01-EVPN命令
本章节下载: 01-EVPN命令 (1.09 MB)
1.1.2 address-family evpn (public instance view)
1.1.3 address-family evpn (VPN instance view)
1.1.4 address-family ipv4 (public instance view)
1.1.5 address-family ipv6 (public instance view)
1.1.6 address-family l2vpn evpn (BGP instance view)
1.1.10 arp mac-learning disable
1.1.11 arp-advertising disable
1.1.13 display bgp l2vpn evpn dampened
1.1.14 display bgp l2vpn evpn flap-info
1.1.15 display bgp l2vpn evpn inlabel
1.1.16 display bgp route-target evpn
1.1.17 display evpn auto-discovery
1.1.18 display evpn df-election
1.1.21 display evpn ipv6 auto-discovery
1.1.24 display evpn route mac-mobility
1.1.26 display evpn routing-table
1.1.27 display evpn route xconnect-group
1.1.28 display evpn track peer
1.1.29 display l2vpn forwarding evpn
1.1.30 display l2vpn forwarding evpn split-horizon
1.1.33 evpn df-election ac-influence enable
1.1.34 evpn df-election algorithm (interface view /IESI view)
1.1.35 evpn df-election algorithm (system view)
1.1.36 evpn df-election preference
1.1.37 evpn df-election preference non-revertive
1.1.39 evpn frr local (cross-connect group EVPN instance view)
1.1.40 evpn frr local (EVPN instance view/VSI EVPN instance view)
1.1.42 evpn local-service-id remote-service-id
1.1.43 evpn mpls routing-enable
1.1.44 evpn multihoming advertise disable
1.1.45 evpn multihoming advertise ignore-ethernet-tag
1.1.46 evpn multihoming vpls-frr local
1.1.47 evpn multihoming vpws-frr local
1.1.48 evpn multihoming re-originated mac
1.1.49 evpn multihoming timer df-delay
1.1.51 evpn route mac-mobility suppression
1.1.65 l2vpn ping-ce source-mac
1.1.66 mac-advertising disable
1.1.67 nd mac-learning disable
1.1.68 peer advertise encap-type mpls
1.1.69 peer next-hop-invariable
1.1.77 reset evpn route mac-mobility suppression
1.1.81 snmp-agent trap enable evpn
1.1.85 vpn-route cross multipath
设备不支持VXLAN、EVPN VXLAN、EVPN数据中心互联组网、以太网服务实例类型的AC。
设备不支持通过evpn instance命令创建EVPN实例。本手册中涉及的上述不支持功能相关内容,仅供理论学习和参考,请勿在本设备上尝试实施相关操作。
ac interface命令用来指定交叉连接关联的接口。
undo ac interface命令用来取消接口与交叉连接的关联。
ac interface interface-type interface-number [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ]
undo ac interface interface-type interface-number
交叉连接未关联接口。
交叉连接视图
access-mode:指定接入模式。当AC为三层接口或三层子接口时,缺省接入模式如下:
· 对于三层接口,缺省接入模式为Ethernet。
· 对于三层子接口,缺省接入模式为VLAN。
ethernet:指定接入模式为Ethernet。
vlan:指定接入模式为VLAN。
track track-entry-number&<1-3>:配置AC(三层接口)与指定Track项联动。track-entry-number为Track项的序号,取值范围为1~1024;&<1-3>表示前面的参数最多可以输入3次。指定本参数后,仅当关联的Track项中至少有一个状态为positive时,AC的状态才会up;否则,AC的状态为down。
在交叉连接视图/自动发现交叉连接视图下执行本命令后,从关联接口接收到的所有报文,将通过与该交叉连接关联的PW或另一条AC转发。
接入模式是PE对从CE收到的以太网帧携带的外层VLAN Tag的理解方式,以及PE向CE发送以太网帧的方式。接入模式分为两种:
· VLAN接入模式:CE发送给PE的以太网帧头需要带有一个VLAN Tag,该Tag被称为P-Tag,即服务提供商网络为了区分用户而添加的“服务定界符”。PE发送以太网帧给CE时,也需要携带P-Tag。
· Ethernet接入模式:CE发送给PE的以太网帧头中如果带有VLAN Tag,则该Tag被称为U-Tag,即用户网络的内部VLAN Tag,对于PE设备没有意义。PE发送以太网帧给CE时,不需要携带P-Tag。
# 在交叉连接组vpna的交叉连接aaa中关联接口GigabitEthernet1/0/6,使该接口接收到的所有报文都通过与该交叉连接关联的PW或另一条AC转发。
[Sysname] xconnect-group vpna
[Sysname-xcg-vpna] connection aaa
[Sysname-xcg-vpna-aaa] ac interface gigabitethernet 1/0/6
· connection(MPLS命令参考/MPLS L2VPN)
· display l2vpn interface(MPLS命令参考/MPLS L2VPN)
· encapsulation(MPLS命令参考/MPLS L2VPN)
· pw-type(MPLS命令参考/MPLS L2VPN)
address-family evpn命令用来进入公网实例EVPN视图。
undo address-family evpn命令用来删除公网实例EVPN视图下的所有配置。
address-family evpn
公网实例视图
在公网实例EVPN视图下可以配置EVPN的参数,如EVPN的RT属性、应用的出方向路由策略等。
# 进入公网实例EVPN视图。
[Sysname] ip public-instance
[Sysname-public-instance] address-family evpn
[Sysname-public-instance-evpn]
address-family evpn命令用来进入VPN实例EVPN视图。
undo address-family evpn命令用来删除VPN实例EVPN视图下的所有配置。
address-family evpn
VPN实例视图
在VPN实例EVPN视图下可以配置EVPN的参数,如EVPN的RT属性、应用的出方向路由策略等。
# 进入VPN实例EVPN视图。
[Sysname] ip vpn-instance tenant
[Sysname-vpn-instance-tenant] address-family evpn
[Sysname-vpn-evpn-tenant]
address-family ipv4命令用来进入公网实例IPv4地址族视图。
undo address-family ipv4命令用来删除公网实例IPv4地址族视图下的所有配置。
address-family ipv4
公网实例视图
# 进入公网实例IPv4地址族视图。
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4]
address-family ipv6命令用来进入公网实例IPv6地址族视图。
undo address-family ipv6命令用来删除公网实例IPv6地址族视图下的所有配置。
address-family ipv6
公网实例视图
# 进入公网实例IPv6地址族视图。
[Sysname-public-instance] address-family ipv6
[Sysname-public-instance-ipv6]
address-family l2vpn evpn命令用来创建BGP EVPN地址族,并进入BGP EVPN地址族视图。如果BGP EVPN地址族已经存在,直接进入BGP EVPN地址族视图。
undo address-family l2vpn evpn命令用来删除BGP EVPN地址族,及相应地址族视图下的所有配置。
不存在BGP EVPN地址族。
BGP实例视图
BGP EVPN地址族视图下的配置,只对公网BGP EVPN地址族的路由和对等体生效。
# 创建BGP EVPN地址族,并进入BGP EVPN地址族视图。
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn]
advertise evpn route命令用来配置允许BGP EVPN路由通过VPNv4或VPNv6地址族发布给邻居。
undo advertise evpn route命令用来禁止BGP EVPN路由通过VPNv4或VPNv6地址族发布给邻居。
advertise evpn route [ replace-rt ] [ advertise-policy policy-name ]
BGP EVPN路由不会通过VPNv4或VPNv6地址族向外发送。
BGP VPNv4地址族视图
BGP VPNv6地址族视图
replace-rt:指定将BGP EVPN路由的RT修改为VPNv4或VPNv6路由的RT。如果不指定本参数,则不修改BGP EVPN路由的RT。
advertise-policy policy-name:指定仅将通过路由策略过滤的BGP EVPN路由发布给VPNv4或VPNv6邻居。policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。如果不指定本参数,则所有BGP EVPN路由都可以发布给VPNv4或VPNv6邻居。
不同的数据中心之间通过MPLS L3VPN网络互联时,需要在ED上配置BGP EVPN和BGP VPNv4/VPNv6路由相互引入以实现数据中心之间的互通。
执行本命令后,设备会将EVPN的IP前缀路由、携带主机路由信息的MAC/IP发布路由通过VPNv4或VPNv6地址族发布给邻居。
# 配置允许BGP EVPN路由通过VPNv4地址族发布给邻居。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] advertise evpn route
advertise l2vpn evpn命令用来配置允许对外发布 BGP EVPN路由。
undo advertise l2vpn evpn命令用来禁止对外发布 BGP EVPN路由。
允许对外发布BGP EVPN路由。
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
配置允许对外发布 BGP EVPN路由后,设备接收到BGP EVPN路由,并将其添加到某个VPN实例路由表后,会将该路由(私网路由)发布到本地站点。
# 配置允许BGP VPN实例vpn1对外发布BGP EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] advertise l2vpn evpn
advertise l3vpn route命令用来配置允许BGP VPNv4或VPNv6路由通过EVPN地址族发布给邻居。
undo advertise l3vpn route命令用来禁止BGP VPNv4或VPNv6路由通过EVPN地址族发布给邻居。
advertise l3vpn route [ replace-rt ] [ advertise-policy policy-name ]
BGP VPNv4或VPNv6路由不会通过EVPN地址族向外发送。
BGP EVPN地址族视图
replace-rt:指定将BGP VPNv4或VPNv6路由的RT修改为EVPN路由的RT。如果不指定本参数,则不修改BGP VPNv4或VPNv6路由的RT。
advertise-policy policy-name:指定仅将通过路由策略过滤的BGP VPNv4或VPNv6路由发布给BGP EVPN邻居。policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。如果不指定本参数,则所有BGP VPNv4或VPNv6路由均可以发布给BGP EVPN邻居。
执行本命令后,BGP VPNv4或VPNv6路由将作为EVPN的IP前缀路由发布给邻居。
# 配置允许BGP VPNv4或VPNv6路由通过EVPN地址族发布给邻居。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] advertise l3vpn route
arp mac-learning disable命令用来配置禁止EVPN从ARP信息中学习MAC地址表项。
undo arp mac-learning disable命令用来恢复缺省情况。
EVPN可以从ARP信息中学习MAC地址表项。
VSI实例下的EVPN实例视图
本端PE可能会同时接收到远端设备通告的MAC地址信息和ARP信息。其中,ARP信息中包含MAC地址信息。为了避免重复,可以在本端设备上执行本命令禁止EVPN从ARP信息中学习MAC地址表项,EVPN仅通过MAC地址信息学习远端MAC地址表项。
# 配置禁止EVPN从ARP信息中学习MAC地址表项。
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation mpls
[Sysname-vsi-aaa-evpn-mpls] arp mac-learning disable
arp-advertising disable命令用来配置禁止通告ARP信息,并撤销已经通告的ARP信息。
undo arp-advertising disable命令用来恢复缺省情况。
允许通告ARP信息。
VSI实例下的EVPN实例视图
在EVPN VPLS组网中,如果同一个VPLS内的所有用户终端都部署在同一台PE下,则EVPN不需要通告该VPLS内的ARP信息。此时,可以配置本命令禁止EVPN通告ARP信息,以减少占用的设备和网络资源。执行本命令后,设备还会撤销已经发布的ARP信息。
# 配置EVPN实例禁止通告ARP信息,并撤销已经通告的ARP信息。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-mpls] arp-advertising disable
display bgp l2vpn evpn命令用来显示BGP EVPN路由信息。
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ { evpn-route route-length | evpn-prefix } [ verbose ] | statistics ] | [ route-distinguisher route-distinguisher | route-type { auto-discovery | es | igmp-js | igmp-ls | imet | ip-prefix | mac-ip | smet } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info ] | ipv4-address | ipv6-address | mac-address ] | statistics ]
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes } ]
display bgp [ instance instance-name ] l2vpn evpn { local-sids | received-sids }
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ route-type { inter-as | intra-as | leaf | shared-tree | source-active | source-tree } ] time-range min-time max-time
peer { ipv4-address | ipv6-address }:显示向指定对等体发布或者从指定对等体收到的BGP EVPN路由。ipv4-address表示对等体的IPv4地址;ipv6-address为对等体的IPv6地址。
advertised-routes:显示向指定对等体发布的BGP EVPN路由信息。
received-routes:显示从指定对等体接收到的BGP EVPN路由信息。
statistics:显示BGP EVPN路由的统计信息。
route-distinguisher route-distinguisher:显示指定路由标识符的BGP EVPN路由信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
· 16位自治系统号:32位用户自定义数,例如:101:3。
· 32位IP地址:16位用户自定义数,例如:192.168.122.15:1。
· 32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
route-type:显示指定类型的BGP EVPN路由。
auto-discovery:显示以太网自动发现路由(Ethernet auto-discovery route)。
es:显示以太网段路由(Ethernet segment route)。
igmp-js:显示IGMP加入同步路由(IGMP join synch route)。
igmp-ls:显示IGMP离开同步路由(IGMP leave synch route)。
imet:显示包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)。
ip-prefix:显示IP前缀路由(IP prefix advertisement route)。
mac-ip:显示MAC/IP发布路由(MAC/IP advertisement route)。
smet:显示选择性组播以太网标签路由(Selective multicast Ethernet tag route)。
evpn-route:显示指定BGP EVPN路由的详细信息。evpn-route表示EVPN路由信息,为1~512个字符的字符串。
route-length:BGP EVPN路由信息的长度,取值范围为0~65535,单位为比特。
evpn-prefix:显示指定BGP EVPN路由的详细信息。evpn-prefix包含EVPN路由信息和路由信息长度,组成格式为evpn-route/route-length,为1~512个字符的字符串,不区分大小写。
verbose:显示路由的详细信息。如果未指定本参数,则显示路由的简要信息。
advertise-info:显示BGP EVPN路由的通告信息。
ipv4-address:显示包含指定IPv4地址的EVPN路由信息。
ipv6-address:显示包含指定IPv6地址的EVPN路由信息。
mac-address:显示包含指定MAC地址的MAC/IP发布路由信息。执行本命令时,如果指定了route-type参数,则只有指定路由类型为mac-ip时,才可以指定本参数。
accepted-routes:显示从指定对等体接收的、并通过接收策略过滤的路由信息。
not-accepted-routes:显示从指定对等体接收的、但没有通过接收策略过滤的路由信息。
local-sids:显示本地发布的路由携带的SRv6 SID信息。
received-sids:显示从对等体接收到的路由携带的SRv6 SID信息。
time-range min-time max-time:显示路由从最后一次更新到目前持续的时间在指定范围内的路由信息。min-time为指定范围内的最小时间,max-time为指定范围内的最大时间。min-time和max-time的形式为<0-10000>d<0-23>h<0-59>m<0-59>s,其中d表示日、h表示时、m表示分、s表示秒,<0-10000>、<0-23>、<0-59>和<0-59>分别表示日、时、分、秒的取值范围。max-time的时间必须大于min-time的时间。
如果未指定任何参数,则显示所有BGP EVPN路由的简要信息。
# 显示所有BGP EVPN路由的简要信息。
<Sysname> display bgp l2vpn evpn
a - additional-path
Total number of routes from all PEs: 0
Route distinguisher: 1:1(vpna)
Total number of routes: 1
* > Network : [2][0][48][1485-247c-0506][32][10.1.2.20]/136
NextHop : 2.2.2.2 LocPrf : 100
PrefVal : 0 OutLabel : NULL
MED : 0
Path/Ogn: i
# 显示本地发布的BGP EVPN单播路由携带的SRv6 SID信息。
a - additional-path
LocalSID: fc00:0:1:40:: SID Type: End.DT6
Locator : aaa
# 显示从对等体接收到的BGP EVPN单播路由携带的SRv6 SID信息。
a - additional-path
Total number of routes from all PEs: 1
NextHop : 1::2
Received SID: fc00:0:2:42::
# 显示BGP实例default内所有从最后一次更新到目前持续的时间在指定范围内的BGP EVPN路由信息。
<Sysname> display bgp l2vpn evpn time-range 1d1h1m1s 7d3h1m1s
a - additional-path
MED : 0 Route age : 06d01h12m44s
表1-1 display bgp l2vpn evpn命令简要显示信息描述表
BGP local router ID |
BGP本地路由器ID |
Status codes |
路由状态代码: · * - valid:合法路由 · > - best:普通优选路由 · d - damped:震荡抑制路由 · h - history:历史路由 · s - suppressed:聚合抑制路由或被抑制的MAC/IP发布路由 · S - stale:过期路由 · i - internal:内部路由 · e - external:外部路由 · a - additional-path:Add-Path优选路由 |
Origin |
路由信息的来源,取值包括: · i – IGP:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP · e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的 · ? - incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete |
Total number of routes from all PEs |
来自所有PE设备且符合命令行过滤条件的BGP EVPN路由总数 |
Route distinguisher |
路由标识符 |
Route distinguisher of public instance |
公网实例的路由标识符 |
Total number of routes |
路由标识符为指定值的BGP EVPN路由总数 |
Network |
BGP EVPN路由/路由长度,例如,Network取值为[2][0][48][1485-247c-0506][32][10.1.2.20]/136时,[2][0][48][1485-247c-0506][32][10.1.2.20]为BGP EVPN路由,136表示该路由的长度为136比特 BGP EVPN路由取值包括: · [1][ESI][EthernetTagID]: ¡ 1:表示以太网自动发现路由(Ethernet auto-discovery route) ¡ ESI:以太网段标识 ¡ EthernetTagID:以太网标签 · [2][EthernetTagID][MACLength][MAC][IPAddressLength][IPAddress] ¡ 2:表示MAC/IP发布路由(MAC/IP advertisement route) ¡ EthernetTagID:以太网标签 ¡ MACLength:MAC地址长度 ¡ MAC:MAC地址 ¡ IPAddressLength:IP地址长度 ¡ IPAddress:IP地址 · [3][EthernetTagID][IPAddressLength][IPAddress] ¡ 3:表示包含性组播以太网标签路由(Inclusive multicast Ethernet tag route) ¡ EthernetTagID:以太网标签 ¡ IPAddressLength:IP地址长度 ¡ IPAddress:始发路由器的IP地址 · [4][ESI][IPAddressLength][IPAddress] ¡ 4:表示以太网段路由(Ethernet segment route) ¡ ESI:以太网段标识 ¡ IPAddressLength:IP地址长度 ¡ IPAddress:始发路由器的IP地址 · [5][EthernetTagID][IPAddressLength][IPAddress] ¡ 5:表示IP前缀路由(IP prefix advertisement route) ¡ EthernetTagID:以太网标签 ¡ IPAddressLength:IP地址长度 ¡ IPAddress:始发路由器的IP地址 · [6][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP] ¡ 6:表示选择性组播以太网标签路由(Selective multicast Ethernet tag route) ¡ EthernetTagID:以太网标签 ¡ Source Len:组播源IP地址长度,(*,G)情况下设置为0 ¡ Source IP:IGMP成员报告的源IP地址,(*,G)情况下该字段不存在 ¡ Group Len:组播组IP地址长度 ¡ Group IP:IGMP成员报告的组IP地址 ¡ Originator Len:始发路由器IP地址长度 ¡ Originator IP:始发路由器IP地址 · [7][ESI][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP] ¡ 7:表示IGMP加入同步路由(IGMP join synch route) ¡ ESI:以太网标识段 ¡ EthernetTagID:以太网标签 ¡ Source Len:组播源IP地址长度,(*,G)情况下设置为0 ¡ Source IP:IGMP成员报告的源IP地址,(*,G)情况下该字段不存在 ¡ Group Len:组播组IP地址长度 ¡ Group IP:IGMP成员报告的组IP地址 ¡ Originator Len:始发路由器IP地址长度 ¡ Originator IP:始发路由器IP地址 · [8][ESI][EthernetTagID] [Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP][ [LeaveGroup Synchronization] ¡ 8:表示IGMP离开同步路由(IGMP leave synch route) ¡ ESI:以太网标识段 ¡ EthernetTagID:以太网标签 ¡ Source Len:组播源IP地址长度,(*,G)情况下设置为0 ¡ Source IP:IGMP成员报告的源IP地址,(*,G)情况下该字段不存在 ¡ Group Len:组播组IP地址长度 ¡ Group IP:IGMP成员报告的组IP地址 ¡ Originator Len:始发路由器IP地址长度 ¡ Originator IP:始发路由器IP地址 ¡ LeaveGroup Synchronization:离开组播组的同步序列号值 · [10][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP] ¡ 10:表示组播源PE向接收端PE请求建立选择性隧道的PMSI自动发现路由(S-PMSI A-D route) ¡ EthernetTagID:以太网标签 ¡ Source Len:组播源IP地址长度,(*,G)情况下设置为0 ¡ Source IP:IGMP成员报告的源IP地址,(*,G)情况下该字段不存在 ¡ Group Len:组播组IP地址长度,(*,G)情况下设置为0 ¡ Group IP:IGMP成员报告的组IP地址,(*,G)情况下该字段不存在 ¡ Originator Len:始发路由器IP地址长度 ¡ Originator IP:始发路由器IP地址 |
NextHop |
下一跳IP地址 |
LocPrf |
本地优先级 |
PrefVal |
路由首选值 |
OutLabel |
路由的出标签值 |
MED |
MED(Multi-Exit Discriminator,多出口区分)属性值 |
Path/Ogn |
路由的AS路径(AS_PATH)属性和路由信息的来源(ORIGIN)属性 |
LocalSID |
本地发布的路由携带的SRv6 SID。如果路由未携带SRv6 SID,则显示“NO SRv6 SID” |
SID Type |
SRv6 SID的类型,取值包括: · End.DT4:用于标识网络中的某个IPv4 VPN · End.DT6:用于标识网络中的某个IPv6 VPN · End.DT46:用于标识网络中的某个IPv4 VPN或IPv6 VPN · End.DX4:用于标识网络中的某个IPv4下一跳 · End.DX6:用于标识网络中的某个IPv6下一跳 |
Locator |
为路由分配SRv6 SID时引用的Locator段名称。未引用Locator段则显示“-” |
Received SID |
从对等体接收到的路由携带的SRv6 SID。如果路由未携带SRv6 SID,则显示“NO SRv6 SID” |
Route age |
路由最后一次更新到目前持续的时间,形式为<0-10000>d<0-23>h<0-59>m<0-59>s,其中d表示日、h表示时、m表示分、s表示秒,<0-10000>、<0-23>、<0-59>和<0-59>分别表示日、时、分、秒的取值范围 |
# EVPN VPLS over SRv6组网中,显示路由标识符为2:33的BGP EVPN路由[1][0001.0001.0001.0001.0001][3111]/120的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 2:33 [1][0001.0001.0001.0001.0001][3111]/120
BGP local router ID: 2.2.2.2
Local AS number: 1
Route distinguisher: 2:33
Paths: 1 available, 1 best
BGP routing table information of [1][0001.0001.0001.0001.0001][3111]/120:
Rely nexthop : FE80::7CBF:38FF:FE28:133
Original nexthop: 3::3333
Out interface : GigabitEthernet1/0/6
Route age : 03h07m27s
OutLabel : 3
Ext-Community : <RT: 11:11>
RxPathID : 0x0
TxPathID : 0x0
PrefixSID : End.DT2U SID <33::1:7:0>, End.DT2UL SID <33::1:8:0>
AS-path : (null)
Origin : igp
State : valid, internal, best
Source type : local
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Ethernet auto-discovery route
ESI : 0001.0001.0001.0001.0001
Ethernet tag ID : 3111
MPLS label : 3
Tunnel policy : NULL
Rely tunnel IDs : N/A
表1-2 display bgp l2vpn evpn命令中Ethernet auto-discovery route详细显示信息描述表
本地的路由器ID |
Local AS number |
本地的AS号 |
路由标识符 |
Paths |
路由数信息 · available:有效路由数目 · best:最佳路由数目 |
BGP routing table information of [1][00:01:02:03:04:05:06:07:08:09][5]/120 |
BGP EVPN路由[1][0001.0203.0405.0607.0809][5]/120的详细信息 |
From |
发布该路由的BGP对等体的IP地址 |
Rely nexthop |
路由迭代后的下一跳IP地址,如果没有迭代出下一跳地址,则显示为“not resolved” |
Original nexthop |
Out interface |
路由下一跳对应的出接口信息 |
Route age |
路由最后一次更新到目前持续的时间 |
OutLabel |
路由的出标签值 |
Ext-Community |
扩展团体属性值,包括: · RT:Route Target属性 · Encapsulation Type:封装类型 · ESI Label:ESI标签 · EVPN Layer 2 Attributes:EVPN二层属性 |
RxPathID |
接收到的路由的Add-Path ID值 BGP EVPN地址族暂不支持本字段 |
TxPathID |
发送的路由的Add-Path ID值 BGP EVPN地址族暂不支持本字段 |
PrefixSID |
路由的SRv6 SID |
AS-path |
路由的AS路径(AS_PATH)属性,记录了此路由经过的所有AS,可以避免路由环路的出现 |
Origin |
路由信息的来源,取值包括: · igp:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP · egp:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的。 · incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete |
Attribute value |
BGP路由属性信息,包括: · MED:与目的网络关联的MED值 · localpref:本地优先级 · pref-val:路由首选值 · pre:协议优先级 |
Inlabel |
路由的入标签值 |
Originator |
生成该路由信息的对等体 |
Cluster list |
路由的CLUSTER_LIST属性,如果未携带CLUSTER_LIST,则不显示 |
State |
路由当前状态,取值包括: · valid:有效路由 · internal:内部路由 · external:外部路由 · local:本地产生路由 · synchronize:同步路由 · best:最佳路由 · localredist:从本地其他VPN实例或公网实例引入到当前VPN实例的路由 · delay:表示该路由优选时将被延迟(仅在显示路由详细信息时显示本字段) · bgp-rib-only:表示该路由禁止下发到IP路由表(仅在显示路由详细信息时显示本字段) |
Source type |
路由的来源 |
IP precedence |
路由的IP优先级,取值范围为0~7,N/A表示无效值 |
QoS local ID |
路由的Qos-Local-ID属性,取值范围为1~4095,N/A表示无效值 |
Traffic index |
流量索引值,取值范围为1~64,N/A表示无效值 |
EVPN route type |
BGP EVPN路由类型,取值为Ethernet auto-discovery route,表示以太网自动发现路由 |
ESI |
以太网段标识 |
Ethernet tag ID |
以太网标签 |
MPLS label |
采用MPLS封装时,表示MPLS标签;采用SRv6封装时,该字段与SRv6 TLV组合在一起表示SID |
Tunnel policy |
路由生效的隧道策略,NULL表示无生效的隧道策略 |
Rely tunnel IDs |
路由迭代后的隧道索引值列表,存在等价隧道时,可能对应多个隧道索引值,如果未迭代隧道,显示为N/A |
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[3][0][32][4.5.5.5]/80的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [3][0][32][4.5.5.5] 80
BGP local router ID: 172.16.250.133
Local AS number: 100
Route distinguisher: 1.1.1.1:100
BGP routing table information of [3][0][32][4.5.5.5]/80:
Rely nexthop : 10.1.1.2
Original nexthop: 10.1.1.2
OutLabel : 0
Ext-Community : <RT: 1:2>, <Encapsulation Type: MPLS>
RxPathID : 0x0
TxPathID : 0x0
PMSI tunnel : Flag 0, TunnelType 2, Label 0, P2MP Type 6, Address Family
1, Address Length 4, Root Node Address 5.5.5.5, Opaque Length
7, Opaque Value: 01 00 04 E4 00 00 03
AS-path : 200
Origin : igp
Attribute value : MED 0,pref-val 0
State : valid, external, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Inclusive multicast Ethernet tag route
Ethernet tag ID : 0
Origin address : 5.5.5.5/32
表1-3 display bgp l2vpn evpn命令中Inclusive multicast Ethernet tag route详细显示信息描述表
Ext-Community |
扩展团体属性值,包括: · RT:Route Target属性 · Encapsulation Type:封装类型 |
PMSI tunnel |
运营商组播服务接口的隧道信息,包括: · Flag:标志位,目前取值只能为0 · TunnelType:隧道类型,取值包括: ¡ 2:表示mLDP P2MP隧道 ¡ 6:表示头端复制隧道 · Label:隧道类型为2时,表示MPLS标签值 · P2MP Type:P2MP FEC的类型,取值为6,仅隧道类型为2时存在本字段 · EndPointAddress:隧道目的端地址,仅隧道类型为6时存在本字段 · Address Family:根节点地址类型,取值为1表示IPv4地址,取值为2表示IPv6地址。仅隧道类型为2时存在本字段 · Address Length:根节点地址长度,单位为字节。仅隧道类型为2时存在本字段 · Root Node Address:mLDP P2MP的根节点地址。仅隧道类型为2时存在本字段 · Opaque Length:Opaque-value的长度,单位为字节。仅隧道类型为2时存在本字段 · Opaque Value:Opaque Value的值,用于在根节点处区分不同的P2MP LSP。仅隧道类型为2时存在本字段 |
EVPN route type |
BGP EVPN路由类型,取值为Inclusive multicast Ethernet tag route,表示包含性组播以太网标签路由 |
Ethernet tag ID |
以太网标签 |
Origin address |
始发路由器地址 |
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][0000.0000.0000.0000.000a][32][4.5.5.5]/128的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][0000.0000.0000.0000.000a][32][4.5.5.5] 128
BGP routing table information of [4][0000.0000.0000.0000.000a][32][4.5.5
.5]/128:
OutLabel : 0
Ext-Community : <ES-Import RT: 0000-0000-0000>, <Encapsulation Type: VXLAN>
: <Encapsulation Type: MPLS>, <EVPN DF Election: Alg Modulus,Cap -,
: Preference ->
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Ethernet segment route
ESI : 0000.0000.0000.0000.000a
Origin address : 4.5.5.5/32
表1-4 display bgp l2vpn evpn命令中Ethernet segment route详细显示信息描述表
Ext-Community |
扩展团体属性值,包括: · RT:Route Target属性 · Encapsulation Type:封装类型 · ES-Import RT:ES-Import Route Target属性 · EVPN DF Election:DF选举属性,包含如下几部分: ¡ Alg:DF选举算法。取值为Modulus,表示基于VLAN Tag的DF选举算法;取值为Preference,表示基于优先级的DF选举算法 ¡ Cap:DF选举能力。取值为DP,表示具备不可回切能力;取值为“-”时,表示不具备任何能力 ¡ Preference:DF选举优先级。取值为“-”时,表示无DF选举优先级 |
EVPN route type |
BGP EVPN路由类型,取值为Ethernet segment route,表示以太网段路由 |
ESI |
以太网段标识 |
Origin address |
始发路由器地址 |
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[5][10][32][4.5.5.5]/80的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [5][10][32][4.5.5.5] 80
BGP routing table information of [5][10][32][4.5.5.5]/80:
OutLabel : 0
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, <Router's Mac:
0006-0708-0910>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
PrefixSID : End.DT4 SID <133::103>
SRv6 Service TLV (37 bytes):
Type: SRv6 L3 Service TLV (5)
Length: 34 bytes, Reserved: 0x0
SRv6 Service Information Sub-TLV (33 bytes):
Type: 1 Length: 30, Rsvdl: 0x0
SID flags:0x0 Endpoint behavior:0x13 Rsvd2: 0x0
SRv6 SID Sub-Sub-TLV:
Type: 1 Length: 6
BL: 40 NL: 56 FL: 20 AL: 0 TL: 20 TO: 96
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : IP prefix advertisement route
Ethernet tag ID : 10
IP address : 4.5.5.5/32
Gateway address : 0.0.0.0
MPLS Label : 1
Re-origination : Enabled
Route distinguisher: 2.2.2.2:100
OutLabel : 0
0006-0708-0910>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
State : valid, external, best, reoriginated, remoteredist
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
MPLS Label : 20
表1-5 display bgp l2vpn evpn命令中IP prefix advertisement route详细显示信息描述表
Ext-Community |
扩展团体属性值,包括: · RT:Route Target属性 · Encapsulation Type:封装类型 · Router's Mac:路由器MAC |
State |
路由当前状态,取值包括: · valid:有效路由 · internal:内部路由 · external:外部路由 · local:本地产生路由 · synchronize:同步路由 · best:最佳路由 · reoriginated:重生成路由 · localredist:本地路由生成的IP前缀路由 · remoteredist:远端路由生成的IP前缀路由 |
PrefixSID |
路由携带的SRv6 SID属性,取值包括: · End.DT4 SID:用于标识网络中的某个IPv4 VPN · End.DT6 SID:用于标识网络中的某个IPv6 VPN · End.DT46 SID:用于标识网络中的某个IPv4 VPN或IPv6 VPN · End.DX4 SID:用于标识网络中的某个IPv4下一跳 · End.DX6 SID:用于标识网络中的某个IPv6下一跳 |
SRv6 Service TLV (37 bytes) |
用于携带SRv6 SID属性的SRv6 Service TLV,以及该TLV的总长度,单位为字节 |
Type |
SRv6 Service TLV的类型,取值包括: · SRv6 L3 Service TLV (5):三层SRv6 Service TLV · SRv6 L2 Service TLV (6):二层SRv6 Service TLV |
Length: 34 bytes, Reserved: 0x0 |
SRv6 Service TLV的内容长度,单位为字节;以及SRv6 Service TLV的保留字段,取值为0x0 |
SRv6 Service Information Sub-TLV (33 bytes) |
SRv6 Service TLV的Sub-TLV,以及该Sub-TLV的总长度,单位为字节 |
Type: 1 Length: 30, Rsvdl: 0x0 |
Sub-TLV的类型,取值为1;Sub-TLV的内容长度,单位为字节;以及Sub-TLV的保留字段,取值为0x0 |
SID flags |
SRv6 SID的标记位,取值为0x0 |
Endpoint behavior |
SRv6 SID的类型,取值包括: · 0x0a:表示End.T SID · 0x10:表示End.DX6 SID · 0x11:表示End.DX4 SID · 0x12:表示End.DT6 SID · 0x13:表示End.DT4 SID · 0x14:表示End.DT46 SID |
Rsvd2 |
保留字段,取值为0x0 |
SRv6 SID Sub-Sub-TLV |
SRv6 Service TLV的Sub-Sub-TLV |
Type: 1 Length: 6 |
Sub-Sub-TLV的类型,取值为1;以及Sub-Sub-TLV的内容长度,单位为字节 |
BL: 40 NL: 56 FL: 20 AL: 0 TL: 20 TO: 96 |
SRv6 SID各部分的长度,内容包括: · BL:Locator Block的长度,单位为位 · NL:Locator Node的长度,单位为位 · FL:Function的长度,单位为位 · AL:Arguments的长度,单位为位 · TL:Transposition的长度,单位为位 · TO:Transposition的偏移长度,单位为位 |
EVPN route type |
BGP EVPN路由类型,取值为IP prefix advertisement route,表示IP前缀路由 |
ESI |
以太网段标识 |
Ethernet tag ID |
以太网标签 |
IP address |
IP网络前缀 |
Gateway address |
网关地址 |
MPLS Label |
用于三层转发的VXLAN ID,即L3VNI |
Re-origination |
是否开启了修改路由信息的功能,取值包括: · Enable:开启修改路由信息功能 · Disable:关闭修改路由信息功能 |
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/160的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1] 160
BGP routing table information of [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/160:
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Selective multicast Ethernet tag route
Ethernet tag ID : 0
Source length : 32
Source address : 10.1.1.1
Group length : 32
Group address : 224.224.224.224
Origin address : 192.168.3.1
IGMP flags : v3, include
表1-6 display bgp l2vpn evpn命令中Selective multicast Ethernet tag route详细显示信息描述表
Ext-Community |
EVPN route type |
BGP EVPN路由类型,取值为Selective multicast Ethernet tag route,表示SMET路由 |
Ethernet tag ID |
以太网标签 |
Source length |
组播源地址长度 |
Source address |
组播源地址 |
Group length |
组播组地址长度 |
Group address |
组播组地址 |
Origin address |
始发路由器地址 |
IGMP flags |
IGMP标记位信息 |
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[7][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/240的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [7][0000.0000.0000.0000.0000][0][32][10.1.1.1][16][224.224.224.224][32][192.168.3.1] 240
BGP routing table information of [7][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/240:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, < ESI-RT: 0:0>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : IGMP join synch route
ESI : 0000.0000.0000.0000.0000
Ethernet tag ID : 0
Source length : 32
Group length : 32
表1-7 display bgp l2vpn evpn命令中IGMP join synch route详细显示信息描述表
Ext-Community |
扩展团体属性值,包括: · RT:Route Target属性 · Encapsulation Type:封装类型 · EVI-RT:与EVI关联的Route Target属性 |
EVPN route type |
BGP EVPN路由类型,取值为IGMP join synch route,表示IGMP-JS路由 |
ESI |
以太网段标识 |
Ethernet tag ID |
以太网标签 |
Source length |
组播源地址长度 |
Source address |
组播源地址 |
Group length |
组播组地址长度 |
Group address |
组播组地址 |
Origin address |
始发路由器地址 |
IGMP flags |
IGMP 标记位信息 |
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[8][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0]/272的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [8][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0] 272
BGP routing table information of [8][0000.0000.0000.0000.0000] [0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0]/272:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, < ESI-RT: 1:200>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : IGMP leave synch route
Ethernet tag ID : 0
Source length : 32
Group length : 32
Leave group sync: 0
Max ResponseTime: 2500ms
Max ResponseCode: 25
表1-8 display bgp l2vpn evpn命令中IGMP leave synch route详细显示信息描述表
Ext-Community |
扩展团体属性值,包括: · RT:Route Target属性 · Encapsulation Type:封装类型 · ESI-RT:与ESI关联的Route Target属性 |
EVPN route type |
BGP EVPN路由类型,取值为IGMP leave synch route,表示IGMP-LS路由 |
ESI |
以太网段标识 |
Ethernet tag ID |
以太网标签 |
Source length |
组播源地址长度 |
Source address |
组播源地址 |
Group length |
组播组地址长度 |
Group address |
组播组地址 |
Origin address |
始发路由器地址 |
Leave group sync |
离开组播组的同步序列号值 |
Max ResponseTime |
最大响应时间,单位为毫秒 |
Max ResponseCode |
接收到的报文中携带的最大响应值,单位为十分之一秒 |
IGMP flags |
IGMP标记位信息 |
# 显示路由标识符为1:1的BGP EVPN路由[10][0][0][0.0.0.0][32][225.0.0.1][32][1.1.1.1]/128的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1:1 [10][0][0][0.0.0.0][32][225.0.0.1][32][1.1.1.1]/128
BGP routing table information of [10][0][0][0.0.0.0][32][225.0.0.1][32][1.1.1.1]/128:
Out interface : NULL0
Route age : 13h49m31s
OutLabel : NULL
Ext-Community : <RT: 34:12>, <Encapsulation Type: MPLS>
RxPathID : 0x0
TxPathID : 0x0
PMSI tunnel : Flag 0, TunnelType 2, Label 4294967295, P2MP Type 6, Addres
s Family 2, Address Length 16, Root Node Address 102:304::,
Opaque Length 7, Opaque Value: 01 00 04 00 00 04 02
AS-path : 200
Origin : igp
State : valid, local, best
Source type : local
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Selective Provider Multicast Service Interface Auto-Discovery route
Ethernet tag ID : 0
Source length : 0
Source address : 0.0.0.0
Group length : 32
Group address : 225.0.0.1
Origin address : 1.1.1.1
表1-9 display bgp l2vpn evpn命令中S-PMSI A-D route详细显示信息描述表
Ext-Community |
PMSI tunnel |
运营商组播服务接口的隧道信息,包括: · Flag:标志位,目前取值只能为0 · TunnelType:隧道类型,取值为2,表示mLDP P2MP隧道 · Label:MPLS标签值 · P2MP Type:P2MP FEC的类型,取值为6 · Address Family:根节点地址类型,取值为1表示IPv4地址,取值为2表示IPv6地址 · Address Length:根节点地址长度,单位为字节 · Root Node Address:mLDP P2MP的根节点地址 · Opaque Length:Opaque-value的长度,单位为字节 · Opaque Value:Opaque Value的值,用于在根节点处区分不同的P2MP LSP |
EVPN route type |
BGP EVPN路由类型,取值为Selective Provider Multicast Service Interface Auto-Discovery route,表示组播源PE向接收端PE请求建立选择性隧道的PMSI自动发现路由 |
Ethernet tag ID |
以太网标签 |
Source length |
组播源地址长度,单位为位 |
Source address |
组播源地址 |
Group length |
组播组地址长度,单位为位 |
Group address |
组播组地址 |
Origin address |
始发路由器地址 |
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][0000.0000.0000.0000.000a][32][4.5.5.5]/128的通告信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][0000.0000.0000.0000.000a][32][4.5.5.5] 128 advertise-info
Paths: 1 best
BGP routing table information of [4][0000.0000.0000.0000.000a][32][4.5.5.5]/128:
10.2.1.2
表1-10 display bgp l2vpn evpn advertise-info命令显示信息描述表
本地的路由器ID |
Local AS number |
本地的AS号 |
路由标识符 |
Paths |
到达指定目的网络的优选路由数目 |
BGP routing table information of [4][0000.0000.0000.0000.000a][32][4.5.5.5]/128 |
BGP EVPN路由[4][0000.0000.0000.0000.000a][32][4.5.5.5]/128的通告信息 |
Advertised to peers (1 in total) |
该路由已经向哪些BGP EVPN对等体发送,以及对等体的数目 |
display bgp l2vpn evpn dampened命令用来显示衰减的BGP EVPN路由信息。
display bgp [ instance instance-name ] l2vpn evpn dampened
# 显示衰减的BGP EVPN路由信息。
<Sysname> display bgp l2vpn evpn dampened
a - additional-path
Total number of routes from all PEs: 2
Route distinguisher: 5:1
Total number of routes: 2
di Network : [5][0][32][55.1.1.1]/80
Path/Ogn: ?
di Network : [5][0][128][55::1]/176
Path/Ogn: ?
表1-11 display bgp l2vpn evpn dampened命令显示信息描述表
本地的路由器ID |
Status codes |
路由状态代码: · * – valid:合法路由 · > – best:优选最佳路由 · d - dampened:震荡抑制路由 · h – history:历史路由 · s – suppressed:聚合抑制路由 · S – stale:过期路由 · i – internal:内部路由 · e – external:外部路由 · a – additional-path:Add-Path优选路由 |
Origin |
路由信息的来源,取值包括: · i – IGP:表示路由产生于本AS内 · e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的 · ? – incomplete:表示路由的来源无法确定 |
路由标识符 |
衰减的路由总数 |
Network |
BGP EVPN路由/路由长度 |
From |
发布该路由的BGP对等体的IP地址 |
Reuse |
路由恢复可用的时间,即还需要等待多长时间该路由将由不可用状态转为可用状态 |
Path/Ogn |
路由的AS路径(AS_PATH)属性和路由信息的来源(ORIGIN)属性,其中: · AS_PATH属性记录了此路由经过的所有AS,可以避免路由环路的出现 · ORIGIN属性标记了此路由如何成为BGP路由 |
· dampening(三层技术-IP路由命令参考/BGP)
· dampening ibgp(MPLS命令参考/MPLS L3VPN)
· reset bgp dampening(三层技术-IP路由命令参考/BGP)
display bgp l2vpn evpn flap-info命令用来显示BGP EVPN路由的震荡统计信息。
display bgp [ instance instance-name ] l2vpn evpn flap-info
# 显示所有BGP EVPN路由的震荡统计信息。
<Sysname> display bgp l2vpn evpn flap-info
a - additional-path
Duration: 00:00:54 Reuse : 00:02:12
Path/Ogn: ?
Duration: 00:00:44 Reuse : 00:02:22
Path/Ogn: ?
表1-12 display bgp l2vpn evpn flap-info命令显示信息描述表
本地的路由器ID |
Status codes |
Origin |
路由标识符 |
衰减的路由总数 |
Network |
目的网络地址 |
From |
发布该路由的BGP对等体的IP地址 |
Flaps |
路由震荡的次数,即路由从可达状态变为不可达状态,及可达路由的属性发生变化的次数 |
Duration |
路由发生震荡的持续时间 |
Reuse |
Path/Ogn |
· reset bgp flap-info(三层技术-IP路由命令参考/BGP)
display bgp l2vpn evpn inlabel命令用来显示BGP EVPN的IP前缀路由的入标签信息。
display bgp [ instance instance-name ] l2vpn evpn inlabel
可通过本命令显示本地PE为EVPN的IP前缀路由分配的私网标签。
# 显示BGP EVPN IP前缀路由的入标签信息。
<Sysname> display bgp l2vpn evpn inlabel
a - additional-path
Origin: i - IGP, e - EGP, ? – incomplete
Route distinguisher: 100:2
Network NextHop OutLabel InLabel
* >e [5][0][24][192.168.1.0]/80
192.168.1.10 NULL 1151
表1-13 display bgp l2vpn evpn inlabel命令显示信息描述表
BGP本地路由器ID |
Status codes |
路由状态代码: · * - valid:合法路由 · > - best:普通优选路由 · d - damped:震荡抑制路由 · h - history:历史路由 · i - internal:内部路由 · e - external:外部路由 · s - suppressed:聚合抑制路由 · S - Stale:过期路由 · a - additional-path:Add-Path优选路由 |
Origin |
路由标识符 |
公网实例的路由标识符 |
Network |
BGP EVPN路由/路由长度,BGP EVPN路由取值为[5][EthernetTagID][IPAddressLength][IPAddress] · 5:表示IP前缀路由(IP prefix advertisement route) · EthernetTagID:以太网标签 · IPAddressLength:IP地址长度 · IPAddress:始发路由器的IP地址 |
NextHop |
下一跳IP地址 |
OutLabel |
出标签值,即对端PE为EVPN路由分配的私网标签,取值为NULL表示空标签 |
InLabel |
入标签值,即本地PE为EVPN路由分配的私网标签 |
· evpn mpls routing-enable
· peer advertise encap-type mpls
display bgp route-target evpn命令用来显示BGP中来源为EVPN进程的Route Target以及ES-Import Route Target信息。
display bgp [ instance instance-name ] route-target evpn
instance instance-name:显示指定BGP实例的信息。instance-name为BGP实例的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示default实例的信息。
本命令用来显示ES-Import Route Target信息,以及所有EVPN实例以及VSI实例下的EVPN实例配置的Route Target信息,这些信息用来控制BGP EVPN路由的接收。
ES-Import Route Target属性是一种扩展团体属性,仅以太网段路由支持携带该属性。ES-Import Route Target属性根据配置的ESI自动生成,长度为48位,格式为H-H-H。在接收以太网段路由时,设备会将携带的ES-Import Route Target属性与本地配置的ESI生成的ES-Import Route Target进行比较,只有本地存在能够生成相同ES-Import Route Target属性的ESI时,该以太网段路由才会被接收。
本命令对Route Targe和ES-Import Route Target信息的显示内容存在上限,每一类信息最多显示8192个字节。其中,信息中的每个字符为一个字节,如“1:1”为3个字节,超过8192个字节的Route Targe和ES-Import Route Target信息会使用“...”来代替。
# 显示BGP中来源为EVPN进程的Route Target以及ES-Import Route Target信息。
<Sysname> display bgp route-target evpn
Total EVPN route target count: 6
EVPN import route-target count: 5
1:1 2:2 3:3 4:4 5:5
EVPN es-import route target count: 1
1111-2222-3333
表1-14 display bgp route-target evpn命令简要显示信息描述表
Total EVPN route target count |
BGP中来源为EVPN进程的Route Target以及ESI信息总数 |
EVPN vsi import route-target count |
EVPN实例以及所有VSI实例下的EVPN实例的Import Target总数 |
EVPN es-import route target count |
所有ES-Import Route Target属性的总数 |
display evpn auto-discovery命令用来显示EVPN通过BGP自动发现的邻居信息。
display evpn auto-discovery { ethernet-ad mpls [ peer ip-address ] [ vsi vsi-name ] | { imet [ mpls ] | mac-ip [ mpls | srv6 ] } [ peer peer-address ] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
ethernet-ad:显示通过以太网自动发现路由(Ethernet auto-discovery route)发现的邻居信息。
imet:显示通过包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)发现的邻居信息。
mac-ip:显示通过MAC/IP发布路由发现的邻居。
mpls:显示EVPN VPLS组网中通过BGP自动发现的邻居信息。
srv6:显示EVPN VPLS over SRv6组网中通过BGP自动发现的邻居信息。EVPN VPLS over SRv6的详细介绍,请参见“Segment Routing配置指导”中的“EVPN VPLS over SRv6”。
peer peer-address:显示指定邻居的自动发现相关信息。peer-address为邻居的IPv4地址或IPv6地址。如果未指定本参数,则显示自动发现的所有邻居的信息。
vsi vsi-name:显示指定VSI内自动发现的邻居信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI内自动发现的邻居信息。
macip-prefix:显示通过携带L3VNI的MAC/IP发布路由和IP前缀路由发现的邻居信息。
nexthop next-hop:显示从指定路由下一跳学习到的邻居信息。next-hop为路由下一跳的IPv地址或IPv6地址。如果未指定本参数,则显示从所有路由下一跳学习到的邻居信息。
count:显示自动发现的邻居数目。如果未指定本参数,则显示邻居的具体信息。
如果执行本命令时,没有指定mpls和srv6参数,则同时显示所有类型组网中EVPN通过BGP自动发现的邻居信息。
# EVPN VPLS组网下显示通过以太网自动发现路由发现的IPv4邻居信息。
<Sysname> display evpn auto-discovery ethernet-ad mpls
Total number of automatically discovered peers: 1
VSI name: vpnb
Destination IP In/Out label Tunnel mode
7.7.7.7 1420/- PW
表1-15 display evpn auto-discovery ethernet-ad命令显示信息描述表
Total number of automatically discovered peers |
自动发现的邻居数目 |
VSI name |
VSI名称 |
Destination IP |
隧道的目的端地址 |
In/Out label |
PW的入标签和出标签,当标签无效时显示为“-” |
Tunnel mode |
隧道的模式,取值为PW |
# EVPN VPLS组网下显示通过包含性组播以太网标签路由发现的邻居信息。
<Sysname> display evpn auto-discovery imet mpls
VSI name: vpna
RD PE_address In/Out label Tunnel mode
1:1 1.1.1.1 1151/1151 PW
# EVPN VPLS over SRv6组网下显示通过包含性组播以太网标签路由发现的邻居信息。
<Sysname> display evpn auto-discovery imet srv6
VSI name: vpnc
EVPN instance: -
RD : 1:1 Tunnel mode : SRv6
PE_address : 1::1
In SID : 100::10::0
Out SID : 200::20::0
表1-16 display evpn auto-discovery imet命令显示信息描述表
自动发现的邻居数目 |
VSI name |
VSI名称 |
EVPN instance |
EVPN实例名称。显示为“-”时,表示VSI实例下创建的EVPN实例 |
RD |
路由标识符 |
PE_address |
远端设备在VSI内的标识 |
Tunnel_address |
隧道的目的端地址 |
Tunnel mode |
隧道的模式,取值包括: · PW:表示PW · SRv6:表示SRv6隧道 |
In/Out label |
In SID |
入SID |
Out SID |
出SID |
# EVPN VPLS组网下显示通过MAC/IP发布路由发现的IPv4邻居信息。
<Sysname> display evpn auto-discovery mac-ip mpls
VSI name: vpnb
EVPN instance: -
Destination IP In/Out label Tunnel Mode
7.7.7.7 1420/1419 PW
# EVPN VPLS over SRv6组网下显示通过MAC/IP发布路由发现的IPv4邻居信息。
<Sysname> display evpn auto-discovery mac-ip srv6
VSI name: vpnb
EVPN instance: -
Destination IP : 1::1
In SID : 100::10::0
表1-17 display evpn auto-discovery mac-ip命令显示信息描述表
自动发现的邻居数目 |
VSI name |
VSI名称 |
EVPN instance |
Destination IP |
隧道的目的端地址 |
Source IP |
隧道的源端地址 |
Tunnel mode |
Tunnel name |
隧道名称 |
In/Out label |
In SID |
入SID |
Out SID |
出SID |
display evpn df-election命令用来显示DF选举的信息。
display evpn df-election [ vsi vsi-name | xconnect-group group-name ] [ esi esi-id ]
vsi vsi-name:显示指定VSI的DF选举信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
xconnect-group group-name:显示指定交叉连接组的DF选举信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。
esi esi-id:显示指定ESI的DF选举信息。esi-id表示以太网链路网段标识符的值,格式为xxxx.xxxx.xxxx.xxxx.xxxx,必须以00开头,其中x为十六进制数,不支持全0。如果未指定本参数,则显示所有ESI的DF选举信息。
执行本命令时,如果未指定vsi vsi-name和xconnect-group group-name参数,则显示所有VSI和交叉连接组的DF选举信息。
# 显示所有VSI和交叉连接组的DF选举信息。
<Sysname> display evpn df-election
VSI name: 1
ESI : 0021.1001.1001.1001.1002
Interface : GigabitEthernet1/0/6
Service instance ID : 1000
Link ID : 1
Ethernet tag ID : 12
DF state : Primary
FSM : DF_DONE
Number of member devices : 2
Originating IP DF state Algorithm Preference Capability
100.100.100.100 Primary Preference 65535 DP
100.100.100.200 Backup Preference 200 DP
ESI : 0002.0002.0002.0002.0002
Interface : GigabitEthernet1/0/7
Link ID : 0
Ethernet tag ID : 0
DF state : -
FSM : DF_CALC
1.1.1.1 - Preference 32767 -
2.2.2.2 - Preference 32767 -
Xconnect-group name : 1
Connection name : 1
Interface : GigabitEthernet1/0/8
Link ID : 1
Ethernet tag ID : 0
DF state : -
FSM : DF_CALC
Number of member devices : 1
表1-18 display evpn df-election命令显示信息描述表
VSI name |
VSI名称 |
ESI |
ES标识符 |
接口名称 |
Service instance ID |
以太网服务实例的ID |
Link ID |
AC在VSI内的链路标识符 |
Ethernet tag ID |
以太网标签 |
DF state |
当前设备的DF(Designated Forwarder)选举结果,取值包括: · Backup:选举设备作为BDF(Backup DF)角色 · Primary:选举设备作为DF角色 · -:未选举出结果 |
FSM |
DF选举状态机的状态,取值包括: · INIT:初始化状态 · DF_WAIT:DF选举等待状态,即在启动DF选举定时器后,定时器超时前的状态 · DF_CALC:正在进行DF选举 · DF_DONE:DF选举完成状态 |
Number of member devices |
参与DF选举的成员设备的数目 |
Originating IP |
参与DF选举的成员设备的IP地址 |
DF state |
Originating IP所代表的设备的DF选举结果,取值包括: · Backup:选举设备作为BDF(Backup DF)角色 · Primary:选举设备作为DF角色 · -:未选举出结果 |
Algorithm |
DF选举使用的算法,取值包括: · modulus:基于VALN Tag的DF选举算法 · Preference:基于优先级的DF选举算法 |
Preference |
DF选举优先级 |
Capability |
支持的DF选举能力,取值包括: · DP:表示DF选举不回切能力 · -:表示不支持任何DF选举能力 |
display evpn es命令用来显示EVPN的ES信息。
display evpn es { local [ count | [ vsi vsi-name | xconnect-group group-name ] [ esi esi-id ] [ verbose [ ades-rd route-distinguisher ] ] ] | remote [ vsi vsi-name | xconnect-group group-name ] [ esi esi-id ] [ nexthop next-hop ] [ verbose [ ades-rd route-distinguisher ] ] }
local:显示本地多归属成员ES信息。
count:显示本地多归属成员ES的数目。
vsi vsi-name:显示指定VSI的ES信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的ES信息。
xconnect-group group-name:显示指定交叉连接组内EVPN的本地ES信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有交叉连接组内EVPN的本地ES信息。
esi esi-id:显示指定ESI的ES信息。esi-id表示以太网链路网段标识符的值,格式为xxxx.xxxx.xxxx.xxxx.xxxx,必须以00开头,其中x为十六进制数,不支持全0。如果未指定本参数,则显示VSI的所有ES信息。
verbose:显示ES的详细信息。如果不指定本参数,则显示ES的简要信息。
ades-rd route-distinguisher:显示指定A-D per ES路由标识符的ES信息。route-distinguisher为路由标识符,为3~21个字符的字符串,格式为“Router ID:N”,其中N为从0开始的整数,N最大取值为65535。如果不指定本参数,则显示所有A-D per ES路由标识符的ES信息。
remote:显示远端多归属成员ES信息。
nexthop next-hop:显示从指定路由下一跳接收到的ES信息。next-hop为路由下一跳的IPv地址或IPv6地址。如果不指定本参数,则显示从所有路由下一跳收到的ES信息。
# 显示本地ES的数目。
<Sysname> display evpn es local count
Total number of ES entries: 1
# EVPN VPLS组网中显示VSI实例vpna的本地ES简要信息。
<Sysname> display evpn es local vsi vpna
Redundacy mode: A – All-active, S – Single-active
VSI name : vpna
EVPN instance: -
VSI ESI Tag ID DF address Mode State ESI label Argument
0001.0002.0002.0002.0002 0 1.1.1.1 A Up 1000 -
0001.0002.0003.0004.0005 0 1.1.1.1 A Up 1001
0003.0003.0003.0003.0003 2 2.2.2.2 A Up 1002
# EVPN VPLS over SRv6组网中显示VSI实例vpna的本地ES简要信息。
VSI name : vpna
Tag ID : 0
DF address : 1.1.1.1
Mode : A
State : Down
Argument : ::1
# EVPN VPWS组网中显示交叉连接组vpna的本地ES简要信息。
<Sysname> display evpn es local xconnect-group vpna
Redundancy mode: A – All-active, S – Single-active
Xconnect group name: vpna
0001.0002.0002.0002.0002 0 1.1.1.1 A Up -
0001.0002.0003.0004.0005 0 1.1.1.1 A Up -
0003.0003.0003.0003.0003 2 2.2.2.2 A Up -
# EVPN VPWS over SRv6组网中显示交叉连接组vpna的本地ES简要信息。
Xconnect-group name : vpna
Tag ID : 0
Mode : A
State : Up
Argument : -
表1-19 display evpn es local命令显示信息描述表
VSI name |
VSI名称 |
EVPN instance |
Xconnect group name |
交叉连接组名称 |
VSI ESI |
VSI实例的ES标识符 |
ESI |
接口或UPW的ES标识符 |
Tag ID |
以太网标签ID |
DF address |
被选为DF的VTEP或PE的Router ID |
Mode |
ES的冗余备份模式,取值包括: · A:表示ES的冗余备份模式为all-active模式 · S:表示ES的冗余备份模式为single-active模式 |
State |
当前ES的状态,取值包括Up和Down |
ESI label |
ESI标签;在EVPN VPWS和EVPN VXLAN组网中ESI label无效,显示为“-” |
Argument |
标识AC的ESI Argument值,在EVPN VPLS over SRv6的多归属组网中用于实现AC间的流量隔离 当无Argument时显示为“-” |
# 显示所有VSI内本地ES的详细信息。
<Sysname> display evpn es local verbose
VSI name : v1
EVPN instance: -
VSI ESI : 0001.0001.0001.0001.0003
Redundancy mode : All-active
ES state : Up
AD-delay remaining time : 10
A-D per ES route RD : 1.1.1.9:2
ESI : 0003.0003.0003.0003.0003
State : Up
A-D per ES route RD : 1.1.1.9:1
ACs :
Link ID Service instance ID Tag ID DF address ESI label
0 1 1 1.1.1.1 1001
1 3 3 3.3.3.3 1002
2 10 10 2.2.2.2 1003
VSI name : v2
EVPN instance: -
ESI : 0004.0004.0004.0004.0004
Interface : -
State : Up
UPWs :
Link ID Tag ID DF address ESI label
0 1 1.1.1.1 1004
VSI name : vpna
EVPN instance: -
ESI : 0001.0002.0002.0002.0002
State : Up
ACs :
1 - 0 1.1.1.1 -
VSI name : vpnb
EVPN instance: -
Interface : GE1/0/8
State : Down
ACs :
Link ID : 0
Service instance ID : -
Tag ID : 0
Argument : ::1
Xconnect group name : vpna
Connection name : aa
AC : GE1/0/10
State : Up
Link ID : 0
Tag ID : 10
Xconnect group name : vpnd
Connection name : dd
ESI : 0006.0006.0006.0006.0006
State : Up
UPW Link ID : 0
Tag ID : 10
表1-20 display evpn es local verbose命令显示信息描述表
VSI name |
VSI名称 |
EVPN instance |
VSI ESI |
VSI实例的ES标识符 |
交叉连接组名称 |
Connection name |
交叉连接名称 |
ESI |
接口或UPW的ES标识符 |
接口名称 |
AC |
与交叉连接关联的接入电路,取值为: · 三层接口名称:表示交叉连接关联三层接口 · 二层接口名称和以太网服务实例:表示交叉连接关联以太网服务实例 |
Redundancy mode |
ES state |
当前VSI对应ES的状态,取值包括Up、Down和“-”。其中,“-”表示未手动配置ESI |
State |
当前接口或UPW对应ES的状态,取值包括Up、Down和“-”。其中,“-”表示未手动配置ESI |
AD-delay remaining time |
以太网自动发现路由延迟发布定时器的剩余时间,单位为秒 |
A-D per ES route RD |
A-D per ES路由中携带的路由标识符 |
ACs |
VSI在当前ES下的AC列表 |
UPWs |
VSI在当前ES下的UPW列表 |
Link ID |
AC在VSI内的链路ID |
以太网服务实例ID |
Tag ID |
以太网标签ID |
DF address |
被选为DF的VTEP或PE的Router ID,取值为“-”表示当前设备未被选举为该AC的DF |
ESI label |
Argument |
UPW link ID |
UPW在VSI内的链路标识符 |
# 显示远端ES的简要信息。
<Sysname> display evpn es remote
Control Flags: P - Primary, B - Backup, C - Control word
Status codes : * - valid
VSI name : vpna
EVPN instance: -
ESI : 0001.0000.0000.0000.0001
Ethernet segment routes :
1.1.1.1
3.3.3.3
A-D per ES routes :
Peer IP Remote Redundancy mode
1.1.1.1 All-active
3.3.3.3 All-active
A-D per EVI routes :
Tag ID Peer IP
0 1.1.1.1
0 3.3.3.3
ESI : 0001.0002.0003.0004.0005
1.1.1.1
A-D per ES routes :
1.1.1.1 All-active
Tag ID Peer IP
0 1.1.1.1
Xconnect group name : a
EVPN instance: -
123.123.123.123
3.3.3.3
A-D per ES routes :
123.123.123.123 All-active
3.3.3.3 All-active
Tag ID Control Flags Peer IP
2 P 3.3.3.3
4 PC 123.123.123.123
# 显示远端ES的详细信息。
<Sysname> display evpn es remote verbose
VSI name : vpna
EVPN instance: -
A-D per ES routes :
Peer IP : 2::2
Remote Redundancy mode: All-active
Argument : ::1
Tag ID : 1
Peer IP : 2::2
EVPN instance: -
2::2
A-D per ES routes :
Peer IP : 2::2
Tag ID : 1
Control Flags : P
Peer IP : 2::2
Remaining Time : 52
# 显示VSI实例vpna内,从下一跳3.3.3.3接收到的远端ES的信息。
<Sysname> display evpn es remote vsi vpna nexthop 3.3.3.3
VSI name : vpna
EVPN instance: -
3.3.3.3
A-D per ES routes :
3.3.3.3 All-active
Tag ID Peer IP
0 3.3.3.3
表1-21 display evpn es remote命令显示信息描述表
VSI name |
VSI名称 |
EVPN instance |
交叉连接组名称 |
ESI |
ES标识符 |
Remote Redundancy mode |
ES的冗余备份模式,取值包括: · All-active:表示ES的冗余备份模式为多活模式 · Single-active:表示ES的冗余备份模式为单活模式 |
Argument |
Ethernet segment routes |
与该ES关联的以太网段路由 |
A-D per Ethernet segment routes |
与该ES关联的A-D per ES路由 |
A-D per EVI routes |
与该ES关联的A-D per EVI路由 |
Tag ID |
以太网标签ID |
Peer IP |
远端设备的IP地址 |
Remaining Time |
回切等待的剩余时间,单位为秒。回切等待定时器启动时,才会显示该字段 |
远端ES的冗余备份模式,取值包括: · All-active:表示ES的冗余备份模式为多活模式 · Single-active:表示ES的冗余备份模式为单活模式 |
Control Flags |
远端路由二层属性控制标识,取值包括: · P:接收到的路由携带了Primary标识 · B:接收到的路由携带了Backup标识 · C:接收到的路由携带了Control word标识 VPWS支持Control Flags,VPLS不支持Control Flags |
Status codes |
路由状态代码:* - valid:合法路由 |
display evpn instance命令用来显示EVPN实例的相关信息。
display evpn instance [ name instance-name | vsi vsi-name | xconnect-group group-name ]
name instance-name:显示指定EVPN实例的信息。instance-name表示EVPN实例名称,为1~31个字符的字符串,区分大小写。
vsi vsi-name:显示指定VSI对应EVPN实例的信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
xconnect-group group-name:显示指定交叉连接组对应EVPN实例的信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。
执行本命令时,如果没有指定name instance-name、vsi vsi-name和xconnect-group group-name参数,则显示所有EVPN实例的信息。
# 显示所有EVPN实例的信息。
<Sysname> display evpn instance
Total number of EVPN instances: 6
EVPN instance : aaa
Route distinguisher : -
Export VPN targets : -
Import VPN targets : -
MAC advertisement : Enabled
ARP advertisement : Enabled
ARP-based MAC learning : Enabled
ND-based MAC learning : Enabled
Local fast-reroute : Inherit
Tunnel policy : -
PW class : -
Dt2uLocatorName : -
Dt2ulLocatorName : -
Dt2mLocatorName : -
E-Tree : Disabled
Best-Effort : Disabled
Traffic-Engineering : Disabled
Import routing policy : -
Export routing policy : -
VSI binding list:
VSI name VSI tag ID
4 100
EVPN instance : - (created on vsi 1)
Encapsulation : VXLAN
VXLAN ID : -
EVPN instance : - (created on vsi 2)
Encapsulation : MPLS
MPLS label : 775127
IMET MPLS label : 775126
Tunnel policy : -
PW class : -
Control Word : Disabled
E-Tree : Disabled
PW type : VLAN
Sequencing : -
Flow label : -
Default color : -
EVPN instance : - (created on vsi 3)
Encapsulation : SRV6
Dt2u SID : -(no locator configration)
Dt2ul SID : -(no locator configration)
Dt2m SID : -(no locator configration)
Dt2uLocatorName : -
Dt2mLocatorName : -
E-Tree : Disabled
Default color : -
EVPN instance : - (created on Xconnect-group 1)
Import Route Policy : -
Export Route Policy : -
Default color : -
EVPN instance : - (created on Xconnect-group 2)
Encapsulation : SRv6
Default color : -
表1-22 display evpn instance命令显示信息描述表
EVPN instance |
EVPN实例名称,显示方式如下: · instance-name:表示系统视图下创建的EVPN实例 · - (created on VSI vsi-name):表示VSI实例vsi-name下创建的EVPN实例 · -(created on Xconnect-group xconnect-group-name):表示交叉连接组xconnect-group-name下创建的EVPN实例 |
Encapsulation |
EVPN的封装类型,取值包括: · VXLAN:表示EVPN的封装类型为VXLAN · MPLS:表示EVPN的封装类型为MPLS · SRv6:表示EVPN的封装类型为SRv6 |
EVPN实例的RD |
Export VPN targets |
EVPN实例的Export Target |
Import VPN targets |
EVPN实例的Import Target |
MAC advertisement |
是否允许通告MAC地址信息,取值包括: · Enabled:允许通告MAC地址信息 · Disabled:禁止通告MAC地址信息 |
ARP advertisement |
是否允许通告ARP信息,取值包括: · Enabled:允许通告ARP信息 · Disabled:禁止通告ARP信息 |
ARP-based MAC learning |
是否允许EVPN从ARP信息中学习MAC地址表项,取值包括: · Enabled:允许EVPN从ARP信息中学习MAC地址表项 · Disabled:禁止EVPN从ARP信息中学习MAC地址表项 |
ND-based MAC learning |
是允许EVPN从ND信息中学习MAC地址表项功能,取值包括: · Enabled:允许EVPN从ND信息中学习MAC地址表项 · Disabled:禁止EVPN从ND信息中学习MAC地址表项 |
MPLS label |
MAC/IP发布路由携带的MPLS标签 |
IMET MPLS label |
IMET路由携带的MPLS标签 |
Tunnel policy |
EVPN实例引用的隧道策略 |
PW class |
EVPN实例引用的PW模板 |
Control word |
是否开启控制字功能,取值包括: · Enabled:PW开启控制字功能 · Disabled:PW关闭控制字功能 |
E-Tree |
是否开启EVPN E-Tree功能,取值包括: · Enabled:开启EVPN E-Tree功能 · Disabled:关闭EVPN E-Tree功能 |
PW type |
PW类型,取值包括: · Ethernet:以太网类型 · VLAN:VLAN类型 |
Sequencing |
PW的排序处理,取值包括: · Both:表示对PW收发两个方向的报文均进行排序处理 · -:表示未配置PW的排序处理,即不对PW上传输的报文进行排序 |
VXLAN ID |
VXLAN编号 |
Flow label |
流标签能力,取值包括: · Both:具有发送和接收能力 · Send:具有发送能力 · Recv:具有接收能力 · -:未开启流标签能力 |
Dt2u SID |
EVPN VPLS over SRv6组网中,用于转发单播报文的SRv6 SID,括号中为SID各组成部分长度,依次为Locator段长度、动态Opcode长度、静态Opcode长度和Argument长度,各组成部分长度之和为128 如果End.DT2U SID取值为“-”,则会显示未分配End.DT2U SID的原因,取值包括: · conflict with dx2 sid:表示End.DT2U SID与End.DX2 SID冲突 · no locator configuration:表示未指定用于分配End.DT2U SID的Locator段 |
Dt2ul SID |
EVPN VPLS over SRv6多归属站点组网中,用于在冗余备份组成员设备间的Bypass隧道上转发单播报文的SRv6 SID,括号中为SID各组成部分长度,依次为Locator段长度、动态Opcode长度、静态Opcode长度和Argument长度,各组成部分长度之和为128 如果End.DT2UL SID取值为“-”,则会显示未分配End.DT2UL SID的原因,取值包括: · conflict with dx2 sid:表示End.DT2UL SID与End.DX2 SID冲突 · no bypass configuration:表示未开启FRR功能 · no locator configuration:表示未指定用于分配End.DT2UL SID的Locator段 |
Dt2m SID |
EVPN VPLS over SRv6组网中,用于转发组播报文的SRv6 SID,括号中为SID各组成部分长度,依次为Locator段长度、动态Opcode长度、静态Opcode长度和Argument长度,各组成部分长度之和为128 如果End.DT2M SID取值为“-”,则会显示未分配End.DT2M SID的原因,取值包括: · conflict with dx2 sid:表示End.DT2M SID与End.DX2 SID冲突 · no locator configuration:表示未指定用于分配End.DT2M SID的Locator段 |
Dt2uLocatorName |
用于申请DT2U SID的Locator段名称 若禁止动态分配SID,则显示auto-sid-disable;否则,不显示 |
Dt2ulLocatorName |
用于申请DT2UL SID的Locator段名称 若禁止动态分配SID,则显示auto-sid-disable;否则,不显示 |
Dt2mLocatorName |
用于申请DT2M SID的Locator段名称 若禁止动态分配SID,则显示auto-sid-disable;否则,不显示 |
Best-Effort |
是否根据SRv6 SID进行SR-BE路由迭代,取值包括: · Enabled:根据SRv6 SID进行SR-BE路由迭代 · Disabled:不会根据SRv6 SID进行SR-BE路由迭代 |
Traffic-Engineering |
是否根据下一跳地址进行SR-TE路由迭代,取值包括: · Enabled:根据下一跳地址进行SR-TE路由迭代 · Disabled:不会根据下一跳地址进行SR-TE路由迭代 |
Import routing policy |
EVPN实例引用的入方向路由策略,如果未引用入方向路由策略,则显示为“-”。只有报文封装类型为MPLS或SRv6时才显示本字段 |
Export routing policy |
EVPN实例引用的出方向路由策略,如果未引用出方向路由策略,则显示为“-”。只有报文封装类型为MPLS或SRv6时才显示本字段 |
Default color |
EVPN路由的缺省Color值,如果未配置EVPN路由的缺省Color值,则显示为“-” |
· evpn encapsulation
· vsi
display evpn ipv6 auto-discovery命令用来显示EVPN通过BGP自动发现的IPv6邻居信息。
display evpn ipv6 auto-discovery { ethernet-ad srv6 [ peer ipv6-address ] [ vsi vsi-name ] | { imet | mac-ip } [ srv6 ] [ peer ipv6-address ] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
imet:显示通过包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)发现的IPv6邻居信息。
mac-ip:显示通过MAC/IP发布路由(MAC/IP Advertisement route)发现的IPv6邻居信息。
srv6:显示EVPN VPLS over SRv6组网中通过BGP自动发现的邻居信息。EVPN VPLS over SRv6组网的详细介绍,请参见“Segment Routing配置指导”中的“EVPN VPLS over SRv6”。
peer ipv6-address:显示指定IPv6邻居的自动发现相关信息。ipv6-address为邻居的IPv6地址。如果未指定本参数,则显示所有IPv6邻居的自动发现相关信息。
vsi vsi-name:显示指定VSI内自动发现的IPv6邻居信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI内自动发现的IPv6邻居信息。
macip-prefix:显示通过携带L3VNI的MAC/IP发布路由或IP前缀路由发现的IPv6邻居信息。
nexthop next-hop:显示从指定路由下一跳学习到的邻居信息。如果未指定本参数,则显示从所有路由下一跳学习到的IPv6邻居信息。
count:显示自动发现的IPv6邻居数目。如果未指定本参数,则显示IPv6邻居的具体信息。
执行本命令时,如果没有指定srv6参数,则显示所有组网中EVPN通过BGP自动发现的IPv6邻居信息。
# EVPN VPLS over SRv6组网中显示通过以太网自动发现路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery ethernet-ad srv6
VSI name: vpnc
Tunnel mode : SRv6
In SID : 100::10::0
表1-23 display evpn ipv6 auto-discovery ethernet-ad命令显示信息描述表
自动发现的邻居数目 |
VSI name |
VSI名称 |
Destination IP |
隧道的目的端地址 |
Tunnel mode |
隧道的模式,取值为SRv6,表示SRv6隧道 |
In SID |
SRv6隧道的入SID |
Out SID |
SRv6隧道的出SID |
# EVPN VXLAN组网中显示通过包含性组播以太网标签路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery imet vxlan
Total number of automatically discovered peers: 2
VSI name: vpna
RD : 1:10
PE address : 11::8
Tunnel address : 11::8
Tunnel mode : VXLAN
VXLAN ID : 10
RD : 2:100
PE address : 12::8
Tunnel address : 12::8
Tunnel mode : VXLAN
VXLAN ID : 10
# EVPN VPLS over SRv6组网中显示通过包含性组播以太网标签路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery imet srv6
VSI name: vpnc
PE_address : 3::3
In SID : 111::1
Out SID : 333::1
表1-24 display evpn ipv6 auto-discovery imet命令显示信息描述表
自动发现的邻居数目 |
VSI name |
VSI名称 |
RD |
路由标识符 |
PE address |
远端设备在VSI内的标识 |
Tunnel address |
隧道的目的端地址 |
Tunnel mode |
隧道的模式,取值包括: · VXLAN:表示VXLAN隧道 · VXLAN-DCI:表示VXLAN数据中心互联隧道 · SRv6:表示SRv6隧道 |
VXLAN ID |
VXLAN编号 |
In SID |
SRv6隧道的入SID |
Out SID |
SRv6隧道的出SID |
# EVPN VXLAN组网中显示通过MAC/IP发布路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery mac-ip vxlan
VSI name: vpna
Destination IP : 6:6::6:8
Source IP : 1:1::1:7
VXLAN ID : 100
Tunnel mode : VXLAN
Tunnel name : Tunnel1
# EVPN VPLS over SRv6组网中显示通过MAC/IP发布路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery mac-ip srv6
VSI name: vpnc
Tunnel mode : SRv6
In SID : 100::10::0
表1-25 display evpn ipv6 auto-discovery mac-ip命令显示信息描述表
自动发现的邻居数目 |
VSI name |
VSI名称 |
Destination IP |
隧道的目的端地址 |
Source IP |
隧道的源端地址 |
VXLAN ID |
VXLAN编号 |
Tunnel mode |
隧道模式,取值包括: · VXLAN,表示VXLAN隧道 · SRv6:表示SRv6隧道 |
Tunnel name |
隧道名称 |
In SID |
SRv6隧道的入SID |
Out SID |
SRv6隧道的出SID |
# 显示通过MAC/IP发布路由和IP前缀路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery macip-prefix
L3VNI : 100
Tunnel mode : VXLAN
Outgoing interface : Vsi-interface3
# 显示通过MAC/IP发布路由和IP前缀路由发现的IPv6邻居总数。
<Sysname> display evpn ipv6 auto-discovery macip-prefix count
Total number of entries: 2
表1-26 display evpn ipv6 auto-discovery macip-prefix命令显示信息描述表
Destination IP |
隧道的目的端地址 |
Source IP |
隧道的源端地址 |
L3VNI |
用于三层转发的VXLAN ID |
Tunnel mode |
隧道的模式,取值包括 · VXLAN:表示VXLAN隧道 · VXLAN-DCI:表示VXLAN数据中心互联隧道 |
Outgoing interface |
出接口,即与L3VNI关联的VSI虚接口 |
Total number of entries |
邻接表项的总数 |
display evpn route arp命令用来显示EVPN的ARP信息。
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ip ip-address ] [ count | verbose ]
local:显示本地ARP信息。
remote:显示远端ARP信息。
public-instance:显示公网实例的ARP信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ARP信息。vpn-instance-name表示 MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ip ip-address:显示指定IP地址的ARP信息。ip-address表示IPv4地址,为点分十进制格式。如果不指定本参数,则显示公网或VPN实例的所有ARP信息。
count:显示ARP表项的数目。如果不指定本参数,则显示ARP表项的具体信息。
verbose:显示ARP表项的详细信息。如果不指定本参数,则显示ARP表项的简要信息。
执行本命令时,如果没有指定local和remote参数,则显示EVPN的本地和远端ARP信息。
执行本命令时,如果没有指定public-instance和vpn-instance vpn-instance-name参数,则显示公网实例和所有VPN实例的ARP信息。
# 显示所有EVPN的ARP信息。
<Sysname> display evpn route arp
Flags: D - Dynamic B - BGP L - Local active
G - Gateway S - Static M - Mapping I - Invalid
VPN instance:abc Interface:Vsi-interface1
IP address MAC address Router MAC VSI index Flags
10.1.1.1 0003-0003-0003 a0ce-7e40-0400 0 GL
10.1.1.11 0001-0001-0001 a0ce-7e40-0400 0 DL
10.1.1.12 0001-0001-0011 a0ce-7e41-0401 0 B
10.1.1.13 0001-0001-0021 a0ce-7e42-0402 0 B
10.1.1.101 0001-0011-0101 a0ce-7e40-0400 0 SL
10.1.1.102 0001-0011-0102 0011-9999-0000 0 BS
Public instance Interface:Vsi-interface2
11.1.1.1 0033-0033-0033 a0ce-7e40-0400 0 GL
11.1.1.11 0011-0011-0011 a0ce-7e40-0400 0 DL
# 显示EVPN的ARP表项总数。
<Sysname> display evpn route arp count
Total number of entries: 6
# 显示EVPN的ARP表项详细信息。
<Sysname> display evpn route arp verbose
VPN instance:abc Interface :Vsi-interface1
IP address : 10.1.1.1 MAC address : 0003-0003-0003
Router MAC : a0ce-7e40-0400 VSI index : 0
Flags : GL SVLAN/CVLAN : 1000/1001
IP address : 10.1.1.11 MAC address : 0001-0001-0001
Router MAC : a0ce-7e40-0407 VSI index : 0
Flags : DL SVLAN/CVLAN : 1000/1001
表1-27 display evpn route arp命令显示信息描述表
VPN instance name |
VPN实例名称 |
Public instance |
公网实例 |
VSI虚接口 |
IP address |
IP地址 |
MAC address |
MAC地址 |
Router MAC |
设备的Router MAC |
VSI index |
VSI索引 |
Flags |
ARP表项类型,取值包括: · D:表示存在动态学习的ARP表项 · B:表示存在通过BGP EVPN路由学习的ARP表项 · L:表示本地ARP表项生效,未设置该标志表示通过BGP EVPN路由学习的ARP表项生效 · G:表示生效的ARP表项是网关的ARP表项 · S:表示生效的ARP表项是静态配置的ARP表项 · M:表示生效的ARP表项是来自映射的远端VXLAN的ARP表项 · I:表示该ARP表项无效,原因如下: ¡ 通过shutdown命令手工关闭VSI ¡ 出方向Tunnel接口不存在 |
SVLAN/CVLAN |
ARP表项所属的公网VLAN ID/私网VLAN ID,“--”表示ARP表项的公网VLAN ID/私网VLAN ID为无效值 |
ARP表项的总数 |
display evpn route mac命令用来显示EVPN的MAC地址信息。
display evpn route mac [ mac-address mac-address | umr [ verbose ] ] [ mpls | srv6 ] [ local | remote ] [ vsi vsi-name ] [ count ]
mac-address mac-address:显示指定MAC地址表项信息。mac-address为MAC地址,格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
umr:显示UMR路由生成的缺省MAC地址表项信息。
verbose:显示UMR路由生成的缺省MAC地址表项的详细信息。如果不指定本参数,则显示UMR路由生成的缺省MAC地址表项的简要信息。
mpls:显示EVPN VPLS组网中的MAC地址信息。
srv6:显示EVPN VPLS over SRv6组网中的MAC地址信息。EVPN VPLS over SRv6的详细介绍,请参见“Segment Routing配置指导”中的“EVPN VPLS over SRv6”。
local:显示本地MAC地址信息。
remote:显示远端MAC地址信息。
vsi vsi-name:显示指定VSI的MAC地址信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的MAC地址信息。
count:显示MAC地址表项的数目。如果不指定本参数,则显示MAC地址的具体信息。
执行本命令时,如果没有指定mac-address和umr参数,则显示所有MAC地址的表项信息;如果没有指定local和remote参数,则显示EVPN的本地和远端MAC地址信息;如果没有指定mpls、srv6参数,则显示所有封装模式下的MAC地址信息。
# EVPN VPLS over SRv6组网中显示所有EVPN的本地和远端MAC地址信息。
<Sysname> display evpn route mac srv6
E - Multihoming ES sync F - Leaf R – Re-Originated
VSI name: vpnb
EVPN instance: -
MAC address : 68ba-0573-0606
Link ID/Name : 0x0
Flags : DL
Encap : SRv6
Next hop : -
Color : -
Color-Only : -
Slice ID : -
MAC address : 68ba-0b4f-0706
Link ID/Name : 0x9000000
Flags : B
Encap : SRv6
Next hop : 2::2
Color : -
Color-Only : -
Slice ID : -
SID : 1::2
# 显示EVPN的MAC地址表项数目。
<Sysname> display evpn route mac count
Total number of entries: 5
表1-28 display evpn route mac命令显示信息描述表
VSI name |
VSI名称 |
EVPN instance |
MAC address |
MAC地址 |
Link ID/Name |
Link ID表示路由表项的出链路标识符,即AC或SRv6隧道在VSI内的链路标识符 |
Flags |
表项类型,取值包括: · D:表示存在动态学习的MAC地址表项 · B:表示存在通过BGP EVPN路由学习的MAC地址表项 · L:表示本地MAC地址表项生效,未设置该标志表示通过BGP EVPN路由学习的MAC地址表项生效 · G:表示生效的MAC地址表项是网关的MAC地址表项 · S:表示生效的MAC地址表项是静态配置的MAC地址表项 · I:表示该MAC地址表项无效,原因如下: ¡ 通过shutdown命令手工关闭VSI ¡ 出方向Tunnel接口不存在 · E:表示多归属成员同步的MAC地址表项 · F:表示EVPN E-tree组网中从Leaf上学习到的MAC地址表项 · R:表示路由重生成的MAC地址表项 |
Encap |
报文封装类型,取值包括: · MPLS:报文封装类型为MPLS · SRv6:报文封装类型为SRv6 |
Nexthop |
远端VTEP或PE的地址,取值为“-”表示本地MAC |
MAC地址表项的总数 |
Color |
MAC地址的Color属性值,如果MAC地址无Color属性,则显示为“-”。只有报文封装类型为SRv6时才显示该字段 |
Color-Only |
CO标记位 |
Slice ID |
网络切片实例ID,取值为“-”时,表示未配置Color映射的Slice ID |
SID |
为MAC地址分配的SRv6 SID |
# 显示所有UMR路由生成的缺省MAC地址表项的详细信息。
<Sysname> display evpn route mac umr verbose
Flags: B - BGP L - Local active S - Static
VSI name: bbb
EVPN instance: -
MAC address Flags Encap Next hop ESI
0000-0000-0000 LS SRv6 -
BS SRv6 2.2.2.2 0003.0003.0003.0003.0003
BS SRv6 3.3.3.3 0000.0000.0000.0000.0000
表1-29 display evpn route mac umr verbose命令显示信息描述表
VSI name |
VSI名称 |
EVPN instance |
MAC address |
MAC地址 |
Flags |
表项类型,取值包括: · B:表示存在通过BGP EVPN路由学习的MAC地址表项 · L:表示本地MAC地址表项生效,未设置该标志表示通过BGP EVPN路由学习的MAC地址表项生效 · S:表示生效的MAC地址表项是静态配置的MAC地址表项 |
Encap |
Next hop |
ESI |
ES标识符,为VSI视图下配置的ESI值 |
display evpn route mac-mobility命令用来显示EVPN的MAC地址迁移信息。
display evpn route mac-mobility [ evpn-instance instance-name | interface interface-type interface-number | vsi vsi-name ] [ mac-address mac-address ] [ verbose ]
evpn-instance instance-name:显示指定EVPN实例内MAC地址迁移信息。instance-name表示EVPN实例名称,为1~31个字符的字符串,区分大小写。
interface interface-type interface-number:显示指定接口上的MAC地址迁移信息。interface-type interface-number为接口类型和接口编号。
vsi vsi-name:显示指定VSI的MAC地址迁移信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的MAC地址迁移信息。
mac-address mac-address:显示指定MAC地址的迁移信息。mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果不指定本参数,则显示VSI的所有MAC地址的迁移信息。
verbose:显示MAC地址迁移的详细信息。如果不指定本参数,则显示MAC地址迁移的简要信息。
配置本命令时,如果不指定vsi vsi-name、evpn-instance instance-name和interface interface-type interface-number参数,则显示所有MAC地址的迁移信息。
# 显示所有MAC地址的迁移信息。
<Sysname> display evpn route mac-mobility
Flags: S - Suppressed, N - Not suppressed
VSI name : vsia
MAC address Move count Moved from Flags Suppressed at
1000-0000-0000 10 GE1/0/6 S 15:30:30 2018/03/30
1000-0000-0001 - - N -
VSI name : vsib
1000-0000-0003 2 GE1/0/7 N -
1000-0000-0005 10 5.5.5.5 S 17:24:33 2018/04/01
表1-30 display evpn route mac-mobility命令显示信息描述表
VSI name |
VSI名称 |
MAC address |
MAC地址 |
Move count |
迁出次数 |
Moved from |
表示MAC地址上一次迁移到的AC接口名称或所在VTEP/PE的IP地址 |
Flags |
MAC地址是否被抑制迁移,取值包括: · S:表示抑制迁移 · N:表示未抑制迁移 |
Suppressed at |
迁移抑制发生的时间 |
# 显示所有MAC的迁移详细信息。
<Sysname> display evpn route mac-mobility verbose
VSI name : vsia
MAC Address : 1000-0000-0000
Move count : 10
Moved from : GE1/0/6
Flags : Suppressed
Suppressed at : 15:30:30 2018/03/30
Suppression threshold: 10
Detection cycle : 180s
Suppression-time : Permanent
表1-31 表1-30 display evpn route mac-mobility verbose命令显示信息描述表
Suppression threshold |
从本地迁移到远端站点的次数阈值 |
Detection cycle |
检测周期,单位为秒 |
Suppression-time |
抑制恢复时间,单位为秒 取值为Permanent时,表示永远抑制 |
VSI name |
VSI名称 |
MAC address |
MAC地址 |
Move count |
迁出次数 |
Moved from |
Flags |
MAC地址是否被抑制迁移标记,取值包括: · Suppressed:表示抑制迁移 · Not suppressed:表示未抑制迁移 |
Suppressed at |
迁移抑制发生的时间 |
从本地迁移到远端站点的次数阈值 如果未开启MAC反复迁移抑制功能或MAC未被抑制迁移,则本字段取值为“-” |
Detection cycle |
检测周期,单位为秒 如果未开启MAC反复迁移抑制功能或MAC未被抑制迁移,则本字段取值为“-” |
Suppression time |
抑制恢复时间,单位为秒 取值为Permanent时,表示永远抑制 如果未开启MAC反复迁移抑制功能或MAC未被抑制迁移,则本字段取值为“-” |
· evpn route mac-mobility suppression
display evpn route nd命令用来显示EVPN的ND表项信息。
display evpn route nd [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ipv6 ipv6-address ] [ count | verbose ]
local:显示本地ND表项信息。
remote:显示远端ND表项信息。
public-instance:显示公网实例的ND表项信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ND表项信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ipv6 ipv6-address:显示指定IPv6地址的ND信息。ipv6-address表示IPv6地址。如果不指定本参数,则显示公网或VPN实例的所有ND信息。
count:显示ND表项的数目。如果不指定本参数,则显示ND表项的具体信息。
verbose:显示ND表项的详细信息。如果不指定本参数,则显示ND表项的简要信息。
执行本命令时,如果没有指定local和remote参数,则显示EVPN的本地和远端的ND表项信息。
执行本命令时,如果没有指定public-instance和vpn-instance vpn-instance-name参数,则显示公网实例和所有VPN实例的ND表项信息。
# 显示所有EVPN的ND表项信息。
<Sysname> display evpn route nd
VPN instance: vpn1 Interface: Vsi-interface1
IPv6 address : AD80:0300:1000:0050:0200:0300:0100:0012
MAC address : 0001-0001-0001 Router MAC : a0ce-7e40-0400
VSI index : 0 Flags : GL
IPv6 address : AD10:0300:1000:0020:0200:0300:0100:0022
MAC address : 0001-0001-0002 Router MAC : a0ce-7e40-0411
Public instance Interface: Vsi-interface1
IPv6 address : BC80:0300:1000:0050:0200:0300:0100:0033
MAC address : 0002-0002-0001 Router MAC : a0ce-7e40-0422
IPv6 address : BC10:0300:1000:0020:0200:0300:0100:0034
MAC address : 0002-0002-0002 Router MAC : a0ce-7e40-0433
#显示EVPN的ND表项总数。
<Sysname>display evpn route nd count
# 显示所有EVPN的ND表项详细信息。
<Sysname> display evpn route nd verbose
SVLAN/CVLAN : 1002/1003
SVLAN/CVLAN : --/--
SVLAN/CVLAN : --/--
表1-32 display evpn route nd命令显示信息描述表
VPN instance |
VPN实例名称 |
Public instance |
公网实例 |
VSI虚接口名称 |
IPv6 address |
IPv6地址 |
MAC address |
MAC地址 |
Router MAC |
设备的Router MAC |
VSI index |
ND表项所属VSI的索引 |
Flags |
ND表项类型,取值包括: · D:表示动态学习的ND表项 · B:表示通过BGP EVPN路由学习的ND表项 · L:表示本地ND表项生效,未设置该标志表示通过BGP EVPN路由学习的ND表项生效 · G:表示生效的ND表项是网关的ND表项 · S:表示生效的ND表项是静态配置的ND表项(暂不支持) · I:表示该ND表项无效,原因如下: ¡ 通过shutdown命令手工关闭VSI ¡ 出方向Tunnel接口不存在 |
SVLAN/CVLAN |
ND表项所属的公网VLAN ID/私网VLAN ID,“--”表示ND表项所属的公网VLAN ID/私网VLAN ID为无效值 |
ND表项的总数 |
display evpn routing-table命令用来显示EVPN的路由表信息。
display evpn routing-table [ ipv6 ] { public-instance | vpn-instance vpn-instance-name } [ count ]
ipv6:显示EVPN的IPv6路由表信息。如果不指定本参数,则显示EVPN的IPv4路由表信息。
public-instance:显示公网实例的路由信息。
vpn-instance vpn-instance-name:显示指定VPN实例的路由信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
count:显示路由表项的数目。如果不指定本参数,则显示路由表项的具体信息。
# 显示VPN实例对应的EVPN IPv4的路由信息。
<Sysname> display evpn routing-table vpn-instance vpn1
Flags: E - with valid ESI A – A-D ready L - Local ES exists
VPN instance:vpna Local L3VNI:111
IP address Nexthop Outgoing interface NibID Flags
10.0.0.2 2.2.2.2 Vsi-interface111 0x18000000 EAL
10.0.0.3 3.3.3.3 Vsi-interface111 0x18000001 EA
20.0.0.2 3.3.3.3 Vsi-interface111 0x18000001 -
# 显示公网实例的EVPN IPv4路由信息。
<Sysname> display evpn routing-table public-instance
Public instance Local L3VNI:111
10.0.0.123 2.2.2.2 Vsi-interface111 0x18000000 EA
1.1.1.1 Vsi-interface111 0x18000001 EA
# 显示VPN实例对应的EVPN IPv4路由表项总数。
<Sysname> display evpn routing-table vpn-instance vpn1 count
# 显示VPN实例vpna对应的EVPN IPv6路由信息。
<Sysname> display evpn routing-table ipv6 vpn-instance vpna
VPN instance: vpna Local L3VNI: 7
Nexthop : 1.1.1.1
NibID : 0x18000000
IPv6 address : BC10:0300:1000:0020:0200:0300:0100:0035
Nexthop : 2.2.2.2
NibID : 0x18000001
表1-33 display evpn routing-table命令显示信息描述表
VPN instance name |
VPN实例名称 |
Public instance |
公网实例 |
Local L3VNI |
与VPN实例或公网实例关联的L3VNI |
IP address |
目的IPv4地址 |
IPv6 address |
目的IPv6地址 |
Nexthop |
下一跳地址 |
出接口 |
NibID |
下一跳ID |
Flags |
表项等价属性,取值包括: · E:表示路由携带了有效的ESI字段 · A:表示1类路由收全,可以下发该下一跳对应的等价路径 · L:表示本地有激活的ESI,不下发远端路由表项 · -:表示该2类路由未携带有效的ESI字段,不支持等价 |
路由表项的总数 |
display evpn route xconnect-group命令用来显示交叉连接的EVPN相关信息。
display evpn route xconnect-group [ name group-name [ connection connection-name ] ] [ count ]
name group-name:显示指定交叉连接组的EVPN相关信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有交叉连接组的EVPN相关信息。
connection connection-name:显示交叉连接组内指定交叉连接的EVPN相关信息。交叉连接的名称,为1~20个字符的字符串,不能包含字符“-”,区分大小写。如果未指定本参数,则显示指定交叉连接组内所有交叉连接的EVPN相关信息。
count:显示EVPN交叉连接的总数。如果不指定本参数,则显示交叉连接的EVPN的具体信息。
# 显示所有交叉连接的EVPN相关信息。
<Sysname> display evpn route xconnect-group
Ctrl Flags: P - Primary, B - Backup, C - Control word
Xconnect group name: aa
Connection name: aaa
Local service ID : 16777215
Remote service ID : 16777214
Control word : Enabled
In label : 502
Local MTU : 1500
AC state : Up
Tunnel policy : -
PW class : -
PW type : VLAN
Nexthop ESI Out label Flags MTU State
192.123.123.123 0001.0002.0002.0002.0001 1299 PC 1500 Up
192.1.1.1 0001.0002.0002.0002.0001 1026 B 1500 Down
Connection name: aab
Remote service ID : 2
Control word : Disabled
In label : 323
Local MTU : 1500
AC state : Up
Tunnel policy : -
PW class : -
PW type : VLAN
192.1.1.1 0002.0002.0002.0002.0001 1234 P 1500 Up
192.2.1.2 0002.0002.0002.0002.0001 603 P 1500 Up
Connection name: aac
Local service ID : 3
Remote service ID : 4
In label : -
Local MTU : 1500
AC state : Up
Tunnel policy : -
PW class : -
PW type : Ethernet
192.1.1.3 0000.0000.0000.0000.0000 555 P 1500 Idle
Connection name: pw1
In SID[DX2] : 100::1
In SID[DX2L] : -
Local MTU : 1500
AC State : Up
Tunnel policy : -
PW class : -
PW type : Ethernet
SRv6 Tunnel:
Next Hop : 2::2
Out SID : 200::1
Flags : P
MTU : 1500
State : Up
# 显示EVPN交叉连接的总数。
<Sysname> display evpn route xconnect-group count
表1-34 display evpn route xconnect-group命令显示信息描述表
交叉连接组名称 |
Connection name |
交叉连接名称 |
Encapsulation |
ESI |
ES标识符 |
Local service ID |
本地服务ID |
Remote service ID |
远端服务ID |
Control word |
是否开启控制字功能取值包括: · Enabled:PW开启控制字功能 · Disabled:PW关闭控制字功能 |
In label |
PW的入标签 |
Local MTU |
本地配置的最大传输单元,单位为字节 |
AC state |
当前AC的状态,取值包括Up、Down和“-”。其中,“-”表示未配置AC |
Tunnel policy |
引用的隧道策略 |
PW class |
引用的PW模板 |
PW type |
PW的数据封装类型,取值包括Ethernet和VLAN |
Nexthop |
远端PE的地址 |
Out label |
PW的出标签 |
Flags |
PW属性标记,取值包括: · P:接收到的路由携带了Primary标识,需要建立主PW · B:接收到的路由携带了Backup标识,需要建立备份PW · C:接收到的路由中携带控制字标识,表示对端开启控制字功能,若本地使能控制字功能,则使EVPN PW处于UP状态,否则EVPN PW无法UP |
MTU |
接收到的路由中携带的最大传输单元,单位为字节 |
State |
EVPN PW的状态,取值包括: · Up:表示协议状态Up · Down:表示协议状态Down · Idle:表示入或出标签不可用 |
In SID[DX2] |
End.DX2类型的入SID |
In SID[DX2L] |
End.DX2L类型的入SID |
SRv6 Tunnel |
SRv6隧道信息 |
Out SID |
出SID |
EVPN PW和SRv6隧道的总数 |
display evpn track peer命令用来在多归属组网中,显示本地设备与冗余备份组中其他成员设备的BGP邻居状态。
display evpn track peer [ esi esi-id ]
esi esi-id:显示指定ESI内本地设备与冗余备份组中其他成员设备的BGP邻居状态。esi-id表示以太网链路网段标识符的值,格式为xxxx.xxxx.xxxx.xxxx.xxxx,必须以00开头,其中x为十六进制数,不支持全0。如果未指定本参数,则显示所有ESI内本地设备与冗余备份组中其他成员设备的BGP邻居状态。
# 显示所有ESI的冗余备份组中其他成员设备的BGP邻居状态。
<Sysname> display evpn track peer
Status : Idle
TimerLeft : 30
Peer Peer Status
1::1 Up
1.1.1.1 Down
表1-35 display evpn track peer命令显示信息描述表
ESI |
ES标识符 |
Status |
以太网段路由的延迟发送定时器的工作状态,取值包括: · Idle:定时器未运行 · Running:定时器运行中 |
TimerLeft |
延迟发送以太网段路由的剩余时间,单位为秒 |
Peer |
冗余备份组中其他成员设备的IP地址 |
Peer Status |
本地设备与冗余备份组中其他成员设备的BGP邻居状态,取值包括: · Up:表示up状态 · Down:表示down状态 |
· evpn track peer
display l2vpn forwarding evpn命令用来显示EVPN VPLS/VPWS和EVPN VPLS/VPWS over SRv6的转发信息。
display l2vpn forwarding evpn [ vsi [ name vsi-name ] [ verbose ] ] slot slot-number
vsi:显示指定VSI下的EVPN的转发信息。不指定本参数时,显示所有关联EVPN的VSI和交叉连接的转发信息。
name vsi-name:显示指定VSI下的EVPN的转发信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI下的EVPN的信息。
verbose:显示指定VSI下的EVPN的详细信息。如果不指定本参数,则显示VSI下的EVPN的简要信息。
slot slot-number:指定单板。slot-number为单板所在的槽位号。
# 显示EVPN VPLS组网中slot 1上所有EVPN的简要转发信息。
<Sysname> display l2vpn forwarding evpn vsi slot 1
Total number of VSIs: 2
VSI name VSI index
vpls1 0
表1-36 display l2vpn forwarding evpn命令显示信息描述表
Total number of VSIs |
VSI的总数 |
VSI name |
VSI名称 |
VSI index |
VSI索引 |
# 显示EVPN VPLS组网中slot 1上所有EVPN的详细转发信息。
<Sysname> display l2vpn forwarding evpn vsi verbose slot 1
VSI name: vpls1
VSI index : 0
MPLS label : 1150
IMET MPLS label : 1149
Control word : enabled
PW type : Ethernet
Sequencing : Both
Flow label : Both
表1-37 display l2vpn forwarding evpn verbose命令显示信息描述表
VSI name |
VSI名称 |
VSI index |
VSI索引 |
Encapsulation |
封装类型,取值包括: · MPLS:表示MPLS封装 · SRv6:表示SRv6封装 |
MPLS label |
IMET MPLS label |
IMET路由携带的MPLS标签 |
Control word |
是否开启控制字功能,取值包括: · enabled:PW开启控制字功能 · disabled:PW关闭控制字功能 |
PW type |
Sequencing |
Flow label |
Dt2u SID |
用于转发单播报文的SRv6 SID |
Dt2ul SID |
多归属站点组网中,用于在冗余备份组成员设备间的Bypass隧道上转发单播报文的SRv6 SID |
Dt2m SID |
用于转发组播报文的SRv6 SID |
· vsi
display l2vpn forwarding evpn split-horizon命令用来显示EVPN多归属组网中满足水平分割原则的接口信息。
display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | upw vsi vsi-name } [ slot slot-number ]
ac interface interface-type interface-number:显示EVPN VPLS多归属组网中AC接口的水平分割信息,即从指定AC收到的泛洪流量不会转发到哪些AC。interface-type interface-number为三层接口的接口类型和接口编号。
upw vsi vsi-name:显示EVPN VPLS over SRv6/EVPN VPLS组网中用来关联SRv6 PW/EVPN PW的LDP PW或静态PW的水平分割信息,即从指定VSI的LDP PW或静态PW收到的泛洪流量不会转发到哪些SRv6 PW或者EVPN PW。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。
# 显示从Tunnel 0上收到的泛洪流量中满足水平分割原则的接口信息。
<Sysname> display l2vpn forwarding evpn split-horizon tunnel 0
Tunnel name: 0
Total number of filtered interfaces: 2
Filtered interfaces:
GE1/0/6
GE1/0/7
# EVPN VPLS组网中显示AC接口GigabitEthernet1/0/6的水平分割信息。
<Sysname> display l2vpn forwarding evpn split-horizon ac interface gigabitethernet 1/0/6
Interface name : GigabitEthernet1/0/6
AC link ID : 0
PW count : 2
VSI name PW link ID ESI label
vpna 8 775128
vpna 9 775128
# EVPN VPLS over SRv6组网中显示AC接口GigabitEthernet1/0/6的水平分割信息。
AC link ID : 0
SRv6 tunnel count : 2
VSI name SRv6 link ID Argument
vpna 0x8 ::1
vpna 0x9 ::1
# EVPN VPLS组网中显示VSI实例vpna的LDP PW或静态PW水平分割信息。
<Sysname> display l2vpn forwarding evpn split-horizon upw vsi vpna
UPW link ID : 0
PW count : 2
VSI name PW link ID Argument
vpna 0x8 ::1
vpna 0x9 ::1
# EVPN VPLS over SRv6组网中显示VSI实例vpna的LDP PW或静态PW水平分割信息。
UPW link ID : 0
vpna 0x8 ::1
vpna 0x9 ::1
表1-38 display l2vpn forwarding evpn split-horizon命令显示信息描述表
Total number of filtered interfaces |
EVPN多归属组网中满足水平分割原则的接口 |
Interface name |
接口名称 |
AC link ID |
AC的链路标识符 |
以太网服务实例编号 |
PW count |
PW的数量 |
SRv6 tunnel count |
SRv6隧道的数量 |
VSI name |
VSI名称 |
PW link ID |
PW的链路标识符 |
SRv6 link ID |
SRv6隧道的链路标识符 |
ESI label |
ESI标签 |
Argument |
UPW link ID |
UPW的链路标识符 |
e-tree enable命令用来开启本地AC与远端AC的EVPN E-Tree功能。
undo e-tree enable命令用来关闭本地AC与远端AC的EVPN E-Tree功能。
e-tree enable
undo e-tree enable
本地AC与远端AC的EVPN E-Tree功能处于关闭状态。
VSI实例下的EVPN实例视图
在EVPN VPLS和EVPN VPLS over SRv6组网中,属于同一个EVPN实例的所有AC均可以互相访问。EVPN承载接入用户的网络中,为了提高用户的安全性,减少用户之间的相互影响,通常需要控制AC侧用户之间的相互访问。EVPN E-Tree功能通过将AC分为Root和Leaf角色,实现了同一EVPN实例内AC之间流量的隔离。
本命令用于开启本地AC与远端AC的EVPN E-Tree功能,若仅需要控制本地AC之间的访问,则无需配置本命令。
EVPN VPLS和EVPN VPLS over SRv6组网中,不能同时配置本功能。
# 开启EVPN E-Tree功能。
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation mpls
[Sysname-vsi-aaa-evpn-mpls] e-tree enable
esi命令用来配置接口、UPW或VSI的ESI(Ethernet Segment Identifier,以太网段标识)。
undo esi命令用来恢复缺省情况。
esi esi-id
undo esi
未配置接口、UPW和VSI的ESI。
交叉连接PW视图
VSI LDP PW视图
VSI静态PW视图
VSI视图
esi-id:以太网链路网段标识符。格式为xxxx.xxxx.xxxx.xxxx.xxxx,必须以00开头,其中x为十六进制数,不支持全0。
ESI是ES的唯一标识,ESI相同的接口(或UPW、VSI)属于同一个ES,报文可以在这些接口(或UPW、VSI)之间进行负载分担。
主接口及其子接口上均可以配置ESI:
· 若主接口及其子接口上都配置了ESI,或仅在子接口上配置了ESI,则子接口的ESI以该子接口上的配置为准,子接口的ES相关配置(evpn redundancy-mode、evpn df-election algorithm、evpn df-election preference、evpn df-election preference non-revertive和evpn timer es-delay命令)也以该子接口上的配置为准。
· 若仅在主接口上配置了ESI,则子接口继承主接口的ESI和ES相关配置。即使子接口上执行了ES相关配置,也不会生效。
只有VSI LDP PW和VSI静态PW不采用水平分割方式转发报文或建立的PW为DCI PW(执行peer命令时指定no-split-horizon参数或dci参数)时,才允许在该VSI LDP PW或VSI静态PW的视图下执行本命令。
多归属组网站点中,PE设备发布UMR路由时,在该路由中携带VSI视图下配置的ESI,以标识路由对应的ES。
不能通过重复执行esi命令修改接口(或UPW、VSI)的ESI属性值。如需修改,请先通过undo esi命令删除接口(或UPW、VSI)的ESI属性值,再执行esi命令配置新的ESI属性值。
# 配置接口GigabitEthernet1/0/6上的ESI值为0000.0001.0002.0003.0004。
[Sysname] interface gigabitethernet 1/0/6
[Sysname-GigabitEthernet1/0/6] esi 0000.0001.0002.0003.0004
# 配置交叉连接PW的ESI值为0000.0001.0002.0003.0004。
[Sysname] xconnect-group 1
[Sysname-xcg-1] connection 1
[Sysname-xcg-1-1] peer 1.1.1.1 pw-id 34
[Sysname-xcg-1-1-1.1.1.1-34] esi 0000.0001.0002.0003.0004
# 配置VSI LDP PW的ESI值为0000.0001.0002.0003.0004。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] pwsignaling ldp
[Sysname-vsi-vpn1-ldp] peer 1.1.1.1 pw-id 23 no-split-horizon
[Sysname-vsi-vpn1-ldp-1.1.1.1-23] esi 0000.0001.0002.0003.0004
# 配置VSI静态PW的ESI值为0000.0001.0002.0003.0004。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] pwsignaling static
[Sysname-vsi-vpn1-static] peer 1.1.1.1 pw-id 23 in-label 100 out-label 200 no-split-horizon
[Sysname-vsi-vpn1-static-1.1.1.1-23] esi 0000.0001.0002.0003.0004
· peer(MPLS命令参考/VPLS)
evpn df-election ac-influence enable命令用来开启AC状态影响DF选举功能。
undo evpn df-electionac-influence enable命令用来关闭AC状态影响DF选举功能。
undo evpn df-election ac-influence enable
AC状态影响DF选举功能处于关闭状态。
缺省情况下,在EVPN多归属组网中,同一ES内的所有VTEP/PE都将参与DF选举,VTEP/PE上AC的状态不影响VTEP/PE是否参与DF选举。若选举为DF的VTEP/PE上AC的状态为Down,会导致VTEP/PE无法通过AC转发流量,此时可以通过配置本命令来解决此问题。
配置本命令之后,只有当AC状态为Up时VTEP/PE才会参与DF选举。VTEP/PE通过如下方式判断AC状态:
· 对于本端VTEP/PE,通过检查本端AC是否Up来判断本端VTEP/PE是否参与DF选举,只有AC状态为Up的本端VTEP/PE才可以参与DF选举。
· 对于远端VTEP/PE,通过检查是否收到远端VTEP/PE发布的AD VTEP/PEr ES路由和AD VTEP/PEr EVI路由来判断远端VTEP/PE是否参与DF选举,只有收到远端VTEP/PE发布的AD VTEP/PEr ES 路由和AD VTEP/PEr EVI路由时,本端VTEP/PE才认为远端VTEP/PE上AC为Up状态,可以参与DF选举。
只有当冗余备份组中的所有VTEP/PE上都开启本功能时,本功能才生效。
# 开启AC状态影响DF选举功能。
[Sysname] evpn df-election ac-influence enable
evpn df-election algorithm命令用来配置DF选举算法。
undo evpn df-election algorithm命令用来恢复缺省情况。
evpn df-election algorithm algorithm
以系统视图下配置的DF选举算法为准。
IESI视图
algorithm:指定DF选举算法。当前仅支持取值preference,表示基于优先级的DF选举算法。
在EVPN多归属组网中,如果用户希望通过更加灵活地方式控制DF选举,则可以配置本命令修改DF选举算法。
接口视图、IESI视图和系统视图下均可以配置DF选举算法。系统视图的配置对所有ES和IES都有效;IESI视图的配置对该IESI标识的IES都有效;接口视图下的配置只对当前接口下的ES有效。对于一个ES来说,优先采用该接口视图下的配置,只有该接口下未进行配置时,才采用系统视图的配置;对于一个IES来说,优先采用该IESI视图下的配置,只有该IESI视图下未进行配置时,才采用系统视图的配置。
# 在接口GigabitEthernet1/0/6上配置基于优先级的DF选举算法。
[Sysname-GigabitEthernet1/0/6] evpn df-election algorithm preference
· evpn df-election algorithm (system view)
· evpn df-election preference
evpn df-election algorithm命令用来全局配置DF选举算法。
采用基于VLAN Tag的DF选举算法。
系统视图、IESI视图和接口视图下均可以配置DF选举算法。系统视图的配置对所有ES和IES都有效;IESI视图的配置对该IESI标识的IES都有效;接口视图下的配置只对当前接口下的ES有效。对于一个ES来说,优先采用该接口视图下的配置,只有该接口下未进行配置时,才采用系统视图的配置;对于一个IES来说,优先采用该IESI视图下的配置,只有该IESI视图下未进行配置时,才采用系统视图的配置。
# 全局配置基于优先级的DF选举算法。
[Sysname] evpn df-election algorithm preference
· evpn df-election algorithm (interface view /IESI view)
evpn df-election preference命令用来配置DF选举优先级。
undo evpn df-election preference命令用来恢复缺省情况。
evpn df-election preference preference
DF选举优先级为32767。
IESI视图
preference:指定DF选举优先级,取值范围为0~65535。优先级数值越大则优先级越高。
在EVPN多归属组网中,若采用了基于优先级的DF选举算法,则可以通过本命令配置DF选举优先级来控制DF的选举。DF优先级最高的设备将选举为DF。
只有在接口视图或系统视图下执行evpn df-election algorithm preference命令后,接口视图下通过本命令配置的优先级才会生效。
只有在IESI视图或系统视图下执行evpn df-election algorithm preference命令后,IESI视图下通过本命令配置的优先级才会生效。
# 配置DF选举优先级为100。
[Sysname-GigabitEthernet1/0/6] evpn df-election preference 100
evpn df-election preference non-revertive命令用来开启基于优先级DF选举算法的不回切功能。
undo evpn df-election preference non-revertive命令用来关闭基于优先级DF选举算法的不回切功能。
基于优先级算法的DF选举不回切功能处于关闭状态。
IESI视图
配置基于优先级的DF选举算法后,优先级最高的设备被选举为DF进行流量转发。
如用户通过多归属接入VTEP 1和VTEP 2,VTEP 1的DF选举优先级为200,VTEP 2的DF选举优先级为100,则VTEP 1被选举为DF。若出现如下情况则会重新选举VTEP 2作为DF:
· VTEP 1设备故障。
· 用户接入VTEP 1的链路故障。
· 在VTEP 2上配置了比VTEP 1更高的DF选举优先级。
若在VTEP 2被选举为DF后,VTEP 1故障恢复、用户接入VTEP 1的链路故障恢复或者VTEP 1上配置了高于VTEP 2上的DF选举优先级,则又会重新选举VTEP 1作为DF。如果此时将DF切换为VTEP 1,则会造成一些不必要的丢包。在VTEP 2上配置本功能,可以避免DF回切为VTEP 1,减少丢包。
只有在接口视图或系统视图下执行evpn df-election algorithm preference命令后,接口视图下配置的本命令才会生效。
只有在IESI视图或系统视图下执行evpn df-election algorithm preference命令后,IESI视图下配置的本命令才会生效。
# 开启基于优先级DF选举算法的不回切功能。
[Sysname-GigabitEthernet1/0/6] evpn df-election preference non-revertive
evpn encapsulation命令用来创建EVPN实例,并进入EVPN实例视图。如果EVPN实例已经存在,则直接进入EVPN实例视图。
undo evpn encapsulation命令用来恢复缺省情况。
VSI视图:
交叉连接组视图:
不存在EVPN实例。
VSI视图
交叉连接组视图
mpls:表示EVPN采用MPLS封装方式。
只有创建EVPN实例后,才能进行EVPN相关配置。
# 创建VSI视图下的EVPN实例,并进入VSI实例下的EVPN实例视图。
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan]
evpn frr local enable命令用来开启指定EVPN实例的Bypass PW功能。
evpn frr local disable命令用来关闭指定EVPN实例的Bypass PW功能,同时删除已经建立的Bypass PW。
undo evpn frr local命令用来恢复缺省情况。
evpn frr local { disable | enable }
undo evpn frr local
EVPN实例的Bypass PW功能状态与EVPN VPWS全局Bypass PW功能状态保持一致。
交叉连接组EVPN实例视图
EVPN多归属站点组网中,CE 1双归属接入PE 1和PE 2,其中PE 1为DF。当PE 1侧的AC故障时,PE 1会向PE 2及远端PE通告本地不可达信息,使PE 1与远端PE间的PW无法转发流量,导致已经从远端PE发送到PE 1的数据报文被丢弃。为解决上述问题,可通过配置本命令在PE 1与PE 2间建立Bypass PW。PE 1侧的AC故障时,通过Bypass PW临时将流量转发到PE 2,以避免流量转发中断。
如果同时执行了本命令和evpn multihoming vpws-frr local命令,则当前EVPN实例的Bypass PW功能状态以本命令的配置为准。
本命令配置在冗余备份组成员PE上。
# 开启交叉连接组aa的EVPN实例的Bypass PW功能。
[Sysname] xconnect-group aa
[Sysname-xcg-1] evpn encapsulation mpls
[Sysname-xcg-1-evpn-mpls] evpn frr local enable
· evpn multihoming vpws-frr local
evpn frr local enable命令用来开启指定EVPN实例的FRR功能。
evpn frr local disable令令用来关闭指定EVPN实例的FRR功能。
undo evpn frr local
EVPN实例的FRR功能状态与EVPN全局FRR功能状态保持一致。
VSI实例下的EVPN实例视图
EVPN VPLS多归属站点组网中,CE 1双归属接入PE 1和PE 2,其中PE 1为DF。当PE 1侧的AC故障时,PE 1会删除对应的MAC地址表项,并向PE 2及远端PE通告本地不可达信息撤销MAC地址,此时已经从远端PE发送到PE 1的数据报文由于没有出接口,会被丢弃。为解决上述问题,可通过本命令在PE 1上开启FRR功能,使PE 1侧的AC故障时,不删除对应的MAC地址表项,而是将出接口变更为PE 1与PE 2间建立的PW的索引,将数据报文转发至PE 2,再由PE 2转发至CE 1,从而减少AC故障导致的丢包。
EVPN采用MPLS封装方式时,如果同时执行了本命令和evpn multihoming vpls-frr local命令,则当前EVPN实例的FRR功能状态以本命令的配置为准。
本命令配置在冗余备份组成员PE上。
# 开启VSI实例vpna下的EVPN实例的FRR功能。
[Sysname] vsi vpna
[Sysname-vsi-vpna] evpn encapsulation mpls
[Sysname-vsi-vpna-evpn-mpls] evpn frr local enable
· evpn multihoming vpls-frr local
evpn frr remote enable命令用来开启指定EVPN实例的主备PW功能。
evpn frr remote disable命令用来关闭指定EVPN实例的主备PW功能,同时删除已经建立的备PW。
undo evpn frr remote命令用来恢复缺省情况。
evpn frr remote [ disable | enable ]
EVPN实例的主备PW功能状态与EVPN VPWS全局主备PW功能状态保持一致。
交叉连接组EVPN实例视图
EVPN VPWS和EVPN VPWS over SRv6组网中,通过本命令开启主备PW功能后,PE间将建立主备两条PW,实现当主PW出现故障后,将流量立即切换到备份PW,使得流量转发得以继续。
MPLS封装和SRv6封装的交叉连接组EVPN实例均支持本命令。
如果同时执行了本命令和evpn vpws-frr remote命令,则当前EVPN实例的主备PW功能状态以本命令的配置为准。
# 开启交叉连接组xcga的EVPN实例的主备PW功能。
[Sysname] xconnect-group xcga
[Sysname-xcg-xcga] evpn encapsulation mpls
[Sysname-xcg-xcga-evpn-mpls] evpn frr remote enable
· evpn vpws-frr remote
evpn local-service-id remote-service-id命令用来创建EVPN PW,并进入EVPN PW视图。如果指定的EVPN PW已经存在,则直接进入EVPN PW视图。
undo evpn local-service-id remote-service-id命令用来删除指定的EVPN PW。
evpn local-service-id local-service-id remote-service-id remote-service-id [ tunnel-policy tunnel-policy-name ] [ pw-class class-name ]
undo evpn local-service-id local-service-id remote-service-id remote-service-id
不存在EVPN PW。
交叉连接视图
local-service-id local-service-id:本端的service ID,取值范围为1~16777215。
remote-service-id remote-service-id:远端的service ID,取值范围为1~16777215。
tunnel-policy tunnel-policy-name:指定PW的隧道策略。tunnel-policy-name表示隧道策略名,为1~126个字符的字符串,区分大小写。如果不指定本参数,则使用缺省的隧道策略。
pw-class class-name:指定PW引用的PW模板。class-name表示PW模板名,为1~19个字符的字符串,区分大小写。PW模板中可以配置PW的数据封装类型、是否使用控制字等。如果不指定本参数,则PW数据封装类型由接口的链路类型决定,对于不强制要求使用控制字的PW数据封装类型,不支持控制字功能。
同一个交叉连接中不能通过重复执行evpn local-service-id remote-service-id修改已经创建的EVPN PW,如需修改已经创建的EVPN PW,请先通过undo evpn local-service-id remote-service-id命令删除已经创建的EVPN PW,再执行evpn local-service-id remote-service-id命令创建新的EVPN PW。
在多归属站点组网中,如果本端PE与冗余备份组中的各PE建立EVPN PW时,通过本命令引用的PW模板中配置了使用BFD检测PW的连通性:
· 若本端PE与冗余备份组中各PE建立的EVPN PW为主备EVPN PW,则仅为主EVPN PW建立动态BFD会话。
· 若本端PE与冗余备份组中各PE建立的EVPN PW为等价EVPN PW,则不建立动态BFD会话。
# 创建EVPN PW,指定PW的隧道策略为aaa并且指定引用的PW模板为bbb,并进入EVPN PW视图。
[Sysname] xconnect-group aaa
[Sysname-xcg-aaa] connection ac2pw
[Sysname-xcg-aaa-ac2pw] evpn local-service-id 2 remote-service-id 4 tunnel-policy aaa pw-class bbb
[Sysname-xcg-aaa-ac2pw-2-4]
evpn mpls routing-enable命令用来开启EVPN通告VPN路由功能。
undo evpn mpls routing-enable命令用来关闭EVPN通告VPN路由功能。
EVPN通告VPN路由功能处于关闭状态。
VPN实例IPv4地址族视图
VPN实例IPv6地址族视图
开启本功能后,VPN路由表中的VPN路由会作为EVPN的IP前缀路由发布给邻居;当收到邻居发送的MPLS封装的IP前缀路由时,会将其插入到相应的VPN路由表中。
本功能需要与向对等体/对等体组发布MPLS封装的IP前缀路由功能配合使用,即在配置本功能后还需要在BGP EVPN地址族视图下执行命令peer advertise encap-type mpls配置向对等体/对等体组发布MPLS封装的IP前缀路由功能。
# 在VPN实例vpna的IPv4地址族视图下使能EVPN通告VPN路由功能。
[Sysname-vpn-instance-vpna] address-family ipv4
[Sysname-vpn-ipv4-vpna] evpn mpls routing-enable
evpn multihoming advertise disable命令用来配置禁止通告以太网自动发现路由和以太网段路由,并撤销已经通告的该类路由。
undo evpn multihoming advertise disable命令用来恢复缺省情况。
允许通告EVPN以太网自动发现路由和以太网段路由。
在站点多归属组网中,用户需要重启其中一台VTEP或PE时,重启该VTEP或PE前,可以通过在该VTEP或PE上执行此命令,来禁止通告以太网自动发现路由和以太网段路由,并撤销已经通告的该类路由,以便其他VTEP或PE及时更新本地的EVPN路由表,确保VTEP或PE的重启不会影响报文转发。
# 配置禁止通告以太网自动发现路由和以太网段路由,并撤销已经通告的该类路由。
[Sysname] evpn multihoming advertise disable
evpn multihoming advertise ignore-ethernet-tag命令用来配置发布以太网自动发现路由和MAC/IP发布路由时忽略以太网标签。
undo evpn multihoming advertise ignore-ethernet-tag命令用来恢复缺省情况。
EVPN多归属组网中,PE发送以太网自动发现路由和MAC/IP发布路由时携带以太网标签。
本命令需要配置在冗余备份组成员PE上。
多归属站点组网中,为冗余备份组成员上的AC配置ESI后,冗余备份组成员发送以太网自动发现路由和MAC/IP发布路由时会携带AC的以太网标签。如果对端设备无法识别以太网标签,为了与该对端设备互通,需要在本端设备上配置本命令,使得本端设备将发送的以太网自动发现路由和MAC/IP发布路由中的以太网标签字段填为0。
执行本命令后,设备会撤销已经发布的以太网自动发现路由和MAC/IP发布路由,并重新发布以太网标签字段为0的以太网自动发现路由和MAC/IP发布路由。
执行本命令时,需要注意的是:
· 为三层主接口配置ESI后,如果该接口上的子接口未配置ESI,则子接口会继承主接口的ESI。此时,具有相同ESI的子接口不能关联相同的VSI。
# 配置发布以太网自动发现路由和MAC/IP发布路由时忽略以太网标签。
[Sysname] evpn multihoming advertise ignore-ethernet-tag
· esi
evpn multihoming vpls-frr local命令用来全局开启EVPN VPLS的FRR功能。
undo evpn multihoming vpls-frr local命令用来关闭全局EVPN VPLS的FRR功能。
EVPN VPLS的FRR功能处于关闭状态。
如果执行本命令的同时在指定EVPN实例下执行了evpn frr local命令,则指定EVPN实例的FRR功能状态以EVPN实例下的配置为准。
如果在指定EVPN实例下开启了EVPN的FRR功能,则执行undo evpn multihoming vpls-frr local命令不会关闭该EVPN实例下的FRR功能。
本命令配置在冗余备份组成员PE上。
# 开启EVPN VPLS全局FRR功能。
[Sysname] evpn multihoming vpls-frr local
· evpn frr local (VSI EVPN instance view)
evpn multihoming vpws-frr local命令用来开启全局EVPN VPWS的Bypass PW功能。
undo evpn multihoming vpws-frr local命令用来关闭全局EVPN VPWS的Bypass PW功能,并删除已经建立的Bypass PW。
EVPN VPWS的Bypass PW功能处于关闭状态。
如果执行本命令的同时在指定EVPN实例下执行了evpn frr local命令,则指定EVPN实例的Bypass PW功能状态以EVPN实例下的配置为准。
执行undo evpn multihoming vpws-frr local命令后,如果EVPN实例下配置了evpn frr local enable命令,则不删除该EVPN实例下的Bypass PW。
本命令配置在冗余备份组成员PE上。
# 开启全局EVPN VPWS的Bypass PW功能。
[Sysname] evpn multihoming vpws-frr local
· evpn frr local (cross-connect group EVPN instance view)
evpn multihoming re-originated mac命令用来配置本地重生成MAC/IP发布路由中的MAC地址。
undo evpn multihoming re-originated mac命令用来恢复缺省情况。
本地不会重生成MAC/IP发布路由中的MAC地址。
EVPN VPLS组网中,CE 1通过聚合口或S-trunk双归属接入PE 1和PE 2,PE 3为远端PE连接CE 2。CE 1选择PE 1侧发送流量至CE 2,CE 2通过PE 1和PE 2两侧均可将流量转发至CE 1。当PE 1侧AC故障时,PE 1会撤销发送至PE 2和PE 3的MAC/IP发布路由,此时PE 2需要重新从CE 1学习MAC地址并同步给PE 3,在此期间PE 3没有CE 1的MAC地址表项,导致断流。
为解决上述问题,可在PE 1和PE 2上均配置本命令,PE 2接收到PE 1同步的MAC/IP发布路由时,在本地重新生成CE 1的MAC地址表项并发布给PE 3,这样即使PE 1侧的AC故障导致PE 1撤销MAC/IP发布路由,PE 3仍有CE 1的MAC地址表项,避免断流。
配置本命令前,需要先开启EVPN VPLS的FRR功能。
# 配置本地重生成MAC/IP发布路由中的MAC地址。
[Sysname] evpn multihoming re-originated mac
evpn multihoming timer df-delay命令用来设置DF选举的延迟时间。
undo evpn multihoming timer df-delay命令用来恢复缺省情况。
evpn multihoming timer df-delay delay-value
DF选举的延迟时间为3秒。
delay-value:DF选举的延迟时间,取值范围为1~1200,单位为秒。
AC所在接口的状态、多归属成员设备数量或者接口下ESI值的频繁变化都会导致DF频繁选举,极大影响了网络的性能。通过配置evpn multihoming timer df-delay命令可以指定DF选举的时间间隔,避免频繁选举DF,保证网络的稳定性。
在多归属组网中,若希望DF故障时,能够快速选举出新的DF,以避免长时间存在多个BFD,导致流量转发中断,则建议通过本命令将DF选举延迟时间配置为0。
# 配置DF选举的延迟时间为5秒。
[Sysname] evpn multihoming timer df-delay 5
evpn redundancy-mode命令用来配置接口、UPW或VSI的冗余备份模式。
undo evpn redundancy-mode命令用来恢复缺省情况。
evpn redundancy-mode { all-active | single-active }
冗余备份模式为多活冗余模式。
交叉连接PW视图
VSI LDP PW视图
VSI静态PW视图
VSI视图
single-active:单活冗余模式。
all-active:多活冗余模式。
在多归属站点组网中,冗余备份组中的各PE分别与远端PE建立EVPN PW(或SRv6 PW),若需两条EVPN PW(或SRv6 PW)间形成主备关系,则使用单活冗余模式;若需EVPN PW(或SRv6 PW)间形成等价负载分担,则使用多活冗余模式。
多归属站点组网中,PE设备发布UMR路由时,在该路由中携带VSI视图下配置的ESI,以标识路由对应的ES。在VSI视图下,还可以通过本命令配置该ES的冗余备份模式。
建议为同一冗余备份组中各PE连接多归属站点的AC(或UPW、VSI)配置相同的冗余备份模式。
本功能需要与配置接口(或UPW、VSI)的ESI配合使用,即还需要执行esi命令配置ESI。
# 配置接口GigabitEthernet1/0/6的冗余备份模式为单活冗余模式。
[Sysname-GigabitEthernet1/0/6] evpn redundancy-mode single-active
# 配置交叉连接PW的冗余备份模式为单活冗余模式。
[Sysname-xcg-1-1-1.1.1.1-34] evpn redundancy-mode single-active
# 配置VSI LDP PW的冗余备份模式为单活冗余模式。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1-ldp-1.1.1.1-23] evpn redundancy-mode single-active
# 配置VSI静态PW的冗余备份模式为单活冗余模式。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1-static] peer 1.1.1.1 pw-id 23 no-split-horizon
[Sysname-vsi-vpn1-static-1.1.1.1-23] evpn redundancy-mode single-active
· esi
evpn route mac-mobility suppression命令用来开启MAC地址反复迁移抑制功能。
undo evpn route mac-mobility suppression命令用来关闭MAC地址反复迁移抑制功能。
evpn route mac-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
MAC地址反复迁移抑制功能处于关闭状态。
VSI实例下的EVPN实例视图
三层接口视图
detect-cycle detect-time:指定MAC地址迁移的检测周期。detect-time取值范围为60~900,单位为秒,缺省值为180。
detect-threshold move-times:指定从本地迁移到远端站点的次数阈值。move-times取值范围为3~10,缺省值为5。
suppression-time:指定MAC迁移抑制功能的抑制恢复时间。被抑制的MAC地址在抑制恢复时间超时后,会从抑制状态恢复为正常状态,可以正常迁移。缺省取值为permanent,即不会恢复被抑制的MAC地址,永远抑制。
suppression-time:抑制恢复时间,取值范围为120~3600,单位为秒。
permanent:不会恢复被抑制的MAC地址,永远抑制。
EVPN VPLS组网中,不同PE下的设备如果错误地配置了相同的MAC地址,会造成PE间不断同步MAC地址信息,并更新本地EVPN的MAC地址表项。此时PE认为该设备在不断迁移。这种情况可能会使PE间形成环路,占用大量的链路带宽。开启本功能后,若在检测周期内某MAC地址从本地迁移到远端的次数超过阈值,则抑制最后一次由远端向本地迁移,即仅本地学习但不对外通告该MAC地址,避免PE间形成环路。
执行undo evpn route mac-mobility suppression命令或MAC地址的抑制时间超过抑制恢复时间时,如果PE上被抑制迁移的MAC地址未老化,则立即向远端通告该MAC地址;如果PE上被抑制迁移的MAC地址已经老化,则PE重新从本地学习该MAC地址后再对外通告。
系统视图、VSI实例下的EVPN实例视图和三层接口视图下均可以开启MAC地址反复迁移抑制功能。系统视图的配置对所有EVPN实例都有效,VSI实例下的EVPN实例视图下的配置仅对该VSI有效,三层接口视图下的配置仅对该接口有效。对于一个MAC地址来说,MAC地址反复迁移抑制功能生效的优先级为三层接口视图>VSI实例下的EVPN实例视图>系统视图。
# 开启MAC地址反复迁移抑制功能。
[Sysname] evpn route mac-mobility suppression
· display evpn route mac-mobility
evpn timer ad-delay命令用来开启以太网自动发现路由延迟发布功能,并指定延迟发布时间。
undo evpn timer ad-delay命令用来关闭以太网自动发现路由延迟发布功能。
evpn timer ad-delay delay-time
以太网自动发现路由延迟发布功能处于关闭状态,即不延迟发布以太网自动发现路由。
IESI视图
delay-time:以太网自动发现路由延迟发布时间,取值范围3~1200,单位为秒。
EVPN VPLS组网中,CE 1通过聚合口或S-trunk双归属多活接入PE 1和PE 2,PE 3为远端PE连接CE 2。CE 1选择PE 1侧发送流量至CE 2,CE 2通过PE 1和PE 2两侧均可将流量转发至CE 1。PE 1重启后,在PE 2发送MAC/IP发布路由同步CE 1的MAC地址之前,PE 1先发送携带下一跳信息的以太网自动发现路由至PE 3,导致PE 3查找CE 1的MAC地址转发流量时会将流量转发给PE 1和PE 2,此时PE 1未学习到CE 1的MAC地址,报文会被丢弃。
为解决上述问题,可在PE 1的AC接口上配置本功能,延迟发布以太网自动发现路由,使PE 1先学习到CE 1的MAC地址,再发布以太网自动发现路由,减少丢包。
# 接口GigabitEthernet1/0/6下配置以太网自动发现路由发布的延迟时间为300秒。
[Sysname-GigabitEthernet1/0/6] evpn timer ad-delay 300
evpn timer es-delay命令用来开启以太网段路由延迟发布功能,并指定延迟发布时间。
undo evpn timer es-delay命令用来关闭以太网段路由延迟发布功能。
evpn timer es-delay delay-time
以太网段路由延迟发布功能处于关闭状态,即不延迟发布以太网段路由。
IESI视图
delay-time:以太网段路由延迟发布时间,取值范围3~1200,单位为秒。
本命令通常与evpn track peer命令配合使用。
在多归属组网中,冗余备份组的一台成员设备因故障等原因重启后,站点间的广播流量转发可能会失败。为了解决这个问题,可以在成员设备连接CE的接口上配置evpn track peer命令。如果通过本命令开启了以太网段路由延迟发布功能,则当成员设备从故障中恢复且连接CE的接口状态变为Up时,成员设备会启动以太网段路由的延迟发送定时器,并对指定BGP邻居状态进行监控。如果在定时器超时前,所有设备的BGP邻居状态均Up,则本地成员设备正常发送以太网段路由;否则,定时器超时后,本地成员设备向所有BGP邻居状态为Up的设备发送以太网段路由。定时器超时或所有监控的BGP邻居均Up后,本地成员设备根据收到的所有以太网段路由进行DF选举。
# 接口GigabitEthernet1/0/6下配置以太网段路由发布的延迟时间为300秒。
[Sysname-GigabitEthernet1/0/6] evpn timer es-delay 300
· evpn track peer
evpn timer es-recovery命令用来配置基于优先级选举DF时,延迟发布以太网段路由。
undo evpn timer es-recovery命令用来恢复缺省情况。
evpn timer es-recovery recovery-time
基于优先级选举DF时,不延迟发布以太网段路由。
IESI视图
recovery-time:以太网段路由延迟发布时间,取值范围为3~1200,单位为秒。
在DF设备重启或者进程重启触发DF重新选举的场景中,DF设备重启或进程重启后会立刻发布以太网段路由,以便快速恢复为DF是。由于接入侧连接恢复较慢,设备切换为DF后,可能会因为AC状态未up而导致丢包。此时,可以配置本命令,使设备在等待接入侧连接恢复或VSI处于Up状态后再发送以太网段路由。
在EVPN多归属组网采用多活冗余模式时,建议配置本功能,解决DF回切造成的丢包问题;采用单活冗余模式时,不建议配置本功能,否则会影响DF回切性能。
# 配置基于优先级选举DF时,延迟300秒发布以太网段路由。
[Sysname-GigabitEthernet1/0/6] evpn timer es-recovery 300
evpn track bfd命令用来配置BDF监测静态BFD会话状态。当DF侧AC故障导致静态BFD会话状态为down时,BDF快速切换为DF。
undo evpn track bfd命令用来恢复缺省情况。
evpn track bfd session-name
undo evpn track bfd
BDF未监测静态BFD会话状态。
三层以太网接口视图
三层聚合接口视图
session-name:静态BFD会话的名称,为1~64个字符的字符串,区分大小写。
EVPN VPWS多归属组网中,当DF侧的AC故障时,BDF无法快速切换为DF并转发流量,导致DF切换过程中丢包。为解决上述问题,可在DF与BDF间创建静态BFD会话,在DF上配置静态BFD会话监测本地AC接口的状态,并在BDF上配置本命令监测静态BFD会话状态,从而实现当DF侧AC故障时,DF上的静态BFD会话状态变为down,并将静态BFD会话状态通告给BDF,BDF快速切换为DF,从而缩短DF的切换时间,减少丢包。
不能通过重复执行evpn track bfd命令修改BDF监测的静态BFD会话。如需修改,请先通过undo evpn track bfd命令取消BDF监测静态BFD会话,再执行evpn track bfd命令配置BDF监测其它的静态BFD会话。
# 配置BDF上的接口GigabitEthernet1/0/6监测静态BFD会话abc。
[Sysname-GigabitEthernet1/0/6] evpn track bfd abc
· bfd static(可靠性命令参考/BFD)
evpn track peer命令用来在多归属组网中,配置冗余备份组中的成员设备监视其它PE设备的BGP邻居状态。
undo evpn track peer命令用来取消监视其它PE设备的BGP邻居状态。
接口视图:
evpn track peer peer-ipv4-address
undo evpn track peer peer-ipv4-address
IESI视图:
evpn track peer { peer-ipv4-address | peer-ipv6-address }
undo evpn track peer { peer-ipv4-address | peer-ipv6-address }
在多归属组网中,冗余备份组中的成员设备不会监视其它设备的BGP邻居状态。
IESI视图
peer-ipv4-address:PE的IPv4地址。
peer-ipv6-address:PE的IPv6地址。
在多归属组网中,冗余备份组的一台成员设备因故障等原因重启后,站点间的广播流量转发可能会失败。为了解决这个问题,可以在成员设备连接CE的接口上配置evpn track peer命令。这样,当成员设备从故障中恢复且连接CE的接口状态变为Up时,成员设备会启动以太网段路由的延迟发送定时器,并对本命令指定的BGP邻居状态进行监控。如果在定时器超时前,所有设备的BGP邻居状态均Up,则本地成员设备正常发送以太网段路由;否则,定时器超时后,本地成员设备向所有BGP邻居状态为Up的设备发送以太网段路由。定时器超时或所有监控的BGP邻居均Up后,本地成员设备根据收到的所有以太网段路由进行DF选举。
# 在接口GigabitEthernet1/0/6上配置本地成员设备监视设备1.1.1.1的BGP邻居状态。
[Sysname-GigabitEthernet1/0/6] evpn track peer 1.1.1.1
· evpn timer es-delay
evpn vpws-frr remote命令用来全局开启EVPN VPWS的主备PW功能。
undo evpn vpws-frr remote命令用来关闭全局EVPN VPWS的主备PW功能,并删除已经建立的备PW。
EVPN VPWS的主备PW功能处于关闭状态。
EVPN VPWS组网中,CE 1接入PE 1,PE 1分别通过RR 1和RR 2连接至PE 2,RR在PE间反射路由时修改下一跳属性并重新分配MPLS标签。RR上配置路由策略修改路由属性,PE 1根据RR反射路由中的路由属性,只会选择RR 1或RR 2其中一条最优路径与PE 2建立PW。为了提高网络可靠性,可在PE 1上配置主备PW功能,实现PE 1通过RR 1、RR 2分别与PE 2创建一主一备两条PW,其中最优路径为主PW,从而减小PE 1与RR 1或RR 2间链路故障对整个网络的影响。
如果执行本命令的同时在指定EVPN实例下执行了evpn frr remote命令,则指定EVPN实例的主备PW功能状态以EVPN实例下的配置为准。
如果EVPN实例下配置了evpn frr remote enable命令,再执行undo evpn vpws-frr remote命令,则EVPN实例下的主备PW功能仍然处于开启状态且不删除该EVPN实例下的备PW。
# 全局开启EVPN VPWS主备PW功能。
[Sysname] evpn vpws-frr remote
· evpn frr remote
export route-policy命令用来在配置EVPN的出方向路由策略。
undo export route-policy命令用来恢复缺省情况。
未配置EVPN的出方向路由策略,即不对发布的路由进行过滤。
VSI实例下的EVPN实例视图
交叉连接组EVPN实例视图
VPN实例EVPN视图
route-policy:出方向路由策略名称,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了EVPN的出方向路由策略,则EVPN实例/VPN实例向BGP EVPN协议发布路由时,将利用指定的路由策略对发布的路由进行过滤、改变发布路由的属性等。使用本命令可以更加精确、灵活地控制路由的发布。
在同一视图下,多次执行本命令,最后一次执行的命令生效。
VSI实例下的EVPN实例视图、交叉连接组EVPN实例视图、VPN实例视图和VPN实例EVPN视图下配置的出方向路由策略均能用来过滤EVPN路由。其中:
· VSI实例下的EVPN实例视图、交叉连接组EVPN实例视图下的配置用于EVPN二层转发场景。
· VPN实例视图和VPN实例EVPN视图下的配置用于EVPN三层转发场景。如果同时配置二者,则EVPN采用VPN实例EVPN视图下的配置。
# 在VPN实例vpn1下配置EVPN的出方向路由策略为poly-1。
[Sysname-vpn-instance-vpn1] address-family evpn
[Sysname-vpn-evpn-vpn1] export route-policy poly-1
· route-policy(三层技术-IP路由命令参考/路由策略)
ignore-ac-state enable命令用来开启当前VSI或交叉连接忽略AC状态的功能。
ignore-ac-state disable命令用来关闭当前VSI或交叉连接忽略AC状态的功能。
undo ignore-ac-state命令用来恢复缺省情况。
ignore-ac-state { enable | disable }
与全局忽略AC功能状态的开关情况保持一致。
VSI视图
交叉连接视图
EVPN VPLS、EVPN VPWS、EVPN VPLS over SRv6或EVPN VPWS over SRv6多归属单活组网中,CE 1采用S-Trunk方式双归属接入PE 1和PE 2,PE 1为主用设备,PE 2为备份设备,PE 2上AC状态为Down。当PE 1上AC故障时,PE 1会撤销以太网自动发现路由,同时PE 2上的AC状态为Up,并向远端PE发送以太网自动发现路由,远端PE需要收到PE 2发送的以太网自动发现路由,才能切换至备份路径,路径切换过程速度较慢,会导致报文丢失。为解决上述问题,可在PE 2上配置本命令,使PE 2忽略AC状态并向远端PE发送以太网自动发现路由,远端PE保存该路由。当PE 1的AC故障时,远端PE将流量快速切换至备份路径,减少丢包。
如果执行本命令的同时在全局执行了l2vpn ignore-ac-state命令,则该VSI或交叉连接的配置以ignore-ac-state命令为准。
本功能可以与本地重生成MAC/IP发布路由中的MAC地址功能配合使用。
# 开启VSI实例vpna忽略AC状态的功能。
[Sysname] vsi vpna
[Sysname-vsi-vpna] ignore-ac-state enable
# 开启交叉连接组aaa下交叉连接ac2pw忽略AC状态的功能。
[Sysname-xcg-aaa-ac2pw] ignore-ac-state enable
· l2vpn ignore-ac-state
igp-metric inherit命令用来配置将BGP EVPN路由添加到VPN实例路由表时,路由的Metric值为到达原EVPN路由下一跳的IGP路由的Metric值。
undo igp-metric inherit命令用来恢复缺省情况。
igp-metric inherit
将BGP EVPN路由添加到VPN实例路由表时,路由的Metric值变为0。
BGP EVPN地址族视图
配置本命令后,设备将BGP EVPN路由添加到VPN实例的路由表时,VPN实例中的该路由将会继承到达原EVPN路由下一跳的IGP路由的Metric值,即该路由在VPN实例路由表中的IGP Metric值为到达原EVPN路由下一跳的IGP路由的Metric值。
# 在BGP EVPN地址族视图下,配置将BGP EVPN路由添加到VPN实例路由表时,路由的Metric值为到达原EVPN路由下一跳的IGP路由的Metric值。
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn] igp-metric inherit
import evpn mac-ip命令用来配置将从对等体/对等体组收到的包含ARP/ND信息的MAC/IP发布路由引入BGP单播路由表。
undo import evpn mac-ip命令用来禁止将从对等体/对等体组收到的包含ARP/ND信息的MAC/IP发布路由引入BGP单播路由表。
import evpn mac-ip
BGP IPv4单播地址族视图
BGP IPv6 单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
在BGP IPv4或BGP IPv6单播地址族视图下执行本命令后,设备从对等体/对等体组收到包含ARP/ND信息的MAC/IP发布路由后,会将其添加到公网实例路由表,并发布到本地站点。
在BGP-VPN IPv4或BGP-VPN IPv6单播地址族视图下执行本命令后,设备从对等体/对等体组收到包含ARP/ND信息的MAC/IP发布路由后,会将其添加到VPN实例对应的BGP IPv4或BGP IPv6单播路由表,是否发布到本地站点取决于是否执行命令advertise l2vpn evpn配置允许向本地站点发布BGP EVPN路由。
# 配置将从对等体/对等体组收到的MAC/IP路由引入VPN实例vpna对应的BGP IPv4单播路由表。
[Sysname] bgp 100
[Sysname-bgp-default] ip vpn-instance vpna
[Sysname-bgp-default-vpna] address-family ipv4
[Sysname-bgp-default-ipv4-vpna] import evpn mac-ip
import route-policy命令用来配置EVPN的入方向路由策略。
undo import route-policy命令用来恢复缺省情况。
未配置EVPN的入方向路由策略,即如果接收到的路由携带的Route Target属性中存在与本地配置的Import Target相同的值,则接收该路由。
VSI实例下的EVPN实例视图
交叉连接组EVPN实例视图
VPN实例EVPN视图
route-policy:入方向路由策略名称,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了EVPN的入方向路由策略,则将BGP EVPN协议的路由引入到EVPN实例或VPN实例时,会利用指定的路由策略对引入的路由进行过滤、改变引入路由的属性等。使用本命令可以更加精确、灵活地控制路由的引入。
VSI实例下的EVPN实例视图、交叉连接组EVPN实例视图、VPN实例视图和VPN实例EVPN视图下配置的入方向路由策略均能用来过滤EVPN路由。其中:
# 在VPN实例vpn1下配置EVPN的入方向路由策略为poly-1。
[Sysname-vpn-evpn-vpn1] import route-policy poly-1
ip public-instance命令用来创建公网实例,并进入公网实例视图。如果公网实例已经存在,则直接进入公网实例视图。
undo ip public-instance命令用来删除公网实例。
ip public-instance
不存在公网实例。
公网实例用来实现分布式EVPN网关转发公网的三层流量及公私网互通。公网实例可以看作是特殊的VPN实例,分布式EVPN网关对公网实例的处理与VPN实例完全相同。
# 创建公网实例,并进入公网实例视图。
[Sysname] ip public-instance
[Sysname-public-instance]
l2vpn ignore-ac-state命令用来全局开启忽略AC状态的功能。
undo l2vpn ignore-ac-state命令用来全局关闭忽略AC状态的功能。
l2vpn ignore-ac-state [ evpn-vpls | evpn-vpws ]
忽略AC状态的功能处于关闭状态。
evpn-vpls:配置VSI忽略AC状态功能。
evpn-vpws:配置交叉连接忽略AC状态功能。
EVPN VPLS、EVPN VPWS、EVPN VPLS over SRv6或EVPN VPWS over SRv6多归属单活组网中,CE 1采用S-Trunk方式双归属接入PE 1和PE 2,PE 1为主用设备,PE 2为备份设备,PE 2上AC状态为Down。当PE 1上AC故障时,PE 1会撤销以太网自动发现路由,同时PE 2上的AC状态为Up,并向远端PE发送以太网自动发现路由,远端PE收到PE 2发送的以太网自动发现路由后,才能切换至备份路径,路径切换过程速度较慢,会导致报文丢失。为解决上述问题,可在PE 2上配置本命令,使PE 2忽略AC状态并向远端PE发送以太网自动发现路由,远端PE保存该路由。当PE 1的AC故障时,远端PE将流量快速切换至备份路径,减少丢包。
如果执行本命令的同时在VSI视图或交叉连接视图下执行了ignore-ac-state命令,则该VSI或交叉连接的配置以ignore-ac-state命令为准。
执行本命令时,如果没有指定evpn-vpls和evpn-vpws参数,则表示同时开启VSI忽略AC状态功能和交叉连接忽略AC状态功能。执行本命令时,如果指定了evpn-vpls(或evpn-vpws)参数开启VSI(或交叉连接)的忽略AC状态功能,则不能通过重复执行本命令开启交叉连接(或VSI)的忽略AC状态功能。如需开启交叉连接(或VSI)的忽略AC状态功能,请先通过undo l2vpn ignore-ac-state命令全局关闭忽略AC状态功能,再执行l2vpn ignore-ac-state命令开启VSI和交叉连接的忽略AC状态功能。
# 全局开启忽略AC状态的功能。
[Sysname] l2vpn ignore-ac-state
· ignore-ac-state
l2vpn ping-ce source-mac命令用来配置ping-ce操作中发送端MAC地址的范围。
undo l2vpn ping-ce source-mac用来恢复缺省情况。
l2vpn ping-ce source-mac start-mac-addres [ end-mac-addres ]
未配置ping-ce中发送端MAC地址的范围。
start-mac-addres:ping-ce操作中发送端MAC地址的起始值。格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
end-mac-addres:ping-ce操作中发送端MAC地址的结束值。格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果未指定本参数,则表示发送端MAC地址的起始值即为结束值。
本命令配置的发送端MAC地址范围最多包含16个MAC地址。
# 配置ping-ce操作中发送端MAC地址的范围为7A3A-2027-B770~7A3A-2027-B77F。
[Sysname] l2vpn ping-ce source-mac 7A3A-2027-B770 7A3A-2027-B77F
If the specified source MAC address is in use, abnormal data transmission might occur in VSI/cross-connect network. Are you sure the source MAC is unused? [Y/N]:y
· ping-ce
· ping-ce ipv6
mac-advertising disable命令用来配置禁止通告MAC地址信息,并撤销已经通告的MAC地址信息。
undo mac-advertising disable命令用来恢复缺省情况。
允许通告MAC地址信息。
VSI实例下的EVPN实例视图
本端VTEP或PE可能会同时向远端设备通告MAC地址信息和ARP信息。其中,ARP信息中已经包含MAC地址信息。为了避免重复,可以执行本命令来禁止本端设备向远端设备通告MAC地址信息。执行本命令后,本端设备还会撤销已经发布的MAC地址信息。
# 配置EVPN实例禁止通告MAC地址信息,并撤销已经通告的MAC地址信息。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-mpls] mac-advertising disable
nd mac-learning disable命令用来配置禁止EVPN从ND信息中学习MAC地址表项。
undo nd mac-learning disable命令用来恢复缺省情况。
EVPN可以从ND信息中学习MAC地址表项。
VSI实例下的EVPN实例视图
本端PE可能会同时接收到远端设备通告的MAC地址信息和ND信息。其中,ND信息中包含MAC地址信息。为了避免重复,可以在本端设备上执行本命令禁止EVPN从ND信息中学习MAC地址表项,EVPN仅通过MAC地址信息学习远端MAC地址表项。
# 配置禁止EVPN从ND信息中学习MAC地址表项。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-mpls] nd mac-learning disable
peer advertise encap-type mpls命令用来配置向对等体/对等体组发布MPLS封装的EVPN路由。
undo peer advertise encap-type mpls命令用来删除向对等体/对等体组发布MPLS封装的EVPN路由的配置。
peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
undo peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
不向对等体/对等体组发布MPLS封装的EVPN路由。
BGP EVPN地址族视图
ipv4-address:对等体的IPv4地址。指定的对等体必须已经创建。
ipv6-address:对等体的IPv6地址。指定的对等体必须已经创建。
prefix-length:前缀长度,取值范围为0~128。如果指定本参数,则表示指定网段内的动态对等体。
在EVPN VPLS、EVPN VPWS和EVPN L3VPN网络中,需要执行本命令配置向邻居发布MPLS封装的EVPN路由。
EVPN L3VPN组网中,本功能通常配置在EVPN承载的L3VPN网络的边缘节点和RR(Route Reflector,路由反射器)设备上。在边缘节点上,本功能需要与EVPN通告VPN路由功能配合使用,即在VPN实例IPv4地址族视图/VPN实例IPv6地址族视图下执行命令evpn mpls routing-enable开启EVPN通告VPN路由功能。
# 配置向对等体1.1.1.1发布MPLS封装的EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise encap-type mpls
· evpn mpls routing-enable
peer next-hop-invariable命令用来配置向EBGP对等体/对等体组发布路由时不改变下一跳。
undo peer next-hop-invariable命令用来配置向EBGP对等体/对等体组发布路由时会将下一跳改为自己的地址。
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } next-hop-invariable
BGP EVPN地址族视图
在两个数据中心之间,BGP EVPN路由通过IBGP—EBGP—IBGP的路径发布。不同数据中心的两个主机通信时,报文通过入口VTEP和出口VTEP之间的VXLAN隧道传输。因此,需要执行本命令配置IBGP路由通告给EBGP对等体时不改变下一跳地址,使得VTEP学习到的BGP EVPN路由下一跳为远端VTEP的地址,以便在两个VTEP之间建立VXLAN隧道。
本命令与peer next-hop-local命令互斥。
# 配置向EBGP对等体1.1.1.1发布路由时不改变下一跳。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 next-hop-invariable
· peer next-hop-local(三层技术-IP路由命令参考/BGP)
peer macip-route-limit命令用来设置允许从指定对等体/对等体组接收的MAC/IP发布路由的最大数量。
undo peer macip-route-limit命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } macip-route-limit route-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } macip-route-limit
不限制从对等体/对等体组接收的MAC/IP发布路由的数量。
BGP EVPN地址族视图
route-number:允许设备接收的MAC/IP发布路由的最大数量。如果没有指定alert-only、discard和reconnect参数,则从指定对等体/对等体组接收的路由的数量大于prefix-number时,路由器自动断开与指定对等体/对等体组的会话。对于BGP动态对等体,本地设备不会尝试与其重新建立会话,但是接收到对等体的BGP会话建立请求后会接受该请求;对于其他非BGP动态对等体,本地设备不会尝试与其重新建立会话,可以通过reset bgp命令重启BGP会话,使得本地设备与对等体重新建立BGP会话。
alert-only:如果路由器从指定对等体/对等体组接收的路由的数量大于prefix-number,仅打印告警信息,路由器保持与指定对等体/对等体组的会话,并可以继续接收路由。
discard:如果路由器从指定对等体/对等体组接收的路由的数量大于prefix-number值,路由器保持与指定对等体/对等体组的会话,但丢弃超出限制的路由,并打印告警信息。从指定对等体/对等体组接收的路由数量小于prefix-number后,路由器可以继续接收路由。如果用户想恢复之前丢弃的路由,则需要执行refresh bgp import命令请求对等体/对等体组重新发布路由。
reconnect reconnect-time:如果路由器从指定对等体/对等体组接收的路由的数量大于prefix-number值,则等待指定的时间间隔后重新与对等体/对等体组建立会话。reconnect-time为路由器与指定对等体/对等体组重建会话的时间间隔,取值范围为1~65535,单位为秒。对于BGP动态对等体,本参数不会生效。
percentage-value:配置路由器产生告警信息的阈值(即路由器接收的路由数量与prefix-number的百分比达到percentage-value时,路由器将产生告警信息),取值范围为1~100,缺省值为75。
执行本命令可以避免攻击者向路由器发送大量的MAC/IP发布路由,对路由器进行攻击。本命令还可以使路由器产生告警信息,提醒用户检查EVPN地址族下接收到的MAC/IP发布路由。
在BGP EVPN地址族视图下,对于同一个对等体/对等体组,peer macip-route-limit命令和peer route-limit命令互斥。
# 在BGP EVPN地址族视图下,设置允许从对等体1.1.1.1收到的MAC/IP发布路由的最大数量为10000。如果从对等体1.1.1.1收到的路由数量超过10000,则断开与该对等体的会话。
[Sysname] bgp 109
[Sysname-bgp-default-evpn] peer 1.1.1.1 macip-route-limit 10000
· peer route-limit(三层技术-IP路由命令参考/BGP)
· refresh bgp(三层技术-IP路由命令参考/BGP)
· reset bgp(三层技术-IP路由命令参考/BGP)
ping evpn vpws命令用来检测EVPN VPWS组网或EVPN VPWS over SRv6组网中PW的连通性。
ping evpn vpws xconnect-group group-name local-service-id remote-service-id [ end-op endop ] [ -a { source-ipv4 | source-ipv6 } | -c count | -exp exp-value | -h hop-limit | -m interval | -r reply-mode | -s packet-size | -t time-out | -tc tc ] *
xconnect-group group-name:交叉连接组的名称,为1~31个字符的字符串,不能包含字符“-”,区分大小写。
local-service-id:本端的Service ID,取值范围为1~16777215。
remote-service-id:远端的Service ID,取值范围为1~16777215。
end-op endop:为MPLS echo request报文添加End.OP SID。end-op为End.OP SID值。通过End.OP SID定位目的节点。如果未指定本参数,则不为MPLS echo request报文添加End.OP SID。本参数仅适用于EVPN VPWS over SRv6组网。
-a source-ipv4:指定发送的MPLS echo request报文的源地址。source-ipv4为源IPv4地址。如果未指定本参数,则MPLS echo request报文的源地址为该节点的MPLS LSR ID。本参数仅适用于EVPN VPWS组网。
-a source-ipv6:指定发送的MPLS echo request报文的源地址。source-ipv6为源IPv6地址。如果未指定本参数,则MPLS echo request报文的源IPv6地址为报文出接口的IPv6地址。本参数仅适用于EVPN VPWS over SRv6组网。
-c count:指定发送MPLS echo request报文的次数。count为MPLS echo request报文发送次数,取值范围为1~4294967295,缺省值为5。当网络状况较差情况时,建议增加发送报文次数,通过丢包率来检测网络质量。
-exp exp-value:指定MPLS echo request报文中标签的EXP值。exp-value为EXP值,取值范围为0~7,缺省值为0。本参数仅适用于EVPN VPWS组网。
-h hop-limit:指定MPLS echo request报文中的Hop limit值。hop-limit为Hop limit值,取值范围为1~255,缺省值为255。本参数仅适用于EVPN VPWS over SRv6组网。
-m interval:指定连续发送MPLS echo request报文的时间间隔。interval为发送报文的时间间隔,取值范围为1~10000,单位为毫秒,缺省值为2000。当网络状况较差情况时,建议配置此参数取值≥2000。
-r reply-mode:指定接收者对MPLS echo request报文的应答模式。reply-mode为应答模式。
· 在EVPN VPWS组网中,reply-mode取值为2或4,2表示使用UDP报文回应,4表示使用VCCV报文回应。缺省值为2。
· 在EVPN VPWS over SRv6组网中,reply-mode取值为2、4,缺省值为2。2表示使用UDP报文回应;4表示通过应用平面的控制通道进行回应,回应时封装SRH信息转发应答报文。
-s packet-size:指定MPLS echo request报文长度。packet-size为MPLS echo request报文长度(不包括IP头和UDP头),取值范围为65~8100,单位为字节,缺省值为100。
-t time-out:指定发送MPLS echo request报文后等待响应的超时时间。time-out为超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000。
-tc tc:指定MPLS Echo请求报文的流量等级。tc为流量等级,取值范围为0~255。缺省值为0。本参数仅适用于EVPN VPWS over SRv6组网。
EVPN VPWS组网和EVPN VPWS over SRv6组网中,本端PE设备与远端PE设备间通过PW传输数据报文。当PE间出现丢包或断流现象时,可通过本命令检测PE设备间的PW连通性。
在EVPN VPWS组网中,通过本命令检测的PW必须引用PW模板,且该PW模板下必须通过vccv cc命令配置VCCV控制通道类型。
# 检测交叉连接组xcga内本端service ID为2、远端service ID为1的PW的连通性。
<Sysname> ping evpn vpws xconnect-group xcga 2 1
EVPN VPWS PING FEC: Local Evpn Vpws Id = 1, Remote Evpn Vpws Id = 2 : 100 data bytes。
Press CTRL+C to break
Reply from 100.1.1.1: bytes=100 Sequence=1 time=11 ms
Reply from 100.1.1.1: bytes=100 Sequence=2 time=15 ms
Reply from 100.1.1.1: bytes=100 Sequence=3 time=11 ms
Reply from 100.1.1.1: bytes=100 Sequence=4 time=15 ms
Reply from 100.1.1.1: bytes=100 Sequence=5 time=11 ms
-- FEC: Local CeId = 1, Remote CeId = 5 ping statistics ---
5 packet(s) transmitted
5 packet(s) received
0.00% packet loss
round-trip min/avg/max = 11/13/15 ms
表1-39 ping evpn vpws命令显示信息描述表
EVPN VPWS PING FEC: Local Evpn Vpws Id = 1, Remote Evpn Vpws Id = 2 : 100 data bytes. |
检测本端service ID为2、远端service ID为1的PW的连通性,每个MPLS echo request报文中的数据为100字节 |
Press CTRL+C to break |
按组合键Ctrl+C可以终止ping操作 |
Reply from 100.1.1.1: bytes=100 Sequence=1 time=11 ms |
收到IP地址为100.1.1.1的设备回复的回显应答报文,包括: · bytes:表示MPLS Echo Reply报文中的数据字节数 · sequence:表示报文序号,用来判断报文是否有分组丢失、失序或重复 · time:表示响应时间 若在等待响应的超时时间内仍没有收到回显应答报文,则显示Request time out |
-- FEC: Local CeId = 1, Remote CeId = 5 ping statistics --- |
Ping操作中收发数据的统计结果,包括: · packet(s) transmitted:发送的MPLS echo request报文数目 · packet(s) received:接收到的MPLS Echo Reply报文数目 · % packet loss:未响应报文数占发送报文总数的百分比 · round-trip min/avg/max:往返时延的最小值、平均值、最大值,单位为ms |
ping evpn vsi命令用来检测EVPN VPLS或EVPN VPLS over SRv6组网中本端PE到指定主机连接的远端PE的PW连通性。
ping evpn vsi vsi-name mac mac-address [ end-op endop ] [-a { source-ipv4 | source-ipv6 } | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -tc tc | -v ] *
vsi vsi-name:检测与指定VSI关联的PW的连通性。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
mac mac-address:检测到指定主机连接的远端PE的PW连通性。mac-address表示MAC地址,形式为H-H-H,不能配置为全0、广播MAC地址和组播MAC地址。
end-op endop:为MPLS echo request报文添加End.OP SID。end-op为End.OP SID值。通过End.OP SID定位目的节点。如果未指定本参数,则不为MPLS echo request报文添加End.OP SID。本参数仅适用于EVPN VPLS over SRv6组网。
-a source-ipv4:指定发送的MPLS echo request报文的源地址。source-ipv4为源IPv4地址。如果未指定本参数,则MPLS echo request报文的源IPv4地址为报文出接口的主IPv4地址。本参数仅适用于EVPN VPLS组网。
-a source-ipv6:指定发送的MPLS echo request报文的源地址。source-ipv6为源IPv6地址。如果未指定本参数,则MPLS echo request报文的源IPv6地址为报文出接口的IPv6地址。本参数仅适用于EVPN VPLS over SRv6组网。
-exp exp-value:MPLS echo request报文中标签的EXP值。exp-value为EXP值,取值范围为0~7,缺省值为0。本参数仅适用于EVPN VPLS组网。
-h ttl-value:指定MPLS echo request报文中的TTL值,ttl-value为TTL值,取值范围为1~255,缺省值为255。
-m wait-time:指定连续发送MPLS echo request报文的时间间隔。wait-time为发送报文的时间间隔,取值范围为1~10000,单位为毫秒,缺省值为200。
-r reply-mode:指定接收者对MPLS echo request报文的应答模式。reply-mode为应答模式,取值为2、4,缺省值为2。2表示使用UDP报文回应。在EVPN VPLS组网中,4表示根据VSI关联的PW转发应答报文;在EVPN VPLS over SRv6组网中,4表示通过应用平面的控制通道进行回应,回应时封装SRH信息转发应答报文。
-rtos tos-value:指定MPLS echo reply报文IP头的ToS值。tos-value为ToS值,取值范围为0~7,缺省值为6。本参数仅适用于EVPN VPLS组网。
-s packet-size:指定MPLS echo request报文长度。packet-size为MPLS echo request报文长度(不包括IP头和UDP头),取值范围为81~1200,单位为字节,缺省值为100。
-tc tc:指定MPLS echo request报文的流量等级。tc为流量等级,取值范围为0~255,缺省值为0。本参数仅适用于EVPN VPLS over SRv6组网。
-v:显示详细的应答信息。如果未指定本参数,则显示简要的应答信息。本参数仅适用于EVPN VPLS组网。
EVPN VPLS组网和EVPN VPLS over SRv6组网中,本端PE设备与远端PE设备间通过PW传输数据报文,当PE间出现丢包或断流现象时,可通过本命令检测PE设备间的PW连通性。
# 检测EVPN VPLS组网中本端PE到MAC地址为2-2-2的主机连接的远端PE之间PW连通性。
<System> ping evpn vsi vpna mac 2-2-2
Ping remote PE with MAC 0002-0002-0002: 100 data bytes.
Press CTRL_C to break.
100 bytes from 50.1.1.12: Sequence=1 time=1 ms
100 bytes from 50.1.1.12: Sequence=2 time=2 ms
100 bytes from 50.1.1.12: Sequence=3 time=1 ms
100 bytes from 50.1.1.12: Sequence=4 time=2 ms
100 bytes from 50.1.1.12: Sequence=5 time=1 ms
--- Ping statistics for mac 0002-0002-0002 ---
Round-trip min/avg/max = 1/1/2 ms
ping-ce命令用来检测PE到CE之间IPv4链路的连通性。
ping-ce ip-address { vsi name | xconnect-group group-name connection connection-name } sender-ip source-ip [ source-mac source-mac ] [ -c count | -m wait-time | -s load-size ] *
ip-address:指定需要检测的CE的IP地址,该IP地址作为ARP请求报文的目标IP地址。
vsi vsi-name:配置在指定VSI内进行连通性检测。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
xconnect-group group-name connection connection-name:配置在指定交叉连接组的交叉连接内进行连通性检测。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。connection-name表示交叉连接的名称,为1~20个字符的字符串,不能包含字符“-”,区分大小写。
sender-ip sender-ip:指定ARP请求报文的发送端IP地址。sender-ip为发送端IP地址。
source-mac mac-address:指定ARP请求报文的发送端MAC地址。mac-address为发送端MAC地址,格式为H-H-H,取值范围由l2vpn ping ce source-mac命令配置。如果未指定本参数,则从l2vpn ping ce source-mac命令配置的MAC地址范围中按从小到大顺序依次选择一个未被使用的MAC地址作为发送端MAC地址。
-c count:指定发送ARP请求报文的次数。count为ARP请求报文发送次数,取值范围为1~255,缺省值为5。
-m interval:指定连续发送ARP请求报文的时间间隔。interval为发送ARP请求报文的时间间隔,取值范围为1~10,单位为秒,缺省值为3。
-s load-size:指定ARP报文填充的负载长度。load-size为填充的负载长度,取值范围为1~100,单位为字节。如果未指定本参数,则表示不对ARP报文进行填充。
执行本命令后,本端PE设备会向指定交叉连接或VSI内的所有AC和PW广播发送ARP请求报文。如果本端PE收到CE的ARP应答,则认为PE与CE之间的链路正常;若本端PE未在默认超时时间(2秒)内收到ARP应答报文,则认为PE与CE之间的链路不通。
执行本命令前,需要先执行l2vpn ping ce source-mac命令配置发送端MAC地址的范围。
执行本命令时,需要注意:
· source-mac mac-address参数指定的源MAC地址必须在l2vpn ping ce source-mac命令配置的发送端MAC地址的范围之内,否则配置失败。
· source-ip source-ip参数指定的源IPv4地址必须为当前设备接口下未配置的IPv4地址。
· 指定的ip-address和source-ip source-ip必须处于同一网段内。
# 对交叉连接组aaa内交叉连接bbb下的、IP地址为10.1.1.1的CE发起链路连通性检测,其中发送端IP地址为10.1.1.2,发送端MAC地址为7A3A-2027-B770。
[Sysname] ping-ce 10.1.1.1 xconnect aaa connection bbb source-ip 10.1.1.2 source-mac 7A3A-2027-B770
If the specified source IP address is in use, abnormal data transmission might occur in VSI/cross-connect network. Are you sure the source IP is unused in this VSI/cross-connect? [Y/N]:y
Reply from Link ID 1:MAC=00e0-fc12-3456 Sequence=1 time=11 ms
Reply from GE1/0/6:MAC=00e0-fc12-3456 Sequence=1 time=11 ms
Reply from unknown :MAC=00e0-fc12-3456 Sequence=1 time=11 ms
表1-40 ping ce命令显示信息描述表
Requset time out |
应答报文超时 |
Reply from GE1/0/6:MAC=00e0-fc12-3456 Sequence=1 time=11 ms |
收到应答报文的信息: · 应答报文的来源,取值包括: ¡ 从远端设备接收到应答报文,显示远端设备的IP地址 ¡ 从本地站点接收到应答报文,显示为接口名称 ¡ 从AC Bypass收到应答报文,显示为Link ID ¡ 在EVPN VPLS/VPWS组网中,从PW接收应答报文,显示为unknown · MAC:发送应答报文的设备的MAC地址 · Sequence:表示应答报文的序号 · time:表示响应时间 |
· l2vpn ping-ce source-mac
ping-ce ipv6命令用来检测PE到CE之间IPv6链路的连通性。
ping-ce ipv6 ipv6-address { vsi name | xconnect-group group-name connection connection-name } source-ip source-ip [ source-mac source-mac ] [ -c count | -m wait-time ] *
ipv6-address:指定需要检测的CE的IPv6地址,该IPv6地址作为NS报文的目标IPv6地址。
source-ip source-ip:指定NS报文的源IPv6地址。source-ip为源IPv6地址。
source-mac mac-address:指定NS报文的源MAC地址。mac-address为源MAC地址,格式为H-H-H,取值范围由l2vpn ping ce source-mac命令配置。如果未指定本参数,则从l2vpn ping ce source-mac命令配置的MAC地址范围中按从小到大顺序依次选择一个未被使用的MAC地址作为源MAC地址。
-c count:指定发送NS报文的次数。count为NS报文发送次数,取值范围为1~255,缺省值为5。
-m interval:指定连续发送NS报文的时间间隔。interval为发送NS报文的时间间隔,取值范围为1~10,单位为秒,缺省值为3。
执行本命令后,本端PE设备会向指定交叉连接或VSI内的所有AC和PW发送NS报文。如果本端PE收到CE应答的NA报文,则认为PE与CE之间的链路正常;若本端PE未在默认超时时间2秒内收到NA报文,则认为PE与CE之间的链路不通。
执行本命令时,需要注意:
· source-ip source-ip参数指定的源IPv6地址必须为当前设备接口下未配置的IPv6地址。
# 对交叉连接组aaa内交叉连接bbb下的、IPv6地址为100::1的CE发起链路连通性检测,其中发送端IPv6地址为100::2,发送端MAC地址为7A3A-2027-B770。
[Sysname] ping-ce ipv6 100::1 xconnect aaa connection bbb source-ip 100::2 source-mac 7A3A-2027-B770
Reply from Link ID 1: MAC=00e0-fc12-3456 Sequence=1 time=11 ms
Reply from GE1/0/6: MAC=00e0-fc12-3456 Sequence=1 time=11 ms
Reply from unknown: MAC=00e0-fc12-3456 Sequence=1 time=11 ms
表1-41 ping ce命令显示信息描述表
Requset time out |
应答报文超时 |
收到应答报文的信息: · 应答报文的来源,取值包括: ¡ 从远端设备接收到应答报文,显示远端设备的IP地址 ¡ 从本地站点接收到应答报文,显示为接口名称 ¡ 从AC Bypass收到应答报文,显示为Link ID ¡ 在EVPN VPLS/EVPN VPWS组网中,从PW接收应答报文,显示为unknown · MAC:发送应答报文的设备的MAC地址 · Sequence:应答报文的序号 · time:响应时间,单位为毫秒 |
policy vpn-target命令用来开启BGP EVPN路由的VPN-Target过滤功能。
undo policy vpn-target命令用来关闭BGP EVPN路由的VPN-Target过滤功能。
policy vpn-target
BGP EVPN路由的VPN-Target过滤功能处于开启状态。
BGP EVPN地址族视图
开启BGP EVPN路由的VPN-Target过滤功能后,设备只将Export Route Target属性与本地Import Route Target属性匹配的BGP EVPN路由加入到BGP EVPN路由表。设备上如需保存所有BGP EVPN路由,则需执行undo policy vpn-target命令,不对BGP EVPN路由进行VPN-Target过滤。
# 关闭BGP EVPN路由的VPN-Target过滤功能。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] undo policy vpn-target
pw-class命令用来指定引用的PW模板。
undo pw-class命令用来恢复缺省情况。
pw-class class-name
undo pw-class
未引用PW模板。
VSI实例下的EVPN实例视图
class-name:PW模板名,为1~19个字符的字符串,区分大小写。
仅采用MPLS封装方式的EVPN实例支持本命令。
在VSI实例下的EVPN实例视图下执行本命令指定引用PW模板后,该PW模板将应用于该视图下建立的所有PW。
在EVPN实例视图下执行本命令指定引用PW模板后,该PW模板将应用于与该EVPN实例关联的VSI下建立的所有PW。
多次执行本命令,则最后一次执行的命令生效。
# 在VSI实例下的EVPN实例视图下指定引用的PW模板为pw100。
[Sysname] vsi vpna
[Sysname-vsi-vpna-evpn-mpls] pw-class pw100
reset evpn route mac-mobility suppression命令用来取消对MAC地址迁移的抑制。
reset evpn route mac-mobility suppression [ evpn-instance instance-name | interface interface-type interface-number | vsi vsi-name ] [ mac mac-address ]
evpn-instance instance-name:取消对指定EVPN实例内MAC地址迁移的抑制。instance-name实例名称,为1~31个字符的字符串,区分大小写。
interface interface-type interface-number:取消对指定接口上MAC地址迁移的抑制。interface-type interface-number为接口类型和接口编号。
vsi vsi-name:取消对指定VSI内MAC地址迁移的抑制。vsi-name表示VSI实例的名称,为1~31个字符的字符串,区分大小写。
mac mac-address:取消对指定MAC地址的迁移抑制。mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果不指定本参数,则取消对所有MAC地址的迁移抑制。
执行reset evpn route mac-mobility suppression命令后,设备将取消对指定VSI内MAC地址迁移的抑制,对外通告该MAC地址。后续,仍然正常进行迁移抑制,直到关闭MAC地址反复迁移抑制功能。
执行本命令时,如果没有指定evpn-instance instance-name、interface interface-type interface-number和vsi vsi-name参数,则表示取消对所有ARP迁移的抑制。
# 取消对VSI实例vpna内MAC地址1-1-1的迁移抑制。
<Sysname> reset evpn route mac-mobility suppression vsi vpna mac 1-1-1
revertive wtr命令用来配置延时回切时间。
undo revertive命令用来恢复缺省情况。
revertive wtr wtr-time
undo revertive wtr
延迟回切时间为0,即不延迟回切。
VSI实例下的EVPN实例视图
交叉连接视图
wtr wtr-time:指定延迟回切时间。wtr-time取值范围为0~3600,单位为秒。
在EVPN VPLS多归属组网中,当主PE的接入侧链路或主PE设备故障恢复后,主PE上将会生成AD Per EVI路由,然后会通过BGP EVPN邻居关系将AD Per EVI路由发布给远端PE。远端PE在收到AD Per EVI路由并生成转发表项后,会将流量从发往备PE的路径切换到发往主PE的路径。此时主PE上可能会由于未完全生成转发表项而产生少量丢包。为了避免此情况的发生,用户可以在远端PE上通过配置本命令配置一个合适的延时切换时间。远端PE在收到EVI AD路由后将延迟生成转发表项,等待主PE上转发表项稳定。当延时超时后,远端PE上将生成新的转发表项,然后流量将被切换发往主PE,避免了丢包现象的发生。
在EVPN VPWS多归属组网中,当主PW或主PE设备故障恢复后,业务流量会切回到主PW上进行转发,此时主PE上可能会由于未完全生成转发表项而产生少量丢包。为了避免此情况的发生,用户可以在远端PE上通过配置本命令配置一个合适的延迟切换时间,等待主PE上转发表项稳定后,然后流量将被切换发往主PE,避免了丢包现象的发生。
在交叉连接视图下配置本命令时,需要与route-select delay命令配合使用。
# 在VSI实例EVPN视图下,配置延时回切时间为120秒。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-mpls] revertive wtr 120
route-distinguisher命令用来配置EVPN实例的RD(Route Distinguisher,路由标识符)。
undo route-distinguisher命令用来恢复缺省情况。
公网实例视图/交叉连接组EVPN实例视图:
VSI实例下的EVPN实例视图:
route-distinguisher { route-distinguisher | auto [ router-id ] }
未指定公网实例/EVPN实例的RD。
公网实例视图
交叉连接组EVPN实例视图
VSI实例下的EVPN实例视图
route-distinguisher:路由标识符,为3~21个字符的字符串(不允许为全0)。路由标识符有四种格式:
· 16位自治系统号:32位用户自定义数,例如:101:3。
· 32位IP地址:16位用户自定义数,例如:192.168.122.15:1。
· 32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1
· 32位点分形式的自治系统号:16位用户自定义数字。例如:10.1:1。
auto:表示自动生成RD。自动生成的RD取值为“N:VXLAN ID”,N为从1开始的整数;如果“N:VXLAN索引”已被使用,则RD取值改为“(N+1):VXLAN ID”,如此反复,直到找到未被使用的RD。
router-id:表示根据Router ID 自动生成RD,自动生成的RD取值为“Router ID:N”。如果不指定本参数,则表示根据VXLAN ID自动生成RD,自动生成的RD取值为“N:VXLAN ID”。其中,N为从1开始的整数;如果“Router ID:N”或“N:VXLAN”已被使用,则RD取值改为“Router ID:(N+1)”或“(N+1):VXLAN ID”,如此反复,直到找到未被使用的RD。
EVPN采用MP-BGP协议进行邻居自动发现、MAC地址通告、主机路由通告。本命令指定的RD,携带在MP-BGP协议发布的邻居、MAC地址、主机路由信息中,以标识不同EVPN实例的邻居、MAC地址、主机路由信息。
不能通过重复执行route-distinguisher命令修改RD值。如需修改RD值,请先通过undo route-distinguisher命令删除RD值,再执行route-distinguisher命令配置新的RD值。
# 配置VSI实例下的EVPN实例的RD为22:1。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] route-distinguisher 22:1
rr-filter命令用来配置路由反射器对反射的EVPN路由进行过滤。
undo rr-filter命令用来恢复缺省情况。
rr-filter { ext-comm-list-number | ext-comm-list-name }
undo rr-filter
路由反射器不会对反射的EVPN路由进行过滤。
BGP EVPN地址族视图
ext-comm-list-number:扩展团体属性列表号,取值范围为1~65535。
ext-comm-list-name:扩展团体属性列表名,为1~63个不全为数字的字符串,区分大小写。
执行本命令后,路由反射器将根据扩展团体属性列表对接收的EVPN路由进行过滤:只有接收的BGP EVPN路由通过扩展团体属性列表过滤时,路由反射器才会反射该EVPN路由。
当一个集群中存在多个路由反射器时,通过在不同的路由反射器上配置不同的反射策略,可以实现路由反射器之间的负载分担。
扩展团体属性列表的详细介绍,请参见“三层技术-IP路由配置指导”中的“路由策略”。
# 配置路由反射器只反射通过扩展团体属性列表10过滤的BGP EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] rr-filter 10
· ip extcommunity-list(三层技术-IP路由命令参考/路由策略)
snmp-agent trap enable evpn命令用来开启EVPN告警功能。
snmp-agent trap enable evpn [ mac-mobility-suppression ]
undo snmp-agent trap enable evpn [ mac-mobility-suppression ]
EVPN告警功能处于关闭状态。
mac-mobility-suppression:开启MAC迁移抑制告警。
开启EVPN告警功能后,当MAC地址迁移次数达到设置的阈值时会产生告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
执行本命令时,如果未指定任何参数,则表示开启或关闭EVPN的所有告警功能。
# 开启EVPN告警功能。
[Sysname] snmp-agent trap enable evpn
tracert evpn vpws命令用来查看EVPN VPWS组网中PW所经过的路径,并根据应答信息对错误点进行定位。
tracert evpn vpws xconnect-group group-name local-service-id remote-service-id [ end-op endop ] [ -a { source-ipv4 | source-ipv6 } | -exp exp-value | -h ttl-value | -r reply-mode | -t time-out | -tc tc ] * [ ddmap | full-lsp-path ] *
-a source-ipv4:指定发送的MPLS echo request报文的源地址。source-ipv4为源IPv4地址。如果未指定本参数,则MPLS echo request报文的源IPv4地址为该节点的MPLS LSR ID。本参数仅适用于EVPN VPWS组网。
-h ttl-value:指定MPLS echo request报文中TTL的最大值(即检测的最大跳数)。ttl-value为TTL最大值,取值范围为1~255,缺省值为255。
-tc tc:指定MPLS echo request报文的流量等级。tc为流量等级,取值范围为0~255。缺省值为0。本参数仅适用于EVPN VPWS over SRv6组网。
ddmap:为MPLS echo reply报文和MPLS echo request报文封装Downstream Detailed Mapping TLV。如果不指定本参数,则封装Downstream Mapping TLV。Downstream Detailed Mapping TLV和Downstream Mapping TLV用来携带LSP在当前节点的下游信息,主要包括下一跳地址、出标签等。进行MPLS Tracert操作时,设备需要检验以上TLV中的下一跳地址和出标签是否正确。如果两项检查均通过,则向头节点发送标识检测成功的MPLS Echo Reply报文;如果任意一项检查未通过,则向头节点发送携带错误码的MPLS Echo Reply报文。本参数仅适用于EVPN VPWS组网。
full-lsp-path:显示本端PE到远端PE之间完整的LSP路径。如果不配置该参数,则只显示PW尾节点回应的信息。本参数仅适用于EVPN VPWS组网。
EVPN VPWS组网和EVPN VPWS over SRv6组网中,本端PE设备与远端PE设备间通过PW传输数据报文。当PE间出现丢包或断流现象时,可通过本命令查看本端PE到远端PE的PW所经过的路径,并根据应答信息对错误点进行定位。
# 对交叉连接组xcga内本端service ID为100、远端service ID为200的PW发起tracert检测。
<Sysname> tracert evpn vpws xconnect-group xcga 100 200
Trace route to a remote PE through a PW with local service ID 100 and remote
service ID 200 in cross-connect group 4.
TTL Replier Time Type Downstream
0 Ingress 42.1.1.2/[3 1892]
1 Request time out
2 41.1.1.1 4 ms Egress
表1-42 tracert evpn vpws命令显示信息描述表
Trace route to a remote PE through a PW with local service ID 100 and remote service ID 200 in cross-connect group 4 |
查看交叉连接组xcga内本端service ID为100、远端service ID为200的PW所经过的路径 |
TTL |
跳数 |
Replier |
节点的IP地址 |
Time |
RTT(Roud-Trip Time,往返时间)值,单位为毫秒 |
Type |
路径经过的节点类型,取值包括: · Ingress:入节点 · Transit:中间节点 · Egress:出节点 |
Downstream |
下一跳IP地址与压入标签值 |
ReturnCode |
返回码,括号内为返回子码 |
Request time out |
若在等待响应的超时时间内没有收到MPLS Echo应答报文,则显示本字段 |
tracert evpn vsi命令用来查看EVPN VPLS组网或EVPN VPLS over SRv6中本端PE到指定主机连接的远端PE间PW所经过的路径,并根据应答信息对错误点进行定位。
tracert evpn vsi vsi-name mac mac-address [ end-op endop ] [ -a { source-ipv4 | source-ipv6 } | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -tc tc ] *
vsi vsi-name:检测指定VSI内PW的连通性。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
-h ttl-value:指定MPLS echo request报文中TTL的最大值,ttl-value为TTL值,取值范围为1~255,缺省值为255。
EVPN VPLS组网和EVPN VPLS over SRv6组网中,本端PE设备与远端PE设备间通过PW传输数据报文。当PE间出现丢包或断流现象时,可通过本命令查看本端PE到指定主机连接的远端PE间PW所经过的路径,并根据应答信息对错误点进行定位。
# 在EVPN VPLS组网中,查看本端PE到MAC地址为1-1-1的主机连接的远端PE之间PW所经过的路径,并根据应答信息对错误点进行定位。
<Sysname> tracert evpn vsi vpna mac 1-1-1
Trace route to a remote PE in VSI vpna by reaching remote-MAC 0001-0001-0001.
Press CTRL+C to break.
0 Ingress
1 11.1.1.2 1 ms Transit
2 12.1.1.1 1 ms Egress
表1-43 tracert evpn vsi命令显示信息描述表
Trace route to a remote PE in VSI vpna by reaching remote-MAC 0001-0001-0001 |
查看VSI vpna内从当前设备到MAC地址为0001-0001-0001的主机连接的远端PE间PW所经过的路径 |
按组合键Ctrl+C可以终止tracert操作 |
TTL |
跳数 |
Replier |
节点的IP地址 |
Time |
Type |
Request time out |
请求超时,若在等待响应的超时时间内没有收到应答报文,则显示本字段 |
tunnel-policy命令用来指定引用的隧道策略。
undo tunnel-policy命令用来恢复缺省情况。
undo tunnel-policy
未引用隧道策略。
VSI实例下的EVPN实例视图
tunnel-policy-name:隧道策略名称,为1~126个字符的字符串,区分大小写。
在VSI实例下的EVPN实例视图下执行本命令指定引用的隧道策略后,与该VSI关联的PW将引用该隧道策略,即根据指定的隧道策略选择承载PW的公网隧道。
如果未引用隧道策略或者引用的隧道策略尚未配置,则PW根据缺省选择策略来选择公网隧道。缺省选择策略为按照LSP隧道->CRLSP->SRLSP隧道的优先级顺序选择隧道,负载分担的隧道数目为1。
多次执行本命令,则仅最后一次执行的生效。
# 在VSI实例下的EVPN实例视图下指定引用的隧道策略为policy1。
[Sysname] vsi aa
[Sysname-vsi-aa] evpn encapsulation mpls
[Sysname-vsi-aa-evpn-mpls] tunnel-policy policy1
vpn-route cross multipath命令用来开启VPN引入等价路由功能。
undo vpn-route cross multipath命令用来关闭VPN引入等价路由功能。
VPN引入等价路由功能处于关闭状态,对于前缀和RD均相同的多条路由,只会将最优路由引入到BGP EVPN路由表中。
BGP EVPN地址族视图
开启VPN引入等价路由功能后,BGP将前缀和RD均相同的多条路由全部引入到BGP EVPN路由表中。
# 开启VPN引入等价路由功能。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] vpn-route cross multipath
vpn-target命令用来配置EVPN的Route Target属性。
undo vpn-target命令用来删除指定的Route Target属性。
VSI实例下的EVPN实例视图:
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { vpn-target&<1-8> | auto | all } [ both | export-extcommunity | import-extcommunity ]
VPN实例EVPN视图/公网实例视图/公网实例IPv4地址族视图/公网实例IPv6地址族视图/公网实例EVPN视图/交叉连接组EVPN实例视图:
未指定EVPN的Route Target属性。
VSI实例下的EVPN实例视图
VPN实例EVPN视图
公网实例视图
公网实例IPv4地址族视图
公网实例IPv6地址族视图
公网实例EVPN视图
交叉连接组EVPN实例视图
vpn-target&<1-8>:Route Target属性值,vpn-target为3~21个字符的字符串。&<1-8>表示前面的参数最多可以输入8次。Route Target有四种格式:
· 32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
auto:表示自动生成RT。自动生成的RT取值为“BGP AS:VXLAN ID”。
both:指定配置的Route Target值同时作为Import Target和Export Target。没有指定both、export-extcommunity和import-extcommunity中的任何一个参数时,缺省值为both。
export-extcommunity:指定配置的Route Target值为Export Target。
import-extcommunity:指定配置的Route Target值为Import Target。
all:所有Route Target值。
EVPN采用MP-BGP协议进行邻居自动发现、MAC地址通告、主机路由通告等。本地设备在通过MP-BGP的Update消息将BGP EVPN路由发送给远端设备时,将Update消息中携带的VPN target属性设置为Export target。远端设备接收到BGP EVPN路由后,将该路由中携带的Export Target属性与本地配置的Import Target进行比较,如果二者中存在相同的值,则接收该信息。
重复执行本命令,Route Target值为多次配置结果的集合。
# 配置EVPN的Import Target为10:1、100:1和1000:1。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] vpn-target 10:1 100:1 1000:1 import-extcommunity
