03-接口管理命令参考
01-以太网接口命令
本章节下载: 01-以太网接口命令  (738.75 KB)
01-以太网接口命令
1 以太网接口
1.1 以太网接口通用配置命令
1.1.1 dampening
1.1.2 display ethernet statistics
1.1.3 display interface
1.1.4 display link-flap protection
1.1.5 display link-state-change statistics interface
1.1.6 display packet-drop
1.1.7 display lbn-group status
1.1.8 duplex
1.1.9 flow-control
1.1.10 flow-control receive enable
1.1.11 flow-interval
1.1.12 group-member interface
1.1.13 ifmonitor crc-error
1.1.14 ifmonitor input-error
1.1.15 ifmonitor input-usage
1.1.16 ifmonitor output-error
1.1.17 ifmonitor output-usage
1.1.18 ifmonitor rx-pause
1.1.19 ifmonitor tx-pause
1.1.20 interface
1.1.21 jumboframe enable
1.1.22 link-delay
1.1.23 link-flap protect enable
1.1.24 loadbalance ecmp lbn-group enable
1.1.25 loadbalance link-aggregation lbn-group enable
1.1.26 loopback
1.1.27 port ifmonitor crc-error
1.1.28 port ifmonitor input-error
1.1.29 port ifmonitor input-usage
1.1.30 port ifmonitor output-error
1.1.31 port ifmonitor output-usage
1.1.32 port ifmonitor rx-pause
1.1.33 port ifmonitor sdh-b1-error
1.1.34 port ifmonitor sdh-b2-error
1.1.35 port ifmonitor sdh-error
1.1.36 port ifmonitor tx-pause
1.1.37 port link-flap protect
1.1.38 port link-mode
1.1.39 port up-mode
1.1.40 lbn-group
1.1.41 reset ethernet statistics
1.1.42 reset link-state-change statistics interface
1.1.43 reset packet-drop interface
1.1.44 shutdown all-interfaces
1.1.45 shutdown all-physical-interface
1.1.46 snmp-agent trap enable ifmonitor
1.1.47 speed
1.1.48 sub-interface rate-statistic
1.1.49 traffic-statistic include-interframe
1.1.50 using eighthundredgige
1.1.51 using fourhundredgige
1.1.52 using hundredgige mode 1-channel
1.1.53 using twohundredgige
1.2 二层以太网接口的配置命令
1.2.1 display storm-constrain
1.2.2 storm-constrain
1.2.3 storm-constrain control
1.2.4 storm-constrain enable log
1.2.5 storm-constrain enable trap
1.2.6 storm-constrain interval
1.3 三层以太网接口/子接口的配置命令
1.3.1 mac-address
1.3.2 mtu
1 以太网接口
1.1  以太网接口通用配置命令
1.1.1  dampening
dampening命令用来开启接口的dampening功能。
undo dampening命令用来恢复缺省情况。
undo dampening
接口的dampening功能处于关闭状态。
以太网接口视图
half-life:半衰期,取值范围为1~120,单位为秒,缺省值为54。
reuse:启用值,取值范围为200~20000,缺省值为750,必须要小于suppress的值。
suppress:抑制门限,取值范围为200~20000,缺省值为2000。
max-suppress-time:最大抑制时间,取值范围为1~255,单位为秒,缺省值为半衰期的3倍,即162。
配置本命令时,各参数之间应满足以下关系,请根据该关系来选择参数的取值:
·     最大惩罚值=2(最大抑制时间/半衰期)×启用值,其中最大惩罚值不可配。
·     抑制值的配置值≤最大惩罚值≤抑制值可配的最大值
以太网接口上不能同时配置本命令、link-delay命令和port link-flap protect enable命令。
本命令对使用shutdown命令手动关闭的接口无效。手工shutdown接口时,dampening的惩罚值恢复为初始值0。
对于使能了MSTP的接口不建议使用该命令。
接口在抑制期发生up事件,通过display interface命令等方式查看时,该接口的状态仍然为down。
# 按照缺省值开启接口FourHundredGigE1/0/1的dampening功能。
[Sysname] interface fourhundredgige 1/0/1
[Sysname-FourHundredGigE1/0/1] dampening
# 开启接口FourHundredGigE1/0/1的dampening功能,配置半衰期为2秒,启用值为800,抑制门限为3000,最大抑制时间为5秒。
[Sysname-FourHundredGigE1/0/1] dampening 2 800 3000 5
·     display interface
·     link-delay
·     port link-flap protect enable
display ethernet statistics命令用来显示以太网软件模块收发报文的统计信息。
display ethernet statistics slot slot-number
slot slot-number:指定设备编号,取值只能为1。
# 显示指定slot上的以太网软件模块收发报文的统计信息。
<Sysname> display ethernet statistics slot 1
ETH receive packet statistics:
    Totalnum        : 10447          ETHIINum     : 4459
    SNAPNum         : 0              RAWNum       : 0
    LLCNum          : 0              UnknownNum   : 0
    ForwardNum      : 4459           ARP          : 0
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
ETH receive error statistics:
    NullPoint       : 0              ErrIfindex   : 0
    ErrIfcb         : 0              IfShut       : 0
    ErrAnalyse      : 5988           ErrSrcMAC    : 5988
    ErrHdrLen       : 0
ETH send packet statistics:
    L3OutNum        : 211            VLANOutNum   : 0
    FastOutNum      : 155            L2OutNum     : 0
ETH send error statistics:
    MbufRelayNum    : 0              NullMbuf     : 0
    ErrAdjFwd       : 0              ErrPrepend   : 0
    ErrHdrLen       : 0              ErrPad       : 0
    ErrQoSTrs       : 0              ErrVLANTrs   : 0
    ErrEncap        : 0              ErrTagVLAN   : 0
    IfShut          : 0              IfErr        : 0
表1-1 display ethernet statistics命令显示信息描述表
以太网软件模块接收到的以太网报文的统计信息:
·     Totalnum:接收报文的总个数
·     ETHIINum:接收的ETHII封装格式报文个数
·     SNAPNum:接收的SNAP封装格式报文个数
·     RAWNum:接收的RAW封装格式报文个数
·     ISISNum:接收的ISIS封装格式报文个数‌
·     LLCNum:接收的LLC封装格式报文个数
·     UnknowNum:接收的未知封装格式报文个数
·     ForwardNum:二层转发或上送CPU的报文个数
·     ARP:接收的ARP报文个数
·     MPLS:接收的MPLS报文个数(暂不支持)‌‌
·     ISIS:接收的ISIS报文个数‌
·     ISIS2:接收的ISIS2报文个数‌
·     IP:接收的IP报文个数
·     IPv6:接收的IPv6报文个数
以太网软件模块接收错误的以太网报文的统计信息(可能是包本身包含错误或者是接收动作出错了):
·     NullPoint:接收报文时指针为空的报文的个数
·     ErrIfindex:接收报文时接口索引错误的报文个数
·     ErrIfcb:接收报文时接口控制块错误的报文个数
·     IfShut:接收报文时接口shutdown的报文个数
·     ErrAnalyse:接收报文时报文解析错误的报文个数
·     ErrSrcMAC:接收的包含源MAC地址错误的报文个数
·     ErrHdrLen:接收的包含报文头长度错误的报文个数
以太网软件模块发送的以太网报文的统计信息:
·     L3OutNum:通过三层以太网接口发送的报文总个数‌
·     VLANOutNum:通过VLAN接口发送的报文总个数
·     FastOutNum:快速发送的报文总个数
·     L2OutNum:通过二层以太网接口发送的报文总个数
以太网软件模块发送的错误以太网报文的统计信息:
·     MbufRelayNum:透传发送的报文总个数
·     NullMbuf:发送报文时空指针错误的报文个数
·     ErrAdjFwd:发送报文时邻接表错误的报文个数
·     ErrPrepend:发送报文时扩展错误的报文个数
·     ErrHdrLen:发送的包含报文头长度错误的报文个数
·     ErrPad:发送报文时填充错误的报文个数
·     ErrQoSTrs:发送报文时QoS发送失败的报文个数
·     ErrVLANTrs:发送报文时VLAN发送失败的报文个数
·     ErrEncap:发送报文时封装链路头失败的报文个数
·     ErrTagVLAN:发送报文时封装VLAN TAG失败的报文个数
·     IfShut:发送报文时端口shutdown的报文个数
·     IfErr:发送报文时出接口错误的报文个数
·     reset ethernet statistics
display interface命令用来显示接口的运行状态和相关信息。
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
interface-type:指定接口类型。
interface-number:指定接口编号。
interface-number.subnumber:指定子接口编号。其中interface-number为主接口编号;subnumber为子接口编号,取值范围为1~4094。
description:用来显示用户配置的接口的全部描述信息。如果某接口的描述信息超过27个字符,不指定该参数时,只显示描述信息中的前27个字符,超出部分不显示。
如果不指定接口类型和接口编号,则显示所有接口的信息。
如果仅指定接口类型,则显示所有该类型接口的信息。
# 查看三层以太网接口FourHundredGigE1/0/1的运行状态和相关信息。
<Sysname> display interface fourhundredgige 1/0/1
Line protocol state: DOWN
Description: FourHundredGigE1/0/1 Interface
Bandwidth: 400000000 kbps
Allow jumbo frames to pass
IP packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
IPv6 packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
Media type is not sure, port hardware type is No connector
Port power is 12W
Fec counter uncorr errors: 0, corr errors: 0
Port priority: 2
Flow-control is not enabled
Maximum frame length: 9216
Last link flapping: 6 hours 39 minutes 28 seconds
Last hardware down reason: PHY line side is down
Current system time:2019-01-08 14:50:06
Last time when physical state changed to up:2019-01-08 14:49:45
Last time when physical state changed to down:2019-01-08 14:49:45
 Peak input rate: 0 bytes/sec, at 2013-07-07 16:07:11
 Peak output rate: 0 bytes/sec, at 2013-07-07 16:07:11
 Last 300 seconds input:  0 packets/sec 0 bytes/sec  0%
 Last 300 seconds output: 0 packets/sec 0 bytes/sec  0%
Traffic statistic: Not include Inter-frame Gaps and Preambles
 Input  (total): 0 packets, 0 bytes
          0 unicasts, 0 broadcasts, 0 multicasts, - pauses
 Input  (normal): 0 packets, 0 bytes
 Input: 0 input errors, 0 runts, 0 giants, 0 throttles
          - ignored, - parity errors
 Output  (total): 0 packets, 0 bytes
 Output  (normal): 0 packets, 0 bytes
          - lost carrier, - no carrier
IPv4 traffic statistics:
 Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec
 Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec
 Input: 0 packets, 0 bytes
 Output: 0 packets, 0 bytes
IPv6 traffic statistics:
# 查看二层以太网接口FourHundredGigE1/0/1的运行状态和相关信息。
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Loopback is not set
Port power is 12W
Allow jumbo frame to pass
Broadcast max-ratio: 100%
Unknown-multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
Port priority: 2
Last link flapping: 6 hours 39 minutes 25 seconds
Last clearing of counters:  14:34:09 Tue 11/01/2011
 Peak input rate: 0 bytes/sec, at 2013-07-17 22:06:19
 Peak output rate: 0 bytes/sec, at 2013-07-17 22:06:19
 Last 300 seconds input:  0 packets/sec 0 bytes/sec -%
 Last 300 seconds output:  0 packets/sec 0 bytes/sec -%
          0 CRC, 0 frame, 0 overruns, 0 aborts
          0 ignored, 0 parity errors
 Output: 0 output errors, 0 underruns, 0 buffer failures
          0 lost carrier, 0 no carrier
表1-2 display interface命令显示信息描述表
接口FourHundredGigE1/0/1的相关信息
Current state
接口的物理状态,状态可能为:
·     DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障)
·     DOWN(up-delay):表示该接口下配置port up-delay命令,使该接口延迟UP。
·     DOWN ( Link-Aggregation interface down ):表示该接口所属的聚合接口已经通过shutdown命令被关闭
·     DOWN ( Tunnel-Bundle administratively down ):表示该接口所属的Tunnel-Bundle接口已经通过shutdown命令被关闭
·     DOWN ( Monitor-Link uplink down ):Monitor Link联动而导致接口被关闭
·     Link-Flap DOWN:表示接口被链路震荡保护功能关闭
·     mac-address moving down:由于MAC地址迁移抑制导致接口被关闭
·     MAD ShutDown:当IRF分裂后,处于Recovery状态的IRF会将除了保留接口外的所有接口状态设置为MAD ShutDown
·     OFP DOWN:表示接口开启了OpenFlow的关闭接口功能
·     Storm-Constrain:表示端口上因为未知单播、组播或广播报文中某类报文的流量大于其上限阈值而被关闭
·     STP DOWN:表示接口由于触发了STP BPDU保护而自动关闭
·     M-LAG MAD Shutdown:表示接口在M-LAG系统分裂时被设置为M-LAG MAD DOWN状态
·     UP:该端口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态。其值由链路层经过参数协商决定,取值为:
·     UP:表示数据链路层协议状态为开启
·     UP(spoofing):表示该接口的数据链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立。通常NULL、LoopBack等接口会具有该属性
·     DOWN:表示数据链路层协议状态为关闭
·     DOWN(protocols):表示接口的数据链路层被一个或者多个协议模块关闭。protocols为DLDP、OAM、LAGG、BFD和MACSEC的任意组合:
¡     DLDP:表示由于DLDP模块检测到单通而关闭接口的数据链路层
¡     OAM:表示由于以太网OAM模块检测到远端链路故障而关闭接口的数据链路层
¡     LAGG:表示聚合接口中没有选中的成员端口而关闭接口的数据链路层
¡     BFD:表示由于BFD模块检测到链路故障而关闭接口的数据链路层
¡     MACSEC:表示由于MACSEC模块还未协商成功接口的通信加密参数而关闭接口的数据链路层
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
接口未配置IP地址时,接口的网络协议配置参数:
·     Disabled:不能处理IP报文
·     Enabled:可以处理IP报文
接口IP地址。Type表示地址获取方式,取值如下:
·     Primary:手动配置的主地址
·     Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息
·     DHCP-allocated:通过DHCP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     BOOTP-allocated:通过BOOTP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP”
·     Unnumbered:借用其他接口的IP地址
IPv4报文发送帧格式
hardware address
接口的MAC地址
IPv6报文发送帧格式
Media type is
接口的介质类型
Port power is
接口可支持的最大功率
FEC纠错统计信息,包括未成功纠正错误的数据码值(uncorr errors)和成功纠正错误的数据码值(corr errors)
Port hardware type is
接口的硬件类型
Port priority
接口优先级
Loopback is set internal
以太网接口正在进行对内环回测试,该显示信息与用户的配置有关
Loopback is set external
对以太网接口进行对外环回测试,该显示信息与用户的配置有关
Loopback is not set
接口上未配置环回测试,该显示信息与用户的配置有关
100Gbps-speed mode
接口速率为100Gbps,该显示信息与用户的配置以及链路参数的协商结果有关
200Gbps-speed mode
接口速率为200Gbps,该显示信息与用户的配置以及链路参数的协商结果有关
400Gbps-speed mode
接口速率为400Gbps,该显示信息与用户的配置以及链路参数的协商结果有关
Unknown-speed mode
速率未知,可能因为速率协商失败或者接口物理未连通
full-duplex mode
接口工作在全双工模式,该显示信息与用户的配置以及链路参数的协商结果有关
unknown-duplex mode
未知双工模式,可能因为双工模式协商失败或者接口物理未连通
当用户配置了speed auto时显示该信息
Link speed type is force link
当用户使用speed命令配置了具体的速率时显示该信息
当用户配置了duplex auto时显示该信息
link duplex type is force link
当用户使用duplex命令配置了具体的双工模式时显示该信息,例如full
未配置流量控制功能,该显示信息与用户的配置以及链路参数的协商结果有关
接口允许通过的最大以太网帧长度
允许长帧通过
Broadcast max-
广播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
Multicast max-
组播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
Unicast max-
未知单播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
PVID
接口所在的缺省VLAN ID
MDI type
网线类型,取值为automdix、mdi或mdix,与用户的配置有关
Port link-type
链路类型,取值为access、trunk或hybrid,与用户的配置有关
Tagged VLANs
通过该接口后携带Tag的VLAN
UnTagged VLANs
通过该接口后不再携带Tag的VLAN
VLAN Passing
该接口实际可以通过的VLAN(接口允许通过并且已创建的VLAN)
VLAN permitted
接口允许通过的VLAN报文
Trunk port encapsulation
Trunk接口的封装格式
Last link flapping
接口最近一次物理状态改变到现在的时长。Never表示接口从设备启动后一直处于down状态(没有改变过)
接口最近一次硬件down的原因:
·     PHY line side is down:PHY线路侧down
·     PHY system side is down:PHY系统侧down
·     No optical signal has been received at the optical port:光口未收到光信号
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never)
Current system time
当前系统时间,时间显示格式为YYYY-MM-DD HH:MM:SS
如果配置了时区,当前系统时间后面会追加显示时区的配置,格式为YYYY-MM-DD HH:MM:SS zone-name±HH:MM:SS,其中zone-name为本地时区名称
最近一次接口物理状态变为UP的时刻
如果配置了时区,该时间后面会追加显示时区的配置,格式为YYYY-MM-DD HH:MM:SS zone-name±HH:MM:SS,其中zone-name为本地时区名称
“-”表示接口物理状态没有发生过变化
最近一次接口物理状态变为DOWN的时刻
“-”表示接口物理状态没有发生过变化
端口在最近300秒接收和发送报文的平均速率,单位分别为数据包/秒和字节/秒,以及实际速率和接口带宽的百分比
如果值显示为“-”,则表示不支持该统计项
Input(total):  0 packets, 0 bytes
端口接收报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口接收的单播报文、广播报文、组播报文和PAUSE帧的数量
Input(normal):  0 packets, 0 bytes
端口接收的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口接收的正常单播报文、广播报文、组播报文和PAUSE帧的数量
input errors
端口接收的错误报文的统计值
runts
接收到的超小帧的数量
超小帧是指长度小于64字节、格式正确且包含有效的CRC字段的帧
giants
接收到的超大帧的数量
超大帧是指有效长度大于端口允许通过最大报文长度的帧:
·     对于禁止长帧通过的以太网端口,超大帧是指有效长度大于1518字节(不带VLAN Tag)或大于1522字节(带VLAN Tag报文)的帧
·     对于允许长帧通过的以太网端口,超大帧是指有效长度大于指定最大长帧长度的帧
throttles
接收到的长度为非整数字节的帧的个数
CRC
接收到的CRC校验错误、长度正常的帧的数量
frame
接收到的CRC校验错误、且长度不是整字节数的帧的数量
overruns
当端口的接收速率超过接收队列的处理能力时,导致报文被丢弃
aborts
接收到的非法报文总数,非法报文包括:
·     报文碎片:长度小于64字节(长度可以为整数或非整数)且CRC校验错误的帧
·     jabber帧:有效长度大于端口允许通过的最大报文长度,且CRC校验错误的帧(长度可以为整字节数或非整字节数)。如对于禁止长帧通过的以太网端口,jabber帧是指大于1518(不带VLAN Tag)或1522(带VLAN Tag)字节,且CRC校验错误的帧;对于允许长帧通过的以太网端口,jabber帧是指有效长度大于指定最大长帧长度,且CRC校验错误的帧
·     符号错误帧:报文中至少包含1个错误的符号
·     操作码未知帧:报文是MAC控制帧,但不是Pause帧
·     长度错误帧:报文中802.3长度字段与报文实际长度(46~1500字节)不匹配
ignored
由于端口接收缓冲区不足等原因而丢弃的报文数量
parity errors
接收到的奇偶校验错误的帧的数量
Output(total): 0 packets, 0 bytes
端口发送报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口发送的单播报文、广播报文、组播报文和PAUSE帧的数量
Output(normal): 0 packets, 0 bytes
端口发送的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口发送的正常单播报文、广播报文、组播报文和PAUSE帧的数量
output errors
各种发送错误的报文总数
underruns
当端口的发送速率超过了发送队列的处理能力,导致报文被丢弃,是一种非常少见的硬件异常
buffer failures
由于端口发送缓冲区不足而丢弃的报文数量
aborts
发送失败的报文总数,即报文已经开始发送,但由于各种原因(如冲突)而导致发送失败
deferred
延迟报文的数量,延迟报文是指发送前检测到冲突而被延迟发送的报文
collisions
冲突帧的数量,冲突帧是指在发送过程中检测到冲突的而停止发送的报文
late collisions
延迟冲突帧的数量,延迟冲突帧是指帧的前512 bits已经被发送,由于检测到冲突,该帧被延迟发送
lost carrier
载波丢失,一般适用于串行WAN接口,发送过程中,每丢失一个载波,此计数器加一
no carrier
无载波,一般适用于串行WAN接口,当试图发送帧时,如果没有载波出现,此计数器加一
Peak input rate
接口输入流量的峰值速率大小(单位为bytes/sec)以及峰值产生的时间
Peak output rate
接口输出流量的峰值速率大小(单位为bytes/sec)以及峰值产生的时间
IPv4报文统计信息
IPv6报文统计信息
端口在最近300秒接收报文的平均速率,单位分别为数据包/秒和字节/秒
端口在最近300秒发送报文的平均速率,单位分别为数据包/秒和字节/秒
端口接收报文的统计值,包括报文数、字节数
端口发送报文的统计值,包括报文数、字节数
# 显示所有接口的概要信息。
Protocol: (s) – spoofing
Interface            Link Protocol Primary IP      Description
400GE1/0/1           DOWN DOWN     --
Loop0                UP   UP(s)    2.2.2.9
NULL0                UP   UP(s)    --
Vlan1                UP   DOWN     --
Vlan999              UP   UP       192.168.1.42
Speed: (a) - auto
400GE1/0/2           DOWN auto    A      A    1
400GE1/0/3           UP   auto    F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaa
# 显示接口FourHundredGigE1/0/3的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface fourhundredgige 1/0/3 brief description
Speed: (a) - auto
GE1/0/3              UP   auto    F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# 显示当前物理状态为down的接口的信息以及down的原因。
400GE1/0/1           DOWN Not connected
Vlan2                DOWN Not connected
400GE1/0/2           DOWN Not connected
表1-3 display interface brief命令显示信息描述表
三层模式下(route)接口的概要信息,即三层接口的概要信息
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员通过shutdown命令关闭,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个处于Standby状态的备份接口
Protocol: (s) - spoofing
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会具有该属性
接口名称缩写
Link
接口物理连接状态,取值为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     ADM:表示接口被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态
Protocol
接口数据链路层协议状态,取值为:
·     UP:表示接口的数据链路层协议状态为开启
·     DOWN:表示接口的数据链路层协议状态为关闭
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会取该值
Primary IP
接口主IP地址。取值为“--”时,表示接口尚未配置IP地址
接口的描述信息
Brief information of interfaces in bridge mode:
二层模式下(bridge)的接口概要信息,即二层接口的概要信息
Speed: (a) - auto
如果某接口的Speed属性值为“(a)”,则表示该接口的速率是通过自动协商获取的
如果某接口的Speed属性值为“auto”,则表示该接口的速率是通过自动协商获取的,但协商还未开始
如果某接口的Duplex属性值为“(a)”或者“A”,则表示该接口的Duplex属性是通过自动协商获取的;取值为“H”则表示为半双工;取值为“F”则表示为全双工
当显示为“A”时表示该接口的Duplex属性是通过自动协商获取的,但协商还未开始
接口的链路类型:
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
Speed
接口的速率,单位为bps
Duplex
接口的双工模式,取值为:
·     A:表示双工模式由自动协商结果决定
·     F:表示全双工
·     F(a):表示自由协商的结果为全双工
·     H:表示半双工
·     H(a):表示自由协商的结果为半双工
接口的链路类型:
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
PVID
接口所在的缺省VLAN ID
Cause
接口物理连接状态为down的原因,取值为:
·     Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态
·     DOWN ( Link-Aggregation interface down ):聚合接口被关闭后,该聚合接口的所有成员端口的状态会显示为DOWN,down的原因会显示为DOWN ( Link-Aggregation interface down )
·     DOWN (Loopback detection down):由于环路检测模块检测到环路而自动关闭接口
·     DOWN ( Monitor-Link uplink down ):由于Monitor Link模块检测到上行链路down而自动关闭接口
·     MAD ShutDown:当IRF分裂后,处于Recovery状态的IRF会将除了保留接口外的所有接口状态设置为DOWN,down的原因会显示为MAD ShutDown
·     Not connected:表示没有物理连接(可能没有插网线或者网线故障)
·     STP DOWN:由于触发了STP BPDU保护而自动关闭接口
·     reset counters interface
display link-flap protection命令用来显示接口链路震荡保护功能的相关信息。
display link-flap protection [ interface interface-type [ interface-number ] ]
interface interface-type [ interface-number ]:显示指定接口的链路震荡保护功能信息。其中,interface-type表示接口类型,interface-number表示指定接口编号。如果不指定本参数,则显示所有支持接口的链路震荡保护功能信息。
如果不指定接口编号,则显示所有该类型接口的信息。
# 显示接口链路震荡保护功能的相关信息。
<Sysname> display link-flap protection
Link-flap protection: Enabled
Interface            Link-flap  Status  Interval  Threshold
400GE1/0/1           Enabled    Down    10        5
400GE1/0/2           Disabled   N/A     --        --
表1-4 display link-flap protection命令显示信息描述表
全局链路震荡保护功能,取值为:
·     Enabled:表示全局的链路震荡功能处于开启状态
·     Disabled:表示全局的链路震荡功能处于关闭状态
接口名称缩写
Link-flap
接口链路震荡保护功能,取值为:
·     Enabled:表示接口的链路震荡功能处于开启状态
·     Disabled:表示接口的链路震荡功能处于关闭状态
·     Unconfig:表示接口下未配置链路震荡功能
Status
接口状态,取值为:
·     Down:表示接口因为受到链路震荡保护被关闭
·     N/A:表示接口状态未受到链路震荡保护功能影响
Interval
接口链路震荡检查时间间隔
Threshold
接口链路震荡次数
·     link-flap protect enable
display link-state-change statistics interface命令用来显示接口状态变化的统计信息。
display link-state-change statistics interface [ interface-type [ interface-number ]
如果不指定interface-type和interface-number,则显示所有接口的统计信息;
如果指定interface-type而不指定interface-number,则显示所有该类型接口的统计信息
# 显示所有以太网接口的状态变化统计信息。
<Sysname> display link-state-change statistics interface
Interface              Change-times  Last-change-time     Reset link-state time
                                     Link-flap-begin      Link-flap-end
400GE1/0/1             0             Never                Never
                                     Never                Never
表1-5 display link-state-change statistics interface命令显示信息描述表
接口名称缩写
Change-times
物理状态变换次数
Last-change-time
上一次物理状态变化的时间
清除接口的状态变化统计信息的时间
Link-flap-begin
最近一次检测到的物理频繁震荡的开始时间,没有发生频繁震荡时显示为Never
Link-flap-end
最近一次检测到的物理频繁震荡的结束时间,没有发生频繁震荡时显示为Never
·     reset link-state-change statistics interface
display packet-drop命令用来显示接口丢弃的报文的信息。
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
summary:将所有支持本命令的接口的丢弃报文统计信息累计后再显示。
如果不指定接口类型和接口编号,显示所有支持本命令的接口的丢弃报文的信息。
如果仅指定接口类型,显示该类型所有支持本命令的接口的丢弃报文的信息。
# 显示接口FourHundredGigE1/0/1丢弃报文的信息。
<Sysname> display packet-drop interface fourhundredgige 1/0/1
FourHundredGigE1/0/1:
  Packets dropped due to full GBP or insufficient bandwidth: 301
  Packets dropped due to Fast Filter Processor (FFP): 261
  Packets dropped due to STP non-forwarding state: 0
  Packets dropped due to insufficient data buffer. Input dropped: 0 Output dropped:0
# 将所有支持本命令的接口的丢弃报文统计信息累计后再显示。
<Sysname> display packet-drop summary
All interfaces:
表1-6 display packet-drop命令显示信息描述表
由于芯片缓存满或者带宽不够导致的丢包数
由于数据包被过滤所导致的丢包数
由于STP协议状态为discarding导致的丢包数
由于数据缓冲区不够导致丢包,入方向丢包数:0  出方向丢包数:0
display lbn-group status命令用来显示LBN信息。
# 显示LBN信息。
<System> display lbn-group status
Global lbn-group configuration: Enable
GroupName      GroupIndex    Index       Interface
Leaf1          1             0           FourHundredGigE1/0/2
Leaf           2             0           FourHundredGigE1/0/3
                                         FourHundredGigE1/0/4
表1-7 display rail-group status命令显示信息描述表
LBN的配置状态,取值包括:
·     Disable:表示关闭状态
·     Enable:表示开启状态
GroupName
LBN组名称
GroupIndex
LBN组索引
Index
LBN组内成员索引
LBN组中成员接口的名称
·     group-member interface
1.1.8  duplex
duplex命令用来设置以太网接口的双工模式。
undo duplex命令用来恢复缺省情况。
duplex { auto | full }
undo duplex
以太网接口的双工模式为auto(自协商)状态。
以太网接口视图
auto:接口与对端接口自动协商双工状态。
full:全双工状态,接口在发送数据包的同时可以接收数据包。
# 将以太网接口FourHundredGigE1/0/1接口设置为全双工状态。
[Sysname-FourHundredGigE1/0/1] duplex full
1.1.9  flow-control
flow-control命令用来开启以太网接口的流量控制功能。
undo flow-control命令用来关闭以太网接口流量控制功能。
flow-control
undo flow-control
以太网接口的流量控制功能处于关闭状态。
以太网接口视图
配置flow-control命令后,设备具有发送和接收流量控制报文的能力:
·     当本端发生拥塞时,设备会向对端发送流量控制报文。
·     当本端收到对端的流量控制报文后,会停止报文发送。
只有本端和对端设备都开启了流量控制功能,才能实现对本端以太网接口的流量控制。
# 开启以太网接口FourHundredGigE1/0/1的流量控制功能。
[Sysname-FourHundredGigE1/0/1] flow-control
flow-control receive enable命令用来开启以太网接口的接收流量控制功能。
undo flow-control命令用来关闭以太网接口的接收流量控制功能。
undo flow-control
以太网接口的接收流量控制功能处于关闭状态。
以太网接口视图
配置flow-control receive enable命令后,设备具有接收流量控制报文的能力,但不具有发送流量控制报文的能力。
开启以太网接口的接收流量控制功能后:
·     当设备收到对端的流量控制报文,会停止向对端发送报文。
·     当本端发生拥塞时,设备不能向对端发送流量控制报文。
如果要应对单向网络拥塞的情况,可以在一端配置flow-control receive enable,在对端配置flow-control;如果要求本端和对端网络拥塞都能处理,则两端都必须配置flow-control。
# 使能以太网接口FourHundredGigE1/0/1的接收流量控制功能。
[Sysname-FourHundredGigE1/0/1] flow-control receive enable
【相关配置】
·     flow-control
flow-interval命令用来配置接口统计报文信息的时间间隔。
undo flow-interval命令用来恢复缺省情况。
flow-interval interval
undo flow-interval
接口统计报文信息的时间间隔为300秒。
以太网接口视图
interval:接口统计信息的时间间隔值,取值范围为5~300,单位为秒,步长为5(即取值必须为5的整数倍)。
# 设置以太网接口FourHundredGigE1/0/1的统计信息时间间隔为100秒。
[Sysname-FourHundredGigE1/0/1] flow-interval 100
group-member interface命令用来将指定的接口添加到LBN组中。
undo group-member interface命令用来将指定的接口从当前LBN组中删除。
group-member interface interface-type interface-number [ to interface-type interface-number ]
undo group-member interface interface-type interface-number [ to interface-type interface-number ]
group-member interface interface-type interface-number index index-value
undo group-member interface interface-type interface-number index index-value
LBN组视图
LBN组中未添加接口。
interface-type interface-number:LBN组成员的接口类型和接口编号。
to:表示结束的成员接口名或接口类型和接口编号,若不指定本参数,则表示指定单个成员接口名或接口类型和接口编号。
index index-value:表示为LBN组成员指定索引,通过一定的算法计算流量的入接口和入接口所对应的出接口,从而实现流量负载分担功能。index-value表示索引值,取值范围为0~63。
将接口添加到LBN组时,可以手工指定接口索引,也可以由设备为添加的接口分配索引。手工指定接口索引时,需要使用index参数,一次只能添加一个接口。设备自动为接口分配索引时,不需要使用index参数,一次可以添加一个或多个接口。
当设备自动为接口分配索引时,设备会为命令行配置的第一个端口分配当前最小的索引,随后将配置的剩余端口按端口编号顺序从小到大分配索引。
请保证LBN组成员接口的索引值连续,索引值不连续会导致所对应的流量出接口不连续,负载流量不均衡:
·     不建议手工指定接口的索引值,请在专业人士的指导下手工配置接口的索引值。
·     如果从LBN组中删除接口导致接口索引值不连续,需要重新手动调整索引值使之连续。
本命令仅支持将物理接口添加到LBN组中,且必须是流量进入的接口。
不支持将IRF物理端口添加到LBN组。
同一个接口只能加入一个LBN组。
接口加入LBN组后,display ip load-sharing path命令对该接口不生效。
执行本命令时,如果使用to关键字,则to关键字前后的接口类型必须相同。
通过port link-mode命令切换成员端口的工作模式或者对成员端口进行拆分合并,会将该端口从LBN组中移出。
# 配置将接口400GE1/0/1到400GE1/0/4加入LBN组Leaf1。
[Sysname] lbn-group Leaf1
[Sysname-lbn-group-Leaf1] group-member interface FourHundredGigE1/0/1 to FourHundredGigE1/0/4
# 配置将接口400GE1/0/1加入到LBN组Leaf1,并指定接口的索引为3。
[Sysname-lbn-group-Leaf1] group-member interface FourHundredGigE1/0/1 index 3
ifmonitor crc-error命令用来全局配置CRC错误报文告警参数。
undo ifmonitor crc-error命令用来恢复缺省情况。
ifmonitor crc-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor crc-error slot slot-number
CRC错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定CRC错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定CRC错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定CRC错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的CRC错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因CRC错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的CRC错误报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
开启CRC错误报文告警功能后,当接口处于正常状态,并在指定的时间内接收的CRC错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收的CRC错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置CRC错误报文告警参数。
·     系统视图下的配置对所有接口有效,接口视图下的配置只对当前接口有效。(不支持指定slot的设备)
·     系统视图下的配置对指定slot的所有接口有效,接口视图下的配置只对当前接口有效。(支持指定slot的设备)
·     对于接口来说,优先采用接口视图下的配置,当该接口未进行配置时,才采用系统视图下的配置。
多次执行本命令,最后一次执行的命令生效。
# 配置CRC错误报文告警上限阈值为5000,CRC错误报文告警下限阈值为400,CRC错误报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
·     snmp-agent trap enable ifmonitor
ifmonitor input-error命令用来全局配置入方向错误报文告警参数。
undo ifmonitor input-error命令用来恢复缺省情况。
ifmonitor input-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor input-error slot slot-number
入方向错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接口入方向错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定接口入方向错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定接口入方向错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口入方向错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因入方向错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的入方向错误报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
开启入方向错误报文告警功能后,当接口处于正常状态,并在指定的时间内入方向错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内入方向错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置入方向错误报文告警参数。
# 配置入方向错误报文告警上限阈值为5000,入方向错误报文告警下限阈值为400,入方向错误报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
ifmonitor input-usage命令用来全局配置入方向带宽利用率的告警参数。
undo ifmonitor input-usage命令用来恢复缺省情况。
ifmonitor input-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor input-usage slot slot-number
入方向带宽利用率告警的上限阈值为90,下限阈值为80。
high-threshold high-value:指定入方向带宽利用率告警上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定入方向带宽利用率告警下限阈值,取值范围是1~100,单位为百分比。
当接口处于正常状态,并在最近一个统计周期内入方向带宽利用率达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在最近一个统计周期内入方向带宽利用率低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
关于统计周期的值,分为以下几种情况:
·     不支持flow-interval命令的设备,统计周期固定为5分钟。
·     对于支持flow-interval命令的设备,统计周期可以通过flow-interval命令来配置。
用户可在系统视图和接口视图下配置入方向带宽利用率告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启入方向带宽利用率告警功能后才能生效。
# 配置全局入方向带宽利用率告警上限阈值为95,入方向带宽利用率告警下限阈值为80。
[Sysname] ifmonitor input-usage high-threshold 95 low-threshold 80
·     flow-interval
ifmonitor output-error命令用来全局配置出方向错误报文告警参数。
undo ifmonitor output-error命令用来恢复缺省情况。
ifmonitor output-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor output-error slot slot-number
出方向错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接口出方向错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定接口出方向错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定接口出方向错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口出方向错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因出方向错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的出方向错误报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
开启出方向错误报文告警功能后,当接口处于正常状态,并在指定的时间内出方向错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内出方向错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置出方向错误报文告警参数。
# 配置出方向错误报文告警上限阈值为5000,出方向错误报文告警下限阈值为400,出方向错误报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
ifmonitor output-usage命令用来全局配置出方向带宽利用率的告警参数。
undo ifmonitor output-usage命令用来恢复缺省情况。
ifmonitor output-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor output-usage slot slot-number
出方向的带宽利用率告警的上限阈值为90,下限阈值为80。
high-threshold high-value:指定出方向带宽利用率告警上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定出方向带宽利用率告警下限阈值,取值范围是1~100,单位为百分比。
当接口处于正常状态,并在最近一个统计周期内出方向带宽利用率达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在最近一个统计周期内出方向带宽利用率低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
关于统计周期的值,分为以下几种情况:
用户可在系统视图和接口视图下配置出方向带宽利用率告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启出方向带宽利用率告警功能后才能生效。
# 配置全局出方向带宽利用率告警上限阈值为80,出方向带宽利用率告警下限阈值为60。
[Sysname] ifmonitor output-usage high-threshold 80 low-threshold 60
·     flow-interval
ifmonitor rx-pause命令用来全局配置接收PAUSE帧告警参数。
undo ifmonitor rx-pause命令用来恢复缺省情况。
ifmonitor rx-pause  slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor rx-pause slot slot-number
接收PAUSE帧告警的上限阈值为500,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接收PAUSE帧告警上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定接收PAUSE帧告警下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定接收PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
当接口处于正常状态,并在指定的时间内接收PAUSE帧的个数达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收PAUSE帧的个数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置接收PAUSE帧告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启接收PAUSE帧告警功能后才能生效。
# 配置接收PAUSE帧告警上限阈值为30,接收PAUSE帧告警下限阈值为20,接收PAUSE帧数据收集和比较时间间隔为4秒。
[Sysname] ifmonitor rx-pause high-threshold 30 low-threshold 20 interval 4
ifmonitor tx-pause命令用来全局配置发送PAUSE帧告警参数。
undo ifmonitor tx-pause命令用来恢复缺省情况。
ifmonitor tx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor tx-pause slot slot-number
发送PAUSE帧告警的上限阈值为500,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定发送PAUSE帧告警上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定发送PAUSE帧告警下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定发送PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
当接口处于正常状态,并在指定的时间内发送PAUSE帧的个数达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内发送PAUSE帧的个数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置发送PAUSE帧告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启发送PAUSE帧告警功能后才能生效。
# 配置发送PAUSE帧告警上限阈值为20,发送PAUSE帧告警下限阈值为10,发送PAUSE帧数据收集和比较时间间隔为5秒。
[Sysname] ifmonitor tx-pause high-threshold 20 low-threshold 10 interval 5
1.1.20  interface
interface命令用来进入接口视图或创建子接口并进入子接口视图。如果指定的子接口已经存在,则直接进入子接口视图。
# 进入以太网接口FourHundredGigE1/0/1视图。
# 创建以太网子接口FourHundredGigE1/0/1.1并进入该子接口的视图。
[Sysname] interface fourhundredgige 1/0/1.1
[Sysname-FourHundredGigE1/0/1.1]
jumboframe enable命令用来允许超长帧通过。
undo jumboframe enable命令用来禁止超长帧通过。
undo jumboframe enable size命令用来恢复缺省情况。
jumboframe enable [ size ]
设备允许长度为9216字节的超长帧通过。
二层以太网接口视图
三层以太网接口视图
# 允许超长帧通过以太网接口FourHundredGigE1/0/1。
[Sysname-FourHundredGigE1/0/1] jumboframe enable
1.1.22  link-delay
link-delay命令用来配置以太网接口物理连接状态抑制功能。
undo link-delay命令用来恢复缺省情况。
undo link-delay { down | up }
接口状态改变时,系统会将接口状态改变立即上报CPU。
以太网接口视图
down:设置以太网接口物理连接down状态抑制功能。
up:设置以太网接口物理连接up状态抑制功能。
msec:表示配置的抑制时间为毫秒级。不指定该参数时,表示配置的抑制时间为秒级。
delay-time:接口物理连接状态抑制时间值,0表示不抑制,即接口状态改变时立即上报CPU。
·     未指定msec参数时,取值范围为0~30,单位为秒。
·     指定msec参数时,取值范围为0~10000,且为100的倍数,单位为毫秒。
使用该命令时,选取的参数不同,抑制效果不同:
·     down:表示接口状态从up变成down时,不会立即上报CPU。而是等待delay-time时间后,再检查接口状态,如果状态仍然是down,再上报。
·     up:表示接口状态从down变成up时,不会立即上报CPU。而是等待delay-time时间后,再检查接口状态,如果状态仍然是up,再上报。
同一接口下,接口状态从up变成down的抑制时间和接口状态从down变成up的抑制时间可以不同。在同一接口下,多次执行本命令:
·     可以分别配置抑制上报down状态和抑制上报up状态。
·     当配置的是同一状态的抑制时间时,则最新的配置生效。
对于开启了生成树协议、RRPP或Smart Link的端口不推荐使用该命令。
以太网接口上不能同时配置本命令和port link-flap protect enable命令。
# 设置以太网接口物理连接down状态抑制时间为8秒。
[Sysname-FourHundredGigE1/0/1] link-delay down 8
# 设置以太网接口物理连接up状态抑制时间为800毫秒。
[Sysname-FourHundredGigE1/0/1] link-delay up msec 800
link-flap protect enable命令用来全局开启链路震荡保护功能。
undo link-flap protect enable命令用来全局关闭链路震荡保护功能。
link-flap protect enable [ batch [ interval interval | threshold threshold ] * ]
undo link-flap protect enable [ batch [ interval | threshold ] ]
全局链路震荡功能处于关闭状态。
batch:开启全局和所有接口链路震荡保护功能,并设置缺省的链路震荡检查时间和缺省的链路震荡次数。如果未指定本参数,则表示仅开启全局的链路震荡保护功能。
interval interval:链路震荡检查时间间隔,取值范围5~86400,单位为秒,缺省值为10秒。
threshold threshold:链路震荡次数阈值,取值范围2~1200,缺省值为5次。
链路震荡即接口的物理状态频繁变化时,会导致网络拓扑结构不断变化,给系统带来额外的开销。例如,在主备链路场景中,当主链路的接口物理状态频繁UP/DOWN时,业务将在主备链路之间来回切换,增加了设备的负担。为了解决该问题,设备提供了链路震荡保护功能。
配置本功能后,当接口状态从UP变为DOWN时,系统会启动链路震荡检查。在链路震荡检查时间间隔内,如果该接口状态从UP变为DOWN的次数大于等于链路震荡次数阈值,则关闭该接口。
只有系统视图下和接口视图下同时开启链路震荡保护功能后,接口的链路震荡保护功能才能生效。以下配置情况均可保证链路震荡保护功能生效:
·     系统视图下配置link-flap protect enable batch命令,接口下未配置链路震荡保护功能。
·     系统视图下配置link-flap protect enable batch命令,接口视图下配置port link-flap protect enable命令。
·     系统视图下配置link-flap protect enable命令和接口视图下配置port link-flap protect enable命令。
执行undo link-flap protect enable命令时,根据指定的参数不同,效果不同:
·     如果未指定batch参数,则表示全局关闭链路震荡保护功能。
·     如果指定batch参数,未指定interval或threshold,则表示恢复interval和threshold的缺省值。
·     如果指定interval或threshold,则表示恢复interval或threshold的缺省值。
执行link-flap protect enable batch命令后,如果接口下存在link-delay或dampening命令,则link-delay或dampening命令优先生效。
# 全局开启链路震荡保护功能。
[Sysname] link-flap protect enable
loadbalance ecmp lbn-group enable命令用来开启等价路由方式的LBN功能。
undo loadbalance ecmp lbn-group enable命令用来关闭等价路由方式的LBN功能。
等价路由方式的LBN功能处于关闭状态。
本命令需要在在配置了等价路由功能的组网中使用,通过LBN功能实现流量负载分担。
# 开启等价路由方式的LBN功能。
[Sysname] loadbalance ecmp lbn-group enable
·     loadbalance link-aggregation lbn-group enable
loadbalance link-aggregation lbn-group enable命令用来开启以太网链路聚合方式的LBN功能。
undo loadbalance link-aggregation lbn-group enable命令用来关闭以太网链路聚合方式的LBN功能。
以太网链路聚合方式的LBN功能处于关闭状态。
本命令需要在在配置了以太网链路聚合功能的组网中使用,通过LBN功能实现流量负载分担。
# 开启以太网链路聚合方式的LBN功能。
[Sysname] loadbalance link-aggregation lbn-group enable
·     loadbalance ecmp lbn-group enable
1.1.26  loopback
开启环回功能后,接口将不能正常转发数据包,请按需配置。
loopback命令用来开启以太网接口的环回功能。
undo loopback命令用来关闭以太网接口的环回功能。
loopback internal
undo loopback
以太网接口的环回功能处于关闭状态。
以太网接口视图
internal:开启以太网接口的内部环回功能。
开启环回功能后,接口将自动切换到全双工模式,关闭环回功能后会自动恢复原有双工模式。
shutdown、port up-mode和loopback命令互斥,后配置的失败。
# 开启以太网接口FourHundredGigE1/0/1的内部环回功能。
[Sysname-FourHundredGigE1/0/1] loopback internal
port ifmonitor crc-error命令用来配置CRC错误报文告警参数。
undo port ifmonitor crc-error命令用来恢复缺省情况。
接口采用的CRC错误报文告警参数与全局采用的CRC错误报文告警参数一致。
以太网接口视图
ratio:表示以百分比形式配置告警阈值。不指定该参数时,表示配置的是告警阈值的大小。
high-threshold high-value:指定CRC错误报文告警上限阈值。指定ratio参数时,取值范围为1~100;未指定ratio参数时,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定CRC错误报文告警下限阈值。指定ratio参数时,取值范围为1~100;未指定ratio参数时,取值范围为1~4294967295,单位为报文个数。
# 在接口FourHundredGigE1/0/1上配置CRC错误报文告警上限阈值为5000,CRC错误报文告警下限阈值为400,CRC错误报文数据收集和比较时间间隔为6秒。
[Sysname-FourHundredGigE1/0/1] port ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-error命令用来配置入方向错误报文告警参数。
undo port ifmonitor input-error命令用来恢复缺省情况。
接口采用的入方向错误报文告警参数与全局采用的入方向错误报文告警参数一致。
以太网接口视图
# 在接口FourHundredGigE1/0/1上配置入方向错误报文告警上限阈值为5000,入方向错误报文告警下限阈值为400,入方向错误报文数据收集和比较时间间隔为6秒。
[Sysname-FourHundredGigE1/0/1] port ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-usage命令用来配置入方向带宽利用率的告警参数。
undo port ifmonitor input-usage命令用来恢复缺省情况。
接口采用的入方向带宽利用率告警参数与全局采用的入方向带宽利用率告警参数一致。
high-threshold high-value:指定入方向带宽利用率告警的上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定入方向带宽利用率告警的下限阈值,取值范围是1~100,单位为百分比。
关于统计周期的值,分为以下几种情况:
# 在接口FourHundredGigE1/0/1上配置入方向带宽利用率告警上限阈值为80,入方向带宽利用率告警下限阈值为60。
[Sysname-FourHundredGigE1/0/1] port ifmonitor input-usage high-threshold 80 low-thershold 60
·     flow-interval
port ifmonitor output-error命令用来配置出方向错误报文告警参数。
undo port ifmonitor output-error命令用来恢复缺省情况。
接口采用的出方向错误报文告警参数与全局采用的出方向错误报文告警参数一致。
以太网接口视图
# 在接口FourHundredGigE1/0/1上配置出方向错误报文告警上限阈值为5000,出方向错误报文告警下限阈值为400,出方向错误报文数据收集和比较时间间隔为6秒。
[Sysname-FourHundredGigE1/0/1] port ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor output-usage命令用来配置出方向带宽利用率的告警参数。
undo port ifmonitor output-usage命令用来恢复缺省情况。
接口采用的出方向带宽利用率告警参数与全局采用的出方向带宽利用率告警参数一致。
high-threshold high-value:指定接口出方向带宽利用率告警的上限阈值,取值范围是1~100,单位为百分比。
high-threshold high-value:指定接口出方向带宽利用率告警的下限阈值,取值范围是1~100,单位为百分比。
关于统计周期的值,分为以下几种情况:
# 在接口FourHundredGigE1/0/1上配置入方向带宽利用率告警上限阈值为9,入方向带宽利用率告警下限阈值为7。
[Sysname-FourHundredGigE1/0/1]port ifmonitor output-usage high-threshold 9 low-threshold 7
·     flow-interval
port ifmonitor rx-pause命令用来配置接口接收PAUSE帧告警参数。
undo port ifmonitor rx-pause命令用来恢复缺省情况。
port ifmonitor rx-pause high-threshold high-value low-threshold low-value interval interval
接口采用的接收PAUSE帧告警参数与全局采用的接收PAUSE帧告警参数一致。
以太网接口视图
high-threshold high-value:指定接口接收PAUSE帧告警的上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定接口接收PAUSE帧告警的下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定接口接收PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
# 在接口FourHundredGigE1/0/1上配置接收PAUSE帧告警上限阈值为90,接收PAUSE帧告警下限阈值为50,接收PAUSE帧数据收集和比较时间间隔为5秒。
[Sysname-FourHundredGigE1/0/1] port ifmonitor rx-pause high-threshold 90 low-threshold 50 interval 5
port ifmonitor sdh-b1-error命令用来配置接口SDH-B1错误报文告警参数。
undo port ifmonitor sdh-b1-error命令用来恢复缺省情况。
port ifmonitor sdh-b1-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的SDH-B1错误告警参数与全局采用的SDH-B1错误告警参数一致。
以太网接口视图
high-threshold high-value:指定接口SDH-B1错误报文告警的上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定接口SDH-B1错误报文告警的下限阈值,取值范围是1~4294967295,单位为报文个数。
interval interval:指定接口SDH-B1错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的SDH-B1错误报文达到上限告警阈值时,关闭接口,该接口将停止转发所有报文。因SDH-B1错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的SDH-B1错误报文达到上限告警阈值,不会关闭该接口,同时接口将产生超上限告警,并进入告警状态。
当接口处于正常状态,并在指定的时间内SDH-B1错误报文达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内SDH-B1错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置SDH-B1错误报文告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启SDH-B1错误报文告警功能后才能生效。
# 在接口FourHundredGigE1/0/1上配置SDH-B1错误报文告警上限阈值为20,SDH-B1错误报文告警下限阈值为10,SDH-B1错误报文数据收集和比较时间间隔为10秒。
[Sysname-FourHundredGigE1/0/1] port ifmonitor sdh-b1-error high-threshold 20 low-threshold 10 interval 10
port ifmonitor sdh-b2-error命令用来配置接口SDH-B2错误报文告警参数。
undo port ifmonitor sdh-b2-error命令用来恢复缺省情况。
port ifmonitor sdh-b2-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的SDH-B2错误告警参数与全局采用的SDH-B2错误告警参数一致。
以太网接口视图
high-threshold high-value:指定接口SDH-B2错误报文告警的上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定接口SDH-B2错误报文告警的下限阈值,取值范围是1~4294967295,单位为报文个数。
interval interval:指定接口SDH-B2错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的SDH-B2错误报文达到上限告警阈值时,关闭接口,该接口将停止转发所有报文。因SDH-B2错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的SDH-B2错误报文达到上限告警阈值,不会关闭该接口,同时接口将产生超上限告警,并进入告警状态。
当接口处于正常状态,并在指定的时间内SDH-B2错误报文达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内SDH-b2错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置SDH-B2错误报文告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启SDH-B2错误报文告警功能后才能生效。
# 在接口FourHundredGigE1/0/1上配置SDH-B2错误报文告警上限阈值为10,SDH-B2错误报文告警下限阈值为8,SDH-B2错误报文数据收集和比较时间间隔为3秒。
[Sysname-FourHundredGigE1/0/1] port ifmonitor sdh-b2-error high-threshold 10 low-threshold 8 interval 3
port ifmonitor sdh-error命令用来配置接口下SDH错误报文告警参数。
undo port ifmonitor sdh-error命令用来恢复缺省情况。
port ifmonitor sdh-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的SDH错误报文告警参数与全局采用的SDH错误报文告警参数一致。
以太网接口视图
high-threshold high-value:指定接口SDH错误报文告警的上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定接口SDH错误报文告警的下限阈值,取值范围是1~4294967295,单位为报文个数。
interval interval:指定接口SDH错误报文数据收集和比较时间间隔,取值范围为1~65535,单位为秒。
shutdown:表示当接口接收到的SDH错误报文达到上限告警阈值时,关闭接口,该接口将停止转发所有报文。因SDH错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的SDH错误报文达到上限告警阈值,不会关闭该接口,同时接口将产生超上限告警,并进入告警状态。
当接口处于正常状态,并在指定的时间内SDH错误报文达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内SDH错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置SDH错误报文告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启SDH错误报文告警功能后才能生效。
# 在接口FourHundredGigE1/0/1上配置SDH错误报文告警上限阈值为50,SDH错误报文告警下限阈值为30,SDH错误报文数据收集和比较时间间隔为10秒。
[Sysname-FourHundredGigE1/0/1] port ifmonitor sdh-error high-threshold 50 low-threshold 30 interval 10
port ifmonitor tx-pause命令用来配置接口发送PAUSE帧告警参数。
undo port ifmonitor tx-pause命令用来恢复缺省情况。
port ifmonitor tx-pause high-threshold high-value low-threshold low-value interval interval
接口采用的发送PAUSE帧告警参数与全局采用的发送PAUSE帧告警参数一致。
以太网接口视图
high-threshold high-value:指定接口发送PAUSE帧告警的上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定接口发送PAUSE帧告警的下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定接口发送PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
# 在接口FourHundredGigE1/0/1上配置发送PAUSE帧告警上限阈值为50,发送PAUSE帧告警下限阈值为40,发送PAUSE帧数据收集和比较时间间隔为8秒。
[Sysname-FourHundredGigE1/0/1] port ifmonitor tx-pause high-threshold 50 low-threshold 40 interval 8
port link-flap protect命令用来配置接口链路震荡保护功能。
undo port link-flap protect命令用来恢复缺省情况。
port link-flap protect { disable | enable [ interval interval | threshold threshold ] * }
undo port link-flap protect { disable | enable [ interval | threshold ] }
未配置接口的链路震荡保护功能,以全局配置的链路震荡保护功能为准。
以太网接口视图
disable:关闭接口的链路震荡保护功能。
enable:开启接口的链路震荡保护功能。
·     系统视图下配置link-flap protect enable batch命令,接口视图下配置port link-flap protect enable。
·     系统视图下配置link-flap protect enable命令,接口视图下配置port link-flap protect enable。
执行port link-flap protect enable命令时,如果未指定interval或threshold,表示采用interval或threshold的缺省值。
执行undo port link-flap protect命令时,根据指定的参数不同,效果不同:
·     如果指定disable或enable参数,则表示接口的链路震荡保护功能恢复缺省情况。
接口下配置本命令后,当接口状态从UP变为DOWN时,系统会启动链路震荡检查。在链路震荡检查时间间隔内,如果该接口状态从UP变为DOWN的次数大于等于链路震荡次数阈值,则关闭该接口。
接口因链路频繁震荡被关闭后,不会自动恢复,需要用户执行undo shutdown命令手工恢复。
以太网接口上不能同时配置本命令和link-delay命令。
# 开启接口的链路震荡保护功能,链路震荡检查时间间隔为10秒,链路震荡次数阈值为5次。
[Sysname-FourHundredGigE1/0/1] port link-flap protect enable interval 10 threshold 5
·     link-delay
port link-mode命令用来切换以太网接口的工作模式。
undo port link-mode命令用来恢复缺省情况。
undo port link-mode
设备上的接口均工作在二层模式。
以太网接口视图
bridge:工作在二层模式。
route:工作在三层模式。
接口模式切换后,除了description、duplex、jumboframe enable、speed、shutdown、combo enable、port fec mode、port training命令,该以太网接口下的其它所有命令都将恢复到新模式下的缺省情况。
设备上的接口比较灵活,工作模式可以通过命令行设置。如果将工作模式设置为二层模式(bridge),则作为一个二层以太网接口使用,如果将工作模式设置为三层模式(route),则作为一个三层以太网接口使用。
# 使接口FourHundredGigE1/0/1工作在二层模式。
[Sysname-FourHundredGigE1/0/1] port link-mode bridge
1.1.39  port up-mode
port up-mode命令用来强制开启光口。
undo port up-mode命令用来恢复缺省情况。
port up-mode
undo port up-mode
没有强制开启光口,光口的物理状态由光纤的物理状态决定。
以太网接口视图
强制开启光口后,不管实际的光纤链路是否连通,甚至没有插入光纤或光模块,光口的物理状态都会变为up。此时,只要光口上有一条光纤链路是连通的,就可以实现报文的单向转发,以达到节约传输链路的效果。
port up-mode、shutdown和loopback命令互斥,后配置的失败。
# 强制开启光口FourHundredGigE1/0/1。
[Sysname-FourHundredGigE1/0/1] port up-mode
1.1.40  lbn-group
lbn-group命令用来创建LBN组,并进入LBN组视图。
undo lbn-group命令用来删除LBN组。
lbn-group group-name
undo lbn-group group-name
不存在LBN组。
group-name:LBN组的名称,为1~31个字符串,区分大小写。
属于LBN组里的接口才能负载分担,不属于LBN组不能负载分担。LBN功能是指,通过将设备的不同入接口加入LBN组中,并为这些接口分配索引。设备会根据接口配置的索引值,通过一定的算法,将流量分配到各个接口。从不同入接口进入的流量,会通过不同的出接口转发出去,从而实现流量的负载分担。
本命令用于创建LBN组,在LBN组中可以配置成员接口及索引。
# 创建LBN组test,并进入LBN组视图。
[Sysname] lbn-group test
[Sysname-lbn-group-test]
reset ethernet statistics命令用来清除以太网软件模块收发报文的统计信息。
reset ethernet statistics [ slot slot-number ]
# 清除指定slot上的以太网软件模块收发报文的统计信息。
<Sysname> reset ethernet statistics slot 1
·     display ethernet statistics
reset link-state-change statistics interface命令用来清除接口的状态变化统计信息。
reset link-state-change statistics interface [ interface-type [ interface-number ] ]
未清除接口状态变化统计信息。
接口的状态变化统计值可以通过display link-state-change statistics interface命令查看,使用本命令,可以将接口的状态变化次数统计值清零。
如果不指定interface-type和interface-number,则清除所有接口的统计信息;
如果指定interface-type而不指定interface-number,则清除所有该类型接口的统计信息
# 清除以太网接口FourHundredGigE1/0/1的状态变化统计信息。
<Sysname> reset link-state-change statistics interface fourhundredgige 1/0/1
·     display link-state-change statistics interface
reset packet-drop interface命令用来清除接口丢弃报文的统计信息。
reset packet-drop interface [ interface-type [ interface-number ] ]
如果不指定接口类型和接口编号,则清除所有接口丢弃的报文的信息。
如果仅指定接口类型,则清除所有该类型接口丢弃的报文的信息。
# 清除以太网接口FourHundredGigE1/0/1丢弃报文的统计信息。
<Sysname> reset packet-drop interface fourhundredgige 1/0/1
# 清除所有接口丢弃报文的统计信息。
·     display packet-drop
shutdown all-interfaces命令用来关闭除管理以太网接口、堆叠物理接口以及过滤接口外的所有主接口。
undo shutdown all-interfaces命令用来开启除管理以太网接口、堆叠物理接口以及过滤接口外的所有主接口。
shutdown all-interfaces exclude interface-list
undo shutdown all-interfaces exclude interface-list
缺省情况下,物理接口处于开启状态。
exclude interface-list:指定需要过滤的接口列表。配置该参数后,会对除管理以太网接口、堆叠物理接口以及指定接口外的所有主接口执行shutdown动作,接口状态变为ADM。表示方式为interface-list = { interface-type interface-number1 [ to interface-type interface-number2 ] },不限制interface-list的输入次数。其中interface-type interface-number表示接口类型和接口编号。选中的接口必须位于同一接口卡或子卡上,interface-number2的值要大于等于interface-number1的值,to关键字左边的接口(起始接口)和to关键字右边的接口(结束接口)类型必须相同,否则将配置失败。
执行本命令后,系统会对除管理以太网接口、堆叠物理接口以及过滤接口外的所有接口执行shutdown操作,对于支持子接口的接口,则只关闭主接口,子接口不关闭。在接口视图下执行display this命令,可以看到接口下会自动生成shutdown配置。
接口被本命令关闭后,用户可以在接口视图下执行undo shutdown命令来开启该接口,也可以在系统视图下执行undo shutdown all-interfaces命令来开启被shutdown all-interfaces命令关闭的所有接口。
# 关闭除管理以太网接口、堆叠物理接口以及FourHundredGigE1/0/1到FourHundredGigE1/0/4以外的所有主接口作。
[Sysname] shutdown all-interfaces exclude fourhundredgige 1/0/1 to fourhundredgige 1/0/4
·     shutdown
·     shutdown all-physical-interfaces
shutdown all-physical-interfaces命令用来关闭全部物理接口。
undo shutdown all-physical-interfaces命令用来开启全部物理接口。
缺省情况下,物理接口处于开启状态。
通过配置shutdown all-physical-interfaces命令,可以关闭和开启设备上除管理以太网接口外的所有物理接口,所有物理接口状态变为ADM。
在系统视图下执行shutdown all-physical-interfaces命令或在接口视图下执行shutdown命令,接口均会被关闭。
在系统视图下执行undo shutdown all-physical-interfaces命令和在接口视图下执行undo shutdown命令后,接口才会被开启。
# 关闭全部物理接口。
[Sysname] shutdown all-physical-interfaces
·     shutdown(接口管理命令参考/接口公共命令)
snmp-agent trap enable ifmonitor命令用来开启接口告警功能。
undo snmp-agent trap enable ifmonitor命令用来关闭接口告警功能。
snmp-agent trap enable ifmonitor [ crc-error | giant | input-error | input-usage | output-error | output-usage | rant | rx-pause | tx-pause ] *
undo snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | tx-pause ] *
接口告警功能处于开启状态。
crc-error:开启接口CRC错误报文告警功能。
input-error:开启接口入方向错误报文告警功能。
input-usage:开启接口入方向带宽利用率告警功能。
output-error:开启接口出方向错误报文告警功能。
output-usage:开启接口出方向带宽利用率告警功能。
rx-pause:开启接口接收PAUSE帧告警功能。
tx-pause:开启接口发送PAUSE帧告警功能。
# 开启接口CRC错误报文告警功能。
[Sysname] snmp-agent trap enable ifmonitor crc-error
1.1.47  speed
speed命令用来设置以太网接口的速率。
undo speed命令用来恢复缺省情况。
speed { 200000 | 400000 | auto }
undo speed
以太网接口的速率为auto(自协商)状态。
以太网接口视图
200000:表示接口速率为200000Mbps。
400000:表示接口速率为400000Mbps。
auto:表示接口速率处于自协商状态。
对于以太网电口来说,使用speed命令设置端口速率,目的是使其与对端进行速率匹配。不同类型的电口支持配置的参数不同,具体情况请在相关接口视图下执行speed ?命令查看。如果配置指定速率时设备未提示操作失败,则表示当前电口支持该速率。否则,当前电口不支持该速率。
对于光口来说,使用speed命令设置端口速率,目的是使其与可插拔光模块进行速率匹配。不同类型的光口支持配置的参数不同,具体情况请在相关接口视图下执行speed ?命令查看。如果配置指定速率时设备未提示操作失败,则表示当前光口支持该速率。否则,当前光口不支持该速率。同时需要根据所选用光模块类型,在光口下配置匹配的速率,以便正常使用光模块。如果光口所配置的速率光模块无法支持,则光模块无法使用。
# 将以太网接口FourHundredGigE1/0/1的速率设置为自协商获得。
[Sysname-FourHundredGigE1/0/1] speed auto
·     speed auto
sub-interface rate-statistic命令用来开启以太网接口/子接口的速率统计功能。
undo sub-interface rate-statistic命令用来关闭接口/子接口的速率统计功能。
以太网接口/子接口的速率统计功能处于关闭状态。
以太网接口视图
开启本功能后可能需要耗费大量系统资源,请谨慎使用。
# 开启FourHundredGigE1/0/1接口的子接口速率统计功能。
[Sysname-FourHundredGigE1/0/1] sub-interface rate-statistic
This configuration may make a negative effect on the performance. Are you sure to continue? [Y/N]:y
traffic-statistic include-interframe命令用来配置接口流量统计时对帧间隙和前导码进行统计。
undo traffic-statistic include-interframe命令用来恢复缺省情况。
本命令的缺省情况与设备的型号有关,请以设备的实际情况为准。
以太网接口视图
用户可执行命令display interface查看以太网接口当前运行状态和接口统计信息。显示信息中的Last 300 seconds input rate或Last 300 seconds output rate字段表示接口在最近300秒内接收和发送报文的平均速率。
缺省情况下,接口流量统计速率=原始报文长度×每秒通过的报文个数。如果用户希望了解接口单位时间内通过的总字节数,即包含报文字节数以及帧间隙和前导码时,可以配置本命令,将包括帧间隙和前导码的流量统计。此时,接口流量统计速率=(原始报文长度+帧间隙+前导码)× 每秒通过的报文个数。
帧间隙和前导码长度一般为固定值。当用户需要调整帧间隙长度时,可执行命令itf number配置帧间隙长度。调整帧间隙后,当前统计周期的流量统计信息会不准确,在下一周期流量统计信息恢复正常。
# 配置对以太网接口FourHundredGigE1/0/1进行流量统计时对帧间隙和前导码进行统计。
[Sysname-FourHundredGigE1/0/1] traffic-statistic include-interframe
Traffic statistic will be set to include Inter-frame Gaps and Preambles. Continue? [Y/N]:y
·     display interface
·     itf number
using eighthundredgige命令用来将从800GE接口拆分出来的接口合并为一个800GE接口。
undo using eighthundredgige命令用来取消对拆分接口的合并。
仅S9827-64EP交换机支持800GE接口和400GE接口的拆分与合并。
拆分接口单独使用,不会合并。
400GE拆分接口视图
如果用户需要更大的带宽,可以进行如下操作:
将从800GE接口拆分出来的两个400GE接口合并为一个800GE接口使用。在任何一个400GE拆分接口下执行该命令均生效,无需在其它拆分接口上配置。
配置本功能后,不需要重启设备,通过执行display interface brief命令就可以看到拆分后的400GE接口。
# 将FourHundredGigE1/0/1:1~FourHundredGigE1/0/1:2接口合并。
[Sysname] interface fourthundredgige 1/0/1:1
[Sysname-FourHundredGigE1/0/1:1] using eighthundredgige
The interfaces HundredGigE1/0/1:1 will be deleted. Continue? [Y/N]:y
·     using fourhundredgige
using fourhundredgige命令用来将从400GE接口拆分出来的200GE接口合并为一个400GE接口,或者将一个800GE接口拆分成多个400GE接口;或者将由400GE接口切换成的100GE接口恢复成400GE接口。
undo using fourhundredgige命令用来取消对拆分接口的合并,或者取消对800GE接口的拆分。
·     仅S9827-64EP交换机支持800GE接口和400GE接口的拆分与合并。
·     仅S9827-128DH交换机支持400GE接口和100GE接口的切换。
·     仅S9827-128DH交换机支持400GE接口和200GE接口的拆分与合并。
200GE拆分接口单独使用,不会合并;800GE接口作为单个接口使用,未拆分;切换成的100GE接口未切换回400GE接口。
100GE切换接口视图
200GE拆分接口视图
800GE接口视图
为了提高端口密度,减少用户使用成本,增加组网灵活性,设备支持将一个800GE接口拆分成多个400GE接口使用。例如,可以将800GE接口EightHundredGigE1/0/1拆分成两个400GE接口FourHundredGigE1/0/1:1~FourHundredGigE1/0/1:2。拆分出来的400GE接口除了接口编号方式外,支持的配置和特性均和普通400GE物理接口相同。拆分出来的400GE接口不支持再次拆分。如果用户需要更大的带宽,可以进行如下操作:
将从400GE接口拆分出来的2个200GE接口合并为一个400GE使用。在任何一个200GE拆分接口下执行该命令均生效,无需在其它拆分接口上配置。
命令配置成功后,不需要重启设备,通过执行display interface brief命令就可以看到拆分、合并或切换后的接口。
对于S9827-128DH交换机,同一接口组内任一400GE接口切换成100GE接口,则该组内的其他400GE接口也会切换成100GE接口;同时,将100GE切换接口恢复成400GE接口时,该组内的其他100GE切换接口也会恢复成400GE接口。S9827-128DH交换机接口组的接口情况如下表所示。
表1-8 S9827交换接口组的接口情况描述表
接口组编号
接口
1
FourHundredGigE1/0/1、FourHundredGigE1/0/9
2
FourHundredGigE1/0/2、FourHundredGigE1/0/10
3
FourHundredGigE1/0/3、FourHundredGigE1/0/4
4
FourHundredGigE1/0/5、FourHundredGigE1/0/6
5
FourHundredGigE1/0/7、FourHundredGigE1/0/15
6
FourHundredGigE1/0/8、FourHundredGigE1/0/16
7
FourHundredGigE1/0/11、FourHundredGigE1/0/12
8
FourHundredGigE1/0/13、FourHundredGigE1/0/14
9
FourHundredGigE1/0/17、FourHundredGigE1/0/25
10
FourHundredGigE1/0/18、FourHundredGigE1/0/26
11
FourHundredGigE1/0/19、FourHundredGigE1/0/21
12
FourHundredGigE1/0/20、FourHundredGigE1/0/22
13
FourHundredGigE1/0/23、FourHundredGigE1/0/31
14
FourHundredGigE1/0/24、FourHundredGigE1/0/32
15
FourHundredGigE1/0/27、FourHundredGigE1/0/29
16
FourHundredGigE1/0/28、FourHundredGigE1/0/30
17
FourHundredGigE1/0/33、FourHundredGigE1/0/41
18
FourHundredGigE1/0/34、FourHundredGigE1/0/42
19
FourHundredGigE1/0/35、FourHundredGigE1/0/37
20
FourHundredGigE1/0/36、FourHundredGigE1/0/38
21
FourHundredGigE1/0/39、FourHundredGigE1/0/47
22
FourHundredGigE1/0/40、FourHundredGigE1/0/48
23
FourHundredGigE1/0/43、FourHundredGigE1/0/45
24
FourHundredGigE1/0/44、FourHundredGigE1/0/46
25
FourHundredGigE1/0/49、FourHundredGigE1/0/57
26
FourHundredGigE1/0/50、FourHundredGigE1/0/58
27
FourHundredGigE1/0/51、FourHundredGigE1/0/52
28
FourHundredGigE1/0/53、FourHundredGigE1/0/54
29
FourHundredGigE1/0/55、FourHundredGigE1/0/63
30
FourHundredGigE1/0/56、FourHundredGigE1/0/64
31
FourHundredGigE1/0/59、FourHundredGigE1/0/60
32
FourHundredGigE1/0/61、FourHundredGigE1/0/62
33
FourHundredGigE1/0/65、FourHundredGigE1/0/73
34
FourHundredGigE1/0/66、FourHundredGigE1/0/74
35
FourHundredGigE1/0/67、FourHundredGigE1/0/68
36
FourHundredGigE1/0/69、FourHundredGigE1/0/70
37
FourHundredGigE1/0/71、FourHundredGigE1/0/79
38
FourHundredGigE1/0/72、FourHundredGigE1/0/80
39
FourHundredGigE1/0/75、FourHundredGigE1/0/76
40
FourHundredGigE1/0/77、FourHundredGigE1/0/78
41
FourHundredGigE1/0/81、FourHundredGigE1/0/89
42
FourHundredGigE1/0/82、FourHundredGigE1/0/90
43
FourHundredGigE1/0/83、FourHundredGigE1/0/85
44
FourHundredGigE1/0/84、FourHundredGigE1/0/86
45
FourHundredGigE1/0/87、FourHundredGigE1/0/95
46
FourHundredGigE1/0/88、FourHundredGigE1/0/96
47
FourHundredGigE1/0/91、FourHundredGigE1/0/93
48
FourHundredGigE1/0/92、FourHundredGigE1/0/94
49
FourHundredGigE1/0/97、FourHundredGigE1/0/105
50
FourHundredGigE1/0/98、FourHundredGigE1/0/106
51
FourHundredGigE1/0/99、FourHundredGigE1/0/101
52
FourHundredGigE1/0/100、FourHundredGigE1/0/102
53
FourHundredGigE1/0/103、FourHundredGigE1/0/111
54
FourHundredGigE1/0/104、FourHundredGigE1/0/112
55
FourHundredGigE1/0/107、FourHundredGigE1/0/109
56
FourHundredGigE1/0/108、FourHundredGigE1/0/110
57
FourHundredGigE1/0/113、FourHundredGigE1/0/121
58
FourHundredGigE1/0/114、FourHundredGigE1/0/122
59
FourHundredGigE1/0/115、FourHundredGigE1/0/116
60
FourHundredGigE1/0/117、FourHundredGigE1/0/118
61
FourHundredGigE1/0/119、FourHundredGigE1/0/127
62
FourHundredGigE1/0/120、FourHundredGigE1/0/128
63
FourHundredGigE1/0/123、FourHundredGigE1/0/124
64
FourHundredGigE1/0/125、FourHundredGigE1/0/126
# 将TwoHundredGigE1/0/1:1和TwoHundredGigE1/0/1:2接口合并。
[Sysname] interface twohundredgige 1/0/1:1
[Sysname-TwoHundredGigE1/0/1:1] using fourhundredgige
The interfaces TwoHundredGigE1/0/1:1 and TwoHundredGigE1/0/1:2 will be deleted. Continue? [Y/N]:y
# 将EightHundredGigE1/0/1接口拆分成两个400GE接口。
[Sysname] interface eighthundredgige 1/0/1
[Sysname-EightHundredGigE1/0/1] using fourhundredgige
The interface EightHundredGigE1/0/1 will be deleted. Continue? [Y/N]:y
# 将切换成的HundredGigE1/0/1切换回400GE接口。
[Sysname-HundredGigE1/0/1] using fourhundredgige
The interface HundredGigE1/0/1 and HundredGigE1/0/9 will be deleted. Continue? [Y/N]:y
·     using twohundredgige
·     using eighthundredgige
·     using hundredgige mode 1-channel
using hundredgige mode 1-channel命令用来将400GE接口切换成100GE的接口。
400GE接口未切换成100GE接口。
400GE接口视图
命令配置成功后,不需要重启设备,通过执行display interface brief命令就可以看到切换后的接口。
表1-9 S9827交换接口组的接口情况描述表
接口组编号
接口
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
# 将FourHundredGigE1/0/1接口切换成100GE接口。
<System> system-view
[System] interface fourhundredgige 1/0/1
[System-FourHundredGigE1/0/1] using hundredgige mode 1-channel
The interface FourHundredGigE1/0/1 and FourHundredGigE1/0/9 will be deleted. Continue? [Y/N]:y
using twohundredgige命令用来将一个400GE接口拆分成两个200GE接口。
undo using twohundredgige命令用来取消对拆分接口的合并;取消对400GE接口的拆分。
400GE接口单独使用,不拆分。
400GE接口视图
为了提高端口密度,减少用户使用成本,增加组网灵活性,设备支持将一个400GE的接口拆分成两个200GE接口使用。例如,400GE接口FourHundredGigE1/0/1可以拆分成两个200GE接口TwoHundredGigE1/0/1:1和TwoHundredGigE1/0/1:2。
拆分出来的200GE接口,接口编号方式和普通200GE物理接口不同,并且不支持通过speed命令修改端口速率。
命令配置成功后,不需要重启设备,通过执行display interface brief命令就可以看到拆分后的200GE接口。
# 将FourHundredGigE1/0/1接口拆分成两个200GE接口。
[System-FourHundredGigE1/0/1] using twohundredgige
The interface FourHundredGigE1/0/1 will be deleted. Continue? [Y/N]:y
1.2  二层以太网接口的配置命令
display storm-constrain命令用来显示接口流量控制信息。
display storm-constrain [ broadcast | known-unicast | multicast | unicast ] [ interface interface-type interface-number ]
broadcast:只显示广播报文流量控制信息。
known-unicast:只显示已知单播报文流量控制信息。
multicast:只显示组播报文流量控制信息。
unicast:只显示未知单播报文流量控制信息。
interface interface-type interface-number:显示指定接口的报文流量控制信息。interface-type interface-number指定接口类型和接口编号。不指定该参数时,显示所有接口报文的流量控制信息。
不指定broadcast、known-unicast、multicast和unicast参数时,则显示所有类型报文的流量控制信息。
# 显示系统当前所有接口的流量控制信息。
<Sysname> display storm-constrain
 Abbreviation: BC - broadcast; MC - multicast; UC - unknown unicast;
               KNUC - known unicast; FW - forwarding
 Flow Statistic Interval: 5 (in seconds)
Port          Type Lower     Upper     Unit  CtrlMode  Status   Trap Log SwitchNum
GE1/0/1       MC   100       200       kbps  shutdown  shutdown off  on  10
表1-10 display storm-constrain命令显示信息描述表
流量统计的时间间隔,单位为秒
Port
接口名称缩写
进行流量阈值控制的报文类型:
·     BC:broadcast,表示广播报文
·     MC:multicast,表示组播报文
·     UC:unknown unicast,表示未知单播报文
·     KUNC:known unicast,表示已知单播报文
Lower
用户配置的流量控制下限阈值或百分比
Upper
用户配置的流量控制上限阈值或百分比
Unit
用户配置的流量阈值的单位,为pps、kbps或百分比
CtrlMode
用户配置的流量阈值超过上限的控制动作:
·     block表示阻塞方式
·     shutdown表示关闭方式
·     N/A表示未配置控制动作
Status
接口报文转发状态,取值为:
·     FW表示该端口处于正常转发状态
·     shutdown表示端口已被关闭
·     block表示该端口对该类报文直接丢弃
Trap
Trap信息输出开关:
·     on表示打开
·     off表示关闭
Log
Log信息输出开关:
·     on表示打开
·     off表示关闭
SwitchNum
接口报文转发状态切换次数
当SwitchNum达到65535次时,会自动跳转到0,重新计数
storm-constrain命令用来开启端口流量阈值控制功能,并设置上限阈值与下限阈值。
undo storm-constrain命令用来关闭端口流量阈值控制功能。
storm-constrain { broadcast | known-unicast | multicast | unicast } { pps | kbps | ratio } upperlimit lowerlimit
undo storm-constrain { all | broadcast | known-unicast | multicast | unicast }
端口流量阈值控制功能处于关闭状态,即不对端口的报文流量进行抑制。
二层以太网接口视图
all:取消端口所有类型(未知单播、已知单播、组播和广播)报文流量阈值配置。
broadcast:设置端口广播报文流量阈值。
known-unicast:设置端口已知单播报文流量阈值。
multicast:设置端口组播报文流量阈值。
unicast:设置端口未知单播报文流量阈值。
pps:以包每秒为单位统计流量。
kbps:以千比特每秒为单位统计流量。
ratio:以每秒钟报文所占接口物理带宽的百分比来统计流量。
upperlimit:端口报文流量的上限阈值。当和pps一起使用时,该参数的取值范围为0~1.4881×接口带宽;当和kbps一起使用时,该参数的取值范围为0~接口带宽;当和ratio一起使用时,该参数的取值范围为为0~100。
lowerlimit:端口报文流量的下限阈值。当和pps一起使用时,该参数的取值范围为0~1.4881×接口带宽;当和kbps一起使用时,该参数的取值范围为0~接口带宽;当和ratio一起使用时,该参数的取值范围为为0~100。
执行本命令后,设备就会周期性地对接口收到的指定类型的报文进行统计,如果流量超过上限阈值,则采取一定的措施。其中,通过storm-constrain interval命令可以配置统计周期,通过storm-constrain control命令可以配置流量超过上限阈值时采取的控制方式。
配置时,upperlimit值必须大于lowerlimit值,建议不要配成相等值。
# 对FourHundredGigE1/0/1端口配置未知单播流量阈值,上限阈值为200pps、下限阈值为150pps。
[Sysname-FourHundredGigE1/0/1] storm-constrain unicast pps 200 150
# 对FourHundredGigE1/0/2端口配置广播流量阈值,上限阈值为2000kbps、下限阈值为1500kbps。
[Sysname] interface fourhundredgige 1/0/2
[Sysname-FourHundredGigE1/0/2] storm-constrain broadcast kbps 2000 1500
# 对FourHundredGigE1/0/3端口配置组播流量百分比阈值,上限为80%、下限为15%。
[Sysname] interface fourhundredgige 1/0/3
[Sysname-FourHundredGigE1/0/3] storm-constrain multicast ratio 80 15
·     storm-constrain control
·     storm-constrain interval
storm-constrain control命令用来设置端口未知单播、组播或者广播流量超过上限阈值时采取的控制方式。
undo storm-constrain control命令用来恢复缺省情况。
不对端口流量进行控制。
二层以太网接口视图
block:block方式,即:当端口上未知单播、已知单播、组播或广播报文中某类报文的流量大于其上限阈值时,端口将暂停转发该类报文(其它类型报文照常转发),端口处于阻塞状态,但仍会统计该类报文的流量。当该类报文的流量小于其下限阈值时,端口将自动恢复对此类报文的转发。
shutdown:shutdown方式,即:当端口上未知单播、已知单播、组播或广播报文中某类报文的流量大于其上限阈值时,端口将被关闭,系统停止转发所有报文。当该类报文的流量小于其下限阈值时,端口状态不会自动恢复,此时可通过执行undo shutdown命令或取消端口上流量阈值的配置来恢复。
# 配置FourHundredGigE1/0/1端口,当流量超过上限阈值时,采用block方式控制。
[Sysname-FourHundredGigE1/0/1] storm-constrain control block
·     storm-constrain
storm-constrain enable log命令用来配置端口流量大于上限阈值或者从超上限回落到小于下限阈值时输出Log信息。
undo storm-constrain enable log命令用来禁止端口流量大于上限阈值或者从超上限回落到小于下限阈值时输出Log信息。
二层以太网接口视图
# 当FourHundredGigE1/0/1端口流量大于上限阈值或者从超上限回落到小于下限阈值时输出Log信息。
[Sysname-FourHundredGigE1/0/1] storm-constrain enable log
storm-constrain enable trap命令用来配置端口流量大于上限阈值或者从超上限回落到小于下限阈值时输出Trap信息。
undo storm-constrain enable trap命令用来禁止端口流量大于上限阈值或者从超上限回落到小于下限阈值时输出Trap信息。
二层以太网接口视图
# 当FourHundredGigE1/0/1端口流量大于上限阈值或者从超上限回落到小于下限阈值时输出Trap信息。
[Sysname-FourHundredGigE1/0/1] storm-constrain enable trap
storm-constrain interval命令用来配置端口流量阈值控制模块流量统计的时间间隔。
undo storm-constrain interval命令用来恢复缺省情况。
storm-constrain interval interval
端口流量统计的时间间隔为10秒。
interval:端口流量统计的时间间隔,取值范围为1~300,单位为秒。为了保持网络状态的稳定,建议设置的时间间隔不低于10秒。
本命令设置的时间间隔专门为storm-constrain命令服务的,不同于flow-interval命令设置的时间间隔。虽然同样是统计端口流量,但是功能是分开的。
# 配置端口流量统计时间间隔为60秒。
[Sysname] storm-constrain interval 60
·     storm-constrain
1.3.1  mac-address
mac-address命令用来配置以太网接口的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
缺省情况下,未配置接口的MAC地址;三层以太网子接口的缺省MAC与主接口MAC相同。
三层以太网接口视图
三层以太网子接口视图
mac-address:MAC地址,形式为H-H-H。
给子接口配置MAC地址时,请不要使用VRRP协议保留的MAC地址段。
配置MAC地址时,需满足以下条件:
·     MAC地址高36位取值必须和MAC基地址相同。
·     MAC地址必须大于等于MAC基地址的值加上160。
有关MAC基地址的详细介绍,请参见“二层技术-以太网交换配置指导”中的“MAC地址表”。
# 配置三层以太网接口FourHundredGigE1/0/1的MAC地址为0001-0001-0001。
[Sysname-FourHundredGigE1/0/1] mac-address 1-1-1
1.3.2  mtu
mtu命令用来设置三层以太网接口/子接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
三层以太网接口/子接口的MTU值为1500字节。
三层以太网接口视图
三层以太网子接口视图
由于QoS队列长度的限制(如FIFO队列的缺省长度为75),MTU太小会造成分片太多,从而被QoS队列丢弃。此时,可适当增大MTU值或QoS队列的长度。以太网接口视图下的命令qos fifo queue-length可以改变QoS队列长度(具体配置请参见“ACL和QoS配置指导”中的“QoS”)。
# 设置三层以太网接口FourHundredGigE1/0/1的最大传输单元为1430字节。
[Sysname-FourHundredGigE1/0/1] mtu 1430
# 设置三层以太网子接口FourHundredGigE1/0/1.1的最大传输单元为1430字节。
[Sysname-FourHundredGigE1/0/1.1] mtu 1430
