethernet <module/port>
取值范围:
<module/port>:单接口,(module {1-2}/port {1-16})如:1/2,
系统提示:
telnet@P3116(config-t)# interf giga-ethernet 1/1
访问级别:1
有关接口千兆以太网配置模式下的命令的详细说明请参见GE 接口命令
该命令用于进入链路汇聚配置模式。
语法:interface link-aggregation <interface ID>
取值范围:
<interface ID>:链路汇聚接口类型:组ID(1至32)
系统提示:
telnet@P3116(config-t)# interface link-aggregation 1
访问级别:1
有关链路汇聚接口配置模式下的命令的详细说明请参见Link Aggregation命令
该命令用于删除链路汇聚配置模式。
语法:no interface link-aggregation <interface ID>
取值范围:
访问级别:1
该命令用于进入环回接口配置模式。
语法:interface loopback <loopback-interface-number>
取值范围:
<loopback-interface-number>:1-16, 环回接口号
系统提示:
telnet@P3116(config-t)# interface loopback 1
访问级别:2
有关环回接口配置模式下的命令的详细说明请参见Loopback命令
该命令用于删除环回接口配置模式。
语法:no interface loopback <loopback-interface-number>
取值范围:
<loopback-interface-number>:1-16 环回接口号
访问级别:2
该命令用于删除pon保护组。
语法:no interface pon-protection-group <psg-id>
取值范围:
<psg-id>:1..8
访问级别:1
该命令用于创建pon保护组。
语法:interface pon-protection-group <psg-id>
取值范围:
<psg-id>:1..8
系统提示:
telnet@P3108(config-t)# interface pon-protection-group 1
telnet@P3108(config-pon-protection-grp-1)#
访问级别:1
6.15.1  member-ports
该命令用于设置相互保护的端口。
语法:member-ports <workpon> <protcetpon> <typeB>
取值范围:
<workpon>    work pon port <module/port> (module {1}/port). for example, 1/2 String
                          up to 8 chars
<protcetpon>   work pon port <module/port> (module {1}/port). for example, 1/2 String
                          up to 8 chars
访问级别:2
该命令用于切换 work ponlink 至protect ponlink。
语法:manual-switch <w2p>
访问级别:1
6.16  interface vlan
该命令用于进入VLAN接口配置模式。
语法:interface vlan <VLAN interface ID>
取值范围:
<Interface ID>:VLAN接口ID:1- 4094
系统提示:
telnet@P3116(config-t)# interface vlan 4094
telnet@P3116(config-t-if-vlan-4094)#
访问级别:1
有关超级VLAN接口配置模式下的命令的详细说明请参见Interface VLAN命令
该命令用于删除VLAN接口配置模式。
语法:no interface vlan <VLAN interface ID>
取值范围:
访问级别:1
该命令用于进入配置范围参数模式。
语法:interface range <range-value>
取值范围:
<range-value>:Interface range, Example, 'ge2/1,ge2/2-4' or 'lg2,lg4-6'.
系统提示:
telnet@P3116(config-t)# interface range ge2/1
telnet@P3116(config-t-if-range-ge2/1)#
访问级别:2
该命令用于定义网关地址。
语法1:ip default-gateway <ip address>
访问级别:2
该命令用于删除网关地址。
语法2:no ip default-gateway
访问级别:2
6.20  ip igmp mode
该命令用于配置IGMP模式。
语法:ip igmp mode <control | snooping-with-proxy | standard-snooping>
访问级别:2
该命令用于配置IGMP最后成员查询间隔。
语法: ip igmp parameter last-member-query-interval <sec>
取值范围:
<sec>:1..25
访问级别:1
该命令用于配置IGMP查询间隔。
语法: ip igmp parameter query-interval <sec>
取值范围:
<sec>:10..3600,默认125秒
访问级别:1
该命令用于配置IGMP最大查询响应间隔。
语法: ip igmp parameter query-response-interval <sec>
取值范围:
<sec>:1..25,缺省值:10
访问级别:1
该命令用于配置IGMP重试时间。
语法: ip igmp parameter robustness <sec>
取值范围:
<retry>:2..10
访问级别:1
该命令用于激活整个系统的IGMPsnooping。
语法:[no] ip igmp snooping
访问级别:2
该命令用于配置IGMP静态组。
语法:[no] ip igmp static-group <group-address> <multicast-vlan>
取值范围:
group-address:<A.B.C.D>
multicast-vlan:<1..4094>
访问级别:2
该命令用于激活整个系统的IGMP代理。
访问级别:2
该命令用于配置IP组播VLAN。
语法:ip multicast  vlan <vid> <multi-vlan> <start> <end>
取值范围:
<vid>:1..256
<multi-vlan> :vlan id 1..4094
<start> :组播开始ip地址 范围 224.0.1.0到 239.255.255.255
<end> :组播结束ip地址 范围 224.0.1.0到 239.255.255.255
访问级别:2
该命令用于删除IP组播VLAN。
语法:[no] ip multicast  vlan <vid>
取值范围:
<vid>:1..256
访问级别:2
该命令用于将多播VLAN配置为映射到多播GEM端口。
语法1:ip multicast  vlan-to-gem <id> <start> <end> <multi-to-gem>
取值范围:
<id>:1..256
<start> :开始vlan 1..4094
<end> :结束vlan 1..4094
<multi-to-gem> :组播gemport 3800..3999
访问级别:2
该命令用于删除多播VLAN配置为映射到多播GEM端口。
语法2:no ip multicast  vlan-to-gem <id>
取值范围:
<id>:1..256
访问级别:2
该命令用于在全局范围激活IP组播路由功能。
语法:[no] ip multicast-routing
访问级别:2
该命令用于在PPPOE (Point To Point Protocol Over Ethernet,以太网承载PPP协议) REQUEST 消息中删除/插入选项字段。
语法:[no] ip pppoe vlan-option <VLAN ID>
取值范围:
<VLAN ID>:1..4094
访问级别:0
该命令用于配置IP SNTP轮询间隔,单位为秒。
语法:ip sntp poll-interval <time>
取值范围:
<time>:IP SNTP轮询间隔值,16至16284(秒)
访问级别:2
6.33  ip sntp sync
该命令用于进行SNTP同步。
语法:ip sntp sync
访问级别:2
该命令用于配置IP SNTP时区。
语法:ip sntp time-zone <zone> [minutes]
取值范围:
<zone>:SNTP时区,-12至13
[minutes] :0..59
访问级别:2
该命令用于设置检测消息的以太网类型。
语法:loop-detect ether-type <ethertype>
取值范围:
<ethertype> :<0x600-0xffff>
访问级别:0
该命令用于设置检测周期。
语法:loop-detect interval <interval-value>
取值范围:
<interval-value> :10..86400秒
访问级别:0
该命令用于设置检测循环恢复时间。
语法:loop-detect recover-time<time>
取值范围:
<time> :1..1440分钟
访问级别:0
该命令用于设置动态MAC老化时间。
语法:mac-address-table aging-time <age-time>
取值范围:
<age-time>:动态老化时间值,范围60至86400秒。
缺省值:300秒
访问级别:2
该命令为每个接口添加静态MAC地址。
语法1:mac-address-table static <mac-address> vlan <VLAN-ID> interface <interface-type> <interface-ID>
取值范围:
<mac-address>:48位十六进制,格式:H:H:H:H:H:H
<VLAN-ID>VLAN ID 1-4094
<interface-type>:千兆以太网(gigabitEthernet)或链路汇聚(linkAggregation)的关键字。
<interface-ID>:当<interface-type>gigabitEthernet时,<interface-ID>应为接口千兆以太网<module/port> (1/port {1-16} or 2/port {1-4}),如:3/2,最多8个字符的ASCII字符串。
<interface-type>linkAggregation时,<interface-ID>应为132之间的整数。
说明:配置GE接口或LAG接口上的静态MAC地址。
访问级别:2
该命令用于在“config terminal”模式下为每个接口删除所有动态MAC地址。
语法2no mac-address-table dynamic
说明:删除所有接口的动态MAC地址。
该命令用于删除一个或多个接口上的所有动态MAC地址。在configure terminal模式下采用该命令。
访问级别:2
语法3:no mac-address-table dynamic interface <interface-type> <interface-ID > (for each interface)
取值范围:
<interface-ID>:单板/端口(如:2/2)或链路汇聚组ID(如:5)。当<interface-type>为gigabitEthernet时,<interface-ID>的格式应为: ([module{1}/ports{1..16}] or [module{2}/ports{1..4}])。
当<interface-type>为linkAggregation时,<interface-ID>应为类似({1..32})(3,5-9)的字符串,最多64个字符。
说明:删除接口的动态MAC地址。
访问级别:2
该命令删除所有动态MAC地址。
语法:no mac-address-table dynamic mac  <mac-address>
取值范围:
<mac-address>:MAC地址,格式为:<H:H:H:H:H:H>
 访问级别:2
该命令从单个VLAN中删除所有动态MAC地址。在VLAN模式下采用该命令。
语法4:no mac-address-table dynamic vlan <VLAN-ID>
取值范围:
 访问级别:2
该命令用于在configure terminal模式下删除系统中所有静态MAC地址或从单个VLAN删除某个MAC地址。
语法5:no mac-address-table static
语法6:no mac-address-table static [<mac-address>] interface <interface-type> <interface-ID>
Syntax7: no mac-address-table static [<mac-address>] vlan <VLAN-ID>
取值范围:
<mac-address>:48位十六进制,格式为:H:H:H:H:H:H
<VLAN-ID>:VLAN ID 1-4094
<interface-ID>:单板/端口(如:2/2)或链路汇聚组ID(如:5)。当<interface-type>为gigabitEthernet时,<interface-ID>的格式应为([module 1/port {1-16} or 2/port {1-4}])。
访问级别:2
6.40  mac-filter
该命令用于静态配置MAC转发表或过滤表的表项。
语法1:mac-filter <ge interface> <deny|permit> <MAC address>
取值范围:
<ge interface>:单接口(ge<module#/port#>)如:ge1/1,最多为256个字符的字符串。
Deny:静态配置MAC过滤表。
Permit:静态配置MAC转发表
<MAC address>:源MAC地址,格式为<H:H:H:H:H:H>。
访问级别:2
该命令用于删除静态配置MAC转发表或过滤表的表项。
语法2:no mac-filter <ge interface>
取值范围:
访问级别:2
6.41  mls qos
该命令用于启用用户配置的qos设置。
语法1:mls qos cos-queue-map <cos> to <queueID>
取值范围:
<cos>:0..7
<queueID>:0..7
访问级别:2
该命令用于禁用用户配置的qos设置。
语法2:no mls qos cos-queue-map <cos> to<queueID>
取值范围:
<cos>:0..7
<queueID>:0..7
访问级别:2
6.42  monitor
该命令用于启用/关闭SPAN会话。
语法1:monitor session <value> <active|deactive>
取值范围:
<value>: 1
访问级别:2
该命令用于配置SPAN目标千兆位以太网接口。
语法2:monitor session<value> destination interface gigabitEthernet <interface>
取值范围:
<interface> :单一上行链路接口,<mode/port>(2/port{1-4})
访问级别:2
该命令用于配置SPAN源千兆位以太网接口。
语法3:monitor session <value> source interface gigabitEthernet <interface> [both|tx|rx]
取值范围:
<interface> :单一上行链路接口,<module/ports> (1/port {1-16} or 2/port {1-4})
[both|tx|rx]:both:监视接受和传输的流量;tx:只监视传输的流量;rx:只监视接受的;流量
访问级别:2
该命令用于删除SPAN会话配置。
语法4:no monitor session
访问级别:2
该命令用于删除ont mac地址筛选器或转发。
语法:no gpon profilemac-filter id <profile-id> <entry-id>
取值范围:
<profile-id>:1..16
<entry-id>:1..16
访问级别:0
该命令用于删除ONT动态多播模板。
语法:no gpon profile multicast-dynamic <profile-id> <profile-id2>
取值范围:
<profile-id>: 1..256
<profile-id2>:0..31
访问级别:0
命令用于删除ONU组播业务操作的模板。
语法:no pon profile multicast-oper  <profile-id>
取值范围:
<profile-id>:1..256
访问级别:0
命令用于删除ONT静态组播的模板。
语法:no gpon profile multicast-static  <profile-id1> <profile-id2>
取值范围:
<profile-id1>:1..256
<profile-id2>:0..31
访问级别:2
该命令用于删除多播用户视图配置。
语法:no gpon profile multicast-userview
访问级别:2
此命令用于删除DBA模板。
语法:no gpon profile dba <profile-id>
取值范围:
<profile-id>:1..256
访问级别:2
命令用于删除SIP代理配置文件。
语法:no gpon profile voip-sip-server <profile-id>
取值范围:
<profile-id>:1..2
访问级别:2
命令用于删除ONT 流量控制的模板。
语法:no gpon profile rate-ctrl <profile-id>
取值范围:
<profile-id>:1..128
访问级别:2
命令用于删除virtual port svc的模板
语法:no gpon profile vportsvc <profile-id>
取值范围:
<profile-id>:1..128
访问级别:2
命令用于删除一条tcont service profile。
语法:no gpon ptofile tcont-svc <profile-id>
取值范围:
<profile-id>:1..128}
访问级别:2
命令用于为T-CONT解绑定模板(vportsvc-profile,tcont-svc-profile)。
语法:no gpon profile tcont-bind  <profile-id> { v-port <vport-vlaue> }
取值范围:
<profile-id>:1..128
<vport-vlaue>:1..16
访问级别:2
命令用于删除ONU业务流的模板。
语法:no gpon profile flow <profile-id1> <profile-id2>
取值范围:
<profile-id1>:1..128
<profile-id1>:0..127
访问级别:2
6.55  olt-opm
该命令用于设置OPM配置。
语法:olt-opm
系统提示:
telnet@P3116(config-t)# olt-opm
telnet@P3116(config-t-olt-opm)#
访问级别:2
6.55.1  alarm
该命令用于配置opm告警配置。
语法1:alarm <type> threshold<raise> <clear>
取值范围:
<type> :告警类型,如下:
VccHighAlarm
VccLowAlarm
VccHighWarning
VccLowWarning
TXBiasHighAlarm
TXBiasLowAlarm
TXBiasHighWarning
TXBiasLowWarning
TempHighAlarm
TempLowAlarm
TempHighWarning
TempLowWarning
TXPowerHighAlarm
TXPowerLowAlarm
TXPowerHighWarning
TXPowerLowWarning
RXPowerHighAlarm
RXPowerLowAlarm
RXPowerHighWarning
RXPowerLowWarning
<raise> :
temperature  <-140..120>单位为1摄氏度,默认为零
voltage      <0..65535>单位为1毫伏,默认为零
voltaic      <0..100000>单位为1微安,默认为零
power <-65535..65535>单位为0.01 dBm,默认为零
<clear>:
访问级别:2
该命令用于删除opm告警配置。
语法2:no alarm <type> threshold
取值范围:
<type> :告警类型,如下:
VccHighAlarm
VccLowAlarm
VccHighWarning
VccLowWarning
TXBiasHighAlarm
TXBiasLowAlarm
TXBiasHighWarning
TXBiasLowWarning
TempHighAlarm
TempLowAlarm
TempHighWarning
TempLowWarning
TXPowerHighAlarm
TXPowerLowAlarm
TXPowerHighWarning
TXPowerLowWarning
RXPowerHighAlarm
RXPowerLowAlarm
RXPowerHighWarning
RXPowerLowWarning
访问级别:2
6.55.2  olt-port
该命令用于设置/删除olt端口opm配置。
语法:[no] olt-port <mode/port>
取值范围:
<mode/port> :单接口,<1/port> (port{1..16}).
访问级别:2
6.55.3  ont
该命令用于设置/删除ont opm配置。
语法:[no] ont <mod/port/lport>
取值范围:
<mod/port/lport> :module{1}/port{1..16}/lport{1..64}, or range, format 1-2/2-3/1-9.
访问级别:2
6.55.4  status
该命令用于设置opm状态。
语法:status <enable|disable>.缺省值:disable。
访问级别:2
6.55.5  time
该命令用于设置opm开始时间和结束时间。
语法:time <start-time> <period>
取值范围:
<start-time>:开始时间,格式为hh:mm字符串,最多64个字符
<period>:  1..8640  OLT OPM的循环周期。以10秒为单位
访问级别:2
6.56  gpon
该命令用于进入GPON配置模式。
语法:gpon
系统提示:
telnet@P3116(config-t)# gpon
telnet@P3116(config-t-gpon)#
访问级别:2
以下命令需要在GPON配置模式下运行。
该命令用于配置系统全局ONT的认证方式。
语法:ont authentication-mode < snonly | snandpassword | disable | passwordonly | loidonly | loidandcheckcode>
取值范围:
snOnly :=  Serial number only
snAndPassword     =  Serial number and password
disable  =  All ONU/ONTs are allowed to be activated always
PasswordOnly    =  Password only
loidoOnly        =  LOID only
loidAndcheCkcode = LOID and checkcode
缺省值:
snonly
访问级别:2
命令用于显示ONT的认证方式
语法:show ont-authentication-mode
访问级别:0
6.56.3  profile
此命令用于设置配置文件。
语法:profile
系统提示:
P3116(config-t-gpon)# profile
P3116(config-t-gpon-pro)#
访问级别:0
以下命令需要在profile配置模式下运行。
1. dba
此命令用于增加DBA(Dynamic Bandwidth Assignment)模板。T-CONT是ONT上的物理资源,只有绑定了DBA模板后,才能够用于承载业务。当系统缺省的DBA模板不能够满足业务需求时,使用此命令新增一个DBA模板。
语法:dab id <profile-id> [name <profile-name>]
[ type1 fix <fix-bandwidth> ] [type2 assure <assure-bandwidth>]
       [ type3 assure <assure-bandwidth> max <max-bandwidth> ]
       [ type4 max <max-bandwidth> ]
       [ type5 fix <fix-bandwidth> assure <assure-bandwidth> max <max-bandwidth>]
取值范围:
参数
参数说明
取值
id <profile-id>
DBA模板编号。
数值类型,取值范围:1-256。
name
<profile-name>
DBA模板名称。
字符串类型,可输入的字符串长度为1-48个字符。
type1
配置类型为固定带宽的DBA模板。
type2
配置类型为保证带宽的DBA模板。
type3
配置类型为保证带宽+最大带宽的DBA模板。
type4
配置类型为最大带宽的DBA模板。
type5
配置类型为固定带宽+保证带宽+最大带宽的DBA模板。
fix fix-bandwidth
固定带宽。此部分带宽固定分配给用户,即使该用户不使用,其他用户也不可以占用。
数值类型,取值范围:256Kbit/s- 1237248Kbit/s。
单位:Kbit/s。
assure assure-bandwidth
保证带宽。此部分带宽分配给用户,如果用户没有使用,其他用户可以占用此部分带宽。
单位:Kbit/s。
max max-bandwidth
最大带宽。此带宽指某用户可以使用的最大的带宽值。
在type3类型的DBA模板中,最大带宽必须大于或等于保证带宽。
在type5类型的DBA模板中,最大带宽必须大于或等于固定带宽与保证带宽之和。
数值类型,取值范围:256Kbit/s-1244160Kbit/s。
单位:Kbit/s。
缺省值:1024
访问级别:2
2. flow
命令用于建立ONU业务流的模板。
语法:flow id <profile-id1> <profile-id2>
[name <profile-name> ]
[uni-type <uni-type-value>]
[uni-port-bitmap <uni-port-bitmap-vlaue>]
[upmap-type <upmap-type-value>]
[ <vlan-start-value>]
[<vlan-stop-value>]
[pri-bitmap <pri-bitmap-vlaue>]
[vport-num <vport-num-vlaue>]
取值范围:
<profile-id2>:1..127
<profile-name>:string,1..48
<uni-type-value>:<ethernet-uni | ip-host|vei)>
<uni-port-bitmap-vlaue> 缺省值0xff,十六进制,以‘0x’开头
<upmap-type-value>     <vlanId|priorityBits|vlanIdAndPriorityBits>
<vlan-start-value>:1..4095 缺省 101
<vlan-stop-value>:1..4095 缺省 101
<pri-bitmap-vlaue>:十六进制,以‘0x’开头  缺省  0xf
<vport-num-vlaue>:1..16  缺省 1
访问级别:2
3. mac-filter
该命令用于定义ont mac地址筛选器或转发。
语法:mac-filter id <profile-id> <entry-id> name <profile-name>
direction <source|destination>
<mac-address>
<forward|filter>
取值范围:
<profile-id>:1..16
<entry-id>:1..16
<profile-name>:string,1..32
<source|destination>      mac地址模式 源地址|目标地址
<mac-address> :<xx:xx:xx:xx:xx:xx>MAC地址
<forward|filter>:设置mac过滤器类型 转发|筛选
访问级别:2
4. multicast-dynamic
该命令用于创建ONT动态多播模板。
语法:multicast-dynamic id <profile-id> <profile-id2> name <profile-name>
gemport<gemport-value>
vlanid<vlanid-vlaue>
[srcip <srcip -value>]
[grpaddr-start <grpaddr-start-value>]
[grpaddr-stop <grpaddr-stop-vlaue>]
[grpbw<grpbw-vlaue>]
取值范围:
<profile-id2>:0..31
<profile-name>:string, 1..48
<gemport-value>:3800..3999
<vlanid-vlaue>:2..4093
<srcip -value>:<A.B.C.D> 源ip地址
<grpaddr-start-value>:<A.B.C.D>组播开始地址:(ip limit:224.0.1.0 - 239.255.255.255)
<grpaddr-stop-vlaue>:<A.B.C.D>组播结束地址:(ip limit:224.0.1.0 - 239.255.255.255)
<grpbw-vlaue>:0..31 设置组播bandwidth
访问级别:2
5. multicast-oper
命令用于建立ONU组播业务操作的模板。
语法:multicast-oper id <profile-id> name <profile-name>
igmp-ver <igmp-ver-value>
ctrl-mode <ctrl-mode-vlaue>
fastleave <enable|disable>
[us-tci-pbits <us-tci-pbits-value>]
[us-tag-ctrl-grp <us-tag-ctrlp-vlaue>]
[ds-tci-pbits <ds-tci-pbits-vlaue>]
[ds-tag-ctrl <ds-tci-pbits-vlaue>]
[ds-tci-vlanId <ds-tci-vlanId-vlaue>]
[us-tci-vlanId <us-tci-vlanIdvlaue>]
取值范围:
<profile-id>:1..256
<igmp-ver-value><v1| v2| v3>
<ctrl-mode-vlaue><snooping-only>
<enabled|disabled> < enabled|disabled>
<us-tci-pbits-value>:0..7
<us-tag-ctrl-vlaue>:      <pass(0)|add(1)|replace(2)|rep-vid-only(3)>
<ds-tci-pbits-vlaue>:0..7
<ds-tci-pbits-vlaue>:<pass(0)|add(1)|replace(2)|rep-vid-only(3)>
<ds-tci-vlanId-vlaue>:0..4094
<us-tci-vlanIdvlaue>:0..4094
访问级别:2
6. multicast-static
命令用于建立ONT静态组播的模板。
语法:multicast-static id <profile-id1> <profile-id2>
gemport <gemport-value>
vlanid <vlanid-vlaue>
[srcip <srcip-value>]
[grpaddr-start<grpaddr-start-value>]
[grpaddr-stop <grpaddr-stop-value>]
[grpbw <grpbw-vlaue>]
取值范围:
<profile-id2>:0..31
<srcip-value> IPaddress
<grpaddr-start-value>    IPaddress:(ip limit:224.0.1.0 - 239.255.255.255)
<grpaddr-stop-value>    IPaddress:(ip limit:224.0.1.0 - 239.255.255.255)
<grpbw-vlaue> 0..31
访问级别:2
7. rate-ctrl
命令用于使用指定的速率控制(PIR、CIR值)和调度策略(SP、WRR等)创建ONU配置文件。
语法:rate-ctrl id <profile-id1>
name <profile-name>
sir<sir-value>
pir <pir-vlaue>
取值范围:
<sir-value>:128..1244160
<pir-vlaue>:128..1244160
访问级别:0
8. tcont-bind
命令用于为T-CONT绑定模板(vportsvc-profile,tcont-svc-profile)。T-CONT是ONT上的物理资源,只有绑定了模板后,才能够用于承载业务。绑定成功后,T-CONT可以依据绑定模板中的不同配置,提供灵活的动态带宽分配方案。
语法:tcont-bind id <profile-id> { v-port <vport-vlaue> }
[ profile-name <profile-name> ]
[vportsvc-id <vportsvc-id-value>]
[tcon-id <tont-id-vlaue>]
[tcontsvc-id <tcontsvc-id-value>]
取值范围:
<profile-id>:1..128
<vport-vlaue>:1..16
<vportsvc-id-value>:1..128
<tont-id-vlaue>:1..8
<tcontsvc-id-value>:1..128
访问级别:0
9. tcont-svc
命令用于创建一条tcont svc-profile,关联dba-profile。
语法:tcont svc id  <profile-id>  [name <profile-name> ]  [ dba-id <dba-profile-id> ]
取值范围:
<profile-id>:1..128
<profile-name>1..48
<dba-profile-id>:1-256
访问级别:2
10. voip-sip-server
命令用于创建SIP代理配置文件。
语法:voip-sip-server id <profile-id> name <name-value>
proxy-addr<proxy-addr-value>
external-proxy-addr<vportsvc-id-value>
registering-addr<registering-addr-vlaue>
[tcp-port <tcp-port-value>]
取值范围:
<profile-id>:1..4
<name-value>:string
<proxy-addr>:string
<external-proxy-addr>:string
<registering-addrvalue> :string
<tcp-port-vlaue>:0..65535
访问级别:2
11. vportsvc
命令用于创建virtual port svc的模板。
语法:vportsvc id <profile-id> [name <profile-name> ] [ us-pri < us-pri-value> ] [ usratectrl-id<usratectrl-id-value> ] [ dsratectrl-id <dsratectrl-id-value>
取值范围:
<profile-id>:1..128
<profile-name> :string
<us-pri-value> :0..7
<usratectrl-idvalue> :0..128
<dsratectrl-id-value> :0..128
访问级别:2
命令用于显示DBA(Dynamic Bandwidth Assignment)模板参数
语法:show gpon profile dba <profile-id | all>
取值范围:
<profile-id | all>:string ,.1..256 | all=全部
访问级别:0
命令用于显示ONT流量控制的模板的参数
语法:show gpon profile rate-ctrl <profile-id | all>
取值范围:
<profile-id | all>:1..128 | all=全部
访问级别:1
命令用于显示指定的或者全部的virtual port svc的模板的配置参数
语法:show gpon profile vportsvc <profile-id | all>
取值范围:
<profile-id>:{1..128}| all 显示所有的
访问级别:2
命令用于显示tcont service profile
语法:show gpon profile tcont-svc <profile-id | all>
取值范围:
<profile-id | all>:string ,.1..128 | all=全部
访问级别:1
命令用于为显示T-CONT绑定模板(vportsvc-profile,tcont-svc-profile)的参数。
语法:show gpon profile tcont-bind <profile-id | all>
取值范围:
访问级别:1
命令用于显示指定ONU业务流的模板的参数。
语法:show gpon profile flow < profile-id1> | all>
取值范围:
<< profile-id1 | all>:string ,.{1..128 } | all=全部
访问级别:1
命令用于显示指定ONT组播业务操作的模板参数。
语法:show gpon profile multicast-oper < profile-id> | all>
取值范围:
<< profile-id> | all>:string ,1..256 | all=全部
访问级别:1
命令用于显示指定ONT静态组播的模板的参数。
语法:show gpon profile multicast-static  < profile-id1 / profile-id2 {1..256}/{0,31}|all>
访问级别:1
6.57  ont-upgrade
该命令用于进入ONU升级配置模式。
语法:ont-upgrade
系统提示:
P3116(config-t)# ont-upgrade
P3116(config-t-ont-ugp)#
访问级别:2
以下命令需要在ONU升级配置模式下运行。
6.57.1  auto-upgrade
该命令用于启用ONU自动升级。
语法1:auto-upgarde <mod/port> start <start-time> end <end-time> filename <filename-vlaue> equip-id <equip-id-value>
取值范围:
<mod/port>:单接口,<1/port> (port{1..16})
<start-time>:开始时间(小时)0..23
<end-time>:结束时间(小时)0..23
<filename-vlaue> :onu升级包文件名文件名字符串最多64个字符
<equip-id-value>:设置onu设备id,最多64个字符
访问级别:0
该命令用于启用ONU手动升级。
语法1:manual-upgrade <mod/port/lport> filename <filename-vlaue> equip-id <equip-id-value>
取值范围:
<mod/port/lport>:mode{1}/port{1..16}/lport{1..64},或范围,格式1-2/2-3/1-9,最多256个字符
<filename-vlaue>:onu升级包文件名文件名字符串最多64个字符
访问级别:0
6.57.3  upgrade-ftp
该命令用于配置ONU升级的ftp server(如果升级文件在本地没有,则去ftp获取)。
语法:upgrade-ftp <A.B.C.D>  <username> <password>
取值范围:<A.B.C.D> 合法的IP地址
          <username>  字符串,长度小于23.
          <password>  字符串,长度小于15.
访问级别:2
该命令用于激活/关闭SNTP客户端。
语法:[no] service sntp client
访问级别:2
6.59  sntp server
该命令用于配置SNTP服务器。
语法:
sntp server <server-ip-addr> [version-number]
no sntp server <server-ip-address>
取值范围:
<server-ip-addr>:SNTP 服务器IP地址
[version-number]:SNTP服务器版本号(1至4)
访问级别:2
该命令用于设置生成树操作模式。
语法1:spanning-tree mode rstp
访问级别:2
该命令用于删除生成树操作模式。
语法2:no spanning-tree mode
访问级别:2
该命令用于设置VLAN交换机生成树。
语法1:spanning-tree vlan <vlanId> [802dot1t-support<enable|disable>] [forward-delay-time <delayTime>] [hello-time <helloTime>] [max-age-time <maxAgeTime>] [priority <priority>]
取值范围:
<vlanId>:1
<delayTime>:4..30秒 该VLAN设置转发延迟时间
<helloTime>:1..10秒 该VLAN设置Hello时间
<maxAgeTime>:6..40秒 设置最大老化时间
<priority>:0..65535 设置桥接优先级 该值必须为4096的倍数。
允许的值为:
0 4096 8192 12288 16384 20480 24576 28672 32768 36864 40960 45056 49152 53248 57344 61440
访问级别:2
该命令用于删除VLAN交换机生成树。
语法2:no spanning-tree vlan <vlanId>
取值范围:
<vlanId>:1
访问级别:2
6.62  user-isolation
该命令用于用户隔离控制。
语法:user-isolation <enable|disable-standard|disable-enhanced>
访问级别:2
6.63  vlan
该命令用于创建VLAN并进入VLAN配置模式。
语法:vlan {VLAN-ID} [VLAN-name]
取值范围:
{VLAN-ID}:1-4094。VLAN 1为缺省值,不需要配置。
[VLAN-name]:最多16个字符的ASCII字符串。
系统提示:
telnet@P3116(config-t)# vlan 333
访问级别:2
以下命令需要在VLAN配置模式下运行。
6.63.1  name
语法:name <VLAN-name>
取值范围:
<VLANname>:最多16个字符的ASCII字符串。
说明:VLAN的ASCII字符串格式名称。
访问级别:2
6.63.2  member
该命令用于将L2接口(GE端口或链路汇聚组)分配到IEEE 802.1Q VLAN。
语法:
member <member -list> {tagged | untagged}
no member <member -list>
取值范围:
<member-list>:接口ID或接口范围、单板/端口格式或范围格式,如“ge2/2”或“ge2/1-2, ge2/4, lg6”,其中“ge”表示“Giga-Ethernet”,“lg”表示“链路汇聚组”,为最多32个字符的字符串。
{tagged}:添加VLAN为标签端口。
{untagged}:添加VLAN为非标签端口。
访问级别:2
如果要从某个VLAN删除成员,删除的成员必须属于该VLAN。否则会出现以下提示:“错误:端口xxx不属于VLAN yyy”。
6.63.3  pvid
该命令用于配置接口的PVID,包括链路汇聚组和当前VLAN ID。
语法:pvid <member-list>
取值范围:
<member-list>:单接口(ge<module#/port#> or lg#) 如:ge3/2;或接口范围(ge<module#/port#>[-port#],.lg# [-#],)为最多32个字符的ASCII字符串。
访问级别:2
该命令用于激活并配置VLAN的IGMP snooping(带特殊参数)。
语法1: ip igmp snooping <fast-leave|last-member-age-timer <last-member-age-time>
|mc-age-timer <mc-age-time>|router-age-timer <router-age-time>
|src-only-mc-age-timer <src-only-mc-age-time>|{static <static-ip> interface <list>}>
取值范围:
<fast-leave>:配置IGMP Fast Leave(快速离开)。
<last-member-age-time>:最后的组成员的老化时间,单位为秒。 1..65535
<mc-age-time>:组播组时长。如果没有刷新,组播组在创建后经过了“组播老化时间”后会消失。 1..65535
<router-age-time>:路由器老化时间,单位为秒。1..65535
<src-only-mc-age-time>:源端组播老化时间,单位为秒。取值范围:1..65535
<static-ip>:配置静态组播IP地址。224.0.0.1 .. 239.255.255.255
 <list>:单接口(ge<module#/port#>或lg#)例如,ge3/2或接口范围(ge<module#/port#>[-port#],..lg#[-#],..)字符串最多32个字符
访问级别:2
该命令用于关闭VLAN的IGMP snooping(带特殊参数)。
语法2:[no] ip igmp snooping <fast-leave|last-member-age-timer |mc-age-timer |router-age-timer|src-only-mc-age-timer |{static <static-ip> interface <list>}>
取值范围:
访问级别:2
IGMP snooping可按VLAN或整个系统激活。有关整个系统的IGMP snooping,请参见ip igmp snooping
6.64  vlan-option
语法 1vlan-option circuit <circuitId> remote <remoteId>
取值范围:
<circuitId>:DHCP和PPPOE包的选项字段的内容。允许的字段有"slot", "port", "lport", "vlan", "mac"。前缀为"$"。例如:$slot$port$vlan。
<remoteId>:DHCP和PPPOE包的选项字段的内容。允许的字段有"slot", "port", "lport", "vlan", "mac"。前缀为"$"。例如:$slot$port$vlan。
访问级别:2
说明:circuitId和remoteId可从允许字段中选择不同的字段。
语法 2vlan-option mode ctc
访问级别:2
说明: 设置VLAN选择为CTC模式
语法 3no vlan-option
访问级别:2
说明: 删除VLAN设置选择字段
语法 4no vlan-option mode
访问级别:2
说明: 恢复缺省模式
6.65  vlan-range
该命令用于配置VLAN范围。
语法:vlan-option <Starting vlan ID> <Ending vlan ID>
取值范围:
<Starting vlan ID>:2..4094
<Ending vlan ID>:2..4094
访问级别:2
该命令用于删除配置VLAN范围。
语法:no vlan-option <Starting vlan ID> <Ending vlan ID>
取值范围:
访问级别:2
7 GE 接口命令
该命令用于进入接口千兆以太网(interface giga-ethernet)配置模式。
语法:interface <interface type> <moudle/port>
取值范围:
<interface type>:千兆以太网的关键字
<module/port>:单接口,({1-2}/{1-16})如:2/2
访问级别:2
GE接口配置模式下可运行以下命令。
Module:1 internal port <1-16>
Module:2 uplink port <1-4>, 1-2 : 10G port /3-4 Ge port
7.1.1  add-to
该命令用于使一个端口同时加入多个VLAN
语法: add-to vlan <vlan ID> {tagged | untagged}
取值范围:
<vlan ID>: for example: 3,5,7-9. String up to 64chars
访问级别:2
该命令用于将储存在数据库中的ACL列表应用/不应用于接口。
语法:[no] apply-access-list filename1
取值范围:
<filename1>:ACL列表名称,ACL单个文件(<file1>),例如a1或多个文件(<file1,file2..file7..>),例如a1,a2..a5....
访问级别:2
该命令用于将储存在数据库中的ACL配置文件应用/不应用于接口。
语法1:apply-acl-profile <profile-ID>
语法2:no apply-acl-profile
取值范围:
<profile-ID>:1~32
访问级别:2
该命令用于激活/关闭端口速率自协商功能。
语法:[no] auto-negotiation
访问级别:2
该命令用于从单个或多个VLAN中删除接口。
语法:delete-from vlan <vlan-list>
取值范围:
<vlan-list>: VLAN列表,最多可达32个字符。如:3,5,7-9 。
访问级别:2
7.1.6  description
语法:description <des-string>
取值范围:
des-string:描述该接口的字符串(最多255个字符)
访问级别:2
7.1.7  flowcontrol
该命令用于激活/关闭流量控制。
语法:[no] flowcontrol receive|transmit
访问级别:2
该命令用于启用/禁用当前接口的vlan筛选器。
语法:[no] ingress-filter
访问级别:2
该命令用于设置所需的接口工作模式。
语法:interface-mode <mode>
取值范围:
<mode>:<SGMII|FIBER|XGMII>
访问级别:2
7.1.10  ip address
该命令用于配置千兆以太网接口的主备IP地址。
语法:[no] ip address <ip-address> <subnet-mask> [secondary]
取值范围:
[secondary]:可选参数。采用该关键字指定接口IP地址为备用IP地址。如果没有该选项,所配置的地址为主用IP地址。
系统最多支持32个备用IP地址。
说明:设置接口的IP地址。在分配IP地址之前,接口必须处于3层模式。
访问级别:2
必须在端口处于3层模式时分配IP地址,即,在运行该命令前运行“no switchport”命令。如果处于2层模式,会出现错误提示“错误:当前交换模式不能配置该特性”。
该命令用于配置IP IGMP最后成员查询间隔,单位为秒。
语法:ip igmp last-member-query-interval <sec>
取值范围:
<sec>:1-25
缺省值:1
访问级别:2
该命令用于配置IP IGMP查询间隔,单位为秒。
语法:ip igmp query-interval <sec>
取值范围:
<sec>:10-3600秒
缺省值:125秒
访问级别:2
该命令用于配置IP IGMP查询响应间隔,单位为秒。
语法:ip igmp query-response-interval <sec>
取值范围:
<sec>:1-25秒
缺省值:10秒
访问级别:2
该命令用于配置IP IGMP的重传次数。
语法:ip igmp robutness <2-10>
取值范围:2-10
缺省值:2
访问级别:2
该命令用于配置IP IGMP启动查询间隔,单位为秒。
语法:ip igmp startup-query-interval <sec>
取值范围:
<sec>:10-3600秒
缺省值:1/4查询间隔
访问级别:2
该命令用于激活/关闭IP IGMP静态组IP地址。
语法:[no] ip igmp static-group <A.B.C.D>
取值范围:
<A.B.C.D>:组IP地址,224.0.1.0至239.255.255.255
访问级别:1
该命令用于配置IP IGMP未请求的上报间隔,单位为秒。
语法:ip igmp unsolicited-report-interval <sec>
取值范围:
<sec>:10-3600秒
缺省值:10秒
访问级别:2
该命令用于激活/关闭IP IGMP版本。
语法:[no] ip igmp version <ver#>
取值范围:
<ver#>:1-3
当前只支持版本2。如果用户输入其他版本号,应出现错误提示:“错误:系统只支持igmp v2。”
缺省值:2
访问级别:2
该命令用于激活当前接口的IGMP代理。
语法:[no] ip igmp-proxy
访问级别:1
该命令用于设置IP组播过滤器状态。
语法:[no] ip multicast filter
访问级别:2
7.1.21  ipg
该命令用于设置上行端口的“Inter-Packet Gap”值。
语法:ipg <gap-value>
取值范围:
gap-value:数据包之间的间隙值,单位为字节<8..31>。
访问级别:2
7.1.22  max-frame
该命令用于配置当前接口的最大帧大小。
语法:max-frame <maximum frame-size>
缺省值:1532
取值范围:<64..12288>
访问级别:2
7.1.23  mls qos
该命令用于激活/关闭MLS QoS配置模式。
语法:[no] mls qos
访问级别:2
缺省值:MLS Qos disable。
该命令用于配置mls qos trust。
语法:[no] mls qos map trust < dscp | ip-prec >
缺省值:no trust。
访问级别:2
该命令用于配置dscp到cos映射。
语法:[no] mls qos map dscp-cos < dscp-value> to <cos-value>
取值范围:
<dscp-value>:0 ..63
<cos-value>:0..7
访问级别:2
该命令用于配置dscp到mutation映射。
语法:[no] mls qos map dscp-mutation< dscp-value> to <mutation-value>
取值范围:
<dscp-value>:0 ..63
<mutation-value>:0..63
访问级别:2
该命令用于配置ip prec到dscp映射。
语法:[no] mls qos map ip-prec-dscp< ip-prec-dscp-value> to <dscp-value>
取值范围:
<ip-prec-dscp-value>:0..7
<dscp-value>:0 ..63
访问级别:2
该命令用于配置优先级队列的严格优先级或权重。
语法1:mls qos queue-set output <queue ID> strict-priority
语法2:mls qos queue-set output <queue ID> wrr <weight>
取值范围:
<queue ID>:0 - 7
strict-priority:给该队列分配严格优先级。
Wrr:权重轮询关键字
<weight>:1 - 127
缺省值:
Cos队列:0   1   2   3
Weights: 2   4   6   8
访问级别:2
该命令用于删除某个队列已分配的优先级。
语法3:no mls qos queue-set output <queue ID>
取值范围:
<queue ID>:0 - 7
访问级别:2
7.1.29  pvid
该命令用于配置当前接口基于端口的VLAN ID(PVID)。
语法:pvid <VLAN-ID>
取值范围:
<VLAN-ID>VLAN ID 1 - 4094
访问级别:1
7.1.30  rate-limit
该命令用于设置最大的输入/输出帧大小,单位为百兆字节。
语法1:rate-limit <input|output> <limit-rate>
语法2:rate-limit <input|output> <limit-rate> burst-size <burstSize>
取值范围:
< limit-rate >:<1..10000>。速率限制带宽(M)。
<burstSize>:<<4|8|16|32|64|128|256|512>
访问级别:2
该命令用于清除最大的输入/输出帧大小配置。
语法3:no rate-limit <input|output>
访问级别:2
7.1.31  shutdown
该命令用于激活/关闭接口管理状态。
语法:[no] shutdown
访问级别:1
该命令用于指定生成树协议所使用的链路类型。
语法:spanning-tree link-type <p2p|shared>
访问级别:2
该命令用于更改实例的接口生成树通道代价。
语法:spanning-tree mst <mst-id> cost <pathcost>
取值范围:
<mst-id>:0..15
<pathcost>:1..200000000
访问级别:2
该命令用于更改实例的接口生成树端口优先级。
语法:spanning-tree mst <mst-id> port-priority <priority>
取值范围:
<mst-id>:0..15
<priority>:0..240,该值必须为16的倍数。
访问级别:2
该命令用于激活接口上的portfast。
语法1:spanning-tree portfast
语法2:no spanning-tree portfast
访问级别:2
该命令用于设置该VLAN该端口的通道代价。
语法:spanning-tree vlan <vlan-id> cost <cost>
取值范围:
<vlan-id>:1..1
<cost>:1..200000000
访问级别:2
该命令用于设置该端口的端口优先级。
语法:spanning-tree vlan <vlan-id> port-priority <priority>
取值范围:
<vlan-id>:1...1
访问级别:2
该命令用于激活接口上的portfast
语法:spanning-tree vlan <vlan-id> portfast
取值范围:
<vlan-id>1...1
访问级别:2
该命令用于配置业务风暴控制。低于每个接口配置级别。
语法:storm-control {broadcast|multicast|unicast} {<value>|<disable>}
取值范围:
broadcast:广播地址风暴控制
multicast:组播地址风暴控制
unicast:单播地址风暴控制
<value>:0-1000000,单位pps
<disable>:关闭风暴控制功能。
缺省值:
broadcast:enable,value值为131
multicast:disable
unicast:enable,value值为131
访问级别:1
说明:每次配置更改时,系统将提示如下警告。
Warning: Arbitrary dropping of certain types of broadcast frames can result in networks instability that in some cases can melt down the network.
7.1.40  switchport
该命令用于将物理千兆以太网口配置为2层端口。
语法1:switchport
访问级别:2
该命令用于将物理千兆以太网口配置为3层端口。
语法2:no switchport
访问级别:2
该命令用于进入链路汇聚配置模式。
语法:[no] interface link-aggregation <group ID>
取值范围:
<group ID>:链路汇聚接口类型:组ID为1至32。
说明:使用[no]命令删除链路汇聚组成员。
访问级别:2
链路汇聚接口配置模式下,可运行以下命令。
8.1.1  add-to vlan
该命令用于将链路汇聚组以标签或非标签模式添加到多个VLAN。VLAN的范围必须为递增顺序而不是递减顺序。
语法:add-to vlan <VLANID> <tagged | untagged>
取值范围:
<VLANID>:1-4094。一组VLAN(如:101-200),为最多12个字符的ASCII字符串
{tagged | untagged}:VLAN中的标签/非标签链路汇聚组
访问级别:2
该命令将数据库存储的ACL列表应用于/不应用于接口。
语法:[no] apply-access-list filename1,[filename2..]
取值范围:
<filename1>:ACL列表名称
访问级别:2
该命令用于将数据库存储的ACL配置文件应用于接口。
语法:
取值范围:
<profile-ID>:配置文件的标识号为1至32。
说明:使用[no]命令关闭将数据库存储的ACL配置文件应用于接口。
访问级别:2
该命令用于从多个VLAN删除链路汇聚组,无论其为标签或非标签模式。VLAN的范围必须为递增顺序而不是递减顺序。
语法:delete-from vlan <VLANID>
取值范围:
VLANID:1-4094,一组VLAN(如:101-200),为最多32个字符的ASCII字符串
访问级别:2
8.1.5  description
该命令用于添加当前链路汇聚接口的说明。
语法:
no description
取值范围:
<des-string>:描述该接口的ASCII字符串,最多16个字符
说明:使用[no]命令删除当前链路汇聚接口的说明。
访问级别:2
8.1.6  flowcontrol
该命令用于设置接收/发送流量控制功能。
语法:[no] flowcontrol <receive | transmit>
说明:使用[no]命令重设接收/发送流量控制功能。
访问级别:2
该命令用于激活/关闭入口过滤器。
访问级别:2
8.1.8  ip address
该命令用于配置接口的IP地址。
语法1:ip address <ip-address> <subnet-mask> [secondary]
取值范围:
[secondary]:可选参数。用该关键字指定接口IP地址为备用IP地址。如果没有该选项,所配置的地址为主用IP地址。
系统支持最多32个备用IP地址。
访问级别:2
该命令用于配置接口的IP地址。
语法2:no ip address <ip-address> <subnet-mask>[secondary]
取值范围:
系统支持最多32个备用IP地址。
访问级别:2
取值范围:
<sec>:1-3600秒
缺省值:1秒
访问级别:2
取值范围:
<sec>:10-3600秒
缺省值:125秒
访问级别:2
取值范围:
<sec>:1-25秒
缺省值:10秒
访问级别:2
取值范围:2-10
缺省值:2
访问级别:2
该命令用于配置IP IGMP的启动查询间隔,单位为秒。
取值范围:
<sec>:10-3600秒
缺省值:1/4查询间隔
访问级别:2
取值范围:
<A.B.C.D>:组IP地址,224.0.2.0至239.255.255.255
访问级别:2
取值范围:
<sec>:10-3600秒
缺省值:10秒
访问级别:2
取值范围:
<ver#>:1-3
访问级别:2
该命令用于激活当前接口的IGMP代理。
访问级别:1
该命令用于设置IP组播过滤器状态。
访问级别:2
8.1.19  load-balance
该命令用于创建负载均衡方法(只在创建链路汇聚组时需要)。
语法:load-balance <src-MAC | dst-MAC | src-IP | dst-IP | src-dst-IP | src-dst-MAC >
取值范围:
dst-IP:目的IP地址
dst-MAC:目的MAC地址
src-dst-IP:源/目的IP地址
src-dst-MAC:源/目的MAC地址
src-IP:源IP地址
src-mac:源MAC地址
说明:创建汇聚组后不可配置。
访问级别:2
8.1.20  max-frame
该命令用于设置当前接口接收的最大帧的大小。
语法:max-frame <64..65535>
访问级别:2
8.1.21  member
该命令用于在“接口链路汇聚<groupID>”模式添加链路汇聚组的成员。
语法:[no] member <member-list>
取值范围:
<member-list>:最多32个字符的字符串。<slot/port>:<2/1-4>
访问级别:2
8.1.22  mls qos
语法:[no] mls qos
访问级别:2
缺省值:mls qos disable。
8.1.23  mls qos map
该命令用于配置MLS QoS map trust。
缺省值:No trust
访问级别:2
该命令用于配置dscp到cos映射。
取值范围:
<dscp-value>:0 ..63
<cos-value>:0..7
访问级别:2
取值范围:
<dscp-value>:0 ..63
访问级别:2
取值范围:
<dscp-value>:0 ..63
访问级别:2
该命令用于选择需要分配优先级的队列。
取值范围:
<queue ID>:0 - 3
wrr:权重轮询关键字
<weight>:1 - 127
缺省值:
Cos队列:0   1   2   3
权重:   2   4   6   8 0
访问级别:2
该命令用于删除某个队列所分配的优先级。
取值范围:
<queue ID>:0 - 3
访问级别:2
8.1.28  pvid
语法:pvid <VLAN-ID>
取值范围:
访问级别:1
8.1.29  shutdown
该命令用于配置链路汇聚的管理状态。
语法:[no] shutdown
访问级别:2
访问级别:2
语法:spanning-tree mst <MST id> cost <pathcost>
取值范围:
<MST id>:0..15
访问级别:2
语法:spanning-tree mst <MST id> port-priority <priority>
取值范围:
<MST id>:0..15
访问级别:2
该命令用于激活/关闭端口的spanning-tree属性为portfast。
语法:[no] spanning-tree portfast
访问级别:2
该命令用于设置该VLAN该端口的路径开销。
语法:spanning-tree vlan <vlan-id> path-cost <cost>
取值范围:
<vlan-id>:1...1
<cost>:1..200000000
访问级别:2
该命令用于设置该端口的端口优先级。
语法3:spanning-tree vlan <vlan-id> port-priority <priority>
取值范围:
<vlan-id>:1...1
访问级别:2
取值范围:
broadcast:广播地址风暴控制
multicast:组播地址风暴控制
unicast:单播地址风暴控制
<disable>:关闭风暴控制功能。
缺省值:
multicast:disable
访问级别:1
说明:每次配置更改时会出现以下警告提示。
8.1.37  switchport
该命令用于倒换/不倒换3层与2层模式之间的接口。
语法:[no] switchport
说明:设置倒换模式特性。
访问级别:2
9 Loopback命令
该命令用于进入环回接口配置模式。
语法:[no] interface loopback <loopback-interface-number>
取值范围:
<loopback-interface-number>:1-16,环回接口号
访问级别:2
环回接口配置模式下可运行以下命令。
9.1.1  description
该命令用于描述环回接口。
取值范围:
<des-string>:描述环回接口的ASCII字符串,最多255个字符
访问级别:2
9.1.2  ip address
该命令用于设置环回接口的接口IP地址。
取值范围:
<ip-address>:IP地址
<subnet-mask>:子网掩码
系统支持最多32个备用IP地址。
访问级别:2
说明:使用[no]命令删除环回接口的接口IP地址。
9.1.3  shutdown
该命令用于配置接口管理状态。
语法:[no] shutdown
说明:使用[no]命令关闭环回接口管理状态。
访问级别:2
该命令用于进入接口范围配置模式。
语法:interface range <interface range>
取值范围:
<interface range>:接口范围格式,如:“ge2/1,ge2/2-4”或“lg2,lg4-6”。但接口必须是同样的类型。GE接口范围只包含GE端口。LG组范围只包含LG组。是最多256个字符的字符串。
说明:必须是相同类型的一组接口,(ge[ports{1..16}]),如:ge1、ge2-4。
接口范围配置模式下可运行以下命令。
访问级别:2
10.1.1  mls qos
该命令用于激活/关闭 MLS QoS配置模式。
语法:[no] mls qos
访问级别:2
10.1.2  mls qos map trust
缺省值:No trust
访问级别:2
10.1.3  mls qos map dscp-cos
该命令用于配置dscp到cos映射。
取值范围:
<dscp-value>:0 ..63
<cos-value>:0..7
访问级别:2
10.1.4  mls qos map dscp-mutation
取值范围:
<dscp-value>:0 ..63
访问级别:2
10.1.5  mls qos map ip-prec-dscp
取值范围:
<dscp-value>:0 ..63
访问级别:2
10.1.6  mls qos queue-set
该命令用于选择需要分配优先级的队列。
取值范围:
<queue ID>:0 - 3
wrr:权重轮询关键字
<weight>:1 - 15
缺省值:
Cos队列:0   1   2   3
权重:   2   4   6   8
访问级别:2
该命令用于删除某个队列所分配的优先级。
取值范围:
<queue ID>:0 - 3
访问级别:2
10.1.7  pvid
语法:pvid <VLAN-ID>
取值范围:
访问级别:1
10.1.8  switchport
语法:[no] switchport
访问级别:2
11 Interface VLAN命令
11.1  interface vlan
该命令用于进入VLAN接口配置模式。
语法:[no] interface vlan <VLAN interface ID>
取值范围:
<Interface ID>:VLAN接口ID 1- 4094
说明:使用[no]命令删除交换虚拟接口或超级SVI。
访问级别:2
VLAN接口配置模式下可运行以下命令。
11.1.1  apply-access-list
该命令用于将储存在数据库中的ACL列表应用/不应用于VLAN接口。
取值范围:
<filename1>:ACL列表名称。
访问级别:2
11.1.2  apply-acl-profile
该命令用于将储存在数据库中的ACL配置文件应用/不应用于SVI接口。
取值范围:
<profile-ID>:1~32
访问级别:2
11.1.3  description
该命令用于描述VLAN接口。
取值范围:
<des-string>:描述该VLAN的字符串(最多255个字符)
访问级别:2
11.1.4  ip address
该命令用于配置SVI接口的主备IP地址。
取值范围:
系统最多支持32个备用IP地址。
访问级别:2
11.1.5  ip igmp last-member-query-interval
取值范围:
<sec>:1-25秒
缺省值:1秒
访问级别:2
11.1.6  ip igmp query-interval
取值范围:
<sec>:10-3600秒
缺省值:125秒
访问级别:2
11.1.7  ip igmp query-response-interval
取值范围:
<sec>:10-25秒
缺省值:10秒
访问级别:2
11.1.8  ip igmp robutness
取值范围:2-10
缺省值:2
访问级别:2
11.1.9  ip igmp startup-query-interval
取值范围:
<sec>:10-3600秒
缺省值:1/4查询间隔
访问级别:2
11.1.10  ip igmp static-group
取值范围:
访问级别:2
11.1.11  ip igmp unsolicited-report-interval
取值范围:
<sec>:10-3600秒
缺省值:10秒
访问级别:2
11.1.12  ip igmp version
该命令用于激活/关闭 IP IGMP版本。
取值范围:
<ver#>:1-3
访问级别:2
11.1.13  ip igmp-proxy
该命令用于激活当前接口的IGMP代理。
访问级别:1
11.1.14  member-vlan
该命令用于配置超级SVI的成员。
语法:[no] member-vlan <member-list>
访问级别:2
11.1.15  shutdown
该命令用于激活/关闭VLAN接口管理状态。
语法:[no] shutdown
访问级别:1
11.1.16  super-svi
该命令用于配置SVI到超级SVI。
语法:[no] super-svi
访问级别:2
采用超级SVI的主要目的是减少3层模式下使用的IP地址的数量。
12 Interface GPON-OLT命令
12.1  interface gpon-olt
该命令用于进入GPON-OLT槽位配置模式。
语法:interface gpon-olt <1/port>
取值范围:
<1/port>:port{1...16}
访问级别:1
接口gpon-olt配置模式下可运行以下命令。
12.1.1   active
该命令用于批量激活ONU。
语法:active <logical-port>
取值范围:
<logical-port>   onu范围,  格式1、1-2、1、3、4,最多256个字符
访问级别:2
12.1.2  deactive
该命令用于去批量锁定ONU。
语法1:deactive <logical-port>
取值范围:
访问级别:2
12.1.3  all-ont
该命令用于配置所有ont。
语法1:all-ont <mode>
取值范围:
<mode> :  <enable>
访问级别:2
12.1.4  description
该命令用于配置接口特定描述。
语法1:description <description-value>
取值范围:
<description-value> :  string,最多256个字节
访问级别:0
12.1.5  disable
该命令用于禁用序列号ont。
语法1:description <logical-port>
取值范围:
<logical-port> :  onu范围,  格式1、1-2、1、3、4,最多256个字符
访问级别:0
12.1.6  enable
该命令用于批量启用序列号。
语法1:enable <logical-port>
取值范围:
访问级别:2
12.1.7  fec-tx
该命令用于关闭/启用下游FEC功能。
语法1:[no] fec-tx
访问级别:2
12.1.8  key-exchange ctrl
该命令用于使能/去使能PON 链路上激活的ONU的安全密钥重协商周期
语法:key-exchange-ctrl <enabled/disabled>
取值范围:
<enabled/disabled>
缺省值:
disabled
访问级别:2
帮助信息
Enable/Disable a periodic process of key exchange for active ONUs
12.1.9  key-exchange-interval
该命令用于配置PON 链路的安全密钥重协商周期
语法:key-exchange-interval <interval-value>
取值范围:
<interval-value>:1000 - 36000
缺省值:
10000 ms
访问级别:2
帮助信息
Key exchange process interval in milliseconds.
12.1.10  ont-discovery-mode
该命令用于设置ont 发现的模式。
语法:ont-discovery-mode < auto | disabled>
取值范围:
< auto | disabled>
访问级别:2
12.1.11  ont-discovery-interval
该命令用于设置ont 自动发现的周期。
语法:ont-discovery-intervlal <interval-value>
取值范围:<interval-value>1..180
访问级别:2
12.1.12  transceiver type
该命令用于配置transceiver 的类型。
语法:transceiver type <type-value>
取值范围:
Value list:
1.sps-43-48h-hp-cde-sd
2.sog4321-psgb
3.lte3680m
4.source-photonics
5.lte3680p-type-c-plus
6.any
7.any-reset-guard
8.any-reset-preamble
9.wtd-rtxm167-526-c-plus
10.wtd-rtxm167-522-b-plus
11.lte3680p-bc
12.superxon-c-plus
13.wtd-rtxm167-521
14.lte3678
15.sogp-4321-psga
16.gpon-general-1
17.gpon-general-2
18.gpon-general-3
19.gpon-general-4
20.gpon-general-5
21.gpon-general-6
22.gpon-general-7
23.gpon-general-8
24.gpon-general-9
访问级别:2
12.1.13  ont
该命令用于输入ONT配置级别。Sn或password 由 6.52.1的命令ont authentication mode来决定。
语法:ont <logical-port>  [ sn <sn-value> ] [ password <password-value> ]
[loid-auth<loid-auth-value>] [checkcode-auth<checkcode-auth-value>]
取值范围:
<logical-prot>:<1-64>
<sn-value>:string,12
<password-value>:string,10
<loid-auth-value>:string,24
<checkcode-auth>:string,12
系统提示:
telnet@P3108(config-if-gpon-ont-1/8/)# ont 1
telnet@P3108(config-if-gpon-ont-1/8/1)#
访问级别:2
12.1.14  no ont
该命令用于删除ont。
语法:no ont <logical-port>
取值范围:
<logical-port>   <1-64>
访问级别:2
12.1.15  pon-max-distance
该命令用于设置pon最大测距距离。
语法:pon-max-distance <max-log-distance>
取值范围:
<max-log-distance>   20..60
访问级别:2
12.1.16  reset
该命令用于批量重置onu。
语法:reset <logical-port>
取值范围:
<logical-port>   onu 范围,  格式1, 1-2, 1,3,4  最多256个字节
访问级别:2
12.1.17  shutdown
该命令用于激活/关闭Pon Link管理状态。
语法:[no] shutdown
访问级别:2
12.1.18  vlantranslate
该命令用于设置服务vlan和ONU vlan交换。
语法:vlantranslate <vport> <cvid> <mode> <svid> [new-cvid] [cos_act] [cos_val]
取值范围:
<vport>   ont port{1..64}/vport{1..16}
<cvid>    1..4095
<mode>   to
<svid>    1..4095
[new-cvid] 1..4095
[cos_act]  <copy|replace>
[cos_val]  0..7
访问级别:2
13 ONT命令
13.1.1  ont
该命令用于输入ONT配置级别。(这里面有组合关系的,需要根据此命令ont authentication-mode的结果来判断)
语法:onu <logical-port>  [ sn <sn-value> ] [ password <password-value> ]
取值范围:
<logical-port> :1..64
<sn-value>:    string,12 固定长度 help <The serial number is unique for ::::each ONT.>
<password-value> string,10 固定长度  help <The password expected of the ::::ONU.>
<loid-auth-value>:      string,24
<checkcode-auth>:      string,12
系统提示:
telnet@P3116(config-t-if-gpon-olt-1/1)# ont 2
telnet@P3116(config-if-gpon-ont-1/1/2)#
13.1.2  reset
该命令用于重置ONT。
语法:reset
Help : <Reset ONT.>
访问级别:2
13.1.3  activate
该命令用于激活ONT。
语法:active
Help: <Lock ONT.>
访问级别:2
13.1.4  deactivate
该命令用于关闭ONT。
语法:deactive
Help: <Unlock ONT.>
访问级别:2
13.1.5  description
该命令用于接口特定描述。
语法:description <description-value>
取值范围:
<description-value> :string,最多256个字节
13.1.6  show ont-info
该命令用于显示ONT的上线信息,如果没有上线,各参数显示空。
语法:show ont-info
Help: <Display the ONT information.>
访问级别:1
13.1.7  virtual-port
该命令用于增加一个virtual port。
语法:virtual-port <vitual-portid>  [port <unlock|lock>]
[encrypt <enabled|disabled>]
[rate-limit <downstream|upstream> <value> [burst]]
取值范围:
<vitual-portid>          1..16
<enaled|disabled>   <1|2>
<value>           0..1244160
[burst]]            0..4095缺省值128
Help: <Add a virtual port >
访问级别:2
13.1.8  no virtual-port
该命令用于删除一个virtual port。
语法:no virtual-port <vitual-portid>
取值范围:
访问级别:2
13.1.9  eth-uni activate/deactivate
该命令用于激活/去激活ONT的ethernet UNI。
语法:eth-uni <phy-portid> <activate|deactivate>
取值范围:
<phy-portid> :1..24
访问级别:2
13.1.10  eth-uni config
该命令用于配置ethernet UNI。
语法:eth-uni <phy-portid> config [mtu<mtu-value>] [pause-time<pause-time-value>] [speed<speed-value>] [duplex<duplex-value>]
取值范围:
<phy-portid> :1..24
<mtu-value>                          64..8192
<pause-time-value>                    0..65535
<speed-value>                        <10m|100m|1000m|10g|20g|5g|25g|40g|auto>
<duplex-value>                       <full|half|auto>
访问级别:2
13.1.11  eth-uni poe
该命令用于配置POE。
语法:eth-uni  <phy-portid> poe [<option-value>] [mode<mode-value>]
[priority<priority-value>] [max-power-class<max-power-class-value>]
取值范围:
<phy-portid> :1..24
<option-value>                       <enable|disable>
<mode-value>                        <signal|spare>
<priority-value>                      <critical|high|low>
<max-power-class-value>              <default|class0|class1|class2|class3|class4>
访问级别:2
13.1.12  no eth-uni
该命令用于删除eth-uni。
语法:no eth-uni <1-24,127,128>
取值范围:
<1-24,127,128> :1-24 for phy-port,127 for veip,128 for voip
访问级别:2
13.1.13  fec-tx
该命令用于开启/关闭 ONU 上行 FEC
语法:[no] fec-tx
取值范围:
访问级别:2
13.1.14  ip-host
该命令用于设置ont 主机ip。
语法:ip-host <ip> <ipmask> <gateway>  [DHCP-mode] [id]
取值范围:
<ip> :ont的IP地址,A.B.C.D
<ipmask>:ont的MASK 地址,A.B.C.D
<gateway>:ont的Gateway地址,A.B.C.D
[DHCP-mode] :DHCP模式,dynami|static
[id]:ip-host 索引
访问级别:2
13.1.15  no ip-host
该命令用于删除ip-host。
语法:no ip-host <id>
取值范围:
<id>
访问级别:2
13.1.16  loop-detect
该命令用于配置ont以太网单环路检测。
语法:loop-detect [state<state-value>] [auto-shutdown<auto-shutdown-value>]
[msg-freq<msg-freq-value>] [revert-time<revert-time-value>]
[msg index<index-value>] [eth-uni <eth-uni-value>] [svlan<svlan-value>]
[cvlan<cvlan-value>]
取值范围:
<state-value> ::<enable|disable>缺省值enable
<auto-shutdown-value>                 <enable|disable>,缺省值:enable
<msg-freq-value>                      1..65535
<revert-time-value>                     1..65535
<index-value>                         1..32
<eth-uni-value>                        1..24
<svlan-value>                          0..4095
<cvlan-value>                          0..4095
访问级别:2
13.1.17  mac-filter
该命令用于绑定mac筛选器配置文件。
语法1:mac-filter eth-uni <1-24,127,128> profile <profileid>
取值范围:
<profileid> :1..16
访问级别:2
语法2:mac-filter eth-uni <1-24,127,128> pre-assign [appletalk<filter-type>] [arp<filter-type>] [bridge-management-info<filter-type>] [ipv4-broadcast<filter-type>]
[ipv4-multicast<filter-type>] [ipv6-multicast<filter-type>] [ipx<filter-type>]
[netbeui<filter-type>] [pppoe-broadcast<filter-type>]
[rarp<filter-type>]
取值范围:
<filter-type> :<forward | filter>
访问级别:2
13.1.18  no mac-filter
该命令用于删除ont eth uni mac筛选器配置文件。
语法:no mac-filter eth-uni<1-24,127,128>profile
取值范围:
访问级别:2
13.1.19  mac-limit
该命令用于设置从ont学习的最大允许MAC条目数。
语法:mac-limit [eth-uni <1-24,127,128>] <maclimit>
取值范围:
<maclimit> :0..192
访问级别:2
13.1.20  multicast
该命令用于配置onu的组播表。
语法:multicast <port-type> <port-list> oper-profile <oper-profile-value>
<proftype-value> <pro-id>
取值范围:
<port-type> :<eth-uni|ip-host|veip>
<port-list> :1-24 for phy-port, 127 for veip, 128 for ip-host
<oper-profile-value>                   1..256
<proftype-value>                      <dynamic-profile|static-profile>
<pro-id>                             1..256
访问级别:2
13.1.21  no multicast
该命令用于配置onu的组播表。
语法:no multicast <port-type> <port-list>
取值范围:
访问级别:2
13.1.22  enable
该命令用于使能ONT。
语法:enable
Help: <Enable ONT>
访问级别:2
13.1.23  disable
该命令用于使能ONT。
语法:deactive
Help: <Disable ONT.>
访问级别:2
13.1.24  ont-pots-uni
该命令用于ONU pots-uni配置。
语法:ont-pots-uni <phy-id> <phone-num> <username> <password> <displayname>
<voip-sip-profile> [ip-host<id>]
取值范围:
<phy-id> :1..2
<phone-num>    string,32
<username>      string,32
<password>      string,32
<displayname>       string,32
<voip-sip-profile>     1..2
<id>                0..24
访问级别:2
13.1.25  no ont-pots-uni
该命令用于删除ONU POTS UNI配置。
语法:no ont-post-uni <phy-id>
取值范围:
<port-type> :1..2
访问级别:2
13.1.26  port-vlan
配置ONTvaln转换表
1. no port-vlan
该命令用于删除vlan 转换。
语法:no port-vlan <phy-portid>  [trans-index]
取值范围:
<phy-portid>    <1-24,127,128>1-24 for phy-port,127 for veip,128 for voip
[trans-index]      1..100
访问级别:2
2. port-vlan..downstream
该命令用于配置VLAN转换表的下行流模式属性。
语法:port-vlan <phy-portid> downstram <mode> intpid <intpid-value> outtpid <outtpid-value>
取值范围:
<mode>
enumerate,<inverse-upstream|forward|filter-vid-pbit-forward|filter-vid-only-forward|filter-pbit-only-forward|filter-vid-pbit-discard|filter-vid-only-discard|filter-pbit-only-discard|discad>
<intpid-value>:string,hex start‘0x’< outtpid-value>           string,hex start ‘0x’
访问级别:0
3. port-vlan ..rule
该命令用于配置port vlan 规则。
语法:
port-vlan <phy-portid> rule <index>
<double-tag|single-tag|untag>
取值范围:
<phy-portid><1-24,127,128>1-24 for phy-port,127 for veip,128 for voip
<index>:1..100
<double-tag|single-tag|untag>{ double-tag,single-tag,untag }
访问级别:0
4. port-vlan..rule ..double-tag
该命令用于设置port vlan 规则为双vlan-tag。
语法:
port-vlan <phy-portid> rule <index> double-tag [inner-pri <inner-pri-value>|inner-vid <inner-vid-value>|inner-tpid <inner-tpid-value>|outer-pri <outer-pri-value>|outer-vid <outer-vid-value>|outer-tpid <outer-tpid-value>]
取值范围:
<index>:1..100
<inner-pri-value>0..8
<inner-vid-value>0..4094
<inner-tpid-value>{  mode0 mode4 mode5 mode6 mode7}
<outer-pri-value>:0..7
<outer-vid-value>0..4094
<outer-tpid-value>:{ mode0 mode4 mode5 mode6 mode7 }
访问级别:0
5. port-vlan..rule ..double-tag discard
该命令用于在双tag下丢弃该port vlan 。
语法:port-vlan <phy-portid> rule <index> double-tag discard
[ether-type<ether-type-value>]
取值范围:
<index>:1..100
<ether-type-value>
ether-type-value list:
 0        - Do not filter on Ethertype
 1        - Ethertype = 0x0800 (filter IPoE frames)
 2        - Ethertype = 0x8863 or 0x8864 (filter PPPoE frames)
 3        - Ethertype = 0x0806 (filter ARP frames)
 4        - Ethertype = 0x86DD (filter IPv6 IpoE frames)
 5        - Ethertype = 0x888E (filter EAPOL frames)
访问级别:0
6. port-vlan..rule ..double-tag remove-both
该命令用于在双tag下删除inter与outer。
语法:
port-vlan <phy-portid> rule <index> double-tag remove-both
取值范围:
<phy-portid>:<1-24,127,128>1-24 for phy-port,127 for veip,128 for voip
<index>:1..100
<ether-type-value>
访问级别:0
7. port-vlan..rule ..double-tag remove-outer
该命令用于在双tag下删除该port vlan 规则外部vlan。
语法:
port-vlan <phy-portid> rule <index> double-tag remove-outer
取值范围:
<index>:1..100
<ether-type-value>
访问级别:0
8. port-vlan..rule ..double-tag translate
该命令用于在双tag下进行vlan转换。
语法:
port-vlan <phy-portid> rule <index> double-tag translate [inner-pri <inner-pri-value>|inner-vid <inner-vid-value>|inner-tpid <inner-tpid-value>|outer-pri <outer-pri-value>|outer-vid <outer-vid-value>|outer-tpid <outer-tpid-value>|ether-type<ether-type-value>]
取值范围:
<index>:1..100
<inner-pri-value>:0-7|copy-inner|copy-outer
<inner-vid-value> :0..4094|4096|4097
<inner-tpid-value>:{  mode0 mode1 mode2 mode3 mode4 mode5 mode6 mode7 }
<outer-pri-value>:0-7|copy-inner|copy-outer
<outer-vid-value>:0..4094|4096|4097
<outer-tpid-value>:{ mode0 mode1 mode2 mode3 mode4 mode5 mode6 mode7 }
<ether-type-value>:ether-type-value list:
访问级别:0
9. port-vlan..rule ..double-tag transparent
该命令用于在双tag规则下进行vlan穿透。
语法:port-vlan <phy-portid> rule <index> double-tag transparent
取值范围:
<index>:1..100
访问级别:0
10. port-vlan..rule ..single-tag
该命令用于设置port vlan 规则为单vlan-tag。
语法:
port-vlan <phy-portid> rule <index> signle-tag [inner-pri <inner-pri-value>|inner-vid <inner-vid-value>|inner-tpid <inner-tpid-value>]
取值范围:
<index>:1..100
<inner-pri-value>:0..8
<inner-vid-value>:0..4094
<inner-tpid-value> :{ mode0 mode4 mode5 mode6 mode7 }
访问级别:0
11. Port-vlan..rule..signle-tag discard
该命令用于在单 tag下丢弃该port vlan 。
语法:
 signle-tag discard[ether-type<ether-type-value>]
取值范围:
<index>:1..100
<ether-type-value>
访问级别:0
12. port-vlan..rule..signle-tag q-in-q
该命令用于在单 tag下增加一层vlan。
语法:
port-vlan <phy-portid> rule <index> signle-tag q-in-q[inner-pri <inner-pri-value>|inner-vid <inner-vid-value>|inner-tpid
取值范围:
<index>:1..100
<inner-vid-value>:0..4096
<inner-tpid-value> :{ mode0 mode1 mode2 mode3 mode4 mode5 mode6 mode7  }
<outer-vid-value>:0..4096
<outer-tpid-value> :{ mode0 mode1 mode2 mode3 mode4 mode5 mode6 mode7 }
<ether-type-value>
访问级别:0
13. port-vlan..rule..signle-tag remove-tag
该命令用于在单vlan tag下删除该port vlan。
语法:
port-vlan <phy-portid> rule <index> signle-tag remove-tag[ether-type<ether-type-value>]
取值范围:
<index>:1..100
<ether-type-value>
访问级别:0
14. port-vlan..rule..signle-tag translate
该命令用于在单tag下进行vlan 转换。
语法:
port-vlan <phy-portid> rule <index> signle-tag translate[inner-pri <inner-pri-value>|inner-vid <inner-vid-value>|inner-tpid <inner-tpid-value>
取值范围:
<index>:1..100
<ether-type-value>
访问级别:0
15. port-vlan..rule..signle-tag transparent
该命令用于在单 tag下进行vlan 穿透。
语法:port-vlan <phy-portid> rule <index> signle-tag transparent
取值范围:
<index>:1..100
访问级别:0
16. port-vlan..rule..untag add-vid
该命令用于在untag下添加vid。
语法:
port-vlan <phy-portid> rule <index> untag add-vid[inner-pri <inner-pri-value>
取值范围:
<index>:1..100
<ether-type-value>
访问级别:0
17. Port-vlan..rule..untag  discard
该命令用于在untag下丢弃该port vlan 。
语法:
port-vlan <phy-portid> rule <index> untag discard
取值范围:
<index>:1..100
<ether-type-value>
访问级别:0
18. port-vlan..rule..untag  q-in-q
该命令用于在untag下在该vlan下再添加一条vlan。
语法:
port-vlan <phy-portid> rule <index> untag  q-in-q [inner-pri <inner-pri-value> |inner-vid <inner-vid-value> |inner-tpid <inner-tpid-value> |outer-pri <outer-pri-value>|outer-vid <outer-vid-value> |outer-tpid <outer-tpid-value>|ether-type<ether-type-value>]
取值范围:
<index>:1..100
<inner-tpid-value>:{ mode0 mode1 mode2 mode3 mode4 mode5 mode6mode7  }
<ether-type-value>
访问级别:0
19. port-vlan..rule..untag transparent
该命令用于在untag下进行vlan穿透。
语法:port-vlan <phy-portid> rule <index> untag transparent
取值范围:
<phy-portid>:<1-24,127,128>, 1-24 for phy-port,127 for veip,128 for voip
<index>:1..100
访问级别:0
13.1.27  no rate-limit
该命令用于删除 ont eth-un的速率限制。
语法:no rate-limit eth-uni<eth-uni-value>  <direction>
取值范围:
<eth-uni-value>:<1-24,127,128>, 1-24 for phy-port,127 for veip,128 for voip
<direction>:<upstream|downstream>
访问级别:2
13.1.28  rate-limit downstream
该命令用于设置ONT以太网端口的下游流量控制。
语法:rate-linlit eth-uni <eth-uni-value>
downstream <ds-rate-limit-cir> <ds-rate-limit-pir>
取值范围:
<ds-rate-limit-cir>:128..1244160
<ds-rate-limit-pir>:128..1244160
访问级别:2
13.1.29  rate-limit upstream
该命令用于设置ONT以太网端口的上游流量控制。
upstream <ds-rate-limit-cir> <ds-rate-limit-pir>
取值范围:
访问级别:2
13.1.30  rogue-ont
该命令用于是否开启流氓onu检测。
语法:rogue ont<mode>
取值范围:
<mode> : <enable/disable>,缺省值:disable
访问级别:2
13.1.31  service
该命令用于绑定业务配置文件。
语法: service flow-profile <flow-profile-id> tcont-bind-profile <tcont-bind-profile-id>
取值范围:
<flow-profile-id>: 1..128
<tcont-bind-profile-id>:1..128
访问级别:2
13.1.32  no service
该命令用于删除业务绑定。
语法:no service
访问级别:2
13.1.33  vlan-filter
该命令用于配置ONT的vlan筛选器。
语法:vlan-filter <port-type> <port-list> vlan-start<vlan-start-value>
vlan-end <vlan-end-value> [tagged<tagged-value>] [untagged<untagged-value>]
取值范围:
<port-list>:<1-24,127,128>1-24 for phy-port, 127 for veip, 128 for ip-host
<vlan-end-value>:1..4095
<tagged-value>:<transparent|discard|vlan-filter>
<untagged-value>:<transparent|discard>
访问级别:2
13.1.34  no vlan-filter
该命令用于删除ONT的vlan筛选器。
语法:no vlan-filter <port-type> <port-list>
取值范围:
<port-type>:<eth-uni|ip-host|veip>
访问级别:2
14 Show命令
14.1  show access-lists
该命令用于显示P3116系统中的访问列表。
语法:show access-lists
访问级别:0
14.2  show acl-applied-interface
该命令用于显示已应用了ACL规则的所有接口。
语法:show acl-applied-interface
访问级别:0
14.3  show alarm
该命令用于显示单板上的当前告警列表。
语法1:show alarm
访问级别:0
该命令用于显示单板上的当前告警列表详细信息。
语法2:show alarm detail
访问级别:0
14.4  show alarm-filter
该命令用于显示alarm的过滤器。
语法:show alarm-filter <filter-index>
取值范围:
<filter-index>:<1-64>
访问级别:0
14.5  show alarm-history
该命令用于显示告警历史。
语法:show alarm-history
访问级别:0
14.6  show alarm-log
该命令用于显示告警日志。
语法:show alarm-log
访问级别:0
14.7  show anti-rogueont
该命令用于流氓onu状态。
语法:show anti-rogueont
访问级别:0
14.8  show banner
该命令用于显示登录横幅。
语法:show banner
访问级别:0
14.9  show boot
该命令用于显示启动及相关环境变量。
语法:show boot attributes
访问级别:0
14.10  show clock
该命令用于显示系统时钟。
语法:show clock
访问级别:0
14.11  show configuration
该命令用于显示当前运行配置信息。
所显示的信息包括用户针对产品所做出的任何最新的更改。
语法:
show configuration running [gpon-profile| interface-ge | { interface-gpon-olt <port> <ontid>} | system| vlan]
取值范围:
<port> :单接口,<1/port> (port{1..16}).
<ontid>:1..64
访问级别:0
14.12  show cpld
该命令用于显示cpld版本。
语法:show cpld
访问级别:0
14.13  show cpu
该命令用于显示CPU利用率信息。
语法:show cpu <delay time>
取值范围:
<delay time>:延迟时间,5、60或300秒
访问级别:0
14.14  show database-acl-record
该命令用于显示保存在数据库的ACL配置文件。
语法:show database-acl-record
访问级别:0
14.15  show event-log
该命令用于显示事件日志。
语法:show event-log
访问级别:0
14.16  show fan
该命令用于显示风扇状态。
语法:show fan
访问级别:0
14.17  show gpon profile
该命令用于显示gpon的配置。
语法:
show gpon profile dba <profile-id>
show gpon profile flow <profile-id1>
show gpon profile multicast-dynamic <profile-id1 / profile-id2>
show gpon profile multicast-oper <profile-id>
show gpon profile multicast-static <profile-id1 / profile-id2>
show gpon profile multicast-userview
show gpon profile ont-uni-cfg [id]
show gpon profile rate-ctrl <profile-id>
show gpon profile tcont-bind <profile-id>
show gpon profile tcont-svc<profile-id>
show gpon profile vportsvc <profile-id>
取值范围:
<profile-id>   1..256|all
<profile-id1>  1..256|all
<profile-id1 / profile-id2> {1..256 }/{0,31}|all
[id]  <1..32>,e例如1 或 1-2 ,最多256个字节
<profile-id3> :1..128
访问级别:0
14.18  show host-route
该命令用于显示主机路由表。
语法:
show host-route
show host-route interface giga-interface <module/port>
show host-route interface link-aggregation <lag-ID>
show host-route interface vlan <VLAN-ID>
取值范围:
<module/port>:单接口千兆以太网<单板/端口>(单板{1-2}/端口{1-16}),如:3/2,为最多32个字符的ASCII字符串。
<lag-ID>:链路汇聚接口号,<1..32>。
<VLAN-ID>:VLAN ID,范围是1至4094。
访问级别:0
14.19  show interface description
该命令用于显示2层接口状态或计数器。
语法:show interface description
访问级别:0
14.20  show interface gpon-olt..broadcast gem-port
该命令用于显示广播信息。
语法:show interface gpon-olt< module/port> broadcast gem-port
取值范围:
module/port:1/1..1/16 string
访问级别:0
14.21  show interface gpon-olt..counters gemport
该命令用于显示GEM端口计数器。
语法:show interface gpon-olt < module/port> counters gemport [vport]
取值范围:
[vport] :ont port{1..64}/vport{1..16}
访问级别:0
14.22  show interface gpon-olt..counters mulitcast
该命令用于显示多播GEM端口计数器。
语法:show interface gpon-olt< module/port>counters mulitcast
取值范围:
访问级别:0
14.23  show interface gpon-olt..counters nni
该命令用于显示nni口计数器。
语法:show interface gpon-olt < module/port> counters nni
取值范围:
访问级别:0
14.24  show interface gpon-olt..ont
该命令用于显示ont 计数器。
语法:show interface gpon-olt< module/port> counters ont [ontid]
取值范围:
[ontid] :1..64
访问级别:0
14.25  show interface gpon-olt..gpon-link
该命令用于显示GPON LINK状态。
语法:show interface gpon-olt< module/port> gpon-link
取值范围:
[ontid] :1..64
访问级别:0
14.26  show interface gpon-olt..key-exchange-ctrl
该命令用于显示用/禁用活动ONU的定期密钥交换过程。
语法:show interface gpon-olt < module/port>key-exchange-ctrl
取值范围:
访问级别:0
14.27  show interface gpon-olt..key-exchange-interval
该命令用于显示密钥交换进程间隔(毫秒)。
语法:show interface gpon-olt < module/port> kkey-exchange-interval
取值范围:
访问级别:0
14.28  show interface gpon-olt..ont..brief
该命令用于显示ONU的主要信息。
语法:show interface gpon-olt [ module/port ] ont <logical-port> brief
取值范围:
logical-port:1..64
访问级别:0
14.29  show interface gpon-olt..ont..capability
该命令用于显示ont功能。
语法:show interface gpon-olt < module/port> ont <logical-port> capability
取值范围:
logical-port:1..64
访问级别:0
14.30  show interface gpon-olt..ont..eth-uni
该命令用于显示ONU统计。
语法:show interface gpon-olt< module/port> ont <logical-port> eth-uni <id>
取值范围:
logical-port:1..64
Id:  ONT eth-port list<1-24,127,128|all>, 例如: 1,3,6-8
访问级别:0
14.31  show interface gpon-olt..ont..loop-detect
该命令用于显示循环检测的配置。
语法:show interface gpon-olt< module/port> ont <logical-port> loop-detect
取值范围:
logical-port:1..64
访问级别:0
14.32  show interface gpon-olt..ont..mac-address
该命令用于显示ont网桥端口mac地址。
语法:show interface gpon-olt< module/port> ont <logical-port> mac-address
取值范围:
logical-port:1..64
访问级别:0
14.33  show interface gpon-olt..ont..mac-filter
该命令用于显示ont eth uni 的mac地址筛选器。
语法:show interface gpon-olt< module/port> ont <logical-port> mac-filter pre-assign|profile <phy-portid>
取值范围:
logical-port:1..64
<phy-portid>: 1..128
访问级别:0
14.34  show interface gpon-olt..ont..optical-info
该命令用于显示当前ONT的光学状态。
语法:show interface gpon-olt< module/port> ont <logical-port> optical-info
取值范围:
logical-port:1..64
访问级别:0
14.35  show interface gpon-olt..ont..port-vlan
语法showinterface gpon-olt< module/port> ont <logical-port> port-vlan <1-24,127,128>
取值范围:
logical-port:1..64
<1-24,127,128>: 1-24 for phy-port,127 for veip,128 for voip
访问级别:2
14.36  show interface gpon-olt..ont..profile
该命令用于显示应用的配置文件信息。
语法:show interface gpon-olt< module/port> ont <logical-port> profile
取值范围:
logical-port:1..64
访问级别:0
14.37  show interface gpon-olt..ont..summary
该命令用于显示ONU摘要。
语法:show interface gpon-olt< module/port> ont <logical-port>summary
取值范围:
logical-port:1..64
访问级别:0
14.38  show interface gpon-olt..ont..uni-status
该命令用于显示ONT UNI端口状态。
语法:show interface gpon-olt< module/port> ont <logical-port> uni-status
取值范围:
logical-port:1..64
访问级别:0
14.39  show interface gpon-olt..ont..virtual-port
该命令用于显示ONT UNI端口状态。
语法:show interface gpon-olt< module/port> ont <logical-port> virtual-port <vitual-portid>
取值范围:
logical-port:1..64
<vitual-portid> ONT virtual-port list, e.g. 1,3,6-9
访问级别:0
14.40  show interface gpon-olt..ont-performance
该命令用于显示ont性能当前/历史-15分钟。
语法:show interface gpon-olt< module/port> ont-performance <logical-port> <type>
取值范围:
logical-port  1..64
<type>        <current-15minutes|historic-15minutes>
访问级别:0
14.41  show interface gpon-olt..ont-range.. mac-address
语法:show interface gpon-olt < module/port> ont-range <logical-port> mac-address
取值范围:
logical-port  1..64
访问级别:0
14.42  show interface gpon-olt..ont-range.. brief
该命令用于显示ONU的主要信息。
语法:show interface gpon-olt < module/port> ont-range <logical-port> brief
取值范围:
logical-port  1..64
访问级别:0
14.43  show interface gpon-olt..ont-range..capability
该命令用于显示ONU的功能。
语法:show interface gpon-olt < module/port> ont-range <logical-port>capability
取值范围:
logical-port  1..64
访问级别:0
14.44  show interface gpon-olt..ont-range..loop-detec
该命令用于显示循环检测的配置。
语法:show interface gpon-olt < module/port> ont-range <logical-port>loop-detec
取值范围:
logical-port  1..64
访问级别:2
14.45  show interface gpon-olt..ont-range..summary
该命令用于显示ont 的 summary。
语法:show interface gpon-olt < module/port> ont-range <logical-port>summary
取值范围:
logical-port  1..64
访问级别:0
14.46  show interface link-aggregation
该命令用于显示链路聚合类型接口。
语法:show interface link-aggregation<group> [counters|switchport]
取值范围:
<group> :1..32
访问级别:0
14.47  show interface gpon-olt..ont-registered
该命令用于显示所有注册的ONU。
语法:show interface gpon-olt< module/port> ont-registered
取值范围:
访问级别:0
14.48  show configuration running interface-gpon-olt
该命令用于显示OLT的运行配置信息。
语法:show configuration running interface-gpon-olt
访问级别:0
14.49  show interface gpon-olt..ont-unbound
该命令用于显示某个端口下的未捆绑的ONU
语法:show interface gpon-olt<module/port> ont-unbound
取值范围:
访问级别:0
14.50  show interface gpon-olt..counters
该命令用于显示OLT统计计数器。
语法:show interface gpon-olt <module/port> counters
取值范围:
访问级别:0
14.51  show interface gpon-olt…optical-info
该命令用于显示当前PON/ONT的光路状态。
语法1:show interface gpon-olt <module/port> optical-info
语法2:show interface gpon-olt <module/port>  ont <ont_id>optical-info
ont_id:   1-64
14.52  show interface gpon-olt..pon-max-distance
该命令用于显示pon最大距离。
语法:show interface gpon-olt <module/port>pon-max-distance
取值范围:
访问级别:0
14.53  show interface gpon-olt..transceiver type
该命令用于显示transceiver 的类型。
语法:show interface gpon-olt <module/port>transceiver type
取值范围:
访问级别:0
14.54  show interface giga-ethernet..counters
该命令用于显示GE接口上的计数器。
语法:show interface giga-ethernet [module/port] counters
取值范围:
module/port:<module/port> (module {1-2}/port {1-16})Module:1 internal port <1-16>.Module:2 uplink port <1-4>, 1-2 : 10G port /3-4 Ge port. for example, 1/2
访问级别:0
14.55  show interface giga-ethernet..optical-info
该命令用于显GE口示激光(SFP)测量参数。
语法:show interface giga-ethernet [module/port] optical-info
取值范围:
访问级别:0
14.56  show interface giga-ethernet..switchport
该命令用于显示GE接口的交换信息。
语法:show interface giga-ethernet [module/port] switchport
取值范围:
访问级别:0
14.57  show interface loopback
该命令用于显示环回接口。
语法:show interface loopback <loopback-id>
取值范围:
loopback-id:1-16
访问级别:0
14.58  show interface management in-band
该命令用于显示带内管理接口。
语法:show interface management in-band
访问级别:0
14.59  show interface pon-protection-group
该命令用于显示pon保护组。
语法:show interface pon-protection-group [psg-id]
取值范围:
psg-id ;1..8
访问级别:0
14.60  show interface super-vlan
该命令用于显示接口Super VLAN信息。
语法:show interface super-vlan
访问级别:0
14.61  show interface vlan
该命令用于显示接口VLAN信息。
语法:show interface vlan [VLAN-ID]
取值范围:
[VLAN-ID]:VLAN ID,1至4094。
访问级别:0
14.62  show ip igmp debug-traces
该命令用于显示IGMP调试跟踪。
语法:show ip igmp debug-traces
访问级别:0
14.63  show ip igmp snooping
该命令用于显示VLAN的IGMP snooping参数,并列出所snooping的组信息。
语法:show ip igmp snooping [vlan <vlan-id>]
取值范围:
<VLAN-ID>:VLAN ID,范围是<1..4094>
访问级别:0
14.64  show ip igmp static-group
该命令用于显示ip igmp静态组。
语法:show ip igmp static-group
访问级别:0
14.65  show ip igmp statistics
该命令用于显示IGMP统计信息。
语法:
show ip igmp statistics [ total | vlan <VLAN-ID>]
取值范围:
total:显示总的IGMP统计的关键字
vlan:指定VLAN ID的 VLAN关键字
访问级别:0
14.66  show ip interface brief
该命令用于显示IP接口简要信息。
语法:show ip interface brief
访问级别:0
14.67  show ip pppoe vlan-option statistics
该命令用于显示L2 PPPOE中继计数器。
语法:show ip pppoe vlan-option statistics
访问级别:0
14.68  show ip sntp
该命令用于显示SNTP的信息,包括SNTP服务端和SNTP客户端。
语法:show ip sntp
访问级别:0
14.69  show leds
该命令用于显示指示灯状态。
语法:show leds
访问级别:0
14.70  show link-aggregation summary
该命令用于显示链路汇聚组端口中继信息。
语法:show link-aggregation summary
访问级别:0
14.71  show mac-address-table
该命令用于显示所有MAC表,包括动态及静态的MAC地址。
语法:
show mac-address-table satic
show mac-address-table interface giga-ethernet <module/port>
show mac-address-table vlan <vlan-id>
取值范围:
static:显示静态MAC表。
<module/port>     module# (1..2), port# (1..16), eg.,2/4<cr>
<vlan-id> :1..4094  通过vlanid显示MAC地址筛选表
访问级别:0
14.72  show mac-age-time
该命令用于显示MAC老化时间。
语法:show mac-age-time
访问级别:0
14.73  show mac-filter
该命令用于显示MAC过滤表。
语法:show mac-filter
访问级别:0
14.74  show management ip route
该命令用于显示管理IP路由表。
语法:show management ip route
访问级别:0
14.75  show memory
该命令用于显示系统内存的信息。
语法:show memory
访问级别:0
14.76  show mls qos
该命令用于显示MLS qos信息。
语法:
show mls qos
show mls qos interface  {giga-ethernet<range> | link-aggregation <link-ID>}
取值范围:
giga-ethernet<range>:GE类型接口范围,如:1/2、2/1-4,为最多32个字符的ASCII字符串
link-aggregation <link-ID>:链路汇聚接口号,1至32
访问级别:0
14.77  show mls qos maps
该命令用于显示MLS qos映射信息。
语法:
show mls qos maps
show mls qos maps {dscp-cos | dscp-mutation | ip-prec-dscp } interface {giga-ethernet<range> | link-aggregation <link-ID>}
取值范围:
dscp-cos:DSCP到CoS的映射关键字
dscp-mutation:DSCP到DSCP的转化映射关键字
ip-prec-dscp:IP优先到DSCP的映射关键字
访问级别:0
14.78  show mls qos queue-set
该命令用于显示MLS qos队列集信息。
语法:
show mls qos queue-set interface {giga-ethernet<range> | link-aggregation <link-ID>}
取值范围:
queue-set:队列集关键字
访问级别:0
14.79  show monitor session
该命令用于显示系统中的监控会话,包括保存在缓存中的和已激活的。
语法:show monitor session [session-id]
取值范围:
session-id:1-4
说明:不带参数时,将显示系统中配置的所有监控会话。当带参数时,将显示参数指定的监控会话。显示的监控会话是基于登录的CLI用户进程的。
访问级别:0
14.80  show multicast-group-author
该命令用于显示多播组作者。
语法:show multicast-group-author <port-id>
取值范围:
<port-id> :1..16
访问级别:0
14.81  show multicast-log
该命令用于显示多播有日志。
语法:show multicast-log
访问级别:0
14.82  show multicast-vlan
该命令用于显示组播VLAN。
语法:show multicast-vlan
访问级别:0
14.83  show multicast-vlan-to-multi-gem
该命令用于显示组播VLAN 到gemport。
语法:show multicast-vlan-to-multi-gem
访问级别:0
14.84  show ont-authentication-mode
该命令用于显示ont身份验证方法。
访问级别:0
14.85  show ont-unbound
该命令用于显示所有未绑定的onu数据。
语法:
show ont-unbound
访问级别:0
14.86  show onu-upgrade
该命令用于显示ONU升级信息。
语法1:
show onu-upgrade result  {auto|manual } [detail]
语法2:
show onu-upgrade config
取值范围:
result:ONU升级结果
detail: onu升级结果详细信息
config:onu升级配置信息。
访问级别:0
14.87  show pm
该命令用于显示性能管理。
语法1:show pm interface
访问级别:0
E.g
Total Monitored ports: 3
Index Interface type  Interface       PM state
1     ONU_UNI         1/1/1/2         Enable
2     GEM             1/2             Enable
3     OLT              1/3             Enable
该命令用于显示PM GPON OLT 的历史。
语法2:show pm interface gpon-olt <port> history
取值范围:
port :<1/port> (port{1..16})
访问级别:0
该命令用于显示PM GPON OLT 的eth uni/gemport历史。
语法2:show pm interface gpon-olt <port> ont <ont-id> {eth-history|gem-history <olt|ont>}
取值范围:
ont-id:1..64
访问级别:0
show preview-group 1 1
14.88  show preview-group
该命令用于显示预览组。
语法2:show preview-group <port-id>
取值范围:
port-id :1..16
访问级别:0
14.89  show spanning-tree mst
该命令用于显示多生成树信息。
语法1:show spanning-tree mst configuration
语法2:show spanning-tree mst instance [MST id] [detail]
语法3:show spanning-tree mst instance [MST id] interface {giga-ethernet <module/port> | link-aggregation <linkid> } [detail]
取值范围:
MST id:0..15
module/port:接口千兆以太网<单板/端口>(单板{1-2}/端口{1-16}),如:2/2,为最多8个字符的字符串
linkid:<1..32>
访问级别:0
14.90  show spanning-tree vlan
该命令用于显示VLAN的详细RSTP信息。
语法:show spanning-tree vlan <vlan id > [detail]
取值范围:<1..1>
访问级别:0
14.91  show syslog
该命令用于显示系统日志及运行配置。
语法:show syslog [flash {all|kernel|alarm|event|others<decimal>} | running-config
取值范围:
flash:显示保存于闪存的系统日志
running-config:显示日志及运行配置。
{all|kernel|syslog}:需要显示的单板
<decimal>:<1..1024> 需要显示log的条数。
访问级别:0
14.92  show system
该命令用于显示系统信息,包括任何配置模式下的单板、硬件、软件版本信息。
语法:show system
访问级别:0
14.93  show task
该命令用于显示当前运行任务的信息。
语法1:show task
访问级别:0
该命令用于显示制定的运行任务的信息。
语法2:show task <taskname>
取值范围:
<taskname> :最多32个字符
访问级别:0
14.94  show temperature
该命令用于显示设备温度。
语法:show temperature
访问级别:0
14.95  show user
该命令用于显示用户账户列表。
语法:show user
访问级别:0
14.96  show user-isolation
该命令用于显示用户隔离配置。
语法:show user-isolation
访问级别:0
14.97  show version
该命令用于显示版本信息,包括单板、硬件、软件版本信息。
语法:show version
访问级别:0
14.98  show vlan
该命令用于显示所有VLAN的信息或特定VLAN的信息。
语法1:show vlan
语法2:show vlan <VLAN-ID>
取值范围:
<VLAN-ID>VLAN ID14094
14.99  show ont-info
该命令用于显示所有ONT的状态和在线信息。
语法1:show ont-info
语法2:show ont-info <pon_id>
语法3:show ont-info <pon_id> detail
取值范围:
<pon_id>:pon ni id,1..16
示例:telnet@P3116> show ont-info
ONT     SN                 Status    Find     Auth      Reason
1/8/1   GPON005f2ab1   online    auto     auto      ----
1/8/2   GPON005f2be1   offline   auto     auto      ----
1/8/3   GPON005f2ad1   online    auto     auto       ----
15 缩写术语
缩略语
英文解释
中文解释
ACL
Access Control List
访问控制列表
ARP
Address Resolution Protocol
地址解析协议
DBA
Dynamic Bandwidth Allocation
动态带宽分配
DHCP
Dynamic Host Configuration Protocol
动态主机配置协议
DMZ
Demilitarized Zone
自治区域
EAPOL
Extensible Authentication Protocol Over LAN
扩展的LAN认证协议
GEPON
Gigabit Ethernet Passive Optical Network
千兆以太无源光网络
ICMP
Internet Control Message Protocol
互联网控制消息协议
IGMP
Internet Group Management Protocol
互联网组管理协议
LTM
Line Terminal Modules
线路终端模块
OAM
Operation, Administration and Maintenance
配置、管理和维护
OID
Object Identifier
实体标识
OLT
Optical Line Terminal
光线路终端
ONU
Optical Network Unit
光网络单元
PON
无源光网络
RADIUS
Remote Authentication Dial in User Service
远程认证服务器
SLA
Service Level Agreement
服务协议水平
VLAN
Virtual Local Area Network
虚拟本地网
