06-MAP-E命令
本章节下载: 06-MAP-E命令 (307.50 KB)
display map instance命令用来显示MAP实例的信息。
display map instance [ name instance-name ] [ verbose ]
name instance-name:显示指定MAP-E实例的信息,instance-name表示实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有MAP-E实例的信息。
verbose:显示MAP-E实例的详细信息。如果未指定本参数,则表示显示MAP-E实例的简要信息。
如果未指定任何参数,则显示所有MAP实例的简要信息。
通过执行本命令可查看MAP-E实例的配置信息以及从DHCPv6服务器获取的MAP-E规则信息。
# 显示MAP-E实例a的简要信息。
<Sysname> display map instance name a
Type: MAP-E
Instance-name: a
Mode: PD
Interface-name: GigabitEthernet0/0/1
Tunnel-name: N/A
Prefix: ::/0
MAP status: Invalid
# 显示所有MAP-E实例的简要信息。
Type: MAP-E
Instance-name: a
Mode: PD
Tunnel-name: N/A
Prefix: ::/0
MAP status: Invalid
Type: MAP-E
Instance-name: b
Mode: PD
Tunnel-name: N/A
Prefix: 2001:DB8:1:64BE:103::/80
MAP status: Valid
# 显示MAP-E实例a的详细信息。
<Sysname> display map instance name a verbose
Type: MAP-E
Instance-name: a
Mode: PD
Interface-name: N/A
Tunnel-name: N/A
Prefix: ::/0
MAP status: Invalid
MAP Rule Info:
BR Address: ::
Rule IPv4 Address: 0.0.0.0/0
Rule IPv6 Prefix Address: ::/0
EA-Bits Length: 0
flags: 0
Calculated Info:
IPv4 Start Address: 0.0.0.0
IPv4 End Address: 0.0.0.0
PSID: N/A
MAP IPv6 Address: ::
Other Info:
NAT last notified: N/A
Tunnel last notified: N/A
# 显示所有MAP-E实例的详细信息。
<Sysname> display map instance verbose
Type: MAP-E
Instance-name: a
Mode: PD
Interface-name: N/A
Tunnel-name: N/A
Prefix: ::/0
MAP status: Invalid
MAP Rule Info:
BR Address: ::
EA-Bits Length: 0
flags: 0
Calculated Info:
PSID: N/A
Other Info:
Type: MAP-E
Instance-name: b
Mode: PD
Tunnel-name: N/A
MAP status: Valid
MAP Rule Info:
BR Address: 2001:DB8:CAFE::1
Rule IPv4 Address: 192.0.0.0/24
Rule IPv6 Prefix Address: 2001:DB8:1:64BE::/64
EA-Bits Length: 16
flags: 128
Calculated Info:
IPv4 Start Address: 192.0.0.1
IPv4 End Address: 192.0.0.1
PSID:
PSID Offset: 2
PSID Len: 4
PSID: 3
MAP IPv6 Address: 2001:DB8:1:64BE:130:C000:1:3
Other Info:
Expired Time: Jan 10 07:45:14 2023
Type: MAP-E
Instance-name: c
Mode: PD
Tunnel-name: N/A
Prefix: ::/0
MAP status: Invalid
MAP Rule Info:
BR Address: ::
EA-Bits Length: 0
flags: 0
Calculated Info:
PSID: N/A
Other Info:
ERROR_INFO: PD prefix has been released.
表1-1 display map instance命令显示信息描述表
Type |
MAP实例类型,取值包括: · MAP-E · MAP-T(暂不支持) |
Instance-name |
MAP实例名称 |
Mode |
MAP-E实例获取MAP-E信息的方式,取值包括: · NDRA:NDRA方式 · PD:DHCPv6方式 |
Interface-name |
MAP-E实例绑定的物理接口名称 |
Tunnel-name |
MAP-E实例绑定的Tunnel接口名称 |
Prefix |
获取的IPv6前缀信息。未获取到前缀时,本字段显示为::/0 |
MAP status |
MAP实例状态,取值包括: · Invalid:不可用(未申请MAP信息或MAP实例解析异常) · Valid:可用 |
MAP Rule Info |
MAP规则信息: · BR Address:BR设备的IPv6地址。当MAP实例状态为Invalid时,本字段取值为:: · Rule IPv4 Address:MAP规则指定的IPv4地址。当MAP实例状态为Invalid时,本字段取值为0.0.0.0/0 · Rule IPv6 Prefix Address:MAP规则指定的IPv6地址前缀。当MAP实例状态为Invalid时,本字段取值为::/0 · EA-Bits Length:EA位的长度。当MAP实例状态为Invalid时,本字段取值为0 · flags:十进制格式的规则标识。转化为二进制时,最后一个bit位取值为1表示BMR规则;最后一个bit位取值为0表示FMR规则。当MAP实例状态为Invalid时,本字段取值为0 |
Calculated Info |
由MAP-E规则计算出的MAP-E信息: · IPv4 Start Address:IPv4前缀起始地址。当MAP实例状态为Invalid时,本字段取值为0.0.0.0 · IPv4 End Address:IPv4前缀结束地址。当MAP实例状态为Invalid时,本字段取值为0.0.0.0 · PSID:Port Set ID。当MAP实例状态为Invalid时,本字段取值为N/A ¡ PSID Offset:PSID的偏移位 ¡ PSID Len:PSID的长度 ¡ PSID:PSID的值 · MAP IPv6 Address:开启MAP功能的CE设备的接口IPv6地址。当MAP实例状态为Invalid时,本字段取值为:: |
Other Info |
其余MAP-E信息: · Expired Time:前缀过期时间 · NAT last notified:最后一次通知NAT模块CE设备的IPv4公网地址和端口号的时间 · Tunnel last notified:最后一次向Tunnel模块推送MAP-E信息的时间 · ERROR_INFO:MAP-E实例异常原因(例如前缀不可用、前缀被释放等)。未申请MAP-E信息或MAP-E实例解析正常时,不显示本字段 |
display nat map interface tunnel命令用来显示MAP-E隧道接口下MAP CE通过DHCPv6服务器通知给NAT模块的MAP-E信息获取到的公网资源。
display nat map interface tunnel [ number ]
number:表示Tunnel接口编号,取值为已创建的Tunnel接口的编号。如果未指定number参数,将显示所有已创建的MAP-E隧道接口下MAP CE通过DHCPv6服务器通知给NAT模块的MAP-E信息获取到的公网资源。
MAP CE的NAT模块接收到DHCPv6服务器通知的MAP-E信息后,自动生成名称为“MAP-E_tunnel_xx”的地址组,此类地址组被称为MAP地址组。NAT模块通过MAP地址组管理公网资源。
MAP地址组中包括公网IPv4地址和Port set,其中公网IPv4地址信息为MAP CE直接从MAP-E信息中获取到的;Port set为MAP CE根据MAP-E信息中的PSID的值、PSID的长度以及PSID偏移位计算而来。通过本命令能够查看公网IPv4地址和Port set的对应关系。
# 显示指定MAP-E隧道接口下MAP CE通过DHCPv6服务器通知给NAT模块的MAP-E信息获取到的公网资源。
<Sysname> display nat map interface tunnel 10
Address group name/ID: MAP-E_tunnel_10/80001
Resource information:
Start address End address Start port End port
1.1.1.1 1.1.1.1 2100 2200
2400 2500
2.1.1.0 2.1.1.255 1024 65535
3.1.1.1 3.1.1.1 1024 65535
# 显示所有已创建的MAP-E隧道接口下DHCPv6服务器通知给NAT模块的公网资源信息。
NAT MAP address group information:
Totally 2 NAT MAP address groups.
Address group name/ID: MAP-E_tunnel_1/80002
2400 2500
Address group name/ID: MAP-E_tunnel_2/2002
10.1.1.1 10.1.1.1 2100 2200
2400 2500
20.1.1.0 20.1.1.255 1024 65535
30.1.1.1 30.1.1.1 1024 65535
表1-2 display nat map interface tunnel命令显示信息描述表
NAT MAP address group information |
MAP地址组信息 |
Totally n NAT MAP address groups |
MAP地址组的数量 |
Address group name/ID |
MAP地址组的名称/编号 |
Resource information |
MAP地址组的资源信息 |
Start address |
起始IPv4地址 |
End address |
结束IPv4地址 |
Start port |
Port set中的起始端口号 |
End port |
Port set中的结束端口号 |
map-e instance命令用来在MAP-E类型的Tunnel接口上绑定MAP-E实例。
undo map-e instance命令用来恢复缺省情况。
map-e instance instance-name
undo map-e instance
MAP-E类型的Tunnel接口上未绑定MAP-E实例。
MAP-E类型的Tunnel接口视图
instance-name:MAP-E类型的Tunnel接口绑定的MAP-E实例名,为1~31个字符的字符串,区分大小写。
MAP-E类型的Tunnel接口绑定MAP-E实例后,DHCPv6模块会将MAP-E实例下的MAP-E规则信息推送给Tunnel模块和NAT模块:
对于发送的IPv4报文,Tunnel模块利用MAP-E规则计算出源IPv6地址,并将该源IPv6地址和BR设备的IPv6地址分别作为源和目的IPv6地址,对IPv4报文加封装IPv6报文头;对于接收的IPv6报文,Tunnel模块利用MAP-E信息校验源和目的IPv6地址是否合法,并解封装IPv6报文头。
NAT模块利用MAP-E信息将IPv4私网地址和端口号转换为IPv4公网地址和端口号。
MAP-E类型的Tunnel接口只能绑定已创建的MAP-E实例,且一旦绑定,不允许删除该实例。如果需要删除该MAP-E实例,则请先删除与其绑定的隧道接口。
一个MAP-E实例只能绑定一个Tunnel口,且一个Tunnel口下只能绑定一个MAP-E实例。
# 配置MAP-E类型的Tunnel接口1绑定MAP-E实例a。
[Sysname] interface tunnel 1 mode map-e
[Sysname-Tunnel1] map-e instance a
· display map instance
map-e instance dynamic命令用来创建从DHCPv6服务器动态获取MAP-E信息的MAP-E实例并进入MAP-E实例视图。
undo map-e instance命令用来删除MAP-E实例。
map-e instance instance-name dynamic
undo map-e instance instance-name
不存在MAP-E实例。
instance-name:MAP-E实例名称,为1~31个字符的字符串,区分大小写。
DHCPv6模块获得MAP-E信息后,需要将MAP-E信息推送给NAT和隧道模块,以便NAT和隧道模块利用MAP-E规则完成相关地址转换和报文封装工作。DHCPv6模块通过创建MAP-E实例并利用MAP-E实例作为中间转换桥梁,向NAT和隧道模块推送MAP-E信息:
(1) MAP-E实例与接收DHCPv6回应报文的物理接口绑定,成功承载DHCPv6回应报文中携带的MAP-E信息;
(2) MAP-E实例与MAP-E类型的隧道接口绑定,通过MAP-E类型的隧道接口将承载的MAP-E信息推送给NAT和隧道模块。
# 创建MAP-E实例ist1并进入该实例视图。
[Sysname] map-e instance ist1 dynamic
[Sysname-mape-ist1]
· map-e instance
· source interface
map-e spoofing-enable命令用来开启MAP-E隧道的报文防攻击校验功能。
undo map-e spoofing-enable命令用来关闭MAP-E隧道的报文防攻击校验功能。
MAP-E隧道的报文防攻击校验功能处于开启状态。
MAP-E隧道接口视图
CE设备的MAP-E模式隧道接口在收到对端发送的IPv6报文后,如果本功能处于开启状态,则首先需要校验报文合法性,然后对校验通过的报文进行解封装处理。
报文校验规则为:
· 报文外层的IPv6源地址如果是MAP BR设备的IPv6地址,则校验通过。
· 报文外层的IPv6源地址如果不是MAP BR设备的IPv6地址,那么MAP-E模块基于会报文内层的源IPv4地址通过BMR规则计算出一个IPv6地址,将该地址与报文外层的IPv6源地址进行匹配,如不匹配则丢弃报文,避免仿冒报文对设备的攻击。
在对端为第三方设备,且不支持MAP-E校验功能时,建议在本端隧道下关闭本功能。
# 在MAP-E模式的Tunnel接口下,关闭MAP-E隧道报文的防攻击校验功能。
[Sysname] interface tunnel 0 mode map-e
[Sysname-Tunnel0] undo map-e spoofing-enable
mode命令用来配置MAP-E实例获取MAP-E信息的方式。
undo mode命令用来恢复缺省情况。
mode { ndra | pd }
undo mode
通过DHCPv6方式获取MAP-E信息。
MAP-E实例视图
ndra:通过NDRA方式获取MAP-E信息。
pd:通过DHCPv6方式获取IPv6前缀的同时获取MAP-E信息。
配置MAP-E实例获取MAP-E信息的方式后,与MAP-E实例绑定的物理接口将通过该方式获取MAP-E信息。
CE设备作为DHCPv6客户端时,支持通过有状态和无状态两种方式获得MAP-E信息:
· 有状态方式(DHCPv6):DHCPv6客户端向DHCPv6服务器发送DHCPv6请求报文申请前缀和MAP-E信息。
· 无状态方式(NDRA):DHCPv6客户端根据邻居发现协议从ND RA报文中自动获取到前缀后,向DHCPv6服务器发送Information-request报文申请MAP-E信息。
# 为MAP-E实例ist1配置获取MAP-E信息的方式为NDRA。
[Sysname-mape-ist1] mode ndra
· map-e instance dynamic
nat map enable命令用来开启NAT的MAP(Mapping of Address and Port,地址端口映射)功能。
undo nat map enable命令用来关闭NAT的MAP功能。
nat map enable
undo nat map enable
NAT MAP功能处于关闭状态。
MAP-E隧道接口视图
地址端口映射(Mapping of Address and Port,MAP)是一种IPv4向IPv6的过渡技术,主要满足运营商在纯IPv6网络中承载用户IPv4业务的需求。MAP技术结合了无状态和双重翻译/封装技术,可以无状态地将IPv4报文映射为IPv6报文。根据对IPv4报文的封装方式不同,将MAP技术分为MAP-E(Mapping of Address and Port with Encapsulation,无状态的映射与双重封装)和MAP-T(Mapping of Address and Port using Translation,无状态的映射与双重翻译)两种,两者均为IPv4 over IPv6的IPv6过渡技术。
当前仅支持MAP-E。
MAP-E技术涉及的基本概念包括:
· MAP-E(Mapping of Address and Port with Encapsulation,无状态的映射与双重封装):MAP-E是一种用IPv6报文头封装IPv4报文的一种无状态过渡技术。
· MAP CE(Customer Edge,用户边缘设备),位于IPv4网络与IPv6网络之间。
· MAP BR(Border Relay,边界中继设备),位于IPv6网络与IPv4网络的边界。
· MAP规则(MAP Rule):IPv4前缀(即IPv4地址的网络号)、独享IPv4地址或共享IPv4地址与IPv6前缀或IPv6地址之间的映射规则。包括BMR规则(Basic Mapping Rule)、FMR规则(Forwarding Mapping Rule)。
¡ BMR规则:主要描述IPv6地址和“IPv4地址+端口”的映射关系。MAP CE使用BMR规则对用户的IPv4报文进行NAT44地址转换,并对转换后的报文进行IPv6封装。MAP BR使用BMR规则对IPv6报文进行解封装,并对回程流量进行IPv6封装,然后在MAP域中按照IPv6路由转发给MAP CE。
¡ FMR规则:用于在MAP域中实现MAP CE间的互访流量直接通信,即不需要通过MAP-BR中转。在MAP域中MAP CE在访问其他MAP CE时,源IPv6地址为MAP CE规则通过BMR规则生成的IPv6地址,目的IPv6地址为对端MAP CE的地址。FMR规则用于MAP CE生成对端MAP CE的IPv6地址,该地址作为目的IPv6地址。BMR规则也可以作为FMR。
· MAP域(MAP domain):使用相同MAP规则的CE和BR组成一个MAP域。
· Port set:端口组,每个端口组中包含一段连续的端口号。不同的端口组的端口号各自独立。不同的MAP CE拥有不同的端口组。
· Port Set ID:简称为PSID。PSID的长度k决定了共享率,共享率R=2^k,即传输层端口分为2^k份,一份包含一组连续的端口号。每份共享给一个MAP CE使用。
· Shared IPv4 address:在多个CE之间共享的IPv4地址。CE只能使用Port set中的端口与其他设备通信。Shared IPv4 address也称为端口受限的IPv4地址。
· End-user IPv6 prefix:通过DHCPv6为MAP CE分配的IPv6前缀。每个MAP CE的End-user IPv6 prefix是唯一的。
· MAP IPv6 address:开启MAP功能的CE的IPv6地址,用于BR或其他CE到达该CE。
· Rule IPv6 prefix:MAP规则指定的IPv6前缀和长度。
· Rule IPv4 prefix:MAP规则指定的IPv4前缀和长度,即IPv4地址的网络号和掩码长度。
· EA位(Embedded Address bits):用以指示分配给CE设备的IPv6前缀中IPv4后缀(即IPv4地址的主机号)与PSID的长度之和。
MAP-E的工作机制如下,本功能用于实现步骤(2),即在MAP CE上开启本功能后,MAP CE使用从DHCPv6服务器通知的MAP-E信息中获取到的公网资源进行“IPv4地址+端口号”转换。
(1) MAP CE设备作为DHCPv6客户端向DHCPv6服务器发送DHCPv6请求报文,向DHCPv6服务器申请End-user IPv6 prefix和MAP-E信息。其中,请求报文中携带Option 6(Option Request Option,选项请求选项)选项,用来向DHCPv6服务器请求包含MAP-E信息的Option 94。
DHCPv6服务器发送的响应报文中的Option 94通过如下子选项来下发MAP-E信息。Option 89和Option 93共同构成了BMR规则。
¡ Option 89,主要包含EA位长度、IPv4前缀、IPv4前缀长度、IPv6前缀、IPv6前缀长度等信息。
¡ Option 93,主要包含PSID的值、PSID的长度、PSID偏移位的数量等信息。
¡ Option 90,主要包含MAP BR的IPv6地址(BR IPv6 address)信息。
(2) MAP CE设备的NAT模块使用从MAP-E信息中获取的公网资源对私网IPv4报文的源IPv4地址和源端口号进行转换。
公网资源包括公网IPv4地址和端口信息,MAP CE设备能够从MAP-E信息中直接获取到公网IPv4地址信息。同时,MAP CE设备根据PSID的值、PSID的长度以及PSID偏移位计算出Post set。
(3) MAP CE设备根据BMR规则计算出公网IPv4地址和端口号对应的IPv6地址。
(4) 后续,MAP CE设备的隧道模块为原始IPv4报文封装IPv6报文头,其中源IPv6地址、目的IPv6地址分别为步骤(3)中的IPv6地址,目的IPv6地址为BR IPv6地址。然后,MAP CE设备将封装后的报文通过IPv6网络发送给MAP BR设备。
(5) MAP BR设备收到该报文后对IPv6源地址和源端口做校验,校验通过后将IPv6报文头去掉得到原始IPv4报文,然后查找路由转发IPv4报文。
如果IPv6报文未通过校验,则MAP BR设备丢弃该IPv6报文。
MAP CE收到私网IPv4报文后,会对该报文的源IPv4地址和源端口号进行转换,然后由MAP CE的隧道模块为转换后的IPv4报文封装IPv6头。为了提高公网IPv4地址的利用率,MAP借用传输层端口来扩展IPv4地址,实现MAP CE上的一个公网IPv4地址可以被多个私网用户使用的目的。
MAP将16位的传输层端口号划分为三部分:A、Port Set ID和M。
A:PSID offset,即PSID偏移位的数量,默认为6。这是为了避免和知名端口区间0~1023中的端口号冲突。
Port Set ID:简称为PSID。PSID的长度k决定了共享率,共享率R=2^k,即传输层端口分为2^k份,一份包含一组连续的端口号。一个MAP CE独占一份Port Set。
M:M域的长度m决定了Port set中连续端口的数量,连续端口的数量=2^m。
通过上述机制可以划分为2^k个Port set,每个Port set由唯一的PSID值标识,每个PSID值对应的Port set中包含((2^a)-1)*(2^m)个端口号。
图1-1 MAP中的传输层端口号结构
例如,PSID offset为4,PSID长度为10,则M域的长度为2。那么传输层端口分成了2^10份Port set,即1024份Port set;每份Port set中包含((2^4)-1)*(2^2)个端口号,即60个端口号。表1-3为PSID值和Port set的对应关系。由于Port set中的端口号是不连续的,所以表格中的Port set是分段的。
表1-3 PSID值和Port set的对应关系表
PSID的值 |
Port set中的第1个连续段(A=0001) |
Port set中的第2个连续段(A=0010) |
Port set中的第15个连续段(A=1111) |
0 |
4096,4097,4098,4099 |
8192,8193,8194,8195 |
61440,61441,61442,61443 |
1 |
4100,4101,4102,4103 |
8196,8197,8198,8199 |
61444,61445,61446,61447 |
2 |
4104,4105,4106,4107 |
8200,8201,8202,8203 |
61448,61449,61450,61451 |
3 |
4108,4109,4110,4111 |
8204,8205,8206,8207 |
61452,61453,61454,61455 |
1023 |
8188,8189,8190,8191 |
12284,12285,12286,12287 |
65532,65533,65534,65535 |
MAP CE将原始IPv4报文转换后的IPv4地址按照图1-2所示的映射规则映射为一个IPv6地址,该地址包括Rule IPv6 prefix、EA、Subnet ID和Interface ID四个字段。映射规则将IPv4的地址和端口信息与IPv6地址建立了强关联,形成无状态的映射,即MAP BR设备不需要维护IPv6地址和IPv4地址之间的映射关系。
· Rule IPv6 prefix字段为DHCPv6服务器为MAP CE下发的IPv6前缀。
· Subnet ID字段在MAP-E中被定义为第一个子网,s位置为0。
· EA字段由IPv4地址的后缀(即IPv4地址的主机号)和传输层端口的PSID的值组合形成。
· Interface ID字段由IPv4 address和PSID的值组合而成,具体机制如下:
¡ 对于IPv4 address字段,如果DHCPv6服务器为MAP CE分配了一个Shared IPv4 address或独享的IPv4 address,则IPv4 address字段填充分配的32位长度的IPv4地址。如果DHCPv6服务器为MAP CE分配了Rule IPv4 prefix,则IPv4 address字段向右填充0补齐32位。例如,Rule IPv4 prefix为2.1.1.0/29,则此处IPv4 address字段填充为“0x02010100”(十六进制)。
¡ 对于PSID字段,如果从EA位提取的PSID值不足16位时,则向左填充0补齐16位。例如,从EA位提取的PSID值为0xAC,则Interface ID中的PSID填充为“0x00AC”。如果DHCPv6服务器分配了Rule IPv4 prefix或者独享的IPv4 address时,则没有PSID值可以提取,Interface ID中的PSID填充为“0x0000”。
图1-2 IPv4与IPv6地址的映射
# 创建MAP-E模式的隧道接口Tunnel1,并在该接口下开启NAT MAP功能。
[Sysname-Tunnel1] nat map enable
source interface命令用来为MAP-E实例绑定物理接口。
undo source interface命令用来恢复缺省情况。
source interface interface-type interface-number
MAP-E实例未绑定物理接口。
MAP-E实例视图
interface-type interface-number:接口类型及接口编号。
MAP-E实例绑定的物理接口接收到DHCPv6服务器回复的应答报文后,设备会将该应答报文中包含的MAP-E规则信息与该物理接口绑定的MAP-E实例关联。
一个MAP-E实例只能绑定一个物理接口,且一个物理接口只能绑定一个MAP-E实例。
# 为MAP-E实例ist1绑定物理接口GigabitEthernet 1/0/1。
[Sysname-mape-ist1] source interface gigabitethernet 1/0/1
