23-Segment Routing命令参考
04-SRv6 VPN命令
本章节下载 04-SRv6 VPN命令  (593.02 KB)
04-SRv6 VPN命令
  录
1 SRv6 VPN
1.1 SRv6 VPN配置命令
1.1.1 advertise route-reoriginate
1.1.2 backup-peer
1.1.3 default color
1.1.4 display l2vpn forwarding srv6
1.1.5 display l2vpn peer srv6
1.1.6 display l2vpn statistics srv6-pw inbound
1.1.7 display l2vpn vsi
1.1.8 display l2vpn xconnect-group
1.1.9 encapsulation source-address
1.1.10 evpn encapsulation srv6
1.1.11 evpn next-header-field
1.1.12 export route-policy
1.1.13 import route-policy
1.1.14 nexthop interface (BGP-VPN IPv4 SR nexthop view/BGP-VPN IPv4 EVPN SR nexthop view)
1.1.15 nexthop interface (BGP SRv6 nexthop view/BGP-VPN SRv6 nexthop view/BGP-VPN IPv6 EVPN SR nexthop view)
1.1.16 peer
1.1.17 peer advertise encap-type srv6
1.1.18 peer advertise original-route
1.1.19 peer prefix-sid
1.1.20 peer re-originated
1.1.21 peer srv6-vpn compatible
1.1.22 peer suppress re-originated
1.1.23 ping evpn vpls srv6
1.1.24 ping evpn vpws srv6
1.1.25 reset l2vpn statistics srv6-pw
1.1.26 segment-routing ipv6
1.1.27 segment-routing ipv6 apply-sid all-nexthop (BGP IPv4/BGP IPv6 address family view)
1.1.28 segment-routing ipv6 apply-sid all-nexthop (BGP-VPN IPv4/IPv6 address family view)
1.1.29 segment-routing ipv6 apply-sid specify-nexthop (BGP IPv6 address family view)
1.1.30 segment-routing ipv6 apply-sid specify-nexthop (BGP-VPN IPv4/IPv6 address family view)
1.1.31 segment-routing ipv6 best-effort
1.1.32 segment-routing ipv6 locator
1.1.33 segment-routing ipv6 locator (cross-connect view,EVPN instance view and VSI EVPN instance view)
1.1.34 segment-routing ipv6 traffic-engineering
1.1.35 srv6-mpls-interworking enable
1.1.36 static-srv6 local-service-id remote-service-id
1.1.37 statistics enable
1.1.38 tracert evpn vpls srv6
1.1.39 tracert evpn vpws srv6
1.1.40 unicast-forwarding dx2-based
1 SRv6 VPN
1.1  SRv6 VPN配置命令
advertise route-reoriginate命令用来配置在VPN实例下将最优路由重生成并向VPNv4或VPNv6对等体发布。
undo advertise route-reoriginate命令用来恢复缺省情况。
在VPN实例下未将最优路由重生成后向VPNv4或VPNv6对等体发布,而是发布源VPNv4/VPNv6路由。
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
HoVPN场景中,不同UPE设备通过MPE和SPE设备实现流量互通。当UPE设备数量较多时,SPE设备会从MPE设备接收到大量的、携带标签的UPE设备路由。如果SPE路由表项资源较小,则某些UPE路由会被SPE设备丢弃,导致发送给这些UPE的流量转发失败。
为解决上述问题,可以在MPE设备上配置本命令进行路由重生成。当MPE设备接收到VPNv4/VPNv6路由后,如果路由中的RT属性与本地VPN实例的Import Route Target属性匹配,则在本地VPN实例下将最优路由重新生成后向VPNv4/VPNv6对等体发布。这样可以减少向SPE发布路由的数量。
配置本命令后,重生成路由携带VPN实例下配置的RD,并在源路由基础上添加VPN实例下的RT。
# 在BGP-VPN IPv4单播地址族视图下,配置在VPN实例1下将最优路由重生成并向VPNv4对等体发布。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] advertise route-reoriginate
1.1.2  backup-peer
backup-peer命令用来配置交叉连接的静态备份SRv6 PW,并进入交叉连接静态备份SRv6 PW视图。如果指定的静态备份SRv6 PW已经存在,则直接进入交叉连接静态备份SRv6 PW视图。
undo backup-peer命令用来删除指定的静态备份SRv6 PW。
backup-peer ipv6-address end-dx2-sid remote-locator locator-name opcode opcode [ color color-value | tunnel-policy tunnel-policy-name ] *
undo backup-peer ipv6-address end-dx2-sid remote-locator locator-name opcode opcode
不存在交叉连接的静态备份SRv6 PW。
交叉连接静态SRv6 PW视图
ipv6-address:静态备份SRv6 PW的远端PE地址。
remote-locator locator-name:指定本地配置的远端Locator段名称。locator-name表示Locator段名称,为1~31个字符的字符串,区分大小写。
opcode opcode指定SRv6 SID操作码。opcode为SRv6 SID操作码,取值范围为1~2static-length-1,其中static-lengthremote-locator命令影响。
color color-value:指定静态备份SRv6 PW的Color属性。color-value为Color值,取值范围为0~4294967295。如果未指定本参数,则表示未指定静态备份SRv6 PW的Color属性。
tunnel-policy tunnel-policy-name:指定静态备份SRv6 PW引用的隧道策略。tunnel-policy-name表示隧道策略名,为1~126个字符的字符串,区分大小写。如果未指定本参数,则使用static-srv6 local-service-id remote-service-id命令引用的隧道策略。
静态备份SRv6 PW作为主SRv6 PW的备份,可以为主SRv6 PW提供冗余保护。当主SRv6 PW出现故障时,设备将通过主SRv6 PW对应的静态备份SRv6 PW转发流量。
配置静态备份SRv6 PW时指定的远端PE的IPv6地址和远端SID,不能与已经存在的静态或者动态SRv6 PW同时相同。
SRv6 PW冗余保护功能与Bypass SRv6 PW功能互斥。即,如果主SRv6 PW已经通过backup-peer命令配置了一条静态备份SRv6 PW,则在交叉连接的AC视图下不能执行bypass-peer命令配置静态Bypass SRv6 PW;反之亦然。
# 配置静态备份SRv6 PW,指定远端PE的IPv6地址为4::4、本地配置的远端的Locator段名称为aaa、Opcode为1,并进入交叉连接静态备份SRv6 PW视图。
[Sysname] xconnect-group svpws0
[Sysname-xcg-svpws0] connection 1
[Sysname-xcg-svpws0-1] static-srv6 local-service-id 1 remote-service-id 2 tunnel-policy 1
[Sysname-xcg-svpws0-1-1-2] peer 1::1 end-dx2-sid remote-locator aaa opcode 1
[Sysname-xcg-svpws0-1-1-2-1::1-aaa-1] backup-peer 3::3 end-dx2-sid remote-locator bbb opcode 2
[Sysname-xcg-svpws0-1-1-2-1::1-aaa-1-3::3-bbb-2]
·     peer
1.1.3  default color
default color命令用来配置EVPN路由的缺省Color值。
undo default color命令用来恢复缺省情况。
default color color-value
undo default color
未配置EVPN路由的缺省Color值。
EVPN实例视图
交叉连接静态SRv6视图
color-value:缺省Color值,取值范围为0~4294967295。
如果EVPN路由不携带Color扩展团体属性,且未通过路由策略方式配置该路由的Color属性,则该路由使用配置的缺省Color值,以便基于该Color值进行引流。
# 在VSI实例下的EVPN实例视图下,配置EVPN路由的缺省Color值为100。
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation srv6
[Sysname-vsi-aaa-mpls-srv6] default color 100
# 在交叉连接组EVPN实例视图下,配置EVPN路由的缺省Color值为100。
[Sysname] xconnect-group vpna
[Sysname-xcg-vpna] evpn encapsulation srv6
[Sysname-xcg-vpna-evpn-mpls] default color 100
display l2vpn forwarding srv6命令用来显示L2VPN的SRv6转发信息。
display l2vpn forwarding srv6 [ vsi vsi-name | xconnect-group group-name ] [ verbose ]
vsi vsi-name:显示指定VSI的SRv6转发信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
xconnect-group group-name:显示指定交叉连接组的SRv6转发信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,不能包含字符“-”,区分大小写。
verbose:显示SRv6转发的详细信息。如果不指定本参数,则显示SRv6转发的简要信息。
执行本命令时,如果没有指定vsi vsi-namexconnect-group group-name参数,则显示所有VSI和所有交叉连接组内的SRv6转发信息。
# 显示L2VPN SRv6转发的简要信息。
<Sysname> display l2vpn forwarding srv6
Total number of cross-connections: 1
Total number of VSIs: 1
Total number of SRv6 tunnels: 2, 2 up, 0 blocked, 0 down
VSI Name : vpnb
Link ID  : 0x9000000   Type: BE     State: Up
In SID   : 100::2
Out SID  : 200::3
Xconnect-group Name : vpna
Connection Name     : pw1
Link ID             : 0x1         Type: BE    State: Up
In SID              : 100::1
Out SID             : 200::1
表1-1 display l2vpn forwarding srv6命令显示信息描述表
交叉连接总数
VSI总数
Total number of SRv6 Tunnels
SRv6隧道的总数,及处于up、blocked、down状态的SRv6隧道数目
VSI Name
VSI名称
Xconnect-group Name
交叉连接组名称
Connection Name
交叉连接名称
Link ID
SRv6隧道在VSI或交叉连接组内的链路ID
路由迭代方式,取值包括:
·     BE:表示SRv6 BE方式,即根据封装的End.DX2 SID、End.DT2M SID或End.DT2U SID查找IPv6路由表进行转发
·     TE:表示SRv6 TE方式,即根据路由的下一跳地址从隧道策略中查找匹配的SRv6 TE Policy,为报文添加携带End.DX2 SID(或End.DT2M SID、End.DT2U SID)和SRv6 TE Policy SID列表的SRH头后,通过SRv6 TE Policy转发该报文
·     BE/TE:表示SRv6-TE和SRv6-BE混合方式,即优先通过SRv6-TE方式选择转发路径;如果SRv6-TE方式未找到可用的SRv6 TE Policy,则通过SRv6-BE方式选择转发路径
SRv6隧道的状态信息,取值包括:
·     Up:表示该SRv6隧道可用
·     Down:表示该SRv6隧道不可用
·     Blocked:表示存在主备SRv6隧道的情况下,该SRv6隧道当前未转发流量,起到备份作用
In SID
入SID,即本地分配的SID
Out SID
出SID,即远端分配的SID
# 显示L2VPN SRv6转发的详细信息。
<Sysname> display l2vpn forwarding srv6 verbose
VSI Name: vpnb
  Link ID                : 0x9000000
  SRv6 Tunnel State      : Up
  In  SID                : 200::3
  Out SID                : 100::2
  MTU                    : 1500
  SRv6 Tunnel Attributes : Main
  SRv6 Forwarding IDs    : -
  Remote Leaf Argument   : -
Xconnect-group Name: vpna
 Connection Name: pw1
  Link ID                : 0x1
  In  SID                : 200::1
  Out SID                : 100::1
  MTU                    : 1500
表1-2 display l2vpn forwarding srv6 verbose命令显示信息描述表
VSI Name
VSI名称
Xconnect-group Name
交叉连接组名称
Connection Name
交叉连接名称
Link ID
SRv6 Tunnel State
SRv6隧道的状态信息,取值为:
·     Up:表示该SRv6隧道可用
·     Down:表示该SRv6隧道不可用
In SID
入SID,即本地分配的SID
Out SID
出SID,即远端分配的SID
MTU
最大传输单元,单位为字节
SRv6隧道属性标记,取值包括:
·     Main:主隧道
·     Backup:备份隧道
·     ac-Bypass:AC侧Bypass 隧道
·     ECMP:等价隧道
SRv6 Forwarding IDs
通过SRv6 TE Policy隧道转发业务流量时,SRv6 TE Policy中包含的各条候选路径的转发表项索引列表
未通过SRv6 TE Policy隧道转发业务流量时,显示为“-”
远端PE标识Leaf AC的Argument值,当无Argument时显示为“-”
display l2vpn peer srv6命令用来显示L2VPN的SRv6相关信息。
display l2vpn peer srv6 [ vsi vsi-name | xconnect-group group-name ] [ state-machine | verbose ]
vsi vsi-name:显示指定VSI内L2VPN的SRv6信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
xconnect-group group-name:显示指定交叉连接组内L2VPN的SRv6信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。
state-machine:显示L2VPN的SRv6状态机信息。
verbose:显示详细信息。
执行本命令时,如果没有指定vsi vsi-namexconnect-group group-name参数,则显示所有VSI和所有交叉连接组内L2VPN的SRv6信息;如果没有指定state-machineverbose参数,则显示L2VPN的SRv6简要信息。
# 显示L2VPN SRv6的简要信息。
<Sysname> display l2vpn peer srv6
Total number of SRv6 Tunnels: 2
VSI Name: vpnb
   Peer            : 2::2
   Flag            : Main
   State           : Up
   Peer            : 2::2
   Flag            : Main
   State           : Up
   Remote SrvID    : 2
# 显示L2VPN SRv6的详细信息。
<Sysname> display l2vpn peer srv6 verbose
VSI Name: vpnb
  Peer: 2::2
   Signaling Protocol            : EVPN
   Link ID                       : 0x9000000
   In SID                        : 100::2
   Out SID                       : 200::3
   MTU                           : 1500
   Tunnel Group ID               : 0x1000000030000000
   SRv6 Forwarding IDs           : 0
   Color                         : -
   Recursion Mode                : SID based
   Output Statistics             :
     Octets             : 0
     Packets            : 0
     Errors             : 0
     Discards           : 0
   Output Rate                   :
     Bytes per second   : 0
     Packets per second : 0
  Peer: 2::2
   Remote Service ID             : 2
   Link ID                       : 0x1
   In SID                        : 100::1
   Out SID                       : 200::1
   MTU                           : 1500
   Color                         : -
   Input Statistics              :
     Octets             : 0
     Packets            : 0
     Errors             : 0
     Discards           : 0
   Output Statistics             :
     Octets             : 0
     Packets            : 0
     Errors             : 0
     Discards           : 0
   Input Rate                    :
   Output Rate                   :
表1-3 display l2vpn peer srv6命令显示信息描述表
VSI Name
VSI名称
Xconnect-group Name
交叉连接组名称
Connection Name
交叉连接名称
Peer
远端PE的IPv6地址
Flag
SRv6隧道的属性标记,取值包括:
·     Main:主SRv6隧道
·     Backup:备份SRv6隧道
·     Bypass:Bypass SRv6隧道
·     ECMP:等价SRv6隧道
State/SRv6 Tunnel State
SRv6隧道的状态,取值包括:
·     Up:表示该SRv6隧道可用
·     Down:表示该SRv6隧道不可用
Remote SrvID/Remote Service ID
远端Service ID
Signaling Protocol
建立SRv6隧道使用的信令协议,取值包括:
·     EVPN:表示通过EVPN协议建立SRv6隧道
·     Static SRv6:表示通过静态方式建立SRv6隧道
Link ID
In SID
入SID,即本地分配的SID
Out SID
出SID,即远端分配的SID
MTU
最大传输单元,单位为字节
SRv6隧道属性标记,取值包括:
·     Main:主SRv6隧道
·     Backup:备份SRv6隧道
·     ac-Bypass:AC侧的Bypass SRv6隧道
·     ECMP:等价SRv6隧道
Tunnel Group ID
承载SRv6隧道的公网隧道组ID
SRv6 Forwarding IDs
Color
期望迭代到的SRv6 TE Policy的Color属性,取值为“-”时,表示无Color属性
Recursion Mode
SRv6隧道的路由迭代方式,取值包括:
·     SID based:根据SID迭代,即采用SRv6 BE路由迭代方式
·     Nexthop based:根据下一跳迭代,即采用SRv6 TE路由迭代方式
·     Nexthop based/SID based:SID和下一跳混合迭代,即采用SRv6 TE和SRv6 BE混合路由迭代方式
Down Reason
SRv6隧道状态为down的原因,取值包括:
·     MTU not match:SRv6隧道两端MTU不一致
·     Local AC Down:本地AC状态为down
·     Local VSI admin Down:本地VSI管理状态为down
·     EVPN VPWS AD per EVI route received from peer:EVPN VPWS over SRv6组网中,本端未收到对端发送的A-D per EVI路由
·     EVPN VPWS AD per ES route not received from peer:EVPN VPWS over SRv6组网中,本端未收到对端发送的A-D per ES路由
·     SRv6 not configured with best effort or traffic engineering:SRv6隧道未配置迭代模式
·     Tunnel Down:BE迭代方式时表示路由不可达;TE迭代方式时表示未配置SRv6-TE policy
·     BFD session for SRv6 PW down:BFD检测到SRv6隧道的状态为down
·     Unknown:未知的原因
Input Statistics
入方向的SRv6 PW流量统计信息,包括入方向接收的字节数(Octets)、接收的报文数(Packets)、接收的错误报文数(Errors)和丢弃的报文数(Discards)
Output statistics
出方向的SRv6 PW流量统计信息,包括出方向发送的字节数(Octets)、发送的报文数(Packets)、发送的错误报文数(Errors)和丢弃的报文数(Discards)
EVPN VPLS over SRv6组网中,不会显示SRv6 PW入方向流量统计信息,仅显示SRv6 PW出方向流量统计信息
Input Rate
入方向的SRv6 PW流量速率统计信息,包括入方向发送的每秒字节数(Bytes per second)、每秒报文数(Packets per second)
Output Rate
出方向的SRv6 PW流量速率统计信息,包括出方向发送的每秒字节数(Bytes per second)、每秒报文数(Packets per second)
EVPN VPLS over SRv6组网中,不会显示SRv6 PW入方向流量速率统计信息,仅显示SRv6 PW出方向流量速率统计信息
# 显示L2VPN SRv6的状态机信息。
<Sysname> display l2vpn peer srv6 state-machine
SRv6 tunnel group state:
  Idle: Idle    N: Normal    UA: Unavailable    PF: Protecting failure
  P: Protection tunnel failure    W: Working tunnel failure    L: Local
VSI Name: vpnb
  SRv6 Group Link ID            : 0x9000000
    Main SRv6 Tunnel:
      Peer                      : 2::2
    Backup SRv6 Tunnel          : -
    Main SRv6 Defect State      : No defect
    Backup SRv6 Defect State    : -
    Switch Result               : Working
    Switch Reason               : None
    Remote Event                : -
    Local Event                 : SFCW
    SRv6 Group Old State        : Idle
    SRv6 Group State            : UA:P:L
  SRv6 Group Link ID            : 0x1
    Main SRv6 Tunnel:
      Peer                      : 2::2
      Service ID                : 2
    Remote Event                : -
    Local Event                 : SFCW
表1-4 display l2vpn peer srv6  state-machine命令显示信息描述表
VSI Name
VSI名称
Xconnect-group Name
交叉连接组名称
Connection Name
交叉连接名称
SRv6 Group Link ID
SRv6组的链路标识符
Main SRv6 Tunnel
主SRv6隧道
Peer
SRv6隧道远端PE的IPv6地址
Service ID
远端PE的Service ID
Backup SRv6 Tunnel
备份SRV6隧道
Signaling Protocol
建立SRv6隧道使用的信令协议,取值为EVPN
主SRv6隧道的缺陷状态,取值包括:
·     No defect:表示没有缺陷
·     Signal defect:表示通过信令协议检测出缺陷
备份SRv6隧道的缺陷状态,取值包括:
·     No defect:表示没有缺陷
取值为“-”表示不存在备份SRv6隧道
Switch Result
SRv6隧道主备切换结果,取值包括:
·     None:主、备SRv6隧道均未使用
·     Working:当前使用主SRv6隧道
·     Backup:当前使用备SRv6隧道
Switch Reason
SRv6隧道主备切换的原因:
·     Config changed:在冗余保护组中添加或删除SRv6隧道
·     Fault dectected:通过信令协议等检测到SRv6隧道故障
·     SRv6 down:SRv6隧道状态由active变为down
·     SRv6 up:SRv6隧道状态由active恢复为up
·     None:没有发生切换
Remote Event
远端状态机事件,暂不支持
Local Event
本地状态机收到的事件,取值包括:
·     SFW:本地主SRv6隧道缺陷
·     SFP:本地备SRv6隧道缺陷
·     SFCW:本地主SRv6隧道up消息
·     SFCP:本地备SRv6隧道up消息
·     None:未收到本地事件
SRv6隧道组切换前的状态,取值包括:
·     Idle:主备SRv6隧道均不可用
·     Normal:主备SRv6隧道均可用,当前主SRv6隧道为up,备SRv6隧道为block,使用主SRv6隧道转发流量
·     UA:P:L:备SRv6隧道存在本地缺陷,主SRv6隧道up
·     PF:W:L:主SRv6隧道存在本地缺陷,备SRv6隧道up
SRv6 Group State
SRv6组切换后的状态,取值同上
display l2vpn statistics srv6-pw inbound命令用来显示EVPN VPLS over SRv6组网中SRv6 PW入方向的报文统计信息。
display l2vpn statistics srv6-pw inbound [ vsi vsi-name ]
vsi vsi-name:显示指定VSI内所有SRv6 PW入方向报文统计信息。vsi-name表示VSI实例的名称,为1~31个字符的字符串,区分大小写。如果不指定该参数,则显示所有VSI内所有SRv6 PW的入方向报文统计信息。
本命令仅用于查看VSI内所有SRv6 PW入方向报文统计信息的总和,出方向报文统计信息可通过display l2vpn peer srv6 verbose命令查看。
# 显示VSI实例aaa下所有SRv6 PW的入方向报文统计信息。
<Sysname> display l2vpn statistics srv6-pw inbound vsi aaa
VSI name: aaa
  Input statistics:
    Octets             : 0
    Packets            : 0
    Errors             : 0
    Discards           : 0
  Input rate      :
表1-5 display l2vpn statistics srv6-pw inbound命令显示信息描述表
VSI name
VSI名称
Input statistics
所有SRv6 PW入方向报文统计信息的总和,包括入方向接收的字节数(Octets)、接收的报文数(Packets)、接收的错误报文数(Errors)和丢弃的报文数(Discards)
Input rate
所有SRv6 PW入方向流量的速率,包括每秒字节数(Bytes per second)和每秒报文(Packets per second)
·     reset l2vpn statistics srv6-pw
·     statistics enable
display l2vpn vsi命令用来显示VSI的信息。
display l2vpn vsi [ evpn-srv6 | name vsi-name ] [ count | verbose ]
evpn-srv6:显示EVPN VPLS over SRv6组网中VSI的信息。如果不指定本参数,则显示所有VSI的信息。
name vsi-name:显示指定VSI的信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的信息。
count:显示VSI的统计信息。
verbose:显示VSI的详细信息。如果不指定本参数,则显示VSI的简要信息。
# 显示EVPN VPLS over SRv6组网中所有VSI的简要信息。
<Sysname> display l2vpn vsi evpn-srv6
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpnb                            0               1500   Up
# 显示EVPN VPLS over SRv6组网中VSI的统计信息。
<Sysname> display l2vpn vsi evpn-srv6 count
表1-6 display l2vpn vsi命令显示信息描述表
VSI的总数,及处于up、down和admin down状态的VSI数目
VSI Name
VSI名称
VSI Index
VSI索引
MTU
VSI上配置的最大传输单元
VSI的状态,取值包括:
·     Up:up状态
·     Down:down状态
·     Admin down:通过shutdown命令手工关闭的VSI
# 显示EVPN VPLS over SRv6组网中所有VSI的详细信息。
<Sysname> display l2vpn vsi evpn-srv6 verbose
VSI Name: vpnb
  VSI Index               : 0
  VSI Description         : vsi for vpnb
  VSI State               : Up
  Diffserv Mode           : -
  Bandwidth               : -
  Broadcast Restrain      : 5120 kbps
  Multicast Restrain      : 5120 kbps
  Unknown Unicast Restrain: 5120 kbps
  MAC Learning            : Enabled
  MAC Table Limit         : -
  MAC Learning rate       : Unlimited
  Local MAC aging time    : 300 sec
  Remote MAC aging time   : 300 sec
  Drop Unknown            : Disabled
  PW Redundancy Mode      : Slave
  Flooding                : Enabled
  Statistics              : Disabled
  VXLAN ID                : -
  EVPN Encapsulation      : SRv6
  SRv6 SIDs:
    Dt2U SID  : 222::1(64/64/0)
    Dt2UL SID : 222::2(64/64/0)
    Dt2M SID  : 222::3(64/64/0)
  SRv6 tunnels:
   Peer        : 2::2
   Link ID     : 0x9000000
   State       : Up
  ACs:
    AC                                 Link ID    State
    GE1/0/1                            0x0        Up
    Statistics: Disabled
<Sysname> display l2vpn vsi verbose
VSI Name: vpnb
  VSI Index               : 0
  VSI State               : Up
  Diffserv Mode           : -
  Bandwidth               : -
  MAC Table Limit         : -
  VXLAN ID                : -
  SRv6 SIDs:
  SRv6 tunnels:
   Peer        : 2::2
   Link ID     : 0x9000000
   State       : Up
  ACs:
    AC                                 Link ID    State
    GE1/0/3 srv1                       0x0        Up
表1-7 display l2vpn vsi verbose命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
VSI Description
VSI的描述信息,如果不配置,则此行不显示
VSI State
VSI的状态,取值包括
·     Up:up状态
·     Down:down状态
·     Administratively down:通过shutdown命令手工关闭VSI
MTU
VSI上配置的最大传输单元
Diffserv Mode
VSI的差分服务模式,取值包括:
·     ingress:入方向的差分服务模式
·     egress:出方向的差分服务模式
·     pipe:差分服务模式为Pipe模式
·     short-pipe:差分服务模式为Short-pipe模式
·     uniform:差分服务模式为Uniform模式
·     trust:出方向的优先级信任模式
·     inner-dot1p:信任报文内层的802.1p优先级
·     dscp:信任报文的DSCP优先级
·     af1、 af2、af3、af4、be、cs6、cs7、ef:MPLS EXP优先级
·     -:未配置差分服务模式
Bandwidth
‌VSI的已知单播流量的最大带宽值,单位为kbps
Broadcast Restrain
‌VSI的广播抑制带宽值,单位为kbps
Multicast Restrain
‌VSI的组播抑制带宽值,单位为kbps
‌VSI的未知单播抑制带宽值,单位为kbps
MAC Learning
是否使能了MAC地址学习功能,取值包括:
·     Enabled:使能了MAC地址学习功能
·     Disabled:未使能MAC地址学习功能
MAC Tabel Limit
‌VSI内MAC地址表项的最大数目
取值为Unlimited,表示不限制VSI内MAC地址表项的最大数目
MAC Learning rate
VSI内MAC地址表项的学习速率
VSI学习的本地动态MAC地址表项的老化时间,单位为秒
显示“NotAging”时,表示本地动态MAC地址表项不老化
VSI学习的远端动态MAC地址表项的老化时间,单位为秒
显示“NotAging”时,表示远端动态MAC地址表项不老化
Drop Unknown
‌当VSI内学习到的MAC地址数达到最大值后,是否禁止转发源MAC地址不在MAC地址表里的报文
·     Enabled:表示禁止转发
·     Disabled:表示允许转发
PW Redundancy Mode
PW冗余保护模式,取值包括:
·     Slave:主从操作模式,且本地PE作为从节点
·     Master:主从操作模式,且本地PE作为主节点
·     Independent:独立操作模式
Flooding
VPLS不支持该字段
Statistics
VSI的统计功能
Input Statistics
入方向的VSI报文统计信息,包括入方向接收的字节数(Octets)、接收的报文数(Packets)、接收的错误报文数(Errors)和丢弃的报文数(Discards)
Output Statistics
出方向的VSI报文统计信息,包括出方向发送的字节数(Octets)、发送的报文数(Packets)、错误报文数(Errors)和丢弃的报文数(Discards)
Input Rate
入方向的VSI报文速率统计信息,包括入方向发送的每秒字节数(Bytes per second)、每秒报文(Packets per second)
Output Rate
出方向的VSI报文速率统计信息,包括出方向发送的每秒字节数(Bytes per second)、每秒报文(Packets per second)
VXLAN ID
VPLS不支持该字段
EVPN Encapsulation
EVPN的封装类型,取值包括:
·     VXLAN:表示EVPN的封装类型为VXLAN
·     MPLS:表示EVPN的封装类型为MPLS
·     SRv6:表示EVPN的封装类型为SRv6
SRv6 SIDs
VSI的SRv6 SID
Dt2U SID
EVPN VPLS over SRv6组网中,用于转发单播报文的SRv6 SID,括号中为SID各组成部分长度,依次为Locator段长度、Opcode长度和Argument长度,各组成部分长度之和为128
Dt2Ul SID
EVPN VPLS over SRv6多归属站点组网中,用于在冗余备份组成员设备间的Bypass隧道上转发单播报文的SRv6 SID,括号中为SID各组成部分长度,依次为Locator段长度、Opcode长度和Argument长度,各组成部分长度之和为128
Dt2M SID
EVPN VPLS over SRv6组网中,用于转发泛洪报文的SRv6 SID,括号中为SID各组成部分长度,依次为Locator段长度、Opcode长度和Argument长度,各组成部分长度之和为128
SRv6 Tunnels
VSI的SRv6隧道列表
Peer
PW远端PE的IPv6地址
Link ID
SRv6隧道在VSI内的链路标识符
SRv6隧道的状态,取值包括Up、Down、Blocked和Defect
ACs
VSI的AC列表
AC
接入电路,取值为:
·     三层接口名称:表示在三层接口下关联VSI
·     二层接口名称和以太网服务实例:表示在以太网服务实例下关联VSI
Link ID
AC在VSI内的链路ID
AC的状态,取值包括Up和Down
Statistics
是否开启AC的统计功能,取值包括:
·     Enabled:开启AC的统计功能
·     Disabled:关闭AC的统计功能
display l2vpn xconnect-group命令用来显示交叉连接组的信息。
display l2vpn xconnect-group [ evpn-srv6 | name group-name [ connection connection-name ] | static-srv6 ] [ count | verbose ]
evpn-srv6:显示EVPN VPWS over SRv6组网中交叉连接组的信息。如果不指定本参数,则显示所有交叉连接组的信息。
name group-name:显示指定交叉连接组的信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有交叉连接组的信息。
connection connection-name:显示指定交叉连接的信息。connection-name表示交叉连接的名称,为1~20个字符的字符串,不能包含字符“-”,区分大小写。如果不指定本参数,则显示指定交叉连接组内所有交叉连接的信息。
static-srv6:显示采用静态方式建立SRv6 PW的EVPN VPWS over SRv6组网中交叉连接组的信息。
count:显示交叉连接组的数目。
verbose:显示交叉连接组的详细信息。如果不指定本参数,则显示交叉连接组的简要信息。
# 显示EVPN VPWS over SRv6组网中所有交叉连接组的简要信息。
<Sysname> display l2vpn xconnect-group evpn-srv6
Status Codes: UP - Up, DN - Down, DF - Defect, BD - Blocked, AD - Admin Down,
              DL - Idle, DP - Duplicate
Total number of cross-connections: 1, 1 up, 0 down, 0 admin down
Xconnect-group                          Connection                          ST
Segment1                            ST  Segment2                            ST
vpna                                    pw1                                 UP
GE1/0/2                             UP  EVPN   2::2                         UP
# 显示EVPN VPWS over SRv6组网中交叉连接的统计信息。
<Sysname> display l2vpn xconnect-group evpn-srv6 count
表1-8 display l2vpn xconnect-group命令显示信息描述表
所有交叉连接组或指定交叉连接组下交叉连接的总数,以及处于up、down、admin down状态的交叉连接数目
Xconnect-group
交叉连接组名称
Connection
交叉连接名称
ST
交叉连接的状态,取值包括:
·     UP:表示up状态
·     DN:表示down状态
·     AD:表示通过shutdown命令手工关闭的交叉连接
Segment1 / Segment2
·     当表示AC时:
¡     若AC为三层接口,则显示接口名称
¡     若AC为以太网服务实例,则显示以太网服务实例名称
·     当表示SRv6隧道时,则显示SRv6隧道的建立方式(目前仅支持EVPN)以及远端PE的IPv6地址
ST
当表示AC状态时,取值包括:
·     UP:表示up状态
·     DN:表示down状态
当表示SRv6隧道状态时,取值包括:
·     UP:表示up状态
·     DN:表示down状态
·     DF:表示BFD检测到该SRv6隧道存在缺陷
·     BD:表示存在主备SRv6隧道的情况下,该SRv6隧道当前未转发流量,起到备份作用
·     DL:表示该SRv6隧道的入SID不可用
·     DP:SRv6隧道暂不支持该取值
# 显示EVPN VPWS over SRv6组网中所有交叉连接组的详细信息。
<Sysname> display l2vpn xconnect-group evpn-srv6 verbose
  Connection ID         : 1
  State                 : Up
  MTU                   : 1500
  Diffserv Mode         : -
  SRv6 tunnels:
   Peer        : 2::2
   Link ID     : 0x1
   State       : Up
  ACs:
    AC                                 Link ID    State
    GE1/0/1                            0x0        Up
  Connection ID         : 1
  State                 : Up
  MTU                   : 1500
  Diffserv Mode         : -
  SRv6 tunnels:
   Peer        : 2::2
   Link ID     : 0x1
   State       : Up
  ACs:
    AC                                 Link ID    State
    GE1/0/4 srv1                       0x0        Up
表1-9 display l2vpn xconnect-group verbose命令显示信息描述表
Xconnect-group Name
交叉连接组名称
交叉连接组的描述信息,如果不配置,则此行不显示
Connection Name
交叉连接名称
Connection ID
交叉连接索引
交叉连接组的状态,取值包括
·     Up:up状态
·     Down:down状态
·     Administratively down:通过shutdown命令手工关闭交叉连接组
MTU
交叉连接的最大传输单元
PW Redundancy Mode
PW冗余保护模式,取值包括:
Diffserv Mode
交叉连接的差分服务模式,取值包括:
·     egress:出方向的差分服务模式
·     trust:出方向的优先级信任模式
·     dscp:信任报文的DSCP优先级
·     -:未配置差分服务模式
SRv6 tunnels
SRv6隧道信息
Peer
SRv6远端PE的IPv6地址
Link ID
SRv6在交叉连接内的链路标识符
SRv6的状态,取值包括Up、Down、Blocked和Defect
ACs
AC相关信息
AC
接入电路,取值为:
·     三层接口名称:表示交叉连接关联三层接口
·     二层接口名称和以太网服务实例:表示交叉连接关联以太网服务实例
Link ID
AC在交叉连接组内的链路ID
AC的状态,取值包括Up和Down
Statistics
是否开启AC的统计功能,取值包括:
·     Enabled:开启AC的统计功能
encapsulation source-address命令用来配置SRv6 VPN封装的IPv6报文头的源地址。
undo encapsulation source-address命令用来恢复缺省情况。
encapsulation source-address ipv6-address [ ip-ttl ttl-value ]
未指定SRv6 VPN封装的IPv6报文头的源地址。
SRv6视图
ipv6-address:指定IPv6源地址,取值不能为环回地址(0:0:0:0:0:0:0:0或::)、链路本地地址、组播地址和未指定地址。
ip-ttl ttl-value:指定IPv6报文头的TTL值,取值范围为1~255,缺省值为255。
在SRv6 VPN组网环境中,必须指定封装的IPv6报文头的源地址。否则,无法通过SRv6 VPN转发数据流量。
指定的源地址必须为本机地址,且已经由路由协议发布,建议指定本设备的Loopback接口地址。
# 配置SRv6 VPN封装的IPv6报文头的源地址为1::1,TTL值为200。
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] encapsulation source-address 1::1 ip-ttl 200
evpn encapsulation srv6命令用来创建EVPN实例,指定EVPN采用SRv6封装方式,并进入EVPN实例视图。如果EVPN实例已经存在,则直接进入EVPN实例视图。
undo evpn encapsulation命令用来恢复缺省情况。
不存在EVPN实例。
VSI视图
交叉连接组视图
只有创建EVPN实例后,才能进行EVPN相关配置。
本命令与evpn encapsulation binding instance命令互斥,即通过本命令在VSI下创建EVPN实例后,不能在该VSI下通过evpn encapsulation binding instance命令将该VSI与其它EVPN实例关联;反之亦然。
# 创建VSI视图下的EVPN实例,指定EVPN采用SRv6封装方式,并进入VSI视图下的EVPN实例视图。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-srv6]
evpn next-header-field命令用来配置SRH的Next Header字段的值。
undo evpn next-header-field命令用来恢复缺省配置。
evpn next-header-field { 59 | 143 }
SRH的Next Header字段的值为143。
SRv6视图
59:SRH的Next Header字段的值为59。
143:SRH的Next Header字段的值为143。
在EVPN VPWS over SRv6和EVPN VPLS over SRv6组网中,设备需要对SRv6报文的SRH的Next Header字段进行校验,如果和本设备可以识别的值不同,则不会按照SRv6报文处理,只会按照普通IPv6报文处理,可能导致报文被丢弃。为了避免以上问题,可以修改SRH的Next Header字段的值,以便与不同版本兼容,使设备正常处理SRv6报文。
# 配置SRH的Next Header字段的值为59。
[Sysname-segment-routing-ipv6] evpn next-header-field 59
export route-policy命令用来在EVPN实例下配置EVPN的出方向路由策略。
undo export route-policy命令用来恢复缺省情况。
在EVPN实例下未配置EVPN的出方向路由策略,即不对发布的路由进行过滤。
EVPN实例视图
route-policy:出方向路由策略名称,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了EVPN的出方向路由策略,则EVPN在发布路由时,将利用指定的路由策略对发布的路由进行过滤、改变发布路由的属性等。使用本命令可以更加精确、灵活地控制路由的发布。
多次执行本命令,最后一次执行的命令生效。
# 在EVPN实例vpna下配置EVPN的出方向路由策略为poly-1。
[Sysname] vsi vpna
[Sysname-vsi-vpna] evpn encapsulation srv6
[Sysname-vsi-vpna-evpn-srv6] route-distinguisher 1:1
[Sysname-vsi-vpna-evpn-srv6] export route-policy poly-1
·     route-policy(三层技术-IP路由命令参考/路由策略)
import route-policy命令用来在EVPN实例下配置EVPN的入方向路由策略。
undo import route-policy命令用来恢复缺省情况。
EVPN实例下未配置EVPN的入方向路由策略,即不对接收的路由进行过滤。
EVPN实例视图
route-policy:入方向路由策略名称,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了EVPN的入方向路由策略,则EVPN在接收路由时,将利用指定的路由策略对接收的路由进行过滤、改变接收路由的属性等。使用本命令可以更加精确、灵活地控制路由的接收。
# 在EVPN实例vpna下配置EVPN的入方向路由策略为poly-1。
[Sysname] vsi vpna
[Sysname-vsi-vpna-evpn-srv6] import route-policy poly-1
nexthop interface命令用来指定允许分配SID的下一跳,并指定该下一跳对应的出接口。
undo nexthop命令用来恢复缺省情况。
nexthop nexthop-address interface interface-type interface-number
undo nexthop nexthop-address
不会为任何下一跳分配End.DX4 SID。
BGP-VPN IPv4单播地址族Segment Routing指定下一跳视图
BGP-VPN IPv4单播地址族EVPN Segment Routing指定下一跳视图
nexthop-address:指定下一跳IPv4地址。
interface-type interface-number:指定出接口的类型和出接口的编号。
在IPv4 L3VPN over SRv6或IPv4 EVPN L3VPN over SRv6场景中,为了加快转发速度,使BGP IPv4路由按照下一跳分配End.DX4 SID,可以执行此命令指定允许分配SID的下一跳,并指定该下一跳对应的出接口。
可以通过两种方式为下一跳分配End.DX4 SID:
·     配置本命令,从VPN实例引用的Locator中动态分配SID。
·     在引用的Locator下配置opcode end-dx4 vpn-instance命令,静态分配SID。
以上两种方式指定的下一跳对应的出接口应与路由表中下一跳对应的出接口保持一致。如果不一致,则设备不会动态分配End.DX4 SID,静态方式分配的End.DX4 SID也不会用来转发报文。
如果为相同的下一跳同时配置以上两种方式,此时设备优先使用静态配置的SID转发报文。
只能为一个下一跳指定一个出接口,不能通过重复执行本命令来修改出接口。如需修改出接口,请先通过undo nexthop命令删除当前指定的下一跳,再执行nexthop interface命令重新指定下一跳和出接口。
动态SID资源不足,导致BGP私网IPv4路由无法按照下一跳分配动态SID,且未静态配置End.DX4 SID时,会按照VPN实例分配End.DT4 SID或End.DT46 SID。
# 在BGP-VPN IPv4单播地址族Segment Routing指定下一跳视图下,指定允许为下一跳地址10.1.1.2分配SID,并指定该下一跳对应的出接口为GigabitEthernet1/0/1。
[Sysname] bgp 100
[Sysname-bgp-default] ip vpn-instance vpna
[Sysname-bgp-default-vpna] address-family ipv4 unicast
[Sysname-bgp-default-ipv4-vpna] segment-routing ipv6 locator aaa
[Sysname-bgp-default-ipv4-vpna] segment-routing ipv6 apply-sid specify-nexthop
[Sysname-bgp-default-sid-np-ipv4-vpna] nexthop 10.1.1.2 interface gigabitethernet 1/0/1
·     opcode
nexthop nexthop-ipv6-address interface interface-type interface-number
undo nexthop nexthop-ipv6-address
不会为任何下一跳分配End.DX6 SID。
BGP-VPN IPv6单播地址族Segment Routing指定下一跳视图
BGP-VPN IPv6单播地址族EVPN Segment Routing指定下一跳视图
BGP IPv6单播地址族Segment Routing指定下一跳视图
nexthop-ipv6-address :指定下一跳IPv6地址。
interface-type interface-number:指定出接口的类型和编号。
在IPv6 L3VPN over SRv6、IPv6 EVPN L3VPN over SRv6或公网IPv6 over SRv6场景中,为了加快转发速度,使BGP IPv6路由按照下一跳分配End.DX6 SID,可以执行此命令指定允许分配SID的下一跳,并指定该下一跳对应的出接口。
可以通过两种方式为下一跳分配End. DX6 SID:
·     在引用的Locator下配置opcode end-dx6 vpn-instance命令,静态分配SID。
以上两种方式指定的下一跳对应的出接口应与路由表中下一跳对应的出接口保持一致。如果不一致,则设备不会动态分配End.DX6 SID,静态方式分配的End.DX6 SID也不会用来转发报文。
如果为相同下一跳同时配置以上两种方式,此时设备优先使用静态配置的SID转发。
动态SID资源不足,导致BGP私网IPv6路由无法按照下一跳分配动态SID,且未静态配置End.DX6 SID时,会按照VPN实例分配End.DT6 SID或End.DT46 SID。
# 在BGP IPv6单播地址族Segment Routing指定下一跳视图下,指定允许为下一跳地址10::1:2分配SID,并指定该下一跳对应的出接口为GigabitEthernet1/0/1。
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 unicast
[Sysname-bgp-default-ipv6] segment-routing ipv6 locator aaa
[Sysname-bgp-default-ipv6] segment-routing ipv6 apply-sid specify-nexthop
[Sysname-bgp-default-sid-np-ipv6] nexthop 10::1:2 interface gigabitethernet 1/0/1
·     opcode
1.1.16  peer
peer命令用来配置静态SRv6 PW,并进入交叉连接静态SRv6 PW视图。如果指定的静态SRv6 PW已经存在,则直接进入交叉连接静态SRv6 PW视图。
undo peer命令用来删除指定的静态SRv6 PW。
peer ipv6-address end-dx2-sid { remote-locator locator-name opcode opcode | remote-sid ipv6-address } [ color color-value | tunnel-policy tunnel-policy-name | track track-entry-number ] *
undo peer ipv6-address  end-dx2-sid { remote-locator locator-name opcode opcode | remote-sid ipv6-address ] }
不存在静态SRv6 PW。
交叉连接静态SRv6视图
ipv6-address:远端PE的IPv6地址。
remote-locator locator-name:指定远端PE的Locator段名称。locator-name表示locator段名称,为1~31个字符的字符串,区分大小写。
opcode opcode指定SRv6 SID操作码。opcode为SRv6 SID操作码,取值范围为1~2static-length-1,其中static-lengthlocator命令配置。
remote-sid ipv6-address:指定远端PE的SID IPV6地址。
color color-value:指定PW的Color属性。color-value为Color值,取值范围为0~4294967295。
tunnel-policy tunnel-policy-name:指定静态SRv6 PW引用的隧道策略。tunnel-policy-name表示隧道策略名,为1~19个字符的字符串,区分大小写。如果不指定本参数,则使用缺省的隧道选择策略。
track track-entry-number:指定静态SRV6 PW关联的Track项,其中,track-entry-number为Track项的序号,取值范围为1~1024。
在本端PE上执行本命令,通过指定本地配置的远端Locator段和SRv6 SID操作码来获取远端PE为交叉连接分配的SRv6 SID,或者通过配置remote-sid参数直接指定远端PE的SRV6 SID。
仅负载分担方式的静态SRv6 PW支持与Track项联动,指定静态SRV6 PW与Track项关联后,当关联的Track项状态为negative时,若存在备份SID则刷新SRv6 PW并使用备份SID,若不存在备份SID,则静态SRV6 PW的状态将变为down。
# 配置静态SRv6 PW,指定远端PE的IPv6地址为1::1、远端的locator段名称为aaa、Opcode为1,并进入指定的peer视图。
[Sysname-xcg-vpna] connection pw1
[Sysname-xcg-vpna-pw1] static-srv6 local-service-id 1 remote-service-id 2 tunnel-policy 1
[Sysname-xcg-vpna-pw1-1-2] peer 1::1 end-dx2-sid remote-locator aaa opcode 1
[Sysname-xcg-vpna-pw1-1-2-1::1-aaa-1]
# 配置静态SRv6 PW,指定远端PE的Pv6地址为1::1、远端PE的SID IPv6地址为100::1、Track项为1,并进入指定的peer视图。
[Sysname-xcg-vpna] connection pw2
[Sysname-xcg-vpna-pw2] static-srv6 local-service-id 3 remote-service-id 4
[Sysname-xcg-vpna-pw2-3-4] peer 1::1 remote-sid 100::1 track 1
[Sysname-xcg-vpna-pw2-3-4-1::1-100::1]
·     backup-peer
peer advertise encap-type srv6命令用来配置向对等体/对等体组发布SRv6封装的EVPN路由。
undo peer advertise encap-type srv6命令用来删除向对等体/对等体组发布SRv6封装的EVPN路由的配置。
peer { group-name | ipv6-address [ prefix-length ] } advertise encap-type srv6
undo peer { group-name | ipv6-address [ prefix-length ] } advertise encap-type srv6
向对等体/对等体组发布VXLAN封装的IP前缀路由。
BGP EVPN地址族视图
ipv6-address:对等体的IPv6地址。指定的对等体必须已经创建。
prefix-length:前缀长度,取值范围为0~128。如果指定本参数,则表示指定网段内的动态对等体。
在EVPN L3VPN over SRv6网络中,需要执行本命令配置向邻居发布SRv6封装的EVPN路由。
本功能通常配置在EVPN承载的L3VPN网络的边缘节点和RR(Route Reflector,路由反射器)设备上。
# 配置向对等体1::1发布SRv6封装的EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn] peer 1::1 advertise encap-type srv6
peer advertise original-route命令用来配置向对等体/对等体组发布源VPNv4/VPNv6/EVPN路由。
undo peer advertise original-route命令用来恢复缺省情况。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise original-route
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise original-route
通过peer re-originated命令配置修改路由信息后,不向对等体/对等体组发布源VPNv4/VPNv6/EVPN路由。
BGP VPNv4地址族视图
BGP VPNv6地址族视图
BGP EVPN地址族视图
ipv4-address:对等体的IPv4地址。指定的对等体必须已经创建。
prefix-length:网络掩码,取值范围为0~128。如果指定本参数,则表示指定网段内的动态对等体。
使用本功能前必须在设备上配置peer re-originated命令,否则本功能不生效。
在设备上配置peer re-originated命令后,该设备仅向对等体/对等体组发布修改路由信息后的路由,不会发布源VPNv4/VPNv6/EVPN路由。此时若有对等体/对等体组希望从该设备接收未经修改的源VPNv4/VPNv6/EVPN路由,则可在设备上执行本命令,向指定对等体/对等体组发送源VPNv4/VPNv6/EVPN路由和修改路由信息后的路由。
# 在BGP VPNv4地址族视图下,配置向对等体1.1.1.1发送源VPNv4路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 advertise original-route
·     peer re-originated
·     peer suppress re-originated
peer prefix-sid命令用来配置与指定IPv6对等体之间交换SRv6 SID信息。
undo peer prefix-sid命令用来恢复缺省情况。
peer { group-name | ipv6-address [ prefix-length ] } prefix-sid
undo peer { group-name | ipv6-address [ prefix-length ] } prefix-sid
IPv6对等体之间不能交换SRv6 SID信息。
BGP VPNv4地址族视图
BGP VPNv6地址族视图
BGP IPv4单播地址族视图
BGP IPv6单播地址族视图
在SRv6 VPN组网场景中,配置本命令后,IPv6对等体之间可以通过VPNv4/VPNv6/IPv4单播/IPv6单播路由交换SRv6 SID信息。
# 在BGP VPNv4地址族视图下,配置与对等体2001:1::1之间交换SRv6 SID信息。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 2001:1::1 prefix-sid
peer re-originated命令用来配置从对等体/对等体组接收到VPNv4/VPNv6/EVPN路由后,修改路由信息。
undo peer re-originated命令用来取消该配置。
BGP VPNv4地址族视图/BGP VPNv6地址族视图:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ replace-rt | stitch-evpn ]
peer { group-name | ipv6-address [ prefix-length ] } re-originated [ replace-rt ] replace-sid
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated
BGP EVPN地址族视图:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ ip-prefix ] [ replace-rt | stitch-l3vpn ]
peer { group-name | ipv6-address [ prefix-length ] } re-originated [ ip-prefix ] [ replace-rt ] replace-sid
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ ip-prefix  ]
不修改从对等体/对等体组接收到的VPNv4/VPNv6/EVPN路由的信息。
BGP VPNv4地址族视图
BGP VPNv6地址族视图
BGP EVPN地址族视图
ip-prefix:指定修改IP前缀路由的信息。如果未指定本参数,则仍表示修改IP前缀路由的信息。
replace-rt:修改路由信息。
·     VPNv4/VPNv6路由:将VPNv4/VPNv6路由的RD和RT信息修改为本地VPN实例的RD和RT,并为路由添加MPLS标签/SRv6 SID(未指定replace-sid参数时)或在本地RT匹配的VPN实例内重新为路由申请SRv6 SID(指定replace-sid参数时)。如果不指定本参数,则仅修改RD,并添加MPLS标签/SRv6 SID(未指定replace-sid参数时)或在本地RT匹配的VPN实例内重新为路由申请SRv6 SID(指定replace-sid参数时),不修改RT。
·     EVPN路由:将EVPN IP前缀路由的L3VNI、RD和RT信息修改为本地VPN实例的L3VNI、RD和RT,并为路由添加MPLS标签/SRv6 SID(未指定replace-sid参数时)或在本地RT匹配的VPN实例内重新为路由申请SRv6 SID(指定replace-sid参数时)。如果不指定本参数,则仅修改L3VNI和RD,并添加MPLS标签/SRv6 SID(未指定replace-sid参数时)或在本地RT匹配的VPN实例内重新为路由申请SRv6 SID(指定replace-sid参数时),不修改RT。
replace-sid:接收到BGP VPNv4/VPNv6/EVPN路由且本地存在RT匹配的VPN实例时,删除路由携带的SRv6 SID,并在本地RT匹配的VPN实例内重新为BGP EVPN路由申请SRv6 SID。如果不指定本参数,则不改变路由的SRv6 SID。
stitch-evpn:将VPNv4/VPNv6路由重生成为EVPN IP前缀路由,不修改路由的RD和RT信息。
stitch-l3vpn:将IP前缀路由重生成为VPNv4/VPNv6路由,不修改路由的RD和RT信息。
应用场景
ASBR作为边界设备同时连接MPLS L3VPN网络与L3VPN over SRv6网络或EVPN L3VPN与EVPN L3VPN over SRv6网络时,通过在ASBR上执行本命令不携带stitch-evpnstitch-l3vpn参数,可以完成VPNv4/VPNv6/EVPN路由信息的转换,以实现MPLS网络和SRv6网络的互通。
ASBR作为边界设备同时连接EVPN L3VPN网络与IP L3VPN over SRv6网络或MPLS L3VPN与EVPN L3VPN over SRv6网络时,通过在ASBR上执行本命令携带stitch-evpnstitch-l3vpn参数,可以完成VPNv4/VPNv6路由信息与EVPN路由信息的转换,以实现SRv6网络与MPLS L3VPN网络或EVPN L3VPN网络的互通。
工作机制
在ASBR节点上执行本命令(未指定stitch-l3vpnstitch-l3vpn参数)后:
·     该节点从MPLS L3VPN/EVPN L3VPN网络接收到VPNv4/VPNv6/EVPN路由后,如果路由中的Route Target属性与本地VPN实例的Import Route Target属性匹配,则修改路由中的RD和RT信息,并为路由分配SRv6 SID,将SRv6 SID和私网标签关联,然后将修改路由信息后的路由发布到SRv6网络。
·     该节点从SRv6网络接收到VPNv4/VPNv6/EVPN路由后,如果路由中的Route Target属性与本地VPN实例的Import Route Target属性匹配,则修改路由中的RD和RT信息,并为路由分配MPLS标签,将私网标签和SRv6 SID关联,然后将修改路由信息后的路由发布到MPLS L3VPN/EVPN L3VPN网络。
在ASBR节点上执行本命令(指定stitch-evpn参数),该节点从SRv6网络或MPLS网络接收到VPNv4/VPNv6路由后,如果路由中的Route Target属性与本地VPN实例的Import Route Target属性匹配,则将VPNv4/VPNv6路由重生成为EVPN IP前缀路由,不修改路由中的RD和RT信息,并为路由分配MPLS标签,将私网标签和SRv6 SID关联,然后将修改路由信息后的路由发布到EVPN L3VPN网络。
在ASBR节点上执行本命令(指定stitch-l3vpn参数),该节点从SRv6网络或MPLS网络接收到EVPN路由后,如果路由中的Route Target属性与本地VPN实例的Import Route Target属性匹配,则将IP前缀路由重生成为VPNv4/VPNv6路由,不修改路由中的RD和RT信息,并为路由分配MPLS标签,将私网标签和SRv6 SID关联,然后将修改路由信息后的路由发布到MPLS L3VPN网络。
在多个AS域内均部署了SRv6的跨域SRv6 VPN网络中,如果要实现跨AS域的用户互通,通常需要将Locator网段路由信息进行跨域发布(例如将IGP协议发布的Locator网段路由引入到BGP协议中进行跨域发布)。将Locator网段路由信息进行跨域发布后,不同AS域间的PE设备即可以建立起跨域的SRv6转发路径。但是在一些场景中,网络管理员处于安全性考虑,不希望将Locator网段路由信息在AS域间传递。此时网络管理员可以在配置本命令时指定replace-sid参数,通过将路由携带的SRv6 SID修改为本地VPN实例的SRv6 SID,使得Locator网段路由无需发布到另一AS域中,不同AS域的PE设备就可以建立起跨域的SRv6转发路径。
注意事项
执行本命令后,仅向对等体/对等体组发布修改路由信息后的路由,不会向对等体/对等体组发布VPN源路由。
如果本地VPN实例的RD与接收到的VPNv4/VPNv6/EVPN路由的RD相同,则不会修改该路由的路由信息,也不会重生成路由,导致该VPNv4/VPNv6/EVPN路由无法向对等体/对等体组发布。因此,执行本命令时,建议在不同设备上为VPN实例配置不同的RD。
# 在BGP VPNv4地址族视图下,配置修改从BGP对等体1.1.1.1收到的VPNv4路由的RD和RT,并为路由分配MPLS标签或SRv6 SID。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 re-originated replace-rt
·     peer advertise original-route
peer srv6-vpn compatible命令用来开启对等体/对等体组之间的SRv6 VPN兼容功能。
undo peer srv6-vpn compatible命令用来关闭对等体/对等体组之间的SRv6 VPN兼容功能。
peer { group-name | ipv6-address [ prefix-length ] } srv6-vpn compatible [ srv6-sid-transposition ]
undo peer { group-name | ipv6-address [ prefix-length ] } srv6-vpn compatible
BGP EVPN地址族视图:
peer { group-name | ipv6-address [ prefix-length ] } srv6-vpn compatible srv6-sid-transposition
SRv6 VPN兼容功能处于关闭状态,设备按照RFC 9252中指定的非Transposition Scheme格式,对发送的BGP路由中携带的SRv6 SID进行封装。
BGP VPNv4地址族视图
BGP VPNv6地址族视图
BGP EVPN地址族视图
srv6-sid-transposition:设备按照RFC 9252中指定的Transposition Scheme格式,对发送的BGP路由中携带的SRv6 SID进行封装。如果未指定本参数,则表示设备按照draft-dawra-idr-srv6-vpn中指定的格式,对发送的BGP路由中携带的SRv6 SID进行封装。
在IP L3VPN over SRv6/EVPN L3VPN over SRv6组网环境中,PE之间交互BGP VPNv4/VPNv6/EVPN路由时,会在BGP路由中携带SRv6 SID。不同厂商可能使用不同的格式将SRv6 SID封装在BGP路由中,造成不同厂商设备无法识别对方发送的BGP路由,从而导致路由信息发布失败。为了解决这一问题,可以通过本命令,修改H3C设备发送的BGP路由中SRv6 SID的封装格式,使其与对端PE设备的SRv6 SID封装格式相同,以实现H3C设备与其他厂商设备的互通。
# 开启本设备与对等体2::2之间的SRv6 VPN兼容功能。
[Sysname] bgp 1
[Sysname-bgp-default-vpnv4] peer 2::2 srv6-vpn compatible
peer suppress re-originated命令用来抑制向对等体/对等体组发送修改路由信息后的VPNv4/VPNv6/EVPN路由。
undo peer suppress re-originated命令用来恢复缺省情况。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated
BGP EVPN地址族视图:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated ip-prefix
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated ip-prefix
通过peer re-originated命令配置修改路由信息后,向对等体/对等体组发送修改路由信息后的VPNv4/VPNv6/EVPN路由。
BGP VPNv4地址族视图
BGP VPNv6地址族视图
BGP EVPN地址族视图
ip-prefix:抑制向对等体/对等体组发送修改路由信息后的IP前缀路由。
如果设备上同时配置了peer re-originatedpeer advertise original-route命令,则该设备会向指定对等体/对等体组发送源VPNv4/VPNv6/EVPN路由和修改路由信息后的VPNv4/VPNv6/EVPN路由。此时若该对等体/对等体组仅希望接收源VPNv4/VPNv6/EVPN路由,则可在设备上配置本命令,抑制向对等体/对等体组发送修改路由信息后的VPNv4/VPNv6/EVPN路由,减少该对等体/对等体组上的VPNv4/VPNv6/EVPN路由条目。
# 在BGP VPNv4地址族视图下,抑制向对等体1.1.1.1发送修改路由信息后的VPNv4路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 suppress re-originated
ping evpn vpls srv6命令用来检测EVPN VPLS over SRv6组网中本端PE到指定主机连接的远端PE间SRv6 PW的单向连通性。
ping evpn vpls srv6 vsi vsi-name mac mac-address [ -a source-ipv6 | -c count | -h hop-limit | -m interval | -r reply-mode | -s packet-size | -t time-out | -tc tc ] *
vsi vsi-name:检测指定VSI内SRv6 PW的连通性。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
mac mac-address:检测到指定主机连接的远端PE的SRv6 PW连通性。mac-address表示MAC地址,形式为H-H-H,不能配置为全0、广播MAC地址和组播MAC地址。
-a source-ipv6:指定发送的MPLS Echo请求报文的源IPv6地址。source-ipv6为源IPv6地址。如果未指定本参数,则MPLS Echo请求报文的源IPv6地址为报文出接口的地址。
-c count:指定发送MPLS Echo请求报文的数目。count为MPLS Echo请求报文发送数目,取值范围为1~4294967295,缺省值为5。
-h hop-limit:指定MPLS Echo请求报文中Hop limit值。hop-limit为Hop limit值,取值范围为1~255,缺省值为255。
-m interval:指定连续发送MPLS Echo请求报文的时间间隔。interval为发送报文的时间间隔,取值范围为1~10000,单位为毫秒,缺省值为2000。
-r reply-mode:指定接收者对MPLS Echo请求报文的应答模式。reply-mode为应答模式,取值为2、4,缺省值为2。2表示根据目的IP地址查找IP转发表转发应答报文;4表示根据请求报文的源IPv6地址在目的节点上查找IPv6路由表,封装SRH信息转发应答报文。
-s packet-size:指定MPLS Echo请求报文长度。packet-size为MPLS Echo请求报文长度(不包括IPv6头和UDP头),取值范围为80~1200,单位为字节,缺省值为100。
-t time-out:指定发送MPLS Echo请求报文后等待响应的超时时间。time-out为超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000。
-tc tc:指定MPLS Echo请求报文的流量等级。tc为流量等级,取值范围为0~255,缺省值为0。
EVPN VPLS over SRv6组网中,本端PE设备与远端PE设备间通过SRv6 PW传输数据报文。当PE间出现丢包或断流现象时,可通过本命令检测本端PE到远端PE间SRv6 PW的单向连通性。
# 检测VSI vpna内本端PE到MAC地址为2-2-2的主机连接的远端PE间SRv6 PW的单向连通性。
<System> ping evpn vpls srv6 vsi vpna mac 2-2-2
Ping a remote PE in VSI vpna over SRv6 by reaching remote-MAC 0002-0002-0002: 100 data bytes.
Press CTRL+C to break.
100 bytes from 11::2: sequence=1 time=1 ms
100 bytes from 11::2: sequence=2 time=2 ms
100 bytes from 11::2: sequence=3 time=1 ms
100 bytes from 11::2: sequence=4 time=2 ms
100 bytes from 11::2: sequence=5 time=1 ms
--- Ping statistics for MAC 0002-0002-0002 ---
5 packets transmitted, 5 packets received, 0.0% packets lost
Round-trip min/avg/max = 1/1/2 ms
表1-10 ping evpn vpls srv6命令显示信息描述表
检测到MAC地址为0002-0002-0002的主机连接的远端PE的SRv6 PW连通性,每个MPLS Echo请求报文中的数据为100字节
按组合键Ctrl+C可以终止ping操作
收到IPv6地址为11::2的设备回复的MPLS Echo应答报文,包括:
·     bytes:表示MPLS Echo应答报文中的数据字节数
·     Sequence:表示报文序号,用来判断报文是否有分组丢失、失序或重复
·     time:表示响应时间
若在等待响应的超时时间内没有收到MPLS Echo应答报文,则显示“Request time out”
Ping操作中收发数据的统计结果
发送的MPLS Echo请求的报文数
5 packets received
收到的MPLS Echo应答的报文数
0.0% packets lost
未响应请求报文占发送的总请求报文的百分比
响应时间的最小值、平均值和最大值,单位为毫秒
·     tracert evpn vpls srv6
ping evpn vpws srv6命令用来检测EVPN VPWS over SRv6组网中本端PE到远端PE间SRv6 PW的单向连通性。
ping evpn vpws srv6 xconnect-group group-name local-service-id  remote-service-id [ -a source-ipv6 | -c count | -h hop-limit | -m interval | -r reply-mode | -s packet-size | -t time-out | -tc tc ] *
xconnect-group group-name:交叉连接组的名称,为1~31个字符的字符串,不能包含字符“-”,区分大小写。
local-service-id:本端的service ID,取值范围为1~16777215。
remote-service-id:远端的service ID,取值范围为1~16777215。
-c count:指定发送MPLS Echo请求报文的次数。count为MPLS Echo请求报文发送次数,取值范围为1~4294967295,缺省值为5。
-tc tc:指定MPLS Echo请求报文的流量等级。tc为流量等级,取值范围为0~255。缺省值为0。
EVPN VPWS over SRv6组网中,本端PE设备与远端PE设备间通过SRv6 PW传输数据报文。当PE间出现丢包或断流现象时,可通过本命令检测本端PE到远端PE间SRv6 PW的单向连通性。
# 检测交叉连接组xcga内本端service ID为2、远端service ID为1的SRv6 PW的单向连通性。
<Sysname> ping evpn vpws srv6 xconnect-group xcga 2 1
Ping a remote PE over SRv6 through a PW with local service ID 2 and remote service ID 1 in cross-connect group xcga: 100 data bytes.
100 bytes from 111::100: sequence=1 time=2 ms
100 bytes from 111::100: sequence=2 time=2 ms
100 bytes from 111::100: sequence=3 time=1 ms
100 bytes from 111::100: sequence=4 time=1 ms
100 bytes from 111::100: sequence=5 time=2 ms
--- Ping statistics for the PW with local ID 2 and remote ID 1 ---
5 packets transmitted,5 packets received,0.00% packets lost
表1-11 ping evpn vpws srv6命令显示信息描述表
检测交叉连接组xcga内本端service ID为2、远端service ID为1的SRv6 PW的连通性,每个MPLS Echo请求t报文中的数据为100字节
100 bytes from 111::100: sequence=5 time=1 ms
收到IP地址为111::100的设备回复的回显应答报文,包括:
·     sequence:表示报文序号,用来判断报文是否有分组丢失、失序或重复
·     time:表示响应时间
Ping操作中收发数据的统计结果
发送的MPLS Echo请求的报文数
5 packets received
收到的MPLS Echo应答的报文数
0.0% packets lost
·     tracert evpn vpws srv6
reset l2vpn statistics srv6-pw命令用来清除SRv6 PW的报文统计信息。
reset l2vpn statistics srv6-pw [ vsi vsi-name [ peer ipv6-address ] | xconnect-group group-name [ connection connection-name ] ]
vsi vsi-name:清除指定VSI内的SRv6 PW报文统计信息。vsi-name表示VSI实例的名称,为1~31个字符的字符串,区分大小写。
peer ipv6-address:清除本地与指定远端PE之间SRv6 PW的出方向报文统计信息。ipv6-address为远端PE的IPv6地址。如果不指定该参数,则清除指定VSI内所有SRv6 PW的统计信息。
xconnect-group group-name:清除指定交叉连接组内SRv6 PW的报文统计信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。
connection connection-name:清除指定SRv6 PW的报文统计信息。connection-name为交叉连接组内交叉连接的名称,为1~20个字符的字符串,区分大小写。如果不指定该参数,则清除指定交叉连接组内所有SRv6 PW的报文统计信息。
当存在主备SRv6 PW时,执行本命令会同时清除主SRv6 PW和备SRv6 PW的报文统计信息。
执行本命令时,如果没有指定任何参数,则清除所有SRv6 PW的报文统计信息。
# 清除所有SRv6 PW的报文统计信息。
<Sysname> reset l2vpn statistics srv6-pw
·     statistics enable
segment-routing ipv6命令用来配置路由迭代方式。
undo segment-routing ipv6命令用来恢复缺省情况。
segment-routing ipv6 { best-effort | traffic-engineering | traffic-engineering best-effort }
BGP路由不会根据自身携带的SRv6 SID进行迭代。
交叉连接组EVPN实例视图
VSI实例下的EVPN实例视图
交叉连接静态SRv6视图
best-effort:采用SRv6 BE方式进行路由迭代。
traffic-engineering:采用SRv6 TE方式进行路由迭代。
traffic-engineering best-effort:采用SRv6 TE和SRv6 BE混合方式进行路由迭代。
EVPN VPWS over SRv6和EVPN VPLS over SRv6网络中,PE为用户侧流量封装End.DX2 SID、End.DT2M SID或End.DT2U SID后,可以根据如下路由迭代方式为封装后的报文查找转发路径:
·     SRv6 BE方式:又称为基于SID的转发方式。该方式根据封装的End.DX2 SID、End.DT2M SID或End.DT2U SID查找IPv6路由表进行转发。
·     SRv6 TE方式:又称为基于下一跳的转发方式。该方式根据路由的下一跳地址从隧道策略中查找匹配的SRv6 TE Policy,为报文添加携带End.DX2 SID(或End.DT2M SID、End.DT2U SID)和SRv6 TE Policy SID列表的SRH头后,通过SRv6 TE Policy转发该报文。
·     SRv6 TE和SRv6 BE混合方式:优先通过SRv6 TE方式选择转发路径;如果SRv6 TE方式未找到可用的SRv6 TE Policy,则通过SRv6 BE方式选择转发路径。
# 在VSI实例下的EVPN实例视图下,配置采用SRv6 BE方式进行路由迭代。
[Sysname] vsi aaa
[Sysname-vsi-aaa-mpls-srv6] segment-routing ipv6 best-effort
# 在交叉连接组EVPN实例视图下,配置采用SRv6 BE方式进行路由迭代。
[Sysname-xcg-vpna-evpn-mpls] segment-routing ipv6 best-effort
segment-routing ipv6 apply-sid all-nexthop命令用来配置根据下一跳为公网路由分配End.DX4/End.DX6 SID。
undo segment-routing ipv6 apply-sid all-nexthop命令用来恢复缺省情况。
PE为BGP公网IPv4/IPv6路由分配End.DT4 SID、End.DT6 SID或End.DT46 SID。
BGP IPv4单播地址族视图
BGP IPv6单播地址族视图
在公网IPv4/IPv6 over SRv6场景中,缺省情况下,PE为所有公网路由都分配相同的SID。PE对接收到的报文解封装后,会在SID所标识的公网路由表中查表转发该报文。如果希望转发过程不查路由表,直接快速地将报文转发给下一跳,则可以配置本命令,使BGP为公网IPv4/IPv6路由的每一个下一跳分别分配不同的End.DX4/End.DX6 SID,PE对接收到的报文解封装后,根据End.DX4/End.DX6 SID查找到对应的出接口和下一跳,通过该出接口将报文转发给下一跳。
在执行该命令前,需要在BGP IPv4/IPv6单播地址族视图下先执行segment-routing ipv6 locator命令指定引用Locator,否则将无法动态分配End.DX4/End.DX6 SID。
在同一视图下,该命令与segment-routing ipv6 apply-sid specify-nexthop命令互斥,不能同时执行这两条命令。
动态SID资源不足,导致BGP私网路由无法按照下一跳分配动态SID,且未静态配置End.DX4/End.DX6 SID时,会按照VPN实例分配End.DT4 SID、End.DT6 SID或End.DT46 SID。
本命令不会为直连路由分配End.DX4 SID或者End.DX6 SID。
# 在BGP IPv6单播地址族视图下,配置公网路由按照下一跳为每一个下一跳地址分别分配一个End.DX6 SID。
[Sysname] bgp 100
[Sysname-bgp-default-ipv6] segment-routing ipv6 apply-sid all-nexthop
·     segment-routing ipv6 apply-sid specify-nexthop
·     segment-routing ipv6 locator
segment-routing ipv6 apply-sid all-nexthop命令用来配置根据下一跳为私网路由分配End.DX4/End.DX6 SID。
segment-routing ipv6 apply-sid all-nexthop [ evpn ]
undo segment-routing ipv6 apply-sid all-nexthop [ evpn ]
根据VPN实例为私网路由分配SID。
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
evpn:配置私网路由转变为EVPN路由时,根据下一跳分配SID。如果不指定本参数,则表示私网路由转变为VPNv4/VPNv6路由时,根据下一跳分配SID。
在MPLS L3VPN over SRv6、EVPN L3VPN over SRv6场景中,如果配置了End.DT4 SID、End.DT6 SID或End.DT46 SID,则特定VPN实例下的BGP私网路由均分配相同SID,PE对接收到的报文解封装后,会在SID标识的VPN实例内查找路由表,将报文转发给CE。如果希望不查路由表,直接快速地将VPN实例报文转发给下一跳,则可以配置本命令基于下一跳地址为所有的BGP私网路由下一跳分配End.DX4/End.DX6 SID,PE根据End.DX4/End.DX6 SID查找到对应的出接口和下一跳,直接通过该出接口将报文转发给下一跳。
在执行该命令前需要在BGP-VPN IPv4/IPv6单播地址族视图下先执行segment-routing ipv6 locator指定引用locator,否则将无法动态分配End.DX4/End.DX6 SID。
动态SID资源不足,导致BGP私网路由无法按照下一跳分配动态SID时,会按照VPN实例分配End.DT4 SID、End.DT6 SID或End.DT46 SID。
# 在BGP-VPN IPv4单播地址族视图下,配置根据下一跳为私网路由分配SID。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 apply-sid all-nexthop
segment-routing ipv6 apply-sid specify-nexthop命令用来配置BGP公网IPv4/IPv6路由按照指定下一跳分配End.DX4/End.DX6 SID,创建并进入BGP IPv4/BGP IPv6单播地址族Segment Routing指定下一跳视图。如果视图已经存在,则直接进入BGP IPv4/BGP IPv6单播地址族Segment Routing指定下一跳视图。
undo segment-routing ipv6 apply-sid specify-nexthop命令用来恢复缺省情况。
BGP IPv4单播地址族视图
BGP IPv6单播地址族视图
在公网IPv4/IPv6 over SRv6场景中,缺省情况下,PE为所有公网路由都分配相同的SID。PE对接收到的报文解封装后,会在SID所标识的公网路由表中查表转发该报文。如果希望不查路由表,直接快速地将报文转发给下一跳,则可以配置本命令基于下一跳地址为BGP公网路由分配End.DX4/End.DX6 SID,并配置nexthop interface命令为下一跳地址指定出接口,以便PE根据End.DX4/End.DX6 SID查找到对应的出接口和下一跳,直接通过该出接口将报文转发给下一跳。
在执行该命令前,需要在BGP IPv4/BGP IPv6单播地址族视图下先执行segment-routing ipv6 locator命令指定引用Locator,否则将无法动态分配End.DX4/End.DX6 SID。
在同一视图下,该命令与segment-routing ipv6 apply-sid all-nexthop命令互斥,不能同时执行这两条命令。
# 在BGP IPv6单播地址族视图下,配置BGP公网IPv6路由按照指定下一跳分配End.DX6 SID。创建并进入BGP IPv6单播地址族Segment Routing指定下一跳视图。
[Sysname] bgp 100
·     nexthop interface
·     segment-routing ipv6 apply-sid all-nexthop
segment-routing ipv6 apply-sid specify-nexthop命令用来配置BGP私网IPv4/IPv6路由按照指定下一跳分配End.DX4/End.DX6 SID,创建并进入BGP-VPN IPv4/IPv6单播地址族Segment Routing指定下一跳视图。如果视图已经存在,则直接进入BGP-VPN IPv4/IPv6单播地址族Segment Routing指定下一跳视图。
segment-routing ipv6 apply-sid specify-nexthop [ evpn ]
undo segment-routing ipv6 apply-sid specify-nexthop [ evpn ]
按照VPN实例为BGP私网IPv4/IPv6路由分配End.DT4 SID、End.DT6 SID或End.DT46 SID。
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
evpn:配置在EVPN L3VPN over SRv6组网中,私网路由转变为EVPN路由时按照指定下一跳为私网路由分配End.DX4或End.DX6 SID。如果未指定本参数,表示在MPLS L3VPN over SRv6组网中,私网路由转变为VPNv4/VPNv6路由时按照指定下一跳为私网路由分配SID。
在MPLS L3VPN over SRv6和EVPN L3VPN over SRv6场景中,缺省情况下,PE根据VPN实例为BGP私网路由分配相同SID。PE对接收到的报文解封装后,会在SID标识的VPN实例内查找路由表,将报文转发给CE。如果希望不查路由表,直接快速地将VPN实例报文转发给下一跳,则可以配置本命令基于下一跳地址为BGP私网路由分配End.DX4/End.DX6 SID,并配置nexthop interface命令为下一跳地址指定出接口,以便PE根据End.DX4/End.DX6 SID查找到对应的出接口和下一跳,直接通过该出接口将报文转发给下一跳。
在执行该命令前,需要在BGP-VPN IPv4/IPv6单播地址族视图下先执行segment-routing ipv6 locator命令指定引用Locator,否则将无法动态分配End.DX4/End.DX6 SID。
在同一视图下,该命令与segment-routing ipv6 apply-sid all-nexthop互斥,不能同时执行这两条命令。
# 在BGP-VPN IPv4单播地址族视图下,配置BGP私网IPv4路由按照指定下一跳分配End.DX4 SID,创建并进入BGP-VPN IPv4单播地址族Segment Routing指定下一跳视图。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4 unicast
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 locator aaa
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 apply-sid specify-nexthop
[Sysname-bgp-default-sid-np-ipv4]
·     nexthop interface
segment-routing ipv6 best-effort命令用来配置路由迭代到SRv6-BE隧道。
undo segment-routing ipv6 best-effort命令用来恢复缺省情况。
BGP-VPN IPv4单播地址族视图/BGP-VPN IPv6单播地址族视图:
segment-routing ipv6 best-effort [ evpn ]
undo segment-routing ipv6 best-effort [ evpn ]
BGP EVPN地址族视图:
segment-routing ipv6 best-effort evpn
undo segment-routing ipv6 best-effort evpn
BGP IPv4单播地址族视图/BGP IPv6单播地址族视图:
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP VPNv4地址族视图
BGP VPNv6地址族视图
BGP EVPN地址族视图
evpn:配置EVPN路由迭代到SRv6-BE隧道。如果未指定本参数,则VPNv4/VPNv6路由迭代到SRv6-BE隧道。
在IP L3VPN over SRv6、EVPN L3VPN over SRv6和公网IP over SRv6组网场景中,配置本命令后,PE设备间可以根据路由迭代SRv6-BE隧道转发报文,即根据封装的SRv6 SID查找IPv6路由表进行转发。
不同组网环境下,需要在不同地址族下配置本命令:
·     BGP-VPN IPv4单播地址族视图/BGP-VPN IPv6单播地址族视图:IPv4/IPv6 L3VPN over SRv6场景和IPv4/IPv6 EVPN L3VPN over SRv6场景。
·     BGP IPv4单播地址族视图/BGP IPv6单播地址族视图:公网IPv4/IPv6 over SRv6场景。
·     BGP VPNv4地址族视图/BGP VPNv6地址族视图/BGP EVPN地址族视图:Option B跨域VPN场景。
本命令与segment-routing ipv6 traffic-engineering命令互斥。
# 在BGP-VPN IPv4单播地址族视图下,配置私网路由根据路由携带的SID属性进行迭代。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort
# 在BGP-VPN IPv6单播地址族视图下,配置私网路由根据VPNv6路由携带的SID属性进行迭代。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv6
[Sysname-bgp-default-ipv6-vpn1] segment-routing ipv6 best-effort
·     segment-routing ipv6 traffic-engineering
segment-routing ipv6 locator命令用来配置私网路由转变为VPNv4/VPNv6/EVPN/BGP IPv4单播/BGP IPv6单播路由时携带SID属性。
undo segment-routing ipv6 locator命令用来恢复缺省情况。
segment-routing ipv6 locator locator-name [ evpn ] [ auto-sid-disable ]
undo segment-routing ipv6 locator [ evpn ]
segment-routing ipv6 locator locator-name [ auto-sid-disable ]
BGP EVPN地址族视图:
segment-routing ipv6 locator locator-name evpn [ auto-sid-disable ]
undo segment-routing ipv6 locator evpn
私网路由转变为VPNv4/VPNv6/EVPN/BGP IPv4单播/BGP IPv6单播路由时不携带SID属性。
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP VPNv4地址族视图
BGP VPNv6地址族视图
BGP EVPN地址族视图
BGP IPv4单播地址族视图
BGP IPv6单播地址族视图
locator-name:指定Locator段名称,为1~31个字符的字符串,区分大小写。
evpn:配置私网路由转变为EVPN路由时携带SID属性。如果不指定本参数,则表示指定私网路由转变为VPNv4/VPNv6路由时携带SID属性。
auto-sid-disable:不允许动态分配SRv6 SID。如果未指定本参数,则表示允许动态分配SRv6 SID。未指定本参数时,如果已经配置了静态SRv6 SID,则优先使用静态SRv6 SID;没有静态SRv6 SID时,则动态分配SRv6 SID。
在SRv6 VPN组网场景中,通过BGP Update消息发布私网路由时,需要携带SRv6 SID。配置本功能后,PE设备将为该VPN实例内的私网路由转变为VPNv4/VPNv6/EVPN/BGP IPv4单播/BGP IPv6单播路由时添加指定的SRv6 SID,通过该SRv6 SID标识该VPN实例的报文。
执行本命令前,指定的Locator必须存在。
# 在BGP-VPN IPv4单播地址族视图下,配置私网路由转变为VPNv4路由时携带SID属性。
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc
# 在BGP-VPN IPv6单播地址族视图下,配置私网路由转变为VPNv6路由时携带SID属性。
[Sysname] bgp 100
[Sysname-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc
# 在BGP-VPN IPv6单播地址族视图下,配置私网路由转变为EVPN路由时携带SID属性。
[Sysname] bgp 100
[Sysname-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc evpn
·     locator
·     opcode
segment-routing ipv6 locator命令用来配置交叉连接或VSI引用的Locator段。
交叉连接视图:
segment-routing ipv6 locator locator-name [ backup-locator backup-locator-name | dx2l-locator dx2l-locator-name ] * [ auto-sid-disable ]
VSI实例下的EVPN实例视图:
segment-routing ipv6 locator locator-name [ dt2u-locator dt2u-locator-name ] [ dt2ul-locator dt2ul-locator-name ] [ dx2-locator dx2-locator-name ] [ dx2l-locator dx2l-locator-name ] [ auto-sid-disable ]
交叉连接视图
VSI实例下的EVPN实例视图
未指定交叉连接和VSI引用的Locator段。
locator-name:Locator段名称,为1~31个字符的字符串,区分大小写。
dx2l-locator dx2l-locator-name:指定用于申请End.DX2L类型SRv6 SID的Locator段。dx2l-locator-name表示Locator段名称,为1~31个字符的字符串,区分大小写。
dt2u-locator dt2u-locator-name:指定用于申请End.DT2U类型SRv6 SID的Locator段。dt2u-locator-name表示Locator段名称,为1~31个字符的字符串,区分大小写。
dt2ul-locator dt2ul-locator-name:指定用于申请End.DT2UL类型SRv6 SID的Locator段。dt2ul-locator-name表示Locator段名称,为1~31个字符的字符串,区分大小写。
dx2-locator dx2-locator-name:指定用于申请End.DX2类型SRv6 SID的Locator段。dx2-locator-name表示Locator段名称,为1~31个字符的字符串,区分大小写。
auto-sid-disable:禁止动态分配SID,即仅支持静态配置SID,如果本命令指定的Locator段下未配置Opcode,则SID申请失败。未指定本参数时,表示支持动态分配SID,即SID既可以静态配置,也可以动态分配,且静态配置的优先级高于动态分配。
backup-locator backup-locator-name:指定用于申请End.DX2类型备份SRv6 SID的Locator段。backup-locator-name表示Locator段名称,为1~31个字符的字符串,区分大小写。
执行本命令后,交叉连接或VSI将从指定的Locator段中申请SRv6 SID:
·     交叉连接视图下,执行本命令时如果指定了dx2l-locator dx2l-locator-name参数,则locator-name用来申请End.DX2类型SRv6 SID,dx2l-locator-name用来申请End.DX2L类型SRv6 SID;如果没有指定dx2l-locator dx2l-locator-name参数,则locator-name同时用来申请End.DX2和End.DX2L类型SRv6 SID。如果指定了backup-locator backup-locator-name参数,则backup-locator-name用来申请End.DX2类型备份SRv6 SID。
·     在VSI实例下的EVPN实例视图下,执行本命令时如果没有指定dt2u-locator dt2u-locator-namedt2ul-locator dt2ul-locator-namedx2-locator dx2-locator-namedx2l-locator dx2l-locator-name参数,则locator-name同时用来申请End.DT2M类型、End.DT2U类型、End.DT2UL类型、End.DX2类型和End.DX2L类型SRv6 SID;如果指定了dt2u-locator dt2u-locator-namedt2ul-locator dt2ul-locator-namedx2-locator dx2-locator-namedx2l-locator dx2l-locator-name参数,则该Locator用来申请End.DT2U类型、End.DT2UL类型、End.DX2类型或End.DX2L类型SRv6 SID,locator-name用来申请其余类型的SRv6 SID。
# 配置VSI实例aaa用于申请End.DT2M类型、End.DT2UL类型、End.DX2类型和End.DX2L类型SRv6 SID的Locator段为test1,用于申请End.DT2U类型SRv6 SID的Locator段为test2。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-srv6] segment-routing ipv6 locator test1 dt2u-locator test2
# 配置交叉连接组bbb下的交叉连接aaa引用Locator段test3,通过该Locator段申请End.DX2类型和End.DX2L类型SRv6 SID,且仅支持静态配置SID。
[Sysname] xconnect-group bbb
[Sysname-xcg-bbb] evpn encapsulation srv6
[Sysname-xcg-bbb-evpn-srv6] quit
[Sysname-xcg-bbb] connection aaa
[Sysname-xcg-bbb-connection-aaa] segment-routing ipv6 locator test3 auto-sid-disable
segment-routing ipv6 traffic-engineering命令用来配置路由迭代到SRv6 TE Policy隧道。
undo segment-routing ipv6 traffic-engineering命令用来恢复缺省情况。
segment-routing ipv6 traffic-engineering [ best-effort | best-effort-backup ] [ evpn ]
undo segment-routing ipv6 traffic-engineering [ best-effort | best-effort-backup ] [ evpn ]
segment-routing ipv6 traffic-engineering [ best-effort ]
undo segment-routing ipv6 traffic-engineering [ best-effort ]
BGP EVPN地址族视图:
segment-routing ipv6 traffic-engineering [ best-effort ] evpn
undo segment-routing ipv6 traffic-engineering [ best-effort ] evpn
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
BGP IPv4单播地址族视图
BGP IPv6单播地址族视图
BGP VPNv4地址族视图
BGP VPNv6地址族视图
BGP EVPN地址族视图
best-effort:当SRv6 TE Policy隧道故障时L3VPN业务会根据SRv6-BE转发。如果未指定本参数,当SRv6 TE Policy隧道故障时,L3VPN业务会根据报文的目的IP地址查找路由表转发。
best-effort-backup:SRv6-TE路径(SRv6-TE选择的路径)和SRv6-BE路径(SRv6-BE选择的路径)形成FRR。其中SRv6-TE路径为主路径,SRv6-BE路径为备份路径。业务流量优先通过SRv6-TE路径转发。当SRv6-TE路径故障或者不存在SRv6-TE路径时,可以将业务流量快速切换到SRv6-BE备份路径转发,以实现快速保护,避免流量长时间丢失。如果SRv6 TE Policy的源节点和目的节点之间存在多条SRv6-BE路径,则在多条SRv6-BE路径中选择下一跳地址最小的SRv6-BE路径作为备份路径。
evpn:配置EVPN路由迭代到SRv6 TE Policy隧道。如果未指定本参数,则VPNv4/VPNv6路由迭代到SRv6 TE Policy隧道。
配置本命令后,设备可以根据路由迭代到SRv6 TE Policy隧道,通过SRv6 TE Policy隧道转发流量。
配置本命令时,可以指定best-effortbest-effort-backup参数来提高报文转发的可靠性。指定该参数后,L3VPN业务报文的转发方式为:
(1)     L3VPN业务报文通过SRv6 TE Policy隧道转发。
(2)     当SRv6 TE Policy隧道故障时,L3VPN业务根据SRv6-BE转发。
¡     如果指定best-effort参数,则根据封装的SRv6 SID查找IPv6路由表,通过SRv6-BE转发。
¡     如果指定best-effort-backup参数,则快速切换到SRv6-BE备份路径转发。
(3)     如果根据报文的SID查找路由表转发失败,再根据报文的目的IP地址查找路由表转发。
(4)     如果依旧失败,则丢弃报文。
如果未指定best-effortbest-effort-backup参数,则当SRv6 TE Policy隧道故障时,用户业务会根据报文的目的IP地址查找路由表转发。
本命令与segment-routing ipv6 best-effort命令互斥。
# 在BGP IPv4单播地址族视图下,配置路由迭代到SRv6 TE Policy隧道。
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4
[Sysname-bgp-default-ipv4] segment-routing ipv6 traffic-engineering
·     segment-routing ipv6 best-effort
srv6-mpls-interworking enable命令用来开启SRv6网络与MPLS网络互通功能。
undo srv6-mpls-interworking enable命令用来关闭SRv6网络与MPLS网络互通功能。
SRv6网络与MPLS网络互操作功能处于关闭状态。
BGP VPNv4地址族视图
BGP VPNv6地址族视图
BGP EVPN地址族视图
在Option B跨域VPN场景中,如果一个AS内部署MPLS网络,另一个AS内部署SRv6网络,为了实现跨域互通,需要在部署SRv6网络的AS域的ASBR上开启本功能,以实现End.T SID的分配,并建立End.T SID与MPLS标签的关联。
开启本功能后,ASBR会按照FEC(目的IPv4地址/掩码或目的IPv6地址/前缀长度)分配End.T SID,并通过IGP协议通告给网络中的其他SRv6节点。End.T SID对应的转发动作为根据End.T SID查找IPv6 FIB表转发报文。
报文从SRv6网络转发到MPLS网络时,在头节点封装End.T SID,然后将报文转发到SRv6网络ASBR。ASBR收到该报文时,根据报文中的End.T SID查找IPv6 FIB表,迭代到指定LSP隧道进行转发。
报文从MPLS网络转发到SRv6网络时,SRv6网络的ASBR收到该报文,会查找标签转发表进行转发,出标签为SRv6网络的End.DT4 SID/End.DT6 SID/End.DT46 SID/End.DX4 SID/End.DX6 SID。SRv6网络的ASBR为报文封装End.DT4 SID/End.DT6 SID/End.DT46 SID/End.DX4 SID/End.DX6 SID后,根据SRv6-BE或SRv6-TE方式进行转发。
# 开启SRv6网络与MPLS网络互通功能。
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] srv6-mpls-interworking enable
static-srv6 local-service-id remote-service-id命令用来指定采用静态方式建立SRv6 PW,并进入交叉连接静态SRv6视图。
undo static-srv6 local-service-id remote-service-id命令用来恢复缺省情况。
static-srv6 local-service-id local-service-id remote-service-id remote-service-id [ tunnel-policy tunnel-policy-name ]
undo static-srv6 local-service-id local-service-id remote-service-id remote-service-id
未指定与远端PE建立SRv6 PW的方式。
交叉连接视图
local-service-id local-service-id:本端的Service ID,取值范围为1~16777215。
remote-service-id remote-service-id:远端的Service ID,取值范围为1~16777215。
tunnel-policy tunnel-policy-name:指定SRv6 PW引用的隧道策略。tunnel-policy-name表示隧道策略名,为1~126个字符的字符串,区分大小写。如果不指定本参数,则使用缺省的隧道策略。
本命令用来指定采用静态方式建立SRv6 PW,并进入交叉连接静态SRv6视图,在该视图下执行peer命令可以配置静态SRv6 PW。
本命令与交叉连接视图下的peer命令互斥。
# 进入交叉连接静态SRv6视图,指定本端的Service ID为1、远端的Service ID为2。
statistics enable命令用来开启SRv6 PW的报文统计功能。
undo statistics enable命令用来关闭SRv6 PW的报文统计功能。
statistics enable
SRv6 PW的报文统计功能处于关闭状态。
交叉连接下的EVPN PW视图
VSI实例下的EVPN实例视图
EVPN VPWS over SRv6组网中,在交叉连接下的EVPN PW视图执行本命令后,会开启当前SRv6 PW的报文统计功能,通过display l2vpn peer srv6 verbose命令可以查看SRv6 PW的报文统计信息,通过reset l2vpn statistics srv6-pw命令可以清除统计信息。
交叉连接组的EVPN实例采用MPLS封装时,在属于该交叉连接组的交叉连接下为EVPN PW开启统计功能后,该功能不生效,即目前,MPLS封装的交叉连接组EVPN实例(EVPN VPWS组网)不支持PW统计功能。
EVPN VPLS over SRv6组网中,在VSI实例下的EVPN实例视图执行本命令后,会开启EVPN实例下所有SRv6 PW的统计功能,通过display l2vpn statistics srv6-pw inbound命令可以查看所有SRv6 PW的入方向报文统计信息,通过display l2vpn peer srv6 verbose命令可以查看每条SRv6 PW的出方向报文统计信息,通过reset l2vpn statistics srv6-pw命令可以清除统计信息。
目前,仅VSI实例下SRv6封装的EVPN实例支持本命令。
# 在EVPN VPWS over SRv6组网中,开启SRv6 PW的报文统计功能。
[Sysname] xconnect-group vpws
[Sysname-xcg-vpws] connection aa
[Sysname-xcg-vpws-aa] evpn local-service-id 2 remote-service-id 4
[Sysname-xcg-vpws-aa-2-4] statistics enable
# 在EVPN VPLS over SRv6组网中,开启EVPN实例下所有SRv6 PW的报文统计功能。
[Sysname] vsi vpna
[Sysname-vsi-vpna-evpn-srv6] stastics enable
·     display l2vpn peer srv6 verbose
·     display l2vpn statistics srv6-pw inbound
tracert evpn vpls srv6命令用来查看EVPN VPLS over SRv6组网中本端PE到指定主机连接的远端PE间单向SRv6 PW所经过的路径,并根据应答信息对错误点进行定位。
tracert evpn vpls srv6 vsi vsi-name mac mac-address [ -a source-ip | -h hop-limit | -r reply-mode | -t time-out | -tc tc ] *
vsi vsi-name:检测与指定VSI关联的SRv6 PW的连通性。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
-a source-ip:指定发送的MPLS Echo请求报文的源地址。source-ip为源IPv6地址。如果未指定本参数,则MPLS Echo请求报文的源地址为报文出接口的地址。
-tc tc:指定MPLS Echo应答报文的流量等级。tc为流量等级,取值范围为0~255,缺省值为0。
EVPN VPLS over SRv6组网中,本端PE设备与远端PE设备间通过SRv6 PW传输数据报文。当PE间出现丢包或断流现象时,可通过本命令查看本端PE到指定主机连接的远端PE间单向SRv6 PW所经过的路径,并根据应答信息对错误点进行定位。
# 对VSI vpna内本端PE到MAC地址为2-2-2的主机连接的远端PE之间的SRv6 PW发起tracert检测。
<Sysname> tracert evpn vpls srv6 vsi vpna mac 2-2-2
Trace route to a remote PE in VSI vpna over SRv6 by reaching remote-MAC 0002-0002-0002.
  Hop  Wait time     Type       Replier
  0    0 ms           Ingress
  1    4 ms           Transit    1111::2
  2    5 ms           Transit    2222::2
  3    6 ms           Transit    3333::2
  4    6 ms           Egress     4444::2
表1-12 tracert evpn vpls srv6命令显示信息描述表
查看VSI vpna内从当前设备到MAC地址为0002-0002-0002的主机连接的远端PE间SRv6 PW所经过的路径
按组合键Ctrl+C可以终止tracert操作
Hop
跳数
Wait time
接收到应答的时间,单位为毫秒
节点类型,取值包括:
·     Ingress:入节点
·     Transit:中间节点
·     Egress:出节点
Replier
节点的IPv6地址
Request time out
若在等待响应的超时时间内没有收到MPLS Echo应答报文,则显示本字段
·     ping evpn vpls srv6
tracert evpn vpws srv6命令用来查看EVPN VPWS over SRv6组网中本端PE到指定主机连接的远端PE间单向SRv6 PW所经过的路径,并根据应答信息对错误点进行定位。
tracert evpn vpws srv6 xconnect-group group-name local-service-id  remote-service-id [ -a source-ip | -h hop-limit | -r reply-mode | -t time-out | -tc tc ] *
-tc tc:指定ICMPv6 echo reply报文的流量等级。tc为流量等级,取值范围为0~255。缺省值为0。
EVPN VPWS over SRv6组网中,本端PE设备与远端PE设备间通过SRv6 PW传输数据报文。当PE间出现丢包或断流现象时,可通过本命令查看本端PE到远端PE间单向的SRv6 PW所经过的路径,并根据应答信息对错误点进行定位。
# 对交叉连接组xcga内本端service ID为2,远端service ID为1的SRv6 PW发起tracert检测。
<Sysname> tracert evpn vpws srv6 xconnect-group xcga 1 2
Trace route to a remote PE over SRv6 through a PW with local service ID 2 and remote service ID 1 in cross-connect group xcga.
  0     0 ms            Ingress
  4     6 ms            Egress     3333::2
表1-13 tracert evpn vpws srv6命令显示信息描述表
查看交叉连接组xcga内本端service ID为2、远端service ID为1的SRv6 PW所经过的路径
Hop
跳数
Wait time
接收到应答的时间,单位为毫秒
路径经过的节点类型,取值包括:
·     Ingress:入节点
·     Transit:中间节点
·     Egress:出节点
Replier
节点的IPv6地址
Request time out
·     ping evpn vpws srv6
unicast-forwarding dx2-based命令用来配置EVPN VPLS over SRv6基于End.DX2 SID和End.DX2L SID转发单播流量。
undo unicast-forwarding dx2-based命令用来恢复缺省情况。
EVPN VPLS over SRv6基于End.DT2U SID和End.DT2UL SID转发单播流量。
VSI实例下的EVPN实例视图
缺省情况下,PE接收到携带End.DT2U SID或End.DT2UL SID的报文后,会在End.DT2U SID或End.DT2UL SID所属的VSI内查找MAC地址表转发该报文。
配置本命令后,PE将为与VSI关联的每个AC分配一个End.DX2 SID或End.DX2L SID,并通过MAC/IP发布路由将该SID通告给远端PE。PE接收到携带本地分配的End.DX2 SID或End.DX2L SID的SRv6报文后,无需查找MAC地址表,直接将解除SRv6封装的报文发送给与该SID关联的AC,从而提高了转发效率。
# 配置EVPN VPLS over SRv6基于End.DX2 SID和End.DX2L SID转发单播流量。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-srv6] unicast-forwarding dx2-based
·     segment-routing ipv6 locator (cross-connect view and VSI EVPN instance view)
